[U-Boot] [PATCH u-boot 0/3] Add USB Support for Amlogic Meson GXL SoCs
This patchset adds support for USB for the Amlogic Meson GXL SoCs following the work done for Linux by Martin Blumenstingl at [1] [2] [3].
The support consist of : - A port of dwc3-of-simple from Linux to U-boot - A change to support more than 2 PHYs in the DWC3 DM driver - An USB2 PHY Driver and an USB3 PHY Driver
The DWC3 Controller has up to 4 PHYs connected : - 2 USB2 PHYs and an USB3 PHY for GXL SoCs - 3 USB2 PHYs and an USB3 PHY for the GXM SoC Variant This is enabled by the "usb: host: dwc3: Add support for multiple PHYs" patch. This patch is based on the "xhci-dwc3: Couple of fixes for USB3 support" serie from Vignesh R, on the u-boot-usb tree.
The DWC3 Controller glue is generic enough to use the dwc3-of-simple from Linux and can be easily ported to U-Boot as a Simple-Bus with Glue-Specific clocks and Reset lines setup.
The USB PHY driver supports the standard generic PHY interface and supports the power-on/off calls and set the Host mode by default. They are based on the excellent work from Martin Blumenstingl merged in linux.
[1] https://lkml.kernel.org/r/20180303184700.21480-1-martin.blumenstingl@googlem... [2] https://lkml.kernel.org/r/20180128202245.25021-1-martin.blumenstingl@googlem... [3] https://lkml.kernel.org/r/20180303214309.25643-1-martin.blumenstingl@googlem...
Neil Armstrong (3): usb: host: Add simple of glue driver for DWC3 USB Controllers integration usb: host: dwc3: Add support for multiple PHYs phy: Add Amlogic Meson USB2 & USB3 Generic PHY drivers
drivers/phy/Kconfig | 8 ++ drivers/phy/Makefile | 1 + drivers/phy/meson-gxl-usb2.c | 238 +++++++++++++++++++++++++++++++++++++++++++ drivers/phy/meson-gxl-usb3.c | 201 ++++++++++++++++++++++++++++++++++++ 4 files changed, 448 insertions(+) create mode 100644 drivers/phy/meson-gxl-usb2.c create mode 100644 drivers/phy/meson-gxl-usb3.c
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/usb/host/Kconfig | 7 ++ drivers/usb/host/Makefile | 1 + drivers/usb/host/dwc3-of-simple.c | 187 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 195 insertions(+) create mode 100644 drivers/usb/host/dwc3-of-simple.c
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index a7249b7..6caa615 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -21,6 +21,13 @@ config USB_XHCI_DWC3 Say Y or if your system has a Dual Role SuperSpeed USB controller based on the DesignWare USB3 IP Core.
+config USB_XHCI_DWC3_OF_SIMPLE + bool "DesignWare USB3 DRD Generic OF Simple Glue Layer" + select MISC + help + Support USB2/3 functionality in simple SoC integrations with + USB controller based on the DesignWare USB3 IP Core. + config USB_XHCI_MVEBU bool "MVEBU USB 3.0 support" default y diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 9819489..abe4f90 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -49,6 +49,7 @@ obj-$(CONFIG_USB_EHCI_ZYNQ) += ehci-zynq.o # xhci obj-$(CONFIG_USB_XHCI_HCD) += xhci.o xhci-mem.o xhci-ring.o obj-$(CONFIG_USB_XHCI_DWC3) += xhci-dwc3.o +obj-$(CONFIG_USB_XHCI_DWC3_OF_SIMPLE) += dwc3-of-simple.o obj-$(CONFIG_USB_XHCI_ROCKCHIP) += xhci-rockchip.o obj-$(CONFIG_USB_XHCI_ZYNQMP) += xhci-zynqmp.o obj-$(CONFIG_USB_XHCI_KEYSTONE) += xhci-keystone.o diff --git a/drivers/usb/host/dwc3-of-simple.c b/drivers/usb/host/dwc3-of-simple.c new file mode 100644 index 0000000..826a996 --- /dev/null +++ b/drivers/usb/host/dwc3-of-simple.c @@ -0,0 +1,187 @@ +/* + * dwc3-of-simple.c - OF glue layer for simple integrations + * + * Copyright (c) 2015 Texas Instruments Incorporated - http://www.ti.com + * + * Author: Felipe Balbi balbi@ti.com + * + * Copyright (C) 2018 BayLibre, SAS + * Author: Neil Armstrong narmstron@baylibre.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <reset.h> +#include <clk.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct dwc3_of_simple { +#if CONFIG_IS_ENABLED(CLK) + struct clk *clks; + int num_clocks; +#endif +#if CONFIG_IS_ENABLED(DM_RESET) + struct reset_ctl *resets; + int num_resets; +#endif +}; + +#if CONFIG_IS_ENABLED(DM_RESET) +static int dwc3_of_simple_reset_init(struct udevice *dev, + struct dwc3_of_simple *simple, + int count) +{ + int i, ret, err; + + if (!count) + return 0; + + simple->resets = devm_kcalloc(dev, count, sizeof(struct reset_ctl), + GFP_KERNEL); + if (!simple->resets) + return -ENOMEM; + + for (i = 0; i < count; i++) { + ret = reset_get_by_index(dev, i, &simple->resets[i]); + if (ret < 0) + break; + + ret = reset_request(&simple->resets[i]); + if (ret) { + pr_err("failed to request reset line %d\n", i); + reset_free(&simple->resets[i]); + goto reset_err; + } + + + ++simple->num_resets; + } + + for (i = 0; i < simple->num_resets; i++) { + ret = reset_deassert(&simple->resets[i]); + if (ret && ret != -ENOSYS && ret != -ENOTSUPP) { + pr_err("failed to deassert reset line %d\n", i); + goto reset_err; + } + } + + return 0; + +reset_err: + err = reset_release_all(simple->resets, simple->num_resets); + if (err) + pr_err("failed to disable all clocks\n"); + + return ret; +} +#endif + +#if CONFIG_IS_ENABLED(CLK) +static int dwc3_of_simple_clk_init(struct udevice *dev, + struct dwc3_of_simple *simple, + int count) +{ + int i, ret, err; + + if (!count) + return 0; + + simple->clks = devm_kcalloc(dev, count, sizeof(struct clk), + GFP_KERNEL); + if (!simple->clks) + return -ENOMEM; + + for (i = 0; i < count; i++) { + ret = clk_get_by_index(dev, i, &simple->clks[i]); + if (ret < 0) + break; + + ret = clk_enable(&simple->clks[i]); + if (ret && ret != -ENOSYS && ret != -ENOTSUPP) { + pr_err("failed to enable clock %d\n", i); + clk_free(&simple->clks[i]); + goto clk_err; + } + + ++simple->num_clocks; + } + + return 0; + +clk_err: + err = clk_release_all(simple->clks, simple->num_clocks); + if (err) + pr_err("failed to disable all clocks\n"); + + return ret; +} +#endif + +static int dwc3_of_simple_probe(struct udevice *dev) +{ +#if CONFIG_IS_ENABLED(DM_RESET) || CONFIG_IS_ENABLED(CLK) + struct dwc3_of_simple *simple = dev_get_platdata(dev); + int ret; +#endif + +#if CONFIG_IS_ENABLED(CLK) + ret = dwc3_of_simple_clk_init(dev, simple, + dev_count_phandle_with_args(dev, "clocks", "#clock-cells")); + if (ret) + return ret; +#endif + +#if CONFIG_IS_ENABLED(DM_RESET) + ret = dwc3_of_simple_reset_init(dev, simple, + dev_count_phandle_with_args(dev, "resets", "#reset-cells")); + if (ret) + return ret; +#endif + + return 0; +} + +static int dwc3_of_simple_remove(struct udevice *dev) +{ +#if CONFIG_IS_ENABLED(DM_RESET) || CONFIG_IS_ENABLED(CLK) + struct dwc3_of_simple *simple = dev_get_platdata(dev); + int i; +#endif + +#if CONFIG_IS_ENABLED(DM_RESET) + for (i = 0; i < simple->num_resets; i++) + reset_assert(&simple->resets[i]); + + if (simple->num_resets) + reset_release_all(simple->resets, simple->num_resets); +#endif + +#if CONFIG_IS_ENABLED(CLK) + for (i = 0; i < simple->num_clocks; i++) + clk_disable(&simple->clks[i]); + + if (simple->num_clocks) + clk_release_all(simple->clks, simple->num_clocks); +#endif + + return dm_scan_fdt_dev(dev); +} + +static const struct udevice_id dwc3_of_simple_ids[] = { + { .compatible = "amlogic,meson-gxl-dwc3" }, + { } +}; + +U_BOOT_DRIVER(dwc3_of_simple) = { + .name = "dwc3-of-simple", + .id = UCLASS_SIMPLE_BUS, + .of_match = dwc3_of_simple_ids, + .probe = dwc3_of_simple_probe, + .remove = dwc3_of_simple_remove, + .platdata_auto_alloc_size = sizeof(struct dwc3_of_simple), + .flags = DM_FLAG_ALLOC_PRIV_DMA, +};
- bool "DesignWare USB3 DRD Generic OF Simple Glue Layer"
- select MISC
- help
- dwc3-of-simple.c - OF glue layer for simple integrations
- Copyright (c) 2015 Texas Instruments Incorporated - http://www.ti.com
- Author: Felipe Balbi balbi@ti.com
- Copyright (C) 2018 BayLibre, SAS
- Author: Neil Armstrong narmstron@baylibre.com
- struct clk *clks;
- int num_clocks;
- struct reset_ctl *resets;
- int num_resets;
+#endif +};
int count)
- int i, ret, err;
- if (!count)
- simple->resets = devm_kcalloc(dev, count, sizeof(struct reset_ctl),
GFP_KERNEL);
- if (!simple->resets)
return -ENOMEM;
- for (i = 0; i < count; i++) {
if (ret < 0)
break;
if (ret) {
goto reset_err;
- for (i = 0; i < simple->num_resets; i++) {
goto reset_err;
This looks like some driver I've seen before. Isn't there similar code for simple EHCI or OHCI driver already ?
- select MISC
- help
- struct clk *clks;
- int num_clocks;
- int num_resets;
+#endif +};
int count)
- int i, ret, err;
- if (!count)
GFP_KERNEL);
return -ENOMEM;
if (ret < 0)
break;
if (ret) {
goto reset_err;
goto reset_err;
This is not an EHCI/OHCI driver, only the glue to init the clocks and reset, it's the exact same as the drivers/usb/dwc3/dwc3-of-simple.c adapted to U-Boot.
yes, similar code exists in drivers/usb/host/ehci-generic.c and drivers/usb/host/ohci-generic.c but the goal here is not to initialize the controller but only the glue.
The device tree representation is : glue@ { compatible = "amlogic,meson-gxl-dwc3"; clocks = <>; resets = <>;
dwc3@ { compatible = "snps,dwc3"; clocks = <>; phys = <>; }; };
Neil
- select MISC
- help
- struct clk *clks;
- int num_clocks;
- int num_resets;
+#endif +};
int count)
- int i, ret, err;
- if (!count)
GFP_KERNEL);
return -ENOMEM;
if (ret < 0)
break;
if (ret) {
goto reset_err;
goto reset_err;
Can't we recycle that code instead of having three copies of similar stuff ?
- select MISC
- help
- struct clk *clks;
- int num_clocks;
- int num_resets;
+#endif +};
int count)
- int i, ret, err;
- if (!count)
GFP_KERNEL);
return -ENOMEM;
if (ret < 0)
break;
if (ret) {
goto reset_err;
goto reset_err;
Sure, where should I put this code ? the clock and resets are stored in the driver's platdata.
Neil
- select MISC
- help
- struct clk *clks;
- int num_clocks;
- int num_resets;
+#endif +};
int count)
- int i, ret, err;
- if (!count)
GFP_KERNEL);
return -ENOMEM;
if (ret < 0)
break;
if (ret) {
goto reset_err;
goto reset_err;
Something-common I guess ?
DWC3 Ips can have more than 1 PHY for USB2 and 1 PHY for USB3, add support for a generic number of PHYs and adapt the code to handle a generic number of PHYs.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/usb/host/xhci-dwc3.c | 105 ++++++++++++++++++++++++------------------- 1 file changed, 58 insertions(+), 47 deletions(-)
diff --git a/drivers/usb/host/xhci-dwc3.c b/drivers/usb/host/xhci-dwc3.c index 1022dd5..da29162 100644 --- a/drivers/usb/host/xhci-dwc3.c +++ b/drivers/usb/host/xhci-dwc3.c @@ -22,8 +22,8 @@ DECLARE_GLOBAL_DATA_PTR;
struct xhci_dwc3_platdata { - struct phy usb_phy; - struct phy usb3_phy; + struct phy *usb_phys; + int num_phys; };
void dwc3_set_mode(struct dwc3 *dwc3_reg, u32 mode) @@ -113,45 +113,74 @@ void dwc3_set_fladj(struct dwc3 *dwc3_reg, u32 val) }
#ifdef CONFIG_DM_USB -static int xhci_dwc3_setup_phy(struct udevice *dev, int index, struct phy *phy) +static int xhci_dwc3_setup_phy(struct udevice *dev, int count) { - int ret = 0; + struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); + int i, ret; + + if (!count) + return 0;
- ret = generic_phy_get_by_index(dev, index, phy); - if (ret) { - if (ret != -ENOENT) { - pr_err("Failed to get USB PHY for %s\n", dev->name); + plat->usb_phys = devm_kcalloc(dev, count, sizeof(struct phy), + GFP_KERNEL); + if (!plat->usb_phys) + return -ENOMEM; + + for (i = 0; i < count; i++) { + ret = generic_phy_get_by_index(dev, i, &plat->usb_phys[i]); + if (ret && ret != -ENOENT) { + pr_err("Failed to get USB PHY%d for %s\n", + i, dev->name); return ret; } - } else { - ret = generic_phy_init(phy); + + ++plat->num_phys; + } + + for (i = 0; i < plat->num_phys; i++) { + ret = generic_phy_init(&plat->usb_phys[i]); if (ret) { - pr_err("Can't init USB PHY for %s\n", dev->name); - return ret; + pr_err("Can't init USB PHY%d for %s\n", + i, dev->name); + goto phys_err; } - ret = generic_phy_power_on(phy); + } + + for (i = 0; i < plat->num_phys; i++) { + ret = generic_phy_power_on(&plat->usb_phys[i]); if (ret) { - pr_err("Can't power on USB PHY for %s\n", dev->name); - generic_phy_exit(phy); - return ret; + pr_err("Can't power USB PHY%d for %s\n", + i, dev->name); + goto phys_err; } }
return 0; + +phys_err: + for (; i >= 0; i--) { + generic_phy_power_off(&plat->usb_phys[i]); + generic_phy_exit(&plat->usb_phys[i]); + } + + return ret; }
-static int xhci_dwc3_shutdown_phy(struct phy *phy) +static int xhci_dwc3_shutdown_phy(struct udevice *dev) { - int ret = 0; + struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); + int i, ret;
- if (generic_phy_valid(phy)) { - ret = generic_phy_power_off(phy); - if (ret) - return ret; + for (i = 0; i < plat->num_phys; i++) { + if (!generic_phy_valid(&plat->usb_phys[i])) + continue;
- ret = generic_phy_exit(phy); - if (ret) - return ret; + ret = generic_phy_power_off(&plat->usb_phys[i]); + ret |= generic_phy_exit(&plat->usb_phys[i]); + if (ret) { + pr_err("Can't shutdown USB PHY%d for %s\n", + i, dev->name); + } }
return 0; @@ -159,7 +188,6 @@ static int xhci_dwc3_shutdown_phy(struct phy *phy)
static int xhci_dwc3_probe(struct udevice *dev) { - struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); struct xhci_hcor *hcor; struct xhci_hccr *hccr; struct dwc3 *dwc3_reg; @@ -170,18 +198,10 @@ static int xhci_dwc3_probe(struct udevice *dev) hcor = (struct xhci_hcor *)((uintptr_t)hccr + HC_LENGTH(xhci_readl(&(hccr)->cr_capbase)));
- ret = xhci_dwc3_setup_phy(dev, 0, &plat->usb_phy); - if (ret) { - pr_err("Failed to setup USB PHY for %s\n", dev->name); - return ret; - } - - ret = xhci_dwc3_setup_phy(dev, 1, &plat->usb3_phy); - if (ret) { - pr_err("Failed to setup USB3 PHY for %s\n", dev->name); - xhci_dwc3_shutdown_phy(&plat->usb_phy); + ret = xhci_dwc3_setup_phy(dev, dev_count_phandle_with_args( + dev, "phys", "#phy-cells")); + if (ret) return ret; - }
dwc3_reg = (struct dwc3 *)((char *)(hccr) + DWC3_REG_OFFSET);
@@ -199,16 +219,7 @@ static int xhci_dwc3_probe(struct udevice *dev)
static int xhci_dwc3_remove(struct udevice *dev) { - struct xhci_dwc3_platdata *plat = dev_get_platdata(dev); - int ret; - - ret = xhci_dwc3_shutdown_phy(&plat->usb_phy); - if (ret) - pr_err("Can't shutdown USB PHY for %s\n", dev->name); - - ret = xhci_dwc3_shutdown_phy(&plat->usb3_phy); - if (ret) - pr_err("Can't shutdown USB3 PHY for %s\n", dev->name); + xhci_dwc3_shutdown_phy(dev);
return xhci_deregister(dev); }
- struct phy *usb_phys;
- int num_phys;
- int ret = 0;
- int i, ret;
- if (!count)
- if (ret) {
- plat->usb_phys = devm_kcalloc(dev, count, sizeof(struct phy),
GFP_KERNEL);
- if (!plat->usb_phys)
return -ENOMEM;
}i, dev->name); return ret;
- } else {
++plat->num_phys;
- for (i = 0; i < plat->num_phys; i++) {
if (ret) {ret = generic_phy_init(&plat->usb_phys[i]);
return ret;
i, dev->name);
}goto phys_err;
if (ret) {ret = generic_phy_power_on(&plat->usb_phys[i]);
return ret;
i, dev->name);
goto phys_err;
+phys_err:
- for (; i >= 0; i--) {
This will not work if all the PHYs are inited, but the power up function fails -- at that point the phy_exit will not be called for all inited PHys.
- int num_phys;
- int ret = 0;
- int i, ret;
- if (!count)
- if (ret) {
GFP_KERNEL);
return -ENOMEM;
- } else {
++plat->num_phys;
return ret;
i, dev->name);
}goto phys_err;
return ret;
i, dev->name);
goto phys_err;
+phys_err:
Ok will split in 2 parts.
Neil
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/phy/Kconfig | 8 ++ drivers/phy/Makefile | 1 + drivers/phy/meson-gxl-usb2.c | 238 +++++++++++++++++++++++++++++++++++++++++++ drivers/phy/meson-gxl-usb3.c | 201 ++++++++++++++++++++++++++++++++++++ 4 files changed, 448 insertions(+) create mode 100644 drivers/phy/meson-gxl-usb2.c create mode 100644 drivers/phy/meson-gxl-usb3.c
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index 3b9a09c..99a6d95 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -85,4 +85,12 @@ config STI_USB_PHY used by USB2 and USB3 Host controllers available on STiH407 SoC families.
+config MESON_GXL_USB_PHY + bool "Amlogic Meson GXL USB PHYs" + depends on PHY && ARCH_MESON && MESON_GXL + imply REGMAP + help + This is the generic phy driver for the Amlogic Meson GXL + USB2 and USB3 PHYS. + endmenu diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index 668040b..6c1610e 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -10,3 +10,4 @@ obj-$(CONFIG_$(SPL_)NOP_PHY) += nop-phy.o obj-$(CONFIG_PHY_SANDBOX) += sandbox-phy.o obj-$(CONFIG_$(SPL_)PIPE3_PHY) += ti-pipe3-phy.o obj-$(CONFIG_STI_USB_PHY) += sti_usb_phy.o +obj-$(CONFIG_MESON_GXL_USB_PHY) += meson-gxl-usb2.o meson-gxl-usb3.o diff --git a/drivers/phy/meson-gxl-usb2.c b/drivers/phy/meson-gxl-usb2.c new file mode 100644 index 0000000..15c9c89 --- /dev/null +++ b/drivers/phy/meson-gxl-usb2.c @@ -0,0 +1,238 @@ +/* + * Meson GXL and GXM USB2 PHY driver + * + * Copyright (C) 2017 Martin Blumenstingl martin.blumenstingl@googlemail.com + * Copyright (C) 2018 BayLibre, SAS + * Author: Neil Armstrong narmstron@baylibre.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <bitfield.h> +#include <dm.h> +#include <errno.h> +#include <generic-phy.h> +#include <regmap.h> +#include <power/regulator.h> +#include <clk.h> + +#include <linux/bitops.h> +#include <linux/compat.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* bits [31:27] are read-only */ +#define U2P_R0 0x0 + #define U2P_R0_BYPASS_SEL BIT(0) + #define U2P_R0_BYPASS_DM_EN BIT(1) + #define U2P_R0_BYPASS_DP_EN BIT(2) + #define U2P_R0_TXBITSTUFF_ENH BIT(3) + #define U2P_R0_TXBITSTUFF_EN BIT(4) + #define U2P_R0_DM_PULLDOWN BIT(5) + #define U2P_R0_DP_PULLDOWN BIT(6) + #define U2P_R0_DP_VBUS_VLD_EXT_SEL BIT(7) + #define U2P_R0_DP_VBUS_VLD_EXT BIT(8) + #define U2P_R0_ADP_PRB_EN BIT(9) + #define U2P_R0_ADP_DISCHARGE BIT(10) + #define U2P_R0_ADP_CHARGE BIT(11) + #define U2P_R0_DRV_VBUS BIT(12) + #define U2P_R0_ID_PULLUP BIT(13) + #define U2P_R0_LOOPBACK_EN_B BIT(14) + #define U2P_R0_OTG_DISABLE BIT(15) + #define U2P_R0_COMMON_ONN BIT(16) + #define U2P_R0_FSEL_MASK GENMASK(19, 17) + #define U2P_R0_REF_CLK_SEL_MASK GENMASK(21, 20) + #define U2P_R0_POWER_ON_RESET BIT(22) + #define U2P_R0_V_ATE_TEST_EN_B_MASK GENMASK(24, 23) + #define U2P_R0_ID_SET_ID_DQ BIT(25) + #define U2P_R0_ATE_RESET BIT(26) + #define U2P_R0_FSV_MINUS BIT(27) + #define U2P_R0_FSV_PLUS BIT(28) + #define U2P_R0_BYPASS_DM_DATA BIT(29) + #define U2P_R0_BYPASS_DP_DATA BIT(30) + +#define U2P_R1 0x4 + #define U2P_R1_BURN_IN_TEST BIT(0) + #define U2P_R1_ACA_ENABLE BIT(1) + #define U2P_R1_DCD_ENABLE BIT(2) + #define U2P_R1_VDAT_SRC_EN_B BIT(3) + #define U2P_R1_VDAT_DET_EN_B BIT(4) + #define U2P_R1_CHARGES_SEL BIT(5) + #define U2P_R1_TX_PREEMP_PULSE_TUNE BIT(6) + #define U2P_R1_TX_PREEMP_AMP_TUNE_MASK GENMASK(8, 7) + #define U2P_R1_TX_RES_TUNE_MASK GENMASK(10, 9) + #define U2P_R1_TX_RISE_TUNE_MASK GENMASK(12, 11) + #define U2P_R1_TX_VREF_TUNE_MASK GENMASK(16, 13) + #define U2P_R1_TX_FSLS_TUNE_MASK GENMASK(20, 17) + #define U2P_R1_TX_HSXV_TUNE_MASK GENMASK(22, 21) + #define U2P_R1_OTG_TUNE_MASK GENMASK(25, 23) + #define U2P_R1_SQRX_TUNE_MASK GENMASK(28, 26) + #define U2P_R1_COMP_DIS_TUNE_MASK GENMASK(31, 29) + +/* bits [31:14] are read-only */ +#define U2P_R2 0x8 + #define U2P_R2_TESTDATA_IN_MASK GENMASK(7, 0) + #define U2P_R2_TESTADDR_MASK GENMASK(11, 8) + #define U2P_R2_TESTDATA_OUT_SEL BIT(12) + #define U2P_R2_TESTCLK BIT(13) + #define U2P_R2_TESTDATA_OUT_MASK GENMASK(17, 14) + #define U2P_R2_ACA_PIN_RANGE_C BIT(18) + #define U2P_R2_ACA_PIN_RANGE_B BIT(19) + #define U2P_R2_ACA_PIN_RANGE_A BIT(20) + #define U2P_R2_ACA_PIN_GND BIT(21) + #define U2P_R2_ACA_PIN_FLOAT BIT(22) + #define U2P_R2_CHARGE_DETECT BIT(23) + #define U2P_R2_DEVICE_SESSION_VALID BIT(24) + #define U2P_R2_ADP_PROBE BIT(25) + #define U2P_R2_ADP_SENSE BIT(26) + #define U2P_R2_SESSION_END BIT(27) + #define U2P_R2_VBUS_VALID BIT(28) + #define U2P_R2_B_VALID BIT(29) + #define U2P_R2_A_VALID BIT(30) + #define U2P_R2_ID_DIG BIT(31) + +#define U2P_R3 0xc + +#define RESET_COMPLETE_TIME 500 + +struct phy_meson_gxl_usb2_priv { + struct regmap *regmap; +#if CONFIG_IS_ENABLED(DM_REGULATOR) + struct udevice *phy_supply; +#endif +#if CONFIG_IS_ENABLED(CLK) + struct clk clk; +#endif +}; + +static void phy_meson_gxl_usb2_reset(struct phy_meson_gxl_usb2_priv *priv) +{ + uint val; + + regmap_read(priv->regmap, U2P_R0, &val); + + /* reset the PHY and wait until settings are stabilized */ + val |= U2P_R0_POWER_ON_RESET; + regmap_write(priv->regmap, U2P_R0, val); + udelay(RESET_COMPLETE_TIME); + + val &= ~U2P_R0_POWER_ON_RESET; + regmap_write(priv->regmap, U2P_R0, val); + udelay(RESET_COMPLETE_TIME); +} + +static void +phy_meson_gxl_usb2_set_host_mode(struct phy_meson_gxl_usb2_priv *priv) +{ + uint val; + + regmap_read(priv->regmap, U2P_R0, &val); + val |= U2P_R0_DM_PULLDOWN; + val |= U2P_R0_DP_PULLDOWN; + val &= ~U2P_R0_ID_PULLUP; + regmap_write(priv->regmap, U2P_R0, val); + + phy_meson_gxl_usb2_reset(priv); +} + +static int phy_meson_gxl_usb2_power_on(struct phy *phy) +{ + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb2_priv *priv = dev_get_priv(dev); + uint val; + + regmap_read(priv->regmap, U2P_R0, &val); + /* power on the PHY by taking it out of reset mode */ + val &= ~U2P_R0_POWER_ON_RESET; + regmap_write(priv->regmap, U2P_R0, val); + + phy_meson_gxl_usb2_set_host_mode(priv); + +#if CONFIG_IS_ENABLED(DM_REGULATOR) + if (priv->phy_supply) { + int ret = regulator_set_enable(priv->phy_supply, true); + if (ret) + return ret; + } +#endif + + return 0; +} + +static int phy_meson_gxl_usb2_power_off(struct phy *phy) +{ + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb2_priv *priv = dev_get_priv(dev); + uint val; + + regmap_read(priv->regmap, U2P_R0, &val); + /* power off the PHY by putting it into reset mode */ + val |= U2P_R0_POWER_ON_RESET; + regmap_write(priv->regmap, U2P_R0, val); + +#if CONFIG_IS_ENABLED(DM_REGULATOR) + if (priv->phy_supply) { + int ret = regulator_set_enable(priv->phy_supply, false); + if (ret) { + pr_err("Error disabling PHY supply\n"); + return ret; + } + } +#endif + + return 0; +} + +struct phy_ops meson_gxl_usb2_phy_ops = { + .power_on = phy_meson_gxl_usb2_power_on, + .power_off = phy_meson_gxl_usb2_power_off, +}; + +int meson_gxl_usb2_phy_probe(struct udevice *dev) +{ + struct phy_meson_gxl_usb2_priv *priv = dev_get_priv(dev); + int ret; + + ret = regmap_init_mem(dev, &priv->regmap); + if (ret) + return ret; + +#if CONFIG_IS_ENABLED(CLK) + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret < 0) + return ret; + + ret = clk_enable(&priv->clk); + if (ret && ret != -ENOSYS && ret != -ENOTSUPP) { + pr_err("failed to enable PHY clock\n"); + clk_free(&priv->clk); + return ret; + } +#endif + +#if CONFIG_IS_ENABLED(DM_REGULATOR) + ret = device_get_supply_regulator(dev, "phy-supply", &priv->phy_supply); + if (ret && ret != -ENOENT) { + pr_err("Failed to get PHY regulator\n"); + return ret; + } +#endif + + return 0; +} + +static const struct udevice_id meson_gxl_usb2_phy_ids[] = { + { .compatible = "amlogic,meson-gxl-usb2-phy" }, + { } +}; + +U_BOOT_DRIVER(meson_gxl_usb2_phy) = { + .name = "meson_gxl_usb2_phy", + .id = UCLASS_PHY, + .of_match = meson_gxl_usb2_phy_ids, + .probe = meson_gxl_usb2_phy_probe, + .ops = &meson_gxl_usb2_phy_ops, + .priv_auto_alloc_size = sizeof(struct phy_meson_gxl_usb2_priv), +}; diff --git a/drivers/phy/meson-gxl-usb3.c b/drivers/phy/meson-gxl-usb3.c new file mode 100644 index 0000000..a385fbd --- /dev/null +++ b/drivers/phy/meson-gxl-usb3.c @@ -0,0 +1,201 @@ +/* + * Meson GXL USB3 PHY driver + * + * Copyright (C) 2018 Martin Blumenstingl martin.blumenstingl@googlemail.com + * Copyright (C) 2018 BayLibre, SAS + * Author: Neil Armstrong narmstron@baylibre.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <bitfield.h> +#include <dm.h> +#include <errno.h> +#include <generic-phy.h> +#include <regmap.h> +#include <clk.h> + +#include <linux/bitops.h> +#include <linux/compat.h> +#include <linux/bitfield.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define USB_R0 0x00 + #define USB_R0_P30_FSEL_MASK GENMASK(5, 0) + #define USB_R0_P30_PHY_RESET BIT(6) + #define USB_R0_P30_TEST_POWERDOWN_HSP BIT(7) + #define USB_R0_P30_TEST_POWERDOWN_SSP BIT(8) + #define USB_R0_P30_ACJT_LEVEL_MASK GENMASK(13, 9) + #define USB_R0_P30_TX_BOOST_LEVEL_MASK GENMASK(16, 14) + #define USB_R0_P30_LANE0_TX2RX_LOOPBACK BIT(17) + #define USB_R0_P30_LANE0_EXT_PCLK_REQ BIT(18) + #define USB_R0_P30_PCS_RX_LOS_MASK_VAL_MASK GENMASK(28, 19) + #define USB_R0_U2D_SS_SCALEDOWN_MODE_MASK GENMASK(30, 29) + #define USB_R0_U2D_ACT BIT(31) + +#define USB_R1 0x04 + #define USB_R1_U3H_BIGENDIAN_GS BIT(0) + #define USB_R1_U3H_PME_ENABLE BIT(1) + #define USB_R1_U3H_HUB_PORT_OVERCURRENT_MASK GENMASK(6, 2) + #define USB_R1_U3H_HUB_PORT_PERM_ATTACH_MASK GENMASK(11, 7) + #define USB_R1_U3H_HOST_U2_PORT_DISABLE_MASK GENMASK(15, 12) + #define USB_R1_U3H_HOST_U3_PORT_DISABLE BIT(16) + #define USB_R1_U3H_HOST_PORT_POWER_CONTROL_PRESENT BIT(17) + #define USB_R1_U3H_HOST_MSI_ENABLE BIT(18) + #define USB_R1_U3H_FLADJ_30MHZ_REG_MASK GENMASK(24, 19) + #define USB_R1_P30_PCS_TX_SWING_FULL_MASK GENMASK(31, 25) + +#define USB_R2 0x08 + #define USB_R2_P30_CR_DATA_IN_MASK GENMASK(15, 0) + #define USB_R2_P30_CR_READ BIT(16) + #define USB_R2_P30_CR_WRITE BIT(17) + #define USB_R2_P30_CR_CAP_ADDR BIT(18) + #define USB_R2_P30_CR_CAP_DATA BIT(19) + #define USB_R2_P30_PCS_TX_DEEMPH_3P5DB_MASK GENMASK(25, 20) + #define USB_R2_P30_PCS_TX_DEEMPH_6DB_MASK GENMASK(31, 26) + +#define USB_R3 0x0c + #define USB_R3_P30_SSC_ENABLE BIT(0) + #define USB_R3_P30_SSC_RANGE_MASK GENMASK(3, 1) + #define USB_R3_P30_SSC_REF_CLK_SEL_MASK GENMASK(12, 4) + #define USB_R3_P30_REF_SSP_EN BIT(13) + #define USB_R3_P30_LOS_BIAS_MASK GENMASK(18, 16) + #define USB_R3_P30_LOS_LEVEL_MASK GENMASK(23, 19) + #define USB_R3_P30_MPLL_MULTIPLIER_MASK GENMASK(30, 24) + +#define USB_R4 0x10 + #define USB_R4_P21_PORT_RESET_0 BIT(0) + #define USB_R4_P21_SLEEP_M0 BIT(1) + #define USB_R4_MEM_PD_MASK GENMASK(3, 2) + #define USB_R4_P21_ONLY BIT(4) + +#define USB_R5 0x14 + #define USB_R5_ID_DIG_SYNC BIT(0) + #define USB_R5_ID_DIG_REG BIT(1) + #define USB_R5_ID_DIG_CFG_MASK GENMASK(3, 2) + #define USB_R5_ID_DIG_EN_0 BIT(4) + #define USB_R5_ID_DIG_EN_1 BIT(5) + #define USB_R5_ID_DIG_CURR BIT(6) + #define USB_R5_ID_DIG_IRQ BIT(7) + #define USB_R5_ID_DIG_TH_MASK GENMASK(15, 8) + #define USB_R5_ID_DIG_CNT_MASK GENMASK(23, 16) + +/* read-only register */ +#define USB_R6 0x18 + #define USB_R6_P30_CR_DATA_OUT_MASK GENMASK(15, 0) + #define USB_R6_P30_CR_ACK BIT(16) + +struct phy_meson_gxl_usb3_priv { + struct regmap *regmap; +#if CONFIG_IS_ENABLED(CLK) + struct clk clk; +#endif +}; + +static int +phy_meson_gxl_usb3_set_host_mode(struct phy_meson_gxl_usb3_priv *priv) +{ + uint val; + + regmap_read(priv->regmap, USB_R0, &val); + val &= ~USB_R0_U2D_ACT; + regmap_write(priv->regmap, USB_R0, val); + + regmap_read(priv->regmap, USB_R4, &val); + val &= ~USB_R4_P21_SLEEP_M0; + regmap_write(priv->regmap, USB_R4, val); + + return 0; +} + +static int phy_meson_gxl_usb3_power_on(struct phy *phy) +{ + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); + uint val; + + regmap_read(priv->regmap, USB_R5, &val); + val |= USB_R5_ID_DIG_EN_0; + val |= USB_R5_ID_DIG_EN_1; + val &= ~USB_R5_ID_DIG_TH_MASK; + val |= FIELD_PREP(USB_R5_ID_DIG_TH_MASK, 0xff); + regmap_write(priv->regmap, USB_R5, val); + + return phy_meson_gxl_usb3_set_host_mode(priv); +} + +static int phy_meson_gxl_usb3_power_off(struct phy *phy) +{ + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); + uint val; + + regmap_read(priv->regmap, USB_R5, &val); + val &= ~USB_R5_ID_DIG_EN_0; + val &= ~USB_R5_ID_DIG_EN_1; + regmap_write(priv->regmap, USB_R5, val); + + return 0; +} + +static int phy_meson_gxl_usb3_init(struct phy *phy) +{ + struct udevice *dev = phy->dev; + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); + uint val; + + regmap_read(priv->regmap, USB_R1, &val); + val &= ~USB_R1_U3H_FLADJ_30MHZ_REG_MASK; + val |= FIELD_PREP(USB_R1_U3H_FLADJ_30MHZ_REG_MASK, 0x20); + regmap_write(priv->regmap, USB_R1, val); + + return 0; +} + +struct phy_ops meson_gxl_usb3_phy_ops = { + .init = phy_meson_gxl_usb3_init, + .power_on = phy_meson_gxl_usb3_power_on, + .power_off = phy_meson_gxl_usb3_power_off, +}; + +int meson_gxl_usb3_phy_probe(struct udevice *dev) +{ + struct phy_meson_gxl_usb3_priv *priv = dev_get_priv(dev); + int ret; + + ret = regmap_init_mem(dev, &priv->regmap); + if (ret) + return ret; + +#if CONFIG_IS_ENABLED(CLK) + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret < 0) + return ret; + + ret = clk_enable(&priv->clk); + if (ret && ret != -ENOSYS && ret != -ENOTSUPP) { + pr_err("failed to enable PHY clock\n"); + clk_free(&priv->clk); + return ret; + } +#endif + + return 0; +} + +static const struct udevice_id meson_gxl_usb3_phy_ids[] = { + { .compatible = "amlogic,meson-gxl-usb3-phy" }, + { } +}; + +U_BOOT_DRIVER(meson_gxl_usb3_phy) = { + .name = "meson_gxl_usb3_phy", + .id = UCLASS_PHY, + .of_match = meson_gxl_usb3_phy_ids, + .probe = meson_gxl_usb3_phy_probe, + .ops = &meson_gxl_usb3_phy_ops, + .priv_auto_alloc_size = sizeof(struct phy_meson_gxl_usb3_priv), +};
Commit message is missing, otherwise looks reasonable.
OOps, will add in v2.
Thanks, Neil
Neil Armstrong
