[U-Boot] [PATCH] Revert "dm: pinctrl: Prevent (re-)configuring pins when already done before relocation"
This reverts commit a7f4b4b344396590845e6552c82829ef68ef9f89.
As reported by Alex Kiernan the above optimization introduces a regression in the below use case where:
1. Device has defined 'u-boot,dm-spl' property (@ eMMC DTS node)
2. The device downloads its MLO/SPL via UART (not eMMC - the eMMC pinmux pins are NOT probed/configured in MLO/SPL).
3. The loaded via UART MLO/SPL wants to load Linux from eMMC. In this case the DM core and pinctrl uclass checks 'u-boot,dm-spl' and don't configure pins (as it thinks that those were initialized in MLO/SPL).
As we are very close to release - please revert this commit.
Reported-by: Alex Kiernan alex.kiernan@gmail.com Signed-off-by: Lukasz Majewski lukma@denx.de
drivers/pinctrl/pinctrl-uclass.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index 29c910c55f..6db0445067 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -117,9 +117,9 @@ static int pinconfig_post_bind(struct udevice *dev) int ret;
dev_for_each_subnode(node, dev) { - if (pre_reloc_only ^ ofnode_pre_reloc(node)) + if (pre_reloc_only && + !ofnode_pre_reloc(node)) continue; - /* * If this node has "compatible" property, this is not * a pin configuration node, but a normal device. skip.
- The loaded via UART MLO/SPL wants to load Linux from eMMC. In this case
Reported-by: Alex Kiernan alex.kiernan@gmail.com Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Simon Glass sjg@chromium.org
Lukasz Majewski
