[U-Boot] [U-BOOT] [PATCH v3] powerpc/t104xrdb: Unification of T104xRDB header files
T1040RDB, T1042RDB header files are very similar so merged into new header file T104xRDB. T104xRDB header file can support both T1040RDB and T1042RDB_PI header.
Patch makes following changes -Update Boards.cfg file for T1040RDB and T1042RDB_PI -Add new T104xRDB header file -Delete T1040RDB, T1042RDB_PI header file
Signed-off-by: Vijay Rai vijay.rai@freescale.com Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- v3: - Rebasing to top of the tree boards.cfg | 4 +- include/configs/T1042RDB_PI.h | 695 ---------------------------- include/configs/{T1040RDB.h => T104xRDB.h} | 57 ++- 3 files changed, 35 insertions(+), 721 deletions(-) delete mode 100644 include/configs/T1042RDB_PI.h rename include/configs/{T1040RDB.h => T104xRDB.h} (95%)
diff --git a/boards.cfg b/boards.cfg index 69c8936..5afca26 100644 --- a/boards.cfg +++ b/boards.cfg @@ -932,8 +932,8 @@ Active powerpc mpc85xx - freescale p2041rdb Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SPIFLASH P2041RDB:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale p2041rdb P2041RDB_SRIO_PCIE_BOOT P2041RDB:SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale t1040qds T1040QDS T1040QDS:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com -Active powerpc mpc85xx - freescale t104xrdb T1040RDB T1040RDB:PPC_T1040 Poonam Aggrwal poonam.aggrwal@freescale.com -Active powerpc mpc85xx - freescale t104xrdb T1042RDB_PI T1042RDB_PI:PPC_T1042 Poonam Aggrwal poonam.aggrwal@freescale.com +Active powerpc mpc85xx - freescale t104xrdb T1040RDB T104xRDB:PPC_T1040,T1040RDB Priyanka Jain Priyanka.Jain@freescale.com +Active powerpc mpc85xx - freescale t104xrdb T1042RDB_PI T104xRDB:PPC_T1042,T1042RDB_PI Priyanka Jain Priyanka.Jain@freescale.com Active powerpc mpc85xx - freescale t208xqds T2080QDS T208xQDS:PPC_T2080 - Active powerpc mpc85xx - freescale t208xqds T2080QDS_NAND T208xQDS:PPC_T2080,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale t208xqds T2080QDS_SDCARD T208xQDS:PPC_T2080,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000 - diff --git a/include/configs/T1042RDB_PI.h b/include/configs/T1042RDB_PI.h deleted file mode 100644 index 68656e6..0000000 --- a/include/configs/T1042RDB_PI.h +++ /dev/null @@ -1,695 +0,0 @@ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * T1042RDB_PI board configuration file - */ -#define CONFIG_T104xRDB -#define CONFIG_T1042RDB_PI -#define CONFIG_PHYS_64BIT - -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#endif - -/* High Level Configuration Options */ -#define CONFIG_BOOKE -#define CONFIG_E500 /* BOOKE e500 family */ -#define CONFIG_E500MC /* BOOKE e500mc family */ -#define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ -#define CONFIG_MP /* support multiple processors */ - -#ifndef CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_TEXT_BASE 0xeff40000 -#endif - -#ifndef CONFIG_RESET_VECTOR_ADDRESS -#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc -#endif - -#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ -#define CONFIG_SYS_NUM_CPC CONFIG_NUM_DDR_CONTROLLERS -#define CONFIG_FSL_IFC /* Enable IFC Support */ -#define CONFIG_PCI /* Enable PCI/PCIE */ -#define CONFIG_PCI_INDIRECT_BRIDGE -#define CONFIG_PCIE1 /* PCIE controler 1 */ -#define CONFIG_PCIE2 /* PCIE controler 2 */ -#define CONFIG_PCIE3 /* PCIE controler 3 */ -#define CONFIG_PCIE4 /* PCIE controler 4 */ - -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ - -#define CONFIG_FSL_LAW /* Use common FSL init code */ - -#define CONFIG_ENV_OVERWRITE - -#ifdef CONFIG_SYS_NO_FLASH -#define CONFIG_ENV_IS_NOWHERE -#else -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE -#endif - -#ifndef CONFIG_SYS_NO_FLASH -#if defined(CONFIG_SPIFLASH) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#elif defined(CONFIG_SDCARD) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 1658) -#elif defined(CONFIG_NAND) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (3 * CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif -#else /* CONFIG_SYS_NO_FLASH */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif - -#define CONFIG_SYS_CLK_FREQ 100000000 -#define CONFIG_DDR_CLK_FREQ 66666666 - -/* - * These can be toggled for performance analysis, otherwise use default. - */ -#define CONFIG_SYS_CACHE_STASHING -#define CONFIG_BACKSIDE_L2_CACHE -#define CONFIG_SYS_INIT_L2CSR0 L2CSR0_L2E -#define CONFIG_BTB /* toggle branch predition */ -#define CONFIG_DDR_ECC -#ifdef CONFIG_DDR_ECC -#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER -#define CONFIG_MEM_INIT_VALUE 0xdeadbeef -#endif - -#define CONFIG_ENABLE_36BIT_PHYS - -#define CONFIG_ADDR_MAP -#define CONFIG_SYS_NUM_ADDR_MAP 64 /* number of TLB1 entries */ - -#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00400000 -#define CONFIG_SYS_ALT_MEMTEST -#define CONFIG_PANIC_HANG /* do not reset board on panic */ - -/* - * Config the L3 Cache as L3 SRAM - */ -#define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 - -#define CONFIG_SYS_DCSRBAR 0xf0000000 -#define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull - -/* - * DDR Setup - */ -#define CONFIG_VERY_BIG_RAM -#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE - -/* CONFIG_NUM_DDR_CONTROLLERS is defined in include/asm/config_mpc85xx.h */ -#define CONFIG_DIMM_SLOTS_PER_CTLR 1 -#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) - -#define CONFIG_DDR_SPD -#define CONFIG_SYS_DDR_RAW_TIMING -#define CONFIG_SYS_FSL_DDR3 - -#define CONFIG_SYS_SPD_BUS_NUM 0 -#define SPD_EEPROM_ADDRESS 0x51 - -#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */ - -/* - * IFC Definitions - */ -#define CONFIG_SYS_FLASH_BASE 0xe8000000 -#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) - -#define CONFIG_SYS_NOR_CSPR_EXT (0xf) -#define CONFIG_SYS_NOR_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) -/* NOR Flash Timing Params */ -#define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 -#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ - FTIM0_NOR_TEADC(0x5) | \ - FTIM0_NOR_TEAHC(0x5)) -#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ - FTIM1_NOR_TRAD_NOR(0x1A) |\ - FTIM1_NOR_TSEQRAD_NOR(0x13)) -#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ - FTIM2_NOR_TCH(0x4) | \ - FTIM2_NOR_TWPH(0x0E) | \ - FTIM2_NOR_TWP(0x1c)) -#define CONFIG_SYS_NOR_FTIM3 0x0 - -#define CONFIG_SYS_FLASH_QUIET_TEST -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ - -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} - -/* CPLD on IFC */ -#define CONFIG_SYS_CPLD_BASE 0xffdf0000 -#define CONFIG_SYS_CPLD_BASE_PHYS (0xf00000000ull | CONFIG_SYS_CPLD_BASE) -#define CONFIG_SYS_CSPR2_EXT (0xf) -#define CONFIG_SYS_CSPR2 (CSPR_PHYS_ADDR(CONFIG_SYS_CPLD_BASE_PHYS) \ - | CSPR_PORT_SIZE_8 \ - | CSPR_MSEL_GPCM \ - | CSPR_V) -#define CONFIG_SYS_AMASK2 IFC_AMASK(64*1024) -#define CONFIG_SYS_CSOR2 0x0 -/* CPLD Timing parameters for IFC CS2 */ -#define CONFIG_SYS_CS2_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ - FTIM0_GPCM_TEADC(0x0e) | \ - FTIM0_GPCM_TEAHC(0x0e)) -#define CONFIG_SYS_CS2_FTIM1 (FTIM1_GPCM_TACO(0x0e) | \ - FTIM1_GPCM_TRAD(0x1f)) -#define CONFIG_SYS_CS2_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ - FTIM2_GPCM_TCH(0x0) | \ - FTIM2_GPCM_TWP(0x1f)) -#define CONFIG_SYS_CS2_FTIM3 0x0 - -/* NAND Flash on IFC */ -#define CONFIG_NAND_FSL_IFC -#define CONFIG_SYS_NAND_BASE 0xff800000 -#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) - -#define CONFIG_SYS_NAND_CSPR_EXT (0xf) -#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ - | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ - | CSPR_MSEL_NAND /* MSEL = NAND */ \ - | CSPR_V) -#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) - -#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ - | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ - | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ - | CSOR_NAND_RAL_3 /* RAL = 3Byes */ \ - | CSOR_NAND_PGS_4K /* Page Size = 4K */ \ - | CSOR_NAND_SPRZ_224/* Spare size = 224 */ \ - | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ - -#define CONFIG_SYS_NAND_ONFI_DETECTION - -/* ONFI NAND Flash mode0 Timing Params */ -#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ - FTIM0_NAND_TWP(0x18) | \ - FTIM0_NAND_TWCHT(0x07) | \ - FTIM0_NAND_TWH(0x0a)) -#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ - FTIM1_NAND_TWBE(0x39) | \ - FTIM1_NAND_TRR(0x0e) | \ - FTIM1_NAND_TRP(0x18)) -#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ - FTIM2_NAND_TREH(0x0a) | \ - FTIM2_NAND_TWHRE(0x1e)) -#define CONFIG_SYS_NAND_FTIM3 0x0 - -#define CONFIG_SYS_NAND_DDR_LAW 11 -#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_MTD_NAND_VERIFY_WRITE -#define CONFIG_CMD_NAND - -#define CONFIG_SYS_NAND_BLOCK_SIZE (512 * 1024) - -#if defined(CONFIG_NAND) -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 -#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR_CSPR_EXT -#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR_CSPR -#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 -#else -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 -#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NAND_CSPR_EXT -#define CONFIG_SYS_CSPR1 CONFIG_SYS_NAND_CSPR -#define CONFIG_SYS_AMASK1 CONFIG_SYS_NAND_AMASK -#define CONFIG_SYS_CSOR1 CONFIG_SYS_NAND_CSOR -#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NAND_FTIM0 -#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NAND_FTIM1 -#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NAND_FTIM2 -#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NAND_FTIM3 -#endif - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE - -#if defined(CONFIG_RAMBOOT_PBL) -#define CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_BOARD_EARLY_INIT_R -#define CONFIG_MISC_INIT_R - -#define CONFIG_HWCONFIG - -/* define to use L1 as initial stack */ -#define CONFIG_L1_INIT_RAM -#define CONFIG_SYS_INIT_RAM_LOCK -#define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe0ec000 -/* The assembler doesn't like typecast */ -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ - ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ - CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) -#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_LEN (512 * 1024) -#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) - -/* Serial Port - controlled on board with jumper J8 - * open - index 2 - * shorted - index 1 - */ -#define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) - -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} - -#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x11C500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) -#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) -#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#define CONFIG_SERIAL_MULTI /* Enable both serial ports */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ - -/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT -#define CONFIG_OF_BOARD_SETUP -#define CONFIG_OF_STDOUT_VIA_ALIAS - -/* new uImage format support */ -#define CONFIG_FIT -#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ - -/* I2C */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_FSL /* Use FSL common I2C driver */ -#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed in Hz */ -#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C2_SPEED 400000 /* I2C speed in Hz */ -#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C_OFFSET 0x118000 -#define CONFIG_SYS_FSL_I2C2_OFFSET 0x119000 - -/* I2C bus multiplexer */ -#define I2C_MUX_PCA_ADDR 0x70 - -/* - * RTC configuration - */ -#define RTC -#define CONFIG_RTC_DS1337 1 -#define CONFIG_SYS_I2C_RTC_ADDR 0x68 - -/*DVI encoder*/ -#define CONFIG_HDMI_ENCODER_I2C_ADDR 0x75 - -/* - * eSPI - Enhanced SPI - */ -#define CONFIG_FSL_ESPI -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_STMICRO -#define CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 - -/* - * General PCI - * Memory space is mapped 1-1, but I/O space must start from 0. - */ - -#ifdef CONFIG_PCI -/* controller 1, direct to uli, tgtid 3, Base address 20000 */ -#ifdef CONFIG_PCIE1 -#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ -#endif - -/* controller 2, Slot 2, tgtid 2, Base address 201000 */ -#ifdef CONFIG_PCIE2 -#define CONFIG_SYS_PCIE2_MEM_VIRT 0x90000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS 0xc10000000ull -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ -#endif - -/* controller 3, Slot 1, tgtid 1, Base address 202000 */ -#ifdef CONFIG_PCIE3 -#define CONFIG_SYS_PCIE3_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc20000000ull -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ -#endif - -/* controller 4, Base address 203000 */ -#ifdef CONFIG_PCIE4 -#define CONFIG_SYS_PCIE4_MEM_VIRT 0xb0000000 -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE4_MEM_PHYS 0xc30000000ull -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE4_IO_VIRT 0xf8030000 -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ -#endif - -#define CONFIG_PCI_PNP /* do pci plug-and-play */ -#define CONFIG_E1000 - -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_DOS_PARTITION -#endif /* CONFIG_PCI */ - -/* SATA */ -#define CONFIG_FSL_SATA_V2 -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_LIBATA -#define CONFIG_FSL_SATA - -#define CONFIG_SYS_SATA_MAX_DEVICE 1 -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA - -#define CONFIG_LBA48 -#define CONFIG_CMD_SATA -#define CONFIG_DOS_PARTITION -#define CONFIG_CMD_EXT2 -#endif - -/* -* USB -*/ -#define CONFIG_HAS_FSL_DR_USB - -#ifdef CONFIG_HAS_FSL_DR_USB -#define CONFIG_USB_EHCI - -#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB -#define CONFIG_USB_STORAGE -#define CONFIG_USB_EHCI_FSL -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 -#endif -#endif - -#define CONFIG_MMC - -#ifdef CONFIG_MMC -#define CONFIG_FSL_ESDHC -#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_CMD_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION -#endif - -/* Qman/Bman */ -#ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ -#define CONFIG_SYS_BMAN_NUM_PORTALS 25 -#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 -#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull -#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 -#define CONFIG_SYS_QMAN_NUM_PORTALS 25 -#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 -#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull -#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 - -#define CONFIG_SYS_DPAA_FMAN -#define CONFIG_SYS_DPAA_PME - -/* Default address of microcode for the Linux Fman driver */ -#if defined(CONFIG_SPIFLASH) -/* - * env is stored at 0x100000, sector size is 0x10000, ucode is stored after - * env, so we got 0x110000. - */ -#define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 -#elif defined(CONFIG_SDCARD) -/* - * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is - * about 825KB (1650 blocks), Env is stored after the image, and the env size is - * 0x2000 (16 blocks), 8 + 1650 + 16 = 1674, enlarge it to 1680. - */ -#define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1680) -#elif defined(CONFIG_NAND) -#define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (4 * CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF00000 -#endif -#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 -#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) -#endif /* CONFIG_NOBQFMAN */ - -#ifdef CONFIG_SYS_DPAA_FMAN -#define CONFIG_FMAN_ENET -#define CONFIG_PHY_VITESSE -#define CONFIG_PHY_REALTEK -#endif - -#ifdef CONFIG_FMAN_ENET -#define CONFIG_SYS_RGMII1_PHY_ADDR 0x01 -#define CONFIG_SYS_RGMII2_PHY_ADDR 0x02 - -#define CONFIG_MII /* MII PHY management */ -#define CONFIG_ETHPRIME "FM1@DTSEC4" -#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ -#endif - -/* - * Environment - */ -#define CONFIG_LOADS_ECHO /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ELF -#define CONFIG_CMD_ERRATA -#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SETEXPR - -#ifdef CONFIG_PCI -#define CONFIG_CMD_PCI -#define CONFIG_CMD_NET -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_CMDLINE_EDITING /* Command-line editing */ -#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ -#ifdef CONFIG_CMD_KGDB -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 64 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial map for Linux*/ -#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ - -#ifdef CONFIG_CMD_KGDB -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#endif - -/* - * Environment Configuration - */ -#define CONFIG_ROOTPATH "/opt/nfsroot" -#define CONFIG_BOOTFILE "uImage" -#define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server*/ - -/* default location for tftp and bootm */ -#define CONFIG_LOADADDR 1000000 - -#define CONFIG_BOOTDELAY 10 /*-1 disables auto-boot*/ - -#define CONFIG_BAUDRATE 115200 - -#define __USB_PHY_TYPE utmi - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "hwconfig=fsl_ddr:bank_intlv=cs0_cs1;" \ - "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) ";"\ - "usb2:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ - "netdev=eth0\0" \ - "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ - "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ - "tftpflash=tftpboot $loadaddr $uboot && " \ - "protect off $ubootaddr +$filesize && " \ - "erase $ubootaddr +$filesize && " \ - "cp.b $loadaddr $ubootaddr $filesize && " \ - "protect on $ubootaddr +$filesize && " \ - "cmp.b $loadaddr $ubootaddr $filesize\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=2000000\0" \ - "ramdiskfile=t1040rdb_pi/ramdisk.uboot\0" \ - "fdtaddr=c00000\0" \ - "fdtfile=t1040rdb_pi/t1040rdb_pi.dtb\0" \ - "bdev=sda3\0" \ - "c=ffe\0" - -#define CONFIG_LINUX \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "setenv ramdiskaddr 0x02000000;" \ - "setenv fdtaddr 0x00c00000;" \ - "setenv loadaddr 0x1000000;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" - -#define CONFIG_HDBOOT \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_RAMBOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $ramdiskaddr $ramdiskfile;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" - -#define CONFIG_BOOTCOMMAND CONFIG_LINUX - -#ifdef CONFIG_SECURE_BOOT -#include <asm/fsl_secure_boot.h> -#endif - -#endif /* __CONFIG_H */ diff --git a/include/configs/T1040RDB.h b/include/configs/T104xRDB.h similarity index 95% rename from include/configs/T1040RDB.h rename to include/configs/T104xRDB.h index 395845b..8d2fdb0 100644 --- a/include/configs/T1040RDB.h +++ b/include/configs/T104xRDB.h @@ -1,33 +1,16 @@ /* - * Copyright 2013 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ ++ * Copyright 2014 Freescale Semiconductor, Inc. ++ * ++ * SPDX-License-Identifier: GPL-2.0+ ++ */
#ifndef __CONFIG_H #define __CONFIG_H
/* - * T1040 RDB board configuration file + * T104x RDB board configuration file */ #define CONFIG_T104xRDB -#define CONFIG_T1040RDB #define CONFIG_PHYS_64BIT
#ifdef CONFIG_RAMBOOT_PBL @@ -371,8 +354,21 @@
/* I2C bus multiplexer */ #define I2C_MUX_PCA_ADDR 0x70 +#ifdef CONFIG_T1040RDB #define I2C_MUX_CH_DEFAULT 0x8 +#endif + +#ifdef CONFIG_T1042RDB_PI +/* + * RTC configuration + */ +#define RTC +#define CONFIG_RTC_DS1337 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68
+/*DVI encoder*/ +#define CONFIG_HDMI_ENCODER_I2C_ADDR 0x75 +#endif
/* * eSPI - Enhanced SPI @@ -544,7 +540,9 @@ #endif
#ifdef CONFIG_FMAN_ENET +#ifdef CONFIG_T1040RDB #define CONFIG_SYS_SGMII1_PHY_ADDR 0x03 +#endif #define CONFIG_SYS_RGMII1_PHY_ADDR 0x01 #define CONFIG_SYS_RGMII2_PHY_ADDR 0x02
@@ -564,6 +562,9 @@ */ #include <config_cmd_default.h>
+#ifdef CONFIG_T1042RDB_PI +#define CONFIG_CMD_DATE +#endif #define CONFIG_CMD_DHCP #define CONFIG_CMD_ELF #define CONFIG_CMD_ERRATA @@ -625,6 +626,14 @@
+#ifdef CONFIG_T1040RDB +#define FDTFILE "t1040rdb/t1040rdb.dtb" +#define RAMDISKFILE "t1040rdb/ramdisk.uboot" +#elif CONFIG_T1042RDB_PI +#define FDTFILE "t1040rdb_pi/t1040rdb_pi.dtb" +#define RAMDISKFILE "t1040rdb_pi/ramdisk.uboot" +#endif + #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:bank_intlv=cs0_cs1;" \ "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) ";"\ @@ -640,9 +649,9 @@ "cmp.b $loadaddr $ubootaddr $filesize\0" \ "consoledev=ttyS0\0" \ "ramdiskaddr=2000000\0" \ - "ramdiskfile=t1040rdb/ramdisk.uboot\0" \ + "ramdiskfile=" __stringify(RAMDISKFILE) "\0" \ "fdtaddr=c00000\0" \ - "fdtfile=t1040rdb/t1040rdb.dtb\0" \ + "fdtfile=" __stringify(FDTFILE) "\0" \ "bdev=sda3\0" \ "c=ffe\0"
v3:
Applied to u-boot-mpc85xx/master, thanks.
York
Vijay Rai
York Sun
