[U-Boot-Users] [PATCH] lpd7a40x register defs, include consolidation
Wolfgang,
I know you dislike large patches with many changes but I am hoping you will accept this. I've changed the register definitions to be in the style preferred by the armlinux folks. Unfortunately, I changed this locally before consolidating the board config includes and improving the SDRAM configuration handling. So I can't really submit the latter changes seperately without many small incremental patches and large headaches on my end.
I will do it if you insist since these changes are quite an improvement for these boards...but it may take a while.
CHANGELOG * Patch by Paul Ruhland, 29 August 2004 - change register definitions to use the __REG style preferred by the arm linux community - add targets to Makefile for all card engine SDRAM configurations - add support for all SDRAM configurations in board config includes, 'sdram_init', and board config.mk - add CONFIG_LPD7A404 to 'ARM base boards' in toplevel README - add CPLD revision detection to handle hardware variations between card-engine revisions - consolidate existing board config includes into generic 'lpd7a40x-10.h' and 'lpd7a40x.h'... differences between boards are small enough not to warrent seperate files
Dear Paul,
Indeed. And I really hate it to receive patches that merge unrelated changes into one big unseparatable thing.
And this is why I have to reject this one.
CHANGELOG
- Patch by Paul Ruhland, 29 August 2004
This is OK with me. [1]
No. I reject this. [2] Please do not pollute the Makefile and MAKEALL (oops, you even forgot to update this one!) with so many different build targets which differ only in the available RAM size of the target. There is existing code (in common/memsize.c) to atomatically detect the available size, so please fix your code and auto-adjust as needed. This will also make your life easier as a board maintainer since you need to have only one image per board type, not a different one for each board configuration.
This is OK with me. [3]
Please feel free to resubmit modifications relating to [1] and [3].
Resubmit [2] after fixing the code.
Paul Ruhland
