[U-Boot] [PATCH] Travis-CI: Split 't208xrdb t4qds t102*'-job into separate jobs
The 't208xrdb t4qds t102*' job is close to the time limit and sometimes fails, so this splits it into 3 separate jobs.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
.travis.yml | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/.travis.yml b/.travis.yml index 0b7a062..8a220cc 100644 --- a/.travis.yml +++ b/.travis.yml @@ -206,7 +206,11 @@ matrix: - env: - BUILDMAN="mpc85xx -x t208xrdb -x t4qds -x t102* -x p1_p2_rdb_pc -x p1010rdb -x corenet_ds -x b4860qds -x sbc8548 -x bsc91*" - env: - - BUILDMAN="t208xrdb t4qds t102*" + - BUILDMAN="t208xrdb" + - env: + - BUILDMAN="t4qds" + - env: + - BUILDMAN="t102*" - env: - BUILDMAN="p1_p2_rdb_pc" - env:
Hi Philipp,
On 20 December 2017 at 03:06, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Should buidman have a time limit parameter? Then it could build for (say) and hour and exit after that, writing out the boards that it completed building.
It would be fairly easy to implement.
- env:
- BUILDMAN="t4qds"
- env:
- BUILDMAN="t102*"
- env:
- env:
-- 2.1.4
On Thu, Dec 28, 2017 at 08:13:57PM -0700, Simon Glass wrote:
Hi Philipp,
I don't think so. We need to build everything and have it pass, and using --dry-run to see / tweak what would be built to re-work jobs works well enough I think. Thanks!
Philipp Tomsich
