[PATCH] binman: Fix replace subcommand help
Fix some copy&paste artifacts:
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- tools/binman/cmdline.py | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/binman/cmdline.py b/tools/binman/cmdline.py index d6156df408..e1a4cea961 100644 --- a/tools/binman/cmdline.py +++ b/tools/binman/cmdline.py @@ -99,7 +99,7 @@ controlled by a description in the board device tree.''' replace_parser.add_argument('-C', '--compressed', action='store_true', help='Input data is already compressed if needed for the entry') replace_parser.add_argument('-i', '--image', type=str, required=True, - help='Image filename to extract') + help='Image filename to replace') replace_parser.add_argument('-f', '--filename', type=str, help='Input filename to read from') replace_parser.add_argument('-F', '--fix-size', action='store_true', @@ -109,7 +109,7 @@ controlled by a description in the board device tree.''' replace_parser.add_argument('-m', '--map', action='store_true', default=False, help='Output a map file for the updated image') replace_parser.add_argument('paths', type=str, nargs='*', - help='Paths within file to extract (wildcard)') + help='Paths within file to replace (wildcard)')
test_parser = subparsers.add_parser('test', help='Run tests') test_parser.add_argument('-P', '--processes', type=int,
s/replace/update/ ?
or
image filename to replace files in?
-- 2.31.1
Regards, Simonn
Jan Kiszka
