[U-Boot-Users] [PATCH 3/5] 83xx: serdes setup routines
This patch adds few routines to configure serdes on 837x targets.
Signed-off-by: Anton Vorontsov avorontsov@ru.mvista.com ---
Rebased on top of today's u-boot-mpc83xx.
cpu/mpc83xx/Makefile | 1 + cpu/mpc83xx/serdes.c | 145 ++++++++++++++++++++++++++++++++++++++++++ include/asm-ppc/fsl_serdes.h | 21 ++++++ 3 files changed, 167 insertions(+), 0 deletions(-) create mode 100644 cpu/mpc83xx/serdes.c create mode 100644 include/asm-ppc/fsl_serdes.h
diff --git a/cpu/mpc83xx/Makefile b/cpu/mpc83xx/Makefile index 7ad7e3e..fcb6a52 100644 --- a/cpu/mpc83xx/Makefile +++ b/cpu/mpc83xx/Makefile @@ -37,6 +37,7 @@ COBJS-y += interrupts.o COBJS-y += spd_sdram.o COBJS-y += ecc.o COBJS-$(CONFIG_QE) += qe_io.o +COBJS-$(CONFIG_FSL_SERDES) += serdes.o COBJS-$(CONFIG_83XX_GENERIC_PCI) += pci.o COBJS-$(CONFIG_OF_LIBFDT) += fdt.o
diff --git a/cpu/mpc83xx/serdes.c b/cpu/mpc83xx/serdes.c new file mode 100644 index 0000000..020c4c8 --- /dev/null +++ b/cpu/mpc83xx/serdes.c @@ -0,0 +1,145 @@ +/* + * Freescale SerDes initialization routine + * + * Copyright (C) 2007 Freescale Semicondutor, Inc. All rights reserved. + * Copyright (C) 2008 MontaVista Software, Inc. All rights reserved. + * + * Author: Li Yang leoli@freescale.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2 of the License, or (at your + * option) any later version. + */ + +#include <config.h> +#include <common.h> +#include <asm/io.h> +#include <asm/fsl_serdes.h> + +/* SerDes registers */ +#define FSL_SRDSCR0_OFFS 0x0 +#define FSL_SRDSCR0_DPP_1V2 0x00008800 +#define FSL_SRDSCR1_OFFS 0x4 +#define FSL_SRDSCR1_PLLBW 0x00000040 +#define FSL_SRDSCR2_OFFS 0x8 +#define FSL_SRDSCR2_VDD_1V2 0x00800000 +#define FSL_SRDSCR2_SEIC_MASK 0x00001c1c +#define FSL_SRDSCR2_SEIC_SATA 0x00001414 +#define FSL_SRDSCR2_SEIC_PEX 0x00001010 +#define FSL_SRDSCR2_SEIC_SGMII 0x00000101 +#define FSL_SRDSCR3_OFFS 0xc +#define FSL_SRDSCR3_KFR_SATA 0x10100000 +#define FSL_SRDSCR3_KPH_SATA 0x04040000 +#define FSL_SRDSCR3_SDFM_SATA_PEX 0x01010000 +#define FSL_SRDSCR3_SDTXL_SATA 0x00000505 +#define FSL_SRDSCR4_OFFS 0x10 +#define FSL_SRDSCR4_PROT_SATA 0x00000808 +#define FSL_SRDSCR4_PROT_PEX 0x00000101 +#define FSL_SRDSCR4_PROT_SGMII 0x00000505 +#define FSL_SRDSCR4_PLANE_X2 0x01000000 +#define FSL_SRDSRSTCTL_OFFS 0x20 +#define FSL_SRDSRSTCTL_RST 0x80000000 +#define FSL_SRDSRSTCTL_SATA_RESET 0xf + +void fsl_setup_serdes(u32 offset, char proto, char rfcks, char vdd) +{ + void *regs = (void *)CFG_IMMR + offset; + u32 tmp; + + /* 1.0V corevdd */ + if (vdd) { + /* DPPE/DPPA = 0 */ + tmp = in_be32(regs + FSL_SRDSCR0_OFFS); + tmp &= ~FSL_SRDSCR0_DPP_1V2; + out_be32(regs + FSL_SRDSCR0_OFFS, tmp); + + /* VDD = 0 */ + tmp = in_be32(regs + FSL_SRDSCR2_OFFS); + tmp &= ~FSL_SRDSCR2_VDD_1V2; + out_be32(regs + FSL_SRDSCR2_OFFS, tmp); + } + + /* protocol specific configuration */ + switch (proto) { + case FSL_SERDES_PROTO_SATA: + /* Set and clear reset bits */ + tmp = in_be32(regs + FSL_SRDSRSTCTL_OFFS); + tmp |= FSL_SRDSRSTCTL_SATA_RESET; + out_be32(regs + FSL_SRDSRSTCTL_OFFS, tmp); + udelay(1000); + tmp &= ~FSL_SRDSRSTCTL_SATA_RESET; + out_be32(regs + FSL_SRDSRSTCTL_OFFS, tmp); + + /* Configure SRDSCR1 */ + tmp = in_be32(regs + FSL_SRDSCR1_OFFS); + tmp &= ~FSL_SRDSCR1_PLLBW; + out_be32(regs + FSL_SRDSCR1_OFFS, tmp); + + /* Configure SRDSCR2 */ + tmp = in_be32(regs + FSL_SRDSCR2_OFFS); + tmp &= ~FSL_SRDSCR2_SEIC_MASK; + tmp |= FSL_SRDSCR2_SEIC_SATA; + out_be32(regs + FSL_SRDSCR2_OFFS, tmp); + + /* Configure SRDSCR3 */ + tmp = FSL_SRDSCR3_KFR_SATA | FSL_SRDSCR3_KPH_SATA | + FSL_SRDSCR3_SDFM_SATA_PEX | + FSL_SRDSCR3_SDTXL_SATA; + out_be32(regs + FSL_SRDSCR3_OFFS, tmp); + + /* Configure SRDSCR4 */ + tmp = rfcks | FSL_SRDSCR4_PROT_SATA; + out_be32(regs + FSL_SRDSCR4_OFFS, tmp); + break; + case FSL_SERDES_PROTO_PEX: + case FSL_SERDES_PROTO_PEX_X2: + /* Configure SRDSCR1 */ + tmp = in_be32(regs + FSL_SRDSCR1_OFFS); + tmp |= FSL_SRDSCR1_PLLBW; + out_be32(regs + FSL_SRDSCR1_OFFS, tmp); + + /* Configure SRDSCR2 */ + tmp = in_be32(regs + FSL_SRDSCR2_OFFS); + tmp &= ~FSL_SRDSCR2_SEIC_MASK; + tmp |= FSL_SRDSCR2_SEIC_PEX; + out_be32(regs + FSL_SRDSCR2_OFFS, tmp); + + /* Configure SRDSCR3 */ + tmp = FSL_SRDSCR3_SDFM_SATA_PEX; + out_be32(regs + FSL_SRDSCR3_OFFS, tmp); + + /* Configure SRDSCR4 */ + tmp = rfcks | FSL_SRDSCR4_PROT_PEX; + if (proto == FSL_SERDES_PROTO_PEX_X2) + tmp |= FSL_SRDSCR4_PLANE_X2; + out_be32(regs + FSL_SRDSCR4_OFFS, tmp); + break; + case FSL_SERDES_PROTO_SGMII: + /* Configure SRDSCR1 */ + tmp = in_be32(regs + FSL_SRDSCR1_OFFS); + tmp &= ~FSL_SRDSCR1_PLLBW; + out_be32(regs + FSL_SRDSCR1_OFFS, tmp); + + /* Configure SRDSCR2 */ + tmp = in_be32(regs + FSL_SRDSCR2_OFFS); + tmp &= ~FSL_SRDSCR2_SEIC_MASK; + tmp |= FSL_SRDSCR2_SEIC_SGMII; + out_be32(regs + FSL_SRDSCR2_OFFS, tmp); + + /* Configure SRDSCR3 */ + out_be32(regs + FSL_SRDSCR3_OFFS, 0); + + /* Configure SRDSCR4 */ + tmp = rfcks | FSL_SRDSCR4_PROT_SGMII; + out_be32(regs + FSL_SRDSCR4_OFFS, tmp); + break; + default: + return; + } + + /* Do a software reset */ + tmp = in_be32(regs + FSL_SRDSRSTCTL_OFFS); + tmp |= FSL_SRDSRSTCTL_RST; + out_be32(regs + FSL_SRDSRSTCTL_OFFS, tmp); +} diff --git a/include/asm-ppc/fsl_serdes.h b/include/asm-ppc/fsl_serdes.h new file mode 100644 index 0000000..733f919 --- /dev/null +++ b/include/asm-ppc/fsl_serdes.h @@ -0,0 +1,21 @@ +#ifndef __FSL_SERDES_H +#define __FSL_SERDES_H + +#include <config.h> + +#define FSL_SERDES_CLK_100 0 +#define FSL_SERDES_CLK_125 1 +#define FSL_SERDES_CLK_150 3 +#define FSL_SERDES_PROTO_SATA 0 +#define FSL_SERDES_PROTO_PEX 1 +#define FSL_SERDES_PROTO_PEX_X2 2 +#define FSL_SERDES_PROTO_SGMII 3 +#define FSL_SERDES_VDD_1V 1 + +#ifdef CONFIG_FSL_SERDES +extern void fsl_setup_serdes(u32 offset, char proto, char rfcks, char vdd); +#else +static void fsl_setup_serdes(u32 offset, char proto, char rfcks, char vdd) {} +#endif /* CONFIG_FSL_SERDES */ + +#endif /* __FSL_SERDES_H */
Anton Vorontsov
