[U-Boot] [PATCH v2 00/34] env: Move environment code to use location drivers
The environment code is ripe for improvement in various ways. It has lots of duplication and inconsistencies between how things work with different environment locations. It does not properly use Kconfig. Error checking and handling is patchy.
This series makes a start at improving things:
- moves the rest of the CONFIG_ENV_IS_IN_... options to Kconfig - introduces the concept of a location driver for the environment - drops some of the duplicated code - improves error handling a little (more to be done here) - moves code into a new env/ directory
There is still much more to do: - complete Kconfig conversion (e.g. CONFIG_ENV_SIZE) - unify environment settings so that all locations support the same options - try to rationalise the redundancy code (can we create a common implementation used by all drivers?) - allow environment in multiple locations (e.g. as a fallback) - figure out why CONFIG_ENV_IS_IN_FLASH enables the environment in flash even in SPL, which other locations do not - move environment functions from common.h to environment.h
Changes in v2: - Add a patch to resync configs - Handle a difficult cases that try to have different env settings for SPL - Update evb-rk3229, phycore-rk3288, poplar - Drop imply for some MIPS Kconfigs - Update CONFIG_ENV_IS_IN_FLASH for MCR3000 also - Update turris_omnia also - Add new patch to convert CONFIG_ENV_IS_IN_ONENAND to Kconfig - Add conditions for the am335x_hs_evm board with SPL - Add new patch to rename setenv() and friends to env_set() - Add new patch to rename getenv() and friends to env_get() - Rebase to master
Simon Glass (34): configs: Resync with savedefconfig Makefile: Rename 'env' target to 'environ' Move environment files from common/ to env/ Convert CONFIG_ENV_IS_IN_MMC et al to Kconfig env: Move help from README to Kconfig Convert CONFIG_ENV_IS_IN_FLASH to Kconfig Convert CONFIG_ENV_IS_IN_NVRAM to Kconfig Convert CONFIG_ENV_IS_IN_EEPROM to Kconfig Convert CONFIG_ENV_IS_IN_DATAFLASH to Kconfig Convert CONFIG_ENV_IS_IN_SPI_FLASH to Kconfig Convert CONFIG_ENV_IS_IN_REMOTE to Kconfig Convert CONFIG_ENV_IS_IN_FAT to Kconfig Convert CONFIG_ENV_IS_IN_ONENAND to Kconfig env: common: Make env_get_addr/get_char_memory() static env: common: Drop env_get_addr() env: common: Factor out the common env_valid check env: common: Drop env_get_char_init() env: common: Drop env_get_char_memory() env: Add an enum for environment state env: Rename nand env_location to nand_env_location env: Create a location driver for each location env: Add a new implementation of environment access env: Switch over to use environment location drivers env: Drop common init() functions env: Drop the env_name_spec global env: Drop unused env_ptr variables env: Drop env_init_new() env: Drop env_get_char_spec() env: Drop env_relocate_spec() in favour of env_load() env: Drop saveenv() in favour of env_save() env: Rename setenv() and friends to env_set() env: Rename getenv() and friends to env_get() env: Adjust the get_char() method to return an int env: Adjust the load() method to return an error
Kconfig | 2 + Makefile | 5 +- README | 354 +---------------- api/api.c | 6 +- arch/arc/lib/bootm.c | 2 +- arch/arm/Kconfig | 2 + arch/arm/cpu/armv7/vf610/generic.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 4 +- arch/arm/lib/bootm.c | 6 +- arch/arm/lib/semihosting.c | 2 +- arch/arm/mach-davinci/misc.c | 4 +- arch/arm/mach-exynos/Kconfig | 1 + arch/arm/mach-imx/mx6/Kconfig | 1 + arch/arm/mach-imx/mx6/opos6ul.c | 2 +- arch/arm/mach-imx/mx7/Kconfig | 1 + arch/arm/mach-imx/mx7/soc.c | 4 +- arch/arm/mach-imx/video.c | 2 +- arch/arm/mach-integrator/Kconfig | 2 + arch/arm/mach-keystone/ddr3.c | 2 +- arch/arm/mach-keystone/keystone.c | 2 +- arch/arm/mach-kirkwood/cpu.c | 4 +- arch/arm/mach-mvebu/Kconfig | 1 + arch/arm/mach-omap2/boot-common.c | 5 +- arch/arm/mach-omap2/utils.c | 20 +- arch/arm/mach-rockchip/rk3036-board.c | 4 +- arch/arm/mach-rockchip/rk322x-board.c | 4 +- arch/arm/mach-rockchip/rk3288-board.c | 4 +- arch/arm/mach-socfpga/misc_gen5.c | 4 +- arch/arm/mach-sunxi/Kconfig | 6 + arch/arm/mach-tegra/Kconfig | 3 + arch/arm/mach-tegra/board2.c | 4 +- arch/arm/mach-tegra/tegra186/nvtboot_board.c | 6 +- arch/arm/mach-uniphier/board_late_init.c | 12 +- arch/arm/mach-uniphier/mmc-first-dev.c | 2 +- arch/m68k/Kconfig | 8 + arch/m68k/lib/bootm.c | 3 +- arch/microblaze/Kconfig | 1 + arch/microblaze/lib/bootm.c | 2 +- arch/mips/Kconfig | 5 + arch/mips/lib/bootm.c | 6 +- arch/nds32/lib/bootm.c | 4 +- arch/nios2/lib/bootm.c | 2 +- arch/powerpc/Kconfig | 1 + arch/powerpc/cpu/mpc83xx/Kconfig | 6 + arch/powerpc/cpu/mpc85xx/Kconfig | 4 + arch/powerpc/cpu/mpc85xx/cpu_init.c | 12 +- arch/powerpc/cpu/mpc85xx/fdt.c | 4 +- arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 2 +- arch/powerpc/cpu/mpc85xx/mp.c | 2 +- arch/powerpc/cpu/mpc86xx/Kconfig | 1 + arch/powerpc/include/asm/fsl_secure_boot.h | 2 +- arch/powerpc/lib/bootm.c | 11 +- arch/sh/Kconfig | 3 + arch/sh/cpu/u-boot.lds | 4 +- arch/sh/lib/bootm.c | 2 +- arch/sh/lib/zimageboot.c | 2 +- arch/x86/cpu/baytrail/Kconfig | 1 + arch/x86/lib/zimage.c | 8 +- arch/xtensa/lib/bootm.c | 2 +- board/Arcturus/ucp1020/cmd_arc.c | 20 +- board/Arcturus/ucp1020/spl.c | 3 +- board/Arcturus/ucp1020/ucp1020.c | 20 +- board/Barix/ipam390/ipam390.c | 2 +- board/BuR/brppt1/board.c | 2 +- board/BuR/brxre1/board.c | 22 +- board/BuR/common/common.c | 56 +-- board/BuS/eb_cpu5282/eb_cpu5282.c | 8 +- board/CZ.NIC/turris_omnia/turris_omnia.c | 8 +- board/CarMediaLab/flea3/flea3.c | 2 +- board/LaCie/net2big_v2/net2big_v2.c | 4 +- board/LaCie/netspace_v2/netspace_v2.c | 4 +- board/Synology/ds414/cmd_syno.c | 6 +- board/amazon/kc1/kc1.c | 4 +- board/amlogic/odroid-c2/odroid-c2.c | 8 +- board/aries/ma5d4evk/ma5d4evk.c | 2 +- board/aristainetos/aristainetos-v2.c | 8 +- board/armltd/integrator/integrator.c | 2 +- board/atmel/sama5d2_xplained/sama5d2_xplained.c | 4 +- board/atmel/sama5d3xek/sama5d3xek.c | 2 +- board/bachmann/ot1200/ot1200.c | 4 +- board/birdland/bav335x/board.c | 12 +- board/bluegiga/apx4devkit/apx4devkit.c | 4 +- board/bluewater/gurnard/gurnard.c | 6 +- board/bosch/shc/board.c | 10 +- board/boundary/nitrogen6x/nitrogen6x.c | 14 +- board/broadcom/bcm23550_w1d/bcm23550_w1d.c | 2 +- board/broadcom/bcm28155_ap/bcm28155_ap.c | 2 +- board/buffalo/lsxl/lsxl.c | 4 +- board/cadence/xtfpga/xtfpga.c | 4 +- board/ccv/xpress/xpress.c | 2 +- board/compulab/cl-som-am57x/eth.c | 6 +- board/compulab/cm_fx6/cm_fx6.c | 12 +- board/compulab/cm_t335/cm_t335.c | 4 +- board/compulab/cm_t35/cm_t35.c | 4 +- board/compulab/cm_t3517/cm_t3517.c | 4 +- board/compulab/cm_t54/cm_t54.c | 6 +- board/compulab/common/omap3_display.c | 4 +- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 8 +- board/cssi/MCR3000/MCR3000.c | 2 +- board/davinci/da8xxevm/da850evm.c | 6 +- board/davinci/da8xxevm/omapl138_lcdk.c | 6 +- board/el/el6x/el6x.c | 2 +- board/engicam/common/board.c | 16 +- board/engicam/common/board.h | 2 +- board/engicam/geam6ul/geam6ul.c | 4 +- board/engicam/icorem6/icorem6.c | 6 +- board/engicam/icorem6_rqs/icorem6_rqs.c | 6 +- board/engicam/isiotmx6ul/isiotmx6ul.c | 6 +- board/esd/meesc/meesc.c | 7 +- board/freescale/b4860qds/b4860qds.c | 8 +- board/freescale/b4860qds/spl.c | 3 +- board/freescale/bsc9131rdb/bsc9131rdb.c | 4 +- board/freescale/bsc9132qds/bsc9132qds.c | 4 +- board/freescale/c29xpcie/c29xpcie.c | 4 +- board/freescale/c29xpcie/spl.c | 3 +- board/freescale/common/cmd_esbc_validate.c | 2 +- board/freescale/common/fsl_chain_of_trust.c | 6 +- board/freescale/common/sys_eeprom.c | 4 +- board/freescale/common/vid.c | 4 +- board/freescale/corenet_ds/corenet_ds.c | 4 +- board/freescale/ls1021aqds/ls1021aqds.c | 2 +- board/freescale/ls1021atwr/ls1021atwr.c | 2 +- board/freescale/ls2080aqds/eth.c | 6 +- board/freescale/ls2080aqds/ls2080aqds.c | 2 +- board/freescale/ls2080ardb/ls2080ardb.c | 2 +- board/freescale/mpc8323erdb/mpc8323erdb.c | 2 +- board/freescale/mpc837xemds/pci.c | 2 +- board/freescale/mpc837xerdb/mpc837xerdb.c | 2 +- board/freescale/mpc8572ds/mpc8572ds.c | 4 +- board/freescale/mx31ads/u-boot.lds | 2 +- board/freescale/mx51evk/mx51evk_video.c | 2 +- board/freescale/mx53loco/mx53loco.c | 4 +- board/freescale/mx53loco/mx53loco_video.c | 2 +- board/freescale/mx6sabreauto/mx6sabreauto.c | 8 +- board/freescale/mx6sabresd/mx6sabresd.c | 8 +- board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 6 +- board/freescale/mx6ullevk/mx6ullevk.c | 4 +- board/freescale/p1010rdb/p1010rdb.c | 4 +- board/freescale/p1010rdb/spl.c | 3 +- board/freescale/p1022ds/p1022ds.c | 4 +- board/freescale/p1022ds/spl.c | 3 +- board/freescale/p1023rdb/p1023rdb.c | 4 +- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 7 +- board/freescale/p1_p2_rdb_pc/spl.c | 3 +- board/freescale/p1_twr/p1_twr.c | 4 +- board/freescale/p2041rdb/p2041rdb.c | 4 +- board/freescale/qemu-ppce500/qemu-ppce500.c | 4 +- board/freescale/t102xqds/spl.c | 3 +- board/freescale/t102xqds/t102xqds.c | 4 +- board/freescale/t102xrdb/spl.c | 3 +- board/freescale/t102xrdb/t102xrdb.c | 4 +- board/freescale/t1040qds/t1040qds.c | 4 +- board/freescale/t104xrdb/spl.c | 3 +- board/freescale/t104xrdb/t104xrdb.c | 4 +- board/freescale/t208xqds/spl.c | 3 +- board/freescale/t208xqds/t208xqds.c | 4 +- board/freescale/t208xrdb/spl.c | 3 +- board/freescale/t208xrdb/t208xrdb.c | 4 +- board/freescale/t4qds/spl.c | 3 +- board/freescale/t4qds/t4240emu.c | 4 +- board/freescale/t4qds/t4240qds.c | 6 +- board/freescale/t4rdb/spl.c | 3 +- board/freescale/t4rdb/t4240rdb.c | 4 +- board/gateworks/gw_ventana/common.c | 2 +- board/gateworks/gw_ventana/gw_ventana.c | 64 ++-- board/gateworks/gw_ventana/gw_ventana_spl.c | 6 +- board/gdsys/a38x/keyprogram.c | 4 +- board/gdsys/mpc8308/hrcon.c | 2 +- board/gdsys/mpc8308/strider.c | 2 +- board/gdsys/p1022/controlcenterd-id.c | 10 +- board/gdsys/p1022/controlcenterd.c | 6 +- board/grinn/chiliboard/board.c | 8 +- board/grinn/liteboard/board.c | 6 +- board/gumstix/pepper/board.c | 4 +- board/highbank/highbank.c | 6 +- board/htkw/mcx/mcx.c | 2 +- board/isee/igep003x/board.c | 10 +- board/isee/igep00x0/igep00x0.c | 4 +- board/keymile/common/common.c | 26 +- board/keymile/common/ivm.c | 10 +- board/keymile/km83xx/km83xx.c | 8 +- board/keymile/km_arm/km_arm.c | 6 +- board/keymile/kmp204x/kmp204x.c | 8 +- board/kosagi/novena/novena.c | 4 +- board/lg/sniper/sniper.c | 4 +- board/liebherr/mccmon6/mccmon6.c | 6 +- board/logicpd/imx6/imx6logic.c | 6 +- board/logicpd/omap3som/omap3logic.c | 4 +- board/logicpd/zoom1/zoom1.c | 4 +- board/micronas/vct/vct.c | 2 +- board/nokia/rx51/rx51.c | 10 +- board/overo/overo.c | 44 +-- board/phytec/pcm051/board.c | 4 +- board/qualcomm/dragonboard410c/dragonboard410c.c | 2 +- board/raspberrypi/rpi/rpi.c | 28 +- board/renesas/alt/alt.c | 2 +- board/renesas/blanche/blanche.c | 4 +- board/renesas/ecovec/ecovec.c | 2 +- board/renesas/gose/gose.c | 2 +- board/renesas/koelsch/koelsch.c | 2 +- board/renesas/lager/lager.c | 2 +- board/renesas/porter/porter.c | 2 +- board/renesas/sh7752evb/sh7752evb.c | 4 +- board/renesas/sh7753evb/sh7753evb.c | 4 +- board/renesas/sh7757lcr/sh7757lcr.c | 6 +- board/renesas/silk/silk.c | 2 +- board/renesas/stout/stout.c | 2 +- board/rockchip/kylin_rk3036/kylin_rk3036.c | 2 +- board/rockchip/tinker_rk3288/tinker-rk3288.c | 2 +- board/samsung/common/exynos5-dt.c | 2 +- board/samsung/common/misc.c | 14 +- board/samsung/odroid/odroid.c | 2 +- board/samsung/trats/trats.c | 2 +- board/samsung/universal_c210/universal.c | 2 +- board/samtec/vining_2000/vining_2000.c | 10 +- board/samtec/vining_fpga/socfpga.c | 18 +- board/siemens/common/board.c | 4 +- board/siemens/common/factoryset.c | 8 +- board/siemens/common/factoryset.h | 2 +- board/siemens/draco/board.c | 8 +- board/siemens/pxm2/board.c | 6 +- board/siemens/rut/board.c | 4 +- board/siemens/taurus/taurus.c | 47 +-- board/silica/pengwyn/board.c | 4 +- board/socrates/socrates.c | 4 +- board/solidrun/mx6cuboxi/mx6cuboxi.c | 8 +- board/spear/common/spr_misc.c | 12 +- board/st/stm32f429-discovery/stm32f429-discovery.c | 4 +- board/sunxi/board.c | 18 +- board/syteco/zmx25/zmx25.c | 6 +- board/tcl/sl50/board.c | 14 +- board/technexion/twister/twister.c | 2 +- board/technologic/ts4800/ts4800.c | 2 +- board/teejet/mt_ventoux/mt_ventoux.c | 4 +- board/theobroma-systems/puma_rk3399/puma-rk3399.c | 12 +- board/ti/am335x/board.c | 16 +- board/ti/am43xx/board.c | 10 +- board/ti/am57xx/board.c | 22 +- board/ti/beagle/beagle.c | 38 +- board/ti/common/board_detect.c | 18 +- board/ti/dra7xx/evm.c | 14 +- board/ti/evm/evm.c | 4 +- board/ti/ks2_evm/board.c | 12 +- board/ti/ks2_evm/board_k2g.c | 4 +- board/ti/panda/panda.c | 4 +- board/ti/ti814x/evm.c | 4 +- board/ti/ti816x/evm.c | 4 +- board/timll/devkit8000/devkit8000.c | 4 +- board/toradex/apalis_imx6/apalis_imx6.c | 9 +- board/toradex/colibri_imx6/colibri_imx6.c | 2 +- board/toradex/colibri_vf/colibri_vf.c | 2 +- board/toradex/common/tdx-cfg-block.c | 2 +- board/toradex/common/tdx-common.c | 10 +- board/tqc/tqma6/tqma6.c | 2 +- board/udoo/neo/neo.c | 2 +- board/udoo/udoo.c | 4 +- board/varisys/common/sys_eeprom.c | 6 +- board/varisys/cyrus/cyrus.c | 4 +- board/vscom/baltos/board.c | 8 +- board/wandboard/wandboard.c | 8 +- .../work-microwave/work_92105/work_92105_display.c | 2 +- board/xes/common/board.c | 6 +- board/xilinx/zynq/board.c | 12 +- board/xilinx/zynqmp/zynqmp.c | 6 +- cmd/bdinfo.c | 6 +- cmd/bootm.c | 4 +- cmd/bootmenu.c | 4 +- cmd/cbfs.c | 2 +- cmd/cramfs.c | 10 +- cmd/elf.c | 32 +- cmd/fdt.c | 31 +- cmd/fpga.c | 4 +- cmd/gpt.c | 6 +- cmd/ini.c | 6 +- cmd/itest.c | 2 +- cmd/jffs2.c | 6 +- cmd/load.c | 16 +- cmd/log.c | 6 +- cmd/lzmadec.c | 2 +- cmd/md5sum.c | 4 +- cmd/mtdparts.c | 44 +-- cmd/mvebu/bubt.c | 2 +- cmd/nand.c | 12 +- cmd/net.c | 40 +- cmd/nvedit.c | 38 +- cmd/part.c | 8 +- cmd/pxe.c | 33 +- cmd/qfw.c | 6 +- cmd/reiser.c | 8 +- cmd/setexpr.c | 10 +- cmd/source.c | 2 +- cmd/tpm.c | 4 +- cmd/trace.c | 18 +- cmd/unzip.c | 2 +- cmd/ximg.c | 6 +- cmd/zfs.c | 6 +- cmd/zip.c | 2 +- common/Kconfig | 69 ---- common/Makefile | 49 +-- common/autoboot.c | 24 +- common/board_f.c | 4 +- common/board_r.c | 22 +- common/bootm.c | 18 +- common/bootm_os.c | 12 +- common/bootretry.c | 2 +- common/cli.c | 2 +- common/cli_hush.c | 16 +- common/cli_simple.c | 4 +- common/console.c | 14 +- common/fb_mmc.c | 2 +- common/fdt_support.c | 6 +- common/hash.c | 4 +- common/hwconfig.c | 6 +- common/image-android.c | 4 +- common/image-fdt.c | 6 +- common/image.c | 32 +- common/lcd.c | 2 +- common/main.c | 4 +- common/spl/Kconfig | 4 +- common/spl/spl_dfu.c | 4 +- common/spl/spl_ext.c | 4 +- common/spl/spl_fat.c | 4 +- common/spl/spl_net.c | 4 +- common/splash.c | 2 +- common/splash_source.c | 6 +- common/update.c | 11 +- common/usb_hub.c | 2 +- common/usb_kbd.c | 6 +- configs/10m50_defconfig | 1 + configs/3c120_defconfig | 1 + configs/B4420QDS_NAND_defconfig | 1 + configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 1 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/CHIP_defconfig | 2 + configs/CHIP_pro_defconfig | 1 + configs/Cyrus_P5020_defconfig | 1 + configs/Cyrus_P5040_defconfig | 1 + configs/M5208EVBE_defconfig | 1 + configs/M52277EVB_defconfig | 1 + configs/M52277EVB_stmicro_defconfig | 1 + configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M53017EVB_defconfig | 1 + configs/M54418TWR_defconfig | 1 + configs/M54418TWR_nand_mii_defconfig | 1 + configs/M54418TWR_nand_rmii_defconfig | 1 + configs/M54418TWR_nand_rmii_lowfreq_defconfig | 1 + configs/M54418TWR_serial_mii_defconfig | 1 + configs/M54418TWR_serial_rmii_defconfig | 1 + configs/M54451EVB_defconfig | 1 + configs/M54451EVB_stmicro_defconfig | 1 + configs/M54455EVB_a66_defconfig | 1 + configs/M54455EVB_defconfig | 1 + configs/M54455EVB_i66_defconfig | 1 + configs/M54455EVB_intel_defconfig | 1 + configs/M54455EVB_stm33_defconfig | 1 + configs/MCR3000_defconfig | 99 ++--- configs/MPC8308RDB_defconfig | 1 + configs/MPC8313ERDB_33_defconfig | 1 + configs/MPC8313ERDB_66_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MPC8315ERDB_defconfig | 1 + configs/MPC8323ERDB_defconfig | 1 + configs/MPC8349EMDS_defconfig | 1 + configs/MPC837XEMDS_HOST_defconfig | 1 + configs/MPC837XEMDS_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8541CDS_defconfig | 1 + configs/MPC8541CDS_legacy_defconfig | 1 + configs/MPC8544DS_defconfig | 3 +- configs/MPC8555CDS_defconfig | 1 + configs/MPC8555CDS_legacy_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 2 +- configs/MigoR_defconfig | 1 + configs/Nintendo_NES_Classic_Edition_defconfig | 2 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020MBG-PC_36BIT_defconfig | 1 + configs/P1020MBG-PC_SDCARD_defconfig | 1 + configs/P1020MBG-PC_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020UTM-PC_36BIT_defconfig | 1 + configs/P1020UTM-PC_SDCARD_defconfig | 1 + configs/P1020UTM-PC_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 1 + configs/P1024RDB_36BIT_defconfig | 1 + configs/P1024RDB_NAND_defconfig | 1 + configs/P1024RDB_SDCARD_defconfig | 1 + configs/P1024RDB_SPIFLASH_defconfig | 1 + configs/P1024RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SECURE_BOOT_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SECURE_BOOT_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SECURE_BOOT_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5020DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5020DS_NAND_defconfig | 1 + configs/P5020DS_SDCARD_defconfig | 1 + configs/P5020DS_SECURE_BOOT_defconfig | 1 + configs/P5020DS_SPIFLASH_defconfig | 1 + configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P5020DS_defconfig | 1 + configs/P5040DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SECURE_BOOT_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/T1023RDB_NAND_defconfig | 1 + configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1023RDB_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SECURE_BOOT_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2081QDS_NAND_defconfig | 1 + configs/T2081QDS_SDCARD_defconfig | 1 + configs/T2081QDS_SPIFLASH_defconfig | 1 + configs/T2081QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2081QDS_defconfig | 1 + configs/T4160QDS_NAND_defconfig | 1 + configs/T4160QDS_SDCARD_defconfig | 1 + configs/T4160QDS_SECURE_BOOT_defconfig | 1 + configs/T4160QDS_defconfig | 1 + configs/T4160RDB_defconfig | 1 + configs/T4240QDS_NAND_defconfig | 1 + configs/T4240QDS_SDCARD_defconfig | 1 + configs/T4240QDS_SECURE_BOOT_defconfig | 1 + configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T4240QDS_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/TQM834x_defconfig | 1 + configs/TWR-P1025_defconfig | 1 + configs/UCP1020_SPIFLASH_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/adp-ae3xx_defconfig | 1 + configs/adp-ag101p_defconfig | 1 + configs/alt_defconfig | 1 + configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_defconfig | 2 +- configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_norboot_defconfig | 1 + configs/am335x_evm_spiboot_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/am335x_hs_evm_defconfig | 3 +- configs/am335x_igep003x_defconfig | 1 + configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 + configs/am335x_shc_prompt_defconfig | 1 + configs/am335x_shc_sdboot_defconfig | 1 + configs/am335x_shc_sdboot_prompt_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am3517_crane_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_ethboot_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_evm_nodt_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/amcore_defconfig | 1 + configs/ap121_defconfig | 1 + configs/ap143_defconfig | 1 + configs/ap325rxa_defconfig | 1 + configs/ap_sh4a_4a_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/apalis_imx6_nospl_com_defconfig | 1 + configs/apalis_imx6_nospl_it_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/armadillo-800eva_defconfig | 1 + configs/arndale_defconfig | 1 + configs/aspenite_defconfig | 1 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/at91sam9260ek_dataflash_cs0_defconfig | 1 + configs/at91sam9260ek_dataflash_cs1_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 1 + configs/at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 1 + configs/at91sam9xeek_dataflash_cs1_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/axm_defconfig | 1 + configs/axs101_defconfig | 1 + configs/axs103_defconfig | 1 + configs/bayleybay_defconfig | 2 +- configs/bcm11130_defconfig | 1 + configs/bcm11130_nand_defconfig | 1 + configs/bcm23550_w1d_defconfig | 1 + configs/bcm28155_ap_defconfig | 1 + configs/bcm28155_w1d_defconfig | 1 + configs/bcm911360_entphn-ns_defconfig | 1 + configs/bcm911360_entphn_defconfig | 1 + configs/bcm911360k_defconfig | 1 + configs/bcm958300k-ns_defconfig | 1 + configs/bcm958300k_defconfig | 1 + configs/bcm958305k_defconfig | 1 + configs/bcm958622hr_defconfig | 1 + configs/bcm958712k_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/bk4r1_defconfig | 3 +- configs/blanche_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/caddy2_defconfig | 1 + configs/cairo_defconfig | 1 + configs/calimain_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_link64_defconfig | 5 +- configs/chromebook_link_defconfig | 5 +- configs/chromebook_minnie_defconfig | 1 + configs/chromebook_samus_defconfig | 3 +- configs/chromebox_panther_defconfig | 5 +- configs/cl-som-am57x_defconfig | 1 + configs/clearfog_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/cm_t54_defconfig | 3 +- configs/colibri_imx6_defconfig | 1 + configs/colibri_imx6_nospl_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colibri_pxa270_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_vf_defconfig | 3 +- ...conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + .../controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/controlcenterdc_defconfig | 3 +- configs/coreboot-x86_defconfig | 1 + configs/corvus_defconfig | 1 + configs/cougarcanyon2_defconfig | 3 +- configs/crownbay_defconfig | 3 +- configs/d2net_v2_defconfig | 1 + configs/da850_am18xxevm_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_direct_nor_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 3 +- configs/dbau1000_defconfig | 1 + configs/dbau1100_defconfig | 1 + configs/dbau1500_defconfig | 1 + configs/dbau1550_defconfig | 1 + configs/dbau1550_el_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/dra7xx_evm_defconfig | 3 +- configs/dra7xx_hs_evm_defconfig | 3 +- configs/draco_defconfig | 1 + configs/dragonboard410c_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/duovero_defconfig | 1 + configs/ea20_defconfig | 1 + configs/eco5pk_defconfig | 1 + configs/ecovec_defconfig | 1 + configs/edb9315a_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/espresso7420_defconfig | 1 + configs/espt_defconfig | 1 + configs/etamin_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/evb-ast2500_defconfig | 1 + configs/evb-px5_defconfig | 1 + configs/evb-rk3036_defconfig | 1 + configs/evb-rk3229_defconfig | 4 +- configs/evb-rk3288_defconfig | 1 + configs/evb-rk3328_defconfig | 23 +- configs/evb-rk3399_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + configs/fennec-rk3288_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 1 + configs/flea3_defconfig | 1 + configs/galileo_defconfig | 1 + configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/geekbox_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/gose_defconfig | 1 + configs/gplugd_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/h2200_defconfig | 1 + configs/harmony_defconfig | 1 + configs/highbank_defconfig | 3 +- configs/hikey_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/hsdk_defconfig | 1 + configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/ids8313_defconfig | 1 + configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/imgtec_xilfpga_defconfig | 1 + configs/imx31_phycore_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 11 +- configs/imx6qdl_icore_nand_defconfig | 3 +- configs/imx6qdl_icore_rqs_defconfig | 3 +- configs/imx6ul_geam_mmc_defconfig | 3 +- configs/imx6ul_geam_nand_defconfig | 3 +- configs/imx6ul_isiot_emmc_defconfig | 3 +- configs/imx6ul_isiot_mmc_defconfig | 3 +- configs/imx6ul_isiot_nand_defconfig | 3 +- configs/inetspace_v2_defconfig | 1 + configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/k2e_evm_defconfig | 6 +- configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 7 +- configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 6 +- configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 6 +- configs/kc1_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge4_defconfig | 1 + configs/kmcoge5ne_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmeter1_defconfig | 1 + configs/kmlion1_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmsugp1_defconfig | 1 + configs/kmsuv31_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/kzm9g_defconfig | 1 + configs/lager_defconfig | 1 + configs/legoev3_defconfig | 1 + configs/liteboard_defconfig | 1 + configs/ls1012afrdm_qspi_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 4 +- configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1021aiot_qspi_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_qspi_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_qspi_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_sdcard_qspi_defconfig | 1 + configs/ls1046ardb_emmc_defconfig | 1 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 1 + configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_defconfig | 1 + configs/ls2080a_emu_defconfig | 1 + configs/ls2080a_simu_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/ls2081ardb_defconfig | 3 +- configs/ls2088ardb_qspi_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/ma5d4evk_defconfig | 1 + configs/marsboard_defconfig | 3 +- configs/mccmon6_nor_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/mcx_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/meesc_dataflash_defconfig | 1 + configs/meesc_defconfig | 1 + configs/mgcoge3un_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/minnowmax_defconfig | 2 +- configs/miqi-rk3288_defconfig | 1 + configs/mpc8308_p1m_defconfig | 1 + configs/ms7722se_defconfig | 1 + configs/ms7750se_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_db-88f7040-nand_defconfig | 73 ++++ configs/mvebu_db-88f7040_defconfig | 71 ++++ configs/mvebu_db_armada8k_defconfig | 1 + configs/mvebu_espressobin-88f3720_defconfig | 1 + configs/mvebu_mcbin-88f8040_defconfig | 1 + configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx25pdk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 3 +- configs/mx28evk_defconfig | 2 +- configs/mx28evk_nand_defconfig | 2 +- configs/mx28evk_spi_defconfig | 2 +- configs/mx31ads_defconfig | 1 + configs/mx31pdk_defconfig | 1 + configs/mx35pdk_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53ard_defconfig | 1 + configs/mx53cx9020_defconfig | 3 +- configs/mx53evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx53smd_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlarm2_defconfig | 1 + configs/mx6dlarm2_lpddr2_defconfig | 1 + configs/mx6qarm2_defconfig | 1 + configs/mx6qarm2_lpddr2_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 44 +++ configs/mx6qsabreauto_defconfig | 45 +++ configs/mx6qsabrelite_defconfig | 1 + configs/mx6sabreauto_defconfig | 2 +- configs/mx6sabresd_defconfig | 1 + configs/mx6slevk_defconfig | 1 + configs/mx6slevk_spinor_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sllevk_defconfig | 1 + configs/mx6sllevk_plugin_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx6ull_14x14_evk_defconfig | 1 + configs/mx6ull_14x14_evk_plugin_defconfig | 1 + configs/mx7ulp_evk_defconfig | 1 + configs/mx7ulp_evk_plugin_defconfig | 1 + configs/nas220_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/novena_defconfig | 1 + configs/nsa310s_defconfig | 1 + configs/nsim_700_defconfig | 1 + configs/nsim_700be_defconfig | 1 + configs/nsim_hs38_defconfig | 1 + configs/nsim_hs38be_defconfig | 1 + configs/nyan-big_defconfig | 4 +- configs/odroid-c2_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/omap5_uevm_defconfig | 3 +- configs/omapl138_lcdk_defconfig | 1 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/opos6uldev_defconfig | 1 + configs/ot1200_defconfig | 3 +- configs/ot1200_spl_defconfig | 3 +- configs/paz00_defconfig | 1 + configs/pb1000_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pcm052_defconfig | 3 +- configs/pcm058_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/pengwyn_defconfig | 1 + configs/pepper_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/pic32mzdask_defconfig | 1 + configs/pico-imx6ul_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/plutux_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/poplar_defconfig | 22 +- configs/popmetal-rk3288_defconfig | 1 + configs/porter_defconfig | 1 + configs/portl2_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/r0p7734_defconfig | 1 + configs/r2dplus_defconfig | 1 + configs/r7780mp_defconfig | 1 + configs/r8a7795_salvator-x_defconfig | 1 + configs/r8a7796_salvator-x_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/riotboard_defconfig | 3 +- configs/rock2_defconfig | 1 + configs/rock_defconfig | 1 + configs/rut_defconfig | 1 + configs/s32v234evb_defconfig | 1 + configs/s5p_goni_defconfig | 1 + configs/sama5d2_ptc_nandflash_defconfig | 1 + configs/sama5d2_ptc_spiflash_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_noblk_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sc_sps_1_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/secomx6quq7_defconfig | 2 +- configs/sh7752evb_defconfig | 1 + configs/sh7753evb_defconfig | 1 + configs/sh7757lcr_defconfig | 1 + configs/sh7763rdp_defconfig | 1 + configs/sh7785lcr_32bit_defconfig | 1 + configs/sh7785lcr_defconfig | 1 + configs/sheep-rk3368_defconfig | 1 + configs/sheevaplug_defconfig | 1 + configs/silk_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/smdkc100_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/sniper_defconfig | 1 + configs/snow_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/socrates_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 2 +- configs/spear300_defconfig | 1 + configs/spear300_nand_defconfig | 1 + configs/spear300_usbtty_defconfig | 1 + configs/spear300_usbtty_nand_defconfig | 1 + configs/spear310_defconfig | 1 + configs/spear310_nand_defconfig | 1 + configs/spear310_pnor_defconfig | 1 + configs/spear310_usbtty_defconfig | 1 + configs/spear310_usbtty_nand_defconfig | 1 + configs/spear310_usbtty_pnor_defconfig | 1 + configs/spear320_defconfig | 1 + configs/spear320_nand_defconfig | 1 + configs/spear320_pnor_defconfig | 1 + configs/spear320_usbtty_defconfig | 1 + configs/spear320_usbtty_nand_defconfig | 1 + configs/spear320_usbtty_pnor_defconfig | 1 + configs/spear600_defconfig | 1 + configs/spear600_nand_defconfig | 1 + configs/spear600_usbtty_defconfig | 1 + configs/spear600_usbtty_nand_defconfig | 1 + configs/spring_defconfig | 1 + configs/stih410-b2260_defconfig | 1 + configs/stm32f429-discovery_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 + configs/stout_defconfig | 1 + configs/stv0991_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/taurus_defconfig | 1 + configs/tb100_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/tec_defconfig | 1 + configs/thuban_defconfig | 1 + configs/thunderx_88xx_defconfig | 1 + configs/ti814x_evm_defconfig | 1 + configs/ti816x_evm_defconfig | 6 +- configs/tinker-rk3288_defconfig | 1 + configs/titanium_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + configs/tqma6dl_mba6_mmc_defconfig | 1 + configs/tqma6dl_mba6_spi_defconfig | 1 + configs/tqma6q_mba6_mmc_defconfig | 1 + configs/tqma6q_mba6_spi_defconfig | 1 + configs/tqma6s_mba6_mmc_defconfig | 1 + configs/tqma6s_mba6_spi_defconfig | 1 + configs/tqma6s_wru4_mmc_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/ts4600_defconfig | 2 +- configs/ts4800_defconfig | 1 + configs/turris_omnia_defconfig | 32 +- configs/twister_defconfig | 1 + configs/udoo_defconfig | 1 + configs/usb_a9263_dataflash_defconfig | 1 + configs/usbarmory_defconfig | 1 + configs/vct_platinum_defconfig | 1 + configs/vct_platinum_onenand_defconfig | 1 + configs/vct_platinum_onenand_small_defconfig | 1 + configs/vct_platinum_small_defconfig | 1 + configs/vct_platinumavc_defconfig | 1 + configs/vct_platinumavc_onenand_defconfig | 1 + configs/vct_platinumavc_onenand_small_defconfig | 1 + configs/vct_platinumavc_small_defconfig | 1 + configs/vct_premium_defconfig | 1 + configs/vct_premium_onenand_defconfig | 1 + configs/vct_premium_onenand_small_defconfig | 1 + configs/vct_premium_small_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/ventana_defconfig | 1 + configs/vexpress_aemv8a_dram_defconfig | 1 + configs/vexpress_aemv8a_juno_defconfig | 1 + configs/vexpress_aemv8a_semi_defconfig | 1 + configs/vexpress_ca15_tc2_defconfig | 1 + configs/vexpress_ca5x2_defconfig | 1 + configs/vexpress_ca9x4_defconfig | 1 + configs/vf610twr_defconfig | 3 +- configs/vf610twr_nand_defconfig | 3 +- configs/vinco_defconfig | 1 + configs/vme8349_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/warp_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + configs/work_92105_defconfig | 1 + configs/x600_defconfig | 1 + configs/xfi3_defconfig | 1 + configs/xilinx_zynqmp_ep_defconfig | 5 +- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 + configs/xilinx_zynqmp_zcu102_defconfig | 5 +- configs/xilinx_zynqmp_zcu102_revB_defconfig | 5 +- configs/xpedite550x_defconfig | 1 + configs/xpress_defconfig | 1 + configs/xpress_spl_defconfig | 1 + configs/xtfpga_defconfig | 1 + configs/zc5202_defconfig | 1 + configs/zc5601_defconfig | 1 + configs/zipitz2_defconfig | 1 + configs/zmx25_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_picozed_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm011_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + disk/part.c | 2 +- disk/part_amiga.c | 4 +- doc/README.enetaddr | 10 +- drivers/bootcount/bootcount_env.c | 11 +- drivers/ddr/fsl/fsl_ddr_gen4.c | 2 +- drivers/ddr/fsl/interactive.c | 8 +- drivers/ddr/fsl/options.c | 6 +- drivers/dfu/dfu.c | 6 +- drivers/dfu/dfu_mmc.c | 2 +- drivers/input/i8042.c | 2 +- drivers/input/input.c | 2 +- drivers/mtd/cfi_flash.c | 2 +- drivers/mtd/dataflash.c | 5 +- drivers/net/dc2114x.c | 2 +- drivers/net/fec_mxc.c | 4 +- drivers/net/fm/b4860.c | 2 +- drivers/net/fm/fdt.c | 2 +- drivers/net/fm/fm.c | 2 +- drivers/net/fsl-mc/mc.c | 10 +- drivers/net/fsl_mcdmafec.c | 4 +- drivers/net/ftgmac100.c | 2 +- drivers/net/ftmac100.c | 2 +- drivers/net/lan91c96.c | 4 +- drivers/net/mcffec.c | 8 +- drivers/net/ne2000_base.c | 6 +- drivers/net/netconsole.c | 14 +- drivers/net/phy/micrel.c | 2 +- drivers/net/sandbox-raw.c | 4 +- drivers/net/sh_eth.c | 2 +- drivers/pci/fsl_pci_init.c | 4 +- drivers/pci/pci.c | 4 +- drivers/pci/pci_common.c | 2 +- drivers/rtc/m41t60.c | 2 +- drivers/scsi/scsi.c | 2 +- drivers/serial/usbtty.c | 9 +- drivers/usb/gadget/designware_udc.c | 2 +- drivers/usb/gadget/ether.c | 14 +- drivers/usb/gadget/f_dfu.c | 2 +- drivers/usb/gadget/f_fastboot.c | 6 +- drivers/usb/host/ehci-fsl.c | 2 +- drivers/video/ati_radeon_fb.c | 3 +- drivers/video/cfb_console.c | 2 +- drivers/video/ct69000.c | 3 +- drivers/video/mb862xx.c | 3 +- drivers/video/mx3fb.c | 2 +- drivers/video/mxsfb.c | 2 +- drivers/video/videomodes.c | 5 +- env/Kconfig | 417 +++++++++++++++++++++ env/Makefile | 57 +++ common/env_attr.c => env/attr.c | 0 common/env_callback.c => env/callback.c | 2 +- common/env_common.c => env/common.c | 46 +-- common/env_dataflash.c => env/dataflash.c | 33 +- common/env_eeprom.c => env/eeprom.c | 61 ++- common/env_embedded.c => env/embedded.c | 0 env/env.c | 151 ++++++++ common/env_ext4.c => env/ext4.c | 28 +- common/env_fat.c => env/fat.c | 48 ++- common/env_flags.c => env/flags.c | 10 +- common/env_flash.c => env/flash.c | 92 +++-- common/env_mmc.c => env/mmc.c | 81 ++-- common/env_nand.c => env/nand.c | 86 +++-- common/env_nowhere.c => env/nowhere.c | 22 +- common/env_nvram.c => env/nvram.c | 26 +- common/env_onenand.c => env/onenand.c | 24 +- common/env_remote.c => env/remote.c | 24 +- common/env_sata.c => env/sata.c | 37 +- common/env_sf.c => env/sf.c | 76 ++-- common/env_ubi.c => env/ubi.c | 59 ++- fs/fs.c | 14 +- fs/ubifs/ubifs.c | 2 +- include/_exports.h | 4 +- include/asm-generic/global_data.h | 4 +- include/common.h | 93 ++++- include/config_fsl_chain_trust.h | 11 - include/configs/10m50_devboard.h | 1 - include/configs/3c120_devboard.h | 1 - include/configs/B4860QDS.h | 8 - include/configs/BSC9131RDB.h | 3 - include/configs/BSC9132QDS.h | 5 - include/configs/C29XPCIE.h | 3 - include/configs/M5208EVBE.h | 5 +- include/configs/M52277EVB.h | 3 - include/configs/M5235EVB.h | 3 +- include/configs/M5249EVB.h | 6 +- include/configs/M5253DEMO.h | 6 +- include/configs/M5253EVBE.h | 4 +- include/configs/M5272C3.h | 6 +- include/configs/M5275EVB.h | 6 +- include/configs/M5282EVB.h | 3 +- include/configs/M53017EVB.h | 3 +- include/configs/M5329EVB.h | 5 +- include/configs/M5373EVB.h | 5 +- include/configs/M54418TWR.h | 3 - include/configs/M54451EVB.h | 2 - include/configs/M54455EVB.h | 3 - include/configs/M5475EVB.h | 1 - include/configs/M5485EVB.h | 1 - include/configs/MCR3000.h | 1 - include/configs/MPC8308RDB.h | 1 - include/configs/MPC8313ERDB.h | 3 - include/configs/MPC8315ERDB.h | 2 - include/configs/MPC8323ERDB.h | 2 - include/configs/MPC832XEMDS.h | 2 - include/configs/MPC8349EMDS.h | 2 - include/configs/MPC8349ITX.h | 2 - include/configs/MPC837XEMDS.h | 2 - include/configs/MPC837XERDB.h | 2 - include/configs/MPC8536DS.h | 4 - include/configs/MPC8540ADS.h | 2 - include/configs/MPC8541CDS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8548CDS.h | 1 - include/configs/MPC8555CDS.h | 1 - include/configs/MPC8560ADS.h | 2 - include/configs/MPC8568MDS.h | 1 - include/configs/MPC8569MDS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 2 - include/configs/MPC8641HPCN.h | 2 - include/configs/MigoR.h | 1 - include/configs/P1010RDB.h | 5 - include/configs/P1022DS.h | 5 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 8 - include/configs/T102xQDS.h | 5 - include/configs/T102xRDB.h | 5 - include/configs/T1040QDS.h | 5 - include/configs/T104xRDB.h | 4 - include/configs/T208xQDS.h | 5 - include/configs/T208xRDB.h | 5 - include/configs/T4240QDS.h | 8 - include/configs/T4240RDB.h | 7 - include/configs/TQM834x.h | 1 - include/configs/UCP1020.h | 5 - include/configs/adp-ae3xx.h | 1 - include/configs/adp-ag101p.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/am335x_evm.h | 6 - include/configs/am335x_igep003x.h | 1 - include/configs/am335x_shc.h | 9 - include/configs/am335x_sl50.h | 4 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 8 - include/configs/am57xx_evm.h | 1 - include/configs/amcore.h | 5 +- include/configs/ap121.h | 1 - include/configs/ap143.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/apalis-tk1.h | 1 - include/configs/apalis_imx6.h | 2 - include/configs/apalis_t30.h | 1 - include/configs/apf27.h | 1 - include/configs/apx4devkit.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/arndale.h | 1 - include/configs/aspenite.h | 1 - include/configs/astro_mcf5373l.h | 4 +- include/configs/at91-sama5_common.h | 3 - include/configs/at91rm9200ek.h | 1 - include/configs/at91sam9260ek.h | 4 - include/configs/at91sam9261ek.h | 3 - include/configs/at91sam9263ek.h | 3 - include/configs/at91sam9m10g45ek.h | 2 - include/configs/at91sam9n12ek.h | 3 - include/configs/at91sam9rlek.h | 3 - include/configs/at91sam9x5ek.h | 4 - include/configs/axs10x.h | 1 - include/configs/baltos.h | 1 - include/configs/bav335x.h | 7 - include/configs/bcm23550_w1d.h | 1 - include/configs/bcm28155_ap.h | 1 - include/configs/bcm_ep_board.h | 1 - include/configs/bcm_northstar2.h | 1 - include/configs/beaver.h | 1 - include/configs/bg0900.h | 1 - include/configs/blanche.h | 2 - include/configs/boston.h | 1 - include/configs/brppt1.h | 9 - include/configs/brxre1.h | 2 - include/configs/calimain.h | 1 - include/configs/cardhu.h | 1 - include/configs/cei-tk1-som.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/chiliboard.h | 1 - include/configs/cl-som-am57x.h | 1 - include/configs/clearfog.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cm_t335.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/cm_t43.h | 1 - include/configs/cm_t54.h | 1 - include/configs/cobra5272.h | 6 +- include/configs/colibri_imx6.h | 2 - include/configs/colibri_imx7.h | 1 - include/configs/colibri_pxa270.h | 5 - include/configs/colibri_t20.h | 1 - include/configs/colibri_t30.h | 1 - include/configs/comtrend_ar5387un.h | 1 - include/configs/comtrend_ct5361.h | 1 - include/configs/comtrend_vr3032u.h | 1 - include/configs/controlcenterd.h | 3 - include/configs/controlcenterdc.h | 1 - include/configs/corenet_ds.h | 8 - include/configs/corvus.h | 1 - include/configs/cyrus.h | 1 - include/configs/da850evm.h | 7 - include/configs/dalmore.h | 1 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/dbau1x00.h | 2 - include/configs/devkit3250.h | 1 - include/configs/devkit8000.h | 1 - include/configs/dns325.h | 3 - include/configs/dockstar.h | 3 - include/configs/dra7xx_evm.h | 3 - include/configs/dragonboard410c.h | 1 - include/configs/dreamplug.h | 3 - include/configs/ds109.h | 3 - include/configs/ds414.h | 1 - include/configs/duovero.h | 1 - include/configs/e2220-1170.h | 1 - include/configs/ea20.h | 4 - include/configs/eb_cpu5282.h | 1 - include/configs/ecovec.h | 1 - include/configs/edb93xx.h | 1 - include/configs/edminiv2.h | 1 - include/configs/efi-x86.h | 2 - include/configs/el6x_common.h | 2 - include/configs/espresso7420.h | 1 - include/configs/espt.h | 1 - include/configs/ethernut5.h | 1 - include/configs/evb_ast2500.h | 2 - include/configs/evb_px5.h | 1 - include/configs/evb_rk3229.h | 1 - include/configs/evb_rk3288.h | 1 - include/configs/evb_rk3328.h | 1 - include/configs/evb_rk3399.h | 1 - include/configs/exynos5-dt-common.h | 1 - include/configs/fennec_rk3288.h | 1 - include/configs/firefly-rk3288.h | 1 - include/configs/flea3.h | 2 - include/configs/ge_bx50v3.h | 1 - include/configs/geekbox.h | 1 - include/configs/goflexhome.h | 3 - include/configs/gplugd.h | 1 - include/configs/guruplug.h | 3 - include/configs/gw_ventana.h | 7 - include/configs/h2200.h | 1 - include/configs/harmony.h | 1 - include/configs/highbank.h | 1 - include/configs/hikey.h | 1 - include/configs/hrcon.h | 2 - include/configs/hsdk.h | 1 - include/configs/huawei_hg556a.h | 1 - include/configs/ib62x0.h | 3 - include/configs/iconnect.h | 3 - include/configs/ids8313.h | 1 - include/configs/imgtec_xilfpga.h | 1 - include/configs/imx27lite-common.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/imx6_logic.h | 1 - include/configs/integratorap.h | 1 - include/configs/integratorcp.h | 1 - include/configs/ipam390.h | 1 - include/configs/jetson-tk1.h | 1 - include/configs/k2e_evm.h | 1 - include/configs/k2g_evm.h | 1 - include/configs/k2hk_evm.h | 1 - include/configs/k2l_evm.h | 1 - include/configs/kc1.h | 1 - include/configs/km/km83xx-common.h | 2 - include/configs/km/km_arm.h | 2 - include/configs/km/kmp204x-common.h | 1 - include/configs/kylin_rk3036.h | 2 - include/configs/kzm9g.h | 1 - include/configs/lacie_kw.h | 1 - include/configs/legoev3.h | 1 - include/configs/liteboard.h | 1 - include/configs/ls1012a_common.h | 1 - include/configs/ls1021aiot.h | 2 - include/configs/ls1021aqds.h | 4 - include/configs/ls1021atwr.h | 3 - include/configs/ls1043aqds.h | 4 - include/configs/ls1043ardb.h | 3 - include/configs/ls1046aqds.h | 4 - include/configs/ls1046ardb.h | 2 - include/configs/ls2080a_common.h | 1 - include/configs/ls2080a_emu.h | 1 - include/configs/ls2080a_simu.h | 1 - include/configs/ls2080aqds.h | 3 - include/configs/ls2080ardb.h | 2 - include/configs/lsxl.h | 3 - include/configs/m28evk.h | 3 - include/configs/m53evk.h | 3 - include/configs/ma5d4evk.h | 1 - include/configs/malta.h | 1 - include/configs/maxbcm.h | 1 - include/configs/mccmon6.h | 1 - include/configs/mcx.h | 1 - include/configs/medcom-wide.h | 1 - include/configs/meesc.h | 2 - include/configs/meson-gxbb-common.h | 1 - include/configs/microblaze-generic.h | 5 - include/configs/miqi_rk3288.h | 1 - include/configs/mpc8308_p1m.h | 1 - include/configs/mpr2.h | 1 - include/configs/ms7720se.h | 1 - include/configs/ms7722se.h | 1 - include/configs/ms7750se.h | 1 - include/configs/mvebu_armada-37xx.h | 1 - include/configs/mvebu_armada-8k.h | 3 - include/configs/mx23_olinuxino.h | 1 - include/configs/mx23evk.h | 1 - include/configs/mx25pdk.h | 1 - include/configs/mx31ads.h | 1 - include/configs/mx31pdk.h | 1 - include/configs/mx35pdk.h | 3 - include/configs/mx51evk.h | 1 - include/configs/mx53ard.h | 1 - include/configs/mx53cx9020.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53smd.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6qarm2.h | 1 - include/configs/mx6sabre_common.h | 2 - include/configs/mx6slevk.h | 2 - include/configs/mx6sllevk.h | 1 - include/configs/mx6sxsabreauto.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx6ullevk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mx7ulp_evk.h | 1 - include/configs/nas220.h | 3 - include/configs/netgear_cg3100d.h | 1 - include/configs/nitrogen6x.h | 6 - include/configs/nokia_rx51.h | 2 - include/configs/novena.h | 3 - include/configs/nsa310s.h | 3 - include/configs/nsim.h | 1 - include/configs/nyan-big.h | 1 - include/configs/odroid.h | 1 - include/configs/odroid_xu3.h | 4 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_cairo.h | 1 - include/configs/omap3_evm.h | 2 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_overo.h | 1 - include/configs/omap3_pandora.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/omap4_panda.h | 1 - include/configs/omap4_sdp4430.h | 1 - include/configs/omap5_uevm.h | 1 - include/configs/omapl138_lcdk.h | 13 - include/configs/openrd.h | 3 - include/configs/opos6uldev.h | 1 - include/configs/origen.h | 1 - include/configs/ot1200.h | 1 - include/configs/p1_p2_rdb_pc.h | 5 - include/configs/p1_twr.h | 3 - include/configs/p2371-0000.h | 1 - include/configs/p2371-2180.h | 1 - include/configs/p2571.h | 1 - include/configs/p2771-0000.h | 1 - include/configs/paz00.h | 1 - include/configs/pb1x00.h | 2 - include/configs/pcm051.h | 1 - include/configs/pcm058.h | 1 - include/configs/pengwyn.h | 1 - include/configs/pepper.h | 1 - include/configs/phycore_rk3288.h | 1 - include/configs/pic32mzdask.h | 1 - include/configs/pico-imx6ul.h | 1 - include/configs/pico-imx7d.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/platinum.h | 2 - include/configs/plutux.h | 1 - include/configs/pm9261.h | 3 - include/configs/pm9263.h | 3 - include/configs/pm9g45.h | 1 - include/configs/pogo_e02.h | 3 - include/configs/poplar.h | 1 - include/configs/popmetal_rk3288.h | 1 - include/configs/puma_rk3399.h | 1 - include/configs/qemu-mips.h | 2 - include/configs/qemu-mips64.h | 2 - include/configs/qemu-ppce500.h | 2 - include/configs/qemu-x86.h | 2 - include/configs/r0p7734.h | 1 - include/configs/r2dplus.h | 1 - include/configs/r7780mp.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rk3036_common.h | 1 - include/configs/rock.h | 1 - include/configs/rock2.h | 1 - include/configs/rpi.h | 1 - include/configs/rsk7203.h | 1 - include/configs/rsk7264.h | 1 - include/configs/rsk7269.h | 1 - include/configs/rv1108_common.h | 1 - include/configs/s32v234evb.h | 1 - include/configs/s5p_goni.h | 1 - include/configs/s5pc210_universal.h | 1 - include/configs/sagem_f@st1704.h | 1 - include/configs/salvator-x.h | 1 - include/configs/sama5d2_ptc.h | 1 - include/configs/sama5d3_xplained.h | 2 - include/configs/sama5d3xek.h | 2 - include/configs/sandbox.h | 1 - include/configs/sansa_fuze_plus.h | 1 - include/configs/sbc8349.h | 2 - include/configs/sbc8548.h | 1 - include/configs/sbc8641d.h | 1 - include/configs/sc_sps_1.h | 3 - include/configs/seaboard.h | 1 - include/configs/sfr_nb4_ser.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/sh7763rdp.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/sheep_rk3368.h | 1 - include/configs/sheevaplug.h | 3 - include/configs/shmin.h | 1 - include/configs/siemens-am33x-common.h | 5 - include/configs/smartweb.h | 1 - include/configs/smdkc100.h | 1 - include/configs/smdkv310.h | 1 - include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/sniper.h | 1 - include/configs/socfpga_arria10_socdk.h | 1 - include/configs/socfpga_arria5_socdk.h | 2 - include/configs/socfpga_cyclone5_socdk.h | 2 - include/configs/socfpga_de0_nano_soc.h | 2 - include/configs/socfpga_de10_nano.h | 2 - include/configs/socfpga_de1_soc.h | 2 - include/configs/socfpga_is1.h | 1 - include/configs/socfpga_mcvevk.h | 1 - include/configs/socfpga_sockit.h | 2 - include/configs/socfpga_socrates.h | 2 - include/configs/socfpga_sr1500.h | 1 - include/configs/socfpga_vining_fpga.h | 1 - include/configs/socrates.h | 1 - include/configs/spear3xx_evb.h | 6 - include/configs/spear6xx_evb.h | 6 - include/configs/stih410-b2260.h | 1 - include/configs/stm32f429-discovery.h | 1 - include/configs/stm32f746-disco.h | 1 - include/configs/strider.h | 2 - include/configs/stv0991.h | 1 - include/configs/tam3517-common.h | 3 +- include/configs/tao3530.h | 1 - include/configs/taurus.h | 1 - include/configs/tb100.h | 1 - include/configs/tbs2910.h | 1 - include/configs/tec-ng.h | 1 - include/configs/tec.h | 1 - include/configs/theadorable.h | 1 - include/configs/thunderx_88xx.h | 1 - include/configs/ti814x_evm.h | 2 - include/configs/ti816x_evm.h | 1 - include/configs/tinker_rk3288.h | 1 - include/configs/titanium.h | 2 - include/configs/topic_miami.h | 1 - include/configs/tplink_wdr4300.h | 1 - include/configs/tqma6.h | 2 - include/configs/trats.h | 1 - include/configs/trats2.h | 1 - include/configs/tricorder.h | 5 - include/configs/trimslice.h | 1 - include/configs/ts4800.h | 1 - include/configs/turris_omnia.h | 1 - include/configs/udoo.h | 1 - include/configs/udoo_neo.h | 1 - include/configs/uniphier.h | 3 - include/configs/usb_a9263.h | 1 - include/configs/usbarmory.h | 1 - include/configs/vct.h | 2 - include/configs/ve8313.h | 1 - include/configs/venice2.h | 1 - include/configs/ventana.h | 1 - include/configs/vexpress_aemv8a.h | 1 - include/configs/vexpress_common.h | 1 - include/configs/veyron.h | 1 - include/configs/vining_2000.h | 1 - include/configs/vme8349.h | 2 - include/configs/wandboard.h | 1 - include/configs/warp.h | 1 - include/configs/warp7.h | 1 - include/configs/woodburn_common.h | 2 - include/configs/work_92105.h | 1 - include/configs/x600.h | 2 - include/configs/x86-chromebook.h | 2 - include/configs/x86-common.h | 1 - include/configs/xfi3.h | 1 - include/configs/xilinx-ppc.h | 2 - include/configs/xilinx_zynqmp.h | 4 - include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - include/configs/xpress.h | 1 - include/configs/xtfpga.h | 1 - include/configs/zipitz2.h | 1 - include/configs/zmx25.h | 1 - include/configs/zynq-common.h | 4 - include/environment.h | 133 ++++++- include/exports.h | 4 +- include/fsl_validate.h | 2 +- include/image.h | 8 +- include/net.h | 12 +- include/search.h | 2 +- lib/fdtdec.c | 2 +- lib/smbios.c | 2 +- lib/uuid.c | 2 +- net/arp.c | 2 +- net/bootp.c | 14 +- net/dns.c | 2 +- net/eth-uclass.c | 10 +- net/eth_common.c | 34 +- net/eth_internal.h | 4 +- net/eth_legacy.c | 8 +- net/link_local.c | 2 +- net/net.c | 14 +- net/net_rand.h | 2 +- net/tftp.c | 10 +- post/post.c | 2 +- scripts/Makefile.spl | 4 +- scripts/config_whitelist.txt | 9 - test/command_ut.c | 16 +- test/dm/eth.c | 108 +++--- tools/Makefile | 4 +- tools/env/fw_env.c | 2 +- tools/env/fw_env.h | 4 +- tools/env/fw_env_main.c | 4 +- 1784 files changed, 3895 insertions(+), 3217 deletions(-) create mode 100644 configs/mvebu_db-88f7040-nand_defconfig create mode 100644 configs/mvebu_db-88f7040_defconfig create mode 100644 configs/mx6qpsabreauto_defconfig create mode 100644 configs/mx6qsabreauto_defconfig create mode 100644 env/Kconfig create mode 100644 env/Makefile rename common/env_attr.c => env/attr.c (100%) rename common/env_callback.c => env/callback.c (98%) rename common/env_common.c => env/common.c (87%) rename common/env_dataflash.c => env/dataflash.c (75%) rename common/env_eeprom.c => env/eeprom.c (86%) rename common/env_embedded.c => env/embedded.c (100%) create mode 100644 env/env.c rename common/env_ext4.c => env/ext4.c (91%) rename common/env_fat.c => env/fat.c (75%) rename common/env_flags.c => env/flags.c (98%) rename common/env_flash.c => env/flash.c (80%) rename common/env_mmc.c => env/mmc.c (88%) rename common/env_nand.c => env/nand.c (86%) rename common/env_nowhere.c => env/nowhere.c (58%) rename common/env_nvram.c => env/nvram.c (86%) rename common/env_onenand.c => env/onenand.c (89%) rename common/env_remote.c => env/remote.c (73%) rename common/env_sata.c => env/sata.c (84%) rename common/env_sf.c => env/sf.c (87%) rename common/env_ubi.c => env/ubi.c (87%)
Rsync all defconfig files using moveconfig.py
Changes in v2: - Add a patch to resync configs
configs/MCR3000_defconfig | 98 +++++++++++++++---------------------- configs/am335x_boneblack_defconfig | 1 - configs/am335x_hs_evm_defconfig | 2 - configs/evb-rk3229_defconfig | 3 +- configs/evb-rk3328_defconfig | 22 ++++----- configs/imx6qdl_icore_mmc_defconfig | 8 +-- configs/k2e_evm_defconfig | 5 +- configs/k2g_evm_defconfig | 6 +-- configs/k2hk_evm_defconfig | 5 +- configs/k2l_evm_defconfig | 5 +- configs/ls1012aqds_qspi_defconfig | 2 +- configs/mx53cx9020_defconfig | 2 +- configs/mx6sabreauto_defconfig | 1 - configs/nyan-big_defconfig | 4 +- configs/ot1200_defconfig | 2 +- configs/ot1200_spl_defconfig | 2 +- configs/poplar_defconfig | 21 +++----- configs/ti816x_evm_defconfig | 5 -- configs/turris_omnia_defconfig | 31 +++--------- 19 files changed, 83 insertions(+), 142 deletions(-)
diff --git a/configs/MCR3000_defconfig b/configs/MCR3000_defconfig index 562face283..84849684e4 100644 --- a/configs/MCR3000_defconfig +++ b/configs/MCR3000_defconfig @@ -1,47 +1,19 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_MCR3000=y -CONFIG_BOOTDELAY=5 -CONFIG_HUSH_PARSER=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_NET=y -CONFIG_CMD_DHCP=y -# CONFIG_LED_STATUS_BOARD_SPECIFIC is not set -# CONFIG_MMC is not set -CONFIG_MTD_NOR_FLASH=y -# CONFIG_PCI is not set -CONFIG_OF_LIBFDT=y -CONFIG_SYS_PROMPT="S3K> " -CONFIG_NETDEVICES=y -CONFIG_MPC8XX_FEC=y - -CONFIG_CMD_SAVEENV=y -CONFIG_CMD_FLASH=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_ASKENV=y -CONFIG_CMD_MTDPARTS=y -CONFIG_CMD_NAND=y -# CONFIG_CMD_BDI is not set -# CONFIG_CMD_ECHO is not set -# CONFIG_CMD_FPGA is not set -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_ITEST is not set -# CONFIG_CMD_CONSOLE is not set -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -# CONFIG_CMD_MD5SUM is not set -# CONFIG_CMD_MISC is not set -# CONFIG_CMD_SETGETDCR is not set -# CONFIG_CMD_SHA1 is not set -# CONFIG_CMD_SOURCE is not set +CONFIG_8xx_GCLK_FREQ=132000000 CONFIG_CMD_IMMAP=y - -CONFIG_SYS_IMMR=0xFF000000 - -CONFIG_SYS_OR0_PRELIM=0xFFC00926 +CONFIG_SYS_SIUMCR=0x00600400 +CONFIG_SYS_SYPCR=0xFFFFFF8F +CONFIG_SYS_TBSCR=0x00C3 +CONFIG_SYS_PISCR=0x0000 +CONFIG_SYS_PLPRCR_BOOL=y +CONFIG_SYS_PLPRCR=0x00460004 +CONFIG_SYS_SCCR=0x00C20000 +CONFIG_SYS_SCCR_MASK=0x60000000 +CONFIG_SYS_DER=0x2002000F CONFIG_SYS_BR0_PRELIM=0x04000801 +CONFIG_SYS_OR0_PRELIM=0xFFC00926 CONFIG_SYS_BR1_PRELIM_BOOL=y CONFIG_SYS_BR1_PRELIM=0x00000081 CONFIG_SYS_OR1_PRELIM=0xFE000E00 @@ -63,26 +35,36 @@ CONFIG_SYS_OR6_PRELIM=0xFFFF0908 CONFIG_SYS_BR7_PRELIM_BOOL=y CONFIG_SYS_BR7_PRELIM=0x1C000001 CONFIG_SYS_OR7_PRELIM=0xFFFF810A - -CONFIG_8xx_GCLK_FREQ=132000000 - -CONFIG_SYS_SYPCR=0xFFFFFF8F -CONFIG_SYS_SIUMCR=0x00600400 -CONFIG_SYS_TBSCR=0x00C3 -CONFIG_SYS_PISCR=0x0000 -CONFIG_SYS_PLPRCR_BOOL=y -CONFIG_SYS_PLPRCR=0x00460004 -CONFIG_SYS_SCCR_MASK=0x60000000 -CONFIG_SYS_SCCR=0x00C20000 -CONFIG_SYS_DER=0x2002000F - -CONFIG_AUTOBOOT=y +CONFIG_SYS_IMMR=0xFF000000 +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=5 +CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="S3K> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="\nEnter password - autoboot in %d sec...\n" CONFIG_AUTOBOOT_DELAY_STR="root" - -CONFIG_OF_BOARD_SETUP=y - -CONFIG_LZMA=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_NAND=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +# CONFIG_CMD_MISC is not set +# CONFIG_MMC is not set +CONFIG_MTD_NOR_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_MPC8XX_FEC=y +# CONFIG_PCI is not set CONFIG_SHA256=y - +CONFIG_LZMA=y +CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index c69867705e..5ad992c6e1 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -23,7 +23,6 @@ CONFIG_FASTBOOT_BUF_ADDR=0x81000000 CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set -CONFIG_CMD_FASTBOOT=y # CONFIG_CMD_SETEXPR is not set CONFIG_DFU_TFTP=y CONFIG_DFU_MMC=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 8ad35c22dc..b0c88a6273 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -21,7 +21,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_YMODEM_SUPPORT is not set # CONFIG_CMD_IMLS is not set -CONFIG_CMD_FASTBOOT=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_SPL_EFI_PARTITION is not set @@ -47,7 +46,6 @@ CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y CONFIG_USB_STORAGE=y -CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 0c3b6f780a..0952fdc698 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -8,6 +8,7 @@ CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y CONFIG_TARGET_EVB_RK3229=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3229-evb" +CONFIG_DEBUG_UART=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200 @@ -31,11 +32,9 @@ CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_PINCTRL=y CONFIG_PINCTRL_ROCKCHIP_RK322X=y -# CONFIG_SPL_PINCTRL_FULL is not set CONFIG_RAM=y CONFIG_SPL_RAM=y CONFIG_BAUDRATE=1500000 -CONFIG_DEBUG_UART=y CONFIG_DEBUG_UART_BASE=0x11030000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index aabc8a48d9..82f03e479c 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -5,6 +5,13 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3328-evb" CONFIG_DEBUG_UART=y CONFIG_FIT=y # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_CMD_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x00800800 +CONFIG_FASTBOOT_BUF_SIZE=0x08000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPT=y @@ -31,28 +38,19 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_SYSRESET=y CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_RK=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_GADGET_DUALSPEED=y CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Rockchip" CONFIG_G_DNL_VENDOR_NUM=0x2207 CONFIG_G_DNL_PRODUCT_NUM=0x330a -CONFIG_FASTBOOT=y -CONFIG_CMD_FASTBOOT=y -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=1 -CONFIG_FASTBOOT_BUF_ADDR=0x00800800 -CONFIG_FASTBOOT_BUF_SIZE=0x08000000 CONFIG_USE_TINY_PRINTF=y CONFIG_ERRNO_STR=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index b0ba7ffb28..4a124b8acc 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y # CONFIG_CMD_BMODE is not set CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" +CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y @@ -42,10 +43,9 @@ CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y -CONFIG_MXC_UART=y -CONFIG_IMX_THERMAL=y -CONFIG_VIDEO_IPUV3=y -CONFIG_DEBUG_UART=y CONFIG_DEBUG_UART_MXC=y CONFIG_DEBUG_UART_BASE=0x021f0000 CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_MXC_UART=y +CONFIG_IMX_THERMAL=y +CONFIG_VIDEO_IPUV3=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index dccaa09e67..4949f22c01 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -11,6 +11,8 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="keystone-k2e-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DTB_RESELECT=y +CONFIG_FIT_EMBED=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y @@ -43,6 +45,3 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_DTB_RESELECT=y -CONFIG_FIT_EMBED=y -CONFIG_OF_LIST="keystone-k2e-evm" diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index a43d7fc779..1eed60576c 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -11,6 +11,8 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="keystone-k2g-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DTB_RESELECT=y +CONFIG_FIT_EMBED=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y @@ -27,6 +29,7 @@ CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_OF_LIST="keystone-k2g-generic keystone-k2g-evm keystone-k2g-ice" CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_MMC=y @@ -45,6 +48,3 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_DTB_RESELECT=y -CONFIG_FIT_EMBED=y -CONFIG_OF_LIST="keystone-k2g-generic keystone-k2g-evm keystone-k2g-ice" diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index e0c266a77c..b9868395a4 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -11,6 +11,8 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="keystone-k2hk-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DTB_RESELECT=y +CONFIG_FIT_EMBED=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y @@ -43,6 +45,3 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_DTB_RESELECT=y -CONFIG_FIT_EMBED=y -CONFIG_OF_LIST="keystone-k2hk-evm" diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 568e8dda67..64301c3bff 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -11,6 +11,8 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="keystone-k2l-evm" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DTB_RESELECT=y +CONFIG_FIT_EMBED=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y @@ -43,6 +45,3 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_DTB_RESELECT=y -CONFIG_FIT_EMBED=y -CONFIG_OF_LIST="keystone-k2l-evm" diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 695d7d1349..5ce3b0b1cc 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -30,8 +30,8 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -# CONFIG_BLK is not set CONFIG_SCSI=y +# CONFIG_BLK is not set CONFIG_DM_MMC=y # CONFIG_DM_MMC_OPS is not set CONFIG_DM_SPI_FLASH=y diff --git a/configs/mx53cx9020_defconfig b/configs/mx53cx9020_defconfig index 9609647f0b..9b3a664a7a 100644 --- a/configs/mx53cx9020_defconfig +++ b/configs/mx53cx9020_defconfig @@ -12,13 +12,13 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y +CONFIG_CMD_PXE=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_PXE=y CONFIG_OF_CONTROL=y CONFIG_FPGA_ALTERA=y CONFIG_FPGA_CYCLON2=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 236af953b5..76c39cea67 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -39,7 +39,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y -# CONFIG_MTD_NOR_FLASH is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index cb3b0a85cf..8183856d94 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -3,6 +3,7 @@ CONFIG_TEGRA=y CONFIG_TEGRA124=y CONFIG_TARGET_NYAN_BIG=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-nyan-big" +CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_OF_SYSTEM_SETUP=y @@ -27,8 +28,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_BMP=y -CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_CACHE=y +CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y @@ -51,7 +52,6 @@ CONFIG_PMIC_AS3722=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y -CONFIG_DEBUG_UART=y CONFIG_DEBUG_UART_BASE=0x70006000 CONFIG_DEBUG_UART_CLOCK=408000000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index 7f1d7a8716..d3e8a275c8 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -23,12 +23,12 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 6c33853987..531fb334ce 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -31,12 +31,12 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/poplar_defconfig b/configs/poplar_defconfig index 8f9f40f64d..1c617713a9 100644 --- a/configs/poplar_defconfig +++ b/configs/poplar_defconfig @@ -2,25 +2,18 @@ CONFIG_ARM=y CONFIG_TARGET_POPLAR=y CONFIG_IDENT_STRING="poplar" CONFIG_DEFAULT_DEVICE_TREE="hi3798cv200-poplar" -CONFIG_SYS_PROMPT="poplar# " CONFIG_DISTRO_DEFAULTS=y -CONFIG_DISPLAY_CPUINFO=n -CONFIG_DISPLAY_BOARDINFO=y -CONFIG_ISO_PARTITION=n +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SYS_PROMPT="poplar# " +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_UNZIP=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_ISO_PARTITION is not set CONFIG_MMC_DW=y CONFIG_MMC_DW_K3=y -CONFIG_PL011_SERIAL=y -CONFIG_PSCI_RESET=y CONFIG_USB=y -CONFIG_USB_EHCI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y -CONFIG_NET=y -# CONFIG_CMD_IMLS is not set -# CONFIG_DM_GPIO is not set CONFIG_LIB_RAND=y -CONFIG_CMD_UNZIP=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y - diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 2ae72b2f77..2448aa51b6 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -36,11 +36,6 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y # CONFIG_USE_PRIVATE_LIBGCC is not set diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 512b9da74d..4a45ed0ea4 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -7,15 +7,17 @@ CONFIG_TARGET_TURRIS_OMNIA=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y -CONFIG_SPL_BOOT_DEVICE_SPI=y -CONFIG_DISTRO_DEFAULTS=y CONFIG_DEFAULT_DEVICE_TREE="armada-385-turris-omnia" +CONFIG_DEBUG_UART=y +CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y @@ -23,40 +25,19 @@ CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -CONFIG_CMD_GO=y -CONFIG_CMD_RUN=y -CONFIG_CMD_MMC=y -CONFIG_CMD_SAVEENV=y -CONFIG_CMD_LOADB=y -CONFIG_CMD_LOADS=y -CONFIG_CMD_MEMORY=y -CONFIG_CMD_ECHO=y -CONFIG_CMD_SETEXPR=y -# CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set -CONFIG_DOS_PARTITION=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_MISC=y CONFIG_ATSHA204A=y -CONFIG_DEBUG_UART=y -CONFIG_DEBUG_UART_NS16550=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_MV=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y -CONFIG_MMC_SDHCI=y -CONFIG_MMC_SDHCI_MV=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_EHCI=y -CONFIG_USB_EHCI_MARVELL=y CONFIG_USB_STORAGE=y CONFIG_WDT=y CONFIG_WDT_ORION=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_CMDLINE=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="=> " -# CONFIG_DISPLAY_BOARDINFO is not set
This target stops us using 'env' as a subdirectory. It is not mentioned in the help so seems to be an internal target. Rename it.
Changes in v2: None
Makefile | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index 452596485d..42d80a2ea8 100644 --- a/Makefile +++ b/Makefile @@ -1455,14 +1455,14 @@ checkarmreloc: u-boot false; \ fi
-env: scripts_basic +environ: scripts_basic $(Q)$(MAKE) $(build)=tools/$@
tools-only: scripts_basic $(version_h) $(timestamp_h) $(Q)$(MAKE) $(build)=tools
tools-all: export HOST_TOOLS_ALL=y -tools-all: env tools ; +tools-all: environ tools ;
cross_tools: export CROSS_BUILD_TOOLS=y cross_tools: tools ;
About a quarter of the files in common/ relate to the environment. It seems better to put these into their own subdirectory and remove the prefix.
Changes in v2: None
Kconfig | 2 + Makefile | 1 + arch/sh/cpu/u-boot.lds | 4 +- board/freescale/mx31ads/u-boot.lds | 2 +- common/Kconfig | 69 ------------------------------- common/Makefile | 49 +--------------------- env/Kconfig | 68 ++++++++++++++++++++++++++++++ env/Makefile | 57 +++++++++++++++++++++++++ common/env_attr.c => env/attr.c | 0 common/env_callback.c => env/callback.c | 0 common/env_common.c => env/common.c | 0 common/env_dataflash.c => env/dataflash.c | 0 common/env_eeprom.c => env/eeprom.c | 0 common/env_embedded.c => env/embedded.c | 0 common/env_ext4.c => env/ext4.c | 0 common/env_fat.c => env/fat.c | 0 common/env_flags.c => env/flags.c | 0 common/env_flash.c => env/flash.c | 0 common/env_mmc.c => env/mmc.c | 0 common/env_nand.c => env/nand.c | 0 common/env_nowhere.c => env/nowhere.c | 0 common/env_nvram.c => env/nvram.c | 0 common/env_onenand.c => env/onenand.c | 0 common/env_remote.c => env/remote.c | 0 common/env_sata.c => env/sata.c | 0 common/env_sf.c => env/sf.c | 0 common/env_ubi.c => env/ubi.c | 0 include/configs/M5208EVBE.h | 4 +- include/configs/M5235EVB.h | 2 +- include/configs/M5249EVB.h | 4 +- include/configs/M5253DEMO.h | 4 +- include/configs/M5253EVBE.h | 2 +- include/configs/M5272C3.h | 4 +- include/configs/M5275EVB.h | 4 +- include/configs/M5282EVB.h | 2 +- include/configs/M53017EVB.h | 2 +- include/configs/M5329EVB.h | 4 +- include/configs/M5373EVB.h | 4 +- include/configs/amcore.h | 4 +- include/configs/astro_mcf5373l.h | 2 +- include/configs/cobra5272.h | 4 +- scripts/Makefile.spl | 4 +- tools/Makefile | 4 +- 43 files changed, 159 insertions(+), 147 deletions(-) create mode 100644 env/Kconfig create mode 100644 env/Makefile rename common/env_attr.c => env/attr.c (100%) rename common/env_callback.c => env/callback.c (100%) rename common/env_common.c => env/common.c (100%) rename common/env_dataflash.c => env/dataflash.c (100%) rename common/env_eeprom.c => env/eeprom.c (100%) rename common/env_embedded.c => env/embedded.c (100%) rename common/env_ext4.c => env/ext4.c (100%) rename common/env_fat.c => env/fat.c (100%) rename common/env_flags.c => env/flags.c (100%) rename common/env_flash.c => env/flash.c (100%) rename common/env_mmc.c => env/mmc.c (100%) rename common/env_nand.c => env/nand.c (100%) rename common/env_nowhere.c => env/nowhere.c (100%) rename common/env_nvram.c => env/nvram.c (100%) rename common/env_onenand.c => env/onenand.c (100%) rename common/env_remote.c => env/remote.c (100%) rename common/env_sata.c => env/sata.c (100%) rename common/env_sf.c => env/sf.c (100%) rename common/env_ubi.c => env/ubi.c (100%)
diff --git a/Kconfig b/Kconfig index bb80adacf4..f48912b7df 100644 --- a/Kconfig +++ b/Kconfig @@ -358,6 +358,8 @@ source "disk/Kconfig"
source "dts/Kconfig"
+source "env/Kconfig" + source "net/Kconfig"
source "drivers/Kconfig" diff --git a/Makefile b/Makefile index 42d80a2ea8..bf2c072b04 100644 --- a/Makefile +++ b/Makefile @@ -687,6 +687,7 @@ libs-y += drivers/usb/phy/ libs-y += drivers/usb/ulpi/ libs-y += cmd/ libs-y += common/ +libs-y += env/ libs-$(CONFIG_API) += api/ libs-$(CONFIG_HAS_POST) += post/ libs-y += test/ diff --git a/arch/sh/cpu/u-boot.lds b/arch/sh/cpu/u-boot.lds index bbf9ff485f..7fc91bc4aa 100644 --- a/arch/sh/cpu/u-boot.lds +++ b/arch/sh/cpu/u-boot.lds @@ -33,9 +33,9 @@ SECTIONS KEEP(CONFIG_BOARDDIR/lowlevel_init.o (.text .spiboot1.text)) KEEP(*(.spiboot2.text)) . = ALIGN(8192); - common/env_embedded.o (.ppcenv) + env/embedded.o (.ppcenv) . = ALIGN(8192); - common/env_embedded.o (.ppcenvr) + env/embedded.o (.ppcenvr) . = ALIGN(8192); *(.text) . = ALIGN(4); diff --git a/board/freescale/mx31ads/u-boot.lds b/board/freescale/mx31ads/u-boot.lds index 8a4a8a2f07..71a63f188e 100644 --- a/board/freescale/mx31ads/u-boot.lds +++ b/board/freescale/mx31ads/u-boot.lds @@ -30,7 +30,7 @@ SECTIONS drivers/mtd/built-in.o (.text*)
. = DEFINED(env_offset) ? env_offset : .; - common/env_embedded.o(.text*) + env/embedded.o(.text*)
*(.text*) } diff --git a/common/Kconfig b/common/Kconfig index 361346b092..5f439bd110 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -174,75 +174,6 @@ config SPI_BOOT
endmenu
-menu "Environment" - -if ARCH_SUNXI - -choice - prompt "Environment Device" - default ENV_IS_IN_MMC if ARCH_SUNXI - -config ENV_IS_IN_MMC - bool "Environment in an MMC device" - depends on CMD_MMC - help - Define this if you have an MMC device which you want to use for the - environment. - -config ENV_IS_IN_NAND - bool "Environment in a NAND device" - depends on CMD_NAND - help - Define this if you have a NAND device which you want to use for the - environment. - -config ENV_IS_IN_UBI - bool "Environment in a UBI volume" - depends on CMD_UBI - depends on CMD_MTDPARTS - help - Define this if you have a UBI volume which you want to use for the - environment. - -config ENV_IS_NOWHERE - bool "Environment is not stored" - help - Define this if you don't want to or can't have an environment stored - on a storage medium - -endchoice - -config ENV_OFFSET - hex "Environment Offset" - depends on !ENV_IS_IN_UBI - depends on !ENV_IS_NOWHERE - default 0x88000 if ARCH_SUNXI - help - Offset from the start of the device (or partition) - -config ENV_SIZE - hex "Environment Size" - depends on !ENV_IS_NOWHERE - default 0x20000 if ARCH_SUNXI - help - Size of the environment storage area - -config ENV_UBI_PART - string "UBI partition name" - depends on ENV_IS_IN_UBI - help - MTD partition containing the UBI device - -config ENV_UBI_VOLUME - string "UBI volume name" - depends on ENV_IS_IN_UBI - help - Name of the volume that you want to store the environment in. - -endif - -endmenu - config BOOTDELAY int "delay in seconds before automatically booting" default 2 diff --git a/common/Makefile b/common/Makefile index 17a92ea2d7..289e491cc5 100644 --- a/common/Makefile +++ b/common/Makefile @@ -19,7 +19,7 @@ ifdef CONFIG_BOOT_RETRY_TIME obj-y += bootretry.o endif
-# boards +# # boards obj-y += board_f.o obj-y += board_r.o obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o @@ -29,29 +29,6 @@ obj-$(CONFIG_CMD_BOOTM) += bootm.o bootm_os.o obj-$(CONFIG_CMD_BOOTZ) += bootm.o bootm_os.o obj-$(CONFIG_CMD_BOOTI) += bootm.o bootm_os.o
-# environment -obj-y += env_attr.o -obj-y += env_callback.o -obj-y += env_flags.o -obj-$(CONFIG_ENV_IS_IN_DATAFLASH) += env_dataflash.o -obj-$(CONFIG_ENV_IS_IN_EEPROM) += env_eeprom.o -extra-$(CONFIG_ENV_IS_EMBEDDED) += env_embedded.o -obj-$(CONFIG_ENV_IS_IN_EEPROM) += env_embedded.o -extra-$(CONFIG_ENV_IS_IN_FLASH) += env_embedded.o -obj-$(CONFIG_ENV_IS_IN_NVRAM) += env_embedded.o -obj-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o -obj-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o -obj-$(CONFIG_ENV_IS_IN_FAT) += env_fat.o -obj-$(CONFIG_ENV_IS_IN_EXT4) += env_ext4.o -obj-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o -obj-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o -obj-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o -obj-$(CONFIG_ENV_IS_IN_SATA) += env_sata.o -obj-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o -obj-$(CONFIG_ENV_IS_IN_REMOTE) += env_remote.o -obj-$(CONFIG_ENV_IS_IN_UBI) += env_ubi.o -obj-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o - obj-$(CONFIG_CMD_BEDBUG) += bedbug.o obj-$(CONFIG_$(SPL_)OF_LIBFDT) += fdt_support.o
@@ -92,7 +69,6 @@ ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_DFU_SUPPORT) += dfu.o obj-$(CONFIG_SPL_DFU_SUPPORT) += cli_hush.o obj-$(CONFIG_SPL_HASH_SUPPORT) += hash.o -obj-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o obj-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o obj-$(CONFIG_SPL_LOAD_FIT) += common_fit.o obj-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o @@ -101,28 +77,7 @@ ifdef CONFIG_SPL_USB_HOST_SUPPORT obj-$(CONFIG_SPL_USB_SUPPORT) += usb.o usb_hub.o obj-$(CONFIG_USB_STORAGE) += usb_storage.o endif -# environment -ifdef CONFIG_TPL_BUILD -obj-$(CONFIG_TPL_ENV_SUPPORT) += env_attr.o -obj-$(CONFIG_TPL_ENV_SUPPORT) += env_flags.o -obj-$(CONFIG_TPL_ENV_SUPPORT) += env_callback.o -else -obj-$(CONFIG_SPL_ENV_SUPPORT) += env_attr.o -obj-$(CONFIG_SPL_ENV_SUPPORT) += env_flags.o -obj-$(CONFIG_SPL_ENV_SUPPORT) += env_callback.o -endif -ifneq ($(CONFIG_TPL_ENV_SUPPORT)$(CONFIG_SPL_ENV_SUPPORT),) -obj-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o -obj-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o -obj-$(CONFIG_ENV_IS_IN_FAT) += env_fat.o -obj-$(CONFIG_ENV_IS_IN_EXT4) += env_ext4.o -obj-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o -obj-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o -obj-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o -endif endif -#environment -obj-y += env_common.o #others obj-$(CONFIG_DDR_SPD) += ddr_spd.o obj-$(CONFIG_SPD_EEPROM) += ddr_spd.o @@ -173,5 +128,3 @@ obj-$(CONFIG_CMD_DFU) += dfu.o obj-y += command.o obj-y += s_record.o obj-y += xyzModem.o - -CFLAGS_env_embedded.o := -Wa,--no-warn -DENV_CRC=$(shell tools/envcrc 2>/dev/null) diff --git a/env/Kconfig b/env/Kconfig new file mode 100644 index 0000000000..b622da71d1 --- /dev/null +++ b/env/Kconfig @@ -0,0 +1,68 @@ +menu "Environment" + +if ARCH_SUNXI + +choice + prompt "Environment Device" + default ENV_IS_IN_MMC if ARCH_SUNXI + +config ENV_IS_IN_MMC + bool "Environment in an MMC device" + depends on CMD_MMC + help + Define this if you have an MMC device which you want to use for the + environment. + +config ENV_IS_IN_NAND + bool "Environment in a NAND device" + depends on CMD_NAND + help + Define this if you have a NAND device which you want to use for the + environment. + +config ENV_IS_IN_UBI + bool "Environment in a UBI volume" + depends on CMD_UBI + depends on CMD_MTDPARTS + help + Define this if you have a UBI volume which you want to use for the + environment. + +config ENV_IS_NOWHERE + bool "Environment is not stored" + help + Define this if you don't want to or can't have an environment stored + on a storage medium + +endchoice + +config ENV_OFFSET + hex "Environment Offset" + depends on !ENV_IS_IN_UBI + depends on !ENV_IS_NOWHERE + default 0x88000 if ARCH_SUNXI + help + Offset from the start of the device (or partition) + +config ENV_SIZE + hex "Environment Size" + depends on !ENV_IS_NOWHERE + default 0x20000 if ARCH_SUNXI + help + Size of the environment storage area + +config ENV_UBI_PART + string "UBI partition name" + depends on ENV_IS_IN_UBI + help + MTD partition containing the UBI device + +config ENV_UBI_VOLUME + string "UBI volume name" + depends on ENV_IS_IN_UBI + help + Name of the volume that you want to store the environment in. + +endif + +endmenu diff --git a/env/Makefile b/env/Makefile new file mode 100644 index 0000000000..4c1bdcfdf4 --- /dev/null +++ b/env/Makefile @@ -0,0 +1,57 @@ +# +# (C) Copyright 2004-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += common.o + +ifndef CONFIG_SPL_BUILD +obj-y += attr.o +obj-y += callback.o +obj-y += flags.o +obj-$(CONFIG_ENV_IS_IN_DATAFLASH) += dataflash.o +obj-$(CONFIG_ENV_IS_IN_EEPROM) += eeprom.o +extra-$(CONFIG_ENV_IS_EMBEDDED) += embedded.o +obj-$(CONFIG_ENV_IS_IN_EEPROM) += embedded.o +extra-$(CONFIG_ENV_IS_IN_FLASH) += embedded.o +obj-$(CONFIG_ENV_IS_IN_NVRAM) += embedded.o +obj-$(CONFIG_ENV_IS_IN_FLASH) += flash.o +obj-$(CONFIG_ENV_IS_IN_MMC) += mmc.o +obj-$(CONFIG_ENV_IS_IN_FAT) += fat.o +obj-$(CONFIG_ENV_IS_IN_EXT4) += ext4.o +obj-$(CONFIG_ENV_IS_IN_NAND) += nand.o +obj-$(CONFIG_ENV_IS_IN_NVRAM) += nvram.o +obj-$(CONFIG_ENV_IS_IN_ONENAND) += onenand.o +obj-$(CONFIG_ENV_IS_IN_SATA) += sata.o +obj-$(CONFIG_ENV_IS_IN_SPI_FLASH) += sf.o +obj-$(CONFIG_ENV_IS_IN_REMOTE) += remote.o +obj-$(CONFIG_ENV_IS_IN_UBI) += ubi.o +obj-$(CONFIG_ENV_IS_NOWHERE) += nowhere.o +endif + +ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_ENV_IS_IN_FLASH) += flash.o +# environment +ifdef CONFIG_TPL_BUILD +obj-$(CONFIG_TPL_ENV_SUPPORT) += attr.o +obj-$(CONFIG_TPL_ENV_SUPPORT) += flags.o +obj-$(CONFIG_TPL_ENV_SUPPORT) += callback.o +else +obj-$(CONFIG_SPL_ENV_SUPPORT) += attr.o +obj-$(CONFIG_SPL_ENV_SUPPORT) += flags.o +obj-$(CONFIG_SPL_ENV_SUPPORT) += callback.o +endif +ifneq ($(CONFIG_TPL_ENV_SUPPORT)$(CONFIG_SPL_ENV_SUPPORT),) +obj-$(CONFIG_ENV_IS_NOWHERE) += nowhere.o +obj-$(CONFIG_ENV_IS_IN_MMC) += mmc.o +obj-$(CONFIG_ENV_IS_IN_FAT) += fat.o +obj-$(CONFIG_ENV_IS_IN_EXT4) += ext4.o +obj-$(CONFIG_ENV_IS_IN_NAND) += nand.o +obj-$(CONFIG_ENV_IS_IN_SPI_FLASH) += sf.o +obj-$(CONFIG_ENV_IS_IN_FLASH) += flash.o +endif +endif + +CFLAGS_embedded.o := -Wa,--no-warn -DENV_CRC=$(shell tools/envcrc 2>/dev/null) diff --git a/common/env_attr.c b/env/attr.c similarity index 100% rename from common/env_attr.c rename to env/attr.c diff --git a/common/env_callback.c b/env/callback.c similarity index 100% rename from common/env_callback.c rename to env/callback.c diff --git a/common/env_common.c b/env/common.c similarity index 100% rename from common/env_common.c rename to env/common.c diff --git a/common/env_dataflash.c b/env/dataflash.c similarity index 100% rename from common/env_dataflash.c rename to env/dataflash.c diff --git a/common/env_eeprom.c b/env/eeprom.c similarity index 100% rename from common/env_eeprom.c rename to env/eeprom.c diff --git a/common/env_embedded.c b/env/embedded.c similarity index 100% rename from common/env_embedded.c rename to env/embedded.c diff --git a/common/env_ext4.c b/env/ext4.c similarity index 100% rename from common/env_ext4.c rename to env/ext4.c diff --git a/common/env_fat.c b/env/fat.c similarity index 100% rename from common/env_fat.c rename to env/fat.c diff --git a/common/env_flags.c b/env/flags.c similarity index 100% rename from common/env_flags.c rename to env/flags.c diff --git a/common/env_flash.c b/env/flash.c similarity index 100% rename from common/env_flash.c rename to env/flash.c diff --git a/common/env_mmc.c b/env/mmc.c similarity index 100% rename from common/env_mmc.c rename to env/mmc.c diff --git a/common/env_nand.c b/env/nand.c similarity index 100% rename from common/env_nand.c rename to env/nand.c diff --git a/common/env_nowhere.c b/env/nowhere.c similarity index 100% rename from common/env_nowhere.c rename to env/nowhere.c diff --git a/common/env_nvram.c b/env/nvram.c similarity index 100% rename from common/env_nvram.c rename to env/nvram.c diff --git a/common/env_onenand.c b/env/onenand.c similarity index 100% rename from common/env_onenand.c rename to env/onenand.c diff --git a/common/env_remote.c b/env/remote.c similarity index 100% rename from common/env_remote.c rename to env/remote.c diff --git a/common/env_sata.c b/env/sata.c similarity index 100% rename from common/env_sata.c rename to env/sata.c diff --git a/common/env_sf.c b/env/sf.c similarity index 100% rename from common/env_sf.c rename to env/sf.c diff --git a/common/env_ubi.c b/env/ubi.c similarity index 100% rename from common/env_ubi.c rename to env/ubi.c diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index f8b1d4af38..2cf05a0978 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -165,8 +165,8 @@ #define CONFIG_ENV_IS_IN_FLASH 1
#define LDS_BOARD_TEXT \ - . = DEFINED(env_offset) ? env_offset : .; \ - common/env_embedded.o (.text*); + . = DEFINED(env_offset) ? env_offset : .; \ + env/embedded.o(.text*);
/* Cache Configuration */ #define CONFIG_SYS_CACHELINE_SIZE 16 diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 7247111cf5..0546afda69 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -181,7 +181,7 @@
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ - common/env_embedded.o (.text); + env/embedded.o(.text);
#ifdef NORFLASH_PS32BIT # define CONFIG_ENV_OFFSET (0x8000) diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 4ef83f7862..7e70a3b045 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -87,8 +87,8 @@ #define CONFIG_ENV_IS_IN_FLASH 1
#define LDS_BOARD_TEXT \ - . = DEFINED(env_offset) ? env_offset : .; \ - common/env_embedded.o (.text); + . = DEFINED(env_offset) ? env_offset : .; \ + env/embedded.o(.text);
#define CONFIG_ENV_OFFSET 0x4000 /* Address of Environment Sector*/ #define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 3efd7e59cf..ef5deb869c 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -31,8 +31,8 @@ #endif
/* * Command line configuration. diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index 4f7a19b5d3..433f8327cc 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -33,7 +33,7 @@
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ - common/env_embedded.o (.text) + env/embedded.o(.text)
/* * BOOTP options diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index 0b0e4e60c7..094973a168 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -41,8 +41,8 @@ #endif
/* * BOOTP options diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 5d324ba5bf..1a8f973e39 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -42,8 +42,8 @@ #endif
/* * BOOTP options diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index 061a632c98..604daf577a 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -33,7 +33,7 @@
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ - common/env_embedded.o (.text*); + env/embedded.o(.text*);
/* * BOOTP options diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index b88c3709c6..86fb277897 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -189,7 +189,7 @@
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ - common/env_embedded.o (.text*) + env/embedded.o(.text*)
/*----------------------------------------------------------------------- * Cache Configuration diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 999bcd9495..7e7f1ee918 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -193,8 +193,8 @@ #define CONFIG_ENV_IS_IN_FLASH 1
/*----------------------------------------------------------------------- * Cache Configuration diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index 3a39e5031d..ee621f03be 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -193,8 +193,8 @@ #define CONFIG_ENV_IS_IN_FLASH 1
/*----------------------------------------------------------------------- * Cache Configuration diff --git a/include/configs/amcore.h b/include/configs/amcore.h index acae6914e5..02a0ad9e7e 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -94,8 +94,8 @@ #define CONFIG_ENV_SECT_SIZE 0x1000
/* memory map space for linux boot data */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 61989d6bab..722f8c79fa 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -307,7 +307,7 @@
#if ENABLE_JFFS /* JFFS Partition offset set */ diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index b078e10475..aff7af7d52 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -104,8 +104,8 @@ #endif
/* * BOOTP options diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index ac3c2c7f13..f25a8bf725 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -69,10 +69,10 @@ libs-y += common/init/
# Special handling for a few options which support SPL/TPL ifeq ($(CONFIG_TPL_BUILD),y) -libs-$(CONFIG_TPL_LIBCOMMON_SUPPORT) += common/ cmd/ +libs-$(CONFIG_TPL_LIBCOMMON_SUPPORT) += common/ cmd/ env/ libs-$(CONFIG_TPL_LIBGENERIC_SUPPORT) += lib/ else -libs-$(CONFIG_SPL_LIBCOMMON_SUPPORT) += common/ cmd/ +libs-$(CONFIG_SPL_LIBCOMMON_SUPPORT) += common/ cmd/ env/ libs-$(CONFIG_SPL_LIBGENERIC_SUPPORT) += lib/ endif
diff --git a/tools/Makefile b/tools/Makefile index cb1683e153..2ce858d2b1 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -37,7 +37,7 @@ hostprogs-$(CONFIG_VIDEO_LOGO) += bmp_logo HOSTCFLAGS_bmp_logo.o := -pedantic
hostprogs-$(CONFIG_BUILD_ENVCRC) += envcrc -envcrc-objs := envcrc.o lib/crc32.o common/env_embedded.o lib/sha1.o +envcrc-objs := envcrc.o lib/crc32.o env/embedded.o lib/sha1.o
hostprogs-$(CONFIG_CMD_NET) += gen_eth_addr HOSTCFLAGS_gen_eth_addr.o := -pedantic @@ -221,7 +221,7 @@ HOSTCFLAGS_sha256.o := -pedantic quiet_cmd_wrap = WRAP $@ cmd_wrap = echo "#include <../$(patsubst $(obj)/%,%,$@)>" >$@
-$(obj)/lib/%.c $(obj)/common/%.c: +$(obj)/lib/%.c $(obj)/common/%.c $(obj)/env/%.c: $(call cmd,wrap)
clean-dirs := lib common
This converts the following to Kconfig: CONFIG_ENV_IS_IN_MMC CONFIG_ENV_IS_IN_NAND CONFIG_ENV_IS_IN_UBI CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not all the choices are available in Kconfig yet so we cannot use that. It would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be stored in more than one place. So the existing choice is converted to a normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
Changes in v2: - Handle a difficult cases that try to have different env settings for SPL - Update evb-rk3229, phycore-rk3288, poplar
arch/arm/Kconfig | 1 + arch/arm/mach-exynos/Kconfig | 1 + arch/arm/mach-imx/mx6/Kconfig | 1 + arch/arm/mach-imx/mx7/Kconfig | 1 + arch/arm/mach-sunxi/Kconfig | 6 ++ arch/arm/mach-tegra/Kconfig | 3 + arch/mips/Kconfig | 1 + configs/B4420QDS_NAND_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 1 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/CHIP_defconfig | 2 + configs/CHIP_pro_defconfig | 1 + configs/Cyrus_P5020_defconfig | 1 + configs/Cyrus_P5040_defconfig | 1 + configs/M54418TWR_nand_mii_defconfig | 1 + configs/M54418TWR_nand_rmii_defconfig | 1 + configs/M54418TWR_nand_rmii_lowfreq_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/Nintendo_NES_Classic_Edition_defconfig | 2 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020MBG-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020UTM-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1024RDB_NAND_defconfig | 1 + configs/P1024RDB_SDCARD_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SECURE_BOOT_defconfig | 1 + configs/P3041DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SECURE_BOOT_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SECURE_BOOT_defconfig | 1 + configs/P5020DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5020DS_NAND_defconfig | 1 + configs/P5020DS_SDCARD_defconfig | 1 + configs/P5020DS_SECURE_BOOT_defconfig | 1 + configs/P5040DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_NAND_defconfig | 1 + configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SECURE_BOOT_defconfig | 1 + configs/T2081QDS_NAND_defconfig | 1 + configs/T2081QDS_SDCARD_defconfig | 1 + configs/T4160QDS_NAND_defconfig | 1 + configs/T4160QDS_SDCARD_defconfig | 1 + configs/T4160QDS_SECURE_BOOT_defconfig | 1 + configs/T4240QDS_NAND_defconfig | 1 + configs/T4240QDS_SDCARD_defconfig | 1 + configs/T4240QDS_SECURE_BOOT_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_igep003x_defconfig | 1 + configs/am335x_shc_defconfig | 1 + configs/am335x_shc_ict_defconfig | 1 + configs/am335x_shc_netboot_defconfig | 1 + configs/am335x_shc_prompt_defconfig | 1 + configs/am335x_shc_sdboot_defconfig | 1 + configs/am335x_shc_sdboot_prompt_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am3517_crane_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_evm_nodt_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/apalis_imx6_nospl_com_defconfig | 1 + configs/apalis_imx6_nospl_it_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/arndale_defconfig | 1 + configs/aspenite_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 1 + configs/at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/axm_defconfig | 1 + configs/bcm11130_defconfig | 1 + configs/bcm11130_nand_defconfig | 1 + configs/bcm23550_w1d_defconfig | 1 + configs/bcm28155_ap_defconfig | 1 + configs/bcm28155_w1d_defconfig | 1 + configs/bcm911360_entphn-ns_defconfig | 1 + configs/bcm911360_entphn_defconfig | 1 + configs/bcm911360k_defconfig | 1 + configs/bcm958300k-ns_defconfig | 1 + configs/bcm958300k_defconfig | 1 + configs/bcm958305k_defconfig | 1 + configs/bcm958622hr_defconfig | 1 + configs/bcm958712k_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/bk4r1_defconfig | 3 +- configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cairo_defconfig | 1 + configs/chiliboard_defconfig | 1 + configs/chromebit_mickey_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_minnie_defconfig | 1 + configs/clearfog_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/cm_t54_defconfig | 3 +- configs/colibri_imx6_defconfig | 1 + configs/colibri_imx6_nospl_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_vf_defconfig | 3 +- .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + .../controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/corvus_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/dbau1000_defconfig | 1 + configs/dbau1100_defconfig | 1 + configs/dbau1500_defconfig | 1 + configs/dbau1550_defconfig | 1 + configs/dbau1550_el_defconfig | 1 + configs/devkit3250_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/dra7xx_evm_defconfig | 3 +- configs/dra7xx_hs_evm_defconfig | 3 +- configs/draco_defconfig | 1 + configs/dragonboard410c_defconfig | 1 + configs/duovero_defconfig | 1 + configs/eco5pk_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/espresso7420_defconfig | 1 + configs/etamin_defconfig | 1 + configs/evb-ast2500_defconfig | 1 + configs/evb-px5_defconfig | 1 + configs/evb-rk3036_defconfig | 1 + configs/evb-rk3229_defconfig | 1 + configs/evb-rk3288_defconfig | 1 + configs/evb-rk3328_defconfig | 1 + configs/evb-rk3399_defconfig | 1 + configs/evb-rv1108_defconfig | 1 + configs/fennec-rk3288_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 1 + configs/geekbox_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/gplugd_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/h2200_defconfig | 1 + configs/harmony_defconfig | 1 + configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/imgtec_xilfpga_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 3 +- configs/imx6qdl_icore_nand_defconfig | 3 +- configs/imx6qdl_icore_rqs_defconfig | 3 +- configs/imx6ul_geam_mmc_defconfig | 3 +- configs/imx6ul_geam_nand_defconfig | 3 +- configs/imx6ul_isiot_emmc_defconfig | 3 +- configs/imx6ul_isiot_mmc_defconfig | 3 +- configs/imx6ul_isiot_nand_defconfig | 3 +- configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/kc1_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/legoev3_defconfig | 1 + configs/liteboard_defconfig | 1 + configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1021aiot_sdcard_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls1046aqds_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_nand_defconfig | 1 + configs/ls1046aqds_sdcard_ifc_defconfig | 1 + configs/ls1046aqds_sdcard_qspi_defconfig | 1 + configs/ls1046ardb_emmc_defconfig | 1 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_sdcard_defconfig | 1 + configs/ls2080a_emu_defconfig | 1 + configs/ls2080a_simu_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_sdcard_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/ma5d4evk_defconfig | 1 + configs/mcx_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/meesc_defconfig | 1 + configs/miqi-rk3288_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/mvebu_db-88f7040-nand_defconfig | 73 ++++++++++++++++++++++ configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx25pdk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 3 +- configs/mx28evk_defconfig | 2 +- configs/mx28evk_nand_defconfig | 2 +- configs/mx31pdk_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53ard_defconfig | 1 + configs/mx53cx9020_defconfig | 1 + configs/mx53evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx53smd_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlarm2_defconfig | 1 + configs/mx6dlarm2_lpddr2_defconfig | 1 + configs/mx6qarm2_defconfig | 1 + configs/mx6qarm2_lpddr2_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 44 +++++++++++++ configs/mx6qsabreauto_defconfig | 45 +++++++++++++ configs/mx6qsabrelite_defconfig | 1 + configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + configs/mx6slevk_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sllevk_defconfig | 1 + configs/mx6sllevk_plugin_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx6ull_14x14_evk_defconfig | 1 + configs/mx6ull_14x14_evk_plugin_defconfig | 1 + configs/mx7ulp_evk_defconfig | 1 + configs/mx7ulp_evk_plugin_defconfig | 1 + configs/nas220_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/novena_defconfig | 1 + configs/nsa310s_defconfig | 1 + configs/nsim_700_defconfig | 1 + configs/nsim_700be_defconfig | 1 + configs/nsim_hs38_defconfig | 1 + configs/nsim_hs38be_defconfig | 1 + configs/odroid-c2_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/omap5_uevm_defconfig | 3 +- configs/omapl138_lcdk_defconfig | 1 + configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/opos6uldev_defconfig | 1 + configs/paz00_defconfig | 1 + configs/pb1000_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pcm052_defconfig | 3 +- configs/pengwyn_defconfig | 1 + configs/pepper_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/pic32mzdask_defconfig | 1 + configs/pico-imx6ul_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/plutux_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/poplar_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/puma-rk3399_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/r8a7795_salvator-x_defconfig | 1 + configs/r8a7796_salvator-x_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/riotboard_defconfig | 3 +- configs/rock2_defconfig | 1 + configs/rock_defconfig | 1 + configs/rut_defconfig | 1 + configs/s32v234evb_defconfig | 1 + configs/s5p_goni_defconfig | 1 + configs/sama5d2_ptc_nandflash_defconfig | 1 + configs/sama5d36ek_cmp_nandflash_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + configs/sandbox_noblk_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sc_sps_1_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/secomx6quq7_defconfig | 2 +- configs/sheep-rk3368_defconfig | 1 + configs/sheevaplug_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/sniper_defconfig | 1 + configs/socfpga_arria10_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/spear300_nand_defconfig | 1 + configs/spear300_usbtty_nand_defconfig | 1 + configs/spear310_nand_defconfig | 1 + configs/spear310_usbtty_nand_defconfig | 1 + configs/spear320_nand_defconfig | 1 + configs/spear320_usbtty_nand_defconfig | 1 + configs/spear600_nand_defconfig | 1 + configs/spear600_usbtty_nand_defconfig | 1 + configs/stih410-b2260_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/taurus_defconfig | 1 + configs/tb100_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/tec_defconfig | 1 + configs/thuban_defconfig | 1 + configs/thunderx_88xx_defconfig | 1 + configs/ti814x_evm_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/tinker-rk3288_defconfig | 1 + configs/titanium_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/tplink_wdr4300_defconfig | 1 + configs/tqma6dl_mba6_mmc_defconfig | 1 + configs/tqma6q_mba6_mmc_defconfig | 1 + configs/tqma6s_mba6_mmc_defconfig | 1 + configs/tqma6s_wru4_mmc_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/ts4600_defconfig | 2 +- configs/ts4800_defconfig | 1 + configs/twister_defconfig | 1 + configs/udoo_defconfig | 1 + configs/usbarmory_defconfig | 1 + configs/ventana_defconfig | 1 + configs/vf610twr_defconfig | 3 +- configs/vf610twr_nand_defconfig | 3 +- configs/wandboard_defconfig | 1 + configs/warp_defconfig | 1 + configs/work_92105_defconfig | 1 + configs/xfi3_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/xpress_defconfig | 1 + configs/xpress_spl_defconfig | 1 + configs/zc5202_defconfig | 1 + configs/zc5601_defconfig | 1 + configs/zynq_picozed_defconfig | 1 + configs/zynq_zc770_xm011_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + env/Kconfig | 13 +--- include/config_fsl_chain_trust.h | 4 -- include/configs/B4860QDS.h | 5 -- include/configs/BSC9131RDB.h | 2 - include/configs/BSC9132QDS.h | 3 - include/configs/C29XPCIE.h | 1 - include/configs/M54418TWR.h | 1 - include/configs/MPC8313ERDB.h | 2 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8323ERDB.h | 1 - include/configs/MPC832XEMDS.h | 1 - include/configs/MPC8349EMDS.h | 1 - include/configs/MPC8349ITX.h | 1 - include/configs/MPC837XEMDS.h | 1 - include/configs/MPC837XERDB.h | 1 - include/configs/MPC8536DS.h | 2 - include/configs/MPC8540ADS.h | 1 - include/configs/MPC8560ADS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1010RDB.h | 3 - include/configs/P1022DS.h | 3 - include/configs/P2041RDB.h | 5 -- include/configs/T102xQDS.h | 2 - include/configs/T102xRDB.h | 2 - include/configs/T1040QDS.h | 3 - include/configs/T104xRDB.h | 2 - include/configs/T208xQDS.h | 2 - include/configs/T208xRDB.h | 2 - include/configs/T4240QDS.h | 5 -- include/configs/T4240RDB.h | 5 -- include/configs/UCP1020.h | 2 - include/configs/am335x_evm.h | 3 - include/configs/am335x_igep003x.h | 1 - include/configs/am335x_shc.h | 9 --- include/configs/am335x_sl50.h | 4 -- include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 5 -- include/configs/am57xx_evm.h | 1 - include/configs/apalis-tk1.h | 1 - include/configs/apalis_imx6.h | 2 - include/configs/apalis_t30.h | 1 - include/configs/apf27.h | 1 - include/configs/apx4devkit.h | 1 - include/configs/arndale.h | 1 - include/configs/aspenite.h | 1 - include/configs/at91-sama5_common.h | 1 - include/configs/at91sam9260ek.h | 2 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/baltos.h | 1 - include/configs/bav335x.h | 5 -- include/configs/bcm23550_w1d.h | 1 - include/configs/bcm28155_ap.h | 1 - include/configs/bcm_ep_board.h | 1 - include/configs/bcm_northstar2.h | 1 - include/configs/beaver.h | 1 - include/configs/bg0900.h | 1 - include/configs/brppt1.h | 8 --- include/configs/brxre1.h | 2 - include/configs/cardhu.h | 1 - include/configs/cei-tk1-som.h | 1 - include/configs/chiliboard.h | 1 - include/configs/clearfog.h | 1 - include/configs/cm_t335.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/cm_t54.h | 1 - include/configs/colibri_imx6.h | 2 - include/configs/colibri_imx7.h | 1 - include/configs/colibri_pxa270.h | 3 - include/configs/colibri_t20.h | 1 - include/configs/colibri_t30.h | 1 - include/configs/comtrend_ar5387un.h | 1 - include/configs/comtrend_ct5361.h | 1 - include/configs/comtrend_vr3032u.h | 1 - include/configs/controlcenterd.h | 2 - include/configs/corenet_ds.h | 5 -- include/configs/corvus.h | 1 - include/configs/cyrus.h | 1 - include/configs/da850evm.h | 3 - include/configs/dalmore.h | 1 - include/configs/dbau1x00.h | 2 - include/configs/devkit3250.h | 1 - include/configs/devkit8000.h | 1 - include/configs/dns325.h | 3 - include/configs/dockstar.h | 3 - include/configs/dra7xx_evm.h | 1 - include/configs/dragonboard410c.h | 1 - include/configs/dreamplug.h | 2 - include/configs/ds109.h | 2 - include/configs/duovero.h | 1 - include/configs/e2220-1170.h | 1 - include/configs/ea20.h | 2 - include/configs/efi-x86.h | 1 - include/configs/el6x_common.h | 2 - include/configs/espresso7420.h | 1 - include/configs/evb_ast2500.h | 2 - include/configs/evb_px5.h | 1 - include/configs/evb_rk3229.h | 1 - include/configs/evb_rk3288.h | 1 - include/configs/evb_rk3328.h | 1 - include/configs/evb_rk3399.h | 1 - include/configs/fennec_rk3288.h | 1 - include/configs/firefly-rk3288.h | 1 - include/configs/geekbox.h | 1 - include/configs/goflexhome.h | 3 - include/configs/gplugd.h | 1 - include/configs/guruplug.h | 3 - include/configs/gw_ventana.h | 4 -- include/configs/h2200.h | 1 - include/configs/harmony.h | 1 - include/configs/hrcon.h | 1 - include/configs/huawei_hg556a.h | 1 - include/configs/ib62x0.h | 3 - include/configs/iconnect.h | 3 - include/configs/imgtec_xilfpga.h | 1 - include/configs/imx6_logic.h | 1 - include/configs/integratorap.h | 1 - include/configs/ipam390.h | 1 - include/configs/jetson-tk1.h | 1 - include/configs/k2e_evm.h | 1 - include/configs/k2hk_evm.h | 1 - include/configs/k2l_evm.h | 1 - include/configs/kc1.h | 1 - include/configs/km/km83xx-common.h | 1 - include/configs/kylin_rk3036.h | 2 - include/configs/legoev3.h | 1 - include/configs/liteboard.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 2 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043aqds.h | 2 - include/configs/ls1043ardb.h | 2 - include/configs/ls1046aqds.h | 2 - include/configs/ls1046ardb.h | 1 - include/configs/ls2080a_emu.h | 1 - include/configs/ls2080a_simu.h | 1 - include/configs/ls2080aqds.h | 2 - include/configs/ls2080ardb.h | 1 - include/configs/lsxl.h | 2 - include/configs/m28evk.h | 3 - include/configs/m53evk.h | 3 - include/configs/ma5d4evk.h | 1 - include/configs/mcx.h | 1 - include/configs/medcom-wide.h | 1 - include/configs/meesc.h | 1 - include/configs/meson-gxbb-common.h | 1 - include/configs/microblaze-generic.h | 3 - include/configs/miqi_rk3288.h | 1 - include/configs/mvebu_armada-8k.h | 2 - include/configs/mx23_olinuxino.h | 1 - include/configs/mx23evk.h | 1 - include/configs/mx25pdk.h | 1 - include/configs/mx31pdk.h | 1 - include/configs/mx35pdk.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53ard.h | 1 - include/configs/mx53cx9020.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53smd.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6qarm2.h | 1 - include/configs/mx6sabre_common.h | 2 - include/configs/mx6slevk.h | 1 - include/configs/mx6sllevk.h | 1 - include/configs/mx6sxsabreauto.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx6ullevk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mx7ulp_evk.h | 1 - include/configs/nas220.h | 3 - include/configs/netgear_cg3100d.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/nokia_rx51.h | 2 - include/configs/novena.h | 3 - include/configs/nsa310s.h | 3 - include/configs/nsim.h | 1 - include/configs/nyan-big.h | 1 - include/configs/odroid.h | 1 - include/configs/odroid_xu3.h | 2 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_cairo.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_overo.h | 1 - include/configs/omap3_pandora.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/omap4_sdp4430.h | 1 - include/configs/omap5_uevm.h | 1 - include/configs/omapl138_lcdk.h | 7 --- include/configs/openrd.h | 3 - include/configs/opos6uldev.h | 1 - include/configs/origen.h | 1 - include/configs/p1_p2_rdb_pc.h | 3 - include/configs/p1_twr.h | 2 - include/configs/p2371-0000.h | 1 - include/configs/p2371-2180.h | 1 - include/configs/p2571.h | 1 - include/configs/p2771-0000.h | 1 - include/configs/paz00.h | 1 - include/configs/pb1x00.h | 2 - include/configs/pcm051.h | 1 - include/configs/pengwyn.h | 1 - include/configs/pepper.h | 1 - include/configs/phycore_rk3288.h | 1 - include/configs/pic32mzdask.h | 1 - include/configs/pico-imx6ul.h | 1 - include/configs/pico-imx7d.h | 1 - include/configs/platinum.h | 2 - include/configs/plutux.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/pogo_e02.h | 3 - include/configs/poplar.h | 1 - include/configs/popmetal_rk3288.h | 1 - include/configs/puma_rk3399.h | 1 - include/configs/qemu-ppce500.h | 2 - include/configs/qemu-x86.h | 1 - include/configs/rk3036_common.h | 1 - include/configs/rock.h | 1 - include/configs/rock2.h | 1 - include/configs/rv1108_common.h | 1 - include/configs/s32v234evb.h | 1 - include/configs/s5p_goni.h | 1 - include/configs/s5pc210_universal.h | 1 - include/configs/sagem_f@st1704.h | 1 - include/configs/salvator-x.h | 1 - include/configs/sama5d2_ptc.h | 1 - include/configs/sama5d3_xplained.h | 2 - include/configs/sama5d3xek.h | 2 - include/configs/sandbox.h | 1 - include/configs/sansa_fuze_plus.h | 1 - include/configs/sbc8349.h | 1 - include/configs/sc_sps_1.h | 3 - include/configs/seaboard.h | 1 - include/configs/sfr_nb4_ser.h | 1 - include/configs/sheep_rk3368.h | 1 - include/configs/sheevaplug.h | 3 - include/configs/siemens-am33x-common.h | 4 -- include/configs/smartweb.h | 1 - include/configs/smdkv310.h | 1 - include/configs/snapper9260.h | 1 - include/configs/snapper9g45.h | 1 - include/configs/sniper.h | 1 - include/configs/socfpga_arria10_socdk.h | 1 - include/configs/socfpga_arria5_socdk.h | 2 - include/configs/socfpga_cyclone5_socdk.h | 2 - include/configs/socfpga_de0_nano_soc.h | 2 - include/configs/socfpga_de10_nano.h | 2 - include/configs/socfpga_de1_soc.h | 2 - include/configs/socfpga_mcvevk.h | 1 - include/configs/socfpga_sockit.h | 2 - include/configs/socfpga_socrates.h | 2 - include/configs/spear3xx_evb.h | 1 - include/configs/spear6xx_evb.h | 1 - include/configs/stih410-b2260.h | 1 - include/configs/stm32f746-disco.h | 1 - include/configs/strider.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/taurus.h | 1 - include/configs/tb100.h | 1 - include/configs/tbs2910.h | 1 - include/configs/tec-ng.h | 1 - include/configs/tec.h | 1 - include/configs/thunderx_88xx.h | 1 - include/configs/ti814x_evm.h | 2 - include/configs/ti816x_evm.h | 1 - include/configs/tinker_rk3288.h | 1 - include/configs/titanium.h | 2 - include/configs/topic_miami.h | 1 - include/configs/tplink_wdr4300.h | 1 - include/configs/tqma6.h | 1 - include/configs/trats.h | 1 - include/configs/trats2.h | 1 - include/configs/tricorder.h | 5 -- include/configs/ts4800.h | 1 - include/configs/udoo.h | 1 - include/configs/udoo_neo.h | 1 - include/configs/uniphier.h | 3 - include/configs/usbarmory.h | 1 - include/configs/venice2.h | 1 - include/configs/ventana.h | 1 - include/configs/veyron.h | 1 - include/configs/vining_2000.h | 1 - include/configs/vme8349.h | 1 - include/configs/wandboard.h | 1 - include/configs/warp.h | 1 - include/configs/warp7.h | 1 - include/configs/work_92105.h | 1 - include/configs/x86-chromebook.h | 1 - include/configs/xfi3.h | 1 - include/configs/xilinx-ppc.h | 2 - include/configs/xilinx_zynqmp.h | 3 - include/configs/xpress.h | 1 - include/configs/zynq-common.h | 2 - 804 files changed, 688 insertions(+), 504 deletions(-) create mode 100644 configs/mvebu_db-88f7040-nand_defconfig create mode 100644 configs/mx6qpsabreauto_defconfig create mode 100644 configs/mx6qsabreauto_defconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f7b44392ac..23d3bf5833 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1019,6 +1019,7 @@ config ARCH_UNIPHIER select SPL_PINCTRL if SPL select SUPPORT_SPL imply FAT_WRITE + imply ENV_IS_IN_MMC help Support for UniPhier SoC family developed by Socionext Inc. (formerly, System LSI Business Division of Panasonic Corporation) diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index c57935e44d..d1aa68db20 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -8,6 +8,7 @@ config ARCH_EXYNOS4 bool "Exynos4 SoC family" select CPU_V7 select BOARD_EARLY_INIT_F + imply ENV_IS_IN_MMC help Samsung Exynos4 SoC family are based on ARM Cortex-A9 CPU. There are multiple SoCs in this family including Exynos4210, Exynos4412, diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 1595a764c5..bb2ce33132 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -30,6 +30,7 @@ config MX6SL config MX6SX select ROM_UNIFIED_SECTIONS bool + imply ENV_IS_IN_MMC
config MX6SLL select ROM_UNIFIED_SECTIONS diff --git a/arch/arm/mach-imx/mx7/Kconfig b/arch/arm/mach-imx/mx7/Kconfig index aea85265ef..7053697f9b 100644 --- a/arch/arm/mach-imx/mx7/Kconfig +++ b/arch/arm/mach-imx/mx7/Kconfig @@ -13,6 +13,7 @@ config MX7D select ROM_UNIFIED_SECTIONS imply CMD_FUSE bool + imply ENV_IS_IN_MMC
choice prompt "MX7 board select" diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index bd3e7d3b3f..94412bac0c 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -59,6 +59,7 @@ config MACH_SUNXI_H3_H5 select SUNXI_DRAM_DW_32BIT select SUNXI_GEN_SUN6I select SUPPORT_SPL + imply ENV_IS_IN_MMC
choice prompt "Sunxi SoC Variant" @@ -70,6 +71,7 @@ config MACH_SUN4I select ARM_CORTEX_CPU_IS_UP select SUNXI_GEN_SUN4I select SUPPORT_SPL + imply ENV_IS_IN_MMC
config MACH_SUN5I bool "sun5i (Allwinner A13)" @@ -87,6 +89,7 @@ config MACH_SUN6I select SUNXI_GEN_SUN6I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT + imply ENV_IS_IN_MMC
config MACH_SUN7I bool "sun7i (Allwinner A20)" @@ -97,6 +100,7 @@ config MACH_SUN7I select SUNXI_GEN_SUN4I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT + imply ENV_IS_IN_MMC
config MACH_SUN8I_A23 bool "sun8i (Allwinner A23)" @@ -107,6 +111,7 @@ config MACH_SUN8I_A23 select SUNXI_GEN_SUN6I select SUPPORT_SPL select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT + imply ENV_IS_IN_MMC
config MACH_SUN8I_A33 bool "sun8i (Allwinner A33)" @@ -132,6 +137,7 @@ config MACH_SUN8I_H3 select ARCH_SUPPORT_PSCI select MACH_SUNXI_H3_H5 select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT + imply ENV_IS_IN_MMC
config MACH_SUN8I_R40 bool "sun8i (Allwinner R40)" diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 89d2a499e4..48387589d5 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -60,6 +60,7 @@ config TEGRA_ARMV8_COMMON bool "Tegra 64-bit common options" select ARM64 select TEGRA_COMMON + imply ENV_IS_IN_MMC
choice prompt "Tegra SoC select" @@ -77,6 +78,7 @@ config TEGRA30 select ARM_ERRATA_743622 select ARM_ERRATA_751472 select TEGRA_ARMV7_COMMON + imply ENV_IS_IN_MMC
config TEGRA114 bool "Tegra114 family" @@ -85,6 +87,7 @@ config TEGRA114 config TEGRA124 bool "Tegra124 family" select TEGRA_ARMV7_COMMON + imply ENV_IS_IN_MMC
config TEGRA210 bool "Tegra210 family" diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index d07b92d1b4..579371e8ee 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -83,6 +83,7 @@ config ARCH_BMIPS select CPU select RAM select SYSRESET + imply ENV_IS_NOWHERE
config MACH_PIC32 bool "Support Microchip PIC32" diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index a33c8ea4f6..b7dde217e9 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index ce18507373..46365722bd 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index e679d0a618..7e7c4bb775 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index 62c436898d..800d29e941 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index c5d9b9ba48..a08b433d48 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig index aea470cfbe..872977d0e6 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index 42ee22741d..7de6d4d3de 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig index 51e19946d8..d160ef5c18 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index 81ace7bda4..e10d6f9971 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig index cea3cb44b8..d084e7647a 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig index c5642abd90..e583bc615c 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig index e8c548286b..d5409f39ae 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig index 22413b4812..7ebe310f97 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig index 3afb011012..2522e62ef2 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig index 10cbd222d2..d9e5a66afd 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig index c5d17bc516..4ba94a70d2 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig index ba0772c07d..f38fa9ce6d 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index 42f085a47c..3e0157b152 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index 99e2b33ac7..8563b5ac27 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index 26544f4ab6..9214b8ce26 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 49e280e26a..f918e95165 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -10,6 +10,8 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_ENV_IS_IN_MMC is not set +CONFIG_ENV_IS_NOWHERE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index 013d908cff..c997b599ad 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_I2C_SUPPORT=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_CMD_MTDPARTS=y +# CONFIG_ENV_IS_IN_MMC is not set CONFIG_MTDIDS_DEFAULT="nand0=sunxi-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=sunxi-nand.0:256k(spl),256k(spl-backup),2m(uboot),2m(uboot-backup),-(UBI)" # CONFIG_MMC is not set diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index 8e036d223b..474c412dfc 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index ee4da81d3e..1b717089f0 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/M54418TWR_nand_mii_defconfig b/configs/M54418TWR_nand_mii_defconfig index 1151fdeb18..eeb09b0ad6 100644 --- a/configs/M54418TWR_nand_mii_defconfig +++ b/configs/M54418TWR_nand_mii_defconfig @@ -16,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_nand_rmii_defconfig b/configs/M54418TWR_nand_rmii_defconfig index 1dcdfbf355..3c55a4757c 100644 --- a/configs/M54418TWR_nand_rmii_defconfig +++ b/configs/M54418TWR_nand_rmii_defconfig @@ -16,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_nand_rmii_lowfreq_defconfig b/configs/M54418TWR_nand_rmii_lowfreq_defconfig index 4bb31d75f6..50d692f626 100644 --- a/configs/M54418TWR_nand_rmii_lowfreq_defconfig +++ b/configs/M54418TWR_nand_rmii_lowfreq_defconfig @@ -16,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index 64247a5335..8d2ee1497a 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index 363d849efc..ad0e72ebe1 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index 761c1652b1..1c6d0a3536 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_FSL_DDR2=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/Nintendo_NES_Classic_Edition_defconfig b/configs/Nintendo_NES_Classic_Edition_defconfig index 5f91c351c3..e4714e9b41 100644 --- a/configs/Nintendo_NES_Classic_Edition_defconfig +++ b/configs/Nintendo_NES_Classic_Edition_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +# CONFIG_ENV_IS_IN_MMC is not set +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_ELDO2_VOLT=1800 diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index 28029b8a74..cce9a47d30 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index fb8ccd8ec4..5f079bb78b 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index f9109e495a..892a430070 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 29738f3126..edb3dc0b9e 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index a5cec4b8b1..5d338b589e 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index d720c229e2..84f7a96672 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 81a083edb3..ad4673dc70 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index d473d6ddaa..11ec042f54 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index d0e5de8331..8dec4a095c 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index aa94431094..62f7fabf6c 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index 137a9ff90b..ee1f26868a 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 93bd550cff..0c4bc0aca6 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index d1c728b01e..41154fa9f6 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 343f225f68..2b8e1bdd48 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index 2c1f471c61..7b27ac9215 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index 765e460d64..e188c3feb5 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index f238caee15..ffc710a57f 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index 76f28fd817..7569ca05d2 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 1c1781b289..dda54a3649 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index a0c9a716ae..d993dfd677 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig index e297a0da5b..cf72170d45 100644 --- a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/P1020MBG-PC_SDCARD_defconfig b/configs/P1020MBG-PC_SDCARD_defconfig index a5bdec3de2..efbf51dc77 100644 --- a/configs/P1020MBG-PC_SDCARD_defconfig +++ b/configs/P1020MBG-PC_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 56a0297520..db1a45a9f1 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 4d882264bb..2c59fb4aca 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 71c0c2d4bf..5bffd5bdaa 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 9d994810cc..f9d4f6824b 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index eb9d2635b9..d62988ee76 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index e6373f4200..fbb2392755 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig index 1d31e0fdc5..23499dd213 100644 --- a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/P1020UTM-PC_SDCARD_defconfig b/configs/P1020UTM-PC_SDCARD_defconfig index d401a8ce3e..c473f42c80 100644 --- a/configs/P1020UTM-PC_SDCARD_defconfig +++ b/configs/P1020UTM-PC_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index f6bbf7db4b..3991a169e2 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index bbeeba0bc8..12680db0de 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index a9af7462a1..3fbfabb149 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index ca77237cf4..3a91572698 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index 9c83a469a8..89340d55a7 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index e1f9a9888d..32342cde09 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index 04bb7a13cd..3bff54675a 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index af7b4dbd5e..052845299b 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index 3a563f5c32..8c58cc90c3 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index 69348a6069..57a8f06f81 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index 221d4ae9f2..ed1d4fe4f2 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 43fed3530e..83efa583fa 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 86a38b85e2..6313fd4f22 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index f67d7cd586..70124476e1 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 4b2651c8e6..be10844614 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index f4cb697687..dcb5548c4f 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 1ae51831ae..9a28aad091 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 15d87e90a9..b9ed94fcb4 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P2041RDB_SECURE_BOOT_defconfig b/configs/P2041RDB_SECURE_BOOT_defconfig index 1bc514c882..40fa472418 100644 --- a/configs/P2041RDB_SECURE_BOOT_defconfig +++ b/configs/P2041RDB_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P3041DS_NAND_SECURE_BOOT_defconfig b/configs/P3041DS_NAND_SECURE_BOOT_defconfig index 1aad2a61e6..78afd64792 100644 --- a/configs/P3041DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P3041DS_NAND_SECURE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index f7ef553f9a..351e81311a 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index e0a5ae05ca..209abc799c 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P3041DS_SECURE_BOOT_defconfig b/configs/P3041DS_SECURE_BOOT_defconfig index c5766ce2f9..6359cf179d 100644 --- a/configs/P3041DS_SECURE_BOOT_defconfig +++ b/configs/P3041DS_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index 2444a664ae..188fd5fc23 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P4080DS_SECURE_BOOT_defconfig b/configs/P4080DS_SECURE_BOOT_defconfig index 81b14dd9c3..ec678762b5 100644 --- a/configs/P4080DS_SECURE_BOOT_defconfig +++ b/configs/P4080DS_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5020DS_NAND_SECURE_BOOT_defconfig b/configs/P5020DS_NAND_SECURE_BOOT_defconfig index 0200c18816..b92acc0ce2 100644 --- a/configs/P5020DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5020DS_NAND_SECURE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5020DS_NAND_defconfig b/configs/P5020DS_NAND_defconfig index eb4b3875c0..0b723a0f5c 100644 --- a/configs/P5020DS_NAND_defconfig +++ b/configs/P5020DS_NAND_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5020DS_SDCARD_defconfig b/configs/P5020DS_SDCARD_defconfig index af9c2b50a3..4ac1457e57 100644 --- a/configs/P5020DS_SDCARD_defconfig +++ b/configs/P5020DS_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5020DS_SECURE_BOOT_defconfig b/configs/P5020DS_SECURE_BOOT_defconfig index 03b1843c96..3539c82df3 100644 --- a/configs/P5020DS_SECURE_BOOT_defconfig +++ b/configs/P5020DS_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5040DS_NAND_SECURE_BOOT_defconfig b/configs/P5040DS_NAND_SECURE_BOOT_defconfig index 3c0335e8b1..4f4e8d9c48 100644 --- a/configs/P5040DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5040DS_NAND_SECURE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index a468b2bf63..9a1535df6c 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index f9fd14c29c..0f183079c5 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5040DS_SECURE_BOOT_defconfig b/configs/P5040DS_SECURE_BOOT_defconfig index 5d7e1d0502..0e8090f1ec 100644 --- a/configs/P5040DS_SECURE_BOOT_defconfig +++ b/configs/P5040DS_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index dcd3b3fb67..313d6c6439 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index 581d044f98..f655eccb6c 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1023RDB_SECURE_BOOT_defconfig b/configs/T1023RDB_SECURE_BOOT_defconfig index f760f4dc34..1067e36e90 100644 --- a/configs/T1023RDB_SECURE_BOOT_defconfig +++ b/configs/T1023RDB_SECURE_BOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index 19f1000657..43fddebbae 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index ac429f6a85..bf941b361e 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 0b75721da2..b81ccb9e6d 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index f1d04889ff..fe54c4035a 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index eeca0a6718..aea64c1b12 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index d742a32651..6a7ddb8096 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 968d8a8941..f0d088695c 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index c22bf9ce8c..3fa9d7a640 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index 63010c546c..025ef1baac 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index 47582578cf..09e90043ec 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index a75ee03bcf..5fcca8d4df 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index b3e9c412b9..375dea03fe 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index 7b2187cf9c..8c77e24ea0 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index f16834b85c..208d9aa231 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index fed89fd5f5..38c3f4f08a 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 52bb08f653..c09fef981a 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 4a94e30117..ce8990f609 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 513bfd39ca..7514335fc6 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index f2e72c229e..e1d8e2e444 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 3e28c56334..8526b0a7a9 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index cdea7857b6..89c1e1bb72 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 650293c948..de4ad5e736 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index af336dff0b..b128e04e82 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 80ad085b1e..564788214c 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 8e7b677725..d8939bb7eb 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index fac743f55c..fb18a66caa 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2080RDB_SECURE_BOOT_defconfig b/configs/T2080RDB_SECURE_BOOT_defconfig index f8296387c4..aaf3acaea6 100644 --- a/configs/T2080RDB_SECURE_BOOT_defconfig +++ b/configs/T2080RDB_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index 4653515682..b51e28da0b 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2081QDS_SDCARD_defconfig b/configs/T2081QDS_SDCARD_defconfig index 749d87bac9..3081e63559 100644 --- a/configs/T2081QDS_SDCARD_defconfig +++ b/configs/T2081QDS_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index d13d330dca..27fbaebb89 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index a11667c5eb..2d6cf2328d 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4160QDS_SECURE_BOOT_defconfig b/configs/T4160QDS_SECURE_BOOT_defconfig index ea79cc2cb5..8469909fcf 100644 --- a/configs/T4160QDS_SECURE_BOOT_defconfig +++ b/configs/T4160QDS_SECURE_BOOT_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index ce51fb9674..c640e804c9 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index 836f2d942b..976c018813 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4240QDS_SECURE_BOOT_defconfig b/configs/T4240QDS_SECURE_BOOT_defconfig index 3219b0c8b3..444d00c381 100644 --- a/configs/T4240QDS_SECURE_BOOT_defconfig +++ b/configs/T4240QDS_SECURE_BOOT_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index ddb8cacee7..6b7e2e4b31 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index b69ba8fefa..ab9c3f383b 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -49,6 +49,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 5ad992c6e1..28326a260a 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -24,6 +24,7 @@ CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_DFU_TFTP=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index b11d0a71da..a658cf7af3 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -28,6 +28,7 @@ CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index 8fc31461f1..ba7110c7b7 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_UBI=y CONFIG_MMC_OMAP_HS=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 4bd1b65880..b3a1faa794 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_GPIO=y CONFIG_DOS_PARTITION=y CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index 1025cd1d5c..ad92afc439 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_GPIO=y CONFIG_DOS_PARTITION=y CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 0011234d55..a7faad27c7 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_GPIO=y CONFIG_DOS_PARTITION=y CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/am335x_shc_prompt_defconfig b/configs/am335x_shc_prompt_defconfig index a6c617f87e..c0b13b8e2f 100644 --- a/configs/am335x_shc_prompt_defconfig +++ b/configs/am335x_shc_prompt_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_GPIO=y CONFIG_DOS_PARTITION=y CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index fa231543a2..c7a13ae00d 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_GPIO=y CONFIG_DOS_PARTITION=y CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/am335x_shc_sdboot_prompt_defconfig b/configs/am335x_shc_sdboot_prompt_defconfig index fa231543a2..c7a13ae00d 100644 --- a/configs/am335x_shc_sdboot_prompt_defconfig +++ b/configs/am335x_shc_sdboot_prompt_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_GPIO=y CONFIG_DOS_PARTITION=y CONFIG_ISO_PARTITION=y # CONFIG_SPL_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 855e1ca9e2..4a3d50874e 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index c51313fc19..73c348e0ac 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 7e9ea0ee51..d1ca466960 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 658ab92487..e731715c6a 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -38,6 +38,7 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am572x-idk am571x-idk" +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPL_DM=y # CONFIG_BLK is not set diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index 6048e6c911..6ae5d501c8 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index b3833303aa..9cde1d30d8 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -42,6 +42,7 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am572x-idk am571x-idk" +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPL_DM=y # CONFIG_BLK is not set diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index d6adf041f3..cc14e91838 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/apalis_imx6_nospl_com_defconfig b/configs/apalis_imx6_nospl_com_defconfig index 6611c4306d..1c0bbb8b7f 100644 --- a/configs/apalis_imx6_nospl_com_defconfig +++ b/configs/apalis_imx6_nospl_com_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/apalis_imx6_nospl_it_defconfig b/configs/apalis_imx6_nospl_it_defconfig index dba0a7c670..00f6b5dc4e 100644 --- a/configs/apalis_imx6_nospl_it_defconfig +++ b/configs/apalis_imx6_nospl_it_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 7474fdd994..81ebd4595f 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -25,5 +25,6 @@ CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_MXC=y CONFIG_OF_LIBFDT=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 8bc1770ec2..28b3aa31bf 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_MXS=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 0f2aa16e0e..e4731ecb1e 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM_I2C_COMPAT=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y diff --git a/configs/aspenite_defconfig b/configs/aspenite_defconfig index 0ac39eabd2..5da2cde2c5 100644 --- a/configs/aspenite_defconfig +++ b/configs/aspenite_defconfig @@ -9,6 +9,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 7df2e06942..8c47534e31 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 16f5defa43..a10bee00df 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index aef21b8125..ad14e8dcef 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 46217efb39..83c75c72d6 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index 2a696d49c0..8e10ef2299 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 55923ca6bd..bc20de347a 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 359ee54646..613a9f34b7 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index ddc26bea20..2ccc3f775b 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 08887c4cfe..b0eb35c03d 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 851867e8a1..efb363b2ac 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index e31b659b22..213104c0af 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index e304fd6072..d70443ba6b 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 14ec8a1f11..e3fec34836 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index 28e399ea9f..81892a053d 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 61caa9be75..9ea9b2fa98 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/bcm23550_w1d_defconfig b/configs/bcm23550_w1d_defconfig index 73c238e152..759e1c4001 100644 --- a/configs/bcm23550_w1d_defconfig +++ b/configs/bcm23550_w1d_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index e3cdf98f98..7c6cece26a 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index aa5216e696..1fa41ce6c9 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_KONA=y diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index 61336d38f0..4d1a9636ed 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_SHA1=y diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index cbef3d8365..c803322b4d 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_SHA1=y diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index b124206361..6ca833a9f5 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_SHA1=y diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index f271fa06e5..63620c1630 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_SHA1=y diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index b124206361..6ca833a9f5 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_SHA1=y diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index b124206361..6ca833a9f5 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_SHA1=y diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index ffda22ed49..e0ad23fa58 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_TIME=y CONFIG_CMD_HASH=y CONFIG_HASH_VERIFY=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/bcm958712k_defconfig b/configs/bcm958712k_defconfig index 96e4bce972..5966f89030 100644 --- a/configs/bcm958712k_defconfig +++ b/configs/bcm958712k_defconfig @@ -6,5 +6,6 @@ CONFIG_BOOTDELAY=5 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SYS_PROMPT="u-boot> " # CONFIG_CMD_IMLS is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 90fce0b4e3..fd810fb884 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 073a58d94e..078a8768c6 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index 5269c177d4..807d66a6c5 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index c5b1e9c062..797bdd1c6c 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -3,7 +3,7 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_TARGET_BK4R1=y CONFIG_DEFAULT_DEVICE_TREE="bk4r1" -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_GPIO=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index e2a009edd9..ffad20659d 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NETCONSOLE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index ba03758b3c..4b16728acb 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_NETCONSOLE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 05ceba8fd6..4aff4e1af3 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -49,6 +49,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NETCONSOLE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 6b10abb690..8a60b25b81 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index 82b527641d..2d911c36ac 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM_GPIO=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y diff --git a/configs/chromebit_mickey_defconfig b/configs/chromebit_mickey_defconfig index 7d0351e324..06afc49608 100644 --- a/configs/chromebit_mickey_defconfig +++ b/configs/chromebit_mickey_defconfig @@ -31,6 +31,7 @@ CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 8f33bb8316..46c7254434 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -33,6 +33,7 @@ CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/chromebook_minnie_defconfig b/configs/chromebook_minnie_defconfig index db1488a2ad..9ee0dae6f1 100644 --- a/configs/chromebook_minnie_defconfig +++ b/configs/chromebook_minnie_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 3bb6c6bf65..9597c01ddb 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index be0536a272..b55b530eeb 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index dbe34eb59e..12c6801a34 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 50f6c6498c..c0f80029bf 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index 6d18eac559..42776c5fab 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -38,8 +38,9 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y -CONFIG_SCSI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 7ed05cf8c9..db65e72901 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -41,6 +41,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/colibri_imx6_nospl_defconfig b/configs/colibri_imx6_nospl_defconfig index df24f17b2d..298605500b 100644 --- a/configs/colibri_imx6_nospl_defconfig +++ b/configs/colibri_imx6_nospl_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 2ba6aea312..4a536609bc 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 1d00055a83..34768aa64e 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_UBI=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 3b510c3e6d..5dd8e535fc 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -4,7 +4,7 @@ CONFIG_ARCH_VF610=y CONFIG_VIDEO=y CONFIG_TARGET_COLIBRI_VF=y CONFIG_DEFAULT_DEVICE_TREE="vf610-colibri" -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,ENV_IS_IN_NAND,IMX_NAND" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,IMX_NAND" CONFIG_BOOTDELAY=1 CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DFU_MMC=y diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index d05f35d967..4fa05d18ac 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_TPM=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index d2af507054..833963a975 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_TPM=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig index 614cdb6201..b5df3253f7 100644 --- a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_TPM=y # CONFIG_CMD_IRQ is not set CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y # CONFIG_PCI is not set CONFIG_SYS_NS16550=y diff --git a/configs/controlcenterd_TRAILBLAZER_defconfig b/configs/controlcenterd_TRAILBLAZER_defconfig index da657f142f..5ed20dc28e 100644 --- a/configs/controlcenterd_TRAILBLAZER_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_TPM=y # CONFIG_CMD_IRQ is not set CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y # CONFIG_PCI is not set CONFIG_SYS_NS16550=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 8b51073030..d7b2c75cfa 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -31,6 +31,7 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_SPI_FLASH=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index ac5eefd0d8..1e01fa1457 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_AT91_UTMI=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 02fceaacd2..a306d53201 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y diff --git a/configs/dbau1000_defconfig b/configs/dbau1000_defconfig index bb65369aaa..b3508fd8da 100644 --- a/configs/dbau1000_defconfig +++ b/configs/dbau1000_defconfig @@ -15,4 +15,5 @@ CONFIG_CMD_IDE=y CONFIG_CMD_DHCP=y CONFIG_MAC_PARTITION=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/dbau1100_defconfig b/configs/dbau1100_defconfig index 98b0d40c7b..f7661d7d65 100644 --- a/configs/dbau1100_defconfig +++ b/configs/dbau1100_defconfig @@ -15,4 +15,5 @@ CONFIG_CMD_IDE=y CONFIG_CMD_DHCP=y CONFIG_MAC_PARTITION=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/dbau1500_defconfig b/configs/dbau1500_defconfig index cdf5477407..8ad3823683 100644 --- a/configs/dbau1500_defconfig +++ b/configs/dbau1500_defconfig @@ -15,4 +15,5 @@ CONFIG_CMD_IDE=y CONFIG_CMD_DHCP=y CONFIG_MAC_PARTITION=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/dbau1550_defconfig b/configs/dbau1550_defconfig index 6a0c8e8c8a..94efd88857 100644 --- a/configs/dbau1550_defconfig +++ b/configs/dbau1550_defconfig @@ -10,4 +10,5 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/dbau1550_el_defconfig b/configs/dbau1550_el_defconfig index e2e5eef38b..1cb7a06da3 100644 --- a/configs/dbau1550_el_defconfig +++ b/configs/dbau1550_el_defconfig @@ -11,4 +11,5 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 06874c9da0..cf482153e9 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_GPIO=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index f5871909ce..8832ac4ad8 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index abe6a6379f..8e4c2365b3 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index a70458872d..16d1f941a2 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 6dd1baf6e9..280b7d5233 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -36,6 +36,7 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y @@ -44,7 +45,6 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_DM_SCSI=y CONFIG_DWC_AHCI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -68,6 +68,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_PALMAS=y CONFIG_DM_REGULATOR_LP873X=y +CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 3008a1fd2c..6252ebffd7 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -41,13 +41,13 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y -CONFIG_DM_SCSI=y CONFIG_DWC_AHCI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -71,6 +71,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_PALMAS=y CONFIG_DM_REGULATOR_LP873X=y +CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 1d32220179..fa1d84b4a3 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_UBI=y # CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index d992c2adda..5523df3f10 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIMER=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_CLK=y CONFIG_MSM_GPIO=y CONFIG_PM8916_GPIO=y diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index b945875adf..e051456635 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/eco5pk_defconfig b/configs/eco5pk_defconfig index 1501368317..6401876169 100644 --- a/configs/eco5pk_defconfig +++ b/configs/eco5pk_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 2fae904589..beeca53b4a 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -31,6 +31,7 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM_PCI=y CONFIG_DEBUG_EFI_CONSOLE=y CONFIG_DEBUG_UART_BASE=0 diff --git a/configs/espresso7420_defconfig b/configs/espresso7420_defconfig index 66f0d63a35..ca3837e97e 100644 --- a/configs/espresso7420_defconfig +++ b/configs/espresso7420_defconfig @@ -11,4 +11,5 @@ CONFIG_SYS_PROMPT="ESPRESSO7420 # " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index 5781974396..143de46925 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_UBI=y # CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y diff --git a/configs/evb-ast2500_defconfig b/configs/evb-ast2500_defconfig index f71d0c10c3..a52bc53769 100644 --- a/configs/evb-ast2500_defconfig +++ b/configs/evb-ast2500_defconfig @@ -9,6 +9,7 @@ CONFIG_PRE_CON_BUF_ADDR=0x1e720000 # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_CMD_IMLS is not set CONFIG_CMD_I2C=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_CLK=y CONFIG_DM_I2C=y diff --git a/configs/evb-px5_defconfig b/configs/evb-px5_defconfig index 2c8c894746..41fb45790a 100644 --- a/configs/evb-px5_defconfig +++ b/configs/evb-px5_defconfig @@ -11,6 +11,7 @@ CONFIG_ANDROID_BOOT_IMAGE=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index 321ef71c73..b09efde392 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_TIME=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/evb-rk3229_defconfig b/configs/evb-rk3229_defconfig index 0952fdc698..4d42e25d02 100644 --- a/configs/evb-rk3229_defconfig +++ b/configs/evb-rk3229_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 0d2831158d..7647dd089f 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 82f03e479c..5fd8553f3f 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index bdab07b56b..883305c5ad 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index 8d147913de..9fa7937cb1 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 3a51da8274..e3a335a11a 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 6f093f48cf..1f1db7d9b4 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 04fb3b7650..7e3d107072 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/geekbox_defconfig b/configs/geekbox_defconfig index 0a1e1dc72d..f5cbd4c90a 100644 --- a/configs/geekbox_defconfig +++ b/configs/geekbox_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3368-geekbox" CONFIG_DEBUG_UART=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_CMD_IMLS is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 4dfb895351..a660b5c80a 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/gplugd_defconfig b/configs/gplugd_defconfig index 75e980979c..d81ed740be 100644 --- a/configs/gplugd_defconfig +++ b/configs/gplugd_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index d43fd14a8a..67551e4999 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 570819d3e5..460682c020 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 57f46af193..ba96c6ef88 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 4bf7122963..150c77d32b 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_PHYLIB=y CONFIG_MV88E61XX_SWITCH=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index ea6c13d9dc..a90b5e7432 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -49,6 +49,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_PHYLIB=y CONFIG_NETDEVICES=y diff --git a/configs/h2200_defconfig b/configs/h2200_defconfig index 9d3698c555..70c304ada4 100644 --- a/configs/h2200_defconfig +++ b/configs/h2200_defconfig @@ -25,5 +25,6 @@ CONFIG_SYS_PROMPT="> " # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_PXA_SERIAL=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index fce3eeef1e..4b6c0db169 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_PCI=y CONFIG_DM_PCI=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index cc9011d05c..272f108efe 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index 3e48380bc7..cb4fa93a5f 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index a86a00997f..74a91cddc5 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 2616fb2e1a..0d7c1196f8 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 5859e6e95e..407ad99091 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y diff --git a/configs/imgtec_xilfpga_defconfig b/configs/imgtec_xilfpga_defconfig index 02969da909..c720a9f757 100644 --- a/configs/imgtec_xilfpga_defconfig +++ b/configs/imgtec_xilfpga_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_TIME=y # CONFIG_ISO_PARTITION is not set CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_CLK=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 503b14c3e2..6a950222c6 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 4a124b8acc..87dbffcf01 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -14,7 +14,7 @@ CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,ENV_IS_IN_MMC" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y @@ -34,6 +34,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_LIST="imx6q-icore imx6dl-icore" # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index f94281cdc0..a584c43b27 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,ENV_IS_IN_NAND" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_OF_LIST="imx6q-icore imx6dl-icore" # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index ca9eb94491..778e5ef5c1 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-rqs" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,ENV_IS_IN_MMC" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_LIST="imx6q-icore-rqs imx6dl-icore-rqs" # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 743f859b99..f48a7b83da 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam-kit" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,ENV_IS_IN_MMC" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index b0da6f1553..df447acefe 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -11,7 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam-kit" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,ENV_IS_IN_NAND" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index 9771b793e5..7697a6fd20 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-emmc" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,ENV_IS_IN_MMC" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y # CONFIG_BLK is not set # CONFIG_DM_MMC_OPS is not set CONFIG_PHYLIB=y diff --git a/configs/imx6ul_isiot_mmc_defconfig b/configs/imx6ul_isiot_mmc_defconfig index f4b5c8f262..d205f0f891 100644 --- a/configs/imx6ul_isiot_mmc_defconfig +++ b/configs/imx6ul_isiot_mmc_defconfig @@ -12,7 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-mmc" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,ENV_IS_IN_MMC" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y CONFIG_SPL_EXT_SUPPORT=y @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 76bfe8da5b..8ee6c6e3e5 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -11,7 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-nand" CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,ENV_IS_IN_NAND" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SPL=y CONFIG_SPL_DMA_SUPPORT=y @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_BLK is not set CONFIG_SYS_I2C_MXC=y # CONFIG_DM_MMC_OPS is not set diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index cace5adcb2..a82935177e 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -8,6 +8,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_PCI=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index a1639ada33..708c26b9af 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -8,6 +8,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_PCI=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index f288dc88e2..55615611da 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -8,6 +8,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_PCI=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index c13af27def..b19a020d84 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -8,6 +8,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_PCI=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 3c32a6b0ec..e6e0b54448 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -25,5 +25,6 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 4949f22c01..76c0b7db55 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 55eab61cc3..92338b1dab 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index b9868395a4..1438e5f884 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index a66a256346..b592a24dfb 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 64301c3bff..38d61d67a1 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index c5ecdda92f..ad8839db9f 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index 715e4b2358..4578efadf5 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_TIME=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 589e8cf880..d04b45fcee 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_DIAG=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index f8494503d8..05becd8032 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -27,5 +27,6 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig index ec6ed377d4..7c39f4e9f2 100644 --- a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index e412024349..663808172d 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index e1ddd293dc..f00feb7b5a 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 6b5477fbd6..aef90f1c48 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index b349fea4d6..9d01392f54 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index ea8738fa90..27615339c5 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index cf99770a60..7e0b6ac9a6 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index d13652a2f5..b75d8ee8f7 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 9809c60d35..c97d46c9df 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 5ccfc96e9d..e579275bc3 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index b9246234b2..f7924e3d7d 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 2680892276..526221ee48 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 88c99a2216..ba00c45572 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index d914be2309..c72639d8dd 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 957f2c7fbb..83ff95a29a 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 0144db585f..7e09b48561 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 4e959bfe60..f69f5c7125 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -36,6 +36,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index ea674c8b2c..ad3eb9c46b 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index cead5afe03..e119205ce5 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index a3c60651ec..190a610962 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index 19b80777fb..21b492483b 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index e49de18746..3c6e7d6219 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index c50931a339..d315a490fd 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index de14dc1a33..34c64df5ec 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 5162c2cadc..165964fa2b 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index da8c5b815b..0b1d7e7640 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index 6211b6b5af..0890997d40 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_CACHE=y # CONFIG_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index b6f7709af2..8b141cb49c 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 617c522851..8760547c5c 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 6548bc099f..9b6ddda664 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_DATE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index f933b8fa2c..bbe07a9fe1 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 70839e6f01..127bf0abe7 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 58eb4c68ef..d084e77e74 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index 944e39dda1..8aeb236e0a 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_MXS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index afcaf58530..f7945100b6 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_USB=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index e838c124a8..6484c9b2ab 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index d0f361f6bb..c40dd02636 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 80e3ed86c9..599ed8c180 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index 12482bf795..160448f303 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -14,5 +14,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index c6bfa1e9f1..d9c3697684 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index edd9e68862..4566d44b71 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/mvebu_db-88f7040-nand_defconfig b/configs/mvebu_db-88f7040-nand_defconfig new file mode 100644 index 0000000000..c301c057b1 --- /dev/null +++ b/configs/mvebu_db-88f7040-nand_defconfig @@ -0,0 +1,73 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_MVEBU_ARMADA_8K=y +CONFIG_DEFAULT_DEVICE_TREE="armada-7040-db-nand" +CONFIG_SMBIOS_PRODUCT_NAME="" +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PART=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_MVEBU_NAND_BOOT=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y +CONFIG_BLOCK_CACHE=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_NAND_PXA3XX=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHYLIB=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_DW_MVEBU=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_8K=y +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART_BASE=0xf0512000 +CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_SMBIOS_MANUFACTURER="" diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 795de14740..7d96dd41de 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 7eb1791d6c..55bad255fb 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_MXS=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mx25pdk_defconfig b/configs/mx25pdk_defconfig index c3a0091ce4..1c1b0bd8b0 100644 --- a/configs/mx25pdk_defconfig +++ b/configs/mx25pdk_defconfig @@ -17,4 +17,5 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 710ae4711d..d6f0d00a23 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -5,7 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_VIDEO=y -CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC" +CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_MXS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 95ac31adaf..fcc98a26fa 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_VIDEO=y CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -34,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_MXS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 3b955401ca..0bdac689e4 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_VIDEO=y -CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_NAND" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -33,6 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_MXS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index e704dfd5f8..2193aee59b 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -15,4 +15,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index 8f09c04ceb..49eabef19c 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/mx53ard_defconfig b/configs/mx53ard_defconfig index 146e7de7e3..a6bc708f88 100644 --- a/configs/mx53ard_defconfig +++ b/configs/mx53ard_defconfig @@ -14,4 +14,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53cx9020_defconfig b/configs/mx53cx9020_defconfig index 9b3a664a7a..659d5e8249 100644 --- a/configs/mx53cx9020_defconfig +++ b/configs/mx53cx9020_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_FPGA_ALTERA=y CONFIG_FPGA_CYCLON2=y CONFIG_NETDEVICES=y diff --git a/configs/mx53evk_defconfig b/configs/mx53evk_defconfig index eed381b2fa..518e028953 100644 --- a/configs/mx53evk_defconfig +++ b/configs/mx53evk_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 6e2f585960..3d44463703 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y # CONFIG_VIDEO_SW_CURSOR is not set diff --git a/configs/mx53smd_defconfig b/configs/mx53smd_defconfig index 2a481a399e..51f3618773 100644 --- a/configs/mx53smd_defconfig +++ b/configs/mx53smd_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index dd974b2193..0aa5df0621 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_SATA=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y diff --git a/configs/mx6dlarm2_defconfig b/configs/mx6dlarm2_defconfig index 82e9a069a3..825cb32e2c 100644 --- a/configs/mx6dlarm2_defconfig +++ b/configs/mx6dlarm2_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6dlarm2_lpddr2_defconfig b/configs/mx6dlarm2_lpddr2_defconfig index 19fede6961..ff3aed0bda 100644 --- a/configs/mx6dlarm2_lpddr2_defconfig +++ b/configs/mx6dlarm2_lpddr2_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qarm2_defconfig b/configs/mx6qarm2_defconfig index cee1300a2d..8be6b8643f 100644 --- a/configs/mx6qarm2_defconfig +++ b/configs/mx6qarm2_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qarm2_lpddr2_defconfig b/configs/mx6qarm2_lpddr2_defconfig index f150e3287e..9629dc3044 100644 --- a/configs/mx6qarm2_lpddr2_defconfig +++ b/configs/mx6qarm2_lpddr2_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig new file mode 100644 index 0000000000..903495dd73 --- /dev/null +++ b/configs/mx6qpsabreauto_defconfig @@ -0,0 +1,44 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_VIDEO=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" +CONFIG_BOOTDELAY=3 +# CONFIG_CONSOLE_MUX is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_DFU_MMC=y +CONFIG_DFU_SF=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="FSL" +CONFIG_G_DNL_VENDOR_NUM=0x0525 +CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +# CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig new file mode 100644 index 0000000000..c086926b87 --- /dev/null +++ b/configs/mx6qsabreauto_defconfig @@ -0,0 +1,45 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_VIDEO=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" +CONFIG_BOOTDELAY=3 +# CONFIG_CONSOLE_MUX is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DFU=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_DFU_MMC=y +CONFIG_DFU_SF=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_CI_UDC=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="FSL" +CONFIG_G_DNL_VENDOR_NUM=0x0525 +CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +# CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 32bd271209..cd8b30abe8 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 76c39cea67..a673905846 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_SPI_FLASH=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index d8e05cfe04..922997f1e4 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PCI=y diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 6903fc9ebc..acd3c1f480 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 39bb63f861..5ceea11eea 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6sllevk_defconfig b/configs/mx6sllevk_defconfig index 949ce91804..3e2c53c348 100644 --- a/configs/mx6sllevk_defconfig +++ b/configs/mx6sllevk_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/mx6sllevk_plugin_defconfig b/configs/mx6sllevk_plugin_defconfig index 60a4431083..58930503a6 100644 --- a/configs/mx6sllevk_plugin_defconfig +++ b/configs/mx6sllevk_plugin_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 54f323192d..fc6b77dccf 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 57ed81f1ab..9defd6a4bb 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6ull_14x14_evk_defconfig b/configs/mx6ull_14x14_evk_defconfig index 4ae492a2d0..3ff18e2eca 100644 --- a/configs/mx6ull_14x14_evk_defconfig +++ b/configs/mx6ull_14x14_evk_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y CONFIG_DM_74X164=y diff --git a/configs/mx6ull_14x14_evk_plugin_defconfig b/configs/mx6ull_14x14_evk_plugin_defconfig index 0b232c4df7..128d7a4323 100644 --- a/configs/mx6ull_14x14_evk_plugin_defconfig +++ b/configs/mx6ull_14x14_evk_plugin_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y CONFIG_DM_74X164=y diff --git a/configs/mx7ulp_evk_defconfig b/configs/mx7ulp_evk_defconfig index 6ab7cb77e6..dca0c806f9 100644 --- a/configs/mx7ulp_evk_defconfig +++ b/configs/mx7ulp_evk_defconfig @@ -9,6 +9,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y diff --git a/configs/mx7ulp_evk_plugin_defconfig b/configs/mx7ulp_evk_plugin_defconfig index 6ab7cb77e6..dca0c806f9 100644 --- a/configs/mx7ulp_evk_plugin_defconfig +++ b/configs/mx7ulp_evk_plugin_defconfig @@ -9,6 +9,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index a57cc9724c..4547d2bc8d 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 3ca00b9899..4804f6354c 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_CFB_CONSOLE_ANSI=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 15cbbace85..7bfad10081 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_PCI=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index ae39818e4b..ca1a1c97ed 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/nsim_700_defconfig b/configs/nsim_700_defconfig index d815434127..f969419d41 100644 --- a/configs/nsim_700_defconfig +++ b/configs/nsim_700_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_PROMPT="nsim# " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/nsim_700be_defconfig b/configs/nsim_700be_defconfig index 991d509d2f..f34a031276 100644 --- a/configs/nsim_700be_defconfig +++ b/configs/nsim_700be_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_PROMPT="nsim# " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/nsim_hs38_defconfig b/configs/nsim_hs38_defconfig index 16e3911152..067839f1d9 100644 --- a/configs/nsim_hs38_defconfig +++ b/configs/nsim_hs38_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_PROMPT="nsim# " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/nsim_hs38be_defconfig b/configs/nsim_hs38be_defconfig index d87833e9cc..67c1dde0b9 100644 --- a/configs/nsim_hs38be_defconfig +++ b/configs/nsim_hs38be_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_PROMPT="nsim# " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 35314142a0..3391b8ff36 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 28025fc4e5..39a387ab4c 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_ADC=y CONFIG_ADC_EXYNOS=y CONFIG_DFU_MMC=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index 3e4dee747b..efe41031c4 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=1 diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 8d5bc8e1fc..064211e505 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_JFFS2=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index fa09a53fa8..13275ff0ae 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index db8f4683e2..6278dd6041 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_BLK is not set CONFIG_DM_I2C=y CONFIG_DM_MMC=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index f4c3d3233d..0c6e28dd9b 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index b86dfadc52..0d119a2cb1 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index a76ac6f2d8..09d48b4a83 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index dda4030ecc..31950624ad 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 0af00b14be..4a91dd954d 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -32,10 +32,11 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y -CONFIG_SCSI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_MMC_OMAP_HS=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index c6f474a9b2..83aadda5fe 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -24,6 +24,7 @@ CONFIG_CRC32_VERIFY=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x28000 diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 1471872833..4e11898eef 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index b62852a10c..63087394bf 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index d57b6962d5..a63be6872d 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index f08e1dd404..76778a12ec 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -52,6 +52,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 3fd171379f..3179e6d1f7 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/pb1000_defconfig b/configs/pb1000_defconfig index 7146a2702c..9b26ea4d90 100644 --- a/configs/pb1000_defconfig +++ b/configs/pb1000_defconfig @@ -15,4 +15,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index 466aa511ba..cabee86194 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 7150e79ed6..1a59ff3a6b 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 1e72e91ede..217df82dbb 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -3,7 +3,7 @@ CONFIG_SYS_THUMB_BUILD=y CONFIG_ARCH_VF610=y CONFIG_TARGET_PCM052=y CONFIG_DEFAULT_DEVICE_TREE="pcm052" -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_GPIO=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 973f3cd53b..ed5a877196 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -49,6 +49,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_DIAG=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 11570a8126..434c4da8c6 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_FAT_WRITE=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index 823db06d85..e4686e4f32 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index 688b989419..74bb5f966f 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_BLK is not set CONFIG_CLK=y diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index d18a96e18e..1994da3ab6 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DFU_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index d361a74033..e55d827d34 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index cf6367a920..6e8d675acd 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 46d30fdf51..4f1d4ac4b0 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 954908e9aa..d7449c5633 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_JFFS2=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 57ebc0694c..f07c42cb4a 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/poplar_defconfig b/configs/poplar_defconfig index 1c617713a9..3785bb9618 100644 --- a/configs/poplar_defconfig +++ b/configs/poplar_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_UNZIP=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_K3=y CONFIG_USB=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 6d026756da..795171f751 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 89f1620023..5e1399f008 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 58de0d48dd..0b260eb7c8 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -52,6 +52,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index f4640b906a..ba8205358a 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y # CONFIG_MMC is not set CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 2b43827254..a05200e8fc 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -52,6 +52,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_SPL_DM=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index b648326041..16609cd137 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -35,6 +35,7 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index e092dbdef6..907325223f 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -32,6 +32,7 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index f8f6295617..a9b7da8c4e 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -33,6 +33,7 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index c0e3999f96..9f61718162 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SH_SDHI=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index d57305112b..430812be88 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SH_SDHI=y CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 6ba984f6ae..14cbbacb51 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_UBI=y # CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index d00666bef0..8f4f273eba 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -3,7 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_VIDEO=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -17,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index eec0613505..35b4f2739e 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent" +CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/rock_defconfig b/configs/rock_defconfig index 5d9b63bd37..9158643959 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_SPL_SIMPLE_BUS is not set diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 9edc4a500d..404f2896a8 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -53,6 +53,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y diff --git a/configs/s32v234evb_defconfig b/configs/s32v234evb_defconfig index 302ec6d030..466c44a913 100644 --- a/configs/s32v234evb_defconfig +++ b/configs/s32v234evb_defconfig @@ -5,4 +5,5 @@ CONFIG_SYS_MALLOC_F=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/s32v234evb/s32v234evb.cfg" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_BOOTZ=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_LIBFDT=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 8aeab15bfb..01dd4967e9 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DFU_MMC=y CONFIG_DM_I2C_GPIO=y CONFIG_MMC_SDHCI=y diff --git a/configs/sama5d2_ptc_nandflash_defconfig b/configs/sama5d2_ptc_nandflash_defconfig index 66edd31bfe..5522f70ec6 100644 --- a/configs/sama5d2_ptc_nandflash_defconfig +++ b/configs/sama5d2_ptc_nandflash_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL=y CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_USB=y diff --git a/configs/sama5d36ek_cmp_nandflash_defconfig b/configs/sama5d36ek_cmp_nandflash_defconfig index e312bbf472..12a868e014 100644 --- a/configs/sama5d36ek_cmp_nandflash_defconfig +++ b/configs/sama5d36ek_cmp_nandflash_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index 0d5d2be2eb..47acdceec7 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index a8f09ed340..89e9e36341 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index bb791a3a97..59ee1eca47 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_CLK=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 5d43ce925c..3b36d7f7f9 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 7a1b9ef052..bd6bc378f1 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -65,6 +65,7 @@ CONFIG_AMIGA_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIVE=y CONFIG_OF_HOSTFILE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NETCONSOLE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index c5ef69f241..d01bde69b9 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -55,6 +55,7 @@ CONFIG_MAC_PARTITION=y CONFIG_AMIGA_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NETCONSOLE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index 747d4b1bba..391efc1d1d 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -69,6 +69,7 @@ CONFIG_ISO_PARTITION=y CONFIG_AMIGA_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NETCONSOLE=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 6889206c1b..3cc595db0a 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -72,6 +72,7 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_HOSTFILE=y CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NETCONSOLE=y CONFIG_SPL_DM=y CONFIG_REGMAP=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 80531fe6d4..5c5b8df934 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_MXS=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index 827f4eeccb..312e1f5c01 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_MXS=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 6900b77fe9..5c3056ed7e 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/secomx6quq7_defconfig b/configs/secomx6quq7_defconfig index 2866bb02f5..22c25548c5 100644 --- a/configs/secomx6quq7_defconfig +++ b/configs/secomx6quq7_defconfig @@ -4,7 +4,6 @@ CONFIG_TARGET_SECOMX6=y CONFIG_SECOMX6_UQ7=y CONFIG_SECOMX6Q=y CONFIG_SECOMX6_2GB=y -CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y @@ -23,4 +22,5 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_LIBFDT=y diff --git a/configs/sheep-rk3368_defconfig b/configs/sheep-rk3368_defconfig index 9167e9d2ea..af9d1d2f08 100644 --- a/configs/sheep-rk3368_defconfig +++ b/configs/sheep-rk3368_defconfig @@ -8,6 +8,7 @@ CONFIG_FASTBOOT=y CONFIG_ANDROID_BOOT_IMAGE=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_MMC=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index ac7217dcba..4a2ebc6fcf 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index a769fc5535..fbcdc394db 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FAT=y # CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index 2fbd7d2a8d..f6fb86f761 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index 12cafd9815..86ff832c90 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 83df0bd9a1..8103ccf287 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 46bda478d5..df418dcf31 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DOS_PARTITION=y # CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index a3f9ef01ba..dae465ed0f 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 9e9f781da1..d2edffffa1 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index f11570298c..d79020c0a9 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 8f7e45961e..2447060a1a 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index 7b7909cb62..cfc123f85d 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 88618f8559..ab9e81873a 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 864ec5916f..53d5fbd3eb 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 706ca72f93..71f32603a6 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/spear300_nand_defconfig b/configs/spear300_nand_defconfig index 2d37bafa1c..21f7ac6c37 100644 --- a/configs/spear300_nand_defconfig +++ b/configs/spear300_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear300_usbtty_nand_defconfig b/configs/spear300_usbtty_nand_defconfig index 6b694b1182..84df6201e4 100644 --- a/configs/spear300_usbtty_nand_defconfig +++ b/configs/spear300_usbtty_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear310_nand_defconfig b/configs/spear310_nand_defconfig index d2d25d0c34..ac9ce8b03c 100644 --- a/configs/spear310_nand_defconfig +++ b/configs/spear310_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear310_usbtty_nand_defconfig b/configs/spear310_usbtty_nand_defconfig index 02b05f9c6e..1498a65f60 100644 --- a/configs/spear310_usbtty_nand_defconfig +++ b/configs/spear310_usbtty_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_nand_defconfig b/configs/spear320_nand_defconfig index cb312bfd1f..76e201d31c 100644 --- a/configs/spear320_nand_defconfig +++ b/configs/spear320_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_usbtty_nand_defconfig b/configs/spear320_usbtty_nand_defconfig index a346084c58..1e082c5322 100644 --- a/configs/spear320_usbtty_nand_defconfig +++ b/configs/spear320_usbtty_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear600_nand_defconfig b/configs/spear600_nand_defconfig index f438575bbd..ac0035f3e3 100644 --- a/configs/spear600_nand_defconfig +++ b/configs/spear600_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear600_usbtty_nand_defconfig b/configs/spear600_usbtty_nand_defconfig index a31fee8e93..3e06fd18c8 100644 --- a/configs/spear600_usbtty_nand_defconfig +++ b/configs/spear600_usbtty_nand_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index 4e6942f56c..f94b5118bc 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_MMC_SDHCI=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index f76d3c521c..083456d68a 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DNS=y CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_TIMER=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_CLK=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index 93714d13c5..8ef18d14b9 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 70d44a760b..59a2108396 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_PING=y # CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y diff --git a/configs/tb100_defconfig b/configs/tb100_defconfig index 294ae63f4c..8bcfee9561 100644 --- a/configs/tb100_defconfig +++ b/configs/tb100_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 90a238cacf..9166675cc4 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_PCI=y CONFIG_DM_THERMAL=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 6d1bde8492..423f8d7e2b 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index e2dc71b02c..9cff32f56a 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_UBI=y # CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y diff --git a/configs/thunderx_88xx_defconfig b/configs/thunderx_88xx_defconfig index a9b095ccd3..6e15c78298 100644 --- a/configs/thunderx_88xx_defconfig +++ b/configs/thunderx_88xx_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_PROMPT="ThunderX_88XX> " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_DM_SERIAL=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index 1b127b8609..6284b2b6c4 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 2448aa51b6..4bfce3f6e6 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index c46bacccf3..2f5e1bb3aa 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_SPL_PARTITION_UUIDS=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index d772ec5777..3d22c85987 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index 8df2fb13ce..922386660e 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_RAM=y CONFIG_MMC_SDHCI=y diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index cddc084a05..efeb9bad18 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_RAM=y CONFIG_MMC_SDHCI=y diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 1016718797..ba5900051e 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_RAM=y CONFIG_MMC_SDHCI=y diff --git a/configs/tplink_wdr4300_defconfig b/configs/tplink_wdr4300_defconfig index 65314df133..33c7bd215d 100644 --- a/configs/tplink_wdr4300_defconfig +++ b/configs/tplink_wdr4300_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CLK=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/tqma6dl_mba6_mmc_defconfig b/configs/tqma6dl_mba6_mmc_defconfig index cd31cf39aa..c3a552806b 100644 --- a/configs/tqma6dl_mba6_mmc_defconfig +++ b/configs/tqma6dl_mba6_mmc_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index 6e8e84225e..f53d13445d 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index eb609e12a4..83796973e8 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/tqma6s_wru4_mmc_defconfig b/configs/tqma6s_wru4_mmc_defconfig index 4dc6b9e291..8a6e6cceb6 100644 --- a/configs/tqma6s_wru4_mmc_defconfig +++ b/configs/tqma6s_wru4_mmc_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=0 diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 03b99ec1b7..e8961b75da 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=1 diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index b777e84314..d9b768443b 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=1 diff --git a/configs/ts4600_defconfig b/configs/ts4600_defconfig index ab4f730a3f..a22d611a3e 100644 --- a/configs/ts4600_defconfig +++ b/configs/ts4600_defconfig @@ -3,7 +3,6 @@ CONFIG_TARGET_TS4600=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_ARCH_MISC_INIT=y @@ -18,5 +17,6 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_MXS=y CONFIG_OF_LIBFDT=y diff --git a/configs/ts4800_defconfig b/configs/ts4800_defconfig index 4d4aebd06f..8bdbcf3a72 100644 --- a/configs/ts4800_defconfig +++ b/configs/ts4800_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_OF_LIBFDT=y diff --git a/configs/twister_defconfig b/configs/twister_defconfig index f7c933630b..a12eb688c3 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index ced195c9f8..4bce7417b2 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/usbarmory_defconfig b/configs/usbarmory_defconfig index a71a75751f..65c5e69629 100644 --- a/configs/usbarmory_defconfig +++ b/configs/usbarmory_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_FUSE=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 5b88b20706..7d0bce457a 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_DM=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 47193094dd..c50b18ab97 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_VF610=y CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_MMC" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index f1dc19a543..80a48369f2 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_VF610=y CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_NAND" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_HUSH_PARSER=y @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_GPIO=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 2e5ca15d4b..76679ee89e 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_SATA=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y diff --git a/configs/warp_defconfig b/configs/warp_defconfig index 36b3b16065..1186a1e2ae 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_DFU_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 06b31baeea..a8f905c219 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_DM_GPIO=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 398d32f701..f0503cce3c 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_MMC_MXS=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 3ac743bedb..80b8530a13 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xpress_defconfig b/configs/xpress_defconfig index 5b8c4eeb6d..549a736e94 100644 --- a/configs/xpress_defconfig +++ b/configs/xpress_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index 0286c99666..03ffe16045 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index b1f86d98ae..fae5855326 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PCI=y diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index ef86cc4f34..81c10c44a1 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index 7ca69a973c..39eb6b3015 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index 148f70360b..0445a986b7 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_MMC is not set diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 5c029109e2..074b420d59 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_NOWHERE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_MMC is not set diff --git a/env/Kconfig b/env/Kconfig index b622da71d1..a555546899 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -1,29 +1,20 @@ menu "Environment"
-if ARCH_SUNXI - -choice - prompt "Environment Device" - default ENV_IS_IN_MMC if ARCH_SUNXI - config ENV_IS_IN_MMC bool "Environment in an MMC device" - depends on CMD_MMC + default y if ARCH_SUNXI help Define this if you have an MMC device which you want to use for the environment.
config ENV_IS_IN_NAND bool "Environment in a NAND device" - depends on CMD_NAND help Define this if you have a NAND device which you want to use for the environment.
config ENV_IS_IN_UBI bool "Environment in a UBI volume" - depends on CMD_UBI - depends on CMD_MTDPARTS help Define this if you have a UBI volume which you want to use for the environment. @@ -34,7 +25,7 @@ config ENV_IS_NOWHERE Define this if you don't want to or can't have an environment stored on a storage medium
-endchoice +if ARCH_SUNXI
config ENV_OFFSET hex "Environment Offset" diff --git a/include/config_fsl_chain_trust.h b/include/config_fsl_chain_trust.h index 40d323e004..5a1a287992 100644 --- a/include/config_fsl_chain_trust.h +++ b/include/config_fsl_chain_trust.h @@ -14,13 +14,9 @@ #ifdef CONFIG_SECURE_BOOT
#undef CONFIG_ENV_IS_IN_EEPROM -#undef CONFIG_ENV_IS_IN_NAND -#undef CONFIG_ENV_IS_IN_MMC #undef CONFIG_ENV_IS_IN_SPI_FLASH #undef CONFIG_ENV_IS_IN_FLASH
-#define CONFIG_ENV_IS_NOWHERE - #endif
#ifdef CONFIG_CHAIN_OF_TRUST diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 2226aba674..61a1fa48ae 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -107,9 +107,6 @@ #define CONFIG_ENV_OVERWRITE
#ifndef CONFIG_MTD_NOR_FLASH -#if !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) && !defined(CONFIG_RAMBOOT_PBL) -#define CONFIG_ENV_IS_NOWHERE -#endif #else #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI @@ -128,13 +125,11 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 1097) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 59b2252e6f..5dd112c0c6 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -276,13 +276,11 @@ extern unsigned long get_sdram_size(void); #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_NAND) -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET ((768 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 407e499de1..2aec01ec54 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -485,7 +485,6 @@ combinations. this should be removed later * Environment */ #if defined(CONFIG_RAMBOOT_SDCARD) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 @@ -499,12 +498,10 @@ combinations. this should be removed later #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_NAND) || defined(CONFIG_NAND_SECBOOT) -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET ((768 * 1024) + CONFIG_SYS_NAND_BLOCK_SIZE) #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #else diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 398d0e0550..a8bc2abcab 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -414,7 +414,6 @@ #define CONFIG_ENV_SIZE 0x2000 #endif #elif defined(CONFIG_NAND) -#define CONFIG_ENV_IS_IN_NAND #ifdef CONFIG_TPL_BUILD #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index f4d970d0d8..985df810cb 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -286,7 +286,6 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #endif #if defined(CONFIG_SYS_NAND_BOOT) -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_OFFSET 0x80000 #define CONFIG_ENV_SIZE 0x20000 #define CONFIG_ENV_SECT_SIZE 0x20000 diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 38a4a6220b..b767401fc1 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -432,7 +432,6 @@ * Environment */ #if defined(CONFIG_NAND) - #define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_OFFSET (512 * 1024) #define CONFIG_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE @@ -449,7 +448,6 @@
/* Address and size of Redundant Environment Sector */ #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 522f12ceec..b281c216cb 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -427,7 +427,6 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index ea99aead45..d34eacbad3 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -301,7 +301,6 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 716fc3822e..28b9478d04 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -385,7 +385,6 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 2f91dd57bb..2835d42b93 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -444,7 +444,6 @@ #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 53e089a82a..4b9bc1fbd1 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -459,7 +459,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_ENV_SIZE 0x2000 #else #undef CONFIG_FLASH_CFI_DRIVER - #define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 459efb560c..781a93ab14 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -448,7 +448,6 @@ extern int board_pci_host_broken(void); #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 7afbc9096f..ada85c7964 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -461,7 +461,6 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) for env */ #define CONFIG_ENV_SIZE 0x4000 #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE-0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 470bb72fcb..1456648d6a 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -566,12 +566,10 @@ #define CONFIG_ENV_OFFSET 0xF0000 #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_RAMBOOT_SDCARD) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 0f96ac0242..decb57404a 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -296,7 +296,6 @@ #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 8d026addb3..47b97d1554 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -335,7 +335,6 @@ #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 1db3a633ef..46b9b7a67d 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -408,7 +408,6 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 /* 126k (one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index e87b11180a..4a4a76d2d4 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -568,7 +568,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #endif #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 0dc062a094..1bbdf2258b 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -678,7 +678,6 @@ extern unsigned long get_sdram_size(void); * Environment */ #if defined(CONFIG_SDCARD) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 @@ -692,7 +691,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_NAND) -#define CONFIG_ENV_IS_IN_NAND #ifdef CONFIG_TPL_BUILD #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (160 << 10)) @@ -707,7 +705,6 @@ extern unsigned long get_sdram_size(void); #endif #define CONFIG_ENV_OFFSET (1024 * 1024) #elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #else diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 2ee6c6442f..e9c755b47d 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -561,7 +561,6 @@ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 @@ -572,11 +571,9 @@ #else #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #endif -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (1024 * 1024) #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #else diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 967c83c53b..d3b655fda9 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -55,9 +55,6 @@ #define CONFIG_ENV_OVERWRITE
#ifndef CONFIG_MTD_NOR_FLASH -#if !defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_NOWHERE -#endif #else #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI @@ -76,14 +73,12 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC - #define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 1658) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 2e3a8c1184..ef8e7b678f 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -155,13 +155,11 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 025e7de8d0..4f2b208219 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -174,13 +174,11 @@ #endif #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #if defined(CONFIG_TARGET_T1024RDB) #define CONFIG_ENV_OFFSET (2 * CONFIG_SYS_NAND_BLOCK_SIZE) diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 86f7880ff1..6077bf470c 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -63,7 +63,6 @@ #define CONFIG_ENV_OVERWRITE
#ifndef CONFIG_MTD_NOR_FLASH -#define CONFIG_ENV_IS_NOWHERE #else #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI @@ -83,13 +82,11 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 1658) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #else diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 350dacaa38..fa50502922 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -186,7 +186,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) @@ -196,7 +195,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_BOOTSCRIPT_COPY_RAM #endif #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (3 * CONFIG_SYS_NAND_BLOCK_SIZE) #else diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 9edf19081c..5d049d1e8f 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -151,13 +151,11 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 0e70aa83ea..2cea8c8505 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -137,13 +137,11 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (2 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index f69746b4da..287c722e2f 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -78,9 +78,6 @@ #include "t4qds.h"
#ifndef CONFIG_MTD_NOR_FLASH -#if !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) && !defined(CONFIG_RAMBOOT_PBL) -#define CONFIG_ENV_IS_NOWHERE -#endif #else #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI @@ -99,13 +96,11 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index ed3b0f7202..d06c5b574e 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -319,9 +319,6 @@ "bootm 0x01000000 - 0x00f00000"
#ifndef CONFIG_MTD_NOR_FLASH -#ifndef CONFIG_RAMBOOT_PBL -#define CONFIG_ENV_IS_NOWHERE -#endif #else #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI @@ -340,13 +337,11 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 0x800) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_ENV_IS_NOWHERE) diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 9a7aa81196..2bf3a5686a 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -388,13 +388,11 @@ #endif
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index b97f525994..764af3d8c7 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -294,8 +294,6 @@
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* Remove other SPL modes. */ -#define CONFIG_ENV_IS_NOWHERE -#undef CONFIG_ENV_IS_IN_NAND /* disable host part of MUSB in SPL */ /* disable EFI partitions and partition UUID support */ #endif @@ -335,7 +333,6 @@ "128k(u-boot-env2),3464k(kernel)," \ "-(rootfs)" #elif defined(CONFIG_EMMC_BOOT) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET 0x0 diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index b1ffcc8872..41cd6e5116 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -144,7 +144,6 @@ #define CONFIG_SPL_UBI_INFO_ADDR 0x88080000
/* environment organization */ -#define CONFIG_ENV_IS_IN_UBI 1 #define CONFIG_ENV_UBI_PART "UBI" #define CONFIG_ENV_UBI_VOLUME "config" #define CONFIG_ENV_UBI_VOLUME_REDUND "config_r" diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index 247679eee3..95d5d1fb2d 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -35,8 +35,6 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#define CONFIG_ENV_IS_IN_MMC 1 - /* * in case of SD Card or Network boot we want to have a possibility to * debrick the shc, therefore do not read environment from eMMC @@ -290,11 +288,4 @@ #define CONFIG_SYS_I2C_SLAVE 1
#define CONFIG_SHOW_BOOT_PROGRESS - -#if defined CONFIG_SHC_NETBOOT -#ifdef CONFIG_SPL_BUILD -#define CONFIG_ENV_IS_NOWHERE -#undef CONFIG_ENV_IS_IN_MMC -#endif -#endif #endif /* ! __CONFIG_AM335X_SHC_H */ diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index 2c4033ca59..5e7bb2331e 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -87,16 +87,12 @@
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* Remove other SPL modes. */ -#define CONFIG_ENV_IS_NOWHERE -#undef CONFIG_ENV_IS_IN_NAND /* disable host part of MUSB in SPL */ #undef CONFIG_MUSB_HOST /* disable EFI partitions and partition UUID support */ #endif
#if defined(CONFIG_EMMC_BOOT) -#undef CONFIG_ENV_IS_NOWHERE -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET 0x0 diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index eb768b9e97..77d9ba1899 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -218,7 +218,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_NAND_OMAP_GPMC -#define CONFIG_ENV_IS_IN_NAND 1 #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB sector */ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 829dd3ecb9..78c7a2b775 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -296,7 +296,6 @@ #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET -#define CONFIG_ENV_IS_IN_NAND
/* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 1d8e39c203..88487c9fb9 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -257,11 +257,6 @@ #define CONFIG_PHYLIB #define PHY_ANEG_TIMEOUT 8000 /* PHY needs longer aneg time at 1G */
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_ETH_SUPPORT) -#undef CONFIG_ENV_IS_IN_FAT -#define CONFIG_ENV_IS_NOWHERE -#endif - #define CONFIG_SYS_RX_ETH_BUFFER 64
/* NAND support */ diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 98ce6c52da..9216998486 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -22,7 +22,6 @@ #define CONFIG_NR_DRAM_BANKS 2
/* MMC ENV related defines */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* eMMC */ #define CONFIG_SYS_MMC_ENV_PART 0 #define CONFIG_ENV_SIZE SZ_128K diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index c3cade9ea6..d6b226c425 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -29,7 +29,6 @@ #define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
/* Environment in eMMC, before config block at the end of 1st "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ CONFIG_TDX_CFG_BLOCK_OFFSET) #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index a18ab12804..4a12ac8ca3 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -300,8 +300,6 @@
#define CONFIG_ENV_SIZE (8 * 1024)
-#define CONFIG_ENV_IS_IN_MMC - #if defined(CONFIG_ENV_IS_IN_MMC) /* Environment in eMMC, before config block at the end of 1st "boot sector" */ #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index 9772d8b5c3..daa3be0999 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -26,7 +26,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, before config block at the end of 1st "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ CONFIG_TDX_CFG_BLOCK_OFFSET) #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 073f3b4fef..3f22ce3501 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -85,7 +85,6 @@ */ #define ACFG_MONITOR_OFFSET 0x00000000 #define CONFIG_SYS_MONITOR_LEN 0x00100000 /* 1MiB */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OVERWRITE #define CONFIG_ENV_OFFSET 0x00100000 /* NAND offset */ #define CONFIG_ENV_SIZE 0x00020000 /* 128kB */ diff --git a/include/configs/apx4devkit.h b/include/configs/apx4devkit.h index cce39f27c7..b54c05353e 100644 --- a/include/configs/apx4devkit.h +++ b/include/configs/apx4devkit.h @@ -30,7 +30,6 @@
/* Environment */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_IS_IN_NAND
/* Environment is in MMC */ #if defined(CONFIG_CMD_MMC) && defined(CONFIG_ENV_IS_IN_MMC) diff --git a/include/configs/arndale.h b/include/configs/arndale.h index 4d770e6077..8f0422943b 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -27,7 +27,6 @@ /* Miscellaneous configurable options */ #define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0"
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (CONFIG_BL2_OFFSET + CONFIG_BL2_SIZE)
#define CONFIG_IRAM_STACK 0x02050000 diff --git a/include/configs/aspenite.h b/include/configs/aspenite.h index e6cddc13ac..36d74f3b26 100644 --- a/include/configs/aspenite.h +++ b/include/configs/aspenite.h @@ -38,7 +38,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ #define CONFIG_ENV_SIZE 0x20000 /* 64k */
#endif /* __CONFIG_ASPENITE_H */ diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index dea8130046..e511d18234 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -79,7 +79,6 @@
#ifdef CONFIG_SYS_USE_NANDFLASH /* u-boot env in nand flash */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0xc0000 #define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 48d7f6a5e6..8b0105c017 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -174,7 +174,6 @@ #elif defined(CONFIG_SYS_USE_NANDFLASH)
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_OFFSET 0x120000 #define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ @@ -188,7 +187,6 @@
#else /* CONFIG_SYS_USE_MMC */ /* bootstrap + u-boot + env + linux in mmc */ -#define CONFIG_ENV_IS_IN_MMC /* For FAT system, most cases it should be in the reserved sector */ #define CONFIG_ENV_OFFSET 0x2000 #define CONFIG_ENV_SIZE 0x1000 diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 505f945bd3..d86f07b982 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -167,7 +167,6 @@ #else /* CONFIG_SYS_USE_NANDFLASH */
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0xc0000 #define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index e45e4dbddc..a8337cdf43 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -264,7 +264,6 @@ #elif CONFIG_SYS_USE_NANDFLASH
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_OFFSET 0x120000 #define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index a0c5b9afae..9e7fd1e1ae 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -90,7 +90,6 @@
#ifdef CONFIG_SYS_USE_NANDFLASH /* bootstrap + u-boot + env in nandflash */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x120000 #define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 50ddbd6475..7bccee905e 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -138,7 +138,6 @@ #elif defined(CONFIG_SYS_USE_NANDFLASH)
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x120000 #define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 8a8eb7c34f..05ba542382 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -109,7 +109,6 @@ #elif CONFIG_SYS_USE_NANDFLASH
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_OFFSET 0x120000 #define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index fd2dbed137..a01072f059 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -117,7 +117,6 @@
#ifdef CONFIG_SYS_USE_NANDFLASH /* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x120000 #define CONFIG_ENV_OFFSET_REDUND 0x100000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index fe4ac05f38..8ef7e348aa 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -325,7 +325,6 @@ "128k(SPL.backup3)," \ "1920k(u-boot)," \ "-(UBI)" -#define CONFIG_ENV_IS_NOWHERE #endif #endif
diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 71b1b96ec4..a37433e03f 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -18,7 +18,6 @@ #define __CONFIG_BAV335X_H
#include <configs/ti_am335x_common.h> -#define CONFIG_ENV_IS_NOWHERE
#ifndef CONFIG_SPL_BUILD # define CONFIG_TIMESTAMP @@ -389,8 +388,6 @@ DEFAULT_LINUX_BOOT_ENV \ "8m(NAND.kernel)," \ "-(NAND.rootfs)" #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 -#undef CONFIG_ENV_IS_NOWHERE -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x001c0000 #define CONFIG_ENV_OFFSET_REDUND 0x001e0000 #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE @@ -515,8 +512,6 @@ DEFAULT_LINUX_BOOT_ENV \ "128k(u-boot-env2),3464k(kernel)," \ "-(rootfs)" #elif defined(CONFIG_EMMC_BOOT) -#undef CONFIG_ENV_IS_NOWHERE -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET 0x0 diff --git a/include/configs/bcm23550_w1d.h b/include/configs/bcm23550_w1d.h index 02ae65ff57..049b4e0a43 100644 --- a/include/configs/bcm23550_w1d.h +++ b/include/configs/bcm23550_w1d.h @@ -81,7 +81,6 @@ #define CONFIG_SYS_NS16550_COM1 0x3e000000
/* must fit into GPT:u-boot-env partition */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_OFFSET (0x00011a00 * 512) #define CONFIG_ENV_SIZE (8 * 512) diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index 5a85f7fa9c..08d1e4e69f 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -80,7 +80,6 @@ #define CONFIG_SYS_NS16550_COM1 0x3e000000
/* must fit into GPT:u-boot-env partition */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_OFFSET (0x00011a00 * 512) #define CONFIG_ENV_SIZE (8 * 512) diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index 2afbbea140..8bd1e301a9 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -46,7 +46,6 @@ #define CONFIG_SYS_NS16550_SERIAL
#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_IS_NOWHERE
/* console configuration */ #define CONFIG_SYS_CBSIZE 1024 /* Console buffer size */ diff --git a/include/configs/bcm_northstar2.h b/include/configs/bcm_northstar2.h index dc2860382d..2352b98f62 100644 --- a/include/configs/bcm_northstar2.h +++ b/include/configs/bcm_northstar2.h @@ -38,7 +38,6 @@ #define CONFIG_BAUDRATE 115200
#define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_IS_NOWHERE
/* console configuration */ #define CONFIG_SYS_CBSIZE SZ_1K diff --git a/include/configs/beaver.h b/include/configs/beaver.h index f3d7a2fad2..6afa1e8c04 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index 40f1538789..c76053e49a 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -23,7 +23,6 @@ /* Environment */ #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_IS_NOWHERE
/* FEC Ethernet on SoC */ #ifdef CONFIG_CMD_NET diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 07e743ac81..aa07e9b2da 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -242,7 +242,6 @@ MMCARGS
#define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 -#undef CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED @@ -251,8 +250,6 @@ MMCARGS #define CONFIG_ENV_OFFSET_REDUND (896 << 10) /* 896 KiB in */
#elif defined(CONFIG_EMMC_BOOT) -#undef CONFIG_ENV_IS_NOWHERE -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET 0x40000 /* TODO: Adresse definieren */ @@ -261,11 +258,6 @@ MMCARGS
#elif defined(CONFIG_NAND) /* No NAND env support in SPL */ -#ifdef CONFIG_SPL_BUILD -#define CONFIG_ENV_IS_NOWHERE -#else -#define CONFIG_ENV_IS_IN_NAND -#endif #define CONFIG_ENV_OFFSET 0x60000 #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_ENV_SIZE #else diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index f7d736939b..8f92d7a958 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -88,8 +88,6 @@ BUR_COMMON_ENV \ #define CONFIG_AM335X_USB1 #define CONFIG_AM335X_USB1_MODE MUSB_HOST
-#undef CONFIG_ENV_IS_NOWHERE -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET 0x40000 /* TODO: Adresse definieren */ diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index f1b5a71edf..a490d06619 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -31,7 +31,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/cei-tk1-som.h b/include/configs/cei-tk1-som.h index fd8df46776..768669ff12 100644 --- a/include/configs/cei-tk1-som.h +++ b/include/configs/cei-tk1-som.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 20168b22b6..6ffe8044d4 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -199,7 +199,6 @@ #define CONFIG_ENV_SIZE SZ_128K #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #else -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_OFFSET SZ_128K #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 77c2493e66..bd80222149 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -54,7 +54,6 @@ #define CONFIG_ENV_MIN_ENTRIES 128
/* Environment in MMC */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SECT_SIZE 0x200 #define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 3fb9daebbc..a1b8e141a9 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -136,7 +136,6 @@ "1m(u-boot),1m(u-boot-env)," \ "1m(dtb),4m(splash)," \ "6m(kernel),-(rootfs)" -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x300000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #define CONFIG_SYS_NAND_ONFI_DETECTION diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index ee7c9de969..2c524b295b 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -218,7 +218,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
-#define CONFIG_ENV_IS_IN_NAND #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index dd78b0c7e8..f3b7f3d512 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -218,7 +218,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 2 sectors */
-#define CONFIG_ENV_IS_IN_NAND #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET diff --git a/include/configs/cm_t54.h b/include/configs/cm_t54.h index 36475734fc..69706d254e 100644 --- a/include/configs/cm_t54.h +++ b/include/configs/cm_t54.h @@ -33,7 +33,6 @@ #undef CONFIG_ENV_OFFSET #undef CONFIG_ENV_SIZE
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_SYS_MMC_ENV_PART 0 #define CONFIG_ENV_OFFSET 0xc0000 /* (in bytes) 768 KB */ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index f3335f5c12..5f7386737a 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -271,8 +271,6 @@ /* environment organization */ #define CONFIG_ENV_SIZE (8 * 1024)
-#define CONFIG_ENV_IS_IN_MMC - #if defined(CONFIG_ENV_IS_IN_MMC) /* Environment in eMMC, before config block at the end of 1st "boot sector" */ #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 3388a95ed3..5637a98050 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -148,7 +148,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* environment organization */ -#define CONFIG_ENV_IS_IN_NAND
#if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1 */ diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index 587963963a..9efe74b593 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -140,9 +140,6 @@ #define CONFIG_SYS_FLASH_PROTECTION 1
#define CONFIG_ENV_IS_IN_FLASH 1 - -#else /* No flash */ -#define CONFIG_ENV_IS_NOWHERE #endif
#define CONFIG_SYS_MONITOR_BASE 0x0 diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index 7355f78fcf..1171359424 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -57,7 +57,6 @@ "-(ubi)"
/* Environment in NAND, 64K is a bit excessive but erase block is 512K anyway */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (SZ_2M) #undef CONFIG_ENV_SIZE /* undef size from tegra20-common.h */ #define CONFIG_ENV_SIZE (SZ_64K) diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index 53ff33e4b9..91433afacc 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -26,7 +26,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, before config block at the end of 1st "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE + \ CONFIG_TDX_CFG_BLOCK_OFFSET) #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/comtrend_ar5387un.h b/include/configs/comtrend_ar5387un.h index 5d8f968c4d..99630c0822 100644 --- a/include/configs/comtrend_ar5387un.h +++ b/include/configs/comtrend_ar5387un.h @@ -9,7 +9,6 @@
#define CONFIG_REMAKE_ELF
-#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE (8 * 1024)
#define CONFIG_AUTO_COMPLETE diff --git a/include/configs/comtrend_ct5361.h b/include/configs/comtrend_ct5361.h index 099684ddd2..94ec498af1 100644 --- a/include/configs/comtrend_ct5361.h +++ b/include/configs/comtrend_ct5361.h @@ -9,7 +9,6 @@
#define CONFIG_AUTO_COMPLETE diff --git a/include/configs/comtrend_vr3032u.h b/include/configs/comtrend_vr3032u.h index d45f8b32da..6d46041af6 100644 --- a/include/configs/comtrend_vr3032u.h +++ b/include/configs/comtrend_vr3032u.h @@ -9,7 +9,6 @@
#define CONFIG_AUTO_COMPLETE diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 072650dfae..f9245e06ba 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -298,7 +298,6 @@ * Environment */ #if defined(CONFIG_TRAILBLAZER) -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #elif defined(CONFIG_RAMBOOT_SPIFLASH) #define CONFIG_ENV_IS_IN_SPI_FLASH @@ -310,7 +309,6 @@ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_RAMBOOT_SDCARD) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 92e6ee0033..abd09ca1ed 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -66,9 +66,6 @@ #define CONFIG_ENV_OVERWRITE
#ifndef CONFIG_MTD_NOR_FLASH -#if !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) && !defined(CONFIG_RAMBOOT_PBL) -#define CONFIG_ENV_IS_NOWHERE -#endif #else #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI @@ -87,14 +84,12 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (512 * 1658) #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 8b8b1220b4..f814e3e2dd 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -109,7 +109,6 @@ #define CONFIG_SYS_LOAD_ADDR ATMEL_BASE_CS6
/* bootstrap + u-boot + env in nandflash */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_ENV_OFFSET_REDUND 0x180000 #define CONFIG_ENV_SIZE SZ_128K diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 6079540bc9..ddbaf327d8 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -58,7 +58,6 @@
#if defined(CONFIG_SDCARD) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index b7199bb9e0..b69303fdba 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -164,7 +164,6 @@ #ifdef CONFIG_USE_NAND #undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_NAND_DAVINCI -#define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 10) #define CONFIG_SYS_NAND_USE_FLASH_BBT @@ -235,7 +234,6 @@
#ifdef CONFIG_USE_SPIFLASH #undef CONFIG_ENV_IS_IN_FLASH -#undef CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_OFFSET (512 << 10) @@ -298,7 +296,6 @@ #if !defined(CONFIG_USE_NAND) && \ !defined(CONFIG_USE_NOR) && \ !defined(CONFIG_USE_SPIFLASH) -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE (16 << 10) #endif
diff --git a/include/configs/dalmore.h b/include/configs/dalmore.h index 96a2df806a..41ab61aa7c 100644 --- a/include/configs/dalmore.h +++ b/include/configs/dalmore.h @@ -24,7 +24,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index 9db3380a95..970e214e07 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -138,8 +138,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT (2 * CONFIG_SYS_HZ) /* Timeout for Flash Erase */ #define CONFIG_SYS_FLASH_WRITE_TOUT (2 * CONFIG_SYS_HZ) /* Timeout for Flash Write */
-#define CONFIG_ENV_IS_NOWHERE 1 - /* Address and size of Primary Environment Sector */ #define CONFIG_ENV_ADDR 0xB0030000 #define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index a8b6802235..dfe9935520 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -138,7 +138,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SIZE SZ_128K #define CONFIG_ENV_OFFSET 0x000A0000
diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 92ce1273c6..5476961847 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -182,7 +182,6 @@ 0x01000000) /* 16MB */
/* NAND and environment organization */ -#define CONFIG_ENV_IS_IN_NAND 1 #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
#define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET diff --git a/include/configs/dns325.h b/include/configs/dns325.h index 470e26256a..3e931edc71 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -73,10 +73,7 @@ * Environment variables configurations */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128KB */ -#else -#define CONFIG_ENV_IS_NOWHERE #endif
#define CONFIG_ENV_SIZE 0x20000 /* 128KB */ diff --git a/include/configs/dockstar.h b/include/configs/dockstar.h index 3b56fd6739..d7ff3f485f 100644 --- a/include/configs/dockstar.h +++ b/include/configs/dockstar.h @@ -34,10 +34,7 @@ * Environment variables configurations */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#else -#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ #endif /* * max 4k env size is enough, but in case of nand diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index d2f7c7cfff..40beb17574 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -24,7 +24,6 @@
#ifndef CONFIG_QSPI_BOOT /* MMC ENV related defines */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_ENV_SIZE (128 << 10) #define CONFIG_ENV_OFFSET 0x260000 diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index 11c842d952..09e39b3031 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -111,7 +111,6 @@ REFLASH(dragonboard/u-boot.img, 8)\ "pxefile_addr_r=0x90100000\0"\ BOOTENV
-#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_VARS_UBOOT_CONFIG
diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index 003cf0e1f3..9715f297a9 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -34,8 +34,6 @@ #ifdef CONFIG_SPI_FLASH #define CONFIG_ENV_IS_IN_SPI_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64k */ -#else -#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ #endif
#ifdef CONFIG_CMD_SF diff --git a/include/configs/ds109.h b/include/configs/ds109.h index 133b2b023c..ad7fce84e8 100644 --- a/include/configs/ds109.h +++ b/include/configs/ds109.h @@ -37,8 +37,6 @@ #ifdef CONFIG_SPI_FLASH #define CONFIG_ENV_IS_IN_SPI_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64k */ -#else -#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ #endif
#ifdef CONFIG_CMD_SF diff --git a/include/configs/duovero.h b/include/configs/duovero.h index f142231689..8efcc94945 100644 --- a/include/configs/duovero.h +++ b/include/configs/duovero.h @@ -39,7 +39,6 @@ /* GPIO */
/* ENV related config options */ -#define CONFIG_ENV_IS_NOWHERE
#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
diff --git a/include/configs/e2220-1170.h b/include/configs/e2220-1170.h index f88045436f..f8a5993326 100644 --- a/include/configs/e2220-1170.h +++ b/include/configs/e2220-1170.h @@ -22,7 +22,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 6fc6ec90af..e00f9648fe 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -88,7 +88,6 @@
#ifdef CONFIG_USE_SPIFLASH #undef CONFIG_ENV_IS_IN_FLASH -#undef CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (8 << 10) #define CONFIG_ENV_OFFSET 0x80000 @@ -165,7 +164,6 @@ #if !defined(CONFIG_SYS_USE_NAND) && \ !defined(CONFIG_USE_NOR) && \ !defined(CONFIG_USE_SPIFLASH) -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE (16 << 10) #endif
diff --git a/include/configs/efi-x86.h b/include/configs/efi-x86.h index 9dcb481707..7763365fe1 100644 --- a/include/configs/efi-x86.h +++ b/include/configs/efi-x86.h @@ -14,7 +14,6 @@ #undef CONFIG_TPM_TIS_BASE_ADDRESS
#undef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_IS_NOWHERE #undef CONFIG_SCSI_AHCI #undef CONFIG_INTEL_ICH6_GPIO #undef CONFIG_USB_EHCI_PCI diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h index 575610d410..531f5bf5aa 100644 --- a/include/configs/el6x_common.h +++ b/include/configs/el6x_common.h @@ -114,8 +114,6 @@
-#define CONFIG_ENV_IS_IN_MMC - #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/espresso7420.h b/include/configs/espresso7420.h index 0a50154dda..0115d398a7 100644 --- a/include/configs/espresso7420.h +++ b/include/configs/espresso7420.h @@ -14,7 +14,6 @@ #define CONFIG_BOARD_COMMON
#define CONFIG_ESPRESSO7420 -#define CONFIG_ENV_IS_NOWHERE
#define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_TEXT_BASE 0x43E00000 diff --git a/include/configs/evb_ast2500.h b/include/configs/evb_ast2500.h index a571f2a749..552cd366bc 100644 --- a/include/configs/evb_ast2500.h +++ b/include/configs/evb_ast2500.h @@ -20,8 +20,6 @@ /* Memory Info */ #define CONFIG_SYS_LOAD_ADDR 0x83000000
-#define CONFIG_ENV_IS_NOWHERE - #define CONFIG_ENV_SIZE 0x20000
#endif /* __CONFIG_H */ diff --git a/include/configs/evb_px5.h b/include/configs/evb_px5.h index 228683739b..d008539eb1 100644 --- a/include/configs/evb_px5.h +++ b/include/configs/evb_px5.h @@ -9,7 +9,6 @@
#include <configs/rk3368_common.h>
#define CONFIG_CONSOLE_SCROLL_LINES 10 diff --git a/include/configs/evb_rk3229.h b/include/configs/evb_rk3229.h index 8f8e50fb60..6e1fd1c293 100644 --- a/include/configs/evb_rk3229.h +++ b/include/configs/evb_rk3229.h @@ -13,7 +13,6 @@ /* Store env in emmc */ #undef CONFIG_ENV_SIZE #define CONFIG_ENV_SIZE (32 << 10) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 0 #define CONFIG_SYS_REDUNDAND_ENVIRONMENT diff --git a/include/configs/evb_rk3288.h b/include/configs/evb_rk3288.h index 0dc3532f33..15a374cca7 100644 --- a/include/configs/evb_rk3288.h +++ b/include/configs/evb_rk3288.h @@ -10,7 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
#endif diff --git a/include/configs/evb_rk3328.h b/include/configs/evb_rk3328.h index fe3ec8c177..c792ce55c1 100644 --- a/include/configs/evb_rk3328.h +++ b/include/configs/evb_rk3328.h @@ -9,7 +9,6 @@
#include <configs/rk3328_common.h>
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* * SPL @ 32k for ~36k diff --git a/include/configs/evb_rk3399.h b/include/configs/evb_rk3399.h index b9fd5b417a..015f25a774 100644 --- a/include/configs/evb_rk3399.h +++ b/include/configs/evb_rk3399.h @@ -9,7 +9,6 @@
#include <configs/rk3399_common.h>
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* * SPL @ 32k for ~36k diff --git a/include/configs/fennec_rk3288.h b/include/configs/fennec_rk3288.h index 0dc3532f33..15a374cca7 100644 --- a/include/configs/fennec_rk3288.h +++ b/include/configs/fennec_rk3288.h @@ -10,7 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
#endif diff --git a/include/configs/firefly-rk3288.h b/include/configs/firefly-rk3288.h index b4dcf23b1c..bd39111710 100644 --- a/include/configs/firefly-rk3288.h +++ b/include/configs/firefly-rk3288.h @@ -14,7 +14,6 @@
#endif diff --git a/include/configs/geekbox.h b/include/configs/geekbox.h index 6f6007e65b..7a707cb2a0 100644 --- a/include/configs/geekbox.h +++ b/include/configs/geekbox.h @@ -9,7 +9,6 @@
#define CONFIG_CONSOLE_SCROLL_LINES 10 diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index d1635b098e..7fdadab101 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -56,10 +56,7 @@ * Environment variables configurations */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#else -#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ #endif /* * max 4k env size is enough, but in case of nand diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index f2260eae56..dddd300fb5 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -78,7 +78,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x4000
#ifdef CONFIG_CMD_USB diff --git a/include/configs/guruplug.h b/include/configs/guruplug.h index 5ac29db240..c69e8994bd 100644 --- a/include/configs/guruplug.h +++ b/include/configs/guruplug.h @@ -31,10 +31,7 @@ * Environment variables configurations */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#else -#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ #endif /* * max 4k env size is enough, but in case of nand diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index de08f2c7cc..7036ed0ef8 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -220,10 +220,6 @@ /* Persistent Environment Config */ #ifdef CONFIG_SPI_FLASH #define CONFIG_ENV_IS_IN_SPI_FLASH -#elif defined(CONFIG_SPL_NAND_SUPPORT) - #define CONFIG_ENV_IS_IN_NAND -#else - #define CONFIG_ENV_IS_IN_MMC #endif #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/h2200.h b/include/configs/h2200.h index 530a88e9e1..fea4044769 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -26,7 +26,6 @@ #define CONFIG_ENV_SIZE 0x00040000 #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024)
-#define CONFIG_ENV_IS_NOWHERE #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_LOAD_ADDR 0xa3000000 /* default load address */
diff --git a/include/configs/harmony.h b/include/configs/harmony.h index c17d7fad79..cc312199ac 100644 --- a/include/configs/harmony.h +++ b/include/configs/harmony.h @@ -32,7 +32,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* Environment in NAND (which is 512M), aligned to start of last sector */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (SZ_512M - SZ_128K) /* 128K sector size */
/* USB Host support */ diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index 405129b7e2..df8e69fe66 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -501,7 +501,6 @@ void fpga_control_clear(unsigned int bus, int pin); #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #else -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #endif
diff --git a/include/configs/huawei_hg556a.h b/include/configs/huawei_hg556a.h index ab64518e0b..6bd2d76f53 100644 --- a/include/configs/huawei_hg556a.h +++ b/include/configs/huawei_hg556a.h @@ -9,7 +9,6 @@
#define CONFIG_AUTO_COMPLETE diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index a5782f3300..d45dc357cb 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -39,10 +39,7 @@ * Environment variables configuration */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SECT_SIZE 0x20000 -#else -#define CONFIG_ENV_IS_NOWHERE #endif #define CONFIG_ENV_SIZE 0x20000 #define CONFIG_ENV_OFFSET 0xe0000 diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index 63e50606d7..f87882e2be 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -43,10 +43,7 @@ * Environment variables configuration */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SECT_SIZE 0x20000 -#else -#define CONFIG_ENV_IS_NOWHERE #endif #define CONFIG_ENV_SIZE 0x20000 #define CONFIG_ENV_OFFSET 0x80000 diff --git a/include/configs/imgtec_xilfpga.h b/include/configs/imgtec_xilfpga.h index 6310423335..934b76ecaf 100644 --- a/include/configs/imgtec_xilfpga.h +++ b/include/configs/imgtec_xilfpga.h @@ -51,7 +51,6 @@ /* ------------------------------------------------- * Environment */ -#define CONFIG_ENV_IS_NOWHERE 1 #define CONFIG_ENV_SIZE 0x4000
/* --------------------------------------------------------------------- diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index 821f1ffacd..c2d64e34ea 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -141,7 +141,6 @@
/* Environment organization */ #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x400000 #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE
diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index 1d1b8b31c2..ae8399426f 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -37,7 +37,6 @@ /* Flash settings */ #define CONFIG_SYS_FLASH_SIZE 0x02000000 /* 32 MiB */ #define CONFIG_SYS_MAX_FLASH_SECT 128 -#define CONFIG_ENV_IS_NOWHERE 1 #define CONFIG_ENV_SIZE 32768
/*----------------------------------------------------------------------- diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index f78aa47ae2..dfbdcb1c1b 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -139,7 +139,6 @@ * Flash & Environment */ #define CONFIG_NAND_DAVINCI -#define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 10) #define CONFIG_SYS_NAND_USE_FLASH_BBT diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index 89f6cbc85b..acc97268ba 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index b186bfc891..7e455498dc 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -28,7 +28,6 @@ "name_fs=arago-console-image-k2e-evm.cpio.gz\0"
#define CONFIG_ENV_SIZE (256 << 10) /* 256 KiB */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x100000
#include <configs/ti_armv7_keystone2.h> diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index 9598bc6976..78b901fb58 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -28,7 +28,6 @@ "name_fs=arago-console-image-k2hk-evm.cpio.gz\0"
#include <configs/ti_armv7_keystone2.h> diff --git a/include/configs/k2l_evm.h b/include/configs/k2l_evm.h index d054276e61..d8bcbde843 100644 --- a/include/configs/k2l_evm.h +++ b/include/configs/k2l_evm.h @@ -28,7 +28,6 @@ "name_fs=arago-console-image-k2l-evm.cpio.gz\0"
#include <configs/ti_armv7_keystone2.h> diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 408e5634b6..f040d0bbb6 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -143,7 +143,6 @@ */
#define CONFIG_ENV_SIZE (128 * 1024) -#define CONFIG_ENV_IS_NOWHERE
diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 7d69224bd1..0db33b701c 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -191,7 +191,6 @@ #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#else /* CFG_SYS_RAMBOOT */ -#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif /* CFG_SYS_RAMBOOT */ diff --git a/include/configs/kylin_rk3036.h b/include/configs/kylin_rk3036.h index 088aced8b6..36009b8599 100644 --- a/include/configs/kylin_rk3036.h +++ b/include/configs/kylin_rk3036.h @@ -15,8 +15,6 @@ /* Store env in emmc */ #undef CONFIG_ENV_SIZE #define CONFIG_ENV_SIZE SZ_32K -#undef CONFIG_ENV_IS_NOWHERE -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 /* emmc */ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */
diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 15da4074f2..4ea61af920 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -206,7 +206,6 @@ #define CONFIG_CLOCKS #endif
/* additions for new relocation code, must added to all boards */ diff --git a/include/configs/liteboard.h b/include/configs/liteboard.h index 016d54f138..76ee91042d 100644 --- a/include/configs/liteboard.h +++ b/include/configs/liteboard.h @@ -129,7 +129,6 @@
/* FLASH and environment organization */ #define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 0 diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index c1ec2d440c..e5544f327d 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -287,7 +287,6 @@
#if defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET 0x100000 -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 152954165c..b3c931e36c 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -550,7 +550,6 @@ unsigned long get_board_ddr_clk(void);
#if defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET 0x300000 -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) @@ -559,7 +558,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_NAND_BOOT) -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #else diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 067ef4df93..06d7d400ca 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -418,7 +418,6 @@
#if defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET 0x300000 -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x20000 #elif defined(CONFIG_QSPI_BOOT) diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 87ca36a8e9..83c8805df6 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -410,12 +410,10 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_OVERWRITE
#ifdef CONFIG_NAND_BOOT -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (24 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET (3 * 1024 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index deae787358..7b8561e9d6 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -233,12 +233,10 @@ #endif
#if defined(CONFIG_NAND_BOOT) -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (24 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET (3 * 1024 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #else diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 77619ab324..860ad8f693 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -444,12 +444,10 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_OVERWRITE
#ifdef CONFIG_NAND_BOOT -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (24 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET (3 * 1024 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 8a6b4e6378..1c30462af2 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -167,7 +167,6 @@ #endif
#if defined(CONFIG_SD_BOOT) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/ls2080a_emu.h b/include/configs/ls2080a_emu.h index cec12ad04c..6b34edfbf1 100644 --- a/include/configs/ls2080a_emu.h +++ b/include/configs/ls2080a_emu.h @@ -82,7 +82,6 @@ #define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 200000
/* Store environment at top of flash */ -#define CONFIG_ENV_IS_NOWHERE 1 #define CONFIG_ENV_SIZE 0x1000
#endif /* __LS2_EMU_H */ diff --git a/include/configs/ls2080a_simu.h b/include/configs/ls2080a_simu.h index de9db4abb4..02589be5fd 100644 --- a/include/configs/ls2080a_simu.h +++ b/include/configs/ls2080a_simu.h @@ -152,7 +152,6 @@ #define CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS 200000
#endif /* __LS2_SIMU_H */ diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 5e1867d81e..b5fa41e33d 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -229,7 +229,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
-#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (896 * 1024) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 @@ -238,7 +237,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NAND_U_BOOT_SIZE (640 * 1024) #elif defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET 0x200000 -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x20000 #endif diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index e8aacd3dcd..a353cf4f68 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -223,7 +223,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3
-#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (2048 * 1024) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 43e4a325b4..b21a285d19 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -62,8 +62,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 8 #define CONFIG_ENV_IS_IN_SPI_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K */ -#else -#define CONFIG_ENV_IS_NOWHERE #endif
#define CONFIG_ENV_SIZE 0x10000 /* 64k */ diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 8dea0313a3..cc0fc9d01d 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -25,7 +25,6 @@
/* Environment */ #define CONFIG_ENV_SIZE (16 * 1024) -#define CONFIG_ENV_IS_IN_NAND
/* Environment is in NAND */ #if defined(CONFIG_CMD_NAND) && defined(CONFIG_ENV_IS_IN_NAND) @@ -51,8 +50,6 @@ "14m(boot)," \ "238m(data)," \ "-@4096k(UBI)" -#else -#define CONFIG_ENV_IS_NOWHERE #endif
/* FEC Ethernet on SoC */ diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index a92c228334..9b8d22c797 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -92,7 +92,6 @@ #define CONFIG_SYS_NAND_USE_FLASH_BBT
/* Environment is in NAND */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_RANGE (4 * CONFIG_ENV_SECT_SIZE) @@ -115,8 +114,6 @@ "14m(boot)," \ "240m(data)," \ "-@2048k(UBI)" -#else -#define CONFIG_ENV_IS_NOWHERE #endif
/* diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 82aee15132..2744efb922 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -32,7 +32,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_SYS_CONSOLE_ENV_OVERWRITE #define CONFIG_ENV_SIZE 0x4000 diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 0c237a59cb..f82982a487 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -260,7 +260,6 @@ #define CONFIG_SYS_NAND_BUSWIDTH_16BIT #define CONFIG_NAND_OMAP_GPMC #define CONFIG_NAND_OMAP_GPMC_PREFETCH -#define CONFIG_ENV_IS_IN_NAND #define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */
/* Redundant Environment */ diff --git a/include/configs/medcom-wide.h b/include/configs/medcom-wide.h index d2165828d3..e007370f90 100644 --- a/include/configs/medcom-wide.h +++ b/include/configs/medcom-wide.h @@ -25,7 +25,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* Environment in NAND, aligned to start of last sector */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (SZ_512M - SZ_128K) /* 128K sectors */
/* USB host support */ diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 3a8e82edbf..3b7643fb63 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -145,7 +145,6 @@ #elif CONFIG_SYS_USE_NANDFLASH
/* bootstrap + u-boot + env + linux in nandflash */ -# define CONFIG_ENV_IS_IN_NAND 1 # define CONFIG_ENV_OFFSET 0xC0000 # define CONFIG_ENV_SIZE 0x20000
diff --git a/include/configs/meson-gxbb-common.h b/include/configs/meson-gxbb-common.h index 89e3807a14..bfc0767f1c 100644 --- a/include/configs/meson-gxbb-common.h +++ b/include/configs/meson-gxbb-common.h @@ -11,7 +11,6 @@ #define CONFIG_CPU_ARMV8 #define CONFIG_REMAKE_ELF #define CONFIG_NR_DRAM_BANKS 1 -#define CONFIG_ENV_IS_NOWHERE 1 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MAXARGS 32 #define CONFIG_SYS_MALLOC_LEN (32 << 20) diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index cc7f81955e..c3d9b99771 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -95,7 +95,6 @@ /* use buffered writes (20x faster) */ # define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 # ifdef RAMENV -# define CONFIG_ENV_IS_NOWHERE 1 # define CONFIG_ENV_SIZE 0x1000 # define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE)
@@ -117,7 +116,6 @@ # define CONFIG_SF_DEFAULT_CS XILINX_SPI_FLASH_CS
@@ -135,7 +133,6 @@ #else /* !SPIFLASH */
/* ENV in RAM */ -# define CONFIG_ENV_IS_NOWHERE 1 # define CONFIG_ENV_SIZE 0x1000 # define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE) #endif /* !SPIFLASH */ diff --git a/include/configs/miqi_rk3288.h b/include/configs/miqi_rk3288.h index 477f296542..0c43a2343d 100644 --- a/include/configs/miqi_rk3288.h +++ b/include/configs/miqi_rk3288.h @@ -14,7 +14,6 @@
#endif diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index ac116edf31..eca13442ab 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -79,8 +79,6 @@ #ifdef CONFIG_MVEBU_SPI_BOOT #define CONFIG_ENV_IS_IN_SPI_FLASH /* Environment in NAND flash */ -#elif defined(CONFIG_MVEBU_NAND_BOOT) -#define CONFIG_ENV_IS_IN_NAND #endif
#define CONFIG_ENV_OFFSET 0x180000 /* as Marvell U-Boot version */ diff --git a/include/configs/mx23_olinuxino.h b/include/configs/mx23_olinuxino.h index cccc3a8ab0..bd3c7ed949 100644 --- a/include/configs/mx23_olinuxino.h +++ b/include/configs/mx23_olinuxino.h @@ -19,7 +19,6 @@ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
/* Environment */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OVERWRITE
/* Environment is in MMC */ diff --git a/include/configs/mx23evk.h b/include/configs/mx23evk.h index 3405172803..9b54d20e21 100644 --- a/include/configs/mx23evk.h +++ b/include/configs/mx23evk.h @@ -23,7 +23,6 @@
/* Environment */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_IS_IN_MMC
/* Environment is in MMC */ #if defined(CONFIG_CMD_MMC) && defined(CONFIG_ENV_IS_IN_MMC) diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 8949ee64db..8b472bf0f0 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -58,7 +58,6 @@ #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
/* U-Boot general configuration */ diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index e45649f566..7ed9012ec9 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -127,7 +127,6 @@ /* * environment organization */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_OFFSET_REDUND 0x60000 #define CONFIG_ENV_SIZE (128 * 1024) diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index e60b96f7dc..4fc0aadd89 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -173,7 +173,6 @@ #define CONFIG_ENV_IS_IN_FLASH
#if defined(CONFIG_FSL_ENV_IN_NAND) - #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (1024 * 1024) #endif
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 4513adf2c4..5daa50d169 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -211,7 +211,6 @@ */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
#endif diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index aee6e70c39..ccbac6ab28 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -196,7 +196,6 @@ /* environment organization */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
#define MX53ARD_CS1GCR1 (CSEN | DSZ(2)) diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index cff1462d00..4137592d4c 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -177,7 +177,6 @@ /* environment organization */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
/* Framebuffer and LCD */ diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index ac9beb60ab..11d1278349 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -139,7 +139,6 @@ /* environment organization */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
#endif /* __CONFIG_H */ diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index c82e426a61..3828b21a8e 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -186,7 +186,6 @@ /* environment organization */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
#ifdef CONFIG_CMD_SATA diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index d064337f47..2990e16372 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -134,7 +134,6 @@ /* environment organization */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 05a9ffde2b..32e898e05c 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -152,7 +152,6 @@
/* Environment organization */ #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (8 * 64 * 1024)
#endif /* __MX6CUBOXI_CONFIG_H */ diff --git a/include/configs/mx6qarm2.h b/include/configs/mx6qarm2.h index de5dc1c451..ff0e4a6444 100644 --- a/include/configs/mx6qarm2.h +++ b/include/configs/mx6qarm2.h @@ -123,7 +123,6 @@ /* Environment organization */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1
/* USB Configs */ diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index d4e4628841..b3638d5cae 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -194,8 +194,6 @@ /* Environment organization */ #define CONFIG_ENV_SIZE (8 * 1024)
-#define CONFIG_ENV_IS_IN_MMC - #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_ENV_OFFSET (768 * 1024) #endif diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 6ab76bb8fa..0f1a67dbb3 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -146,7 +146,6 @@ #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #else #define CONFIG_ENV_OFFSET (8 * SZ_64K) -#define CONFIG_ENV_IS_IN_MMC #endif
#ifdef CONFIG_CMD_SF diff --git a/include/configs/mx6sllevk.h b/include/configs/mx6sllevk.h index 62159a16b7..67807f6280 100644 --- a/include/configs/mx6sllevk.h +++ b/include/configs/mx6sllevk.h @@ -133,7 +133,6 @@ #define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC1 */
#define CONFIG_ENV_OFFSET (12 * SZ_64K) -#define CONFIG_ENV_IS_IN_MMC
/* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 3e73dad9a3..3468b491a7 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -171,7 +171,6 @@
#define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_IS_IN_MMC
#define CONFIG_SYS_FSL_USDHC_NUM 2 #if defined(CONFIG_ENV_IS_IN_MMC) diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index b39ab729d8..319fed4ebc 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -211,7 +211,6 @@
#define CONFIG_SYS_FSL_USDHC_NUM 3 #if defined(CONFIG_ENV_IS_IN_MMC) diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index d38c27a641..c9b7e7b473 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -166,7 +166,6 @@
/* environment organization */ #define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_SYS_MMC_ENV_DEV 1 /* USDHC2 */ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ diff --git a/include/configs/mx6ullevk.h b/include/configs/mx6ullevk.h index 30e7518495..8787df4907 100644 --- a/include/configs/mx6ullevk.h +++ b/include/configs/mx6ullevk.h @@ -155,7 +155,6 @@ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_ENV_OFFSET (12 * SZ_64K)
diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index fe9fd661e8..43453323f7 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -185,7 +185,6 @@
/* * If want to use nand, define CONFIG_NAND_MXS and rework board diff --git a/include/configs/mx7ulp_evk.h b/include/configs/mx7ulp_evk.h index 288a8894d1..532f47ea4f 100644 --- a/include/configs/mx7ulp_evk.h +++ b/include/configs/mx7ulp_evk.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_MMC_IMG_LOAD_PART 1
#define CONFIG_ENV_OFFSET (12 * SZ_64K) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_SIZE SZ_8K
/* Using ULP WDOG for reset */ diff --git a/include/configs/nas220.h b/include/configs/nas220.h index dfa81223c4..1f339c6f29 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -56,10 +56,7 @@ * Environment variables configurations */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SECT_SIZE 0x10000 -#else -#define CONFIG_ENV_IS_NOWHERE #endif
#define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/netgear_cg3100d.h b/include/configs/netgear_cg3100d.h index c97d4e57ed..457a50d472 100644 --- a/include/configs/netgear_cg3100d.h +++ b/include/configs/netgear_cg3100d.h @@ -7,7 +7,6 @@ #include <configs/bmips_common.h> #include <configs/bmips_bcm3380.h>
#define CONFIG_AUTO_COMPLETE diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 576b7b07db..6d5b0bd831 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -271,7 +271,6 @@ #define CONFIG_ENV_SIZE (8 * 1024)
#if defined(CONFIG_SABRELITE) -#define CONFIG_ENV_IS_IN_MMC #else #define CONFIG_ENV_IS_IN_SPI_FLASH #endif diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 5e2d5991e7..4e8f664e69 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -381,8 +381,6 @@ int rx51_kp_getc(struct stdio_dev *sdev); * FLASH and environment organization */
-#define CONFIG_ENV_IS_NOWHERE - #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 #define CONFIG_SYS_INIT_RAM_SIZE 0x800 diff --git a/include/configs/novena.h b/include/configs/novena.h index 041159806b..2bba741ac3 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -30,14 +30,11 @@ * http://homepage.ntlworld.com./jonathan.deboynepollard/FGA/disc-partition-ali... */ #ifdef CONFIG_CMD_MMC -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_OFFSET (512 * 1024) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET_REDUND \ (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) -#else -#define CONFIG_ENV_IS_NOWHERE #endif
/* Booting Linux */ diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index bc67270af7..2342f7452f 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -33,10 +33,7 @@
/* environment variables configuration */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SECT_SIZE 0x20000 -#else -#define CONFIG_ENV_IS_NOWHERE #endif #define CONFIG_ENV_SIZE 0x20000 #define CONFIG_ENV_OFFSET 0xe0000 diff --git a/include/configs/nsim.h b/include/configs/nsim.h index 5bbf610846..4490663020 100644 --- a/include/configs/nsim.h +++ b/include/configs/nsim.h @@ -42,7 +42,6 @@ /* * Environment settings */ -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE SZ_512 #define CONFIG_ENV_OFFSET 0
diff --git a/include/configs/nyan-big.h b/include/configs/nyan-big.h index b5357ea15c..ca409949ad 100644 --- a/include/configs/nyan-big.h +++ b/include/configs/nyan-big.h @@ -25,7 +25,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 609a3d1c45..9552c967c8 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -52,7 +52,6 @@
#define CONFIG_SYS_MONITOR_BASE 0x00000000
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV #define CONFIG_ENV_SIZE 4096 #define CONFIG_ENV_OFFSET (SZ_1K * 1280) /* 1.25 MiB offset */ diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index ba29f3e7d1..3b920ccf16 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -29,8 +29,6 @@ #define CONFIG_SYS_MEM_TOP_HIDE (22UL << 20UL) #define CONFIG_TZSW_RESERVED_DRAM_SIZE CONFIG_SYS_MEM_TOP_HIDE
-#define CONFIG_ENV_IS_IN_MMC - #undef CONFIG_ENV_SIZE #undef CONFIG_ENV_OFFSET #define CONFIG_ENV_SIZE (SZ_1K * 16) diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 0d48d4ecc1..4422d5e8d5 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -250,7 +250,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
-#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ #define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index b5d2b007e8..7e1f4751fb 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -175,7 +175,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
-#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ #define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 53bfc13264..76c00d4efa 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -266,7 +266,6 @@
#if !defined(CONFIG_ENV_IS_NOWHERE) #if defined(CONFIG_CMD_NAND) -#define CONFIG_ENV_IS_IN_NAND #elif defined(CONFIG_CMD_ONENAND) #define CONFIG_ENV_IS_IN_ONENAND #define CONFIG_ENV_OFFSET ONENAND_ENV_OFFSET diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 59da726bd6..3a868797b8 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -135,7 +135,6 @@ #define CONFIG_SPL_UBI_INFO_ADDR 0x88080000
/* environment organization */ -#define CONFIG_ENV_IS_NOWHERE 1 #define CONFIG_ENV_UBI_PART "UBI" #define CONFIG_ENV_UBI_VOLUME "config" #define CONFIG_ENV_UBI_VOLUME_REDUND "config_r" diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index f8978037f2..bed8ceb45b 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -254,7 +254,6 @@ /* Monitor at start of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
-#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 111aec58d3..074e17d178 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -184,7 +184,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
-#define CONFIG_ENV_IS_IN_NAND #define ONENAND_ENV_OFFSET 0x240000 /* environment starts here */ #define SMNAND_ENV_OFFSET 0x240000 /* environment starts here */
diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index efee5b0c3f..189b389db5 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -108,7 +108,6 @@ /* Monitor at start of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 6c869c4c07..23603c61e2 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -155,7 +155,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
-#define CONFIG_ENV_IS_IN_NAND 1 #define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ #define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */
diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index b82ad13489..c89bd13f55 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -22,7 +22,6 @@ #include <configs/ti_omap4_common.h>
/* ENV related config options */ -#define CONFIG_ENV_IS_IN_MMC 1 #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_ENV_OFFSET 0xE0000
diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 15d06bbe45..eb5e6df9ca 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -34,7 +34,6 @@
#define CONFIG_MISC_INIT_R /* MMC ENV related defines */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1 /* SLOT2: eMMC(1) */ #define CONFIG_ENV_SIZE (128 << 10) #define CONFIG_ENV_OFFSET 0x260000 diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 5f118950aa..f566d0f1ba 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -156,7 +156,6 @@ #ifdef CONFIG_USE_NAND #undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_NAND_DAVINCI -#define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */ #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 9) #define CONFIG_SYS_NAND_USE_FLASH_BBT @@ -216,7 +215,6 @@
#ifdef CONFIG_USE_SPIFLASH #undef CONFIG_ENV_IS_IN_FLASH -#undef CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_OFFSET (256 << 10) @@ -305,14 +303,10 @@ #if !defined(CONFIG_USE_NAND) && \ !defined(CONFIG_SYS_USE_NOR) && \ !defined(CONFIG_USE_SPIFLASH) -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE (16 << 10) #endif
/* SD/MMC */ -#ifdef CONFIG_MMC -#undef CONFIG_ENV_IS_IN_MMC -#endif
#ifdef CONFIG_ENV_IS_IN_MMC #undef CONFIG_ENV_SIZE @@ -320,7 +314,6 @@ #define CONFIG_ENV_SIZE (16 << 10) /* 16 KiB */ #define CONFIG_ENV_OFFSET (51 << 9) /* Sector 51 */ #undef CONFIG_ENV_IS_IN_FLASH -#undef CONFIG_ENV_IS_IN_NAND #undef CONFIG_ENV_IS_IN_SPI_FLASH #endif
diff --git a/include/configs/openrd.h b/include/configs/openrd.h index 89e963d524..a30efdeb85 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -38,10 +38,7 @@ * Environment variables configurations */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#else -#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ #endif /* * max 4k env size is enough, but in case of nand diff --git a/include/configs/opos6uldev.h b/include/configs/opos6uldev.h index e7bc044acf..9b96cd0be8 100644 --- a/include/configs/opos6uldev.h +++ b/include/configs/opos6uldev.h @@ -74,7 +74,6 @@ #endif
/* Environment is stored in the eMMC boot partition */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1 #define CONFIG_ENV_SIZE (10 * 1024) diff --git a/include/configs/origen.h b/include/configs/origen.h index 6980e9e548..c363653537 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -89,7 +89,6 @@ /* MIU (Memory Interleaving Unit) */ #define CONFIG_MIU_2BIT_21_7_INTERLEAVED
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define RESERVE_BLOCK_SIZE (512) diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index a72a57c904..248203d9bf 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -781,7 +781,6 @@ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #elif defined(CONFIG_SDCARD) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_FSL_FIXED_MMC_LOCATION #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 @@ -792,11 +791,9 @@ #else #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #endif -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (1024 * 1024) #define CONFIG_ENV_RANGE (3 * CONFIG_ENV_SIZE) #elif defined(CONFIG_SYS_RAMBOOT) -#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #else diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index dffb15aea9..799672fff7 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -362,11 +362,9 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); */ #ifdef CONFIG_SYS_RAMBOOT #ifdef CONFIG_RAMBOOT_SDCARD -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 #else -#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/p2371-0000.h b/include/configs/p2371-0000.h index b106439071..3f5c669c39 100644 --- a/include/configs/p2371-0000.h +++ b/include/configs/p2371-0000.h @@ -22,7 +22,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) diff --git a/include/configs/p2371-2180.h b/include/configs/p2371-2180.h index 22fc122cc3..3fb62ded1e 100644 --- a/include/configs/p2371-2180.h +++ b/include/configs/p2371-2180.h @@ -22,7 +22,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) diff --git a/include/configs/p2571.h b/include/configs/p2571.h index 974fd3f59f..e8ed8b0fd3 100644 --- a/include/configs/p2571.h +++ b/include/configs/p2571.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) diff --git a/include/configs/p2771-0000.h b/include/configs/p2771-0000.h index 791a48a3be..55230291c2 100644 --- a/include/configs/p2771-0000.h +++ b/include/configs/p2771-0000.h @@ -18,7 +18,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) diff --git a/include/configs/paz00.h b/include/configs/paz00.h index 87a8557ea9..88754f0403 100644 --- a/include/configs/paz00.h +++ b/include/configs/paz00.h @@ -23,7 +23,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_PAZ00
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index efbcbd2e05..85cac5a7b4 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -86,8 +86,6 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT (2 * CONFIG_SYS_HZ) /* Timeout for Flash Erase */ #define CONFIG_SYS_FLASH_WRITE_TOUT (2 * CONFIG_SYS_HZ) /* Timeout for Flash Write */
-#define CONFIG_ENV_IS_NOWHERE 1 - /* Address and size of Primary Environment Sector */ #define CONFIG_ENV_ADDR 0xB0030000 #define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index fc75ca85c5..ce80e7ecbc 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -116,7 +116,6 @@ 4800, 9600, 14400, 19200, 28800, 38400, 56000, 57600, 115200 }
/* CPU */ -#define CONFIG_ENV_IS_NOWHERE
#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index 9c8720bee9..421d804bd7 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -162,7 +162,6 @@ "512k(SPL.backup3),1536k(u-boot)," \ "512k(u-boot-spl-os)," \ "512k(u-boot-env),5m(kernel),-(rootfs)" -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ /* NAND: SPL falcon mode configs */ diff --git a/include/configs/pepper.h b/include/configs/pepper.h index 5abeffbade..ff3cd74ac3 100644 --- a/include/configs/pepper.h +++ b/include/configs/pepper.h @@ -19,7 +19,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_PEPPER
#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_ENV_IS_NOWHERE
#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/phycore_rk3288.h b/include/configs/phycore_rk3288.h index aab43ed594..7a977a8e5e 100644 --- a/include/configs/phycore_rk3288.h +++ b/include/configs/phycore_rk3288.h @@ -17,7 +17,6 @@ func(MMC, mmc, 0) \ func(MMC, mmc, 1)
#endif diff --git a/include/configs/pic32mzdask.h b/include/configs/pic32mzdask.h index c5bfdec8fa..57b265ce14 100644 --- a/include/configs/pic32mzdask.h +++ b/include/configs/pic32mzdask.h @@ -97,7 +97,6 @@ /* ------------------------------------------------- * Environment */ -#define CONFIG_ENV_IS_NOWHERE 1 #define CONFIG_ENV_SIZE 0x4000
/* --------------------------------------------------------------------- diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 38ae83786d..7b44752e55 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -143,7 +143,6 @@
#define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index d128eded05..e623f48fa2 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -122,7 +122,6 @@
#define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_SYS_FSL_USDHC_NUM 2 diff --git a/include/configs/platinum.h b/include/configs/platinum.h index 9c2182cbea..fb01f97254 100644 --- a/include/configs/platinum.h +++ b/include/configs/platinum.h @@ -92,7 +92,6 @@ #define CONFIG_APBH_DMA_BURST8
/* Environment in NAND */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (16 << 20) #define CONFIG_ENV_SECT_SIZE (128 << 10) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE @@ -103,7 +102,6 @@
/* Environment in MMC */ #define CONFIG_ENV_SIZE (8 << 10) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
diff --git a/include/configs/plutux.h b/include/configs/plutux.h index ff396eceb9..5d692d159c 100644 --- a/include/configs/plutux.h +++ b/include/configs/plutux.h @@ -25,7 +25,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* USB host support */ diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index b22a3b6a2b..b6ec563cee 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -256,7 +256,6 @@ #elif defined(CONFIG_SYS_USE_NANDFLASH) /* CONFIG_SYS_USE_NANDFLASH */
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_OFFSET 0x60000 #define CONFIG_ENV_OFFSET_REDUND 0x80000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 41d5722490..eeb3f27cfe 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -282,7 +282,6 @@ #elif defined(CONFIG_SYS_USE_NANDFLASH) /* CFG_USE_NANDFLASH */
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x60000 #define CONFIG_ENV_OFFSET_REDUND 0x80000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 5e58b6b021..dc4ebeab31 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -119,7 +119,6 @@ #define CONFIG_SYS_MEMTEST_END CONFIG_AT91SAM9G45_LCD_BASE
/* bootstrap + u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_OFFSET 0x60000 #define CONFIG_ENV_OFFSET_REDUND 0x80000 #define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index f94e74f0fc..db298f2841 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -41,10 +41,7 @@ * Environment variables configurations */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#else -#define CONFIG_ENV_IS_NOWHERE #endif
#define CONFIG_ENV_SIZE 0x20000 /* 128k */ diff --git a/include/configs/poplar.h b/include/configs/poplar.h index 55e05d6ca5..d59f32a352 100644 --- a/include/configs/poplar.h +++ b/include/configs/poplar.h @@ -67,7 +67,6 @@
/* Command line configuration */ -#define CONFIG_ENV_IS_IN_MMC 1 #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_OFFSET (0x780 * 512) /* env_mmc_blknum */ #define CONFIG_ENV_SIZE 0x10000 /* env_mmc_nblks bytes */ diff --git a/include/configs/popmetal_rk3288.h b/include/configs/popmetal_rk3288.h index 0dc3532f33..15a374cca7 100644 --- a/include/configs/popmetal_rk3288.h +++ b/include/configs/popmetal_rk3288.h @@ -10,7 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3288_common.h>
#endif diff --git a/include/configs/puma_rk3399.h b/include/configs/puma_rk3399.h index af1dae88ed..e481a28ae9 100644 --- a/include/configs/puma_rk3399.h +++ b/include/configs/puma_rk3399.h @@ -17,7 +17,6 @@ #undef CONFIG_ENV_OFFSET #define CONFIG_ENV_OFFSET (240 * 1024)
#define SDRAM_BANK_SIZE (2UL << 30) diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index c26810723e..703d158b8b 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -71,8 +71,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void);
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
-#define CONFIG_ENV_IS_NOWHERE - #define CONFIG_HWCONFIG
#define CONFIG_SYS_INIT_RAM_ADDR 0x00100000 diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h index 05eb5ebf91..9690757109 100644 --- a/include/configs/qemu-x86.h +++ b/include/configs/qemu-x86.h @@ -49,7 +49,6 @@
/* SPI is not supported */ #undef CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_IS_NOWHERE
#define CONFIG_SPL_FRAMEWORK
diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 18b7dce94e..43fece6b8a 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -10,7 +10,6 @@ #include "rockchip-common.h"
#define CONFIG_NR_DRAM_BANKS 1 -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_MALLOC_LEN (32 << 20) diff --git a/include/configs/rock.h b/include/configs/rock.h index de5291cd05..e998ec5f03 100644 --- a/include/configs/rock.h +++ b/include/configs/rock.h @@ -10,7 +10,6 @@ #define ROCKCHIP_DEVICE_SETTINGS #include <configs/rk3188_common.h>
#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM diff --git a/include/configs/rock2.h b/include/configs/rock2.h index b4dcf23b1c..bd39111710 100644 --- a/include/configs/rock2.h +++ b/include/configs/rock2.h @@ -14,7 +14,6 @@
#endif diff --git a/include/configs/rv1108_common.h b/include/configs/rv1108_common.h index 52750cb81b..2b63abce46 100644 --- a/include/configs/rv1108_common.h +++ b/include/configs/rv1108_common.h @@ -9,7 +9,6 @@ #include <asm/arch/hardware.h> #include "rockchip-common.h"
-#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_MALLOC_LEN (32 << 20) diff --git a/include/configs/s32v234evb.h b/include/configs/s32v234evb.h index b25a7ea344..c56125209d 100644 --- a/include/configs/s32v234evb.h +++ b/include/configs/s32v234evb.h @@ -211,7 +211,6 @@
/* environment organization */ #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC
#define CONFIG_ENV_OFFSET (12 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index c328e43dd6..0673fe54a4 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -199,7 +199,6 @@
/* FLASH and environment organization */ #define CONFIG_MMC_DEFAULT_DEV 0 -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV #define CONFIG_ENV_SIZE 4096 #define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 0265684e67..b0bc69dab0 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -77,7 +77,6 @@ #define CONFIG_BOOTBLOCK "10" #define CONFIG_UBIBLOCK "9"
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV #define CONFIG_ENV_SIZE 4096 #define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ diff --git a/include/configs/sagem_f@st1704.h b/include/configs/sagem_f@st1704.h index dbc7725796..fd1c75935e 100644 --- a/include/configs/sagem_f@st1704.h +++ b/include/configs/sagem_f@st1704.h @@ -7,7 +7,6 @@ #include <configs/bmips_common.h> #include <configs/bmips_bcm6338.h>
-#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE (8 * 1024)
#define CONFIG_AUTO_COMPLETE diff --git a/include/configs/salvator-x.h b/include/configs/salvator-x.h index 0ac3900326..7f81063d13 100644 --- a/include/configs/salvator-x.h +++ b/include/configs/salvator-x.h @@ -73,7 +73,6 @@ #define CONFIG_SH_SDHI_FREQ 200000000
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 1 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/sama5d2_ptc.h b/include/configs/sama5d2_ptc.h index 7607f94640..b25be974b6 100644 --- a/include/configs/sama5d2_ptc.h +++ b/include/configs/sama5d2_ptc.h @@ -88,7 +88,6 @@ #undef CONFIG_ENV_OFFSET_REDUND #undef CONFIG_BOOTCOMMAND /* u-boot env in nand flash */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x200000 #define CONFIG_ENV_OFFSET_REDUND 0x400000 #define CONFIG_BOOTCOMMAND "nand read 0x21000000 0xb80000 0x80000;" \ diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index fbe26cae21..c028ee384f 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -80,8 +80,6 @@ /* override the bootcmd, bootargs and other configuration for nandflash env */ #elif CONFIG_SYS_USE_MMC /* override the bootcmd, bootargs and other configuration for sd/mmc env */ -#else -#define CONFIG_ENV_IS_NOWHERE #endif
/* SPL */ diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 891d6a0f79..a5a0f7c32f 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -109,8 +109,6 @@ /* override the bootcmd, bootargs and other configuration nandflash env */ #elif CONFIG_SYS_USE_MMC /* override the bootcmd, bootargs and other configuration for sd/mmc env */ -#else -#define CONFIG_ENV_IS_NOWHERE #endif
/* SPL */ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 1e8404cbdf..d823cc76c4 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -52,7 +52,6 @@ #define CONFIG_AUTO_COMPLETE
#define CONFIG_ENV_SIZE 8192 -#define CONFIG_ENV_IS_NOWHERE
/* SPI - enable all SPI flash types for testing purposes */ #define CONFIG_CMD_SF_TEST diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index a6da2ccf82..e55addb99c 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -19,7 +19,6 @@
/* Environment */ #define CONFIG_ENV_SIZE (16 * 1024) -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_OVERWRITE
/* Booting Linux */ diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 4d87f5334a..1d07593e95 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -380,7 +380,6 @@ #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/sc_sps_1.h b/include/configs/sc_sps_1.h index 73e7e6bbcf..f7aeb640f6 100644 --- a/include/configs/sc_sps_1.h +++ b/include/configs/sc_sps_1.h @@ -23,14 +23,11 @@
/* Environment */ #define CONFIG_ENV_SIZE (16 * 1024) -#define CONFIG_ENV_IS_IN_MMC
/* Environment is in MMC */ #if defined(CONFIG_CMD_MMC) && defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_ENV_OFFSET (256 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 -#else -#define CONFIG_ENV_IS_NOWHERE #endif
/* FEC Ethernet on SoC */ diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index afc2c7dfe9..2482ba1dcd 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -31,7 +31,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/sfr_nb4_ser.h b/include/configs/sfr_nb4_ser.h index ab64518e0b..6bd2d76f53 100644 --- a/include/configs/sfr_nb4_ser.h +++ b/include/configs/sfr_nb4_ser.h @@ -9,7 +9,6 @@
#define CONFIG_AUTO_COMPLETE diff --git a/include/configs/sheep_rk3368.h b/include/configs/sheep_rk3368.h index ec33565d09..eac9755bba 100644 --- a/include/configs/sheep_rk3368.h +++ b/include/configs/sheep_rk3368.h @@ -13,7 +13,6 @@ #define KERNEL_LOAD_ADDR 0x280000 #define DTB_LOAD_ADDR 0x5600000 #define INITRD_LOAD_ADDR 0x5bf0000 -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x2000
#define CONFIG_CONSOLE_SCROLL_LINES 10 diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 9d2c106d46..d4c9995d50 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -35,10 +35,7 @@ * Environment variables configurations */ #ifdef CONFIG_CMD_NAND -#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ -#else -#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ #endif /* * max 4k env size is enough, but in case of nand diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 21029d10ae..73cfb44881 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -38,7 +38,6 @@ #endif
#define CONFIG_ENV_OVERWRITE 1 -#define CONFIG_ENV_IS_NOWHERE
#define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING @@ -216,7 +215,6 @@ * 0x442000 - 0x800000 : Userland */ #if defined(CONFIG_SPI_BOOT) -# undef CONFIG_ENV_IS_NOWHERE # define CONFIG_ENV_IS_IN_SPI_FLASH # define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED # define CONFIG_ENV_OFFSET (892 << 10) /* 892 KiB in */ @@ -536,8 +534,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #if !defined(CONFIG_SPI_BOOT) -#undef CONFIG_ENV_IS_NOWHERE -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x260000 /* environment starts here */ #define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #endif diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 8400278209..9df88d6a56 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -183,7 +183,6 @@ /* * The NAND Flash partitions: */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (0x100000) #define CONFIG_ENV_OFFSET_REDUND (0x180000) #define CONFIG_ENV_RANGE (SZ_512K) diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index ccb89216d8..9986a3b707 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -73,7 +73,6 @@ /* MIU (Memory Interleaving Unit) */ #define CONFIG_MIU_2BIT_INTERLEAVED
-#define CONFIG_ENV_IS_IN_MMC 1 #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ #define RESERVE_BLOCK_SIZE (512) diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index d3e73f2097..63bc769efe 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -119,7 +119,6 @@ #define CONFIG_BOOTP_HOSTNAME
/* Environment settings */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (512 << 10) #define CONFIG_ENV_SIZE (256 << 10) #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index 4e0b9b1252..2c5f2648ee 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -89,7 +89,6 @@ #define CONFIG_BOOTP_HOSTNAME
/* Environment settings */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (512 << 10) #define CONFIG_ENV_SIZE (256 << 10) #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 6b065c9dc7..669ce8588d 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -143,7 +143,6 @@ */
diff --git a/include/configs/socfpga_arria10_socdk.h b/include/configs/socfpga_arria10_socdk.h index 3b59b6a106..55850bd1b3 100644 --- a/include/configs/socfpga_arria10_socdk.h +++ b/include/configs/socfpga_arria10_socdk.h @@ -33,7 +33,6 @@ /* * U-Boot environment configurations */ -#define CONFIG_ENV_IS_IN_MMC
/* * arguments passed to the bootz command. The value of diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index fe4031910b..9f83858bd1 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -23,8 +23,6 @@ #define CONFIG_PHY_MICREL_KSZ9021 #endif
-#define CONFIG_ENV_IS_IN_MMC - /* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index be56521121..86b4a9dfb8 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -23,8 +23,6 @@ #define CONFIG_PHY_MICREL_KSZ9021 #endif
diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index 320c585a39..6516c45acf 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -23,8 +23,6 @@ #define CONFIG_PHY_MICREL_KSZ9031 #endif
diff --git a/include/configs/socfpga_de10_nano.h b/include/configs/socfpga_de10_nano.h index ef693b0038..04be2b1689 100644 --- a/include/configs/socfpga_de10_nano.h +++ b/include/configs/socfpga_de10_nano.h @@ -23,8 +23,6 @@ #define CONFIG_PHY_MICREL_KSZ9031 #endif
diff --git a/include/configs/socfpga_de1_soc.h b/include/configs/socfpga_de1_soc.h index 522ac74ffe..9405083b3e 100644 --- a/include/configs/socfpga_de1_soc.h +++ b/include/configs/socfpga_de1_soc.h @@ -23,8 +23,6 @@ #define CONFIG_PHY_MICREL_KSZ9021 #endif
diff --git a/include/configs/socfpga_mcvevk.h b/include/configs/socfpga_mcvevk.h index ee85708b7a..e9c7c71a73 100644 --- a/include/configs/socfpga_mcvevk.h +++ b/include/configs/socfpga_mcvevk.h @@ -23,7 +23,6 @@
/* Environment is in MMC */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_IS_IN_MMC
/* Extra Environment */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index c75acc0749..57de60ecfa 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -23,8 +23,6 @@ #define CONFIG_PHY_MICREL_KSZ9021 #endif
diff --git a/include/configs/socfpga_socrates.h b/include/configs/socfpga_socrates.h index a08fa9ff4c..6b6cb6aa14 100644 --- a/include/configs/socfpga_socrates.h +++ b/include/configs/socfpga_socrates.h @@ -23,8 +23,6 @@ #define CONFIG_PHY_MICREL_KSZ9021 #endif
diff --git a/include/configs/spear3xx_evb.h b/include/configs/spear3xx_evb.h index dd73a4d1bd..98a74fa6e1 100644 --- a/include/configs/spear3xx_evb.h +++ b/include/configs/spear3xx_evb.h @@ -25,7 +25,6 @@ #endif
#if defined(CONFIG_NAND) -#define CONFIG_ENV_IS_IN_NAND #else #define CONFIG_ENV_IS_IN_FLASH #endif diff --git a/include/configs/spear6xx_evb.h b/include/configs/spear6xx_evb.h index 7745247052..de08a72704 100644 --- a/include/configs/spear6xx_evb.h +++ b/include/configs/spear6xx_evb.h @@ -17,7 +17,6 @@ #endif
#if defined(CONFIG_NAND) -#define CONFIG_ENV_IS_IN_NAND #else #define CONFIG_ENV_IS_IN_FLASH #endif diff --git a/include/configs/stih410-b2260.h b/include/configs/stih410-b2260.h index 6f4070ff43..eaa93a5830 100644 --- a/include/configs/stih410-b2260.h +++ b/include/configs/stih410-b2260.h @@ -28,7 +28,6 @@ "board= B2260" \ "load_addr= #CONFIG_SYS_LOAD_ADDR \0"
-#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x4000
/* Extra Commands */ diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index 4e0edcbc01..46955b1f1f 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 8 #define CONFIG_SYS_MAX_FLASH_BANKS 1
-#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE (8 << 10)
#define CONFIG_STM32_FLASH diff --git a/include/configs/strider.h b/include/configs/strider.h index 994ac73e13..be6bd7352a 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -537,7 +537,6 @@ void fpga_control_clear(unsigned int bus, int pin); #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #else -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #endif
diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 0b87c9ca97..dbf4496167 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -137,7 +137,6 @@ /* **** PISMO SUPPORT *** */ #define CONFIG_NAND #define CONFIG_NAND_OMAP_GPMC -#define CONFIG_ENV_IS_IN_NAND #define SMNAND_ENV_OFFSET 0x180000 /* environment starts here */
/* Redundant Environment */ diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index f994d2dbf3..5650394ebe 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -203,7 +203,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
diff --git a/include/configs/taurus.h b/include/configs/taurus.h index bed2a5c3c0..ecf12fe302 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -145,7 +145,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x22000000
/* bootstrap in spi flash , u-boot + env + linux in nandflash */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_ENV_OFFSET_REDUND 0x180000 #define CONFIG_ENV_SIZE (SZ_128K) /* 1 sector = 128 kB */ diff --git a/include/configs/tb100.h b/include/configs/tb100.h index fe8e6c4e3b..67b5774a09 100644 --- a/include/configs/tb100.h +++ b/include/configs/tb100.h @@ -65,7 +65,6 @@ /* * Environment settings */ -#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE SZ_2K #define CONFIG_ENV_OFFSET 0
diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 79f6b162f7..4baccdc1e9 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -128,7 +128,6 @@ #endif
/* Environment organization */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 2 /* overwritten on SD boot */ #define CONFIG_SYS_MMC_ENV_PART 1 /* overwritten on SD boot */ #define CONFIG_ENV_SIZE (8 * 1024) diff --git a/include/configs/tec-ng.h b/include/configs/tec-ng.h index 6406d39698..c32a087099 100644 --- a/include/configs/tec-ng.h +++ b/include/configs/tec-ng.h @@ -21,7 +21,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/tec.h b/include/configs/tec.h index 8ffdbec9d1..5f84f2489a 100644 --- a/include/configs/tec.h +++ b/include/configs/tec.h @@ -25,7 +25,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* USB host support */ diff --git a/include/configs/thunderx_88xx.h b/include/configs/thunderx_88xx.h index f52fc8225c..514590a270 100644 --- a/include/configs/thunderx_88xx.h +++ b/include/configs/thunderx_88xx.h @@ -76,7 +76,6 @@ "root=/dev/sda2 coherent_pool=16M"
/* Do not preserve environment */ -#define CONFIG_ENV_IS_NOWHERE 1 #define CONFIG_ENV_SIZE 0x1000
/* Monitor Command Prompt */ diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index ea83ea2495..b5f817749c 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -135,8 +135,6 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
-#define CONFIG_ENV_IS_NOWHERE - /* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE 0x40300000 diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 4a81b1daf8..bba10ec001 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -107,7 +107,6 @@ "8m(NAND.kernel)," \ "-(NAND.file-system)" #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x001c0000 #define CONFIG_ENV_OFFSET_REDUND 0x001e0000 #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE diff --git a/include/configs/tinker_rk3288.h b/include/configs/tinker_rk3288.h index 72578f9202..58eea3c405 100644 --- a/include/configs/tinker_rk3288.h +++ b/include/configs/tinker_rk3288.h @@ -18,7 +18,6 @@ func(PXE, pxe, na) \ func(DHCP, dchp, na)
#endif diff --git a/include/configs/titanium.h b/include/configs/titanium.h index 79e37e2cef..cb695356f0 100644 --- a/include/configs/titanium.h +++ b/include/configs/titanium.h @@ -168,7 +168,6 @@ #define CONFIG_APBH_DMA_BURST8
/* Environment in NAND */ -#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (16 << 20) #define CONFIG_ENV_SECT_SIZE (128 << 10) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE @@ -179,7 +178,6 @@
diff --git a/include/configs/topic_miami.h b/include/configs/topic_miami.h index ee46d3ac7e..d538080aa3 100644 --- a/include/configs/topic_miami.h +++ b/include/configs/topic_miami.h @@ -14,7 +14,6 @@ #define CONFIG_ZYNQ_I2C1
/* Speed up boot time by ignoring the environment which we never used */ -#define CONFIG_ENV_IS_NOWHERE
#include "zynq-common.h"
diff --git a/include/configs/tplink_wdr4300.h b/include/configs/tplink_wdr4300.h index fc99dbd91e..a03ad67af0 100644 --- a/include/configs/tplink_wdr4300.h +++ b/include/configs/tplink_wdr4300.h @@ -37,7 +37,6 @@ #define CONFIG_BOOTCOMMAND \ "dhcp 192.168.1.1:wdr4300.fit && bootm $loadaddr"
-#define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x10000
/* diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 0b362559f2..29e22aa311 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -92,7 +92,6 @@
#if defined(CONFIG_TQMA6X_MMC_BOOT)
-#define CONFIG_ENV_IS_IN_MMC #define TQMA6_UBOOT_OFFSET SZ_1K #define TQMA6_UBOOT_SECTOR_START 0x2 #define TQMA6_UBOOT_SECTOR_COUNT 0x7fe diff --git a/include/configs/trats.h b/include/configs/trats.h index e08bbc49ae..3059d89ac9 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -55,7 +55,6 @@ #define CONFIG_BOOTBLOCK "10" #define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}"
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV #define CONFIG_ENV_SIZE 4096 #define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 927d48255c..1f3ce9d941 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -49,7 +49,6 @@
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV #define CONFIG_ENV_SIZE 4096 #define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index d18a333d01..8aa8e357fd 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -152,9 +152,6 @@ * which will not be influenced by any data already on the device. */ #ifdef CONFIG_FLASHCARD - -#define CONFIG_ENV_IS_NOWHERE - /* the rdaddr is 16 MiB before the loadaddr */ #define CONFIG_ENV_RDADDR "rdaddr=0x81000000\0"
@@ -175,8 +172,6 @@
#define CONFIG_ENV_OVERWRITE /* allow to overwrite serial and ethaddr */
-#define CONFIG_ENV_IS_IN_NAND - #define CONFIG_EXTRA_ENV_SETTINGS \ CONFIG_COMMON_ENV_SETTINGS \ "mmcargs=" \ diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index 7bb8c87988..959db5fdb2 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -160,7 +160,6 @@
#endif diff --git a/include/configs/udoo.h b/include/configs/udoo.h index aef4563ede..d3fa5d71c1 100644 --- a/include/configs/udoo.h +++ b/include/configs/udoo.h @@ -168,7 +168,6 @@ /* Environment organization */ #define CONFIG_ENV_SIZE (8 * 1024)
diff --git a/include/configs/udoo_neo.h b/include/configs/udoo_neo.h index c6f39c38b3..60b76edd1f 100644 --- a/include/configs/udoo_neo.h +++ b/include/configs/udoo_neo.h @@ -85,7 +85,6 @@ /* Environment organization */ #define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_IS_IN_MMC
#define CONFIG_IMX_THERMAL
diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index e45b506eba..b8afa81325 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -70,9 +70,6 @@
-/* #define CONFIG_ENV_IS_NOWHERE */ -/* #define CONFIG_ENV_IS_IN_NAND */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_ENV_SIZE 0x2000 /* #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) */ diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index e25bf99e1c..5bacc9d834 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -21,7 +21,6 @@ /* U-Boot environment */ #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
/* U-Boot general configurations */ diff --git a/include/configs/venice2.h b/include/configs/venice2.h index 850a9bd49a..5e9b79eb04 100644 --- a/include/configs/venice2.h +++ b/include/configs/venice2.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) diff --git a/include/configs/ventana.h b/include/configs/ventana.h index 1ab6476f3c..9b8b1010a9 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -21,7 +21,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_VENTANA
/* Environment in eMMC, at the end of 2nd "boot sector" */ -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 2 diff --git a/include/configs/veyron.h b/include/configs/veyron.h index 3bd8dd60b5..3f236aa13c 100644 --- a/include/configs/veyron.h +++ b/include/configs/veyron.h @@ -14,7 +14,6 @@
-#define CONFIG_ENV_IS_NOWHERE #define CONFIG_SPL_SPI_LOAD #define CONFIG_SPI_FLASH_GIGADEVICE
diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 78e14b38c1..0fed7f37ca 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -101,7 +101,6 @@ #define CONFIG_ENV_SIZE SZ_8K #define CONFIG_ENV_OFFSET_REDUND (9 * SZ_64K) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE -#define CONFIG_ENV_IS_IN_MMC
#ifdef CONFIG_ENV_IS_IN_MMC #define CONFIG_SUPPORT_EMMC_BOOT diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 1aed81fc14..f2a15f37fe 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -323,7 +323,6 @@ #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#else - #define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #endif diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index be2f619f7c..a8a48a597f 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -151,7 +151,6 @@ /* Environment organization */ #define CONFIG_ENV_SIZE (8 * 1024)
-#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
diff --git a/include/configs/warp.h b/include/configs/warp.h index 389831595b..139cde4d11 100644 --- a/include/configs/warp.h +++ b/include/configs/warp.h @@ -49,7 +49,6 @@
#define CONFIG_ENV_OFFSET (6 * SZ_64K) #define CONFIG_ENV_SIZE SZ_8K -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
/* VDD voltage 1.65 - 1.95 */ diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 23b6eae533..75ae8a3e33 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -112,7 +112,6 @@
#define CONFIG_ENV_OFFSET (8 * SZ_64K) #define CONFIG_SYS_FSL_USDHC_NUM 1 diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index 56f53b9732..807cb99c81 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -138,7 +138,6 @@ * Environment */
-#define CONFIG_ENV_IS_IN_NAND 1 #define CONFIG_ENV_SIZE 0x00020000 #define CONFIG_ENV_OFFSET 0x00100000 #define CONFIG_ENV_OFFSET_REDUND 0x00120000 diff --git a/include/configs/x86-chromebook.h b/include/configs/x86-chromebook.h index b0e7e8115f..51366d4d4e 100644 --- a/include/configs/x86-chromebook.h +++ b/include/configs/x86-chromebook.h @@ -39,7 +39,6 @@ #define VIDEO_IO_OFFSET 0 #define CONFIG_X86EMU_RAW_IO
-#undef CONFIG_ENV_IS_NOWHERE #undef CONFIG_ENV_SIZE #define CONFIG_ENV_SIZE 0x1000 #define CONFIG_ENV_SECT_SIZE 0x1000 diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index 2e6e75d5e3..bd829a9495 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -19,7 +19,6 @@
/* Booting Linux */ diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index e8a0c1c33d..cfc687806a 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -77,8 +77,6 @@ #define CONFIG_CMD_MTDPARTS #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_FLASH_CFI_MTD -#else -#define CONFIG_ENV_IS_NOWHERE #endif
/* The following table includes the supported baudrates */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index c7fcd86dd5..0f4ca7452b 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -138,9 +138,6 @@ #endif
/* Do not preserve environment */ -#if !defined(CONFIG_ENV_IS_IN_FAT) -#define CONFIG_ENV_IS_NOWHERE 1 -#endif #define CONFIG_ENV_SIZE 0x8000
/* Monitor Command Prompt */ diff --git a/include/configs/xpress.h b/include/configs/xpress.h index 9edb35322d..629e3df641 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -57,7 +57,6 @@
/* Environment is in stored in the eMMC boot partition */ #define CONFIG_ENV_SIZE (16 << 10) -#define CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_OFFSET (512 << 10) #define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC2 */ #define CONFIG_SYS_MMC_ENV_PART 1 /* boot parition */ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 4b6b088851..807b097d34 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -165,8 +165,6 @@ # elif defined(CONFIG_ZYNQ_QSPI) /* Environment in Serial Flash */ # define CONFIG_ENV_IS_IN_SPI_FLASH -# elif !defined(CONFIG_MTD_NOR_FLASH) -# define CONFIG_ENV_IS_NOWHERE # endif
# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE
On Sun, Jul 23, 2017 at 09:19:39PM -0600, Simon Glass wrote:
This converts the following to Kconfig: CONFIG_ENV_IS_IN_MMC CONFIG_ENV_IS_IN_NAND CONFIG_ENV_IS_IN_UBI CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not all the choices are available in Kconfig yet so we cannot use that. It would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be stored in more than one place. So the existing choice is converted to a normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
Signed-off-by: Simon Glass sjg@chromium.org
With a few minor changes so that CHAIN_OF_TRUST enforces CONFIG_ENV_IS_NOWHERE, and so that CHIP_pro is ENV_IN_UBI (which is what the old result was, build-wise):
The CONFIG_ENV_IS_IN_... options which have already been converted to Kconfig only have a small amount of help. Move the rest of it over from the README.
Changes in v2: None
README | 114 ------------------------------------------------------------ env/Kconfig | 103 ++++++++++++++++++++++++++++++++++++++++++++++++++++-- 2 files changed, 101 insertions(+), 116 deletions(-)
diff --git a/README b/README index c73f6dd574..3db9c2dd87 100644 --- a/README +++ b/README @@ -3654,75 +3654,12 @@ BE CAREFUL! For some special cases, the local device can not use environment stored in a remote NOR flash by SRIO or PCIE link, but it can not erase, write this NOR flash by SRIO or PCIE interface.
-- CONFIG_ENV_IS_IN_NAND: - - Define this if you have a NAND device which you want to use - for the environment. - - - CONFIG_ENV_OFFSET: - - CONFIG_ENV_SIZE: - - These two #defines specify the offset and size of the environment - area within the first NAND device. CONFIG_ENV_OFFSET must be - aligned to an erase block boundary. - - - CONFIG_ENV_OFFSET_REDUND (optional): - - This setting describes a second storage area of CONFIG_ENV_SIZE - size used to hold a redundant copy of the environment data, so - that there is a valid backup copy in case there is a power failure - during a "saveenv" operation. CONFIG_ENV_OFFSET_REDUND must be - aligned to an erase block boundary. - - - CONFIG_ENV_RANGE (optional): - - Specifies the length of the region in which the environment - can be written. This should be a multiple of the NAND device's - block size. Specifying a range with more erase blocks than - are needed to hold CONFIG_ENV_SIZE allows bad blocks within - the range to be avoided. - - - CONFIG_ENV_OFFSET_OOB (optional): - - Enables support for dynamically retrieving the offset of the - environment from block zero's out-of-band data. The - "nand env.oob" command can be used to record this offset. - Currently, CONFIG_ENV_OFFSET_REDUND is not supported when - using CONFIG_ENV_OFFSET_OOB. - - CONFIG_NAND_ENV_DST
Defines address in RAM to which the nand_spl code should copy the environment. If redundant environment is used, it will be copied to CONFIG_NAND_ENV_DST + CONFIG_ENV_SIZE.
-- CONFIG_ENV_IS_IN_UBI: - - Define this if you have an UBI volume that you want to use for the - environment. This has the benefit of wear-leveling the environment - accesses, which is important on NAND. - - - CONFIG_ENV_UBI_PART: - - Define this to a string that is the mtd partition containing the UBI. - - - CONFIG_ENV_UBI_VOLUME: - - Define this to the name of the volume that you want to store the - environment in. - - - CONFIG_ENV_UBI_VOLUME_REDUND: - - Define this to the name of another volume to store a second copy of - the environment in. This will enable redundant environments in UBI. - It is assumed that both volumes are in the same MTD partition. - - - CONFIG_UBI_SILENCE_MSG - - CONFIG_UBIFS_SILENCE_MSG - - You will probably want to define these to avoid a really noisy system - when storing the env in UBI. - - CONFIG_ENV_IS_IN_FAT: Define this if you want to use the FAT file system for the environment.
@@ -3754,57 +3691,6 @@ but it can not erase, write this NOR flash by SRIO or PCIE interface. - CONFIG_FAT_WRITE: This must be enabled. Otherwise it cannot save the environment file.
-- CONFIG_ENV_IS_IN_MMC: - - Define this if you have an MMC device which you want to use for the - environment. - - - CONFIG_SYS_MMC_ENV_DEV: - - Specifies which MMC device the environment is stored in. - - - CONFIG_SYS_MMC_ENV_PART (optional): - - Specifies which MMC partition the environment is stored in. If not - set, defaults to partition 0, the user area. Common values might be - 1 (first MMC boot partition), 2 (second MMC boot partition). - - - CONFIG_ENV_OFFSET: - - CONFIG_ENV_SIZE: - - These two #defines specify the offset and size of the environment - area within the specified MMC device. - - If offset is positive (the usual case), it is treated as relative to - the start of the MMC partition. If offset is negative, it is treated - as relative to the end of the MMC partition. This can be useful if - your board may be fitted with different MMC devices, which have - different sizes for the MMC partitions, and you always want the - environment placed at the very end of the partition, to leave the - maximum possible space before it, to store other data. - - These two values are in units of bytes, but must be aligned to an - MMC sector boundary. - - - CONFIG_ENV_OFFSET_REDUND (optional): - - Specifies a second storage area, of CONFIG_ENV_SIZE size, used to - hold a redundant copy of the environment data. This provides a - valid backup copy in case the other copy is corrupted, e.g. due - to a power failure during a "saveenv" operation. - - This value may also be positive or negative; this is handled in the - same way as CONFIG_ENV_OFFSET. - - This value is also in units of bytes, but must also be aligned to - an MMC sector boundary. - - - CONFIG_ENV_SIZE_REDUND (optional): - - This value need not be set, even when CONFIG_ENV_OFFSET_REDUND is - set. If this value is set, it must be set to the same value as - CONFIG_ENV_SIZE. - Please note that the environment is read-only until the monitor has been relocated to RAM and a RAM copy of the environment has been created; also, when using EEPROM you will have to use getenv_f() diff --git a/env/Kconfig b/env/Kconfig index a555546899..5a314022ef 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -7,17 +7,116 @@ config ENV_IS_IN_MMC Define this if you have an MMC device which you want to use for the environment.
+ CONFIG_SYS_MMC_ENV_DEV: + + Specifies which MMC device the environment is stored in. + + CONFIG_SYS_MMC_ENV_PART (optional): + + Specifies which MMC partition the environment is stored in. If not + set, defaults to partition 0, the user area. Common values might be + 1 (first MMC boot partition), 2 (second MMC boot partition). + + CONFIG_ENV_OFFSET: + CONFIG_ENV_SIZE: + + These two #defines specify the offset and size of the environment + area within the specified MMC device. + + If offset is positive (the usual case), it is treated as relative to + the start of the MMC partition. If offset is negative, it is treated + as relative to the end of the MMC partition. This can be useful if + your board may be fitted with different MMC devices, which have + different sizes for the MMC partitions, and you always want the + environment placed at the very end of the partition, to leave the + maximum possible space before it, to store other data. + + These two values are in units of bytes, but must be aligned to an + MMC sector boundary. + + CONFIG_ENV_OFFSET_REDUND (optional): + + Specifies a second storage area, of CONFIG_ENV_SIZE size, used to + hold a redundant copy of the environment data. This provides a + valid backup copy in case the other copy is corrupted, e.g. due + to a power failure during a "saveenv" operation. + + This value may also be positive or negative; this is handled in the + same way as CONFIG_ENV_OFFSET. + + This value is also in units of bytes, but must also be aligned to + an MMC sector boundary. + + CONFIG_ENV_SIZE_REDUND (optional): + + This value need not be set, even when CONFIG_ENV_OFFSET_REDUND is + set. If this value is set, it must be set to the same value as + CONFIG_ENV_SIZE. + config ENV_IS_IN_NAND bool "Environment in a NAND device" help Define this if you have a NAND device which you want to use for the environment.
+ - CONFIG_ENV_OFFSET: + - CONFIG_ENV_SIZE: + + These two #defines specify the offset and size of the environment + area within the first NAND device. CONFIG_ENV_OFFSET must be + aligned to an erase block boundary. + + - CONFIG_ENV_OFFSET_REDUND (optional): + + This setting describes a second storage area of CONFIG_ENV_SIZE + size used to hold a redundant copy of the environment data, so + that there is a valid backup copy in case there is a power failure + during a "saveenv" operation. CONFIG_ENV_OFFSET_REDUND must be + aligned to an erase block boundary. + + - CONFIG_ENV_RANGE (optional): + + Specifies the length of the region in which the environment + can be written. This should be a multiple of the NAND device's + block size. Specifying a range with more erase blocks than + are needed to hold CONFIG_ENV_SIZE allows bad blocks within + the range to be avoided. + + - CONFIG_ENV_OFFSET_OOB (optional): + + Enables support for dynamically retrieving the offset of the + environment from block zero's out-of-band data. The + "nand env.oob" command can be used to record this offset. + Currently, CONFIG_ENV_OFFSET_REDUND is not supported when + using CONFIG_ENV_OFFSET_OOB. + config ENV_IS_IN_UBI bool "Environment in a UBI volume" help - Define this if you have a UBI volume which you want to use for the - environment. + Define this if you have an UBI volume that you want to use for the + environment. This has the benefit of wear-leveling the environment + accesses, which is important on NAND. + + - CONFIG_ENV_UBI_PART: + + Define this to a string that is the mtd partition containing the UBI. + + - CONFIG_ENV_UBI_VOLUME: + + Define this to the name of the volume that you want to store the + environment in. + + - CONFIG_ENV_UBI_VOLUME_REDUND: + + Define this to the name of another volume to store a second copy of + the environment in. This will enable redundant environments in UBI. + It is assumed that both volumes are in the same MTD partition. + + - CONFIG_UBI_SILENCE_MSG + - CONFIG_UBIFS_SILENCE_MSG + + You will probably want to define these to avoid a really noisy system + when storing the env in UBI.
config ENV_IS_NOWHERE bool "Environment is not stored"
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FLASH
Changes in v2: - Drop imply for some MIPS Kconfigs - Update CONFIG_ENV_IS_IN_FLASH for MCR3000 also
README | 70 -------------------------- arch/arm/mach-integrator/Kconfig | 2 + arch/m68k/Kconfig | 8 +++ arch/microblaze/Kconfig | 1 + arch/mips/Kconfig | 4 ++ arch/powerpc/Kconfig | 1 + arch/powerpc/cpu/mpc83xx/Kconfig | 6 +++ arch/powerpc/cpu/mpc85xx/Kconfig | 4 ++ arch/powerpc/cpu/mpc86xx/Kconfig | 1 + arch/sh/Kconfig | 3 ++ configs/10m50_defconfig | 1 + configs/3c120_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/M5208EVBE_defconfig | 1 + configs/M52277EVB_defconfig | 1 + configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M53017EVB_defconfig | 1 + configs/M54451EVB_defconfig | 1 + configs/M54455EVB_a66_defconfig | 1 + configs/M54455EVB_defconfig | 1 + configs/M54455EVB_i66_defconfig | 1 + configs/M54455EVB_intel_defconfig | 1 + configs/MCR3000_defconfig | 1 + configs/MPC8308RDB_defconfig | 1 + configs/MPC8313ERDB_33_defconfig | 1 + configs/MPC8313ERDB_66_defconfig | 1 + configs/MPC8315ERDB_defconfig | 1 + configs/MPC8323ERDB_defconfig | 1 + configs/MPC8349EMDS_defconfig | 1 + configs/MPC837XEMDS_HOST_defconfig | 1 + configs/MPC837XEMDS_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8541CDS_defconfig | 1 + configs/MPC8541CDS_legacy_defconfig | 1 + configs/MPC8544DS_defconfig | 3 +- configs/MPC8555CDS_defconfig | 1 + configs/MPC8555CDS_legacy_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 2 +- configs/MigoR_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1020MBG-PC_36BIT_defconfig | 1 + configs/P1020MBG-PC_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P1020UTM-PC_36BIT_defconfig | 1 + configs/P1020UTM-PC_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 1 + configs/P1024RDB_36BIT_defconfig | 1 + configs/P1024RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5020DS_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/T1023RDB_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2081QDS_defconfig | 1 + configs/T4160QDS_defconfig | 1 + configs/T4160RDB_defconfig | 1 + configs/T4240QDS_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/TQM834x_defconfig | 1 + configs/TWR-P1025_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/adp-ae3xx_defconfig | 1 + configs/adp-ag101p_defconfig | 1 + configs/am335x_evm_norboot_defconfig | 1 + configs/amcore_defconfig | 1 + configs/ap325rxa_defconfig | 1 + configs/ap_sh4a_4a_defconfig | 1 + configs/armadillo-800eva_defconfig | 1 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/blanche_defconfig | 1 + configs/caddy2_defconfig | 1 + configs/calimain_defconfig | 1 + configs/colibri_pxa270_defconfig | 1 + configs/da850evm_direct_nor_defconfig | 1 + configs/ecovec_defconfig | 1 + configs/edb9315a_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/espt_defconfig | 1 + configs/flea3_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/ids8313_defconfig | 1 + configs/kmcoge5ne_defconfig | 1 + configs/kmeter1_defconfig | 1 + configs/kzm9g_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1046aqds_defconfig | 1 + configs/ls1046aqds_lpuart_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/mccmon6_nor_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/mpc8308_p1m_defconfig | 1 + configs/ms7722se_defconfig | 1 + configs/ms7750se_defconfig | 1 + configs/mx31ads_defconfig | 1 + configs/mx35pdk_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/r0p7734_defconfig | 1 + configs/r2dplus_defconfig | 1 + configs/r7780mp_defconfig | 1 + configs/sh7763rdp_defconfig | 1 + configs/sh7785lcr_32bit_defconfig | 1 + configs/sh7785lcr_defconfig | 1 + configs/socrates_defconfig | 1 + configs/spear300_defconfig | 1 + configs/spear300_usbtty_defconfig | 1 + configs/spear310_defconfig | 1 + configs/spear310_pnor_defconfig | 1 + configs/spear310_usbtty_defconfig | 1 + configs/spear310_usbtty_pnor_defconfig | 1 + configs/spear320_defconfig | 1 + configs/spear320_pnor_defconfig | 1 + configs/spear320_usbtty_defconfig | 1 + configs/spear320_usbtty_pnor_defconfig | 1 + configs/spear600_defconfig | 1 + configs/spear600_usbtty_defconfig | 1 + configs/stm32f429-discovery_defconfig | 1 + configs/vct_platinum_defconfig | 1 + configs/vct_platinum_small_defconfig | 1 + configs/vct_platinumavc_defconfig | 1 + configs/vct_platinumavc_small_defconfig | 1 + configs/vct_premium_defconfig | 1 + configs/vct_premium_small_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/vexpress_aemv8a_dram_defconfig | 1 + configs/vexpress_aemv8a_juno_defconfig | 1 + configs/vexpress_aemv8a_semi_defconfig | 1 + configs/vexpress_ca15_tc2_defconfig | 1 + configs/vexpress_ca5x2_defconfig | 1 + configs/vexpress_ca9x4_defconfig | 1 + configs/vme8349_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + configs/x600_defconfig | 1 + configs/xpedite550x_defconfig | 1 + configs/xtfpga_defconfig | 1 + configs/zipitz2_defconfig | 1 + configs/zmx25_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + env/Kconfig | 71 +++++++++++++++++++++++++++ include/config_fsl_chain_trust.h | 1 - include/configs/10m50_devboard.h | 1 - include/configs/3c120_devboard.h | 1 - include/configs/B4860QDS.h | 1 - include/configs/BSC9132QDS.h | 1 - include/configs/C29XPCIE.h | 1 - include/configs/M5208EVBE.h | 1 - include/configs/M52277EVB.h | 2 - include/configs/M5235EVB.h | 1 - include/configs/M5249EVB.h | 2 - include/configs/M5253DEMO.h | 2 - include/configs/M5253EVBE.h | 2 - include/configs/M5272C3.h | 2 - include/configs/M5275EVB.h | 2 - include/configs/M5282EVB.h | 1 - include/configs/M53017EVB.h | 1 - include/configs/M5329EVB.h | 1 - include/configs/M5373EVB.h | 1 - include/configs/M54451EVB.h | 1 - include/configs/M54455EVB.h | 2 - include/configs/M5475EVB.h | 1 - include/configs/M5485EVB.h | 1 - include/configs/MCR3000.h | 1 - include/configs/MPC8308RDB.h | 1 - include/configs/MPC8313ERDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC8323ERDB.h | 1 - include/configs/MPC832XEMDS.h | 1 - include/configs/MPC8349EMDS.h | 1 - include/configs/MPC8349ITX.h | 1 - include/configs/MPC837XEMDS.h | 1 - include/configs/MPC837XERDB.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8540ADS.h | 1 - include/configs/MPC8541CDS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8548CDS.h | 1 - include/configs/MPC8555CDS.h | 1 - include/configs/MPC8560ADS.h | 1 - include/configs/MPC8568MDS.h | 1 - include/configs/MPC8569MDS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/MigoR.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P1022DS.h | 1 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240QDS.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/TQM834x.h | 1 - include/configs/UCP1020.h | 2 - include/configs/adp-ae3xx.h | 1 - include/configs/adp-ag101p.h | 1 - include/configs/am335x_evm.h | 1 - include/configs/amcore.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/astro_mcf5373l.h | 2 - include/configs/at91rm9200ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/bav335x.h | 1 - include/configs/blanche.h | 1 - include/configs/boston.h | 1 - include/configs/calimain.h | 1 - include/configs/cobra5272.h | 2 - include/configs/colibri_pxa270.h | 2 - include/configs/corenet_ds.h | 1 - include/configs/da850evm.h | 3 -- include/configs/dra7xx_evm.h | 1 - include/configs/ea20.h | 1 - include/configs/eb_cpu5282.h | 1 - include/configs/ecovec.h | 1 - include/configs/edb93xx.h | 1 - include/configs/edminiv2.h | 1 - include/configs/espt.h | 1 - include/configs/flea3.h | 2 - include/configs/hrcon.h | 1 - include/configs/ids8313.h | 1 - include/configs/imx27lite-common.h | 1 - include/configs/integratorcp.h | 1 - include/configs/km/km83xx-common.h | 1 - include/configs/kzm9g.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/malta.h | 1 - include/configs/mccmon6.h | 1 - include/configs/microblaze-generic.h | 1 - include/configs/mpc8308_p1m.h | 1 - include/configs/mpr2.h | 1 - include/configs/ms7720se.h | 1 - include/configs/ms7722se.h | 1 - include/configs/ms7750se.h | 1 - include/configs/mx31ads.h | 1 - include/configs/mx35pdk.h | 2 - include/configs/omapl138_lcdk.h | 4 -- include/configs/p1_p2_rdb_pc.h | 1 - include/configs/p1_twr.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/qemu-mips.h | 2 - include/configs/qemu-mips64.h | 2 - include/configs/r0p7734.h | 1 - include/configs/r2dplus.h | 1 - include/configs/r7780mp.h | 1 - include/configs/rsk7203.h | 1 - include/configs/rsk7264.h | 1 - include/configs/rsk7269.h | 1 - include/configs/sbc8349.h | 1 - include/configs/sbc8548.h | 1 - include/configs/sbc8641d.h | 1 - include/configs/sh7763rdp.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/shmin.h | 1 - include/configs/socrates.h | 1 - include/configs/spear3xx_evb.h | 5 -- include/configs/spear6xx_evb.h | 5 -- include/configs/stm32f429-discovery.h | 1 - include/configs/strider.h | 1 - include/configs/vct.h | 1 - include/configs/ve8313.h | 1 - include/configs/vexpress_aemv8a.h | 1 - include/configs/vexpress_common.h | 1 - include/configs/vme8349.h | 1 - include/configs/woodburn_common.h | 2 - include/configs/x600.h | 2 - include/configs/xpedite517x.h | 1 - include/configs/xpedite520x.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - include/configs/xtfpga.h | 1 - include/configs/zipitz2.h | 1 - include/configs/zmx25.h | 1 - include/configs/zynq-common.h | 1 - scripts/config_whitelist.txt | 1 - 339 files changed, 282 insertions(+), 250 deletions(-)
diff --git a/README b/README index 3db9c2dd87..caf35a10b2 100644 --- a/README +++ b/README @@ -3432,76 +3432,6 @@ following configurations: Builds up envcrc with the target environment so that external utils may easily extract it and embed it in final U-Boot images.
-- CONFIG_ENV_IS_IN_FLASH: - - Define this if the environment is in flash memory. - - a) The environment occupies one whole flash sector, which is - "embedded" in the text segment with the U-Boot code. This - happens usually with "bottom boot sector" or "top boot - sector" type flash chips, which have several smaller - sectors at the start or the end. For instance, such a - layout can have sector sizes of 8, 2x4, 16, Nx32 kB. In - such a case you would place the environment in one of the - 4 kB sectors - with U-Boot code before and after it. With - "top boot sector" type flash chips, you would put the - environment in one of the last sectors, leaving a gap - between U-Boot and the environment. - - - CONFIG_ENV_OFFSET: - - Offset of environment data (variable area) to the - beginning of flash memory; for instance, with bottom boot - type flash chips the second sector can be used: the offset - for this sector is given here. - - CONFIG_ENV_OFFSET is used relative to CONFIG_SYS_FLASH_BASE. - - - CONFIG_ENV_ADDR: - - This is just another way to specify the start address of - the flash sector containing the environment (instead of - CONFIG_ENV_OFFSET). - - - CONFIG_ENV_SECT_SIZE: - - Size of the sector containing the environment. - - - b) Sometimes flash chips have few, equal sized, BIG sectors. - In such a case you don't want to spend a whole sector for - the environment. - - - CONFIG_ENV_SIZE: - - If you use this in combination with CONFIG_ENV_IS_IN_FLASH - and CONFIG_ENV_SECT_SIZE, you can specify to use only a part - of this flash sector for the environment. This saves - memory for the RAM copy of the environment. - - It may also save flash memory if you decide to use this - when your environment is "embedded" within U-Boot code, - since then the remainder of the flash sector could be used - for U-Boot code. It should be pointed out that this is - STRONGLY DISCOURAGED from a robustness point of view: - updating the environment in flash makes it always - necessary to erase the WHOLE sector. If something goes - wrong before the contents has been restored from a copy in - RAM, your target system will be dead. - - - CONFIG_ENV_ADDR_REDUND - CONFIG_ENV_SIZE_REDUND - - These settings describe a second storage area used to hold - a redundant copy of the environment data, so that there is - a valid backup copy in case there is a power failure during - a "saveenv" operation. - -BE CAREFUL! Any changes to the flash layout, and some changes to the -source code will make it necessary to adapt <board>/u-boot.lds* -accordingly! - - - CONFIG_ENV_IS_IN_NVRAM:
Define this if you have some non-volatile memory device diff --git a/arch/arm/mach-integrator/Kconfig b/arch/arm/mach-integrator/Kconfig index d506ee5b39..5146e51f9c 100644 --- a/arch/arm/mach-integrator/Kconfig +++ b/arch/arm/mach-integrator/Kconfig @@ -11,11 +11,13 @@ config ARCH_INTEGRATOR_AP config ARCH_INTEGRATOR_CP bool "Support Integrator/CP platform" select ARCH_CINTEGRATOR + imply ENV_IS_IN_FLASH
endchoice
config ARCH_CINTEGRATOR bool + imply ENV_IS_IN_FLASH
choice prompt "Integrator core module select" diff --git a/arch/m68k/Kconfig b/arch/m68k/Kconfig index 26509b73c6..88e7d6a7b6 100644 --- a/arch/m68k/Kconfig +++ b/arch/m68k/Kconfig @@ -10,6 +10,7 @@ config MCF520x
config MCF52x2 bool + imply ENV_IS_IN_FLASH
config MCF523x bool @@ -22,6 +23,7 @@ config MCF5301x
config MCF532x bool + imply ENV_IS_IN_FLASH
config MCF537x bool @@ -37,6 +39,7 @@ config MCF5227x
config MCF547x_8x bool + imply ENV_IS_IN_FLASH
# processor type config M5208 @@ -70,6 +73,7 @@ config M5275 config M5282 bool select MCF52x2 + imply ENV_IS_IN_FLASH
config M5307 bool @@ -107,10 +111,12 @@ config M52277 config M547x bool select MCF547x_8x + imply ENV_IS_IN_FLASH
config M548x bool select MCF547x_8x + imply ENV_IS_IN_FLASH
choice prompt "Target select" @@ -191,10 +197,12 @@ config TARGET_M54455EVB config TARGET_M5475EVB bool "Support M5475EVB" select M547x + imply ENV_IS_IN_FLASH
config TARGET_M5485EVB bool "Support M5485EVB" select M548x + imply ENV_IS_IN_FLASH
config TARGET_AMCORE bool "Support AMCORE" diff --git a/arch/microblaze/Kconfig b/arch/microblaze/Kconfig index 80d85e46d4..20fa25b5cc 100644 --- a/arch/microblaze/Kconfig +++ b/arch/microblaze/Kconfig @@ -15,6 +15,7 @@ config TARGET_MICROBLAZE_GENERIC select OF_CONTROL select DM select DM_SERIAL + select ENV_IS_IN_FLASH
endchoice
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 579371e8ee..b53206bf8e 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -21,6 +21,7 @@ config TARGET_QEMU_MIPS select SUPPORTS_CPU_MIPS64_R1 select SUPPORTS_CPU_MIPS64_R2 select ROM_EXCEPTION_VECTORS + imply ENV_IS_IN_FLASH
config TARGET_MALTA bool "Support malta" @@ -42,6 +43,7 @@ config TARGET_MALTA select SWAP_IO_SPACE select MIPS_L1_CACHE_SHIFT_6 select ROM_EXCEPTION_VECTORS + imply ENV_IS_IN_FLASH
config TARGET_VCT bool "Support vct" @@ -108,6 +110,7 @@ config TARGET_BOSTON select SUPPORTS_CPU_MIPS64_R2 select SUPPORTS_CPU_MIPS64_R6 select ROM_EXCEPTION_VECTORS + imply ENV_IS_IN_FLASH
config TARGET_XILFPGA bool "Support Imagination Xilfpga" @@ -197,6 +200,7 @@ config CPU_MIPS64_R2 bool "MIPS64 Release 2" depends on SUPPORTS_CPU_MIPS64_R2 select 64BIT + imply ENV_IS_IN_FLASH help Choose this option to build a kernel for release 2 through 5 of the MIPS64 architecture. diff --git a/arch/powerpc/Kconfig b/arch/powerpc/Kconfig index e9002a76ab..8094416e4a 100644 --- a/arch/powerpc/Kconfig +++ b/arch/powerpc/Kconfig @@ -28,6 +28,7 @@ config MPC86xx bool "MPC86xx" select SYS_FSL_DDR select SYS_FSL_DDR_BE + imply ENV_IS_IN_FLASH
config 8xx bool "MPC8xx" diff --git a/arch/powerpc/cpu/mpc83xx/Kconfig b/arch/powerpc/cpu/mpc83xx/Kconfig index cdd21a253a..b5b26f9b3a 100644 --- a/arch/powerpc/cpu/mpc83xx/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/Kconfig @@ -13,6 +13,7 @@ config TARGET_MPC8308_P1M
config TARGET_SBC8349 bool "Support sbc8349" + imply ENV_IS_IN_FLASH
config TARGET_VE8313 bool "Support ve8313" @@ -39,6 +40,7 @@ config TARGET_MPC8323ERDB config TARGET_MPC832XEMDS bool "Support MPC832XEMDS" select BOARD_EARLY_INIT_F + imply ENV_IS_IN_FLASH
config TARGET_MPC8349EMDS bool "Support MPC8349EMDS" @@ -50,6 +52,7 @@ config TARGET_MPC8349EMDS config TARGET_MPC8349ITX bool "Support MPC8349ITX" imply CMD_IRQ + imply ENV_IS_IN_FLASH
config TARGET_MPC837XEMDS bool "Support MPC837XEMDS" @@ -74,11 +77,13 @@ config TARGET_SUVD3 bool "Support suvd3" imply CMD_CRAMFS imply FS_CRAMFS + imply ENV_IS_IN_FLASH
config TARGET_TUXX1 bool "Support tuxx1" imply CMD_CRAMFS imply FS_CRAMFS + imply ENV_IS_IN_FLASH
config TARGET_TQM834X bool "Support TQM834x" @@ -90,6 +95,7 @@ config TARGET_HRCON config TARGET_STRIDER bool "Support strider" select SYS_FSL_ERRATUM_ESDHC111 + imply ENV_IS_IN_FLASH
endchoice
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 0bff79adbb..942907c7c3 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -19,6 +19,7 @@ choice config TARGET_SBC8548 bool "Support sbc8548" select ARCH_MPC8548 + imply ENV_IS_IN_FLASH
config TARGET_SOCRATES bool "Support socrates" @@ -104,6 +105,7 @@ config TARGET_MPC8544DS config TARGET_MPC8548CDS bool "Support MPC8548CDS" select ARCH_MPC8548 + imply ENV_IS_IN_FLASH
config TARGET_MPC8555CDS bool "Support MPC8555CDS" @@ -548,6 +550,7 @@ config ARCH_MPC8548 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + imply ENV_IS_IN_FLASH
config ARCH_MPC8555 bool @@ -595,6 +598,7 @@ config ARCH_MPC8572 select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB select FSL_ELBC + imply ENV_IS_IN_FLASH
config ARCH_P1010 bool diff --git a/arch/powerpc/cpu/mpc86xx/Kconfig b/arch/powerpc/cpu/mpc86xx/Kconfig index 2cc180da38..fe56efdf55 100644 --- a/arch/powerpc/cpu/mpc86xx/Kconfig +++ b/arch/powerpc/cpu/mpc86xx/Kconfig @@ -40,6 +40,7 @@ config ARCH_MPC8641 select FSL_LAW select SYS_FSL_HAS_DDR1 select SYS_FSL_HAS_DDR2 + imply ENV_IS_IN_FLASH
config FSL_LAW bool diff --git a/arch/sh/Kconfig b/arch/sh/Kconfig index 6ac22af2f1..1d40fe6845 100644 --- a/arch/sh/Kconfig +++ b/arch/sh/Kconfig @@ -3,13 +3,16 @@ menu "SuperH architecture"
config CPU_SH2 bool + imply ENV_IS_IN_FLASH
config CPU_SH2A bool select CPU_SH2 + imply ENV_IS_IN_FLASH
config CPU_SH3 bool + imply ENV_IS_IN_FLASH
config CPU_SH4 bool diff --git a/configs/10m50_defconfig b/configs/10m50_defconfig index ed9a867d72..1252029dc5 100644 --- a/configs/10m50_defconfig +++ b/configs/10m50_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y diff --git a/configs/3c120_defconfig b/configs/3c120_defconfig index 95e794afca..299fcbb829 100644 --- a/configs/3c120_defconfig +++ b/configs/3c120_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_ALTERA_PIO=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index a64bc6bdb6..23a2427e77 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index 80e06fb0d6..83577b76fd 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig index f07841feab..0293abb871 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig index ae753405ec..2101022b6d 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index 70b447863d..9ca62460ef 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 1ac3e5e846..5756f82383 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -8,4 +8,5 @@ CONFIG_SYS_PROMPT="-> " CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/M52277EVB_defconfig b/configs/M52277EVB_defconfig index 903eef536c..7cc64d6dc6 100644 --- a/configs/M52277EVB_defconfig +++ b/configs/M52277EVB_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M5235EVB_Flash32_defconfig b/configs/M5235EVB_Flash32_defconfig index 19596cbeb1..c3bf2d5ccc 100644 --- a/configs/M5235EVB_Flash32_defconfig +++ b/configs/M5235EVB_Flash32_defconfig @@ -12,4 +12,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index 026177db4c..0c4869d8e9 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -12,4 +12,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index 19b1fcd237..727c89cf0d 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -9,4 +9,5 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/M54451EVB_defconfig b/configs/M54451EVB_defconfig index 63c1a4bbe6..19670d9372 100644 --- a/configs/M54451EVB_defconfig +++ b/configs/M54451EVB_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_a66_defconfig b/configs/M54455EVB_a66_defconfig index 221c70750b..9f0e8936fd 100644 --- a/configs/M54455EVB_a66_defconfig +++ b/configs/M54455EVB_a66_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_defconfig b/configs/M54455EVB_defconfig index 557b87b78c..cd046dfb04 100644 --- a/configs/M54455EVB_defconfig +++ b/configs/M54455EVB_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_i66_defconfig b/configs/M54455EVB_i66_defconfig index 9ad0564788..f2924d2502 100644 --- a/configs/M54455EVB_i66_defconfig +++ b/configs/M54455EVB_i66_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_intel_defconfig b/configs/M54455EVB_intel_defconfig index dc7af6cb19..ac33bb20d7 100644 --- a/configs/M54455EVB_intel_defconfig +++ b/configs/M54455EVB_intel_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/MCR3000_defconfig b/configs/MCR3000_defconfig index 84849684e4..7c935fa26a 100644 --- a/configs/MCR3000_defconfig +++ b/configs/MCR3000_defconfig @@ -60,6 +60,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8308RDB_defconfig b/configs/MPC8308RDB_defconfig index c0f994a5ea..29e865f343 100644 --- a/configs/MPC8308RDB_defconfig +++ b/configs/MPC8308RDB_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_33_defconfig b/configs/MPC8313ERDB_33_defconfig index f4bdfe046d..c5aebfff10 100644 --- a/configs/MPC8313ERDB_33_defconfig +++ b/configs/MPC8313ERDB_33_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8313ERDB_66_defconfig b/configs/MPC8313ERDB_66_defconfig index 119c04e661..53db7c2efc 100644 --- a/configs/MPC8313ERDB_66_defconfig +++ b/configs/MPC8313ERDB_66_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8315ERDB_defconfig b/configs/MPC8315ERDB_defconfig index 32b88fc9d5..47dbef15bc 100644 --- a/configs/MPC8315ERDB_defconfig +++ b/configs/MPC8315ERDB_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8323ERDB_defconfig b/configs/MPC8323ERDB_defconfig index 54d8a3ea1d..f3c840bf4f 100644 --- a/configs/MPC8323ERDB_defconfig +++ b/configs/MPC8323ERDB_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_EEPROM=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8349EMDS_defconfig b/configs/MPC8349EMDS_defconfig index 82a61f8883..664246b2cd 100644 --- a/configs/MPC8349EMDS_defconfig +++ b/configs/MPC8349EMDS_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y # CONFIG_PCI is not set diff --git a/configs/MPC837XEMDS_HOST_defconfig b/configs/MPC837XEMDS_HOST_defconfig index 787ac9dbce..71683cfbf9 100644 --- a/configs/MPC837XEMDS_HOST_defconfig +++ b/configs/MPC837XEMDS_HOST_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/MPC837XEMDS_defconfig b/configs/MPC837XEMDS_defconfig index f76cec1104..d292299117 100644 --- a/configs/MPC837XEMDS_defconfig +++ b/configs/MPC837XEMDS_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y # CONFIG_PCI is not set CONFIG_SYS_NS16550=y diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index fc21671ce7..dd661e2af0 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index 5db680bbd1..b79f568be9 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_FSL_DDR2=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index 3c563d6ff9..96695117e0 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_FSL_DDR2=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/MPC8541CDS_defconfig b/configs/MPC8541CDS_defconfig index 8268388d84..13646d7103 100644 --- a/configs/MPC8541CDS_defconfig +++ b/configs/MPC8541CDS_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8541CDS_legacy_defconfig b/configs/MPC8541CDS_legacy_defconfig index 09a9c0f90b..c9916dea47 100644 --- a/configs/MPC8541CDS_legacy_defconfig +++ b/configs/MPC8541CDS_legacy_defconfig @@ -11,6 +11,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index cb15afa9cc..e5429cdee2 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -15,12 +15,13 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y -CONFIG_SCSI=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_RTL8139=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/MPC8555CDS_defconfig b/configs/MPC8555CDS_defconfig index 00c7a76508..1fbdb98ba2 100644 --- a/configs/MPC8555CDS_defconfig +++ b/configs/MPC8555CDS_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8555CDS_legacy_defconfig b/configs/MPC8555CDS_legacy_defconfig index 36da612318..5c9eda4166 100644 --- a/configs/MPC8555CDS_legacy_defconfig +++ b/configs/MPC8555CDS_legacy_defconfig @@ -11,6 +11,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8568MDS_defconfig b/configs/MPC8568MDS_defconfig index 6e3cfa16f2..0c94088555 100644 --- a/configs/MPC8568MDS_defconfig +++ b/configs/MPC8568MDS_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8569MDS_ATM_defconfig b/configs/MPC8569MDS_ATM_defconfig index 6adb9cf087..9ce4e25af3 100644 --- a/configs/MPC8569MDS_ATM_defconfig +++ b/configs/MPC8569MDS_ATM_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/MPC8569MDS_defconfig b/configs/MPC8569MDS_defconfig index 73cf6e35b7..f923b353d8 100644 --- a/configs/MPC8569MDS_defconfig +++ b/configs/MPC8569MDS_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 6aef6d8434..57d8583fd1 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -15,9 +15,9 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y -CONFIG_SCSI=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y diff --git a/configs/MigoR_defconfig b/configs/MigoR_defconfig index f09794e13c..e0d4ab4138 100644 --- a/configs/MigoR_defconfig +++ b/configs/MigoR_defconfig @@ -18,5 +18,6 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 48157c22a4..2226558ec1 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index e94feb5997..7db3a968e9 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 53b5d732e4..4e923e5e71 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 35e85306fc..045c72c9ba 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1020MBG-PC_36BIT_defconfig b/configs/P1020MBG-PC_36BIT_defconfig index c8df31d1a0..89ff048771 100644 --- a/configs/P1020MBG-PC_36BIT_defconfig +++ b/configs/P1020MBG-PC_36BIT_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/P1020MBG-PC_defconfig b/configs/P1020MBG-PC_defconfig index a9bae76a4b..614cbf92ef 100644 --- a/configs/P1020MBG-PC_defconfig +++ b/configs/P1020MBG-PC_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 8e275e0bd5..2caa40dd6f 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 11f5961bd4..082de27479 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 30257b64f5..56bd76cae8 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020UTM-PC_36BIT_defconfig b/configs/P1020UTM-PC_36BIT_defconfig index 031a7f2ced..2e446e173a 100644 --- a/configs/P1020UTM-PC_36BIT_defconfig +++ b/configs/P1020UTM-PC_36BIT_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/P1020UTM-PC_defconfig b/configs/P1020UTM-PC_defconfig index c6e12d6c35..6f5f98e8d6 100644 --- a/configs/P1020UTM-PC_defconfig +++ b/configs/P1020UTM-PC_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/P1021RDB-PC_36BIT_defconfig b/configs/P1021RDB-PC_36BIT_defconfig index 42ab8b95b1..ec9ae39c95 100644 --- a/configs/P1021RDB-PC_36BIT_defconfig +++ b/configs/P1021RDB-PC_36BIT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1021RDB-PC_defconfig b/configs/P1021RDB-PC_defconfig index 6aff0a0a9d..fb75fd2310 100644 --- a/configs/P1021RDB-PC_defconfig +++ b/configs/P1021RDB-PC_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index 58335cbab0..62d6e15867 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index c0864a44e9..e574f60815 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig index c53b7e0819..57cb6dad4c 100644 --- a/configs/P1023RDB_defconfig +++ b/configs/P1023RDB_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_36BIT_defconfig b/configs/P1024RDB_36BIT_defconfig index 5b2773abc6..8046445cc2 100644 --- a/configs/P1024RDB_36BIT_defconfig +++ b/configs/P1024RDB_36BIT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1024RDB_defconfig b/configs/P1024RDB_defconfig index 56bd118dd5..d1c70be4e0 100644 --- a/configs/P1024RDB_defconfig +++ b/configs/P1024RDB_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1025RDB_36BIT_defconfig b/configs/P1025RDB_36BIT_defconfig index 50ac75d701..94c093e7f9 100644 --- a/configs/P1025RDB_36BIT_defconfig +++ b/configs/P1025RDB_36BIT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1025RDB_defconfig b/configs/P1025RDB_defconfig index 22bfb2edcf..b24f73a950 100644 --- a/configs/P1025RDB_defconfig +++ b/configs/P1025RDB_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index e40e371bf5..f7abc19080 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index df1dbffaa4..bc218af1cb 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index d47c7873c1..48dd991db7 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index d8276c7b6d..2998961b18 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index ec3d6f9304..747b469362 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5020DS_defconfig b/configs/P5020DS_defconfig index 55e0dbdf90..c26981fe86 100644 --- a/configs/P5020DS_defconfig +++ b/configs/P5020DS_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index b56c86eec8..9ae5c15fab 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1023RDB_defconfig b/configs/T1023RDB_defconfig index 43853e7f85..33a4b27351 100644 --- a/configs/T1023RDB_defconfig +++ b/configs/T1023RDB_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index 7a57b08085..6e44f10325 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index b09e9a026d..2c726f49a0 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index da924d8f54..806a1cb741 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index 82d6140518..191b0de6ab 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 063ae20c83..e4b802eb7a 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 5d8cdf1383..98f714ff6e 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 7d6ed1bb72..743e54ff7a 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 410a124908..47ad7b769a 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index bad51b5534..7ac54cd15d 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index ba8b11c570..4f3e354aab 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index 09dc9e2619..a39209dd3d 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 424eda104e..47b9fdfb24 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2081QDS_defconfig b/configs/T2081QDS_defconfig index 9afc426211..ea88175906 100644 --- a/configs/T2081QDS_defconfig +++ b/configs/T2081QDS_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4160QDS_defconfig b/configs/T4160QDS_defconfig index 93411bab86..4e817308d9 100644 --- a/configs/T4160QDS_defconfig +++ b/configs/T4160QDS_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4160RDB_defconfig b/configs/T4160RDB_defconfig index 356e2d861e..33c10c1fcb 100644 --- a/configs/T4160RDB_defconfig +++ b/configs/T4160RDB_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4240QDS_defconfig b/configs/T4240QDS_defconfig index 6061244a43..08607974ae 100644 --- a/configs/T4240QDS_defconfig +++ b/configs/T4240QDS_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 6c023337a6..d9def12bd8 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/TQM834x_defconfig b/configs/TQM834x_defconfig index ef73ed40c8..f704025e76 100644 --- a/configs/TQM834x_defconfig +++ b/configs/TQM834x_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/TWR-P1025_defconfig b/configs/TWR-P1025_defconfig index e210643aa4..5f78a53664 100644 --- a/configs/TWR-P1025_defconfig +++ b/configs/TWR-P1025_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index dbf073d774..f796163297 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_CRAMFS=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/adp-ae3xx_defconfig b/configs/adp-ae3xx_defconfig index d47ad86fee..9e1e5ecb47 100644 --- a/configs/adp-ae3xx_defconfig +++ b/configs/adp-ae3xx_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MMC=y diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 6ce9e809dd..ced042e49f 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MMC=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 7e80c56953..bbad4a2152 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -16,6 +16,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x81000000 CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/amcore_defconfig b/configs/amcore_defconfig index e8c6adccb4..48ef25b521 100644 --- a/configs/amcore_defconfig +++ b/configs/amcore_defconfig @@ -16,6 +16,7 @@ CONFIG_LOOPW=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIMER=y CONFIG_CMD_DIAG=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_DM_SERIAL=y diff --git a/configs/ap325rxa_defconfig b/configs/ap325rxa_defconfig index ebefd126a8..bd79f7e3ac 100644 --- a/configs/ap325rxa_defconfig +++ b/configs/ap325rxa_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_BAUDRATE=38400 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ap_sh4a_4a_defconfig b/configs/ap_sh4a_4a_defconfig index 41c8be9120..364927c528 100644 --- a/configs/ap_sh4a_4a_defconfig +++ b/configs/ap_sh4a_4a_defconfig @@ -21,5 +21,6 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/armadillo-800eva_defconfig b/configs/armadillo-800eva_defconfig index 4c16ec19fd..c07abc71b8 100644 --- a/configs/armadillo-800eva_defconfig +++ b/configs/armadillo-800eva_defconfig @@ -25,5 +25,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 0abfeab1e6..cb6c70bf2e 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_USB=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 545b24a9b1..28051aa652 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_USB=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 66484a18f2..aa2d6ae297 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 1e177480c9..a405e7003d 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index bf7700cbe1..0c9384c95b 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index 007cce1075..863d5c086e 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -11,6 +11,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index 48422ddffe..89c9e9c9fb 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DIAG=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig index ddf4bf655e..7f8c97574a 100644 --- a/configs/colibri_pxa270_defconfig +++ b/configs/colibri_pxa270_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_MTD_NOR_FLASH=y CONFIG_DM_SERIAL=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 99543d39e1..2490fda402 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DIAG=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/ecovec_defconfig b/configs/ecovec_defconfig index cc172f5181..43c9d26a04 100644 --- a/configs/ecovec_defconfig +++ b/configs/ecovec_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index bb67881a25..a854477665 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y # CONFIG_DOS_PARTITION is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=0 diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index d67b548977..8e6b9d2421 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_EXT2=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/espt_defconfig b/configs/espt_defconfig index a6a7af9755..ef496a9111 100644 --- a/configs/espt_defconfig +++ b/configs/espt_defconfig @@ -21,5 +21,6 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 8a64386319..48c1e684f0 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_OF_LIBFDT=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index aea06769f4..2cfc343830 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index 8e911d49a0..5b24a6f270 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 2a8c239d69..c33f6f4a49 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y # CONFIG_PCI is not set diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index db93dee323..2e518dbc1e 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y # CONFIG_PCI is not set diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 163f4f927d..00bad22dda 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y # CONFIG_PCI is not set diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index a884e5a10c..fe9f226c42 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -11,6 +11,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y # CONFIG_FAT_WRITE is not set diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index e753f4c589..087022e058 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index ed03812a92..cece5b1720 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 6b435cc4d5..3018c101ec 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 8fdd8b63db..07395c9853 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index c56533af3b..bcf4033161 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 89b89cd211..9e17a9881a 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 37662082c6..7640c1a3c4 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index ed125d7494..ace95becdb 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 6974a58797..bac2e3e90c 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 894110bd1e..b2987aa1a6 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 87df2fec9b..1fd98fcd8d 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 47dba49fbd..4d373178cf 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 0106e9ad0d..b930e61ba7 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index ed79c97121..ab7539075e 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index acc43ad94a..60147cbee9 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 61c436e22c..8e347987b1 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 4a137007bf..d787a310b6 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_NETCONSOLE=y CONFIG_SPL_DM=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/mpc8308_p1m_defconfig b/configs/mpc8308_p1m_defconfig index ee92e4fb83..5b5336c9a3 100644 --- a/configs/mpc8308_p1m_defconfig +++ b/configs/mpc8308_p1m_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/ms7722se_defconfig b/configs/ms7722se_defconfig index 92f3158dae..f2e5032521 100644 --- a/configs/ms7722se_defconfig +++ b/configs/ms7722se_defconfig @@ -21,5 +21,6 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_JFFS2=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ms7750se_defconfig b/configs/ms7750se_defconfig index 88bbb12003..6185fbe135 100644 --- a/configs/ms7750se_defconfig +++ b/configs/ms7750se_defconfig @@ -21,6 +21,7 @@ CONFIG_BOOTDELAY=-1 # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_BAUDRATE=38400 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/mx31ads_defconfig b/configs/mx31ads_defconfig index c9ba6975f8..098a763550 100644 --- a/configs/mx31ads_defconfig +++ b/configs/mx31ads_defconfig @@ -6,5 +6,6 @@ CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 0da348adff..7e0a06a1c4 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index ba079de6dc..04d636e0af 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_USB=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 7cf2722740..b57de5d423 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_JFFS2=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_USB=y diff --git a/configs/r0p7734_defconfig b/configs/r0p7734_defconfig index 91b08dc24f..fc1b8445ff 100644 --- a/configs/r0p7734_defconfig +++ b/configs/r0p7734_defconfig @@ -21,5 +21,6 @@ CONFIG_VERSION_VARIABLE=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index ba68b504d0..9ec4f7033a 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -7,6 +7,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_NETDEVICES=y CONFIG_RTL8139=y diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index 2a37db824d..34a1fb8ebf 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_PCI=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7763rdp_defconfig b/configs/sh7763rdp_defconfig index 028616666c..b663f69904 100644 --- a/configs/sh7763rdp_defconfig +++ b/configs/sh7763rdp_defconfig @@ -22,5 +22,6 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_JFFS2=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7785lcr_32bit_defconfig b/configs/sh7785lcr_32bit_defconfig index 8cb58e9d18..f556adcddd 100644 --- a/configs/sh7785lcr_32bit_defconfig +++ b/configs/sh7785lcr_32bit_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_MAC_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_PCI=y CONFIG_USB=y diff --git a/configs/sh7785lcr_defconfig b/configs/sh7785lcr_defconfig index 5b6ebf8528..7e74c1252e 100644 --- a/configs/sh7785lcr_defconfig +++ b/configs/sh7785lcr_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_MAC_PARTITION=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_PCI=y CONFIG_USB=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 5def6d5991..2e3cce09fe 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/spear300_defconfig b/configs/spear300_defconfig index 300bc08d5d..f9916ff60a 100644 --- a/configs/spear300_defconfig +++ b/configs/spear300_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear300_usbtty_defconfig b/configs/spear300_usbtty_defconfig index 99a72a0cab..e0657ae86d 100644 --- a/configs/spear300_usbtty_defconfig +++ b/configs/spear300_usbtty_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear310_defconfig b/configs/spear310_defconfig index d93f8fcf5e..6eb9c7ac50 100644 --- a/configs/spear310_defconfig +++ b/configs/spear310_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear310_pnor_defconfig b/configs/spear310_pnor_defconfig index 78a558bc42..91fa35ca84 100644 --- a/configs/spear310_pnor_defconfig +++ b/configs/spear310_pnor_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear310_usbtty_defconfig b/configs/spear310_usbtty_defconfig index 92d24794f9..3cc362895d 100644 --- a/configs/spear310_usbtty_defconfig +++ b/configs/spear310_usbtty_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear310_usbtty_pnor_defconfig b/configs/spear310_usbtty_pnor_defconfig index f922e8fd9f..5a174e6223 100644 --- a/configs/spear310_usbtty_pnor_defconfig +++ b/configs/spear310_usbtty_pnor_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_defconfig b/configs/spear320_defconfig index dd1798fdfe..efb494ed60 100644 --- a/configs/spear320_defconfig +++ b/configs/spear320_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_pnor_defconfig b/configs/spear320_pnor_defconfig index 1ed8e83bc2..f02af74a2c 100644 --- a/configs/spear320_pnor_defconfig +++ b/configs/spear320_pnor_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_usbtty_defconfig b/configs/spear320_usbtty_defconfig index ff897822aa..613654cf59 100644 --- a/configs/spear320_usbtty_defconfig +++ b/configs/spear320_usbtty_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear320_usbtty_pnor_defconfig b/configs/spear320_usbtty_pnor_defconfig index bc8f0e20f5..adee03aa15 100644 --- a/configs/spear320_usbtty_pnor_defconfig +++ b/configs/spear320_usbtty_pnor_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear600_defconfig b/configs/spear600_defconfig index 7b8cd06297..c83dc606f3 100644 --- a/configs/spear600_defconfig +++ b/configs/spear600_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/spear600_usbtty_defconfig b/configs/spear600_usbtty_defconfig index ef9308c368..88cdc6831a 100644 --- a/configs/spear600_usbtty_defconfig +++ b/configs/spear600_usbtty_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index 751e485b49..19363f7e7d 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIMER=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_OF_LIBFDT=y diff --git a/configs/vct_platinum_defconfig b/configs/vct_platinum_defconfig index f8b9d7e61b..0e4fcbaa26 100644 --- a/configs/vct_platinum_defconfig +++ b/configs/vct_platinum_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/vct_platinum_small_defconfig b/configs/vct_platinum_small_defconfig index 2b49d4c9a0..eafece0723 100644 --- a/configs/vct_platinum_small_defconfig +++ b/configs/vct_platinum_small_defconfig @@ -18,5 +18,6 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_defconfig b/configs/vct_platinumavc_defconfig index 5efe2236a3..ebbf6c1a02 100644 --- a/configs/vct_platinumavc_defconfig +++ b/configs/vct_platinumavc_defconfig @@ -11,5 +11,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_small_defconfig b/configs/vct_platinumavc_small_defconfig index 1b5c125893..f7823ef050 100644 --- a/configs/vct_platinumavc_small_defconfig +++ b/configs/vct_platinumavc_small_defconfig @@ -18,5 +18,6 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_premium_defconfig b/configs/vct_premium_defconfig index 24f776b49f..f89a0a5ee5 100644 --- a/configs/vct_premium_defconfig +++ b/configs/vct_premium_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/vct_premium_small_defconfig b/configs/vct_premium_small_defconfig index 276650dbe1..0420cd15a6 100644 --- a/configs/vct_premium_small_defconfig +++ b/configs/vct_premium_small_defconfig @@ -18,5 +18,6 @@ CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index 2fdf77d80b..60eea83a27 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -10,6 +10,7 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/vexpress_aemv8a_dram_defconfig b/configs/vexpress_aemv8a_dram_defconfig index c06b989366..54794988e2 100644 --- a/configs/vexpress_aemv8a_dram_defconfig +++ b/configs/vexpress_aemv8a_dram_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index b2e3098fc4..b1363c313d 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 33639f2f8c..967a4e402d 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_CACHE=y # CONFIG_CMD_MISC is not set # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index ba489ea1d1..2907493bcb 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index fb671419c5..40ab671ef7 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 7b845c6c79..5e49e99628 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_BAUDRATE=38400 CONFIG_OF_LIBFDT=y diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index c27a44744a..609ca7df75 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -10,6 +10,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_BAUDRATE=9600 diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index 53a97078b3..c83a6ad755 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 22172c57b3..931349f5b7 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -30,4 +30,5 @@ CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index 2e5d5f1ae8..1d2758939e 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index cad0d239e9..ff6c487f92 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y diff --git a/configs/xtfpga_defconfig b/configs/xtfpga_defconfig index 9f85d63965..a9ddd139b6 100644 --- a/configs/xtfpga_defconfig +++ b/configs/xtfpga_defconfig @@ -12,6 +12,7 @@ CONFIG_CRC32_VERIFY=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_DIAG=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_DM=y # CONFIG_DM_WARN is not set # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig index 0b38f2b1af..b2815a2c7d 100644 --- a/configs/zipitz2_defconfig +++ b/configs/zipitz2_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_PXA_SERIAL=y CONFIG_USB=y diff --git a/configs/zmx25_defconfig b/configs/zmx25_defconfig index 7a939036d9..f6a2f86ef9 100644 --- a/configs/zmx25_defconfig +++ b/configs/zmx25_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FLASH=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_USB=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 943efdb141..4d9320611e 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_MMC is not set diff --git a/env/Kconfig b/env/Kconfig index 5a314022ef..5cc55f8972 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -1,5 +1,76 @@ menu "Environment"
+config ENV_IS_IN_FLASH + bool "Environment in flash memory" + help + Define this if you have a flash device which you want to use for the + environment. + + a) The environment occupies one whole flash sector, which is + "embedded" in the text segment with the U-Boot code. This + happens usually with "bottom boot sector" or "top boot + sector" type flash chips, which have several smaller + sectors at the start or the end. For instance, such a + layout can have sector sizes of 8, 2x4, 16, Nx32 kB. In + such a case you would place the environment in one of the + 4 kB sectors - with U-Boot code before and after it. With + "top boot sector" type flash chips, you would put the + environment in one of the last sectors, leaving a gap + between U-Boot and the environment. + + CONFIG_ENV_OFFSET: + + Offset of environment data (variable area) to the + beginning of flash memory; for instance, with bottom boot + type flash chips the second sector can be used: the offset + for this sector is given here. + + CONFIG_ENV_OFFSET is used relative to CONFIG_SYS_FLASH_BASE. + + CONFIG_ENV_ADDR: + + This is just another way to specify the start address of + the flash sector containing the environment (instead of + CONFIG_ENV_OFFSET). + + CONFIG_ENV_SECT_SIZE: + + Size of the sector containing the environment. + + + b) Sometimes flash chips have few, equal sized, BIG sectors. + In such a case you don't want to spend a whole sector for + the environment. + + CONFIG_ENV_SIZE: + + If you use this in combination with CONFIG_ENV_IS_IN_FLASH + and CONFIG_ENV_SECT_SIZE, you can specify to use only a part + of this flash sector for the environment. This saves + memory for the RAM copy of the environment. + + It may also save flash memory if you decide to use this + when your environment is "embedded" within U-Boot code, + since then the remainder of the flash sector could be used + for U-Boot code. It should be pointed out that this is + STRONGLY DISCOURAGED from a robustness point of view: + updating the environment in flash makes it always + necessary to erase the WHOLE sector. If something goes + wrong before the contents has been restored from a copy in + RAM, your target system will be dead. + + CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SIZE_REDUND + + These settings describe a second storage area used to hold + a redundant copy of the environment data, so that there is + a valid backup copy in case there is a power failure during + a "saveenv" operation. + + BE CAREFUL! Any changes to the flash layout, and some changes to the + source code will make it necessary to adapt <board>/u-boot.lds* + accordingly! + config ENV_IS_IN_MMC bool "Environment in an MMC device" default y if ARCH_SUNXI diff --git a/include/config_fsl_chain_trust.h b/include/config_fsl_chain_trust.h index 5a1a287992..6b6ae7cc78 100644 --- a/include/config_fsl_chain_trust.h +++ b/include/config_fsl_chain_trust.h @@ -15,7 +15,6 @@
#undef CONFIG_ENV_IS_IN_EEPROM #undef CONFIG_ENV_IS_IN_SPI_FLASH -#undef CONFIG_ENV_IS_IN_FLASH
#endif
diff --git a/include/configs/10m50_devboard.h b/include/configs/10m50_devboard.h index ea980e6511..d05cc613d0 100644 --- a/include/configs/10m50_devboard.h +++ b/include/configs/10m50_devboard.h @@ -70,7 +70,6 @@ * of flash. NOTE: the monitor length must be multiple of sector size * (which is common practice). */ -#define CONFIG_ENV_IS_IN_FLASH
#define CONFIG_ENV_SIZE 0x10000 /* 64k, 1 sector */ #define CONFIG_ENV_OVERWRITE /* Serial change Ok */ diff --git a/include/configs/3c120_devboard.h b/include/configs/3c120_devboard.h index 65271773f4..0d3794dd06 100644 --- a/include/configs/3c120_devboard.h +++ b/include/configs/3c120_devboard.h @@ -73,7 +73,6 @@ * of flash. NOTE: the monitor length must be multiple of sector size * (which is common practice). */ -#define CONFIG_ENV_IS_IN_FLASH
#define CONFIG_ENV_SIZE 0x20000 /* 128k, 1 sector */ #define CONFIG_ENV_OVERWRITE /* Serial change Ok */ diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 61a1fa48ae..d580e9b36e 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -139,7 +139,6 @@ #elif defined(CONFIG_ENV_IS_NOWHERE) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 2aec01ec54..54d613707b 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -505,7 +505,6 @@ combinations. this should be removed later #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index a8bc2abcab..937e93ef0a 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -423,7 +423,6 @@ #endif #define CONFIG_ENV_OFFSET CONFIG_SYS_NAND_BLOCK_SIZE #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index 2cf05a0978..0a1a0d8673 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -162,7 +162,6 @@ #define CONFIG_ENV_OFFSET 0x2000 #define CONFIG_ENV_SIZE 0x1000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index fc9b26ff46..75acc59910 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -201,8 +201,6 @@ #ifdef CONFIG_CF_SBF # define CONFIG_ENV_IS_IN_SPI_FLASH # define CONFIG_ENV_SPI_CS 2 -#else -# define CONFIG_ENV_IS_IN_FLASH 1 #endif #define CONFIG_ENV_OVERWRITE 1
diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 0546afda69..f28a574713 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -177,7 +177,6 @@ /* Configuration for environment * Environment is embedded in u-boot in the second sector of the flash */ -#define CONFIG_ENV_IS_IN_FLASH 1
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 7e70a3b045..df0733e6c2 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -84,8 +84,6 @@ #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
-#define CONFIG_ENV_IS_IN_FLASH 1 - #define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ env/embedded.o(.text); diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index ef5deb869c..da8333ac6f 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -23,11 +23,9 @@ #ifdef CONFIG_MONITOR_IS_IN_RAM # define CONFIG_ENV_OFFSET 0x4000 # define CONFIG_ENV_SECT_SIZE 0x1000 -# define CONFIG_ENV_IS_IN_FLASH 1 #else # define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x4000) # define CONFIG_ENV_SECT_SIZE 0x1000 -# define CONFIG_ENV_IS_IN_FLASH 1 #endif
#define LDS_BOARD_TEXT \ diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index 433f8327cc..5a2f0e204f 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -24,11 +24,9 @@ #ifndef CONFIG_MONITOR_IS_IN_RAM #define CONFIG_ENV_OFFSET 0x4000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1 #else #define CONFIG_ENV_ADDR 0xffe04000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1 #endif
#define LDS_BOARD_TEXT \ diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index 094973a168..f5693d8178 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -33,11 +33,9 @@ #ifndef CONFIG_MONITOR_IS_IN_RAM #define CONFIG_ENV_OFFSET 0x4000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1 #else #define CONFIG_ENV_ADDR 0xffe04000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1 #endif
#define LDS_BOARD_TEXT \ diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 1a8f973e39..339a03c7b1 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -34,11 +34,9 @@ #ifndef CONFIG_MONITOR_IS_IN_RAM #define CONFIG_ENV_OFFSET 0x4000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1 #else #define CONFIG_ENV_ADDR 0xffe04000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1 #endif
#define LDS_BOARD_TEXT \ diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index 604daf577a..3f2d9a9bac 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -29,7 +29,6 @@ */ #define CONFIG_ENV_ADDR 0xffe04000 #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index 86fb277897..5331533446 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -185,7 +185,6 @@ #define CONFIG_ENV_OFFSET (CONFIG_SYS_FLASH_BASE + 0x40000) #define CONFIG_ENV_SIZE 0x1000 #define CONFIG_ENV_SECT_SIZE 0x8000 -#define CONFIG_ENV_IS_IN_FLASH 1
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 7e7f1ee918..14bfc60b88 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -190,7 +190,6 @@ */ #define CONFIG_ENV_OFFSET 0x4000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index ee621f03be..5bc41bfbb9 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -190,7 +190,6 @@ */ #define CONFIG_ENV_OFFSET 0x4000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1
#define LDS_BOARD_TEXT \ . = DEFINED(env_offset) ? env_offset : .; \ diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index 7d6edda361..fbd5287147 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -222,7 +222,6 @@ # define CONFIG_ENV_SIZE 0x2000 # define CONFIG_ENV_SECT_SIZE 0x10000 #else -# define CONFIG_ENV_IS_IN_FLASH 1 # define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000) # define CONFIG_ENV_SIZE 0x2000 # define CONFIG_ENV_SECT_SIZE 0x20000 diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index 39ba94065a..cc08df7d3d 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -273,8 +273,6 @@ #ifdef CONFIG_CF_SBF # define CONFIG_ENV_IS_IN_SPI_FLASH # define CONFIG_ENV_SPI_CS 1 -#else -# define CONFIG_ENV_IS_IN_FLASH 1 #endif #undef CONFIG_ENV_OVERWRITE
diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index cf9d3b8e1b..be05e3a735 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -233,7 +233,6 @@ */ #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_IS_IN_FLASH 1
/*----------------------------------------------------------------------- * Cache Configuration diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index 934c9d8903..a8ad62c237 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -220,7 +220,6 @@ */ #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SECT_SIZE 0x10000 -#define CONFIG_ENV_IS_IN_FLASH 1
/*----------------------------------------------------------------------- * Cache Configuration diff --git a/include/configs/MCR3000.h b/include/configs/MCR3000.h index 15bb0e9d6a..17090da796 100644 --- a/include/configs/MCR3000.h +++ b/include/configs/MCR3000.h @@ -125,7 +125,6 @@ /* Environment Configuration */
/* environment is in FLASH */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 0f26467e29..25d5cab959 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -394,7 +394,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index b767401fc1..566be9b6ea 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -440,7 +440,6 @@ #define CONFIG_ENV_OFFSET_REDUND \ (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) #elif !defined(CONFIG_SYS_RAMBOOT) - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index b281c216cb..4a973de4e3 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -421,7 +421,6 @@ * Environment */ #if !defined(CONFIG_SYS_RAMBOOT) - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index d34eacbad3..b8f8f493eb 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -295,7 +295,6 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 28b9478d04..428f3abf90 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -379,7 +379,6 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 2835d42b93..18f7523692 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -433,7 +433,6 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 4b9bc1fbd1..221c35cf51 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -452,7 +452,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_ENV_OVERWRITE
#ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) for environment */ diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 781a93ab14..1a65c25c48 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -442,7 +442,6 @@ extern int board_pci_host_broken(void); * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index ada85c7964..d93f7a0074 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -455,7 +455,6 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE+CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) for env */ diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 1456648d6a..d96c15ec01 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -574,7 +574,6 @@ #define CONFIG_ENV_SIZE 0x2000 #endif #else - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index decb57404a..ca4ccd8ad3 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -291,7 +291,6 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 029aa572ce..977454167d 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -323,7 +323,6 @@ extern unsigned long get_clock_freq(void); /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index ffa8796407..b4f4c4e32b 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -325,7 +325,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) */ #if CONFIG_SYS_MONITOR_BASE > 0xfff80000 #define CONFIG_ENV_ADDR 0xfff80000 diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 43e05516ab..b41543688b 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -438,7 +438,6 @@ extern unsigned long get_clock_freq(void); /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #if CONFIG_SYS_MONITOR_BASE > 0xfff80000 #define CONFIG_ENV_ADDR 0xfff80000 #else diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 96a125c323..d31395cf81 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -321,7 +321,6 @@ extern unsigned long get_clock_freq(void); /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 47b97d1554..2e13fb52df 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -330,7 +330,6 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 3734055bd3..c0af7451b8 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -336,7 +336,6 @@ extern unsigned long get_clock_freq(void); /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index eb7db20b7f..a75ce0b93d 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -424,7 +424,6 @@ extern unsigned long get_clock_freq(void); */ #if defined(CONFIG_SYS_RAMBOOT) #else -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index d8e0dfd807..0a2bcb2383 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -531,7 +531,6 @@ #if defined(CONFIG_SYS_RAMBOOT)
#else - #define CONFIG_ENV_IS_IN_FLASH 1 #if CONFIG_SYS_MONITOR_BASE > 0xfff80000 #define CONFIG_ENV_ADDR 0xfff80000 #else diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 46b9b7a67d..5e8211609a 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -403,7 +403,6 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 126k (one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 4a4a76d2d4..7b9b2458b3 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -563,7 +563,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index 7217426d3a..5ee83b9034 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -94,7 +94,6 @@ #undef CONFIG_SYS_DIRECT_FLASH_TFTP
/* ENV setting */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 1bbdf2258b..c4c8f3e617 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -708,7 +708,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index e9c755b47d..b7507a2b29 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -577,7 +577,6 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 719043d5a1..be42dadac7 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -230,7 +230,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_ENV_OVERWRITE
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index d3b655fda9..36d08d8e7f 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -88,7 +88,6 @@ #elif defined(CONFIG_ENV_IS_NOWHERE) #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE \ - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index ef8e7b678f..48c7b2dcc2 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -169,7 +169,6 @@ #elif defined(CONFIG_ENV_IS_NOWHERE) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 4f2b208219..dcfedc0410 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -192,7 +192,6 @@ #elif defined(CONFIG_ENV_IS_NOWHERE) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 6077bf470c..56591f38d9 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -90,7 +90,6 @@ #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index fa50502922..9cdd67f5b7 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -198,7 +198,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (3 * CONFIG_SYS_NAND_BLOCK_SIZE) #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 5d049d1e8f..0dcef00186 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -165,7 +165,6 @@ #elif defined(CONFIG_ENV_IS_NOWHERE) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 2cea8c8505..90401a3256 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -151,7 +151,6 @@ #elif defined(CONFIG_ENV_IS_NOWHERE) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 287c722e2f..d9983653f0 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -110,7 +110,6 @@ #elif defined(CONFIG_ENV_IS_NOWHERE) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index d06c5b574e..ee1110a317 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -347,7 +347,6 @@ #elif defined(CONFIG_ENV_IS_NOWHERE) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index a79dabef61..fa92af3c95 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -251,7 +251,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) for env */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 2bf3a5686a..31d7cdbd10 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -362,7 +362,6 @@ */ #ifdef CONFIG_ENV_FIT_UCBOOT
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x20000) #define CONFIG_ENV_SIZE 0x20000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ @@ -397,7 +396,6 @@ #define CONFIG_ENV_SIZE 0x2000
#else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_BASE (CONFIG_SYS_FLASH_BASE) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index 6bfc08e5af..cef1eddeb6 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -236,7 +236,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 512
/* environments */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x140000) #define CONFIG_ENV_SIZE 8192 #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 4cef64e3c5..f9662780de 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -358,7 +358,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 512
/* environments */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x140000) #define CONFIG_ENV_SIZE 8192 #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 764af3d8c7..751929339a 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -340,7 +340,6 @@ #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_SYS_MMC_MAX_DEVICE 2 #elif defined(CONFIG_NOR_BOOT) -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #define CONFIG_ENV_OFFSET (512 << 10) /* 512 KiB */ #define CONFIG_ENV_OFFSET_REDUND (768 << 10) /* 768 KiB */ diff --git a/include/configs/amcore.h b/include/configs/amcore.h index 02a0ad9e7e..5f8b6c5518 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -87,7 +87,6 @@ #define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) #define CONFIG_SYS_BOOTPARAMS_LEN (64 * 1024)
-#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SIZE 0x1000 diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index b3c22cf4a4..285041dbf8 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -124,7 +124,6 @@ #undef CONFIG_SYS_DIRECT_FLASH_TFTP
/* ENV setting */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index 440505dd1f..078c77bf68 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -107,7 +107,6 @@ #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* ENV setting */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 2023895c3e..492062abb3 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -87,7 +87,6 @@ #define CONFIG_SYS_FLASH_UNLOCK_TOUT 3000
/* ENV setting */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 722f8c79fa..65c76c328c 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -121,7 +121,6 @@ #ifndef CONFIG_MONITOR_IS_IN_RAM #define CONFIG_ENV_OFFSET 0x1FF8000 #define CONFIG_ENV_SECT_SIZE 0x8000 -#define CONFIG_ENV_IS_IN_FLASH 1 #else /* * environment in RAM - This is used to use a single PC-based application @@ -131,7 +130,6 @@ */ #define CONFIG_ENV_ADDR 0x40060000 #define CONFIG_ENV_SECT_SIZE 0x8000 -#define CONFIG_ENV_IS_IN_FLASH 1 #endif
/* here we put our FPGA configuration... */ diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 53e191a312..cb6dae71e9 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -149,7 +149,6 @@ /* * Environment Settings */ -#define CONFIG_ENV_IS_IN_FLASH
/* * after u-boot.bin diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index a8337cdf43..9effe9ebd9 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_MONITOR_SEC 1:0-3 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN (256 << 10) -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x007E0000) #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR - CONFIG_ENV_SIZE)
diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index a37433e03f..04a6e06e0f 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -553,7 +553,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Reduce SPL size by removing unlikey targets */ #ifdef CONFIG_NOR_BOOT -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ #define CONFIG_ENV_OFFSET (512 << 10) /* 512 KiB */ #define CONFIG_ENV_OFFSET_REDUND (768 << 10) /* 768 KiB */ diff --git a/include/configs/blanche.h b/include/configs/blanche.h index cb80b90381..50692cba65 100755 --- a/include/configs/blanche.h +++ b/include/configs/blanche.h @@ -83,7 +83,6 @@ #else #undef CONFIG_ENV_IS_IN_SPI_FLASH #undef CONFIG_ENV_ADDR -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (256 * 1024) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) diff --git a/include/configs/boston.h b/include/configs/boston.h index 50aaa7be8c..2646cf09ed 100644 --- a/include/configs/boston.h +++ b/include/configs/boston.h @@ -64,7 +64,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #ifdef CONFIG_64BIT diff --git a/include/configs/calimain.h b/include/configs/calimain.h index d43e3314a7..b6c8035fb5 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -154,7 +154,6 @@ #define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) #define CONFIG_CONS_INDEX 1 /* use UART0 for console */
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_PROTECTION diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index aff7af7d52..c1c3013dc3 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -96,11 +96,9 @@ #ifndef CONFIG_MONITOR_IS_IN_RAM #define CONFIG_ENV_OFFSET 0x4000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1 #else #define CONFIG_ENV_ADDR 0xffe04000 #define CONFIG_ENV_SECT_SIZE 0x2000 -#define CONFIG_ENV_IS_IN_FLASH 1 #endif
#define LDS_BOARD_TEXT \ diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index 9efe74b593..4be06f1914 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -138,8 +138,6 @@
#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 #define CONFIG_SYS_FLASH_PROTECTION 1 - -#define CONFIG_ENV_IS_IN_FLASH 1 #endif
#define CONFIG_SYS_MONITOR_BASE 0x0 diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index abd09ca1ed..70fdb58163 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -99,7 +99,6 @@ #elif defined(CONFIG_ENV_IS_NOWHERE) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index b69303fdba..2277215445 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -162,7 +162,6 @@ * Flash & Environment */ #ifdef CONFIG_USE_NAND -#undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_NAND_DAVINCI #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 10) @@ -217,7 +216,6 @@ #endif
#ifdef CONFIG_USE_NOR -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_PROTECTION @@ -233,7 +231,6 @@ #endif
#ifdef CONFIG_USE_SPIFLASH -#undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_OFFSET (512 << 10) diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 40beb17574..1c2cc6f4b0 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -236,7 +236,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Reduce SPL size by removing unlikey targets */ #ifdef CONFIG_NOR_BOOT -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (128 * 1024) /* 128 KiB */ #define MTDIDS_DEFAULT "nor0=physmap-flash.0" #define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0:" \ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index e00f9648fe..699888b9ea 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -87,7 +87,6 @@ #endif
#ifdef CONFIG_USE_SPIFLASH -#undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (8 << 10) #define CONFIG_ENV_OFFSET 0x80000 diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 45ce944eb1..755e7887df 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -43,7 +43,6 @@
#define CONFIG_ENV_ADDR 0xFF040000 #define CONFIG_ENV_SECT_SIZE 0x00020000 -#define CONFIG_ENV_IS_IN_FLASH 1
/* * BOOTP options diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 2404441860..cabbe160a3 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -139,7 +139,6 @@ #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* ENV setting */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index def28f2cf1..92842e1e18 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -198,7 +198,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024)
#define CONFIG_ENV_OVERWRITE /* Vendor params unprotected */ -#define CONFIG_ENV_IS_IN_FLASH
#define CONFIG_ENV_ADDR 0x60040000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index cc5cc7bac6..31364c2533 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -187,7 +187,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x2000 /* 16K */ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET 0x4000 /* env starts here */ diff --git a/include/configs/espt.h b/include/configs/espt.h index 845bcc1c9a..1b3295346d 100644 --- a/include/configs/espt.h +++ b/include/configs/espt.h @@ -74,7 +74,6 @@ /* Use hardware flash sectors protection instead of U-Boot software protection */ #undef CONFIG_SYS_FLASH_PROTECTION #undef CONFIG_SYS_DIRECT_FLASH_TFTP -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + (1 * CONFIG_ENV_SECT_SIZE)) diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 0ab33953ac..a9b882b940 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -155,8 +155,6 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN)
-#define CONFIG_ENV_IS_IN_FLASH - /* * CFI FLASH driver setup */ diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index df8e69fe66..c5b6fddee7 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -493,7 +493,6 @@ void fpga_control_clear(unsigned int bus, int pin); * Environment */ #if 1 -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 7bedcb94d7..a04652f68f 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -429,7 +429,6 @@ /* * Environment Configuration */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE \ + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SIZE 0x20000 diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 18d8d2fd3d..08a03e8ae3 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -89,7 +89,6 @@ /* * Flash & Environment */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI /* Use buffered writes (~10x faster) */ diff --git a/include/configs/integratorcp.h b/include/configs/integratorcp.h index d0b6af8cad..8c9ad6c183 100644 --- a/include/configs/integratorcp.h +++ b/include/configs/integratorcp.h @@ -42,7 +42,6 @@ */ #define PHYS_FLASH_SIZE 0x01000000 /* 16MB */ #define CONFIG_SYS_MAX_FLASH_SECT 64 -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_SYS_MONITOR_LEN 0x00100000
/* diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 0db33b701c..0bd42799f1 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -175,7 +175,6 @@ */
#ifndef CONFIG_SYS_RAMBOOT -#define CONFIG_ENV_IS_IN_FLASH #ifndef CONFIG_ENV_ADDR #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index feb3eec446..f434991314 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -98,7 +98,6 @@
/* GPIO / PFC */ #define CONFIG_SH_GPIO_PFC diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index b3c931e36c..b823ff23bf 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -561,7 +561,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 06d7d400ca..8fe34ef658 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -426,7 +426,6 @@ #define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_ENV_SECT_SIZE 0x10000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SIZE 0x20000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 83c8805df6..740facfa58 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -422,7 +422,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 7b8561e9d6..59e7760b10 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -240,7 +240,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 860ad8f693..782669ad2c 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -456,7 +456,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index b5fa41e33d..929ae3286a 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -270,7 +270,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3
#ifndef CONFIG_QSPI_BOOT -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index a353cf4f68..0be4c4fa0b 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -248,7 +248,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 #define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/malta.h b/include/configs/malta.h index 1f977cb71a..8eb6d7a269 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -82,7 +82,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_ADDR \ diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index fca1af9d2b..87bbb4a75a 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -314,7 +314,6 @@ #define CONFIG_ENV_SIZE (SZ_128K)
/* Envs are stored in NOR flash */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (SZ_128K) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000)
diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index c3d9b99771..5736621d41 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -99,7 +99,6 @@ # define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE)
# else /* FLASH && !RAMENV */ -# define CONFIG_ENV_IS_IN_FLASH 1 /* 128K(one sector) for env */ # define CONFIG_ENV_SECT_SIZE 0x20000 # define CONFIG_ENV_ADDR \ diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index b865d9f916..cd5971d30c 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -361,7 +361,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ diff --git a/include/configs/mpr2.h b/include/configs/mpr2.h index df8ffe29d0..5b37277cce 100644 --- a/include/configs/mpr2.h +++ b/include/configs/mpr2.h @@ -51,7 +51,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index 2855c00723..850a8cc222 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -65,7 +65,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE }
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index de6e58a71e..f456bf6293 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -85,7 +85,6 @@
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SECT_SIZE (8 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/ms7750se.h b/include/configs/ms7750se.h index 394ce6cd38..8ea431efdc 100644 --- a/include/configs/ms7750se.h +++ b/include/configs/ms7750se.h @@ -63,7 +63,6 @@ #undef CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 5db3677566..fba6454172 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -132,7 +132,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Monitor at beginning of flash */ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256KiB */
-#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 4fc0aadd89..58779948ca 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -170,8 +170,6 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN)
-#define CONFIG_ENV_IS_IN_FLASH - #if defined(CONFIG_FSL_ENV_IN_NAND) #define CONFIG_ENV_OFFSET (1024 * 1024) #endif diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index f566d0f1ba..83692c8982 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -154,7 +154,6 @@ * Flash & Environment */ #ifdef CONFIG_USE_NAND -#undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_NAND_DAVINCI #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ #define CONFIG_ENV_SIZE (128 << 9) @@ -198,7 +197,6 @@ #endif
#ifdef CONFIG_SYS_USE_NOR -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_PROTECTION @@ -214,7 +212,6 @@ #endif
#ifdef CONFIG_USE_SPIFLASH -#undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_OFFSET (256 << 10) @@ -313,7 +310,6 @@ #undef CONFIG_ENV_OFFSET #define CONFIG_ENV_SIZE (16 << 10) /* 16 KiB */ #define CONFIG_ENV_OFFSET (51 << 9) /* Sector 51 */ -#undef CONFIG_ENV_IS_IN_FLASH #undef CONFIG_ENV_IS_IN_SPI_FLASH #endif
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 248203d9bf..201310d1d1 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -797,7 +797,6 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index 799672fff7..4c9eb6b419 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -369,7 +369,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_ENV_SIZE 0x2000 #endif #else -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index b6ec563cee..bae5736801 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -269,7 +269,6 @@
#elif defined (CONFIG_SYS_USE_FLASH)
-#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index eeb3f27cfe..9ea444009a 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -299,7 +299,6 @@
#elif defined(CONFIG_SYS_USE_FLASH) /* CFG_USE_FLASH */
-#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index abdc93c7d2..89d1ad91e0 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -111,8 +111,6 @@ #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE
-#define CONFIG_ENV_IS_IN_FLASH - /* Address and size of Primary Environment Sector */ #define CONFIG_ENV_SIZE 0x8000 #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + (4 << 20) - CONFIG_ENV_SIZE) diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index f1e096fddd..a78112d5bc 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -111,8 +111,6 @@ #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE
-#define CONFIG_ENV_IS_IN_FLASH - /* Address and size of Primary Environment Sector */ #define CONFIG_ENV_SIZE 0x8000 #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + (4 << 20) - CONFIG_ENV_SIZE) diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index 6212dbae21..5f74b2a0e0 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -112,7 +112,6 @@ #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* ENV setting */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 744d567805..64fd4b97a0 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -53,7 +53,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE }
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE 0x40000 #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index bb79a9ffea..c5f577a3bf 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -77,7 +77,6 @@ /* print 'E' for empty sector on flinfo */ #define CONFIG_SYS_FLASH_EMPTY_INFO
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (256 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/rsk7203.h b/include/configs/rsk7203.h index 8dc839df96..8f30aefc41 100644 --- a/include/configs/rsk7203.h +++ b/include/configs/rsk7203.h @@ -63,7 +63,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 64 #define CONFIG_SYS_MAX_FLASH_BANKS 1
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/rsk7264.h b/include/configs/rsk7264.h index cc709097c0..14e55c579d 100644 --- a/include/configs/rsk7264.h +++ b/include/configs/rsk7264.h @@ -48,7 +48,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 512
-#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_OFFSET (128 * 1024) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SECT_SIZE (128 * 1024) diff --git a/include/configs/rsk7269.h b/include/configs/rsk7269.h index 12812f9a34..60844ab738 100644 --- a/include/configs/rsk7269.h +++ b/include/configs/rsk7269.h @@ -47,7 +47,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 512
-#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_OFFSET (128 * 1024) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SECT_SIZE (64 * 1024) diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 1d07593e95..c0faac3b79 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -370,7 +370,6 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x40000) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index e872e7f810..cf9809df49 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -485,7 +485,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SIZE 0x2000 #if CONFIG_SYS_TEXT_BASE == 0xfff00000 /* Boot from 64MB SODIMM */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0x80000) diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 33b6d1fb93..c5f9fcb918 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -443,7 +443,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/sh7763rdp.h b/include/configs/sh7763rdp.h index 2186f21f7a..50a0e3e7d1 100644 --- a/include/configs/sh7763rdp.h +++ b/include/configs/sh7763rdp.h @@ -74,7 +74,6 @@ /* Use hardware flash sectors protection instead of U-Boot software protection */ #undef CONFIG_SYS_FLASH_PROTECTION #undef CONFIG_SYS_DIRECT_FLASH_TFTP -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + (1 * CONFIG_ENV_SECT_SIZE)) diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index ab30428063..59fcad0309 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -132,7 +132,6 @@ #define CONFIG_PCI_SYS_SIZE CONFIG_SYS_SDRAM_SIZE
/* ENV setting */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_ENV_SECT_SIZE (256 * 1024) #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/shmin.h b/include/configs/shmin.h index 995f76a1ea..c9718f9b36 100644 --- a/include/configs/shmin.h +++ b/include/configs/shmin.h @@ -72,7 +72,6 @@ #define CONFIG_SYS_ATMEL_SECT {1, 2, 1, 7} #define CONFIG_SYS_ATMEL_SECTSZ {0x4000, 0x2000, 0x8000, 0x10000}
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index bfd4e5fe3f..3864dfb09f 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -256,7 +256,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x4000 diff --git a/include/configs/spear3xx_evb.h b/include/configs/spear3xx_evb.h index 98a74fa6e1..4dbf919cfa 100644 --- a/include/configs/spear3xx_evb.h +++ b/include/configs/spear3xx_evb.h @@ -24,11 +24,6 @@ #define CONFIG_SPEAR_USBTTY #endif
-#if defined(CONFIG_NAND) -#else -#define CONFIG_ENV_IS_IN_FLASH -#endif - #include <configs/spear-common.h>
/* Ethernet driver configuration */ diff --git a/include/configs/spear6xx_evb.h b/include/configs/spear6xx_evb.h index de08a72704..4bd989e2f0 100644 --- a/include/configs/spear6xx_evb.h +++ b/include/configs/spear6xx_evb.h @@ -16,11 +16,6 @@ #define CONFIG_SPEAR_USBTTY #endif
/* Serial Configuration (PL011) */ diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 8609f2a0a9..c47be514d8 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -35,7 +35,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 12 #define CONFIG_SYS_MAX_FLASH_BANKS 2
-#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OFFSET (256 << 10) #define CONFIG_ENV_SECT_SIZE (128 << 10) #define CONFIG_ENV_SIZE (8 << 10) diff --git a/include/configs/strider.h b/include/configs/strider.h index be6bd7352a..a702ec71da 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -529,7 +529,6 @@ void fpga_control_clear(unsigned int bus, int pin); * Environment */ #if 1 -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ diff --git a/include/configs/vct.h b/include/configs/vct.h index 7b04e65d70..42f71112f8 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -137,7 +137,6 @@ * FLASH and environment organization */ #if defined(CONFIG_VCT_NOR) -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_FLASH_NOT_MEM_MAPPED
/* diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index f0e9a2e58d..32ed2f95c9 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -290,7 +290,6 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR \ (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index 11cb53587c..3b1233f615 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -284,6 +284,5 @@ #define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */ #define FLASH_MAX_SECTOR_SIZE 0x00040000 #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_IS_IN_FLASH 1
#endif /* __VEXPRESS_AEMV8A_H */ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 0880b627ae..8f9ba91641 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -262,7 +262,6 @@ #define CONFIG_ENV_OVERWRITE 1
/* Store environment at top of flash */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_OFFSET (PHYS_FLASH_SIZE - \ (2 * CONFIG_ENV_SECT_SIZE)) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE1 + \ diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index f2a15f37fe..13ebafeac8 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -313,7 +313,6 @@ * Environment */ #ifndef CONFIG_SYS_RAMBOOT - #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + 0xc0000) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 46a6706171..1d51ffc8ce 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -168,8 +168,6 @@ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ CONFIG_SYS_MONITOR_LEN)
-#define CONFIG_ENV_IS_IN_FLASH - /* * CFI FLASH driver setup */ diff --git a/include/configs/x600.h b/include/configs/x600.h index c7d32fedb3..013be46ca1 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -33,8 +33,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN 0x60000
-#define CONFIG_ENV_IS_IN_FLASH - /* Serial Configuration (PL011) */ #define CONFIG_SYS_SERIAL0 0xD0000000 #define CONFIG_SYS_SERIAL1 0xD0080000 diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index 07f26544fd..9b6a5f8ce1 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -517,7 +517,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Environment Configuration */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k (one sector) for env */ #define CONFIG_ENV_SIZE 0x8000 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index 2645006b37..715acc4fbc 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -322,7 +322,6 @@ /* * Environment Configuration */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k (one sector) for env */ #define CONFIG_ENV_SIZE 0x8000 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - (256 * 1024)) diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index abbaeaad10..7d05a5aa82 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -371,7 +371,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Environment Configuration */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k (one sector) for env */ #define CONFIG_ENV_SIZE 0x8000 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - (256 * 1024)) diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 254fc12cf6..68795d8faa 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -370,7 +370,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); /* * Environment Configuration */ -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128k (one sector) for env */ #define CONFIG_ENV_SIZE 0x8000 #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - (256 * 1024)) diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 7d7d9bb983..206ec344d9 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -250,7 +250,6 @@ * Put environment in top block (64kB) * Another option would be to put env. in 2nd param block offs 8KB, size 8KB */ -#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OFFSET (CONFIG_SYS_FLASH_SIZE - CONFIG_SYS_FLASH_SECT_SZ) #define CONFIG_ENV_SIZE CONFIG_SYS_FLASH_SECT_SZ
diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 9b3769b5f1..e730824146 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -22,7 +22,6 @@ * Environment settings */ #define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_ADDR 0x40000 #define CONFIG_ENV_SIZE 0x10000
diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index c1daf65621..05420af409 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -107,7 +107,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 256
#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00040000) -#define CONFIG_ENV_IS_IN_FLASH 1 #define CONFIG_ENV_SECT_SIZE (128 * 1024) #define CONFIG_ENV_SIZE (128 * 1024)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 807b097d34..9b527feec8 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -161,7 +161,6 @@ #ifndef CONFIG_ENV_IS_NOWHERE # ifdef CONFIG_MTD_NOR_FLASH /* Environment in NOR flash */ -# define CONFIG_ENV_IS_IN_FLASH # elif defined(CONFIG_ZYNQ_QSPI) /* Environment in Serial Flash */ # define CONFIG_ENV_IS_IN_SPI_FLASH diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index baf87996a8..2c7ea85618 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -636,7 +636,6 @@ CONFIG_ENV_IS_IN_ CONFIG_ENV_IS_IN_DATAFLASH CONFIG_ENV_IS_IN_EEPROM CONFIG_ENV_IS_IN_FAT -CONFIG_ENV_IS_IN_FLASH CONFIG_ENV_IS_IN_MRAM CONFIG_ENV_IS_IN_NVRAM CONFIG_ENV_IS_IN_ONENAND
On Sun, Jul 23, 2017 at 09:19:41PM -0600, Simon Glass wrote:
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FLASH
Signed-off-by: Simon Glass sjg@chromium.org
This converts the following to Kconfig: CONFIG_ENV_IS_IN_NVRAM
Changes in v2: None
README | 14 -------------- configs/highbank_defconfig | 3 ++- env/Kconfig | 15 +++++++++++++++ include/configs/M54418TWR.h | 1 - include/configs/highbank.h | 1 - scripts/config_whitelist.txt | 2 -- 6 files changed, 17 insertions(+), 19 deletions(-)
diff --git a/README b/README index caf35a10b2..05a4fcf4b5 100644 --- a/README +++ b/README @@ -3432,20 +3432,6 @@ following configurations: Builds up envcrc with the target environment so that external utils may easily extract it and embed it in final U-Boot images.
-- CONFIG_ENV_IS_IN_NVRAM: - - Define this if you have some non-volatile memory device - (NVRAM, battery buffered SRAM) which you want to use for the - environment. - - - CONFIG_ENV_ADDR: - - CONFIG_ENV_SIZE: - - These two #defines are used to determine the memory area you - want to use for environment. It is assumed that this memory - can just be read and written to, without any special - provision. - BE CAREFUL! The first access to the environment happens quite early in U-Boot initialization (when we try to get the setting of for the console baudrate). You *MUST* have mapped your NVRAM area then, or diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index 6f19492251..552bdcffad 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set -CONFIG_SCSI=y +CONFIG_ENV_IS_IN_NVRAM=y # CONFIG_MMC is not set +CONFIG_SCSI=y CONFIG_OF_LIBFDT=y diff --git a/env/Kconfig b/env/Kconfig index 5cc55f8972..75dd57843f 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -161,6 +161,21 @@ config ENV_IS_IN_NAND Currently, CONFIG_ENV_OFFSET_REDUND is not supported when using CONFIG_ENV_OFFSET_OOB.
+config ENV_IS_IN_NVRAM + bool "Environment in a non-volatile RAM" + help + Define this if you have some non-volatile memory device + (NVRAM, battery buffered SRAM) which you want to use for the + environment. + + - CONFIG_ENV_ADDR: + - CONFIG_ENV_SIZE: + + These two #defines are used to determine the memory area you + want to use for environment. It is assumed that this memory + can just be read and written to, without any special + provision. + config ENV_IS_IN_UBI bool "Environment in a UBI volume" help diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index 985df810cb..db40b426a8 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -273,7 +273,6 @@ * Environment is embedded in u-boot in the second sector of the flash */ #if !defined(CONFIG_SERIAL_BOOT) /*MRAM boot*/ -#define CONFIG_ENV_IS_IN_MRAM 1 #define CONFIG_ENV_ADDR (0x40000 - 0x1000) /*MRAM size 40000*/ #define CONFIG_ENV_SIZE 0x1000 #endif diff --git a/include/configs/highbank.h b/include/configs/highbank.h index 533d3e3f82..0328c4100b 100644 --- a/include/configs/highbank.h +++ b/include/configs/highbank.h @@ -74,7 +74,6 @@
/* Environment data setup */ -#define CONFIG_ENV_IS_IN_NVRAM #define CONFIG_SYS_NVRAM_BASE_ADDR 0xfff88000 /* NVRAM base address */ #define CONFIG_SYS_NVRAM_SIZE 0x8000 /* NVRAM size */ #define CONFIG_ENV_SIZE 0x2000 /* Size of Environ */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2c7ea85618..e4d434b73b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -636,8 +636,6 @@ CONFIG_ENV_IS_IN_ CONFIG_ENV_IS_IN_DATAFLASH CONFIG_ENV_IS_IN_EEPROM CONFIG_ENV_IS_IN_FAT -CONFIG_ENV_IS_IN_MRAM -CONFIG_ENV_IS_IN_NVRAM CONFIG_ENV_IS_IN_ONENAND CONFIG_ENV_IS_IN_REMOTE CONFIG_ENV_IS_IN_SPI_FLASH
This converts the following to Kconfig: CONFIG_ENV_IS_IN_EEPROM
Changes in v2: None
README | 60 ------------------------------------ configs/imx31_phycore_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/mgcoge3un_defconfig | 1 + configs/portl2_defconfig | 1 + env/Kconfig | 60 ++++++++++++++++++++++++++++++++++++ include/config_fsl_chain_trust.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/km/km_arm.h | 1 - scripts/config_whitelist.txt | 1 - 13 files changed, 67 insertions(+), 64 deletions(-)
diff --git a/README b/README index 05a4fcf4b5..d94a4ac120 100644 --- a/README +++ b/README @@ -3442,66 +3442,6 @@ environment in RAM: we could work on NVRAM directly, but we want to keep settings there always unmodified except somebody uses "saveenv" to save the current settings.
- -- CONFIG_ENV_IS_IN_EEPROM: - - Use this if you have an EEPROM or similar serial access - device and a driver for it. - - - CONFIG_ENV_OFFSET: - - CONFIG_ENV_SIZE: - - These two #defines specify the offset and size of the - environment area within the total memory of your EEPROM. - - - CONFIG_SYS_I2C_EEPROM_ADDR: - If defined, specified the chip address of the EEPROM device. - The default address is zero. - - - CONFIG_SYS_I2C_EEPROM_BUS: - If defined, specified the i2c bus of the EEPROM device. - - - CONFIG_SYS_EEPROM_PAGE_WRITE_BITS: - If defined, the number of bits used to address bytes in a - single page in the EEPROM device. A 64 byte page, for example - would require six bits. - - - CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS: - If defined, the number of milliseconds to delay between - page writes. The default is zero milliseconds. - - - CONFIG_SYS_I2C_EEPROM_ADDR_LEN: - The length in bytes of the EEPROM memory array address. Note - that this is NOT the chip address length! - - - CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW: - EEPROM chips that implement "address overflow" are ones - like Catalyst 24WC04/08/16 which has 9/10/11 bits of - address and the extra bits end up in the "chip address" bit - slots. This makes a 24WC08 (1Kbyte) chip look like four 256 - byte chips. - - Note that we consider the length of the address field to - still be one byte because the extra address bits are hidden - in the chip address. - - - CONFIG_SYS_EEPROM_SIZE: - The size in bytes of the EEPROM device. - - - CONFIG_ENV_EEPROM_IS_ON_I2C - define this, if you have I2C and SPI activated, and your - EEPROM, which holds the environment, is on the I2C bus. - - - CONFIG_I2C_ENV_EEPROM_BUS - if you have an Environment on an EEPROM reached over - I2C muxes, you can define here, how to reach this - EEPROM. For example: - - #define CONFIG_I2C_ENV_EEPROM_BUS 1 - - EEPROM which holds the environment, is reached over - a pca9547 i2c mux with address 0x70, channel 3. - - CONFIG_ENV_IS_IN_DATAFLASH:
Define this if you have a DataFlash memory device which you diff --git a/configs/imx31_phycore_defconfig b/configs/imx31_phycore_defconfig index 224bedb1d6..652fe8662c 100644 --- a/configs/imx31_phycore_defconfig +++ b/configs/imx31_phycore_defconfig @@ -6,5 +6,6 @@ CONFIG_CMD_EEPROM=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_EEPROM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/imx31_phycore_eet_defconfig b/configs/imx31_phycore_eet_defconfig index c881b8fdcc..2a0033d615 100644 --- a/configs/imx31_phycore_eet_defconfig +++ b/configs/imx31_phycore_eet_defconfig @@ -10,5 +10,6 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_CMD_BMP=y +CONFIG_ENV_IS_IN_EEPROM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index df7dac8c37..eed0ebe341 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_EEPROM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index 4b9cdb7f47..766753165c 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_EEPROM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 79952774ae..6a74864dc6 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_EEPROM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index 2add8828b8..00a85e3c44 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_EEPROM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/portl2_defconfig b/configs/portl2_defconfig index a0faba50ff..eb741804aa 100644 --- a/configs/portl2_defconfig +++ b/configs/portl2_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_EEPROM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/env/Kconfig b/env/Kconfig index 75dd57843f..30a493fcdd 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -1,5 +1,65 @@ menu "Environment"
+config ENV_IS_IN_EEPROM + bool "Environment in EEPROM" + help + Use this if you have an EEPROM or similar serial access + device and a driver for it. + + - CONFIG_ENV_OFFSET: + - CONFIG_ENV_SIZE: + + These two #defines specify the offset and size of the + environment area within the total memory of your EEPROM. + + - CONFIG_SYS_I2C_EEPROM_ADDR: + If defined, specified the chip address of the EEPROM device. + The default address is zero. + + - CONFIG_SYS_I2C_EEPROM_BUS: + If defined, specified the i2c bus of the EEPROM device. + + - CONFIG_SYS_EEPROM_PAGE_WRITE_BITS: + If defined, the number of bits used to address bytes in a + single page in the EEPROM device. A 64 byte page, for example + would require six bits. + + - CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS: + If defined, the number of milliseconds to delay between + page writes. The default is zero milliseconds. + + - CONFIG_SYS_I2C_EEPROM_ADDR_LEN: + The length in bytes of the EEPROM memory array address. Note + that this is NOT the chip address length! + + - CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW: + EEPROM chips that implement "address overflow" are ones + like Catalyst 24WC04/08/16 which has 9/10/11 bits of + address and the extra bits end up in the "chip address" bit + slots. This makes a 24WC08 (1Kbyte) chip look like four 256 + byte chips. + + Note that we consider the length of the address field to + still be one byte because the extra address bits are hidden + in the chip address. + + - CONFIG_SYS_EEPROM_SIZE: + The size in bytes of the EEPROM device. + + - CONFIG_ENV_EEPROM_IS_ON_I2C + define this, if you have I2C and SPI activated, and your + EEPROM, which holds the environment, is on the I2C bus. + + - CONFIG_I2C_ENV_EEPROM_BUS + if you have an Environment on an EEPROM reached over + I2C muxes, you can define here, how to reach this + EEPROM. For example: + + #define CONFIG_I2C_ENV_EEPROM_BUS 1 + + EEPROM which holds the environment, is reached over + a pca9547 i2c mux with address 0x70, channel 3. + config ENV_IS_IN_FLASH bool "Environment in flash memory" help diff --git a/include/config_fsl_chain_trust.h b/include/config_fsl_chain_trust.h index 6b6ae7cc78..195419b888 100644 --- a/include/config_fsl_chain_trust.h +++ b/include/config_fsl_chain_trust.h @@ -13,7 +13,6 @@ */ #ifdef CONFIG_SECURE_BOOT
-#undef CONFIG_ENV_IS_IN_EEPROM #undef CONFIG_ENV_IS_IN_SPI_FLASH
#endif diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 739af03e88..ba7c3e186d 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -135,7 +135,6 @@ /* Monitor at beginning of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE
-#define CONFIG_ENV_IS_IN_EEPROM #define CONFIG_ENV_OFFSET 0x00 /* env. starts here */ #define CONFIG_ENV_SIZE 4096 #define CONFIG_SYS_I2C_EEPROM_ADDR 0x52 diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 0c5f6e7515..9a90e08d65 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -222,7 +222,6 @@ int get_scl(void); CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_TOTAL_SIZE 0x20000 /* no bracets! */ #else -#define CONFIG_ENV_IS_IN_EEPROM /* use EEPROM for environment vars */ #define CONFIG_SYS_DEF_EEPROM_ADDR 0x50 #define CONFIG_ENV_EEPROM_IS_ON_I2C #define CONFIG_SYS_EEPROM_WREN diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e4d434b73b..91e5f89d04 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -634,7 +634,6 @@ CONFIG_ENV_FLASHBOOT CONFIG_ENV_IS_EMBEDDED CONFIG_ENV_IS_IN_ CONFIG_ENV_IS_IN_DATAFLASH -CONFIG_ENV_IS_IN_EEPROM CONFIG_ENV_IS_IN_FAT CONFIG_ENV_IS_IN_ONENAND CONFIG_ENV_IS_IN_REMOTE
This converts the following to Kconfig: CONFIG_ENV_IS_IN_DATAFLASH
Changes in v2: None
README | 13 ------------- configs/at91sam9260ek_dataflash_cs0_defconfig | 1 + configs/at91sam9260ek_dataflash_cs1_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 1 + configs/at91sam9xeek_dataflash_cs1_defconfig | 1 + configs/meesc_dataflash_defconfig | 1 + configs/usb_a9263_dataflash_defconfig | 1 + env/Kconfig | 14 ++++++++++++++ include/configs/at91sam9260ek.h | 2 -- include/configs/at91sam9261ek.h | 2 -- include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/meesc.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/usb_a9263.h | 1 - scripts/config_whitelist.txt | 1 - 26 files changed, 29 insertions(+), 24 deletions(-)
diff --git a/README b/README index d94a4ac120..59b160ad1e 100644 --- a/README +++ b/README @@ -3442,19 +3442,6 @@ environment in RAM: we could work on NVRAM directly, but we want to keep settings there always unmodified except somebody uses "saveenv" to save the current settings.
-- CONFIG_ENV_IS_IN_DATAFLASH: - - Define this if you have a DataFlash memory device which you - want to use for the environment. - - - CONFIG_ENV_OFFSET: - - CONFIG_ENV_ADDR: - - CONFIG_ENV_SIZE: - - These three #defines specify the offset and size of the - environment area within the total memory of your DataFlash placed - at the specified address. - - CONFIG_ENV_IS_IN_SPI_FLASH:
Define this if you have a SPI Flash memory device which you diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 7c43c5082e..8eeccd88f3 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_DATAFLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 1f959eaca6..867bfcd42d 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_DATAFLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 15adf43c42..dd5ba3a547 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_DATAFLASH=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 05113b9805..77c96e8913 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_DATAFLASH=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index d1074faea3..f04981e477 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_DATAFLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index d1074faea3..f04981e477 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_DATAFLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 70e526a5cf..b00a17cac6 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_DATAFLASH=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index 8da1bfe5cd..e74e4cf09b 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_DATAFLASH=y # CONFIG_MMC is not set CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 3df66b6488..9461ebd4f3 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_DATAFLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index f0a3a667c4..870b3db37a 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_DATAFLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index e2642b9e76..9913a9fe2a 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_DATAFLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 5405939640..cf23b39f94 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_DATAFLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index a0577026d6..2792ae505b 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_DATAFLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index de8a8cbf0a..bd048acf57 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -14,5 +14,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_DATAFLASH=y # CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 7a8005b6db..d744f7c86b 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -16,5 +16,6 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y +CONFIG_ENV_IS_IN_DATAFLASH=y # CONFIG_MMC is not set CONFIG_OF_LIBFDT=y diff --git a/env/Kconfig b/env/Kconfig index 30a493fcdd..ea973458ca 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -1,5 +1,19 @@ menu "Environment"
+config ENV_IS_IN_DATAFLASH + bool "Environment in dataflash" + help + Define this if you have a DataFlash memory device which you + want to use for the environment. + + - CONFIG_ENV_OFFSET: + - CONFIG_ENV_ADDR: + - CONFIG_ENV_SIZE: + + These three #defines specify the offset and size of the + environment area within the total memory of your DataFlash placed + at the specified address. + config ENV_IS_IN_EEPROM bool "Environment in EEPROM" help diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 8b0105c017..51b6fab716 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -146,7 +146,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH_CS0
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) @@ -160,7 +159,6 @@ #elif CONFIG_SYS_USE_DATAFLASH_CS1
/* bootstrap + u-boot + env + linux in dataflash on CS1 */ -#define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + 0x8400) #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + CONFIG_ENV_OFFSET) diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index d86f07b982..4e151cdd04 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -139,7 +139,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH_CS0
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) @@ -153,7 +152,6 @@ #elif CONFIG_SYS_USE_DATAFLASH_CS3
/* bootstrap + u-boot + env + linux in dataflash on CS3 */ -#define CONFIG_ENV_IS_IN_DATAFLASH #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 + 0x8400) #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 + CONFIG_ENV_OFFSET) diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 9effe9ebd9..62099c7024 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -249,7 +249,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 05ba542382..1d068f4c50 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -95,7 +95,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 3b7643fb63..63d3fdc6ee 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -134,7 +134,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env in dataflash on CS0 */ -# define CONFIG_ENV_IS_IN_DATAFLASH # define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ 0x8400) # define CONFIG_ENV_OFFSET 0x4200 diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index bae5736801..f100a40f21 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -240,7 +240,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH_CS0
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE \ (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) #define CONFIG_ENV_OFFSET 0x4200 diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 9ea444009a..da0cd9d62b 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -268,7 +268,6 @@ #ifdef CONFIG_SYS_USE_DATAFLASH
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH #define CFG_MONITOR_BASE (CFG_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CFG_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 57e22208c4..335ce4e12e 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -112,7 +112,6 @@ #define CONFIG_SYS_MEMTEST_END 0x23e00000
/* bootstrap + u-boot + env in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_DATAFLASH #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x4000) #define CONFIG_ENV_OFFSET 0x2000 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 91e5f89d04..4530924dd5 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -633,7 +633,6 @@ CONFIG_ENV_FLAGS_LIST_STATIC CONFIG_ENV_FLASHBOOT CONFIG_ENV_IS_EMBEDDED CONFIG_ENV_IS_IN_ -CONFIG_ENV_IS_IN_DATAFLASH CONFIG_ENV_IS_IN_FAT CONFIG_ENV_IS_IN_ONENAND CONFIG_ENV_IS_IN_REMOTE
This converts the following to Kconfig: CONFIG_ENV_IS_IN_SPI_FLASH
Changes in v2: - Update turris_omnia also
README | 37 ----------- arch/arm/mach-mvebu/Kconfig | 1 + arch/x86/cpu/baytrail/Kconfig | 1 + configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/M52277EVB_stmicro_defconfig | 1 + configs/M54418TWR_defconfig | 1 + configs/M54418TWR_serial_mii_defconfig | 1 + configs/M54418TWR_serial_rmii_defconfig | 1 + configs/M54451EVB_stmicro_defconfig | 1 + configs/M54455EVB_stm33_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1024RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P5020DS_SPIFLASH_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2081QDS_SPIFLASH_defconfig | 1 + configs/UCP1020_SPIFLASH_defconfig | 1 + configs/alt_defconfig | 1 + configs/am335x_evm_spiboot_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/ap121_defconfig | 1 + configs/ap143_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/bayleybay_defconfig | 2 +- configs/brppt1_spi_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chromebook_link64_defconfig | 5 +- configs/chromebook_link_defconfig | 5 +- configs/chromebook_samus_defconfig | 3 +- configs/chromebox_panther_defconfig | 5 +- configs/cl-som-am57x_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t43_defconfig | 1 + ...conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/controlcenterdc_defconfig | 3 +- configs/cougarcanyon2_defconfig | 3 +- configs/crownbay_defconfig | 3 +- configs/d2net_v2_defconfig | 1 + configs/da850_am18xxevm_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/db-88f6720_defconfig | 1 + configs/db-88f6820-amc_defconfig | 1 + configs/db-88f6820-gp_defconfig | 3 +- configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/ea20_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/galileo_defconfig | 1 + configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/gose_defconfig | 1 + configs/inetspace_v2_defconfig | 1 + configs/kmcoge4_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmlion1_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmsugp1_defconfig | 1 + configs/kmsuv31_defconfig | 1 + configs/koelsch_defconfig | 1 + configs/lager_defconfig | 1 + configs/ls1012afrdm_qspi_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 2 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1021aiot_qspi_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + configs/ls1043aqds_qspi_defconfig | 1 + configs/ls1046aqds_qspi_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2081ardb_defconfig | 3 +- configs/ls2088ardb_qspi_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/marsboard_defconfig | 3 +- configs/minnowmax_defconfig | 2 +- configs/mvebu_db-88f3720_defconfig | 1 + configs/mvebu_db-88f7040_defconfig | 71 ++++++++++++++++++++++ configs/mvebu_db_armada8k_defconfig | 1 + configs/mvebu_espressobin-88f3720_defconfig | 1 + configs/mvebu_mcbin-88f8040_defconfig | 1 + configs/mx28evk_spi_defconfig | 2 +- configs/mx6slevk_spinor_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/ot1200_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/pcm058_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/porter_defconfig | 1 + configs/sama5d2_ptc_spiflash_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d36ek_cmp_spiflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sh7752evb_defconfig | 1 + configs/sh7753evb_defconfig | 1 + configs/sh7757lcr_defconfig | 1 + configs/silk_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/snow_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 2 +- configs/spring_defconfig | 1 + configs/stout_defconfig | 1 + configs/stv0991_defconfig | 1 + configs/tqma6dl_mba6_spi_defconfig | 1 + configs/tqma6q_mba6_spi_defconfig | 1 + configs/tqma6s_mba6_spi_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/turris_omnia_defconfig | 1 + configs/vinco_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + env/Kconfig | 38 ++++++++++++ include/config_fsl_chain_trust.h | 5 -- include/configs/B4860QDS.h | 1 - include/configs/BSC9131RDB.h | 1 - include/configs/BSC9132QDS.h | 1 - include/configs/C29XPCIE.h | 1 - include/configs/M52277EVB.h | 1 - include/configs/M54418TWR.h | 1 - include/configs/M54451EVB.h | 1 - include/configs/M54455EVB.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P1022DS.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240QDS.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/UCP1020.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/am335x_evm.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/ap121.h | 1 - include/configs/ap143.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/at91-sama5_common.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 2 - include/configs/bav335x.h | 1 - include/configs/blanche.h | 1 - include/configs/brppt1.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cl-som-am57x.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cm_t43.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/controlcenterdc.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/da850evm.h | 1 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/dreamplug.h | 1 - include/configs/ds109.h | 1 - include/configs/ds414.h | 1 - include/configs/ea20.h | 1 - include/configs/efi-x86.h | 1 - include/configs/ethernut5.h | 1 - include/configs/exynos5-dt-common.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 3 - include/configs/km/km_arm.h | 1 - include/configs/km/kmp204x-common.h | 1 - include/configs/lacie_kw.h | 1 - include/configs/ls1012a_common.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1046ardb.h | 1 - include/configs/ls2080a_common.h | 1 - include/configs/lsxl.h | 1 - include/configs/maxbcm.h | 1 - include/configs/microblaze-generic.h | 1 - include/configs/mvebu_armada-37xx.h | 1 - include/configs/mvebu_armada-8k.h | 1 - include/configs/mx6slevk.h | 1 - include/configs/nitrogen6x.h | 5 -- include/configs/odroid_xu3.h | 2 - include/configs/omapl138_lcdk.h | 2 - include/configs/ot1200.h | 1 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/pcm058.h | 1 - include/configs/qemu-x86.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/socfpga_is1.h | 1 - include/configs/socfpga_sr1500.h | 1 - include/configs/socfpga_vining_fpga.h | 1 - include/configs/stv0991.h | 1 - include/configs/theadorable.h | 1 - include/configs/tqma6.h | 1 - include/configs/trimslice.h | 1 - include/configs/turris_omnia.h | 1 - include/configs/x86-chromebook.h | 1 - include/configs/x86-common.h | 1 - include/configs/zynq-common.h | 1 - scripts/config_whitelist.txt | 1 - 269 files changed, 292 insertions(+), 164 deletions(-) create mode 100644 configs/mvebu_db-88f7040_defconfig
diff --git a/README b/README index 59b160ad1e..84da090e50 100644 --- a/README +++ b/README @@ -3442,43 +3442,6 @@ environment in RAM: we could work on NVRAM directly, but we want to keep settings there always unmodified except somebody uses "saveenv" to save the current settings.
-- CONFIG_ENV_IS_IN_SPI_FLASH: - - Define this if you have a SPI Flash memory device which you - want to use for the environment. - - - CONFIG_ENV_OFFSET: - - CONFIG_ENV_SIZE: - - These two #defines specify the offset and size of the - environment area within the SPI Flash. CONFIG_ENV_OFFSET must be - aligned to an erase sector boundary. - - - CONFIG_ENV_SECT_SIZE: - - Define the SPI flash's sector size. - - - CONFIG_ENV_OFFSET_REDUND (optional): - - This setting describes a second storage area of CONFIG_ENV_SIZE - size used to hold a redundant copy of the environment data, so - that there is a valid backup copy in case there is a power failure - during a "saveenv" operation. CONFIG_ENV_OFFSET_REDUND must be - aligned to an erase sector boundary. - - - CONFIG_ENV_SPI_BUS (optional): - - CONFIG_ENV_SPI_CS (optional): - - Define the SPI bus and chip select. If not defined they will be 0. - - - CONFIG_ENV_SPI_MAX_HZ (optional): - - Define the SPI max work clock. If not defined then use 1MHz. - - - CONFIG_ENV_SPI_MODE (optional): - - Define the SPI work mode. If not defined then use SPI_MODE_3. - - CONFIG_ENV_IS_IN_REMOTE:
Define this if you have a remote memory space which you diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 01d700bf2e..1b12b33060 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -32,6 +32,7 @@ config ARMADA_38X config ARMADA_XP bool select ARMADA_32BIT + imply ENV_IS_IN_SPI_FLASH
# ARMv8 SoCs... config ARMADA_3700 diff --git a/arch/x86/cpu/baytrail/Kconfig b/arch/x86/cpu/baytrail/Kconfig index 6c85186486..4e7d4a4e25 100644 --- a/arch/x86/cpu/baytrail/Kconfig +++ b/arch/x86/cpu/baytrail/Kconfig @@ -7,6 +7,7 @@ config INTEL_BAYTRAIL bool select HAVE_FSP if !EFI + imply ENV_IS_IN_SPI_FLASH
if INTEL_BAYTRAIL config INTERNAL_UART diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index bf0b26f0a2..72a01a9582 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index 04849d6315..97cff60290 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index 4434790b65..75fdf736b8 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index 4bce5427b8..3e4ca3ecde 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig index e848d8a2af..66c8ff8747 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig index 444d552293..6088e2bc8b 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index 41bf176650..9c54432cd0 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/M52277EVB_stmicro_defconfig b/configs/M52277EVB_stmicro_defconfig index d657f863d0..8a8eec7c3b 100644 --- a/configs/M52277EVB_stmicro_defconfig +++ b/configs/M52277EVB_stmicro_defconfig @@ -13,6 +13,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y CONFIG_CMD_JFFS2=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54418TWR_defconfig b/configs/M54418TWR_defconfig index 3445394b90..99ab91874c 100644 --- a/configs/M54418TWR_defconfig +++ b/configs/M54418TWR_defconfig @@ -16,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_serial_mii_defconfig b/configs/M54418TWR_serial_mii_defconfig index 729acfebdd..d433ca5837 100644 --- a/configs/M54418TWR_serial_mii_defconfig +++ b/configs/M54418TWR_serial_mii_defconfig @@ -16,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_serial_rmii_defconfig b/configs/M54418TWR_serial_rmii_defconfig index 3445394b90..99ab91874c 100644 --- a/configs/M54418TWR_serial_rmii_defconfig +++ b/configs/M54418TWR_serial_rmii_defconfig @@ -16,5 +16,6 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54451EVB_stmicro_defconfig b/configs/M54451EVB_stmicro_defconfig index d675825018..5f227980d0 100644 --- a/configs/M54451EVB_stmicro_defconfig +++ b/configs/M54451EVB_stmicro_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_DATE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_stm33_defconfig b/configs/M54455EVB_stm33_defconfig index eed2eabe68..a6330aba43 100644 --- a/configs/M54455EVB_stm33_defconfig +++ b/configs/M54455EVB_stm33_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index 156c8590ba..8f2ead0a9b 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_FSL_DDR2=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index dc4a6a72c9..80306c7edd 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index f15da83b99..eaa21cbb3b 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 8f33a9be78..6b1a273d6b 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 6070bf1f57..e8185d2ee7 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 324c6a055c..3ecd7d050c 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 79cba1a071..8d2f84e824 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 60f5ab3206..7db7be237f 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index ec326a089a..e251dfa44b 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index 86052a4c7d..2e8c69fe78 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index 25521d8787..9755931a37 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 22c3b6b278..d573045ba3 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_PING=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index ae12d7c03e..b91bf1df35 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index 672b7bbbf9..305ca553c0 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index ee8227a5ba..6e6f17fb2a 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 5091022f81..a5a1fc1a98 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_DATE=y # CONFIG_CMD_HASH is not set CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 5a7821a48b..ef8acbd695 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index e2308a26fb..34fe785199 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index 37575eca2f..b0977b0b82 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5020DS_SPIFLASH_defconfig b/configs/P5020DS_SPIFLASH_defconfig index c5e0b6aaeb..29119cf088 100644 --- a/configs/P5020DS_SPIFLASH_defconfig +++ b/configs/P5020DS_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index e31215ac68..c27f8c21d1 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index c63b98c8ef..cf72ebee57 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index f55a2bb424..bf36f7634d 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 25e81fdc19..b5433037df 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 2a872b930f..957c9aba6d 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index 9f5a8c4e9c..b4a9bb0ba8 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_ETHSW=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index c6fcaf3b98..49ccb00af4 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 807519162a..c1b1d79ece 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 10b29c4a9a..c3b5744a4a 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index ca7a38b7d2..ca83834a5d 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/T2081QDS_SPIFLASH_defconfig b/configs/T2081QDS_SPIFLASH_defconfig index 3e3031e134..8f00fecb77 100644 --- a/configs/T2081QDS_SPIFLASH_defconfig +++ b/configs/T2081QDS_SPIFLASH_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_FSL_CAAM=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig index 29bf82a456..80bf962e26 100644 --- a/configs/UCP1020_SPIFLASH_defconfig +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_CRAMFS=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 04dda72532..110bdd62c2 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 562c048c90..04cde994eb 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -22,6 +22,7 @@ CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 87d5ba7ea9..fb0bf46ed9 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig index 3e1f0587a1..703149c2fc 100644 --- a/configs/ap121_defconfig +++ b/configs/ap121_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y diff --git a/configs/ap143_defconfig b/configs/ap143_defconfig index 58eb77b5a2..b294b19de4 100644 --- a/configs/ap143_defconfig +++ b/configs/ap143_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_SPI=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 4bd3087cb9..59c6edb3a0 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index dfdc972327..3a6d35f441 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 0a8b38d9c6..2871e489c7 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_MTD_UBI_FASTMAP=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 8b8229b2cb..e23801fd6d 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index f52d9210fc..1efcf3dee3 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index f8d2ce3702..5f1c4706f5 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 14b74c4a16..03a71edb24 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -46,7 +46,6 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_SCSI=y CONFIG_CPU=y CONFIG_MMC=y CONFIG_MMC_PCI=y @@ -60,6 +59,7 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_ICH_SPI=y CONFIG_TIMER=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 66e086db68..ec9e620a9f 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -53,6 +53,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NETCONSOLE=y CONFIG_MMC_OMAP_HS=y CONFIG_SPI_FLASH=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 85ac7ace12..1463de5a0e 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -44,6 +44,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_USB=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 557919c5d8..1f1d7183bc 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -52,13 +52,12 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_DM=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_BLK=y CONFIG_CPU=y CONFIG_DM_I2C=y @@ -71,6 +70,8 @@ CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 CONFIG_DEBUG_UART_BOARD_INIT=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 3105fed469..70d6baa0af 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -38,10 +38,9 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_BLK=y CONFIG_CPU=y CONFIG_DM_I2C=y @@ -54,6 +53,8 @@ CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 CONFIG_DEBUG_UART_BOARD_INIT=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index ab2d27eb03..8cfe8bf16a 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -38,9 +38,9 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_SCSI=y CONFIG_CPU=y CONFIG_INTEL_BROADWELL_GPIO=y CONFIG_CROS_EC=y @@ -51,6 +51,7 @@ CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_SCSI=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 CONFIG_DEBUG_UART_BOARD_INIT=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 30d4019856..8f34fc3d6a 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -34,10 +34,9 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_BLK=y CONFIG_CROS_EC=y CONFIG_CROS_EC_LPC=y @@ -49,6 +48,8 @@ CONFIG_DM_ETH=y CONFIG_RTL8169=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_ICH_SPI=y CONFIG_TIMER=y diff --git a/configs/cl-som-am57x_defconfig b/configs/cl-som-am57x_defconfig index bf753bc074..f3fd2c4985 100644 --- a/configs/cl-som-am57x_defconfig +++ b/configs/cl-som-am57x_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 26b4f8abc1..3ff96f3663 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -46,6 +46,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index c652c4fa1e..73f3868809 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -48,6 +48,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_MMC_OMAP_HS=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index a0cce754ff..2cb00de288 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -44,6 +44,7 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index a46c46875d..1e4b9ee0db 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -33,8 +33,8 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_EFI_PARTITION=y CONFIG_OF_BOARD_FIXUP=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_SCSI=y CONFIG_DM_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y @@ -45,6 +45,7 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MV=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SCSI=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 1008ef7301..21bbc325e5 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -27,13 +27,14 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_SCSI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_ICH_SPI=y CONFIG_TIMER=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index ac50681e19..5bb354bc39 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -33,9 +33,9 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_SCSI=y CONFIG_CPU=y CONFIG_MMC=y CONFIG_MMC_PCI=y @@ -51,6 +51,7 @@ CONFIG_E1000=y CONFIG_PCH_GBE=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_ICH_SPI=y CONFIG_TIMER=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index a0b5c752cc..a83865493f 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index 74b3f0398d..7d830da174 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_DIAG=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 3745b859ed..bd011d745a 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_DIAG=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 55378efb0f..5dbaf0822d 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y # CONFIG_DOS_PARTITION is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_MISC=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index 3831f403b8..271d440203 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index f0b0d698b1..4611503831 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -36,8 +36,8 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_SCSI=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_MV=y @@ -45,6 +45,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PCI=y +CONFIG_SCSI=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index 60db28979c..743276d164 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index 7a8c268672..d9e14d87a0 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 8f3ffcf5ba..ff8ec6002f 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index d8f373b492..eeac7cc0be 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 4ee7d5aac1..a6abe02e30 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 197052dba6..5006c87118 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MTD_NOR_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index f60abc3422..d8460ad309 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -37,6 +37,7 @@ CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index aaeb34d7c0..8e4f2260ac 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_GENERIC=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index 78187051eb..9bafa18b8d 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_GENERIC=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 967ddba13a..c709cd5d4e 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FS_GENERIC=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 5627a18631..9f66c6fabe 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 8daf4332ca..2e116a4b7e 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 8d46b6ad3e..8854db4e9b 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set CONFIG_CMD_UBI=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index af0df7ef22..3470717605 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmlion1_defconfig b/configs/kmlion1_defconfig index 23859e9bed..f3b9ac322e 100644 --- a/configs/kmlion1_defconfig +++ b/configs/kmlion1_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_JFFS2=y # CONFIG_CMD_IRQ is not set CONFIG_CMD_UBI=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index eb70cd600a..ce79da1738 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index ed90f9d5b6..3d97fd5cf3 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index c5edce8e4f..e2bfe7b362 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 465a6be8e7..0383380cfb 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index c2f216bd51..9602020193 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index 7932ab5ada..636823b450 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y # CONFIG_MMC is not set diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 5ce3b0b1cc..b6d2d1fa1c 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SCSI=y @@ -42,6 +43,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index acf0a90c29..dada416746 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y # CONFIG_BLK is not set diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index 3628367df0..744653af3f 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -6,6 +6,7 @@ CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_GPT=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 7993a69ee3..65d0450715 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 07a414397a..cd0a46d9f6 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_BMP=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 348be3b1b9..80fae3c44e 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index d145c5a3a2..da34852a27 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 0a8f1a0501..d80cf53be0 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index f08e7bfa87..3383aa509d 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DATE=y # CONFIG_ISO_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index bc2792e533..cd19a20389 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -19,9 +19,9 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_SCSI=y CONFIG_FSL_CAAM=y CONFIG_DM_SPI_FLASH=y CONFIG_NETDEVICES=y @@ -30,6 +30,7 @@ CONFIG_PCI=y CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SCSI=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 76b2f32677..0ca4113d58 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_FSL_CAAM=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 1d55003d67..bf91343e2a 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 75fe55d819..67ed1c9702 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index b6fbbb965b..04b09cbd2a 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -3,7 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_VIDEO=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -17,6 +17,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index a64a0a3455..81e8253719 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -47,7 +47,6 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_SCSI=y CONFIG_CPU=y CONFIG_MMC=y CONFIG_MMC_PCI=y @@ -62,6 +61,7 @@ CONFIG_DM_ETH=y CONFIG_RTL8169=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_SCSI=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 CONFIG_SYS_NS16550=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index f2b2e5db90..451cf39e63 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BLOCK_CACHE=y CONFIG_DM_GPIO=y # CONFIG_MVEBU_GPIO is not set diff --git a/configs/mvebu_db-88f7040_defconfig b/configs/mvebu_db-88f7040_defconfig new file mode 100644 index 0000000000..bbe9c8e683 --- /dev/null +++ b/configs/mvebu_db-88f7040_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_MVEBU_ARMADA_8K=y +CONFIG_DEFAULT_DEVICE_TREE="armada-7040-db" +CONFIG_SMBIOS_PRODUCT_NAME="" +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_MVEBU_BUBT=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_BLOCK_CACHE=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_XENON=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_MARVELL=y +CONFIG_MVPP2=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_DW_MVEBU=y +CONFIG_MVEBU_COMPHY_SUPPORT=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_ARMADA_8K=y +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_DEBUG_UART_BASE=0xf0512000 +CONFIG_DEBUG_UART_CLOCK=200000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_SMBIOS_MANUFACTURER="" diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig index 7f36eda665..6bb62ce80e 100644 --- a/configs/mvebu_db_armada8k_defconfig +++ b/configs/mvebu_db_armada8k_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 9ab7f4603a..14f5d28192 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BLOCK_CACHE=y CONFIG_DM_I2C=y CONFIG_MISC=y diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig index a4fec5dc1f..cfb665cee3 100644 --- a/configs/mvebu_mcbin-88f8040_defconfig +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_MAC_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BLOCK_CACHE=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 1b5de66553..4164965cc2 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_VIDEO=y -CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -33,6 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MMC_MXS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 67d62f8812..99d6a6e0f3 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_GPIO=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index ab8eb958ca..5a624aed3a 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 66db6447ac..63861dde4d 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 04abc9405b..02e6e5be94 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 5f79e6f0e2..cb4e464e93 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index a81ad0b1e8..01683f6083 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 5744ede776..d851661850 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index dca89ec34e..0dd8affe0c 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index baa509d48e..54684cfd72 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index ebfa843061..d5ff2476f8 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 0f7532062a..77e0940f7a 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 45a5acb96c..79c7f39c99 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index d3e8a275c8..7d23a990ad 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 531fb334ce..3ad7a50769 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index d18faf7a04..d618e8b25e 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -42,6 +42,7 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_MTD=y CONFIG_SPI_FLASH=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 0b53af833e..1a28fe9966 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 1e93856f71..4b765da46e 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_TUNNEL=y CONFIG_I2C_MUX=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index a50d9ed99b..185ec9f7fb 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/sama5d2_ptc_spiflash_defconfig b/configs/sama5d2_ptc_spiflash_defconfig index 8771e0846c..951c792ebb 100644 --- a/configs/sama5d2_ptc_spiflash_defconfig +++ b/configs/sama5d2_ptc_spiflash_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL=y CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y CONFIG_USB=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 2680ab99af..7fc2b07f8d 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d36ek_cmp_spiflash_defconfig b/configs/sama5d36ek_cmp_spiflash_defconfig index 8db4f524f8..3f6df43942 100644 --- a/configs/sama5d36ek_cmp_spiflash_defconfig +++ b/configs/sama5d36ek_cmp_spiflash_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 0166cb6e12..79e6a67faf 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index e7e3169bbc..b6dae2386b 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 98813bcd7e..7da9c45d2c 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index 4e19243f0d..1db697205c 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_MAC_PARTITION=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index 23b7d7df48..5f36a8cd7d 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_MAC_PARTITION=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index 44224e1e43..3ea2158fca 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_MAC_PARTITION=y CONFIG_DOS_PARTITION=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index d161c3bb88..3726b235a6 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index c51df50678..b095f02c9b 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_SOUND=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_I2C_COMPAT=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index bff944491e..5889de8cdb 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_I2C_COMPAT=y CONFIG_MMC_DW=y CONFIG_MMC_SDHCI=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 5cccd910a5..d5c9c082ae 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 058791e968..73b940506c 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 4468d3b71d..44b195bd92 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DM_GPIO=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 21754b4c5d..01ffeb31c6 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 56a7e4b017..47daca0969 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -43,7 +43,6 @@ CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_SCSI=y CONFIG_CPU=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y @@ -54,6 +53,7 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_DM_PCI=y CONFIG_DM_RTC=y +CONFIG_SCSI=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 CONFIG_SYS_NS16550=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 554ac7771b..41c793004d 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_I2C_COMPAT=y CONFIG_I2C_CROS_EC_LDO=y CONFIG_I2C_MUX=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index 48989aaea6..8c27a1052c 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig index c91b8b7335..fe8d8243bf 100644 --- a/configs/stv0991_defconfig +++ b/configs/stv0991_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y # CONFIG_MMC is not set CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/tqma6dl_mba6_spi_defconfig b/configs/tqma6dl_mba6_spi_defconfig index dee295ee35..46d6b77561 100644 --- a/configs/tqma6dl_mba6_spi_defconfig +++ b/configs/tqma6dl_mba6_spi_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index 3ec25c8217..2c345de7a5 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index f824018849..365d36f2bd 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index cb42ac559a..efb0006e3e 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 4a45ed0ea4..32ec7180a5 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y # CONFIG_SPL_PARTITION_UUIDS is not set +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_MISC=y CONFIG_ATSHA204A=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index c8da54d9b6..71d7e6cb35 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index 2d7fffc1f4..d4ede3ebf7 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 8f20b09244..0be8e028d7 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 825346abd6..98ef6d7887 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index a1ef49f250..c4c2714952 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_MMC_SDHCI=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 2887ca4167..42f5ba1ec3 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index f3f89cb5e4..3689c53643 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y diff --git a/env/Kconfig b/env/Kconfig index ea973458ca..1f744cc576 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -250,6 +250,44 @@ config ENV_IS_IN_NVRAM can just be read and written to, without any special provision.
+config ENV_IS_IN_SPI_FLASH + bool "Environment is in SPI flash" + help + Define this if you have a SPI Flash memory device which you + want to use for the environment. + + - CONFIG_ENV_OFFSET: + - CONFIG_ENV_SIZE: + + These two #defines specify the offset and size of the + environment area within the SPI Flash. CONFIG_ENV_OFFSET must be + aligned to an erase sector boundary. + + - CONFIG_ENV_SECT_SIZE: + + Define the SPI flash's sector size. + + - CONFIG_ENV_OFFSET_REDUND (optional): + + This setting describes a second storage area of CONFIG_ENV_SIZE + size used to hold a redundant copy of the environment data, so + that there is a valid backup copy in case there is a power failure + during a "saveenv" operation. CONFIG_ENV_OFFSET_REDUND must be + aligned to an erase sector boundary. + + - CONFIG_ENV_SPI_BUS (optional): + - CONFIG_ENV_SPI_CS (optional): + + Define the SPI bus and chip select. If not defined they will be 0. + + - CONFIG_ENV_SPI_MAX_HZ (optional): + + Define the SPI max work clock. If not defined then use 1MHz. + + - CONFIG_ENV_SPI_MODE (optional): + + Define the SPI work mode. If not defined then use SPI_MODE_3. + config ENV_IS_IN_UBI bool "Environment in a UBI volume" help diff --git a/include/config_fsl_chain_trust.h b/include/config_fsl_chain_trust.h index 195419b888..1aabe6e747 100644 --- a/include/config_fsl_chain_trust.h +++ b/include/config_fsl_chain_trust.h @@ -11,11 +11,6 @@ * not verified, undef CONFIG_ENV_xxx and set default env * (CONFIG_ENV_IS_NOWHERE) */ -#ifdef CONFIG_SECURE_BOOT - -#undef CONFIG_ENV_IS_IN_SPI_FLASH - -#endif
#ifdef CONFIG_CHAIN_OF_TRUST
diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index d580e9b36e..6ae9851545 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -115,7 +115,6 @@
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 5dd112c0c6..512e7cec1e 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -267,7 +267,6 @@ extern unsigned long get_sdram_size(void); * Environment */ #if defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 54d613707b..890d2e1206 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -489,7 +489,6 @@ combinations. this should be removed later #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 937e93ef0a..629a326d7b 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -404,7 +404,6 @@ */ #if defined(CONFIG_SYS_RAMBOOT) #if defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index 75acc59910..6f9ebee635 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -199,7 +199,6 @@ * crc error warning if there is no correct environment on the flash. */ #ifdef CONFIG_CF_SBF -# define CONFIG_ENV_IS_IN_SPI_FLASH # define CONFIG_ENV_SPI_CS 2 #endif #define CONFIG_ENV_OVERWRITE 1 diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index db40b426a8..7f4b671063 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -278,7 +278,6 @@ #endif
#if defined(CONFIG_CF_SBF) -#define CONFIG_ENV_IS_IN_SPI_FLASH 1 #define CONFIG_ENV_SPI_CS 1 #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index fbd5287147..b32ac11e8d 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -216,7 +216,6 @@ * crc error warning if there is no correct environment on the flash. */ #if defined(CONFIG_SYS_STMICRO_BOOT) -# define CONFIG_ENV_IS_IN_SPI_FLASH 1 # define CONFIG_ENV_SPI_CS 1 # define CONFIG_ENV_OFFSET 0x20000 # define CONFIG_ENV_SIZE 0x2000 diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index cc08df7d3d..1a0cc340fd 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -271,7 +271,6 @@ * crc error warning if there is no correct environment on the flash. */ #ifdef CONFIG_CF_SBF -# define CONFIG_ENV_IS_IN_SPI_FLASH # define CONFIG_ENV_SPI_CS 1 #endif #undef CONFIG_ENV_OVERWRITE diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index d96c15ec01..0245fc68eb 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -557,7 +557,6 @@
#if defined(CONFIG_SYS_RAMBOOT) #if defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index c4c8f3e617..846f94a00a 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -682,7 +682,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_SPIFLASH) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index b7507a2b29..32712e78ed 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -552,7 +552,6 @@ * Environment */ #ifdef CONFIG_SPIFLASH -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 36d08d8e7f..a31989835b 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -63,7 +63,6 @@
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC - #define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 48c7b2dcc2..79537755cc 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -145,7 +145,6 @@
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index dcfedc0410..a7f1bbcba7 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -160,7 +160,6 @@
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 56591f38d9..a0651a425e 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -72,7 +72,6 @@ #ifdef CONFIG_MTD_NOR_FLASH #if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 9cdd67f5b7..ca178a7f24 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -180,7 +180,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 0dcef00186..a7b894e316 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -141,7 +141,6 @@
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 90401a3256..274ff49aba 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -127,7 +127,6 @@
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index d9983653f0..0c1ec41e66 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -86,7 +86,6 @@
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index ee1110a317..df3888310c 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -327,7 +327,6 @@
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 31d7cdbd10..6fd3fa4712 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -375,7 +375,6 @@
#ifdef CONFIG_RAMBOOT_SPIFLASH
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x3000 /* 12KB */ #define CONFIG_ENV_OFFSET 0x2000 /* 8KB */ #define CONFIG_ENV_SECT_SIZE 0x1000 diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 58cf7ad888..22a4e69be5 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -239,7 +239,6 @@
/* FLASH and environment organization */
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (64 * 1024) diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 751929339a..ba3d0555ea 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -321,7 +321,6 @@ #define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 88487c9fb9..ffef0b8afe 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -128,7 +128,6 @@ #define CONFIG_SYS_TEXT_BASE CONFIG_ISW_ENTRY_ADDR #endif #undef CONFIG_ENV_IS_IN_FAT -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64 KB sectors */ diff --git a/include/configs/ap121.h b/include/configs/ap121.h index 2284b8bc66..e6778fe0c6 100644 --- a/include/configs/ap121.h +++ b/include/configs/ap121.h @@ -41,7 +41,6 @@ "64k(NVRAM),64k(ART)"
#define CONFIG_ENV_SPI_MAX_HZ 25000000 -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/ap143.h b/include/configs/ap143.h index 2950783097..bd6b83729c 100644 --- a/include/configs/ap143.h +++ b/include/configs/ap143.h @@ -45,7 +45,6 @@ "64k(ART)"
#define CONFIG_ENV_SPI_MAX_HZ 25000000 -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_SIZE 0x10000 diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 7360e11ff1..461de801f8 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -160,7 +160,6 @@
/* Environment organization */ #define CONFIG_ENV_SIZE (12 * 1024) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS #define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index e511d18234..33f2d85319 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -87,7 +87,6 @@ "bootz 0x22000000 - 0x21000000" #elif CONFIG_SYS_USE_SERIALFLASH /* u-boot env in serial flash, by default is bus 0 and cs 0 */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x6000 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x1000 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 7bccee905e..03846b55f5 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -126,7 +126,6 @@ #ifdef CONFIG_SYS_USE_SPIFLASH
/* bootstrap + u-boot + env + linux in dataflash on CS0 */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x5000 #define CONFIG_ENV_SIZE 0x3000 #define CONFIG_ENV_SECT_SIZE 0x1000 diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index a01072f059..7357e18115 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -125,7 +125,6 @@ "bootm 0x22000000" #elif defined(CONFIG_SYS_USE_SPIFLASH) /* bootstrap + u-boot + env + linux in spi flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x5000 #define CONFIG_ENV_SIZE 0x3000 #define CONFIG_ENV_SECT_SIZE 0x1000 @@ -135,7 +134,6 @@ "bootm 0x22000000" #elif defined(CONFIG_SYS_USE_DATAFLASH) /* bootstrap + u-boot + env + linux in data flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_SIZE 0x4200 #define CONFIG_ENV_SECT_SIZE 0x210 diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 04a6e06e0f..878731389e 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -500,7 +500,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ diff --git a/include/configs/blanche.h b/include/configs/blanche.h index 50692cba65..9a18046d9c 100755 --- a/include/configs/blanche.h +++ b/include/configs/blanche.h @@ -81,7 +81,6 @@ /* ENV setting */ #if !defined(CONFIG_MTD_NOR_FLASH) #else -#undef CONFIG_ENV_IS_IN_SPI_FLASH #undef CONFIG_ENV_ADDR #define CONFIG_ENV_SECT_SIZE (256 * 1024) #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index aa07e9b2da..c4079926d1 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -242,7 +242,6 @@ MMCARGS
#define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 5d797b4403..b36cbb9679 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -245,7 +245,6 @@
-#define CONFIG_ENV_IS_IN_SPI_FLASH #if defined(CONFIG_ENV_IS_IN_SPI_FLASH) #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (64 * 1024) diff --git a/include/configs/cl-som-am57x.h b/include/configs/cl-som-am57x.h index a04f4cd23d..c1cf4132fe 100644 --- a/include/configs/cl-som-am57x.h +++ b/include/configs/cl-som-am57x.h @@ -50,7 +50,6 @@ #define CONFIG_ENV_SIZE (16 << 10) /* 16 KiB env size */ #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SPI_MAX_HZ 48000000 diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 1d9c1650d5..b217083ac1 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -67,7 +67,6 @@ "-(reserved)"
/* Environment */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 7b5ca0db0f..f6e0743b53 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -97,7 +97,6 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SPI_MAX_HZ 48000000 diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index f9245e06ba..1ac416260e 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -300,7 +300,6 @@ #if defined(CONFIG_TRAILBLAZER) #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #elif defined(CONFIG_RAMBOOT_SPIFLASH) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index f10cddafe0..021150ed61 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -65,7 +65,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 1 #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 70fdb58163..07183c9095 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -74,7 +74,6 @@
#if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 2277215445..100b114e25 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -231,7 +231,6 @@ #endif
#ifdef CONFIG_USE_SPIFLASH -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_OFFSET (512 << 10) #define CONFIG_ENV_SECT_SIZE (64 << 10) diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index 699c03f844..cdaaced2eb 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -40,7 +40,6 @@ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */ diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 0f0ab01f62..864222955f 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -40,7 +40,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 1 #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 292bfb8f7d..4a9d2f75bf 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -62,7 +62,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 187ead3e4b..6ad5206fc0 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -44,7 +44,6 @@ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */ diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 1c2cc6f4b0..8566bdc569 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -137,7 +137,6 @@ #define CONFIG_SYS_SPI_ARGS_OFFS 0x140000 #define CONFIG_SYS_SPI_ARGS_SIZE 0x80000 #if defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SIZE (64 << 10) diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index 9715f297a9..7a739e39d7 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -32,7 +32,6 @@ * Environment variables configurations */ #ifdef CONFIG_SPI_FLASH -#define CONFIG_ENV_IS_IN_SPI_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64k */ #endif
diff --git a/include/configs/ds109.h b/include/configs/ds109.h index ad7fce84e8..a2c6837348 100644 --- a/include/configs/ds109.h +++ b/include/configs/ds109.h @@ -35,7 +35,6 @@ * Environment variables configurations */ #ifdef CONFIG_SPI_FLASH -#define CONFIG_ENV_IS_IN_SPI_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64k */ #endif
diff --git a/include/configs/ds414.h b/include/configs/ds414.h index aaba5d8eab..a209e6f09c 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -36,7 +36,6 @@ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x7E0000 /* RedBoot config partition in DTS */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 699888b9ea..e98f14f63d 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -87,7 +87,6 @@ #endif
#ifdef CONFIG_USE_SPIFLASH -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (8 << 10) #define CONFIG_ENV_OFFSET 0x80000 #define CONFIG_ENV_SECT_SIZE (64 << 10) diff --git a/include/configs/efi-x86.h b/include/configs/efi-x86.h index 7763365fe1..f5331915e2 100644 --- a/include/configs/efi-x86.h +++ b/include/configs/efi-x86.h @@ -13,7 +13,6 @@
#undef CONFIG_TPM_TIS_BASE_ADDRESS
-#undef CONFIG_ENV_IS_IN_SPI_FLASH #undef CONFIG_SCSI_AHCI #undef CONFIG_INTEL_ICH6_GPIO #undef CONFIG_USB_EHCI_PCI diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index e7f7a7cbe6..8a5eb89f8f 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -61,7 +61,6 @@ #define DATAFLASH_TCSS (0x1a << 16) #define DATAFLASH_TCHS (0x1 << 24)
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x3DE000 #define CONFIG_ENV_SECT_SIZE (132 << 10) #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index 1b94d07f67..11aa6b8a9a 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -18,7 +18,6 @@
#define CONFIG_EXYNOS5_DT
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BASE 0x12D30000 #define FLASH_SIZE (4 << 20) #define CONFIG_ENV_OFFSET (FLASH_SIZE - CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index ad97a16bc7..5e04dd24f4 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -269,7 +269,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* environment organization */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (64 * 1024) diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 7036ed0ef8..b9e85f249d 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -218,9 +218,6 @@ #endif
/* Persistent Environment Config */ -#ifdef CONFIG_SPI_FLASH - #define CONFIG_ENV_IS_IN_SPI_FLASH -#endif #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 1 diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 9a90e08d65..63319735de 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -214,7 +214,6 @@ int get_scl(void); * Environment variables configurations */ #if defined CONFIG_KM_ENV_IS_IN_SPI_NOR -#define CONFIG_ENV_IS_IN_SPI_FLASH /* use SPI-Flash for environment vars */ #define CONFIG_ENV_OFFSET 0xc0000 /* no bracets! */ #define CONFIG_ENV_SIZE 0x02000 /* Size of Environment */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 664a64c55a..373e4bc3b4 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -44,7 +44,6 @@
/* Environment in SPI Flash */ #define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 20000000 diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 66e65c878c..d3ec21142b 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -137,7 +137,6 @@ /* * Environment variables configurations */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64KB */ #define CONFIG_ENV_SIZE 0x1000 /* 4KB */ #define CONFIG_ENV_ADDR 0x70000 diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 42bbc028d3..74af0b9dc6 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -64,7 +64,6 @@ */ #define CONFIG_ENV_OVERWRITE
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x40000 /* 256KB */ #define CONFIG_ENV_OFFSET 0x200000 /* 2MB */ #define CONFIG_ENV_SECT_SIZE 0x40000 diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index e5544f327d..1f2eb52c24 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -290,7 +290,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index b823ff23bf..251a66e595 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -553,7 +553,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 8fe34ef658..b9e5cdbb1e 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -421,7 +421,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x20000 #elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET 0x300000 #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 740facfa58..415a705508 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -417,7 +417,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 782669ad2c..ea99676b7a 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -451,7 +451,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_QSPI_BOOT) -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 1c30462af2..20a5e7f659 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -171,7 +171,6 @@ #define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_ENV_SIZE 0x2000 #else -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index dbca05a3f6..6ae5586d64 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -31,7 +31,6 @@ #endif #else #define CONFIG_SYS_TEXT_BASE 0x20100000 -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index b21a285d19..8b94412028 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -60,7 +60,6 @@ #ifdef CONFIG_SPI_FLASH #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 8 -#define CONFIG_ENV_IS_IN_SPI_FLASH 1 #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K */ #endif
diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index b82a684cc9..66641ff1c9 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -36,7 +36,6 @@ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 5736621d41..d2442068b2 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -119,7 +119,6 @@ # define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE)
# else /* SPIFLASH && !RAMENV */ -# define CONFIG_ENV_IS_IN_SPI_FLASH 1 # define CONFIG_ENV_SPI_MODE SPI_MODE_3 # define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED # define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index eb80ac5b48..778cc9e378 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -79,7 +79,6 @@ #define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x180000 /* as Marvell U-Boot version */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64KiB sectors */ diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index eca13442ab..53db10f9bc 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -77,7 +77,6 @@
/* Environment in SPI NOR flash */ #ifdef CONFIG_MVEBU_SPI_BOOT -#define CONFIG_ENV_IS_IN_SPI_FLASH /* Environment in NAND flash */ #endif
diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 0f1a67dbb3..98797b07c1 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -137,7 +137,6 @@ #define CONFIG_ENV_SIZE SZ_8K
#if defined CONFIG_SPI_BOOT -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 6d5b0bd831..a1a0cdaf2e 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -270,11 +270,6 @@ /* Environment organization */ #define CONFIG_ENV_SIZE (8 * 1024)
-#if defined(CONFIG_SABRELITE) -#else -#define CONFIG_ENV_IS_IN_SPI_FLASH -#endif - #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index 3b920ccf16..697f8d2582 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -11,8 +11,6 @@ #include "exynos5420-common.h" #include <configs/exynos5-common.h>
-#undef CONFIG_ENV_IS_IN_SPI_FLASH - #define CONFIG_BOARD_COMMON
#define CONFIG_SYS_SDRAM_BASE 0x40000000 diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 83692c8982..6af8e80952 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -212,7 +212,6 @@ #endif
#ifdef CONFIG_USE_SPIFLASH -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_OFFSET (256 << 10) #define CONFIG_ENV_SECT_SIZE (64 << 10) @@ -310,7 +309,6 @@ #undef CONFIG_ENV_OFFSET #define CONFIG_ENV_SIZE (16 << 10) /* 16 KiB */ #define CONFIG_ENV_OFFSET (51 << 9) /* Sector 51 */ -#undef CONFIG_ENV_IS_IN_SPI_FLASH #endif
#ifndef CONFIG_DIRECT_NOR_BOOT diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index be6bbad32e..373c2d5ca2 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -115,7 +115,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* Environment organization */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (64 * 1024) /* 64 kb */ #define CONFIG_ENV_OFFSET (1024 * 1024) /* M25P16 has an erase size of 64 KiB */ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 201310d1d1..066674cb2f 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -772,7 +772,6 @@ * Environment */ #ifdef CONFIG_SPIFLASH -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index 39018ac62f..92087d1066 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -106,7 +106,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 1
/* Environment organization */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_OFFSET (1024 * SZ_1K) #define CONFIG_ENV_SECT_SIZE (64 * SZ_1K) diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h index 9690757109..64cbc807a6 100644 --- a/include/configs/qemu-x86.h +++ b/include/configs/qemu-x86.h @@ -48,7 +48,6 @@ #undef CONFIG_INTEL_ICH6_GPIO
/* SPI is not supported */ -#undef CONFIG_ENV_IS_IN_SPI_FLASH
#define CONFIG_SPL_FRAMEWORK
diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 365950d729..16f45f2bea 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* ENV setting */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_ADDR 0xC0000
/* Common ENV setting */ diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index 3342a2966c..46d0f2aede 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -84,7 +84,6 @@
/* ENV setting */ #define CONFIG_ENV_IS_EMBEDDED -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_ADDR (0x00080000) #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 78670422f7..aa8d05c221 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -84,7 +84,6 @@
/* ENV setting */ #define CONFIG_ENV_IS_EMBEDDED -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_ADDR (0x00080000) #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index e9cd3d749a..1759a6f5d9 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -94,7 +94,6 @@
/* ENV setting */ #define CONFIG_ENV_IS_EMBEDDED -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_ADDR (0x00080000) #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 73cfb44881..cd163d64f5 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -215,7 +215,6 @@ * 0x442000 - 0x800000 : Userland */ #if defined(CONFIG_SPI_BOOT) -# define CONFIG_ENV_IS_IN_SPI_FLASH # define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED # define CONFIG_ENV_OFFSET (892 << 10) /* 892 KiB in */ # define CONFIG_ENV_SECT_SIZE (4 << 10) /* 4 KB sectors */ diff --git a/include/configs/socfpga_is1.h b/include/configs/socfpga_is1.h index 68403aa744..febb8f7fcc 100644 --- a/include/configs/socfpga_is1.h +++ b/include/configs/socfpga_is1.h @@ -19,7 +19,6 @@ #define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) #define CONFIG_LOADADDR 0x01000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR -#define CONFIG_ENV_IS_IN_SPI_FLASH
/* Ethernet on SoC (EMAC) */ #if defined(CONFIG_CMD_NET) diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 4366061f77..39bf612291 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -24,7 +24,6 @@ #define PHY_ANEG_TIMEOUT 8000
/* Enable SPI NOR flash reset, needed for SPI booting */ #define CONFIG_SPI_N25Q256A_RESET diff --git a/include/configs/socfpga_vining_fpga.h b/include/configs/socfpga_vining_fpga.h index e2bdfb12f9..10240a1077 100644 --- a/include/configs/socfpga_vining_fpga.h +++ b/include/configs/socfpga_vining_fpga.h @@ -182,7 +182,6 @@ "256k(samtec2)," \ "-(rcvrfs);" /* Recovery */ \
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_SECT_SIZE (64 * 1024) diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index 2f808c6c72..0ac262e095 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -19,7 +19,6 @@ #define PHYS_SDRAM_1_SIZE 0x00198000
#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE #define CONFIG_ENV_OFFSET 0x30000 #define CONFIG_ENV_ADDR \ diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 94e207c8c4..3f9b69aeda 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -50,7 +50,6 @@ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_3
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 29e22aa311..b5b71570d1 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -166,7 +166,6 @@ #define TQMA6_UBOOT_SIZE (TQMA6_UBOOT_SECTOR_SIZE * \ TQMA6_UBOOT_SECTOR_COUNT)
-#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_OFFSET (TQMA6_UBOOT_SIZE) #define CONFIG_ENV_SECT_SIZE TQMA6_SPI_FLASH_SECTOR_SIZE diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index ab9c5c3ab8..fd36634ae9 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_I2C_TEGRA
/* Environment in SPI */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SPI_MAX_HZ 48000000 #define CONFIG_ENV_SPI_MODE SPI_MODE_0 #define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE diff --git a/include/configs/turris_omnia.h b/include/configs/turris_omnia.h index 4ad603d2fb..1020355ed5 100644 --- a/include/configs/turris_omnia.h +++ b/include/configs/turris_omnia.h @@ -69,7 +69,6 @@ #define CONFIG_EHCI_IS_TDI
/* Environment in SPI NOR flash */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET (3*(1 << 18)) /* 768KiB in */ #define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ #define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ diff --git a/include/configs/x86-chromebook.h b/include/configs/x86-chromebook.h index 51366d4d4e..4d02cd45f5 100644 --- a/include/configs/x86-chromebook.h +++ b/include/configs/x86-chromebook.h @@ -42,7 +42,6 @@ #undef CONFIG_ENV_SIZE #define CONFIG_ENV_SIZE 0x1000 #define CONFIG_ENV_SECT_SIZE 0x1000 -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_OFFSET 0x003f8000
#define CONFIG_STD_DEVICES_SETTINGS "stdin=usbkbd,i8042-kbd,serial\0" \ diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index d104449e3b..01558a8d6c 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -118,7 +118,6 @@ /*----------------------------------------------------------------------- * Environment configuration */ -#define CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_SIZE 0x01000
/*----------------------------------------------------------------------- diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 9b527feec8..83a2a028e9 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -163,7 +163,6 @@ /* Environment in NOR flash */ # elif defined(CONFIG_ZYNQ_QSPI) /* Environment in Serial Flash */ -# define CONFIG_ENV_IS_IN_SPI_FLASH # endif
# define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 4530924dd5..844d97a6cf 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -636,7 +636,6 @@ CONFIG_ENV_IS_IN_ CONFIG_ENV_IS_IN_FAT CONFIG_ENV_IS_IN_ONENAND CONFIG_ENV_IS_IN_REMOTE -CONFIG_ENV_IS_IN_SPI_FLASH CONFIG_ENV_MAX_ENTRIES CONFIG_ENV_MIN_ENTRIES CONFIG_ENV_OFFSET_OOB
On Sun, Jul 23, 2017 at 09:19:45PM -0600, Simon Glass wrote:
This converts the following to Kconfig: CONFIG_ENV_IS_IN_SPI_FLASH
Signed-off-by: Simon Glass sjg@chromium.org
This converts the following to Kconfig: CONFIG_ENV_IS_IN_REMOTE
Changes in v2: None
configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 1 + configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2081QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 1 + env/Kconfig | 14 ++++++++++++++ include/configs/B4860QDS.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240QDS.h | 1 - include/configs/corenet_ds.h | 1 - scripts/config_whitelist.txt | 1 - 19 files changed, 23 insertions(+), 9 deletions(-)
diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index 3f35106fbf..ac9271def7 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y +CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig index ebca0cec7b..547467ec25 100644 --- a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig index 390eea869b..321a05807a 100644 --- a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig index c2fd7d0586..e993748c06 100644 --- a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig index 068301c44d..de0d5437b3 100644 --- a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 97527e28a1..682cdd5ca9 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig index 2829d06d27..c700c45707 100644 --- a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y # CONFIG_CMD_IRQ is not set +CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig index 19c48a8f66..95536ff267 100644 --- a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig index e13d7b7444..3536795b29 100644 --- a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_REMOTE=y CONFIG_FSL_CAAM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/env/Kconfig b/env/Kconfig index 1f744cc576..3eb46111ff 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -250,6 +250,20 @@ config ENV_IS_IN_NVRAM can just be read and written to, without any special provision.
+config ENV_IS_IN_REMOTE + bool "Environment is in remove memory space" + help + Define this if you have a remote memory space which you + want to use for the local device's environment. + + - CONFIG_ENV_ADDR: + - CONFIG_ENV_SIZE: + + These two #defines specify the address and size of the + environment area within the remote memory space. The + local device can get the environment from remote memory + space by SRIO or PCIE links. + config ENV_IS_IN_SPI_FLASH bool "Environment is in SPI flash" help diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 6ae9851545..f9a677124b 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -132,7 +132,6 @@ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_ENV_IS_NOWHERE) diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index a31989835b..38fbf3785f 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -81,7 +81,6 @@ #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_ENV_IS_NOWHERE) diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 79537755cc..4bcd00426e 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -162,7 +162,6 @@ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_ENV_IS_NOWHERE) diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index a7f1bbcba7..c3716f76f1 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -185,7 +185,6 @@ #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #endif #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_ENV_IS_NOWHERE) diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index a7b894e316..fd2e3d323f 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -158,7 +158,6 @@ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_ENV_IS_NOWHERE) diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 274ff49aba..93e0cf6c93 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -144,7 +144,6 @@ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (2 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_ENV_IS_NOWHERE) diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 0c1ec41e66..944dab8068 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -103,7 +103,6 @@ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_ENV_IS_NOWHERE) diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 07183c9095..0ea76b3300 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -92,7 +92,6 @@ #define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) -#define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 #define CONFIG_ENV_SIZE 0x2000 #elif defined(CONFIG_ENV_IS_NOWHERE) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 844d97a6cf..222e553bf6 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -635,7 +635,6 @@ CONFIG_ENV_IS_EMBEDDED CONFIG_ENV_IS_IN_ CONFIG_ENV_IS_IN_FAT CONFIG_ENV_IS_IN_ONENAND -CONFIG_ENV_IS_IN_REMOTE CONFIG_ENV_MAX_ENTRIES CONFIG_ENV_MIN_ENTRIES CONFIG_ENV_OFFSET_OOB
This converts the following to Kconfig: CONFIG_ENV_IS_IN_FAT
Changes in v2: None
README | 44 ------------------------ arch/arm/Kconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/am335x_hs_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_ethboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/axs101_defconfig | 1 + configs/axs103_defconfig | 1 + configs/hikey_defconfig | 1 + configs/hsdk_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d36ek_cmp_mmc_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/xilinx_zynqmp_ep_defconfig | 5 +-- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 + configs/xilinx_zynqmp_zcu102_defconfig | 5 +-- configs/xilinx_zynqmp_zcu102_revB_defconfig | 5 +-- env/Kconfig | 33 ++++++++++++++++++ include/configs/am335x_evm.h | 1 - include/configs/am43xx_evm.h | 2 -- include/configs/at91-sama5_common.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/axs10x.h | 1 - include/configs/hikey.h | 1 - include/configs/hsdk.h | 1 - include/configs/k2g_evm.h | 1 - include/configs/omap4_panda.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/rpi.h | 1 - include/configs/xilinx_zynqmp.h | 1 - scripts/config_whitelist.txt | 1 - 51 files changed, 72 insertions(+), 67 deletions(-)
diff --git a/README b/README index 84da090e50..6084b8e553 100644 --- a/README +++ b/README @@ -3442,19 +3442,6 @@ environment in RAM: we could work on NVRAM directly, but we want to keep settings there always unmodified except somebody uses "saveenv" to save the current settings.
-- CONFIG_ENV_IS_IN_REMOTE: - - Define this if you have a remote memory space which you - want to use for the local device's environment. - - - CONFIG_ENV_ADDR: - - CONFIG_ENV_SIZE: - - These two #defines specify the address and size of the - environment area within the remote memory space. The - local device can get the environment from remote memory - space by SRIO or PCIE links. - BE CAREFUL! For some special cases, the local device can not use "saveenv" command. For example, the local device will get the environment stored in a remote NOR flash by SRIO or PCIE link, @@ -3466,37 +3453,6 @@ but it can not erase, write this NOR flash by SRIO or PCIE interface. environment. If redundant environment is used, it will be copied to CONFIG_NAND_ENV_DST + CONFIG_ENV_SIZE.
-- CONFIG_ENV_IS_IN_FAT: - Define this if you want to use the FAT file system for the environment. - - - FAT_ENV_INTERFACE: - - Define this to a string that is the name of the block device. - - - FAT_ENV_DEVICE_AND_PART: - - Define this to a string to specify the partition of the device. It can - be as following: - - "D:P", "D:0", "D", "D:" or "D:auto" (D, P are integers. And P >= 1) - - "D:P": device D partition P. Error occurs if device D has no - partition table. - - "D:0": device D. - - "D" or "D:": device D partition 1 if device D has partition - table, or the whole device D if has no partition - table. - - "D:auto": first partition in device D with bootable flag set. - If none, first valid partition in device D. If no - partition table then means device D. - - - FAT_ENV_FILE: - - It's a string of the FAT file name. This file use to store the - environment. - - - CONFIG_FAT_WRITE: - This must be enabled. Otherwise it cannot save the environment file. - Please note that the environment is read-only until the monitor has been relocated to RAM and a RAM copy of the environment has been created; also, when using EEPROM you will have to use getenv_f() diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 23d3bf5833..2d0e1e4a0c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -488,6 +488,7 @@ config ARCH_BCM283X select DM_GPIO select OF_CONTROL imply FAT_WRITE + imply ENV_IS_IN_FAT
config TARGET_VEXPRESS_CA15_TC2 bool "Support vexpress_ca15_tc2" diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 4591c20f8e..c820dcff3f 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -24,6 +24,7 @@ CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bonegreen am335x-icev2" +CONFIG_ENV_IS_IN_FAT=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_NAND=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 07beba6d19..be1865158a 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_DFU_MMC=y CONFIG_DFU_NAND=y CONFIG_DFU_RAM=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index 7809786e4e..3358ec5739 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -24,6 +24,7 @@ CONFIG_FASTBOOT_BUF_SIZE=0x07000000 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_ENV_IS_IN_FAT=y CONFIG_DFU_MMC=y CONFIG_DFU_NAND=y CONFIG_DFU_RAM=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index b0c88a6273..d8a5c2893a 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_MTD_SUPPORT=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bonegreen am335x-icev2" +CONFIG_ENV_IS_IN_FAT=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_NAND=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 3878d2724a..2d40097734 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -20,6 +20,7 @@ CONFIG_HUSH_PARSER=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 6df60e83de..1f06fd3415 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 2006957638..74b1c4ccb5 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index fb4bb037dd..20286bdc92 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -30,6 +30,7 @@ CONFIG_HUSH_PARSER=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="am437x-gp-evm am437x-sk-evm am43x-epos-evm am437x-idk-evm" +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 46f082f683..9e3feadb23 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index f323ce8686..1d19fb3384 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index afe28d6136..769940ef42 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 1aa1dd82b0..dadab0a293 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index 0b15652493..fb1555f1af 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MMC=y diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index add24cfe22..234057b600 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MMC=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index 88d5853d11..82c78e15e8 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -12,6 +12,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_CACHE=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_MMC_DW=y CONFIG_MMC_DW_K3=y CONFIG_USB=y diff --git a/configs/hsdk_defconfig b/configs/hsdk_defconfig index 0018c0482e..40aec3f7f2 100644 --- a/configs/hsdk_defconfig +++ b/configs/hsdk_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_MMC=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 1eed60576c..8b517e7dba 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -30,6 +30,7 @@ CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_OF_LIST="keystone-k2g-generic keystone-k2g-evm keystone-k2g-ice" +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_MMC=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 51c701ed90..56aa779d5c 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y # CONFIG_BLK is not set CONFIG_DM_MMC=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 3d91f137e8..a78e0aba78 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_USB=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index aa61e4b65a..ca6d1c5e07 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 2602aff9bc..a8c5d91355 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d36ek_cmp_mmc_defconfig b/configs/sama5d36ek_cmp_mmc_defconfig index 1c5d85b4ad..0c467e71ce 100644 --- a/configs/sama5d36ek_cmp_mmc_defconfig +++ b/configs/sama5d36ek_cmp_mmc_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_AT91=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 2e42a2e02e..fbb3db233c 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 4cbfa0723f..fc41f1df06 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 157fbe4577..bcddd7438e 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_CLK=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index e78460dc94..75ca0e81b0 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dma-names dmas" +CONFIG_ENV_IS_IN_FAT=y CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index 578db22e41..61acff9beb 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -43,11 +43,10 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_SATA_CEVA=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y @@ -63,6 +62,8 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ZYNQ_GEM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=25000000 diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 9daaa06c73..238f7d0940 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -35,6 +35,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index 0f9e4b24fe..49bf7c922d 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index 463a9c7aee..7662a0d5d5 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_FPGA_XILINX=y diff --git a/configs/xilinx_zynqmp_zcu102_defconfig b/configs/xilinx_zynqmp_zcu102_defconfig index 4f1524b149..792ae5f978 100644 --- a/configs/xilinx_zynqmp_zcu102_defconfig +++ b/configs/xilinx_zynqmp_zcu102_defconfig @@ -36,11 +36,10 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_SATA_CEVA=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y @@ -56,6 +55,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_ZYNQ_GEM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 4b944cb6e1..07b8e299bc 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -36,11 +36,10 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_ISO_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_ENV_IS_IN_FAT=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_SCSI=y -CONFIG_DM_SCSI=y CONFIG_SATA_CEVA=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y @@ -56,6 +55,8 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_ZYNQ_GEM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_DEBUG_UART_BASE=0xff000000 CONFIG_DEBUG_UART_CLOCK=100000000 diff --git a/env/Kconfig b/env/Kconfig index 3eb46111ff..f0dc49b4d9 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -74,6 +74,39 @@ config ENV_IS_IN_EEPROM EEPROM which holds the environment, is reached over a pca9547 i2c mux with address 0x70, channel 3.
+config ENV_IS_IN_FAT + bool "Environment is in a FAT filesystem" + help + Define this if you want to use the FAT file system for the environment. + + - FAT_ENV_INTERFACE: + + Define this to a string that is the name of the block device. + + - FAT_ENV_DEVICE_AND_PART: + + Define this to a string to specify the partition of the device. It can + be as following: + + "D:P", "D:0", "D", "D:" or "D:auto" (D, P are integers. And P >= 1) + - "D:P": device D partition P. Error occurs if device D has no + partition table. + - "D:0": device D. + - "D" or "D:": device D partition 1 if device D has partition + table, or the whole device D if has no partition + table. + - "D:auto": first partition in device D with bootable flag set. + If none, first valid partition in device D. If no + partition table then means device D. + + - FAT_ENV_FILE: + + It's a string of the FAT file name. This file use to store the + environment. + + - CONFIG_FAT_WRITE: + This must be enabled. Otherwise it cannot save the environment file. + config ENV_IS_IN_FLASH bool "Environment in flash memory" help diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index ba3d0555ea..e0be4cb9c2 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -354,7 +354,6 @@ #define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE #elif !defined(CONFIG_ENV_IS_NOWHERE) /* Not NAND, SPI, NOR or eMMC env, so put ENV in a file on FAT */ -#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" #define FAT_ENV_FILE "uboot.env" diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index ffef0b8afe..a91b7df347 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -71,7 +71,6 @@ /* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */
-#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" #define FAT_ENV_FILE "uboot.env" @@ -127,7 +126,6 @@ #ifndef CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_TEXT_BASE CONFIG_ISW_ENTRY_ADDR #endif -#undef CONFIG_ENV_IS_IN_FAT #define CONFIG_SYS_REDUNDAND_ENVIRONMENT #define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED #define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64 KB sectors */ diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index 33f2d85319..b4135235d4 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -53,7 +53,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #else /* u-boot env in sd/mmc card */ -#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0" #define FAT_ENV_FILE "uboot.env" diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 9e7fd1e1ae..8b00370cdd 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -113,7 +113,6 @@ */ #define FAT_ENV_DEVICE_AND_PART "0" #define FAT_ENV_FILE "uboot.env" -#define CONFIG_ENV_IS_IN_FAT #define CONFIG_ENV_SIZE 0x4000
#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 03846b55f5..2616ae4b0a 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -157,7 +157,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 #else /* Use file in FAT file to save environment */ -#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_FILE "uboot.env" #define FAT_ENV_DEVICE_AND_PART "0" diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 1d068f4c50..6132076e82 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -124,7 +124,6 @@ #else /* CONFIG_SYS_USE_MMC */
/* bootstrap + u-boot + env + linux in mmc */ -#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_FILE "uboot.env" #define FAT_ENV_DEVICE_AND_PART "0" diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 7357e18115..a80fe6a8a6 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -143,7 +143,6 @@ "bootm 0x22000000" #else /* CONFIG_SYS_USE_MMC */ /* bootstrap + u-boot + env + linux in mmc */ -#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_FILE "uboot.env" #define FAT_ENV_DEVICE_AND_PART "0" diff --git a/include/configs/axs10x.h b/include/configs/axs10x.h index 908b018800..b583267b3e 100644 --- a/include/configs/axs10x.h +++ b/include/configs/axs10x.h @@ -75,7 +75,6 @@ /* * Environment settings */ -#define CONFIG_ENV_IS_IN_FAT #define CONFIG_ENV_SIZE SZ_16K #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" diff --git a/include/configs/hikey.h b/include/configs/hikey.h index c7fb8a5f8e..8b2d012309 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -106,7 +106,6 @@
/* Preserve environment on sd card */ #define CONFIG_ENV_SIZE 0x1000 -#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "1:1" #define FAT_ENV_FILE "uboot.env" diff --git a/include/configs/hsdk.h b/include/configs/hsdk.h index 28ac090c05..68900ac980 100644 --- a/include/configs/hsdk.h +++ b/include/configs/hsdk.h @@ -60,7 +60,6 @@ * Environment settings */ #define CONFIG_ENV_SIZE SZ_16K -#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" #define FAT_ENV_FILE "uboot.env" diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index 5bf630e7f2..b0b420645e 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -70,7 +70,6 @@ #define CONFIG_PHY_MICREL #define PHY_ANEG_TIMEOUT 10000 /* PHY needs longer aneg time */
-#define CONFIG_ENV_IS_IN_FAT #define CONFIG_ENV_SIZE (256 << 10) /* 256 KiB */ #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index e1263b68bc..a973ce6a62 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -35,7 +35,6 @@ /* ENV related config options */
#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG -#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" #define FAT_ENV_FILE "uboot.env" diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index c83e559a5a..88f841dfd8 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -115,7 +115,6 @@ */ #define FAT_ENV_DEVICE_AND_PART "0" #define FAT_ENV_FILE "uboot.env" -#define CONFIG_ENV_IS_IN_FAT #define CONFIG_ENV_SIZE 0x4000
#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ diff --git a/include/configs/rpi.h b/include/configs/rpi.h index b31e2acce6..c545f99838 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -92,7 +92,6 @@
/* Environment */ #define CONFIG_ENV_SIZE SZ_16K -#define CONFIG_ENV_IS_IN_FAT #define FAT_ENV_INTERFACE "mmc" #define FAT_ENV_DEVICE_AND_PART "0:1" #define FAT_ENV_FILE "uboot.env" diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 0f4ca7452b..c30e37ccca 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -73,7 +73,6 @@ # ifndef CONFIG_ZYNQ_SDHCI_MAX_FREQ # define CONFIG_ZYNQ_SDHCI_MAX_FREQ 200000000 # endif -# define CONFIG_ENV_IS_IN_FAT # define FAT_ENV_DEVICE_AND_PART "0:auto" # define FAT_ENV_FILE "uboot.env" # define FAT_ENV_INTERFACE "mmc" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 222e553bf6..721a638d53 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -633,7 +633,6 @@ CONFIG_ENV_FLAGS_LIST_STATIC CONFIG_ENV_FLASHBOOT CONFIG_ENV_IS_EMBEDDED CONFIG_ENV_IS_IN_ -CONFIG_ENV_IS_IN_FAT CONFIG_ENV_IS_IN_ONENAND CONFIG_ENV_MAX_ENTRIES CONFIG_ENV_MIN_ENTRIES
This converts the following to Kconfig: CONFIG_ENV_IS_IN_ONENAND
Changes in v2: - Add new patch to convert CONFIG_ENV_IS_IN_ONENAND to Kconfig
configs/smdkc100_defconfig | 1 + configs/vct_platinum_onenand_defconfig | 1 + configs/vct_platinum_onenand_small_defconfig | 1 + configs/vct_platinumavc_onenand_defconfig | 1 + configs/vct_platinumavc_onenand_small_defconfig | 1 + configs/vct_premium_onenand_defconfig | 1 + configs/vct_premium_onenand_small_defconfig | 1 + env/Kconfig | 14 ++++++++++++++ include/configs/omap3_evm.h | 1 - include/configs/smdkc100.h | 1 - include/configs/vct.h | 1 - scripts/config_whitelist.txt | 1 - 12 files changed, 21 insertions(+), 4 deletions(-)
diff --git a/configs/smdkc100_defconfig b/configs/smdkc100_defconfig index edaf73a72c..d6e9791651 100644 --- a/configs/smdkc100_defconfig +++ b/configs/smdkc100_defconfig @@ -11,4 +11,5 @@ CONFIG_SYS_PROMPT="SMDKC100 # " # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y +CONFIG_ENV_IS_IN_ONENAND=y # CONFIG_MMC is not set diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig index 5d4cccccba..c348827cdd 100644 --- a/configs/vct_platinum_onenand_defconfig +++ b/configs/vct_platinum_onenand_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_ONENAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/vct_platinum_onenand_small_defconfig b/configs/vct_platinum_onenand_small_defconfig index 5a5edd8260..b2babc17e0 100644 --- a/configs/vct_platinum_onenand_small_defconfig +++ b/configs/vct_platinum_onenand_small_defconfig @@ -23,4 +23,5 @@ CONFIG_SYS_PROMPT="$ " CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_ONENAND=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig index 1f0a3f8b49..b2843091e8 100644 --- a/configs/vct_platinumavc_onenand_defconfig +++ b/configs/vct_platinumavc_onenand_defconfig @@ -16,4 +16,5 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_ONENAND=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_platinumavc_onenand_small_defconfig b/configs/vct_platinumavc_onenand_small_defconfig index 9e2fcbf6d0..b0a1a0ac20 100644 --- a/configs/vct_platinumavc_onenand_small_defconfig +++ b/configs/vct_platinumavc_onenand_small_defconfig @@ -23,4 +23,5 @@ CONFIG_SYS_PROMPT="$ " CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_ONENAND=y CONFIG_SYS_NS16550=y diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig index ac9cf36f68..e0ab1b896e 100644 --- a/configs/vct_premium_onenand_defconfig +++ b/configs/vct_premium_onenand_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_SNTP=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_ENV_IS_IN_ONENAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/vct_premium_onenand_small_defconfig b/configs/vct_premium_onenand_small_defconfig index 6e649ec0d7..2d6cd09a21 100644 --- a/configs/vct_premium_onenand_small_defconfig +++ b/configs/vct_premium_onenand_small_defconfig @@ -23,4 +23,5 @@ CONFIG_SYS_PROMPT="$ " CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set +CONFIG_ENV_IS_IN_ONENAND=y CONFIG_SYS_NS16550=y diff --git a/env/Kconfig b/env/Kconfig index f0dc49b4d9..16c172408c 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -283,6 +283,20 @@ config ENV_IS_IN_NVRAM can just be read and written to, without any special provision.
+config ENV_IS_IN_ONENAND + bool "Environment is in OneNAND" + help + Define this if you want to put your local device's environment in + OneNAND. + + - CONFIG_ENV_ADDR: + - CONFIG_ENV_SIZE: + + These two #defines are used to determine the device range you + want to use for environment. It is assumed that this memory + can just be read and written to, without any special + provision. + config ENV_IS_IN_REMOTE bool "Environment is in remove memory space" help diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 76c00d4efa..15eb08bba8 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -267,7 +267,6 @@ #if !defined(CONFIG_ENV_IS_NOWHERE) #if defined(CONFIG_CMD_NAND) #elif defined(CONFIG_CMD_ONENAND) -#define CONFIG_ENV_IS_IN_ONENAND #define CONFIG_ENV_OFFSET ONENAND_ENV_OFFSET #endif #endif /* CONFIG_ENV_IS_NOWHERE */ diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index ab75504188..cdfec610b8 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -176,7 +176,6 @@ /*----------------------------------------------------------------------- * Boot configuration */ -#define CONFIG_ENV_IS_IN_ONENAND 1 #define CONFIG_ENV_SIZE (128 << 10) /* 128KiB, 0x20000 */ #define CONFIG_ENV_ADDR (256 << 10) /* 256KiB, 0x40000 */ #define CONFIG_ENV_OFFSET (256 << 10) /* 256KiB, 0x40000 */ diff --git a/include/configs/vct.h b/include/configs/vct.h index 42f71112f8..a24b0aac28 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -183,7 +183,6 @@
#if defined(CONFIG_VCT_ONENAND) #define CONFIG_USE_ONENAND_BOARD_INIT -#define CONFIG_ENV_IS_IN_ONENAND #define CONFIG_SYS_ONENAND_BASE 0x00000000 /* this is not real address */ #define CONFIG_SYS_FLASH_BASE 0x00000000 #define CONFIG_ENV_ADDR (128 << 10) /* after compr. U-Boot image */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 721a638d53..93f0bf47c6 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -633,7 +633,6 @@ CONFIG_ENV_FLAGS_LIST_STATIC CONFIG_ENV_FLASHBOOT CONFIG_ENV_IS_EMBEDDED CONFIG_ENV_IS_IN_ -CONFIG_ENV_IS_IN_ONENAND CONFIG_ENV_MAX_ENTRIES CONFIG_ENV_MIN_ENTRIES CONFIG_ENV_OFFSET_OOB
These functions are not used outside this file. Make them static and order them to avoid forward declarations.
Changes in v2: None
env/common.c | 18 +++++++++--------- include/environment.h | 4 ---- 2 files changed, 9 insertions(+), 13 deletions(-)
diff --git a/env/common.c b/env/common.c index 6845f8d8d5..ff3f47e536 100644 --- a/env/common.c +++ b/env/common.c @@ -41,7 +41,15 @@ static uchar env_get_char_init(int index) return default_environment[index]; }
-uchar env_get_char_memory(int index) +static const uchar *env_get_addr(int index) +{ + if (gd->env_valid) + return (uchar *)(gd->env_addr + index); + else + return &default_environment[index]; +} + +static uchar env_get_char_memory(int index) { return *env_get_addr(index); } @@ -55,14 +63,6 @@ uchar env_get_char(int index) return env_get_char_init(index); }
-const uchar *env_get_addr(int index) -{ - if (gd->env_valid) - return (uchar *)(gd->env_addr + index); - else - return &default_environment[index]; -} - /* * Read an environment variable as a boolean * Return -1 if variable does not exist (default to true) diff --git a/include/environment.h b/include/environment.h index 6f94986c6b..d6aa1f0fff 100644 --- a/include/environment.h +++ b/include/environment.h @@ -202,10 +202,6 @@ extern struct hsearch_data env_htab; /* Function that returns a character from the environment */ unsigned char env_get_char(int);
-/* Function that returns a pointer to a value from the environment */ -const unsigned char *env_get_addr(int); -unsigned char env_get_char_memory(int index); - /* Function that updates CRC of the enironment */ void env_crc_update(void);
This function is not used anywhere other than env_get_char(). Move the code into that function.
Changes in v2: None
env/common.c | 11 +++-------- 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/env/common.c b/env/common.c index ff3f47e536..ce6b5f927a 100644 --- a/env/common.c +++ b/env/common.c @@ -41,17 +41,12 @@ static uchar env_get_char_init(int index) return default_environment[index]; }
-static const uchar *env_get_addr(int index) +static uchar env_get_char_memory(int index) { if (gd->env_valid) - return (uchar *)(gd->env_addr + index); + return *(uchar *)(gd->env_addr + index); else - return &default_environment[index]; -} - -static uchar env_get_char_memory(int index) -{ - return *env_get_addr(index); + return default_environment[index]; }
The check for gd->env_valid is used in both the 'if' and 'else' part of env_get_char(). Move it into that function instead for simplicity. Drop that code from the two leaf functions.
Changes in v2: None
env/common.c | 17 ++++++----------- 1 file changed, 6 insertions(+), 11 deletions(-)
diff --git a/env/common.c b/env/common.c index ce6b5f927a..10c4e134f4 100644 --- a/env/common.c +++ b/env/common.c @@ -34,25 +34,20 @@ __weak uchar env_get_char_spec(int index)
static uchar env_get_char_init(int index) { - /* if crc was bad, use the default environment */ - if (gd->env_valid) - return env_get_char_spec(index); - else - return default_environment[index]; + return env_get_char_spec(index); }
static uchar env_get_char_memory(int index) { - if (gd->env_valid) - return *(uchar *)(gd->env_addr + index); - else - return default_environment[index]; + return *(uchar *)(gd->env_addr + index); }
uchar env_get_char(int index) { - /* if relocated to RAM */ - if (gd->flags & GD_FLG_RELOC) + /* if env is not set up, or crc was bad, use the default environment */ + if (!gd->env_valid) + return default_environment[index]; + else if (gd->flags & GD_FLG_RELOC) /* if relocated to RAM */ return env_get_char_memory(index); else return env_get_char_init(index);
This function does nothing but call env_get_char_spec(). Drop it and adjust its only caller.
Changes in v2: None
env/common.c | 7 +------ 1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/env/common.c b/env/common.c index 10c4e134f4..e919269c7f 100644 --- a/env/common.c +++ b/env/common.c @@ -32,11 +32,6 @@ __weak uchar env_get_char_spec(int index) return *((uchar *)(gd->env_addr + index)); }
-static uchar env_get_char_init(int index) -{ - return env_get_char_spec(index); -} - static uchar env_get_char_memory(int index) { return *(uchar *)(gd->env_addr + index); @@ -50,7 +45,7 @@ uchar env_get_char(int index) else if (gd->flags & GD_FLG_RELOC) /* if relocated to RAM */ return env_get_char_memory(index); else - return env_get_char_init(index); + return env_get_char_spec(index); }
This function is the same as env_get_char_spec() apart from dropping the brackets. Drop the brackets from env_get_char_spec() and use that instead of env_get_char_memory().
Changes in v2: None
env/common.c | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/env/common.c b/env/common.c index e919269c7f..7ed4bb28dd 100644 --- a/env/common.c +++ b/env/common.c @@ -28,11 +28,6 @@ struct hsearch_data env_htab = { };
__weak uchar env_get_char_spec(int index) -{ - return *((uchar *)(gd->env_addr + index)); -} - -static uchar env_get_char_memory(int index) { return *(uchar *)(gd->env_addr + index); } @@ -42,8 +37,6 @@ uchar env_get_char(int index) /* if env is not set up, or crc was bad, use the default environment */ if (!gd->env_valid) return default_environment[index]; - else if (gd->flags & GD_FLG_RELOC) /* if relocated to RAM */ - return env_get_char_memory(index); else return env_get_char_spec(index); }
At present we have three states for the environment, numbered 0, 1 and 2. Add an enum to record this to avoid open-coded values.
Changes in v2: None
board/Arcturus/ucp1020/spl.c | 3 ++- board/freescale/b4860qds/spl.c | 3 ++- board/freescale/c29xpcie/spl.c | 3 ++- board/freescale/p1010rdb/spl.c | 3 ++- board/freescale/p1022ds/spl.c | 3 ++- board/freescale/p1_p2_rdb_pc/spl.c | 3 ++- board/freescale/t102xqds/spl.c | 3 ++- board/freescale/t102xrdb/spl.c | 3 ++- board/freescale/t104xrdb/spl.c | 3 ++- board/freescale/t208xqds/spl.c | 3 ++- board/freescale/t208xrdb/spl.c | 3 ++- board/freescale/t4qds/spl.c | 3 ++- board/freescale/t4rdb/spl.c | 3 ++- env/dataflash.c | 2 +- env/eeprom.c | 30 ++++++++++++++-------------- env/ext4.c | 2 +- env/fat.c | 2 +- env/flash.c | 22 ++++++++++---------- env/mmc.c | 22 ++++++++++---------- env/nand.c | 41 +++++++++++++++++++------------------- env/nvram.c | 2 +- env/onenand.c | 4 ++-- env/remote.c | 2 +- env/sata.c | 2 +- env/sf.c | 26 ++++++++++++------------ env/ubi.c | 22 ++++++++++---------- include/asm-generic/global_data.h | 2 +- include/environment.h | 7 +++++++ 28 files changed, 124 insertions(+), 103 deletions(-)
diff --git a/board/Arcturus/ucp1020/spl.c b/board/Arcturus/ucp1020/spl.c index cd484fc44b..b5e7a5db06 100644 --- a/board/Arcturus/ucp1020/spl.c +++ b/board/Arcturus/ucp1020/spl.c @@ -10,6 +10,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <ns16550.h> #include <malloc.h> #include <mmc.h> @@ -99,7 +100,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, (uchar *)CONFIG_ENV_ADDR); gd->env_addr = (ulong)(CONFIG_ENV_ADDR); - gd->env_valid = 1; + gd->env_valid = ENV_VALID; #else env_relocate(); #endif diff --git a/board/freescale/b4860qds/spl.c b/board/freescale/b4860qds/spl.c index 60d7f0d48a..b1824b07a2 100644 --- a/board/freescale/b4860qds/spl.c +++ b/board/freescale/b4860qds/spl.c @@ -5,6 +5,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <asm/spl.h> #include <malloc.h> #include <ns16550.h> @@ -101,7 +102,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, (uchar *)CONFIG_ENV_ADDR); gd->env_addr = (ulong)(CONFIG_ENV_ADDR); - gd->env_valid = 1; + gd->env_valid = ENV_VALID; #endif
i2c_init_all(); diff --git a/board/freescale/c29xpcie/spl.c b/board/freescale/c29xpcie/spl.c index 94093f11a8..28541a72cb 100644 --- a/board/freescale/c29xpcie/spl.c +++ b/board/freescale/c29xpcie/spl.c @@ -5,6 +5,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <ns16550.h> #include <malloc.h> #include <mmc.h> @@ -63,7 +64,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, (uchar *)CONFIG_ENV_ADDR); gd->env_addr = (ulong)(CONFIG_ENV_ADDR); - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
i2c_init_all();
diff --git a/board/freescale/p1010rdb/spl.c b/board/freescale/p1010rdb/spl.c index 2cebc2c002..001308874e 100644 --- a/board/freescale/p1010rdb/spl.c +++ b/board/freescale/p1010rdb/spl.c @@ -5,6 +5,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <ns16550.h> #include <malloc.h> #include <mmc.h> @@ -87,7 +88,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, (uchar *)CONFIG_ENV_ADDR); gd->env_addr = (ulong)(CONFIG_ENV_ADDR); - gd->env_valid = 1; + gd->env_valid = ENV_VALID; #else env_relocate(); #endif diff --git a/board/freescale/p1022ds/spl.c b/board/freescale/p1022ds/spl.c index a117dc3a2c..94b357d446 100644 --- a/board/freescale/p1022ds/spl.c +++ b/board/freescale/p1022ds/spl.c @@ -6,6 +6,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <ns16550.h> #include <malloc.h> #include <mmc.h> @@ -100,7 +101,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) (uchar *)CONFIG_ENV_ADDR);
gd->env_addr = (ulong)(CONFIG_ENV_ADDR); - gd->env_valid = 1; + gd->env_valid = ENV_VALID; #else env_relocate(); #endif diff --git a/board/freescale/p1_p2_rdb_pc/spl.c b/board/freescale/p1_p2_rdb_pc/spl.c index ca7ba5754e..c1d4c36b06 100644 --- a/board/freescale/p1_p2_rdb_pc/spl.c +++ b/board/freescale/p1_p2_rdb_pc/spl.c @@ -6,6 +6,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <ns16550.h> #include <malloc.h> #include <mmc.h> @@ -92,7 +93,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, (uchar *)CONFIG_ENV_ADDR); gd->env_addr = (ulong)(CONFIG_ENV_ADDR); - gd->env_valid = 1; + gd->env_valid = ENV_VALID; #else env_relocate(); #endif diff --git a/board/freescale/t102xqds/spl.c b/board/freescale/t102xqds/spl.c index b987ecea1d..3aa19e6715 100644 --- a/board/freescale/t102xqds/spl.c +++ b/board/freescale/t102xqds/spl.c @@ -5,6 +5,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <malloc.h> #include <ns16550.h> #include <nand.h> @@ -138,7 +139,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) #endif
i2c_init_all();
diff --git a/board/freescale/t102xrdb/spl.c b/board/freescale/t102xrdb/spl.c index dc6d9eeef6..ca1e49ffa7 100644 --- a/board/freescale/t102xrdb/spl.c +++ b/board/freescale/t102xrdb/spl.c @@ -5,6 +5,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <malloc.h> #include <ns16550.h> #include <nand.h> @@ -125,7 +126,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) #endif
i2c_init_all();
diff --git a/board/freescale/t104xrdb/spl.c b/board/freescale/t104xrdb/spl.c index 2e43307b2d..4fb9323873 100644 --- a/board/freescale/t104xrdb/spl.c +++ b/board/freescale/t104xrdb/spl.c @@ -5,6 +5,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <malloc.h> #include <ns16550.h> #include <nand.h> @@ -119,7 +120,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) (uchar *)CONFIG_ENV_ADDR); #endif gd->env_addr = (ulong)(CONFIG_ENV_ADDR); - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
i2c_init_all();
diff --git a/board/freescale/t208xqds/spl.c b/board/freescale/t208xqds/spl.c index d7d716b690..36961dc9b0 100644 --- a/board/freescale/t208xqds/spl.c +++ b/board/freescale/t208xqds/spl.c @@ -5,6 +5,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <malloc.h> #include <ns16550.h> #include <nand.h> @@ -124,7 +125,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) #endif
i2c_init_all();
diff --git a/board/freescale/t208xrdb/spl.c b/board/freescale/t208xrdb/spl.c index b43140148b..f0cc34d788 100644 --- a/board/freescale/t208xrdb/spl.c +++ b/board/freescale/t208xrdb/spl.c @@ -5,6 +5,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <malloc.h> #include <ns16550.h> #include <nand.h> @@ -94,7 +95,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) #endif
i2c_init_all();
diff --git a/board/freescale/t4qds/spl.c b/board/freescale/t4qds/spl.c index 9ecdaedda3..750f155493 100644 --- a/board/freescale/t4qds/spl.c +++ b/board/freescale/t4qds/spl.c @@ -5,6 +5,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <asm/spl.h> #include <malloc.h> #include <ns16550.h> @@ -129,7 +130,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) #endif
i2c_init_all();
diff --git a/board/freescale/t4rdb/spl.c b/board/freescale/t4rdb/spl.c index 5feab1cfcd..932954e93d 100644 --- a/board/freescale/t4rdb/spl.c +++ b/board/freescale/t4rdb/spl.c @@ -8,6 +8,7 @@
#include <common.h> #include <console.h> +#include <environment.h> #include <asm/spl.h> #include <malloc.h> #include <ns16550.h> @@ -87,7 +88,7 @@ void board_init_r(gd_t *gd, ulong dest_addr) (uchar *)CONFIG_ENV_ADDR);
i2c_init_all();
diff --git a/env/dataflash.c b/env/dataflash.c index 034e323169..c140b74c98 100644 --- a/env/dataflash.c +++ b/env/dataflash.c @@ -78,7 +78,7 @@ int env_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
return 0; } diff --git a/env/eeprom.c b/env/eeprom.c index 5f63a6cd4a..ac6b30fa8f 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -71,7 +71,7 @@ uchar env_get_char_spec(int index) unsigned int off = CONFIG_ENV_OFFSET;
#ifdef CONFIG_ENV_OFFSET_REDUND - if (gd->env_valid == 2) + if (gd->env_valid == ENV_REDUND) off = CONFIG_ENV_OFFSET_REDUND; #endif eeprom_bus_read(CONFIG_SYS_DEF_EEPROM_ADDR, @@ -128,21 +128,21 @@ void env_relocate_spec(void) gd->env_addr = 0; gd->env_valid = 0; } else if (crc_ok[0] && !crc_ok[1]) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (!crc_ok[0] && crc_ok[1]) { - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else { /* both ok - check serial */ if (flags[0] == ACTIVE_FLAG && flags[1] == OBSOLETE_FLAG) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else if (flags[0] == OBSOLETE_FLAG && flags[1] == ACTIVE_FLAG) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else if (flags[0] == 0xFF && flags[1] == 0) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else if (flags[1] == 0xFF && flags[0] == 0) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else /* flags are equal - almost impossible */ - gd->env_valid = 1; + gd->env_valid = ENV_VALID; }
#else /* CONFIG_ENV_OFFSET_REDUND */ @@ -170,7 +170,7 @@ void env_relocate_spec(void) }
if (crc == new) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else { gd->env_valid = 0; } @@ -178,7 +178,7 @@ void env_relocate_spec(void)
off = CONFIG_ENV_OFFSET; #ifdef CONFIG_ENV_OFFSET_REDUND - if (gd->env_valid == 2) + if (gd->env_valid == ENV_REDUND) off = CONFIG_ENV_OFFSET_REDUND; #endif
@@ -205,7 +205,7 @@ int saveenv(void) return rc;
#ifdef CONFIG_ENV_OFFSET_REDUND - if (gd->env_valid == 1) { + if (gd->env_valid == ENV_VALID) { off = CONFIG_ENV_OFFSET_REDUND; off_red = CONFIG_ENV_OFFSET; } @@ -222,10 +222,10 @@ int saveenv(void) off_red + offsetof(env_t, flags), (uchar *)&flag_obsolete, 1);
- if (gd->env_valid == 1) - gd->env_valid = 2; + if (gd->env_valid == ENV_VALID) + gd->env_valid = ENV_REDUND; else - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } #endif return rc; @@ -240,6 +240,6 @@ int saveenv(void) int env_init(void) { gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID; return 0; } diff --git a/env/ext4.c b/env/ext4.c index adefa7dc99..7bb4ce7cff 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -41,7 +41,7 @@ int env_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
return 0; } diff --git a/env/fat.c b/env/fat.c index 75616d4c5b..5a2131a5a9 100644 --- a/env/fat.c +++ b/env/fat.c @@ -29,7 +29,7 @@ int env_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
return 0; } diff --git a/env/flash.c b/env/flash.c index 004e8849a7..dcf3cd2c62 100644 --- a/env/flash.c +++ b/env/flash.c @@ -75,28 +75,28 @@ int env_init(void)
if (crc1_ok && !crc2_ok) { gd->env_addr = addr1; - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (!crc1_ok && crc2_ok) { gd->env_addr = addr2; - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (!crc1_ok && !crc2_ok) { gd->env_addr = addr_default; gd->env_valid = 0; } else if (flag1 == ACTIVE_FLAG && flag2 == OBSOLETE_FLAG) { gd->env_addr = addr1; - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (flag1 == OBSOLETE_FLAG && flag2 == ACTIVE_FLAG) { gd->env_addr = addr2; - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (flag1 == flag2) { gd->env_addr = addr1; - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else if (flag1 == 0xFF) { gd->env_addr = addr1; - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else if (flag2 == 0xFF) { gd->env_addr = addr2; - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; }
return 0; @@ -211,7 +211,7 @@ int env_init(void) { if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { gd->env_addr = (ulong)&(env_ptr->data); - gd->env_valid = 1; + gd->env_valid = ENV_VALID; return 0; }
@@ -309,7 +309,7 @@ void env_relocate_spec(void) crc32(0, flash_addr_new->data, ENV_SIZE) == flash_addr_new->crc) { char flag = OBSOLETE_FLAG;
- gd->env_valid = 2; + gd->env_valid = ENV_REDUND; flash_sect_protect(0, (ulong)flash_addr_new, end_addr_new); flash_write(&flag, (ulong)&(flash_addr_new->flags), @@ -321,7 +321,7 @@ void env_relocate_spec(void) (flash_addr->flags & ACTIVE_FLAG) == ACTIVE_FLAG) { char flag = ACTIVE_FLAG;
- gd->env_valid = 2; + gd->env_valid = ENV_REDUND; flash_sect_protect(0, (ulong)flash_addr, end_addr); flash_write(&flag, (ulong)&(flash_addr->flags), @@ -329,7 +329,7 @@ void env_relocate_spec(void) flash_sect_protect(1, (ulong)flash_addr, end_addr); }
- if (gd->env_valid == 2) + if (gd->env_valid == ENV_REDUND) puts("*** Warning - some problems detected " "reading environment; recovered successfully\n\n"); #endif /* CONFIG_ENV_ADDR_REDUND */ diff --git a/env/mmc.c b/env/mmc.c index 88b043ec35..32764a15c9 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -86,7 +86,7 @@ int env_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
return 0; } @@ -186,7 +186,7 @@ int saveenv(void) #ifdef CONFIG_ENV_OFFSET_REDUND env_new->flags = ++env_flags; /* increase the serial */
- if (gd->env_valid == 1) + if (gd->env_valid == ENV_VALID) copy = 1; #endif
@@ -206,7 +206,7 @@ int saveenv(void) ret = 0;
#ifdef CONFIG_ENV_OFFSET_REDUND - gd->env_valid = gd->env_valid == 2 ? 1 : 2; + gd->env_valid = gd->env_valid == ENV_REDUND ? ENV_VALID : ENV_REDUND; #endif
fini: @@ -278,26 +278,26 @@ void env_relocate_spec(void) ret = 1; goto fini; } else if (crc1_ok && !crc2_ok) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (!crc1_ok && crc2_ok) { - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else { /* both ok - check serial */ if (tmp_env1->flags == 255 && tmp_env2->flags == 0) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else if (tmp_env2->flags == 255 && tmp_env1->flags == 0) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else if (tmp_env1->flags > tmp_env2->flags) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else if (tmp_env2->flags > tmp_env1->flags) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else /* flags are equal - almost impossible */ - gd->env_valid = 1; + gd->env_valid = ENV_VALID; }
free(env_ptr);
- if (gd->env_valid == 1) + if (gd->env_valid == ENV_VALID) ep = tmp_env1; else ep = tmp_env2; diff --git a/env/nand.c b/env/nand.c index 133ecfbb8e..357f1baf7a 100644 --- a/env/nand.c +++ b/env/nand.c @@ -84,37 +84,37 @@ int env_init(void)
return 0; } else if (crc1_ok && !crc2_ok) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } #ifdef CONFIG_ENV_OFFSET_REDUND else if (!crc1_ok && crc2_ok) { - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else { /* both ok - check serial */ if (tmp_env1->flags == 255 && tmp_env2->flags == 0) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else if (tmp_env2->flags == 255 && tmp_env1->flags == 0) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else if (tmp_env1->flags > tmp_env2->flags) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else if (tmp_env2->flags > tmp_env1->flags) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else /* flags are equal - almost impossible */ - gd->env_valid = 1; + gd->env_valid = ENV_VALID; }
- if (gd->env_valid == 2) + if (gd->env_valid == ENV_REDUND) env_ptr = tmp_env2; else #endif - if (gd->env_valid == 1) + if (gd->env_valid == ENV_VALID) env_ptr = tmp_env1;
gd->env_addr = (ulong)env_ptr->data;
#else /* ENV_IS_EMBEDDED || CONFIG_NAND_ENV_DST */ gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID; #endif /* ENV_IS_EMBEDDED || CONFIG_NAND_ENV_DST */
return 0; @@ -222,14 +222,15 @@ int saveenv(void)
#ifdef CONFIG_ENV_OFFSET_REDUND env_new->flags = ++env_flags; /* increase the serial */ - env_idx = (gd->env_valid == 1); + env_idx = (gd->env_valid == ENV_VALID); #endif
ret = erase_and_write_env(&location[env_idx], (u_char *)env_new); #ifdef CONFIG_ENV_OFFSET_REDUND if (!ret) { /* preset other copy for next write */ - gd->env_valid = gd->env_valid == 2 ? 1 : 2; + gd->env_valid = gd->env_valid == ENV_REDUND ? ENV_VALID : + ENV_REDUND; return ret; }
@@ -353,26 +354,26 @@ void env_relocate_spec(void) set_default_env("!bad CRC"); goto done; } else if (crc1_ok && !crc2_ok) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (!crc1_ok && crc2_ok) { - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else { /* both ok - check serial */ if (tmp_env1->flags == 255 && tmp_env2->flags == 0) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else if (tmp_env2->flags == 255 && tmp_env1->flags == 0) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else if (tmp_env1->flags > tmp_env2->flags) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else if (tmp_env2->flags > tmp_env1->flags) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else /* flags are equal - almost impossible */ - gd->env_valid = 1; + gd->env_valid = ENV_VALID; }
free(env_ptr);
- if (gd->env_valid == 1) + if (gd->env_valid == ENV_VALID) ep = tmp_env1; else ep = tmp_env2; diff --git a/env/nvram.c b/env/nvram.c index 524f07d5f8..d046c9393c 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -104,7 +104,7 @@ int env_init(void) if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { gd->env_addr = (ulong)&env_ptr->data; #endif - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else { gd->env_addr = (ulong)&default_environment[0]; gd->env_valid = 0; diff --git a/env/onenand.c b/env/onenand.c index cc3d670de8..d7ad45a0e5 100644 --- a/env/onenand.c +++ b/env/onenand.c @@ -60,7 +60,7 @@ void env_relocate_spec(void)
rc = env_import(buf, 1); if (rc) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; }
int saveenv(void) @@ -110,7 +110,7 @@ int env_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
return 0; } diff --git a/env/remote.c b/env/remote.c index eb977ee1fe..e003e02fb9 100644 --- a/env/remote.c +++ b/env/remote.c @@ -29,7 +29,7 @@ int env_init(void) { if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { gd->env_addr = (ulong)&(env_ptr->data); - gd->env_valid = 1; + gd->env_valid = ENV_VALID; return 0; }
diff --git a/env/sata.c b/env/sata.c index b0cee35a60..64589117f2 100644 --- a/env/sata.c +++ b/env/sata.c @@ -37,7 +37,7 @@ int env_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
return 0; } diff --git a/env/sf.c b/env/sf.c index 45f441a042..1da3549138 100644 --- a/env/sf.c +++ b/env/sf.c @@ -93,7 +93,7 @@ int saveenv(void) return ret; env_new.flags = ACTIVE_FLAG;
- if (gd->env_valid == 1) { + if (gd->env_valid == ENV_VALID) { env_new_offset = CONFIG_ENV_OFFSET_REDUND; env_offset = CONFIG_ENV_OFFSET; } else { @@ -145,7 +145,7 @@ int saveenv(void)
puts("done\n");
printf("Valid environment: %d\n", (int)gd->env_valid);
@@ -198,30 +198,30 @@ void env_relocate_spec(void) set_default_env("!bad CRC"); goto err_read; } else if (crc1_ok && !crc2_ok) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (!crc1_ok && crc2_ok) { - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else if (tmp_env1->flags == ACTIVE_FLAG && tmp_env2->flags == OBSOLETE_FLAG) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (tmp_env1->flags == OBSOLETE_FLAG && tmp_env2->flags == ACTIVE_FLAG) { - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else if (tmp_env1->flags == tmp_env2->flags) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (tmp_env1->flags == 0xFF) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (tmp_env2->flags == 0xFF) { - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else { /* * this differs from code in env_flash.c, but I think a sane * default path is desirable. */ - gd->env_valid = 1; + gd->env_valid = ENV_VALID; }
- if (gd->env_valid == 1) + if (gd->env_valid == ENV_VALID) ep = tmp_env1; else ep = tmp_env2; @@ -324,7 +324,7 @@ void env_relocate_spec(void)
ret = env_import(buf, 1); if (ret) - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
err_read: spi_flash_free(env_flash); @@ -338,7 +338,7 @@ int env_init(void) { /* SPI flash isn't usable before relocation */ gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
return 0; } diff --git a/env/ubi.c b/env/ubi.c index 0ac2f65f0b..d37095db0c 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -26,7 +26,7 @@ int env_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 1; + gd->env_valid = ENV_VALID;
return 0; } @@ -52,7 +52,7 @@ int saveenv(void)
- if (gd->env_valid == 1) { + if (gd->env_valid == ENV_VALID) { puts("Writing to redundant UBI... "); if (ubi_volume_write(CONFIG_ENV_UBI_VOLUME_REDUND, (void *)env_new, CONFIG_ENV_SIZE)) { @@ -74,7 +74,7 @@ int saveenv(void)
puts("done\n");
return 0; } @@ -155,24 +155,24 @@ void env_relocate_spec(void) set_default_env("!bad CRC"); return; } else if (crc1_ok && !crc2_ok) { - gd->env_valid = 1; + gd->env_valid = ENV_VALID; } else if (!crc1_ok && crc2_ok) { - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; } else { /* both ok - check serial */ if (tmp_env1->flags == 255 && tmp_env2->flags == 0) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else if (tmp_env2->flags == 255 && tmp_env1->flags == 0) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else if (tmp_env1->flags > tmp_env2->flags) - gd->env_valid = 1; + gd->env_valid = ENV_VALID; else if (tmp_env2->flags > tmp_env1->flags) - gd->env_valid = 2; + gd->env_valid = ENV_REDUND; else /* flags are equal - almost impossible */ - gd->env_valid = 1; + gd->env_valid = ENV_VALID; }
- if (gd->env_valid == 1) + if (gd->env_valid == ENV_VALID) ep = tmp_env1; else ep = tmp_env2; diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index fb90be9d3e..d8d1b444f2 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -49,7 +49,7 @@ typedef struct global_data { unsigned long precon_buf_idx; /* Pre-Console buffer index */ #endif unsigned long env_addr; /* Address of Environment struct */ - unsigned long env_valid; /* Checksum of Environment valid? */ + unsigned long env_valid; /* Environment valid? enum env_valid */
unsigned long ram_top; /* Top address of RAM used by U-Boot */ unsigned long relocaddr; /* Start address of U-Boot in RAM */ diff --git a/include/environment.h b/include/environment.h index d6aa1f0fff..b4c8c48717 100644 --- a/include/environment.h +++ b/include/environment.h @@ -197,6 +197,13 @@ extern uint mmc_get_env_part(struct mmc *mmc); #include <env_flags.h> #include <search.h>
+/* Value for environment validity */ +enum env_valid { + ENV_INVALID, /* No valid environment */ + ENV_VALID, /* First or only environment is valid */ + ENV_REDUND, /* Redundant environment is valid */ +}; + extern struct hsearch_data env_htab;
Signed-off-by: Simon Glass sjg@chromium.org
We want to use this name for all environment drivers. Update the nand driver to use a more specific name.
Changes in v2: None
env/nand.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/env/nand.c b/env/nand.c index 357f1baf7a..11900deb25 100644 --- a/env/nand.c +++ b/env/nand.c @@ -158,12 +158,12 @@ static int writeenv(size_t offset, u_char *buf) return 0; }
-struct env_location { +struct nand_env_location { const char *name; const nand_erase_options_t erase_opts; };
-static int erase_and_write_env(const struct env_location *location, +static int erase_and_write_env(const struct nand_env_location *location, u_char *env_new) { struct mtd_info *mtd; @@ -193,7 +193,7 @@ int saveenv(void) int ret = 0; ALLOC_CACHE_ALIGN_BUFFER(env_t, env_new, 1); int env_idx = 0; - static const struct env_location location[] = { + static const struct nand_env_location location[] = { { .name = "NAND", .erase_opts = {
Set up a location driver for each supported environment locatoin. At present this just points to the global functions and is not used. A later patch will switch this over to use private functions in each driver.
Changes in v2: - Add conditions for the am335x_hs_evm board with SPL
env/dataflash.c | 8 ++++++ env/eeprom.c | 8 ++++++ env/ext4.c | 8 ++++++ env/fat.c | 30 ++++++++++++++++++++-- env/flash.c | 39 +++++++++++++++++++++++++--- env/mmc.c | 10 ++++++++ env/nand.c | 12 ++++++++- env/nowhere.c | 6 +++++ env/nvram.c | 10 ++++++++ env/onenand.c | 8 ++++++ env/remote.c | 8 ++++++ env/sata.c | 8 ++++++ env/sf.c | 20 +++++++++++++++ env/ubi.c | 8 ++++++ include/environment.h | 70 +++++++++++++++++++++++++++++++++++++++++++++++++++ 15 files changed, 246 insertions(+), 7 deletions(-)
diff --git a/env/dataflash.c b/env/dataflash.c index c140b74c98..9c59d8e63a 100644 --- a/env/dataflash.c +++ b/env/dataflash.c @@ -82,3 +82,11 @@ int env_init(void)
return 0; } + +U_BOOT_ENV_LOCATION(dataflash) = { + .location = ENVL_DATAFLASH, + .get_char = env_get_char_spec, + .load = env_relocate_spec, + .save = env_save_ptr(saveenv), + .init = env_init, +}; diff --git a/env/eeprom.c b/env/eeprom.c index ac6b30fa8f..78569b286b 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -243,3 +243,11 @@ int env_init(void) gd->env_valid = ENV_VALID; return 0; } + +U_BOOT_ENV_LOCATION(eeprom) = { + .location = ENVL_EEPROM, + .get_char = env_get_char_spec, + .load = env_relocate_spec, + .save = env_save_ptr(saveenv), + .init = env_init, +}; diff --git a/env/ext4.c b/env/ext4.c index 7bb4ce7cff..c6a84925d9 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -127,3 +127,11 @@ void env_relocate_spec(void) err_env_relocate: set_default_env(NULL); } + +U_BOOT_ENV_LOCATION(ext4) = { + .location = ENVL_EXT4, + .get_char = env_get_char_spec, + .load = env_relocate_spec, + .save = env_save_ptr(saveenv), + .init = env_init, +}; diff --git a/env/fat.c b/env/fat.c index 5a2131a5a9..8f5fff81ad 100644 --- a/env/fat.c +++ b/env/fat.c @@ -19,6 +19,18 @@ #include <fat.h> #include <mmc.h>
+#ifdef CONFIG_SPL_BUILD +/* TODO(sjg@chromium.org): Figure out why this is needed */ +# if !defined(CONFIG_TARGET_AM335X_EVM) || defined(CONFIG_SPL_OS_BOOT) +# define LOADENV +# endif +#else +# define LOADENV +# if defined(CONFIG_CMD_SAVEENV) +# define CMD_SAVEENV +# endif +#endif + char *env_name_spec = "FAT";
env_t *env_ptr; @@ -34,7 +46,7 @@ int env_init(void) return 0; }
-#ifdef CONFIG_CMD_SAVEENV +#ifdef CMD_SAVEENV int saveenv(void) { env_t env_new; @@ -72,8 +84,9 @@ int saveenv(void) puts("done\n"); return 0; } -#endif /* CONFIG_CMD_SAVEENV */ +#endif /* CMD_SAVEENV */
+#ifdef LOADENV void env_relocate_spec(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); @@ -108,3 +121,16 @@ void env_relocate_spec(void) err_env_relocate: set_default_env(NULL); } +#endif /* LOADENV */ + +U_BOOT_ENV_LOCATION(fat) = { + .location = ENVL_FAT, + .get_char = env_get_char_spec, +#ifdef LOADENV + .load = env_relocate_spec, +#endif +#ifdef CMD_SAVEENV + .save = env_save_ptr(saveenv), +#endif + .init = env_init, +}; diff --git a/env/flash.c b/env/flash.c index dcf3cd2c62..cf068d11ee 100644 --- a/env/flash.c +++ b/env/flash.c @@ -20,10 +20,12 @@
DECLARE_GLOBAL_DATA_PTR;
-#if defined(CONFIG_CMD_SAVEENV) && defined(CONFIG_CMD_FLASH) -#define CMD_SAVEENV -#elif defined(CONFIG_ENV_ADDR_REDUND) -#error CONFIG_ENV_ADDR_REDUND must have CONFIG_CMD_SAVEENV & CONFIG_CMD_FLASH +#ifndef CONFIG_SPL_BUILD +# if defined(CONFIG_CMD_SAVEENV) && defined(CONFIG_CMD_FLASH) +# define CMD_SAVEENV +# elif defined(CONFIG_ENV_ADDR_REDUND) +# error CONFIG_ENV_ADDR_REDUND must have CONFIG_CMD_SAVEENV & CONFIG_CMD_FLASH +# endif #endif
#if defined(CONFIG_ENV_SIZE_REDUND) && \ @@ -31,6 +33,18 @@ DECLARE_GLOBAL_DATA_PTR; #error CONFIG_ENV_SIZE_REDUND should not be less then CONFIG_ENV_SIZE #endif
+/* TODO(sjg@chromium.org): Figure out all these special cases */ +#if (!defined(CONFIG_MICROBLAZE) && !defined(CONFIG_ARCH_ZYNQ) && \ + !defined(CONFIG_TARGET_MCCMON6) && !defined(CONFIG_TARGET_X600) && \ + !defined(CONFIG_TARGET_EDMINIV2)) || \ + !defined(CONFIG_SPL_BUILD) +#define LOADENV +#endif + +#if !defined(CONFIG_TARGET_X600) || !defined(CONFIG_SPL_BUILD) +#define INITENV +#endif + char *env_name_spec = "Flash";
#ifdef ENV_IS_EMBEDDED @@ -58,6 +72,7 @@ static ulong end_addr_new = CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SECT_SIZE - 1;
#ifdef CONFIG_ENV_ADDR_REDUND +#ifdef INITENV int env_init(void) { int crc1_ok = 0, crc2_ok = 0; @@ -101,6 +116,7 @@ int env_init(void)
return 0; } +#endif
#ifdef CMD_SAVEENV int saveenv(void) @@ -207,6 +223,7 @@ done:
#else /* ! CONFIG_ENV_ADDR_REDUND */
+#ifdef INITENV int env_init(void) { if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { @@ -219,6 +236,7 @@ int env_init(void) gd->env_valid = 0; return 0; } +#endif
#ifdef CMD_SAVEENV int saveenv(void) @@ -336,3 +354,16 @@ void env_relocate_spec(void)
env_import((char *)flash_addr, 1); } + +U_BOOT_ENV_LOCATION(flash) = { + .location = ENVL_FLASH, +#ifdef LOADENV + .load = env_relocate_spec, +#endif +#ifdef CMD_SAVEENV + .save = env_save_ptr(saveenv), +#endif +#ifdef INITENV + .init = env_init, +#endif +}; diff --git a/env/mmc.c b/env/mmc.c index 32764a15c9..4249182d58 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -354,3 +354,13 @@ err: #endif } #endif /* CONFIG_ENV_OFFSET_REDUND */ + +U_BOOT_ENV_LOCATION(mmc) = { + .location = ENVL_MMC, + .get_char = env_get_char_spec, + .load = env_relocate_spec, +#ifndef CONFIG_SPL_BUILD + .save = env_save_ptr(saveenv), +#endif + .init = env_init, +}; diff --git a/env/nand.c b/env/nand.c index 11900deb25..3e7c30600f 100644 --- a/env/nand.c +++ b/env/nand.c @@ -24,7 +24,8 @@ #include <search.h> #include <errno.h>
-#if defined(CONFIG_CMD_SAVEENV) && defined(CONFIG_CMD_NAND) +#if defined(CONFIG_CMD_SAVEENV) && defined(CONFIG_CMD_NAND) && \ + !defined(CONFIG_SPL_BUILD) #define CMD_SAVEENV #elif defined(CONFIG_ENV_OFFSET_REDUND) #error CONFIG_ENV_OFFSET_REDUND must have CONFIG_CMD_SAVEENV & CONFIG_CMD_NAND @@ -423,3 +424,12 @@ void env_relocate_spec(void) #endif /* ! ENV_IS_EMBEDDED */ } #endif /* CONFIG_ENV_OFFSET_REDUND */ + +U_BOOT_ENV_LOCATION(nand) = { + .location = ENVL_NAND, + .load = env_relocate_spec, +#if defined(CMD_SAVEENV) + .save = env_save_ptr(saveenv), +#endif + .init = env_init, +}; diff --git a/env/nowhere.c b/env/nowhere.c index bdc1ed5e67..c58d299308 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -33,3 +33,9 @@ int env_init(void)
return 0; } + +U_BOOT_ENV_LOCATION(nowhere) = { + .location = ENVL_NOWHERE, + .load = env_relocate_spec, + .init = env_init, +}; diff --git a/env/nvram.c b/env/nvram.c index d046c9393c..4f45eae73e 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -112,3 +112,13 @@ int env_init(void)
return 0; } + +U_BOOT_ENV_LOCATION(nvram) = { + .location = ENVL_NVRAM, +#ifdef CONFIG_SYS_NVRAM_ACCESS_ROUTINE + .get_char = env_get_char_spec, +#endif + .load = env_relocate_spec, + .save = env_save_ptr(saveenv), + .init = env_init, +}; diff --git a/env/onenand.c b/env/onenand.c index d7ad45a0e5..d4dfc02a46 100644 --- a/env/onenand.c +++ b/env/onenand.c @@ -114,3 +114,11 @@ int env_init(void)
return 0; } + +U_BOOT_ENV_LOCATION(onenand) = { + .location = ENVL_ONENAND, + .get_char = env_get_char_spec, + .load = env_relocate_spec, + .save = env_save_ptr(saveenv), + .init = env_init, +}; diff --git a/env/remote.c b/env/remote.c index e003e02fb9..c221d55c4f 100644 --- a/env/remote.c +++ b/env/remote.c @@ -56,3 +56,11 @@ void env_relocate_spec(void) env_import((char *)env_ptr, 1); #endif } + +U_BOOT_ENV_LOCATION(remote) = { + .location = ENVL_REMOTE, + .get_char = env_get_char_spec, + .load = env_relocate_spec, + .save = env_save_ptr(saveenv), + .init = env_init, +}; diff --git a/env/sata.c b/env/sata.c index 64589117f2..f7b159a347 100644 --- a/env/sata.c +++ b/env/sata.c @@ -125,3 +125,11 @@ void env_relocate_spec(void)
env_import(buf, 1); } + +U_BOOT_ENV_LOCATION(sata) = { + .location = ENVL_ESATA, + .get_char = env_get_char_spec, + .load = env_relocate_spec, + .save = env_save_ptr(saveenv), + .init = env_init, +}; diff --git a/env/sf.c b/env/sf.c index 1da3549138..8f81cf5e40 100644 --- a/env/sf.c +++ b/env/sf.c @@ -32,9 +32,15 @@ # define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE #endif
+#ifndef CONFIG_SPL_BUILD +#define CMD_SAVEENV +#endif + #ifdef CONFIG_ENV_OFFSET_REDUND +#ifdef CMD_SAVEENV static ulong env_offset = CONFIG_ENV_OFFSET; static ulong env_new_offset = CONFIG_ENV_OFFSET_REDUND; +#endif
#define ACTIVE_FLAG 1 #define OBSOLETE_FLAG 0 @@ -77,6 +83,7 @@ static int setup_flash_device(void) }
#if defined(CONFIG_ENV_OFFSET_REDUND) +#ifdef CMD_SAVEENV int saveenv(void) { env_t env_new; @@ -155,6 +162,7 @@ int saveenv(void)
return ret; } +#endif /* CMD_SAVEENV */
void env_relocate_spec(void) { @@ -240,6 +248,7 @@ out: free(tmp_env2); } #else +#ifdef CMD_SAVEENV int saveenv(void) { u32 saved_size, saved_offset, sector; @@ -299,6 +308,7 @@ int saveenv(void)
void env_relocate_spec(void) { @@ -342,3 +352,13 @@ int env_init(void)
return 0; } + +U_BOOT_ENV_LOCATION(sf) = { + .location = ENVL_SPI_FLASH, + .get_char = env_get_char_spec, + .load = env_relocate_spec, +#ifdef CMD_SAVEENV + .save = env_save_ptr(saveenv), +#endif + .init = env_init, +}; diff --git a/env/ubi.c b/env/ubi.c index d37095db0c..16f6d74d2e 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -212,3 +212,11 @@ void env_relocate_spec(void) env_import(buf, 1); } #endif /* CONFIG_SYS_REDUNDAND_ENVIRONMENT */ + +U_BOOT_ENV_LOCATION(ubi) = { + .location = ENVL_UBI, + .get_char = env_get_char_spec, + .load = env_relocate_spec, + .save = env_save_ptr(saveenv), + .init = env_init, +}; diff --git a/include/environment.h b/include/environment.h index b4c8c48717..c3a75c8a66 100644 --- a/include/environment.h +++ b/include/environment.h @@ -204,6 +204,76 @@ enum env_valid { ENV_REDUND, /* Redundant environment is valid */ };
+enum env_location { + ENVL_DATAFLASH, + ENVL_EEPROM, + ENVL_EXT4, + ENVL_FAT, + ENVL_FLASH, + ENVL_MMC, + ENVL_NAND, + ENVL_NVRAM, + ENVL_ONENAND, + ENVL_REMOTE, + ENVL_SPI_FLASH, + ENVL_UBI, + ENVL_NOWHERE, + + ENVL_COUNT, + ENVL_UNKNOWN, +}; + +struct env_driver { + enum env_location location; + + /** + * get_char() - Read a character from the environment + * + * This method is optional. If not provided, a default implementation + * will read from gd->env_addr. + * + * @index: Index of character to read (0=first) + * @return character read + */ + unsigned char (*get_char)(int index); + + /** + * load() - Load the environment from storage + * + * This method is optional. If not provided, no environment will be + * loaded. + */ + void (*load)(void); + + /** + * save() - Save the environment to storage + * + * This method is required for 'saveenv' to work. + * + * @return 0 if OK, -ve on error + */ + int (*save)(void); + + /** + * init() - Set up the initial pre-relocation environment + * + * This method is optional. + * + * @return 0 if OK, -ve on error + */ + int (*init)(void); +}; + +/* Declare a new environment location driver */ +#define U_BOOT_ENV_LOCATION(__name) \ + ll_entry_declare(struct env_driver, __name, env_driver) + +#ifdef CONFIG_CMD_SAVEENV +#define env_save_ptr(x) x +#else +#define env_save_ptr(x) NULL +#endif + extern struct hsearch_data env_htab;
Changes in v2:
[snip]
Hmm, so. I think we have an out-of-sync with desires defconfig here, and I'm going to post a few patches shortly since I found some similar things as part of the env Kconfig series. am335x_hs_evm turned off almost all of the SPL stuff it doesn't want / need (such as SPL_OS) but missed SPL_ENV_SUPPORT.
[snip]
- !defined(CONFIG_TARGET_MCCMON6) && !defined(CONFIG_TARGET_X600) && \
- !defined(CONFIG_TARGET_EDMINIV2)) || \
- !defined(CONFIG_SPL_BUILD)
I bet some of these special cases are also places where Kconfig logic and human intentions got slightly out of sync.
We plan to move to a environment access via drivers for each location where the environment can be stored. Add an implementation for this. So far it is not used, but will be pressed into service in a future patch.
Changes in v2: None
env/Makefile | 2 +- env/env.c | 145 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 146 insertions(+), 1 deletion(-) create mode 100644 env/env.c
diff --git a/env/Makefile b/env/Makefile index 4c1bdcfdf4..8df5b9d4c9 100644 --- a/env/Makefile +++ b/env/Makefile @@ -5,7 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += common.o +obj-y += common.o env.o
ifndef CONFIG_SPL_BUILD obj-y += attr.o diff --git a/env/env.c b/env/env.c new file mode 100644 index 0000000000..9f0a04c33c --- /dev/null +++ b/env/env.c @@ -0,0 +1,145 @@ +/* + * Copyright (C) 2017 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <environment.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct env_driver *env_driver_lookup(enum env_location loc) +{ + struct env_driver *drv; + const int n_ents = ll_entry_count(struct env_driver, env_driver); + struct env_driver *entry; + + drv = ll_entry_start(struct env_driver, env_driver); + for (entry = drv; entry != drv + n_ents; entry++) { + if (loc == entry->location) + return entry; + } + + /* Not found */ + return NULL; +} + +static enum env_location env_get_default_location(void) +{ + if IS_ENABLED(CONFIG_ENV_IS_IN_DATAFLASH) + return ENVL_DATAFLASH; + else if IS_ENABLED(CONFIG_ENV_IS_IN_EEPROM) + return ENVL_EEPROM; + else if IS_ENABLED(CONFIG_ENV_IS_IN_FAT) + return ENVL_FAT; + else if IS_ENABLED(CONFIG_ENV_IS_IN_FLASH) + return ENVL_FLASH; + else if IS_ENABLED(CONFIG_ENV_IS_IN_MMC) + return ENVL_MMC; + else if IS_ENABLED(CONFIG_ENV_IS_IN_NAND) + return ENVL_NAND; + else if IS_ENABLED(CONFIG_ENV_IS_IN_NVRAM) + return ENVL_NVRAM; + else if IS_ENABLED(CONFIG_ENV_IS_IN_REMOTE) + return ENVL_REMOTE; + else if IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) + return ENVL_SPI_FLASH; + else if IS_ENABLED(CONFIG_ENV_IS_IN_UBI) + return ENVL_UBI; + else if IS_ENABLED(CONFIG_ENV_IS_NOWHERE) + return ENVL_NOWHERE; + else + return ENVL_UNKNOWN; +} + +static struct env_driver *env_driver_lookup_default(void) +{ + enum env_location loc = env_get_default_location(); + struct env_driver *drv; + + drv = env_driver_lookup(loc); + if (!drv) { + debug("%s: No environment driver for location %d\n", __func__, + loc); + return NULL; + } + + return drv; +} + +int env_get_char_new(int index) +{ + struct env_driver *drv = env_driver_lookup_default(); + int ret; + + if (!drv) + return -ENODEV; + if (!drv->get_char) + return *(uchar *)(gd->env_addr + index); + ret = drv->get_char(index); + if (ret < 0) { + debug("%s: Environment failed to load (err=%d)\n", + __func__, ret); + } + + return ret; +} + +int env_load(void) +{ + struct env_driver *drv = env_driver_lookup_default(); + int ret = 0; + + if (!drv) + return -ENODEV; + if (!drv->load) + return 0; + drv->load(); /* TODO(sjg@chromium.org): Make this return an error */ + if (ret) { + debug("%s: Environment failed to load (err=%d)\n", __func__, + ret); + return ret; + } + + return 0; +} + +int env_save(void) +{ + struct env_driver *drv = env_driver_lookup_default(); + int ret; + + if (!drv) + return -ENODEV; + if (!drv->save) + return -ENOSYS; + ret = drv->save(); + if (ret) { + debug("%s: Environment failed to save (err=%d)\n", __func__, + ret); + return ret; + } + + return 0; +} + +int env_init_new(void) +{ + struct env_driver *drv = env_driver_lookup_default(); + int ret; + + if (!drv) + return -ENODEV; + if (!drv->init) + return -ENOSYS; + ret = drv->init(); + if (ret) { + debug("%s: Environment failed to init (err=%d)\n", __func__, + ret); + return ret; + } + + return 0; +}
[snip]
- if IS_ENABLED(CONFIG_ENV_IS_IN_DATAFLASH)
- else if IS_ENABLED(CONFIG_ENV_IS_IN_EEPROM)
return ENVL_EEPROM;
- else if IS_ENABLED(CONFIG_ENV_IS_IN_FAT)
return ENVL_FAT;
- else if IS_ENABLED(CONFIG_ENV_IS_IN_FLASH)
return ENVL_FLASH;
- else if IS_ENABLED(CONFIG_ENV_IS_IN_MMC)
return ENVL_MMC;
- else if IS_ENABLED(CONFIG_ENV_IS_IN_NAND)
return ENVL_NAND;
- else if IS_ENABLED(CONFIG_ENV_IS_IN_NVRAM)
return ENVL_NVRAM;
- else if IS_ENABLED(CONFIG_ENV_IS_IN_REMOTE)
return ENVL_REMOTE;
- else if IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH)
- else if IS_ENABLED(CONFIG_ENV_IS_IN_UBI)
return ENVL_UBI;
- else if IS_ENABLED(CONFIG_ENV_IS_NOWHERE)
- else
I think the kernel has a few examples of how the Kconfig side of things looks so that you can offer N options and then pick a default one (io scheduler, etc). We should do that rather than alphabetical IS_ENABLED tests.
Otherwise, TODOs aside, looks good.
Hi Tom,
[snip]
return ENVL_EEPROM;
return ENVL_FAT;
return ENVL_FLASH;
return ENVL_MMC;
return ENVL_NAND;
return ENVL_NVRAM;
return ENVL_REMOTE;
return ENVL_UBI;
else
Yes it is possible to have a choice in Kconfig, but for this first series I have left it as a option. My plan is to allow the environment to be in multiple places in the future, e.g. try using mmc and fall back to SPI flash. I think that the environment location should be able to be a run-time decision.
What do you think?
On Wed, Jul 26, 2017 at 10:32:51AM -0600, Simon Glass wrote:
Hi Tom,
[snip]
return ENVL_EEPROM;
return ENVL_FAT;
return ENVL_FLASH;
return ENVL_MMC;
return ENVL_NAND;
return ENVL_NVRAM;
return ENVL_REMOTE;
return ENVL_UBI;
else
What do you think?
I think run-time decision will be helpful, yeah, but we'll still need a way to say "this is the default place to start from" at build time and be explicit about it, rather than rely on link order or "first probed" or whatever.
Hi Tom,
Hi Tom,
[snip]
return ENVL_EEPROM;
return ENVL_FAT;
return ENVL_FLASH;
return ENVL_MMC;
return ENVL_NAND;
return ENVL_NVRAM;
return ENVL_REMOTE;
return ENVL_UBI;
else
What do you think?
At present you can really only enable one environment location and the above function enforces that. This function is intended to provide the 'default place to start from'. It's just that it's not enforced by Kconfig. What do you think we should do in the interim? I suspect I could add a patch to change it to a choice (in the interim) now that the Kconfig version is done?
On Wed, Jul 26, 2017 at 12:02:55PM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
[snip]
return ENVL_EEPROM;
return ENVL_FAT;
return ENVL_FLASH;
return ENVL_MMC;
return ENVL_NAND;
return ENVL_NVRAM;
return ENVL_REMOTE;
return ENVL_UBI;
else
What do you think?
Hmm, I thought at the end of your series it was at least linkable to have more than one at a time. But even so, I think we'll still need a build-time "user selected X as default" when more than one are allowed.
Hi Tom,
Hi Tom,
Hi Tom,
[snip]
return ENVL_EEPROM;
return ENVL_FAT;
return ENVL_FLASH;
return ENVL_MMC;
return ENVL_NAND;
return ENVL_NVRAM;
return ENVL_REMOTE;
return ENVL_UBI;
else
What do you think?
Yes it is possible to link more than one, but we still (as of this series) don't support it. Needs more work.
If more than one if enabled at present, it will just use the one selected by this function. There is no way to specify a default other than via this function. And since it can never select a different one (other than the default), I think it is currently meaningless to talk about having more than one.
I'll take a look at this for follow-up work but it will be next release now.
Move over to use a the master implementation of the location drivers, with each method calling out to the appropriate driver.
Changes in v2: None
env/dataflash.c | 16 ++++++++-------- env/eeprom.c | 16 ++++++++-------- env/env.c | 26 ++++++++++++++++++++++++++ env/ext4.c | 13 ++++++------- env/fat.c | 13 ++++++------- env/flash.c | 34 ++++++++++++++++++---------------- env/mmc.c | 27 +++++++++++++-------------- env/nand.c | 14 +++++++------- env/nowhere.c | 8 ++++---- env/nvram.c | 16 ++++++++-------- env/onenand.c | 13 ++++++------- env/remote.c | 13 ++++++------- env/sata.c | 13 ++++++------- env/sf.c | 17 ++++++++--------- env/ubi.c | 17 ++++++++--------- 15 files changed, 138 insertions(+), 118 deletions(-)
diff --git a/env/dataflash.c b/env/dataflash.c index 9c59d8e63a..6d95d6409b 100644 --- a/env/dataflash.c +++ b/env/dataflash.c @@ -18,7 +18,7 @@ env_t *env_ptr;
char *env_name_spec = "dataflash";
-uchar env_get_char_spec(int index) +static unsigned char env_dataflash_get_char(int index) { uchar c;
@@ -27,7 +27,7 @@ uchar env_get_char_spec(int index) return c; }
-void env_relocate_spec(void) +static void env_dataflash_load(void) { ulong crc, new = 0; unsigned off; @@ -54,7 +54,7 @@ void env_relocate_spec(void) #error No support for redundant environment on dataflash yet! #endif
-int saveenv(void) +static int env_dataflash_save(void) { env_t env_new; int ret; @@ -74,7 +74,7 @@ int saveenv(void) * We are still running from ROM, so data use is limited. * Use a (moderately small) buffer on the stack */ -int env_init(void) +int env_dataflash_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; @@ -85,8 +85,8 @@ int env_init(void)
U_BOOT_ENV_LOCATION(dataflash) = { .location = ENVL_DATAFLASH, - .get_char = env_get_char_spec, - .load = env_relocate_spec, - .save = env_save_ptr(saveenv), - .init = env_init, + .get_char = env_dataflash_get_char, + .load = env_dataflash_load, + .save = env_save_ptr(env_dataflash_save), + .init = env_dataflash_init, }; diff --git a/env/eeprom.c b/env/eeprom.c index 78569b286b..eb69f75f7b 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -65,7 +65,7 @@ static int eeprom_bus_write(unsigned dev_addr, unsigned offset, return rcode; }
-uchar env_get_char_spec(int index) +static uchar env_eeprom_get_char(int index) { uchar c; unsigned int off = CONFIG_ENV_OFFSET; @@ -80,7 +80,7 @@ uchar env_get_char_spec(int index) return c; }
-void env_relocate_spec(void) +static void env_eeprom_load(void) { char buf_env[CONFIG_ENV_SIZE]; unsigned int off = CONFIG_ENV_OFFSET; @@ -188,7 +188,7 @@ void env_relocate_spec(void) env_import(buf_env, 1); }
-int saveenv(void) +static int env_eeprom_save(void) { env_t env_new; int rc; @@ -237,7 +237,7 @@ int saveenv(void) * We are still running from ROM, so data use is limited. * Use a (moderately small) buffer on the stack */ -int env_init(void) +static int env_eeprom_init(void) { gd->env_addr = (ulong)&default_environment[0]; gd->env_valid = ENV_VALID; @@ -246,8 +246,8 @@ int env_init(void)
U_BOOT_ENV_LOCATION(eeprom) = { .location = ENVL_EEPROM, - .get_char = env_get_char_spec, - .load = env_relocate_spec, - .save = env_save_ptr(saveenv), - .init = env_init, + .get_char = env_eeprom_get_char, + .load = env_eeprom_load, + .save = env_save_ptr(env_eeprom_save), + .init = env_eeprom_init, }; diff --git a/env/env.c b/env/env.c index 9f0a04c33c..608ab7bb39 100644 --- a/env/env.c +++ b/env/env.c @@ -143,3 +143,29 @@ int env_init_new(void)
return 0; } + +unsigned char env_get_char_spec(int index) +{ + int ch; + + ch = env_get_char(index); + if (ch < 0) + return 0; + + return ch; +} + +void env_relocate_spec(void) +{ + env_load(); +} + +int saveenv(void) +{ + return env_save(); +} + +int env_init(void) +{ + return env_init_new(); +} diff --git a/env/ext4.c b/env/ext4.c index c6a84925d9..aa69219021 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -37,7 +37,7 @@ env_t *env_ptr;
-int env_init(void) +static int env_ext4_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; @@ -47,7 +47,7 @@ int env_init(void) }
#ifdef CONFIG_CMD_SAVEENV -int saveenv(void) +static int env_ext4_save(void) { env_t env_new; struct blk_desc *dev_desc = NULL; @@ -88,7 +88,7 @@ int saveenv(void) } #endif /* CONFIG_CMD_SAVEENV */
-void env_relocate_spec(void) +static void env_ext4_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); struct blk_desc *dev_desc = NULL; @@ -130,8 +130,7 @@ err_env_relocate:
U_BOOT_ENV_LOCATION(ext4) = { .location = ENVL_EXT4, - .get_char = env_get_char_spec, - .load = env_relocate_spec, - .save = env_save_ptr(saveenv), - .init = env_init, + .load = env_ext4_load, + .save = env_save_ptr(env_ext4_save), + .init = env_ext4_init, }; diff --git a/env/fat.c b/env/fat.c index 8f5fff81ad..f7abfdb952 100644 --- a/env/fat.c +++ b/env/fat.c @@ -37,7 +37,7 @@ env_t *env_ptr;
-int env_init(void) +static int env_fat_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; @@ -47,7 +47,7 @@ int env_init(void) }
#ifdef CMD_SAVEENV -int saveenv(void) +static int env_fat_save(void) { env_t env_new; struct blk_desc *dev_desc = NULL; @@ -87,7 +87,7 @@ int saveenv(void) #endif /* CMD_SAVEENV */
#ifdef LOADENV -void env_relocate_spec(void) +static void env_fat_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); struct blk_desc *dev_desc = NULL; @@ -125,12 +125,11 @@ err_env_relocate:
U_BOOT_ENV_LOCATION(fat) = { .location = ENVL_FAT, - .get_char = env_get_char_spec, #ifdef LOADENV - .load = env_relocate_spec, + .load = env_fat_load, #endif #ifdef CMD_SAVEENV - .save = env_save_ptr(saveenv), + .save = env_save_ptr(env_fat_save), #endif - .init = env_init, + .init = env_fat_init, }; diff --git a/env/flash.c b/env/flash.c index cf068d11ee..6ec9b61883 100644 --- a/env/flash.c +++ b/env/flash.c @@ -50,30 +50,30 @@ char *env_name_spec = "Flash"; #ifdef ENV_IS_EMBEDDED env_t *env_ptr = &environment;
-static env_t *flash_addr = (env_t *)CONFIG_ENV_ADDR; +static __maybe_unused env_t *flash_addr = (env_t *)CONFIG_ENV_ADDR;
#else /* ! ENV_IS_EMBEDDED */
env_t *env_ptr = (env_t *)CONFIG_ENV_ADDR; -static env_t *flash_addr = (env_t *)CONFIG_ENV_ADDR; +static __maybe_unused env_t *flash_addr = (env_t *)CONFIG_ENV_ADDR; #endif /* ENV_IS_EMBEDDED */
-#if defined(CMD_SAVEENV) || defined(CONFIG_ENV_ADDR_REDUND) /* CONFIG_ENV_ADDR is supposed to be on sector boundary */ -static ulong end_addr = CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1; -#endif +static ulong __maybe_unused end_addr = + CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1;
#ifdef CONFIG_ENV_ADDR_REDUND -static env_t *flash_addr_new = (env_t *)CONFIG_ENV_ADDR_REDUND; + +static env_t __maybe_unused *flash_addr_new = (env_t *)CONFIG_ENV_ADDR_REDUND;
/* CONFIG_ENV_ADDR_REDUND is supposed to be on sector boundary */ -static ulong end_addr_new = CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SECT_SIZE - 1; +static ulong __maybe_unused end_addr_new = + CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SECT_SIZE - 1; #endif /* CONFIG_ENV_ADDR_REDUND */
- #ifdef CONFIG_ENV_ADDR_REDUND #ifdef INITENV -int env_init(void) +static int env_flash_init(void) { int crc1_ok = 0, crc2_ok = 0;
@@ -119,7 +119,7 @@ int env_init(void) #endif
#ifdef CMD_SAVEENV -int saveenv(void) +static int env_flash_save(void) { env_t env_new; char *saved_data = NULL; @@ -224,7 +224,7 @@ done: #else /* ! CONFIG_ENV_ADDR_REDUND */
#ifdef INITENV -int env_init(void) +static int env_flash_init(void) { if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { gd->env_addr = (ulong)&(env_ptr->data); @@ -239,7 +239,7 @@ int env_init(void) #endif
#ifdef CMD_SAVEENV -int saveenv(void) +static int env_flash_save(void) { env_t env_new; int rc = 1; @@ -309,7 +309,8 @@ done:
-void env_relocate_spec(void) +#ifdef LOADENV +static void env_flash_load(void) { #ifdef CONFIG_ENV_ADDR_REDUND if (gd->env_addr != (ulong)&(flash_addr->data)) { @@ -354,16 +355,17 @@ void env_relocate_spec(void)
env_import((char *)flash_addr, 1); } +#endif /* LOADENV */
U_BOOT_ENV_LOCATION(flash) = { .location = ENVL_FLASH, #ifdef LOADENV - .load = env_relocate_spec, + .load = env_flash_load, #endif #ifdef CMD_SAVEENV - .save = env_save_ptr(saveenv), + .save = env_save_ptr(env_flash_save), #endif #ifdef INITENV - .init = env_init, + .init = env_flash_init, #endif }; diff --git a/env/mmc.c b/env/mmc.c index 4249182d58..2bdeeb7dc6 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -82,7 +82,7 @@ __weak int mmc_get_env_dev(void) return CONFIG_SYS_MMC_ENV_DEV; }
-int env_init(void) +static int env_mmc_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; @@ -145,7 +145,11 @@ static void fini_mmc_for_env(struct mmc *mmc) #endif }
-#ifdef CONFIG_CMD_SAVEENV +#ifdef CONFIG_ENV_OFFSET_REDUND +static unsigned char env_flags; +#endif + +#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_SPL_BUILD) static inline int write_env(struct mmc *mmc, unsigned long size, unsigned long offset, const void *buffer) { @@ -160,11 +164,7 @@ static inline int write_env(struct mmc *mmc, unsigned long size, return (n == blk_cnt) ? 0 : -1; }
-#ifdef CONFIG_ENV_OFFSET_REDUND -static unsigned char env_flags; -#endif - -int saveenv(void) +static int env_mmc_save(void) { ALLOC_CACHE_ALIGN_BUFFER(env_t, env_new, 1); int dev = mmc_get_env_dev(); @@ -213,7 +213,7 @@ fini: fini_mmc_for_env(mmc); return ret; } -#endif /* CONFIG_CMD_SAVEENV */ +#endif /* CONFIG_CMD_SAVEENV && !CONFIG_SPL_BUILD */
static inline int read_env(struct mmc *mmc, unsigned long size, unsigned long offset, const void *buffer) @@ -230,7 +230,7 @@ static inline int read_env(struct mmc *mmc, unsigned long size, }
#ifdef CONFIG_ENV_OFFSET_REDUND -void env_relocate_spec(void) +static void env_mmc_load(void) { #if !defined(ENV_IS_EMBEDDED) struct mmc *mmc; @@ -314,7 +314,7 @@ err: #endif } #else /* ! CONFIG_ENV_OFFSET_REDUND */ -void env_relocate_spec(void) +static void env_mmc_load(void) { #if !defined(ENV_IS_EMBEDDED) ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); @@ -357,10 +357,9 @@ err:
U_BOOT_ENV_LOCATION(mmc) = { .location = ENVL_MMC, - .get_char = env_get_char_spec, - .load = env_relocate_spec, + .load = env_mmc_load, #ifndef CONFIG_SPL_BUILD - .save = env_save_ptr(saveenv), + .save = env_save_ptr(env_mmc_save), #endif - .init = env_init, + .init = env_mmc_init, }; diff --git a/env/nand.c b/env/nand.c index 3e7c30600f..23cb812d78 100644 --- a/env/nand.c +++ b/env/nand.c @@ -64,7 +64,7 @@ DECLARE_GLOBAL_DATA_PTR; * This way the SPL loads not only the U-Boot image from NAND but * also the environment. */ -int env_init(void) +static int env_nand_init(void) { #if defined(ENV_IS_EMBEDDED) || defined(CONFIG_NAND_ENV_DST) int crc1_ok = 0, crc2_ok = 0; @@ -189,7 +189,7 @@ static int erase_and_write_env(const struct nand_env_location *location, static unsigned char env_flags; #endif
-int saveenv(void) +static int env_nand_save(void) { int ret = 0; ALLOC_CACHE_ALIGN_BUFFER(env_t, env_new, 1); @@ -322,7 +322,7 @@ int get_nand_env_oob(struct mtd_info *mtd, unsigned long *result) #endif
#ifdef CONFIG_ENV_OFFSET_REDUND -void env_relocate_spec(void) +static void env_nand_load(void) { #if !defined(ENV_IS_EMBEDDED) int read1_fail = 0, read2_fail = 0; @@ -394,7 +394,7 @@ done: * device i.e., nand_dev_desc + 0. This is also the behaviour using * the new NAND code. */ -void env_relocate_spec(void) +static void env_nand_load(void) { #if !defined(ENV_IS_EMBEDDED) int ret; @@ -427,9 +427,9 @@ void env_relocate_spec(void)
U_BOOT_ENV_LOCATION(nand) = { .location = ENVL_NAND, - .load = env_relocate_spec, + .load = env_nand_load, #if defined(CMD_SAVEENV) - .save = env_save_ptr(saveenv), + .save = env_save_ptr(env_nand_save), #endif - .init = env_init, + .init = env_nand_init, }; diff --git a/env/nowhere.c b/env/nowhere.c index c58d299308..6a67ab09ff 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -17,7 +17,7 @@ DECLARE_GLOBAL_DATA_PTR;
env_t *env_ptr;
-void env_relocate_spec(void) +static void env_nowhere_load(void) { }
@@ -26,7 +26,7 @@ void env_relocate_spec(void) * * We are still running from ROM, so data use is limited */ -int env_init(void) +static int env_nowhere_init(void) { gd->env_addr = (ulong)&default_environment[0]; gd->env_valid = 0; @@ -36,6 +36,6 @@ int env_init(void)
U_BOOT_ENV_LOCATION(nowhere) = { .location = ENVL_NOWHERE, - .load = env_relocate_spec, - .init = env_init, + .load = env_nowhere_load, + .init = env_nowhere_init, }; diff --git a/env/nvram.c b/env/nvram.c index 4f45eae73e..09091b8eb7 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -44,7 +44,7 @@ env_t *env_ptr = (env_t *)CONFIG_ENV_ADDR; char *env_name_spec = "NVRAM";
#ifdef CONFIG_SYS_NVRAM_ACCESS_ROUTINE -uchar env_get_char_spec(int index) +static uchar env_nvram_get_char(int index) { uchar c;
@@ -54,7 +54,7 @@ uchar env_get_char_spec(int index) } #endif
-void env_relocate_spec(void) +static void env_nvram_load(void) { char buf[CONFIG_ENV_SIZE];
@@ -66,7 +66,7 @@ void env_relocate_spec(void) env_import(buf, 1); }
-int saveenv(void) +static int env_nvram_save(void) { env_t env_new; int rcode = 0; @@ -89,7 +89,7 @@ int saveenv(void) * * We are still running from ROM, so data use is limited */ -int env_init(void) +static int env_nvram_init(void) { #if defined(CONFIG_SYS_NVRAM_ACCESS_ROUTINE) ulong crc; @@ -116,9 +116,9 @@ int env_init(void) U_BOOT_ENV_LOCATION(nvram) = { .location = ENVL_NVRAM, #ifdef CONFIG_SYS_NVRAM_ACCESS_ROUTINE - .get_char = env_get_char_spec, + .get_char = env_nvram_get_char, #endif - .load = env_relocate_spec, - .save = env_save_ptr(saveenv), - .init = env_init, + .load = env_nvram_load, + .save = env_save_ptr(env_nvram_save), + .init = env_nvram_init, }; diff --git a/env/onenand.c b/env/onenand.c index d4dfc02a46..f72aa4b036 100644 --- a/env/onenand.c +++ b/env/onenand.c @@ -28,7 +28,7 @@ char *env_name_spec = "OneNAND";
-void env_relocate_spec(void) +static void env_onenand_load(void) { struct mtd_info *mtd = &onenand_mtd; #ifdef CONFIG_ENV_ADDR_FLEX @@ -63,7 +63,7 @@ void env_relocate_spec(void) gd->env_valid = ENV_VALID; }
-int saveenv(void) +static int env_onenand_save(void) { env_t env_new; int ret; @@ -106,7 +106,7 @@ int saveenv(void) return 0; }
-int env_init(void) +static int env_onenand_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; @@ -117,8 +117,7 @@ int env_init(void)
U_BOOT_ENV_LOCATION(onenand) = { .location = ENVL_ONENAND, - .get_char = env_get_char_spec, - .load = env_relocate_spec, - .save = env_save_ptr(saveenv), - .init = env_init, + .load = env_onenand_load, + .save = env_save_ptr(env_onenand_save), + .init = env_onenand_init, }; diff --git a/env/remote.c b/env/remote.c index c221d55c4f..0324cba099 100644 --- a/env/remote.c +++ b/env/remote.c @@ -25,7 +25,7 @@ DECLARE_GLOBAL_DATA_PTR; #define CONFIG_ENV_OFFSET 0 #endif
-int env_init(void) +static int env_remote_init(void) { if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { gd->env_addr = (ulong)&(env_ptr->data); @@ -39,7 +39,7 @@ int env_init(void) }
#ifdef CONFIG_CMD_SAVEENV -int saveenv(void) +static int env_remote_save(void) { #ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE printf("Can not support the 'saveenv' when boot from SRIO or PCIE!\n"); @@ -50,7 +50,7 @@ int saveenv(void) } #endif /* CONFIG_CMD_SAVEENV */
-void env_relocate_spec(void) +static void env_remote_load(void) { #ifndef ENV_IS_EMBEDDED env_import((char *)env_ptr, 1); @@ -59,8 +59,7 @@ void env_relocate_spec(void)
U_BOOT_ENV_LOCATION(remote) = { .location = ENVL_REMOTE, - .get_char = env_get_char_spec, - .load = env_relocate_spec, - .save = env_save_ptr(saveenv), - .init = env_init, + .load = env_remote_load, + .save = env_save_ptr(env_remote_save), + .init = env_remote_init, }; diff --git a/env/sata.c b/env/sata.c index f7b159a347..6f9099873d 100644 --- a/env/sata.c +++ b/env/sata.c @@ -33,7 +33,7 @@ __weak int sata_get_env_dev(void) return CONFIG_SYS_SATA_ENV_DEV; }
-int env_init(void) +static int env_sata_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; @@ -56,7 +56,7 @@ static inline int write_env(struct blk_desc *sata, unsigned long size, return (n == blk_cnt) ? 0 : -1; }
-int saveenv(void) +static int env_sata_save(void) { ALLOC_CACHE_ALIGN_BUFFER(env_t, env_new, 1); struct blk_desc *sata = NULL; @@ -102,7 +102,7 @@ static inline int read_env(struct blk_desc *sata, unsigned long size, return (n == blk_cnt) ? 0 : -1; }
-void env_relocate_spec(void) +static void env_sata_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); struct blk_desc *sata = NULL; @@ -128,8 +128,7 @@ void env_relocate_spec(void)
U_BOOT_ENV_LOCATION(sata) = { .location = ENVL_ESATA, - .get_char = env_get_char_spec, - .load = env_relocate_spec, - .save = env_save_ptr(saveenv), - .init = env_init, + .load = env_sata_load, + .save = env_save_ptr(env_sata_save), + .init = env_sata_init, }; diff --git a/env/sf.c b/env/sf.c index 8f81cf5e40..82babaab67 100644 --- a/env/sf.c +++ b/env/sf.c @@ -84,7 +84,7 @@ static int setup_flash_device(void)
#if defined(CONFIG_ENV_OFFSET_REDUND) #ifdef CMD_SAVEENV -int saveenv(void) +static int env_sf_save(void) { env_t env_new; char *saved_buffer = NULL, flag = OBSOLETE_FLAG; @@ -164,7 +164,7 @@ int saveenv(void) } #endif /* CMD_SAVEENV */
-void env_relocate_spec(void) +static void env_sf_load(void) { int ret; int crc1_ok = 0, crc2_ok = 0; @@ -249,7 +249,7 @@ out: } #else #ifdef CMD_SAVEENV -int saveenv(void) +static int env_sf_save(void) { u32 saved_size, saved_offset, sector; char *saved_buffer = NULL; @@ -310,7 +310,7 @@ int saveenv(void) } #endif /* CMD_SAVEENV */
-void env_relocate_spec(void) +static void env_sf_load(void) { int ret; char *buf = NULL; @@ -344,7 +344,7 @@ out: } #endif
-int env_init(void) +static int env_sf_init(void) { /* SPI flash isn't usable before relocation */ gd->env_addr = (ulong)&default_environment[0]; @@ -355,10 +355,9 @@ int env_init(void)
U_BOOT_ENV_LOCATION(sf) = { .location = ENVL_SPI_FLASH, - .get_char = env_get_char_spec, - .load = env_relocate_spec, + .load = env_sf_load, #ifdef CMD_SAVEENV - .save = env_save_ptr(saveenv), + .save = env_save_ptr(env_sf_save), #endif - .init = env_init, + .init = env_sf_init, }; diff --git a/env/ubi.c b/env/ubi.c index 16f6d74d2e..82a9c3bd03 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -22,7 +22,7 @@ env_t *env_ptr;
-int env_init(void) +static int env_ubi_init(void) { /* use default */ gd->env_addr = (ulong)&default_environment[0]; @@ -35,7 +35,7 @@ int env_init(void) #ifdef CONFIG_SYS_REDUNDAND_ENVIRONMENT static unsigned char env_flags;
-int saveenv(void) +static int env_ubi_save(void) { ALLOC_CACHE_ALIGN_BUFFER(env_t, env_new, 1); int ret; @@ -79,7 +79,7 @@ int saveenv(void) return 0; } #else /* ! CONFIG_SYS_REDUNDAND_ENVIRONMENT */ -int saveenv(void) +static int env_ubi_save(void) { ALLOC_CACHE_ALIGN_BUFFER(env_t, env_new, 1); int ret; @@ -108,7 +108,7 @@ int saveenv(void) #endif /* CONFIG_CMD_SAVEENV */
#ifdef CONFIG_SYS_REDUNDAND_ENVIRONMENT -void env_relocate_spec(void) +static void env_ubi_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, env1_buf, CONFIG_ENV_SIZE); ALLOC_CACHE_ALIGN_BUFFER(char, env2_buf, CONFIG_ENV_SIZE); @@ -181,7 +181,7 @@ void env_relocate_spec(void) env_import((char *)ep, 0); } #else /* ! CONFIG_SYS_REDUNDAND_ENVIRONMENT */ -void env_relocate_spec(void) +static void env_ubi_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE);
@@ -215,8 +215,7 @@ void env_relocate_spec(void)
U_BOOT_ENV_LOCATION(ubi) = { .location = ENVL_UBI, - .get_char = env_get_char_spec, - .load = env_relocate_spec, - .save = env_save_ptr(saveenv), - .init = env_init, + .load = env_ubi_load, + .save = env_save_ptr(env_ubi_save), + .init = env_ubi_init, };
Most of the init() implementations just use the default environment. Adjust env_init_new() to do this automatically, and drop the redundant code.
Changes in v2: None
env/dataflash.c | 16 ---------------- env/eeprom.c | 14 -------------- env/env.c | 14 +++++++++----- env/ext4.c | 10 ---------- env/fat.c | 10 ---------- env/mmc.c | 10 ---------- env/nowhere.c | 19 ------------------- env/onenand.c | 10 ---------- env/remote.c | 4 +--- env/sata.c | 10 ---------- env/sf.c | 10 ---------- env/ubi.c | 10 ---------- include/environment.h | 3 ++- 13 files changed, 12 insertions(+), 128 deletions(-)
diff --git a/env/dataflash.c b/env/dataflash.c index 6d95d6409b..8ab482b3b4 100644 --- a/env/dataflash.c +++ b/env/dataflash.c @@ -68,25 +68,9 @@ static int env_dataflash_save(void) CONFIG_ENV_SIZE); }
-/* - * Initialize environment use - * - * We are still running from ROM, so data use is limited. - * Use a (moderately small) buffer on the stack - */ -int env_dataflash_init(void) -{ - /* use default */ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; - - return 0; -} - U_BOOT_ENV_LOCATION(dataflash) = { .location = ENVL_DATAFLASH, .get_char = env_dataflash_get_char, .load = env_dataflash_load, .save = env_save_ptr(env_dataflash_save), - .init = env_dataflash_init, }; diff --git a/env/eeprom.c b/env/eeprom.c index eb69f75f7b..3cc412620a 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -231,23 +231,9 @@ static int env_eeprom_save(void) return rc; }
-/* - * Initialize Environment use - * - * We are still running from ROM, so data use is limited. - * Use a (moderately small) buffer on the stack - */ -static int env_eeprom_init(void) -{ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; - return 0; -} - U_BOOT_ENV_LOCATION(eeprom) = { .location = ENVL_EEPROM, .get_char = env_eeprom_get_char, .load = env_eeprom_load, .save = env_save_ptr(env_eeprom_save), - .init = env_eeprom_init, }; diff --git a/env/env.c b/env/env.c index 608ab7bb39..73547002d1 100644 --- a/env/env.c +++ b/env/env.c @@ -128,14 +128,18 @@ int env_save(void) int env_init_new(void) { struct env_driver *drv = env_driver_lookup_default(); - int ret; + int ret = -ENOSYS;
if (!drv) return -ENODEV; - if (!drv->init) - return -ENOSYS; - ret = drv->init(); - if (ret) { + if (drv->init) + ret = drv->init(); + if (ret == -ENOENT) { + gd->env_addr = (ulong)&default_environment[0]; + gd->env_valid = ENV_VALID; + + return 0; + } else if (ret) { debug("%s: Environment failed to init (err=%d)\n", __func__, ret); return ret; diff --git a/env/ext4.c b/env/ext4.c index aa69219021..25a5cbecdd 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -37,15 +37,6 @@ env_t *env_ptr;
-static int env_ext4_init(void) -{ - /* use default */ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; - - return 0; -} - #ifdef CONFIG_CMD_SAVEENV static int env_ext4_save(void) { @@ -132,5 +123,4 @@ U_BOOT_ENV_LOCATION(ext4) = { .location = ENVL_EXT4, .load = env_ext4_load, .save = env_save_ptr(env_ext4_save), - .init = env_ext4_init, }; diff --git a/env/fat.c b/env/fat.c index f7abfdb952..bd31b2904d 100644 --- a/env/fat.c +++ b/env/fat.c @@ -37,15 +37,6 @@ env_t *env_ptr;
-static int env_fat_init(void) -{ - /* use default */ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; - - return 0; -} - #ifdef CMD_SAVEENV static int env_fat_save(void) { @@ -131,5 +122,4 @@ U_BOOT_ENV_LOCATION(fat) = { #ifdef CMD_SAVEENV .save = env_save_ptr(env_fat_save), #endif - .init = env_fat_init, }; diff --git a/env/mmc.c b/env/mmc.c index 2bdeeb7dc6..2dd0382bfb 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -82,15 +82,6 @@ __weak int mmc_get_env_dev(void) return CONFIG_SYS_MMC_ENV_DEV; }
-static int env_mmc_init(void) -{ - /* use default */ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; - - return 0; -} - #ifdef CONFIG_SYS_MMC_ENV_PART __weak uint mmc_get_env_part(struct mmc *mmc) { @@ -361,5 +352,4 @@ U_BOOT_ENV_LOCATION(mmc) = { #ifndef CONFIG_SPL_BUILD .save = env_save_ptr(env_mmc_save), #endif - .init = env_mmc_init, }; diff --git a/env/nowhere.c b/env/nowhere.c index 6a67ab09ff..1d2ae85a57 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -17,25 +17,6 @@ DECLARE_GLOBAL_DATA_PTR;
env_t *env_ptr;
-static void env_nowhere_load(void) -{ -} - -/* - * Initialize Environment use - * - * We are still running from ROM, so data use is limited - */ -static int env_nowhere_init(void) -{ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = 0; - - return 0; -} - U_BOOT_ENV_LOCATION(nowhere) = { .location = ENVL_NOWHERE, - .load = env_nowhere_load, - .init = env_nowhere_init, }; diff --git a/env/onenand.c b/env/onenand.c index f72aa4b036..cb1ab53216 100644 --- a/env/onenand.c +++ b/env/onenand.c @@ -106,18 +106,8 @@ static int env_onenand_save(void) return 0; }
-static int env_onenand_init(void) -{ - /* use default */ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; - - return 0; -} - U_BOOT_ENV_LOCATION(onenand) = { .location = ENVL_ONENAND, .load = env_onenand_load, .save = env_save_ptr(env_onenand_save), - .init = env_onenand_init, }; diff --git a/env/remote.c b/env/remote.c index 0324cba099..c5dce5b966 100644 --- a/env/remote.c +++ b/env/remote.c @@ -33,9 +33,7 @@ static int env_remote_init(void) return 0; }
- gd->env_addr = (ulong)default_environment; - gd->env_valid = 0; - return 0; + return -ENOENT; }
#ifdef CONFIG_CMD_SAVEENV diff --git a/env/sata.c b/env/sata.c index 6f9099873d..a5ff54c287 100644 --- a/env/sata.c +++ b/env/sata.c @@ -33,15 +33,6 @@ __weak int sata_get_env_dev(void) return CONFIG_SYS_SATA_ENV_DEV; }
-static int env_sata_init(void) -{ - /* use default */ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; - - return 0; -} - #ifdef CONFIG_CMD_SAVEENV static inline int write_env(struct blk_desc *sata, unsigned long size, unsigned long offset, void *buffer) @@ -130,5 +121,4 @@ U_BOOT_ENV_LOCATION(sata) = { .location = ENVL_ESATA, .load = env_sata_load, .save = env_save_ptr(env_sata_save), - .init = env_sata_init, }; diff --git a/env/sf.c b/env/sf.c index 82babaab67..a07641b7d4 100644 --- a/env/sf.c +++ b/env/sf.c @@ -344,20 +344,10 @@ out: } #endif
-static int env_sf_init(void) -{ - /* SPI flash isn't usable before relocation */ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; - - return 0; -} - U_BOOT_ENV_LOCATION(sf) = { .location = ENVL_SPI_FLASH, .load = env_sf_load, #ifdef CMD_SAVEENV .save = env_save_ptr(env_sf_save), #endif - .init = env_sf_init, }; diff --git a/env/ubi.c b/env/ubi.c index 82a9c3bd03..773fcf0ed2 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -22,15 +22,6 @@ env_t *env_ptr;
-static int env_ubi_init(void) -{ - /* use default */ - gd->env_addr = (ulong)&default_environment[0]; - gd->env_valid = ENV_VALID; - - return 0; -} - #ifdef CONFIG_CMD_SAVEENV #ifdef CONFIG_SYS_REDUNDAND_ENVIRONMENT static unsigned char env_flags; @@ -217,5 +208,4 @@ U_BOOT_ENV_LOCATION(ubi) = { .location = ENVL_UBI, .load = env_ubi_load, .save = env_save_ptr(env_ubi_save), - .init = env_ubi_init, }; diff --git a/include/environment.h b/include/environment.h index c3a75c8a66..87727f2b29 100644 --- a/include/environment.h +++ b/include/environment.h @@ -259,7 +259,8 @@ struct env_driver { * * This method is optional. * - * @return 0 if OK, -ve on error + * @return 0 if OK, -ENOENT if no initial environment could be found, + * other -ve on error */ int (*init)(void); };
Add a name to the driver and use that instead of the global variable declared by each driver.
Changes in v2: None
cmd/nvedit.c | 4 +++- env/dataflash.c | 3 +-- env/eeprom.c | 3 +-- env/env.c | 2 +- env/ext4.c | 3 +-- env/fat.c | 3 +-- env/flash.c | 3 +-- env/mmc.c | 3 +-- env/nand.c | 3 +-- env/nowhere.c | 1 + env/nvram.c | 3 +-- env/onenand.c | 3 +-- env/remote.c | 3 +-- env/sata.c | 3 +-- env/sf.c | 3 +-- env/ubi.c | 2 -- include/environment.h | 19 +++++++++++++++---- 17 files changed, 32 insertions(+), 32 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index cd17db6409..75df997592 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -706,7 +706,9 @@ ulong getenv_ulong(const char *name, int base, ulong default_val) static int do_env_save(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - printf("Saving Environment to %s...\n", env_name_spec); + struct env_driver *env = env_driver_lookup_default(); + + printf("Saving Environment to %s...\n", env->name);
return saveenv() ? 1 : 0; } diff --git a/env/dataflash.c b/env/dataflash.c index 8ab482b3b4..9421a6a5b2 100644 --- a/env/dataflash.c +++ b/env/dataflash.c @@ -16,8 +16,6 @@ DECLARE_GLOBAL_DATA_PTR;
env_t *env_ptr;
-char *env_name_spec = "dataflash"; - static unsigned char env_dataflash_get_char(int index) { uchar c; @@ -70,6 +68,7 @@ static int env_dataflash_save(void)
U_BOOT_ENV_LOCATION(dataflash) = { .location = ENVL_DATAFLASH, + ENV_NAME("dataflash") .get_char = env_dataflash_get_char, .load = env_dataflash_load, .save = env_save_ptr(env_dataflash_save), diff --git a/env/eeprom.c b/env/eeprom.c index 3cc412620a..2c795b9236 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -23,8 +23,6 @@ DECLARE_GLOBAL_DATA_PTR;
env_t *env_ptr;
-char *env_name_spec = "EEPROM"; - static int eeprom_bus_read(unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) { @@ -233,6 +231,7 @@ static int env_eeprom_save(void)
U_BOOT_ENV_LOCATION(eeprom) = { .location = ENVL_EEPROM, + ENV_NAME("EEPROM") .get_char = env_eeprom_get_char, .load = env_eeprom_load, .save = env_save_ptr(env_eeprom_save), diff --git a/env/env.c b/env/env.c index 73547002d1..a649457270 100644 --- a/env/env.c +++ b/env/env.c @@ -54,7 +54,7 @@ static enum env_location env_get_default_location(void) return ENVL_UNKNOWN; }
-static struct env_driver *env_driver_lookup_default(void) +struct env_driver *env_driver_lookup_default(void) { enum env_location loc = env_get_default_location(); struct env_driver *drv; diff --git a/env/ext4.c b/env/ext4.c index 25a5cbecdd..5acdf0eda0 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -31,8 +31,6 @@ #include <ext4fs.h> #include <mmc.h>
-char *env_name_spec = "EXT4"; - env_t *env_ptr;
DECLARE_GLOBAL_DATA_PTR; @@ -121,6 +119,7 @@ err_env_relocate:
U_BOOT_ENV_LOCATION(ext4) = { .location = ENVL_EXT4, + ENV_NAME("EXT4") .load = env_ext4_load, .save = env_save_ptr(env_ext4_save), }; diff --git a/env/fat.c b/env/fat.c index bd31b2904d..ad0c4321c7 100644 --- a/env/fat.c +++ b/env/fat.c @@ -31,8 +31,6 @@ # endif #endif
-char *env_name_spec = "FAT"; - env_t *env_ptr;
DECLARE_GLOBAL_DATA_PTR; @@ -116,6 +114,7 @@ err_env_relocate:
U_BOOT_ENV_LOCATION(fat) = { .location = ENVL_FAT, + ENV_NAME("FAT") #ifdef LOADENV .load = env_fat_load, #endif diff --git a/env/flash.c b/env/flash.c index 6ec9b61883..2d72c51622 100644 --- a/env/flash.c +++ b/env/flash.c @@ -45,8 +45,6 @@ DECLARE_GLOBAL_DATA_PTR; #define INITENV #endif
-char *env_name_spec = "Flash"; - #ifdef ENV_IS_EMBEDDED env_t *env_ptr = &environment;
@@ -359,6 +357,7 @@ static void env_flash_load(void)
U_BOOT_ENV_LOCATION(flash) = { .location = ENVL_FLASH, + ENV_NAME("Flash") #ifdef LOADENV .load = env_flash_load, #endif diff --git a/env/mmc.c b/env/mmc.c index 2dd0382bfb..ae10b5b1f8 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -23,8 +23,6 @@ #error CONFIG_ENV_SIZE_REDUND should be the same as CONFIG_ENV_SIZE #endif
-char *env_name_spec = "MMC"; - #ifdef ENV_IS_EMBEDDED env_t *env_ptr = &environment; #else /* ! ENV_IS_EMBEDDED */ @@ -348,6 +346,7 @@ err:
U_BOOT_ENV_LOCATION(mmc) = { .location = ENVL_MMC, + ENV_NAME("MMC") .load = env_mmc_load, #ifndef CONFIG_SPL_BUILD .save = env_save_ptr(env_mmc_save), diff --git a/env/nand.c b/env/nand.c index 23cb812d78..e26f5638c4 100644 --- a/env/nand.c +++ b/env/nand.c @@ -40,8 +40,6 @@ #define CONFIG_ENV_RANGE CONFIG_ENV_SIZE #endif
-char *env_name_spec = "NAND"; - #if defined(ENV_IS_EMBEDDED) env_t *env_ptr = &environment; #elif defined(CONFIG_NAND_ENV_DST) @@ -427,6 +425,7 @@ static void env_nand_load(void)
U_BOOT_ENV_LOCATION(nand) = { .location = ENVL_NAND, + ENV_NAME("NAND") .load = env_nand_load, #if defined(CMD_SAVEENV) .save = env_save_ptr(env_nand_save), diff --git a/env/nowhere.c b/env/nowhere.c index 1d2ae85a57..1a17d6978b 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -19,4 +19,5 @@ env_t *env_ptr;
U_BOOT_ENV_LOCATION(nowhere) = { .location = ENVL_NOWHERE, + ENV_NAME("nowhere") }; diff --git a/env/nvram.c b/env/nvram.c index 09091b8eb7..0f4b491fd3 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -41,8 +41,6 @@ env_t *env_ptr; env_t *env_ptr = (env_t *)CONFIG_ENV_ADDR; #endif
-char *env_name_spec = "NVRAM"; - #ifdef CONFIG_SYS_NVRAM_ACCESS_ROUTINE static uchar env_nvram_get_char(int index) { @@ -115,6 +113,7 @@ static int env_nvram_init(void)
U_BOOT_ENV_LOCATION(nvram) = { .location = ENVL_NVRAM, + ENV_NAME("NVRAM") #ifdef CONFIG_SYS_NVRAM_ACCESS_ROUTINE .get_char = env_nvram_get_char, #endif diff --git a/env/onenand.c b/env/onenand.c index cb1ab53216..319f553262 100644 --- a/env/onenand.c +++ b/env/onenand.c @@ -21,8 +21,6 @@ #include <linux/mtd/mtd.h> #include <linux/mtd/onenand.h>
-char *env_name_spec = "OneNAND"; - #define ONENAND_MAX_ENV_SIZE CONFIG_ENV_SIZE #define ONENAND_ENV_SIZE(mtd) (ONENAND_MAX_ENV_SIZE - ENV_HEADER_SIZE)
@@ -108,6 +106,7 @@ static int env_onenand_save(void)
U_BOOT_ENV_LOCATION(onenand) = { .location = ENVL_ONENAND, + ENV_NAME("OneNAND") .load = env_onenand_load, .save = env_save_ptr(env_onenand_save), }; diff --git a/env/remote.c b/env/remote.c index c5dce5b966..0d8865bd67 100644 --- a/env/remote.c +++ b/env/remote.c @@ -11,8 +11,6 @@ #include <environment.h> #include <linux/stddef.h>
-char *env_name_spec = "Remote"; - #ifdef ENV_IS_EMBEDDED env_t *env_ptr = &environment; #else /* ! ENV_IS_EMBEDDED */ @@ -57,6 +55,7 @@ static void env_remote_load(void)
U_BOOT_ENV_LOCATION(remote) = { .location = ENVL_REMOTE, + ENV_NAME("Remote") .load = env_remote_load, .save = env_save_ptr(env_remote_save), .init = env_remote_init, diff --git a/env/sata.c b/env/sata.c index a5ff54c287..16d8f939db 100644 --- a/env/sata.c +++ b/env/sata.c @@ -24,8 +24,6 @@ #error CONFIG_ENV_OFFSET or CONFIG_ENV_SIZE not defined #endif
-char *env_name_spec = "SATA"; - DECLARE_GLOBAL_DATA_PTR;
__weak int sata_get_env_dev(void) @@ -119,6 +117,7 @@ static void env_sata_load(void)
U_BOOT_ENV_LOCATION(sata) = { .location = ENVL_ESATA, + ENV_NAME("SATA") .load = env_sata_load, .save = env_save_ptr(env_sata_save), }; diff --git a/env/sf.c b/env/sf.c index a07641b7d4..07386c629a 100644 --- a/env/sf.c +++ b/env/sf.c @@ -48,8 +48,6 @@ static ulong env_new_offset = CONFIG_ENV_OFFSET_REDUND;
-char *env_name_spec = "SPI Flash"; - static struct spi_flash *env_flash;
static int setup_flash_device(void) @@ -346,6 +344,7 @@ out:
U_BOOT_ENV_LOCATION(sf) = { .location = ENVL_SPI_FLASH, + ENV_NAME("SPI Flash") .load = env_sf_load, #ifdef CMD_SAVEENV .save = env_save_ptr(env_sf_save), diff --git a/env/ubi.c b/env/ubi.c index 773fcf0ed2..0f1e5bcd22 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -16,8 +16,6 @@ #include <ubi_uboot.h> #undef crc32
-char *env_name_spec = "UBI"; - env_t *env_ptr;
DECLARE_GLOBAL_DATA_PTR; diff --git a/include/environment.h b/include/environment.h index 87727f2b29..03fe00f215 100644 --- a/include/environment.h +++ b/include/environment.h @@ -143,10 +143,6 @@ extern unsigned long nand_env_oob_offset; # define ENV_HEADER_SIZE (sizeof(uint32_t)) #endif
-#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) -extern char *env_name_spec; -#endif - #ifdef CONFIG_ENV_AES /* Make sure the payload is multiple of AES block size */ #define ENV_SIZE ((CONFIG_ENV_SIZE - ENV_HEADER_SIZE) & ~(16 - 1)) @@ -224,6 +220,7 @@ enum env_location { };
struct env_driver { + const char *name; enum env_location location;
/** @@ -269,6 +266,13 @@ struct env_driver { #define U_BOOT_ENV_LOCATION(__name) \ ll_entry_declare(struct env_driver, __name, env_driver)
+/* Declare the name of a location */ +#ifdef CONFIG_CMD_SAVEENV +#define ENV_NAME(_name) .name = _name, +#else +#define ENV_NAME(_name) +#endif + #ifdef CONFIG_CMD_SAVEENV #define env_save_ptr(x) x #else @@ -298,6 +302,13 @@ int env_import(const char *buf, int check); /* Export from hash table into binary representation */ int env_export(env_t *env_out);
+/** + * env_driver_lookup_default() - Look up the default environment driver + * + * @return pointer to driver, or NULL if none (which should not happen) + */ +struct env_driver *env_driver_lookup_default(void); + #endif /* DO_DEPS_ONLY */
#endif /* _ENVIRONMENT_H_ */
This variable is declared as a global in most environment location drivers. But it is not used outside the drivers and most of the declarations are unnecessary.
Also some drivers call free() on env_ptr which seems wrong since it is not in the heap.
Drop the variable where possible, and all calls to free().
Changes in v2: None
env/dataflash.c | 2 -- env/eeprom.c | 4 ---- env/ext4.c | 2 -- env/fat.c | 2 -- env/mmc.c | 8 -------- env/nand.c | 2 -- env/nowhere.c | 2 -- env/nvram.c | 1 - env/ubi.c | 2 -- 9 files changed, 25 deletions(-)
diff --git a/env/dataflash.c b/env/dataflash.c index 9421a6a5b2..28dcf6fa1c 100644 --- a/env/dataflash.c +++ b/env/dataflash.c @@ -14,8 +14,6 @@
-env_t *env_ptr; - static unsigned char env_dataflash_get_char(int index) { uchar c; diff --git a/env/eeprom.c b/env/eeprom.c index 2c795b9236..39adccabbe 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -21,8 +21,6 @@
-env_t *env_ptr; - static int eeprom_bus_read(unsigned dev_addr, unsigned offset, uchar *buffer, unsigned cnt) { @@ -196,8 +194,6 @@ static int env_eeprom_save(void) char flag_obsolete = OBSOLETE_FLAG; #endif
- BUG_ON(env_ptr != NULL); - rc = env_export(&env_new); if (rc) return rc; diff --git a/env/ext4.c b/env/ext4.c index 5acdf0eda0..ee073a8b7c 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -31,8 +31,6 @@ #include <ext4fs.h> #include <mmc.h>
-env_t *env_ptr; - DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_CMD_SAVEENV diff --git a/env/fat.c b/env/fat.c index ad0c4321c7..69319f8834 100644 --- a/env/fat.c +++ b/env/fat.c @@ -31,8 +31,6 @@ # endif #endif
#ifdef CMD_SAVEENV diff --git a/env/mmc.c b/env/mmc.c index ae10b5b1f8..cf85bc232f 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -23,12 +23,6 @@ #error CONFIG_ENV_SIZE_REDUND should be the same as CONFIG_ENV_SIZE #endif
-#ifdef ENV_IS_EMBEDDED -env_t *env_ptr = &environment; -#else /* ! ENV_IS_EMBEDDED */ -env_t *env_ptr; -#endif /* ENV_IS_EMBEDDED */ - DECLARE_GLOBAL_DATA_PTR;
#if !defined(CONFIG_ENV_OFFSET) @@ -284,8 +278,6 @@ static void env_mmc_load(void) gd->env_valid = ENV_VALID; }
- free(env_ptr); - if (gd->env_valid == ENV_VALID) ep = tmp_env1; else diff --git a/env/nand.c b/env/nand.c index e26f5638c4..e0368bf8de 100644 --- a/env/nand.c +++ b/env/nand.c @@ -370,8 +370,6 @@ static void env_nand_load(void) gd->env_valid = ENV_VALID; }
- free(env_ptr); - if (gd->env_valid == ENV_VALID) ep = tmp_env1; else diff --git a/env/nowhere.c b/env/nowhere.c index 1a17d6978b..d60de494e6 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -15,8 +15,6 @@
-env_t *env_ptr; - U_BOOT_ENV_LOCATION(nowhere) = { .location = ENVL_NOWHERE, ENV_NAME("nowhere") diff --git a/env/nvram.c b/env/nvram.c index 0f4b491fd3..ac389ace62 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -36,7 +36,6 @@ DECLARE_GLOBAL_DATA_PTR; #ifdef CONFIG_SYS_NVRAM_ACCESS_ROUTINE extern void *nvram_read(void *dest, const long src, size_t count); extern void nvram_write(long dest, const void *src, size_t count); -env_t *env_ptr; #else env_t *env_ptr = (env_t *)CONFIG_ENV_ADDR; #endif diff --git a/env/ubi.c b/env/ubi.c index 0f1e5bcd22..65be2b1bbf 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -16,8 +16,6 @@ #include <ubi_uboot.h> #undef crc32
Signed-off-by: Simon Glass sjg@chromium.org
Now that env_init() is only defined once we can drop the env_init_new() name and just use env_init().
Changes in v2: None
env/env.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/env/env.c b/env/env.c index a649457270..70ce2857c3 100644 --- a/env/env.c +++ b/env/env.c @@ -125,7 +125,7 @@ int env_save(void) return 0; }
-int env_init_new(void) +int env_init(void) { struct env_driver *drv = env_driver_lookup_default(); int ret = -ENOSYS; @@ -169,7 +169,3 @@ int saveenv(void) return env_save(); }
-int env_init(void) -{ - return env_init_new(); -}
We only have a single implementation of this function now and it is called env_get_char(). Drop the old function and the weak version.
Changes in v2: None
env/common.c | 14 -------------- env/env.c | 15 +++------------ include/environment.h | 14 ++++++++++---- 3 files changed, 13 insertions(+), 30 deletions(-)
diff --git a/env/common.c b/env/common.c index 7ed4bb28dd..9f1d21adbd 100644 --- a/env/common.c +++ b/env/common.c @@ -27,20 +27,6 @@ struct hsearch_data env_htab = { .change_ok = env_flags_validate, };
-__weak uchar env_get_char_spec(int index) -{ - return *(uchar *)(gd->env_addr + index); -} - -uchar env_get_char(int index) -{ - /* if env is not set up, or crc was bad, use the default environment */ - if (!gd->env_valid) - return default_environment[index]; - else - return env_get_char_spec(index); -} - /* * Read an environment variable as a boolean * Return -1 if variable does not exist (default to true) diff --git a/env/env.c b/env/env.c index 70ce2857c3..809889f55e 100644 --- a/env/env.c +++ b/env/env.c @@ -69,11 +69,13 @@ struct env_driver *env_driver_lookup_default(void) return drv; }
-int env_get_char_new(int index) +int env_get_char(int index) { struct env_driver *drv = env_driver_lookup_default(); int ret;
+ if (!gd->env_valid) + return default_environment[index]; if (!drv) return -ENODEV; if (!drv->get_char) @@ -148,17 +150,6 @@ int env_init(void) return 0; }
-unsigned char env_get_char_spec(int index) -{ - int ch; - - ch = env_get_char(index); - if (ch < 0) - return 0; - - return ch; -} - void env_relocate_spec(void) { env_load(); diff --git a/include/environment.h b/include/environment.h index 03fe00f215..a494500825 100644 --- a/include/environment.h +++ b/include/environment.h @@ -171,7 +171,6 @@ extern const unsigned char default_environment[]; extern env_t *env_ptr;
extern void env_relocate_spec(void); -extern unsigned char env_get_char_spec(int);
#if defined(CONFIG_NEEDS_MANUAL_RELOC) extern void env_reloc(void); @@ -281,9 +280,6 @@ struct env_driver {
-/* Function that returns a character from the environment */ -unsigned char env_get_char(int); - /* Function that updates CRC of the enironment */ void env_crc_update(void);
@@ -309,6 +305,16 @@ int env_export(env_t *env_out); */ struct env_driver *env_driver_lookup_default(void);
+/** + * env_get_char() - Get a character from the early environment + * + * This reads from the pre-relocation environemnt + * + * @index: Index of character to read (0 = first) + * @return character read, or -ve on error + */ +int env_get_char(int index); + #endif /* DO_DEPS_ONLY */
This is a strange name for a function that loads the environment. There is now only one implementation of this function, so use the new env_load() function directly instead.
Changes in v2: None
board/birdland/bav335x/board.c | 2 +- board/gateworks/gw_ventana/gw_ventana_spl.c | 2 +- board/tcl/sl50/board.c | 2 +- board/ti/am335x/board.c | 2 +- board/ti/am57xx/board.c | 2 +- board/ti/dra7xx/evm.c | 2 +- env/common.c | 2 +- env/env.c | 5 ----- include/environment.h | 9 +++++++-- 9 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/board/birdland/bav335x/board.c b/board/birdland/bav335x/board.c index 67aca3cc43..b49365e157 100644 --- a/board/birdland/bav335x/board.c +++ b/board/birdland/bav335x/board.c @@ -162,7 +162,7 @@ int spl_start_uboot(void)
#ifdef CONFIG_SPL_ENV_SUPPORT env_init(); - env_relocate_spec(); + env_load(); if (getenv_yesno("boot_os") != 1) return 1; #endif diff --git a/board/gateworks/gw_ventana/gw_ventana_spl.c b/board/gateworks/gw_ventana/gw_ventana_spl.c index 69a638d71d..baa8480b6c 100644 --- a/board/gateworks/gw_ventana/gw_ventana_spl.c +++ b/board/gateworks/gw_ventana/gw_ventana_spl.c @@ -690,7 +690,7 @@ int spl_start_uboot(void) debug("%s\n", __func__); #ifdef CONFIG_SPL_ENV_SUPPORT env_init(); - env_relocate_spec(); + env_load(); debug("boot_os=%s\n", getenv("boot_os")); if (getenv_yesno("boot_os") == 1) ret = 0; diff --git a/board/tcl/sl50/board.c b/board/tcl/sl50/board.c index e89ee35d30..d3c953e993 100644 --- a/board/tcl/sl50/board.c +++ b/board/tcl/sl50/board.c @@ -76,7 +76,7 @@ int spl_start_uboot(void)
#ifdef CONFIG_SPL_ENV_SUPPORT env_init(); - env_relocate_spec(); + env_load(); if (getenv_yesno("boot_os") != 1) return 1; #endif diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 0a16529b5f..ac0592b725 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -249,7 +249,7 @@ int spl_start_uboot(void)
#ifdef CONFIG_SPL_ENV_SUPPORT env_init(); - env_relocate_spec(); + env_load(); if (getenv_yesno("boot_os") != 1) return 1; #endif diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index bf8c8e1a67..e4f1681860 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -737,7 +737,7 @@ int spl_start_uboot(void)
#ifdef CONFIG_SPL_ENV_SUPPORT env_init(); - env_relocate_spec(); + env_load(); if (getenv_yesno("boot_os") != 1) return 1; #endif diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 7d36f03fa1..23be2c70e4 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -825,7 +825,7 @@ int spl_start_uboot(void)
#ifdef CONFIG_SPL_ENV_SUPPORT env_init(); - env_relocate_spec(); + env_load(); if (getenv_yesno("boot_os") != 1) return 1; #endif diff --git a/env/common.c b/env/common.c index 9f1d21adbd..b63b5fc12f 100644 --- a/env/common.c +++ b/env/common.c @@ -229,7 +229,7 @@ void env_relocate(void) set_default_env("!bad CRC"); #endif } else { - env_relocate_spec(); + env_load(); } }
diff --git a/env/env.c b/env/env.c index 809889f55e..d2704f4861 100644 --- a/env/env.c +++ b/env/env.c @@ -150,11 +150,6 @@ int env_init(void) return 0; }
-void env_relocate_spec(void) -{ - env_load(); -} - int saveenv(void) { return env_save(); diff --git a/include/environment.h b/include/environment.h index a494500825..fa82f72baf 100644 --- a/include/environment.h +++ b/include/environment.h @@ -170,8 +170,6 @@ extern env_t environment; extern const unsigned char default_environment[]; extern env_t *env_ptr;
-extern void env_relocate_spec(void); - #if defined(CONFIG_NEEDS_MANUAL_RELOC) extern void env_reloc(void); #endif @@ -315,6 +313,13 @@ struct env_driver *env_driver_lookup_default(void); */ int env_get_char(int index);
+/** + * env_load() - Load the environment from storage + * + * @return 0 if OK, -ve on error + */ +int env_load(void); + #endif /* DO_DEPS_ONLY */
Use the env_save() function directly now that there is only one implementation of saveenv().
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Wolfgang Denk wd@denx.de ---
Changes in v2: None
arch/arm/mach-omap2/boot-common.c | 3 ++- board/siemens/taurus/taurus.c | 5 +++-- board/toradex/apalis_imx6/apalis_imx6.c | 3 ++- cmd/nvedit.c | 2 +- drivers/bootcount/bootcount_env.c | 3 ++- env/env.c | 6 ------ include/common.h | 1 - include/environment.h | 7 +++++++ 8 files changed, 17 insertions(+), 13 deletions(-)
diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index 700e6c2f79..2bcc8e9f97 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -10,6 +10,7 @@
#include <common.h> #include <ahci.h> +#include <environment.h> #include <spl.h> #include <asm/omap_common.h> #include <asm/arch/omap.h> @@ -241,7 +242,7 @@ int fb_set_reboot_flag(void) { printf("Setting reboot to fastboot flag ...\n"); setenv("dofastboot", "1"); - saveenv(); + env_save(); return 0; } #endif diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 4aa8d64869..3b742ebc22 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -15,6 +15,7 @@ #include <command.h> #include <common.h> #include <dm.h> +#include <environment.h> #include <asm/io.h> #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> @@ -405,7 +406,7 @@ static int upgrade_failure_fallback(void) setenv("bootargs", '\0'); setenv("upgrade_available", '\0'); setenv("boot_retries", '\0'); - saveenv(); + env_save();
return 0; } @@ -424,7 +425,7 @@ static int do_upgrade_available(cmd_tbl_t *cmdtp, int flag, int argc, boot_retry++; sprintf(boot_buf, "%lx", boot_retry); setenv("boot_retries", boot_buf); - saveenv(); + env_save();
/* * Here the boot_retries count is checked, and if the diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 8e5613cb12..e41547bbee 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -9,6 +9,7 @@
#include <common.h> #include <dm.h> +#include <environment.h> #include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> #include <asm/arch/mxc_hdmi.h> @@ -818,7 +819,7 @@ int board_late_init(void) setenv("fdt_file", FDT_FILE_V1_0); printf("patching fdt_file to " FDT_FILE_V1_0 "\n"); #ifndef CONFIG_ENV_IS_NOWHERE - saveenv(); + env_save(); #endif } } diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 75df997592..4431ef66d8 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -710,7 +710,7 @@ static int do_env_save(cmd_tbl_t *cmdtp, int flag, int argc,
- return saveenv() ? 1 : 0; + return env_save() ? 1 : 0; }
U_BOOT_CMD( diff --git a/drivers/bootcount/bootcount_env.c b/drivers/bootcount/bootcount_env.c index 2d6e8db126..7f22dd0748 100644 --- a/drivers/bootcount/bootcount_env.c +++ b/drivers/bootcount/bootcount_env.c @@ -6,6 +6,7 @@ */
void bootcount_store(ulong a) { @@ -13,7 +14,7 @@ void bootcount_store(ulong a)
if (upgrade_available) { setenv_ulong("bootcount", a); - saveenv(); + env_save(); } }
diff --git a/env/env.c b/env/env.c index d2704f4861..9d232c1f34 100644 --- a/env/env.c +++ b/env/env.c @@ -149,9 +149,3 @@ int env_init(void)
return 0; } - -int saveenv(void) -{ - return env_save(); -} - diff --git a/include/common.h b/include/common.h index 751665f8a4..f0fc02cd3b 100644 --- a/include/common.h +++ b/include/common.h @@ -335,7 +335,6 @@ ulong getenv_hex(const char *varname, ulong default_val); * Return -1 if variable does not exist (default to true) */ int getenv_yesno(const char *var); -int saveenv (void); int setenv (const char *, const char *); int setenv_ulong(const char *varname, ulong value); int setenv_hex(const char *varname, ulong value); diff --git a/include/environment.h b/include/environment.h index fa82f72baf..faf4d6adbb 100644 --- a/include/environment.h +++ b/include/environment.h @@ -320,6 +320,13 @@ int env_get_char(int index); */ int env_load(void);
+/** + * env_save() - Save the environment to storage + * + * @return 0 if OK, -ve on error + */ +int env_save(void); + #endif /* DO_DEPS_ONLY */
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h.
Suggested-by: Wolfgang Denk wd@denx.de Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Add new patch to rename setenv() and friends to env_set()
api/api.c | 4 +- arch/arm/cpu/armv7/vf610/generic.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 +- arch/arm/lib/semihosting.c | 2 +- arch/arm/mach-davinci/misc.c | 2 +- arch/arm/mach-imx/mx6/opos6ul.c | 2 +- arch/arm/mach-imx/mx7/soc.c | 4 +- arch/arm/mach-omap2/boot-common.c | 2 +- arch/arm/mach-omap2/utils.c | 12 ++-- arch/arm/mach-rockchip/rk3036-board.c | 4 +- arch/arm/mach-rockchip/rk322x-board.c | 4 +- arch/arm/mach-rockchip/rk3288-board.c | 4 +- arch/arm/mach-socfpga/misc_gen5.c | 4 +- arch/arm/mach-tegra/board2.c | 4 +- arch/arm/mach-tegra/tegra186/nvtboot_board.c | 4 +- arch/arm/mach-uniphier/board_late_init.c | 10 +-- arch/arm/mach-uniphier/mmc-first-dev.c | 2 +- arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- arch/powerpc/include/asm/fsl_secure_boot.h | 2 +- board/Arcturus/ucp1020/cmd_arc.c | 14 ++--- board/Arcturus/ucp1020/ucp1020.c | 6 +- board/BuR/brppt1/board.c | 2 +- board/BuR/brxre1/board.c | 16 ++--- board/BuR/common/common.c | 4 +- board/CZ.NIC/turris_omnia/turris_omnia.c | 8 +-- board/LaCie/net2big_v2/net2big_v2.c | 2 +- board/LaCie/netspace_v2/netspace_v2.c | 2 +- board/Synology/ds414/cmd_syno.c | 6 +- board/amazon/kc1/kc1.c | 2 +- board/amlogic/odroid-c2/odroid-c2.c | 4 +- board/aries/ma5d4evk/ma5d4evk.c | 2 +- board/aristainetos/aristainetos-v2.c | 4 +- board/armltd/integrator/integrator.c | 2 +- board/atmel/sama5d2_xplained/sama5d2_xplained.c | 2 +- board/atmel/sama5d3xek/sama5d3xek.c | 2 +- board/bachmann/ot1200/ot1200.c | 4 +- board/birdland/bav335x/board.c | 6 +- board/bosch/shc/board.c | 8 +-- board/boundary/nitrogen6x/nitrogen6x.c | 6 +- board/buffalo/lsxl/lsxl.c | 2 +- board/cadence/xtfpga/xtfpga.c | 2 +- board/ccv/xpress/xpress.c | 2 +- board/compulab/cl-som-am57x/eth.c | 2 +- board/compulab/cm_fx6/cm_fx6.c | 2 +- board/compulab/cm_t335/cm_t335.c | 2 +- board/compulab/cm_t35/cm_t35.c | 2 +- board/compulab/cm_t3517/cm_t3517.c | 2 +- board/compulab/cm_t54/cm_t54.c | 2 +- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 4 +- board/cssi/MCR3000/MCR3000.c | 2 +- board/davinci/da8xxevm/da850evm.c | 2 +- board/davinci/da8xxevm/omapl138_lcdk.c | 2 +- board/el/el6x/el6x.c | 2 +- board/engicam/common/board.c | 16 ++--- board/engicam/common/board.h | 2 +- board/engicam/geam6ul/geam6ul.c | 4 +- board/engicam/icorem6/icorem6.c | 6 +- board/engicam/icorem6_rqs/icorem6_rqs.c | 6 +- board/engicam/isiotmx6ul/isiotmx6ul.c | 6 +- board/freescale/common/cmd_esbc_validate.c | 2 +- board/freescale/common/fsl_chain_of_trust.c | 6 +- board/freescale/common/sys_eeprom.c | 2 +- board/freescale/ls1021aqds/ls1021aqds.c | 2 +- board/freescale/ls1021atwr/ls1021atwr.c | 2 +- board/freescale/mpc8323erdb/mpc8323erdb.c | 2 +- board/freescale/mx53loco/mx53loco.c | 4 +- board/freescale/mx6sabreauto/mx6sabreauto.c | 8 +-- board/freescale/mx6sabresd/mx6sabresd.c | 8 +-- board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 6 +- board/freescale/mx6ullevk/mx6ullevk.c | 4 +- board/freescale/qemu-ppce500/qemu-ppce500.c | 4 +- board/gateworks/gw_ventana/gw_ventana.c | 30 ++++----- board/grinn/chiliboard/board.c | 4 +- board/grinn/liteboard/board.c | 4 +- board/gumstix/pepper/board.c | 2 +- board/highbank/highbank.c | 4 +- board/htkw/mcx/mcx.c | 2 +- board/isee/igep003x/board.c | 8 +-- board/isee/igep00x0/igep00x0.c | 4 +- board/keymile/common/common.c | 16 ++--- board/keymile/common/ivm.c | 4 +- board/keymile/km83xx/km83xx.c | 8 +-- board/keymile/km_arm/km_arm.c | 4 +- board/keymile/kmp204x/kmp204x.c | 2 +- board/kosagi/novena/novena.c | 2 +- board/lg/sniper/sniper.c | 2 +- board/liebherr/mccmon6/mccmon6.c | 2 +- board/logicpd/imx6/imx6logic.c | 6 +- board/logicpd/omap3som/omap3logic.c | 2 +- board/logicpd/zoom1/zoom1.c | 2 +- board/nokia/rx51/rx51.c | 2 +- board/overo/overo.c | 44 ++++++------- board/phytec/pcm051/board.c | 2 +- board/qualcomm/dragonboard410c/dragonboard410c.c | 2 +- board/raspberrypi/rpi/rpi.c | 18 +++--- board/renesas/blanche/blanche.c | 2 +- board/renesas/ecovec/ecovec.c | 2 +- board/renesas/sh7752evb/sh7752evb.c | 4 +- board/renesas/sh7753evb/sh7753evb.c | 4 +- board/renesas/sh7757lcr/sh7757lcr.c | 6 +- board/rockchip/kylin_rk3036/kylin_rk3036.c | 2 +- board/rockchip/tinker_rk3288/tinker-rk3288.c | 2 +- board/samsung/common/misc.c | 14 ++--- board/samsung/trats/trats.c | 2 +- board/samsung/universal_c210/universal.c | 2 +- board/samtec/vining_2000/vining_2000.c | 8 +-- board/samtec/vining_fpga/socfpga.c | 12 ++-- board/siemens/common/factoryset.c | 8 +-- board/siemens/common/factoryset.h | 2 +- board/siemens/draco/board.c | 8 +-- board/siemens/pxm2/board.c | 6 +- board/siemens/rut/board.c | 4 +- board/siemens/taurus/taurus.c | 24 ++++---- board/silica/pengwyn/board.c | 2 +- board/solidrun/mx6cuboxi/mx6cuboxi.c | 8 +-- board/spear/common/spr_misc.c | 10 +-- board/st/stm32f429-discovery/stm32f429-discovery.c | 2 +- board/sunxi/board.c | 12 ++-- board/syteco/zmx25/zmx25.c | 4 +- board/tcl/sl50/board.c | 6 +- board/technologic/ts4800/ts4800.c | 2 +- board/theobroma-systems/puma_rk3399/puma-rk3399.c | 6 +- board/ti/am335x/board.c | 8 +-- board/ti/am43xx/board.c | 6 +- board/ti/am57xx/board.c | 14 ++--- board/ti/beagle/beagle.c | 38 ++++++------ board/ti/common/board_detect.c | 18 +++--- board/ti/dra7xx/evm.c | 6 +- board/ti/evm/evm.c | 2 +- board/ti/ks2_evm/board_k2g.c | 4 +- board/ti/panda/panda.c | 4 +- board/ti/ti814x/evm.c | 2 +- board/ti/ti816x/evm.c | 2 +- board/timll/devkit8000/devkit8000.c | 2 +- board/toradex/apalis_imx6/apalis_imx6.c | 4 +- board/toradex/colibri_imx6/colibri_imx6.c | 2 +- board/toradex/colibri_vf/colibri_vf.c | 2 +- board/toradex/common/tdx-common.c | 6 +- board/tqc/tqma6/tqma6.c | 2 +- board/udoo/neo/neo.c | 2 +- board/udoo/udoo.c | 4 +- board/varisys/common/sys_eeprom.c | 4 +- board/vscom/baltos/board.c | 6 +- board/wandboard/wandboard.c | 8 +-- board/xilinx/zynq/board.c | 12 ++-- board/xilinx/zynqmp/zynqmp.c | 2 +- cmd/cbfs.c | 2 +- cmd/cramfs.c | 2 +- cmd/fdt.c | 29 +++++---- cmd/gpt.c | 2 +- cmd/ini.c | 2 +- cmd/jffs2.c | 2 +- cmd/load.c | 6 +- cmd/lzmadec.c | 2 +- cmd/md5sum.c | 2 +- cmd/mtdparts.c | 28 ++++----- cmd/nand.c | 6 +- cmd/net.c | 34 +++++----- cmd/nvedit.c | 14 ++--- cmd/part.c | 8 +-- cmd/pxe.c | 6 +- cmd/qfw.c | 2 +- cmd/reiser.c | 2 +- cmd/setexpr.c | 8 +-- cmd/tpm.c | 4 +- cmd/trace.c | 12 ++-- cmd/unzip.c | 2 +- cmd/ximg.c | 4 +- cmd/zfs.c | 2 +- cmd/zip.c | 2 +- common/autoboot.c | 6 +- common/board_r.c | 4 +- common/bootm.c | 6 +- common/bootm_os.c | 2 +- common/cli_hush.c | 2 +- common/console.c | 4 +- common/hash.c | 2 +- common/hwconfig.c | 4 +- common/image-android.c | 2 +- common/main.c | 2 +- common/spl/Kconfig | 2 +- common/spl/spl_dfu.c | 2 +- common/spl/spl_net.c | 4 +- common/update.c | 4 +- doc/README.enetaddr | 6 +- drivers/bootcount/bootcount_env.c | 2 +- drivers/mtd/dataflash.c | 5 +- drivers/net/fec_mxc.c | 2 +- drivers/net/fm/fm.c | 2 +- drivers/net/lan91c96.c | 2 +- drivers/net/ne2000_base.c | 2 +- drivers/net/sandbox-raw.c | 4 +- drivers/scsi/scsi.c | 2 +- drivers/usb/gadget/ether.c | 2 +- fs/fs.c | 10 +-- fs/ubifs/ubifs.c | 2 +- include/_exports.h | 2 +- include/common.h | 39 ++++++++++-- include/configs/tam3517-common.h | 2 +- include/exports.h | 2 +- include/fsl_validate.h | 2 +- include/net.h | 6 +- include/search.h | 2 +- lib/uuid.c | 2 +- net/arp.c | 2 +- net/bootp.c | 2 +- net/dns.c | 2 +- net/eth-uclass.c | 2 +- net/eth_common.c | 12 ++-- net/eth_internal.h | 4 +- net/eth_legacy.c | 4 +- net/net.c | 4 +- test/dm/eth.c | 72 +++++++++++----------- tools/env/fw_env_main.c | 4 +- 214 files changed, 630 insertions(+), 599 deletions(-)
diff --git a/api/api.c b/api/api.c index c368511704..2e620e2a0f 100644 --- a/api/api.c +++ b/api/api.c @@ -481,7 +481,7 @@ static int API_env_set(va_list ap) if ((value = (char *)va_arg(ap, uintptr_t)) == NULL) return API_EINVAL;
- setenv(name, value); + env_set(name, value);
return 0; } @@ -663,7 +663,7 @@ void api_init(void) return; }
- setenv_hex("api_address", (unsigned long)sig); + env_set_hex("api_address", (unsigned long)sig); debugf("API sig @ 0x%lX\n", (unsigned long)sig); memcpy(sig->magic, API_SIG_MAGIC, 8); sig->version = API_SIG_VERSION; diff --git a/arch/arm/cpu/armv7/vf610/generic.c b/arch/arm/cpu/armv7/vf610/generic.c index ac2d8d1a3f..88f3f4dd16 100644 --- a/arch/arm/cpu/armv7/vf610/generic.c +++ b/arch/arm/cpu/armv7/vf610/generic.c @@ -329,7 +329,7 @@ int arch_misc_init(void)
strcpy(soc, "vf"); strcat(soc, soc_type); - setenv("soc", soc); + env_set("soc", soc);
return 0; } diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index aee1ffa7d4..23f3809418 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -522,7 +522,7 @@ int board_late_init(void) sata_init(); #endif #ifdef CONFIG_CHAIN_OF_TRUST - fsl_setenv_chain_of_trust(); + fsl_env_set_chain_of_trust(); #endif #ifdef CONFIG_QSPI_AHB_INIT qspi_ahb_init(); diff --git a/arch/arm/lib/semihosting.c b/arch/arm/lib/semihosting.c index 415ac89de9..bcd16ee591 100644 --- a/arch/arm/lib/semihosting.c +++ b/arch/arm/lib/semihosting.c @@ -200,7 +200,7 @@ static int do_smhload(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* Optionally save returned end to the environment */ if (argc == 4) { sprintf(end_str, "0x%08lx", end_addr); - setenv(argv[3], end_str); + env_set(argv[3], end_str); } } else { return CMD_RET_USAGE; diff --git a/arch/arm/mach-davinci/misc.c b/arch/arm/mach-davinci/misc.c index ec331ba6bb..4441242cc7 100644 --- a/arch/arm/mach-davinci/misc.c +++ b/arch/arm/mach-davinci/misc.c @@ -99,7 +99,7 @@ void davinci_sync_env_enetaddr(uint8_t *rom_enetaddr) debug("### Setting environment from EEPROM MAC address = " ""%pM"\n", env_enetaddr); - ret = !eth_setenv_enetaddr("ethaddr", rom_enetaddr); + ret = !eth_env_set_enetaddr("ethaddr", rom_enetaddr); } if (!ret) printf("Failed to set mac address from EEPROM: %d\n", ret); diff --git a/arch/arm/mach-imx/mx6/opos6ul.c b/arch/arm/mach-imx/mx6/opos6ul.c index 22b244079b..f8d7e8ee68 100644 --- a/arch/arm/mach-imx/mx6/opos6ul.c +++ b/arch/arm/mach-imx/mx6/opos6ul.c @@ -132,7 +132,7 @@ int board_late_init(void) /* In bootstrap don't use the env vars */ if (((reg & 0x3000000) >> 24) == 0x1) { set_default_env(NULL); - setenv("preboot", ""); + env_set("preboot", ""); }
return opos6ul_board_late_init(); diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index 4cf977e20a..7152c847d0 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -256,9 +256,9 @@ int arch_misc_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (is_mx7d()) - setenv("soc", "imx7d"); + env_set("soc", "imx7d"); else - setenv("soc", "imx7s"); + env_set("soc", "imx7s"); #endif
return 0; diff --git a/arch/arm/mach-omap2/boot-common.c b/arch/arm/mach-omap2/boot-common.c index 2bcc8e9f97..26245aa169 100644 --- a/arch/arm/mach-omap2/boot-common.c +++ b/arch/arm/mach-omap2/boot-common.c @@ -241,7 +241,7 @@ void arch_preboot_os(void) int fb_set_reboot_flag(void) { printf("Setting reboot to fastboot flag ...\n"); - setenv("dofastboot", "1"); + env_set("dofastboot", "1"); env_save(); return 0; } diff --git a/arch/arm/mach-omap2/utils.c b/arch/arm/mach-omap2/utils.c index 1946641eb9..c03e93878d 100644 --- a/arch/arm/mach-omap2/utils.c +++ b/arch/arm/mach-omap2/utils.c @@ -40,7 +40,7 @@ static void omap_set_fastboot_cpu(void) printf("Warning: fastboot.cpu: unknown CPU rev: %u\n", cpu_rev); }
- setenv("fastboot.cpu", cpu); + env_set("fastboot.cpu", cpu); }
static void omap_set_fastboot_secure(void) @@ -63,7 +63,7 @@ static void omap_set_fastboot_secure(void) printf("Warning: fastboot.secure: unknown CPU sec: %u\n", dev); }
- setenv("fastboot.secure", secure); + env_set("fastboot.secure", secure); }
static void omap_set_fastboot_board_rev(void) @@ -74,7 +74,7 @@ static void omap_set_fastboot_board_rev(void) if (board_rev == NULL) printf("Warning: fastboot.board_rev: unknown board revision\n");
- setenv("fastboot.board_rev", board_rev); + env_set("fastboot.board_rev", board_rev); }
#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV @@ -118,7 +118,7 @@ static void omap_set_fastboot_userdata_size(void) sprintf(buf, "%u", sz_kb); }
- setenv("fastboot.userdata_size", buf); + env_set("fastboot.userdata_size", buf); } #else static inline void omap_set_fastboot_userdata_size(void) @@ -173,7 +173,7 @@ void omap_die_id_serial(void) snprintf(serial_string, sizeof(serial_string), "%08x%08x", die_id[0], die_id[3]);
- setenv("serial#", serial_string); + env_set("serial#", serial_string); } }
@@ -214,7 +214,7 @@ void omap_die_id_usbethaddr(void) mac[4] = die_id[0] & 0xff; mac[5] = (die_id[0] >> 8) & 0xff;
- eth_setenv_enetaddr("usbethaddr", mac); + eth_env_set_enetaddr("usbethaddr", mac); } }
diff --git a/arch/arm/mach-rockchip/rk3036-board.c b/arch/arm/mach-rockchip/rk3036-board.c index 26ea23b014..a3457f3914 100644 --- a/arch/arm/mach-rockchip/rk3036-board.c +++ b/arch/arm/mach-rockchip/rk3036-board.c @@ -34,11 +34,11 @@ static void setup_boot_mode(void) switch (boot_mode) { case BOOT_FASTBOOT: printf("enter fastboot!\n"); - setenv("preboot", "setenv preboot; fastboot usb0"); + env_set("preboot", "setenv preboot; fastboot usb0"); break; case BOOT_UMS: printf("enter UMS!\n"); - setenv("preboot", "setenv preboot; ums mmc 0"); + env_set("preboot", "setenv preboot; ums mmc 0"); break; } } diff --git a/arch/arm/mach-rockchip/rk322x-board.c b/arch/arm/mach-rockchip/rk322x-board.c index b6543a5108..1e79c19309 100644 --- a/arch/arm/mach-rockchip/rk322x-board.c +++ b/arch/arm/mach-rockchip/rk322x-board.c @@ -30,11 +30,11 @@ static void setup_boot_mode(void) switch (boot_mode) { case BOOT_FASTBOOT: printf("enter fastboot!\n"); - setenv("preboot", "setenv preboot; fastboot usb0"); + env_set("preboot", "setenv preboot; fastboot usb0"); break; case BOOT_UMS: printf("enter UMS!\n"); - setenv("preboot", "setenv preboot; ums mmc 0"); + env_set("preboot", "setenv preboot; ums mmc 0"); break; } } diff --git a/arch/arm/mach-rockchip/rk3288-board.c b/arch/arm/mach-rockchip/rk3288-board.c index 613967c307..4a3f9e8df3 100644 --- a/arch/arm/mach-rockchip/rk3288-board.c +++ b/arch/arm/mach-rockchip/rk3288-board.c @@ -37,11 +37,11 @@ static void setup_boot_mode(void) switch (boot_mode) { case BOOT_FASTBOOT: printf("enter fastboot!\n"); - setenv("preboot", "setenv preboot; fastboot usb0"); + env_set("preboot", "setenv preboot; fastboot usb0"); break; case BOOT_UMS: printf("enter UMS!\n"); - setenv("preboot", "setenv preboot; if mmc dev 0;" + env_set("preboot", "setenv preboot; if mmc dev 0;" "then ums mmc 0; else ums mmc 1;fi"); break; } diff --git a/arch/arm/mach-socfpga/misc_gen5.c b/arch/arm/mach-socfpga/misc_gen5.c index 49b26b3570..2f1da740fb 100644 --- a/arch/arm/mach-socfpga/misc_gen5.c +++ b/arch/arm/mach-socfpga/misc_gen5.c @@ -219,9 +219,9 @@ int arch_misc_init(void) { const u32 bsel = readl(&sysmgr_regs->bootinfo) & 0x7; const int fpga_id = socfpga_fpga_id(0); - setenv("bootmode", bsel_str[bsel].mode); + env_set("bootmode", bsel_str[bsel].mode); if (fpga_id >= 0) - setenv("fpgatype", socfpga_fpga_model[fpga_id].var); + env_set("fpgatype", socfpga_fpga_model[fpga_id].var); return socfpga_eth_reset(); } #endif diff --git a/arch/arm/mach-tegra/board2.c b/arch/arm/mach-tegra/board2.c index 6b5fa7df62..621d0eea1f 100644 --- a/arch/arm/mach-tegra/board2.c +++ b/arch/arm/mach-tegra/board2.c @@ -220,9 +220,9 @@ int board_late_init(void) #if defined(CONFIG_TEGRA_SUPPORT_NON_SECURE) if (tegra_cpu_is_non_secure()) { printf("CPU is in NS mode\n"); - setenv("cpu_ns_mode", "1"); + env_set("cpu_ns_mode", "1"); } else { - setenv("cpu_ns_mode", ""); + env_set("cpu_ns_mode", ""); } #endif start_cpu_fan(); diff --git a/arch/arm/mach-tegra/tegra186/nvtboot_board.c b/arch/arm/mach-tegra/tegra186/nvtboot_board.c index feb935f0d9..9cd3fe2f30 100644 --- a/arch/arm/mach-tegra/tegra186/nvtboot_board.c +++ b/arch/arm/mach-tegra/tegra186/nvtboot_board.c @@ -15,7 +15,7 @@ static int set_fdt_addr(void) { int ret;
- ret = setenv_hex("fdt_addr", nvtboot_boot_x0); + ret = env_set_hex("fdt_addr", nvtboot_boot_x0); if (ret) { printf("Failed to set fdt_addr to point at DTB: %d\n", ret); return ret; @@ -49,7 +49,7 @@ static int set_ethaddr_from_nvtboot(void) return -ENOENT; }
- ret = setenv("ethaddr", (void *)prop); + ret = env_set("ethaddr", (void *)prop); if (ret) { printf("Failed to set ethaddr from nvtboot DTB: %d\n", ret); return ret; diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index 4bfa10b374..e6d600e41f 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -55,7 +55,7 @@ static int uniphier_set_fdt_file(void)
strncat(dtb_name, ".dtb", buf_len);
- return setenv("fdt_file", dtb_name); + return env_set("fdt_file", dtb_name); }
int board_late_init(void) @@ -65,20 +65,20 @@ int board_late_init(void) switch (uniphier_boot_device_raw()) { case BOOT_DEVICE_MMC1: printf("eMMC Boot"); - setenv("bootmode", "emmcboot"); + env_set("bootmode", "emmcboot"); break; case BOOT_DEVICE_NAND: printf("NAND Boot"); - setenv("bootmode", "nandboot"); + env_set("bootmode", "nandboot"); nand_denali_wp_disable(); break; case BOOT_DEVICE_NOR: printf("NOR Boot"); - setenv("bootmode", "norboot"); + env_set("bootmode", "norboot"); break; case BOOT_DEVICE_USB: printf("USB Boot"); - setenv("bootmode", "usbboot"); + env_set("bootmode", "usbboot"); break; default: printf("Unknown"); diff --git a/arch/arm/mach-uniphier/mmc-first-dev.c b/arch/arm/mach-uniphier/mmc-first-dev.c index 8c45229a89..acc859a6c3 100644 --- a/arch/arm/mach-uniphier/mmc-first-dev.c +++ b/arch/arm/mach-uniphier/mmc-first-dev.c @@ -35,7 +35,7 @@ static int do_mmcsetn(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (dev < 0) return CMD_RET_FAILURE;
- setenv_ulong("mmc_first_dev", dev); + env_set_ulong("mmc_first_dev", dev); return CMD_RET_SUCCESS; }
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index a3076d8d71..52a33ec53f 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -1052,7 +1052,7 @@ void cpu_secondary_init_r(void) int board_late_init(void) { #ifdef CONFIG_CHAIN_OF_TRUST - fsl_setenv_chain_of_trust(); + fsl_env_set_chain_of_trust(); #endif
return 0; diff --git a/arch/powerpc/include/asm/fsl_secure_boot.h b/arch/powerpc/include/asm/fsl_secure_boot.h index 76921eea9a..13eee1bfcf 100644 --- a/arch/powerpc/include/asm/fsl_secure_boot.h +++ b/arch/powerpc/include/asm/fsl_secure_boot.h @@ -103,7 +103,7 @@
#ifndef CONFIG_SPL_BUILD /* - * fsl_setenv_chain_of_trust() must be called from + * fsl_env_set_chain_of_trust() must be called from * board_late_init() */
diff --git a/board/Arcturus/ucp1020/cmd_arc.c b/board/Arcturus/ucp1020/cmd_arc.c index fa6b4853f9..c32f7df454 100644 --- a/board/Arcturus/ucp1020/cmd_arc.c +++ b/board/Arcturus/ucp1020/cmd_arc.c @@ -138,7 +138,7 @@ int get_arc_info(void) printf("\t<not found>\n"); } else { printf("\t%s\n", smac[3]); - setenv("SERIAL", smac[3]); + env_set("SERIAL", smac[3]); } }
@@ -152,7 +152,7 @@ int get_arc_info(void) char *ret = getenv("ethaddr");
if (strcmp(ret, __stringify(CONFIG_ETHADDR)) == 0) { - setenv("ethaddr", smac[2]); + env_set("ethaddr", smac[2]); printf("\t%s (factory)\n", smac[2]); } else { printf("\t%s\n", ret); @@ -160,8 +160,8 @@ int get_arc_info(void) }
if (strcmp(smac[1], "00:00:00:00:00:00") == 0) { - setenv("eth1addr", smac[2]); - setenv("eth2addr", smac[2]); + env_set("eth1addr", smac[2]); + env_set("eth2addr", smac[2]); return 0; }
@@ -172,7 +172,7 @@ int get_arc_info(void) char *ret = getenv("eth1addr");
if (strcmp(ret, __stringify(CONFIG_ETH1ADDR)) == 0) { - setenv("eth1addr", smac[1]); + env_set("eth1addr", smac[1]); printf("\t%s (factory)\n", smac[1]); } else { printf("\t%s\n", ret); @@ -180,7 +180,7 @@ int get_arc_info(void) }
if (strcmp(smac[0], "00:00:00:00:00:00") == 0) { - setenv("eth2addr", smac[1]); + env_set("eth2addr", smac[1]); return 0; }
@@ -191,7 +191,7 @@ int get_arc_info(void) char *ret = getenv("eth2addr");
if (strcmp(ret, __stringify(CONFIG_ETH2ADDR)) == 0) { - setenv("eth2addr", smac[0]); + env_set("eth2addr", smac[0]); printf("\t%s (factory)\n", smac[0]); } else { printf("\t%s\n", ret); diff --git a/board/Arcturus/ucp1020/ucp1020.c b/board/Arcturus/ucp1020/ucp1020.c index 0d086e87fa..2cc2e54d5b 100644 --- a/board/Arcturus/ucp1020/ucp1020.c +++ b/board/Arcturus/ucp1020/ucp1020.c @@ -230,9 +230,9 @@ int last_stage_init(void) strcat(newkernelargs, mmckargs); strcat(newkernelargs, " "); strcat(newkernelargs, &tmp[n]); - setenv("kernelargs", newkernelargs); + env_set("kernelargs", newkernelargs); } else { - setenv("kernelargs", mmckargs); + env_set("kernelargs", mmckargs); } } get_arc_info(); @@ -244,7 +244,7 @@ int last_stage_init(void) strcat(newkernelargs, sval); strcat(newkernelargs, " "); strcat(newkernelargs, kval); - setenv("kernelargs", newkernelargs); + env_set("kernelargs", newkernelargs); } } else { printf("Error reading kernelargs env variable!\n"); diff --git a/board/BuR/brppt1/board.c b/board/BuR/brppt1/board.c index a22722122b..6083479f2b 100644 --- a/board/BuR/brppt1/board.c +++ b/board/BuR/brppt1/board.c @@ -167,7 +167,7 @@ int board_late_init(void) lcd_position_cursor(1, 8); lcd_puts( "switching to network-console ... "); - setenv("bootcmd", "run netconsole"); + env_set("bootcmd", "run netconsole"); } return 0; } diff --git a/board/BuR/brxre1/board.c b/board/BuR/brxre1/board.c index f4bfa410cc..cdbc93a8ec 100644 --- a/board/BuR/brxre1/board.c +++ b/board/BuR/brxre1/board.c @@ -203,7 +203,7 @@ int board_late_init(void) lcd_position_cursor(1, 8); lcd_puts( "switching to network-console ... "); - setenv("bootcmd", "run netconsole"); + env_set("bootcmd", "run netconsole"); cnt = 4; break; } else if (!gpio_get_value(ESC_KEY) && @@ -211,7 +211,7 @@ int board_late_init(void) lcd_position_cursor(1, 8); lcd_puts( "starting u-boot script from USB ... "); - setenv("bootcmd", "run usbscript"); + env_set("bootcmd", "run usbscript"); cnt = 4; break; } else if ((!gpio_get_value(ESC_KEY) && @@ -221,7 +221,7 @@ int board_late_init(void) lcd_position_cursor(1, 8); lcd_puts( "starting script from network ... "); - setenv("bootcmd", "run netscript"); + env_set("bootcmd", "run netscript"); cnt = 4; break; } else if (!gpio_get_value(ESC_KEY)) { @@ -232,19 +232,19 @@ int board_late_init(void) lcd_position_cursor(1, 8); lcd_puts( "starting vxworks from network ... "); - setenv("bootcmd", "run netboot"); + env_set("bootcmd", "run netboot"); cnt = 4; } else if (scratchreg == 0xCD) { lcd_position_cursor(1, 8); lcd_puts( "starting script from network ... "); - setenv("bootcmd", "run netscript"); + env_set("bootcmd", "run netscript"); cnt = 4; } else if (scratchreg == 0xCE) { lcd_position_cursor(1, 8); lcd_puts( "starting AR from eMMC ... "); - setenv("bootcmd", "run mmcboot"); + env_set("bootcmd", "run mmcboot"); cnt = 4; }
@@ -252,7 +252,7 @@ int board_late_init(void) switch (cnt) { case 0: lcd_puts("entering BOOT-mode. "); - setenv("bootcmd", "run defaultAR"); + env_set("bootcmd", "run defaultAR"); buf = 0x0000; break; case 1: @@ -285,7 +285,7 @@ int board_late_init(void) (u32)getenv_ulong("vx_memtop", 16, gd->fb_base-0x20), (u32)getenv_ulong("vx_romfsbase", 16, 0), (u32)getenv_ulong("vx_romfssize", 16, 0)); - setenv("othbootargs", othbootargs); + env_set("othbootargs", othbootargs); /* * reset VBAR registers to its reset location, VxWorks 6.9.3.2 does * expect that vectors are there, original u-boot moves them to _start diff --git a/board/BuR/common/common.c b/board/BuR/common/common.c index c3a56db76a..eb34de931e 100644 --- a/board/BuR/common/common.c +++ b/board/BuR/common/common.c @@ -184,7 +184,7 @@ int load_lcdtiming(struct am335x_lcdpanel *panel) puts("no 'factory-settings / rotation' in dtb!\n"); } snprintf(buf, sizeof(buf), "fbcon=rotate:%d", panel_info.vl_rot); - setenv("optargs_rot", buf); + env_set("optargs_rot", buf); #else pnltmp.hactive = getenv_ulong("ds1_hactive", 10, ~0UL); pnltmp.vactive = getenv_ulong("ds1_vactive", 10, ~0UL); @@ -670,7 +670,7 @@ int board_eth_init(bd_t *bis)
if (mac) { printf("using: %pM on ", mac); - eth_setenv_enetaddr("ethaddr", (const u8 *)mac); + eth_env_set_enetaddr("ethaddr", (const u8 *)mac); } } writel(MII_MODE_ENABLE, &cdev->miisel); diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index 86926f8050..a4d1725b13 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -280,7 +280,7 @@ static int set_regdomain(void) puts("EEPROM regdomain read failed.\n");
printf("Regdomain set to %s\n", rd); - return setenv("regdomain", rd); + return env_set("regdomain", rd); } #endif
@@ -510,17 +510,17 @@ int misc_init_r(void) mac[5] = mac1[3];
if (is_valid_ethaddr(mac)) - eth_setenv_enetaddr("ethaddr", mac); + eth_env_set_enetaddr("ethaddr", mac);
increment_mac(mac);
if (is_valid_ethaddr(mac)) - eth_setenv_enetaddr("eth1addr", mac); + eth_env_set_enetaddr("eth1addr", mac);
increment_mac(mac);
if (is_valid_ethaddr(mac)) - eth_setenv_enetaddr("eth2addr", mac); + eth_env_set_enetaddr("eth2addr", mac);
out: #endif diff --git a/board/LaCie/net2big_v2/net2big_v2.c b/board/LaCie/net2big_v2/net2big_v2.c index 2e6e9ef916..416af469fa 100644 --- a/board/LaCie/net2big_v2/net2big_v2.c +++ b/board/LaCie/net2big_v2/net2big_v2.c @@ -224,7 +224,7 @@ int misc_init_r(void) if (!getenv("ethaddr")) { uchar mac[6]; if (lacie_read_mac_address(mac) == 0) - eth_setenv_enetaddr("ethaddr", mac); + eth_env_set_enetaddr("ethaddr", mac); } #endif init_leds(); diff --git a/board/LaCie/netspace_v2/netspace_v2.c b/board/LaCie/netspace_v2/netspace_v2.c index 16d694716f..fa07288d6e 100644 --- a/board/LaCie/netspace_v2/netspace_v2.c +++ b/board/LaCie/netspace_v2/netspace_v2.c @@ -86,7 +86,7 @@ int misc_init_r(void) if (!getenv("ethaddr")) { uchar mac[6]; if (lacie_read_mac_address(mac) == 0) - eth_setenv_enetaddr("ethaddr", mac); + eth_env_set_enetaddr("ethaddr", mac); } #endif return 0; diff --git a/board/Synology/ds414/cmd_syno.c b/board/Synology/ds414/cmd_syno.c index 20544e29c4..6313882a52 100644 --- a/board/Synology/ds414/cmd_syno.c +++ b/board/Synology/ds414/cmd_syno.c @@ -81,7 +81,7 @@ static int do_syno_populate(int argc, char * const argv[]) ethaddr[0], ethaddr[1], ethaddr[2], ethaddr[3], ethaddr[4], ethaddr[5]); printf("parsed %s = %s\n", var, val); - setenv(var, val); + env_set(var, val); } if (!strncmp(buf + 32, SYNO_SN_TAG, strlen(SYNO_SN_TAG))) { char *snp, *csump; @@ -111,7 +111,7 @@ static int do_syno_populate(int argc, char * const argv[]) goto out_unmap; } printf("parsed SN = %s\n", snp); - setenv("SN", snp); + env_set("SN", snp); } else { /* old style format */ unsigned char csum = 0;
@@ -125,7 +125,7 @@ static int do_syno_populate(int argc, char * const argv[]) } bufp[n] = '\0'; printf("parsed SN = %s\n", buf + 32); - setenv("SN", buf + 32); + env_set("SN", buf + 32); } out_unmap: unmap_physmem(buf, len); diff --git a/board/amazon/kc1/kc1.c b/board/amazon/kc1/kc1.c index 13a9c6a0fe..2d8be1804a 100644 --- a/board/amazon/kc1/kc1.c +++ b/board/amazon/kc1/kc1.c @@ -119,7 +119,7 @@ int misc_init_r(void)
if (reboot_mode[0] > 0 && isascii(reboot_mode[0])) { if (!getenv("reboot-mode")) - setenv("reboot-mode", (char *)reboot_mode); + env_set("reboot-mode", (char *)reboot_mode); }
omap_reboot_mode_clear(); diff --git a/board/amlogic/odroid-c2/odroid-c2.c b/board/amlogic/odroid-c2/odroid-c2.c index b29f56d5eb..ca9c13bcc1 100644 --- a/board/amlogic/odroid-c2/odroid-c2.c +++ b/board/amlogic/odroid-c2/odroid-c2.c @@ -48,14 +48,14 @@ int misc_init_r(void) len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, mac_addr, EFUSE_MAC_SIZE); if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); }
if (!getenv("serial#")) { len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial, EFUSE_SN_SIZE); if (len == EFUSE_SN_SIZE) - setenv("serial#", serial); + env_set("serial#", serial); }
return 0; diff --git a/board/aries/ma5d4evk/ma5d4evk.c b/board/aries/ma5d4evk/ma5d4evk.c index b9294fc881..956c297e72 100644 --- a/board/aries/ma5d4evk/ma5d4evk.c +++ b/board/aries/ma5d4evk/ma5d4evk.c @@ -325,7 +325,7 @@ int board_init(void)
int board_late_init(void) { - setenv("bootmode", boot_mode_sf ? "sf" : "emmc"); + env_set("bootmode", boot_mode_sf ? "sf" : "emmc"); return 0; }
diff --git a/board/aristainetos/aristainetos-v2.c b/board/aristainetos/aristainetos-v2.c index 6abc2159bb..bdf41b99c8 100644 --- a/board/aristainetos/aristainetos-v2.c +++ b/board/aristainetos/aristainetos-v2.c @@ -670,9 +670,9 @@ int board_late_init(void) if (bootmode == 7) { my_bootdelay = getenv("nor_bootdelay"); if (my_bootdelay != NULL) - setenv("bootdelay", my_bootdelay); + env_set("bootdelay", my_bootdelay); else - setenv("bootdelay", "-2"); + env_set("bootdelay", "-2"); }
/* if we have the lg panel, we can initialze it now */ diff --git a/board/armltd/integrator/integrator.c b/board/armltd/integrator/integrator.c index c3bafd453e..858f74e5cf 100644 --- a/board/armltd/integrator/integrator.c +++ b/board/armltd/integrator/integrator.c @@ -116,7 +116,7 @@ extern void cm_remap(void);
int misc_init_r (void) { - setenv("verify", "n"); + env_set("verify", "n"); return (0); }
diff --git a/board/atmel/sama5d2_xplained/sama5d2_xplained.c b/board/atmel/sama5d2_xplained/sama5d2_xplained.c index 48f45b35ce..4a06cda6f4 100644 --- a/board/atmel/sama5d2_xplained/sama5d2_xplained.c +++ b/board/atmel/sama5d2_xplained/sama5d2_xplained.c @@ -192,7 +192,7 @@ static int set_ethaddr_from_eeprom(void) return -1; }
- return eth_setenv_enetaddr(ETHADDR_NAME, ethaddr); + return eth_env_set_enetaddr(ETHADDR_NAME, ethaddr); } #else static int set_ethaddr_from_eeprom(void) diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index c1f2769f1c..88bcd876c9 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -267,7 +267,7 @@ int board_late_init(void) *p = tolower(*p);
strcat(name, "ek.dtb"); - setenv("dtb_name", name); + env_set("dtb_name", name); #endif return 0; } diff --git a/board/bachmann/ot1200/ot1200.c b/board/bachmann/ot1200/ot1200.c index 1ad4ef93cf..df10d6a0d0 100644 --- a/board/bachmann/ot1200/ot1200.c +++ b/board/bachmann/ot1200/ot1200.c @@ -312,9 +312,9 @@ int board_eth_init(bd_t *bis)
/* depending on the phy address we can detect our board version */ if (phydev->addr == 0) - setenv("boardver", ""); + env_set("boardver", ""); else - setenv("boardver", "mr"); + env_set("boardver", "mr");
printf("using phy at %d\n", phydev->addr); ret = fec_probe(bis, -1, base, bus, phydev); diff --git a/board/birdland/bav335x/board.c b/board/birdland/bav335x/board.c index b49365e157..a9d9ce6fa5 100644 --- a/board/birdland/bav335x/board.c +++ b/board/birdland/bav335x/board.c @@ -301,8 +301,8 @@ int board_init(void) int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - setenv("board_name", "BAV335xB"); - setenv("board_rev", "B"); /* Fix me, but why bother.. */ + env_set("board_name", "BAV335xB"); + env_set("board_rev", "B"); /* Fix me, but why bother.. */ #endif return 0; } @@ -396,7 +396,7 @@ int board_eth_init(bd_t *bis) printf("<ethaddr> not set. Validating first E-fuse MAC\n");
if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); }
#ifdef CONFIG_DRIVER_TI_CPSW diff --git a/board/bosch/shc/board.c b/board/bosch/shc/board.c index 38577f30f1..b4c6a0b45d 100644 --- a/board/bosch/shc/board.c +++ b/board/bosch/shc/board.c @@ -251,7 +251,7 @@ static void check_button_status(void)
if (value == 0) { printf("front button activated !\n"); - setenv("harakiri", "1"); + env_set("harakiri", "1"); } }
@@ -460,7 +460,7 @@ int board_late_init(void) #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (shc_eeprom_valid) if (is_valid_ethaddr(header.mac_addr)) - eth_setenv_enetaddr("ethaddr", header.mac_addr); + eth_env_set_enetaddr("ethaddr", header.mac_addr); #endif
return 0; @@ -549,7 +549,7 @@ int board_eth_init(bd_t *bis) printf("<ethaddr> not set. Validating first E-fuse MAC\n");
writel(MII_MODE_ENABLE, &cdev->miisel); @@ -565,7 +565,7 @@ int board_eth_init(bd_t *bis) #if defined(CONFIG_USB_ETHER) && \ (!defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_USBETH_SUPPORT)) if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("usbnet_devaddr", mac_addr); + eth_env_set_enetaddr("usbnet_devaddr", mac_addr);
rv = usb_eth_initialize(bis); if (rv < 0) diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 17fd6f56ea..0e2c4fc0ef 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -954,7 +954,7 @@ static int do_kbd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { char envvalue[ARRAY_SIZE(buttons)+1]; int numpressed = read_keys(envvalue); - setenv("keybd", envvalue); + env_set("keybd", envvalue); return numpressed == 0; }
@@ -995,7 +995,7 @@ static void preboot_keys(void) sprintf(cmd_name, "%s%c", kbd_command_prefix, *suffix); cmd = getenv(cmd_name); if (cmd) { - setenv("preboot", cmd); + env_set("preboot", cmd); return; } } @@ -1021,6 +1021,6 @@ int misc_init_r(void) #ifdef CONFIG_CMD_BMODE add_board_boot_modes(board_boot_modes); #endif - setenv_hex("reset_cause", get_imx_reset_cause()); + env_set_hex("reset_cause", get_imx_reset_cause()); return 0; } diff --git a/board/buffalo/lsxl/lsxl.c b/board/buffalo/lsxl/lsxl.c index 0f3734587a..5b31e056ba 100644 --- a/board/buffalo/lsxl/lsxl.c +++ b/board/buffalo/lsxl/lsxl.c @@ -228,7 +228,7 @@ static void erase_environment(void) static void rescue_mode(void) { printf("Entering rescue mode..\n"); - setenv("bootsource", "rescue"); + env_set("bootsource", "rescue"); }
static void check_push_button(void) diff --git a/board/cadence/xtfpga/xtfpga.c b/board/cadence/xtfpga/xtfpga.c index 0265e9bb36..83244c3ad4 100644 --- a/board/cadence/xtfpga/xtfpga.c +++ b/board/cadence/xtfpga/xtfpga.c @@ -93,7 +93,7 @@ int misc_init_r(void) x = (*(volatile u32 *)CONFIG_SYS_FPGAREG_DIPSW) & FPGAREG_MAC_MASK; sprintf(&s[15], "%02x", x); - setenv("ethaddr", s); + env_set("ethaddr", s); } #endif /* CONFIG_CMD_NET */
diff --git a/board/ccv/xpress/xpress.c b/board/ccv/xpress/xpress.c index 542e534270..b65646588a 100644 --- a/board/ccv/xpress/xpress.c +++ b/board/ccv/xpress/xpress.c @@ -318,7 +318,7 @@ static const struct boot_mode board_boot_modes[] = { int board_late_init(void) { add_board_boot_modes(board_boot_modes); - setenv("board_name", "xpress"); + env_set("board_name", "xpress");
return 0; } diff --git a/board/compulab/cl-som-am57x/eth.c b/board/compulab/cl-som-am57x/eth.c index 0c4bf91c13..d2992d3a63 100644 --- a/board/compulab/cl-som-am57x/eth.c +++ b/board/compulab/cl-som-am57x/eth.c @@ -107,7 +107,7 @@ static int cl_som_am57x_handle_mac_address(char *env_name, uint port_num) if (!is_valid_ethaddr(enetaddr)) return -1;
- ret = eth_setenv_enetaddr(env_name, enetaddr); + ret = eth_env_set_enetaddr(env_name, enetaddr); if (ret) printf("cl-som-am57x: Failed to set Eth port %d MAC address\n", port_num); diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index c59884a8c3..2368226546 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -481,7 +481,7 @@ static int handle_mac_address(char *env_var, uint eeprom_bus) if (!is_valid_ethaddr(enetaddr)) return -1;
- return eth_setenv_enetaddr(env_var, enetaddr); + return eth_env_set_enetaddr(env_var, enetaddr); }
#define SB_FX6_I2C_EEPROM_BUS 0 diff --git a/board/compulab/cm_t335/cm_t335.c b/board/compulab/cm_t335/cm_t335.c index c4506b910e..f6030ddf29 100644 --- a/board/compulab/cm_t335/cm_t335.c +++ b/board/compulab/cm_t335/cm_t335.c @@ -117,7 +117,7 @@ static int handle_mac_address(void) if (!is_valid_ethaddr(enetaddr)) return -1;
- return eth_setenv_enetaddr("ethaddr", enetaddr); + return eth_env_set_enetaddr("ethaddr", enetaddr); }
#define AR8051_PHY_DEBUG_ADDR_REG 0x1d diff --git a/board/compulab/cm_t35/cm_t35.c b/board/compulab/cm_t35/cm_t35.c index f1691257e7..a8696aea83 100644 --- a/board/compulab/cm_t35/cm_t35.c +++ b/board/compulab/cm_t35/cm_t35.c @@ -445,7 +445,7 @@ static int handle_mac_address(void) if (!is_valid_ethaddr(enetaddr)) return -1;
/* diff --git a/board/compulab/cm_t3517/cm_t3517.c b/board/compulab/cm_t3517/cm_t3517.c index 38eb641bc4..0568234f66 100644 --- a/board/compulab/cm_t3517/cm_t3517.c +++ b/board/compulab/cm_t3517/cm_t3517.c @@ -182,7 +182,7 @@ static int cm_t3517_handle_mac_address(void) if (!is_valid_ethaddr(enetaddr)) return -1;
#define SB_T35_ETH_RST_GPIO 164 diff --git a/board/compulab/cm_t54/cm_t54.c b/board/compulab/cm_t54/cm_t54.c index 6437718415..582512dbe4 100644 --- a/board/compulab/cm_t54/cm_t54.c +++ b/board/compulab/cm_t54/cm_t54.c @@ -172,7 +172,7 @@ static int handle_mac_address(void) if (!is_valid_ethaddr(enetaddr)) return -1;
- return eth_setenv_enetaddr("usbethaddr", enetaddr); + return eth_env_set_enetaddr("usbethaddr", enetaddr); }
int board_eth_init(bd_t *bis) diff --git a/board/congatec/cgtqmx6eval/cgtqmx6eval.c b/board/congatec/cgtqmx6eval/cgtqmx6eval.c index 5cb97b4778..ac66248b3f 100644 --- a/board/congatec/cgtqmx6eval/cgtqmx6eval.c +++ b/board/congatec/cgtqmx6eval/cgtqmx6eval.c @@ -755,9 +755,9 @@ int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (is_mx6dq()) - setenv("board_rev", "MX6Q"); + env_set("board_rev", "MX6Q"); else - setenv("board_rev", "MX6DL"); + env_set("board_rev", "MX6DL"); #endif
return 0; diff --git a/board/cssi/MCR3000/MCR3000.c b/board/cssi/MCR3000/MCR3000.c index 43c4cb77bb..c928881804 100644 --- a/board/cssi/MCR3000/MCR3000.c +++ b/board/cssi/MCR3000/MCR3000.c @@ -123,7 +123,7 @@ int misc_init_r(void)
/* if BTN_ACQ_AL is pressed then bootdelay is changed to 60 second */ if ((in_be16(&iop->iop_pcdat) & 0x0004) == 0) - setenv("bootdelay", "60"); + env_set("bootdelay", "60");
return 0; } diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index 11ea52f240..8cab357a92 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -147,7 +147,7 @@ int misc_init_r(void) if (!enetaddr_found) { if (!spi_mac_read) { if (is_valid_ethaddr(buff)) { - if (eth_setenv_enetaddr("ethaddr", buff)) { + if (eth_env_set_enetaddr("ethaddr", buff)) { printf("Warning: Failed to " "set MAC address from SPI flash\n"); } diff --git a/board/davinci/da8xxevm/omapl138_lcdk.c b/board/davinci/da8xxevm/omapl138_lcdk.c index 52bb7363a7..29296b0478 100644 --- a/board/davinci/da8xxevm/omapl138_lcdk.c +++ b/board/davinci/da8xxevm/omapl138_lcdk.c @@ -337,7 +337,7 @@ int misc_init_r(void) addr[0], addr[1], addr[2], addr[3], addr[4], addr[5]);
- setenv("ethaddr", (char *)tmp); + env_set("ethaddr", (char *)tmp); } else { printf("Invalid MAC address read.\n"); } diff --git a/board/el/el6x/el6x.c b/board/el/el6x/el6x.c index cbe355a600..6b98b5c3eb 100644 --- a/board/el/el6x/el6x.c +++ b/board/el/el6x/el6x.c @@ -466,7 +466,7 @@ int board_late_init(void) add_board_boot_modes(board_boot_modes); #endif
- setenv("board_name", BOARD_NAME); + env_set("board_name", BOARD_NAME); return 0; }
diff --git a/board/engicam/common/board.c b/board/engicam/common/board.c index e3bb5698f6..c4a3a0f290 100644 --- a/board/engicam/common/board.c +++ b/board/engicam/common/board.c @@ -21,11 +21,11 @@ static void mmc_late_init(void) char mmcblk[32]; u32 dev_no = mmc_get_env_dev();
- setenv_ulong("mmcdev", dev_no); + env_set_ulong("mmcdev", dev_no);
/* Set mmcblk env */ sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", dev_no); - setenv("mmcroot", mmcblk); + env_set("mmcroot", mmcblk);
sprintf(cmd, "mmc dev %d", dev_no); run_command(cmd, 0); @@ -43,22 +43,22 @@ int board_late_init(void) #ifdef CONFIG_ENV_IS_IN_MMC mmc_late_init(); #endif - setenv("modeboot", "mmcboot"); + env_set("modeboot", "mmcboot"); break; case IMX6_BMODE_NAND: - setenv("modeboot", "nandboot"); + env_set("modeboot", "nandboot"); break; default: - setenv("modeboot", ""); + env_set("modeboot", ""); break; }
if (is_mx6ul()) - setenv("console", "ttymxc0"); + env_set("console", "ttymxc0"); else - setenv("console", "ttymxc3"); + env_set("console", "ttymxc3");
- setenv_fdt_file(); + env_set_fdt_file();
return 0; } diff --git a/board/engicam/common/board.h b/board/engicam/common/board.h index f364a23296..434926c36c 100644 --- a/board/engicam/common/board.h +++ b/board/engicam/common/board.h @@ -6,7 +6,7 @@
#ifndef _BOARD_H_ #define _BOARD_H_ -void setenv_fdt_file(void); +void env_set_fdt_file(void); void setup_gpmi_nand(void); void setup_display(void); #endif /* _BOARD_H_ */ diff --git a/board/engicam/geam6ul/geam6ul.c b/board/engicam/geam6ul/geam6ul.c index bc36fc77ee..fd7e25f0e5 100644 --- a/board/engicam/geam6ul/geam6ul.c +++ b/board/engicam/geam6ul/geam6ul.c @@ -90,10 +90,10 @@ void setup_gpmi_nand(void) } #endif /* CONFIG_NAND_MXS */
-void setenv_fdt_file(void) +void env_set_fdt_file(void) { if (is_mx6ul()) - setenv("fdt_file", "imx6ul-geam-kit.dtb"); + env_set("fdt_file", "imx6ul-geam-kit.dtb"); }
#ifdef CONFIG_SPL_BUILD diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index 5b2ed066b4..6dfd64e851 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -192,12 +192,12 @@ void setup_display(void) } #endif /* CONFIG_VIDEO_IPUV3 */
-void setenv_fdt_file(void) +void env_set_fdt_file(void) { if (is_mx6dq()) - setenv("fdt_file", "imx6q-icore.dtb"); + env_set("fdt_file", "imx6q-icore.dtb"); else if(is_mx6dl() || is_mx6solo()) - setenv("fdt_file", "imx6dl-icore.dtb"); + env_set("fdt_file", "imx6dl-icore.dtb"); }
#ifdef CONFIG_SPL_BUILD diff --git a/board/engicam/icorem6_rqs/icorem6_rqs.c b/board/engicam/icorem6_rqs/icorem6_rqs.c index 10a9471730..a5741adb31 100644 --- a/board/engicam/icorem6_rqs/icorem6_rqs.c +++ b/board/engicam/icorem6_rqs/icorem6_rqs.c @@ -32,12 +32,12 @@ int board_mmc_get_env_dev(int devno) } #endif
-void setenv_fdt_file(void) +void env_set_fdt_file(void) { if (is_mx6dq()) - setenv("fdt_file", "imx6q-icore-rqs.dtb"); + env_set("fdt_file", "imx6q-icore-rqs.dtb"); else if(is_mx6dl() || is_mx6solo()) - setenv("fdt_file", "imx6dl-icore-rqs.dtb"); + env_set("fdt_file", "imx6dl-icore-rqs.dtb"); }
#ifdef CONFIG_SPL_BUILD diff --git a/board/engicam/isiotmx6ul/isiotmx6ul.c b/board/engicam/isiotmx6ul/isiotmx6ul.c index 4dcc9ea11b..d6daa3e3c5 100644 --- a/board/engicam/isiotmx6ul/isiotmx6ul.c +++ b/board/engicam/isiotmx6ul/isiotmx6ul.c @@ -98,13 +98,13 @@ int board_mmc_get_env_dev(int devno) } #endif
-void setenv_fdt_file(void) +void env_set_fdt_file(void) { if (is_mx6ul()) { #ifdef CONFIG_ENV_IS_IN_MMC - setenv("fdt_file", "imx6ul-isiot-emmc.dtb"); + env_set("fdt_file", "imx6ul-isiot-emmc.dtb"); #else - setenv("fdt_file", "imx6ul-isiot-nand.dtb"); + env_set("fdt_file", "imx6ul-isiot-nand.dtb"); #endif } } diff --git a/board/freescale/common/cmd_esbc_validate.c b/board/freescale/common/cmd_esbc_validate.c index cefe3cc531..b3e5f019b8 100644 --- a/board/freescale/common/cmd_esbc_validate.c +++ b/board/freescale/common/cmd_esbc_validate.c @@ -52,7 +52,7 @@ static int do_esbc_validate(cmd_tbl_t *cmdtp, int flag, int argc, * to continue U-Boot */ sprintf(buf, "%lx", img_addr); - setenv("img_addr", buf); + env_set("img_addr", buf);
if (ret) return 1; diff --git a/board/freescale/common/fsl_chain_of_trust.c b/board/freescale/common/fsl_chain_of_trust.c index 2cd4fba13f..a9ba9beef5 100644 --- a/board/freescale/common/fsl_chain_of_trust.c +++ b/board/freescale/common/fsl_chain_of_trust.c @@ -68,7 +68,7 @@ int fsl_check_boot_mode_secure(void) }
#ifndef CONFIG_SPL_BUILD -int fsl_setenv_chain_of_trust(void) +int fsl_env_set_chain_of_trust(void) { /* Check Boot Mode * If Boot Mode is Non-Secure, no changes are required @@ -80,8 +80,8 @@ int fsl_setenv_chain_of_trust(void) * bootdelay = 0 (To disable Boot Prompt) * bootcmd = CONFIG_CHAIN_BOOT_CMD (Validate and execute Boot script) */ - setenv("bootdelay", "0"); - setenv("bootcmd", CONFIG_CHAIN_BOOT_CMD); + env_set("bootdelay", "0"); + env_set("bootcmd", CONFIG_CHAIN_BOOT_CMD); return 0; } #endif diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index 29aa778dbe..c593cff5e7 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -479,7 +479,7 @@ int mac_read_from_eeprom(void) * (i.e. have not yet been set) */ if (!getenv(enetvar)) - setenv(enetvar, ethaddr); + env_set(enetvar, ethaddr); } }
diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index d81d8abc9b..66c28fd333 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -368,7 +368,7 @@ int board_late_init(void) ls1021a_sata_init(); #endif #ifdef CONFIG_CHAIN_OF_TRUST - fsl_setenv_chain_of_trust(); + fsl_env_set_chain_of_trust(); #endif
return 0; diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index ff32d5cb28..c56769afbf 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -523,7 +523,7 @@ int board_late_init(void) ls1021a_sata_init(); #endif #ifdef CONFIG_CHAIN_OF_TRUST - fsl_setenv_chain_of_trust(); + fsl_env_set_chain_of_trust(); #endif
return 0; diff --git a/board/freescale/mpc8323erdb/mpc8323erdb.c b/board/freescale/mpc8323erdb/mpc8323erdb.c index f30a1510ee..b715d8363e 100644 --- a/board/freescale/mpc8323erdb/mpc8323erdb.c +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c @@ -216,7 +216,7 @@ int mac_read_from_eeprom(void) buf[i * 6 + 4], buf[i * 6 + 5]); sprintf((char *)enetvar, i ? "eth%daddr" : "ethaddr", i); - setenv((char *)enetvar, str); + env_set((char *)enetvar, str); } } } diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index 27d606f310..ea36603686 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -246,7 +246,7 @@ static int power_init(void) if (!p) return -ENODEV;
- setenv("fdt_file", "imx53-qsb.dtb"); + env_set("fdt_file", "imx53-qsb.dtb");
/* Set VDDA to 1.25V */ val = DA9052_BUCKCORE_BCOREEN | DA_BUCKCORE_VBCORE_1_250V; @@ -289,7 +289,7 @@ static int power_init(void) if (!p) return -ENODEV;
- setenv("fdt_file", "imx53-qsrb.dtb"); + env_set("fdt_file", "imx53-qsrb.dtb");
/* Set VDDGP to 1.25V for 1GHz on SW1 */ pmic_reg_read(p, REG_SW_0, &val); diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index a5703a35b1..ea78091744 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -687,14 +687,14 @@ int board_late_init(void) #endif
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - setenv("board_name", "SABREAUTO"); + env_set("board_name", "SABREAUTO");
if (is_mx6dqp()) - setenv("board_rev", "MX6QP"); + env_set("board_rev", "MX6QP"); else if (is_mx6dq()) - setenv("board_rev", "MX6Q"); + env_set("board_rev", "MX6Q"); else if (is_mx6sdl()) - setenv("board_rev", "MX6DL"); + env_set("board_rev", "MX6DL"); #endif
return 0; diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index e4160420fa..19aa6f44d0 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -700,14 +700,14 @@ int board_late_init(void) #endif
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - setenv("board_name", "SABRESD"); + env_set("board_name", "SABRESD");
return 0; diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index a30c379e4d..cf7a069c56 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -674,12 +674,12 @@ int board_late_init(void) #endif
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - setenv("board_name", "EVK"); + env_set("board_name", "EVK");
if (is_mx6ul_9x9_evk()) - setenv("board_rev", "9X9"); + env_set("board_rev", "9X9"); else - setenv("board_rev", "14X14"); + env_set("board_rev", "14X14"); #endif
return 0; diff --git a/board/freescale/mx6ullevk/mx6ullevk.c b/board/freescale/mx6ullevk/mx6ullevk.c index 66b08f823e..cebcec738f 100644 --- a/board/freescale/mx6ullevk/mx6ullevk.c +++ b/board/freescale/mx6ullevk/mx6ullevk.c @@ -84,8 +84,8 @@ int board_late_init(void) #endif
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - setenv("board_name", "EVK"); - setenv("board_rev", "14X14"); + env_set("board_name", "EVK"); + env_set("board_rev", "14X14"); #endif
return 0; diff --git a/board/freescale/qemu-ppce500/qemu-ppce500.c b/board/freescale/qemu-ppce500/qemu-ppce500.c index 6cb5692eda..d40e62af4f 100644 --- a/board/freescale/qemu-ppce500/qemu-ppce500.c +++ b/board/freescale/qemu-ppce500/qemu-ppce500.c @@ -205,10 +205,10 @@ int last_stage_init(void) /* -kernel boot */ prop = fdt_getprop(fdt, chosen, "qemu,boot-kernel", &len); if (prop && (len >= 8)) - setenv_hex("qemu_kernel_addr", *prop); + env_set_hex("qemu_kernel_addr", *prop);
/* Give the user a variable for the host fdt */ - setenv_hex("fdt_addr_r", (ulong)fdt); + env_set_hex("fdt_addr_r", (ulong)fdt);
return 0; } diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 89848c8f07..61298ab2fd 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -301,7 +301,7 @@ int board_eth_init(bd_t *bis) if (!getenv("ethprime")) { struct eth_device *dev = eth_get_dev_by_index(0); if (dev) { - setenv("ethprime", dev->name); + env_set("ethprime", dev->name); printf("set ethprime to %s\n", getenv("ethprime")); } } @@ -662,7 +662,7 @@ int checkboard(void) if (p) quiet = simple_strtol(p, NULL, 10); else - setenv("quiet", "0"); + env_set("quiet", "0");
puts("\nGateworks Corporation Copyright 2014\n"); if (info->model[0]) { @@ -737,26 +737,26 @@ int misc_init_r(void) else if (is_cpu_type(MXC_CPU_MX6DL) || is_cpu_type(MXC_CPU_MX6SOLO)) cputype = "imx6dl"; - setenv("soctype", cputype); + env_set("soctype", cputype); if (8 << (ventana_info.nand_flash_size-1) >= 2048) - setenv("flash_layout", "large"); + env_set("flash_layout", "large"); else - setenv("flash_layout", "normal"); + env_set("flash_layout", "normal"); memset(str, 0, sizeof(str)); for (i = 0; i < (sizeof(str)-1) && info->model[i]; i++) str[i] = tolower(info->model[i]); - setenv("model", str); + env_set("model", str); if (!getenv("fdt_file")) { sprintf(fdt, "%s-%s.dtb", cputype, str); - setenv("fdt_file", fdt); + env_set("fdt_file", fdt); } p = strchr(str, '-'); if (p) { *p++ = 0;
- setenv("model_base", str); + env_set("model_base", str); sprintf(fdt, "%s-%s.dtb", cputype, str); - setenv("fdt_file1", fdt); + env_set("fdt_file1", fdt); if (board_type != GW551x && board_type != GW552x && board_type != GW553x && @@ -765,26 +765,26 @@ int misc_init_r(void) str[5] = 'x'; str[6] = 0; sprintf(fdt, "%s-%s.dtb", cputype, str); - setenv("fdt_file2", fdt); + env_set("fdt_file2", fdt); }
/* initialize env from EEPROM */ if (test_bit(EECONFIG_ETH0, info->config) && !getenv("ethaddr")) { - eth_setenv_enetaddr("ethaddr", info->mac0); + eth_env_set_enetaddr("ethaddr", info->mac0); } if (test_bit(EECONFIG_ETH1, info->config) && !getenv("eth1addr")) { - eth_setenv_enetaddr("eth1addr", info->mac1); + eth_env_set_enetaddr("eth1addr", info->mac1); }
/* board serial-number */ sprintf(str, "%6d", info->serial); - setenv("serial#", str); + env_set("serial#", str);
/* memory MB */ sprintf(str, "%d", (int) (gd->ram_size >> 20)); - setenv("mem_mb", str); + env_set("mem_mb", str); }
/* Set a non-initialized hwconfig based on board configuration */ @@ -798,7 +798,7 @@ int misc_init_r(void) if (strlen(buf) + strlen(buf1) < sizeof(buf)) strcat(buf, buf1); } - setenv("hwconfig", buf); + env_set("hwconfig", buf); }
/* setup baseboard specific GPIO based on board and env */ diff --git a/board/grinn/chiliboard/board.c b/board/grinn/chiliboard/board.c index e3f82b0a80..2900109bbd 100644 --- a/board/grinn/chiliboard/board.c +++ b/board/grinn/chiliboard/board.c @@ -130,7 +130,7 @@ int board_late_init(void) printf("<ethaddr> not set. Validating first E-fuse MAC\n");
mac_lo = readl(&cdev->macid1l); @@ -144,7 +144,7 @@ int board_late_init(void)
if (!getenv("eth1addr")) { if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("eth1addr", mac_addr); + eth_env_set_enetaddr("eth1addr", mac_addr); } #endif
diff --git a/board/grinn/liteboard/board.c b/board/grinn/liteboard/board.c index 817e22fd45..24956927ac 100644 --- a/board/grinn/liteboard/board.c +++ b/board/grinn/liteboard/board.c @@ -168,12 +168,12 @@ void board_late_mmc_init(void) if (!check_mmc_autodetect()) return;
sprintf(cmd, "mmc dev %d", dev_no); run_command(cmd, 0); diff --git a/board/gumstix/pepper/board.c b/board/gumstix/pepper/board.c index d76c28bd3c..7e8b014e3d 100644 --- a/board/gumstix/pepper/board.c +++ b/board/gumstix/pepper/board.c @@ -250,7 +250,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8; if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); }
writel((RGMII_MODE_ENABLE | RGMII_INT_DELAY), &cdev->miisel); diff --git a/board/highbank/highbank.c b/board/highbank/highbank.c index 1af2207867..e51043aa91 100644 --- a/board/highbank/highbank.c +++ b/board/highbank/highbank.c @@ -82,9 +82,9 @@ int misc_init_r(void) sprintf(envbuffer, "bootcmd%d", boot_choice); if (getenv(envbuffer)) { sprintf(envbuffer, "run bootcmd%d", boot_choice); - setenv("bootcmd", envbuffer); + env_set("bootcmd", envbuffer); } else - setenv("bootcmd", ""); + env_set("bootcmd", "");
return 0; } diff --git a/board/htkw/mcx/mcx.c b/board/htkw/mcx/mcx.c index 1deb2bdd8b..0a02e44046 100644 --- a/board/htkw/mcx/mcx.c +++ b/board/htkw/mcx/mcx.c @@ -83,7 +83,7 @@ int board_late_init(void) if (gpio_get_value(HOT_WATER_BUTTON)) return 0;
- setenv("bootcmd", "run swupdate"); + env_set("bootcmd", "run swupdate");
return 0; } diff --git a/board/isee/igep003x/board.c b/board/isee/igep003x/board.c index e33170d65f..1aa2f52069 100644 --- a/board/isee/igep003x/board.c +++ b/board/isee/igep003x/board.c @@ -194,13 +194,13 @@ int board_late_init(void) #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG switch (get_board_revision()) { case 0: - setenv("board_name", "igep0034-lite"); + env_set("board_name", "igep0034-lite"); break; case 1: - setenv("board_name", "igep0034"); + env_set("board_name", "igep0034"); break; default: - setenv("board_name", "igep0033"); + env_set("board_name", "igep0033"); break; } #endif @@ -275,7 +275,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8; if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); }
writel((GMII1_SEL_RMII | RMII1_IO_CLK_EN), diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index 843d35eb2d..a7a75601dd 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -251,10 +251,10 @@ void set_fdt(void) { switch (gd->bd->bi_arch_number) { case MACH_TYPE_IGEP0020: - setenv("fdtfile", "omap3-igep0020.dtb"); + env_set("fdtfile", "omap3-igep0020.dtb"); break; case MACH_TYPE_IGEP0030: - setenv("fdtfile", "omap3-igep0030.dtb"); + env_set("fdtfile", "omap3-igep0030.dtb"); break; } } diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 408079c9a1..56d3044241 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -51,7 +51,7 @@ int set_km_env(void) pnvramaddr = gd->ram_size - CONFIG_KM_RESERVED_PRAM - CONFIG_KM_PHRAM - CONFIG_KM_PNVRAM; sprintf((char *)buf, "0x%x", pnvramaddr); - setenv("pnvramaddr", (char *)buf); + env_set("pnvramaddr", (char *)buf);
/* try to read rootfssize (ram image) from environment */ p = getenv("rootfssize"); @@ -60,15 +60,15 @@ int set_km_env(void) pram = (rootfssize + CONFIG_KM_RESERVED_PRAM + CONFIG_KM_PHRAM + CONFIG_KM_PNVRAM) / 0x400; sprintf((char *)buf, "0x%x", pram); - setenv("pram", (char *)buf); + env_set("pram", (char *)buf);
varaddr = gd->ram_size - CONFIG_KM_RESERVED_PRAM - CONFIG_KM_PHRAM; sprintf((char *)buf, "0x%x", varaddr); - setenv("varaddr", (char *)buf); + env_set("varaddr", (char *)buf);
kernelmem = gd->ram_size - 0x400 * pram; sprintf((char *)buf, "0x%x", kernelmem); - setenv("kernelmem", (char *)buf); + env_set("kernelmem", (char *)buf);
return 0; } @@ -169,7 +169,7 @@ static int do_setboardid(cmd_tbl_t *cmdtp, int flag, int argc, return 1; } strcpy((char *)buf, p); - setenv("boardid", (char *)buf); + env_set("boardid", (char *)buf); printf("set boardid=%s\n", buf);
p = get_local_var("IVM_HWKey"); @@ -178,7 +178,7 @@ static int do_setboardid(cmd_tbl_t *cmdtp, int flag, int argc, return 1; } strcpy((char *)buf, p); - setenv("hwkey", (char *)buf); + env_set("hwkey", (char *)buf); printf("set hwkey=%s\n", buf); printf("Execute manually saveenv for persistent storage.\n");
@@ -311,9 +311,9 @@ static int do_checkboardidhwk(cmd_tbl_t *cmdtp, int flag, int argc, envbid = bid; envhwkey = hwkey; sprintf(buf, "%lx", bid); - setenv("boardid", buf); + env_set("boardid", buf); sprintf(buf, "%lx", hwkey); - setenv("hwkey", buf); + env_set("hwkey", buf); } } /* end while( ! found ) */ } diff --git a/board/keymile/common/ivm.c b/board/keymile/common/ivm.c index 42db54221b..cfb3494053 100644 --- a/board/keymile/common/ivm.c +++ b/board/keymile/common/ivm.c @@ -303,12 +303,12 @@ static int ivm_populate_env(unsigned char *buf, int len) /* if an offset is defined, add it */ process_mac(valbuf, page2, CONFIG_PIGGY_MAC_ADRESS_OFFSET); if (getenv("ethaddr") == NULL) - setenv((char *)"ethaddr", (char *)valbuf); + env_set((char *)"ethaddr", (char *)valbuf); #ifdef CONFIG_KMVECT1 /* KMVECT1 has two ethernet interfaces */ if (getenv("eth1addr") == NULL) { process_mac(valbuf, page2, 1); - setenv((char *)"eth1addr", (char *)valbuf); + env_set((char *)"eth1addr", (char *)valbuf); } #endif
diff --git a/board/keymile/km83xx/km83xx.c b/board/keymile/km83xx/km83xx.c index 8020c379fd..5e07faa818 100644 --- a/board/keymile/km83xx/km83xx.c +++ b/board/keymile/km83xx/km83xx.c @@ -263,11 +263,11 @@ int last_stage_init(void) mv88e_sw_reset(name, CONFIG_KM_MVEXTSW_ADDR);
if (piggy_present()) { - setenv("ethact", "UEC2"); - setenv("netdev", "eth1"); + env_set("ethact", "UEC2"); + env_set("netdev", "eth1"); puts("using PIGGY for network boot\n"); } else { - setenv("netdev", "eth0"); + env_set("netdev", "eth0"); puts("using frontport for network boot\n"); } #endif @@ -280,7 +280,7 @@ int last_stage_init(void) if (dip_switch != 0) { /* start bootloader */ puts("DIP: Enabled\n"); - setenv("actual_bank", "0"); + env_set("actual_bank", "0"); } #endif set_km_env(); diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index 85785ffc02..08ae9ae346 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -193,7 +193,7 @@ static void set_bootcount_addr(void) unsigned int bootcountaddr; bootcountaddr = gd->ram_size - BOOTCOUNT_ADDR; sprintf((char *)buf, "0x%x", bootcountaddr); - setenv("bootcountaddr", (char *)buf); + env_set("bootcountaddr", (char *)buf); }
int misc_init_r(void) @@ -299,7 +299,7 @@ int board_late_init(void) if (dip_switch != 0) { /* start bootloader */ puts("DIP: Enabled\n"); - setenv("actual_bank", "0"); + env_set("actual_bank", "0"); } #endif
diff --git a/board/keymile/kmp204x/kmp204x.c b/board/keymile/kmp204x/kmp204x.c index abb20196c5..095e467ac0 100644 --- a/board/keymile/kmp204x/kmp204x.c +++ b/board/keymile/kmp204x/kmp204x.c @@ -222,7 +222,7 @@ int last_stage_init(void) if (dip_switch != 0) { /* start bootloader */ puts("DIP: Enabled\n"); - setenv("actual_bank", "0"); + env_set("actual_bank", "0"); } #endif set_km_env(); diff --git a/board/kosagi/novena/novena.c b/board/kosagi/novena/novena.c index 980cd6288c..baca7223fa 100644 --- a/board/kosagi/novena/novena.c +++ b/board/kosagi/novena/novena.c @@ -264,7 +264,7 @@ int misc_init_r(void) }
/* Set ethernet address from EEPROM. */ - eth_setenv_enetaddr("ethaddr", data.mac); + eth_env_set_enetaddr("ethaddr", data.mac);
return ret; } diff --git a/board/lg/sniper/sniper.c b/board/lg/sniper/sniper.c index f924645dc0..4906e4f9d2 100644 --- a/board/lg/sniper/sniper.c +++ b/board/lg/sniper/sniper.c @@ -134,7 +134,7 @@ int misc_init_r(void)
omap_reboot_mode_clear(); diff --git a/board/liebherr/mccmon6/mccmon6.c b/board/liebherr/mccmon6/mccmon6.c index e265e2a732..8d0a66621d 100644 --- a/board/liebherr/mccmon6/mccmon6.c +++ b/board/liebherr/mccmon6/mccmon6.c @@ -367,7 +367,7 @@ int board_init(void)
int board_late_init(void) { - setenv("board_name", "mccmon6"); + env_set("board_name", "mccmon6");
return 0; } diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index 0a7d4124a6..78fc5466b6 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -173,11 +173,11 @@ int board_init(void)
int board_late_init(void) { - setenv("board_name", "imx6logic"); + env_set("board_name", "imx6logic");
if (is_mx6dq()) { - setenv("board_rev", "MX6DQ"); - setenv("fdt_file", "imx6q-logicpd.dtb"); + env_set("board_rev", "MX6DQ"); + env_set("fdt_file", "imx6q-logicpd.dtb"); }
return 0; diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 7990dd2513..8885d1e6a9 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -220,7 +220,7 @@ int board_late_init(void)
/* If the user has not set fdtimage, set the default */ if (!getenv("fdtimage")) - setenv("fdtimage", board->fdtfile); + env_set("fdtimage", board->fdtfile); }
/* restore hsusb0_data5 pin as hsusb0_data5 */ diff --git a/board/logicpd/zoom1/zoom1.c b/board/logicpd/zoom1/zoom1.c index e91f874a2b..f76223cacd 100644 --- a/board/logicpd/zoom1/zoom1.c +++ b/board/logicpd/zoom1/zoom1.c @@ -133,7 +133,7 @@ int board_eth_init(bd_t *bis) if (!eth_getenv_enetaddr(STR_ENV_ETHADDR, eth_addr)) { dev = eth_get_dev_by_index(0); if (dev) { - eth_setenv_enetaddr(STR_ENV_ETHADDR, dev->enetaddr); + eth_env_set_enetaddr(STR_ENV_ETHADDR, dev->enetaddr); } else { printf("zoom1: Couldn't get eth device\n"); rc = -1; diff --git a/board/nokia/rx51/rx51.c b/board/nokia/rx51/rx51.c index 6a4427a42e..889e748f98 100644 --- a/board/nokia/rx51/rx51.c +++ b/board/nokia/rx51/rx51.c @@ -413,7 +413,7 @@ int misc_init_r(void)
/* set env variable attkernaddr for relocated kernel */ sprintf(buf, "%#x", KERNEL_ADDRESS); - setenv("attkernaddr", buf); + env_set("attkernaddr", buf);
/* initialize omap tags */ init_omap_tags(); diff --git a/board/overo/overo.c b/board/overo/overo.c index adf33cfd37..140e34d4dd 100644 --- a/board/overo/overo.c +++ b/board/overo/overo.c @@ -172,47 +172,47 @@ int misc_init_r(void) expansion_config.revision, expansion_config.fab_revision); MUX_GUMSTIX(); - setenv("defaultdisplay", "dvi"); - setenv("expansionname", "summit"); + env_set("defaultdisplay", "dvi"); + env_set("expansionname", "summit"); break; case GUMSTIX_TOBI: printf("Recognized Tobi expansion board (rev %d %s)\n", expansion_config.revision, expansion_config.fab_revision); MUX_GUMSTIX(); - setenv("defaultdisplay", "dvi"); - setenv("expansionname", "tobi"); + env_set("defaultdisplay", "dvi"); + env_set("expansionname", "tobi"); break; case GUMSTIX_TOBI_DUO: printf("Recognized Tobi Duo expansion board (rev %d %s)\n", expansion_config.revision, expansion_config.fab_revision); MUX_GUMSTIX(); - setenv("expansionname", "tobiduo"); + env_set("expansionname", "tobiduo"); break; case GUMSTIX_PALO35: printf("Recognized Palo35 expansion board (rev %d %s)\n", expansion_config.revision, expansion_config.fab_revision); MUX_GUMSTIX(); - setenv("defaultdisplay", "lcd35"); - setenv("expansionname", "palo35"); + env_set("defaultdisplay", "lcd35"); + env_set("expansionname", "palo35"); break; case GUMSTIX_PALO43: printf("Recognized Palo43 expansion board (rev %d %s)\n", expansion_config.revision, expansion_config.fab_revision); MUX_GUMSTIX(); - setenv("defaultdisplay", "lcd43"); - setenv("expansionname", "palo43"); + env_set("defaultdisplay", "lcd43"); + env_set("expansionname", "palo43"); break; case GUMSTIX_CHESTNUT43: printf("Recognized Chestnut43 expansion board (rev %d %s)\n", expansion_config.revision, expansion_config.fab_revision); MUX_GUMSTIX(); - setenv("defaultdisplay", "lcd43"); - setenv("expansionname", "chestnut43"); + env_set("defaultdisplay", "lcd43"); + env_set("expansionname", "chestnut43"); break; case GUMSTIX_PINTO: printf("Recognized Pinto expansion board (rev %d %s)\n", @@ -225,8 +225,8 @@ int misc_init_r(void) expansion_config.revision, expansion_config.fab_revision); MUX_GUMSTIX(); - setenv("defaultdisplay", "lcd43"); - setenv("expansionname", "gallop43"); + env_set("defaultdisplay", "lcd43"); + env_set("expansionname", "gallop43"); break; case GUMSTIX_ALTO35: printf("Recognized Alto35 expansion board (rev %d %s)\n", @@ -234,8 +234,8 @@ int misc_init_r(void) expansion_config.fab_revision); MUX_GUMSTIX(); MUX_ALTO35(); - setenv("defaultdisplay", "lcd35"); - setenv("expansionname", "alto35"); + env_set("defaultdisplay", "lcd35"); + env_set("expansionname", "alto35"); break; case GUMSTIX_STAGECOACH: printf("Recognized Stagecoach expansion board (rev %d %s)\n", @@ -261,8 +261,8 @@ int misc_init_r(void) expansion_config.fab_revision); MUX_GUMSTIX(); MUX_ARBOR43C(); - setenv("defaultdisplay", "lcd43"); - setenv("expansionname", "arbor43c"); + env_set("defaultdisplay", "lcd43"); + env_set("expansionname", "arbor43c"); break; case ETTUS_USRP_E: printf("Recognized Ettus Research USRP-E (rev %d %s)\n", @@ -270,13 +270,13 @@ int misc_init_r(void) expansion_config.fab_revision); MUX_GUMSTIX(); MUX_USRP_E(); - setenv("defaultdisplay", "dvi"); + env_set("defaultdisplay", "dvi"); break; case GUMSTIX_NO_EEPROM: case GUMSTIX_EMPTY_EEPROM: puts("No or empty EEPROM on expansion board\n"); MUX_GUMSTIX(); - setenv("expansionname", "tobi"); + env_set("expansionname", "tobi"); break; default: printf("Unrecognized expansion board 0x%08x\n", expansion_id); @@ -284,14 +284,14 @@ int misc_init_r(void) }
if (expansion_config.content == 1) - setenv(expansion_config.env_var, expansion_config.env_setting); + env_set(expansion_config.env_var, expansion_config.env_setting);
omap_die_id_display();
if (get_cpu_family() == CPU_OMAP34XX) - setenv("boardname", "overo"); + env_set("boardname", "overo"); else - setenv("boardname", "overo-storm"); + env_set("boardname", "overo-storm");
return 0; } diff --git a/board/phytec/pcm051/board.c b/board/phytec/pcm051/board.c index 4f3853ac42..0da96e7413 100644 --- a/board/phytec/pcm051/board.c +++ b/board/phytec/pcm051/board.c @@ -229,7 +229,7 @@ int board_eth_init(bd_t *bis) mac_addr[5] = (mac_lo & 0xFF00) >> 8;
if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); else goto try_usbether; } diff --git a/board/qualcomm/dragonboard410c/dragonboard410c.c b/board/qualcomm/dragonboard410c/dragonboard410c.c index 37d0b85e0e..848e27848b 100644 --- a/board/qualcomm/dragonboard410c/dragonboard410c.c +++ b/board/qualcomm/dragonboard410c/dragonboard410c.c @@ -128,7 +128,7 @@ int misc_init_r(void) }
if (dm_gpio_get_value(&resin)) { - setenv("bootdelay", "-1"); + env_set("bootdelay", "-1"); printf("Power button pressed - dropping to console.\n"); }
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index d3c6ba580f..7ff7b269f9 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -251,7 +251,7 @@ static void set_fdtfile(void) return;
fdtfile = model->fdtfile; - setenv("fdtfile", fdtfile); + env_set("fdtfile", fdtfile); }
/* @@ -266,7 +266,7 @@ static void set_fdt_addr(void) if (fdt_magic(fw_dtb_pointer) != FDT_MAGIC) return;
- setenv_hex("fdt_addr", fw_dtb_pointer); + env_set_hex("fdt_addr", fw_dtb_pointer); }
/* @@ -300,10 +300,10 @@ static void set_usbethaddr(void) return; }
- eth_setenv_enetaddr("usbethaddr", msg->get_mac_address.body.resp.mac); + eth_env_set_enetaddr("usbethaddr", msg->get_mac_address.body.resp.mac);
if (!getenv("ethaddr")) - setenv("ethaddr", getenv("usbethaddr")); + env_set("ethaddr", getenv("usbethaddr"));
return; } @@ -314,13 +314,13 @@ static void set_board_info(void) char s[11];
snprintf(s, sizeof(s), "0x%X", revision); - setenv("board_revision", s); + env_set("board_revision", s); snprintf(s, sizeof(s), "%d", rev_scheme); - setenv("board_rev_scheme", s); + env_set("board_rev_scheme", s); /* Can't rename this to board_rev_type since it's an ABI for scripts */ snprintf(s, sizeof(s), "0x%X", rev_type); - setenv("board_rev", s); - setenv("board_name", model->name); + env_set("board_rev", s); + env_set("board_name", model->name); } #endif /* CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG */
@@ -345,7 +345,7 @@ static void set_serial_number(void)
snprintf(serial_string, sizeof(serial_string), "%016" PRIx64, msg->get_board_serial.body.resp.serial); - setenv("serial#", serial_string); + env_set("serial#", serial_string); }
int misc_init_r(void) diff --git a/board/renesas/blanche/blanche.c b/board/renesas/blanche/blanche.c index 5156eafeb4..e3262f779a 100644 --- a/board/renesas/blanche/blanche.c +++ b/board/renesas/blanche/blanche.c @@ -421,7 +421,7 @@ int board_eth_init(bd_t *bis) if (!eth_getenv_enetaddr(STR_ENV_ETHADDR, eth_addr)) { dev = eth_get_dev_by_index(0); if (dev) { - eth_setenv_enetaddr(STR_ENV_ETHADDR, dev->enetaddr); + eth_env_set_enetaddr(STR_ENV_ETHADDR, dev->enetaddr); } else { printf("blanche: Couldn't get eth device\n"); rc = -1; diff --git a/board/renesas/ecovec/ecovec.c b/board/renesas/ecovec/ecovec.c index 28b557a5b0..e4bb440d24 100644 --- a/board/renesas/ecovec/ecovec.c +++ b/board/renesas/ecovec/ecovec.c @@ -55,7 +55,7 @@ int board_late_init(void) /* Set MAC address */ sprintf(env_mac, "%02X:%02X:%02X:%02X:%02X:%02X", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]); - setenv("ethaddr", env_mac); + env_set("ethaddr", env_mac);
debug_led(0x0F);
diff --git a/board/renesas/sh7752evb/sh7752evb.c b/board/renesas/sh7752evb/sh7752evb.c index 525d979724..4a76fb73ee 100644 --- a/board/renesas/sh7752evb/sh7752evb.c +++ b/board/renesas/sh7752evb/sh7752evb.c @@ -221,10 +221,10 @@ static void init_ethernet_mac(void) for (i = 0; i < SH7752EVB_ETHERNET_NUM_CH; i++) { get_sh_eth_mac(i, mac_string, buf); if (i == 0) - setenv("ethaddr", mac_string); + env_set("ethaddr", mac_string); else { sprintf(env_string, "eth%daddr", i); - setenv(env_string, mac_string); + env_set(env_string, mac_string); } set_mac_to_sh_giga_eth_register(i, mac_string); } diff --git a/board/renesas/sh7753evb/sh7753evb.c b/board/renesas/sh7753evb/sh7753evb.c index 3d1eedaa5f..ca9e144743 100644 --- a/board/renesas/sh7753evb/sh7753evb.c +++ b/board/renesas/sh7753evb/sh7753evb.c @@ -237,10 +237,10 @@ static void init_ethernet_mac(void) for (i = 0; i < SH7753EVB_ETHERNET_NUM_CH; i++) { get_sh_eth_mac(i, mac_string, buf); if (i == 0) - setenv("ethaddr", mac_string); + env_set("ethaddr", mac_string); else { sprintf(env_string, "eth%daddr", i); - setenv(env_string, mac_string); + env_set(env_string, mac_string); } set_mac_to_sh_giga_eth_register(i, mac_string); } diff --git a/board/renesas/sh7757lcr/sh7757lcr.c b/board/renesas/sh7757lcr/sh7757lcr.c index 0a04a9d39d..3f970fc401 100644 --- a/board/renesas/sh7757lcr/sh7757lcr.c +++ b/board/renesas/sh7757lcr/sh7757lcr.c @@ -278,10 +278,10 @@ static void init_ethernet_mac(void) for (i = 0; i < SH7757LCR_ETHERNET_NUM_CH; i++) { get_sh_eth_mac(i, mac_string, buf); if (i == 0) - setenv("ethaddr", mac_string); + env_set("ethaddr", mac_string); else { sprintf(env_string, "eth%daddr", i); - setenv(env_string, mac_string); + env_set(env_string, mac_string); }
set_mac_to_sh_eth_register(i, mac_string); @@ -291,7 +291,7 @@ static void init_ethernet_mac(void) for (i = 0; i < SH7757LCR_GIGA_ETHERNET_NUM_CH; i++) { get_sh_eth_mac(i + SH7757LCR_ETHERNET_NUM_CH, mac_string, buf); sprintf(env_string, "eth%daddr", i + SH7757LCR_ETHERNET_NUM_CH); - setenv(env_string, mac_string); + env_set(env_string, mac_string);
set_mac_to_sh_giga_eth_register(i, mac_string); } diff --git a/board/rockchip/kylin_rk3036/kylin_rk3036.c b/board/rockchip/kylin_rk3036/kylin_rk3036.c index 7e2edf4a56..9134994874 100644 --- a/board/rockchip/kylin_rk3036/kylin_rk3036.c +++ b/board/rockchip/kylin_rk3036/kylin_rk3036.c @@ -44,7 +44,7 @@ int rk_board_late_init(void) { if (fastboot_key_pressed()) { printf("enter fastboot!\n"); - setenv("preboot", "setenv preboot; fastboot usb0"); + env_set("preboot", "setenv preboot; fastboot usb0"); }
return 0; diff --git a/board/rockchip/tinker_rk3288/tinker-rk3288.c b/board/rockchip/tinker_rk3288/tinker-rk3288.c index c2872e7330..790a921515 100644 --- a/board/rockchip/tinker_rk3288/tinker-rk3288.c +++ b/board/rockchip/tinker_rk3288/tinker-rk3288.c @@ -29,7 +29,7 @@ int rk_board_late_init(void) return 0;
if (is_valid_ethaddr(ethaddr)) - eth_setenv_enetaddr("ethaddr", ethaddr); + eth_env_set_enetaddr("ethaddr", ethaddr);
return 0; } diff --git a/board/samsung/common/misc.c b/board/samsung/common/misc.c index b18eed2fac..4157349d02 100644 --- a/board/samsung/common/misc.c +++ b/board/samsung/common/misc.c @@ -51,7 +51,7 @@ void set_dfu_alt_info(char *interface, char *devstr)
alt_setting = get_dfu_alt_boot(interface, devstr); if (alt_setting) { - setenv("dfu_alt_boot", alt_setting); + env_set("dfu_alt_boot", alt_setting); offset = snprintf(buf, buf_size, "%s", alt_setting); }
@@ -71,7 +71,7 @@ void set_dfu_alt_info(char *interface, char *devstr) status = "done\n"; }
- setenv("dfu_alt_info", alt_info); + env_set("dfu_alt_info", alt_info); puts(status); } #endif @@ -83,14 +83,14 @@ void set_board_info(void)
snprintf(info, ARRAY_SIZE(info), "%u.%u", (s5p_cpu_rev & 0xf0) >> 4, s5p_cpu_rev & 0xf); - setenv("soc_rev", info); + env_set("soc_rev", info);
snprintf(info, ARRAY_SIZE(info), "%x", s5p_cpu_id); - setenv("soc_id", info); + env_set("soc_id", info);
#ifdef CONFIG_REVISION_TAG snprintf(info, ARRAY_SIZE(info), "%x", get_board_rev()); - setenv("board_rev", info); + env_set("board_rev", info); #endif #ifdef CONFIG_OF_LIBFDT const char *bdtype = ""; @@ -102,11 +102,11 @@ void set_board_info(void) bdtype = "";
sprintf(info, "%s%s", bdname, bdtype); - setenv("boardname", info); + env_set("boardname", info); #endif snprintf(info, ARRAY_SIZE(info), "%s%x-%s%s.dtb", CONFIG_SYS_SOC, s5p_cpu_id, bdname, bdtype); - setenv("fdtfile", info); + env_set("fdtfile", info); #endif } #endif /* CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG */ diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index 00059a1317..f0913383b9 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -469,7 +469,7 @@ void exynos_lcd_misc_init(vidinfo_t *vid) #endif #ifdef CONFIG_S6E8AX0 s6e8ax0_init(); - setenv("lcdinfo", "lcd=s6e8ax0"); + env_set("lcdinfo", "lcd=s6e8ax0"); #endif } #endif diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index cc6eaf7ad0..549ac8b48a 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -397,6 +397,6 @@ void exynos_lcd_misc_init(vidinfo_t *vid) vid->pclk_name = 1; /* MPLL */ vid->sclk_div = 1;
- setenv("lcdinfo", "lcd=ld9040"); + env_set("lcdinfo", "lcd=ld9040"); } #endif diff --git a/board/samtec/vining_2000/vining_2000.c b/board/samtec/vining_2000/vining_2000.c index 5c8b436776..125f6e7070 100644 --- a/board/samtec/vining_2000/vining_2000.c +++ b/board/samtec/vining_2000/vining_2000.c @@ -132,7 +132,7 @@ int board_eth_init(bd_t *bis) /* just to get secound mac address */ imx_get_mac_from_fuse(1, eth1addr); if (!getenv("eth1addr") && is_valid_ethaddr(eth1addr)) - eth_setenv_enetaddr("eth1addr", eth1addr); + eth_env_set_enetaddr("eth1addr", eth1addr);
imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads));
@@ -413,11 +413,11 @@ static int set_pin_state(void) return ret;
if (val >= VAL_UPPER) - setenv("pin_state", "connected"); + env_set("pin_state", "connected"); else if (val < VAL_UPPER && val > VAL_LOWER) - setenv("pin_state", "open"); + env_set("pin_state", "open"); else - setenv("pin_state", "button"); + env_set("pin_state", "button");
return ret; } diff --git a/board/samtec/vining_fpga/socfpga.c b/board/samtec/vining_fpga/socfpga.c index f888ecbbc1..760fc71217 100644 --- a/board/samtec/vining_fpga/socfpga.c +++ b/board/samtec/vining_fpga/socfpga.c @@ -69,9 +69,9 @@ int misc_init_r(void) /* Check EEPROM signature. */ if (!(data[0] == 0xa5 && data[1] == 0x5a)) { puts("Invalid I2C EEPROM signature.\n"); - setenv("unit_serial", "invalid"); - setenv("unit_ident", "VINing-xxxx-STD"); - setenv("hostname", "vining-invalid"); + env_set("unit_serial", "invalid"); + env_set("unit_ident", "VINing-xxxx-STD"); + env_set("hostname", "vining-invalid"); return 0; }
@@ -82,18 +82,18 @@ int misc_init_r(void) (data[0x56] << 8) | (data[0x57] << 0); memset(str, 0, sizeof(str)); sprintf(str, "%07i", serial); - setenv("unit_serial", str); + env_set("unit_serial", str); }
if (!getenv("unit_ident")) { memset(str, 0, sizeof(str)); memcpy(str, &data[0x2e], 18); - setenv("unit_ident", str); + env_set("unit_ident", str); }
/* Set ethernet address from EEPROM. */ if (!getenv("ethaddr") && is_valid_ethaddr(&data[0x62])) - eth_setenv_enetaddr("ethaddr", &data[0x62]); + eth_env_set_enetaddr("ethaddr", &data[0x62]);
return 0; } diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index 6c869ed2b0..b4f027af28 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -266,7 +266,7 @@ err:
static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE;
-static int factoryset_mac_setenv(void) +static int factoryset_mac_env_set(void) { uint8_t mac_addr[6];
@@ -292,15 +292,15 @@ static int factoryset_mac_setenv(void) } }
- eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); return 0; }
-int factoryset_setenv(void) +int factoryset_env_set(void) { int ret = 0;
- if (factoryset_mac_setenv() < 0) + if (factoryset_mac_env_set() < 0) ret = -1;
return ret; diff --git a/board/siemens/common/factoryset.h b/board/siemens/common/factoryset.h index 3f23d5ebf4..8602627d2e 100644 --- a/board/siemens/common/factoryset.h +++ b/board/siemens/common/factoryset.h @@ -25,7 +25,7 @@ struct factorysetcontainer { };
int factoryset_read_eeprom(int i2c_addr); -int factoryset_setenv(void); +int factoryset_env_set(void); extern struct factorysetcontainer factory_dat;
#endif /* __FACTORYSET_H */ diff --git a/board/siemens/draco/board.c b/board/siemens/draco/board.c index d8869a09dd..c705b5ab0f 100644 --- a/board/siemens/draco/board.c +++ b/board/siemens/draco/board.c @@ -272,13 +272,13 @@ int board_late_init(void) #ifdef CONFIG_FACTORYSET /* Set ASN in environment*/ if (factory_dat.asn[0] != 0) { - setenv("dtb_name", (char *)factory_dat.asn); + env_set("dtb_name", (char *)factory_dat.asn); } else { /* dtb suffix gets added in load script */ - setenv("dtb_name", "am335x-draco"); + env_set("dtb_name", "am335x-draco"); } #else - setenv("dtb_name", "am335x-draco"); + env_set("dtb_name", "am335x-draco"); #endif
return 0; @@ -330,7 +330,7 @@ int board_eth_init(bd_t *bis) int n = 0; int rv;
- factoryset_setenv(); + factoryset_env_set();
/* Set rgmii mode and enable rmii clock to be sourced from chip */ writel((RMII_MODE_ENABLE | RMII_CHIPCKL_ENABLE), &cdev->miisel); diff --git a/board/siemens/pxm2/board.c b/board/siemens/pxm2/board.c index 750f338897..8bbb03561b 100644 --- a/board/siemens/pxm2/board.c +++ b/board/siemens/pxm2/board.c @@ -225,7 +225,7 @@ int board_eth_init(bd_t *bis) if (!is_valid_ethaddr(factory_dat.mac)) printf("Error: no valid mac address\n"); else - eth_setenv_enetaddr("ethaddr", factory_dat.mac); + eth_env_set_enetaddr("ethaddr", factory_dat.mac); #endif /* #ifdef CONFIG_FACTORYSET */
/* Set rgmii mode and enable rmii clock to be sourced from chip */ @@ -446,12 +446,12 @@ int board_late_init(void) factory_dat.pxm50 = 0; sprintf(tmp, "%s_%s", factory_dat.asn, factory_dat.comp_version); - ret = setenv("boardid", tmp); + ret = env_set("boardid", tmp); if (ret) printf("error setting board id\n"); } else { factory_dat.pxm50 = 1; - ret = setenv("boardid", "PXM50_1.0"); + ret = env_set("boardid", "PXM50_1.0"); if (ret) printf("error setting board id\n"); } diff --git a/board/siemens/rut/board.c b/board/siemens/rut/board.c index b3c666c054..2a97414baf 100644 --- a/board/siemens/rut/board.c +++ b/board/siemens/rut/board.c @@ -182,7 +182,7 @@ int board_eth_init(bd_t *bis) int rv;
#ifndef CONFIG_SPL_BUILD - factoryset_setenv(); + factoryset_env_set(); #endif
/* Set rgmii mode and enable rmii clock to be sourced from chip */ @@ -482,7 +482,7 @@ int board_late_init(void) else strcpy(tmp, "QMX7.E38_4.0");
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 3b742ebc22..d877a9c771 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -380,9 +380,9 @@ static int upgrade_failure_fallback(void) partitionset_active = getenv("partitionset_active"); if (partitionset_active) { if (partitionset_active[0] == 'A') - setenv("partitionset_active", "B"); + env_set("partitionset_active", "B"); else - setenv("partitionset_active", "A"); + env_set("partitionset_active", "A"); } else { printf("partitionset_active missing.\n"); return -ENOENT; @@ -390,22 +390,22 @@ static int upgrade_failure_fallback(void)
rootfs = getenv("rootfs"); rootfs_fallback = getenv("rootfs_fallback"); - setenv("rootfs", rootfs_fallback); - setenv("rootfs_fallback", rootfs); + env_set("rootfs", rootfs_fallback); + env_set("rootfs_fallback", rootfs);
kern_size = getenv("kernel_size"); kern_size_fb = getenv("kernel_size_fallback"); - setenv("kernel_size", kern_size_fb); - setenv("kernel_size_fallback", kern_size); + env_set("kernel_size", kern_size_fb); + env_set("kernel_size_fallback", kern_size);
kern_off = getenv("kernel_Off"); kern_off_fb = getenv("kernel_Off_fallback"); - setenv("kernel_Off", kern_off_fb); - setenv("kernel_Off_fallback", kern_off); + env_set("kernel_Off", kern_off_fb); + env_set("kernel_Off_fallback", kern_off);
- setenv("bootargs", '\0'); - setenv("upgrade_available", '\0'); - setenv("boot_retries", '\0'); + env_set("bootargs", '\0'); + env_set("upgrade_available", '\0'); + env_set("boot_retries", '\0'); env_save();
return 0; @@ -424,7 +424,7 @@ static int do_upgrade_available(cmd_tbl_t *cmdtp, int flag, int argc, boot_retry = simple_strtoul(getenv("boot_retries"), NULL, 10); boot_retry++; sprintf(boot_buf, "%lx", boot_retry); - setenv("boot_retries", boot_buf); + env_set("boot_retries", boot_buf); env_save();
/* diff --git a/board/silica/pengwyn/board.c b/board/silica/pengwyn/board.c index 1f5a5868cb..057691b045 100644 --- a/board/silica/pengwyn/board.c +++ b/board/silica/pengwyn/board.c @@ -184,7 +184,7 @@ int board_eth_init(bd_t *bis) mac_addr[5] = (mac_lo & 0xFF00) >> 8;
if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); else return n; } diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 1ccdfa8e05..7e59fb259e 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -376,14 +376,14 @@ int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (is_hummingboard()) - setenv("board_name", "HUMMINGBOARD"); + env_set("board_name", "HUMMINGBOARD"); else - setenv("board_name", "CUBOXI"); + env_set("board_name", "CUBOXI");
return 0; diff --git a/board/spear/common/spr_misc.c b/board/spear/common/spr_misc.c index d6a84dba60..67de28e7ea 100644 --- a/board/spear/common/spr_misc.c +++ b/board/spear/common/spr_misc.c @@ -54,14 +54,14 @@ int misc_init_r(void) uchar mac_id[6];
if (!eth_getenv_enetaddr("ethaddr", mac_id) && !i2c_read_mac(mac_id)) - eth_setenv_enetaddr("ethaddr", mac_id); + eth_env_set_enetaddr("ethaddr", mac_id); #endif - setenv("verify", "n"); + env_set("verify", "n");
#if defined(CONFIG_SPEAR_USBTTY) - setenv("stdin", "usbtty"); - setenv("stdout", "usbtty"); - setenv("stderr", "usbtty"); + env_set("stdin", "usbtty"); + env_set("stdout", "usbtty"); + env_set("stderr", "usbtty");
#ifndef CONFIG_SYS_NO_DCACHE dcache_enable(); diff --git a/board/st/stm32f429-discovery/stm32f429-discovery.c b/board/st/stm32f429-discovery/stm32f429-discovery.c index 8c8abf6a06..673e7728f1 100644 --- a/board/st/stm32f429-discovery/stm32f429-discovery.c +++ b/board/st/stm32f429-discovery/stm32f429-discovery.c @@ -320,7 +320,7 @@ int misc_init_r(void) u_id_high = readl(&STM32_U_ID->u_id_high); sprintf(serialno, "%08x%08x%08x", u_id_high, u_id_mid, u_id_low); - setenv("serial#", serialno); + env_set("serial#", serialno); }
return 0; diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 800f412b38..26732dc40f 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -646,7 +646,7 @@ static void parse_spl_header(const uint32_t spl_addr) return; } /* otherwise assume .scr format (mkimage-type script) */ - setenv_hex("fel_scriptaddr", spl->fel_script_address); + env_set_hex("fel_scriptaddr", spl->fel_script_address); }
/* @@ -705,14 +705,14 @@ static void setup_environment(const void *fdt) mac_addr[4] = (sid[3] >> 8) & 0xff; mac_addr[5] = (sid[3] >> 0) & 0xff;
- eth_setenv_enetaddr(ethaddr, mac_addr); + eth_env_set_enetaddr(ethaddr, mac_addr); }
if (!getenv("serial#")) { snprintf(serial_string, sizeof(serial_string), "%08x%08x", sid[0], sid[3]);
- setenv("serial#", serial_string); + env_set("serial#", serial_string); } } } @@ -721,11 +721,11 @@ int misc_init_r(void) { __maybe_unused int ret;
- setenv("fel_booted", NULL); - setenv("fel_scriptaddr", NULL); + env_set("fel_booted", NULL); + env_set("fel_scriptaddr", NULL); /* determine if we are running in FEL mode */ if (!is_boot0_magic(SPL_ADDR + 4)) { /* eGON.BT0 */ - setenv("fel_booted", "1"); + env_set("fel_booted", "1"); parse_spl_header(SPL_ADDR); }
diff --git a/board/syteco/zmx25/zmx25.c b/board/syteco/zmx25/zmx25.c index bdbf02a067..e02dcf2995 100644 --- a/board/syteco/zmx25/zmx25.c +++ b/board/syteco/zmx25/zmx25.c @@ -156,9 +156,9 @@ int board_late_init(void) gpio_set_value(IMX_GPIO_NR(1, 29), 0); gpio_set_value(IMX_GPIO_NR(4, 21), 0);
- setenv("preboot", "run gs_slow_boot"); + env_set("preboot", "run gs_slow_boot"); } else - setenv("preboot", "run gs_fast_boot"); + env_set("preboot", "run gs_fast_boot"); } }
diff --git a/board/tcl/sl50/board.c b/board/tcl/sl50/board.c index d3c953e993..cc65c7b84b 100644 --- a/board/tcl/sl50/board.c +++ b/board/tcl/sl50/board.c @@ -326,7 +326,7 @@ int board_eth_init(bd_t *bis) printf("<ethaddr> not set. Validating first E-fuse MAC\n");
#ifdef CONFIG_DRIVER_TI_CPSW @@ -342,7 +342,7 @@ int board_eth_init(bd_t *bis)
@@ -373,7 +373,7 @@ int board_eth_init(bd_t *bis) #if defined(CONFIG_USB_ETHER) && \ (!defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_USBETH_SUPPORT)) if (is_valid_ether_addr(mac_addr)) - eth_setenv_enetaddr("usbnet_devaddr", mac_addr); + eth_env_set_enetaddr("usbnet_devaddr", mac_addr);
rv = usb_eth_initialize(bis); if (rv < 0) diff --git a/board/technologic/ts4800/ts4800.c b/board/technologic/ts4800/ts4800.c index 94251c6d91..8fe26a75e8 100644 --- a/board/technologic/ts4800/ts4800.c +++ b/board/technologic/ts4800/ts4800.c @@ -178,7 +178,7 @@ static int fec_get_mac_from_register(uint32_t base_addr) ethaddr[i] = (reg_mac[i / 4] >> ((i % 4) * 8)) & 0xFF;
if (is_valid_ethaddr(ethaddr)) { - eth_setenv_enetaddr("ethaddr", ethaddr); + eth_env_set_enetaddr("ethaddr", ethaddr); return 0; }
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 36e9cd7f84..d8c8083e16 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -98,7 +98,7 @@ static void setup_macaddr(void) /* Make this a valid MAC address and set it */ mac_addr[0] &= 0xfe; /* clear multicast bit */ mac_addr[0] |= 0x02; /* set local assignment bit (IEEE802) */ - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); #endif
return; @@ -150,8 +150,8 @@ static void setup_serial(void) serialno |= (u64)crc32_no_comp(serialno, high, 8) << 32; snprintf(serialno_str, sizeof(serialno_str), "%llx", serialno);
- setenv("cpuid#", cpuid_str); - setenv("serial#", serialno_str); + env_set("cpuid#", cpuid_str); + env_set("serial#", serialno_str); #endif
return; diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index ac0592b725..7bdbc89d5e 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -731,7 +731,7 @@ int board_late_init(void) * on HS devices. */ if (get_device_type() == HS_DEVICE) - setenv("boot_fit", "1"); + env_set("boot_fit", "1"); #endif
#if !defined(CONFIG_SPL_BUILD) @@ -749,7 +749,7 @@ int board_late_init(void) printf("<ethaddr> not set. Validating first E-fuse MAC\n");
mac_lo = readl(&cdev->macid1l); @@ -763,7 +763,7 @@ int board_late_init(void)
@@ -908,7 +908,7 @@ int board_eth_init(bd_t *bis) #if defined(CONFIG_USB_ETHER) && \ (!defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_USBETH_SUPPORT)) if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("usbnet_devaddr", mac_addr); + eth_env_set_enetaddr("usbnet_devaddr", mac_addr);
rv = usb_eth_initialize(bis); if (rv < 0) diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 54f40e64a4..db9aff3739 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -626,7 +626,7 @@ int board_late_init(void) * on HS devices. */ if (get_device_type() == HS_DEVICE) - setenv("boot_fit", "1"); + env_set("boot_fit", "1"); #endif return 0; } @@ -794,7 +794,7 @@ int board_eth_init(bd_t *bis) if (!getenv("ethaddr")) { puts("<ethaddr> not set. Validating first E-fuse MAC\n"); if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); }
mac_lo = readl(&cdev->macid1l); @@ -808,7 +808,7 @@ int board_eth_init(bd_t *bis)
if (board_is_eposevm()) { diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index e4f1681860..b656f88163 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -588,7 +588,7 @@ void am57x_idk_lcd_detect(void) /* we will let default be "no lcd" */ } out: - setenv("idk_lcd", idk_lcd); + env_set("idk_lcd", idk_lcd); return; }
@@ -608,7 +608,7 @@ int board_late_init(void) * on HS devices. */ if (get_device_type() == HS_DEVICE) - setenv("boot_fit", "1"); + env_set("boot_fit", "1");
/* * Set the GPIO7 Pad to POWERHOLD. This has higher priority @@ -932,7 +932,7 @@ int board_eth_init(bd_t *bis) printf("<ethaddr> not set. Validating first E-fuse MAC\n");
mac_lo = readl((*ctrl)->control_core_mac_id_1_lo); @@ -946,7 +946,7 @@ int board_eth_init(bd_t *bis)
ctrl_val = readl((*ctrl)->control_core_control_io1) & (~0x33); @@ -981,9 +981,9 @@ int board_eth_init(bd_t *bis) for (i = 0; i < num_macs; i++) { u64_to_mac(mac1 + i, mac_addr); if (is_valid_ethaddr(mac_addr)) { - eth_setenv_enetaddr_by_index("eth", - i + 2, - mac_addr); + eth_env_set_enetaddr_by_index("eth", + i + 2, + mac_addr); } } } diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 887b577b6a..2f62fbec69 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -341,16 +341,16 @@ int misc_init_r(void) switch (get_board_revision()) { case REVISION_AXBX: printf("Beagle Rev Ax/Bx\n"); - setenv("beaglerev", "AxBx"); + env_set("beaglerev", "AxBx"); break; case REVISION_CX: printf("Beagle Rev C1/C2/C3\n"); - setenv("beaglerev", "Cx"); + env_set("beaglerev", "Cx"); MUX_BEAGLE_C(); break; case REVISION_C4: printf("Beagle Rev C4\n"); - setenv("beaglerev", "C4"); + env_set("beaglerev", "C4"); MUX_BEAGLE_C(); /* Set VAUX2 to 1.8V for EHCI PHY */ twl4030_pmrecv_vsel_cfg(TWL4030_PM_RECEIVER_VAUX2_DEDICATED, @@ -360,7 +360,7 @@ int misc_init_r(void) break; case REVISION_XM_AB: printf("Beagle xM Rev A/B\n"); - setenv("beaglerev", "xMAB"); + env_set("beaglerev", "xMAB"); MUX_BEAGLE_XM(); /* Set VAUX2 to 1.8V for EHCI PHY */ twl4030_pmrecv_vsel_cfg(TWL4030_PM_RECEIVER_VAUX2_DEDICATED, @@ -371,7 +371,7 @@ int misc_init_r(void) break; case REVISION_XM_C: printf("Beagle xM Rev C\n"); - setenv("beaglerev", "xMC"); + env_set("beaglerev", "xMC"); MUX_BEAGLE_XM(); /* Set VAUX2 to 1.8V for EHCI PHY */ twl4030_pmrecv_vsel_cfg(TWL4030_PM_RECEIVER_VAUX2_DEDICATED, @@ -397,14 +397,14 @@ int misc_init_r(void) expansion_config.revision, expansion_config.fab_revision); MUX_TINCANTOOLS_ZIPPY(); - setenv("buddy", "zippy"); + env_set("buddy", "zippy"); break; case TINCANTOOLS_ZIPPY2: printf("Recognized Tincantools Zippy2 board (rev %d %s)\n", expansion_config.revision, expansion_config.fab_revision); MUX_TINCANTOOLS_ZIPPY(); - setenv("buddy", "zippy2"); + env_set("buddy", "zippy2"); break; case TINCANTOOLS_TRAINER: printf("Recognized Tincantools Trainer board (rev %d %s)\n", @@ -412,37 +412,37 @@ int misc_init_r(void) expansion_config.fab_revision); MUX_TINCANTOOLS_ZIPPY(); MUX_TINCANTOOLS_TRAINER(); - setenv("buddy", "trainer"); + env_set("buddy", "trainer"); break; case TINCANTOOLS_SHOWDOG: printf("Recognized Tincantools Showdow board (rev %d %s)\n", expansion_config.revision, expansion_config.fab_revision); /* Place holder for DSS2 definition for showdog lcd */ - setenv("defaultdisplay", "showdoglcd"); - setenv("buddy", "showdog"); + env_set("defaultdisplay", "showdoglcd"); + env_set("buddy", "showdog"); break; case KBADC_BEAGLEFPGA: printf("Recognized KBADC Beagle FPGA board\n"); MUX_KBADC_BEAGLEFPGA(); - setenv("buddy", "beaglefpga"); + env_set("buddy", "beaglefpga"); break; case LW_BEAGLETOUCH: printf("Recognized Liquidware BeagleTouch board\n"); - setenv("buddy", "beagletouch"); + env_set("buddy", "beagletouch"); break; case BRAINMUX_LCDOG: printf("Recognized Brainmux LCDog board\n"); - setenv("buddy", "lcdog"); + env_set("buddy", "lcdog"); break; case BRAINMUX_LCDOGTOUCH: printf("Recognized Brainmux LCDog Touch board\n"); - setenv("buddy", "lcdogtouch"); + env_set("buddy", "lcdogtouch"); break; case BBTOYS_WIFI: printf("Recognized BeagleBoardToys WiFi board\n"); MUX_BBTOYS_WIFI() - setenv("buddy", "bbtoys-wifi"); + env_set("buddy", "bbtoys-wifi"); break; case BBTOYS_VGA: printf("Recognized BeagleBoardToys VGA board\n"); @@ -459,20 +459,20 @@ int misc_init_r(void) case LSR_COM6L_ADPT: printf("Recognized LSR COM6L Adapter Board\n"); MUX_BBTOYS_WIFI() - setenv("buddy", "lsr-com6l-adpt"); + env_set("buddy", "lsr-com6l-adpt"); break; case BEAGLE_NO_EEPROM: printf("No EEPROM on expansion board\n"); - setenv("buddy", "none"); + env_set("buddy", "none"); break; default: printf("Unrecognized expansion board: %x\n", expansion_config.device_vendor); - setenv("buddy", "unknown"); + env_set("buddy", "unknown"); }
twl4030_power_init(); switch (get_board_revision()) { diff --git a/board/ti/common/board_detect.c b/board/ti/common/board_detect.c index 1da5ace923..6f07ec331a 100644 --- a/board/ti/common/board_detect.c +++ b/board/ti/common/board_detect.c @@ -379,21 +379,21 @@ void __maybe_unused set_board_info_env(char *name) struct ti_common_eeprom *ep = TI_EEPROM_DATA;
if (name) - setenv("board_name", name); + env_set("board_name", name); else if (ep->name) - setenv("board_name", ep->name); + env_set("board_name", ep->name); else - setenv("board_name", unknown); + env_set("board_name", unknown);
if (ep->version) - setenv("board_rev", ep->version); + env_set("board_rev", ep->version); else - setenv("board_rev", unknown); + env_set("board_rev", unknown);
if (ep->serial) - setenv("board_serial", ep->serial); + env_set("board_serial", ep->serial); else - setenv("board_serial", unknown); + env_set("board_serial", unknown); }
static u64 mac_to_u64(u8 mac[6]) @@ -451,8 +451,8 @@ void board_ti_set_ethaddr(int index) for (i = 0; i < num_macs; i++) { u64_to_mac(mac1 + i, mac_addr); if (is_valid_ethaddr(mac_addr)) { - eth_setenv_enetaddr_by_index("eth", i + index, - mac_addr); + eth_env_set_enetaddr_by_index("eth", i + index, + mac_addr); } } } diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 23be2c70e4..4252074e74 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -558,7 +558,7 @@ int board_late_init(void) * on HS devices. */ if (get_device_type() == HS_DEVICE) - setenv("boot_fit", "1"); + env_set("boot_fit", "1");
omap_die_id_serial(); omap_set_fastboot_vars(); @@ -897,7 +897,7 @@ int board_eth_init(bd_t *bis) printf("<ethaddr> not set. Validating first E-fuse MAC\n");
mac_lo = readl((*ctrl)->control_core_mac_id_1_lo); @@ -911,7 +911,7 @@ int board_eth_init(bd_t *bis)
ctrl_val = readl((*ctrl)->control_core_control_io1) & (~0x33); diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index fe8e79312f..ac8e093e5a 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -248,7 +248,7 @@ int board_eth_init(bd_t *bis) if (!eth_getenv_enetaddr(STR_ENV_ETHADDR, eth_addr)) { dev = eth_get_dev_by_index(0); if (dev) { - eth_setenv_enetaddr(STR_ENV_ETHADDR, dev->enetaddr); + eth_env_set_enetaddr(STR_ENV_ETHADDR, dev->enetaddr); } else { printf("omap3evm: Couldn't get eth device\n"); rc = -1; diff --git a/board/ti/ks2_evm/board_k2g.c b/board/ti/ks2_evm/board_k2g.c index 21605762ef..15f0f54af6 100644 --- a/board/ti/ks2_evm/board_k2g.c +++ b/board/ti/ks2_evm/board_k2g.c @@ -310,9 +310,9 @@ int board_late_init(void)
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (board_is_k2g_gp()) - setenv("board_name", "66AK2GGP\0"); + env_set("board_name", "66AK2GGP\0"); else if (board_is_k2g_ice()) - setenv("board_name", "66AK2GIC\0"); + env_set("board_name", "66AK2GIC\0"); #endif return 0; } diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 6ffb53c4c6..c59e58a82a 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -103,7 +103,7 @@ int get_board_revision(void) board_id4 = gpio_get_value(PANDA_ES_BOARD_ID_4_GPIO);
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - setenv("board_name", "panda-es"); + env_set("board_name", "panda-es"); #endif board_id = ((board_id4 << 4) | (board_id3 << 3) | (board_id2 << 2) | (board_id1 << 1) | (board_id0)); @@ -117,7 +117,7 @@ int get_board_revision(void)
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if ((board_id >= 0x3) && (processor_rev == OMAP4430_ES2_3)) - setenv("board_name", "panda-a4"); + env_set("board_name", "panda-a4"); #endif }
diff --git a/board/ti/ti814x/evm.c b/board/ti/ti814x/evm.c index 055a29d9c6..38f9c57606 100644 --- a/board/ti/ti814x/evm.c +++ b/board/ti/ti814x/evm.c @@ -179,7 +179,7 @@ int board_eth_init(bd_t *bis) mac_addr[5] = (mac_lo & 0xFF00) >> 8;
if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); else printf("Unable to read MAC address. Set <ethaddr>\n"); } diff --git a/board/ti/ti816x/evm.c b/board/ti/ti816x/evm.c index 9d6c3d6b5d..1a8fe27c9f 100644 --- a/board/ti/ti816x/evm.c +++ b/board/ti/ti816x/evm.c @@ -51,7 +51,7 @@ int board_eth_init(bd_t *bis) mac_addr[5] = (mac_lo & 0xFF00) >> 8;
if (is_valid_ethaddr(mac_addr)) - eth_setenv_enetaddr("ethaddr", mac_addr); + eth_env_set_enetaddr("ethaddr", mac_addr); else printf("Unable to read MAC address. Set <ethaddr>\n"); } diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index d31eeb878a..2f80d15666 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -111,7 +111,7 @@ int misc_init_r(void) enetaddr[3] = (die_id_0 & 0x00ff0000) >> 16; enetaddr[4] = (die_id_0 & 0x0000ff00) >> 8; enetaddr[5] = (die_id_0 & 0x000000ff); - eth_setenv_enetaddr("ethaddr", enetaddr); + eth_env_set_enetaddr("ethaddr", enetaddr); } #endif
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index e41547bbee..86a7a159e8 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -804,7 +804,7 @@ int board_late_init(void)
rev = get_board_rev(); snprintf(env_str, ARRAY_SIZE(env_str), "%.4x", rev); - setenv("board_rev", env_str); + env_set("board_rev", env_str);
#ifndef CONFIG_TDX_APALIS_IMX6_V1_0 if ((rev & 0xfff0) == 0x0100) { @@ -816,7 +816,7 @@ int board_late_init(void) /* if using the default device tree, use version for V1.0 HW */ fdt_env = getenv("fdt_file"); if ((fdt_env != NULL) && (strcmp(FDT_FILE, fdt_env) == 0)) { - setenv("fdt_file", FDT_FILE_V1_0); + env_set("fdt_file", FDT_FILE_V1_0); printf("patching fdt_file to " FDT_FILE_V1_0 "\n"); #ifndef CONFIG_ENV_IS_NOWHERE env_save(); diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index cbf7aa952a..dbcd233782 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -676,7 +676,7 @@ int board_late_init(void)
rev = get_board_rev(); snprintf(env_str, ARRAY_SIZE(env_str), "%.4x", rev); - setenv("board_rev", env_str); + env_set("board_rev", env_str); #endif
return 0; diff --git a/board/toradex/colibri_vf/colibri_vf.c b/board/toradex/colibri_vf/colibri_vf.c index 46dd15bac8..3858af9c40 100644 --- a/board/toradex/colibri_vf/colibri_vf.c +++ b/board/toradex/colibri_vf/colibri_vf.c @@ -535,7 +535,7 @@ int board_late_init(void) if (((src->sbmr2 & SRC_SBMR2_BMOD_MASK) >> SRC_SBMR2_BMOD_SHIFT) == SRC_SBMR2_BMOD_SERIAL) { printf("Serial Downloader recovery mode, disable autoboot\n"); - setenv("bootdelay", "-1"); + env_set("bootdelay", "-1"); }
return 0; diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index 0d267877fa..78b2bc0c2b 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -80,14 +80,14 @@ int show_board_info(void) tdx_hw_tag.ver_minor, (char)tdx_hw_tag.ver_assembly + 'A');
- setenv("serial#", tdx_serial_str); + env_set("serial#", tdx_serial_str);
/* * Check if environment contains a valid MAC address, * set the one from config block if not */ if (!eth_getenv_enetaddr("ethaddr", ethaddr)) - eth_setenv_enetaddr("ethaddr", (u8 *)&tdx_eth_addr); + eth_env_set_enetaddr("ethaddr", (u8 *)&tdx_eth_addr);
#ifdef CONFIG_TDX_CFG_BLOCK_2ND_ETHADDR if (!eth_getenv_enetaddr("eth1addr", ethaddr)) { @@ -97,7 +97,7 @@ int show_board_info(void) */ memcpy(ethaddr, &tdx_eth_addr, 6); ethaddr[3] += 0x10; - eth_setenv_enetaddr("eth1addr", ethaddr); + eth_env_set_enetaddr("eth1addr", ethaddr); } #endif
diff --git a/board/tqc/tqma6/tqma6.c b/board/tqc/tqma6/tqma6.c index fcdea34f05..14991fdb00 100644 --- a/board/tqc/tqma6/tqma6.c +++ b/board/tqc/tqma6/tqma6.c @@ -251,7 +251,7 @@ int power_init_board(void)
int board_late_init(void) { - setenv("board_name", tqma6_get_boardname()); + env_set("board_name", tqma6_get_boardname());
tqma6_bb_board_late_init();
diff --git a/board/udoo/neo/neo.c b/board/udoo/neo/neo.c index 276c625cfd..7fa1289de0 100644 --- a/board/udoo/neo/neo.c +++ b/board/udoo/neo/neo.c @@ -437,7 +437,7 @@ int checkboard(void) int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - setenv("board_name", board_string()); + env_set("board_name", board_string()); #endif
return 0; diff --git a/board/udoo/udoo.c b/board/udoo/udoo.c index 7534935dde..a359626b81 100644 --- a/board/udoo/udoo.c +++ b/board/udoo/udoo.c @@ -255,9 +255,9 @@ int board_late_init(void) { #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (is_cpu_type(MXC_CPU_MX6Q)) - setenv("board_rev", "MX6Q"); + env_set("board_rev", "MX6Q"); else - setenv("board_rev", "MX6DL"); + env_set("board_rev", "MX6DL"); #endif return 0; } diff --git a/board/varisys/common/sys_eeprom.c b/board/varisys/common/sys_eeprom.c index b55ab818e6..d235897311 100644 --- a/board/varisys/common/sys_eeprom.c +++ b/board/varisys/common/sys_eeprom.c @@ -401,7 +401,7 @@ int mac_read_from_generic_eeprom(const char *envvar, int chip, mac[5]);
printf("MAC: %s\n", ethaddr); - setenv(envvar, ethaddr); + env_set(envvar, ethaddr); }
return ret; @@ -487,7 +487,7 @@ int mac_read_from_eeprom_common(void) * (i.e. have not yet been set) */ if (!getenv(enetvar)) - setenv(enetvar, ethaddr); + env_set(enetvar, ethaddr); } }
diff --git a/board/vscom/baltos/board.c b/board/vscom/baltos/board.c index d3b1f1564f..2e3baeb118 100644 --- a/board/vscom/baltos/board.c +++ b/board/vscom/baltos/board.c @@ -68,7 +68,7 @@ static int baltos_set_console(void) printf("DIPs: 0x%1x\n", (~dips) & 0xf);
if ((dips & 0xf) == 0xe) - setenv("console", "ttyUSB0,115200n8"); + env_set("console", "ttyUSB0,115200n8");
return 0; } @@ -373,7 +373,7 @@ int board_late_init(void) return -ENODEV; }
- setenv("board_name", model); + env_set("board_name", model); #endif
return 0; @@ -457,7 +457,7 @@ int board_eth_init(bd_t *bis) printf("<ethaddr> not set. Validating first E-fuse MAC\n");
#ifdef CONFIG_DRIVER_TI_CPSW diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 1dbc966b6e..adfcf48562 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -425,14 +425,14 @@ int board_late_init(void)
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (is_mx6dq()) - setenv("board_rev", "MX6Q"); + env_set("board_rev", "MX6Q"); else - setenv("board_rev", "MX6DL"); + env_set("board_rev", "MX6DL");
if (is_revc1()) - setenv("board_name", "C1"); + env_set("board_name", "C1"); else - setenv("board_name", "B1"); + env_set("board_name", "B1"); #endif return 0; } diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index b2fbecf6de..90ef542458 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -86,22 +86,22 @@ int board_late_init(void) { switch ((zynq_slcr_get_boot_mode()) & ZYNQ_BM_MASK) { case ZYNQ_BM_QSPI: - setenv("modeboot", "qspiboot"); + env_set("modeboot", "qspiboot"); break; case ZYNQ_BM_NAND: - setenv("modeboot", "nandboot"); + env_set("modeboot", "nandboot"); break; case ZYNQ_BM_NOR: - setenv("modeboot", "norboot"); + env_set("modeboot", "norboot"); break; case ZYNQ_BM_SD: - setenv("modeboot", "sdboot"); + env_set("modeboot", "sdboot"); break; case ZYNQ_BM_JTAG: - setenv("modeboot", "jtagboot"); + env_set("modeboot", "jtagboot"); break; default: - setenv("modeboot", ""); + env_set("modeboot", ""); break; }
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 51a3d9f276..89ab24417d 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -285,7 +285,7 @@ int board_late_init(void) strlen(getenv("boot_targets")) + 2);
sprintf(new_targets, "%s %s", mode, getenv("boot_targets")); - setenv("boot_targets", new_targets); + env_set("boot_targets", new_targets);
return 0; } diff --git a/cmd/cbfs.c b/cmd/cbfs.c index 95a11a3616..799ba01fcc 100644 --- a/cmd/cbfs.c +++ b/cmd/cbfs.c @@ -80,7 +80,7 @@ static int do_cbfs_fsload(cmd_tbl_t *cmdtp, int flag, int argc,
printf("\n%ld bytes read\n", size);
- setenv_hex("filesize", size); + env_set_hex("filesize", size);
return 0; } diff --git a/cmd/cramfs.c b/cmd/cramfs.c index 49ee36c74a..7b23c5b3dd 100644 --- a/cmd/cramfs.c +++ b/cmd/cramfs.c @@ -138,7 +138,7 @@ int do_cramfs_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (size > 0) { printf("### CRAMFS load complete: %d bytes loaded to 0x%lx\n", size, offset); - setenv_hex("filesize", size); + env_set_hex("filesize", size); } else { printf("### CRAMFS LOAD ERROR<%x> for %s!\n", size, filename); } diff --git a/cmd/fdt.c b/cmd/fdt.c index 05e19f8a72..eb01a889ad 100644 --- a/cmd/fdt.c +++ b/cmd/fdt.c @@ -43,21 +43,21 @@ void set_working_fdt_addr(ulong addr)
buf = map_sysmem(addr, 0); working_fdt = buf; - setenv_hex("fdtaddr", addr); + env_set_hex("fdtaddr", addr); }
/* * Get a value from the fdt and format it to be set in the environment */ -static int fdt_value_setenv(const void *nodep, int len, const char *var) +static int fdt_value_env_set(const void *nodep, int len, const char *var) { if (is_printable_string(nodep, len)) - setenv(var, (void *)nodep); + env_set(var, (void *)nodep); else if (len == 4) { char buf[11];
sprintf(buf, "0x%08X", fdt32_to_cpu(*(fdt32_t *)nodep)); - setenv(var, buf); + env_set(var, buf); } else if (len%4 == 0 && len <= 20) { /* Needed to print things like sha1 hashes. */ char buf[41]; @@ -66,7 +66,7 @@ static int fdt_value_setenv(const void *nodep, int len, const char *var) for (i = 0; i < len; i += sizeof(unsigned int)) sprintf(buf + (i * 2), "%08x", *(unsigned int *)(nodep + i)); - setenv(var, buf); + env_set(var, buf); } else { printf("error: unprintable value\n"); return 1; @@ -358,10 +358,12 @@ static int do_fdt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (curDepth == startDepth + 1) curIndex++; if (subcmd[0] == 'n' && curIndex == reqIndex) { - const char *nodeName = fdt_get_name( - working_fdt, nextNodeOffset, NULL); + const char *node_name;
- setenv(var, (char *)nodeName); + node_name = fdt_get_name(working_fdt, + nextNodeOffset, + NULL); + env_set(var, node_name); return 0; } nextNodeOffset = fdt_next_node( @@ -371,7 +373,7 @@ static int do_fdt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } if (subcmd[0] == 's') { /* get the num nodes at this level */ - setenv_ulong(var, curIndex + 1); + env_set_ulong(var, curIndex + 1); } else { /* node index not found */ printf("libfdt node not found\n"); @@ -382,13 +384,14 @@ static int do_fdt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) working_fdt, nodeoffset, prop, &len); if (len == 0) { /* no property value */ - setenv(var, ""); + env_set(var, ""); return 0; } else if (nodep && len > 0) { if (subcmd[0] == 'v') { int ret;
- ret = fdt_value_setenv(nodep, len, var); + ret = fdt_value_env_set(nodep, len, + var); if (ret != 0) return ret; } else if (subcmd[0] == 'a') { @@ -396,13 +399,13 @@ static int do_fdt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) char buf[11];
sprintf(buf, "0x%p", nodep); - setenv(var, buf); + env_set(var, buf); } else if (subcmd[0] == 's') { /* Get size */ char buf[11];
sprintf(buf, "0x%08X", len); - setenv(var, buf); + env_set(var, buf); } else return CMD_RET_USAGE; return 0; diff --git a/cmd/gpt.c b/cmd/gpt.c index 3e98821868..cb76d5e540 100644 --- a/cmd/gpt.c +++ b/cmd/gpt.c @@ -55,7 +55,7 @@ static int extract_env(const char *str, char **env) #ifdef CONFIG_RANDOM_UUID debug("%s unset. ", str); gen_rand_uuid_str(uuid_str, UUID_STR_FORMAT_GUID); - setenv(s, uuid_str); + env_set(s, uuid_str);
e = getenv(s); if (e) { diff --git a/cmd/ini.c b/cmd/ini.c index 727fd1c664..449f6e9f51 100644 --- a/cmd/ini.c +++ b/cmd/ini.c @@ -219,7 +219,7 @@ static int ini_handler(void *user, char *section, char *name, char *value) for (i = 0; i < strlen(value); i++) value[i] = tolower(value[i]); #endif - setenv(name, value); + env_set(name, value); printf("ini: Imported %s as %s\n", name, value); }
diff --git a/cmd/jffs2.c b/cmd/jffs2.c index dc94705ccd..add89dee6a 100644 --- a/cmd/jffs2.c +++ b/cmd/jffs2.c @@ -512,7 +512,7 @@ int do_jffs2_fsload(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (size > 0) { printf("### %s load complete: %d bytes loaded to 0x%lx\n", fsname, size, offset); - setenv_hex("filesize", size); + env_set_hex("filesize", size); } else { printf("### %s LOAD ERROR<%x> for %s!\n", fsname, size, filename); } diff --git a/cmd/load.c b/cmd/load.c index 4597ec5618..ec3730e0f6 100644 --- a/cmd/load.c +++ b/cmd/load.c @@ -182,7 +182,7 @@ static ulong load_serial(long offset) start_addr, end_addr, size, size ); flush_cache(start_addr, size); - setenv_hex("filesize", size); + env_set_hex("filesize", size); return (addr); case SREC_START: break; @@ -529,7 +529,7 @@ static ulong load_serial_bin(ulong offset) flush_cache(offset, size);
printf("## Total Size = 0x%08x = %d Bytes\n", size, size); - setenv_hex("filesize", size); + env_set_hex("filesize", size);
return offset; } @@ -1000,7 +1000,7 @@ static ulong load_serial_ymodem(ulong offset, int mode) flush_cache(offset, ALIGN(size, ARCH_DMA_MINALIGN));
return offset; } diff --git a/cmd/lzmadec.c b/cmd/lzmadec.c index c78df825e8..1b482edb58 100644 --- a/cmd/lzmadec.c +++ b/cmd/lzmadec.c @@ -42,7 +42,7 @@ static int do_lzmadec(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) return 1; printf("Uncompressed size: %ld = %#lX\n", (ulong)src_len, (ulong)src_len); - setenv_hex("filesize", src_len); + env_set_hex("filesize", src_len);
return 0; } diff --git a/cmd/md5sum.c b/cmd/md5sum.c index 23bb81e88c..1b2352ea55 100644 --- a/cmd/md5sum.c +++ b/cmd/md5sum.c @@ -35,7 +35,7 @@ static void store_result(const u8 *sum, const char *dest) sprintf(str_ptr, "%02x", sum[i]); str_ptr += 2; } - setenv(dest, str_output); + env_set(dest, str_output); } }
diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index 683c48bdad..d3fde77ef0 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -239,19 +239,19 @@ static void index_partitions(void) dev = list_entry(dentry, struct mtd_device, link); if (dev == current_mtd_dev) { mtddevnum += current_mtd_partnum; - setenv_ulong("mtddevnum", mtddevnum); + env_set_ulong("mtddevnum", mtddevnum); break; } mtddevnum += dev->num_parts; }
part = mtd_part_info(current_mtd_dev, current_mtd_partnum); - setenv("mtddevname", part->name); + env_set("mtddevname", part->name);
debug("=> mtddevnum %d,\n=> mtddevname %s\n", mtddevnum, part->name); } else { - setenv("mtddevnum", NULL); - setenv("mtddevname", NULL); + env_set("mtddevnum", NULL); + env_set("mtddevname", NULL);
debug("=> mtddevnum NULL\n=> mtddevname NULL\n"); } @@ -270,12 +270,12 @@ static void current_save(void) sprintf(buf, "%s%d,%d", MTD_DEV_TYPE(current_mtd_dev->id->type), current_mtd_dev->id->num, current_mtd_partnum);
- setenv("partition", buf); + env_set("partition", buf); strncpy(last_partition, buf, 16);
debug("=> partition %s\n", buf); } else { - setenv("partition", NULL); + env_set("partition", NULL); last_partition[0] = '\0';
debug("=> partition NULL\n"); @@ -1213,9 +1213,9 @@ static int generate_mtdparts_save(char *buf, u32 buflen) ret = generate_mtdparts(buf, buflen);
if ((buf[0] != '\0') && (ret == 0)) - setenv("mtdparts", buf); + env_set("mtdparts", buf); else - setenv("mtdparts", NULL); + env_set("mtdparts", NULL);
return ret; } @@ -1764,7 +1764,7 @@ int mtdparts_init(void) if (mtdids_default) { debug("mtdids variable not defined, using default\n"); ids = mtdids_default; - setenv("mtdids", (char *)ids); + env_set("mtdids", (char *)ids); } else { printf("mtdids not defined, no default present\n"); return 1; @@ -1780,7 +1780,7 @@ int mtdparts_init(void) if (!parts) { if (mtdparts_default && use_defaults) { parts = mtdparts_default; - if (setenv("mtdparts", (char *)parts) == 0) + if (env_set("mtdparts", (char *)parts) == 0) use_defaults = 0; } else printf("mtdparts variable not set, see 'help mtdparts'\n"); @@ -1956,9 +1956,9 @@ static int do_mtdparts(cmd_tbl_t *cmdtp, int flag, int argc, { if (argc == 2) { if (strcmp(argv[1], "default") == 0) { - setenv("mtdids", NULL); - setenv("mtdparts", NULL); - setenv("partition", NULL); + env_set("mtdids", NULL); + env_set("mtdparts", NULL); + env_set("partition", NULL); use_defaults = 1;
mtdparts_init(); @@ -1967,7 +1967,7 @@ static int do_mtdparts(cmd_tbl_t *cmdtp, int flag, int argc, /* this may be the first run, initialize lists if needed */ mtdparts_init();
/* mtd_devices_init() calls current_save() */ return mtd_devices_init(); diff --git a/cmd/nand.c b/cmd/nand.c index a2152ec826..0f5d431e5c 100644 --- a/cmd/nand.c +++ b/cmd/nand.c @@ -305,9 +305,9 @@ static void nand_print_and_set_info(int idx) printf(" bbt options 0x%08x\n", chip->bbt_options);
/* Set geometry info */ - setenv_hex("nand_writesize", mtd->writesize); - setenv_hex("nand_oobsize", mtd->oobsize); - setenv_hex("nand_erasesize", mtd->erasesize); + env_set_hex("nand_writesize", mtd->writesize); + env_set_hex("nand_oobsize", mtd->oobsize); + env_set_hex("nand_erasesize", mtd->erasesize); }
static int raw_access(struct mtd_info *mtd, ulong addr, loff_t off, diff --git a/cmd/net.c b/cmd/net.c index df8b6c9b53..fa6d02f90d 100644 --- a/cmd/net.c +++ b/cmd/net.c @@ -116,23 +116,23 @@ static void netboot_update_env(void)
if (net_gateway.s_addr) { ip_to_string(net_gateway, tmp); - setenv("gatewayip", tmp); + env_set("gatewayip", tmp); }
if (net_netmask.s_addr) { ip_to_string(net_netmask, tmp); - setenv("netmask", tmp); + env_set("netmask", tmp); }
if (net_hostname[0]) - setenv("hostname", net_hostname); + env_set("hostname", net_hostname);
if (net_root_path[0]) - setenv("rootpath", net_root_path); + env_set("rootpath", net_root_path);
if (net_ip.s_addr) { ip_to_string(net_ip, tmp); - setenv("ipaddr", tmp); + env_set("ipaddr", tmp); } #if !defined(CONFIG_BOOTP_SERVERIP) /* @@ -141,32 +141,32 @@ static void netboot_update_env(void) */ if (net_server_ip.s_addr) { ip_to_string(net_server_ip, tmp); - setenv("serverip", tmp); + env_set("serverip", tmp); } #endif if (net_dns_server.s_addr) { ip_to_string(net_dns_server, tmp); - setenv("dnsip", tmp); + env_set("dnsip", tmp); } #if defined(CONFIG_BOOTP_DNS2) if (net_dns_server2.s_addr) { ip_to_string(net_dns_server2, tmp); - setenv("dnsip2", tmp); + env_set("dnsip2", tmp); } #endif if (net_nis_domain[0]) - setenv("domain", net_nis_domain); + env_set("domain", net_nis_domain);
#if defined(CONFIG_CMD_SNTP) && defined(CONFIG_BOOTP_TIMEOFFSET) if (net_ntp_time_offset) { sprintf(tmp, "%d", net_ntp_time_offset); - setenv("timeoffset", tmp); + env_set("timeoffset", tmp); } #endif #if defined(CONFIG_CMD_SNTP) && defined(CONFIG_BOOTP_NTPSERVER) if (net_ntp_server.s_addr) { ip_to_string(net_ntp_server, tmp); - setenv("ntpserverip", tmp); + env_set("ntpserverip", tmp); } #endif } @@ -291,14 +291,14 @@ static void cdp_update_env(void) printf("CDP offered appliance VLAN %d\n", ntohs(cdp_appliance_vlan)); vlan_to_string(cdp_appliance_vlan, tmp); - setenv("vlan", tmp); + env_set("vlan", tmp); net_our_vlan = cdp_appliance_vlan; }
if (cdp_native_vlan != htons(-1)) { printf("CDP offered native VLAN %d\n", ntohs(cdp_native_vlan)); vlan_to_string(cdp_native_vlan, tmp); - setenv("nvlan", tmp); + env_set("nvlan", tmp); net_native_vlan = cdp_native_vlan; } } @@ -423,14 +423,14 @@ static int do_link_local(cmd_tbl_t *cmdtp, int flag, int argc,
net_gateway.s_addr = 0; ip_to_string(net_gateway, tmp); - setenv("gatewayip", tmp); + env_set("gatewayip", tmp);
ip_to_string(net_ip, tmp); - setenv("ipaddr", tmp); - setenv("llipaddr", tmp); /* store this for next time */ + env_set("ipaddr", tmp); + env_set("llipaddr", tmp); /* store this for next time */
return CMD_RET_SUCCESS; } diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 4431ef66d8..a649004850 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -283,7 +283,7 @@ static int _do_env_set(int flag, int argc, char * const argv[], int env_flag) return 0; }
-int setenv(const char *varname, const char *varvalue) +int env_set(const char *varname, const char *varvalue) { const char * const argv[4] = { "setenv", varname, varvalue, NULL };
@@ -304,12 +304,12 @@ int setenv(const char *varname, const char *varvalue) * @param value Value to set it to * @return 0 if ok, 1 on error */ -int setenv_ulong(const char *varname, ulong value) +int env_set_ulong(const char *varname, ulong value) { /* TODO: this should be unsigned */ char *str = simple_itoa(value);
- return setenv(varname, str); + return env_set(varname, str); }
/** @@ -319,12 +319,12 @@ int setenv_ulong(const char *varname, ulong value) * @param value Value to set it to * @return 0 if ok, 1 on error */ -int setenv_hex(const char *varname, ulong value) +int env_set_hex(const char *varname, ulong value) { char str[17];
sprintf(str, "%lx", value); - return setenv(varname, str); + return env_set(varname, str); }
ulong getenv_hex(const char *varname, ulong default_val) @@ -931,7 +931,7 @@ NXTARG: ; return 1; } sprintf(buf, "%zX", (size_t)len); - setenv("filesize", buf); + env_set("filesize", buf);
return 0; } @@ -957,7 +957,7 @@ NXTARG: ; envp->flags = ACTIVE_FLAG; #endif } - setenv_hex("filesize", len + offsetof(env_t, data)); + env_set_hex("filesize", len + offsetof(env_t, data));
diff --git a/cmd/part.c b/cmd/part.c index 8ba05984e4..746bf40b2d 100644 --- a/cmd/part.c +++ b/cmd/part.c @@ -38,7 +38,7 @@ static int do_part_uuid(int argc, char * const argv[]) return 1;
if (argc > 2) - setenv(argv[2], info.uuid); + env_set(argv[2], info.uuid); else printf("%s\n", info.uuid);
@@ -99,7 +99,7 @@ static int do_part_list(int argc, char * const argv[]) sprintf(t, "%s%x", str[0] ? " " : "", p); strcat(str, t); } - setenv(var, str); + env_set(var, str); return 0; }
@@ -135,7 +135,7 @@ static int do_part_start(int argc, char * const argv[]) snprintf(buf, sizeof(buf), LBAF, info.start);
if (argc > 3) - setenv(argv[3], buf); + env_set(argv[3], buf); else printf("%s\n", buf);
@@ -169,7 +169,7 @@ static int do_part_size(int argc, char * const argv[]) snprintf(buf, sizeof(buf), LBAF, info.size);
diff --git a/cmd/pxe.c b/cmd/pxe.c index 0a07f14ca8..357b96940c 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -591,7 +591,7 @@ static int label_localboot(struct pxe_label *label) char bootargs[CONFIG_SYS_CBSIZE];
cli_simple_process_macros(label->append, bootargs); - setenv("bootargs", bootargs); + env_set("bootargs", bootargs); }
debug("running: %s\n", localcmd); @@ -695,7 +695,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) strcat(bootargs, mac_str);
cli_simple_process_macros(bootargs, finalbootargs); - setenv("bootargs", finalbootargs); + env_set("bootargs", finalbootargs); printf("append: %s\n", finalbootargs); }
@@ -1674,7 +1674,7 @@ static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) filename = getenv("bootfile"); else { filename = argv[5]; - setenv("bootfile", filename); + env_set("bootfile", filename); }
if (strstr(argv[3], "ext2")) diff --git a/cmd/qfw.c b/cmd/qfw.c index 12436ec9b4..9b12ab40ca 100644 --- a/cmd/qfw.c +++ b/cmd/qfw.c @@ -55,7 +55,7 @@ static int qemu_fwcfg_setup_kernel(void *load_addr, void *initrd_addr) * when invoking qemu), do not update bootargs */ if (*data_addr != '\0') { - if (setenv("bootargs", data_addr) < 0) + if (env_set("bootargs", data_addr) < 0) printf("warning: unable to change bootargs\n"); } } diff --git a/cmd/reiser.c b/cmd/reiser.c index 9c3e9e9e58..4df9c5f5db 100644 --- a/cmd/reiser.c +++ b/cmd/reiser.c @@ -157,7 +157,7 @@ int do_reiserload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) load_addr = addr;
printf ("\n%ld bytes read\n", filelen); - setenv_hex("filesize", filelen); + env_set_hex("filesize", filelen);
return filelen; } diff --git a/cmd/setexpr.c b/cmd/setexpr.c index e7194fc4f4..91a5a9a770 100644 --- a/cmd/setexpr.c +++ b/cmd/setexpr.c @@ -282,11 +282,11 @@ static int regex_sub(const char *name, if (!global) break; } - debug("## FINAL (now setenv()) : %s\n", data); + debug("## FINAL (now env_set()) : %s\n", data);
printf("%s=%s\n", name, data);
- return setenv(name, data); + return env_set(name, data); } #endif
@@ -314,7 +314,7 @@ static int do_setexpr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* plain assignment: "setexpr name value" */ if (argc == 3) { - setenv_hex(argv[1], a); + env_set_hex(argv[1], a); return 0; }
@@ -370,7 +370,7 @@ static int do_setexpr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; }
- setenv_hex(argv[1], value); + env_set_hex(argv[1], value);
return 0; } diff --git a/cmd/tpm.c b/cmd/tpm.c index 0c4bc73ca6..d9b433582c 100644 --- a/cmd/tpm.c +++ b/cmd/tpm.c @@ -231,7 +231,7 @@ static int type_string_write_vars(const char *type_str, uint8_t *data, default: return -1; } - if (setenv_ulong(*vars, value)) + if (env_set_ulong(*vars, value)) return -1; }
@@ -624,7 +624,7 @@ static int do_tpm_load_key_by_sha1(cmd_tbl_t *cmdtp, int flag, int argc, char * &key_handle); if (!err) { printf("Key handle is 0x%x\n", key_handle); - setenv_hex("key_handle", key_handle); + env_set_hex("key_handle", key_handle); }
return report_return_code(err); diff --git a/cmd/trace.c b/cmd/trace.c index 1a6d8c3047..e6c08e4ba5 100644 --- a/cmd/trace.c +++ b/cmd/trace.c @@ -46,9 +46,9 @@ static int create_func_list(int argc, char * const argv[]) used = min(avail, (size_t)needed); printf("Function trace dumped to %08lx, size %#zx\n", (ulong)map_to_sysmem(buff + buff_ptr), used); - setenv_hex("profbase", map_to_sysmem(buff)); - setenv_hex("profsize", buff_size); - setenv_hex("profoffset", buff_ptr + used); + env_set_hex("profbase", map_to_sysmem(buff)); + env_set_hex("profsize", buff_size); + env_set_hex("profoffset", buff_ptr + used);
return 0; } @@ -71,9 +71,9 @@ static int create_call_list(int argc, char * const argv[]) printf("Call list dumped to %08lx, size %#zx\n", (ulong)map_to_sysmem(buff + buff_ptr), used);
return 0; } diff --git a/cmd/unzip.c b/cmd/unzip.c index a8bcb1f529..94f883f92a 100644 --- a/cmd/unzip.c +++ b/cmd/unzip.c @@ -29,7 +29,7 @@ static int do_unzip(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1;
printf("Uncompressed size: %ld = 0x%lX\n", src_len, src_len); - setenv_hex("filesize", src_len); + env_set_hex("filesize", src_len);
return 0; } diff --git a/cmd/ximg.c b/cmd/ximg.c index d033c15b62..50dc00e4f8 100644 --- a/cmd/ximg.c +++ b/cmd/ximg.c @@ -251,8 +251,8 @@ do_imgextract(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[])
flush_cache(dest, len);
- setenv_hex("fileaddr", data); - setenv_hex("filesize", len); + env_set_hex("fileaddr", data); + env_set_hex("filesize", len);
return 0; } diff --git a/cmd/zfs.c b/cmd/zfs.c index 3ed9912d19..08b0062c10 100644 --- a/cmd/zfs.c +++ b/cmd/zfs.c @@ -115,7 +115,7 @@ static int do_zfs_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[] load_addr = addr;
printf("%llu bytes read\n", zfile.size); - setenv_hex("filesize", zfile.size); + env_set_hex("filesize", zfile.size);
return 0; } diff --git a/cmd/zip.c b/cmd/zip.c index 7fcd9d5bf8..dac7527721 100644 --- a/cmd/zip.c +++ b/cmd/zip.c @@ -30,7 +30,7 @@ static int do_zip(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1;
printf("Compressed size: %ld = 0x%lX\n", dst_len, dst_len); - setenv_hex("filesize", dst_len); + env_set_hex("filesize", dst_len);
return 0; } diff --git a/common/autoboot.c b/common/autoboot.c index c52bad84a4..41f18208c3 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -278,12 +278,12 @@ static void process_fdt_options(const void *blob) /* Add an env variable to point to a kernel payload, if available */ addr = fdtdec_get_config_int(gd->fdt_blob, "kernel-offset", 0); if (addr) - setenv_addr("kernaddr", (void *)(CONFIG_SYS_TEXT_BASE + addr)); + env_set_addr("kernaddr", (void *)(CONFIG_SYS_TEXT_BASE + addr));
/* Add an env variable to point to a root disk, if available */ addr = fdtdec_get_config_int(gd->fdt_blob, "rootdisk-offset", 0); if (addr) - setenv_addr("rootaddr", (void *)(CONFIG_SYS_TEXT_BASE + addr)); + env_set_addr("rootaddr", (void *)(CONFIG_SYS_TEXT_BASE + addr)); #endif /* CONFIG_OF_CONTROL && CONFIG_SYS_TEXT_BASE */ }
@@ -300,7 +300,7 @@ const char *bootdelay_process(void) bootcount = bootcount_load(); bootcount++; bootcount_store(bootcount); - setenv_ulong("bootcount", bootcount); + env_set_ulong("bootcount", bootcount); bootlimit = getenv_ulong("bootlimit", 10, 0); #endif /* CONFIG_BOOTCOUNT_LIMIT */
diff --git a/common/board_r.c b/common/board_r.c index ecca1edb04..3b7bc6bbd0 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -486,7 +486,7 @@ static int initr_env(void) else set_default_env(NULL); #ifdef CONFIG_OF_CONTROL - setenv_addr("fdtcontroladdr", gd->fdt_blob); + env_set_addr("fdtcontroladdr", gd->fdt_blob); #endif
/* Initialize from environment */ @@ -658,7 +658,7 @@ int initr_mem(void) pram += (LOGBUFF_LEN + LOGBUFF_OVERHEAD) / 1024; # endif sprintf(memsz, "%ldk", (long int) ((gd->ram_size / 1024) - pram)); - setenv("mem", memsz); + env_set("mem", memsz);
return 0; } diff --git a/common/bootm.c b/common/bootm.c index b2c09126ce..e34617a145 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -569,7 +569,7 @@ static void fixup_silent_linux(void) env_val = CONSOLE_ARG; }
- setenv("bootargs", env_val); + env_set("bootargs", env_val); debug("after silent fix-up: %s\n", env_val); free(buf); } @@ -645,8 +645,8 @@ int do_bootm_states(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], ret = boot_ramdisk_high(&images->lmb, images->rd_start, rd_len, &images->initrd_start, &images->initrd_end); if (!ret) { - setenv_hex("initrd_start", images->initrd_start); - setenv_hex("initrd_end", images->initrd_end); + env_set_hex("initrd_start", images->initrd_start); + env_set_hex("initrd_end", images->initrd_end); } } #endif diff --git a/common/bootm_os.c b/common/bootm_os.c index d9e6e937f7..86a37cb925 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -23,7 +23,7 @@ static int do_bootm_standalone(int flag, int argc, char * const argv[], /* Don't start if "autostart" is set to "no" */ s = getenv("autostart"); if ((s != NULL) && !strcmp(s, "no")) { - setenv_hex("filesize", images->os.image_len); + env_set_hex("filesize", images->os.image_len); return 0; } appl = (int (*)(int, char * const []))images->ep; diff --git a/common/cli_hush.c b/common/cli_hush.c index 00861e2d9e..280289639c 100644 --- a/common/cli_hush.c +++ b/common/cli_hush.c @@ -2265,7 +2265,7 @@ void unset_local_var(const char *name) } else { #ifndef __U_BOOT__ if(cur->flg_export) - unsetenv(cur->name); + unenv_set(cur->name); #endif free(cur->name); free(cur->value); diff --git a/common/console.c b/common/console.c index c6156f33bb..2f3fa28f74 100644 --- a/common/console.c +++ b/common/console.c @@ -817,7 +817,7 @@ done: #ifdef CONFIG_SYS_CONSOLE_ENV_OVERWRITE /* set the environment variables (will overwrite previous env settings) */ for (i = 0; i < 3; i++) { - setenv(stdio_names[i], stdio_devices[i]->name); + env_set(stdio_names[i], stdio_devices[i]->name); } #endif /* CONFIG_SYS_CONSOLE_ENV_OVERWRITE */
@@ -896,7 +896,7 @@ int console_init_r(void)
/* Setting environment variables */ for (i = 0; i < 3; i++) { - setenv(stdio_names[i], stdio_devices[i]->name); + env_set(stdio_names[i], stdio_devices[i]->name); }
gd->flags |= GD_FLG_DEVINIT; /* device initialization completed */ diff --git a/common/hash.c b/common/hash.c index 771d8fa87f..fda636d34a 100644 --- a/common/hash.c +++ b/common/hash.c @@ -302,7 +302,7 @@ static void store_result(struct hash_algo *algo, const uint8_t *sum, str_ptr += 2; } *str_ptr = '\0'; - setenv(dest, str_output); + env_set(dest, str_output); } else { ulong addr; void *buf; diff --git a/common/hwconfig.c b/common/hwconfig.c index 4ae042ee33..85aaabbb85 100644 --- a/common/hwconfig.c +++ b/common/hwconfig.c @@ -243,7 +243,7 @@ int main() const char *ret; size_t len;
- setenv("hwconfig", "key1:subkey1=value1,subkey2=value2;key2:value3;;;;" + env_set("hwconfig", "key1:subkey1=value1,subkey2=value2;key2:value3;;;;" "key3;:,:=;key4", 1);
ret = hwconfig_arg("key1", &len); @@ -274,7 +274,7 @@ int main() assert(hwconfig_arg("key4", &len) == NULL); assert(hwconfig_arg("bogus", &len) == NULL);
- unsetenv("hwconfig"); + unenv_set("hwconfig");
assert(hwconfig(NULL) == 0); assert(hwconfig("") == 0); diff --git a/common/image-android.c b/common/image-android.c index c668407817..018c7594fe 100644 --- a/common/image-android.c +++ b/common/image-android.c @@ -90,7 +90,7 @@ int android_image_get_kernel(const struct andr_img_hdr *hdr, int verify, if (*hdr->cmdline) strcat(newbootargs, hdr->cmdline);
- setenv("bootargs", newbootargs); + env_set("bootargs", newbootargs);
if (os_data) { *os_data = (ulong)hdr; diff --git a/common/main.c b/common/main.c index 2116a9e0a2..07fc31b716 100644 --- a/common/main.c +++ b/common/main.c @@ -48,7 +48,7 @@ void main_loop(void) bootstage_mark_name(BOOTSTAGE_ID_MAIN_LOOP, "main_loop");
#ifdef CONFIG_VERSION_VARIABLE - setenv("ver", version_string); /* set version variable */ + env_set("ver", version_string); /* set version variable */ #endif /* CONFIG_VERSION_VARIABLE */
cli_init(); diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 4de81392b0..60a73311d9 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -249,7 +249,7 @@ config SPL_ENV_SUPPORT configuration. But some boards use this to support 'Falcon' boot on EXT2 and FAT, where SPL boots directly into Linux without starting U-Boot first. Enabling this option will make getenv() - and setenv() available in SPL. + and env_set() available in SPL.
config SPL_SAVEENV bool "Support save environment" diff --git a/common/spl/spl_dfu.c b/common/spl/spl_dfu.c index e8d0ba18e6..f5ec0fb396 100644 --- a/common/spl/spl_dfu.c +++ b/common/spl/spl_dfu.c @@ -46,7 +46,7 @@ int spl_dfu_cmd(int usbctrl, char *dfu_alt_info, char *interface, char *devstr) return -EINVAL; }
- ret = setenv("dfu_alt_info", str_env); + ret = env_set("dfu_alt_info", str_env); if (ret) { error("unable to set env variable "dfu_alt_info"!\n"); return -EINVAL; diff --git a/common/spl/spl_net.c b/common/spl/spl_net.c index 85fe508b17..88831097fa 100644 --- a/common/spl/spl_net.c +++ b/common/spl/spl_net.c @@ -33,14 +33,14 @@ static int spl_net_load_image(struct spl_image_info *spl_image,
env_init(); env_relocate(); - setenv("autoload", "yes"); + env_set("autoload", "yes"); rv = eth_initialize(); if (rv == 0) { printf("No Ethernet devices found\n"); return -ENODEV; } if (bootdev->boot_device_name) - setenv("ethact", bootdev->boot_device_name); + env_set("ethact", bootdev->boot_device_name); rv = net_loop(BOOTP); if (rv < 0) { printf("Problem booting with BOOTP\n"); diff --git a/common/update.c b/common/update.c index 0767fcbcb5..061a5541b1 100644 --- a/common/update.c +++ b/common/update.c @@ -67,7 +67,7 @@ static int update_load(char *filename, ulong msec_max, int cnt_max, ulong addr) tftp_timeout_count_max = cnt_max;
/* we don't want to retry the connection if errors occur */ - setenv("netretry", "no"); + env_set("netretry", "no");
/* download the update file */ load_addr = addr; @@ -83,7 +83,7 @@ static int update_load(char *filename, ulong msec_max, int cnt_max, ulong addr) tftp_timeout_ms = saved_timeout_msecs; tftp_timeout_count_max = saved_timeout_count;
- setenv("netretry", saved_netretry); + env_set("netretry", saved_netretry); if (saved_netretry != NULL) free(saved_netretry);
diff --git a/doc/README.enetaddr b/doc/README.enetaddr index 50e4899787..241d528ff7 100644 --- a/doc/README.enetaddr +++ b/doc/README.enetaddr @@ -98,12 +98,12 @@ if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { } /* enetaddr is now set to the value stored in the ethaddr env var */
- * int eth_setenv_enetaddr(char *name, const uchar *enetaddr); + * int eth_env_set_enetaddr(char *name, const uchar *enetaddr);
Store the MAC address into the named environment variable. The return value is -the same as the setenv() function. +the same as the env_set() function. uchar enetaddr[6] = { 0x00, 0x11, 0x22, 0x33, 0x44, 0x55 }; -eth_setenv_enetaddr("ethaddr", enetaddr); +eth_env_set_enetaddr("ethaddr", enetaddr); /* the "ethaddr" env var should now be set to "00:11:22:33:44:55" */
* the %pM format modifier diff --git a/drivers/bootcount/bootcount_env.c b/drivers/bootcount/bootcount_env.c index 7f22dd0748..ec5f942676 100644 --- a/drivers/bootcount/bootcount_env.c +++ b/drivers/bootcount/bootcount_env.c @@ -13,7 +13,7 @@ void bootcount_store(ulong a) int upgrade_available = getenv_ulong("upgrade_available", 10, 0);
if (upgrade_available) { - setenv_ulong("bootcount", a); + env_set_ulong("bootcount", a); env_save(); } } diff --git a/drivers/mtd/dataflash.c b/drivers/mtd/dataflash.c index 2d2c318adf..b20a2e0a8e 100644 --- a/drivers/mtd/dataflash.c +++ b/drivers/mtd/dataflash.c @@ -169,8 +169,9 @@ void AT91F_DataflashSetEnv (void) /* Set the environment according to the label...*/ if((env & FLAG_SETENV) == FLAG_SETENV) { start = dataflash_info[i].Device.area_list[j].start; - sprintf((char*) s,"%lX",start); - setenv((char*) area_list[part].label,(char*) s); + sprintf((char *)s, "%lX", start); + env_set((char *)area_list[part].label, + (char *)s); } part++; } diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 40be52070e..424c347e0e 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1097,7 +1097,7 @@ static int fec_probe(bd_t *bd, int dev_id, uint32_t base_addr, else strcpy(mac, "ethaddr"); if (!getenv(mac)) - eth_setenv_enetaddr(mac, ethaddr); + eth_env_set_enetaddr(mac, ethaddr); } return ret; err4: diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index 9fe34ad4a9..451dfded77 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -418,7 +418,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) rc = fman_upload_firmware(index, ®->fm_imem, addr); if (rc) return rc; - setenv_addr("fman_ucode", addr); + env_set_addr("fman_ucode", addr);
fm_init_muram(index, ®->muram); fm_init_qmi(®->fm_qmi_common); diff --git a/drivers/net/lan91c96.c b/drivers/net/lan91c96.c index 3526876d14..255c7010cc 100644 --- a/drivers/net/lan91c96.c +++ b/drivers/net/lan91c96.c @@ -710,7 +710,7 @@ static int smc_get_ethaddr(bd_t *bd, struct eth_device *dev) printf("\n*** ERROR: ethaddr is NOT set !!\n"); return -1; } - eth_setenv_enetaddr("ethaddr", v_mac); + eth_env_set_enetaddr("ethaddr", v_mac); }
smc_set_mac_addr(v_mac); /* use old function to update smc default */ diff --git a/drivers/net/ne2000_base.c b/drivers/net/ne2000_base.c index 377d87f04b..f6e5eafba5 100644 --- a/drivers/net/ne2000_base.c +++ b/drivers/net/ne2000_base.c @@ -723,7 +723,7 @@ static int ne2k_setup_driver(struct eth_device *dev) * returns -1 due to eth_getenv_enetaddr_by_index() failing, * and this causes "Warning: failed to set MAC address", and * cmd_bdinfo has no ethaddr value which it can show: */ - eth_setenv_enetaddr("ethaddr", dev->enetaddr); + eth_env_set_enetaddr("ethaddr", dev->enetaddr); } return 0; } diff --git a/drivers/net/sandbox-raw.c b/drivers/net/sandbox-raw.c index f5fa0e8533..590ae0c0fc 100644 --- a/drivers/net/sandbox-raw.c +++ b/drivers/net/sandbox-raw.c @@ -33,8 +33,8 @@ static int sb_eth_raw_start(struct udevice *dev)
if (strcmp(interface, "lo") == 0) { priv->local = 1; - setenv("ipaddr", "127.0.0.1"); - setenv("serverip", "127.0.0.1"); + env_set("ipaddr", "127.0.0.1"); + env_set("serverip", "127.0.0.1"); } return sandbox_eth_raw_os_start(interface, pdata->enetaddr, priv); } diff --git a/drivers/scsi/scsi.c b/drivers/scsi/scsi.c index 7ec7ecc295..f47628b2de 100644 --- a/drivers/scsi/scsi.c +++ b/drivers/scsi/scsi.c @@ -682,7 +682,7 @@ int scsi_scan(bool verbose)
printf("Found %d device(s).\n", scsi_max_devs); #ifndef CONFIG_SPL_BUILD - setenv_ulong("scsidevs", scsi_max_devs); + env_set_ulong("scsidevs", scsi_max_devs); #endif return 0; } diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 4137d76c42..d0105372cf 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -2685,7 +2685,7 @@ static int usb_eth_probe(struct udevice *dev) l_priv = priv;
get_ether_addr(CONFIG_USBNET_DEVADDR, pdata->enetaddr); - eth_setenv_enetaddr("usbnet_devaddr", pdata->enetaddr); + eth_env_set_enetaddr("usbnet_devaddr", pdata->enetaddr);
return 0; } diff --git a/fs/fs.c b/fs/fs.c index 595ff1fe69..055dffdafd 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -348,7 +348,7 @@ int do_size(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], if (fs_size(argv[3], &size) < 0) return CMD_RET_FAILURE;
return 0; } @@ -417,8 +417,8 @@ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], } puts("\n");
- setenv_hex("fileaddr", addr); - setenv_hex("filesize", len_read); + env_set_hex("fileaddr", addr); + env_set_hex("filesize", len_read);
return 0; } @@ -509,7 +509,7 @@ int do_fs_uuid(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], return CMD_RET_FAILURE;
if (argc == 4) - setenv(argv[3], uuid); + env_set(argv[3], uuid); else printf("%s\n", uuid);
@@ -529,7 +529,7 @@ int do_fs_type(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) info = fs_get_info(fs_type);
if (argc == 4) - setenv(argv[3], info->name); + env_set(argv[3], info->name); else printf("%s\n", info->name);
diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index db29489eca..8f1c9d167d 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -941,7 +941,7 @@ int ubifs_load(char *filename, u32 addr, u32 size)
err = ubifs_read(filename, (void *)(uintptr_t)addr, 0, size, &actread); if (err == 0) { - setenv_hex("filesize", actread); + env_set_hex("filesize", actread); printf("Done\n"); }
diff --git a/include/_exports.h b/include/_exports.h index 6ff4364e44..9deed77378 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -32,7 +32,7 @@ EXPORT_FUNC(do_reset, int, do_reset, cmd_tbl_t *, int , int , char * const []) EXPORT_FUNC(getenv, char *, getenv, const char*) - EXPORT_FUNC(setenv, int, setenv, const char *, const char *) + EXPORT_FUNC(env_set, int, env_set, const char *, const char *) EXPORT_FUNC(simple_strtoul, unsigned long, simple_strtoul, const char *, char **, unsigned int) EXPORT_FUNC(strict_strtoul, int, strict_strtoul, diff --git a/include/common.h b/include/common.h index f0fc02cd3b..57f53f54ed 100644 --- a/include/common.h +++ b/include/common.h @@ -335,19 +335,46 @@ ulong getenv_hex(const char *varname, ulong default_val); * Return -1 if variable does not exist (default to true) */ int getenv_yesno(const char *var); -int setenv (const char *, const char *); -int setenv_ulong(const char *varname, ulong value); -int setenv_hex(const char *varname, ulong value); + +/** + * env_set() - set an environment variable + * + * This sets or deletes the value of an environment variable. For setting the + * value the variable is created if it does not already exist. + * + * @varname: Variable to adjust + * @value: Value to set for the variable, or NULL or "" to delete the variable + * @return 0 if OK, 1 on error + */ +int env_set(const char *varname, const char *value); + +/** + * env_set_ulong() - set an environment variable to an integer + * + * @varname: Variable to adjust + * @value: Value to set for the variable (will be converted to a string) + * @return 0 if OK, 1 on error + */ +int env_set_ulong(const char *varname, ulong value); + +/** + * env_set_hex() - set an environment variable to a hex value + * + * @varname: Variable to adjust + * @value: Value to set for the variable (will be converted to a hex string) + * @return 0 if OK, 1 on error + */ +int env_set_hex(const char *varname, ulong value); /** - * setenv_addr - Set an environment variable to an address in hex + * env_set_addr - Set an environment variable to an address in hex * * @varname: Environment variable to set * @addr: Value to set it to * @return 0 if ok, 1 on error */ -static inline int setenv_addr(const char *varname, const void *addr) +static inline int env_set_addr(const char *varname, const void *addr) { - return setenv_hex(varname, (ulong)addr); + return env_set_hex(varname, (ulong)addr); }
#ifdef CONFIG_AUTO_COMPLETE diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index dbf4496167..4f2ede6139 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -345,7 +345,7 @@ do { \ else \ strcpy(ethname, "ethaddr"); \ printf("Setting %s from EEPROM with %s\n", ethname, buf);\ - setenv(ethname, buf); \ + env_set(ethname, buf); \ } \ } while (0)
diff --git a/include/exports.h b/include/exports.h index 1d81bc4b28..6522d78fac 100644 --- a/include/exports.h +++ b/include/exports.h @@ -28,7 +28,7 @@ int vprintf(const char *, va_list); unsigned long simple_strtoul(const char *cp, char **endp, unsigned int base); int strict_strtoul(const char *cp, unsigned int base, unsigned long *res); char *getenv (const char *name); -int setenv (const char *varname, const char *varvalue); +int env_set(const char *varname, const char *value); long simple_strtol(const char *cp, char **endp, unsigned int base); int strcmp(const char *cs, const char *ct); unsigned long ustrtoul(const char *cp, char **endp, unsigned int base); diff --git a/include/fsl_validate.h b/include/fsl_validate.h index 452c6df83f..b0971651eb 100644 --- a/include/fsl_validate.h +++ b/include/fsl_validate.h @@ -273,7 +273,7 @@ int fsl_secboot_blob_decap(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
int fsl_check_boot_mode_secure(void); -int fsl_setenv_chain_of_trust(void); +int fsl_env_set_chain_of_trust(void);
/* * This function is used to validate the main U-boot binary from diff --git a/include/net.h b/include/net.h index 2eaa88224c..65ab7b2c79 100644 --- a/include/net.h +++ b/include/net.h @@ -240,10 +240,10 @@ void eth_set_current(void); /* set nterface to ethcur var */ int eth_get_dev_index(void); /* get the device index */ void eth_parse_enetaddr(const char *addr, uchar *enetaddr); int eth_getenv_enetaddr(const char *name, uchar *enetaddr); -int eth_setenv_enetaddr(const char *name, const uchar *enetaddr); +int eth_env_set_enetaddr(const char *name, const uchar *enetaddr);
/** - * eth_setenv_enetaddr_by_index() - set the MAC address environment variable + * eth_env_set_enetaddr_by_index() - set the MAC address environment variable * * This sets up an environment variable with the given MAC address (@enetaddr). * The environment variable to be set is defined by <@base_name><@index>addr. @@ -255,7 +255,7 @@ int eth_setenv_enetaddr(const char *name, const uchar *enetaddr); * @enetaddr: Pointer to MAC address to put into the variable * @return 0 if OK, other value on error */ -int eth_setenv_enetaddr_by_index(const char *base_name, int index, +int eth_env_set_enetaddr_by_index(const char *base_name, int index, uchar *enetaddr);
diff --git a/include/search.h b/include/search.h index 402dfd84fb..df5d61c2eb 100644 --- a/include/search.h +++ b/include/search.h @@ -118,7 +118,7 @@ extern int hwalk_r(struct hsearch_data *__htab, int (*callback)(ENTRY *)); #define H_MATCH_SUBSTR (1 << 7) /* search for substring matches */ #define H_MATCH_REGEX (1 << 8) /* search for regular expression matches */ #define H_MATCH_METHOD (H_MATCH_IDENT | H_MATCH_SUBSTR | H_MATCH_REGEX) -#define H_PROGRAMMATIC (1 << 9) /* indicate that an import is from setenv() */ +#define H_PROGRAMMATIC (1 << 9) /* indicate that an import is from env_set() */ #define H_ORIGIN_FLAGS (H_INTERACTIVE | H_PROGRAMMATIC)
#endif /* _SEARCH_H_ */ diff --git a/lib/uuid.c b/lib/uuid.c index c8584edcb8..1536c027da 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -291,7 +291,7 @@ int do_uuid(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (argc == 1) printf("%s\n", uuid); else - setenv(argv[1], uuid); + env_set(argv[1], uuid);
return CMD_RET_SUCCESS; } diff --git a/net/arp.c b/net/arp.c index f3ceff9ed8..4c79e09ccb 100644 --- a/net/arp.c +++ b/net/arp.c @@ -194,7 +194,7 @@ void arp_receive(struct ethernet_hdr *et, struct ip_udp_hdr *ip, int len) if (net_server_ip.s_addr == net_arp_wait_packet_ip.s_addr) { char buf[20]; sprintf(buf, "%pM", &arp->ar_sha); - setenv("serveraddr", buf); + env_set("serveraddr", buf); } #endif
diff --git a/net/bootp.c b/net/bootp.c index be8f710e0c..579515687b 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -170,7 +170,7 @@ static void store_net_params(struct bootp_hdr *bp) * not contain a new value */ if (*net_boot_file_name) - setenv("bootfile", net_boot_file_name); + env_set("bootfile", net_boot_file_name); #endif net_copy_ip(&net_ip, &bp->bp_yiaddr); } diff --git a/net/dns.c b/net/dns.c index 7017bac75a..eee8a02f7c 100644 --- a/net/dns.c +++ b/net/dns.c @@ -184,7 +184,7 @@ static void dns_handler(uchar *pkt, unsigned dest, struct in_addr sip, ip_to_string(ip_addr, ip_str); printf("%s\n", ip_str); if (net_dns_env_var) - setenv(net_dns_env_var, ip_str); + env_set(net_dns_env_var, ip_str); } else { puts("server responded with invalid IP number\n"); } diff --git a/net/eth-uclass.c b/net/eth-uclass.c index b659961a5d..d356576210 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -510,7 +510,7 @@ static int eth_post_probe(struct udevice *dev) /* Override the ROM MAC address */ memcpy(pdata->enetaddr, env_enetaddr, ARP_HLEN); } else if (is_valid_ethaddr(pdata->enetaddr)) { - eth_setenv_enetaddr_by_index("eth", dev->seq, pdata->enetaddr); + eth_env_set_enetaddr_by_index("eth", dev->seq, pdata->enetaddr); printf("\nWarning: %s using MAC address from ROM\n", dev->name); } else if (is_zero_ethaddr(pdata->enetaddr) || diff --git a/net/eth_common.c b/net/eth_common.c index 58fa295771..7b36532ee1 100644 --- a/net/eth_common.c +++ b/net/eth_common.c @@ -30,7 +30,7 @@ int eth_getenv_enetaddr(const char *name, uchar *enetaddr) return is_valid_ethaddr(enetaddr); }
-int eth_setenv_enetaddr(const char *name, const uchar *enetaddr) +int eth_env_set_enetaddr(const char *name, const uchar *enetaddr) { char buf[ARP_HLEN_ASCII + 1];
@@ -39,7 +39,7 @@ int eth_setenv_enetaddr(const char *name, const uchar *enetaddr)
sprintf(buf, "%pM", enetaddr);
- return setenv(name, buf); + return env_set(name, buf); }
int eth_getenv_enetaddr_by_index(const char *base_name, int index, @@ -50,12 +50,12 @@ int eth_getenv_enetaddr_by_index(const char *base_name, int index, return eth_getenv_enetaddr(enetvar, enetaddr); }
-int eth_setenv_enetaddr_by_index(const char *base_name, int index, +int eth_env_set_enetaddr_by_index(const char *base_name, int index, uchar *enetaddr) { char enetvar[32]; sprintf(enetvar, index ? "%s%daddr" : "%saddr", base_name, index); - return eth_setenv_enetaddr(enetvar, enetaddr); + return eth_env_set_enetaddr(enetvar, enetaddr); }
void eth_common_init(void) @@ -97,14 +97,14 @@ void eth_current_changed(void) /* update current ethernet name */ if (eth_get_dev()) { if (act == NULL || strcmp(act, eth_get_name()) != 0) - setenv("ethact", eth_get_name()); + env_set("ethact", eth_get_name()); } /* * remove the variable completely if there is no active * interface */ else if (act != NULL) - setenv("ethact", NULL); + env_set("ethact", NULL); }
void eth_try_another(int first_restart) diff --git a/net/eth_internal.h b/net/eth_internal.h index a14b20844f..4b0e716b73 100644 --- a/net/eth_internal.h +++ b/net/eth_internal.h @@ -13,7 +13,7 @@ void eth_common_init(void);
/** - * eth_setenv_enetaddr_by_index() - set the MAC address environment variable + * eth_env_set_enetaddr_by_index() - set the MAC address environment variable * * This sets up an environment variable with the given MAC address (@enetaddr). * The environment variable to be set is defined by <@base_name><@index>addr. @@ -25,7 +25,7 @@ void eth_common_init(void); * @enetaddr: Pointer to MAC address to put into the variable * @return 0 if OK, other value on error */ -int eth_setenv_enetaddr_by_index(const char *base_name, int index, +int eth_env_set_enetaddr_by_index(const char *base_name, int index, uchar *enetaddr);
int eth_mac_skip(int index); diff --git a/net/eth_legacy.c b/net/eth_legacy.c index e4bd0f4c1a..2608302648 100644 --- a/net/eth_legacy.c +++ b/net/eth_legacy.c @@ -152,8 +152,8 @@ int eth_write_hwaddr(struct eth_device *dev, const char *base_name,
memcpy(dev->enetaddr, env_enetaddr, ARP_HLEN); } else if (is_valid_ethaddr(dev->enetaddr)) { - eth_setenv_enetaddr_by_index(base_name, eth_number, - dev->enetaddr); + eth_env_set_enetaddr_by_index(base_name, eth_number, + dev->enetaddr); } else if (is_zero_ethaddr(dev->enetaddr)) { #ifdef CONFIG_NET_RANDOM_ETHADDR net_random_ethaddr(dev->enetaddr); diff --git a/net/net.c b/net/net.c index 6e678770fa..2fed28092d 100644 --- a/net/net.c +++ b/net/net.c @@ -616,8 +616,8 @@ restart: if (net_boot_file_size > 0) { printf("Bytes transferred = %d (%x hex)\n", net_boot_file_size, net_boot_file_size); - setenv_hex("filesize", net_boot_file_size); - setenv_hex("fileaddr", load_addr); + env_set_hex("filesize", net_boot_file_size); + env_set_hex("fileaddr", load_addr); } if (protocol != NETCONS) eth_halt(); diff --git a/test/dm/eth.c b/test/dm/eth.c index 564ad36916..f824d704c6 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -26,15 +26,15 @@ static int dm_test_eth(struct unit_test_state *uts) { net_ping_ip = string_to_ip("1.1.2.2");
- setenv("ethact", "eth@10002000"); + env_set("ethact", "eth@10002000"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10002000", getenv("ethact"));
- setenv("ethact", "eth@10003000"); + env_set("ethact", "eth@10003000"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10003000", getenv("ethact"));
- setenv("ethact", "eth@10004000"); + env_set("ethact", "eth@10004000"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10004000", getenv("ethact"));
@@ -45,20 +45,20 @@ DM_TEST(dm_test_eth, DM_TESTF_SCAN_FDT); static int dm_test_eth_alias(struct unit_test_state *uts) { net_ping_ip = string_to_ip("1.1.2.2"); - setenv("ethact", "eth0"); + env_set("ethact", "eth0"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10002000", getenv("ethact"));
- setenv("ethact", "eth1"); + env_set("ethact", "eth1"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10004000", getenv("ethact"));
/* Expected to fail since eth2 is not defined in the device tree */ - setenv("ethact", "eth2"); + env_set("ethact", "eth2"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10002000", getenv("ethact"));
- setenv("ethact", "eth5"); + env_set("ethact", "eth5"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10003000", getenv("ethact"));
@@ -71,14 +71,14 @@ static int dm_test_eth_prime(struct unit_test_state *uts) net_ping_ip = string_to_ip("1.1.2.2");
/* Expected to be "eth@10003000" because of ethprime variable */ - setenv("ethact", NULL); - setenv("ethprime", "eth5"); + env_set("ethact", NULL); + env_set("ethprime", "eth5"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10003000", getenv("ethact"));
/* Expected to be "eth@10002000" because it is first */ - setenv("ethact", NULL); - setenv("ethprime", NULL); + env_set("ethact", NULL); + env_set("ethprime", NULL); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10002000", getenv("ethact"));
@@ -121,26 +121,26 @@ static int dm_test_eth_act(struct unit_test_state *uts) /* Invalidate MAC address */ strcpy(ethaddr[i], getenv(addrname[i])); /* Must disable access protection for ethaddr before clearing */ - setenv(".flags", addrname[i]); - setenv(addrname[i], NULL); + env_set(".flags", addrname[i]); + env_set(addrname[i], NULL); }
/* Set ethact to "eth@10002000" */ - setenv("ethact", ethname[0]); + env_set("ethact", ethname[0]);
/* Segment fault might happen if something is wrong */ ut_asserteq(-ENODEV, net_loop(PING));
for (i = 0; i < DM_TEST_ETH_NUM; i++) { /* Restore the env */ - setenv(".flags", addrname[i]); - setenv(addrname[i], ethaddr[i]); + env_set(".flags", addrname[i]); + env_set(addrname[i], ethaddr[i]);
/* Probe the device again */ ut_assertok(device_probe(dev[i])); } - setenv(".flags", NULL); - setenv("ethact", NULL); + env_set(".flags", NULL); + env_set("ethact", NULL);
return 0; } @@ -150,13 +150,13 @@ DM_TEST(dm_test_eth_act, DM_TESTF_SCAN_FDT); static int _dm_test_eth_rotate1(struct unit_test_state *uts) { /* Make sure that the default is to rotate to the next interface */ - setenv("ethact", "eth@10004000"); + env_set("ethact", "eth@10004000"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10002000", getenv("ethact"));
/* If ethrotate is no, then we should fail on a bad MAC */ - setenv("ethact", "eth@10004000"); - setenv("ethrotate", "no"); + env_set("ethact", "eth@10004000"); + env_set("ethrotate", "no"); ut_asserteq(-EINVAL, net_loop(PING)); ut_asserteq_str("eth@10004000", getenv("ethact"));
@@ -166,12 +166,12 @@ static int _dm_test_eth_rotate1(struct unit_test_state *uts) static int _dm_test_eth_rotate2(struct unit_test_state *uts) { /* Make sure we can skip invalid devices */ - setenv("ethact", "eth@10004000"); + env_set("ethact", "eth@10004000"); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10004000", getenv("ethact"));
/* Make sure we can handle device name which is not eth# */ - setenv("ethact", "sbe5"); + env_set("ethact", "sbe5"); ut_assertok(net_loop(PING)); ut_asserteq_str("sbe5", getenv("ethact"));
@@ -189,29 +189,29 @@ static int dm_test_eth_rotate(struct unit_test_state *uts) /* Invalidate eth1's MAC address */ strcpy(ethaddr, getenv("eth1addr")); /* Must disable access protection for eth1addr before clearing */ - setenv(".flags", "eth1addr"); - setenv("eth1addr", NULL); + env_set(".flags", "eth1addr"); + env_set("eth1addr", NULL);
retval = _dm_test_eth_rotate1(uts);
/* Restore the env */ - setenv("eth1addr", ethaddr); - setenv("ethrotate", NULL); + env_set("eth1addr", ethaddr); + env_set("ethrotate", NULL);
if (!retval) { /* Invalidate eth0's MAC address */ strcpy(ethaddr, getenv("ethaddr")); /* Must disable access protection for ethaddr before clearing */ - setenv(".flags", "ethaddr"); - setenv("ethaddr", NULL); + env_set(".flags", "ethaddr"); + env_set("ethaddr", NULL);
retval = _dm_test_eth_rotate2(uts);
/* Restore the env */ - setenv("ethaddr", ethaddr); + env_set("ethaddr", ethaddr); } /* Restore the env */ - setenv(".flags", NULL); + env_set(".flags", NULL);
return retval; } @@ -225,8 +225,8 @@ static int _dm_test_net_retry(struct unit_test_state *uts) * the active device should be eth0 */ sandbox_eth_disable_response(1, true); - setenv("ethact", "eth@10004000"); - setenv("netretry", "yes"); + env_set("ethact", "eth@10004000"); + env_set("netretry", "yes"); sandbox_eth_skip_timeout(); ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10002000", getenv("ethact")); @@ -235,8 +235,8 @@ static int _dm_test_net_retry(struct unit_test_state *uts) * eth1 is disabled and netretry is no, so the ping should fail and the * active device should be eth1 */ - setenv("ethact", "eth@10004000"); - setenv("netretry", "no"); + env_set("ethact", "eth@10004000"); + env_set("netretry", "no"); sandbox_eth_skip_timeout(); ut_asserteq(-ETIMEDOUT, net_loop(PING)); ut_asserteq_str("eth@10004000", getenv("ethact")); @@ -253,7 +253,7 @@ static int dm_test_net_retry(struct unit_test_state *uts) retval = _dm_test_net_retry(uts);
/* Restore the env */ - setenv("netretry", NULL); + env_set("netretry", NULL); sandbox_eth_disable_response(1, false);
return retval; diff --git a/tools/env/fw_env_main.c b/tools/env/fw_env_main.c index b8bff264eb..748deadd09 100644 --- a/tools/env/fw_env_main.c +++ b/tools/env/fw_env_main.c @@ -183,7 +183,7 @@ int parse_printenv_args(int argc, char *argv[]) return 0; }
-int parse_setenv_args(int argc, char *argv[]) +int parse_env_set_args(int argc, char *argv[]) { int c;
@@ -236,7 +236,7 @@ int main(int argc, char *argv[]) if (parse_printenv_args(argc, argv)) exit(EXIT_FAILURE); } else { - if (parse_setenv_args(argc, argv)) + if (parse_env_set_args(argc, argv)) exit(EXIT_FAILURE); }
On Sun, Jul 23, 2017 at 09:20:06PM -0600, Simon Glass wrote:
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h.
Suggested-by: Wolfgang Denk wd@denx.de Signed-off-by: Simon Glass sjg@chromium.org
Changes in v2:
- Add new patch to rename setenv() and friends to env_set()
[snip]
214 files changed, 630 insertions(+), 599 deletions(-)
This gets pretty massive, and the "and friends" includes things like eth_setenv_enetaddr and fsl_setenv_chain_of_trust. Wolfgang, since it was your suggestion, how about we just rename setenv() to env_set() to match the rest and leave "and friends" alone? Thanks!
Hi Tom,
Changes in v2:
[snip]
I'm fine with that. It does leave some inconsistency though. Is that the end state you want?
On Wed, Jul 26, 2017 at 10:28:38AM -0600, Simon Glass wrote:
Hi Tom,
Changes in v2:
[snip]
Honestly? I think so, yes. "^setenv()$" becoming "^env_set()$" to match the rest of the "^env_xxx()$" API makes sense to me, while "^eth_setenv_enetaddr()$" and "^fsl_setenv_chain_of_trust()$" are other namespaces and at least should be stand-alone patches that their respective custodians ack and pickup. YMMV on if those different names make it clearer in those cases, but making it clear setenv() is part of the env_xxx family is an improvement in my mind. And %s/set/get/ as well, for the follow-up patch of course.
Hi Tom,
Changes in v2:
[snip]
And now, trying to be clear has bit me. setenv_hex, etc, are part of the "env" API and should also be renamed for clarity.
Hi Tom,
Hi Tom,
Changes in v2:
[snip]
OK, sounds good. I'll redo those two patches, but please go ahead and take whatever you can from that series, then I'll rebase. I should have more time next week.
On Wed, Jul 26, 2017 at 12:34:33PM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Changes in v2:
[snip]
Will do. I think it's the first 10 or 11 I can pick up now and then we hit the one with the TODOs.
Suggested-by: Wolfgang Denk wd@denx.de Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Add new patch to rename getenv() and friends to env_get()
README | 2 +- api/api.c | 2 +- arch/arc/lib/bootm.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 +- arch/arm/lib/bootm.c | 6 +-- arch/arm/mach-davinci/misc.c | 2 +- arch/arm/mach-imx/video.c | 2 +- arch/arm/mach-keystone/ddr3.c | 2 +- arch/arm/mach-keystone/keystone.c | 2 +- arch/arm/mach-kirkwood/cpu.c | 4 +- arch/arm/mach-omap2/utils.c | 8 ++-- arch/arm/mach-tegra/tegra186/nvtboot_board.c | 2 +- arch/arm/mach-uniphier/board_late_init.c | 2 +- arch/m68k/lib/bootm.c | 3 +- arch/microblaze/lib/bootm.c | 2 +- arch/mips/lib/bootm.c | 6 +-- arch/nds32/lib/bootm.c | 4 +- arch/nios2/lib/bootm.c | 2 +- arch/powerpc/cpu/mpc85xx/cpu_init.c | 10 ++-- arch/powerpc/cpu/mpc85xx/fdt.c | 4 +- arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c | 2 +- arch/powerpc/cpu/mpc85xx/mp.c | 2 +- arch/powerpc/lib/bootm.c | 11 +++-- arch/sh/lib/bootm.c | 2 +- arch/sh/lib/zimageboot.c | 2 +- arch/x86/lib/zimage.c | 8 ++-- arch/xtensa/lib/bootm.c | 2 +- board/Arcturus/ucp1020/cmd_arc.c | 6 +-- board/Arcturus/ucp1020/ucp1020.c | 14 +++--- board/Barix/ipam390/ipam390.c | 2 +- board/BuR/brxre1/board.c | 6 +-- board/BuR/common/common.c | 52 ++++++++++----------- board/BuS/eb_cpu5282/eb_cpu5282.c | 8 ++-- board/CarMediaLab/flea3/flea3.c | 2 +- board/LaCie/net2big_v2/net2big_v2.c | 2 +- board/LaCie/netspace_v2/netspace_v2.c | 2 +- board/amazon/kc1/kc1.c | 2 +- board/amlogic/odroid-c2/odroid-c2.c | 4 +- board/aristainetos/aristainetos-v2.c | 4 +- board/atmel/sama5d2_xplained/sama5d2_xplained.c | 2 +- board/birdland/bav335x/board.c | 4 +- board/bluegiga/apx4devkit/apx4devkit.c | 4 +- board/bluewater/gurnard/gurnard.c | 6 +-- board/bosch/shc/board.c | 2 +- board/boundary/nitrogen6x/nitrogen6x.c | 8 ++-- board/broadcom/bcm23550_w1d/bcm23550_w1d.c | 2 +- board/broadcom/bcm28155_ap/bcm28155_ap.c | 2 +- board/buffalo/lsxl/lsxl.c | 2 +- board/cadence/xtfpga/xtfpga.c | 2 +- board/compulab/cl-som-am57x/eth.c | 4 +- board/compulab/cm_fx6/cm_fx6.c | 10 ++-- board/compulab/cm_t335/cm_t335.c | 2 +- board/compulab/cm_t35/cm_t35.c | 2 +- board/compulab/cm_t3517/cm_t3517.c | 2 +- board/compulab/cm_t54/cm_t54.c | 4 +- board/compulab/common/omap3_display.c | 4 +- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 4 +- board/davinci/da8xxevm/da850evm.c | 4 +- board/davinci/da8xxevm/omapl138_lcdk.c | 4 +- board/esd/meesc/meesc.c | 7 +-- board/freescale/b4860qds/b4860qds.c | 8 ++-- board/freescale/bsc9131rdb/bsc9131rdb.c | 4 +- board/freescale/bsc9132qds/bsc9132qds.c | 4 +- board/freescale/c29xpcie/c29xpcie.c | 4 +- board/freescale/common/sys_eeprom.c | 2 +- board/freescale/common/vid.c | 4 +- board/freescale/corenet_ds/corenet_ds.c | 4 +- board/freescale/ls2080aqds/eth.c | 6 +-- board/freescale/ls2080aqds/ls2080aqds.c | 2 +- board/freescale/ls2080ardb/ls2080ardb.c | 2 +- board/freescale/mpc837xemds/pci.c | 2 +- board/freescale/mpc837xerdb/mpc837xerdb.c | 2 +- board/freescale/mpc8572ds/mpc8572ds.c | 4 +- board/freescale/mx51evk/mx51evk_video.c | 2 +- board/freescale/mx53loco/mx53loco_video.c | 2 +- board/freescale/p1010rdb/p1010rdb.c | 4 +- board/freescale/p1022ds/p1022ds.c | 4 +- board/freescale/p1023rdb/p1023rdb.c | 4 +- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 7 +-- board/freescale/p1_twr/p1_twr.c | 4 +- board/freescale/p2041rdb/p2041rdb.c | 4 +- board/freescale/t102xqds/t102xqds.c | 4 +- board/freescale/t102xrdb/t102xrdb.c | 4 +- board/freescale/t1040qds/t1040qds.c | 4 +- board/freescale/t104xrdb/t104xrdb.c | 4 +- board/freescale/t208xqds/t208xqds.c | 4 +- board/freescale/t208xrdb/t208xrdb.c | 4 +- board/freescale/t4qds/t4240emu.c | 4 +- board/freescale/t4qds/t4240qds.c | 6 +-- board/freescale/t4rdb/t4240rdb.c | 4 +- board/gateworks/gw_ventana/common.c | 2 +- board/gateworks/gw_ventana/gw_ventana.c | 34 +++++++------- board/gateworks/gw_ventana/gw_ventana_spl.c | 4 +- board/gdsys/a38x/keyprogram.c | 4 +- board/gdsys/mpc8308/hrcon.c | 2 +- board/gdsys/mpc8308/strider.c | 2 +- board/gdsys/p1022/controlcenterd-id.c | 10 ++-- board/gdsys/p1022/controlcenterd.c | 6 +-- board/grinn/chiliboard/board.c | 4 +- board/grinn/liteboard/board.c | 2 +- board/gumstix/pepper/board.c | 2 +- board/highbank/highbank.c | 2 +- board/isee/igep003x/board.c | 2 +- board/keymile/common/common.c | 10 ++-- board/keymile/common/ivm.c | 6 +-- board/keymile/km_arm/km_arm.c | 2 +- board/keymile/kmp204x/kmp204x.c | 6 +-- board/kosagi/novena/novena.c | 2 +- board/lg/sniper/sniper.c | 2 +- board/liebherr/mccmon6/mccmon6.c | 4 +- board/logicpd/omap3som/omap3logic.c | 2 +- board/logicpd/zoom1/zoom1.c | 2 +- board/micronas/vct/vct.c | 2 +- board/nokia/rx51/rx51.c | 8 ++-- board/phytec/pcm051/board.c | 2 +- board/raspberrypi/rpi/rpi.c | 12 ++--- board/renesas/alt/alt.c | 2 +- board/renesas/blanche/blanche.c | 2 +- board/renesas/gose/gose.c | 2 +- board/renesas/koelsch/koelsch.c | 2 +- board/renesas/lager/lager.c | 2 +- board/renesas/porter/porter.c | 2 +- board/renesas/silk/silk.c | 2 +- board/renesas/stout/stout.c | 2 +- board/samsung/common/exynos5-dt.c | 2 +- board/samsung/odroid/odroid.c | 2 +- board/samtec/vining_2000/vining_2000.c | 2 +- board/samtec/vining_fpga/socfpga.c | 6 +-- board/siemens/common/board.c | 4 +- board/siemens/taurus/taurus.c | 18 ++++---- board/silica/pengwyn/board.c | 2 +- board/socrates/socrates.c | 4 +- board/spear/common/spr_misc.c | 2 +- board/st/stm32f429-discovery/stm32f429-discovery.c | 2 +- board/sunxi/board.c | 6 +-- board/syteco/zmx25/zmx25.c | 2 +- board/tcl/sl50/board.c | 6 +-- board/technexion/twister/twister.c | 2 +- board/teejet/mt_ventoux/mt_ventoux.c | 4 +- board/theobroma-systems/puma_rk3399/puma-rk3399.c | 6 +-- board/ti/am335x/board.c | 6 +-- board/ti/am43xx/board.c | 4 +- board/ti/am57xx/board.c | 6 +-- board/ti/dra7xx/evm.c | 6 +-- board/ti/evm/evm.c | 2 +- board/ti/ks2_evm/board.c | 12 ++--- board/ti/ti814x/evm.c | 2 +- board/ti/ti816x/evm.c | 2 +- board/timll/devkit8000/devkit8000.c | 2 +- board/toradex/apalis_imx6/apalis_imx6.c | 2 +- board/toradex/common/tdx-cfg-block.c | 2 +- board/toradex/common/tdx-common.c | 4 +- board/varisys/common/sys_eeprom.c | 2 +- board/varisys/cyrus/cyrus.c | 4 +- board/vscom/baltos/board.c | 2 +- .../work-microwave/work_92105/work_92105_display.c | 2 +- board/xes/common/board.c | 6 +-- board/xilinx/zynqmp/zynqmp.c | 4 +- cmd/bdinfo.c | 6 +-- cmd/bootm.c | 4 +- cmd/bootmenu.c | 4 +- cmd/cramfs.c | 8 ++-- cmd/elf.c | 32 ++++++------- cmd/fdt.c | 2 +- cmd/fpga.c | 4 +- cmd/gpt.c | 4 +- cmd/ini.c | 4 +- cmd/itest.c | 2 +- cmd/jffs2.c | 4 +- cmd/load.c | 10 ++-- cmd/log.c | 6 ++- cmd/md5sum.c | 2 +- cmd/mtdparts.c | 16 +++---- cmd/mvebu/bubt.c | 2 +- cmd/nand.c | 6 +-- cmd/net.c | 6 +-- cmd/nvedit.c | 18 ++++---- cmd/pxe.c | 27 ++++++----- cmd/qfw.c | 4 +- cmd/reiser.c | 6 +-- cmd/setexpr.c | 2 +- cmd/source.c | 2 +- cmd/trace.c | 6 +-- cmd/ximg.c | 2 +- cmd/zfs.c | 4 +- common/autoboot.c | 18 ++++---- common/board_f.c | 4 +- common/board_r.c | 18 ++++---- common/bootm.c | 12 ++--- common/bootm_os.c | 10 ++-- common/bootretry.c | 2 +- common/cli.c | 2 +- common/cli_hush.c | 14 +++--- common/cli_simple.c | 4 +- common/console.c | 10 ++-- common/fb_mmc.c | 2 +- common/fdt_support.c | 6 +-- common/hash.c | 2 +- common/hwconfig.c | 2 +- common/image-android.c | 2 +- common/image-fdt.c | 6 +-- common/image.c | 32 +++++++------ common/lcd.c | 2 +- common/main.c | 2 +- common/spl/Kconfig | 2 +- common/spl/spl_dfu.c | 2 +- common/spl/spl_ext.c | 4 +- common/spl/spl_fat.c | 4 +- common/splash.c | 2 +- common/splash_source.c | 6 +-- common/update.c | 7 +-- common/usb_hub.c | 2 +- common/usb_kbd.c | 6 +-- disk/part.c | 2 +- disk/part_amiga.c | 4 +- doc/README.enetaddr | 4 +- drivers/bootcount/bootcount_env.c | 6 +-- drivers/ddr/fsl/fsl_ddr_gen4.c | 2 +- drivers/ddr/fsl/interactive.c | 8 ++-- drivers/ddr/fsl/options.c | 6 +-- drivers/dfu/dfu.c | 6 +-- drivers/dfu/dfu_mmc.c | 2 +- drivers/input/i8042.c | 2 +- drivers/input/input.c | 2 +- drivers/mtd/cfi_flash.c | 2 +- drivers/net/dc2114x.c | 2 +- drivers/net/fec_mxc.c | 2 +- drivers/net/fm/b4860.c | 2 +- drivers/net/fm/fdt.c | 2 +- drivers/net/fsl-mc/mc.c | 10 ++-- drivers/net/fsl_mcdmafec.c | 4 +- drivers/net/ftgmac100.c | 2 +- drivers/net/ftmac100.c | 2 +- drivers/net/lan91c96.c | 2 +- drivers/net/mcffec.c | 8 ++-- drivers/net/ne2000_base.c | 4 +- drivers/net/netconsole.c | 14 +++--- drivers/net/phy/micrel.c | 2 +- drivers/net/sh_eth.c | 2 +- drivers/pci/fsl_pci_init.c | 4 +- drivers/pci/pci.c | 4 +- drivers/pci/pci_common.c | 2 +- drivers/rtc/m41t60.c | 2 +- drivers/serial/usbtty.c | 9 ++-- drivers/usb/gadget/designware_udc.c | 2 +- drivers/usb/gadget/ether.c | 12 ++--- drivers/usb/gadget/f_dfu.c | 2 +- drivers/usb/gadget/f_fastboot.c | 6 +-- drivers/usb/host/ehci-fsl.c | 2 +- drivers/video/ati_radeon_fb.c | 3 +- drivers/video/cfb_console.c | 2 +- drivers/video/ct69000.c | 3 +- drivers/video/mb862xx.c | 3 +- drivers/video/mx3fb.c | 2 +- drivers/video/mxsfb.c | 2 +- drivers/video/videomodes.c | 5 +- env/callback.c | 2 +- env/common.c | 8 ++-- env/flags.c | 10 ++-- fs/fs.c | 4 +- include/_exports.h | 2 +- include/asm-generic/global_data.h | 2 +- include/common.h | 53 +++++++++++++++++----- include/environment.h | 2 +- include/exports.h | 2 +- include/image.h | 8 ++-- include/net.h | 6 +-- lib/fdtdec.c | 2 +- lib/smbios.c | 2 +- net/bootp.c | 12 ++--- net/eth-uclass.c | 8 ++-- net/eth_common.c | 22 ++++----- net/eth_legacy.c | 4 +- net/link_local.c | 2 +- net/net.c | 10 ++-- net/net_rand.h | 2 +- net/tftp.c | 10 ++-- post/post.c | 2 +- test/command_ut.c | 16 +++---- test/dm/eth.c | 36 +++++++-------- tools/env/fw_env.c | 2 +- tools/env/fw_env.h | 4 +- 282 files changed, 756 insertions(+), 716 deletions(-)
diff --git a/README b/README index 6084b8e553..dc4b17f6ac 100644 --- a/README +++ b/README @@ -3455,7 +3455,7 @@ but it can not erase, write this NOR flash by SRIO or PCIE interface.
Please note that the environment is read-only until the monitor has been relocated to RAM and a RAM copy of the environment has been -created; also, when using EEPROM you will have to use getenv_f() +created; also, when using EEPROM you will have to use env_get_f() until then to read environment variables.
The environment is protected by a CRC32 checksum. Before the monitor diff --git a/api/api.c b/api/api.c index 2e620e2a0f..24be170148 100644 --- a/api/api.c +++ b/api/api.c @@ -458,7 +458,7 @@ static int API_env_get(va_list ap) if ((value = (char **)va_arg(ap, uintptr_t)) == NULL) return API_EINVAL;
- *value = getenv(name); + *value = env_get(name);
return 0; } diff --git a/arch/arc/lib/bootm.c b/arch/arc/lib/bootm.c index 5798149046..a498ce5b29 100644 --- a/arch/arc/lib/bootm.c +++ b/arch/arc/lib/bootm.c @@ -85,7 +85,7 @@ static void boot_jump_linux(bootm_headers_t *images, int flag) r2 = (unsigned int)images->ft_addr; } else { r0 = 1; - r2 = (unsigned int)getenv("bootargs"); + r2 = (unsigned int)env_get("bootargs"); }
smp_set_core_boot_addr((unsigned long)kernel_entry, -1); diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 23f3809418..d33a6c636c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -95,7 +95,7 @@ static void erratum_a008514(void)
static unsigned long get_internval_val_mhz(void) { - char *interval = getenv(PLATFORM_CYCLE_ENV_VAR); + char *interval = env_get(PLATFORM_CYCLE_ENV_VAR); /* * interval is the number of platform cycles(MHz) between * wake up events generated by EPU. diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 704849bd0c..5c62d9c144 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -216,7 +216,7 @@ static void do_nonsec_virt_switch(void) /* Subcommand: PREP */ static void boot_prep_linux(bootm_headers_t *images) { - char *commandline = getenv("bootargs"); + char *commandline = env_get("bootargs");
if (IMAGE_ENABLE_OF_LIBFDT && images->ft_len) { #ifdef CONFIG_OF_LIBFDT @@ -273,7 +273,7 @@ __weak bool armv7_boot_nonsec_default(void) #ifdef CONFIG_ARMV7_NONSEC bool armv7_boot_nonsec(void) { - char *s = getenv("bootm_boot_mode"); + char *s = env_get("bootm_boot_mode"); bool nonsec = armv7_boot_nonsec_default();
if (s && !strcmp(s, "sec")) @@ -361,7 +361,7 @@ static void boot_jump_linux(bootm_headers_t *images, int flag) ulong addr = (ulong)kernel_entry | 1; kernel_entry = (void *)addr; #endif - s = getenv("machid"); + s = env_get("machid"); if (s) { if (strict_strtoul(s, 16, &machid) < 0) { debug("strict_strtoul failed!\n"); diff --git a/arch/arm/mach-davinci/misc.c b/arch/arm/mach-davinci/misc.c index 4441242cc7..461ff778c2 100644 --- a/arch/arm/mach-davinci/misc.c +++ b/arch/arm/mach-davinci/misc.c @@ -90,7 +90,7 @@ void davinci_sync_env_enetaddr(uint8_t *rom_enetaddr) uint8_t env_enetaddr[6]; int ret;
- ret = eth_getenv_enetaddr_by_index("eth", 0, env_enetaddr); + ret = eth_env_get_enetaddr_by_index("eth", 0, env_enetaddr); if (!ret) { /* * There is no MAC address in the environment, so we diff --git a/arch/arm/mach-imx/video.c b/arch/arm/mach-imx/video.c index 55242f0eaa..c670c5dfc9 100644 --- a/arch/arm/mach-imx/video.c +++ b/arch/arm/mach-imx/video.c @@ -10,7 +10,7 @@ int board_video_skip(void) { int i; int ret; - char const *panel = getenv("panel"); + char const *panel = env_get("panel");
if (!panel) { for (i = 0; i < display_count; i++) { diff --git a/arch/arm/mach-keystone/ddr3.c b/arch/arm/mach-keystone/ddr3.c index 4cad6a2d81..b2f5414a5c 100644 --- a/arch/arm/mach-keystone/ddr3.c +++ b/arch/arm/mach-keystone/ddr3.c @@ -331,7 +331,7 @@ void ddr3_check_ecc_int(u32 base) int ecc_test = 0; u32 value = __raw_readl(base + KS2_DDR3_ECC_INT_STATUS_OFFSET);
- env = getenv("ecc_test"); + env = env_get("ecc_test"); if (env) ecc_test = simple_strtol(env, NULL, 0);
diff --git a/arch/arm/mach-keystone/keystone.c b/arch/arm/mach-keystone/keystone.c index beb8a767c4..fcabfbd5c3 100644 --- a/arch/arm/mach-keystone/keystone.c +++ b/arch/arm/mach-keystone/keystone.c @@ -46,7 +46,7 @@ int misc_init_r(void) char *env; long ks2_debug = 0;
- env = getenv("ks2_debug"); + env = env_get("ks2_debug");
if (env) ks2_debug = simple_strtol(env, NULL, 0); diff --git a/arch/arm/mach-kirkwood/cpu.c b/arch/arm/mach-kirkwood/cpu.c index 4c9d3fde47..db2ff0311c 100644 --- a/arch/arm/mach-kirkwood/cpu.c +++ b/arch/arm/mach-kirkwood/cpu.c @@ -129,7 +129,7 @@ int kw_config_adr_windows(void) static void kw_sysrst_action(void) { int ret; - char *s = getenv("sysrstcmd"); + char *s = env_get("sysrstcmd");
if (!s) { debug("Error.. %s failed, check sysrstcmd\n", @@ -153,7 +153,7 @@ static void kw_sysrst_check(void) /* * no action if sysrstdelay environment variable is not defined */ - s = getenv("sysrstdelay"); + s = env_get("sysrstdelay"); if (s == NULL) return;
diff --git a/arch/arm/mach-omap2/utils.c b/arch/arm/mach-omap2/utils.c index c03e93878d..0b0bf1837c 100644 --- a/arch/arm/mach-omap2/utils.c +++ b/arch/arm/mach-omap2/utils.c @@ -70,7 +70,7 @@ static void omap_set_fastboot_board_rev(void) { const char *board_rev;
- board_rev = getenv("board_rev"); + board_rev = env_get("board_rev"); if (board_rev == NULL) printf("Warning: fastboot.board_rev: unknown board revision\n");
@@ -169,7 +169,7 @@ void omap_die_id_serial(void)
omap_die_id((unsigned int *)&die_id);
- if (!getenv("serial#")) { + if (!env_get("serial#")) { snprintf(serial_string, sizeof(serial_string), "%08x%08x", die_id[0], die_id[3]);
@@ -182,7 +182,7 @@ void omap_die_id_get_board_serial(struct tag_serialnr *serialnr) char *serial_string; unsigned long long serial;
- serial_string = getenv("serial#"); + serial_string = env_get("serial#");
if (serial_string) { serial = simple_strtoull(serial_string, NULL, 16); @@ -202,7 +202,7 @@ void omap_die_id_usbethaddr(void)
- if (!getenv("usbethaddr")) { + if (!env_get("usbethaddr")) { /* * Create a fake MAC address from the processor ID code. * First byte is 0x02 to signify locally administered. diff --git a/arch/arm/mach-tegra/tegra186/nvtboot_board.c b/arch/arm/mach-tegra/tegra186/nvtboot_board.c index 9cd3fe2f30..b94eb424aa 100644 --- a/arch/arm/mach-tegra/tegra186/nvtboot_board.c +++ b/arch/arm/mach-tegra/tegra186/nvtboot_board.c @@ -35,7 +35,7 @@ static int set_ethaddr_from_nvtboot(void) const u32 *prop;
/* Already a valid address in the environment? If so, keep it */ - if (getenv("ethaddr")) + if (env_get("ethaddr")) return 0;
node = fdt_path_offset(nvtboot_blob, "/chosen"); diff --git a/arch/arm/mach-uniphier/board_late_init.c b/arch/arm/mach-uniphier/board_late_init.c index e6d600e41f..b9a2cbe148 100644 --- a/arch/arm/mach-uniphier/board_late_init.c +++ b/arch/arm/mach-uniphier/board_late_init.c @@ -37,7 +37,7 @@ static int uniphier_set_fdt_file(void) char dtb_name[256]; int buf_len = sizeof(dtb_name);
- if (getenv("fdt_file")) + if (env_get("fdt_file")) return 0; /* do nothing if it is already set */
compat = fdt_stringlist_get(gd->fdt_blob, 0, "compatible", 0, NULL); diff --git a/arch/m68k/lib/bootm.c b/arch/m68k/lib/bootm.c index fa9c493081..c976904fa9 100644 --- a/arch/m68k/lib/bootm.c +++ b/arch/m68k/lib/bootm.c @@ -113,7 +113,8 @@ static void set_clocks_in_mhz (bd_t *kbd) { char *s;
- if ((s = getenv("clocks_in_mhz")) != NULL) { + s = env_get("clocks_in_mhz"); + if (s) { /* convert all clock information to MHz */ kbd->bi_intfreq /= 1000000L; kbd->bi_busfreq /= 1000000L; diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index 2732203b93..0a286e82c2 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -27,7 +27,7 @@ int do_bootm_linux(int flag, int argc, char * const argv[], { /* First parameter is mapped to $r5 for kernel boot args */ void (*thekernel) (char *, ulong, ulong); - char *commandline = getenv("bootargs"); + char *commandline = env_get("bootargs"); ulong rd_data_start, rd_data_end;
/* diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index be877625a8..e53d0cb8d5 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -80,7 +80,7 @@ static void linux_cmdline_legacy(bootm_headers_t *images)
linux_cmdline_init();
- bootargs = getenv("bootargs"); + bootargs = env_get("bootargs"); if (!bootargs) return;
@@ -202,11 +202,11 @@ static void linux_env_legacy(bootm_headers_t *images) sprintf(env_buf, "0x%X", (uint) (gd->bd->bi_flashsize)); linux_env_set("flash_size", env_buf);
- cp = getenv("ethaddr"); + cp = env_get("ethaddr"); if (cp) linux_env_set("ethaddr", cp);
- cp = getenv("eth1addr"); + cp = env_get("eth1addr"); if (cp) linux_env_set("eth1addr", cp);
diff --git a/arch/nds32/lib/bootm.c b/arch/nds32/lib/bootm.c index 21aadf284f..e834329e0b 100644 --- a/arch/nds32/lib/bootm.c +++ b/arch/nds32/lib/bootm.c @@ -50,7 +50,7 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) void (*theKernel)(int zero, int arch, uint params);
#ifdef CONFIG_CMDLINE_TAG - char *commandline = getenv("bootargs"); + char *commandline = env_get("bootargs"); #endif
/* @@ -64,7 +64,7 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images)
theKernel = (void (*)(int, int, uint))images->ep;
- s = getenv("machid"); + s = env_get("machid"); if (s) { machid = simple_strtoul(s, NULL, 16); printf("Using machid 0x%x from environment\n", machid); diff --git a/arch/nios2/lib/bootm.c b/arch/nios2/lib/bootm.c index 4e5c269193..00ade2c573 100644 --- a/arch/nios2/lib/bootm.c +++ b/arch/nios2/lib/bootm.c @@ -12,7 +12,7 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *images) { void (*kernel)(int, int, int, char *) = (void *)images->ep; - char *commandline = getenv("bootargs"); + char *commandline = env_get("bootargs"); ulong initrd_start = images->rd_start; ulong initrd_end = images->rd_end; char *of_flat_tree = NULL; diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 52a33ec53f..2a5699152f 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -256,7 +256,7 @@ static void enable_tdm_law(void) * is not setup properly yet. Search for tdm entry in * hwconfig. */ - ret = getenv_f("hwconfig", buffer, sizeof(buffer)); + ret = env_get_f("hwconfig", buffer, sizeof(buffer)); if (ret > 0) { tdm_hwconfig_enabled = hwconfig_f("tdm", buffer); /* If tdm is defined in hwconfig, set law for tdm workaround */ @@ -280,7 +280,7 @@ void enable_cpc(void) cpc_corenet_t *cpc = (cpc_corenet_t *)CONFIG_SYS_FSL_CPC_ADDR;
/* Extract hwconfig from environment */ - ret = getenv_f("hwconfig", buffer, sizeof(buffer)); + ret = env_get_f("hwconfig", buffer, sizeof(buffer)); if (ret > 0) { /* * If "en_cpc" is not defined in hwconfig then by default all @@ -754,7 +754,7 @@ int cpu_init_r(void) char *buf = NULL; int n, res;
- n = getenv_f("hwconfig", buffer, sizeof(buffer)); + n = env_get_f("hwconfig", buffer, sizeof(buffer)); if (n > 0) buf = buffer;
@@ -794,7 +794,7 @@ int cpu_init_r(void) #endif
#if defined(CONFIG_PPC_SPINTABLE_COMPATIBLE) && defined(CONFIG_MP) - spin = getenv("spin_table_compat"); + spin = env_get("spin_table_compat"); if (spin && (*spin == 'n')) spin_table_compat = 0; else @@ -845,7 +845,7 @@ int cpu_init_r(void) #ifdef CONFIG_SYS_SRIO srio_init(); #ifdef CONFIG_SRIO_PCIE_BOOT_MASTER - char *s = getenv("bootmaster"); + char *s = env_get("bootmaster"); if (s) { if (!strcmp(s, "SRIO1")) { srio_boot_master(1); diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index a9ea947305..599839d0ff 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -92,7 +92,7 @@ void ft_fixup_cpu(void *blob, u64 memory_limit) * Extract hwconfig from environment. * Search for tdm entry in hwconfig. */ - ret = getenv_f("hwconfig", buffer, sizeof(buffer)); + ret = env_get_f("hwconfig", buffer, sizeof(buffer)); if (ret > 0) tdm_hwconfig_enabled = hwconfig_f("tdm", buffer);
@@ -580,7 +580,7 @@ static void fdt_fixup_l2_switch(void *blob) return;
/* Get MAC address for the l2switch from "l2switchaddr"*/ - if (!eth_getenv_enetaddr("l2switchaddr", l2swaddr)) { + if (!eth_env_get_enetaddr("l2switchaddr", l2swaddr)) { printf("Warning: MAC address for l2switch not found\n"); memset(l2swaddr, 0, sizeof(l2swaddr)); } diff --git a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c index 1bc0c64cfc..79d6544a09 100644 --- a/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/fsl_corenet_serdes.c @@ -514,7 +514,7 @@ void fsl_serdes_init(void) * Extract hwconfig from environment since we have not properly setup * the environment but need it for ddr config params */ - if (getenv_f("hwconfig", buffer, sizeof(buffer)) > 0) + if (env_get_f("hwconfig", buffer, sizeof(buffer)) > 0) buf = buffer; #endif if (serdes_prtcl_map & (1 << NONE)) diff --git a/arch/powerpc/cpu/mpc85xx/mp.c b/arch/powerpc/cpu/mpc85xx/mp.c index 0addf8493c..2ea9f5c7be 100644 --- a/arch/powerpc/cpu/mpc85xx/mp.c +++ b/arch/powerpc/cpu/mpc85xx/mp.c @@ -31,7 +31,7 @@ u32 get_my_id() int hold_cores_in_reset(int verbose) { /* Default to no, overridden by 'y', 'yes', 'Y', 'Yes', or '1' */ - if (getenv_yesno("mp_holdoff") == 1) { + if (env_get_yesno("mp_holdoff") == 1) { if (verbose) { puts("Secondary cores are being held in reset.\n"); puts("See 'mp_holdoff' environment variable\n"); diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index 42a6afbc31..93754c4363 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -84,7 +84,7 @@ static void boot_jump_linux(bootm_headers_t *images) debug (" Booting using OF flat tree...\n"); WATCHDOG_RESET (); (*kernel) ((bd_t *)of_flat_tree, 0, 0, EPAPR_MAGIC, - getenv_bootm_mapsize(), 0, 0); + env_get_bootm_mapsize(), 0, 0); /* does not return */ } else #endif @@ -119,8 +119,8 @@ void arch_lmb_reserve(struct lmb *lmb) phys_size_t bootm_size; ulong size, sp, bootmap_base;
- bootmap_base = getenv_bootm_low(); - bootm_size = getenv_bootm_size(); + bootmap_base = env_get_bootm_low(); + bootm_size = env_get_bootm_size();
#ifdef DEBUG if (((u64)bootmap_base + bootm_size) > @@ -273,7 +273,8 @@ static void set_clocks_in_mhz (bd_t *kbd) { char *s;
- if ((s = getenv ("clocks_in_mhz")) != NULL) { + s = env_get("clocks_in_mhz"); + if (s) { /* convert all clock information to MHz */ kbd->bi_intfreq /= 1000000L; kbd->bi_busfreq /= 1000000L; @@ -337,6 +338,6 @@ void boot_jump_vxworks(bootm_headers_t *images)
((void (*)(void *, ulong, ulong, ulong, ulong, ulong, ulong))images->ep)(images->ft_addr, - 0, 0, EPAPR_MAGIC, getenv_bootm_mapsize(), 0, 0); + 0, 0, EPAPR_MAGIC, env_get_bootm_mapsize(), 0, 0); } #endif diff --git a/arch/sh/lib/bootm.c b/arch/sh/lib/bootm.c index 8a0010be23..09fbd5e5df 100644 --- a/arch/sh/lib/bootm.c +++ b/arch/sh/lib/bootm.c @@ -61,7 +61,7 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *ima char *cmdline = (char *)param + COMMAND_LINE; /* PAGE_SIZE */ unsigned long size = images->ep - (unsigned long)param; - char *bootargs = getenv("bootargs"); + char *bootargs = env_get("bootargs");
/* * allow the PREP bootm subcommand, it is required for bootm to work diff --git a/arch/sh/lib/zimageboot.c b/arch/sh/lib/zimageboot.c index 3fea5f5b53..cd4abba10a 100644 --- a/arch/sh/lib/zimageboot.c +++ b/arch/sh/lib/zimageboot.c @@ -42,7 +42,7 @@ int do_sh_zimageboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* Linux kernel command line */ cmdline = (char *)param + COMMAND_LINE; - bootargs = getenv("bootargs"); + bootargs = env_get("bootargs");
/* Clear zero page */ /* cppcheck-suppress nullPointer */ diff --git a/arch/x86/lib/zimage.c b/arch/x86/lib/zimage.c index aafbeb01f9..00172dc7c1 100644 --- a/arch/x86/lib/zimage.c +++ b/arch/x86/lib/zimage.c @@ -48,15 +48,15 @@ static void build_command_line(char *command_line, int auto_boot)
command_line[0] = '\0';
- env_command_line = getenv("bootargs"); + env_command_line = env_get("bootargs");
/* set console= argument if we use a serial console */ if (!strstr(env_command_line, "console=")) { - if (!strcmp(getenv("stdout"), "serial")) { + if (!strcmp(env_get("stdout"), "serial")) {
/* We seem to use serial console */ sprintf(command_line, "console=ttyS0,%s ", - getenv("baudrate")); + env_get("baudrate")); } }
@@ -285,7 +285,7 @@ int do_zboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) /* argv[1] holds the address of the bzImage */ s = argv[1]; } else { - s = getenv("fileaddr"); + s = env_get("fileaddr"); }
if (s) diff --git a/arch/xtensa/lib/bootm.c b/arch/xtensa/lib/bootm.c index 1604bb9536..16961acba5 100644 --- a/arch/xtensa/lib/bootm.c +++ b/arch/xtensa/lib/bootm.c @@ -136,7 +136,7 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) { struct bp_tag *params, *params_start; ulong initrd_start, initrd_end; - char *commandline = getenv("bootargs"); + char *commandline = env_get("bootargs");
if (!(flag & (BOOTM_STATE_OS_GO | BOOTM_STATE_OS_FAKE_GO))) return 0; diff --git a/board/Arcturus/ucp1020/cmd_arc.c b/board/Arcturus/ucp1020/cmd_arc.c index c32f7df454..0d3ac88fff 100644 --- a/board/Arcturus/ucp1020/cmd_arc.c +++ b/board/Arcturus/ucp1020/cmd_arc.c @@ -149,7 +149,7 @@ int get_arc_info(void) if (smac[2][0] == 0xFF) { printf("\t<not found>\n"); } else { - char *ret = getenv("ethaddr"); + char *ret = env_get("ethaddr");
if (strcmp(ret, __stringify(CONFIG_ETHADDR)) == 0) { env_set("ethaddr", smac[2]); @@ -169,7 +169,7 @@ int get_arc_info(void) if (smac[1][0] == 0xFF) { printf("\t<not found>\n"); } else { - char *ret = getenv("eth1addr"); + char *ret = env_get("eth1addr");
if (strcmp(ret, __stringify(CONFIG_ETH1ADDR)) == 0) { env_set("eth1addr", smac[1]); @@ -188,7 +188,7 @@ int get_arc_info(void) if (smac[0][0] == 0xFF) { printf("\t<not found>\n"); } else { - char *ret = getenv("eth2addr"); + char *ret = env_get("eth2addr");
if (strcmp(ret, __stringify(CONFIG_ETH2ADDR)) == 0) { env_set("eth2addr", smac[0]); diff --git a/board/Arcturus/ucp1020/ucp1020.c b/board/Arcturus/ucp1020/ucp1020.c index 2cc2e54d5b..3f786a2014 100644 --- a/board/Arcturus/ucp1020/ucp1020.c +++ b/board/Arcturus/ucp1020/ucp1020.c @@ -64,7 +64,7 @@ void board_gpio_init(void)
for (i = 0; i < GPIO_MAX_NUM; i++) { sprintf(envname, "GPIO%d", i); - val = getenv(envname); + val = env_get(envname); if (val) { char direction = toupper(val[0]); char level = toupper(val[1]); @@ -82,7 +82,7 @@ void board_gpio_init(void) } }
- val = getenv("PCIE_OFF"); + val = env_get("PCIE_OFF"); if (val) { gpio_direction_input(GPIO_PCIE1_EN); gpio_direction_input(GPIO_PCIE2_EN); @@ -91,7 +91,7 @@ void board_gpio_init(void) gpio_direction_output(GPIO_PCIE2_EN, 1); }
- val = getenv("SDHC_CDWP_OFF"); + val = env_get("SDHC_CDWP_OFF"); if (!val) { ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
@@ -214,7 +214,7 @@ int last_stage_init(void) else printf("NCT72(0x%x): ready\n", id2);
- kval = getenv("kernelargs"); + kval = env_get("kernelargs");
mmc = find_mmc_device(0); if (mmc) @@ -238,7 +238,7 @@ int last_stage_init(void) get_arc_info();
if (kval) { - sval = getenv("SERIAL"); + sval = env_get("SERIAL"); if (sval) { strcpy(newkernelargs, "SN="); strcat(newkernelargs, sval); @@ -307,8 +307,8 @@ int ft_board_setup(void *blob, bd_t *bd)
ft_cpu_setup(blob, bd);
- base = getenv_bootm_low(); - size = getenv_bootm_size(); + base = env_get_bootm_low(); + size = env_get_bootm_size();
fdt_fixup_memory(blob, (u64)base, (u64)size);
diff --git a/board/Barix/ipam390/ipam390.c b/board/Barix/ipam390/ipam390.c index 3a584021ac..d203429738 100644 --- a/board/Barix/ipam390/ipam390.c +++ b/board/Barix/ipam390/ipam390.c @@ -157,7 +157,7 @@ u32 get_board_rev(void) u32 maxcpuclk = CONFIG_DA850_EVM_MAX_CPU_CLK; u32 rev = 0;
- s = getenv("maxcpuclk"); + s = env_get("maxcpuclk"); if (s) maxcpuclk = simple_strtoul(s, NULL, 10);
diff --git a/board/BuR/brxre1/board.c b/board/BuR/brxre1/board.c index cdbc93a8ec..ca08f3cd90 100644 --- a/board/BuR/brxre1/board.c +++ b/board/BuR/brxre1/board.c @@ -282,9 +282,9 @@ int board_late_init(void) snprintf(othbootargs, sizeof(othbootargs), "u=vxWorksFTP pw=vxWorks o=0x%08x;0x%08x;0x%08x;0x%08x", (unsigned int) gd->fb_base-0x20, - (u32)getenv_ulong("vx_memtop", 16, gd->fb_base-0x20), - (u32)getenv_ulong("vx_romfsbase", 16, 0), - (u32)getenv_ulong("vx_romfssize", 16, 0)); + (u32)env_get_ulong("vx_memtop", 16, gd->fb_base-0x20), + (u32)env_get_ulong("vx_romfsbase", 16, 0), + (u32)env_get_ulong("vx_romfssize", 16, 0)); env_set("othbootargs", othbootargs); /* * reset VBAR registers to its reset location, VxWorks 6.9.3.2 does diff --git a/board/BuR/common/common.c b/board/BuR/common/common.c index eb34de931e..c1cd010023 100644 --- a/board/BuR/common/common.c +++ b/board/BuR/common/common.c @@ -58,9 +58,9 @@ void lcdbacklight(int on) unsigned int bright = FDTPROP(PATHINF, "brightdef"); unsigned int pwmfrq = FDTPROP(PATHINF, "brightfdim"); #else - unsigned int driver = getenv_ulong("ds1_bright_drv", 16, 0UL); - unsigned int bright = getenv_ulong("ds1_bright_def", 10, 50); - unsigned int pwmfrq = getenv_ulong("ds1_pwmfreq", 10, ~0UL); + unsigned int driver = env_get_ulong("ds1_bright_drv", 16, 0UL); + unsigned int bright = env_get_ulong("ds1_bright_def", 10, 50); + unsigned int pwmfrq = env_get_ulong("ds1_pwmfreq", 10, ~0UL); #endif unsigned int tmp; struct gptimer *timerhw; @@ -186,20 +186,20 @@ int load_lcdtiming(struct am335x_lcdpanel *panel) snprintf(buf, sizeof(buf), "fbcon=rotate:%d", panel_info.vl_rot); env_set("optargs_rot", buf); #else - pnltmp.hactive = getenv_ulong("ds1_hactive", 10, ~0UL); - pnltmp.vactive = getenv_ulong("ds1_vactive", 10, ~0UL); - pnltmp.bpp = getenv_ulong("ds1_bpp", 10, ~0UL); - pnltmp.hfp = getenv_ulong("ds1_hfp", 10, ~0UL); - pnltmp.hbp = getenv_ulong("ds1_hbp", 10, ~0UL); - pnltmp.hsw = getenv_ulong("ds1_hsw", 10, ~0UL); - pnltmp.vfp = getenv_ulong("ds1_vfp", 10, ~0UL); - pnltmp.vbp = getenv_ulong("ds1_vbp", 10, ~0UL); - pnltmp.vsw = getenv_ulong("ds1_vsw", 10, ~0UL); - pnltmp.pxl_clk_div = getenv_ulong("ds1_pxlclkdiv", 10, ~0UL); - pnltmp.pol = getenv_ulong("ds1_pol", 16, ~0UL); - pnltmp.pup_delay = getenv_ulong("ds1_pupdelay", 10, ~0UL); - pnltmp.pon_delay = getenv_ulong("ds1_tondelay", 10, ~0UL); - panel_info.vl_rot = getenv_ulong("ds1_rotation", 10, 0); + pnltmp.hactive = env_get_ulong("ds1_hactive", 10, ~0UL); + pnltmp.vactive = env_get_ulong("ds1_vactive", 10, ~0UL); + pnltmp.bpp = env_get_ulong("ds1_bpp", 10, ~0UL); + pnltmp.hfp = env_get_ulong("ds1_hfp", 10, ~0UL); + pnltmp.hbp = env_get_ulong("ds1_hbp", 10, ~0UL); + pnltmp.hsw = env_get_ulong("ds1_hsw", 10, ~0UL); + pnltmp.vfp = env_get_ulong("ds1_vfp", 10, ~0UL); + pnltmp.vbp = env_get_ulong("ds1_vbp", 10, ~0UL); + pnltmp.vsw = env_get_ulong("ds1_vsw", 10, ~0UL); + pnltmp.pxl_clk_div = env_get_ulong("ds1_pxlclkdiv", 10, ~0UL); + pnltmp.pol = env_get_ulong("ds1_pol", 16, ~0UL); + pnltmp.pup_delay = env_get_ulong("ds1_pupdelay", 10, ~0UL); + pnltmp.pon_delay = env_get_ulong("ds1_tondelay", 10, ~0UL); + panel_info.vl_rot = env_get_ulong("ds1_rotation", 10, 0); #endif if ( ~0UL == (pnltmp.hactive) || @@ -251,7 +251,7 @@ static int load_devicetree(void) { int rc; loff_t dtbsize; - u32 dtbaddr = getenv_ulong("dtbaddr", 16, 0UL); + u32 dtbaddr = env_get_ulong("dtbaddr", 16, 0UL);
if (dtbaddr == 0) { printf("%s: don't have a valid <dtbaddr> in env!\n", __func__); @@ -263,9 +263,9 @@ static int load_devicetree(void) (size_t *)&dtbsize, NULL, 0x20000, (u_char *)dtbaddr); #else - char *dtbname = getenv("dtb"); - char *dtbdev = getenv("dtbdev"); - char *dtbpart = getenv("dtbpart"); + char *dtbname = env_get("dtb"); + char *dtbdev = env_get("dtbdev"); + char *dtbpart = env_get("dtbpart"); if (!dtbdev || !dtbpart || !dtbname) { printf("%s: <dtbdev>/<dtbpart>/<dtb> missing.\n", __func__); return -1; @@ -375,7 +375,7 @@ int ft_board_setup(void *blob, bd_t *bd) * if no simplefb is requested through environment, we don't set up * one, instead we turn off backlight. */ - if (getenv_ulong("simplefb", 10, 0) == 0) { + if (env_get_ulong("simplefb", 10, 0) == 0) { lcdbacklight(0); return 0; } @@ -405,11 +405,11 @@ static void br_summaryscreen_printenv(char *prefix, char *name, char *altname, char *suffix) { - char *envval = getenv(name); + char *envval = env_get(name); if (0 != envval) { lcd_printf("%s %s %s", prefix, envval, suffix); } else if (0 != altname) { - envval = getenv(altname); + envval = env_get(altname); if (0 != envval) lcd_printf("%s %s %s", prefix, envval, suffix); } else { @@ -447,7 +447,7 @@ void lcdpower(int on) } pin = FDTPROP(PATHINF, "pwrpin"); #else - pin = getenv_ulong("ds1_pwr", 16, ~0UL); + pin = env_get_ulong("ds1_pwr", 16, ~0UL); #endif if (pin == ~0UL) { puts("no pwrpin in dtb/env, cannot powerup display!\n"); @@ -657,7 +657,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
- if (!getenv("ethaddr")) { + if (!env_get("ethaddr")) { #if !defined(CONFIG_SPL_BUILD) && defined(CONFIG_USE_FDT) printf("<ethaddr> not set. trying DTB ... "); mac = dtbmacaddr(0); diff --git a/board/BuS/eb_cpu5282/eb_cpu5282.c b/board/BuS/eb_cpu5282/eb_cpu5282.c index a00a83a4a5..d23b9f3a4f 100644 --- a/board/BuS/eb_cpu5282/eb_cpu5282.c +++ b/board/BuS/eb_cpu5282/eb_cpu5282.c @@ -139,7 +139,7 @@ void hw_watchdog_init(void) int enable;
enable = 1; - s = getenv("watchdog"); + s = env_get("watchdog"); if (s != NULL) if ((strncmp(s, "off", 3) == 0) || (strncmp(s, "0", 1) == 0)) enable = 0; @@ -191,13 +191,13 @@ int drv_video_init(void) unsigned long splash; #endif printf("Init Video as "); - s = getenv("displaywidth"); + s = env_get("displaywidth"); if (s != NULL) display_width = simple_strtoul(s, NULL, 10); else display_width = 256;
- s = getenv("displayheight"); + s = env_get("displayheight"); if (s != NULL) display_height = simple_strtoul(s, NULL, 10); else @@ -211,7 +211,7 @@ int drv_video_init(void) vcxk_init(display_width, display_height);
#ifdef CONFIG_SPLASH_SCREEN - s = getenv("splashimage"); + s = env_get("splashimage"); if (s != NULL) { splash = simple_strtoul(s, NULL, 16); vcxk_acknowledge_wait(); diff --git a/board/CarMediaLab/flea3/flea3.c b/board/CarMediaLab/flea3/flea3.c index 3cd4dc95fe..5e75eb0b64 100644 --- a/board/CarMediaLab/flea3/flea3.c +++ b/board/CarMediaLab/flea3/flea3.c @@ -211,7 +211,7 @@ int ft_board_setup(void *blob, bd_t *bd) { "mxc_nand", MTD_DEV_TYPE_NAND, }, /* NAND flash */ };
- if (getenv("fdt_noauto")) { + if (env_get("fdt_noauto")) { puts(" Skiping ft_board_setup (fdt_noauto defined)\n"); return 0; } diff --git a/board/LaCie/net2big_v2/net2big_v2.c b/board/LaCie/net2big_v2/net2big_v2.c index 416af469fa..f639a37d4d 100644 --- a/board/LaCie/net2big_v2/net2big_v2.c +++ b/board/LaCie/net2big_v2/net2big_v2.c @@ -221,7 +221,7 @@ int misc_init_r(void) { init_fan(); #if defined(CONFIG_CMD_I2C) && defined(CONFIG_SYS_I2C_EEPROM_ADDR) - if (!getenv("ethaddr")) { + if (!env_get("ethaddr")) { uchar mac[6]; if (lacie_read_mac_address(mac) == 0) eth_env_set_enetaddr("ethaddr", mac); diff --git a/board/LaCie/netspace_v2/netspace_v2.c b/board/LaCie/netspace_v2/netspace_v2.c index fa07288d6e..52f36644a3 100644 --- a/board/LaCie/netspace_v2/netspace_v2.c +++ b/board/LaCie/netspace_v2/netspace_v2.c @@ -83,7 +83,7 @@ int board_init(void) int misc_init_r(void) { #if defined(CONFIG_CMD_I2C) && defined(CONFIG_SYS_I2C_EEPROM_ADDR) - if (!getenv("ethaddr")) { + if (!env_get("ethaddr")) { uchar mac[6]; if (lacie_read_mac_address(mac) == 0) eth_env_set_enetaddr("ethaddr", mac); diff --git a/board/amazon/kc1/kc1.c b/board/amazon/kc1/kc1.c index 2d8be1804a..eead98b24e 100644 --- a/board/amazon/kc1/kc1.c +++ b/board/amazon/kc1/kc1.c @@ -118,7 +118,7 @@ int misc_init_r(void) }
if (reboot_mode[0] > 0 && isascii(reboot_mode[0])) { - if (!getenv("reboot-mode")) + if (!env_get("reboot-mode")) env_set("reboot-mode", (char *)reboot_mode); }
diff --git a/board/amlogic/odroid-c2/odroid-c2.c b/board/amlogic/odroid-c2/odroid-c2.c index ca9c13bcc1..eac04d8178 100644 --- a/board/amlogic/odroid-c2/odroid-c2.c +++ b/board/amlogic/odroid-c2/odroid-c2.c @@ -44,14 +44,14 @@ int misc_init_r(void) mdelay(10); setbits_le32(GXBB_GPIO_OUT(3), BIT(14));
- if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, mac_addr, EFUSE_MAC_SIZE); if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("ethaddr", mac_addr); }
- if (!getenv("serial#")) { + if (!env_get("serial#")) { len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial, EFUSE_SN_SIZE); if (len == EFUSE_SN_SIZE) diff --git a/board/aristainetos/aristainetos-v2.c b/board/aristainetos/aristainetos-v2.c index bdf41b99c8..698715ca20 100644 --- a/board/aristainetos/aristainetos-v2.c +++ b/board/aristainetos/aristainetos-v2.c @@ -651,7 +651,7 @@ int board_late_init(void) { char *my_bootdelay; char bootmode = 0; - char const *panel = getenv("panel"); + char const *panel = env_get("panel");
/* * Check the boot-source. If booting from NOR Flash, @@ -668,7 +668,7 @@ int board_late_init(void) bootmode |= (gpio_get_value(IMX_GPIO_NR(7, 1)) ? 1 : 0) << 2;
if (bootmode == 7) { - my_bootdelay = getenv("nor_bootdelay"); + my_bootdelay = env_get("nor_bootdelay"); if (my_bootdelay != NULL) env_set("bootdelay", my_bootdelay); else diff --git a/board/atmel/sama5d2_xplained/sama5d2_xplained.c b/board/atmel/sama5d2_xplained/sama5d2_xplained.c index 4a06cda6f4..3f0860c555 100644 --- a/board/atmel/sama5d2_xplained/sama5d2_xplained.c +++ b/board/atmel/sama5d2_xplained/sama5d2_xplained.c @@ -169,7 +169,7 @@ static int set_ethaddr_from_eeprom(void) const char *ETHADDR_NAME = "ethaddr"; struct udevice *bus, *dev;
- if (getenv(ETHADDR_NAME)) + if (env_get(ETHADDR_NAME)) return 0;
if (uclass_get_device_by_seq(UCLASS_I2C, 1, &bus)) { diff --git a/board/birdland/bav335x/board.c b/board/birdland/bav335x/board.c index a9d9ce6fa5..f284568ec9 100644 --- a/board/birdland/bav335x/board.c +++ b/board/birdland/bav335x/board.c @@ -163,7 +163,7 @@ int spl_start_uboot(void) #ifdef CONFIG_SPL_ENV_SUPPORT env_init(); env_load(); - if (getenv_yesno("boot_os") != 1) + if (env_get_yesno("boot_os") != 1) return 1; #endif
@@ -392,7 +392,7 @@ int board_eth_init(bd_t *bis) #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ (defined(CONFIG_SPL_ETH_SUPPORT) && defined(CONFIG_SPL_BUILD))
- if (!getenv("ethaddr")) { + if (!env_get("ethaddr")) { printf("<ethaddr> not set. Validating first E-fuse MAC\n");
if (is_valid_ethaddr(mac_addr)) diff --git a/board/bluegiga/apx4devkit/apx4devkit.c b/board/bluegiga/apx4devkit/apx4devkit.c index 2215c29c9c..25e5c3d80c 100644 --- a/board/bluegiga/apx4devkit/apx4devkit.c +++ b/board/bluegiga/apx4devkit/apx4devkit.c @@ -133,8 +133,8 @@ void get_board_serial(struct tag_serialnr *serialnr) #ifdef CONFIG_REVISION_TAG u32 get_board_rev(void) { - if (getenv("revision#") != NULL) - return simple_strtoul(getenv("revision#"), NULL, 10); + if (env_get("revision#") != NULL) + return simple_strtoul(env_get("revision#"), NULL, 10); return 0; } #endif diff --git a/board/bluewater/gurnard/gurnard.c b/board/bluewater/gurnard/gurnard.c index e82c691841..8733a9af16 100644 --- a/board/bluewater/gurnard/gurnard.c +++ b/board/bluewater/gurnard/gurnard.c @@ -341,7 +341,7 @@ int board_init(void) at91_set_A_periph(AT91_PIN_PE6, 1); /* power up */
/* Select the second timing index for board rev 2 */ - rev_str = getenv("board_rev"); + rev_str = env_get("board_rev"); if (rev_str && !strncmp(rev_str, "2", 1)) { struct udevice *dev;
@@ -368,7 +368,7 @@ int board_late_init(void) * Set MAC address so we do not need to init Ethernet before Linux * boot */ - env_str = getenv("ethaddr"); + env_str = env_get("ethaddr"); if (env_str) { struct at91_emac *emac = (struct at91_emac *)ATMEL_BASE_EMAC; /* Parse MAC address */ @@ -385,7 +385,7 @@ int board_late_init(void) &emac->sa2l); writel((env_enetaddr[4] | env_enetaddr[5] << 8), &emac->sa2h);
- printf("MAC: %s\n", getenv("ethaddr")); + printf("MAC: %s\n", env_get("ethaddr")); } else { /* Not set in environment */ printf("MAC: not set\n"); diff --git a/board/bosch/shc/board.c b/board/bosch/shc/board.c index b4c6a0b45d..999ed95c31 100644 --- a/board/bosch/shc/board.c +++ b/board/bosch/shc/board.c @@ -545,7 +545,7 @@ int board_eth_init(bd_t *bis)
#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ (defined(CONFIG_SPL_ETH_SUPPORT) && defined(CONFIG_SPL_BUILD)) - if (!getenv("ethaddr")) { + if (!env_get("ethaddr")) { printf("<ethaddr> not set. Validating first E-fuse MAC\n");
if (is_valid_ethaddr(mac_addr)) diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 0e2c4fc0ef..3b92b64f6a 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -749,7 +749,7 @@ size_t display_count = ARRAY_SIZE(displays);
int board_cfb_skip(void) { - return NULL != getenv("novideo"); + return NULL != env_get("novideo"); }
static void setup_display(void) @@ -974,7 +974,7 @@ static void preboot_keys(void) char keypress[ARRAY_SIZE(buttons)+1]; numpressed = read_keys(keypress); if (numpressed) { - char *kbd_magic_keys = getenv("magic_keys"); + char *kbd_magic_keys = env_get("magic_keys"); char *suffix; /* * loop over all magic keys @@ -983,7 +983,7 @@ static void preboot_keys(void) char *keys; char magic[sizeof(kbd_magic_prefix) + 1]; sprintf(magic, "%s%c", kbd_magic_prefix, *suffix); - keys = getenv(magic); + keys = env_get(magic); if (keys) { if (!strcmp(keys, keypress)) break; @@ -993,7 +993,7 @@ static void preboot_keys(void) char cmd_name[sizeof(kbd_command_prefix) + 1]; char *cmd; sprintf(cmd_name, "%s%c", kbd_command_prefix, *suffix); - cmd = getenv(cmd_name); + cmd = env_get(cmd_name); if (cmd) { env_set("preboot", cmd); return; diff --git a/board/broadcom/bcm23550_w1d/bcm23550_w1d.c b/board/broadcom/bcm23550_w1d/bcm23550_w1d.c index 5f4c634362..0267582186 100644 --- a/board/broadcom/bcm23550_w1d/bcm23550_w1d.c +++ b/board/broadcom/bcm23550_w1d/bcm23550_w1d.c @@ -103,7 +103,7 @@ int board_usb_init(int index, enum usb_init_type init) int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) { debug("%s\n", __func__); - if (!getenv("serial#")) + if (!env_get("serial#")) g_dnl_set_serialnumber(CONFIG_USB_SERIALNO); return 0; } diff --git a/board/broadcom/bcm28155_ap/bcm28155_ap.c b/board/broadcom/bcm28155_ap/bcm28155_ap.c index f5b94f6430..8f48ccbf1c 100644 --- a/board/broadcom/bcm28155_ap/bcm28155_ap.c +++ b/board/broadcom/bcm28155_ap/bcm28155_ap.c @@ -110,7 +110,7 @@ int board_usb_init(int index, enum usb_init_type init) int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) { debug("%s\n", __func__); - if (!getenv("serial#")) + if (!env_get("serial#")) g_dnl_set_serialnumber(CONFIG_USB_SERIALNO); return 0; } diff --git a/board/buffalo/lsxl/lsxl.c b/board/buffalo/lsxl/lsxl.c index 5b31e056ba..2d01ac25d8 100644 --- a/board/buffalo/lsxl/lsxl.c +++ b/board/buffalo/lsxl/lsxl.c @@ -203,7 +203,7 @@ void check_enetaddr(void) { uchar enetaddr[6];
- if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { + if (!eth_env_get_enetaddr("ethaddr", enetaddr)) { /* signal unset/invalid ethaddr to user */ set_led(LED_INFO_BLINKING); } diff --git a/board/cadence/xtfpga/xtfpga.c b/board/cadence/xtfpga/xtfpga.c index 83244c3ad4..f81fa95c18 100644 --- a/board/cadence/xtfpga/xtfpga.c +++ b/board/cadence/xtfpga/xtfpga.c @@ -86,7 +86,7 @@ int misc_init_r(void) * Default MAC address comes from CONFIG_ETHADDR + DIP switches 1-6. */
- char *s = getenv("ethaddr"); + char *s = env_get("ethaddr"); if (s == 0) { unsigned int x; char s[] = __stringify(CONFIG_ETHBASE); diff --git a/board/compulab/cl-som-am57x/eth.c b/board/compulab/cl-som-am57x/eth.c index d2992d3a63..b615fb9e7e 100644 --- a/board/compulab/cl-som-am57x/eth.c +++ b/board/compulab/cl-som-am57x/eth.c @@ -95,7 +95,7 @@ static int cl_som_am57x_handle_mac_address(char *env_name, uint port_num) int ret; uint8_t enetaddr[6];
- ret = eth_getenv_enetaddr(env_name, enetaddr); + ret = eth_env_get_enetaddr(env_name, enetaddr); if (ret) return 0;
@@ -181,7 +181,7 @@ int board_eth_init(bd_t *bis) gpio_set_value(CL_SOM_AM57X_GPIO_PHY1_RST, 1); mdelay(20);
- cpsw_phy_envval = getenv("cpsw_phy"); + cpsw_phy_envval = env_get("cpsw_phy"); if (cpsw_phy_envval != NULL) cpsw_act_phy = simple_strtoul(cpsw_phy_envval, NULL, 0);
diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index 2368226546..a1da2780aa 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -114,10 +114,10 @@ int board_video_skip(void) { int ret; struct display_info_t *preset; - char const *panel = getenv("displaytype"); + char const *panel = env_get("displaytype");
if (!panel) /* Also accept panel for backward compatibility */ - panel = getenv("panel"); + panel = env_get("panel");
if (!panel) return -ENOENT; @@ -470,7 +470,7 @@ static int handle_mac_address(char *env_var, uint eeprom_bus) unsigned char enetaddr[6]; int rc;
- rc = eth_getenv_enetaddr(env_var, enetaddr); + rc = eth_env_get_enetaddr(env_var, enetaddr); if (rc) return 0;
@@ -605,13 +605,13 @@ int ft_board_setup(void *blob, bd_t *bd) fdt_shrink_to_minimum(blob, 0); /* Make room for new properties */
/* MAC addr */ - if (eth_getenv_enetaddr("ethaddr", enetaddr)) { + if (eth_env_get_enetaddr("ethaddr", enetaddr)) { fdt_find_and_setprop(blob, "/soc/aips-bus@02100000/ethernet@02188000", "local-mac-address", enetaddr, 6, 1); }
- if (eth_getenv_enetaddr("eth1addr", enetaddr)) { + if (eth_env_get_enetaddr("eth1addr", enetaddr)) { fdt_find_and_setprop(blob, "/eth@pcie", "local-mac-address", enetaddr, 6, 1); } diff --git a/board/compulab/cm_t335/cm_t335.c b/board/compulab/cm_t335/cm_t335.c index f6030ddf29..6f6ba49af5 100644 --- a/board/compulab/cm_t335/cm_t335.c +++ b/board/compulab/cm_t335/cm_t335.c @@ -106,7 +106,7 @@ static int handle_mac_address(void) uchar enetaddr[6]; int rv;
- rv = eth_getenv_enetaddr("ethaddr", enetaddr); + rv = eth_env_get_enetaddr("ethaddr", enetaddr); if (rv) return 0;
diff --git a/board/compulab/cm_t35/cm_t35.c b/board/compulab/cm_t35/cm_t35.c index a8696aea83..1e37e392ec 100644 --- a/board/compulab/cm_t35/cm_t35.c +++ b/board/compulab/cm_t35/cm_t35.c @@ -434,7 +434,7 @@ static int handle_mac_address(void) unsigned char enetaddr[6]; int rc;
- rc = eth_getenv_enetaddr("ethaddr", enetaddr); + rc = eth_env_get_enetaddr("ethaddr", enetaddr); if (rc) return 0;
diff --git a/board/compulab/cm_t3517/cm_t3517.c b/board/compulab/cm_t3517/cm_t3517.c index 0568234f66..0ff49dcdcc 100644 --- a/board/compulab/cm_t3517/cm_t3517.c +++ b/board/compulab/cm_t3517/cm_t3517.c @@ -168,7 +168,7 @@ static int cm_t3517_handle_mac_address(void) unsigned char enetaddr[6]; int ret;
- ret = eth_getenv_enetaddr("ethaddr", enetaddr); + ret = eth_env_get_enetaddr("ethaddr", enetaddr); if (ret) return 0;
diff --git a/board/compulab/cm_t54/cm_t54.c b/board/compulab/cm_t54/cm_t54.c index 582512dbe4..31730a4d1c 100644 --- a/board/compulab/cm_t54/cm_t54.c +++ b/board/compulab/cm_t54/cm_t54.c @@ -126,7 +126,7 @@ int ft_board_setup(void *blob, bd_t *bd) uint8_t enetaddr[6];
/* MAC addr */ - if (eth_getenv_enetaddr("usbethaddr", enetaddr)) { + if (eth_env_get_enetaddr("usbethaddr", enetaddr)) { fdt_find_and_setprop(blob, "/smsc95xx@0", "mac-address", enetaddr, 6, 1); } @@ -161,7 +161,7 @@ static int handle_mac_address(void) uint8_t enetaddr[6]; int ret;
- ret = eth_getenv_enetaddr("usbethaddr", enetaddr); + ret = eth_env_get_enetaddr("usbethaddr", enetaddr); if (ret) return 0;
diff --git a/board/compulab/common/omap3_display.c b/board/compulab/common/omap3_display.c index 61707f5b90..ed2077e361 100644 --- a/board/compulab/common/omap3_display.c +++ b/board/compulab/common/omap3_display.c @@ -400,7 +400,7 @@ void lcd_ctrl_init(void *lcdbase) { struct prcm *prcm = (struct prcm *)PRCM_BASE; char *custom_lcd; - char *displaytype = getenv("displaytype"); + char *displaytype = env_get("displaytype");
if (displaytype == NULL) return; @@ -408,7 +408,7 @@ void lcd_ctrl_init(void *lcdbase) lcd_def = env_parse_displaytype(displaytype); /* If we did not recognize the preset, check if it's an env variable */ if (lcd_def == NONE) { - custom_lcd = getenv(displaytype); + custom_lcd = env_get(displaytype); if (custom_lcd == NULL || parse_customlcd(custom_lcd) < 0) return; } diff --git a/board/congatec/cgtqmx6eval/cgtqmx6eval.c b/board/congatec/cgtqmx6eval/cgtqmx6eval.c index ac66248b3f..8cd0090887 100644 --- a/board/congatec/cgtqmx6eval/cgtqmx6eval.c +++ b/board/congatec/cgtqmx6eval/cgtqmx6eval.c @@ -235,7 +235,7 @@ int power_init_board(void) return 0;
/* set level of MIPI if specified */ - lv_mipi = getenv("lv_mipi"); + lv_mipi = env_get("lv_mipi"); if (lv_mipi) return 0;
@@ -583,7 +583,7 @@ int board_video_skip(void) { int i; int ret; - char const *panel = getenv("panel"); + char const *panel = env_get("panel"); if (!panel) { for (i = 0; i < ARRAY_SIZE(displays); i++) { struct display_info_t const *dev = displays + i; diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index 8cab357a92..c2d2e8e882 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -131,7 +131,7 @@ int misc_init_r(void) uchar env_enetaddr[6]; int enetaddr_found;
- enetaddr_found = eth_getenv_enetaddr("ethaddr", env_enetaddr); + enetaddr_found = eth_env_get_enetaddr("ethaddr", env_enetaddr);
#ifdef CONFIG_MAC_ADDR_IN_SPIFLASH int spi_mac_read; @@ -292,7 +292,7 @@ u32 get_board_rev(void) u32 maxcpuclk = CONFIG_DA850_EVM_MAX_CPU_CLK; u32 rev = 0;
diff --git a/board/davinci/da8xxevm/omapl138_lcdk.c b/board/davinci/da8xxevm/omapl138_lcdk.c index 29296b0478..565020760d 100644 --- a/board/davinci/da8xxevm/omapl138_lcdk.c +++ b/board/davinci/da8xxevm/omapl138_lcdk.c @@ -293,7 +293,7 @@ static void dspwake(void) if ((REG(CHIP_REV_ID_REG) & 0x3f) == 0x10) return;
- if (!strcmp(getenv("dspwake"), "no")) + if (!strcmp(env_get("dspwake"), "no")) return;
*resetvect++ = 0x1E000; /* DSP Idle */ @@ -323,7 +323,7 @@ int misc_init_r(void) uint8_t tmp[20], addr[10];
- if (getenv("ethaddr") == NULL) { + if (env_get("ethaddr") == NULL) { /* Read Ethernet MAC address from EEPROM */ if (dvevm_read_mac_address(addr)) { /* Set Ethernet MAC address from EEPROM */ diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c index e4bda7909a..7cc3fdd2f2 100644 --- a/board/esd/meesc/meesc.c +++ b/board/esd/meesc/meesc.c @@ -181,7 +181,7 @@ int checkboard(void) puts("Board: EtherCAN/2 Gateway"); break; } - if (getenv_f("serial#", str, sizeof(str)) > 0) { + if (env_get_f("serial#", str, sizeof(str)) > 0) { puts(", serial# "); puts(str); } @@ -198,7 +198,7 @@ void get_board_serial(struct tag_serialnr *serialnr) { char *str;
- char *serial = getenv("serial#"); + char *serial = env_get("serial#"); if (serial) { str = strchr(serial, '_'); if (str && (strlen(str) >= 4)) { @@ -231,7 +231,8 @@ int misc_init_r(void) * In some cases this this needs to be set to 4. * Check the user has set environment mdiv to 4 to change the divisor. */ - if ((str = getenv("mdiv")) && (strcmp(str, "4") == 0)) { + str = env_get("mdiv"); + if (str && (strcmp(str, "4") == 0)) { writel((readl(&pmc->mckr) & ~AT91_PMC_MDIV) | AT91SAM9_PMC_MDIV_4, &pmc->mckr); at91_clock_init(CONFIG_SYS_AT91_MAIN_CLOCK); diff --git a/board/freescale/b4860qds/b4860qds.c b/board/freescale/b4860qds/b4860qds.c index 83a70153e8..5d872fdfd9 100644 --- a/board/freescale/b4860qds/b4860qds.c +++ b/board/freescale/b4860qds/b4860qds.c @@ -195,7 +195,7 @@ static int adjust_vdd(ulong vdd_override) vid, vdd_target/10);
/* check override variable for overriding VDD */ - vdd_string = getenv("b4qds_vdd_mv"); + vdd_string = env_get("b4qds_vdd_mv"); if (vdd_override == 0 && vdd_string && !strict_strtoul(vdd_string, 10, &vdd_string_override)) vdd_override = vdd_string_override; @@ -542,7 +542,7 @@ int configure_vsc3316_3308(void) * Extract hwconfig from environment since environment * is not setup properly yet */ - getenv_f("hwconfig", buffer, sizeof(buffer)); + env_get_f("hwconfig", buffer, sizeof(buffer)); buf = buffer;
if (hwconfig_subarg_cmp_f("fsl_b4860_serdes2", @@ -1197,8 +1197,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/bsc9131rdb/bsc9131rdb.c b/board/freescale/bsc9131rdb/bsc9131rdb.c index fb8bb39d87..c642e88a09 100644 --- a/board/freescale/bsc9131rdb/bsc9131rdb.c +++ b/board/freescale/bsc9131rdb/bsc9131rdb.c @@ -65,8 +65,8 @@ int ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_memory(blob, (u64)base, (u64)size); #ifdef CONFIG_FDT_FIXUP_PARTITIONS diff --git a/board/freescale/bsc9132qds/bsc9132qds.c b/board/freescale/bsc9132qds/bsc9132qds.c index a7772c4bf4..ed0b453e54 100644 --- a/board/freescale/bsc9132qds/bsc9132qds.c +++ b/board/freescale/bsc9132qds/bsc9132qds.c @@ -370,8 +370,8 @@ int ft_board_setup(void *blob, bd_t *bd)
#if defined(CONFIG_PCI) FT_FSL_PCI_SETUP; diff --git a/board/freescale/c29xpcie/c29xpcie.c b/board/freescale/c29xpcie/c29xpcie.c index 45f463f01f..23901a4f96 100644 --- a/board/freescale/c29xpcie/c29xpcie.c +++ b/board/freescale/c29xpcie/c29xpcie.c @@ -138,8 +138,8 @@ int ft_board_setup(void *blob, bd_t *bd)
#if defined(CONFIG_PCI) FT_FSL_PCI_SETUP; diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index c593cff5e7..152ad84672 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -478,7 +478,7 @@ int mac_read_from_eeprom(void) /* Only initialize environment variables that are blank * (i.e. have not yet been set) */ - if (!getenv(enetvar)) + if (!env_get(enetvar)) env_set(enetvar, ethaddr); } } diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index 9b65c13b1a..d6d1bfc861 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -376,7 +376,7 @@ int adjust_vdd(ulong vdd_override) vdd_target = vdd[vid];
/* check override variable for overriding VDD */ - vdd_string = getenv(CONFIG_VID_FLS_ENV); + vdd_string = env_get(CONFIG_VID_FLS_ENV); if (vdd_override == 0 && vdd_string && !strict_strtoul(vdd_string, 10, &vdd_string_override)) vdd_override = vdd_string_override; @@ -560,7 +560,7 @@ int adjust_vdd(ulong vdd_override) vdd_target = vdd[vid];
/* check override variable for overriding VDD */ - vdd_string = getenv(CONFIG_VID_FLS_ENV); + vdd_string = env_get(CONFIG_VID_FLS_ENV); if (vdd_override == 0 && vdd_string && !strict_strtoul(vdd_string, 10, &vdd_string_override)) vdd_override = vdd_string_override; diff --git a/board/freescale/corenet_ds/corenet_ds.c b/board/freescale/corenet_ds/corenet_ds.c index 93e1258295..132650c938 100644 --- a/board/freescale/corenet_ds/corenet_ds.c +++ b/board/freescale/corenet_ds/corenet_ds.c @@ -191,8 +191,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index defcac5263..aca29bc361 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -449,7 +449,7 @@ static void initialize_dpmac_to_slot(void) >> FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT;
char *env_hwconfig; - env_hwconfig = getenv("hwconfig"); + env_hwconfig = env_get("hwconfig");
switch (serdes1_prtcl) { case 0x07: @@ -603,7 +603,7 @@ void ls2080a_handle_phy_interface_sgmii(int dpmac_id) >> FSL_CHASSIS3_RCWSR28_SRDS2_PRTCL_SHIFT;
int *riser_phy_addr; - char *env_hwconfig = getenv("hwconfig"); + char *env_hwconfig = env_get("hwconfig");
if (hwconfig_f("xqsgmii", env_hwconfig)) riser_phy_addr = &xqsgii_riser_phy_addr[0]; @@ -849,7 +849,7 @@ int board_eth_init(bd_t *bis) unsigned int i; char *env_hwconfig;
initialize_dpmac_to_slot();
diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index f36fb9810b..83773d0af5 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -204,7 +204,7 @@ int board_init(void)
val = in_le32(dcfg_ccsr + DCFG_RCWSR13 / 4);
if (hwconfig_f("dspi", env_hwconfig) && DCFG_RCWSR13_DSPI == (val & (u32)(0xf << 8))) diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index df2d768718..ed1fbb23fe 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -215,7 +215,7 @@ int board_init(void)
if (hwconfig_f("dspi", env_hwconfig) && DCFG_RCWSR13_DSPI == (val & (u32)(0xf << 8))) diff --git a/board/freescale/mpc837xemds/pci.c b/board/freescale/mpc837xemds/pci.c index 39c40e5cc9..e5d3dfd454 100644 --- a/board/freescale/mpc837xemds/pci.c +++ b/board/freescale/mpc837xemds/pci.c @@ -67,7 +67,7 @@ static struct pci_region pcie_regions_1[] = {
static int is_pex_x2(void) { - const char *pex_x2 = getenv("pex_x2"); + const char *pex_x2 = env_get("pex_x2");
if (pex_x2 && !strcmp(pex_x2, "yes")) return 1; diff --git a/board/freescale/mpc837xerdb/mpc837xerdb.c b/board/freescale/mpc837xerdb/mpc837xerdb.c index 319f0479e2..9a0ab7f2ad 100644 --- a/board/freescale/mpc837xerdb/mpc837xerdb.c +++ b/board/freescale/mpc837xerdb/mpc837xerdb.c @@ -173,7 +173,7 @@ int board_mmc_init(bd_t *bd) char buffer[HWCONFIG_BUFFER_SIZE] = {0}; int esdhc_hwconfig_enabled = 0;
- if (getenv_f("hwconfig", buffer, sizeof(buffer)) > 0) + if (env_get_f("hwconfig", buffer, sizeof(buffer)) > 0) esdhc_hwconfig_enabled = hwconfig_f("esdhc", buffer);
if (esdhc_hwconfig_enabled == 0) diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index ed6836a930..93d54f5c4a 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -239,8 +239,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/mx51evk/mx51evk_video.c b/board/freescale/mx51evk/mx51evk_video.c index 86ec7508db..cc2c855b88 100644 --- a/board/freescale/mx51evk/mx51evk_video.c +++ b/board/freescale/mx51evk/mx51evk_video.c @@ -76,7 +76,7 @@ void setup_iomux_lcd(void) int board_video_skip(void) { int ret; - char const *e = getenv("panel"); + char const *e = env_get("panel");
if (e) { if (strcmp(e, "claa") == 0) { diff --git a/board/freescale/mx53loco/mx53loco_video.c b/board/freescale/mx53loco/mx53loco_video.c index bc5e8a9d3e..5fb0f04387 100644 --- a/board/freescale/mx53loco/mx53loco_video.c +++ b/board/freescale/mx53loco/mx53loco_video.c @@ -92,7 +92,7 @@ void setup_iomux_lcd(void) int board_video_skip(void) { int ret; - char const *e = getenv("panel"); + char const *e = env_get("panel");
if (e) { if (strcmp(e, "seiko") == 0) { diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 65bb575a96..aa04e993c4 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -453,8 +453,8 @@ int ft_board_setup(void *blob, bd_t *bd)
#if defined(CONFIG_PCI) FT_FSL_PCI_SETUP; diff --git a/board/freescale/p1022ds/p1022ds.c b/board/freescale/p1022ds/p1022ds.c index 345feac0b2..bf493262d0 100644 --- a/board/freescale/p1022ds/p1022ds.c +++ b/board/freescale/p1022ds/p1022ds.c @@ -339,8 +339,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/p1023rdb/p1023rdb.c b/board/freescale/p1023rdb/p1023rdb.c index 0451722603..ccda824125 100644 --- a/board/freescale/p1023rdb/p1023rdb.c +++ b/board/freescale/p1023rdb/p1023rdb.c @@ -137,8 +137,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 51217c58e5..31c8ed9ae1 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -350,7 +350,8 @@ int board_eth_init(bd_t *bis)
#ifdef CONFIG_VSC7385_ENET /* If a VSC7385 microcode image is present, then upload it. */ - if ((tmp = getenv("vscfw_addr")) != NULL) { + tmp = env_get("vscfw_addr"); + if (tmp) { vscfw_addr = simple_strtoul(tmp, NULL, 16); printf("uploading VSC7385 microcode from %x\n", vscfw_addr); if (vsc7385_upload_firmware((void *) vscfw_addr, @@ -438,8 +439,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/p1_twr/p1_twr.c b/board/freescale/p1_twr/p1_twr.c index f54a6ff8dc..02c89998cb 100644 --- a/board/freescale/p1_twr/p1_twr.c +++ b/board/freescale/p1_twr/p1_twr.c @@ -268,8 +268,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/p2041rdb/p2041rdb.c b/board/freescale/p2041rdb/p2041rdb.c index 21fb66f184..78ee74770c 100644 --- a/board/freescale/p2041rdb/p2041rdb.c +++ b/board/freescale/p2041rdb/p2041rdb.c @@ -219,8 +219,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/t102xqds/t102xqds.c b/board/freescale/t102xqds/t102xqds.c index 1b2f6b2487..20374baf48 100644 --- a/board/freescale/t102xqds/t102xqds.c +++ b/board/freescale/t102xqds/t102xqds.c @@ -363,8 +363,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/t102xrdb/t102xrdb.c b/board/freescale/t102xrdb/t102xrdb.c index f370f72baa..8885a546fa 100644 --- a/board/freescale/t102xrdb/t102xrdb.c +++ b/board/freescale/t102xrdb/t102xrdb.c @@ -186,8 +186,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/t1040qds/t1040qds.c b/board/freescale/t1040qds/t1040qds.c index 5466fbf5f6..a36997b48c 100644 --- a/board/freescale/t1040qds/t1040qds.c +++ b/board/freescale/t1040qds/t1040qds.c @@ -245,8 +245,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/t104xrdb/t104xrdb.c b/board/freescale/t104xrdb/t104xrdb.c index d4c3d4dcb4..2818cdf274 100644 --- a/board/freescale/t104xrdb/t104xrdb.c +++ b/board/freescale/t104xrdb/t104xrdb.c @@ -132,8 +132,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/t208xqds/t208xqds.c b/board/freescale/t208xqds/t208xqds.c index 26093ea9d2..ed3d3f4b71 100644 --- a/board/freescale/t208xqds/t208xqds.c +++ b/board/freescale/t208xqds/t208xqds.c @@ -451,8 +451,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/t208xrdb/t208xrdb.c b/board/freescale/t208xrdb/t208xrdb.c index 1ab05ec9fd..619495e6ab 100644 --- a/board/freescale/t208xrdb/t208xrdb.c +++ b/board/freescale/t208xrdb/t208xrdb.c @@ -118,8 +118,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/t4qds/t4240emu.c b/board/freescale/t4qds/t4240emu.c index 35ad19e045..7136acafea 100644 --- a/board/freescale/t4qds/t4240emu.c +++ b/board/freescale/t4qds/t4240emu.c @@ -70,8 +70,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/t4qds/t4240qds.c b/board/freescale/t4qds/t4240qds.c index 8f9e7e8255..7b71b541fd 100644 --- a/board/freescale/t4qds/t4240qds.c +++ b/board/freescale/t4qds/t4240qds.c @@ -265,7 +265,7 @@ static int adjust_vdd(ulong vdd_override) vdd_target = vdd[vid];
/* check override variable for overriding VDD */ - vdd_string = getenv("t4240qds_vdd_mv"); + vdd_string = env_get("t4240qds_vdd_mv"); if (vdd_override == 0 && vdd_string && !strict_strtoul(vdd_string, 10, &vdd_string_override)) vdd_override = vdd_string_override; @@ -684,8 +684,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/freescale/t4rdb/t4240rdb.c b/board/freescale/t4rdb/t4240rdb.c index bdd6f4ef49..f511706b9f 100644 --- a/board/freescale/t4rdb/t4240rdb.c +++ b/board/freescale/t4rdb/t4240rdb.c @@ -97,8 +97,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 46404b4d59..e9865b4adb 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -1160,7 +1160,7 @@ void setup_board_gpio(int board, struct ventana_board_info *info) char arg[10]; size_t len; int i; - int quiet = simple_strtol(getenv("quiet"), NULL, 10); + int quiet = simple_strtol(env_get("quiet"), NULL, 10);
if (board >= GW_UNKNOWN) return; diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 61298ab2fd..4ddc7e1fa2 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -298,11 +298,11 @@ int board_eth_init(bd_t *bis) #endif
/* default to the first detected enet dev */ - if (!getenv("ethprime")) { + if (!env_get("ethprime")) { struct eth_device *dev = eth_get_dev_by_index(0); if (dev) { env_set("ethprime", dev->name); - printf("set ethprime to %s\n", getenv("ethprime")); + printf("set ethprime to %s\n", env_get("ethprime")); } }
@@ -579,7 +579,7 @@ void board_pci_fixup_dev(struct pci_controller *hose, pci_dev_t dev, */ void get_board_serial(struct tag_serialnr *serialnr) { - char *serial = getenv("serial#"); + char *serial = env_get("serial#");
if (serial) { serialnr->high = 0; @@ -658,7 +658,7 @@ int checkboard(void) int quiet; /* Quiet or minimal output mode */
quiet = 0; - p = getenv("quiet"); + p = env_get("quiet"); if (p) quiet = simple_strtol(p, NULL, 10); else @@ -746,7 +746,7 @@ int misc_init_r(void) for (i = 0; i < (sizeof(str)-1) && info->model[i]; i++) str[i] = tolower(info->model[i]); env_set("model", str); - if (!getenv("fdt_file")) { + if (!env_get("fdt_file")) { sprintf(fdt, "%s-%s.dtb", cputype, str); env_set("fdt_file", fdt); } @@ -770,11 +770,11 @@ int misc_init_r(void)
/* initialize env from EEPROM */ if (test_bit(EECONFIG_ETH0, info->config) && - !getenv("ethaddr")) { + !env_get("ethaddr")) { eth_env_set_enetaddr("ethaddr", info->mac0); } if (test_bit(EECONFIG_ETH1, info->config) && - !getenv("eth1addr")) { + !env_get("eth1addr")) { eth_env_set_enetaddr("eth1addr", info->mac1); }
@@ -788,7 +788,7 @@ int misc_init_r(void) }
/* Set a non-initialized hwconfig based on board configuration */ - if (!strcmp(getenv("hwconfig"), "_UNKNOWN_")) { + if (!strcmp(env_get("hwconfig"), "_UNKNOWN_")) { buf[0] = 0; if (gpio_cfg[board_type].rs232_en) strcat(buf, "rs232;"); @@ -1035,7 +1035,7 @@ int fdt_fixup_sky2(void *blob, int np, struct pci_dev *dev) int j;
sprintf(mac, "eth1addr"); - tmp = getenv(mac); + tmp = env_get(mac); if (tmp) { for (j = 0; j < 6; j++) { mac_addr[j] = tmp ? @@ -1118,8 +1118,8 @@ int ft_board_setup(void *blob, bd_t *bd) { "sst,w25q256", MTD_DEV_TYPE_NOR, }, /* SPI flash */ { "fsl,imx6q-gpmi-nand", MTD_DEV_TYPE_NAND, }, /* NAND flash */ }; - const char *model = getenv("model"); - const char *display = getenv("display"); + const char *model = env_get("model"); + const char *display = env_get("display"); int i; char rev = 0;
@@ -1131,7 +1131,7 @@ int ft_board_setup(void *blob, bd_t *bd) } }
- if (getenv("fdt_noauto")) { + if (env_get("fdt_noauto")) { puts(" Skiping ft_board_setup (fdt_noauto defined)\n"); return 0; } @@ -1152,15 +1152,15 @@ int ft_board_setup(void *blob, bd_t *bd) printf(" Adjusting FDT per EEPROM for %s...\n", model);
/* board serial number */ - fdt_setprop(blob, 0, "system-serial", getenv("serial#"), - strlen(getenv("serial#")) + 1); + fdt_setprop(blob, 0, "system-serial", env_get("serial#"), + strlen(env_get("serial#")) + 1);
/* board (model contains model from device-tree) */ fdt_setprop(blob, 0, "board", info->model, strlen((const char *)info->model) + 1);
/* set desired digital video capture format */ - ft_sethdmiinfmt(blob, getenv("hdmiinfmt")); + ft_sethdmiinfmt(blob, env_get("hdmiinfmt"));
/* * Board model specific fixups @@ -1315,7 +1315,7 @@ int ft_board_setup(void *blob, bd_t *bd) }
#if defined(CONFIG_CMD_PCI) - if (!getenv("nopcifixup")) + if (!env_get("nopcifixup")) ft_board_pci_fixup(blob, bd); #endif
@@ -1324,7 +1324,7 @@ int ft_board_setup(void *blob, bd_t *bd) * remove nodes by alias path if EEPROM config tells us the * peripheral is not loaded on the board. */ - if (getenv("fdt_noconfig")) { + if (env_get("fdt_noconfig")) { puts(" Skiping periperhal config (fdt_noconfig defined)\n"); return 0; } diff --git a/board/gateworks/gw_ventana/gw_ventana_spl.c b/board/gateworks/gw_ventana/gw_ventana_spl.c index baa8480b6c..9524da7daf 100644 --- a/board/gateworks/gw_ventana/gw_ventana_spl.c +++ b/board/gateworks/gw_ventana/gw_ventana_spl.c @@ -691,8 +691,8 @@ int spl_start_uboot(void) #ifdef CONFIG_SPL_ENV_SUPPORT env_init(); env_load(); - debug("boot_os=%s\n", getenv("boot_os")); - if (getenv_yesno("boot_os") == 1) + debug("boot_os=%s\n", env_get("boot_os")); + if (env_get_yesno("boot_os") == 1) ret = 0; #else /* use i2c-0:0x50:0x00 for falcon boot mode (0=linux, else uboot) */ diff --git a/board/gdsys/a38x/keyprogram.c b/board/gdsys/a38x/keyprogram.c index a4a6f1cca5..d75e08b39f 100644 --- a/board/gdsys/a38x/keyprogram.c +++ b/board/gdsys/a38x/keyprogram.c @@ -129,12 +129,12 @@ int load_and_run_keyprog(void) char *hexprog; struct key_program *prog;
- cmd = getenv("loadkeyprogram"); + cmd = env_get("loadkeyprogram");
if (!cmd || run_command(cmd, 0)) return 1;
- hexprog = getenv("keyprogram"); + hexprog = env_get("keyprogram");
if (decode_hexstr(hexprog, &binprog)) return 1; diff --git a/board/gdsys/mpc8308/hrcon.c b/board/gdsys/mpc8308/hrcon.c index c6566e9196..7e485074ce 100644 --- a/board/gdsys/mpc8308/hrcon.c +++ b/board/gdsys/mpc8308/hrcon.c @@ -103,7 +103,7 @@ int fpga_get_reg(u32 fpga, u16 *reg, off_t regoff, u16 *data)
int checkboard(void) { - char *s = getenv("serial#"); + char *s = env_get("serial#"); bool hw_type_cat = pca9698_get_value(0x20, 20);
puts("Board: "); diff --git a/board/gdsys/mpc8308/strider.c b/board/gdsys/mpc8308/strider.c index 34e9d1956e..fec691515d 100644 --- a/board/gdsys/mpc8308/strider.c +++ b/board/gdsys/mpc8308/strider.c @@ -106,7 +106,7 @@ int fpga_get_reg(u32 fpga, u16 *reg, off_t regoff, u16 *data)
int checkboard(void) { - char *s = getenv("serial#"); + char *s = env_get("serial#"); bool hw_type_cat = pca9698_get_value(0x20, 18);
puts("Board: "); diff --git a/board/gdsys/p1022/controlcenterd-id.c b/board/gdsys/p1022/controlcenterd-id.c index 95f11fb69f..1813a58e60 100644 --- a/board/gdsys/p1022/controlcenterd-id.c +++ b/board/gdsys/p1022/controlcenterd-id.c @@ -217,7 +217,7 @@ static u8 *get_2nd_stage_bl_location(ulong target_addr) { ulong addr; #ifdef CCDM_SECOND_STAGE - addr = getenv_ulong("loadaddr", 16, CONFIG_LOADADDR); + addr = env_get_ulong("loadaddr", 16, CONFIG_LOADADDR); #else addr = target_addr; #endif @@ -235,7 +235,7 @@ static u8 *get_image_location(void) { ulong addr; /* TODO use other area? */ - addr = getenv_ulong("loadaddr", 16, CONFIG_LOADADDR); + addr = env_get_ulong("loadaddr", 16, CONFIG_LOADADDR); return (u8 *)(addr); } #endif @@ -1043,13 +1043,13 @@ static int second_stage_init(void) goto failure;
/* run "prepboot" from env to get "mmcdev" set */ - cptr = getenv("prepboot"); + cptr = env_get("prepboot"); if (cptr && !run_command(cptr, 0)) - mmcdev = getenv("mmcdev"); + mmcdev = env_get("mmcdev"); if (!mmcdev) goto failure;
- cptr = getenv("ramdiskimage"); + cptr = env_get("ramdiskimage"); if (cptr) image_path = cptr;
diff --git a/board/gdsys/p1022/controlcenterd.c b/board/gdsys/p1022/controlcenterd.c index 01064dcfde..9fb814d8c7 100644 --- a/board/gdsys/p1022/controlcenterd.c +++ b/board/gdsys/p1022/controlcenterd.c @@ -223,7 +223,7 @@ void hw_watchdog_reset(void) #ifdef CONFIG_TRAILBLAZER int do_bootd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - return run_command(getenv("bootcmd"), flag); + return run_command(env_get("bootcmd"), flag); }
int board_early_init_r(void) @@ -335,8 +335,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/grinn/chiliboard/board.c b/board/grinn/chiliboard/board.c index 2900109bbd..2f5974a246 100644 --- a/board/grinn/chiliboard/board.c +++ b/board/grinn/chiliboard/board.c @@ -126,7 +126,7 @@ int board_late_init(void) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
if (is_valid_ethaddr(mac_addr)) @@ -142,7 +142,7 @@ int board_late_init(void) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
- if (!getenv("eth1addr")) { + if (!env_get("eth1addr")) { if (is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("eth1addr", mac_addr); } diff --git a/board/grinn/liteboard/board.c b/board/grinn/liteboard/board.c index 24956927ac..941e7ea2c8 100644 --- a/board/grinn/liteboard/board.c +++ b/board/grinn/liteboard/board.c @@ -149,7 +149,7 @@ int board_mmc_init(bd_t *bis)
static int check_mmc_autodetect(void) { - char *autodetect_str = getenv("mmcautodetect"); + char *autodetect_str = env_get("mmcautodetect");
if ((autodetect_str != NULL) && (strcmp(autodetect_str, "yes") == 0)) { diff --git a/board/gumstix/pepper/board.c b/board/gumstix/pepper/board.c index 7e8b014e3d..bfc5fd1c46 100644 --- a/board/gumstix/pepper/board.c +++ b/board/gumstix/pepper/board.c @@ -239,7 +239,7 @@ int board_eth_init(bd_t *bis) uint32_t mac_hi, mac_lo; const char *devname;
- if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { /* try reading mac address from efuse */ mac_lo = readl(&cdev->macid0l); mac_hi = readl(&cdev->macid0h); diff --git a/board/highbank/highbank.c b/board/highbank/highbank.c index e51043aa91..f7c05ab08f 100644 --- a/board/highbank/highbank.c +++ b/board/highbank/highbank.c @@ -80,7 +80,7 @@ int misc_init_r(void)
boot_choice = readl(HB_SREG_A9_BOOT_SRC_STAT) & 0xff; sprintf(envbuffer, "bootcmd%d", boot_choice); - if (getenv(envbuffer)) { + if (env_get(envbuffer)) { sprintf(envbuffer, "run bootcmd%d", boot_choice); env_set("bootcmd", envbuffer); } else diff --git a/board/isee/igep003x/board.c b/board/isee/igep003x/board.c index 1aa2f52069..d33dc960a5 100644 --- a/board/isee/igep003x/board.c +++ b/board/isee/igep003x/board.c @@ -264,7 +264,7 @@ int board_eth_init(bd_t *bis) uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo;
- if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { /* try reading mac address from efuse */ mac_lo = readl(&cdev->macid0l); mac_hi = readl(&cdev->macid0h); diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 56d3044241..6cd281218e 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -54,7 +54,7 @@ int set_km_env(void) env_set("pnvramaddr", (char *)buf);
/* try to read rootfssize (ram image) from environment */ - p = getenv("rootfssize"); + p = env_get("rootfssize"); if (p != NULL) strict_strtoul(p, 16, &rootfssize); pram = (rootfssize + CONFIG_KM_RESERVED_PRAM + CONFIG_KM_PHRAM + @@ -236,10 +236,10 @@ static int do_checkboardidhwk(cmd_tbl_t *cmdtp, int flag, int argc, }
/* now try to read values from environment if available */ - p = getenv("boardid"); + p = env_get("boardid"); if (p != NULL) rc = strict_strtoul(p, 16, &envbid); - p = getenv("hwkey"); + p = env_get("hwkey"); if (p != NULL) rc = strict_strtoul(p, 16, &envhwkey);
@@ -253,7 +253,7 @@ static int do_checkboardidhwk(cmd_tbl_t *cmdtp, int flag, int argc, * BoardId/HWkey not available in the environment, so try the * environment variable for BoardId/HWkey list */ - char *bidhwklist = getenv("boardIdListHex"); + char *bidhwklist = env_get("boardIdListHex");
if (bidhwklist) { int found = 0; @@ -355,7 +355,7 @@ static int do_checktestboot(cmd_tbl_t *cmdtp, int flag, int argc, #if defined(CONFIG_POST) testpin = post_hotkeys_pressed(); #endif - s = getenv("test_bank"); + s = env_get("test_bank"); /* when test_bank is not set, act as if testpin is not asserted */ testboot = (testpin != 0) && (s); if (verbose) { diff --git a/board/keymile/common/ivm.c b/board/keymile/common/ivm.c index cfb3494053..3c8de10c1d 100644 --- a/board/keymile/common/ivm.c +++ b/board/keymile/common/ivm.c @@ -254,7 +254,7 @@ int ivm_analyze_eeprom(unsigned char *buf, int len)
GET_STRING("IVM_Symbol", IVM_POS_SYMBOL_ONLY, 8) GET_STRING("IVM_DeviceName", IVM_POS_SHORT_TEXT, 64) - tmp = (unsigned char *) getenv("IVM_DeviceName"); + tmp = (unsigned char *)env_get("IVM_DeviceName"); if (tmp) { int len = strlen((char *)tmp); int i = 0; @@ -302,11 +302,11 @@ static int ivm_populate_env(unsigned char *buf, int len)
/* if an offset is defined, add it */ process_mac(valbuf, page2, CONFIG_PIGGY_MAC_ADRESS_OFFSET); - if (getenv("ethaddr") == NULL) + if (env_get("ethaddr") == NULL) env_set((char *)"ethaddr", (char *)valbuf); #ifdef CONFIG_KMVECT1 /* KMVECT1 has two ethernet interfaces */ - if (getenv("eth1addr") == NULL) { + if (env_get("eth1addr") == NULL) { process_mac(valbuf, page2, 1); env_set((char *)"eth1addr", (char *)valbuf); } diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index 08ae9ae346..af1ebc4101 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -201,7 +201,7 @@ int misc_init_r(void) #if defined(CONFIG_KM_MGCOGE3UN) char *wait_for_ne; u8 dip_switch = kw_gpio_get_value(KM_FLASH_ERASE_ENABLE); - wait_for_ne = getenv("waitforne"); + wait_for_ne = env_get("waitforne");
if ((wait_for_ne != NULL) && (dip_switch == 0)) { if (strcmp(wait_for_ne, "true") == 0) { diff --git a/board/keymile/kmp204x/kmp204x.c b/board/keymile/kmp204x/kmp204x.c index 095e467ac0..8c9d6b167d 100644 --- a/board/keymile/kmp204x/kmp204x.c +++ b/board/keymile/kmp204x/kmp204x.c @@ -239,7 +239,7 @@ void fdt_fixup_fman_mac_addresses(void *blob) unsigned char mac_addr[6];
/* get the mac addr from env */ - tmp = getenv("ethaddr"); + tmp = env_get("ethaddr"); if (!tmp) { printf("ethaddr env variable not defined\n"); return; @@ -271,8 +271,8 @@ int ft_board_setup(void *blob, bd_t *bd)
diff --git a/board/kosagi/novena/novena.c b/board/kosagi/novena/novena.c index baca7223fa..f0ace03009 100644 --- a/board/kosagi/novena/novena.c +++ b/board/kosagi/novena/novena.c @@ -240,7 +240,7 @@ int misc_init_r(void) int ret;
/* If 'ethaddr' is already set, do nothing. */ - if (getenv("ethaddr")) + if (env_get("ethaddr")) return 0;
/* EEPROM is at bus 2. */ diff --git a/board/lg/sniper/sniper.c b/board/lg/sniper/sniper.c index 4906e4f9d2..a299f761f9 100644 --- a/board/lg/sniper/sniper.c +++ b/board/lg/sniper/sniper.c @@ -133,7 +133,7 @@ int misc_init_r(void) }
diff --git a/board/liebherr/mccmon6/mccmon6.c b/board/liebherr/mccmon6/mccmon6.c index 8d0a66621d..4f7e018dea 100644 --- a/board/liebherr/mccmon6/mccmon6.c +++ b/board/liebherr/mccmon6/mccmon6.c @@ -467,7 +467,7 @@ int spl_start_uboot(void) return 1;
env_init(); - ret = getenv_f("boot_os", s, sizeof(s)); + ret = env_get_f("boot_os", s, sizeof(s)); if ((ret != -1) && (strcmp(s, "no") == 0)) return 1;
@@ -481,7 +481,7 @@ int spl_start_uboot(void) * recovery_status = <any value> -> start SWUpdate * */ - ret = getenv_f("recovery_status", s, sizeof(s)); + ret = env_get_f("recovery_status", s, sizeof(s)); if (ret != -1) return 1;
diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 8885d1e6a9..faf04df99f 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -219,7 +219,7 @@ int board_late_init(void) gd->bd->bi_arch_number = board->machine_id;
/* If the user has not set fdtimage, set the default */ - if (!getenv("fdtimage")) + if (!env_get("fdtimage")) env_set("fdtimage", board->fdtfile); }
diff --git a/board/logicpd/zoom1/zoom1.c b/board/logicpd/zoom1/zoom1.c index f76223cacd..e6c2526ea1 100644 --- a/board/logicpd/zoom1/zoom1.c +++ b/board/logicpd/zoom1/zoom1.c @@ -130,7 +130,7 @@ int board_eth_init(bd_t *bis) uchar eth_addr[6];
rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); - if (!eth_getenv_enetaddr(STR_ENV_ETHADDR, eth_addr)) { + if (!eth_env_get_enetaddr(STR_ENV_ETHADDR, eth_addr)) { dev = eth_get_dev_by_index(0); if (dev) { eth_env_set_enetaddr(STR_ENV_ETHADDR, dev->enetaddr); diff --git a/board/micronas/vct/vct.c b/board/micronas/vct/vct.c index 8bf8d5f4e8..510746d35c 100644 --- a/board/micronas/vct/vct.c +++ b/board/micronas/vct/vct.c @@ -72,7 +72,7 @@ int dram_init(void) int checkboard(void) { char buf[64]; - int i = getenv_f("serial#", buf, sizeof(buf)); + int i = env_get_f("serial#", buf, sizeof(buf)); u32 config0 = read_c0_prid();
if ((config0 & 0xff0000) == PRID_COMP_LEGACY diff --git a/board/nokia/rx51/rx51.c b/board/nokia/rx51/rx51.c index 889e748f98..7764288811 100644 --- a/board/nokia/rx51/rx51.c +++ b/board/nokia/rx51/rx51.c @@ -234,18 +234,18 @@ void setup_board_tags(struct tag **in_params) params->u.core.rootdev = 0x0;
/* append omap atag only if env setup_omap_atag is set to 1 */ - str = getenv("setup_omap_atag"); + str = env_get("setup_omap_atag"); if (!str || str[0] != '1') return;
- str = getenv("setup_console_atag"); + str = env_get("setup_console_atag"); if (str && str[0] == '1') setup_console_atag = 1; else setup_console_atag = 0;
- setup_boot_reason_atag = getenv("setup_boot_reason_atag"); - setup_boot_mode_atag = getenv("setup_boot_mode_atag"); + setup_boot_reason_atag = env_get("setup_boot_reason_atag"); + setup_boot_mode_atag = env_get("setup_boot_mode_atag");
params = *in_params; t = (struct tag_omap *)¶ms->u; diff --git a/board/phytec/pcm051/board.c b/board/phytec/pcm051/board.c index 0da96e7413..52ad5b64de 100644 --- a/board/phytec/pcm051/board.c +++ b/board/phytec/pcm051/board.c @@ -216,7 +216,7 @@ int board_eth_init(bd_t *bis) uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo;
- if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { printf("<ethaddr> not set. Reading from E-fuse\n"); /* try reading mac address from efuse */ mac_lo = readl(&cdev->macid0l); diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 7ff7b269f9..530f149617 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -247,7 +247,7 @@ static void set_fdtfile(void) { const char *fdtfile;
- if (getenv("fdtfile")) + if (env_get("fdtfile")) return;
fdtfile = model->fdtfile; @@ -260,7 +260,7 @@ static void set_fdtfile(void) */ static void set_fdt_addr(void) { - if (getenv("fdt_addr")) + if (env_get("fdt_addr")) return;
if (fdt_magic(fw_dtb_pointer) != FDT_MAGIC) @@ -287,7 +287,7 @@ static void set_usbethaddr(void) if (!model->has_onboard_eth) return;
- if (getenv("usbethaddr")) + if (env_get("usbethaddr")) return;
BCM2835_MBOX_INIT_HDR(msg); @@ -302,8 +302,8 @@ static void set_usbethaddr(void)
eth_env_set_enetaddr("usbethaddr", msg->get_mac_address.body.resp.mac);
- if (!getenv("ethaddr")) - env_set("ethaddr", getenv("usbethaddr")); + if (!env_get("ethaddr")) + env_set("ethaddr", env_get("usbethaddr"));
return; } @@ -330,7 +330,7 @@ static void set_serial_number(void) int ret; char serial_string[17] = { 0 };
- if (getenv("serial#")) + if (env_get("serial#")) return;
BCM2835_MBOX_INIT_HDR(msg); diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index b35b6a3ad1..0bf8160f1f 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -143,7 +143,7 @@ int board_eth_init(bd_t *bis) unsigned char enetaddr[6];
ret = sh_eth_initialize(bis); - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) + if (!eth_env_get_enetaddr("ethaddr", enetaddr)) return ret;
/* Set Mac address */ diff --git a/board/renesas/blanche/blanche.c b/board/renesas/blanche/blanche.c index e3262f779a..574dcda01b 100644 --- a/board/renesas/blanche/blanche.c +++ b/board/renesas/blanche/blanche.c @@ -418,7 +418,7 @@ int board_eth_init(bd_t *bis)
- if (!eth_getenv_enetaddr(STR_ENV_ETHADDR, eth_addr)) { + if (!eth_env_get_enetaddr(STR_ENV_ETHADDR, eth_addr)) { dev = eth_get_dev_by_index(0); if (dev) { eth_env_set_enetaddr(STR_ENV_ETHADDR, dev->enetaddr); diff --git a/board/renesas/gose/gose.c b/board/renesas/gose/gose.c index 359f95e264..54e126985b 100644 --- a/board/renesas/gose/gose.c +++ b/board/renesas/gose/gose.c @@ -126,7 +126,7 @@ int board_eth_init(bd_t *bis)
#ifdef CONFIG_SH_ETHER ret = sh_eth_initialize(bis); - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) + if (!eth_env_get_enetaddr("ethaddr", enetaddr)) return ret;
/* Set Mac address */ diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c index dd62145ac9..8fa648e40a 100644 --- a/board/renesas/koelsch/koelsch.c +++ b/board/renesas/koelsch/koelsch.c @@ -131,7 +131,7 @@ int board_eth_init(bd_t *bis) unsigned char enetaddr[6];
/* Set Mac address */ diff --git a/board/renesas/lager/lager.c b/board/renesas/lager/lager.c index 2ada816006..562be04760 100644 --- a/board/renesas/lager/lager.c +++ b/board/renesas/lager/lager.c @@ -136,7 +136,7 @@ int board_eth_init(bd_t *bis) unsigned char enetaddr[6];
/* Set Mac address */ diff --git a/board/renesas/porter/porter.c b/board/renesas/porter/porter.c index 926a657511..5b1a167906 100644 --- a/board/renesas/porter/porter.c +++ b/board/renesas/porter/porter.c @@ -126,7 +126,7 @@ int board_eth_init(bd_t *bis) unsigned char enetaddr[6];
/* Set Mac address */ diff --git a/board/renesas/silk/silk.c b/board/renesas/silk/silk.c index e13a38f5ea..a8de402d20 100644 --- a/board/renesas/silk/silk.c +++ b/board/renesas/silk/silk.c @@ -135,7 +135,7 @@ int board_eth_init(bd_t *bis) unsigned char enetaddr[6];
/* Set Mac address */ diff --git a/board/renesas/stout/stout.c b/board/renesas/stout/stout.c index fe8dd3d952..d681148273 100644 --- a/board/renesas/stout/stout.c +++ b/board/renesas/stout/stout.c @@ -137,7 +137,7 @@ int board_eth_init(bd_t *bis) unsigned char enetaddr[6];
/* Set Mac address */ diff --git a/board/samsung/common/exynos5-dt.c b/board/samsung/common/exynos5-dt.c index 44f412db5d..ae2a6e6bfa 100644 --- a/board/samsung/common/exynos5-dt.c +++ b/board/samsung/common/exynos5-dt.c @@ -179,7 +179,7 @@ char *get_dfu_alt_system(char *interface, char *devstr) if (board_is_odroidxu4()) return info;
- return getenv("dfu_alt_system"); + return env_get("dfu_alt_system"); }
char *get_dfu_alt_boot(char *interface, char *devstr) diff --git a/board/samsung/odroid/odroid.c b/board/samsung/odroid/odroid.c index b4cb33240e..e40a2f6e3a 100644 --- a/board/samsung/odroid/odroid.c +++ b/board/samsung/odroid/odroid.c @@ -66,7 +66,7 @@ const char *get_board_type(void) #ifdef CONFIG_SET_DFU_ALT_INFO char *get_dfu_alt_system(char *interface, char *devstr) { - return getenv("dfu_alt_system"); + return env_get("dfu_alt_system"); }
char *get_dfu_alt_boot(char *interface, char *devstr) diff --git a/board/samtec/vining_2000/vining_2000.c b/board/samtec/vining_2000/vining_2000.c index 125f6e7070..af1a3e75cb 100644 --- a/board/samtec/vining_2000/vining_2000.c +++ b/board/samtec/vining_2000/vining_2000.c @@ -131,7 +131,7 @@ int board_eth_init(bd_t *bis)
/* just to get secound mac address */ imx_get_mac_from_fuse(1, eth1addr); - if (!getenv("eth1addr") && is_valid_ethaddr(eth1addr)) + if (!env_get("eth1addr") && is_valid_ethaddr(eth1addr)) eth_env_set_enetaddr("eth1addr", eth1addr);
imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); diff --git a/board/samtec/vining_fpga/socfpga.c b/board/samtec/vining_fpga/socfpga.c index 760fc71217..229b12f308 100644 --- a/board/samtec/vining_fpga/socfpga.c +++ b/board/samtec/vining_fpga/socfpga.c @@ -76,7 +76,7 @@ int misc_init_r(void) }
/* If 'unit_serial' is already set, do nothing. */ - if (!getenv("unit_serial")) { + if (!env_get("unit_serial")) { /* This field is Big Endian ! */ serial = (data[0x54] << 24) | (data[0x55] << 16) | (data[0x56] << 8) | (data[0x57] << 0); @@ -85,14 +85,14 @@ int misc_init_r(void) env_set("unit_serial", str); }
- if (!getenv("unit_ident")) { + if (!env_get("unit_ident")) { memset(str, 0, sizeof(str)); memcpy(str, &data[0x2e], 18); env_set("unit_ident", str); }
/* Set ethernet address from EEPROM. */ - if (!getenv("ethaddr") && is_valid_ethaddr(&data[0x62])) + if (!env_get("ethaddr") && is_valid_ethaddr(&data[0x62])) eth_env_set_enetaddr("ethaddr", &data[0x62]);
return 0; diff --git a/board/siemens/common/board.c b/board/siemens/common/board.c index b967227411..65fa6af2d4 100644 --- a/board/siemens/common/board.c +++ b/board/siemens/common/board.c @@ -121,7 +121,7 @@ unsigned char get_button_state(char * const envname, unsigned char def) char *ptr_env;
/* If button is not found we take default */ - ptr_env = getenv(envname); + ptr_env = env_get(envname); if (NULL == ptr_env) { gpio = def; } else { @@ -199,7 +199,7 @@ void set_env_gpios(unsigned char state) strcat(str_tmp, num);
/* If env var is not found we stop */ - ptr_env = getenv(str_tmp); + ptr_env = env_get(str_tmp); if (NULL == ptr_env) break;
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index d877a9c771..8390bdd5f8 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -377,7 +377,7 @@ static int upgrade_failure_fallback(void) char *kern_size; char *kern_size_fb;
- partitionset_active = getenv("partitionset_active"); + partitionset_active = env_get("partitionset_active"); if (partitionset_active) { if (partitionset_active[0] == 'A') env_set("partitionset_active", "B"); @@ -388,18 +388,18 @@ static int upgrade_failure_fallback(void) return -ENOENT; }
- rootfs = getenv("rootfs"); - rootfs_fallback = getenv("rootfs_fallback"); + rootfs = env_get("rootfs"); + rootfs_fallback = env_get("rootfs_fallback"); env_set("rootfs", rootfs_fallback); env_set("rootfs_fallback", rootfs);
- kern_size = getenv("kernel_size"); - kern_size_fb = getenv("kernel_size_fallback"); + kern_size = env_get("kernel_size"); + kern_size_fb = env_get("kernel_size_fallback"); env_set("kernel_size", kern_size_fb); env_set("kernel_size_fallback", kern_size);
- kern_off = getenv("kernel_Off"); - kern_off_fb = getenv("kernel_Off_fallback"); + kern_off = env_get("kernel_Off"); + kern_off_fb = env_get("kernel_Off_fallback"); env_set("kernel_Off", kern_off_fb); env_set("kernel_Off_fallback", kern_off);
@@ -418,10 +418,10 @@ static int do_upgrade_available(cmd_tbl_t *cmdtp, int flag, int argc, unsigned long boot_retry = 0; char boot_buf[10];
- upgrade_available = simple_strtoul(getenv("upgrade_available"), NULL, + upgrade_available = simple_strtoul(env_get("upgrade_available"), NULL, 10); if (upgrade_available) { - boot_retry = simple_strtoul(getenv("boot_retries"), NULL, 10); + boot_retry = simple_strtoul(env_get("boot_retries"), NULL, 10); boot_retry++; sprintf(boot_buf, "%lx", boot_retry); env_set("boot_retries", boot_buf); diff --git a/board/silica/pengwyn/board.c b/board/silica/pengwyn/board.c index 057691b045..0429e6f0c7 100644 --- a/board/silica/pengwyn/board.c +++ b/board/silica/pengwyn/board.c @@ -171,7 +171,7 @@ int board_eth_init(bd_t *bis) uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo;
- if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { printf("<ethaddr> not set. Reading from E-fuse\n"); /* try reading mac address from efuse */ mac_lo = readl(&cdev->macid0l); diff --git a/board/socrates/socrates.c b/board/socrates/socrates.c index fb691c22d9..004f37009a 100644 --- a/board/socrates/socrates.c +++ b/board/socrates/socrates.c @@ -38,7 +38,7 @@ int checkboard (void) volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); char buf[64]; int f; - int i = getenv_f("serial#", buf, sizeof(buf)); + int i = env_get_f("serial#", buf, sizeof(buf)); #ifdef CONFIG_PCI char *src; #endif @@ -409,7 +409,7 @@ void board_backlight_switch (int flag) printf ("hwmon IC init failed\n");
if (flag) { - param = getenv("brightness"); + param = env_get("brightness"); rc = param ? simple_strtol(param, NULL, 10) : -1; if (rc < 0) rc = DEFAULT_BRIGHTNESS; diff --git a/board/spear/common/spr_misc.c b/board/spear/common/spr_misc.c index 67de28e7ea..a02304f49e 100644 --- a/board/spear/common/spr_misc.c +++ b/board/spear/common/spr_misc.c @@ -53,7 +53,7 @@ int misc_init_r(void) #if defined(CONFIG_CMD_NET) uchar mac_id[6];
- if (!eth_getenv_enetaddr("ethaddr", mac_id) && !i2c_read_mac(mac_id)) + if (!eth_env_get_enetaddr("ethaddr", mac_id) && !i2c_read_mac(mac_id)) eth_env_set_enetaddr("ethaddr", mac_id); #endif env_set("verify", "n"); diff --git a/board/st/stm32f429-discovery/stm32f429-discovery.c b/board/st/stm32f429-discovery/stm32f429-discovery.c index 673e7728f1..d6763c306f 100644 --- a/board/st/stm32f429-discovery/stm32f429-discovery.c +++ b/board/st/stm32f429-discovery/stm32f429-discovery.c @@ -314,7 +314,7 @@ int misc_init_r(void) char serialno[25]; uint32_t u_id_low, u_id_mid, u_id_high;
- if (!getenv("serial#")) { + if (!env_get("serial#")) { u_id_low = readl(&STM32_U_ID->u_id_low); u_id_mid = readl(&STM32_U_ID->u_id_mid); u_id_high = readl(&STM32_U_ID->u_id_high); diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 26732dc40f..70e01437c4 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -602,7 +602,7 @@ void get_board_serial(struct tag_serialnr *serialnr) char *serial_string; unsigned long long serial;
- serial_string = getenv("serial#"); + serial_string = env_get("serial#");
if (serial_string) { serial = simple_strtoull(serial_string, NULL, 16); @@ -694,7 +694,7 @@ static void setup_environment(const void *fdt) else sprintf(ethaddr, "eth%daddr", i);
- if (getenv(ethaddr)) + if (env_get(ethaddr)) continue;
/* Non OUI / registered MAC address */ @@ -708,7 +708,7 @@ static void setup_environment(const void *fdt) eth_env_set_enetaddr(ethaddr, mac_addr); }
- if (!getenv("serial#")) { + if (!env_get("serial#")) { snprintf(serial_string, sizeof(serial_string), "%08x%08x", sid[0], sid[3]);
diff --git a/board/syteco/zmx25/zmx25.c b/board/syteco/zmx25/zmx25.c index e02dcf2995..85fda13188 100644 --- a/board/syteco/zmx25/zmx25.c +++ b/board/syteco/zmx25/zmx25.c @@ -146,7 +146,7 @@ int board_late_init(void) udelay(5000); #endif
- e = getenv("gs_base_board"); + e = env_get("gs_base_board"); if (e != NULL) { if (strcmp(e, "G283") == 0) { int key = gpio_get_value(IMX_GPIO_NR(2, 29)); diff --git a/board/tcl/sl50/board.c b/board/tcl/sl50/board.c index cc65c7b84b..f79bb9dcdd 100644 --- a/board/tcl/sl50/board.c +++ b/board/tcl/sl50/board.c @@ -77,7 +77,7 @@ int spl_start_uboot(void) #ifdef CONFIG_SPL_ENV_SUPPORT env_init(); env_load(); - if (getenv_yesno("boot_os") != 1) + if (env_get_yesno("boot_os") != 1) return 1; #endif
@@ -322,7 +322,7 @@ int board_eth_init(bd_t *bis)
if (is_valid_ethaddr(mac_addr)) @@ -340,7 +340,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
- if (!getenv("eth1addr")) { + if (!env_get("eth1addr")) { if (is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("eth1addr", mac_addr); } diff --git a/board/technexion/twister/twister.c b/board/technexion/twister/twister.c index 25aeebc8d0..8c38f14cde 100644 --- a/board/technexion/twister/twister.c +++ b/board/technexion/twister/twister.c @@ -94,7 +94,7 @@ int misc_init_r(void)
omap_die_id_display();
- eth_addr = getenv("ethaddr"); + eth_addr = env_get("ethaddr"); if (eth_addr) return 0;
diff --git a/board/teejet/mt_ventoux/mt_ventoux.c b/board/teejet/mt_ventoux/mt_ventoux.c index 6e73ae114a..9eaae50f27 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.c +++ b/board/teejet/mt_ventoux/mt_ventoux.c @@ -261,7 +261,7 @@ int misc_init_r(void)
if (ret) return 0; - eth_addr = getenv("ethaddr"); + eth_addr = env_get("ethaddr"); if (!eth_addr) TAM3517_READ_MAC_FROM_EEPROM(&info);
@@ -311,7 +311,7 @@ int board_video_init(void)
fb = (void *)0x88000000;
- s = getenv("panel"); + s = env_get("panel"); if (s) { index = simple_strtoul(s, NULL, 10); if (index < ARRAY_SIZE(lcd_cfg)) diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index d8c8083e16..de782b9f45 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -72,13 +72,13 @@ static void setup_macaddr(void) { #if CONFIG_IS_ENABLED(CMD_NET) int ret; - const char *cpuid = getenv("cpuid#"); + const char *cpuid = env_get("cpuid#"); u8 hash[SHA256_SUM_LEN]; int size = sizeof(hash); u8 mac_addr[6];
/* Only generate a MAC address, if none is set in the environment */ - if (getenv("ethaddr")) + if (env_get("ethaddr")) return;
if (!cpuid) { @@ -171,7 +171,7 @@ void get_board_serial(struct tag_serialnr *serialnr) char *serial_string; u64 serial = 0;
if (serial_string) serial = simple_strtoull(serial_string, NULL, 16); diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 7bdbc89d5e..1a52bffc00 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -250,7 +250,7 @@ int spl_start_uboot(void) #ifdef CONFIG_SPL_ENV_SUPPORT env_init(); env_load(); - if (getenv_yesno("boot_os") != 1) + if (env_get_yesno("boot_os") != 1) return 1; #endif
@@ -745,7 +745,7 @@ int board_late_init(void) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
if (is_valid_ethaddr(mac_addr)) @@ -761,7 +761,7 @@ int board_late_init(void) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
- if (!getenv("eth1addr")) { + if (!env_get("eth1addr")) { if (is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("eth1addr", mac_addr); } diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index db9aff3739..1d1b6b9845 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -791,7 +791,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
- if (!getenv("ethaddr")) { + if (!env_get("ethaddr")) { puts("<ethaddr> not set. Validating first E-fuse MAC\n"); if (is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("ethaddr", mac_addr); @@ -806,7 +806,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = mac_lo & 0xFF; mac_addr[5] = (mac_lo & 0xFF00) >> 8;
- if (!getenv("eth1addr")) { + if (!env_get("eth1addr")) { if (is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("eth1addr", mac_addr); } diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index b656f88163..1b00cec460 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -738,7 +738,7 @@ int spl_start_uboot(void) #ifdef CONFIG_SPL_ENV_SUPPORT env_init(); env_load(); - if (getenv_yesno("boot_os") != 1) + if (env_get_yesno("boot_os") != 1) return 1; #endif
@@ -928,7 +928,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = (mac_lo & 0xFF00) >> 8; mac_addr[5] = mac_lo & 0xFF;
if (is_valid_ethaddr(mac_addr)) @@ -944,7 +944,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = (mac_lo & 0xFF00) >> 8; mac_addr[5] = mac_lo & 0xFF;
- if (!getenv("eth1addr")) { + if (!env_get("eth1addr")) { if (is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("eth1addr", mac_addr); } diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 4252074e74..93d3d0b54e 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -826,7 +826,7 @@ int spl_start_uboot(void) #ifdef CONFIG_SPL_ENV_SUPPORT env_init(); env_load(); - if (getenv_yesno("boot_os") != 1) + if (env_get_yesno("boot_os") != 1) return 1; #endif
@@ -893,7 +893,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = (mac_lo & 0xFF00) >> 8; mac_addr[5] = mac_lo & 0xFF;
if (is_valid_ethaddr(mac_addr)) @@ -909,7 +909,7 @@ int board_eth_init(bd_t *bis) mac_addr[4] = (mac_lo & 0xFF00) >> 8; mac_addr[5] = mac_lo & 0xFF;
- if (!getenv("eth1addr")) { + if (!env_get("eth1addr")) { if (is_valid_ethaddr(mac_addr)) eth_env_set_enetaddr("eth1addr", mac_addr); } diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index ac8e093e5a..61f69e1296 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -245,7 +245,7 @@ int board_eth_init(bd_t *bis)
- if (!eth_getenv_enetaddr(STR_ENV_ETHADDR, eth_addr)) { + if (!eth_env_get_enetaddr(STR_ENV_ETHADDR, eth_addr)) { dev = eth_get_dev_by_index(0); if (dev) { eth_env_set_enetaddr(STR_ENV_ETHADDR, dev->enetaddr); diff --git a/board/ti/ks2_evm/board.c b/board/ti/ks2_evm/board.c index c61baeeb8c..ae86dfbe0a 100644 --- a/board/ti/ks2_evm/board.c +++ b/board/ti/ks2_evm/board.c @@ -74,7 +74,7 @@ int get_eth_env_param(char *env_name) char *env; int res = -1;
- env = getenv(env_name); + env = env_get(env_name); if (env) res = simple_strtol(env, NULL, 0);
@@ -151,9 +151,9 @@ int ft_board_setup(void *blob, bd_t *bd) u32 ddr3a_size; int unitrd_fixup = 0;
- env = getenv("mem_lpae"); + env = env_get("mem_lpae"); lpae = env && simple_strtol(env, NULL, 0); - env = getenv("uinitrd_fixup"); + env = env_get("uinitrd_fixup"); unitrd_fixup = env && simple_strtol(env, NULL, 0);
ddr3a_size = 0; @@ -180,13 +180,13 @@ int ft_board_setup(void *blob, bd_t *bd) }
/* reserve memory at start of bank */ - env = getenv("mem_reserve_head"); + env = env_get("mem_reserve_head"); if (env) { start[0] += ustrtoul(env, &endp, 0); size[0] -= ustrtoul(env, &endp, 0); }
- env = getenv("mem_reserve"); + env = env_get("mem_reserve"); if (env) size[0] -= ustrtoul(env, &endp, 0);
@@ -251,7 +251,7 @@ void ft_board_setup_ex(void *blob, bd_t *bd) char *env; u64 *reserve_start;
if (lpae) { diff --git a/board/ti/ti814x/evm.c b/board/ti/ti814x/evm.c index 38f9c57606..cdde6a8ca3 100644 --- a/board/ti/ti814x/evm.c +++ b/board/ti/ti814x/evm.c @@ -166,7 +166,7 @@ int board_eth_init(bd_t *bis) uint8_t mac_addr[6]; uint32_t mac_hi, mac_lo;
- if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { printf("<ethaddr> not set. Reading from E-fuse\n"); /* try reading mac address from efuse */ mac_lo = readl(&cdev->macid0l); diff --git a/board/ti/ti816x/evm.c b/board/ti/ti816x/evm.c index 1a8fe27c9f..cb40cc5f47 100644 --- a/board/ti/ti816x/evm.c +++ b/board/ti/ti816x/evm.c @@ -38,7 +38,7 @@ int board_eth_init(bd_t *bis) uint32_t mac_hi, mac_lo; struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE;
- if (!eth_getenv_enetaddr("ethaddr", mac_addr)) { + if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { printf("<ethaddr> not set. Reading from E-fuse\n"); /* try reading mac address from efuse */ mac_lo = readl(&cdev->macid0l); diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index 2f80d15666..741b3acce2 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -102,7 +102,7 @@ int misc_init_r(void) CONFIG_DM9000_BASE, GPMC_SIZE_16M);
/* Use OMAP DIE_ID as MAC address */ - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { + if (!eth_env_get_enetaddr("ethaddr", enetaddr)) { printf("ethaddr not set, using Die ID\n"); die_id_0 = readl(&id_base->die_id_0); enetaddr[0] = 0x02; /* locally administered */ diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 86a7a159e8..7a3e493faf 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -814,7 +814,7 @@ int board_late_init(void) setup_iomux_dce_uart();
/* if using the default device tree, use version for V1.0 HW */ - fdt_env = getenv("fdt_file"); + fdt_env = env_get("fdt_file"); if ((fdt_env != NULL) && (strcmp(FDT_FILE, fdt_env) == 0)) { env_set("fdt_file", FDT_FILE_V1_0); printf("patching fdt_file to " FDT_FILE_V1_0 "\n"); diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 1bf8ca8f76..328c4c0200 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -278,7 +278,7 @@ static int get_cfgblock_interactive(void) len = cli_readline(message); it = console_buffer[0];
- soc = getenv("soc"); + soc = env_get("soc"); if (!strcmp("mx6", soc)) { #ifdef CONFIG_MACH_TYPE if (it == 'y' || it == 'Y') diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index 78b2bc0c2b..b4e4727e63 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -86,11 +86,11 @@ int show_board_info(void) * Check if environment contains a valid MAC address, * set the one from config block if not */ - if (!eth_getenv_enetaddr("ethaddr", ethaddr)) + if (!eth_env_get_enetaddr("ethaddr", ethaddr)) eth_env_set_enetaddr("ethaddr", (u8 *)&tdx_eth_addr);
#ifdef CONFIG_TDX_CFG_BLOCK_2ND_ETHADDR - if (!eth_getenv_enetaddr("eth1addr", ethaddr)) { + if (!eth_env_get_enetaddr("eth1addr", ethaddr)) { /* * Secondary MAC address is allocated from block * 0x100000 higher then the first MAC address diff --git a/board/varisys/common/sys_eeprom.c b/board/varisys/common/sys_eeprom.c index d235897311..69f596a4cc 100644 --- a/board/varisys/common/sys_eeprom.c +++ b/board/varisys/common/sys_eeprom.c @@ -486,7 +486,7 @@ int mac_read_from_eeprom_common(void) /* Only initialize environment variables that are blank * (i.e. have not yet been set) */ - if (!getenv(enetvar)) + if (!env_get(enetvar)) env_set(enetvar, ethaddr); } } diff --git a/board/varisys/cyrus/cyrus.c b/board/varisys/cyrus/cyrus.c index 74f4473877..30f518abe8 100644 --- a/board/varisys/cyrus/cyrus.c +++ b/board/varisys/cyrus/cyrus.c @@ -87,8 +87,8 @@ int ft_board_setup(void *blob, bd_t *bd)
ft_cpu_setup(blob, bd);
- base = getenv_bootm_low(); - size = getenv_bootm_size(); + base = env_get_bootm_low(); + size = env_get_bootm_size();
diff --git a/board/vscom/baltos/board.c b/board/vscom/baltos/board.c index 2e3baeb118..cb39190c28 100644 --- a/board/vscom/baltos/board.c +++ b/board/vscom/baltos/board.c @@ -453,7 +453,7 @@ int board_eth_init(bd_t *bis)
#if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ (defined(CONFIG_SPL_ETH_SUPPORT) && defined(CONFIG_SPL_BUILD)) - if (!getenv("ethaddr")) { + if (!env_get("ethaddr")) { printf("<ethaddr> not set. Validating first E-fuse MAC\n");
if (is_valid_ethaddr(mac_addr)) diff --git a/board/work-microwave/work_92105/work_92105_display.c b/board/work-microwave/work_92105/work_92105_display.c index 37a736351c..c997cea6f0 100644 --- a/board/work-microwave/work_92105/work_92105_display.c +++ b/board/work-microwave/work_92105/work_92105_display.c @@ -228,7 +228,7 @@ void work_92105_display_init(void) i2c_write(0x2c, 0x01, 1, &enable_backlight, 1);
/* set display contrast */ - display_contrast_str = getenv("fwopt_dispcontrast"); + display_contrast_str = env_get("fwopt_dispcontrast"); if (display_contrast_str) display_contrast = simple_strtoul(display_contrast_str, NULL, 10); diff --git a/board/xes/common/board.c b/board/xes/common/board.c index 4ed6f50e5c..b76eb948d5 100644 --- a/board/xes/common/board.c +++ b/board/xes/common/board.c @@ -51,13 +51,13 @@ int checkboard(void)
/* Display board specific information */ puts(" "); - i = getenv_f("board_rev", buf, sizeof(buf)); + i = env_get_f("board_rev", buf, sizeof(buf)); if (i > 0) printf("Rev %s, ", buf); - i = getenv_f("serial#", buf, sizeof(buf)); + i = env_get_f("serial#", buf, sizeof(buf)); if (i > 0) printf("Serial# %s, ", buf); - i = getenv_f("board_cfg", buf, sizeof(buf)); + i = env_get_f("board_cfg", buf, sizeof(buf)); if (i > 0) printf("Cfg %s", buf); puts("\n"); diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 89ab24417d..ddbb5ce8fd 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -282,9 +282,9 @@ int board_late_init(void) * and default boot_targets */ new_targets = calloc(1, strlen(mode) + - strlen(getenv("boot_targets")) + 2); + strlen(env_get("boot_targets")) + 2);
- sprintf(new_targets, "%s %s", mode, getenv("boot_targets")); + sprintf(new_targets, "%s %s", mode, env_get("boot_targets")); env_set("boot_targets", new_targets);
return 0; diff --git a/cmd/bdinfo.c b/cmd/bdinfo.c index 8971697e60..e97fa1cdb4 100644 --- a/cmd/bdinfo.c +++ b/cmd/bdinfo.c @@ -28,7 +28,7 @@ static void print_eth(int idx) sprintf(name, "eth%iaddr", idx); else strcpy(name, "ethaddr"); - val = getenv(name); + val = env_get(name); if (!val) val = "(not set)"; printf("%-12s= %s\n", name, val); @@ -51,7 +51,7 @@ static void print_eths(void) } while (dev);
printf("current eth = %s\n", eth_get_name()); - printf("ip_addr = %s\n", getenv("ipaddr")); + printf("ip_addr = %s\n", env_get("ipaddr")); } #endif
@@ -141,7 +141,7 @@ static inline void print_eth_ip_addr(void) #if defined(CONFIG_HAS_ETH5) print_eth(5); #endif - printf("IP addr = %s\n", getenv("ipaddr")); + printf("IP addr = %s\n", env_get("ipaddr")); #endif }
diff --git a/cmd/bootm.c b/cmd/bootm.c index daf15d9e80..df0bbe19ca 100644 --- a/cmd/bootm.c +++ b/cmd/bootm.c @@ -138,7 +138,7 @@ int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
int bootm_maybe_autostart(cmd_tbl_t *cmdtp, const char *cmd) { - const char *ep = getenv("autostart"); + const char *ep = env_get("autostart");
if (ep && !strcmp(ep, "yes")) { char *local_args[2]; @@ -202,7 +202,7 @@ U_BOOT_CMD( #if defined(CONFIG_CMD_BOOTD) int do_bootd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - return run_command(getenv("bootcmd"), flag); + return run_command(env_get("bootcmd"), flag); }
U_BOOT_CMD( diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 5879065c2e..870db7c1de 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -53,7 +53,7 @@ static char *bootmenu_getoption(unsigned short int n) return NULL;
sprintf(name, "bootmenu_%d", n); - return getenv(name); + return env_get(name); }
static void bootmenu_print_entry(void *data) @@ -483,7 +483,7 @@ int do_bootmenu(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) delay_str = argv[1];
if (!delay_str) - delay_str = getenv("bootmenu_delay"); + delay_str = env_get("bootmenu_delay");
if (delay_str) delay = (int)simple_strtol(delay_str, NULL, 10); diff --git a/cmd/cramfs.c b/cmd/cramfs.c index 7b23c5b3dd..86f1bac272 100644 --- a/cmd/cramfs.c +++ b/cmd/cramfs.c @@ -104,7 +104,7 @@ int do_cramfs_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) struct mtdids id;
ulong addr; - addr = simple_strtoul(getenv("cramfsaddr"), NULL, 16); + addr = simple_strtoul(env_get("cramfsaddr"), NULL, 16);
/* hack! */ /* cramfs_* only supports NOR flash chips */ @@ -117,9 +117,9 @@ int do_cramfs_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) part.offset = (u64)(uintptr_t) map_sysmem(addr - OFFSET_ADJUSTMENT, 0);
/* pre-set Boot file name */ - if ((filename = getenv("bootfile")) == NULL) { + filename = env_get("bootfile"); + if (!filename) filename = "uImage"; - }
if (argc == 2) { filename = argv[1]; @@ -169,7 +169,7 @@ int do_cramfs_ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) struct mtdids id;
/* hack! */ /* cramfs_* only supports NOR flash chips */ diff --git a/cmd/elf.c b/cmd/elf.c index ed9625b221..5745a389da 100644 --- a/cmd/elf.c +++ b/cmd/elf.c @@ -148,7 +148,7 @@ int do_bootelf(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) unsigned long addr; /* Address of the ELF image */ unsigned long rc; /* Return value from user code */ char *sload = NULL; - const char *ep = getenv("autostart"); + const char *ep = env_get("autostart"); int rcode = 0;
/* Consume 'bootelf' */ @@ -242,11 +242,11 @@ int do_bootvx(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) */ #if defined(CONFIG_WALNUT) tmp = (char *)CONFIG_SYS_NVRAM_BASE_ADDR + 0x500; - eth_getenv_enetaddr("ethaddr", (uchar *)build_buf); + eth_env_get_enetaddr("ethaddr", (uchar *)build_buf); memcpy(tmp, &build_buf[3], 3); #elif defined(CONFIG_SYS_VXWORKS_MAC_PTR) tmp = (char *)CONFIG_SYS_VXWORKS_MAC_PTR; - eth_getenv_enetaddr("ethaddr", (uchar *)build_buf); + eth_env_get_enetaddr("ethaddr", (uchar *)build_buf); memcpy(tmp, build_buf, 6); #else puts("## Ethernet MAC address not copied to NV RAM\n"); @@ -258,7 +258,7 @@ int do_bootvx(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) * (LOCAL_MEM_LOCAL_ADRS + BOOT_LINE_OFFSET) as defined by * VxWorks BSP. For example, on PowerPC it defaults to 0x4200. */ - tmp = getenv("bootaddr"); + tmp = env_get("bootaddr"); if (!tmp) { printf("## VxWorks bootline address not specified\n"); } else { @@ -269,21 +269,21 @@ int do_bootvx(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) * parameter. If it is not defined, we may be able to * construct the info. */ - bootline = getenv("bootargs"); + bootline = env_get("bootargs"); if (bootline) { memcpy((void *)bootaddr, bootline, max(strlen(bootline), (size_t)255)); flush_cache(bootaddr, max(strlen(bootline), (size_t)255)); } else { - tmp = getenv("bootdev"); + tmp = env_get("bootdev"); if (tmp) { strcpy(build_buf, tmp); ptr = strlen(tmp); } else printf("## VxWorks boot device not specified\n");
- tmp = getenv("bootfile"); + tmp = env_get("bootfile"); if (tmp) ptr += sprintf(build_buf + ptr, "host:%s ", tmp); @@ -295,12 +295,12 @@ int do_bootvx(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) * The following parameters are only needed if 'bootdev' * is an ethernet device, otherwise they are optional. */ - tmp = getenv("ipaddr"); + tmp = env_get("ipaddr"); if (tmp) { ptr += sprintf(build_buf + ptr, "e=%s", tmp); - tmp = getenv("netmask"); + tmp = env_get("netmask"); if (tmp) { - u32 mask = getenv_ip("netmask").s_addr; + u32 mask = env_get_ip("netmask").s_addr; ptr += sprintf(build_buf + ptr, ":%08x ", ntohl(mask)); } else { @@ -308,19 +308,19 @@ int do_bootvx(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } }
- tmp = getenv("serverip"); + tmp = env_get("serverip"); if (tmp) ptr += sprintf(build_buf + ptr, "h=%s ", tmp);
- tmp = getenv("gatewayip"); + tmp = env_get("gatewayip"); if (tmp) ptr += sprintf(build_buf + ptr, "g=%s ", tmp);
- tmp = getenv("hostname"); + tmp = env_get("hostname"); if (tmp) ptr += sprintf(build_buf + ptr, "tn=%s ", tmp);
- tmp = getenv("othbootargs"); + tmp = env_get("othbootargs"); if (tmp) { strcpy(build_buf + ptr, tmp); ptr += strlen(tmp); @@ -341,12 +341,12 @@ int do_bootvx(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) * Since E820 information is critical to the kernel, if we don't * specify these in the environments, use a default one. */ - tmp = getenv("e820data"); + tmp = env_get("e820data"); if (tmp) data = (struct e820entry *)simple_strtoul(tmp, NULL, 16); else data = (struct e820entry *)VXWORKS_E820_DATA_ADDR; - tmp = getenv("e820info"); + tmp = env_get("e820info"); if (tmp) info = (struct e820info *)simple_strtoul(tmp, NULL, 16); else diff --git a/cmd/fdt.c b/cmd/fdt.c index eb01a889ad..118613f405 100644 --- a/cmd/fdt.c +++ b/cmd/fdt.c @@ -111,7 +111,7 @@ static int do_fdt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; printf("The address of the fdt is %#08lx\n", control ? (ulong)map_to_sysmem(blob) : - getenv_hex("fdtaddr", 0)); + env_get_hex("fdtaddr", 0)); return 0; }
diff --git a/cmd/fpga.c b/cmd/fpga.c index 016349f560..ac6f504140 100644 --- a/cmd/fpga.c +++ b/cmd/fpga.c @@ -43,8 +43,8 @@ int do_fpga(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) int op, dev = FPGA_INVALID_DEVICE; size_t data_size = 0; void *fpga_data = NULL; - char *devstr = getenv("fpga"); - char *datastr = getenv("fpgadata"); + char *devstr = env_get("fpga"); + char *datastr = env_get("fpgadata"); int rc = FPGA_FAIL; int wrong_parms = 0; #if defined(CONFIG_FIT) diff --git a/cmd/gpt.c b/cmd/gpt.c index cb76d5e540..e0ff9b9291 100644 --- a/cmd/gpt.c +++ b/cmd/gpt.c @@ -50,14 +50,14 @@ static int extract_env(const char *str, char **env) memset(s + strlen(s) - 1, '\0', 1); memmove(s, s + 2, strlen(s) - 1);
- e = getenv(s); + e = env_get(s); if (e == NULL) { #ifdef CONFIG_RANDOM_UUID debug("%s unset. ", str); gen_rand_uuid_str(uuid_str, UUID_STR_FORMAT_GUID); env_set(s, uuid_str);
- e = getenv(s); + e = env_get(s); if (e) { debug("Set to random.\n"); ret = 0; diff --git a/cmd/ini.c b/cmd/ini.c index 449f6e9f51..8656299447 100644 --- a/cmd/ini.c +++ b/cmd/ini.c @@ -238,9 +238,9 @@ static int do_ini(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
section = argv[1]; file_address = (char *)simple_strtoul( - argc < 3 ? getenv("loadaddr") : argv[2], NULL, 16); + argc < 3 ? env_get("loadaddr") : argv[2], NULL, 16); file_size = (size_t)simple_strtoul( - argc < 4 ? getenv("filesize") : argv[3], NULL, 16); + argc < 4 ? env_get("filesize") : argv[3], NULL, 16);
return ini_parse(file_address, file_size, ini_handler, (void *)section); } diff --git a/cmd/itest.c b/cmd/itest.c index e1896d9f97..70db04a04f 100644 --- a/cmd/itest.c +++ b/cmd/itest.c @@ -101,7 +101,7 @@ static char * evalstr(char *s) i++; } s[i] = 0; - return getenv((const char *)&s[2]); + return env_get((const char *)&s[2]); } else { return s; } diff --git a/cmd/jffs2.c b/cmd/jffs2.c index add89dee6a..aee2f4513d 100644 --- a/cmd/jffs2.c +++ b/cmd/jffs2.c @@ -479,9 +479,9 @@ int do_jffs2_fsload(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) ulong offset = load_addr;
if (argc == 2) { filename = argv[1]; diff --git a/cmd/load.c b/cmd/load.c index ec3730e0f6..519c309a61 100644 --- a/cmd/load.c +++ b/cmd/load.c @@ -50,11 +50,11 @@ static int do_load_serial(cmd_tbl_t *cmdtp, int flag, int argc, load_baudrate = current_baudrate = gd->baudrate; #endif
- if (((env_echo = getenv("loads_echo")) != NULL) && (*env_echo == '1')) { + env_echo = env_get("loads_echo"); + if (env_echo && *env_echo == '1') do_echo = 1; - } else { + else do_echo = 0; - }
#ifdef CONFIG_SYS_LOADS_BAUD_CHANGE if (argc >= 2) { @@ -427,9 +427,9 @@ static int do_load_serial_bin(cmd_tbl_t *cmdtp, int flag, int argc, offset = CONFIG_SYS_LOAD_ADDR;
/* pre-set offset from $loadaddr */ - if ((s = getenv("loadaddr")) != NULL) { + s = env_get("loadaddr"); + if (s) offset = simple_strtoul(s, NULL, 16); - }
diff --git a/cmd/log.c b/cmd/log.c index 873ee40371..7a3bd5cd69 100644 --- a/cmd/log.c +++ b/cmd/log.c @@ -71,7 +71,8 @@ void logbuff_init_ptrs(void) #endif
/* Set up log version */ - if ((s = getenv ("logversion")) != NULL) + s = env_get("logversion"); + if (s) log_version = (int)simple_strtoul(s, NULL, 10);
if (log_version == 2) @@ -94,7 +95,8 @@ void logbuff_init_ptrs(void) log->v2.start = log->v2.con;
/* Initialize default loglevel if present */ - if ((s = getenv ("loglevel")) != NULL) + s = env_get("loglevel"); + if (s) console_loglevel = (int)simple_strtoul(s, NULL, 10);
gd->flags |= GD_FLG_LOGINIT; diff --git a/cmd/md5sum.c b/cmd/md5sum.c index 1b2352ea55..c737cb23b5 100644 --- a/cmd/md5sum.c +++ b/cmd/md5sum.c @@ -54,7 +54,7 @@ static int parse_verify_sum(char *verify_str, u8 *vsum) if (strlen(verify_str) == 32) vsum_str = verify_str; else { - vsum_str = getenv(verify_str); + vsum_str = env_get(verify_str); if (vsum_str == NULL || strlen(vsum_str) != 32) return 1; } diff --git a/cmd/mtdparts.c b/cmd/mtdparts.c index d3fde77ef0..615aa7459a 100644 --- a/cmd/mtdparts.c +++ b/cmd/mtdparts.c @@ -1533,11 +1533,11 @@ static int spread_partitions(void) * @param buf temporary buffer pointer MTDPARTS_MAXLEN long * @return mtdparts variable string, NULL if not found */ -static const char *getenv_mtdparts(char *buf) +static const char *env_get_mtdparts(char *buf) { if (gd->flags & GD_FLG_ENV_READY) - return getenv("mtdparts"); - if (getenv_f("mtdparts", buf, MTDPARTS_MAXLEN) != -1) + return env_get("mtdparts"); + if (env_get_f("mtdparts", buf, MTDPARTS_MAXLEN) != -1) return buf; return NULL; } @@ -1565,7 +1565,7 @@ static int parse_mtdparts(const char *const mtdparts) }
/* re-read 'mtdparts' variable, mtd_devices_init may be updating env */ - p = getenv_mtdparts(tmp_parts); + p = env_get_mtdparts(tmp_parts); if (!p) p = mtdparts;
@@ -1741,9 +1741,9 @@ int mtdparts_init(void) }
/* get variables */ - ids = getenv("mtdids"); - parts = getenv_mtdparts(tmp_parts); - current_partition = getenv("partition"); + ids = env_get("mtdids"); + parts = env_get_mtdparts(tmp_parts); + current_partition = env_get("partition");
/* save it for later parsing, cannot rely on current partition pointer * as 'partition' variable may be updated during init */ @@ -1850,7 +1850,7 @@ int mtdparts_init(void) current_mtd_partnum = pnum; current_save(); } - } else if (getenv("partition") == NULL) { + } else if (env_get("partition") == NULL) { debug("no partition variable set, setting...\n"); current_save(); } diff --git a/cmd/mvebu/bubt.c b/cmd/mvebu/bubt.c index ea46e7b108..a1997ac0d3 100644 --- a/cmd/mvebu/bubt.c +++ b/cmd/mvebu/bubt.c @@ -98,7 +98,7 @@ static ulong get_load_addr(void) const char *addr_str; unsigned long addr;
- addr_str = getenv("loadaddr"); + addr_str = env_get("loadaddr"); if (addr_str) addr = simple_strtoul(addr_str, NULL, 16); else diff --git a/cmd/nand.c b/cmd/nand.c index 0f5d431e5c..a22945d144 100644 --- a/cmd/nand.c +++ b/cmd/nand.c @@ -383,7 +383,7 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #else int quiet = 0; #endif - const char *quiet_str = getenv("quiet"); + const char *quiet_str = env_get("quiet"); int dev = nand_curr_device; int repeat = flag & CMD_FLAG_REPEAT;
@@ -966,11 +966,11 @@ static int do_nandboot(cmd_tbl_t *cmdtp, int flag, int argc, switch (argc) { case 1: addr = CONFIG_SYS_LOAD_ADDR; - boot_device = getenv("bootdevice"); + boot_device = env_get("bootdevice"); break; case 2: addr = simple_strtoul(argv[1], NULL, 16); - boot_device = getenv("bootdevice"); + boot_device = env_get("bootdevice"); break; case 3: addr = simple_strtoul(argv[1], NULL, 16); diff --git a/cmd/net.c b/cmd/net.c index fa6d02f90d..d090f7cade 100644 --- a/cmd/net.c +++ b/cmd/net.c @@ -181,7 +181,7 @@ static int netboot_common(enum proto_t proto, cmd_tbl_t *cmdtp, int argc, ulong addr;
/* pre-set load_addr */ - s = getenv("loadaddr"); + s = env_get("loadaddr"); if (s != NULL) load_addr = simple_strtoul(s, NULL, 16);
@@ -331,7 +331,7 @@ int do_sntp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) char *toff;
if (argc < 2) { - net_ntp_server = getenv_ip("ntpserverip"); + net_ntp_server = env_get_ip("ntpserverip"); if (net_ntp_server.s_addr == 0) { printf("ntpserverip not set\n"); return CMD_RET_FAILURE; @@ -344,7 +344,7 @@ int do_sntp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } }
- toff = getenv("timeoffset"); + toff = env_get("timeoffset"); if (toff == NULL) net_ntp_time_offset = 0; else diff --git a/cmd/nvedit.c b/cmd/nvedit.c index a649004850..4033d90c8e 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -327,13 +327,13 @@ int env_set_hex(const char *varname, ulong value) return env_set(varname, str); }
-ulong getenv_hex(const char *varname, ulong default_val) +ulong env_get_hex(const char *varname, ulong default_val) { const char *s; ulong value; char *endp;
- s = getenv(varname); + s = env_get(varname); if (s) value = simple_strtoul(s, &endp, 16); if (!s || endp == s) @@ -594,7 +594,7 @@ static int do_env_edit(cmd_tbl_t *cmdtp, int flag, int argc, return 1;
/* Set read buffer to initial value or empty sting */ - init_val = getenv(argv[1]); + init_val = env_get(argv[1]); if (init_val) snprintf(buffer, CONFIG_SYS_CBSIZE, "%s", init_val); else @@ -622,7 +622,7 @@ static int do_env_edit(cmd_tbl_t *cmdtp, int flag, int argc, * return address of storage for that variable, * or NULL if not found */ -char *getenv(const char *name) +char *env_get(const char *name) { if (gd->flags & GD_FLG_ENV_READY) { /* after import into hashtable */ ENTRY e, *ep; @@ -637,7 +637,7 @@ char *getenv(const char *name) }
/* restricted capabilities before import */ - if (getenv_f(name, (char *)(gd->env_buf), sizeof(gd->env_buf)) > 0) + if (env_get_f(name, (char *)(gd->env_buf), sizeof(gd->env_buf)) > 0) return (char *)(gd->env_buf);
return NULL; @@ -646,7 +646,7 @@ char *getenv(const char *name) /* * Look up variable from environment for restricted C runtime env. */ -int getenv_f(const char *name, char *buf, unsigned len) +int env_get_f(const char *name, char *buf, unsigned len) { int i, nxt;
@@ -690,13 +690,13 @@ int getenv_f(const char *name, char *buf, unsigned len) * found * @return the decoded value, or default_val if not found */ -ulong getenv_ulong(const char *name, int base, ulong default_val) +ulong env_get_ulong(const char *name, int base, ulong default_val) { /* - * We can use getenv() here, even before relocation, since the + * We can use env_get() here, even before relocation, since the * environment variable value is an integer and thus short. */ - const char *str = getenv(name); + const char *str = env_get(name);
return str ? simple_strtoul(str, NULL, base) : default_val; } diff --git a/cmd/pxe.c b/cmd/pxe.c index 357b96940c..94faf59ad0 100644 --- a/cmd/pxe.c +++ b/cmd/pxe.c @@ -41,7 +41,7 @@ static char *from_env(const char *envvar) { char *ret;
- ret = getenv(envvar); + ret = env_get(envvar);
if (!ret) printf("missing environment variable: %s\n", envvar); @@ -70,8 +70,7 @@ static int format_mac_pxe(char *outbuf, size_t outbuf_len) return -EINVAL; }
- if (!eth_getenv_enetaddr_by_index("eth", eth_get_dev_index(), - ethaddr)) + if (!eth_env_get_enetaddr_by_index("eth", eth_get_dev_index(), ethaddr)) return -ENOENT;
sprintf(outbuf, "01-%02x-%02x-%02x-%02x-%02x-%02x", @@ -649,9 +648,9 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) }
bootm_argv[2] = initrd_str; - strcpy(bootm_argv[2], getenv("ramdisk_addr_r")); + strcpy(bootm_argv[2], env_get("ramdisk_addr_r")); strcat(bootm_argv[2], ":"); - strcat(bootm_argv[2], getenv("filesize")); + strcat(bootm_argv[2], env_get("filesize")); }
if (get_relfile_envaddr(cmdtp, label->kernel, "kernel_addr_r") < 0) { @@ -662,8 +661,8 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label)
if (label->ipappend & 0x1) { sprintf(ip_str, " ip=%s:%s:%s:%s", - getenv("ipaddr"), getenv("serverip"), - getenv("gatewayip"), getenv("netmask")); + env_get("ipaddr"), env_get("serverip"), + env_get("gatewayip"), env_get("netmask")); }
#ifdef CONFIG_CMD_NET @@ -699,7 +698,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) printf("append: %s\n", finalbootargs); }
- bootm_argv[1] = getenv("kernel_addr_r"); + bootm_argv[1] = env_get("kernel_addr_r");
/* * fdt usage is optional: @@ -714,7 +713,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) * * Scenario 3: fdt blob is not available. */ - bootm_argv[3] = getenv("fdt_addr_r"); + bootm_argv[3] = env_get("fdt_addr_r");
/* if fdt label is defined then get fdt from server */ if (bootm_argv[3]) { @@ -726,7 +725,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) } else if (label->fdtdir) { char *f1, *f2, *f3, *f4, *slash;
- f1 = getenv("fdtfile"); + f1 = env_get("fdtfile"); if (f1) { f2 = ""; f3 = ""; @@ -739,9 +738,9 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) * or the boot scripts should set $fdtfile * before invoking "pxe" or "sysboot". */ - f1 = getenv("soc"); + f1 = env_get("soc"); f2 = "-"; - f3 = getenv("board"); + f3 = env_get("board"); f4 = ".dtb"; }
@@ -781,7 +780,7 @@ static int label_boot(cmd_tbl_t *cmdtp, struct pxe_label *label) }
if (!bootm_argv[3]) - bootm_argv[3] = getenv("fdt_addr"); + bootm_argv[3] = env_get("fdt_addr");
if (bootm_argv[3]) { if (!bootm_argv[2]) @@ -1671,7 +1670,7 @@ static int do_sysboot(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
if (argc < 6) - filename = getenv("bootfile"); + filename = env_get("bootfile"); else { filename = argv[5]; env_set("bootfile", filename); diff --git a/cmd/qfw.c b/cmd/qfw.c index 9b12ab40ca..b38026ba81 100644 --- a/cmd/qfw.c +++ b/cmd/qfw.c @@ -123,7 +123,7 @@ static int qemu_fwcfg_do_load(cmd_tbl_t *cmdtp, int flag, void *load_addr; void *initrd_addr;
- env = getenv("loadaddr"); + env = env_get("loadaddr"); load_addr = env ? (void *)simple_strtoul(env, NULL, 16) : #ifdef CONFIG_LOADADDR @@ -132,7 +132,7 @@ static int qemu_fwcfg_do_load(cmd_tbl_t *cmdtp, int flag, NULL; #endif
- env = getenv("ramdiskaddr"); + env = env_get("ramdiskaddr"); initrd_addr = env ? (void *)simple_strtoul(env, NULL, 16) : #ifdef CONFIG_RAMDISK_ADDR diff --git a/cmd/reiser.c b/cmd/reiser.c index 4df9c5f5db..e10c7b9eba 100644 --- a/cmd/reiser.c +++ b/cmd/reiser.c @@ -88,18 +88,18 @@ int do_reiserload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
switch (argc) { case 3: - addr_str = getenv("loadaddr"); + addr_str = env_get("loadaddr"); if (addr_str != NULL) { addr = simple_strtoul (addr_str, NULL, 16); } else { addr = CONFIG_SYS_LOAD_ADDR; } - filename = getenv ("bootfile"); + filename = env_get("bootfile"); count = 0; break; case 4: addr = simple_strtoul (argv[3], NULL, 16); - filename = getenv ("bootfile"); + filename = env_get("bootfile"); count = 0; break; case 5: diff --git a/cmd/setexpr.c b/cmd/setexpr.c index 91a5a9a770..af210225f1 100644 --- a/cmd/setexpr.c +++ b/cmd/setexpr.c @@ -145,7 +145,7 @@ static int regex_sub(const char *name, }
if (t == NULL) { - value = getenv(name); + value = env_get(name);
if (value == NULL) { printf("## Error: variable "%s" not defined\n", name); diff --git a/cmd/source.c b/cmd/source.c index 177f86bb54..a9831b6608 100644 --- a/cmd/source.c +++ b/cmd/source.c @@ -40,7 +40,7 @@ source (ulong addr, const char *fit_uname) size_t fit_len; #endif
- verify = getenv_yesno ("verify"); + verify = env_get_yesno("verify");
buf = map_sysmem(addr, 0); switch (genimg_get_format(buf)) { diff --git a/cmd/trace.c b/cmd/trace.c index e6c08e4ba5..a0a7dd1995 100644 --- a/cmd/trace.c +++ b/cmd/trace.c @@ -16,10 +16,10 @@ static int get_args(int argc, char * const argv[], char **buff, if (argc < 2) return -1; if (argc < 4) { - *buff_size = getenv_ulong("profsize", 16, 0); - *buff = map_sysmem(getenv_ulong("profbase", 16, 0), + *buff_size = env_get_ulong("profsize", 16, 0); + *buff = map_sysmem(env_get_ulong("profbase", 16, 0), *buff_size); - *buff_ptr = getenv_ulong("profoffset", 16, 0); + *buff_ptr = env_get_ulong("profoffset", 16, 0); } else { *buff_size = simple_strtoul(argv[3], NULL, 16); *buff = map_sysmem(simple_strtoul(argv[2], NULL, 16), diff --git a/cmd/ximg.c b/cmd/ximg.c index 50dc00e4f8..21b5c37721 100644 --- a/cmd/ximg.c +++ b/cmd/ximg.c @@ -52,7 +52,7 @@ do_imgextract(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) #endif uint8_t comp;
- verify = getenv_yesno("verify"); + verify = env_get_yesno("verify");
if (argc > 1) { addr = simple_strtoul(argv[1], NULL, 16); diff --git a/cmd/zfs.c b/cmd/zfs.c index 08b0062c10..6913043d7f 100644 --- a/cmd/zfs.c +++ b/cmd/zfs.c @@ -51,10 +51,10 @@ static int do_zfs_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]
count = 0; addr = simple_strtoul(argv[3], NULL, 16); - filename = getenv("bootfile"); + filename = env_get("bootfile"); switch (argc) { case 3: - addr_str = getenv("loadaddr"); + addr_str = env_get("loadaddr"); if (addr_str != NULL) addr = simple_strtoul(addr_str, NULL, 16); else diff --git a/common/autoboot.c b/common/autoboot.c index 41f18208c3..a011865028 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -50,7 +50,7 @@ static int slow_equals(u8 *a, u8 *b, int len)
static int passwd_abort(uint64_t etime) { - const char *sha_env_str = getenv("bootstopkeysha256"); + const char *sha_env_str = env_get("bootstopkeysha256"); u8 sha_env[SHA256_SUM_LEN]; u8 sha[SHA256_SUM_LEN]; char presskey[MAX_DELAY_STOP_STR]; @@ -109,8 +109,8 @@ static int passwd_abort(uint64_t etime) int retry; } delaykey[] = { - { .str = getenv("bootdelaykey"), .retry = 1 }, - { .str = getenv("bootstopkey"), .retry = 0 }, + { .str = env_get("bootdelaykey"), .retry = 1 }, + { .str = env_get("bootstopkey"), .retry = 0 }, };
char presskey[MAX_DELAY_STOP_STR]; @@ -301,10 +301,10 @@ const char *bootdelay_process(void) bootcount++; bootcount_store(bootcount); env_set_ulong("bootcount", bootcount); - bootlimit = getenv_ulong("bootlimit", 10, 0); + bootlimit = env_get_ulong("bootlimit", 10, 0); #endif /* CONFIG_BOOTCOUNT_LIMIT */
- s = getenv("bootdelay"); + s = env_get("bootdelay"); bootdelay = s ? (int)simple_strtol(s, NULL, 10) : CONFIG_BOOTDELAY;
#ifdef CONFIG_OF_CONTROL @@ -321,17 +321,17 @@ const char *bootdelay_process(void)
#ifdef CONFIG_POST if (gd->flags & GD_FLG_POSTFAIL) { - s = getenv("failbootcmd"); + s = env_get("failbootcmd"); } else #endif /* CONFIG_POST */ #ifdef CONFIG_BOOTCOUNT_LIMIT if (bootlimit && (bootcount > bootlimit)) { printf("Warning: Bootlimit (%u) exceeded. Using altbootcmd.\n", (unsigned)bootlimit); - s = getenv("altbootcmd"); + s = env_get("altbootcmd"); } else #endif /* CONFIG_BOOTCOUNT_LIMIT */ - s = getenv("bootcmd"); + s = env_get("bootcmd");
process_fdt_options(gd->fdt_blob); stored_bootdelay = bootdelay; @@ -357,7 +357,7 @@ void autoboot_command(const char *s)
#ifdef CONFIG_MENUKEY if (menukey == CONFIG_MENUKEY) { - s = getenv("menucmd"); + s = env_get("menucmd"); if (s) run_command_list(s, -1, 0); } diff --git a/common/board_f.c b/common/board_f.c index ffa84e3566..e281bee592 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -118,7 +118,7 @@ __weak void board_add_ram_info(int use_default)
static int init_baud_rate(void) { - gd->baudrate = getenv_ulong("baudrate", 10, CONFIG_BAUDRATE); + gd->baudrate = env_get_ulong("baudrate", 10, CONFIG_BAUDRATE); return 0; }
@@ -324,7 +324,7 @@ static int reserve_pram(void) { ulong reg;
- reg = getenv_ulong("pram", 10, CONFIG_PRAM); + reg = env_get_ulong("pram", 10, CONFIG_PRAM); gd->relocaddr -= (reg << 10); /* size is in kB */ debug("Reserving %ldk for protected RAM at %08lx\n", reg, gd->relocaddr); diff --git a/common/board_r.c b/common/board_r.c index 3b7bc6bbd0..aab3253079 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -372,7 +372,7 @@ static int initr_flash(void) * * NOTE: Maybe we should add some WATCHDOG_RESET()? XXX */ - if (getenv_yesno("flashchecksum") == 1) { + if (env_get_yesno("flashchecksum") == 1) { printf(" CRC: %08X", crc32(0, (const unsigned char *) CONFIG_SYS_FLASH_BASE, flash_size)); @@ -490,7 +490,7 @@ static int initr_env(void) #endif
/* Initialize from environment */ - load_addr = getenv_ulong("loadaddr", 16, load_addr); + load_addr = env_get_ulong("loadaddr", 16, load_addr);
return 0; } @@ -537,21 +537,21 @@ static int initr_ethaddr(void) bd_t *bd = gd->bd;
/* kept around for legacy kernels only ... ignore the next section */ - eth_getenv_enetaddr("ethaddr", bd->bi_enetaddr); + eth_env_get_enetaddr("ethaddr", bd->bi_enetaddr); #ifdef CONFIG_HAS_ETH1 - eth_getenv_enetaddr("eth1addr", bd->bi_enet1addr); + eth_env_get_enetaddr("eth1addr", bd->bi_enet1addr); #endif #ifdef CONFIG_HAS_ETH2 - eth_getenv_enetaddr("eth2addr", bd->bi_enet2addr); + eth_env_get_enetaddr("eth2addr", bd->bi_enet2addr); #endif #ifdef CONFIG_HAS_ETH3 - eth_getenv_enetaddr("eth3addr", bd->bi_enet3addr); + eth_env_get_enetaddr("eth3addr", bd->bi_enet3addr); #endif #ifdef CONFIG_HAS_ETH4 - eth_getenv_enetaddr("eth4addr", bd->bi_enet4addr); + eth_env_get_enetaddr("eth4addr", bd->bi_enet4addr); #endif #ifdef CONFIG_HAS_ETH5 - eth_getenv_enetaddr("eth5addr", bd->bi_enet5addr); + eth_env_get_enetaddr("eth5addr", bd->bi_enet5addr); #endif return 0; } @@ -651,7 +651,7 @@ int initr_mem(void) char memsz[32];
# ifdef CONFIG_PRAM - pram = getenv_ulong("pram", 10, CONFIG_PRAM); + pram = env_get_ulong("pram", 10, CONFIG_PRAM); # endif # if defined(CONFIG_LOGBUFFER) && !defined(CONFIG_ALT_LB_ADDR) /* Also take the logbuffer into account (pram is in kB) */ diff --git a/common/bootm.c b/common/bootm.c index e34617a145..32b3ea8e2d 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -55,8 +55,8 @@ static void boot_start_lmb(bootm_headers_t *images)
lmb_init(&images->lmb);
- mem_start = getenv_bootm_low(); - mem_size = getenv_bootm_size(); + mem_start = env_get_bootm_low(); + mem_size = env_get_bootm_size();
lmb_add(&images->lmb, (phys_addr_t)mem_start, mem_size);
@@ -72,7 +72,7 @@ static int bootm_start(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { memset((void *)&images, 0, sizeof(images)); - images.verify = getenv_yesno("verify"); + images.verify = env_get_yesno("verify");
boot_start_lmb(&images);
@@ -524,7 +524,7 @@ static void fixup_silent_linux(void) { char *buf; const char *env_val; - char *cmdline = getenv("bootargs"); + char *cmdline = env_get("bootargs"); int want_silent;
/* @@ -534,7 +534,7 @@ static void fixup_silent_linux(void) * yes - we always fixup * unset - we rely on the console silent flag */ - want_silent = getenv_yesno("silent_linux"); + want_silent = env_get_yesno("silent_linux"); if (want_silent == 0) return; else if (want_silent == -1 && !(gd->flags & GD_FLG_SILENT)) @@ -691,7 +691,7 @@ int do_bootm_states(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], #ifdef CONFIG_TRACE /* Pretend to run the OS, then run a user command */ if (!ret && (states & BOOTM_STATE_OS_FAKE_GO)) { - char *cmd_list = getenv("fakegocmd"); + char *cmd_list = env_get("fakegocmd");
ret = boot_selected_os(argc, argv, BOOTM_STATE_OS_FAKE_GO, images, boot_fn); diff --git a/common/bootm_os.c b/common/bootm_os.c index 86a37cb925..1feea8af17 100644 --- a/common/bootm_os.c +++ b/common/bootm_os.c @@ -21,7 +21,7 @@ static int do_bootm_standalone(int flag, int argc, char * const argv[], int (*appl)(int, char *const[]);
/* Don't start if "autostart" is set to "no" */ - s = getenv("autostart"); + s = env_get("autostart"); if ((s != NULL) && !strcmp(s, "no")) { env_set_hex("filesize", images->os.image_len); return 0; @@ -96,7 +96,7 @@ static int do_bootm_netbsd(int flag, int argc, char * const argv[], cmdline = malloc(len); copy_args(cmdline, argc, argv, ' '); } else { - cmdline = getenv("bootargs"); + cmdline = env_get("bootargs"); if (cmdline == NULL) cmdline = ""; } @@ -227,14 +227,14 @@ static int do_bootm_plan9(int flag, int argc, char * const argv[], #endif
/* See README.plan9 */ - s = getenv("confaddr"); + s = env_get("confaddr"); if (s != NULL) { char *confaddr = (char *)simple_strtoul(s, NULL, 16);
if (argc > 0) { copy_args(confaddr, argc, argv, '\n'); } else { - s = getenv("bootargs"); + s = env_get("bootargs"); if (s != NULL) strcpy(confaddr, s); } @@ -278,7 +278,7 @@ void do_bootvx_fdt(bootm_headers_t *images)
ret = fdt_add_subnode(*of_flat_tree, 0, "chosen"); if ((ret >= 0 || ret == -FDT_ERR_EXISTS)) { - bootline = getenv("bootargs"); + bootline = env_get("bootargs"); if (bootline) { ret = fdt_find_and_setprop(*of_flat_tree, "/chosen", "bootargs", diff --git a/common/bootretry.c b/common/bootretry.c index 2d82798cd0..b3b8271a92 100644 --- a/common/bootretry.c +++ b/common/bootretry.c @@ -23,7 +23,7 @@ static int retry_time = -1; /* -1 so can call readline before main_loop */ */ void bootretry_init_cmd_timeout(void) { - char *s = getenv("bootretry"); + char *s = env_get("bootretry");
if (s != NULL) retry_time = (int)simple_strtol(s, NULL, 10); diff --git a/common/cli.c b/common/cli.c index a433ef2166..57874d8797 100644 --- a/common/cli.c +++ b/common/cli.c @@ -129,7 +129,7 @@ int do_run(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) for (i = 1; i < argc; ++i) { char *arg;
- arg = getenv(argv[i]); + arg = env_get(argv[i]); if (arg == NULL) { printf("## Error: "%s" not defined\n", argv[i]); return 1; diff --git a/common/cli_hush.c b/common/cli_hush.c index 280289639c..07c048ec6a 100644 --- a/common/cli_hush.c +++ b/common/cli_hush.c @@ -560,7 +560,7 @@ static int builtin_cd(struct child_prog *child) { char *newdir; if (child->argv[1] == NULL) - newdir = getenv("HOME"); + newdir = env_get("HOME"); else newdir = child->argv[1]; if (chdir(newdir)) { @@ -948,7 +948,7 @@ static inline void cmdedit_set_initial_prompt(void) #ifndef CONFIG_FEATURE_SH_FANCY_PROMPT PS1 = NULL; #else - PS1 = getenv("PS1"); + PS1 = env_get("PS1"); if(PS1==0) PS1 = "\w \$ "; #endif @@ -987,9 +987,9 @@ static int uboot_cli_readline(struct in_str *i)
#ifdef CONFIG_CMDLINE_PS_SUPPORT if (i->promptmode == 1) - ps_prompt = getenv("PS1"); + ps_prompt = env_get("PS1"); else - ps_prompt = getenv("PS2"); + ps_prompt = env_get("PS2"); if (ps_prompt) prompt = ps_prompt; #endif @@ -2172,7 +2172,7 @@ int set_local_var(const char *s, int flg_export) name=strdup(s);
#ifdef __U_BOOT__ - if (getenv(name) != NULL) { + if (env_get(name) != NULL) { printf ("ERROR: " "There is a global environment variable with the same name.\n"); free(name); @@ -2793,7 +2793,7 @@ static char *lookup_param(char *src) } }
- p = getenv(src); + p = env_get(src); if (!p) p = get_local_var(src);
@@ -3157,7 +3157,7 @@ static void mapset(const unsigned char *set, int code) static void update_ifs_map(void) { /* char *ifs and char map[256] are both globals. */ - ifs = (uchar *)getenv("IFS"); + ifs = (uchar *)env_get("IFS"); if (ifs == NULL) ifs=(uchar *)" \t\n"; /* Precompute a list of 'flow through' behavior so it can be treated * quickly up front. Computation is necessary because of IFS. diff --git a/common/cli_simple.c b/common/cli_simple.c index bb96aaead6..cb642d2ff3 100644 --- a/common/cli_simple.c +++ b/common/cli_simple.c @@ -131,7 +131,7 @@ void cli_simple_process_macros(const char *input, char *output) envname[i] = 0;
/* Get its value */ - envval = getenv(envname); + envval = env_get(envname);
/* Copy into the line if it exists */ if (envval != NULL) @@ -168,7 +168,7 @@ void cli_simple_process_macros(const char *input, char *output) * WARNING: * * We must create a temporary copy of the command since the command we get - * may be the result from getenv(), which returns a pointer directly to + * may be the result from env_get(), which returns a pointer directly to * the environment data, which may change magicly when the command we run * creates or modifies environment variables (like "bootp" does). */ diff --git a/common/console.c b/common/console.c index 2f3fa28f74..683f4c3073 100644 --- a/common/console.c +++ b/common/console.c @@ -682,7 +682,7 @@ int console_assign(int file, const char *devname) static void console_update_silent(void) { #ifdef CONFIG_SILENT_CONSOLE - if (getenv("silent") != NULL) + if (env_get("silent") != NULL) gd->flags |= GD_FLG_SILENT; else gd->flags &= ~GD_FLG_SILENT; @@ -761,9 +761,9 @@ int console_init_r(void)
/* stdin stdout and stderr are in environment */ /* scan for it */ - stdinname = getenv("stdin"); - stdoutname = getenv("stdout"); - stderrname = getenv("stderr"); + stdinname = env_get("stdin"); + stdoutname = env_get("stdout"); + stderrname = env_get("stderr");
if (OVERWRITE_CONSOLE == 0) { /* if not overwritten by config switch */ inputdev = search_device(DEV_FLAGS_INPUT, stdinname); @@ -852,7 +852,7 @@ int console_init_r(void) * console to serial console in this case or suppress it if * "silent" mode was requested. */ - if (getenv("splashimage") != NULL) { + if (env_get("splashimage") != NULL) { if (!(gd->flags & GD_FLG_SILENT)) outputdev = search_device (DEV_FLAGS_OUTPUT, "serial"); } diff --git a/common/fb_mmc.c b/common/fb_mmc.c index 2113b6c372..5065ad5f73 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -49,7 +49,7 @@ static int part_get_info_by_name_or_alias(struct blk_desc *dev_desc, /* check for alias */ strcpy(env_alias_name, "fastboot_partition_alias_"); strncat(env_alias_name, name, 32); - aliased_part_name = getenv(env_alias_name); + aliased_part_name = env_get(env_alias_name); if (aliased_part_name != NULL) ret = part_get_info_by_name(dev_desc, aliased_part_name, info); diff --git a/common/fdt_support.c b/common/fdt_support.c index 5aa8e3422e..b0d7f82894 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -197,7 +197,7 @@ int fdt_root(void *fdt) return err; }
- serial = getenv("serial#"); + serial = env_get("serial#"); if (serial) { err = fdt_setprop(fdt, 0, "serial-number", serial, strlen(serial) + 1); @@ -289,7 +289,7 @@ int fdt_chosen(void *fdt) if (nodeoffset < 0) return nodeoffset;
- str = getenv("bootargs"); + str = env_get("bootargs"); if (str) { err = fdt_setprop(fdt, nodeoffset, "bootargs", str, strlen(str) + 1); @@ -509,7 +509,7 @@ void fdt_fixup_ethernet(void *fdt) } else { continue; } - tmp = getenv(mac); + tmp = env_get(mac); if (!tmp) continue;
diff --git a/common/hash.c b/common/hash.c index fda636d34a..dcf016d8a7 100644 --- a/common/hash.c +++ b/common/hash.c @@ -362,7 +362,7 @@ static int parse_verify_sum(struct hash_algo *algo, char *verify_str, if (strlen(verify_str) == digits) vsum_str = verify_str; else { - vsum_str = getenv(verify_str); + vsum_str = env_get(verify_str); if (vsum_str == NULL || strlen(vsum_str) != digits) { printf("Expected %d hex digits in env var\n", digits); diff --git a/common/hwconfig.c b/common/hwconfig.c index 85aaabbb85..e5186d7796 100644 --- a/common/hwconfig.c +++ b/common/hwconfig.c @@ -81,7 +81,7 @@ static const char *__hwconfig(const char *opt, size_t *arglen, "and before environment is ready\n"); return NULL; } - env_hwconfig = getenv("hwconfig"); + env_hwconfig = env_get("hwconfig"); }
if (env_hwconfig) { diff --git a/common/image-android.c b/common/image-android.c index 018c7594fe..e74d0aafca 100644 --- a/common/image-android.c +++ b/common/image-android.c @@ -72,7 +72,7 @@ int android_image_get_kernel(const struct andr_img_hdr *hdr, int verify, len += strlen(hdr->cmdline); }
- char *bootargs = getenv("bootargs"); + char *bootargs = env_get("bootargs"); if (bootargs) len += strlen(bootargs);
diff --git a/common/image-fdt.c b/common/image-fdt.c index c6e8832d66..da4d007081 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -132,7 +132,7 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) of_len = *of_size + CONFIG_SYS_FDT_PAD;
/* If fdt_high is set use it to select the relocation address */ - fdt_high = getenv("fdt_high"); + fdt_high = env_get("fdt_high"); if (fdt_high) { void *desired_addr = (void *)simple_strtoul(fdt_high, NULL, 16);
@@ -156,8 +156,8 @@ int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size) } else { of_start = (void *)(ulong) lmb_alloc_base(lmb, of_len, 0x1000, - getenv_bootm_mapsize() - + getenv_bootm_low()); + env_get_bootm_mapsize() + + env_get_bootm_low()); }
if (of_start == NULL) { diff --git a/common/image.c b/common/image.c index 0f88984f2d..a058eb85e1 100644 --- a/common/image.c +++ b/common/image.c @@ -465,9 +465,9 @@ static int on_loadaddr(const char *name, const char *value, enum env_op op, } U_BOOT_ENV_CALLBACK(loadaddr, on_loadaddr);
-ulong getenv_bootm_low(void) +ulong env_get_bootm_low(void) { - char *s = getenv("bootm_low"); + char *s = env_get("bootm_low"); if (s) { ulong tmp = simple_strtoul(s, NULL, 16); return tmp; @@ -482,11 +482,11 @@ ulong getenv_bootm_low(void) #endif }
-phys_size_t getenv_bootm_size(void) +phys_size_t env_get_bootm_size(void) { phys_size_t tmp, size; phys_addr_t start; - char *s = getenv("bootm_size"); + char *s = env_get("bootm_size"); if (s) { tmp = (phys_size_t)simple_strtoull(s, NULL, 16); return tmp; @@ -500,7 +500,7 @@ phys_size_t getenv_bootm_size(void) size = gd->bd->bi_memsize; #endif
- s = getenv("bootm_low"); + s = env_get("bootm_low"); if (s) tmp = (phys_size_t)simple_strtoull(s, NULL, 16); else @@ -509,10 +509,10 @@ phys_size_t getenv_bootm_size(void) return size - (tmp - start); }
-phys_size_t getenv_bootm_mapsize(void) +phys_size_t env_get_bootm_mapsize(void) { phys_size_t tmp; - char *s = getenv("bootm_mapsize"); + char *s = env_get("bootm_mapsize"); if (s) { tmp = (phys_size_t)simple_strtoull(s, NULL, 16); return tmp; @@ -521,7 +521,7 @@ phys_size_t getenv_bootm_mapsize(void) #if defined(CONFIG_SYS_BOOTMAPSZ) return CONFIG_SYS_BOOTMAPSZ; #else - return getenv_bootm_size(); + return env_get_bootm_size(); #endif }
@@ -1224,7 +1224,8 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, ulong initrd_high; int initrd_copy_to_ram = 1;
- if ((s = getenv("initrd_high")) != NULL) { + s = env_get("initrd_high"); + if (s) { /* a value of "no" or a similar string will act like 0, * turning the "load high" feature off. This is intentional. */ @@ -1232,7 +1233,7 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, if (initrd_high == ~0) initrd_copy_to_ram = 0; } else { - initrd_high = getenv_bootm_mapsize() + getenv_bootm_low(); + initrd_high = env_get_bootm_mapsize() + env_get_bootm_low(); }
@@ -1505,7 +1506,7 @@ int boot_get_loadable(int argc, char * const argv[], bootm_headers_t *images, * @cmd_end: pointer to a ulong variable, will hold cmdline end * * boot_get_cmdline() allocates space for kernel command line below - * BOOTMAPSZ + getenv_bootm_low() address. If "bootargs" U-Boot environemnt + * BOOTMAPSZ + env_get_bootm_low() address. If "bootargs" U-Boot environemnt * variable is present its contents is copied to allocated kernel * command line. * @@ -1519,12 +1520,13 @@ int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end) char *s;
cmdline = (char *)(ulong)lmb_alloc_base(lmb, CONFIG_SYS_BARGSIZE, 0xf, - getenv_bootm_mapsize() + getenv_bootm_low()); + env_get_bootm_mapsize() + env_get_bootm_low());
if (cmdline == NULL) return -1;
- if ((s = getenv("bootargs")) == NULL) + s = env_get("bootargs"); + if (!s) s = "";
strcpy(cmdline, s); @@ -1545,7 +1547,7 @@ int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end) * @kbd: double pointer to board info data * * boot_get_kbd() allocates space for kernel copy of board info data below - * BOOTMAPSZ + getenv_bootm_low() address and kernel board info is initialized + * BOOTMAPSZ + env_get_bootm_low() address and kernel board info is initialized * with the current u-boot board info data. * * returns: @@ -1555,7 +1557,7 @@ int boot_get_cmdline(struct lmb *lmb, ulong *cmd_start, ulong *cmd_end) int boot_get_kbd(struct lmb *lmb, bd_t **kbd) { *kbd = (bd_t *)(ulong)lmb_alloc_base(lmb, sizeof(bd_t), 0xf, - getenv_bootm_mapsize() + getenv_bootm_low()); + env_get_bootm_mapsize() + env_get_bootm_low()); if (*kbd == NULL) return -1;
diff --git a/common/lcd.c b/common/lcd.c index 7e399cee2d..c3ff9599ed 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -223,7 +223,7 @@ void lcd_clear(void) /* Paint the logo and retrieve LCD base address */ debug("[LCD] Drawing the logo...\n"); if (do_splash) { - s = getenv("splashimage"); + s = env_get("splashimage"); if (s) { do_splash = 0; addr = simple_strtoul(s, NULL, 16); diff --git a/common/main.c b/common/main.c index 07fc31b716..6a1159879e 100644 --- a/common/main.c +++ b/common/main.c @@ -25,7 +25,7 @@ static void run_preboot_environment_command(void) #ifdef CONFIG_PREBOOT char *p;
- p = getenv("preboot"); + p = env_get("preboot"); if (p != NULL) { # ifdef CONFIG_AUTOBOOT_KEYED int prev = disable_ctrlc(1); /* disable Control C checking */ diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 60a73311d9..c96e7bfceb 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -248,7 +248,7 @@ config SPL_ENV_SUPPORT needed in SPL as it has a much simpler task with less configuration. But some boards use this to support 'Falcon' boot on EXT2 and FAT, where SPL boots directly into Linux without - starting U-Boot first. Enabling this option will make getenv() + starting U-Boot first. Enabling this option will make env_get() and env_set() available in SPL.
config SPL_SAVEENV diff --git a/common/spl/spl_dfu.c b/common/spl/spl_dfu.c index f5ec0fb396..2c974735b1 100644 --- a/common/spl/spl_dfu.c +++ b/common/spl/spl_dfu.c @@ -40,7 +40,7 @@ int spl_dfu_cmd(int usbctrl, char *dfu_alt_info, char *interface, char *devstr)
/* set default environment */ set_default_env(0); - str_env = getenv(dfu_alt_info); + str_env = env_get(dfu_alt_info); if (!str_env) { error(""dfu_alt_info" env variable not defined!\n"); return -EINVAL; diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index f17c6b9494..559ba0b797 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -89,7 +89,7 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image, return -1; } #if defined(CONFIG_SPL_ENV_SUPPORT) - file = getenv("falcon_args_file"); + file = env_get("falcon_args_file"); if (file) { err = ext4fs_open(file, &filelen); if (err < 0) { @@ -102,7 +102,7 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image, file, err); goto defaults; } - file = getenv("falcon_image_file"); + file = env_get("falcon_image_file"); if (file) { err = spl_load_image_ext(spl_image, block_dev, partition, file); diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index 5e312160d9..60b85f082d 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -113,7 +113,7 @@ int spl_load_image_fat_os(struct spl_image_info *spl_image, return err;
#if defined(CONFIG_SPL_ENV_SUPPORT) && defined(CONFIG_SPL_OS_BOOT) - file = getenv("falcon_args_file"); + file = env_get("falcon_args_file"); if (file) { err = file_fat_read(file, (void *)CONFIG_SYS_SPL_ARGS_ADDR, 0); if (err <= 0) { @@ -121,7 +121,7 @@ int spl_load_image_fat_os(struct spl_image_info *spl_image, file, err); goto defaults; } - file = getenv("falcon_image_file"); + file = env_get("falcon_image_file"); if (file) { err = spl_load_image_fat(spl_image, block_dev, partition, file); diff --git a/common/splash.c b/common/splash.c index 89af437f2c..d251b3b654 100644 --- a/common/splash.c +++ b/common/splash.c @@ -60,7 +60,7 @@ __weak int splash_screen_prepare(void) #ifdef CONFIG_SPLASH_SCREEN_ALIGN void splash_get_pos(int *x, int *y) { - char *s = getenv("splashpos"); + char *s = env_get("splashpos");
if (!s) return; diff --git a/common/splash_source.c b/common/splash_source.c index 867a798487..8c0ac581f7 100644 --- a/common/splash_source.c +++ b/common/splash_source.c @@ -220,7 +220,7 @@ static int splash_load_fs(struct splash_location *location, u32 bmp_load_addr) loff_t actread; char *splash_file;
- splash_file = getenv("splashfile"); + splash_file = env_get("splashfile"); if (!splash_file) splash_file = SPLASH_SOURCE_DEFAULT_FILE_NAME;
@@ -286,7 +286,7 @@ static struct splash_location *select_splash_location( if (!locations || size == 0) return NULL;
- env_splashsource = getenv("splashsource"); + env_splashsource = env_get("splashsource"); if (env_splashsource == NULL) return &locations[0];
@@ -383,7 +383,7 @@ int splash_source_load(struct splash_location *locations, uint size) char *env_splashimage_value; u32 bmp_load_addr;
- env_splashimage_value = getenv("splashimage"); + env_splashimage_value = env_get("splashimage"); if (env_splashimage_value == NULL) return -ENOENT;
diff --git a/common/update.c b/common/update.c index 061a5541b1..974f4655e7 100644 --- a/common/update.c +++ b/common/update.c @@ -59,7 +59,7 @@ static int update_load(char *filename, ulong msec_max, int cnt_max, ulong addr) /* save used globals and env variable */ saved_timeout_msecs = tftp_timeout_ms; saved_timeout_count = tftp_timeout_count_max; - saved_netretry = strdup(getenv("netretry")); + saved_netretry = strdup(env_get("netretry")); saved_bootfile = strdup(net_boot_file_name);
/* set timeouts for auto-update */ @@ -254,7 +254,7 @@ int update_tftp(ulong addr, char *interface, char *devstring) printf("Auto-update from TFTP: ");
/* get the file name of the update file */ - filename = getenv(UPDATE_FILE_ENV); + filename = env_get(UPDATE_FILE_ENV); if (filename == NULL) { printf("failed, env. variable '%s' not found\n", UPDATE_FILE_ENV); @@ -264,7 +264,8 @@ int update_tftp(ulong addr, char *interface, char *devstring) printf("trying update file '%s'\n", filename);
/* get load address of downloaded update file */ - if ((env_addr = getenv("loadaddr")) != NULL) + env_addr = env_get("loadaddr"); + if (env_addr) addr = simple_strtoul(env_addr, NULL, 16); else addr = CONFIG_UPDATE_LOAD_ADDR; diff --git a/common/usb_hub.c b/common/usb_hub.c index d135526e4f..b51e2c5a7d 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -131,7 +131,7 @@ static void usb_hub_power_on(struct usb_hub_device *hub) * but allow this time to be increased via env variable as some * devices break the spec and require longer warm-up times */ - env = getenv("usb_pgood_delay"); + env = env_get("usb_pgood_delay"); if (env) pgood_delay = max(pgood_delay, (unsigned)simple_strtol(env, NULL, 0)); diff --git a/common/usb_kbd.c b/common/usb_kbd.c index d2d29cc98f..8cbdba6ac2 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -515,7 +515,7 @@ static int probe_usb_keyboard(struct usb_device *dev) if (error) return error;
- stdinname = getenv("stdin"); + stdinname = env_get("stdin"); #if CONFIG_IS_ENABLED(CONSOLE_MUX) error = iomux_doenv(stdin, stdinname); if (error) @@ -582,7 +582,7 @@ int usb_kbd_deregister(int force) if (stdio_deregister_dev(dev, force) != 0) return 1; #if CONFIG_IS_ENABLED(CONSOLE_MUX) - if (iomux_doenv(stdin, getenv("stdin")) != 0) + if (iomux_doenv(stdin, env_get("stdin")) != 0) return 1; #endif #ifdef CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE @@ -627,7 +627,7 @@ static int usb_kbd_remove(struct udevice *dev) goto err; } #if CONFIG_IS_ENABLED(CONSOLE_MUX) - if (iomux_doenv(stdin, getenv("stdin"))) { + if (iomux_doenv(stdin, env_get("stdin"))) { ret = -ENOLINK; goto err; } diff --git a/disk/part.c b/disk/part.c index 491b02dc9c..05d07d850b 100644 --- a/disk/part.c +++ b/disk/part.c @@ -452,7 +452,7 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str, /* If no dev_part_str, use bootdevice environment variable */ if (!dev_part_str || !strlen(dev_part_str) || !strcmp(dev_part_str, "-")) - dev_part_str = getenv("bootdevice"); + dev_part_str = env_get("bootdevice");
/* If still no dev_part_str, it's an error */ if (!dev_part_str) { diff --git a/disk/part_amiga.c b/disk/part_amiga.c index 25fe56ce42..f8dae008d7 100644 --- a/disk/part_amiga.c +++ b/disk/part_amiga.c @@ -132,7 +132,7 @@ struct rigid_disk_block *get_rdisk(struct blk_desc *dev_desc) int limit; char *s;
- s = getenv("amiga_scanlimit"); + s = env_get("amiga_scanlimit"); if (s) limit = simple_strtoul(s, NULL, 10); else @@ -172,7 +172,7 @@ struct bootcode_block *get_bootcode(struct blk_desc *dev_desc) int limit; char *s;
- s = getenv("amiga_scanlimit"); + s = env_get("amiga_scanlimit"); if (s) limit = simple_strtoul(s, NULL, 10); else diff --git a/doc/README.enetaddr b/doc/README.enetaddr index 241d528ff7..f926485986 100644 --- a/doc/README.enetaddr +++ b/doc/README.enetaddr @@ -84,7 +84,7 @@ uchar enetaddr[6]; eth_parse_enetaddr(addr, enetaddr); /* enetaddr now equals { 0x00, 0x11, 0x22, 0x33, 0x44, 0x55 } */
- * int eth_getenv_enetaddr(char *name, uchar *enetaddr); + * int eth_env_get_enetaddr(char *name, uchar *enetaddr);
Look up an environment variable and convert the stored address. If the address is valid, then the function returns 1. Otherwise, the function returns 0. In @@ -92,7 +92,7 @@ all cases, the enetaddr memory is initialized. If the env var is not found, then it is set to all zeros. The common function is_valid_ethaddr() is used to determine address validity. uchar enetaddr[6]; -if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { +if (!eth_env_get_enetaddr("ethaddr", enetaddr)) { /* "ethaddr" is not set in the environment */ ... try and setup "ethaddr" in the env ... } diff --git a/drivers/bootcount/bootcount_env.c b/drivers/bootcount/bootcount_env.c index ec5f942676..c3618d3a59 100644 --- a/drivers/bootcount/bootcount_env.c +++ b/drivers/bootcount/bootcount_env.c @@ -10,7 +10,7 @@
void bootcount_store(ulong a) { - int upgrade_available = getenv_ulong("upgrade_available", 10, 0); + int upgrade_available = env_get_ulong("upgrade_available", 10, 0);
if (upgrade_available) { env_set_ulong("bootcount", a); @@ -20,11 +20,11 @@ void bootcount_store(ulong a)
ulong bootcount_load(void) { - int upgrade_available = getenv_ulong("upgrade_available", 10, 0); + int upgrade_available = env_get_ulong("upgrade_available", 10, 0); ulong val = 0;
if (upgrade_available) - val = getenv_ulong("bootcount", 10, 0); + val = env_get_ulong("bootcount", 10, 0);
return val; } diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index 3349fc5c3b..058c9b9da8 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -469,7 +469,7 @@ step2: #define CTLR_INTLV_MASK 0x20000000 /* Perform build-in test on memory. Three-way interleaving is not yet * supported by this code. */ - if (getenv_f("ddr_bist", buffer, CONFIG_SYS_CBSIZE) >= 0) { + if (env_get_f("ddr_bist", buffer, CONFIG_SYS_CBSIZE) >= 0) { puts("Running BIST test. This will take a while..."); cs0_config = ddr_in32(&ddr->cs0_config); cs0_bnds = ddr_in32(&ddr->cs0_bnds); diff --git a/drivers/ddr/fsl/interactive.c b/drivers/ddr/fsl/interactive.c index 653bbabc95..c99bd2fb6d 100644 --- a/drivers/ddr/fsl/interactive.c +++ b/drivers/ddr/fsl/interactive.c @@ -1861,7 +1861,7 @@ int fsl_ddr_interactive_env_var_exists(void) { char buffer[CONFIG_SYS_CBSIZE];
- if (getenv_f("ddr_interactive", buffer, CONFIG_SYS_CBSIZE) >= 0) + if (env_get_f("ddr_interactive", buffer, CONFIG_SYS_CBSIZE) >= 0) return 1;
return 0; @@ -1891,11 +1891,11 @@ unsigned long long fsl_ddr_interactive(fsl_ddr_info_t *pinfo, int var_is_set) };
if (var_is_set) { - if (getenv_f("ddr_interactive", buffer2, CONFIG_SYS_CBSIZE) > 0) { + if (env_get_f("ddr_interactive", buffer2, + CONFIG_SYS_CBSIZE) > 0) p = buffer2; - } else { + else var_is_set = 0; - } }
/* diff --git a/drivers/ddr/fsl/options.c b/drivers/ddr/fsl/options.c index 20edd2dc28..7ef342f625 100644 --- a/drivers/ddr/fsl/options.c +++ b/drivers/ddr/fsl/options.c @@ -18,7 +18,7 @@ * Use our own stack based buffer before relocation to allow accessing longer * hwconfig strings that might be in the environment before we've relocated. * This is pretty fragile on both the use of stack and if the buffer is big - * enough. However we will get a warning from getenv_f for the later. + * enough. However we will get a warning from env_get_f for the later. */
/* Board-specific functions defined in each board's ddr.c */ @@ -755,7 +755,7 @@ unsigned int populate_memctl_options(const common_timing_params_t *common_dimm, * Extract hwconfig from environment since we have not properly setup * the environment but need it for ddr config params */ - if (getenv_f("hwconfig", buffer, sizeof(buffer)) > 0) + if (env_get_f("hwconfig", buffer, sizeof(buffer)) > 0) buf = buffer;
#if defined(CONFIG_SYS_FSL_DDR3) || \ @@ -1399,7 +1399,7 @@ int fsl_use_spd(void) * Extract hwconfig from environment since we have not properly setup * the environment but need it for ddr config params */ - if (getenv_f("hwconfig", buffer, sizeof(buffer)) > 0) + if (env_get_f("hwconfig", buffer, sizeof(buffer)) > 0) buf = buffer;
/* if hwconfig is not enabled, or "sdram" is not defined, use spd */ diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index ceb33e35ee..856a793c17 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -62,7 +62,7 @@ int dfu_init_env_entities(char *interface, char *devstr) #ifdef CONFIG_SET_DFU_ALT_INFO set_dfu_alt_info(interface, devstr); #endif - str_env = getenv("dfu_alt_info"); + str_env = env_get("dfu_alt_info"); if (!str_env) { error(""dfu_alt_info" env variable not defined!\n"); return -EINVAL; @@ -101,7 +101,7 @@ unsigned char *dfu_get_buf(struct dfu_entity *dfu) if (dfu_buf != NULL) return dfu_buf;
- s = getenv("dfu_bufsiz"); + s = env_get("dfu_bufsiz"); if (s) dfu_buf_size = (unsigned long)simple_strtol(s, NULL, 0);
@@ -123,7 +123,7 @@ static char *dfu_get_hash_algo(void) { char *s;
- s = getenv("dfu_hash_algo"); + s = env_get("dfu_hash_algo"); if (!s) return NULL;
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 926ccbd2ef..79135563ae 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -161,7 +161,7 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, }
if (op != DFU_OP_WRITE) { - str_env = getenv("filesize"); + str_env = env_get("filesize"); if (str_env == NULL) { puts("dfu: Wrong file size!\n"); return -1; diff --git a/drivers/input/i8042.c b/drivers/input/i8042.c index 0fd25b17ec..18476e97d1 100644 --- a/drivers/input/i8042.c +++ b/drivers/input/i8042.c @@ -274,7 +274,7 @@ static int i8042_start(struct udevice *dev)
/* Init keyboard device (default US layout) */ keymap = KBD_US; - penv = getenv("keymap"); + penv = env_get("keymap"); if (penv != NULL) { if (strncmp(penv, "de", 3) == 0) keymap = KBD_GER; diff --git a/drivers/input/input.c b/drivers/input/input.c index 011667fedd..26da3a95ff 100644 --- a/drivers/input/input.c +++ b/drivers/input/input.c @@ -652,7 +652,7 @@ int input_stdio_register(struct stdio_dev *dev) error = stdio_register(dev);
/* check if this is the standard input device */ - if (!error && strcmp(getenv("stdin"), dev->name) == 0) { + if (!error && strcmp(env_get("stdin"), dev->name) == 0) { /* reassign the console */ if (OVERWRITE_CONSOLE || console_assign(stdin, dev->name)) diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 048a51785e..42bc2efd90 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -2353,7 +2353,7 @@ unsigned long flash_init (void) #ifdef CONFIG_SYS_FLASH_PROTECTION /* read environment from EEPROM */ char s[64]; - getenv_f("unlock", s, sizeof(s)); + env_get_f("unlock", s, sizeof(s)); #endif
#ifdef CONFIG_CFI_FLASH /* for driver model */ diff --git a/drivers/net/dc2114x.c b/drivers/net/dc2114x.c index 8245cf51cc..f38f36beb1 100644 --- a/drivers/net/dc2114x.c +++ b/drivers/net/dc2114x.c @@ -750,7 +750,7 @@ static void update_srom(struct eth_device *dev, bd_t *bis) uchar enetaddr[6];
/* Ethernet Addr... */ - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) + if (!eth_env_get_enetaddr("ethaddr", enetaddr)) return; eeprom[0x0a] = (enetaddr[1] << 8) | enetaddr[0]; eeprom[0x0b] = (enetaddr[3] << 8) | enetaddr[2]; diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 424c347e0e..797e34f7cc 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1096,7 +1096,7 @@ static int fec_probe(bd_t *bd, int dev_id, uint32_t base_addr, sprintf(mac, "eth%daddr", fec->dev_id); else strcpy(mac, "ethaddr"); - if (!getenv(mac)) + if (!env_get(mac)) eth_env_set_enetaddr(mac, ethaddr); } return ret; diff --git a/drivers/net/fm/b4860.c b/drivers/net/fm/b4860.c index 5aeeb87282..3245bee473 100644 --- a/drivers/net/fm/b4860.c +++ b/drivers/net/fm/b4860.c @@ -97,7 +97,7 @@ phy_interface_t fman_port_enet_if(enum fm_port port) * Extract hwconfig from environment since environment * is not setup yet */ - getenv_f("hwconfig", buffer, sizeof(buffer)); + env_get_f("hwconfig", buffer, sizeof(buffer)); buf = buffer;
/* check if XFI interface enable in hwconfig for 10g */ diff --git a/drivers/net/fm/fdt.c b/drivers/net/fm/fdt.c index 9918d8089a..5920fecea1 100644 --- a/drivers/net/fm/fdt.c +++ b/drivers/net/fm/fdt.c @@ -36,7 +36,7 @@ void fdt_fixup_fman_firmware(void *blob) return;
/* If the environment variable is not set, then exit silently */ - p = getenv("fman_ucode"); + p = env_get("fman_ucode"); if (!p) return;
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index 8bf25c7040..142aeecfe9 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -190,8 +190,8 @@ static int mc_fixup_mac_addr(void *blob, int nodeoffset, /* MAC address property present */ if (fdt_get_property(blob, nodeoffset, propname, NULL)) { /* u-boot MAC addr randomly assigned - leave the present one */ - if (!eth_getenv_enetaddr_by_index("eth", eth_dev->index, - env_enetaddr)) + if (!eth_env_get_enetaddr_by_index("eth", eth_dev->index, + env_enetaddr)) return err; } else { size = MC_DT_INCREASE_SIZE + strlen(propname) + len; @@ -530,7 +530,7 @@ static unsigned long get_mc_boot_timeout_ms(void) { unsigned long timeout_ms = CONFIG_SYS_LS_MC_BOOT_TIMEOUT_MS;
- char *timeout_ms_env_var = getenv(MC_BOOT_TIMEOUT_ENV_VAR); + char *timeout_ms_env_var = env_get(MC_BOOT_TIMEOUT_ENV_VAR);
if (timeout_ms_env_var) { timeout_ms = simple_strtoul(timeout_ms_env_var, NULL, 10); @@ -815,7 +815,7 @@ unsigned long mc_get_dram_block_size(void) { unsigned long dram_block_size = CONFIG_SYS_LS_MC_DRAM_BLOCK_MIN_SIZE;
- char *dram_block_size_env_var = getenv(MC_MEM_SIZE_ENV_VAR); + char *dram_block_size_env_var = env_get(MC_MEM_SIZE_ENV_VAR);
if (dram_block_size_env_var) { dram_block_size = simple_strtoul(dram_block_size_env_var, NULL, @@ -1511,7 +1511,7 @@ void mc_env_boot(void) * address info properly. Without MAC addresses, the MC code * can not properly initialize the DPC. */ - mc_boot_env_var = getenv(MC_BOOT_ENV_VAR); + mc_boot_env_var = env_get(MC_BOOT_ENV_VAR); if (mc_boot_env_var) run_command_list(mc_boot_env_var, -1, 0); #endif /* CONFIG_FSL_MC_ENET */ diff --git a/drivers/net/fsl_mcdmafec.c b/drivers/net/fsl_mcdmafec.c index 628b420add..26c714cc04 100644 --- a/drivers/net/fsl_mcdmafec.c +++ b/drivers/net/fsl_mcdmafec.c @@ -383,9 +383,9 @@ static int fec_init(struct eth_device *dev, bd_t * bd)
/* Set station address */ if ((u32) fecp == CONFIG_SYS_FEC0_IOBASE) - eth_getenv_enetaddr("ethaddr", enetaddr); + eth_env_get_enetaddr("ethaddr", enetaddr); else - eth_getenv_enetaddr("eth1addr", enetaddr); + eth_env_get_enetaddr("eth1addr", enetaddr); fec_set_hwaddr(fecp, enetaddr);
/* Set Opcode/Pause Duration Register */ diff --git a/drivers/net/ftgmac100.c b/drivers/net/ftgmac100.c index 5ccc4beda8..d0939e93dc 100644 --- a/drivers/net/ftgmac100.c +++ b/drivers/net/ftgmac100.c @@ -346,7 +346,7 @@ static void ftgmac100_set_mac(struct eth_device *dev,
static void ftgmac100_set_mac_from_env(struct eth_device *dev) { - eth_getenv_enetaddr("ethaddr", dev->enetaddr); + eth_env_get_enetaddr("ethaddr", dev->enetaddr);
ftgmac100_set_mac(dev, dev->enetaddr); } diff --git a/drivers/net/ftmac100.c b/drivers/net/ftmac100.c index cd24a21f04..f231e6b33b 100644 --- a/drivers/net/ftmac100.c +++ b/drivers/net/ftmac100.c @@ -355,7 +355,7 @@ static int ftmac100_free_pkt(struct udevice *dev, uchar *packet, int length) int ftmac100_read_rom_hwaddr(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); - eth_getenv_enetaddr("ethaddr", pdata->enetaddr); + eth_env_get_enetaddr("ethaddr", pdata->enetaddr); return 0; }
diff --git a/drivers/net/lan91c96.c b/drivers/net/lan91c96.c index 255c7010cc..a9fc74bdee 100644 --- a/drivers/net/lan91c96.c +++ b/drivers/net/lan91c96.c @@ -704,7 +704,7 @@ static int smc_get_ethaddr(bd_t *bd, struct eth_device *dev) { uchar v_mac[6];
- if (!eth_getenv_enetaddr("ethaddr", v_mac)) { + if (!eth_env_get_enetaddr("ethaddr", v_mac)) { /* get ROM mac value if any */ if (!get_rom_mac(dev, v_mac)) { printf("\n*** ERROR: ethaddr is NOT set !!\n"); diff --git a/drivers/net/mcffec.c b/drivers/net/mcffec.c index e1b06b25d7..39a6747320 100644 --- a/drivers/net/mcffec.c +++ b/drivers/net/mcffec.c @@ -428,25 +428,25 @@ int fec_init(struct eth_device *dev, bd_t * bd) if ((u32) fecp == CONFIG_SYS_FEC0_IOBASE) { #ifdef CONFIG_SYS_FEC1_IOBASE volatile fec_t *fecp1 = (fec_t *) (CONFIG_SYS_FEC1_IOBASE); - eth_getenv_enetaddr("eth1addr", ea); + eth_env_get_enetaddr("eth1addr", ea); fecp1->palr = (ea[0] << 24) | (ea[1] << 16) | (ea[2] << 8) | (ea[3]); fecp1->paur = (ea[4] << 24) | (ea[5] << 16); #endif - eth_getenv_enetaddr("ethaddr", ea); + eth_env_get_enetaddr("ethaddr", ea); fecp->palr = (ea[0] << 24) | (ea[1] << 16) | (ea[2] << 8) | (ea[3]); fecp->paur = (ea[4] << 24) | (ea[5] << 16); } else { #ifdef CONFIG_SYS_FEC0_IOBASE volatile fec_t *fecp0 = (fec_t *) (CONFIG_SYS_FEC0_IOBASE); - eth_getenv_enetaddr("ethaddr", ea); + eth_env_get_enetaddr("ethaddr", ea); fecp0->palr = (ea[0] << 24) | (ea[1] << 16) | (ea[2] << 8) | (ea[3]); fecp0->paur = (ea[4] << 24) | (ea[5] << 16); #endif #ifdef CONFIG_SYS_FEC1_IOBASE - eth_getenv_enetaddr("eth1addr", ea); + eth_env_get_enetaddr("eth1addr", ea); fecp->palr = (ea[0] << 24) | (ea[1] << 16) | (ea[2] << 8) | (ea[3]); fecp->paur = (ea[4] << 24) | (ea[5] << 16); diff --git a/drivers/net/ne2000_base.c b/drivers/net/ne2000_base.c index f6e5eafba5..fb088e06a4 100644 --- a/drivers/net/ne2000_base.c +++ b/drivers/net/ne2000_base.c @@ -715,12 +715,12 @@ static int ne2k_setup_driver(struct eth_device *dev) * to the MAC address value in the environment, so we do not read * it from the prom or eeprom if it is specified in the environment. */ - if (!eth_getenv_enetaddr("ethaddr", dev->enetaddr)) { + if (!eth_env_get_enetaddr("ethaddr", dev->enetaddr)) { /* If the MAC address is not in the environment, get it: */ if (!get_prom(dev->enetaddr, nic.base)) /* get MAC from prom */ dp83902a_init(dev->enetaddr); /* fallback: seeprom */ /* And write it into the environment otherwise eth_write_hwaddr - * returns -1 due to eth_getenv_enetaddr_by_index() failing, + * returns -1 due to eth_env_get_enetaddr_by_index() failing, * and this causes "Warning: failed to set MAC address", and * cmd_bdinfo has no ethaddr value which it can show: */ eth_env_set_enetaddr("ethaddr", dev->enetaddr); diff --git a/drivers/net/netconsole.c b/drivers/net/netconsole.c index 3500047577..e9dbedf326 100644 --- a/drivers/net/netconsole.c +++ b/drivers/net/netconsole.c @@ -62,8 +62,8 @@ static int is_broadcast(struct in_addr ip)
/* update only when the environment has changed */ if (env_changed_id != env_id) { - netmask = getenv_ip("netmask"); - our_ip = getenv_ip("ipaddr"); + netmask = env_get_ip("netmask"); + our_ip = env_get_ip("ipaddr");
env_changed_id = env_id; } @@ -82,11 +82,11 @@ static int refresh_settings_from_env(void)
/* update only when the environment has changed */ if (env_changed_id != env_id) { - if (getenv("ncip")) { - nc_ip = getenv_ip("ncip"); + if (env_get("ncip")) { + nc_ip = env_get_ip("ncip"); if (!nc_ip.s_addr) return -1; /* ncip is 0.0.0.0 */ - p = strchr(getenv("ncip"), ':'); + p = strchr(env_get("ncip"), ':'); if (p != NULL) { nc_out_port = simple_strtoul(p + 1, NULL, 10); nc_in_port = nc_out_port; @@ -95,10 +95,10 @@ static int refresh_settings_from_env(void) nc_ip.s_addr = ~0; /* ncip is not set, so broadcast */ }
- p = getenv("ncoutport"); + p = env_get("ncoutport"); if (p != NULL) nc_out_port = simple_strtoul(p, NULL, 10); - p = getenv("ncinport"); + p = env_get("ncinport"); if (p != NULL) nc_in_port = simple_strtoul(p, NULL, 10);
diff --git a/drivers/net/phy/micrel.c b/drivers/net/phy/micrel.c index 0e4a4ebcc6..15cae957e7 100644 --- a/drivers/net/phy/micrel.c +++ b/drivers/net/phy/micrel.c @@ -357,7 +357,7 @@ static int ksz9021_config(struct phy_device *phydev) if (ret) return ret;
- if (getenv("disable_giga")) + if (env_get("disable_giga")) features &= ~(SUPPORTED_1000baseT_Half | SUPPORTED_1000baseT_Full); /* force master mode for 1000BaseT due to chip errata */ diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index a7c265b980..970d730e56 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -578,7 +578,7 @@ int sh_eth_initialize(bd_t *bd) if (retval < 0) return retval;
- if (!eth_getenv_enetaddr("ethaddr", dev->enetaddr)) + if (!eth_env_get_enetaddr("ethaddr", dev->enetaddr)) puts("Please set MAC address\n");
return ret; diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index af20cf0f3e..df76a94144 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -390,7 +390,7 @@ void fsl_pci_init(struct pci_controller *hose, struct fsl_pci_info *pci_info)
#ifdef CONFIG_SRIO_PCIE_BOOT_MASTER /* boot from PCIE --master */ - char *s = getenv("bootmaster"); + char *s = env_get("bootmaster"); char pcie[6]; sprintf(pcie, "PCIE%d", pci_info->pci_num);
@@ -673,7 +673,7 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info, #ifdef CONFIG_SRIO_PCIE_BOOT_MASTER } else { /* boot from PCIE --master releases slave's core 0 */ - char *s = getenv("bootmaster"); + char *s = env_get("bootmaster"); char pcie[6]; sprintf(pcie, "PCIE%d", pci_info->pci_num);
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 6b36c187b5..bbc7dab366 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -427,7 +427,7 @@ int pci_hose_scan(struct pci_controller *hose)
if (!gd->pcidelay_done) { /* wait "pcidelay" ms (if defined)... */ - s = getenv("pcidelay"); + s = env_get("pcidelay"); if (s) { int val = simple_strtoul(s, NULL, 10); for (i = 0; i < val; i++) @@ -459,7 +459,7 @@ void pci_init(void) hose_head = NULL;
/* allow env to disable pci init/enum */ - if (getenv("pcidisable") != NULL) + if (env_get("pcidisable") != NULL) return;
/* now call board specific pci_init()... */ diff --git a/drivers/pci/pci_common.c b/drivers/pci/pci_common.c index 6526de80db..faf25d96cb 100644 --- a/drivers/pci/pci_common.c +++ b/drivers/pci/pci_common.c @@ -89,7 +89,7 @@ __weak int pci_skip_dev(struct pci_controller *hose, pci_dev_t dev) /* * Only skip configuration if "pciconfighost" is not set */ - if (getenv("pciconfighost") == NULL) + if (env_get("pciconfighost") == NULL) return 1; #else return 1; diff --git a/drivers/rtc/m41t60.c b/drivers/rtc/m41t60.c index 95083f0d72..2ddfd4ea5c 100644 --- a/drivers/rtc/m41t60.c +++ b/drivers/rtc/m41t60.c @@ -200,7 +200,7 @@ int rtc_set(struct rtc_time *tmp) void rtc_reset(void) { uchar *const data = rtc_validate(); - char const *const s = getenv("rtccal"); + char const *const s = env_get("rtccal");
if (!data) return; diff --git a/drivers/serial/usbtty.c b/drivers/serial/usbtty.c index 29799dce93..353109c070 100644 --- a/drivers/serial/usbtty.c +++ b/drivers/serial/usbtty.c @@ -526,9 +526,9 @@ int drv_usbtty_init (void) int snlen;
/* Ger seiral number */ - if (!(sn = getenv("serial#"))) { + sn = env_get("serial#"); + if (!sn) sn = "000000000000"; - } snlen = strlen(sn); if (snlen > sizeof(serial_number) - 1) { printf ("Warning: serial number %s is too long (%d > %lu)\n", @@ -540,10 +540,9 @@ int drv_usbtty_init (void)
/* Decide on which type of UDC device to be. */ - - if(!(tt = getenv("usbtty"))) { + tt = env_get("usbtty"); + if (!tt) tt = "generic"; - } usbtty_init_terminal_type(strcmp(tt,"cdc_acm"));
/* prepare buffers... */ diff --git a/drivers/usb/gadget/designware_udc.c b/drivers/usb/gadget/designware_udc.c index 0db7a3b6c1..a25f5019e8 100644 --- a/drivers/usb/gadget/designware_udc.c +++ b/drivers/usb/gadget/designware_udc.c @@ -601,7 +601,7 @@ void udc_setup_ep(struct usb_device_instance *device, if ((ep != 0) && (udc_device->device_state < STATE_ADDRESSED)) return;
- tt = getenv("usbtty"); + tt = env_get("usbtty"); if (!tt) tt = "generic";
diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index d0105372cf..2cf5c8d31e 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -2384,12 +2384,12 @@ static int _usb_eth_init(struct ether_priv *priv) strlcpy(host_addr, CONFIG_USBNET_HOST_ADDR, sizeof(host_addr)); #endif /* Check if the user overruled the MAC addresses */ - if (getenv("usbnet_devaddr")) - strlcpy(dev_addr, getenv("usbnet_devaddr"), + if (env_get("usbnet_devaddr")) + strlcpy(dev_addr, env_get("usbnet_devaddr"), sizeof(dev_addr));
- if (getenv("usbnet_hostaddr")) - strlcpy(host_addr, getenv("usbnet_hostaddr"), + if (env_get("usbnet_hostaddr")) + strlcpy(host_addr, env_get("usbnet_hostaddr"), sizeof(host_addr));
if (!is_eth_addr_valid(dev_addr)) { @@ -2420,8 +2420,8 @@ static int _usb_eth_init(struct ether_priv *priv) gadget = dev->gadget; usb_gadget_connect(gadget);
- if (getenv("cdc_connect_timeout")) - timeout = simple_strtoul(getenv("cdc_connect_timeout"), + if (env_get("cdc_connect_timeout")) + timeout = simple_strtoul(env_get("cdc_connect_timeout"), NULL, 10) * CONFIG_SYS_HZ; ts = get_timer(0); while (!dev->network_started) { diff --git a/drivers/usb/gadget/f_dfu.c b/drivers/usb/gadget/f_dfu.c index dfa4359577..bc4be712da 100644 --- a/drivers/usb/gadget/f_dfu.c +++ b/drivers/usb/gadget/f_dfu.c @@ -725,7 +725,7 @@ static int dfu_bind(struct usb_configuration *c, struct usb_function *f)
cdev->req->context = f_dfu;
- s = getenv("serial#"); + s = env_get("serial#"); if (s) g_dnl_set_serialnumber((char *)s);
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 7cd6d24bf5..d05b74b2d2 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -212,7 +212,7 @@ static int fastboot_bind(struct usb_configuration *c, struct usb_function *f) f->hs_descriptors = fb_hs_function; }
@@ -426,7 +426,7 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req) sprintf(str_num, "0x%08x", CONFIG_FASTBOOT_BUF_SIZE); strncat(response, str_num, chars_left); } else if (!strcmp_l1("serialno", cmd)) { - s = getenv("serial#"); + s = env_get("serial#"); if (s) strncat(response, s, chars_left); else @@ -441,7 +441,7 @@ static void cb_getvar(struct usb_ep *ep, struct usb_request *req) }
sprintf(envstr, "fastboot.%s", cmd); - s = getenv(envstr); + s = env_get(envstr); if (s) { strncat(response, s, chars_left); } else { diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index b57c6cd35a..62c431b99f 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -225,7 +225,7 @@ static int ehci_fsl_init(int index, struct usb_ehci *ehci, "phy_type", &len); #endif else - phy_type = getenv("usb_phy_type"); + phy_type = env_get("usb_phy_type");
if (!phy_type) { #ifdef CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY diff --git a/drivers/video/ati_radeon_fb.c b/drivers/video/ati_radeon_fb.c index 07a29eaba1..5b6c42291c 100644 --- a/drivers/video/ati_radeon_fb.c +++ b/drivers/video/ati_radeon_fb.c @@ -637,7 +637,8 @@ void *video_hw_init(void)
videomode = CONFIG_SYS_DEFAULT_VIDEO_MODE; /* get video mode via environment */ - if ((penv = getenv ("videomode")) != NULL) { + penv = env_get("videomode"); + if (penv) { /* deceide if it is a string */ if (penv[0] <= '9') { videomode = (int) simple_strtoul (penv, NULL, 16); diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index f54802052e..75d4388943 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -1866,7 +1866,7 @@ static void *video_logo(void) splash_get_pos(&video_logo_xpos, &video_logo_ypos);
#ifdef CONFIG_SPLASH_SCREEN - s = getenv("splashimage"); + s = env_get("splashimage"); if (s != NULL) { ret = splash_screen_prepare(); if (ret < 0) diff --git a/drivers/video/ct69000.c b/drivers/video/ct69000.c index a74e4e6868..5148413773 100644 --- a/drivers/video/ct69000.c +++ b/drivers/video/ct69000.c @@ -918,7 +918,8 @@ video_hw_init (void) tmp = 0; videomode = 0x301; /* get video mode via environment */ - if ((penv = getenv ("videomode")) != NULL) { + penv = env_get("videomode"); + if (penv) { /* deceide if it is a string */ if (penv[0] <= '9') { videomode = (int) simple_strtoul (penv, NULL, 16); diff --git a/drivers/video/mb862xx.c b/drivers/video/mb862xx.c index 1c74e97c5e..e0565e1d2e 100644 --- a/drivers/video/mb862xx.c +++ b/drivers/video/mb862xx.c @@ -246,7 +246,8 @@ unsigned int card_init (void) tmp = 0; videomode = 0x310; /* get video mode via environment */ - if ((penv = getenv ("videomode")) != NULL) { + penv = env_get("videomode"); + if (penv) { /* decide if it is a string */ if (penv[0] <= '9') { videomode = (int) simple_strtoul (penv, NULL, 16); diff --git a/drivers/video/mx3fb.c b/drivers/video/mx3fb.c index 51d06d6677..78e595ea4a 100644 --- a/drivers/video/mx3fb.c +++ b/drivers/video/mx3fb.c @@ -816,7 +816,7 @@ void *video_hw_init(void)
videomode = CONFIG_SYS_DEFAULT_VIDEO_MODE; /* get video mode via environment */ - penv = getenv("videomode"); + penv = env_get("videomode"); if (penv) { /* decide if it is a string */ if (penv[0] <= '9') { diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 0ddce3db58..9d810bab31 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -161,7 +161,7 @@ void *video_hw_init(void) puts("Video: ");
/* Suck display configuration from "videomode" variable */ - penv = getenv("videomode"); + penv = env_get("videomode"); if (!penv) { puts("MXSFB: 'videomode' variable not set!\n"); return NULL; diff --git a/drivers/video/videomodes.c b/drivers/video/videomodes.c index cf71ad120e..6d96b33f20 100644 --- a/drivers/video/videomodes.c +++ b/drivers/video/videomodes.c @@ -165,7 +165,8 @@ int video_get_params (struct ctfb_res_modes *pPar, char *penv) /* first search for the environment containing the real param string */ s = penv;
- if ((p = getenv (s)) != NULL) + p = env_get(s); + if (p) s = p;
/* @@ -234,7 +235,7 @@ int video_get_params (struct ctfb_res_modes *pPar, char *penv) int video_get_video_mode(unsigned int *xres, unsigned int *yres, unsigned int *depth, unsigned int *freq, const char **options) { - char *p = getenv("video-mode"); + char *p = env_get("video-mode"); if (!p) return 0;
diff --git a/env/callback.c b/env/callback.c index 1957cc1996..be70980f04 100644 --- a/env/callback.c +++ b/env/callback.c @@ -51,7 +51,7 @@ void env_callback_init(ENTRY *var_entry) int ret = 1;
if (first_call) { - callback_list = getenv(ENV_CALLBACK_VAR); + callback_list = env_get(ENV_CALLBACK_VAR); first_call = 0; }
diff --git a/env/common.c b/env/common.c index b63b5fc12f..a30c04cf2c 100644 --- a/env/common.c +++ b/env/common.c @@ -31,9 +31,9 @@ struct hsearch_data env_htab = { * Read an environment variable as a boolean * Return -1 if variable does not exist (default to true) */ -int getenv_yesno(const char *var) +int env_get_yesno(const char *var) { - char *s = getenv(var); + char *s = env_get(var);
if (s == NULL) return -1; @@ -44,7 +44,7 @@ int getenv_yesno(const char *var) /* * Look up the variable from the default environment */ -char *getenv_default(const char *name) +char *env_get_default(const char *name) { char *ret_val; unsigned long really_valid = gd->env_valid; @@ -53,7 +53,7 @@ char *getenv_default(const char *name) /* Pretend that the image is bad. */ gd->flags &= ~GD_FLG_ENV_READY; gd->env_valid = 0; - ret_val = getenv(name); + ret_val = env_get(name); gd->env_valid = really_valid; gd->flags = real_gd_flags; return ret_val; diff --git a/env/flags.c b/env/flags.c index 3c50620cb3..4b0ddb6bb8 100644 --- a/env/flags.c +++ b/env/flags.c @@ -15,7 +15,7 @@ #include "fw_env.h" #include <env_attr.h> #include <env_flags.h> -#define getenv fw_getenv +#define env_get fw_getenv #define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) #else #include <common.h> @@ -308,7 +308,7 @@ static inline int env_flags_lookup(const char *flags_list, const char *name, */ enum env_flags_vartype env_flags_get_type(const char *name) { - const char *flags_list = getenv(ENV_FLAGS_VAR); + const char *flags_list = env_get(ENV_FLAGS_VAR); char flags[ENV_FLAGS_ATTR_MAX_LEN + 1];
if (env_flags_lookup(flags_list, name, flags)) @@ -325,7 +325,7 @@ enum env_flags_vartype env_flags_get_type(const char *name) */ enum env_flags_varaccess env_flags_get_varaccess(const char *name) { - const char *flags_list = getenv(ENV_FLAGS_VAR); + const char *flags_list = env_get(ENV_FLAGS_VAR); char flags[ENV_FLAGS_ATTR_MAX_LEN + 1];
if (env_flags_lookup(flags_list, name, flags)) @@ -426,7 +426,7 @@ void env_flags_init(ENTRY *var_entry) int ret = 1;
if (first_call) { - flags_list = getenv(ENV_FLAGS_VAR); + flags_list = env_get(ENV_FLAGS_VAR); first_call = 0; } /* look in the ".flags" and static for a reference to this variable */ @@ -541,7 +541,7 @@ int env_flags_validate(const ENTRY *item, const char *newval, enum env_op op, return 1; } else if (item->flags & ENV_FLAGS_VARACCESS_PREVENT_NONDEF_OVERWR) { - const char *defval = getenv_default(name); + const char *defval = env_get_default(name);
if (defval == NULL) defval = ""; diff --git a/fs/fs.c b/fs/fs.c index 055dffdafd..13cd3626c6 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -379,7 +379,7 @@ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], if (ep == argv[3] || *ep != '\0') return CMD_RET_USAGE; } else { - addr_str = getenv("loadaddr"); + addr_str = env_get("loadaddr"); if (addr_str != NULL) addr = simple_strtoul(addr_str, NULL, 16); else @@ -388,7 +388,7 @@ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], if (argc >= 5) { filename = argv[4]; } else { - filename = getenv("bootfile"); + filename = env_get("bootfile"); if (!filename) { puts("** No boot file defined **\n"); return 1; diff --git a/include/_exports.h b/include/_exports.h index 9deed77378..5416041243 100644 --- a/include/_exports.h +++ b/include/_exports.h @@ -31,7 +31,7 @@ EXPORT_FUNC(vprintf, int, vprintf, const char *, va_list) EXPORT_FUNC(do_reset, int, do_reset, cmd_tbl_t *, int , int , char * const []) - EXPORT_FUNC(getenv, char *, getenv, const char*) + EXPORT_FUNC(env_get, char *, env_get, const char*) EXPORT_FUNC(env_set, int, env_set, const char *, const char *) EXPORT_FUNC(simple_strtoul, unsigned long, simple_strtoul, const char *, char **, unsigned int) diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index d8d1b444f2..9238c7988b 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -76,7 +76,7 @@ typedef struct global_data { struct device_node *of_root; #endif struct jt_funcs *jt; /* jump table */ - char env_buf[32]; /* buffer for getenv() before reloc. */ + char env_buf[32]; /* buffer for env_get() before reloc. */ #ifdef CONFIG_TRACE void *trace_buff; /* The trace buffer */ #endif diff --git a/include/common.h b/include/common.h index 57f53f54ed..ea24db68ed 100644 --- a/include/common.h +++ b/include/common.h @@ -310,16 +310,45 @@ int env_init (void); void env_relocate (void); int envmatch (uchar *, int);
-/* Avoid unfortunate conflict with libc's getenv() */ -#ifdef CONFIG_SANDBOX -#define getenv uboot_getenv -#endif -char *getenv (const char *); -int getenv_f (const char *name, char *buf, unsigned len); -ulong getenv_ulong(const char *name, int base, ulong default_val); +/** + * env_get() - Look up the value of an environment variable + * + * In U-Boot proper this can be called before relocation (which is when the + * environment is loaded from storage, i.e. GD_FLG_ENV_READY is 0). In that + * case this function calls env_get_f(). + * + * @varname: Variable to look up + * @return value of variable, or NULL if not found + */ +char *env_get(const char *varname); + +/** + * env_get_f() - Look up the value of an environment variable (early) + * + * This function is called from env_get() if the environment has not been + * loaded yet (GD_FLG_ENV_READY flag is 0). Some environment locations will + * support reading the value (slowly) and some will not. + * + * @varname: Variable to look up + * @return value of variable, or NULL if not found + */ +int env_get_f(const char *name, char *buf, unsigned len); + +/** + * env_get_ulong() - Return an environment variable as an integer value + * + * Most U-Boot environment variables store hex values. For those which store + * (e.g.) base-10 integers, this function can be used to read the value. + * + * @name: Variable to look up + * @base: Base to use (e.g. 10 for base 10, 2 for binary) + * @default_val: Default value to return if no value is found + * @return the value found, or @default_val if none + */ +ulong env_get_ulong(const char *name, int base, ulong default_val);
/** - * getenv_hex() - Return an environment variable as a hex value + * env_get_hex() - Return an environment variable as a hex value * * Decode an environment as a hex number (it may or may not have a 0x * prefix). If the environment variable cannot be found, or does not start @@ -328,13 +357,13 @@ ulong getenv_ulong(const char *name, int base, ulong default_val); * @varname: Variable to decode * @default_val: Value to return on error */ -ulong getenv_hex(const char *varname, ulong default_val); +ulong env_get_hex(const char *varname, ulong default_val);
/* * Read an environment variable as a boolean * Return -1 if variable does not exist (default to true) */ -int getenv_yesno(const char *var); +int env_get_yesno(const char *var);
/** * env_set() - set an environment variable @@ -718,9 +747,9 @@ int zzip(void *dst, unsigned long *lenp, unsigned char *src,
/* lib/net_utils.c */ #include <net.h> -static inline struct in_addr getenv_ip(char *var) +static inline struct in_addr env_get_ip(char *var) { - return string_to_ip(getenv(var)); + return string_to_ip(env_get(var)); }
int pcmcia_init (void); diff --git a/include/environment.h b/include/environment.h index faf4d6adbb..dc1293dfb2 100644 --- a/include/environment.h +++ b/include/environment.h @@ -282,7 +282,7 @@ extern struct hsearch_data env_htab; void env_crc_update(void);
/* Look up the variable from the default environment */ -char *getenv_default(const char *name); +char *env_get_default(const char *name);
/* [re]set to the default environment */ void set_default_env(const char *s); diff --git a/include/exports.h b/include/exports.h index 6522d78fac..ebe81d914c 100644 --- a/include/exports.h +++ b/include/exports.h @@ -27,7 +27,7 @@ unsigned long get_timer(unsigned long); int vprintf(const char *, va_list); unsigned long simple_strtoul(const char *cp, char **endp, unsigned int base); int strict_strtoul(const char *cp, unsigned int base, unsigned long *res); -char *getenv (const char *name); +char *env_get(const char *name); int env_set(const char *varname, const char *value); long simple_strtol(const char *cp, char **endp, unsigned int base); int strcmp(const char *cs, const char *ct); diff --git a/include/image.h b/include/image.h index c6f1513220..1f4bfda2f3 100644 --- a/include/image.h +++ b/include/image.h @@ -373,7 +373,7 @@ typedef struct bootm_headers { bd_t *kbd; #endif
- int verify; /* getenv("verify")[0] != 'n' */ + int verify; /* env_get("verify")[0] != 'n' */
#define BOOTM_STATE_START (0x00000001) #define BOOTM_STATE_FINDOS (0x00000002) @@ -769,9 +769,9 @@ static inline void image_set_name(image_header_t *hdr, const char *name) int image_check_hcrc(const image_header_t *hdr); int image_check_dcrc(const image_header_t *hdr); #ifndef USE_HOSTCC -ulong getenv_bootm_low(void); -phys_size_t getenv_bootm_size(void); -phys_size_t getenv_bootm_mapsize(void); +ulong env_get_bootm_low(void); +phys_size_t env_get_bootm_size(void); +phys_size_t env_get_bootm_mapsize(void); #endif void memmove_wd(void *to, void *from, size_t len, ulong chunksz);
diff --git a/include/net.h b/include/net.h index 65ab7b2c79..2647769cb6 100644 --- a/include/net.h +++ b/include/net.h @@ -239,7 +239,7 @@ void eth_set_current(void); /* set nterface to ethcur var */
int eth_get_dev_index(void); /* get the device index */ void eth_parse_enetaddr(const char *addr, uchar *enetaddr); -int eth_getenv_enetaddr(const char *name, uchar *enetaddr); +int eth_env_get_enetaddr(const char *name, uchar *enetaddr); int eth_env_set_enetaddr(const char *name, const uchar *enetaddr);
/** @@ -275,7 +275,7 @@ int usb_ether_init(void); * Returns: * Return true if the address is valid. */ -int eth_getenv_enetaddr_by_index(const char *base_name, int index, +int eth_env_get_enetaddr_by_index(const char *base_name, int index, uchar *enetaddr);
int eth_init(void); /* Initialize the device */ @@ -834,7 +834,7 @@ void vlan_to_string(ushort x, char *s); ushort string_to_vlan(const char *s);
/* read a VLAN id from an environment variable */ -ushort getenv_vlan(char *); +ushort env_get_vlan(char *);
/* copy a filename (allow for "..." notation, limit length) */ void copy_filename(char *dst, const char *src, int size); diff --git a/lib/fdtdec.c b/lib/fdtdec.c index fbb48bf74d..31b29b1016 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1246,7 +1246,7 @@ int fdtdec_setup(void) # endif # ifndef CONFIG_SPL_BUILD /* Allow the early environment to override the fdt address */ - gd->fdt_blob = (void *)getenv_ulong("fdtcontroladdr", 16, + gd->fdt_blob = (void *)env_get_ulong("fdtcontroladdr", 16, (uintptr_t)gd->fdt_blob); # endif #endif diff --git a/lib/smbios.c b/lib/smbios.c index 22ca247fec..8f19ad89c1 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -112,7 +112,7 @@ static int smbios_write_type1(ulong *current, int handle) { struct smbios_type1 *t = (struct smbios_type1 *)*current; int len = sizeof(struct smbios_type1); - char *serial_str = getenv("serial#"); + char *serial_str = env_get("serial#");
memset(t, 0, sizeof(struct smbios_type1)); fill_smbios_header(t, SMBIOS_SYSTEM_INFORMATION, len, handle); diff --git a/net/bootp.c b/net/bootp.c index 579515687b..73370a13fe 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -414,7 +414,7 @@ static void bootp_timeout_handler(void) static u8 *add_vci(u8 *e) { char *vci = NULL; - char *env_vci = getenv("bootp_vci"); + char *env_vci = env_get("bootp_vci");
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_NET_VCI_STRING) vci = CONFIG_SPL_NET_VCI_STRING; @@ -488,7 +488,7 @@ static int dhcp_extended(u8 *e, int message_type, struct in_addr server_ip, *e++ = tmp & 0xff; } #if defined(CONFIG_BOOTP_SEND_HOSTNAME) - hostname = getenv("hostname"); + hostname = env_get("hostname"); if (hostname) { int hostnamelen = strlen(hostname);
@@ -503,8 +503,8 @@ static int dhcp_extended(u8 *e, int message_type, struct in_addr server_ip, clientarch = CONFIG_BOOTP_PXE_CLIENTARCH; #endif
- if (getenv("bootp_arch")) - clientarch = getenv_ulong("bootp_arch", 16, clientarch); + if (env_get("bootp_arch")) + clientarch = env_get_ulong("bootp_arch", 16, clientarch);
if (clientarch > 0) { *e++ = 93; /* Client System Architecture */ @@ -520,7 +520,7 @@ static int dhcp_extended(u8 *e, int message_type, struct in_addr server_ip, *e++ = 0; /* minor revision */
#ifdef CONFIG_LIB_UUID - uuid = getenv("pxeuuid"); + uuid = env_get("pxeuuid");
if (uuid) { if (uuid_str_valid(uuid)) { @@ -713,7 +713,7 @@ void bootp_request(void) dhcp_state = INIT; #endif
- ep = getenv("bootpretryperiod"); + ep = env_get("bootpretryperiod"); if (ep != NULL) time_taken_max = simple_strtoul(ep, NULL, 10); else diff --git a/net/eth-uclass.c b/net/eth-uclass.c index d356576210..d30b04ba86 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -241,8 +241,8 @@ U_BOOT_ENV_CALLBACK(ethaddr, on_ethaddr);
int eth_init(void) { - char *ethact = getenv("ethact"); - char *ethrotate = getenv("ethrotate"); + char *ethact = env_get("ethact"); + char *ethrotate = env_get("ethrotate"); struct udevice *current = NULL; struct udevice *old_current; int ret = -ENODEV; @@ -401,7 +401,7 @@ int eth_initialize(void) printf("No ethernet found.\n"); bootstage_error(BOOTSTAGE_ID_NET_ETH_START); } else { - char *ethprime = getenv("ethprime"); + char *ethprime = env_get("ethprime"); struct udevice *prime_dev = NULL;
if (ethprime) @@ -495,7 +495,7 @@ static int eth_post_probe(struct udevice *dev) if (eth_get_ops(dev)->read_rom_hwaddr) eth_get_ops(dev)->read_rom_hwaddr(dev);
- eth_getenv_enetaddr_by_index("eth", dev->seq, env_enetaddr); + eth_env_get_enetaddr_by_index("eth", dev->seq, env_enetaddr); if (!is_zero_ethaddr(env_enetaddr)) { if (!is_zero_ethaddr(pdata->enetaddr) && memcmp(pdata->enetaddr, env_enetaddr, ARP_HLEN)) { diff --git a/net/eth_common.c b/net/eth_common.c index 7b36532ee1..66d0d22966 100644 --- a/net/eth_common.c +++ b/net/eth_common.c @@ -24,9 +24,9 @@ void eth_parse_enetaddr(const char *addr, uchar *enetaddr) } }
-int eth_getenv_enetaddr(const char *name, uchar *enetaddr) +int eth_env_get_enetaddr(const char *name, uchar *enetaddr) { - eth_parse_enetaddr(getenv(name), enetaddr); + eth_parse_enetaddr(env_get(name), enetaddr); return is_valid_ethaddr(enetaddr); }
@@ -34,7 +34,7 @@ int eth_env_set_enetaddr(const char *name, const uchar *enetaddr) { char buf[ARP_HLEN_ASCII + 1];
- if (eth_getenv_enetaddr(name, (uchar *)buf)) + if (eth_env_get_enetaddr(name, (uchar *)buf)) return -EEXIST;
sprintf(buf, "%pM", enetaddr); @@ -42,12 +42,12 @@ int eth_env_set_enetaddr(const char *name, const uchar *enetaddr) return env_set(name, buf); }
-int eth_getenv_enetaddr_by_index(const char *base_name, int index, +int eth_env_get_enetaddr_by_index(const char *base_name, int index, uchar *enetaddr) { char enetvar[32]; sprintf(enetvar, index ? "%s%daddr" : "%saddr", base_name, index); - return eth_getenv_enetaddr(enetvar, enetaddr); + return eth_env_get_enetaddr(enetvar, enetaddr); }
int eth_env_set_enetaddr_by_index(const char *base_name, int index, @@ -76,13 +76,13 @@ int eth_mac_skip(int index) char *skip_state;
sprintf(enetvar, index ? "eth%dmacskip" : "ethmacskip", index); - skip_state = getenv(enetvar); + skip_state = env_get(enetvar); return skip_state != NULL; }
void eth_current_changed(void) { - char *act = getenv("ethact"); + char *act = env_get("ethact"); char *ethrotate;
/* @@ -90,7 +90,7 @@ void eth_current_changed(void) * ethernet device if uc_priv->current == NULL. This is not what * we want when 'ethrotate' variable is 'no'. */ - ethrotate = getenv("ethrotate"); + ethrotate = env_get("ethrotate"); if ((ethrotate != NULL) && (strcmp(ethrotate, "no") == 0)) return;
@@ -116,7 +116,7 @@ void eth_try_another(int first_restart) * Do not rotate between network interfaces when * 'ethrotate' variable is set to 'no'. */ - ethrotate = getenv("ethrotate"); + ethrotate = env_get("ethrotate"); if ((ethrotate != NULL) && (strcmp(ethrotate, "no") == 0)) return;
@@ -142,12 +142,12 @@ void eth_set_current(void)
env_id = get_env_id(); if ((act == NULL) || (env_changed_id != env_id)) { - act = getenv("ethact"); + act = env_get("ethact"); env_changed_id = env_id; }
if (act == NULL) { - char *ethprime = getenv("ethprime"); + char *ethprime = env_get("ethprime"); void *dev = NULL;
if (ethprime) diff --git a/net/eth_legacy.c b/net/eth_legacy.c index 2608302648..be0cf64a3d 100644 --- a/net/eth_legacy.c +++ b/net/eth_legacy.c @@ -137,7 +137,7 @@ int eth_write_hwaddr(struct eth_device *dev, const char *base_name, unsigned char env_enetaddr[ARP_HLEN]; int ret = 0;
- eth_getenv_enetaddr_by_index(base_name, eth_number, env_enetaddr); + eth_env_get_enetaddr_by_index(base_name, eth_number, env_enetaddr);
if (!is_zero_ethaddr(env_enetaddr)) { if (!is_zero_ethaddr(dev->enetaddr) && @@ -261,7 +261,7 @@ int eth_initialize(void) bootstage_error(BOOTSTAGE_ID_NET_ETH_START); } else { struct eth_device *dev = eth_devices; - char *ethprime = getenv("ethprime"); + char *ethprime = env_get("ethprime");
bootstage_mark(BOOTSTAGE_ID_NET_ETH_INIT); do { diff --git a/net/link_local.c b/net/link_local.c index dfd240dfbc..31cdef4083 100644 --- a/net/link_local.c +++ b/net/link_local.c @@ -104,7 +104,7 @@ static void configure_wait(void)
void link_local_start(void) { - ip = getenv_ip("llipaddr"); + ip = env_get_ip("llipaddr"); if (ip.s_addr != 0 && (ntohl(ip.s_addr) & IN_CLASSB_NET) != LINKLOCAL_ADDR) { puts("invalid link address"); diff --git a/net/net.c b/net/net.c index 2fed28092d..ebadd679c8 100644 --- a/net/net.c +++ b/net/net.c @@ -319,7 +319,7 @@ U_BOOT_ENV_CALLBACK(dnsip, on_dnsip); void net_auto_load(void) { #if defined(CONFIG_CMD_NFS) - const char *s = getenv("autoload"); + const char *s = env_get("autoload");
if (s != NULL && strcmp(s, "NFS") == 0) { /* @@ -329,7 +329,7 @@ void net_auto_load(void) return; } #endif - if (getenv_yesno("autoload") == 0) { + if (env_get_yesno("autoload") == 0) { /* * Just use BOOTP/RARP to configure system; * Do not use TFTP to load the bootfile. @@ -668,7 +668,7 @@ int net_start_again(void) unsigned long retrycnt = 0; int ret;
- nretry = getenv("netretry"); + nretry = env_get("netretry"); if (nretry) { if (!strcmp(nretry, "yes")) retry_forever = 1; @@ -1536,7 +1536,7 @@ ushort string_to_vlan(const char *s) return htons(id); }
-ushort getenv_vlan(char *var) +ushort env_get_vlan(char *var) { - return string_to_vlan(getenv(var)); + return string_to_vlan(env_get(var)); } diff --git a/net/net_rand.h b/net/net_rand.h index ba9d0642cf..4b31227cee 100644 --- a/net/net_rand.h +++ b/net/net_rand.h @@ -20,7 +20,7 @@ static inline unsigned int seed_mac(void) unsigned int seed;
/* get our mac */ - eth_getenv_enetaddr("ethaddr", enetaddr); + eth_env_get_enetaddr("ethaddr", enetaddr);
seed = enetaddr[5]; seed ^= enetaddr[4] << 8; diff --git a/net/tftp.c b/net/tftp.c index ced45ec1f1..f498263376 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -706,11 +706,11 @@ void tftp_start(enum proto_t protocol) * TFTP protocol has a minimal timeout of 1 second. */
- ep = getenv("tftpblocksize"); + ep = env_get("tftpblocksize"); if (ep != NULL) tftp_block_size_option = simple_strtol(ep, NULL, 10);
- ep = getenv("tftptimeout"); + ep = env_get("tftptimeout"); if (ep != NULL) timeout_ms = simple_strtol(ep, NULL, 10);
@@ -720,7 +720,7 @@ void tftp_start(enum proto_t protocol) timeout_ms = 1000; }
- ep = getenv("tftptimeoutcountmax"); + ep = env_get("tftptimeoutcountmax"); if (ep != NULL) tftp_timeout_count_max = simple_strtol(ep, NULL, 10);
@@ -822,10 +822,10 @@ void tftp_start(enum proto_t protocol) tftp_our_port = 1024 + (get_timer(0) % 3072);
#ifdef CONFIG_TFTP_PORT - ep = getenv("tftpdstp"); + ep = env_get("tftpdstp"); if (ep != NULL) tftp_remote_port = simple_strtol(ep, NULL, 10); - ep = getenv("tftpsrcp"); + ep = env_get("tftpsrcp"); if (ep != NULL) tftp_our_port = simple_strtol(ep, NULL, 10); #endif diff --git a/post/post.c b/post/post.c index 8c2c822acb..8fef0c3412 100644 --- a/post/post.c +++ b/post/post.c @@ -180,7 +180,7 @@ static void post_get_env_flags(int *test_flags) int i, j;
for (i = 0; i < varnum; i++) { - if (getenv_f(var[i], list, sizeof(list)) <= 0) + if (env_get_f(var[i], list, sizeof(list)) <= 0) continue;
for (j = 0; j < post_list_size; j++) diff --git a/test/command_ut.c b/test/command_ut.c index 21283eb357..f76d52569d 100644 --- a/test/command_ut.c +++ b/test/command_ut.c @@ -19,16 +19,16 @@ static int do_ut_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* commands separated by \n */ run_command_list("setenv list 1\n setenv list ${list}1", -1, 0); - assert(!strcmp("11", getenv("list"))); + assert(!strcmp("11", env_get("list")));
/* command followed by \n and nothing else */ run_command_list("setenv list 1${list}\n", -1, 0); - assert(!strcmp("111", getenv("list"))); + assert(!strcmp("111", env_get("list")));
/* a command string with \0 in it. Stuff after \0 should be ignored */ run_command("setenv list", 0); run_command_list(test_cmd, sizeof(test_cmd), 0); - assert(!strcmp("123", getenv("list"))); + assert(!strcmp("123", env_get("list")));
/* * a command list where we limit execution to only the first command @@ -36,7 +36,7 @@ static int do_ut_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) */ run_command_list("setenv list 1\n setenv list ${list}2; " "setenv list ${list}3", strlen("setenv list 1"), 0); - assert(!strcmp("1", getenv("list"))); + assert(!strcmp("1", env_get("list")));
assert(run_command("false", 0) == 1); assert(run_command("echo", 0) == 0); @@ -46,10 +46,10 @@ static int do_ut_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_HUSH_PARSER run_command("setenv foo 'setenv black 1\nsetenv adder 2'", 0); run_command("run foo", 0); - assert(getenv("black") != NULL); - assert(!strcmp("1", getenv("black"))); - assert(getenv("adder") != NULL); - assert(!strcmp("2", getenv("adder"))); + assert(env_get("black") != NULL); + assert(!strcmp("1", env_get("black"))); + assert(env_get("adder") != NULL); + assert(!strcmp("2", env_get("adder"))); #endif
assert(run_command("", 0) == 0); diff --git a/test/dm/eth.c b/test/dm/eth.c index f824d704c6..122fab924d 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -28,15 +28,15 @@ static int dm_test_eth(struct unit_test_state *uts)
env_set("ethact", "eth@10002000"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10002000", getenv("ethact")); + ut_asserteq_str("eth@10002000", env_get("ethact"));
env_set("ethact", "eth@10003000"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10003000", getenv("ethact")); + ut_asserteq_str("eth@10003000", env_get("ethact"));
env_set("ethact", "eth@10004000"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10004000", getenv("ethact")); + ut_asserteq_str("eth@10004000", env_get("ethact"));
return 0; } @@ -47,20 +47,20 @@ static int dm_test_eth_alias(struct unit_test_state *uts) net_ping_ip = string_to_ip("1.1.2.2"); env_set("ethact", "eth0"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10002000", getenv("ethact")); + ut_asserteq_str("eth@10002000", env_get("ethact"));
env_set("ethact", "eth1"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10004000", getenv("ethact")); + ut_asserteq_str("eth@10004000", env_get("ethact"));
/* Expected to fail since eth2 is not defined in the device tree */ env_set("ethact", "eth2"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10002000", getenv("ethact")); + ut_asserteq_str("eth@10002000", env_get("ethact"));
env_set("ethact", "eth5"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10003000", getenv("ethact")); + ut_asserteq_str("eth@10003000", env_get("ethact"));
return 0; } @@ -74,13 +74,13 @@ static int dm_test_eth_prime(struct unit_test_state *uts) env_set("ethact", NULL); env_set("ethprime", "eth5"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10003000", getenv("ethact")); + ut_asserteq_str("eth@10003000", env_get("ethact"));
/* Expected to be "eth@10002000" because it is first */ env_set("ethact", NULL); env_set("ethprime", NULL); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10002000", getenv("ethact")); + ut_asserteq_str("eth@10002000", env_get("ethact"));
return 0; } @@ -119,7 +119,7 @@ static int dm_test_eth_act(struct unit_test_state *uts) ut_assertok(device_remove(dev[i], DM_REMOVE_NORMAL));
/* Invalidate MAC address */ - strcpy(ethaddr[i], getenv(addrname[i])); + strcpy(ethaddr[i], env_get(addrname[i])); /* Must disable access protection for ethaddr before clearing */ env_set(".flags", addrname[i]); env_set(addrname[i], NULL); @@ -152,13 +152,13 @@ static int _dm_test_eth_rotate1(struct unit_test_state *uts) /* Make sure that the default is to rotate to the next interface */ env_set("ethact", "eth@10004000"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10002000", getenv("ethact")); + ut_asserteq_str("eth@10002000", env_get("ethact"));
/* If ethrotate is no, then we should fail on a bad MAC */ env_set("ethact", "eth@10004000"); env_set("ethrotate", "no"); ut_asserteq(-EINVAL, net_loop(PING)); - ut_asserteq_str("eth@10004000", getenv("ethact")); + ut_asserteq_str("eth@10004000", env_get("ethact"));
return 0; } @@ -168,12 +168,12 @@ static int _dm_test_eth_rotate2(struct unit_test_state *uts) /* Make sure we can skip invalid devices */ env_set("ethact", "eth@10004000"); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10004000", getenv("ethact")); + ut_asserteq_str("eth@10004000", env_get("ethact"));
/* Make sure we can handle device name which is not eth# */ env_set("ethact", "sbe5"); ut_assertok(net_loop(PING)); - ut_asserteq_str("sbe5", getenv("ethact")); + ut_asserteq_str("sbe5", env_get("ethact"));
return 0; } @@ -187,7 +187,7 @@ static int dm_test_eth_rotate(struct unit_test_state *uts) net_ping_ip = string_to_ip("1.1.2.2");
/* Invalidate eth1's MAC address */ - strcpy(ethaddr, getenv("eth1addr")); + strcpy(ethaddr, env_get("eth1addr")); /* Must disable access protection for eth1addr before clearing */ env_set(".flags", "eth1addr"); env_set("eth1addr", NULL); @@ -200,7 +200,7 @@ static int dm_test_eth_rotate(struct unit_test_state *uts)
if (!retval) { /* Invalidate eth0's MAC address */ - strcpy(ethaddr, getenv("ethaddr")); + strcpy(ethaddr, env_get("ethaddr")); /* Must disable access protection for ethaddr before clearing */ env_set(".flags", "ethaddr"); env_set("ethaddr", NULL); @@ -229,7 +229,7 @@ static int _dm_test_net_retry(struct unit_test_state *uts) env_set("netretry", "yes"); sandbox_eth_skip_timeout(); ut_assertok(net_loop(PING)); - ut_asserteq_str("eth@10002000", getenv("ethact")); + ut_asserteq_str("eth@10002000", env_get("ethact"));
/* * eth1 is disabled and netretry is no, so the ping should fail and the @@ -239,7 +239,7 @@ static int _dm_test_net_retry(struct unit_test_state *uts) env_set("netretry", "no"); sandbox_eth_skip_timeout(); ut_asserteq(-ETIMEDOUT, net_loop(PING)); - ut_asserteq_str("eth@10004000", getenv("ethact")); + ut_asserteq_str("eth@10004000", env_get("ethact"));
return 0; } diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 2861656183..3e20481921 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -286,7 +286,7 @@ int fw_printenv(int argc, char *argv[], int value_only, struct env_opts *opts) char *name = argv[i]; char *val = NULL;
- val = fw_getenv(name); + val = fw_env_get(name); if (!val) { fprintf (stderr, "## Error: "%s" not defined\n", name); rc = -1; diff --git a/tools/env/fw_env.h b/tools/env/fw_env.h index 04bb64602b..8ee7d546e3 100644 --- a/tools/env/fw_env.h +++ b/tools/env/fw_env.h @@ -112,13 +112,13 @@ int fw_parse_script(char *fname, struct env_opts *opts); int fw_env_open(struct env_opts *opts);
/** - * fw_getenv() - lookup variable in the RAM cache + * fw_env_get() - lookup variable in the RAM cache * * @name: variable to be searched * Return: * pointer to start of value, NULL if not found */ -char *fw_getenv(char *name); +char *fw_env_get(char *name);
/** * fw_env_write() - modify a variable held in the RAM cache
On Sun, Jul 23, 2017 at 09:20:07PM -0600, Simon Glass wrote:
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h.
Suggested-by: Wolfgang Denk wd@denx.de Signed-off-by: Simon Glass sjg@chromium.org
And same question / request as the setenv one here.
In principle this can fail, e.g. if the index is out of range. Adjust the driver signature to allow returning an error code.
Changes in v2: None
env/dataflash.c | 2 +- env/eeprom.c | 2 +- env/nvram.c | 2 +- include/environment.h | 4 ++-- 4 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/env/dataflash.c b/env/dataflash.c index 28dcf6fa1c..afa08f8fd5 100644 --- a/env/dataflash.c +++ b/env/dataflash.c @@ -14,7 +14,7 @@
DECLARE_GLOBAL_DATA_PTR;
-static unsigned char env_dataflash_get_char(int index) +static int env_dataflash_get_char(int index) { uchar c;
diff --git a/env/eeprom.c b/env/eeprom.c index 39adccabbe..fbe4fd4efc 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -61,7 +61,7 @@ static int eeprom_bus_write(unsigned dev_addr, unsigned offset, return rcode; }
-static uchar env_eeprom_get_char(int index) +static int env_eeprom_get_char(int index) { uchar c; unsigned int off = CONFIG_ENV_OFFSET; diff --git a/env/nvram.c b/env/nvram.c index ac389ace62..85af37d4a0 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -41,7 +41,7 @@ env_t *env_ptr = (env_t *)CONFIG_ENV_ADDR; #endif
#ifdef CONFIG_SYS_NVRAM_ACCESS_ROUTINE -static uchar env_nvram_get_char(int index) +static int env_nvram_get_char(int index) { uchar c;
diff --git a/include/environment.h b/include/environment.h index dc1293dfb2..bfb6fbc22d 100644 --- a/include/environment.h +++ b/include/environment.h @@ -227,9 +227,9 @@ struct env_driver { * will read from gd->env_addr. * * @index: Index of character to read (0=first) - * @return character read + * @return character read, or -ve on error */ - unsigned char (*get_char)(int index); + int (*get_char)(int index);
/** * load() - Load the environment from storage
The load() methods have inconsistent behaviour on error. Some of them load an empty default environment. Some load an environment containing an error message. Others do nothing.
As a step in the right direction, have the method return an error code. Then the caller could handle this itself in a consistent way.
Changes in v2: - Rebase to master
env/dataflash.c | 4 +++- env/eeprom.c | 4 +++- env/ext4.c | 6 ++++-- env/fat.c | 6 ++++-- env/flash.c | 4 +++- env/mmc.c | 19 +++++++++++-------- env/nand.c | 18 +++++++++++++----- env/nvram.c | 4 +++- env/onenand.c | 4 +++- env/remote.c | 4 +++- env/sata.c | 15 +++++++++------ env/sf.c | 20 +++++++++++++------- env/ubi.c | 16 ++++++++++------ include/environment.h | 4 +++- 14 files changed, 85 insertions(+), 43 deletions(-)
diff --git a/env/dataflash.c b/env/dataflash.c index afa08f8fd5..77bc595e0d 100644 --- a/env/dataflash.c +++ b/env/dataflash.c @@ -23,7 +23,7 @@ static int env_dataflash_get_char(int index) return c; }
-static void env_dataflash_load(void) +static int env_dataflash_load(void) { ulong crc, new = 0; unsigned off; @@ -44,6 +44,8 @@ static void env_dataflash_load(void) env_import(buf, 1); else set_default_env("!bad CRC"); + + return 0; }
#ifdef CONFIG_ENV_OFFSET_REDUND diff --git a/env/eeprom.c b/env/eeprom.c index fbe4fd4efc..08ef6307fc 100644 --- a/env/eeprom.c +++ b/env/eeprom.c @@ -76,7 +76,7 @@ static int env_eeprom_get_char(int index) return c; }
-static void env_eeprom_load(void) +static int env_eeprom_load(void) { char buf_env[CONFIG_ENV_SIZE]; unsigned int off = CONFIG_ENV_OFFSET; @@ -182,6 +182,8 @@ static void env_eeprom_load(void) off, (uchar *)buf_env, CONFIG_ENV_SIZE);
env_import(buf_env, 1); + + return 0; }
static int env_eeprom_save(void) diff --git a/env/ext4.c b/env/ext4.c index ee073a8b7c..65202213d3 100644 --- a/env/ext4.c +++ b/env/ext4.c @@ -75,7 +75,7 @@ static int env_ext4_save(void) } #endif /* CONFIG_CMD_SAVEENV */
-static void env_ext4_load(void) +static int env_ext4_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); struct blk_desc *dev_desc = NULL; @@ -109,10 +109,12 @@ static void env_ext4_load(void) }
env_import(buf, 1); - return; + return 0;
err_env_relocate: set_default_env(NULL); + + return -EIO; }
U_BOOT_ENV_LOCATION(ext4) = { diff --git a/env/fat.c b/env/fat.c index 69319f8834..83d4ba1340 100644 --- a/env/fat.c +++ b/env/fat.c @@ -74,7 +74,7 @@ static int env_fat_save(void) #endif /* CMD_SAVEENV */
#ifdef LOADENV -static void env_fat_load(void) +static int env_fat_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); struct blk_desc *dev_desc = NULL; @@ -103,10 +103,12 @@ static void env_fat_load(void) }
err_env_relocate: set_default_env(NULL); + + return -EIO; } #endif /* LOADENV */
diff --git a/env/flash.c b/env/flash.c index 2d72c51622..b60be57a8d 100644 --- a/env/flash.c +++ b/env/flash.c @@ -308,7 +308,7 @@ done: #endif /* CONFIG_ENV_ADDR_REDUND */
#ifdef LOADENV -static void env_flash_load(void) +static int env_flash_load(void) { #ifdef CONFIG_ENV_ADDR_REDUND if (gd->env_addr != (ulong)&(flash_addr->data)) { @@ -352,6 +352,8 @@ static void env_flash_load(void) #endif /* CONFIG_ENV_ADDR_REDUND */
env_import((char *)flash_addr, 1); + + return 0; } #endif /* LOADENV */
diff --git a/env/mmc.c b/env/mmc.c index cf85bc232f..c7746492af 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -213,7 +213,7 @@ static inline int read_env(struct mmc *mmc, unsigned long size, }
#ifdef CONFIG_ENV_OFFSET_REDUND -static void env_mmc_load(void) +static int env_mmc_load(void) { #if !defined(ENV_IS_EMBEDDED) struct mmc *mmc; @@ -232,13 +232,13 @@ static void env_mmc_load(void)
errmsg = init_mmc_for_env(mmc); if (errmsg) { - ret = 1; + ret = -EIO; goto err; }
if (mmc_get_env_addr(mmc, 0, &offset1) || mmc_get_env_addr(mmc, 1, &offset2)) { - ret = 1; + ret = -EIO; goto fini; }
@@ -258,7 +258,7 @@ static void env_mmc_load(void)
if (!crc1_ok && !crc2_ok) { errmsg = "!bad CRC"; - ret = 1; + ret = -EIO; goto fini; } else if (crc1_ok && !crc2_ok) { gd->env_valid = ENV_VALID; @@ -292,10 +292,12 @@ fini: err: if (ret) set_default_env(errmsg); + #endif + return ret; } #else /* ! CONFIG_ENV_OFFSET_REDUND */ -static void env_mmc_load(void) +static int env_mmc_load(void) { #if !defined(ENV_IS_EMBEDDED) ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE); @@ -309,18 +311,18 @@ static void env_mmc_load(void)
if (mmc_get_env_addr(mmc, 0, &offset)) { - ret = 1; + ret = -EIO; goto fini; }
if (read_env(mmc, CONFIG_ENV_SIZE, offset, buf)) { errmsg = "!read failed"; - ret = 1; + ret = -EIO; goto fini; }
@@ -333,6 +335,7 @@ err: if (ret) set_default_env(errmsg); #endif + return ret; } #endif /* CONFIG_ENV_OFFSET_REDUND */
diff --git a/env/nand.c b/env/nand.c index e0368bf8de..c0d9ae66a1 100644 --- a/env/nand.c +++ b/env/nand.c @@ -307,7 +307,7 @@ int get_nand_env_oob(struct mtd_info *mtd, unsigned long *result) }
if (oob_buf[0] == ENV_OOB_MARKER) { - *result = oob_buf[1] * mtd->erasesize; + *result = ovoid ob_buf[1] * mtd->erasesize; } else if (oob_buf[0] == ENV_OOB_MARKER_OLD) { *result = oob_buf[1]; } else { @@ -320,18 +320,22 @@ int get_nand_env_oob(struct mtd_info *mtd, unsigned long *result) #endif
#ifdef CONFIG_ENV_OFFSET_REDUND -static void env_nand_load(void) +static int env_nand_load(void) { -#if !defined(ENV_IS_EMBEDDED) +#if defined(ENV_IS_EMBEDDED) + return 0; +#else int read1_fail = 0, read2_fail = 0; int crc1_ok = 0, crc2_ok = 0; env_t *ep, *tmp_env1, *tmp_env2; + int ret = 0;
tmp_env1 = (env_t *)malloc(CONFIG_ENV_SIZE); tmp_env2 = (env_t *)malloc(CONFIG_ENV_SIZE); if (tmp_env1 == NULL || tmp_env2 == NULL) { puts("Can't allocate buffers for environment\n"); set_default_env("!malloc() failed"); + ret = -EIO; goto done; }
@@ -351,6 +355,7 @@ static void env_nand_load(void)
if (!crc1_ok && !crc2_ok) { set_default_env("!bad CRC"); + ret = -EIO; goto done; } else if (crc1_ok && !crc2_ok) { gd->env_valid = ENV_VALID; @@ -382,6 +387,7 @@ done: free(tmp_env1); free(tmp_env2);
+ return ret; #endif /* ! ENV_IS_EMBEDDED */ } #else /* ! CONFIG_ENV_OFFSET_REDUND */ @@ -390,7 +396,7 @@ done: * device i.e., nand_dev_desc + 0. This is also the behaviour using * the new NAND code. */ -static void env_nand_load(void) +static int env_nand_load(void) { #if !defined(ENV_IS_EMBEDDED) int ret; @@ -413,11 +419,13 @@ static void env_nand_load(void) ret = readenv(CONFIG_ENV_OFFSET, (u_char *)buf); if (ret) { set_default_env("!readenv() failed"); - return; + return -EIO; }
env_import(buf, 1); #endif /* ! ENV_IS_EMBEDDED */ + + return 0; } #endif /* CONFIG_ENV_OFFSET_REDUND */
diff --git a/env/nvram.c b/env/nvram.c index 85af37d4a0..5fb3115ce6 100644 --- a/env/nvram.c +++ b/env/nvram.c @@ -51,7 +51,7 @@ static int env_nvram_get_char(int index) } #endif
-static void env_nvram_load(void) +static int env_nvram_load(void) { char buf[CONFIG_ENV_SIZE];
@@ -61,6 +61,8 @@ static void env_nvram_load(void) memcpy(buf, (void *)CONFIG_ENV_ADDR, CONFIG_ENV_SIZE); #endif env_import(buf, 1); + + return 0; }
static int env_nvram_save(void) diff --git a/env/onenand.c b/env/onenand.c index 319f553262..2e3045c5f5 100644 --- a/env/onenand.c +++ b/env/onenand.c @@ -26,7 +26,7 @@
-static void env_onenand_load(void) +static int env_onenand_load(void) { struct mtd_info *mtd = &onenand_mtd; #ifdef CONFIG_ENV_ADDR_FLEX @@ -59,6 +59,8 @@ static void env_onenand_load(void) rc = env_import(buf, 1); if (rc) gd->env_valid = ENV_VALID; + + return rc ? 0 : -EIO; }
static int env_onenand_save(void) diff --git a/env/remote.c b/env/remote.c index 0d8865bd67..c013fdd4b0 100644 --- a/env/remote.c +++ b/env/remote.c @@ -46,11 +46,13 @@ static int env_remote_save(void) } #endif /* CONFIG_CMD_SAVEENV */
-static void env_remote_load(void) +static int env_remote_load(void) { #ifndef ENV_IS_EMBEDDED env_import((char *)env_ptr, 1); #endif + + return 0; }
U_BOOT_ENV_LOCATION(remote) = { diff --git a/env/sata.c b/env/sata.c index 16d8f939db..a77029774e 100644 --- a/env/sata.c +++ b/env/sata.c @@ -98,21 +98,24 @@ static void env_sata_load(void) int env_sata;
if (sata_initialize()) - return; + return -EIO;
env_sata = sata_get_env_dev();
sata = sata_get_dev(env_sata); if (sata == NULL) { - printf("Unknown SATA(%d) device for environment!\n", - env_sata); - return; + printf("Unknown SATA(%d) device for environment!\n", env_sata); + return -EIO; }
- if (read_env(sata, CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, buf)) - return set_default_env(NULL); + if (read_env(sata, CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, buf)) { + set_default_env(NULL); + return -EIO; + }
U_BOOT_ENV_LOCATION(sata) = { diff --git a/env/sf.c b/env/sf.c index 07386c629a..6f74371c09 100644 --- a/env/sf.c +++ b/env/sf.c @@ -61,7 +61,7 @@ static int setup_flash_device(void) 0, 0, &new); if (ret) { set_default_env("!spi_flash_probe_bus_cs() failed"); - return 1; + return ret; }
env_flash = dev_get_uclass_priv(new); @@ -73,7 +73,7 @@ static int setup_flash_device(void) CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); if (!env_flash) { set_default_env("!spi_flash_probe() failed"); - return 1; + return -EIO; } } #endif @@ -95,7 +95,7 @@ static int env_sf_save(void)
ret = env_export(&env_new); if (ret) - return ret; + return -EIO; env_new.flags = ACTIVE_FLAG;
if (gd->env_valid == ENV_VALID) { @@ -112,7 +112,7 @@ static int env_sf_save(void) saved_offset = env_new_offset + CONFIG_ENV_SIZE; saved_buffer = memalign(ARCH_DMA_MINALIGN, saved_size); if (!saved_buffer) { - ret = 1; + ret = -ENOMEM; goto done; } ret = spi_flash_read(env_flash, saved_offset, @@ -162,7 +162,7 @@ static int env_sf_save(void) } #endif /* CMD_SAVEENV */
-static void env_sf_load(void) +static int env_sf_load(void) { int ret; int crc1_ok = 0, crc2_ok = 0; @@ -176,6 +176,7 @@ static void env_sf_load(void) CONFIG_ENV_SIZE); if (!tmp_env1 || !tmp_env2) { set_default_env("!malloc() failed"); + ret = -EIO; goto out; }
@@ -202,6 +203,7 @@ static void env_sf_load(void)
if (!crc1_ok && !crc2_ok) { set_default_env("!bad CRC"); + ret = -EIO; goto err_read; } else if (crc1_ok && !crc2_ok) { gd->env_valid = ENV_VALID; @@ -244,6 +246,8 @@ err_read: out: free(tmp_env1); free(tmp_env2); + + return ret; } #else #ifdef CMD_SAVEENV @@ -308,7 +312,7 @@ static int env_sf_save(void) } #endif /* CMD_SAVEENV */
-static void env_sf_load(void) +static int env_sf_load(void) { int ret; char *buf = NULL; @@ -316,7 +320,7 @@ static void env_sf_load(void) buf = (char *)memalign(ARCH_DMA_MINALIGN, CONFIG_ENV_SIZE); if (!buf) { set_default_env("!malloc() failed"); - return; + return -EIO; }
ret = setup_flash_device(); @@ -339,6 +343,8 @@ err_read: env_flash = NULL; out: free(buf); + + return ret; } #endif
diff --git a/env/ubi.c b/env/ubi.c index 65be2b1bbf..6ac86c8571 100644 --- a/env/ubi.c +++ b/env/ubi.c @@ -95,7 +95,7 @@ static int env_ubi_save(void) #endif /* CONFIG_CMD_SAVEENV */
#ifdef CONFIG_SYS_REDUNDAND_ENVIRONMENT -static void env_ubi_load(void) +static int env_ubi_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, env1_buf, CONFIG_ENV_SIZE); ALLOC_CACHE_ALIGN_BUFFER(char, env2_buf, CONFIG_ENV_SIZE); @@ -120,7 +120,7 @@ static void env_ubi_load(void) printf("\n** Cannot find mtd partition "%s"\n", CONFIG_ENV_UBI_PART); set_default_env(NULL); - return; + return -EIO; }
if (ubi_volume_read(CONFIG_ENV_UBI_VOLUME, (void *)tmp_env1, @@ -140,7 +140,7 @@ static void env_ubi_load(void)
if (!crc1_ok && !crc2_ok) { set_default_env("!bad CRC"); - return; + return -EIO; } else if (crc1_ok && !crc2_ok) { gd->env_valid = ENV_VALID; } else if (!crc1_ok && crc2_ok) { @@ -166,9 +166,11 @@ static void env_ubi_load(void)
env_flags = ep->flags; env_import((char *)ep, 0); + + return 0; } #else /* ! CONFIG_SYS_REDUNDAND_ENVIRONMENT */ -static void env_ubi_load(void) +static int env_ubi_load(void) { ALLOC_CACHE_ALIGN_BUFFER(char, buf, CONFIG_ENV_SIZE);
@@ -186,17 +188,19 @@ static void env_ubi_load(void) printf("\n** Cannot find mtd partition "%s"\n", CONFIG_ENV_UBI_PART); set_default_env(NULL); - return; + return -EIO; }
if (ubi_volume_read(CONFIG_ENV_UBI_VOLUME, buf, CONFIG_ENV_SIZE)) { printf("\n** Unable to read env from %s:%s **\n", CONFIG_ENV_UBI_PART, CONFIG_ENV_UBI_VOLUME); set_default_env(NULL); - return; + return -EIO; }
env_import(buf, 1); + + return 0; } #endif /* CONFIG_SYS_REDUNDAND_ENVIRONMENT */
diff --git a/include/environment.h b/include/environment.h index bfb6fbc22d..c4453024fe 100644 --- a/include/environment.h +++ b/include/environment.h @@ -236,8 +236,10 @@ struct env_driver { * * This method is optional. If not provided, no environment will be * loaded. + * + * @return 0 if OK, -ve on error */ - void (*load)(void); + int (*load)(void);
/** * save() - Save the environment to storage
On Sun, Jul 23, 2017 at 09:19:35PM -0600, Simon Glass wrote:
The environment code is ripe for improvement in various ways. It has lots of duplication and inconsistencies between how things work with different environment locations. It does not properly use Kconfig. Error checking and handling is patchy.
This series makes a start at improving things:
- moves the rest of the CONFIG_ENV_IS_IN_... options to Kconfig
I would like to see just this part first, by itself, so we can be sure it's right. I took a quick stab at trying this, and here's a few things: - The freescale SECURE_BOOT boards aren't right. board/freescale/common/Kconfig must have it select ENV_IS_NOWHERE and the other options must depend on !CHAIN_OF_TRUST. - Patch 3 seem to, due to moving things slightly, cause tiny size changes. On balance, this is fine. But in terms of "did Kconfig migration happen correctly" it is not, since it makes it easier for something to slip past.
So, I'm going to grab and update the migration portions of this series and have them as a zero size (aside from boards with CMD_CONFIG on) change, hopefully shortly. And then we can still take in the rest of this series, after comments, this release. Sound good? Thanks!
Hi Tom,
I was unable to make this series avoid effective CONFIG changes as in some cases the environment is in one place in SPL (e.g. ENV_IS_NOWHERE) and another in U-Boot proper. I assumed that this was just going to have to be resolved by maintainers if it is a problem.
Anyway please do whatever you wish and I can rebase the other patches afterwards. We have time for people to chime in and adjust things later.
On Tue, Jul 25, 2017 at 03:40:42PM -0600, Simon Glass wrote:
Hi Tom,
OK, thanks! My first pass at size changes is looking good, I think the *_SECURE_* things might have been what tripped up on the SPL-vs-not as the code was messy to lead to ENV_IS_NOWHERE being in both. This is actually going quicker than I thought it might, and I should push the Kconfig part in today or tomorrow.
Hi Simon,
2017-07-24 12:19 GMT+09:00 Simon Glass sjg@chromium.org:
- introduces the concept of a location driver for the environment
- drops some of the duplicated code
- improves error handling a little (more to be done here)
- moves code into a new env/ directory
There is still much more to do:
- complete Kconfig conversion (e.g. CONFIG_ENV_SIZE)
- unify environment settings so that all locations support the same options
- try to rationalise the redundancy code (can we create a common implementation used by all drivers?)
- allow environment in multiple locations (e.g. as a fallback)
I noticed CONFIG_ENV_IS_IN_* options have been moved to Kconfig.
In Kconfig, users are allowed to enable as many options as they like.
[ ] Environment in dataflash [*] Environment in EEPROM [*] Environment is in a FAT filesystem [*] Environment in flash memory [*] Environment in an MMC device [*] Environment in a NAND device [*] Environment in a non-volatile RAM [*] Environment is in OneNAND [*] Environment is in remove memory space [*] Environment is in SPI flash [*] Environment in a UBI volume [*] Environment is not stored
Enabling multiple locations will cause build error for now.
I assume you intentionally did not use "choice" because you mentioned "allow environment in multiple locations" as your future plan.
Is this right?
This maybe already in your mind.
I'd like to decide environment source run-time.
For boot image location, we provide board_boot_order() hook to change the spl_boot_list.
I though we could provide a similar way to decide the search order of environments. I do not have enough time these days, but it is good if you are taking care of it.
Thanks for you work!
Hi Masahiro,
On 25 July 2017 at 22:51, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Hi Simon,
What is the error?
Is this right?
Yes that's right. Also it does not seem possible to migrate with moveconfig with a choice.
Yes it would be nice. I think this is enough for this release, but hopefully next one.
-- Best Regards Masahiro Yamada
Masahiro Yamada
