Re: [DNX#2006040142001007] [U-Boot-Users] [PATCH] wrsbc8560 support
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142001007] was created:
<snip>
This patch add the Wind River wrsbc8560 support back into u-boot. At one time it worked until some code conflicting code was removed to support the Motorolla 85xx evaluation platforms.
The PHY code for the wrsbc8560 has been added in again.
Signed-off-by: Jason Wessel jason.wessel@windriver.com
-------------BEGIN PATCH-------------------------- Separate Motorolla sbc8540 and sbc8560 from wrsbc8560
commit fe3c13d77c1d36fddcf751d8c4b183bc2373b9da tree 9aab5c704d53170090d7152d56daa739d06cbfc3 parent 77f6580cc078fea22c2b1348f5b177edcd63885f author <jwessel@jwessel3-lx.(none)> Sat, 01 Oct 2005 11:10:05 -0500 committer <jwessel@jwessel3-lx.(none)> Sat, 01 Oct 2005 11:10:05 -0500
CHANGELOG | 3 Makefile | 13 + doc/README.wrsbc8560 | 57 ++++++ drivers/tsec.c | 32 +++ include/configs/wrsbc8560.h | 410 +++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 515 insertions(+), 0 deletions(-)
diff --git a/CHANGELOG b/CHANGELOG --- a/CHANGELOG +++ b/CHANGELOG @@ -2,6 +2,9 @@ Changes for U-Boot 1.1.4: ======================================================================
+* Fix Wind River wrsb8560 support
- Patch by Jason Wessel, 01 Sep 2005
- Fix problems with ld version 2.16 (dot outside sections problem) Pointed out by Gerhard Jaeger, 31 Aug 2005; cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
diff --git a/Makefile b/Makefile --- a/Makefile +++ b/Makefile @@ -1301,6 +1301,19 @@ sbc8560_66_config: unconfig fi @./mkconfig -a sbc8560 ppc mpc85xx sbc8560
+wrsbc8560_config \ +wrsbc8560_33_config \ +wrsbc8560_66_config: unconfig
- @if [ "$(findstring _66_,$@)" ] ; then \
echo "#define CONFIG_PCI_66" >>include/config.h ; \
echo "... 66 MHz PCI" ; \
- else \
echo "... 33 MHz PCI" ; \
- fi
- @./mkconfig -a wrsbc8560 ppc mpc85xx sbc8560
stxgp3_config: unconfig @./mkconfig $(@:_config=) ppc mpc85xx stxgp3
diff --git a/doc/README.wrsbc8560 b/doc/README.wrsbc8560 new file mode 100644 --- /dev/null +++ b/doc/README.wrsbc8560 @@ -0,0 +1,57 @@ +The port was tested on Wind River System wrsbc8560 board +<www.windriver.com>. U-Boot was installed on the flash memory of the +CPU card (not the SODIMM).
+NOTE: Please configure uboot compile to the proper PCI frequency and +setup the appropriate DIP switch settings.
+wrsb8560 board:
+Make sure boards switches are set to their appropriate conditions. +Refer to the Engineering Reference Guide ERG-00300-002. Of particular +importance are: 1) the settings for JP4 (JP4 1-3 and 2-4), which +select the on-board FLASH device (Intel 28F128Jx); 2) The settings +for the Clock SW9 (33 MHz or 66 MHz).
- Note: SW9 Settings: 66 MHz
4:1 ratio CCB clocks:SYSCLK
3:1 ration e500 Core:CCB
pos1 - on, pos2 - on, pos3 - off, pos4 - on, pos5 - off,
pos6 - on
- Note: SW9 Settings: 33 MHz
8:1 ratio CCB clocks:SYSCLK
pos1 - on, pos2 - on, pos3 - on, pos4 - off, pos5 - off,
pos6 - on
+Flashing the FLASH device with the "Wind River ICE":
+1) Properly connect and configure the Wind River ICE to the target
- JTAG port. This includes running the wrsbc8560 register script. Make
</snip>
Your U-Boot support team
DENX Support System
