[U-Boot] [PATCH] arm: imx: make bmode command work with SPL/U-Boot combo
The bmode command forces the SoC to use a specific boot device by writing its boot mode into SRC_GPR9, and notifying the SoC of the change using SRC_GPR10[28] bit: if the bit is on, bootROM uses the value in SRC_GPR9 instead of SRC_SMBR1 to determine the boot device.
SPL on the other hand is oblivious to this distinction, so once the bootROM loads SPL from the device configured in SRC_GPR10, SPL will attempt to load U-Boot from the device configured in SRC_SMBR1, which is not updated by the bootROM to the value in SRC_GPR9.
The result is that the selected boot device is not used across all the boot stages.
Update spl_boot_device() to look at gpr9 when necessary.
Signed-off-by: Nikita Kiryanov nikita@compulab.co.il Cc: Stefano Babic sbabic@denx.de Cc: Troy Kisky troy.kisky@boundarydevices.com Cc: Tim Harvey tharvey@gateworks.com Cc: Eric Nelson eric.nelson@boundarydevices.com Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Heiko Schocher hs@denx.de --- arch/arm/cpu/armv7/mx6/soc.c | 4 ++-- arch/arm/imx-common/spl.c | 5 +++-- 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index dd5aaa2..07ae79e 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -333,8 +333,8 @@ void boot_mode_apply(unsigned cfg_val) /* * cfg_val will be used for * Boot_cfg4[7:0]:Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] - * After reset, if GPR10[28] is 1, ROM will copy GPR9[25:0] - * to SBMR1, which will determine the boot device. + * After reset, if GPR10[28] is 1, ROM will use GPR9[25:0] + * instead of SBMR1 to determine the boot device. */ const struct boot_mode soc_boot_modes[] = { {"normal", MAKE_CFGVAL(0x00, 0x00, 0x00, 0x00)}, diff --git a/arch/arm/imx-common/spl.c b/arch/arm/imx-common/spl.c index 9d3c31a..477c38c 100644 --- a/arch/arm/imx-common/spl.c +++ b/arch/arm/imx-common/spl.c @@ -14,11 +14,12 @@ #include <spl.h>
#if defined(CONFIG_MX6) -/* determine boot device from SRC_SBMR1 register (BOOT_CFG[4:1]) */ +/* determine boot device from SRC_SBMR1 (BOOT_CFG[4:1]) or SRC_GPR9 register */ u32 spl_boot_device(void) { struct src *psrc = (struct src *)SRC_BASE_ADDR; - unsigned reg = readl(&psrc->sbmr1); + unsigned int gpr10_boot = readl(&psrc->gpr10) & (1 << 28); + unsigned reg = gpr10_boot ? readl(&psrc->gpr9) : readl(&psrc->sbmr1);
/* BOOT_CFG1[7:4] - see IMX6DQRM Table 8-8 */ switch ((reg & 0x000000FF) >> 4) {
Gentle ping.
- cfg_val will be used for
- Boot_cfg4[7:0]:Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0]
- After reset, if GPR10[28] is 1, ROM will copy GPR9[25:0]
- to SBMR1, which will determine the boot device.
- After reset, if GPR10[28] is 1, ROM will use GPR9[25:0]
- instead of SBMR1 to determine the boot device.
Hi Nikita,
Best regards, Stefano Babic
Nikita Kiryanov
Stefano Babic
