Re: [U-Boot] [PATCH] Add CONFIG_GMAC_TX_DELAY=4 for OlinuXino Lime2
On 21-03-16 18:30, Karsten Merker wrote:
On Mon, Mar 21, 2016 at 04:47:15PM +0100, Karsten Merker wrote:
On Sun, Mar 20, 2016 at 07:51:20PM +0100, Hans de Goede wrote:
On 20-03-16 16:28, Michael Haas wrote:
On 03/20/2016 02:45 PM, Hans de Goede wrote:
On 19-03-16 14:40, Michael Haas wrote:
0xA was set to 7800 for working runs and 3800 for broken runs. The difference is bit 14 in the GBSR: 'MASTER/SLAVE Configuration Resolution'. In the broken runs, the autonegotation configured the OlinuXino to 'slave'. I have whipped up a quick patch which disable the master/slave part of the autonegotiation and force master mode.
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 51b5746..484b2be 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -170,6 +170,7 @@ int genphy_restart_aneg(struct phy_device *phydev) int genphy_config_aneg(struct phy_device *phydev) { int result;
phy_write(phydev, MDIO_DEVAD_NONE, 0x09, 0x1A00); if (AUTONEG_ENABLE != phydev->autoneg) return genphy_setup_forced(phydev);
I was going to add that in realtek.c, not in phy.c - as soon as I figure out which section there is applicable.
Unfortunately the issue is now split over two threads - this one and the "Which entry in drivers/net/phy/realtek.c matches my device?" thread.
It looks like we have three related but separate issues here:
a) The sunxi config doesn't actually build the phy drivers:
include/configs/sunxi-common.h contains: 302 /* Ethernet support */ 303 #ifdef CONFIG_SUNXI_EMAC 304 #define CONFIG_PHY_ADDR 1 305 #define CONFIG_MII /* MII PHY management */ 306 #define CONFIG_PHYLIB 307 #endif 308 309 #ifdef CONFIG_SUNXI_GMAC 310 #define CONFIG_PHY_GIGE /* GMAC can use gigabit PHY */ 311 #define CONFIG_PHY_ADDR 1 312 #define CONFIG_MII /* MII PHY management */ 313 #endif For the sunxi EMAC case (which is AFAIK only used on A10/A13) CONFIG_PHYLIB is enabled, but for the CONFIG_SUNXI_GMAC case (all other sunxi-based systems) we don't enable any PHY driver.
We do enable phylib for gmac based systems, we have CONFIG_ETH_DESIGNWARE=y in defconfigs using GMAC and drivers/net/Kconfig has:
config ETH_DESIGNWARE bool "Synopsys Designware Ethernet MAC" select PHYLIB
We do however only enable the generic (vendor neutral phy) phylib support and not any vendor specific drivers, I've a commit in my tree enabling realtek phy support.
https://github.com/jwrdegoede/u-boot-sunxi/commit/8121866aa55b010d31fe75c1eb...
So it looks like a) is already covered :)
So we either need to enable CONFIG_PHYLIB for CONFIG_SUNXI_GMAC as well or enable the relevant PHY drivers (do we actually have anything besides realtek on sunxi-based systems?) separately, i.e. something like
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b26363d..ea15e37 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -310,6 +310,7 @@ extern int soft_i2c_gpio_scl; #define CONFIG_PHY_GIGE /* GMAC can use gigabit PHY */ #define CONFIG_PHY_ADDR 1 #define CONFIG_MII /* MII PHY management */ +#define CONFIG_PHY_REALTEK #endif
#ifdef CONFIG_USB_EHCI_HCD
b) The realtek PHY driver (drivers/net/phy/realtek.c) doesn't match on the RTL8211CL PHY ID, so even if it is compiled in, it still doesn't work. For more details on this issue, see the "Which entry in drivers/net/phy/realtek.c matches my device?" thread.
c) The master/slave mode problem that can be worked around by forcing master mode on the RTL8211CL.
Regards,
Hans
Hans de Goede
