[PATCH v9 0/1] PE/COFF measurement support
This patch series add the PE/COFF measurement support. Extending PCR and Event Log is tested with fTPM running as a OP-TEE TA. Unit test will be added in the separate series.
Originally, this patch series have three patches. Two out of three patches are already merged, so this series only contain one remaining commit from v9.
Masahisa Kojima (1): efi_loader: add PE/COFF image measurement
include/efi_loader.h | 6 + include/efi_tcg2.h | 9 ++ include/tpm-v2.h | 18 +++ lib/efi_loader/Kconfig | 1 + lib/efi_loader/efi_image_loader.c | 62 ++++++--- lib/efi_loader/efi_tcg2.c | 207 ++++++++++++++++++++++++++++-- 6 files changed, 277 insertions(+), 26 deletions(-)
"TCG PC Client Platform Firmware Profile Specification" requires to measure every attempt to load and execute a OS Loader(a UEFI application) into PCR[4]. This commit adds the PE/COFF image measurement, extends PCR, and appends measurement into Event Log.
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org Tested-by: Ilias Apalodimas ilias.apalodimas@linaro.org Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org ---
Changes in v9: - use original return code from __get_active_pcr_banks() - return EFI_UNSUPPORTED instead of EFI_INVALID_PARAMETER if efi_image_parse() fails, it complies with TCG spec - remove **new_efi parameter from efi_prepare_aligned_image() to improve the readability
(no changes since v7)
Changes in v7: - include hash-checksum.h instead of rsa.h - select HASH_CALCULATE in Kconfig, not to update lib/Makefile - rebased the base code
Changes in v6: - update lib/Makefile to add hash-checksum.c as a compilation target
(no changes since v2)
Changes in v2: - Remove duplicate <efi.h> include - Remove unnecessary __packed attribute - Add all EV_EFI_* event definition - Create common function to prepare 8-byte aligned image - Add measurement for EV_EFI_BOOT_SERVICES_DRIVER and EV_EFI_RUNTIME_SERVICES_DRIVER - Use efi_search_protocol() to get device_path - Add function comment
diff --git a/include/efi_loader.h b/include/efi_loader.h index 522696d635..0a9c82a257 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -426,6 +426,10 @@ efi_status_t efi_disk_register(void); efi_status_t efi_rng_register(void); /* Called by efi_init_obj_list() to install EFI_TCG2_PROTOCOL */ efi_status_t efi_tcg2_register(void); +/* measure the pe-coff image, extend PCR and add Event Log */ +efi_status_t tcg2_measure_pe_image(void *efi, u64 efi_size, + struct efi_loaded_image_obj *handle, + struct efi_loaded_image *loaded_image_info); /* Create handles and protocols for the partitions of a block device */ int efi_disk_create_partitions(efi_handle_t parent, struct blk_desc *desc, const char *if_typename, int diskid, @@ -886,6 +890,8 @@ bool efi_secure_boot_enabled(void);
bool efi_capsule_auth_enabled(void);
+void *efi_prepare_aligned_image(void *efi, u64 *efi_size); + bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, WIN_CERTIFICATE **auth, size_t *auth_len);
diff --git a/include/efi_tcg2.h b/include/efi_tcg2.h index 40e241ce31..bcfb98168a 100644 --- a/include/efi_tcg2.h +++ b/include/efi_tcg2.h @@ -9,6 +9,7 @@ #if !defined _EFI_TCG2_PROTOCOL_H_ #define _EFI_TCG2_PROTOCOL_H_
+#include <efi_api.h> #include <tpm-v2.h>
#define EFI_TCG2_PROTOCOL_GUID \ @@ -53,6 +54,14 @@ struct efi_tcg2_event { u8 event[]; } __packed;
+struct uefi_image_load_event { + efi_physical_addr_t image_location_in_memory; + u64 image_length_in_memory; + u64 image_link_time_address; + u64 length_of_device_path; + struct efi_device_path device_path[]; +}; + struct efi_tcg2_boot_service_capability { u8 size; struct efi_tcg2_version structure_version; diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 7de7d6a57d..247b386967 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -70,6 +70,24 @@ struct udevice; #define EV_TABLE_OF_DEVICES ((u32)0x0000000B) #define EV_COMPACT_HASH ((u32)0x0000000C)
+/* + * event types, cf. + * "TCG PC Client Platform Firmware Profile Specification", Family "2.0" + * rev 1.04, June 3, 2019 + */ +#define EV_EFI_EVENT_BASE ((u32)0x80000000) +#define EV_EFI_VARIABLE_DRIVER_CONFIG ((u32)0x80000001) +#define EV_EFI_VARIABLE_BOOT ((u32)0x80000002) +#define EV_EFI_BOOT_SERVICES_APPLICATION ((u32)0x80000003) +#define EV_EFI_BOOT_SERVICES_DRIVER ((u32)0x80000004) +#define EV_EFI_RUNTIME_SERVICES_DRIVER ((u32)0x80000005) +#define EV_EFI_GPT_EVENT ((u32)0x80000006) +#define EV_EFI_ACTION ((u32)0x80000007) +#define EV_EFI_PLATFORM_FIRMWARE_BLOB ((u32)0x80000008) +#define EV_EFI_HANDOFF_TABLES ((u32)0x80000009) +#define EV_EFI_HCRTM_EVENT ((u32)0x80000010) +#define EV_EFI_VARIABLE_AUTHORITY ((u32)0x800000E0) + /* TPMS_TAGGED_PROPERTY Structure */ struct tpms_tagged_property { u32 property; diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 98845b8ba3..0e6200fa25 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -309,6 +309,7 @@ config EFI_TCG2_PROTOCOL select SHA512_ALGO select SHA384 select SHA512 + select HASH_CALCULATE help Provide a EFI_TCG2_PROTOCOL implementation using the TPM hardware of the platform. diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index fe1ee198e2..bcd57f7fcc 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -302,6 +302,38 @@ static int cmp_pe_section(const void *arg1, const void *arg2) return 1; }
+/** + * efi_prepare_aligned_image() - prepare 8-byte aligned image + * @efi: pointer to the EFI binary + * @efi_size: size of @efi binary + * + * If @efi is not 8-byte aligned, this function newly allocates + * the image buffer. + * + * Return: valid pointer to a image, return NULL if allocation fails. + */ +void *efi_prepare_aligned_image(void *efi, u64 *efi_size) +{ + size_t new_efi_size; + void *new_efi; + + /* + * Size must be 8-byte aligned and the trailing bytes must be + * zero'ed. Otherwise hash value may be incorrect. + */ + if (!IS_ALIGNED(*efi_size, 8)) { + new_efi_size = ALIGN(*efi_size, 8); + new_efi = calloc(new_efi_size, 1); + if (!new_efi) + return NULL; + memcpy(new_efi, efi, *efi_size); + *efi_size = new_efi_size; + return new_efi; + } else { + return efi; + } +} + /** * efi_image_parse() - parse a PE image * @efi: Pointer to image @@ -561,7 +593,7 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) struct efi_signature_store *db = NULL, *dbx = NULL; void *new_efi = NULL; u8 *auth, *wincerts_end; - size_t new_efi_size, auth_size; + size_t auth_size; bool ret = false;
EFI_PRINT("%s: Enter, %d\n", __func__, ret); @@ -569,21 +601,11 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) if (!efi_secure_boot_enabled()) return true;
- /* - * Size must be 8-byte aligned and the trailing bytes must be - * zero'ed. Otherwise hash value may be incorrect. - */ - if (efi_size & 0x7) { - new_efi_size = (efi_size + 0x7) & ~0x7ULL; - new_efi = calloc(new_efi_size, 1); - if (!new_efi) - return false; - memcpy(new_efi, efi, efi_size); - efi = new_efi; - efi_size = new_efi_size; - } + new_efi = efi_prepare_aligned_image(efi, (u64 *)&efi_size); + if (!new_efi) + return false;
- if (!efi_image_parse(efi, efi_size, ®s, &wincerts, + if (!efi_image_parse(new_efi, efi_size, ®s, &wincerts, &wincerts_len)) { EFI_PRINT("Parsing PE executable image failed\n"); goto err; @@ -725,7 +747,8 @@ err: efi_sigstore_free(dbx); pkcs7_free_message(msg); free(regs); - free(new_efi); + if (new_efi != efi) + free(new_efi);
EFI_PRINT("%s: Exit, %d\n", __func__, ret); return ret; @@ -891,6 +914,13 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, goto err; }
+#if CONFIG_IS_ENABLED(EFI_TCG2_PROTOCOL) + /* Measure an PE/COFF image */ + if (tcg2_measure_pe_image(efi, efi_size, handle, + loaded_image_info)) + log_err("PE image measurement failed\n"); +#endif + /* Copy PE headers */ memcpy(efi_reloc, efi, sizeof(*dos) diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 39074f7547..3dd417aa27 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -13,8 +13,10 @@ #include <efi_loader.h> #include <efi_tcg2.h> #include <log.h> +#include <malloc.h> #include <version.h> #include <tpm-v2.h> +#include <u-boot/hash-checksum.h> #include <u-boot/sha1.h> #include <u-boot/sha256.h> #include <u-boot/sha512.h> @@ -707,6 +709,183 @@ out: return EFI_EXIT(ret); }
+/** + * tcg2_hash_pe_image() - calculate PE/COFF image hash + * + * @efi: pointer to the EFI binary + * @efi_size: size of @efi binary + * @digest_list: list of digest algorithms to extend + * + * Return: status code + */ +static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, + struct tpml_digest_values *digest_list) +{ + WIN_CERTIFICATE *wincerts = NULL; + size_t wincerts_len; + struct efi_image_regions *regs = NULL; + void *new_efi = NULL; + u8 hash[TPM2_SHA512_DIGEST_SIZE]; + efi_status_t ret; + u32 active; + int i; + + new_efi = efi_prepare_aligned_image(efi, &efi_size); + if (!new_efi) + return EFI_OUT_OF_RESOURCES; + + if (!efi_image_parse(new_efi, efi_size, ®s, &wincerts, + &wincerts_len)) { + log_err("Parsing PE executable image failed\n"); + ret = EFI_UNSUPPORTED; + goto out; + } + + ret = __get_active_pcr_banks(&active); + if (ret != EFI_SUCCESS) { + goto out; + } + + digest_list->count = 0; + for (i = 0; i < MAX_HASH_COUNT; i++) { + u16 hash_alg = hash_algo_list[i].hash_alg; + + if (!(active & alg_to_mask(hash_alg))) + continue; + switch (hash_alg) { + case TPM2_ALG_SHA1: + hash_calculate("sha1", regs->reg, regs->num, hash); + break; + case TPM2_ALG_SHA256: + hash_calculate("sha256", regs->reg, regs->num, hash); + break; + case TPM2_ALG_SHA384: + hash_calculate("sha384", regs->reg, regs->num, hash); + break; + case TPM2_ALG_SHA512: + hash_calculate("sha512", regs->reg, regs->num, hash); + break; + default: + EFI_PRINT("Unsupported algorithm %x\n", hash_alg); + return EFI_INVALID_PARAMETER; + } + digest_list->digests[i].hash_alg = hash_alg; + memcpy(&digest_list->digests[i].digest, hash, (u32)alg_to_len(hash_alg)); + digest_list->count++; + } + +out: + if (new_efi != efi) + free(new_efi); + free(regs); + + return ret; +} + +/** + * tcg2_measure_pe_image() - measure PE/COFF image + * + * @efi: pointer to the EFI binary + * @efi_size: size of @efi binary + * @handle: loaded image handle + * @loaded_image: loaded image protocol + * + * Return: status code + */ +efi_status_t tcg2_measure_pe_image(void *efi, u64 efi_size, + struct efi_loaded_image_obj *handle, + struct efi_loaded_image *loaded_image) +{ + struct tpml_digest_values digest_list; + efi_status_t ret; + struct udevice *dev; + u32 pcr_index, event_type, event_size; + struct uefi_image_load_event *image_load_event; + struct efi_device_path *device_path; + u32 device_path_length; + IMAGE_DOS_HEADER *dos; + IMAGE_NT_HEADERS32 *nt; + struct efi_handler *handler; + + ret = platform_get_tpm2_device(&dev); + if (ret != EFI_SUCCESS) + return ret; + + switch (handle->image_type) { + case IMAGE_SUBSYSTEM_EFI_APPLICATION: + pcr_index = 4; + event_type = EV_EFI_BOOT_SERVICES_APPLICATION; + break; + case IMAGE_SUBSYSTEM_EFI_BOOT_SERVICE_DRIVER: + pcr_index = 2; + event_type = EV_EFI_BOOT_SERVICES_DRIVER; + break; + case IMAGE_SUBSYSTEM_EFI_RUNTIME_DRIVER: + pcr_index = 2; + event_type = EV_EFI_RUNTIME_SERVICES_DRIVER; + break; + default: + return EFI_UNSUPPORTED; + } + + ret = tcg2_hash_pe_image(efi, efi_size, &digest_list); + if (ret != EFI_SUCCESS) + return ret; + + ret = tcg2_pcr_extend(dev, pcr_index, &digest_list); + if (ret != EFI_SUCCESS) + return ret; + + ret = EFI_CALL(efi_search_protocol(&handle->header, + &efi_guid_loaded_image_device_path, + &handler)); + if (ret != EFI_SUCCESS) + return ret; + + device_path = EFI_CALL(handler->protocol_interface); + device_path_length = efi_dp_size(device_path); + if (device_path_length > 0) { + /* add end node size */ + device_path_length += sizeof(struct efi_device_path); + } + event_size = sizeof(struct uefi_image_load_event) + device_path_length; + image_load_event = (struct uefi_image_load_event *)malloc(event_size); + if (!image_load_event) + return EFI_OUT_OF_RESOURCES; + + image_load_event->image_location_in_memory = (efi_physical_addr_t)efi; + image_load_event->image_length_in_memory = efi_size; + image_load_event->length_of_device_path = device_path_length; + + dos = (IMAGE_DOS_HEADER *)efi; + nt = (IMAGE_NT_HEADERS32 *)(efi + dos->e_lfanew); + if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR64_MAGIC) { + IMAGE_NT_HEADERS64 *nt64 = (IMAGE_NT_HEADERS64 *)nt; + + image_load_event->image_link_time_address = + nt64->OptionalHeader.ImageBase; + } else if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR32_MAGIC) { + image_load_event->image_link_time_address = + nt->OptionalHeader.ImageBase; + } else { + ret = EFI_INVALID_PARAMETER; + goto out; + } + + if (device_path_length > 0) { + memcpy(image_load_event->device_path, device_path, + device_path_length); + } + + ret = tcg2_agile_log_append(pcr_index, event_type, &digest_list, + event_size, (u8 *)image_load_event); + +out: + free(image_load_event); + + return ret; +} + /** * efi_tcg2_hash_log_extend_event() - extend and optionally log events * @@ -758,24 +937,32 @@ efi_tcg2_hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, /* * if PE_COFF_IMAGE is set we need to make sure the image is not * corrupted, verify it and hash the PE/COFF image in accordance with - * the procedure specified in "Calculating the PE Image Hash" - * section of the "Windows Authenticode Portable Executable Signature + * the procedure specified in "Calculating the PE Image Hash" + * section of the "Windows Authenticode Portable Executable Signature * Format" - * Not supported for now */ if (flags & PE_COFF_IMAGE) { - ret = EFI_UNSUPPORTED; - goto out; - } + IMAGE_NT_HEADERS32 *nt;
- pcr_index = efi_tcg_event->header.pcr_index; - event_type = efi_tcg_event->header.event_type; + ret = efi_check_pe((void *)data_to_hash, data_to_hash_len, + (void **)&nt); + if (ret != EFI_SUCCESS) { + log_err("Not a valid PE-COFF file\n"); + goto out; + } + ret = tcg2_hash_pe_image((void *)data_to_hash, data_to_hash_len, + &digest_list); + } else { + ret = tcg2_create_digest((u8 *)(uintptr_t)data_to_hash, + data_to_hash_len, &digest_list); + }
- ret = tcg2_create_digest((u8 *)(uintptr_t)data_to_hash, - data_to_hash_len, &digest_list); if (ret != EFI_SUCCESS) goto out;
+ pcr_index = efi_tcg_event->header.pcr_index; + event_type = efi_tcg_event->header.event_type; + ret = tcg2_pcr_extend(dev, pcr_index, &digest_list); if (ret != EFI_SUCCESS) goto out;
Changes in v9:
Changes in v7:
I want to remove HASH_CALCULATE for Kconfig for reasons outlined in (1):
(1) https://patchwork.ozlabs.org/project/uboot/patch/20210524192857.1486696-2-mr...
The root of the problem is that selecting SHA_xxx should compile and link the hash_calculate() symbol, and this would make the existing kconfig correct. Unfortunately, the selection doesn't happen automatically because the SHA code isn't too well organized.
To solve your problem, I would prefer that you take the series in (1) -- there's a second patch after it -- and use "select HASH" here. You're asking "What's the difference ?". The difference is that "HASH" is an existing Kconfig symbol, so we don't need to also add "HASH_CALULATE".
Alex
Changes in v6:
Changes in v2:
/* Create handles and protocols for the partitions of a block device */ int efi_disk_create_partitions(efi_handle_t parent, struct blk_desc *desc, const char *if_typename, int diskid,struct efi_loaded_image *loaded_image_info);
- bool efi_image_parse(void *efi, size_t len, struct efi_image_regions **regp, WIN_CERTIFICATE **auth, size_t *auth_len);
- efi_physical_addr_t image_location_in_memory;
- u64 image_length_in_memory;
- u64 image_link_time_address;
- u64 length_of_device_path;
- struct efi_device_path device_path[];
- struct efi_tcg2_boot_service_capability { u8 size; struct efi_tcg2_version structure_version;
- event types, cf.
- "TCG PC Client Platform Firmware Profile Specification", Family "2.0"
- rev 1.04, June 3, 2019
- /* TPMS_TAGGED_PROPERTY Structure */ struct tpms_tagged_property { u32 property;
- select HASH_CALCULATE help Provide a EFI_TCG2_PROTOCOL implementation using the TPM hardware of the platform.
- efi_prepare_aligned_image() - prepare 8-byte aligned image
- @efi: pointer to the EFI binary
- @efi_size: size of @efi binary
- If @efi is not 8-byte aligned, this function newly allocates
- the image buffer.
- Return: valid pointer to a image, return NULL if allocation fails.
- size_t new_efi_size;
- void *new_efi;
- if (!IS_ALIGNED(*efi_size, 8)) {
if (!new_efi)
return NULL;
return new_efi;
- } else {
return efi;
- efi_image_parse() - parse a PE image
- @efi: Pointer to image
if (!new_efi)
return false;
efi = new_efi;
- new_efi = efi_prepare_aligned_image(efi, (u64 *)&efi_size);
- if (!new_efi)
return false;
- if (!efi_image_parse(new_efi, efi_size, ®s, &wincerts, &wincerts_len)) { EFI_PRINT("Parsing PE executable image failed\n"); goto err;
- free(new_efi);
if (new_efi != efi)
free(new_efi);
- /* Measure an PE/COFF image */
- if (tcg2_measure_pe_image(efi, efi_size, handle,
loaded_image_info))
- /* Copy PE headers */ memcpy(efi_reloc, efi, sizeof(*dos)
- tcg2_hash_pe_image() - calculate PE/COFF image hash
- @digest_list: list of digest algorithms to extend
- Return: status code
- WIN_CERTIFICATE *wincerts = NULL;
- size_t wincerts_len;
- struct efi_image_regions *regs = NULL;
- void *new_efi = NULL;
- u8 hash[TPM2_SHA512_DIGEST_SIZE];
- efi_status_t ret;
- u32 active;
- int i;
- new_efi = efi_prepare_aligned_image(efi, &efi_size);
- if (!new_efi)
&wincerts_len)) {
goto out;
- ret = __get_active_pcr_banks(&active);
- if (ret != EFI_SUCCESS) {
goto out;
- digest_list->count = 0;
- for (i = 0; i < MAX_HASH_COUNT; i++) {
continue;
switch (hash_alg) {
case TPM2_ALG_SHA1:
break;
break;
break;
break;
default:
+out:
- if (new_efi != efi)
free(new_efi);
- free(regs);
- return ret;
- tcg2_measure_pe_image() - measure PE/COFF image
- @handle: loaded image handle
- @loaded_image: loaded image protocol
- struct tpml_digest_values digest_list;
- efi_status_t ret;
- struct udevice *dev;
- u32 pcr_index, event_type, event_size;
- struct uefi_image_load_event *image_load_event;
- struct efi_device_path *device_path;
- u32 device_path_length;
- IMAGE_DOS_HEADER *dos;
- IMAGE_NT_HEADERS32 *nt;
- struct efi_handler *handler;
- ret = platform_get_tpm2_device(&dev);
return ret;
- switch (handle->image_type) {
- case IMAGE_SUBSYSTEM_EFI_APPLICATION:
pcr_index = 4;
break;
- case IMAGE_SUBSYSTEM_EFI_BOOT_SERVICE_DRIVER:
pcr_index = 2;
break;
- case IMAGE_SUBSYSTEM_EFI_RUNTIME_DRIVER:
pcr_index = 2;
break;
- default:
- ret = tcg2_hash_pe_image(efi, efi_size, &digest_list);
return ret;
- ret = tcg2_pcr_extend(dev, pcr_index, &digest_list);
return ret;
- ret = EFI_CALL(efi_search_protocol(&handle->header,
&handler));
return ret;
- device_path = EFI_CALL(handler->protocol_interface);
- device_path_length = efi_dp_size(device_path);
- if (device_path_length > 0) {
- event_size = sizeof(struct uefi_image_load_event) + device_path_length;
- image_load_event = (struct uefi_image_load_event *)malloc(event_size);
- if (!image_load_event)
- image_load_event->image_location_in_memory = (efi_physical_addr_t)efi;
- image_load_event->image_length_in_memory = efi_size;
- image_load_event->length_of_device_path = device_path_length;
- dos = (IMAGE_DOS_HEADER *)efi;
- nt = (IMAGE_NT_HEADERS32 *)(efi + dos->e_lfanew);
- if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR64_MAGIC) {
- } else if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR32_MAGIC) {
- } else {
goto out;
- ret = tcg2_agile_log_append(pcr_index, event_type, &digest_list,
+out:
- free(image_load_event);
- return ret;
- efi_tcg2_hash_log_extend_event() - extend and optionally log events
- Format"
*/ if (flags & PE_COFF_IMAGE) {* Not supported for now
goto out;
(void **)&nt);
goto out;
&digest_list);
- } else {
if (ret != EFI_SUCCESS) goto out;data_to_hash_len, &digest_list);
- ret = tcg2_pcr_extend(dev, pcr_index, &digest_list); if (ret != EFI_SUCCESS) goto out;
Changes in v9:
Changes in v7:
As I replied to your series, I agree with your modification.
Thanks, Masahisa Kojima
Alex
Changes in v6:
Changes in v2:
- event types, cf.
- the image buffer.
void *new_efi;
if (!new_efi)
return NULL;
return new_efi;
} else {
return efi;
size_t auth_size; bool ret = false; EFI_PRINT("%s: Enter, %d\n", __func__, ret);
if (!new_efi)
return false;
efi = new_efi;
if (!new_efi)
return false;
free(new_efi);
if (new_efi != efi)
free(new_efi); EFI_PRINT("%s: Exit, %d\n", __func__, ret); return ret;
loaded_image_info))
efi_status_t ret;
u32 active;
int i;
if (!new_efi)
&wincerts_len)) {
goto out;
goto out;
continue;
switch (hash_alg) {
case TPM2_ALG_SHA1:
break;
break;
break;
break;
default:
+out:
if (new_efi != efi)
free(new_efi);
free(regs);
return ret;
efi_status_t ret;
return ret;
pcr_index = 4;
break;
pcr_index = 2;
break;
pcr_index = 2;
break;
default:
return ret;
return ret;
&handler));
return ret;
} else {
goto out;
+out:
return ret;
goto out;
(void **)&nt);
goto out;
&digest_list);
} else {
Changes in v9:
Changes in v7:
Changes in v6:
Changes in v2:
- event types, cf.
- the image buffer.
- void *new_efi;
if (!new_efi)
return NULL;
return new_efi;
- } else {
return efi;
if (!new_efi)
return false;
efi = new_efi;
- if (!new_efi)
return false;
- free(new_efi);
if (new_efi != efi)
free(new_efi);
loaded_image_info))
- efi_status_t ret;
- u32 active;
- int i;
- if (!new_efi)
&wincerts_len)) {
goto out;
goto out;
continue;
switch (hash_alg) {
case TPM2_ALG_SHA1:
break;
break;
break;
break;
default:
+out:
free(new_efi);
- free(regs);
- return ret;
- efi_status_t ret;
return ret;
pcr_index = 4;
break;
pcr_index = 2;
break;
pcr_index = 2;
break;
- default:
return ret;
return ret;
&handler));
return ret;
- } else {
goto out;
+out:
- return ret;
- Format"
goto out;
(void **)&nt);
goto out;
&digest_list);
Compiling on a 32bit system fails:
https://source.denx.de/u-boot/custodians/u-boot-efi/-/jobs/273092
I hope the following applied on top catches all the reported issues:
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 3dd417aa27..47bc371477 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -853,7 +853,7 @@ efi_status_t tcg2_measure_pe_image(void *efi, u64 efi_size, if (!image_load_event) return EFI_OUT_OF_RESOURCES;
- image_load_event->image_location_in_memory = (efi_physical_addr_t)efi; + image_load_event->image_location_in_memory = (uintptr_t)efi; image_load_event->image_length_in_memory = efi_size; image_load_event->length_of_device_path = device_path_length;
@@ -944,14 +944,14 @@ efi_tcg2_hash_log_extend_event(struct efi_tcg2_protocol *this, u64 flags, if (flags & PE_COFF_IMAGE) { IMAGE_NT_HEADERS32 *nt;
- ret = efi_check_pe((void *)data_to_hash, data_to_hash_len, - (void **)&nt); + ret = efi_check_pe((void *)(uintptr_t)data_to_hash, + data_to_hash_len, (void **)&nt); if (ret != EFI_SUCCESS) { log_err("Not a valid PE-COFF file\n"); goto out; } - ret = tcg2_hash_pe_image((void *)data_to_hash, data_to_hash_len, - &digest_list); + ret = tcg2_hash_pe_image((void *)(uintptr_t)data_to_hash, + data_to_hash_len, &digest_list); } else { ret = tcg2_create_digest((u8 *)(uintptr_t)data_to_hash, data_to_hash_len, &digest_list);
Best regards
Heinrich
- } else {
Alex G.
Masahisa Kojima
