ChangeLog:
* Patch by Robert Schwebel, 14 May 2004: use config.h (which is needed in serial.c for CFG_HZ)
Robert
In message 20040515150855.GO27774@pengutronix.de you wrote:
- Patch by Robert Schwebel, 14 May 2004: use config.h (which is needed in serial.c for CFG_HZ)
What makes you think this is needed? The code compiles fine as is...
#include <common.h> +#include <config.h> #include <clps7111.h>
And actually this _IS_ redundand, since "include/common.h" already includes <config.h>.
Which problem are you tring to fix? I can't see any...
Rejected.
It's normally good coding practise to include the files which have the stuff you actually need, instead of relying on other include files including other includefiles and wondering why things break if somebody changes something in the other file. But the decision is surely up to you.
Robert
Actually config.h is needed more or less everywhere so I think it makes more sense to have it included once (in common.h) instead of adding it in more than 500 other files.
Nothing is broken, so I see no need to fix anything.
Robert Schwebel
Robert Schwebel
