[U-Boot-Users] [PATCH 5/8] [SH] SuperH support
6 May
2007
6 May
'07
10:14 p.m.
Hi, all.
I wrote the code in which u-boot was supported for SH [0]. I am maintaining SH-IPL+g[1] that is the boot loader only for SH now. However, I think that I will maintain u-boot in the future.
Now, 0. SDRAM controler 1. Internal serial device 2. Flash 3. Timer working.
I plan to adopt it as a boot loader of the main in the future though only several boards are supported now.
Please apply this patch .
regards, Nobuhiro
[0] : http://america.renesas.com/fmwk.jsp?cnt=superh_family_landing.jsp&fp=/pr... [1] : http://git.nigauri.org
Nobuhiro Iwamatsu
E-Mail : iwamatsu@nigauri.org
GPG ID : 3170EBE9
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org
diff --git a/include/asm-sh/posix_types.h b/include/asm-sh/posix_types.h
new file mode 100644
index 0000000..4bb9f7e
--- /dev/null
+++ b/include/asm-sh/posix_types.h
@@ -0,0 +1,123 @@
+#ifndef __ASM_SH_POSIX_TYPES_H
+#define __ASM_SH_POSIX_TYPES_H
+ * This file is generally used by user-level software, so you need to
+ * be a little careful about namespace pollution etc. Also, we cannot
+ * assume GCC is being used.
+typedef unsigned short __kernel_dev_t;
+typedef unsigned long __kernel_ino_t;
+typedef unsigned short __kernel_mode_t;
+typedef unsigned short __kernel_nlink_t;
+typedef long __kernel_off_t;
+typedef int __kernel_pid_t;
+typedef unsigned short __kernel_ipc_pid_t;
+typedef unsigned short __kernel_uid_t;
+typedef unsigned short __kernel_gid_t;
+typedef unsigned int __kernel_size_t;
+typedef int __kernel_ssize_t;
+typedef int __kernel_ptrdiff_t;
+typedef long __kernel_time_t;
+typedef long __kernel_suseconds_t;
+typedef long __kernel_clock_t;
+typedef int __kernel_timer_t;
+typedef int __kernel_clockid_t;
+typedef int __kernel_daddr_t;
+typedef char * __kernel_caddr_t;
+typedef unsigned short __kernel_uid16_t;
+typedef unsigned short __kernel_gid16_t;
+typedef unsigned int __kernel_uid32_t;
+typedef unsigned int __kernel_gid32_t;
+typedef unsigned short __kernel_old_uid_t;
+typedef unsigned short __kernel_old_gid_t;
+typedef unsigned short __kernel_old_dev_t;
+#ifdef __GNUC__
+typedef long long __kernel_loff_t;
+typedef struct {
+#if defined(__KERNEL__) || defined(__USE_ALL)
+ int val[2];
+#else /* !defined(__KERNEL__) && !defined(__USE_ALL) */
+ int __val[2];
+#endif /* !defined(__KERNEL__) && !defined(__USE_ALL) */
+} __kernel_fsid_t;
+#if defined(__KERNEL__) || !defined(__GLIBC__) || (__GLIBC__ < 2)
+#undef __FD_SET
+static __inline__ void __FD_SET(unsigned long __fd, __kernel_fd_set *__fdsetp)
+ unsigned long __tmp = __fd / __NFDBITS;
+ unsigned long __rem = __fd % __NFDBITS;
+ __fdsetp->fds_bits[__tmp] |= (1UL<<__rem);
+#undef __FD_CLR
+static __inline__ void __FD_CLR(unsigned long __fd, __kernel_fd_set *__fdsetp)
+ __fdsetp->fds_bits[__tmp] &= ~(1UL<<__rem);
+#undef __FD_ISSET
+static __inline__ int __FD_ISSET(unsigned long __fd, const __kernel_fd_set *__p)
+ return (__p->fds_bits[__tmp] & (1UL<<__rem)) != 0;
+ * This will unroll the loop for the normal constant case (8 ints,
+ * for a 256-bit fd_set)
+#undef __FD_ZERO
+static __inline__ void __FD_ZERO(__kernel_fd_set *__p)
+ unsigned long *__tmp = __p->fds_bits;
+ int __i;
+ if (__builtin_constant_p(__FDSET_LONGS)) {
+ switch (__FDSET_LONGS) {
+ case 16:
+ __tmp[ 0] = 0; __tmp[ 1] = 0;
+ __tmp[ 2] = 0; __tmp[ 3] = 0;
+ __tmp[ 4] = 0; __tmp[ 5] = 0;
+ __tmp[ 6] = 0; __tmp[ 7] = 0;
+ __tmp[ 8] = 0; __tmp[ 9] = 0;
+ __tmp[10] = 0; __tmp[11] = 0;
+ __tmp[12] = 0; __tmp[13] = 0;
+ __tmp[14] = 0; __tmp[15] = 0;
+ return;
+ case 8:
+ return;
+ case 4:
+ return;
+ __i = __FDSET_LONGS;
+ while (__i) {
+ __i--;
+ *__tmp = 0;
+ __tmp++;
+#endif /* defined(__KERNEL__) || !defined(__GLIBC__) || (__GLIBC__ < 2) */
+#endif /* __ASM_SH_POSIX_TYPES_H */
diff --git a/include/asm-sh/processor.h b/include/asm-sh/processor.h
index 0000000..bb9a35f
--- /dev/null
+++ b/include/asm-sh/processor.h
@@ -0,0 +1,8 @@
+#ifndef _ASM_SH_PROCESSOR_H_
+#define _ASM_SH_PROCESSOR_H_
+#if defined CONFIG_SH3
+# include <asm/cpu_sh3.h>
+#elif defined (CONFIG_SH4)
+# include <asm/cpu_sh4.h>
diff --git a/include/asm-sh/ptrace.h b/include/asm-sh/ptrace.h
index 0000000..14cc1ac
--- /dev/null
+++ b/include/asm-sh/ptrace.h
@@ -0,0 +1,112 @@
+#ifndef __ASM_SH_PTRACE_H
+#define __ASM_SH_PTRACE_H
+ * Copyright (C) 1999, 2000 Niibe Yutaka
+ * from linux kernel code.
+ * GCC defines register number like this:
+ * 0 - 15 are integer registers
+ * 17 - 22 are control/special registers
+ * 24 - 39 fp registers
+ * 40 - 47 xd registers
+ * 48 - fpscr register
+ * We follows above, except:
+ * 16 --- program counter (PC)
+ * 22 --- syscall #
+ * 23 --- floating point communication register
+#define REG_REG0 0
+#define REG_REG15 15
+#define REG_PC 16
+#define REG_PR 17
+#define REG_SR 18
+#define REG_GBR 19
+#define REG_MACH 20
+#define REG_MACL 21
+#define REG_SYSCALL 22
+#define REG_FPREG0 23
+#define REG_FPREG15 38
+#define REG_XFREG0 39
+#define REG_XFREG15 54
+#define REG_FPSCR 55
+#define REG_FPUL 56
+/* options set using PTRACE_SETOPTIONS */
+#define PTRACE_O_TRACESYSGOOD 0x00000001
+ * This struct defines the way the registers are stored on the
+ * kernel stack during a system call or other kernel entry.
+struct pt_regs {
+ unsigned long regs[16];
+ unsigned long pc;
+ unsigned long pr;
+ unsigned long sr;
+ unsigned long gbr;
+ unsigned long mach;
+ unsigned long macl;
+ long tra;
+ * This struct defines the way the DSP registers are stored on the
+struct pt_dspregs {
+ unsigned long a1;
+ unsigned long a0g;
+ unsigned long a1g;
+ unsigned long m0;
+ unsigned long m1;
+ unsigned long a0;
+ unsigned long x0;
+ unsigned long x1;
+ unsigned long y0;
+ unsigned long y1;
+ unsigned long dsr;
+ unsigned long rs;
+ unsigned long re;
+ unsigned long mod;
+#define PTRACE_GETDSPREGS 55
+#define PTRACE_SETDSPREGS 56
+#ifdef __KERNEL__
+#define user_mode(regs) (((regs)->sr & 0x40000000)==0)
+#define instruction_pointer(regs) ((regs)->pc)
+extern void show_regs(struct pt_regs *);
+#ifdef CONFIG_SH_DSP
+#define task_pt_regs(task) \
+ ((struct pt_regs *) (task_stack_page(task) + THREAD_SIZE \
+ - sizeof(struct pt_dspregs) - sizeof(unsigned long)) - 1)
+#else
+ - sizeof(unsigned long)) - 1)
+static inline unsigned long profile_pc(struct pt_regs *regs)
+ unsigned long pc = instruction_pointer(regs);
+ if (pc >= 0xa0000000UL && pc < 0xc0000000UL)
+ pc -= 0x20000000;
+ return pc;
+#endif /* __ASM_SH_PTRACE_H */
diff --git a/include/asm-sh/string.h b/include/asm-sh/string.h
index 0000000..a78ef81
--- /dev/null
+++ b/include/asm-sh/string.h
@@ -0,0 +1,132 @@
+#ifndef __ASM_SH_STRING_H
+#define __ASM_SH_STRING_H
+ * Copyright (C) 1999 Niibe Yutaka
+ * But consider these trivial functions to be public domain.
+#define __HAVE_ARCH_STRCPY
+static inline char *strcpy(char *__dest, const char *__src)
+ register char *__xdest = __dest;
+ unsigned long __dummy;
+ __asm__ __volatile__("1:\n\t"
+ "mov.b @%1+, %2\n\t"
+ "mov.b %2, @%0\n\t"
+ "cmp/eq #0, %2\n\t"
+ "bf/s 1b\n\t"
+ " add #1, %0\n\t"
+ : "=r" (__dest), "=r" (__src), "=&z" (__dummy)
+ : "0" (__dest), "1" (__src)
+ : "memory", "t");
+ return __xdest;
+#define __HAVE_ARCH_STRNCPY
+static inline char *strncpy(char *__dest, const char *__src, size_t __n)
+ if (__n == 0)
+ return __xdest;
+ "1:\n"
+ "bt/s 2f\n\t"
+ " cmp/eq %5,%1\n\t"
+ "bf/s 1b\n\t"
+ " add #1, %0\n"
+ "2:"
+ : "0" (__dest), "1" (__src), "r" (__src+__n)
+ : "memory", "t");
+ return __xdest;
+#define __HAVE_ARCH_STRCMP
+static inline int strcmp(const char *__cs, const char *__ct)
+ register int __res;
+ "mov.b @%1+, %3\n"
+ "1:\n\t"
+ "mov.b @%0+, %2\n\t"
+ "cmp/eq #0, %3\n\t"
+ "bt 2f\n\t"
+ "cmp/eq %2, %3\n\t"
+ "bt/s 1b\n\t"
+ " mov.b @%1+, %3\n\t"
+ "add #-2, %1\n\t"
+ "mov.b @%1, %3\n\t"
+ "sub %3, %2\n"
+ "2:"
+ : "=r" (__cs), "=r" (__ct), "=&r" (__res), "=&z" (__dummy)
+ : "0" (__cs), "1" (__ct)
+ : "t");
+ return __res;
+#define __HAVE_ARCH_STRNCMP
+static inline int strncmp(const char *__cs, const char *__ct, size_t __n)
+ if (__n == 0)
+ return 0;
+ "1:\n\t"
+ "cmp/eq %6, %0\n\t"
+ "bt/s 2f\n\t"
+ " cmp/eq #0, %3\n\t"
+ "bt/s 3f\n\t"
+ " cmp/eq %3, %2\n\t"
+ "bt/s 1b\n\t"
+ "add #-2, %1\n\t"
+ "mov.b @%1, %3\n"
+ "2:\n\t"
+ "sub %3, %2\n"
+ "3:"
+ :"=r" (__cs), "=r" (__ct), "=&r" (__res), "=&z" (__dummy)
+ : "0" (__cs), "1" (__ct), "r" (__cs+__n)
+ : "t");
+ return __res;
+#undef __HAVE_ARCH_MEMSET
+extern void *memset(void *__s, int __c, size_t __count);
+#undef __HAVE_ARCH_MEMCPY
+extern void *memcpy(void *__to, __const__ void *__from, size_t __n);
+#undef __HAVE_ARCH_MEMMOVE
+extern void *memmove(void *__dest, __const__ void *__src, size_t __n);
+#undef __HAVE_ARCH_MEMCHR
+extern void *memchr(const void *__s, int __c, size_t __n);
+#undef __HAVE_ARCH_STRLEN
+extern size_t strlen(const char *);
+/* arch/sh/lib/strcasecmp.c */
+extern int strcasecmp(const char *, const char *);
+#endif /* __ASM_SH_STRING_H */
6575
Nobuhiro Iwamatsu
