[U-Boot] [PATCH] usb: ehci: Fix warning on aarch64
Fix the following warning on aarch64 introduced by using p2v/v2p functions in the code:
In file included from ./arch/arm/include/asm/byteorder.h:29:0, from include/compiler.h:125, from include/image.h:19, from include/common.h:88, from drivers/usb/host/ehci-hcd.c:10: drivers/usb/host/ehci-hcd.c: In function ‘ehci_td_buffer’: drivers/usb/host/ehci-hcd.c:250:49: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] td->qt_buffer[idx] = cpu_to_hc32(virt_to_phys((void *)addr)); ^ include/linux/byteorder/little_endian.h:34:51: note: in definition of macro ‘__cpu_to_le32’ #define __cpu_to_le32(x) ((__force __le32)(__u32)(x)) ^ drivers/usb/host/ehci-hcd.c:250:24: note: in expansion of macro ‘cpu_to_hc32’ td->qt_buffer[idx] = cpu_to_hc32(virt_to_phys((void *)addr));
Signed-off-by: Marek Vasut marex@denx.de Cc: Stephen Warren swarren@wwwdotorg.org Cc: Tom Rini trini@konsulko.com --- drivers/usb/host/ehci-hcd.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index 8f259be..0113c6c 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -237,7 +237,7 @@ static int ehci_shutdown(struct ehci_ctrl *ctrl) static int ehci_td_buffer(struct qTD *td, void *buf, size_t sz) { uint32_t delta, next; - uint32_t addr = (unsigned long)buf; + unsigned long addr = (unsigned long)buf; int idx;
if (addr != ALIGN(addr, ARCH_DMA_MINALIGN))
In that case, applied, thanks!
