[U-Boot] [PATCH 6/7] Implement SC520 timers
Signed-off-by: Graeme Russ <graeme.russ at gmail.com> --- cpu/i386/Makefile | 2 cpu/i386/sc520/sc520_timer.c | 71 ++++++++----- cpu/i386/timer.c | 211 ---------------------------------------- include/asm-i386/u-boot-i386.h | 7 + lib_i386/Makefile | 2 lib_i386/pcat_timer.c | 102 +++++++++++++++++++ lib_i386/timer.c | 107 ++++++++++++++++++++ 7 files changed, 259 insertions(+), 243 deletions(-) delete mode 100644 cpu/i386/timer.c create mode 100644 lib_i386/pcat_timer.c create mode 100644 lib_i386/timer.c
diff --git a/cpu/i386/Makefile b/cpu/i386/Makefile index f72cd6e..e98bd3d 100644 --- a/cpu/i386/Makefile +++ b/cpu/i386/Makefile @@ -29,7 +29,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
START = start.o start16.o resetvec.o -COBJS = serial.o interrupts.o exceptions.o cpu.o timer.o +COBJS = serial.o interrupts.o exceptions.o cpu.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/cpu/i386/sc520/sc520_timer.c b/cpu/i386/sc520/sc520_timer.c index 7578511..2cb8656 100644 --- a/cpu/i386/sc520/sc520_timer.c +++ b/cpu/i386/sc520/sc520_timer.c @@ -27,47 +27,56 @@ #include <asm/interrupt.h> #include <asm/ic/sc520.h>
-void reset_timer(void) +void sc520_timer_isr(void) { - write_mmcr_word(SC520_GPTMR0CNT, 0); - write_mmcr_word(SC520_GPTMR0CTL, 0x6001); - + /* Ack the GP Timer Interrupt */ + write_mmcr_byte (SC520_GPTMRSTA, 0x02); }
-ulong get_timer(ulong base) +int timer_init(void) { - /* fixme: 30 or 33 */ - return read_mmcr_word(SC520_GPTMR0CNT) / 33; -} + /* Map GP Timer 1 to Master PIC IR0 */ + write_mmcr_byte (SC520_GPTMR1MAP, 0x01);
-void set_timer(ulong t) -{ - /* FixMe: use two cascade coupled timers */ - write_mmcr_word(SC520_GPTMR0CTL, 0x4001); - write_mmcr_word(SC520_GPTMR0CNT, t*33); - write_mmcr_word(SC520_GPTMR0CTL, 0x6001); -} + /* Disable GP Timers 1 & 2 - Allow configuration writes */ + write_mmcr_word (SC520_GPTMR1CTL, 0x4000); + write_mmcr_word (SC520_GPTMR2CTL, 0x4000); + + /* Reset GP Timers 1 & 2 */ + write_mmcr_word (SC520_GPTMR1CNT, 0x0000); + write_mmcr_word (SC520_GPTMR2CNT, 0x0000); + + /* Setup GP Timer 2 as a 100kHz (10us) prescaler */ + write_mmcr_word (SC520_GPTMR2MAXCMPA, 83); + write_mmcr_word (SC520_GPTMR2CTL, 0xc001); + + /* Setup GP Timer 1 as a 1000 Hz (1ms) interrupt generator */ + write_mmcr_word (SC520_GPTMR1MAXCMPA, 100); + write_mmcr_word (SC520_GPTMR1CTL, 0xe009);
+ /* Clear the GP Timers status register */ + write_mmcr_byte (SC520_GPTMRSTA, 0x07); + + /* Register the SC520 specific timer interrupt handler */ + register_timer_isr (sc520_timer_isr); + + /* Install interrupt handler for GP Timer 1 */ + irq_install_handler (0, timer_isr, NULL); + unmask_irq (0); + + return 0; +}
void udelay(unsigned long usec) { - int m=0; + int m = 0; long u;
- read_mmcr_word(SC520_SWTMRMILLI); - read_mmcr_word(SC520_SWTMRMICRO); - -#if 0 - /* do not enable this line, udelay is used in the serial driver -> recursion */ - printf("udelay: %ld m.u %d.%d tm.tu %d.%d\n", usec, m, u, tm, tu); -#endif - while (1) { - - m += read_mmcr_word(SC520_SWTMRMILLI); - u = read_mmcr_word(SC520_SWTMRMICRO) + (m * 1000); + read_mmcr_word (SC520_SWTMRMILLI); + read_mmcr_word (SC520_SWTMRMICRO);
- if (usec <= u) { - break; - } - } + do { + m += read_mmcr_word (SC520_SWTMRMILLI); + u = read_mmcr_word (SC520_SWTMRMICRO) + (m * 1000); + } while (u < usec); } diff --git a/cpu/i386/timer.c b/cpu/i386/timer.c deleted file mode 100644 index 79039c2..0000000 --- a/cpu/i386/timer.c +++ /dev/null @@ -1,211 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/i8254.h> -#include <asm/ibmpc.h> - - -static volatile unsigned long system_ticks; -static int timer_init_done =0; - -static void timer_isr(void *unused) -{ - system_ticks++; -} - -unsigned long get_system_ticks(void) -{ - return system_ticks; -} - -#define TIMER0_VALUE 0x04aa /* 1kHz 1.9318MHz / 1000 */ -#define TIMER2_VALUE 0x0a8e /* 440Hz */ - -int timer_init(void) -{ - system_ticks = 0; - - irq_install_handler(0, timer_isr, NULL); - - /* initialize timer 0 and 2 - * - * Timer 0 is used to increment system_tick 1000 times/sec - * Timer 1 was used for DRAM refresh in early PC's - * Timer 2 is used to drive the speaker - * (to stasrt a beep: write 3 to port 0x61, - * to stop it again: write 0) - */ - - outb(PIT_CMD_CTR0|PIT_CMD_BOTH|PIT_CMD_MODE2, PIT_BASE + PIT_COMMAND); - outb(TIMER0_VALUE&0xff, PIT_BASE + PIT_T0); - outb(TIMER0_VALUE>>8, PIT_BASE + PIT_T0); - - outb(PIT_CMD_CTR2|PIT_CMD_BOTH|PIT_CMD_MODE3, PIT_BASE + PIT_COMMAND); - outb(TIMER2_VALUE&0xff, PIT_BASE + PIT_T2); - outb(TIMER2_VALUE>>8, PIT_BASE + PIT_T2); - - timer_init_done = 1; - - return 0; -} - - -#ifdef CONFIG_SYS_GENERIC_TIMER - -/* the unit for these is CONFIG_SYS_HZ */ - -/* FixMe: implement these */ -void reset_timer (void) -{ - system_ticks = 0; -} - -ulong get_timer (ulong base) -{ - return (system_ticks - base); -} - -void set_timer (ulong t) -{ - system_ticks = t; -} - -static u16 read_pit(void) -{ - u8 low; - outb(PIT_CMD_LATCH, PIT_BASE + PIT_COMMAND); - low = inb(PIT_BASE + PIT_T0); - return ((inb(PIT_BASE + PIT_T0) << 8) | low); -} - -/* this is not very exact */ -void udelay (unsigned long usec) -{ - int counter; - int wraps; - - if (!timer_init_done) { - return; - } - counter = read_pit(); - wraps = usec/1000; - usec = usec%1000; - - usec*=1194; - usec/=1000; - usec+=counter; - if (usec > 1194) { - usec-=1194; - wraps++; - } - - while (1) { - int new_count = read_pit(); - - if (((new_count < usec) && !wraps) || wraps < 0) { - break; - } - - if (new_count > counter) { - wraps--; - } - counter = new_count; - } - -} - -#if 0 -/* this is a version with debug output */ -void _udelay (unsigned long usec) -{ - int counter; - int wraps; - - int usec1, usec2, usec3; - int wraps1, wraps2, wraps3, wraps4; - int ctr1, ctr2, ctr3, nct1, nct2; - int i; - usec1=usec; - if (!timer_init_done) { - return; - } - counter = read_pit(); - ctr1 = counter; - wraps = usec/1000; - usec = usec%1000; - - usec2 = usec; - wraps1 = wraps; - - usec*=1194; - usec/=1000; - usec+=counter; - if (usec > 1194) { - usec-=1194; - wraps++; - } - - usec3 = usec; - wraps2 = wraps; - - ctr2 = wraps3 = nct1 = 4711; - ctr3 = wraps4 = nct2 = 4711; - i=0; - while (1) { - int new_count = read_pit(); - i++; - if ((new_count < usec && !wraps) || wraps < 0) { - break; - } - - if (new_count > counter) { - wraps--; - } - if (ctr2==4711) { - ctr2 = counter; - wraps3 = wraps; - nct1 = new_count; - } else { - ctr3 = counter; - wraps4 = wraps; - nct2 = new_count; - } - - counter = new_count; - } - - printf("udelay(%d)\n", usec1); - printf("counter %d\n", ctr1); - printf("1: wraps %d, usec %d\n", wraps1, usec2); - printf("2: wraps %d, usec %d\n", wraps2, usec3); - printf("new_count[0] %d counter %d wraps %d\n", nct1, ctr2, wraps3); - printf("new_count[%d] %d counter %d wraps %d\n", i, nct2, ctr3, wraps4); - - printf("%d %d %d %d %d\n", - read_pit(), read_pit(), read_pit(), - read_pit(), read_pit()); -} -#endif -#endif diff --git a/include/asm-i386/u-boot-i386.h b/include/asm-i386/u-boot-i386.h index 9a60cac..3921e01 100644 --- a/include/asm-i386/u-boot-i386.h +++ b/include/asm-i386/u-boot-i386.h @@ -43,6 +43,13 @@ extern ulong i386boot_bios_size; /* size of BIOS emulation code */
/* cpu/.../cpu.c */ int cpu_init(void); + +/* cpu/.../timer.c */ +void timer_isr(void *); +typedef void (timer_fnc_t) (void); +int register_timer_isr (timer_fnc_t *isr_func); + +/* Architecture specific - can be in cpu/i386/, lib_i386/, or $(BOARD)/ */ int timer_init(void);
/* cpu/.../interrupts.c */ diff --git a/lib_i386/Makefile b/lib_i386/Makefile index fb4184b..ec6f236 100644 --- a/lib_i386/Makefile +++ b/lib_i386/Makefile @@ -39,7 +39,9 @@ COBJS-y += video_bios.o COBJS-y += video.o COBJS-y += zimage.o COBJS-y += interrupts.o +COBJS-y += timer.o COBJS-$(CONFIG_SYS_PCAT_INTERRUPTS) += pcat_interrupts.o +COBJS-$(CONFIG_SYS_GENERIC_TIMER) += pcat_timer.o
SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) diff --git a/lib_i386/pcat_timer.c b/lib_i386/pcat_timer.c new file mode 100644 index 0000000..e282f64 --- /dev/null +++ b/lib_i386/pcat_timer.c @@ -0,0 +1,102 @@ +/* + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/i8254.h> +#include <asm/ibmpc.h> + +#define TIMER0_VALUE 0x04aa /* 1kHz 1.9318MHz / 1000 */ +#define TIMER2_VALUE 0x0a8e /* 440Hz */ + +int timer_init(void) +{ + /* initialize timer 0 and 2 + * + * Timer 0 is used to increment system_tick 1000 times/sec + * Timer 1 was used for DRAM refresh in early PC's + * Timer 2 is used to drive the speaker + * (to stasrt a beep: write 3 to port 0x61, + * to stop it again: write 0) + */ + outb (PIT_CMD_CTR0 | PIT_CMD_BOTH | PIT_CMD_MODE2, + PIT_BASE + PIT_COMMAND); + outb (TIMER0_VALUE & 0xff, PIT_BASE + PIT_T0); + outb (TIMER0_VALUE >> 8, PIT_BASE + PIT_T0); + + outb (PIT_CMD_CTR2 | PIT_CMD_BOTH | PIT_CMD_MODE3, + PIT_BASE + PIT_COMMAND); + outb (TIMER2_VALUE & 0xff, PIT_BASE + PIT_T2); + outb (TIMER2_VALUE >> 8, PIT_BASE + PIT_T2); + + irq_install_handler (0, timer_isr, NULL); + unmask_irq (0); + + return 0; +} + +static u16 read_pit(void) +{ + u8 low; + + outb (PIT_CMD_LATCH, PIT_BASE + PIT_COMMAND); + low = inb (PIT_BASE + PIT_T0); + + return ((inb (PIT_BASE + PIT_T0) << 8) | low); +} + +/* this is not very exact */ +void udelay (unsigned long usec) +{ + int counter; + int wraps; + + if (timer_init_done) + { + counter = read_pit (); + wraps = usec / 1000; + usec = usec % 1000; + + usec *= 1194; + usec /= 1000; + usec += counter; + + while (usec > 1194) { + usec -= 1194; + wraps++; + } + + while (1) { + int new_count = read_pit (); + + if (((new_count < usec) && !wraps) || wraps < 0) + break; + + if (new_count > counter) + wraps--; + + counter = new_count; + } + } + +} diff --git a/lib_i386/timer.c b/lib_i386/timer.c new file mode 100644 index 0000000..5cb1f54 --- /dev/null +++ b/lib_i386/timer.c @@ -0,0 +1,107 @@ +/* + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/i8254.h> +#include <asm/ibmpc.h> + +struct timer_isr_function { + struct timer_isr_function *next; + timer_fnc_t *isr_func; +}; + +static struct timer_isr_function *first_timer_isr = NULL; +static volatile unsigned long system_ticks = 0; + +/* + * register_timer_isr() allows multiple architecture and board specific + * functions to be called every millisecond. Keep the execution time of + * each function as low as possible + */ +int register_timer_isr (timer_fnc_t *isr_func) +{ + struct timer_isr_function *new_func; + struct timer_isr_function *temp; + int flag; + + new_func = malloc(sizeof(struct timer_isr_function)); + + if (new_func == NULL) + return 1; + + new_func->isr_func = isr_func; + new_func->next = NULL; + + /* + * Don't allow timer interrupts while the + * linked list is being modified + */ + flag = disable_interrupts (); + + if (first_timer_isr == NULL) { + first_timer_isr = new_func; + } else { + temp = first_timer_isr; + while (temp->next != NULL) + temp = temp->next; + temp->next = new_func; + } + + if (flag) + enable_interrupts (); + + return 0; +} + +/* + * timer_isr() MUST be the registered interrupt handler for + */ +void timer_isr(void *unused) +{ + struct timer_isr_function *temp = first_timer_isr; + + system_ticks++; + + /* Execute each registered function */ + while (temp != NULL) { + temp->isr_func (); + temp = temp->next; + } +} + +void reset_timer (void) +{ + system_ticks = 0; +} + +ulong get_timer (ulong base) +{ + return (system_ticks - base); +} + +void set_timer (ulong t) +{ + system_ticks = t; +}
Dear Graeme Russ,
cpu/i386/Makefile | 2 =
cpu/i386/sc520/sc520_timer.c | 71 ++++++++----- cpu/i386/timer.c | 211 ------------------------------------=
include/asm-i386/u-boot-i386.h | 7 + lib_i386/Makefile | 2 =
Applied to "next" branch. Thanks.
Graeme Russ
