[PATCH V6 00/13] IOT2050-related enhancements
(Almost) flushing our upstream queue for the IOT2050 device, this mostly brings board-specific changes such as:
- updated build process and firmware layout for PG1 vs. PG2 devices - more watchdog preparations - preparations for verified boot on IOT2050 Advanced devices
This series depends on
https://lore.kernel.org/u-boot/cover.1675426972.git.jan.kiszka@siemens.com/ ("env: Enhancements for establishing variable protection")
Changes in v6: - fixed CFG_ENV_FLAGS_LIST_STATIC setup - migrated to board env file - cleaned up #ifdef in "Optionally embed OTP programming data into image" - rebased over latest master
Changes in v5: - factored out two patches
Changes in v4: - rebased over latest master - make use of new CONFIG_EFI_SCROLL_ON_CLEAR_SCREEN
Changes in v3: - further reworked patch 1 to load default env directly, leaving driver ordering alone
Changes in v2: - rebased over latest master - reworked patch 1 to be less invasive to the code - added "iot2050: use the named gpio to control the user-button"
Still in our backlog is support for a new variant that comes with M.2 slots. Related DT patches were sent to the kernel and are under review now.
Jan
CC: chao zeng chao.zeng@siemens.com CC: Su Baocheng baocheng.su@siemens.com
Jan Kiszka (10): iot2050: Update firmware layout iot2050: Migrate settings into board env file iot2050: Add watchdog start to bootcmd iot2050: Add CFG_ENV_FLAGS_LIST_STATIC arm: dts: iot2050: Allow verifying U-Boot proper by SPL tools: Add script for converting public key into device tree include iot2050: Add script for signing artifacts arm: dts: iot2050: Optionally embed OTP programming data into image doc: iot2050: Add a note about the watchdog firmware iot2050: Refresh defconfigs and activate CONFIG_EFI_SCROLL_ON_CLEAR_SCREEN
Su Baocheng (2): board: siemens: iot2050: Split the build for PG1 and PG2 arm: dts: iot2050: Use the auto generator nodes for fdt
chao zeng (1): board: siemens: iot2050: use the named gpio to control the user-button
arch/arm/dts/k3-am65-iot2050-boot-image.dtsi | 133 ++++++------------ board/siemens/iot2050/Kconfig | 35 ++++- board/siemens/iot2050/board.c | 17 +-- board/siemens/iot2050/iot2050.env | 17 +++ ...ot2050_defconfig => iot2050_pg1_defconfig} | 13 +- ...ot2050_defconfig => iot2050_pg2_defconfig} | 15 +- doc/board/siemens/iot2050.rst | 79 ++++++++++- include/configs/iot2050.h | 18 +-- tools/binman/missing-blob-help | 14 +- tools/iot2050-sign-fw.sh | 51 +++++++ tools/key2dtsi.py | 64 +++++++++ 11 files changed, 318 insertions(+), 138 deletions(-) create mode 100644 board/siemens/iot2050/iot2050.env copy configs/{iot2050_defconfig => iot2050_pg1_defconfig} (93%) rename configs/{iot2050_defconfig => iot2050_pg2_defconfig} (91%) create mode 100755 tools/iot2050-sign-fw.sh create mode 100755 tools/key2dtsi.py
Due to different signature keys, the PG1 and the PG2 boards can no longer use the same FSBL (tiboot3). This makes it impossible anyway to maintaine a single flash.bin for both variants, so we can also split the build.
A new target is added to indicates the build is for PG1 vs. PG2 boards. Hence now the variants have separated defconfig files.
The runtime board_is_sr1() check does make no sense anymore, so remove it and replace with build time check.
Documentation is updated accordingly. New binary artifacts are already available via meta-iot2050.
Signed-off-by: Su Baocheng baocheng.su@siemens.com [Jan: refactor config option into targets, tweak some wordings] Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- arch/arm/dts/k3-am65-iot2050-boot-image.dtsi | 80 ++++++------------- board/siemens/iot2050/Kconfig | 28 ++++++- board/siemens/iot2050/board.c | 12 +-- ...ot2050_defconfig => iot2050_pg1_defconfig} | 2 +- ...ot2050_defconfig => iot2050_pg2_defconfig} | 5 +- doc/board/siemens/iot2050.rst | 15 +++- 6 files changed, 66 insertions(+), 76 deletions(-) copy configs/{iot2050_defconfig => iot2050_pg1_defconfig} (99%) rename configs/{iot2050_defconfig => iot2050_pg2_defconfig} (97%)
diff --git a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi index 27058370ccc..3135ad04715 100644 --- a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi +++ b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (c) Siemens AG, 2020-2021 + * Copyright (c) Siemens AG, 2020-2022 * * Authors: * Jan Kiszka jan.kiszka@siemens.com @@ -17,7 +17,11 @@
blob-ext@0x000000 { offset = <0x000000>; - filename = "tiboot3.bin"; +#ifdef CONFIG_TARGET_IOT2050_A53_PG1 + filename = "seboot_pg1.bin"; +#else + filename = "seboot_pg2.bin"; +#endif missing-msg = "iot2050-seboot"; };
@@ -43,42 +47,30 @@ };
fdt-iot2050-basic { - description = "k3-am6528-iot2050-basic.dtb"; + description = "k3-am6528-iot2050-basic*.dtb"; type = "flat_dt"; arch = "arm64"; compression = "none"; blob { +#ifdef CONFIG_TARGET_IOT2050_A53_PG1 filename = "arch/arm/dts/k3-am6528-iot2050-basic.dtb"; - }; - }; - - fdt-iot2050-basic-pg2 { - description = "k3-am6528-iot2050-basic-pg2.dtb"; - type = "flat_dt"; - arch = "arm64"; - compression = "none"; - blob { +#else filename = "arch/arm/dts/k3-am6528-iot2050-basic-pg2.dtb"; +#endif }; };
fdt-iot2050-advanced { - description = "k3-am6548-iot2050-advanced.dtb"; + description = "k3-am6548-iot2050-advanced*.dtb"; type = "flat_dt"; arch = "arm64"; compression = "none"; blob { +#ifdef CONFIG_TARGET_IOT2050_A53_PG1 filename = "arch/arm/dts/k3-am6548-iot2050-advanced.dtb"; - }; - }; - - fdt-iot2050-advanced-pg2 { - description = "k3-am6548-iot2050-advanced-pg2.dtb"; - type = "flat_dt"; - arch = "arm64"; - compression = "none"; - blob { +#else filename = "arch/arm/dts/k3-am6548-iot2050-advanced-pg2.dtb"; +#endif }; };
@@ -108,30 +100,12 @@ #endif };
- conf-iot2050-basic-pg2 { - description = "iot2050-basic-pg2"; - firmware = "u-boot"; - fdt = "fdt-iot2050-basic-pg2"; -#ifdef CONFIG_WDT_K3_RTI_FW_FILE - loadables = "k3-rti-wdt-firmware"; -#endif - }; - conf-iot2050-advanced { description = "iot2050-advanced"; firmware = "u-boot"; fdt = "fdt-iot2050-advanced"; #ifdef CONFIG_WDT_K3_RTI_FW_FILE loadables = "k3-rti-wdt-firmware"; -#endif - }; - - conf-iot2050-advanced-pg2 { - description = "iot2050-advanced-pg2"; - firmware = "u-boot"; - fdt = "fdt-iot2050-advanced-pg2"; -#ifdef CONFIG_WDT_K3_RTI_FW_FILE - loadables = "k3-rti-wdt-firmware"; #endif }; }; @@ -150,28 +124,24 @@ fill-byte = [00]; };
- /* PG1 sysfw, basic variant */ + /* sysfw, basic variant */ blob-ext@0x6c0000 { offset = <0x6c0000>; - filename = "sysfw.itb"; +#ifdef CONFIG_TARGET_IOT2050_A53_PG1 + filename = "sysfw_sr1.itb"; +#else + filename = "sysfw_sr2.itb"; +#endif missing-msg = "iot2050-sysfw"; }; - /* PG1 sysfw, advanced variant */ + /* sysfw, advanced variant */ blob-ext@0x740000 { offset = <0x740000>; - filename = "sysfw.itb_HS"; - missing-msg = "iot2050-sysfw"; - }; - /* PG2 sysfw, basic variant */ - blob-ext@0x7c0000 { - offset = <0x7c0000>; - filename = "sysfw_sr2.itb"; - missing-msg = "iot2050-sysfw"; - }; - /* PG2 sysfw, advanced variant */ - blob-ext@0x840000 { - offset = <0x840000>; +#ifdef CONFIG_TARGET_IOT2050_A53_PG1 + filename = "sysfw_sr1.itb_HS"; +#else filename = "sysfw_sr2.itb_HS"; +#endif missing-msg = "iot2050-sysfw"; }; }; diff --git a/board/siemens/iot2050/Kconfig b/board/siemens/iot2050/Kconfig index 063142a43bf..a2b40881d11 100644 --- a/board/siemens/iot2050/Kconfig +++ b/board/siemens/iot2050/Kconfig @@ -1,20 +1,40 @@ # SPDX-License-Identifier: GPL-2.0+ # -# Copyright (c) Siemens AG, 2018-2021 +# Copyright (c) Siemens AG, 2018-2022 # # Authors: # Le Jin le.jin@siemens.com # Jan Kiszka jan.kiszka@siemens.com
-config TARGET_IOT2050_A53 - bool "IOT2050 running on A53" +choice + prompt "Siemens SIMATIC IOT2050 boards" + optional + +config TARGET_IOT2050_A53_PG1 + bool "IOT2050 PG1 running on A53" + select IOT2050_A53_COMMON + help + This builds U-Boot for the Product Generation 1 (PG1) of the IOT2050 + devices. + +config TARGET_IOT2050_A53_PG2 + bool "IOT2050 PG2 running on A53" + select IOT2050_A53_COMMON + help + This builds U-Boot for the Product Generation 2 (PG2) of the IOT2050 + devices. + +endchoice + +config IOT2050_A53_COMMON + bool select ARM64 select SOC_K3_AM654 select BOARD_LATE_INIT select SYS_DISABLE_DCACHE_OPS select BINMAN
-if TARGET_IOT2050_A53 +if IOT2050_A53_COMMON
config SYS_BOARD default "iot2050" diff --git a/board/siemens/iot2050/board.c b/board/siemens/iot2050/board.c index 8f4b0eae495..dbf893000a7 100644 --- a/board/siemens/iot2050/board.c +++ b/board/siemens/iot2050/board.c @@ -55,14 +55,6 @@ static bool board_is_advanced(void) strstr((char *)info->name, "IOT2050-ADVANCED") != NULL; }
-static bool board_is_sr1(void) -{ - struct iot2050_info *info = IOT2050_INFO_DATA; - - return info->magic == IOT2050_INFO_MAGIC && - !strstr((char *)info->name, "-PG2"); -} - static void remove_mmc1_target(void) { char *boot_targets = strdup(env_get("boot_targets")); @@ -109,12 +101,12 @@ void set_board_info_env(void) }
if (board_is_advanced()) { - if (board_is_sr1()) + if (IS_ENABLED(CONFIG_TARGET_IOT2050_A53_PG1)) fdtfile = "ti/k3-am6548-iot2050-advanced.dtb"; else fdtfile = "ti/k3-am6548-iot2050-advanced-pg2.dtb"; } else { - if (board_is_sr1()) + if (IS_ENABLED(CONFIG_TARGET_IOT2050_A53_PG1)) fdtfile = "ti/k3-am6528-iot2050-basic.dtb"; else fdtfile = "ti/k3-am6528-iot2050-basic-pg2.dtb"; diff --git a/configs/iot2050_defconfig b/configs/iot2050_pg1_defconfig similarity index 99% copy from configs/iot2050_defconfig copy to configs/iot2050_pg1_defconfig index 4ae85f391b7..3dfebedfb97 100644 --- a/configs/iot2050_defconfig +++ b/configs/iot2050_pg1_defconfig @@ -8,7 +8,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM654=y -CONFIG_TARGET_IOT2050_A53=y +CONFIG_TARGET_IOT2050_A53_PG1=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_ENV_SECT_SIZE=0x20000 diff --git a/configs/iot2050_defconfig b/configs/iot2050_pg2_defconfig similarity index 97% rename from configs/iot2050_defconfig rename to configs/iot2050_pg2_defconfig index 4ae85f391b7..4eba7a3476d 100644 --- a/configs/iot2050_defconfig +++ b/configs/iot2050_pg2_defconfig @@ -8,13 +8,13 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM654=y -CONFIG_TARGET_IOT2050_A53=y +CONFIG_TARGET_IOT2050_A53_PG2=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am6528-iot2050-basic" +CONFIG_DEFAULT_DEVICE_TREE="k3-am6528-iot2050-basic-pg2" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_SYS_PROMPT="IOT2050> " CONFIG_SPL_SERIAL=y @@ -74,6 +74,7 @@ CONFIG_SPL_OF_LIST="k3-am65-iot2050-spl" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y +CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y diff --git a/doc/board/siemens/iot2050.rst b/doc/board/siemens/iot2050.rst index 7e97f817ce4..fd3431fa3f8 100644 --- a/doc/board/siemens/iot2050.rst +++ b/doc/board/siemens/iot2050.rst @@ -24,9 +24,10 @@ Binary dependencies can be found in https://github.com/siemens/meta-iot2050/tree/master/recipes-bsp/u-boot/files.... The following binaries from that source need to be present in the build folder:
- - tiboot3.bin - - sysfw.itb - - sysfw.itb_HS + - seboot_pg1.bin + - sysfw_sr1.itb + - sysfw_sr1.itb_HS + - seboot_pg2.bin - sysfw_sr2.itb - sysfw_sr2.itb_HS
@@ -57,7 +58,13 @@ U-Boot:
$ export ATF=/path/to/bl31.bin $ export TEE=/path/to/tee-pager_v2.bin - $ make iot2050_defconfig + + # configure for PG1 + $ make iot2050_pg1_defconfig + + # or configure for PG2 + $ make iot2050_pg2_defconfig + $ make
Flashing
Refactor according to the entry `fit: Entry containing a FIT` of document tools/binman/README.entries.
As the generator uses the device tree name for the config description, board_fit_config_name_match requires a small adjustment as well.
Signed-off-by: Su Baocheng baocheng.su@siemens.com [Jan: re-add now required CONFIG_OF_LIST, update config matching] Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- arch/arm/dts/k3-am65-iot2050-boot-image.dtsi | 44 ++++---------------- board/siemens/iot2050/board.c | 3 ++ configs/iot2050_pg1_defconfig | 1 + configs/iot2050_pg2_defconfig | 1 + 4 files changed, 12 insertions(+), 37 deletions(-)
diff --git a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi index 3135ad04715..46669576864 100644 --- a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi +++ b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi @@ -32,6 +32,7 @@
fit@0x280000 { description = "U-Boot for IOT2050"; + fit,fdt-list = "of-list"; offset = <0x280000>; images { u-boot { @@ -46,32 +47,11 @@ }; };
- fdt-iot2050-basic { - description = "k3-am6528-iot2050-basic*.dtb"; + @fdt-SEQ { + description = "fdt-NAME"; type = "flat_dt"; arch = "arm64"; compression = "none"; - blob { -#ifdef CONFIG_TARGET_IOT2050_A53_PG1 - filename = "arch/arm/dts/k3-am6528-iot2050-basic.dtb"; -#else - filename = "arch/arm/dts/k3-am6528-iot2050-basic-pg2.dtb"; -#endif - }; - }; - - fdt-iot2050-advanced { - description = "k3-am6548-iot2050-advanced*.dtb"; - type = "flat_dt"; - arch = "arm64"; - compression = "none"; - blob { -#ifdef CONFIG_TARGET_IOT2050_A53_PG1 - filename = "arch/arm/dts/k3-am6548-iot2050-advanced.dtb"; -#else - filename = "arch/arm/dts/k3-am6548-iot2050-advanced-pg2.dtb"; -#endif - }; };
#ifdef CONFIG_WDT_K3_RTI_FW_FILE @@ -89,21 +69,11 @@ };
configurations { - default = "conf-iot2050-basic"; - - conf-iot2050-basic { - description = "iot2050-basic"; - firmware = "u-boot"; - fdt = "fdt-iot2050-basic"; -#ifdef CONFIG_WDT_K3_RTI_FW_FILE - loadables = "k3-rti-wdt-firmware"; -#endif - }; - - conf-iot2050-advanced { - description = "iot2050-advanced"; + default = "@config-DEFAULT-SEQ"; + @config-SEQ { + description = "NAME"; firmware = "u-boot"; - fdt = "fdt-iot2050-advanced"; + fdt = "fdt-SEQ"; #ifdef CONFIG_WDT_K3_RTI_FW_FILE loadables = "k3-rti-wdt-firmware"; #endif diff --git a/board/siemens/iot2050/board.c b/board/siemens/iot2050/board.c index dbf893000a7..57d7009e8c7 100644 --- a/board/siemens/iot2050/board.c +++ b/board/siemens/iot2050/board.c @@ -154,6 +154,9 @@ int board_fit_config_name_match(const char *name) struct iot2050_info *info = IOT2050_INFO_DATA; char upper_name[32];
+ /* skip the prefix "k3-am65x8-" */ + name += 10; + if (info->magic != IOT2050_INFO_MAGIC || strlen(name) >= sizeof(upper_name)) return -1; diff --git a/configs/iot2050_pg1_defconfig b/configs/iot2050_pg1_defconfig index 3dfebedfb97..85f153842cd 100644 --- a/configs/iot2050_pg1_defconfig +++ b/configs/iot2050_pg1_defconfig @@ -69,6 +69,7 @@ CONFIG_CMD_TIME=y # CONFIG_ISO_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIST="k3-am6528-iot2050-basic k3-am6548-iot2050-advanced" CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_OF_LIST="k3-am65-iot2050-spl" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y diff --git a/configs/iot2050_pg2_defconfig b/configs/iot2050_pg2_defconfig index 4eba7a3476d..6b5e50a99a7 100644 --- a/configs/iot2050_pg2_defconfig +++ b/configs/iot2050_pg2_defconfig @@ -69,6 +69,7 @@ CONFIG_CMD_TIME=y # CONFIG_ISO_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIST="k3-am6528-iot2050-basic-pg2 k3-am6548-iot2050-advanced-pg2" CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_OF_LIST="k3-am65-iot2050-spl" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y
(for the dtsi bits)
The latest version of the binary-only firmware parts come in a combined form of FSBL and sysfw containers. This implies some layout changes to the generated firmware image but also makes handling of artifacts much simpler (4 files less). The env locations will not change, just the space reserved for U-Boot will shrink from 4 to 3 MB - still plenty of space left in practice.
Adjust configuration and documentation accordingly.
Along this change, add a new reservation for update commands of the user-controlled OTP part. A specific userspace tool will fill it, and the FSBL will evaluate it during boot. This reservation will use 64K of the former sysfw section.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- arch/arm/dts/k3-am65-iot2050-boot-image.dtsi | 30 ++++++-------------- configs/iot2050_pg1_defconfig | 2 +- configs/iot2050_pg2_defconfig | 2 +- doc/board/siemens/iot2050.rst | 4 --- tools/binman/missing-blob-help | 8 +----- 5 files changed, 11 insertions(+), 35 deletions(-)
diff --git a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi index 46669576864..3ee0842e993 100644 --- a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi +++ b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi @@ -25,15 +25,15 @@ missing-msg = "iot2050-seboot"; };
- blob@0x080000 { - offset = <0x080000>; + blob@0x180000 { + offset = <0x180000>; filename = "tispl.bin"; };
- fit@0x280000 { + fit@0x380000 { description = "U-Boot for IOT2050"; fit,fdt-list = "of-list"; - offset = <0x280000>; + offset = <0x380000>; images { u-boot { description = "U-Boot"; @@ -94,25 +94,11 @@ fill-byte = [00]; };
- /* sysfw, basic variant */ - blob-ext@0x6c0000 { + /* OTP update command block */ + fill@0x6c0000 { offset = <0x6c0000>; -#ifdef CONFIG_TARGET_IOT2050_A53_PG1 - filename = "sysfw_sr1.itb"; -#else - filename = "sysfw_sr2.itb"; -#endif - missing-msg = "iot2050-sysfw"; - }; - /* sysfw, advanced variant */ - blob-ext@0x740000 { - offset = <0x740000>; -#ifdef CONFIG_TARGET_IOT2050_A53_PG1 - filename = "sysfw_sr1.itb_HS"; -#else - filename = "sysfw_sr2.itb_HS"; -#endif - missing-msg = "iot2050-sysfw"; + size = <0x010000>; + fill-byte = [ff]; }; }; }; diff --git a/configs/iot2050_pg1_defconfig b/configs/iot2050_pg1_defconfig index 85f153842cd..28930aac5eb 100644 --- a/configs/iot2050_pg1_defconfig +++ b/configs/iot2050_pg1_defconfig @@ -52,7 +52,7 @@ CONFIG_SPL_POWER_DOMAIN=y # CONFIG_SPL_SPI_FLASH_TINY is not set CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 +CONFIG_SYS_SPI_U_BOOT_OFFS=0x380000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_ASKENV=y diff --git a/configs/iot2050_pg2_defconfig b/configs/iot2050_pg2_defconfig index 6b5e50a99a7..c76abcca672 100644 --- a/configs/iot2050_pg2_defconfig +++ b/configs/iot2050_pg2_defconfig @@ -52,7 +52,7 @@ CONFIG_SPL_POWER_DOMAIN=y # CONFIG_SPL_SPI_FLASH_TINY is not set CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 +CONFIG_SYS_SPI_U_BOOT_OFFS=0x380000 CONFIG_SYS_MAXARGS=64 CONFIG_SYS_PBSIZE=1050 CONFIG_CMD_ASKENV=y diff --git a/doc/board/siemens/iot2050.rst b/doc/board/siemens/iot2050.rst index fd3431fa3f8..26972e20ae9 100644 --- a/doc/board/siemens/iot2050.rst +++ b/doc/board/siemens/iot2050.rst @@ -25,11 +25,7 @@ https://github.com/siemens/meta-iot2050/tree/master/recipes-bsp/u-boot/files... The following binaries from that source need to be present in the build folder:
- seboot_pg1.bin - - sysfw_sr1.itb - - sysfw_sr1.itb_HS - seboot_pg2.bin - - sysfw_sr2.itb - - sysfw_sr2.itb_HS
Building -------- diff --git a/tools/binman/missing-blob-help b/tools/binman/missing-blob-help index c61ca02a35e..5bb8961ce03 100644 --- a/tools/binman/missing-blob-help +++ b/tools/binman/missing-blob-help @@ -21,13 +21,7 @@ Please read the section on SCP firmware in board/sunxi/README.sunxi64 iot2050-seboot: See the documentation for IOT2050 board. Your image is missing SEBoot which is mandatory for board startup. Prebuilt SEBoot located at -meta-iot2050/tree/master/recipes-bsp/u-boot/files/prebuild/tiboot3.bin. - -iot2050-sysfw: -See the documentation for IOT2050 board. Your image is missing system -firmware which is mandatory for board startup. Prebuilt system firmware -located at meta-iot2050/tree/master/recipes-bsp/u-boot/files/prebuild/ -with sysfw prefix. +meta-iot2050/tree/master/recipes-bsp/u-boot/files/prebuild/seboot_pg*.bin.
k3-rti-wdt-firmware: If CONFIG_WDT_K3_RTI_LOAD_FW is enabled, a firmware image is needed for
Anything that is not boot-env related is better kept there by now.
At this chance, also drop a stale comment from iot2050.h
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- board/siemens/iot2050/iot2050.env | 9 +++++++++ include/configs/iot2050.h | 11 ++--------- 2 files changed, 11 insertions(+), 9 deletions(-) create mode 100644 board/siemens/iot2050/iot2050.env
diff --git a/board/siemens/iot2050/iot2050.env b/board/siemens/iot2050/iot2050.env new file mode 100644 index 00000000000..4bd93f0b2f4 --- /dev/null +++ b/board/siemens/iot2050/iot2050.env @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) Siemens AG, 2023 + * + * Authors: + * Jan Kiszka jan.kiszka@siemens.com + */ + +usb_pgood_delay=900 diff --git a/include/configs/iot2050.h b/include/configs/iot2050.h index 7d087413362..dd02e3f7543 100644 --- a/include/configs/iot2050.h +++ b/include/configs/iot2050.h @@ -13,12 +13,6 @@
#include <linux/sizes.h>
-/* SPL Loader Configuration */ - -/* U-Boot general configuration */ -#define EXTRA_ENV_IOT2050_BOARD_SETTINGS \ - "usb_pgood_delay=900\0" - #if CONFIG_IS_ENABLED(CMD_USB) # define BOOT_TARGET_USB(func) \ func(USB, usb, 0) \ @@ -40,10 +34,9 @@
#include <config_distro_bootcmd.h>
-#define CFG_EXTRA_ENV_SETTINGS \ +#define CFG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ - BOOTENV \ - EXTRA_ENV_IOT2050_BOARD_SETTINGS + BOOTENV
#include <configs/ti_armv7_common.h>
Allows run-time control over watchdog auto-start and the timeout via setting the environment variable watchdog_timeout_ms. A value of zero means "do not start". Use CONFIG_WATCHDOG_TIMEOUT_MSECS as initial value and this to zero by default. Users can then enable the watchdog once the use and OS which picks it up during boot.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- board/siemens/iot2050/iot2050.env | 8 ++++++++ configs/iot2050_pg1_defconfig | 2 ++ configs/iot2050_pg2_defconfig | 2 ++ 3 files changed, 12 insertions(+)
diff --git a/board/siemens/iot2050/iot2050.env b/board/siemens/iot2050/iot2050.env index 4bd93f0b2f4..02958798b49 100644 --- a/board/siemens/iot2050/iot2050.env +++ b/board/siemens/iot2050/iot2050.env @@ -7,3 +7,11 @@ */
usb_pgood_delay=900 + +watchdog_timeout_ms=CONFIG_WATCHDOG_TIMEOUT_MSECS +start_watchdog= + if test ${watchdog_timeout_ms} -gt 0; then + wdt dev watchdog@40610000; + wdt start ${watchdog_timeout_ms}; + echo Watchdog started, timeout ${watchdog_timeout_ms} ms; + fi diff --git a/configs/iot2050_pg1_defconfig b/configs/iot2050_pg1_defconfig index 28930aac5eb..6c6af35cdee 100644 --- a/configs/iot2050_pg1_defconfig +++ b/configs/iot2050_pg1_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTSTAGE=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_SPL_SHOW_BOOT_PROGRESS=y +CONFIG_BOOTCOMMAND="run start_watchdog; run distro_bootcmd" CONFIG_CONSOLE_MUX=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0x58000 @@ -141,6 +142,7 @@ CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y # CONFIG_WATCHDOG is not set # CONFIG_WATCHDOG_AUTOSTART is not set +CONFIG_WATCHDOG_TIMEOUT_MSECS=0 CONFIG_WDT=y CONFIG_WDT_K3_RTI=y CONFIG_WDT_K3_RTI_LOAD_FW=y diff --git a/configs/iot2050_pg2_defconfig b/configs/iot2050_pg2_defconfig index c76abcca672..43410160c8a 100644 --- a/configs/iot2050_pg2_defconfig +++ b/configs/iot2050_pg2_defconfig @@ -32,6 +32,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTSTAGE=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_SPL_SHOW_BOOT_PROGRESS=y +CONFIG_BOOTCOMMAND="run start_watchdog; run distro_bootcmd" CONFIG_CONSOLE_MUX=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0x58000 @@ -142,6 +143,7 @@ CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y # CONFIG_WATCHDOG is not set # CONFIG_WATCHDOG_AUTOSTART is not set +CONFIG_WATCHDOG_TIMEOUT_MSECS=0 CONFIG_WDT=y CONFIG_WDT_K3_RTI=y CONFIG_WDT_K3_RTI_LOAD_FW=y
Will be needed when CONFIG_ENV_WRITEABLE_LIST is enabled. The listed variables shall remain writable, for informational purposes - they have to be considered untrusted because the persistent U-Boot env is not protected.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- include/configs/iot2050.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/configs/iot2050.h b/include/configs/iot2050.h index dd02e3f7543..92d2f8d7705 100644 --- a/include/configs/iot2050.h +++ b/include/configs/iot2050.h @@ -40,4 +40,11 @@
+#ifdef CONFIG_ENV_WRITEABLE_LIST +#define CFG_ENV_FLAGS_LIST_STATIC \ + "board_uuid:sw,board_name:sw,board_serial:sw,board_a5e:sw," \ + "mlfb:sw,fw_version:sw,seboot_version:sw," \ + "eth1addr:mw,eth2addr:mw,watchdog_timeout_ms:dw,boot_targets:sw" +#endif + #endif /* __CONFIG_IOT2050_H */
Add hashes and configuration signature stubs to prepare verified boot of main U-Boot by SPL.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- arch/arm/dts/k3-am65-iot2050-boot-image.dtsi | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi index 3ee0842e993..9082a79a034 100644 --- a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi +++ b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi @@ -14,6 +14,7 @@ filename = "flash.bin"; pad-byte = <0xff>; size = <0x8c0000>; + allow-repack;
blob-ext@0x000000 { offset = <0x000000>; @@ -45,6 +46,9 @@ entry = <0x80800000>; u-boot-nodtb { }; + hash { + algo = "sha256"; + }; };
@fdt-SEQ { @@ -52,6 +56,9 @@ type = "flat_dt"; arch = "arm64"; compression = "none"; + hash { + algo = "sha256"; + }; };
#ifdef CONFIG_WDT_K3_RTI_FW_FILE @@ -64,6 +71,9 @@ filename = CONFIG_WDT_K3_RTI_FW_FILE; missing-msg = "k3-rti-wdt-firmware"; }; + hash { + algo = "sha256"; + }; }; #endif }; @@ -77,10 +87,16 @@ #ifdef CONFIG_WDT_K3_RTI_FW_FILE loadables = "k3-rti-wdt-firmware"; #endif + signature { + sign-images = "firmware", "fdt", "loadables"; + }; }; }; };
+ fdtmap { + }; + /* primary env */ fill@0x680000 { offset = <0x680000>;
Allows to create a public key device tree dtsi for inclusion into U-Boot SPL and proper during first build already. This can be achieved via CONFIG_DEVICE_TREE_INCLUDES.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- tools/key2dtsi.py | 64 +++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 64 insertions(+) create mode 100755 tools/key2dtsi.py
diff --git a/tools/key2dtsi.py b/tools/key2dtsi.py new file mode 100755 index 00000000000..1dbb2cc94bf --- /dev/null +++ b/tools/key2dtsi.py @@ -0,0 +1,64 @@ +#!/usr/bin/env python3 +# SPDX-License-Identifier: GPL-2.0-only +# +# Public key to dtsi converter. +# +# Copyright (c) Siemens AG, 2022 +# + +from argparse import ArgumentParser, FileType +from os.path import basename, splitext +from Cryptodome.PublicKey import RSA +from Cryptodome.Util.number import inverse + +def int_to_bytestr(n, length=None): + if not length: + length = (n.bit_length() + 7) // 8 + byte_array = n.to_bytes(length, 'big') + return ' '.join(['{:02x}'.format(byte) for byte in byte_array]) + +ap = ArgumentParser(description='Public key to dtsi converter') + +ap.add_argument('--hash', '-H', default='sha256', + help='hash to be used with key (default: sha256)') +ap.add_argument('--required-conf', '-c', action='store_true', + help='mark key required for configuration') +ap.add_argument('--required-image', '-i', action='store_true', + help='mark key required for image') +ap.add_argument('--spl', '-s', action='store_true', + help='mark key for usage in SPL') +ap.add_argument('key_file', metavar='KEY_FILE', type=FileType('r'), + help='key file (formats: X.509, PKCS#1, OpenSSH)') +ap.add_argument('dtsi_file', metavar='DTSI_FILE', type=FileType('w'), + help='dtsi output file') + +args = ap.parse_args() + +key_name, _ = splitext(basename(args.key_file.name)) + +key_data = args.key_file.read() +key = RSA.importKey(key_data) + +r_squared = (2**key.size_in_bits())**2 % key.n +n0_inverse = 2**32 - inverse(key.n, 2**32) + +out = args.dtsi_file +out.write('/ {\n') +out.write('\tsignature {\n') +out.write('\t\tkey-{} {{\n'.format(key_name)) +out.write('\t\t\tkey-name-hint = "{}";\n'.format(key_name)) +out.write('\t\t\talgo = "{},rsa{}";\n'.format(args.hash, key.size_in_bits())) +out.write('\t\t\trsa,num-bits = <{}>;\n'.format(key.size_in_bits())) +out.write('\t\t\trsa,modulus = [{}];\n'.format(int_to_bytestr(key.n))) +out.write('\t\t\trsa,exponent = [{}];\n'.format(int_to_bytestr(key.e, 8))) +out.write('\t\t\trsa,r-squared = [{}];\n'.format(int_to_bytestr(r_squared))) +out.write('\t\t\trsa,n0-inverse = <0x{:x}>;\n'.format(n0_inverse)) +if args.required_conf: + out.write('\t\t\trequired = "conf";\n') +elif args.required_image: + out.write('\t\t\trequired = "image";\n') +if args.spl: + out.write('\t\t\tu-boot,dm-spl;\n') +out.write('\t\t};\n') +out.write('\t};\n') +out.write('};\n')
There are many ways to get a signed firmware for the IOT2050 devices, namely for the parts under user-control. This script documents one way of doing it, given a signing key. Augment the board documentation with the required procedure around it.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- doc/board/siemens/iot2050.rst | 52 +++++++++++++++++++++++++++++++++++ tools/iot2050-sign-fw.sh | 51 ++++++++++++++++++++++++++++++++++ 2 files changed, 103 insertions(+) create mode 100755 tools/iot2050-sign-fw.sh
diff --git a/doc/board/siemens/iot2050.rst b/doc/board/siemens/iot2050.rst index 26972e20ae9..4e0925c72c9 100644 --- a/doc/board/siemens/iot2050.rst +++ b/doc/board/siemens/iot2050.rst @@ -79,3 +79,55 @@ Via external programmer Dediprog SF100 or SF600: .. code-block:: text
$ dpcmd --vcc 2 -v -u flash.bin + +Signing (optional) +------------------ + +To enable verified boot for the firmware artifacts after the Siemens-managed +first-stage loader (seboot_pg*.bin), the following steps need to be taken +before and after the build: + +Generate dtsi holding the public key +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +.. code-block:: text + + tools/key2dtsi.py -c -s key.pem public-key.dtsi + +This will be used to embed the public key into U-Boot SPL and main so that each +step can validate signatures of the succeeding one. + +Adjust U-Boot configuration +^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +Enabled at least the following options in U-Boot: + +.. code-block:: text + + CONFIG_SPL_FIT_SIGNATURE=y + CONFIG_DEVICE_TREE_INCLUDES="/path/to/public-key.dtsi" + CONFIG_RSA=y + +Note that there are more configuration changes needed in order to lock-down +the command line and the boot process of U-Boot for secure scenarios. These are +not in scope here. + +Build U-Boot +^^^^^^^^^^^^ + +See related section above. + +Sign flash.bin +^^^^^^^^^^^^^^ + +In the build folder still containing artifacts from step 3, invoke: + +.. code-block:: text + + tools/iot2050-sign-fw.sh /path/to/key.pem + +Flash signed flash.bin +^^^^^^^^^^^^^^^^^^^^^^ + +The signing has happen in-place in flash.bin, thus the flashing procedure +described above. diff --git a/tools/iot2050-sign-fw.sh b/tools/iot2050-sign-fw.sh new file mode 100755 index 00000000000..4d1d79498c2 --- /dev/null +++ b/tools/iot2050-sign-fw.sh @@ -0,0 +1,51 @@ +#!/bin/sh + +if [ -z "$1" ]; then + echo "Usage: $0 KEY" + exit 1 +fi + +TEMP_X509=$(mktemp XXXXXXXX.temp) + +REVISION=${2:-0} +SHA_VAL=$(openssl dgst -sha512 -hex tispl.bin | sed -e "s/^.*= //g") +BIN_SIZE=$(stat -c %s tispl.bin) + +cat <<EOF >$TEMP_X509 +[ req ] +distinguished_name = req_distinguished_name +x509_extensions = v3_ca +prompt = no +dirstring_type = nobmp + +[ req_distinguished_name ] +CN = IOT2050 Firmware Signature + +[ v3_ca ] +basicConstraints = CA:true +1.3.6.1.4.1.294.1.3 = ASN1:SEQUENCE:swrv +1.3.6.1.4.1.294.1.34 = ASN1:SEQUENCE:sysfw_image_integrity + +[ swrv ] +swrv = INTEGER:$REVISION + +[ sysfw_image_integrity ] +shaType = OID:2.16.840.1.101.3.4.2.3 +shaValue = FORMAT:HEX,OCT:$SHA_VAL +imageSize = INTEGER:$BIN_SIZE +EOF + +CERT_X509=$(mktemp XXXXXXXX.crt) + +openssl req -new -x509 -key $1 -nodes -outform DER -out $CERT_X509 -config $TEMP_X509 -sha512 +cat $CERT_X509 tispl.bin > tispl.bin_signed +# currently broken in upstream +#source/tools/binman/binman replace -i flash.bin -f tispl.bin_signed blob@0x180000 +dd if=tispl.bin_signed of=flash.bin bs=$((0x1000)) seek=$((0x180000/0x1000)) conv=notrunc + +rm $TEMP_X509 $CERT_X509 + +tools/mkimage -G $1 -r -o sha256,rsa4096 -F fit@0x380000.fit +# currently broken in upstream +#source/tools/binman/binman replace -i flash.bin -f fit@0x380000.fit fit@0x380000 +dd if=fit@0x380000.fit of=flash.bin bs=$((0x1000)) seek=$((0x380000/0x1000)) conv=notrunc
Use external blob otpcmd.bin to replace the 0xff filled OTP programming command block to create a firmware image that provisions the OTP on first boot. This otpcmd.bin is generated from the customer keys using steps described in the meta-iot2050 integration layer for the device.
Based on original patch by Baocheng Su.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- arch/arm/dts/k3-am65-iot2050-boot-image.dtsi | 9 +++++++++ board/siemens/iot2050/Kconfig | 7 +++++++ doc/board/siemens/iot2050.rst | 8 ++++++++ tools/binman/missing-blob-help | 8 ++++++++ 4 files changed, 32 insertions(+)
diff --git a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi index 9082a79a034..a2fc8bbc123 100644 --- a/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi +++ b/arch/arm/dts/k3-am65-iot2050-boot-image.dtsi @@ -111,10 +111,19 @@ };
/* OTP update command block */ +#if CONFIG_IOT2050_EMBED_OTPCMD + blob-ext@0x6c0000 { + offset = <0x6c0000>; + size = <0x010000>; + filename = "otpcmd.bin"; + missing-msg = "iot2050-otpcmd"; + }; +#else fill@0x6c0000 { offset = <0x6c0000>; size = <0x010000>; fill-byte = [ff]; }; +#endif }; }; diff --git a/board/siemens/iot2050/Kconfig b/board/siemens/iot2050/Kconfig index a2b40881d11..e66b2427d95 100644 --- a/board/siemens/iot2050/Kconfig +++ b/board/siemens/iot2050/Kconfig @@ -49,4 +49,11 @@ config IOT2050_BOOT_SWITCH bool "Disable eMMC boot via USER button (Advanced version only)" default y
+config IOT2050_EMBED_OTPCMD + bool "Embed OTP programming data" + help + Embed signed OTP programming data 'otpcmd.bin' into the firmware + image. This data will be evaluated and executed on first boot of the + device. + endif diff --git a/doc/board/siemens/iot2050.rst b/doc/board/siemens/iot2050.rst index 4e0925c72c9..cb49a0e36bf 100644 --- a/doc/board/siemens/iot2050.rst +++ b/doc/board/siemens/iot2050.rst @@ -27,6 +27,14 @@ The following binaries from that source need to be present in the build folder: - seboot_pg1.bin - seboot_pg2.bin
+For building an image containing the OTP key provisioning data, below binary +needs to be present in the build folder: + + - otpcmd.bin + +Regarding how to generating this otpcmd.bin, please refer to: +https://github.com/siemens/meta-iot2050/tree/master/recipes-bsp/secure-boot-... + Building --------
diff --git a/tools/binman/missing-blob-help b/tools/binman/missing-blob-help index 5bb8961ce03..7e88cd03954 100644 --- a/tools/binman/missing-blob-help +++ b/tools/binman/missing-blob-help @@ -23,6 +23,14 @@ See the documentation for IOT2050 board. Your image is missing SEBoot which is mandatory for board startup. Prebuilt SEBoot located at meta-iot2050/tree/master/recipes-bsp/u-boot/files/prebuild/seboot_pg*.bin.
+iot2050-otpcmd: +See the documentation for IOT2050 board. Your image is missing OTP command data +block which is used for provisioning the customer keys to the board. +Please refer to +meta-iot2050/tree/master/recipes-bsp/secure-boot-otp-provisioning/files/make-otpcmd.sh +for how to generate this binary. If you are not using secure boot or do not +intend to provision the keys, disable CONFIG_IOT2050_EMBED_OTPCMD. + k3-rti-wdt-firmware: If CONFIG_WDT_K3_RTI_LOAD_FW is enabled, a firmware image is needed for the R5F core(s) to trigger the system reset. One possible source is
This is enabled by default, thus should be described as well.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- doc/board/siemens/iot2050.rst | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/doc/board/siemens/iot2050.rst b/doc/board/siemens/iot2050.rst index cb49a0e36bf..efe94a448a9 100644 --- a/doc/board/siemens/iot2050.rst +++ b/doc/board/siemens/iot2050.rst @@ -27,6 +27,10 @@ The following binaries from that source need to be present in the build folder: - seboot_pg1.bin - seboot_pg2.bin
+When using the watchdog, a related firmware for the R5 core(s) is needed, e.g. +https://github.com/siemens/k3-rti-wdt. The name and location of the image is +configured via CONFIG_WDT_K3_RTI_FW_FILE. + For building an image containing the OTP key provisioning data, below binary needs to be present in the build folder:
User-button is controlled by the mcu domain gpio number 25. But main0 main1 mcu domain all have gpio number 25.
To identify where the gpio is from, Using gpio controll base as the prefix to indicate the gpio resource.
Signed-off-by: chao zeng chao.zeng@siemens.com --- board/siemens/iot2050/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/siemens/iot2050/board.c b/board/siemens/iot2050/board.c index 57d7009e8c7..2735ae3fb74 100644 --- a/board/siemens/iot2050/board.c +++ b/board/siemens/iot2050/board.c @@ -183,7 +183,7 @@ static bool user_button_pressed(void)
memset(&gpio, 0, sizeof(gpio));
- if (dm_gpio_lookup_name("25", &gpio) < 0 || + if (dm_gpio_lookup_name("gpio@42110000_25", &gpio) < 0 || dm_gpio_request(&gpio, "USER button") < 0 || dm_gpio_set_dir_flags(&gpio, GPIOD_IS_IN) < 0) return false;
This feature is desired on the platform.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- configs/iot2050_pg1_defconfig | 6 +++--- configs/iot2050_pg2_defconfig | 7 +++---- 2 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/configs/iot2050_pg1_defconfig b/configs/iot2050_pg1_defconfig index 6c6af35cdee..6f2ab72f921 100644 --- a/configs/iot2050_pg1_defconfig +++ b/configs/iot2050_pg1_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM654=y CONFIG_TARGET_IOT2050_A53_PG1=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80100000 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_ENV_SECT_SIZE=0x20000 @@ -23,11 +25,8 @@ CONFIG_ENV_OFFSET_REDUND=0x6a0000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80100000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTSTAGE=y CONFIG_SHOW_BOOT_PROGRESS=y @@ -147,3 +146,4 @@ CONFIG_WDT=y CONFIG_WDT_K3_RTI=y CONFIG_WDT_K3_RTI_LOAD_FW=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_SCROLL_ON_CLEAR_SCREEN=y diff --git a/configs/iot2050_pg2_defconfig b/configs/iot2050_pg2_defconfig index 43410160c8a..d2bdeab593b 100644 --- a/configs/iot2050_pg2_defconfig +++ b/configs/iot2050_pg2_defconfig @@ -9,6 +9,8 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM654=y CONFIG_TARGET_IOT2050_A53_PG2=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80100000 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x680000 CONFIG_ENV_SECT_SIZE=0x20000 @@ -23,11 +25,8 @@ CONFIG_ENV_OFFSET_REDUND=0x6a0000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80100000 # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_LOAD_FIT=y -# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTSTAGE=y CONFIG_SHOW_BOOT_PROGRESS=y @@ -76,7 +75,6 @@ CONFIG_SPL_OF_LIST="k3-am65-iot2050-spl" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y @@ -148,3 +146,4 @@ CONFIG_WDT=y CONFIG_WDT_K3_RTI=y CONFIG_WDT_K3_RTI_LOAD_FW=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_SCROLL_ON_CLEAR_SCREEN=y
Jan Kiszka
