[U-Boot-Users] [PATCH] Make sure common.h is the first include.
If common.h isn't first we can get CONFIG_ options defined in the board config file ignored. This can cause an issue if any of those config options impact the size of types of data structures (eg CONFIG_PHYS_64BIT).
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
Should be looked at for v1.3.3
- k
common/dlmalloc.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/common/dlmalloc.c b/common/dlmalloc.c index 20c2069..c51351e 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -1,3 +1,5 @@ +#include <common.h> + #if 0 /* Moved to malloc.h */ /* ---------- To make a malloc.h, start cutting here ------------ */
@@ -947,7 +949,6 @@ void malloc_stats(); #endif /* 0 */
#endif /* 0 */ /* Moved to malloc.h */ -#include <common.h>
DECLARE_GLOBAL_DATA_PTR;
In message Pine.LNX.4.64.0805131901170.29341@blarg.am.freescale.net you wrote:
- k
Applied, thanks.
Kumar Gala
