[U-Boot] pull request: u-boot-uniphier/master
Hi Tom,
Here, UniPhier SoC updates for v2016.09-rc1. Please pull!
The following changes since commit 04a4786c7c3907a8e0cf271c02a437858a3ea96d:
test/py: vboot can be run only at Sandbox (2016-07-22 14:52:04 -0400)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to 29d63a59eaf1c9f3b37e249cda2a97e5e4f183f8:
ARM: uniphier: add clock/reset settings for xHCI of ProXstream2 (2016-07-24 00:44:55 +0900)
---------------------------------------------------------------- Masahiro Yamada (9): ARM: dts: uniphier: renumber serial aliases for Gentil/Vodka boards ARM: uniphier: select CONFIG_ARMV8_SPIN_TABLE ARM: uniphier: fix doubled tftpboot commands ARM: uniphier: use (devm_)ioremap() instead of map_sysmem() ARM: uniphier: clear notification flag before L2 operation ARM: uniphier: rename outer-cache register macros ARM: uniphier: introduce flags to uniphier_board_data structure ARM: uniphier: add PH1-LD21 board data ARM: uniphier: add clock/reset settings for xHCI of ProXstream2
arch/arm/dts/uniphier-proxstream2-gentil.dts | 8 +- arch/arm/dts/uniphier-proxstream2-vodka.dts | 8 +- arch/arm/mach-uniphier/Kconfig | 1 + arch/arm/mach-uniphier/arm32/Makefile | 2 +- arch/arm/mach-uniphier/arm32/cache-uniphier.c | 165 +++++++++++++++++++++++++++++++++++++++ arch/arm/mach-uniphier/arm32/cache_uniphier.c | 156 ------------------------------------ arch/arm/mach-uniphier/arm32/late_lowlevel_init.S | 4 +- arch/arm/mach-uniphier/arm32/lowlevel_init.S | 18 +++-- arch/arm/mach-uniphier/arm32/ssc-regs.h | 101 ++++++++++++------------ arch/arm/mach-uniphier/arm64/arm-cci500.c | 9 +-- arch/arm/mach-uniphier/arm64/smp_kick_cpus.c | 9 +-- arch/arm/mach-uniphier/arm64/timer.c | 9 +-- arch/arm/mach-uniphier/boards.c | 24 +++++- arch/arm/mach-uniphier/clk/clk-pxs2.c | 7 +- arch/arm/mach-uniphier/dram/cmd_ddrphy.c | 13 +-- arch/arm/mach-uniphier/dram/umc-ld4.c | 6 +- arch/arm/mach-uniphier/dram/umc-pro4.c | 6 +- arch/arm/mach-uniphier/dram/umc-sld8.c | 6 +- arch/arm/mach-uniphier/init.h | 8 +- arch/arm/mach-uniphier/sc-regs.h | 8 +- drivers/clk/uniphier/clk-uniphier-core.c | 15 +--- drivers/clk/uniphier/clk-uniphier-mio.c | 4 +- drivers/clk/uniphier/clk-uniphier.h | 4 +- drivers/gpio/gpio-uniphier.c | 16 +--- drivers/i2c/i2c-uniphier-f.c | 17 +--- drivers/i2c/i2c-uniphier.c | 17 +--- drivers/mmc/uniphier-sd.c | 7 +- drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 16 +--- drivers/pinctrl/uniphier/pinctrl-uniphier-ld11.c | 1 - drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 1 - drivers/pinctrl/uniphier/pinctrl-uniphier-ld4.c | 4 +- drivers/pinctrl/uniphier/pinctrl-uniphier-ld6b.c | 4 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pro4.c | 4 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pro5.c | 4 +- drivers/pinctrl/uniphier/pinctrl-uniphier-pxs2.c | 4 +- drivers/pinctrl/uniphier/pinctrl-uniphier-sld8.c | 4 +- drivers/pinctrl/uniphier/pinctrl-uniphier.h | 5 +- drivers/serial/serial_uniphier.c | 15 +--- include/configs/uniphier.h | 1 - 39 files changed, 352 insertions(+), 359 deletions(-) create mode 100644 arch/arm/mach-uniphier/arm32/cache-uniphier.c delete mode 100644 arch/arm/mach-uniphier/arm32/cache_uniphier.c
On Sun, Jul 24, 2016 at 12:55:52AM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
