[U-Boot] [PATCH V2] exynos: spl: Add a custom spi copy function
This patch implements a custom spi_copy funtion to copy u-boot from SF to RAM. This is faster then iROM spi_copy funtion as this runs spi at 50Mhz and also in WORD mode of operation.
Changed a printf in pinmux.c to debug just to avoid the compilation error in SPL. Removed enum for boot mode from spl_boot.c as it was already define in spl.h
Based on "[PATCH V2] spi: exynos: Support word transfers"
Signed-off-by: Alim Akhtar alim.akhtar@samsung.com Signed-off-by: Tom Wai-Hong Tam waihong@chromium.org Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- Changes in V2: - Corrected the commit message. - Added a SPI timeout check. - Corrected the comments. arch/arm/cpu/armv7/exynos/pinmux.c | 2 +- arch/arm/include/asm/arch-exynos/spi.h | 2 + board/samsung/smdk5250/spl_boot.c | 136 ++++++++++++++++++++++++++++--- include/configs/exynos5250-dt.h | 3 + spl/Makefile | 4 + 5 files changed, 132 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index bd499b4..c484a86 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -427,7 +427,7 @@ static int exynos4_pinmux_config(int peripheral, int flags) case PERIPH_ID_SDMMC1: case PERIPH_ID_SDMMC3: case PERIPH_ID_SDMMC4: - printf("SDMMC device %d not implemented\n", peripheral); + debug("SDMMC device %d not implemented\n", peripheral); return -1; default: debug("%s: invalid peripheral %d", __func__, peripheral); diff --git a/arch/arm/include/asm/arch-exynos/spi.h b/arch/arm/include/asm/arch-exynos/spi.h index e67ad27..3430ac1 100644 --- a/arch/arm/include/asm/arch-exynos/spi.h +++ b/arch/arm/include/asm/arch-exynos/spi.h @@ -43,6 +43,8 @@ struct exynos_spi {
#define SPI_TIMEOUT_MS 10
+#define SF_READ_DATA_CMD 0x3 + /* SPI_CHCFG */ #define SPI_CH_HS_EN (1 << 6) #define SPI_CH_RST (1 << 5) diff --git a/board/samsung/smdk5250/spl_boot.c b/board/samsung/smdk5250/spl_boot.c index c0bcf46..85a5d68 100644 --- a/board/samsung/smdk5250/spl_boot.c +++ b/board/samsung/smdk5250/spl_boot.c @@ -22,17 +22,13 @@
#include<common.h> #include<config.h> +#include <asm/arch/clk.h> +#include <asm/arch/spi.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/periph.h> +#include <asm/arch/spl.h>
-enum boot_mode { - BOOT_MODE_MMC = 4, - BOOT_MODE_SERIAL = 20, - /* Boot based on Operating Mode pin settings */ - BOOT_MODE_OM = 32, - BOOT_MODE_USB, /* Boot using USB download */ -}; - - typedef u32 (*spi_copy_func_t)(u32 offset, u32 nblock, u32 dst); - typedef u32 (*usb_copy_func_t)(void); +typedef u32 (*usb_copy_func_t)(void);
/* * Set/clear program flow prediction and return the previous state. @@ -48,6 +44,119 @@ static int config_branch_prediction(int set_cr_z) return cr & CR_Z; }
+static void spi_rx_tx(struct exynos_spi *regs, int todo, + void *dinp, void const *doutp, int i) +{ + uint *rxp = (uint *)(dinp + (i * (32 * 1024))); + int rx_lvl, tx_lvl; + uint out_bytes, in_bytes; + + out_bytes = todo; + in_bytes = todo; + setbits_le32(®s->ch_cfg, SPI_CH_RST); + clrbits_le32(®s->ch_cfg, SPI_CH_RST); + writel(((todo * 8) / 32) | SPI_PACKET_CNT_EN, ®s->pkt_cnt); + + while (in_bytes) { + uint32_t spi_sts; + int temp; + + spi_sts = readl(®s->spi_sts); + rx_lvl = ((spi_sts >> 15) & 0x7f); + tx_lvl = ((spi_sts >> 6) & 0x7f); + while (tx_lvl < 32 && out_bytes) { + temp = 0xffffffff; + writel(temp, ®s->tx_data); + out_bytes -= 4; + tx_lvl += 4; + } + while (rx_lvl >= 4 && in_bytes) { + temp = readl(®s->rx_data); + if (rxp) + *rxp++ = temp; + in_bytes -= 4; + rx_lvl -= 4; + } + } +} + +/* +* Copy uboot from spi flash to RAM +* +* @parma uboot_size size of u-boot to copy +* @param uboot_addr address in u-boot to copy +*/ +static void exynos_spi_copy(unsigned int uboot_size, unsigned int uboot_addr) +{ + int upto, todo; + int i, timeout = 100; + struct exynos_spi *regs = (struct exynos_spi *)CONFIG_ENV_SPI_BASE; + + set_spi_clk(PERIPH_ID_SPI1, 50000000); /* set spi clock to 50Mhz */ + /* set the spi1 GPIO */ + exynos_pinmux_config(PERIPH_ID_SPI1, PINMUX_FLAG_NONE); + + /* set pktcnt and enable it */ + writel(4 | SPI_PACKET_CNT_EN, ®s->pkt_cnt); + /* set FB_CLK_SEL */ + writel(SPI_FB_DELAY_180, ®s->fb_clk); + /* set CH_WIDTH and BUS_WIDTH as word */ + setbits_le32(®s->mode_cfg, SPI_MODE_CH_WIDTH_WORD | + SPI_MODE_BUS_WIDTH_WORD); + clrbits_le32(®s->ch_cfg, SPI_CH_CPOL_L); /* CPOL: active high */ + + /* clear rx and tx channel if set priveously */ + clrbits_le32(®s->ch_cfg, SPI_RX_CH_ON | SPI_TX_CH_ON); + + setbits_le32(®s->swap_cfg, SPI_RX_SWAP_EN | + SPI_RX_BYTE_SWAP | + SPI_RX_HWORD_SWAP); + + /* do a soft reset */ + setbits_le32(®s->ch_cfg, SPI_CH_RST); + clrbits_le32(®s->ch_cfg, SPI_CH_RST); + + /* now set rx and tx channel ON */ + setbits_le32(®s->ch_cfg, SPI_RX_CH_ON | SPI_TX_CH_ON | SPI_CH_HS_EN); + clrbits_le32(®s->cs_reg, SPI_SLAVE_SIG_INACT); /* CS low */ + + /* Send read instruction (0x3h) followed by a 24 bit addr */ + writel((SF_READ_DATA_CMD << 24) | SPI_FLASH_UBOOT_POS, ®s->tx_data); + + /* waiting for TX done */ + while (!(readl(®s->spi_sts) & SPI_ST_TX_DONE)) { + if (!timeout) { + debug("SPI TIMEOUT\n"); + break; + } + timeout--; + } + + for (upto = 0, i = 0; upto < uboot_size; upto += todo, i++) { + todo = min(uboot_size - upto, (1 << 15)); + spi_rx_tx(regs, todo, (void *)(uboot_addr), + (void *)(SPI_FLASH_UBOOT_POS), i); + } + + setbits_le32(®s->cs_reg, SPI_SLAVE_SIG_INACT);/* make the CS high */ + + /* + * Let put controller mode to BYTE as + * SPI driver does not support WORD mode yet + */ + clrbits_le32(®s->mode_cfg, SPI_MODE_CH_WIDTH_WORD | + SPI_MODE_BUS_WIDTH_WORD); + writel(0, ®s->swap_cfg); + + /* + * Flush spi tx, rx fifos and reset the SPI controller + * and clear rx/tx channel + */ + clrsetbits_le32(®s->ch_cfg, SPI_CH_HS_EN, SPI_CH_RST); + clrbits_le32(®s->ch_cfg, SPI_CH_RST); + clrbits_le32(®s->ch_cfg, SPI_TX_CH_ON | SPI_RX_CH_ON); +} + /* * Copy U-boot from mmc to RAM: * COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains @@ -55,13 +164,13 @@ static int config_branch_prediction(int set_cr_z) */ void copy_uboot_to_ram(void) { - spi_copy_func_t spi_copy; usb_copy_func_t usb_copy;
int is_cr_z_set; unsigned int sec_boot_check; enum boot_mode bootmode = BOOT_MODE_OM; u32 (*copy_bl2)(u32, u32, u32); + struct spl_machine_param *param = spl_get_machine_params();
/* Read iRAM location to check for secondary USB boot mode */ sec_boot_check = readl(EXYNOS_IRAM_SECONDARY_BASE); @@ -73,9 +182,8 @@ void copy_uboot_to_ram(void)
switch (bootmode) { case BOOT_MODE_SERIAL: - spi_copy = *(spi_copy_func_t *)EXYNOS_COPY_SPI_FNPTR_ADDR; - spi_copy(SPI_FLASH_UBOOT_POS, CONFIG_BL2_SIZE, - CONFIG_SYS_TEXT_BASE); + /* Customised function to copy u-boot from SF */ + exynos_spi_copy(param->uboot_size, CONFIG_SYS_TEXT_BASE); break; case BOOT_MODE_MMC: copy_bl2 = (void *) *(u32 *)COPY_BL2_FNPTR_ADDR; diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index d78b892..c759ad2 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -152,6 +152,8 @@
/* MMC SPL */ #define CONFIG_SPL +#define CONFIG_SPL_GPIO_SUPPORT + #define COPY_BL2_FNPTR_ADDR 0x02020030
/* specific .lds file */ @@ -306,6 +308,7 @@ #define CONFIG_ENV_SPI_MODE SPI_MODE_0 #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE #define CONFIG_ENV_SPI_BUS 1 +#define CONFIG_ENV_SPI_BASE 0x12D30000 #define CONFIG_ENV_SPI_MAX_HZ 50000000 #endif
diff --git a/spl/Makefile b/spl/Makefile index 8b655c4..974cc06 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -102,6 +102,10 @@ ifneq ($(CONFIG_MX23)$(CONFIG_MX35),) LIBS-y += arch/$(ARCH)/imx-common/libimx-common.o endif
+ifneq ($(CONFIG_EXYNOS4)$(CONFIG_EXYNOS5),) +LIBS-y += $(CPUDIR)/s5p-common/libs5p-common.o +endif + # Add GCC lib ifeq ("$(USE_PRIVATE_LIBGCC)", "yes") PLATFORM_LIBGCC = $(SPLTREE)/arch/$(ARCH)/lib/libgcc.o
I think this needs to send as v3, as Simon sent v2 for this. http://patchwork.ozlabs.org/patch/243139/
-- Thanks, Jagan.
On Thu, May 30, 2013 at 12:01 PM, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
-enum boot_mode {
BOOT_MODE_MMC = 4,
BOOT_MODE_OM = 32,
- Set/clear program flow prediction and return the previous state.
int rx_lvl, tx_lvl;
out_bytes = todo;
in_bytes = todo;
while (in_bytes) {
uint32_t spi_sts;
int temp;
temp = 0xffffffff;
out_bytes -= 4;
tx_lvl += 4;
if (rxp)
*rxp++ = temp;
in_bytes -= 4;
rx_lvl -= 4;
int upto, todo;
SPI_RX_BYTE_SWAP |
SPI_RX_HWORD_SWAP);
if (!timeout) {
break;
timeout--;
- Copy U-boot from mmc to RAM:
- COPY_BL2_FNPTR_ADDR: Address in iRAM, which Contains
spi_copy_func_t spi_copy; usb_copy_func_t usb_copy; int is_cr_z_set; unsigned int sec_boot_check; enum boot_mode bootmode = BOOT_MODE_OM; u32 (*copy_bl2)(u32, u32, u32);
struct spl_machine_param *param = spl_get_machine_params(); /* Read iRAM location to check for secondary USB boot mode */ sec_boot_check = readl(EXYNOS_IRAM_SECONDARY_BASE);
# Add GCC lib ifeq ("$(USE_PRIVATE_LIBGCC)", "yes") PLATFORM_LIBGCC = $(SPLTREE)/arch/$(ARCH)/lib/libgcc.o --
Hi Jagan,
Simon had sent a V2 by rebasing the patch on MMC series submitted by Amar, but there are no comments on those MMC patches and are not yet merged. I incorporated the review comments given by Wolfgang Denk on top of V1 and sent a V2 patch.
Regards, Rajeshwari Shinde.
-- Thanks, Jagan.
-enum boot_mode {
BOOT_MODE_MMC = 4,
BOOT_MODE_OM = 32,
int rx_lvl, tx_lvl;
out_bytes = todo;
in_bytes = todo;
while (in_bytes) {
uint32_t spi_sts;
int temp;
temp = 0xffffffff;
out_bytes -= 4;
tx_lvl += 4;
if (rxp)
*rxp++ = temp;
in_bytes -= 4;
rx_lvl -= 4;
int upto, todo;
SPI_RX_BYTE_SWAP |
SPI_RX_HWORD_SWAP);
if (!timeout) {
break;
timeout--;
Jagan Teki
Rajeshwari Birje
Rajeshwari Shinde
