[U-Boot] [PATCH v2] pci: add DM based mpc85xx driver
add DM based PCI Configuration space access support for MPC85xx PCI Bridge. This driver is based on arch/powerpc/cpu/mpc85xx/pci.c
In the old driver there is a fix for a hw issue on the TARGET_MPC8555CDS and TARGET_MPC8541CDS boards. As I have no such hardware I did not port this part.
Signed-off-by: Heiko Schocher hs@denx.de
--- Travis build, see: https://travis-ci.org/hsdenx/u-boot-test/builds/597452473
Changes in v2: - added in commit message that this driver is based on arch/powerpc/cpu/mpc85xx/pci.c - add note, that I did not port the fix for hw issue on TARGET_MPC8555CDS and TARGET_MPC8541CDS boards - set LAWs in this driver not in board code as suggested by Zhiqiang
MAINTAINERS | 5 ++ drivers/pci/Kconfig | 7 ++ drivers/pci/Makefile | 1 + drivers/pci/pci_mpc85xx.c | 158 ++++++++++++++++++++++++++++++++++++++ 4 files changed, 171 insertions(+) create mode 100644 drivers/pci/pci_mpc85xx.c
diff --git a/MAINTAINERS b/MAINTAINERS index 2ef2976855..c9cd817b59 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -692,6 +692,11 @@ S: Maintained F: drivers/pci_endpoint/ F: include/pci_ep.h
+PCI MPC85xx +M: Heiko Schocher hs@denx.de +S: Maintained +F: drivers/pci/pci_mpc85xx.c + POWER M: Jaehoon Chung jh80.chung@samsung.com S: Maintained diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 19e7b50046..71aab85ed3 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -68,6 +68,13 @@ config PCIE_FSL PowerPC MPC85xx, MPC86xx, B series, P series and T series SoCs. This driver does not support SRIO_PCIE_BOOT feature.
+config PCI_MPC85XX + bool "MPC85XX PowerPC PCI support" + depends on DM_PCI + help + Say Y here if you want to enable PCI controller support on FSL + PowerPC MPC85xx SoC. + config PCI_RCAR_GEN2 bool "Renesas RCar Gen2 PCIe driver" depends on DM_PCI diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index b1d3dc8610..856ac71a1c 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -19,6 +19,7 @@ obj-$(CONFIG_PCIE_ECAM_GENERIC) += pcie_ecam_generic.o obj-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o obj-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o obj-$(CONFIG_PCI_GT64120) += pci_gt64120.o +obj-$(CONFIG_PCI_MPC85XX) += pci_mpc85xx.o obj-$(CONFIG_PCI_MSC01) += pci_msc01.o obj-$(CONFIG_PCIE_IMX) += pcie_imx.o obj-$(CONFIG_FTPCI100) += pci_ftpci100.o diff --git a/drivers/pci/pci_mpc85xx.c b/drivers/pci/pci_mpc85xx.c new file mode 100644 index 0000000000..e58ab60ee0 --- /dev/null +++ b/drivers/pci/pci_mpc85xx.c @@ -0,0 +1,158 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2019 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + */ +#include <common.h> +#include <asm/cpm_85xx.h> +#include <pci.h> +#include <dm.h> +#include <asm/fsl_law.h> + +struct mpc85xx_pci_priv { + void __iomem *cfg_addr; + void __iomem *cfg_data; +}; + +static int mpc85xx_pci_dm_read_config(struct udevice *dev, pci_dev_t bdf, + uint offset, ulong *value, + enum pci_size_t size) +{ + struct mpc85xx_pci_priv *priv = dev_get_priv(dev); + u32 addr; + + addr = bdf | (offset & 0xfc) | ((offset & 0xf00) << 16) | 0x80000000; + out_be32(priv->cfg_addr, addr); + sync(); + *value = pci_conv_32_to_size(in_le32(priv->cfg_data), offset, size); + + return 0; +} + +static int mpc85xx_pci_dm_write_config(struct udevice *dev, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + struct mpc85xx_pci_priv *priv = dev_get_priv(dev); + u32 addr; + + addr = bdf | (offset & 0xfc) | ((offset & 0xf00) << 16) | 0x80000000; + out_be32(priv->cfg_addr, addr); + sync(); + out_le32(priv->cfg_data, pci_conv_size_to_32(0, value, offset, size)); + + return 0; +} + +static int +mpc85xx_pci_dm_setup_laws(struct pci_region *io, struct pci_region *mem, + struct pci_region *pre) +{ + /* + * Unfortunately we have defines for this addresse, + * as we have to setup the TLB, and at this stage + * we have no access to DT ... may we check here + * if the value in the define is the same ? + */ + if (mem) + set_next_law(mem->phys_start, law_size_bits(mem->size), + LAW_TRGT_IF_PCI); + if (io) + set_next_law(io->phys_start, law_size_bits(io->size), + LAW_TRGT_IF_PCI); + if (pre) + set_next_law(pre->phys_start, law_size_bits(pre->size), + LAW_TRGT_IF_PCI); + + return 0; +} + +static int mpc85xx_pci_dm_probe(struct udevice *dev) +{ + struct mpc85xx_pci_priv *priv = dev_get_priv(dev); + struct pci_region *io; + struct pci_region *mem; + struct pci_region *pre; + int count; + ccsr_pcix_t *pcix; + + count = pci_get_regions(dev, &io, &mem, &pre); + if (count != 2) { + printf("%s: wrong count of regions %d only 2 allowed\n", + __func__, count); + return -EINVAL; + } + + mpc85xx_pci_dm_setup_laws(io, mem, pre); + + pcix = priv->cfg_addr; + /* BAR 1: memory */ + out_be32(&pcix->potar1, (mem->bus_start >> 12) & 0x000fffff); + out_be32(&pcix->potear1, 0); + out_be32(&pcix->powbar1, (mem->phys_start >> 12) & 0x000fffff); + out_be32(&pcix->powbear1, 0); + out_be32(&pcix->powar1, (POWAR_EN | POWAR_MEM_READ | + POWAR_MEM_WRITE | (__ilog2(mem->size) - 1))); + + /* BAR 1: IO */ + out_be32(&pcix->potar2, (io->bus_start >> 12) & 0x000fffff); + out_be32(&pcix->potear2, 0); + out_be32(&pcix->powbar2, (io->phys_start >> 12) & 0x000fffff); + out_be32(&pcix->powbear2, 0); + out_be32(&pcix->powar2, (POWAR_EN | POWAR_IO_READ | + POWAR_IO_WRITE | (__ilog2(io->size) - 1))); + + out_be32(&pcix->pitar1, 0); + out_be32(&pcix->piwbar1, 0); + out_be32(&pcix->piwar1, (PIWAR_EN | PIWAR_PF | PIWAR_LOCAL | + PIWAR_READ_SNOOP | PIWAR_WRITE_SNOOP | PIWAR_MEM_2G)); + + out_be32(&pcix->powar3, 0); + out_be32(&pcix->powar4, 0); + out_be32(&pcix->piwar2, 0); + out_be32(&pcix->piwar3, 0); + + return 0; +} + +static int mpc85xx_pci_dm_remove(struct udevice *dev) +{ + return 0; +} + +static int mpc85xx_pci_ofdata_to_platdata(struct udevice *dev) +{ + struct mpc85xx_pci_priv *priv = dev_get_priv(dev); + fdt_addr_t addr; + + addr = devfdt_get_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + priv->cfg_addr = (void __iomem *)addr; + addr += 4; + priv->cfg_data = (void __iomem *)addr; + + return 0; +} + +static const struct dm_pci_ops mpc85xx_pci_ops = { + .read_config = mpc85xx_pci_dm_read_config, + .write_config = mpc85xx_pci_dm_write_config, +}; + +static const struct udevice_id mpc85xx_pci_ids[] = { + { .compatible = "fsl,mpc8540-pci" }, + { } +}; + +U_BOOT_DRIVER(mpc85xx_pci) = { + .name = "mpc85xx_pci", + .id = UCLASS_PCI, + .of_match = mpc85xx_pci_ids, + .ops = &mpc85xx_pci_ops, + .probe = mpc85xx_pci_dm_probe, + .remove = mpc85xx_pci_dm_remove, + .ofdata_to_platdata = mpc85xx_pci_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct mpc85xx_pci_priv), +};
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Heiko Schocher Sent: Monday, October 14, 2019 3:00 PM To: u-boot@lists.denx.de Cc: Heinrich Schuchardt xypron.glpk@gmx.de; Z.q. Hou zhiqiang.hou@nxp.com; Michal Simek michal.simek@xilinx.com; Ryder Lee ryder.lee@mediatek.com; Stefan Roese sr@denx.de Subject: [U-Boot] [PATCH v2] pci: add DM based mpc85xx driver
Travis build, see: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftravis- ci.org%2Fhsdenx%2Fu-boot- test%2Fbuilds%2F597452473&data=02%7C01%7Cpriyanka.jain%40nxp.co m%7Cec182e150f6a4dd75f6408d750891bbc%7C686ea1d3bc2b4c6fa92cd99c5c 301635%7C0%7C0%7C637066422116723776&sdata=h3jdy9SofUyvjzm5Jdy NTnWqphxOLRnzEkxYBguxYrw%3D&reserved=0
Changes in v2:
+config PCI_MPC85XX
- bool "MPC85XX PowerPC PCI support"
- depends on DM_PCI
- help
- (C) Copyright 2019
- Heiko Schocher, DENX Software Engineering, hs@denx.de.
- void __iomem *cfg_addr;
- void __iomem *cfg_data;
- struct mpc85xx_pci_priv *priv = dev_get_priv(dev);
- u32 addr;
- addr = bdf | (offset & 0xfc) | ((offset & 0xf00) << 16) | 0x80000000;
- out_be32(priv->cfg_addr, addr);
- sync();
- *value = pci_conv_32_to_size(in_le32(priv->cfg_data), offset, size);
- u32 addr;
- sync();
- out_le32(priv->cfg_data, pci_conv_size_to_32(0, value, offset, size));
- if (mem)
LAW_TRGT_IF_PCI);
- if (io)
LAW_TRGT_IF_PCI);
- if (pre)
LAW_TRGT_IF_PCI);
+static int mpc85xx_pci_dm_probe(struct udevice *dev) {
- struct pci_region *io;
- struct pci_region *mem;
- struct pci_region *pre;
- int count;
- ccsr_pcix_t *pcix;
- count = pci_get_regions(dev, &io, &mem, &pre);
- if (count != 2) {
__func__, count);
return -EINVAL;
- mpc85xx_pci_dm_setup_laws(io, mem, pre);
- pcix = priv->cfg_addr;
- /* BAR 1: memory */
- out_be32(&pcix->potar1, (mem->bus_start >> 12) & 0x000fffff);
- out_be32(&pcix->potear1, 0);
- out_be32(&pcix->powbar1, (mem->phys_start >> 12) & 0x000fffff);
- out_be32(&pcix->powbear1, 0);
- out_be32(&pcix->powar1, (POWAR_EN | POWAR_MEM_READ |
- /* BAR 1: IO */
- out_be32(&pcix->potar2, (io->bus_start >> 12) & 0x000fffff);
- out_be32(&pcix->potear2, 0);
- out_be32(&pcix->powbar2, (io->phys_start >> 12) & 0x000fffff);
- out_be32(&pcix->powbear2, 0);
- out_be32(&pcix->powar2, (POWAR_EN | POWAR_IO_READ |
- out_be32(&pcix->pitar1, 0);
- out_be32(&pcix->piwbar1, 0);
- out_be32(&pcix->piwar1, (PIWAR_EN | PIWAR_PF | PIWAR_LOCAL |
PIWAR_MEM_2G));
- out_be32(&pcix->powar3, 0);
- out_be32(&pcix->powar4, 0);
- out_be32(&pcix->piwar2, 0);
- out_be32(&pcix->piwar3, 0);
+static int mpc85xx_pci_dm_remove(struct udevice *dev) {
+static int mpc85xx_pci_ofdata_to_platdata(struct udevice *dev) {
- fdt_addr_t addr;
- addr = devfdt_get_addr_index(dev, 0);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- priv->cfg_addr = (void __iomem *)addr;
- addr += 4;
- priv->cfg_data = (void __iomem *)addr;
- .read_config = mpc85xx_pci_dm_read_config,
- .write_config = mpc85xx_pci_dm_write_config,
- { .compatible = "fsl,mpc8540-pci" },
- .name = "mpc85xx_pci",
- .id = UCLASS_PCI,
- .of_match = mpc85xx_pci_ids,
- .ops = &mpc85xx_pci_ops,
- .probe = mpc85xx_pci_dm_probe,
- .remove = mpc85xx_pci_dm_remove,
- .ofdata_to_platdata = mpc85xx_pci_ofdata_to_platdata,
- .priv_auto_alloc_size = sizeof(struct mpc85xx_pci_priv),
2.21.0
U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.de nx.de%2Flistinfo%2Fu- boot&data=02%7C01%7Cpriyanka.jain%40nxp.com%7Cec182e150f6a4dd 75f6408d750891bbc%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C6 37066422116723776&sdata=uSVBiA5dF7j1dXC0NvsvNTVL3ZhaX2qEydW5 %2FGWkSDM%3D&reserved=0
Applied to mpc85xx master, awaiting upstream.
Thanks priyankajain
Heiko Schocher
Priyanka Jain
