[U-Boot] [PATCH] NAND: Don't walk past end of oobfree[]
When computing oobavail from the list of free areas in the OOB, don't assume there will always be an unused slot at the end.
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- Applies to u-boot-nand-flash/next This particular issue was found by TI while testing the DaVinci DM3xx with new 4 KB page sized NAND devices. I am going to attempt to send patches to sync up the MTD NAND driver in u-boot with what is in the kernel.I am already using this feature in our internal releases. drivers/mtd/nand/nand_base.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 30a3e9e..9263a69 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2868,7 +2868,8 @@ int nand_scan_tail(struct mtd_info *mtd) * the out of band area */ chip->ecc.layout->oobavail = 0; - for (i = 0; chip->ecc.layout->oobfree[i].length; i++) + for (i = 0; chip->ecc.layout->oobfree[i].length + && i < ARRAY_SIZE(chip->ecc.layout->oobfree); i++) chip->ecc.layout->oobavail += chip->ecc.layout->oobfree[i].length; mtd->oobavail = chip->ecc.layout->oobavail;
s-paulraj@ti.com
