[v3][PATCH 1/3] efi_loader: Add check for event log passed from firmware
Platforms may have support to measure their initial firmware components and pass the event log to u-boot. The event log address can be passed in property tpm_event_log_addr and tpm_event_log_size of the tpm node. Platforms may choose their own specific mechanism to do so. A weak function is added to check if even log has been passed to u-boot from earlier firmware components. If available, the eventlog is parsed to check for its correctness and further event logs are appended to the passed log.
Signed-off-by: Ruchika Gupta ruchika.gupta@linaro.org --- v3: Return as soon as you detect error
v2: Moved firmware eventlog code parsing to tcg2_get_fw_eventlog()
lib/efi_loader/efi_tcg2.c | 322 ++++++++++++++++++++++++++++++++++++-- 1 file changed, 311 insertions(+), 11 deletions(-)
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 8c1f22e337..ebd7847957 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -324,6 +324,45 @@ __weak efi_status_t platform_get_tpm2_device(struct udevice **dev) return EFI_NOT_FOUND; }
+/** + * platform_get_eventlog() - retrieve the eventlog address and size + * + * This function retrieves the eventlog address and size if the underlying + * firmware has done some measurements and passed them. + * + * This function may be overridden based on platform specific method of + * passing the eventlog address and size. + * + * @dev: udevice + * @addr: eventlog address + * @sz: eventlog size + * Return: status code + */ +__weak efi_status_t platform_get_eventlog(struct udevice *dev, u64 *addr, + u32 *sz) +{ + const u64 *basep; + const u32 *sizep; + + basep = dev_read_prop(dev, "tpm_event_log_addr", NULL); + if (!basep) + return EFI_NOT_FOUND; + + *addr = be64_to_cpup((__force __be64 *)basep); + + sizep = dev_read_prop(dev, "tpm_event_log_size", NULL); + if (!sizep) + return EFI_NOT_FOUND; + + *sz = be32_to_cpup((__force __be32 *)sizep); + if (*sz == 0) { + log_debug("event log empty\n"); + return EFI_NOT_FOUND; + } + + return EFI_SUCCESS; +} + /** * tpm2_get_max_command_size() - get the supported max command size * @@ -1181,6 +1220,250 @@ static const struct efi_tcg2_protocol efi_tcg2_protocol = { .get_result_of_set_active_pcr_banks = efi_tcg2_get_result_of_set_active_pcr_banks, };
+/** + * parse_event_log_header() - Parse and verify the event log header fields + * + * @buffer: Pointer to the event header + * @size: Size of the eventlog + * @pos: Position in buffer after event log header + * + * Return: status code + */ +efi_status_t parse_event_log_header(void *buffer, u32 size, u32 *pos) +{ + struct tcg_pcr_event *event_header = (struct tcg_pcr_event *)buffer; + int i = 0; + + if (size < sizeof(*event_header)) + return EFI_COMPROMISED_DATA; + + if (get_unaligned_le32(&event_header->pcr_index) != 0 || + get_unaligned_le32(&event_header->event_type) != EV_NO_ACTION) + return EFI_COMPROMISED_DATA; + + for (i = 0; i < sizeof(event_header->digest); i++) { + if (event_header->digest[i] != 0) + return EFI_COMPROMISED_DATA; + } + + *pos += sizeof(*event_header); + + return EFI_SUCCESS; +} + +/** + * parse_specid_event() - Parse and verify the specID Event in the eventlog + * + * @dev: udevice + * @buffer: Pointer to the start of the eventlog + * @log_size: Size of the eventlog + * @pos: Offset in the evenlog where specID event starts + * + * Return: status code + * @pos Offset in the eventlog where the specID event ends + * @digest_list: list of digests in the event + */ +efi_status_t parse_specid_event(struct udevice *dev, void *buffer, u32 log_size, + u32 *pos, + struct tpml_digest_values *digest_list) +{ + struct tcg_efi_spec_id_event *spec_event; + struct tcg_pcr_event *event_header = (struct tcg_pcr_event *)buffer; + size_t spec_event_size; + u32 active = 0, supported = 0, pcr_count = 0, alg_count = 0; + u32 spec_active = 0; + u16 hash_alg, hash_sz; + u8 vendor_sz; + int err, i; + + /* Check specID event data */ + spec_event = (struct tcg_efi_spec_id_event *)((uintptr_t)buffer + *pos); + /* Check for signature */ + if (memcmp(spec_event->signature, TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03, + sizeof(TCG_EFI_SPEC_ID_EVENT_SIGNATURE_03))) { + log_err("specID Event: Signature mismatch\n"); + return EFI_COMPROMISED_DATA; + } + + if (spec_event->spec_version_minor != + TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MINOR_TPM2 || + spec_event->spec_version_major != + TCG_EFI_SPEC_ID_EVENT_SPEC_VERSION_MAJOR_TPM2) + return EFI_COMPROMISED_DATA; + + if (spec_event->number_of_algorithms > MAX_HASH_COUNT || + spec_event->number_of_algorithms < 1) { + log_err("specID Event: Number of algorithms incorrect\n"); + return EFI_COMPROMISED_DATA; + } + + alg_count = spec_event->number_of_algorithms; + + err = tpm2_get_pcr_info(dev, &supported, &active, &pcr_count); + if (err) + return EFI_DEVICE_ERROR; + + digest_list->count = 0; + /* + * We may need to worry about the order of algs in this structure as + * subsequent entries in event should be in same order + */ + for (i = 0; i < alg_count; i++) { + hash_alg = + get_unaligned_le16(&spec_event->digest_sizes[i].algorithm_id); + hash_sz = + get_unaligned_le16(&spec_event->digest_sizes[i].digest_size); + + if (!(supported & alg_to_mask(hash_alg))) { + log_err("specID Event: Unsupported algorithm\n"); + return EFI_COMPROMISED_DATA; + } + digest_list->digests[digest_list->count++].hash_alg = hash_alg; + + spec_active |= alg_to_mask(hash_alg); + } + + /* TCG spec expects the event log to have hashes for all active PCR's */ + if (spec_active != active) { + /* + * Previous stage bootloader should know all the active PCR's + * and use them in the Eventlog. + */ + log_err("specID Event: All active hash alg not present\n"); + return EFI_COMPROMISED_DATA; + } + + /* + * the size of the spec event and placement of vendor_info_size + * depends on supported algoriths + */ + spec_event_size = + offsetof(struct tcg_efi_spec_id_event, digest_sizes) + + alg_count * sizeof(spec_event->digest_sizes[0]); + + vendor_sz = *(uint8_t *)((uintptr_t)buffer + *pos + spec_event_size); + + spec_event_size += sizeof(vendor_sz) + vendor_sz; + *pos += spec_event_size; + + if (get_unaligned_le32(&event_header->event_size) != spec_event_size) { + log_err("specID event: header event size mismatch\n"); + /* Right way to handle this can be to call SetActive PCR's */ + return EFI_COMPROMISED_DATA; + } + + return EFI_SUCCESS; +} + +efi_status_t tcg2_parse_event(struct udevice *dev, void *buffer, u32 log_size, + u32 *offset, struct tpml_digest_values *digest_list, + u32 *pcr) +{ + struct tcg_pcr_event2 *event = NULL; + u32 event_type, count, size, event_size; + size_t pos; + + if (*offset > log_size) + return EFI_COMPROMISED_DATA; + + event = (struct tcg_pcr_event2 *)((uintptr_t)buffer + *offset); + + *pcr = get_unaligned_le32(&event->pcr_index); + + event_size = tcg_event_final_size(digest_list); + + if (*offset + event_size > log_size) { + log_err("Event exceeds log size\n"); + return EFI_COMPROMISED_DATA; + } + + event_type = get_unaligned_le32(&event->event_type); + + /* get the count */ + count = get_unaligned_le32(&event->digests.count); + if (count != digest_list->count) + return EFI_COMPROMISED_DATA; + + pos = offsetof(struct tcg_pcr_event2, digests); + pos += offsetof(struct tpml_digest_values, digests); + + for (int i = 0; i < digest_list->count; i++) { + u16 alg; + u16 hash_alg = digest_list->digests[i].hash_alg; + u8 *digest = (u8 *)&digest_list->digests[i].digest; + + alg = get_unaligned_le16((void *)((uintptr_t)event + pos)); + + if (alg != hash_alg) + return EFI_COMPROMISED_DATA; + + pos += offsetof(struct tpmt_ha, digest); + memcpy(digest, (void *)((uintptr_t)event + pos), alg_to_len(hash_alg)); + pos += alg_to_len(hash_alg); + } + + size = get_unaligned_le32((void *)((uintptr_t)event + pos)); + event_size += size; + pos += sizeof(u32); /* tcg_pcr_event2 event_size*/ + pos += size; + + /* make sure the calculated buffer is what we checked against */ + if (pos != event_size) + return EFI_COMPROMISED_DATA; + + if (pos > log_size) + return EFI_COMPROMISED_DATA; + + *offset += pos; + + return EFI_SUCCESS; +} + +efi_status_t tcg2_get_fw_eventlog(struct udevice *dev, void *log_buffer, + size_t *log_sz) +{ + struct tpml_digest_values digest_list; + void *buffer; + efi_status_t ret; + u32 pcr, pos; + u64 base; + u32 sz; + + ret = platform_get_eventlog(dev, &base, &sz); + if (ret != EFI_SUCCESS) + return ret; + + if (sz > TPM2_EVENT_LOG_SIZE) + return EFI_VOLUME_FULL; + + buffer = (void *)base; + pos = 0; + /* Parse the eventlog to check for its validity */ + ret = parse_event_log_header(buffer, sz, &pos); + if (ret || pos > sz) + return EFI_COMPROMISED_DATA; + + ret = parse_specid_event(dev, buffer, sz, &pos, &digest_list); + if (ret || pos > sz) { + log_err("Error parsing SPEC ID Event\n"); + return EFI_COMPROMISED_DATA; + } + + while (pos < sz) { + ret = tcg2_parse_event(dev, buffer, sz, &pos, &digest_list, + &pcr); + if (ret) { + log_err("Error parsing event\n"); + return ret; + } + } + + memcpy(log_buffer, buffer, sz); + *log_sz = sz; + + return ret; +} + /** * create_specid_event() - Create the first event in the eventlog * @@ -1340,6 +1623,12 @@ static efi_status_t efi_init_event_log(void) * last log entry */ memset(event_log.buffer, 0xff, TPM2_EVENT_LOG_SIZE); + + /* + * The log header is defined to be in SHA1 event log entry format. + * Setup event header + */ + event_header = (struct tcg_pcr_event *)event_log.buffer; event_log.pos = 0; event_log.last_event_size = 0; event_log.get_event_called = false; @@ -1347,20 +1636,31 @@ static efi_status_t efi_init_event_log(void) event_log.truncated = false;
/* - * The log header is defined to be in SHA1 event log entry format. - * Setup event header + * Check if earlier firmware have passed any eventlog. Different + * platforms can use different ways to do so */ - event_header = (struct tcg_pcr_event *)event_log.buffer; - put_unaligned_le32(0, &event_header->pcr_index); - put_unaligned_le32(EV_NO_ACTION, &event_header->event_type); - memset(&event_header->digest, 0, sizeof(event_header->digest)); - ret = create_specid_event(dev, (void *)((uintptr_t)event_log.buffer + sizeof(*event_header)), - &spec_event_size); + ret = tcg2_get_fw_eventlog(dev, event_log.buffer, &event_log.pos); + /* + * If earlier firmware hasn't passed any eventlog, go ahead and + * create the eventlog header + */ + if (ret == EFI_NOT_FOUND) { + put_unaligned_le32(0, &event_header->pcr_index); + put_unaligned_le32(EV_NO_ACTION, &event_header->event_type); + memset(&event_header->digest, 0, sizeof(event_header->digest)); + ret = create_specid_event(dev, + (void *)((uintptr_t)event_log.buffer + + sizeof(*event_header)), + &spec_event_size); + if (ret != EFI_SUCCESS) + goto free_pool; + put_unaligned_le32(spec_event_size, &event_header->event_size); + event_log.pos = spec_event_size + sizeof(*event_header); + event_log.last_event_size = event_log.pos; + } + if (ret != EFI_SUCCESS) goto free_pool; - put_unaligned_le32(spec_event_size, &event_header->event_size); - event_log.pos = spec_event_size + sizeof(*event_header); - event_log.last_event_size = event_log.pos;
ret = create_final_event(); if (ret != EFI_SUCCESS)
The current tpm2_pcr_read is hardcoded using SHA256. Make the actual command to TPM configurable to use wider range of algorithms. The current command line is kept as is i.e limited to SHA-256 only.
Signed-off-by: Ruchika Gupta ruchika.gupta@linaro.org --- v3: No change
v2: Change algorithm from u32 to u16 Add parameter description in function declaration
cmd/tpm-v2.c | 3 ++- include/tpm-v2.h | 5 ++++- lib/tpm-v2.c | 12 ++++++++---- 3 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/cmd/tpm-v2.c b/cmd/tpm-v2.c index daae91100a..4ea5f9f094 100644 --- a/cmd/tpm-v2.c +++ b/cmd/tpm-v2.c @@ -151,7 +151,8 @@ static int do_tpm_pcr_read(struct cmd_tbl *cmdtp, int flag, int argc,
data = map_sysmem(simple_strtoul(argv[2], NULL, 0), 0);
- rc = tpm2_pcr_read(dev, index, priv->pcr_select_min, data, &updates); + rc = tpm2_pcr_read(dev, index, priv->pcr_select_min, TPM2_ALG_SHA256, + data, TPM2_DIGEST_LEN, &updates); if (!rc) { printf("PCR #%u content (%u known updates):\n", index, updates); print_byte_string(data, TPM2_DIGEST_LEN); diff --git a/include/tpm-v2.h b/include/tpm-v2.h index ceff7d245e..4e9dd52cb6 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -512,13 +512,16 @@ u32 tpm2_nv_write_value(struct udevice *dev, u32 index, const void *data, * @dev TPM device * @idx Index of the PCR * @idx_min_sz Minimum size in bytes of the pcrSelect array + * @algorithm Algorithm used, defined in 'enum tpm2_algorithms' * @data Output buffer for contents of the named PCR + * @digest_len len of the data * @updates Optional out parameter: number of updates for this PCR * * @return code of the operation */ u32 tpm2_pcr_read(struct udevice *dev, u32 idx, unsigned int idx_min_sz, - void *data, unsigned int *updates); + u16 algorithm, void *data, u32 digest_len, + unsigned int *updates);
/** * Issue a TPM2_GetCapability command. This implementation is limited diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 2e7b27bd6b..1bf627853a 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -254,7 +254,8 @@ u32 tpm2_nv_write_value(struct udevice *dev, u32 index, const void *data, }
u32 tpm2_pcr_read(struct udevice *dev, u32 idx, unsigned int idx_min_sz, - void *data, unsigned int *updates) + u16 algorithm, void *data, u32 digest_len, + unsigned int *updates) { u8 idx_array_sz = max(idx_min_sz, DIV_ROUND_UP(idx, 8)); u8 command_v2[COMMAND_BUFFER_SIZE] = { @@ -264,7 +265,7 @@ u32 tpm2_pcr_read(struct udevice *dev, u32 idx, unsigned int idx_min_sz,
/* TPML_PCR_SELECTION */ tpm_u32(1), /* Number of selections */ - tpm_u16(TPM2_ALG_SHA256), /* Algorithm of the hash */ + tpm_u16(algorithm), /* Algorithm of the hash */ idx_array_sz, /* Array size for selection */ /* bitmap(idx) Selected PCR bitmap */ }; @@ -283,10 +284,13 @@ u32 tpm2_pcr_read(struct udevice *dev, u32 idx, unsigned int idx_min_sz, if (ret) return ret;
+ if (digest_len > response_len) + return TPM_LIB_ERROR; + if (unpack_byte_string(response, response_len, "ds", 10, &counter, - response_len - TPM2_DIGEST_LEN, data, - TPM2_DIGEST_LEN)) + response_len - digest_len, data, + digest_len)) return TPM_LIB_ERROR;
if (updates)
v3: No change
- rc = tpm2_pcr_read(dev, index, priv->pcr_select_min, TPM2_ALG_SHA256,
if (!rc) { printf("PCR #%u content (%u known updates):\n", index, updates); print_byte_string(data, TPM2_DIGEST_LEN);data, TPM2_DIGEST_LEN, &updates);
- @dev TPM device
- @idx Index of the PCR
- @idx_min_sz Minimum size in bytes of the pcrSelect array
- @algorithm Algorithm used, defined in 'enum tpm2_algorithms'
- @data Output buffer for contents of the named PCR
- @digest_len len of the data
- @updates Optional out parameter: number of updates for this PCR
- @return code of the operation
- Issue a TPM2_GetCapability command. This implementation is limited
idx_array_sz, /* Array size for selection */ /* bitmap(idx) Selected PCR bitmap */ };tpm_u16(algorithm), /* Algorithm of the hash */
- if (digest_len > response_len)
- if (unpack_byte_string(response, response_len, "ds", 10, &counter,
TPM2_DIGEST_LEN))
digest_len))
if (updates)
-- 2.25.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Firmwares before U-Boot may be capable of doing tpm measurements and passing them to U-Boot in the form of eventlog. However there may be scenarios where the firmwares don't have TPM driver and are not capable of extending the measurements in the PCRs. Based on TCG spec, if previous firnware has extended PCR's, PCR0 would not be 0. So, read the PCR0 to determine if the PCR's need to be extended as eventlog is parsed or not.
Signed-off-by: Ruchika Gupta ruchika.gupta@linaro.org --- v3 : Rebase changes on top of changes made in first patch of series
v2 : Removed check for PCR0 in eventlog
lib/efi_loader/efi_tcg2.c | 75 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 75 insertions(+)
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index ebd7847957..b5343bf039 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -199,6 +199,43 @@ static efi_status_t tcg2_pcr_extend(struct udevice *dev, u32 pcr_index, return EFI_SUCCESS; }
+/* tcg2_pcr_read - Read PCRs for a TPM2 device for a given tpml_digest_values + * + * @dev: device + * @digest_list: list of digest algorithms to extend + * + * @Return: status code + */ +static efi_status_t tcg2_pcr_read(struct udevice *dev, u32 pcr_index, + struct tpml_digest_values *digest_list) +{ + struct tpm_chip_priv *priv; + unsigned int updates, pcr_select_min; + u32 rc; + size_t i; + + priv = dev_get_uclass_priv(dev); + if (!priv) + return EFI_DEVICE_ERROR; + + pcr_select_min = priv->pcr_select_min; + + for (i = 0; i < digest_list->count; i++) { + u16 hash_alg = digest_list->digests[i].hash_alg; + u8 *digest = (u8 *)&digest_list->digests[i].digest; + + rc = tpm2_pcr_read(dev, pcr_index, pcr_select_min, + hash_alg, digest, alg_to_len(hash_alg), + &updates); + if (rc) { + EFI_PRINT("Failed to read PCR\n"); + return EFI_DEVICE_ERROR; + } + } + + return EFI_SUCCESS; +} + /* put_event - Append an agile event to an eventlog * * @pcr_index: PCR index @@ -1428,6 +1465,8 @@ efi_status_t tcg2_get_fw_eventlog(struct udevice *dev, void *log_buffer, u32 pcr, pos; u64 base; u32 sz; + bool extend_pcr = false; + int i;
ret = platform_get_eventlog(dev, &base, &sz); if (ret != EFI_SUCCESS) @@ -1449,6 +1488,26 @@ efi_status_t tcg2_get_fw_eventlog(struct udevice *dev, void *log_buffer, return EFI_COMPROMISED_DATA; }
+ ret = tcg2_pcr_read(dev, 0, &digest_list); + if (ret) { + log_err("Error reading PCR 0\n"); + return ret; + } + + /* + * If PCR0 is 0, previous firmware didn't have the capability + * to extend the PCR. In this scenario, extend the PCR as + * the eventlog is parsed. + */ + for (i = 0; i < digest_list.count; i++) { + u8 buffer[TPM2_DIGEST_LEN] = { 0 }; + u16 hash_alg = digest_list.digests[i].hash_alg; + + if (!memcmp((u8 *)&digest_list.digests[i].digest, buffer, + alg_to_len(hash_alg))) + extend_pcr = true; + } + while (pos < sz) { ret = tcg2_parse_event(dev, buffer, sz, &pos, &digest_list, &pcr); @@ -1456,6 +1515,22 @@ efi_status_t tcg2_get_fw_eventlog(struct udevice *dev, void *log_buffer, log_err("Error parsing event\n"); return ret; } + if (extend_pcr) { + ret = tcg2_pcr_extend(dev, pcr, &digest_list); + if (ret != EFI_SUCCESS) { + log_err("Error in extending PCR\n"); + return ret; + } + + /* Clear the digest for next event */ + for (i = 0; i < digest_list.count; i++) { + u16 hash_alg = digest_list.digests[i].hash_alg; + u8 *digest = + (u8 *)&digest_list.digests[i].digest; + + memset(digest, 0, alg_to_len(hash_alg)); + } + } }
- @dev: device
- @digest_list: list of digest algorithms to extend
- @Return: status code
- struct tpm_chip_priv *priv;
- unsigned int updates, pcr_select_min;
- u32 rc;
- size_t i;
- priv = dev_get_uclass_priv(dev);
- if (!priv)
- pcr_select_min = priv->pcr_select_min;
- for (i = 0; i < digest_list->count; i++) {
&updates);
if (rc) {
- return EFI_SUCCESS;
- @pcr_index: PCR index
int i;
- ret = tcg2_pcr_read(dev, 0, &digest_list);
- if (ret) {
return ret;
- for (i = 0; i < digest_list.count; i++) {
extend_pcr = true;
- while (pos < sz) { ret = tcg2_parse_event(dev, buffer, sz, &pos, &digest_list, &pcr);
if (extend_pcr) {
return ret;
u8 *digest =
-- 2.25.1
- ret = tcg2_get_fw_eventlog(dev, event_log.buffer, &event_log.pos);
- if (ret == EFI_NOT_FOUND) {
&spec_event_size);
goto free_pool;
- if (ret != EFI_SUCCESS) goto free_pool;
-- 2.25.1
I think Kojima-san is right. I don't think it's a good idea to turn our startup code into a 'PC client spec' parser and try to reason about previous events. The Spec is pretty clear on "3.2.3.1 Firmware Boot Block SRTM". Specifically it says:
"In this architecture, the Platform Firmware is composed of a Boot Block (SEC/PEI/IBB) and a UEFI firmware. Each of these is an independent component and each can be updated independent of the other. In this architecture, the Boot Block is the SRTM while the UEFI Firmware is not but is a measured component of chain of trust".
So in our case the (SEC/PEI/IBB) is basically TF-A. So TF-A should compose the S_CRTM_VERSION event. If it doesn't we need to go back to TF-A and fix it. I think unconditionally removing it from u-boot makes more sense, rather that parse events and try to figure out if the previous loader has a bug....
Regards /Ilias
Ilias Apalodimas
Ruchika Gupta
