[U-Boot] Please pull u-boot-rockchip
Hi Tom,
Here is additional rk3368 and rk3399 support, rv1108 support, refactoring HDMI video (brought in from Anatolij's tree to resolve conflicts), some mkimage fixes and a few other things.
New boards supported are:
aarch64: sheep-rk3368 evb-px5 geekbox arm: evb-rv1108
The following changes since commit 24796d27be0d0f403ed6ad7e3022b33e36ac08b5:
Merge git://git.denx.de/u-boot-ubi (2017-06-06 07:13:39 -0400)
git://git.denx.de/u-boot-rockchip.git
for you to fetch changes up to 6c53d680c6b57bb9617a93cd1e92c242ae0aab21:
rockchip: board: puma_rk3399: enable BMP_16BPP, BMP_24BPP and BMP_32BPP (2017-06-07 21:30:50 -0600)
---------------------------------------------------------------- Andreas Färber (2): rockchip: rk3368: Add core start-up code for RK3368 rockchip: rk3368: Add initial support for RK3368 based GeekBox
Andy Yan (10): rockchip: rk3368: Add clock driver rockchip: rk3368: Add pinctrl driver rockchip: rk3368: Add sysreset driver rockchip: rk3368: add Sheep board rockchip: rk3368: Add PX5 Evaluation board rockchip: mkimage: Add support for RV1108 rockchip: pinctrl: Add rv1108 pinctrl driver rockchip: clk: Add rv1108 clock driver rockchip: Add core Soc start-up code for rv1108 rockchip: Add basic support for evb-rv1108 board
Heiko Stübner (2): defconfig: firefly-rk3399: fix pinctrl config option power: rk808: fix ldo register offset
Kever Yang (10): rockchip; rk3399: disable SRAM security region rockchip: rk8xx: allocate priv structure for driver rockchip: rk3036: clean mask definition for cru reg rockchip: clock: rk3036: some fix according TRM rockchip: rk3036: clean mask definition for grf reg rockchip: pinctrl: move rk3328 grf reg definition in header file rockchip: pinctrl: rk3328: do not set io routing MAINTAINERS: git-mailrc: update maintainer for Rockchip MAINTAINERS: rockchip: add board/rockchip as maintained entry rockchip: evb-rk3328: update board maintainer
Klaus Goger (2): rockchip: board: puma_rk3399: derive ethaddr from cpuid rockchip: dts: rk3399-puma: set spl-payload-offset
Mark Kettenis (1): regulator: pwm: Fix handling of missing init voltage
Meng Dongyang (5): configs: rk3328: add support for usb and config ehci and ohci driver rockchip: dts: rk3328: add ehci and ohci node and enable host0 port configs: rk3328: config xhci controller rockchip: dts: rk3328: support and enable xhci rockchip: usb: host: xhci-rockchip: add support for rk3328
Philipp Tomsich (35): rockchip: efuse: add (misc) driver for RK3399 non-secure efuse block rockchip: board: puma_rk3399: add support for serial# and cpuid# via efuses rockchip: defconfig: puma-rk3399: enable RK3399 efuse driver rockchip: board: puma_rk3399: build FIT image via u-boot.itb rockchip: mkimage: add support for verify_header/print_header rockchip: mkimage: force 2KB alignment for init_size rockchip: mkimage: set init_boot_size to avoid confusing the boot ROM rockchip: arm64: rk3399: revise timeout-handling for DRAM PHY lock rockchip: arm64: rk3399: support DDR3-1866 (i.e. 933MHz clock) rockchip: dts: rk3399-puma: Add DDR3-1866 timings rockchip: dts: rk3399-puma: make the debug serial dm-pre-reloc rockchip: dts: rk3399-puma: release reset of on-module USB3 hub via vbus-gpio rockchip: defconfig: puma-rk3399: enable RK808 support rockchip: defconfig: puma-rk3399: enable CONFIG_PHY_MICREL_KSZ9031 rockchip: defconfig: puma-rk3399: enable I2C rockchip: defconfig: puma-rk3399: do not filter clock-names for SPL rockchip: rk3328: don't implement usb_gadget_handle_interrupts twice rockchip: video: rk_hdmi: fix implicit definition warnings rockchip: defconfig: puma-rk3399: update defconfig with video-support usb: dwc2-otg: make regs_otg (in platdata) a uintptr_t rockchip: dts: rk3399: enable HDMI output in the DTS rockchip: dts: rk3399-puma: sync DTS with Linux tree rockchip: dts: rk3399-puma: refactor and rename (default) DDR3-1600 DTS rockchip: dts: rk3399-puma: add DTS for the DDR3-1333 timing rockchip: dts: rk3399-puma: add DTS for the DDR3-1866 timing rockchip: defconfig: puma-rk3399: enable SPL_BOARD_INIT rockchip: video: Kconfig: reformat help for VIDEO_ROCKCHIP rockchip: video: Kconfig: set MAX_XRES and MAX_YRES via Kconfig rockchip: video: refactor rk_vop and split RK3288-specific code off rockchip: video: rk3399: enable HDMI output (from the rk_vop) for the RK3399 rockchip: video: add mpixelclock settings from Linux driver rockchip: video: split RK3288-specific part off from rk_hdmi rockchip: video: rk3399: add HDMI TX support on the RK3399 rockchip: video: rk_vop: add grf field rockchip: board: puma_rk3399: enable BMP_16BPP, BMP_24BPP and BMP_32BPP
Romain Perier (1): rockchip: rk3288: grf: Fix shift for RK3288_TXCLK_DLY_ENA_GMAC_ENABLE
MAINTAINERS | 1 + arch/arm/dts/Makefile | 8 +- arch/arm/dts/rk3328-evb.dts | 13 + arch/arm/dts/rk3328.dtsi | 25 + arch/arm/dts/rk3368-geekbox.dts | 319 +++++ arch/arm/dts/rk3368-px5-evb.dts | 319 +++++ arch/arm/dts/rk3368-sheep.dts | 283 ++++ arch/arm/dts/rk3368.dtsi | 1090 +++++++++++++++ arch/arm/dts/rk3399-puma-ddr1333.dts | 11 + arch/arm/dts/rk3399-puma-ddr1600.dts | 11 + arch/arm/dts/rk3399-puma-ddr1866.dts | 11 + arch/arm/dts/rk3399-puma.dts | 192 --- arch/arm/dts/rk3399-puma.dtsi | 642 +++++++++ arch/arm/dts/rk3399-sdram-ddr3-1866.dtsi | 1537 +++++++++++++++++++++ arch/arm/dts/rk3399.dtsi | 39 + arch/arm/dts/rv1108-evb.dts | 54 + arch/arm/dts/rv1108.dtsi | 479 +++++++ arch/arm/include/asm/arch-rockchip/cru_rk3036.h | 76 +- arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 124 ++ arch/arm/include/asm/arch-rockchip/cru_rv1108.h | 111 ++ arch/arm/include/asm/arch-rockchip/grf_rk3036.h | 133 +- arch/arm/include/asm/arch-rockchip/grf_rk3288.h | 2 +- arch/arm/include/asm/arch-rockchip/grf_rk3328.h | 114 ++ arch/arm/include/asm/arch-rockchip/grf_rk3368.h | 440 ++++++ arch/arm/include/asm/arch-rockchip/grf_rk3399.h | 3 + arch/arm/include/asm/arch-rockchip/grf_rv1108.h | 509 +++++++ arch/arm/include/asm/arch-rockchip/periph.h | 1 + arch/arm/include/asm/arch-rockchip/vop_rk3288.h | 11 + arch/arm/mach-rockchip/Kconfig | 21 + arch/arm/mach-rockchip/Makefile | 2 + arch/arm/mach-rockchip/rk3368/Kconfig | 32 + arch/arm/mach-rockchip/rk3368/Makefile | 8 + arch/arm/mach-rockchip/rk3368/clk_rk3368.c | 32 + arch/arm/mach-rockchip/rk3368/rk3368.c | 86 ++ arch/arm/mach-rockchip/rk3368/syscon_rk3368.c | 24 + arch/arm/mach-rockchip/rk3399-board-spl.c | 8 +- arch/arm/mach-rockchip/rk3399/sdram_rk3399.c | 19 +- arch/arm/mach-rockchip/rv1108/Kconfig | 28 + arch/arm/mach-rockchip/rv1108/Makefile | 11 + arch/arm/mach-rockchip/rv1108/clk_rv1108.c | 32 + arch/arm/mach-rockchip/rv1108/rv1108.c | 15 + arch/arm/mach-rockchip/rv1108/syscon_rv1108.c | 21 + board/geekbuying/geekbox/Kconfig | 15 + board/geekbuying/geekbox/MAINTAINERS | 6 + board/geekbuying/geekbox/Makefile | 7 + board/geekbuying/geekbox/README | 1 + board/geekbuying/geekbox/geekbox.c | 28 + board/rockchip/evb_px5/Kconfig | 15 + board/rockchip/evb_px5/MAINTAINERS | 6 + board/rockchip/evb_px5/Makefile | 7 + board/rockchip/evb_px5/README | 1 + board/rockchip/evb_px5/evb-px5.c | 51 + board/rockchip/evb_rk3328/MAINTAINERS | 2 +- board/rockchip/evb_rk3328/evb-rk3328.c | 5 - board/rockchip/evb_rv1108/Kconfig | 15 + board/rockchip/evb_rv1108/MAINTAINERS | 6 + board/rockchip/evb_rv1108/Makefile | 7 + board/rockchip/evb_rv1108/README | 47 + board/rockchip/evb_rv1108/evb_rv1108.c | 52 + board/rockchip/sheep_rk3368/Kconfig | 15 + board/rockchip/sheep_rk3368/MAINTAINERS | 6 + board/rockchip/sheep_rk3368/Makefile | 7 + board/rockchip/sheep_rk3368/README | 44 + board/rockchip/sheep_rk3368/sheep_rk3368.c | 37 + board/theobroma-systems/puma_rk3399/README | 5 +- board/theobroma-systems/puma_rk3399/puma-rk3399.c | 118 ++ configs/evb-px5_defconfig | 30 + configs/evb-rk3328_defconfig | 11 + configs/evb-rv1108_defconfig | 40 + configs/firefly-rk3399_defconfig | 2 +- configs/geekbox_defconfig | 22 + configs/puma-rk3399_defconfig | 25 +- configs/sheep-rk3368_defconfig | 28 + doc/git-mailrc | 2 +- drivers/clk/rockchip/Makefile | 2 + drivers/clk/rockchip/clk_rk3036.c | 93 +- drivers/clk/rockchip/clk_rk3368.c | 291 ++++ drivers/clk/rockchip/clk_rv1108.c | 223 +++ drivers/misc/Kconfig | 13 + drivers/misc/Makefile | 1 + drivers/misc/rockchip-efuse.c | 161 +++ drivers/pinctrl/Kconfig | 20 + drivers/pinctrl/rockchip/Makefile | 2 + drivers/pinctrl/rockchip/pinctrl_rk3036.c | 44 +- drivers/pinctrl/rockchip/pinctrl_rk3328.c | 228 +-- drivers/pinctrl/rockchip/pinctrl_rk3368.c | 149 ++ drivers/pinctrl/rockchip/pinctrl_rv1108.c | 184 +++ drivers/power/pmic/rk8xx.c | 1 + drivers/power/regulator/pwm_regulator.c | 8 +- drivers/power/regulator/rk8xx.c | 4 +- drivers/sysreset/Makefile | 2 + drivers/sysreset/sysreset_rk3368.c | 62 + drivers/sysreset/sysreset_rv1108.c | 46 + drivers/usb/host/xhci-rockchip.c | 31 +- drivers/video/rockchip/Kconfig | 29 +- drivers/video/rockchip/Makefile | 6 +- drivers/video/rockchip/rk3288_hdmi.c | 116 ++ drivers/video/rockchip/rk3288_vop.c | 95 ++ drivers/video/rockchip/rk3399_hdmi.c | 81 ++ drivers/video/rockchip/rk3399_vop.c | 105 ++ drivers/video/rockchip/rk_hdmi.c | 115 +- drivers/video/rockchip/rk_hdmi.h | 32 + drivers/video/rockchip/rk_vop.c | 185 ++- drivers/video/rockchip/rk_vop.h | 33 + include/configs/evb_px5.h | 17 + include/configs/evb_rv1108.h | 26 + include/configs/geekbox.h | 17 + include/configs/puma_rk3399.h | 8 + include/configs/rk3328_common.h | 6 + include/configs/rk3368_common.h | 49 + include/configs/rv1108_common.h | 33 + include/configs/sheep_rk3368.h | 21 + include/dt-bindings/clock/rk3368-cru.h | 384 +++++ include/dt-bindings/clock/rv1108-cru.h | 269 ++++ include/usb/dwc2_udc.h | 2 +- tools/rkcommon.c | 131 +- tools/rkcommon.h | 20 + tools/rksd.c | 35 +- tools/rkspi.c | 23 +- 119 files changed, 10141 insertions(+), 822 deletions(-) create mode 100644 arch/arm/dts/rk3368-geekbox.dts create mode 100644 arch/arm/dts/rk3368-px5-evb.dts create mode 100644 arch/arm/dts/rk3368-sheep.dts create mode 100644 arch/arm/dts/rk3368.dtsi create mode 100644 arch/arm/dts/rk3399-puma-ddr1333.dts create mode 100644 arch/arm/dts/rk3399-puma-ddr1600.dts create mode 100644 arch/arm/dts/rk3399-puma-ddr1866.dts delete mode 100644 arch/arm/dts/rk3399-puma.dts create mode 100644 arch/arm/dts/rk3399-puma.dtsi create mode 100644 arch/arm/dts/rk3399-sdram-ddr3-1866.dtsi create mode 100644 arch/arm/dts/rv1108-evb.dts create mode 100644 arch/arm/dts/rv1108.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk3368.h create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rv1108.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk3368.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rv1108.h create mode 100644 arch/arm/mach-rockchip/rk3368/Kconfig create mode 100644 arch/arm/mach-rockchip/rk3368/Makefile create mode 100644 arch/arm/mach-rockchip/rk3368/clk_rk3368.c create mode 100644 arch/arm/mach-rockchip/rk3368/rk3368.c create mode 100644 arch/arm/mach-rockchip/rk3368/syscon_rk3368.c create mode 100644 arch/arm/mach-rockchip/rv1108/Kconfig create mode 100644 arch/arm/mach-rockchip/rv1108/Makefile create mode 100644 arch/arm/mach-rockchip/rv1108/clk_rv1108.c create mode 100644 arch/arm/mach-rockchip/rv1108/rv1108.c create mode 100644 arch/arm/mach-rockchip/rv1108/syscon_rv1108.c create mode 100644 board/geekbuying/geekbox/Kconfig create mode 100644 board/geekbuying/geekbox/MAINTAINERS create mode 100644 board/geekbuying/geekbox/Makefile create mode 100644 board/geekbuying/geekbox/README create mode 100644 board/geekbuying/geekbox/geekbox.c create mode 100644 board/rockchip/evb_px5/Kconfig create mode 100644 board/rockchip/evb_px5/MAINTAINERS create mode 100644 board/rockchip/evb_px5/Makefile create mode 100644 board/rockchip/evb_px5/README create mode 100644 board/rockchip/evb_px5/evb-px5.c create mode 100644 board/rockchip/evb_rv1108/Kconfig create mode 100644 board/rockchip/evb_rv1108/MAINTAINERS create mode 100644 board/rockchip/evb_rv1108/Makefile create mode 100644 board/rockchip/evb_rv1108/README create mode 100644 board/rockchip/evb_rv1108/evb_rv1108.c create mode 100644 board/rockchip/sheep_rk3368/Kconfig create mode 100644 board/rockchip/sheep_rk3368/MAINTAINERS create mode 100644 board/rockchip/sheep_rk3368/Makefile create mode 100644 board/rockchip/sheep_rk3368/README create mode 100644 board/rockchip/sheep_rk3368/sheep_rk3368.c create mode 100644 configs/evb-px5_defconfig create mode 100644 configs/evb-rv1108_defconfig create mode 100644 configs/geekbox_defconfig create mode 100644 configs/sheep-rk3368_defconfig create mode 100644 drivers/clk/rockchip/clk_rk3368.c create mode 100644 drivers/clk/rockchip/clk_rv1108.c create mode 100644 drivers/misc/rockchip-efuse.c create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk3368.c create mode 100644 drivers/pinctrl/rockchip/pinctrl_rv1108.c create mode 100644 drivers/sysreset/sysreset_rk3368.c create mode 100644 drivers/sysreset/sysreset_rv1108.c create mode 100644 drivers/video/rockchip/rk3288_hdmi.c create mode 100644 drivers/video/rockchip/rk3288_vop.c create mode 100644 drivers/video/rockchip/rk3399_hdmi.c create mode 100644 drivers/video/rockchip/rk3399_vop.c create mode 100644 drivers/video/rockchip/rk_hdmi.h create mode 100644 drivers/video/rockchip/rk_vop.h create mode 100644 include/configs/evb_px5.h create mode 100644 include/configs/evb_rv1108.h create mode 100644 include/configs/geekbox.h create mode 100644 include/configs/rk3368_common.h create mode 100644 include/configs/rv1108_common.h create mode 100644 include/configs/sheep_rk3368.h create mode 100644 include/dt-bindings/clock/rk3368-cru.h create mode 100644 include/dt-bindings/clock/rv1108-cru.h
On Thu, Jun 08, 2017 at 06:53:32AM -0600, Simon Glass wrote:
Hi Tom,
