[U-Boot] [PATCH v2 0/3] ARM: meson: add p200 and p201 boards
This adds support for p200 and p201 reference boards from amlogic
Mohammad Rasim (3): ARM: dts: meson: add p200 and p201 boards ARM: board: meson: add p201 board ARM: board: meson: add p200 board
arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-gxbb-p200.dts | 99 +++++++++++ arch/arm/dts/meson-gxbb-p201.dts | 26 +++ arch/arm/dts/meson-gxbb-p20x.dtsi | 247 ++++++++++++++++++++++++++++ board/amlogic/odroid-c2/README.p200 | 103 ++++++++++++ board/amlogic/p201/MAINTAINERS | 6 + board/amlogic/p201/Makefile | 5 + board/amlogic/p201/README.p201 | 103 ++++++++++++ board/amlogic/p201/p201.c | 43 +++++ configs/p200_defconfig | 41 +++++ configs/p201_defconfig | 41 +++++ 11 files changed, 716 insertions(+) create mode 100644 arch/arm/dts/meson-gxbb-p200.dts create mode 100644 arch/arm/dts/meson-gxbb-p201.dts create mode 100644 arch/arm/dts/meson-gxbb-p20x.dtsi create mode 100644 board/amlogic/odroid-c2/README.p200 create mode 100644 board/amlogic/p201/MAINTAINERS create mode 100644 board/amlogic/p201/Makefile create mode 100644 board/amlogic/p201/README.p201 create mode 100644 board/amlogic/p201/p201.c create mode 100644 configs/p200_defconfig create mode 100644 configs/p201_defconfig
-- 2.21.0
This adds the device trees for p200 and p201 boards. Synced from kernel 5.0.0 revision a667cb7a94d48a483fb5d6006fe04a440f1a42ce.
Signed-off-by: Mohammad Rasim mohammad.rasim96@gmail.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-gxbb-p200.dts | 99 ++++++++++++ arch/arm/dts/meson-gxbb-p201.dts | 26 ++++ arch/arm/dts/meson-gxbb-p20x.dtsi | 247 ++++++++++++++++++++++++++++++ 4 files changed, 374 insertions(+) create mode 100644 arch/arm/dts/meson-gxbb-p200.dts create mode 100644 arch/arm/dts/meson-gxbb-p201.dts create mode 100644 arch/arm/dts/meson-gxbb-p20x.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 2a040b20a5..adf5f26fac 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -60,6 +60,8 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-nanopi-k2.dtb \ meson-gxbb-odroidc2.dtb \ meson-gxbb-nanopi-k2.dtb \ + meson-gxbb-p200.dtb \ + meson-gxbb-p201.dtb \ meson-gxl-s905x-p212.dtb \ meson-gxl-s905x-libretech-cc.dtb \ meson-gxl-s905x-khadas-vim.dtb \ diff --git a/arch/arm/dts/meson-gxbb-p200.dts b/arch/arm/dts/meson-gxbb-p200.dts new file mode 100644 index 0000000000..9d2406a7c4 --- /dev/null +++ b/arch/arm/dts/meson-gxbb-p200.dts @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2016 Andreas Färber + * Copyright (c) 2016 BayLibre, Inc. + * Author: Kevin Hilman khilman@kernel.org + */ + +/dts-v1/; + +#include "meson-gxbb-p20x.dtsi" +#include <dt-bindings/input/input.h> + +/ { + compatible = "amlogic,p200", "amlogic,meson-gxbb"; + model = "Amlogic Meson GXBB P200 Development Board"; + + avdd18_usb_adc: regulator-avdd18_usb_adc { + compatible = "regulator-fixed"; + regulator-name = "AVDD18_USB_ADC"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + adc_keys { + compatible = "adc-keys"; + io-channels = <&saradc 0>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + + button-home { + label = "Home"; + linux,code = <KEY_HOME>; + press-threshold-microvolt = <900000>; /* 50% */ + }; + + button-esc { + label = "Esc"; + linux,code = <KEY_ESC>; + press-threshold-microvolt = <684000>; /* 38% */ + }; + + button-up { + label = "Volume Up"; + linux,code = <KEY_VOLUMEUP>; + press-threshold-microvolt = <468000>; /* 26% */ + }; + + button-down { + label = "Volume Down"; + linux,code = <KEY_VOLUMEDOWN>; + press-threshold-microvolt = <252000>; /* 14% */ + }; + + button-menu { + label = "Menu"; + linux,code = <KEY_MENU>; + press-threshold-microvolt = <0>; /* 0% */ + }; + }; +}; + +ðmac { + status = "okay"; + pinctrl-0 = <ð_rgmii_pins>; + pinctrl-names = "default"; + phy-handle = <ð_phy0>; + phy-mode = "rgmii"; + + amlogic,tx-delay-ns = <2>; + + snps,reset-gpio = <&gpio GPIOZ_14 0>; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-active-low; + + mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + + eth_phy0: ethernet-phy@3 { + /* Micrel KSZ9031 (0x00221620) */ + reg = <3>; + interrupt-parent = <&gpio_intc>; + /* MAC_INTR on GPIOZ_15 */ + interrupts = <29 IRQ_TYPE_LEVEL_LOW>; + }; + }; +}; + +&i2c_B { + status = "okay"; + pinctrl-0 = <&i2c_b_pins>; + pinctrl-names = "default"; +}; + +&saradc { + status = "okay"; + vref-supply = <&avdd18_usb_adc>; +}; diff --git a/arch/arm/dts/meson-gxbb-p201.dts b/arch/arm/dts/meson-gxbb-p201.dts new file mode 100644 index 0000000000..56e0dd1ff5 --- /dev/null +++ b/arch/arm/dts/meson-gxbb-p201.dts @@ -0,0 +1,26 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2016 Andreas Färber + * Copyright (c) 2016 BayLibre, Inc. + * Author: Kevin Hilman khilman@kernel.org + */ + +/dts-v1/; + +#include "meson-gxbb-p20x.dtsi" + +/ { + compatible = "amlogic,p201", "amlogic,meson-gxbb"; + model = "Amlogic Meson GXBB P201 Development Board"; +}; + +ðmac { + status = "okay"; + pinctrl-0 = <ð_rmii_pins>; + pinctrl-names = "default"; + phy-mode = "rmii"; + + snps,reset-gpio = <&gpio GPIOZ_14 0>; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-active-low; +}; diff --git a/arch/arm/dts/meson-gxbb-p20x.dtsi b/arch/arm/dts/meson-gxbb-p20x.dtsi new file mode 100644 index 0000000000..0be0f2a5d2 --- /dev/null +++ b/arch/arm/dts/meson-gxbb-p20x.dtsi @@ -0,0 +1,247 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2016 Andreas Färber + * Copyright (c) 2016 BayLibre, Inc. + * Author: Kevin Hilman khilman@kernel.org + */ + +#include "meson-gxbb.dtsi" + +/ { + aliases { + serial0 = &uart_AO; + ethernet0 = ðmac; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x40000000>; + }; + + usb_pwr: regulator-usb-pwrs { + compatible = "regulator-fixed"; + + regulator-name = "USB_PWR"; + + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + + /* signal name in schematic: USB_PWR_EN */ + gpio = <&gpio GPIODV_24 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vddio_card: gpio-regulator { + compatible = "regulator-gpio"; + + regulator-name = "VDDIO_CARD"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpio_ao GPIOAO_5 GPIO_ACTIVE_HIGH>; + gpios-states = <1>; + + /* Based on P200 schematics, signal CARD_1.8V/3.3V_CTR */ + states = <1800000 0 + 3300000 1>; + + regulator-settling-time-up-us = <10000>; + regulator-settling-time-down-us = <150000>; + }; + + vddio_boot: regulator-vddio_boot { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_BOOT"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vddao_3v3: regulator-vddao_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc_3v3: regulator-vcc_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VCC_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_9 GPIO_ACTIVE_LOW>; + }; + + wifi32k: wifi32k { + compatible = "pwm-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>; + clocks = <&wifi32k>; + clock-names = "ext_clock"; + }; + + cvbs_connector: cvbs-connector { + compatible = "composite-video-connector"; + + port { + cvbs_connector_in: endpoint { + remote-endpoint = <&cvbs_vdac_out>; + }; + }; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; +}; + +&cec_AO { + status = "okay"; + pinctrl-0 = <&ao_cec_pins>; + pinctrl-names = "default"; + hdmi-phandle = <&hdmi_tx>; +}; + +&cvbs_vdac_port { + cvbs_vdac_out: endpoint { + remote-endpoint = <&cvbs_connector_in>; + }; +}; + +&hdmi_tx { + status = "okay"; + pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>; + pinctrl-names = "default"; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + +&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; +}; + +&pwm_ef { + status = "okay"; + pinctrl-0 = <&pwm_e_pins>; + pinctrl-names = "default"; + clocks = <&clkc CLKID_FCLK_DIV4>; + clock-names = "clkin0"; +}; + +/* Wireless SDIO Module */ +&sd_emmc_a { + status = "okay"; + pinctrl-0 = <&sdio_pins>; + pinctrl-1 = <&sdio_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + #address-cells = <1>; + #size-cells = <0>; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <100000000>; + + non-removable; + disable-wp; + + mmc-pwrseq = <&sdio_pwrseq>; + + vmmc-supply = <&vddao_3v3>; + vqmmc-supply = <&vddio_boot>; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + }; +}; + +/* SD card */ +&sd_emmc_b { + status = "okay"; + pinctrl-0 = <&sdcard_pins>; + pinctrl-1 = <&sdcard_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + max-frequency = <100000000>; + disable-wp; + + cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>; + + vmmc-supply = <&vddao_3v3>; + vqmmc-supply = <&vddio_card>; +}; + +/* eMMC */ +&sd_emmc_c { + status = "okay"; + pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + max-frequency = <200000000>; + non-removable; + disable-wp; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&vddio_boot>; +}; + +/* This UART is brought out to the DB9 connector */ +&uart_AO { + status = "okay"; + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; +}; + +&usb0_phy { + status = "okay"; + phy-supply = <&usb_pwr>; +}; + +&usb1_phy { + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&usb1 { + status = "okay"; +}; -- 2.21.0
Commits should be described using the 12bytes identifier, like the Fixes tag. You can update it if you resend, and keep my Acked-by.
- meson-gxbb-p200.dtb \
- meson-gxbb-p201.dtb \ meson-gxl-s905x-p212.dtb \ meson-gxl-s905x-libretech-cc.dtb \ meson-gxl-s905x-khadas-vim.dtb \
- Copyright (c) 2016 Andreas Färber
- Copyright (c) 2016 BayLibre, Inc.
- Author: Kevin Hilman khilman@kernel.org
+/dts-v1/;
- compatible = "amlogic,p200", "amlogic,meson-gxbb";
- model = "Amlogic Meson GXBB P200 Development Board";
- avdd18_usb_adc: regulator-avdd18_usb_adc {
- adc_keys {
button-home {
label = "Home";
button-esc {
label = "Esc";
button-up {
button-down {
button-menu {
label = "Menu";
+ðmac {
- status = "okay";
- pinctrl-0 = <ð_rgmii_pins>;
- pinctrl-names = "default";
- phy-handle = <ð_phy0>;
- phy-mode = "rgmii";
- amlogic,tx-delay-ns = <2>;
- snps,reset-gpio = <&gpio GPIOZ_14 0>;
- snps,reset-delays-us = <0 10000 1000000>;
- snps,reset-active-low;
- mdio {
#size-cells = <0>;
reg = <3>;
+&i2c_B {
- status = "okay";
- pinctrl-0 = <&i2c_b_pins>;
+&saradc {
- status = "okay";
- vref-supply = <&avdd18_usb_adc>;
+/dts-v1/;
- compatible = "amlogic,p201", "amlogic,meson-gxbb";
- model = "Amlogic Meson GXBB P201 Development Board";
+ðmac {
- status = "okay";
- pinctrl-0 = <ð_rmii_pins>;
- phy-mode = "rmii";
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
- memory@0 {
- usb_pwr: regulator-usb-pwrs {
enable-active-high;
- vddio_card: gpio-regulator {
gpios-states = <1>;
states = <1800000 0
3300000 1>;
- vddio_boot: regulator-vddio_boot {
- vddao_3v3: regulator-vddao_3v3 {
- vcc_3v3: regulator-vcc_3v3 {
- emmc_pwrseq: emmc-pwrseq {
- wifi32k: wifi32k {
#clock-cells = <0>;
- sdio_pwrseq: sdio-pwrseq {
- cvbs_connector: cvbs-connector {
port {
- hdmi-connector {
type = "a";
port {
+&cec_AO {
- status = "okay";
- pinctrl-0 = <&ao_cec_pins>;
- hdmi-phandle = <&hdmi_tx>;
+&cvbs_vdac_port {
- cvbs_vdac_out: endpoint {
+&hdmi_tx {
- status = "okay";
- pinctrl-0 = <&hdmi_hpd_pins>, <&hdmi_i2c_pins>;
- hdmi_tx_tmds_out: endpoint {
+&ir {
- status = "okay";
- pinctrl-0 = <&remote_input_ao_pins>;
+&pwm_ef {
- status = "okay";
- pinctrl-0 = <&pwm_e_pins>;
- clocks = <&clkc CLKID_FCLK_DIV4>;
- clock-names = "clkin0";
- status = "okay";
- pinctrl-0 = <&sdio_pins>;
- pinctrl-1 = <&sdio_clk_gate_pins>;
- pinctrl-names = "default", "clk-gate";
- #address-cells = <1>;
- #size-cells = <0>;
- bus-width = <4>;
- cap-sd-highspeed;
- max-frequency = <100000000>;
- non-removable;
- disable-wp;
- mmc-pwrseq = <&sdio_pwrseq>;
- vmmc-supply = <&vddao_3v3>;
- vqmmc-supply = <&vddio_boot>;
- brcmf: wifi@1 {
reg = <1>;
- status = "okay";
- pinctrl-0 = <&sdcard_pins>;
- pinctrl-1 = <&sdcard_clk_gate_pins>;
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- disable-wp;
- cd-gpios = <&gpio CARD_6 GPIO_ACTIVE_LOW>;
- vqmmc-supply = <&vddio_card>;
- status = "okay";
- pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>;
- pinctrl-1 = <&emmc_clk_gate_pins>;
- bus-width = <8>;
- cap-mmc-highspeed;
- max-frequency = <200000000>;
- non-removable;
- disable-wp;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- mmc-pwrseq = <&emmc_pwrseq>;
- vmmc-supply = <&vcc_3v3>;
- status = "okay";
- pinctrl-0 = <&uart_ao_a_pins>;
+&usb0_phy {
- status = "okay";
- phy-supply = <&usb_pwr>;
+&usb1_phy {
- status = "okay";
+&usb0 {
- status = "okay";
+&usb1 {
- status = "okay";
2.21.0
Acked-by: Neil Armstrong narmstrong@baylibre.com
Thanks, Neil
Signed-off-by: Mohammad Rasim mohammad.rasim96@gmail.com --- board/amlogic/p201/MAINTAINERS | 6 ++ board/amlogic/p201/Makefile | 5 ++ board/amlogic/p201/README.p201 | 103 +++++++++++++++++++++++++++++++++ board/amlogic/p201/p201.c | 43 ++++++++++++++ configs/p201_defconfig | 41 +++++++++++++ 5 files changed, 198 insertions(+) create mode 100644 board/amlogic/p201/MAINTAINERS create mode 100644 board/amlogic/p201/Makefile create mode 100644 board/amlogic/p201/README.p201 create mode 100644 board/amlogic/p201/p201.c create mode 100644 configs/p201_defconfig
diff --git a/board/amlogic/p201/MAINTAINERS b/board/amlogic/p201/MAINTAINERS new file mode 100644 index 0000000000..6ebb5f6396 --- /dev/null +++ b/board/amlogic/p201/MAINTAINERS @@ -0,0 +1,6 @@ +P201 +M: Beniamino Galvani b.galvani@gmail.com +M: Neil Armstrong narmstrong@baylibre.com +S: Maintained +F: board/amlogic/p201/ +F: configs/p201_defconfig diff --git a/board/amlogic/p201/Makefile b/board/amlogic/p201/Makefile new file mode 100644 index 0000000000..11de5396ab --- /dev/null +++ b/board/amlogic/p201/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com + +obj-y := p201.o diff --git a/board/amlogic/p201/README.p201 b/board/amlogic/p201/README.p201 new file mode 100644 index 0000000000..c251096ce1 --- /dev/null +++ b/board/amlogic/p201/README.p201 @@ -0,0 +1,103 @@ +U-Boot for Amlogic P201 +======================= + +P201 is a reference board manufactured by Amlogic with the following +specifications: + + - Amlogic S905 ARM Cortex-A53 quad-core SoC @ 1.5GHz + - ARM Mali 450 GPU + - 2GB DDR3 SDRAM + - 10/100 Ethernet + - HDMI 2.0 4K/60Hz display + - 2 x USB 2.0 Host + - eMMC, microSD + - Infrared receiver + - SDIO WiFi Module + - CVBS+Stereo Audio Jack + +Schematics are available from Amlogic on demand. + +Currently the u-boot port supports the following devices: + - serial + - eMMC, microSD + - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - USB Host + - ADC + +u-boot compilation +================== + + > export ARCH=arm + > export CROSS_COMPILE=aarch64-none-elf- + > make p201_defconfig + > make + +Image creation +============== + +Amlogic doesn't provide sources for the firmware and for tools needed +to create the bootloader image, so it is necessary to obtain them from +the git tree published by the board vendor: + + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz + > tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz + > export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH + > git clone https://github.com/BayLibre/u-boot.git -b n-amlogic-openlinux-20170606 amlogic-u-boot + > cd amlogic-u-boot + > make gxb_p201_v1_defconfig + > make + > export FIPDIR=$PWD/fip + +Go back to mainline U-boot source tree then : + > mkdir fip + + > cp $FIPDIR/gxl/bl2.bin fip/ + > cp $FIPDIR/gxl/acs.bin fip/ + > cp $FIPDIR/gxl/bl21.bin fip/ + > cp $FIPDIR/gxl/bl30.bin fip/ + > cp $FIPDIR/gxl/bl301.bin fip/ + > cp $FIPDIR/gxl/bl31.img fip/ + > cp u-boot.bin fip/bl33.bin + + > $FIPDIR/blx_fix.sh \ + fip/bl30.bin \ + fip/zero_tmp \ + fip/bl30_zero.bin \ + fip/bl301.bin \ + fip/bl301_zero.bin \ + fip/bl30_new.bin \ + bl30 + + > $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 + + > $FIPDIR/blx_fix.sh \ + fip/bl2_acs.bin \ + fip/zero_tmp \ + fip/bl2_zero.bin \ + fip/bl21.bin \ + fip/bl21_zero.bin \ + fip/bl2_new.bin \ + bl2 + + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl30_new.bin + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl31.img + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl33.bin + > $FIPDIR/gxl/aml_encrypt_gxl --bl2sig --input fip/bl2_new.bin --output fip/bl2.n.bin.sig + > $FIPDIR/gxl/aml_encrypt_gxl --bootmk \ + --output fip/u-boot.bin \ + --bl2 fip/bl2.n.bin.sig \ + --bl30 fip/bl30_new.bin.enc \ + --bl31 fip/bl31.img.enc \ + --bl33 fip/bl33.bin.enc + +and then write the image to SD with: + + > DEV=/dev/your_sd_device + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444 diff --git a/board/amlogic/p201/p201.c b/board/amlogic/p201/p201.c new file mode 100644 index 0000000000..ef0c65cd9f --- /dev/null +++ b/board/amlogic/p201/p201.c @@ -0,0 +1,43 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com + */ + +#include <common.h> +#include <dm.h> +#include <environment.h> +#include <asm/io.h> +#include <asm/arch/gx.h> +#include <asm/arch/sm.h> +#include <asm/arch/eth.h> +#include <asm/arch/mem.h> + +#define EFUSE_SN_OFFSET 20 +#define EFUSE_SN_SIZE 16 +#define EFUSE_MAC_OFFSET 52 +#define EFUSE_MAC_SIZE 6 + +int misc_init_r(void) +{ + u8 mac_addr[EFUSE_MAC_SIZE]; + char serial[EFUSE_SN_SIZE]; + ssize_t len; + + meson_eth_init(PHY_INTERFACE_MODE_RMII, 0); + + if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { + len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, + mac_addr, EFUSE_MAC_SIZE); + if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr)) + eth_env_set_enetaddr("ethaddr", mac_addr); + } + + if (!env_get("serial#")) { + len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial, + EFUSE_SN_SIZE); + if (len == EFUSE_SN_SIZE) + env_set("serial#", serial); + } + + return 0; +} diff --git a/configs/p201_defconfig b/configs/p201_defconfig new file mode 100644 index 0000000000..f6a821cf32 --- /dev/null +++ b/configs/p201_defconfig @@ -0,0 +1,41 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" p201" +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p201" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MESON=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_GXBB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SYS_BOARD="p201" -- 2.21.0
You can remove Beniamino for this one.
- ARM Mali 450 GPU
- 2GB DDR3 SDRAM
- 10/100 Ethernet
- 2 x USB 2.0 Host
- eMMC, microSD
- Infrared receiver
- SDIO WiFi Module
- serial
- eMMC, microSD
- Ethernet
- I2C
- Regulators
- Reset controller
- Clock controller
- USB Host
- ADC
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make p201_defconfig make+Image creation +==============
wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH git clone https://github.com/BayLibre/u-boot.git -b n-amlogic-openlinux-20170606 amlogic-u-boot cd amlogic-u-boot make gxb_p201_v1_defconfig make export FIPDIR=$PWD/fip+Go back to mainline U-boot source tree then :
mkdir fip cp $FIPDIR/gxl/bl2.bin fip/ cp $FIPDIR/gxl/acs.bin fip/ cp $FIPDIR/gxl/bl21.bin fip/ cp $FIPDIR/gxl/bl30.bin fip/ cp $FIPDIR/gxl/bl301.bin fip/ cp $FIPDIR/gxl/bl31.img fip/ cp u-boot.bin fip/bl33.bin $FIPDIR/blx_fix.sh \- fip/bl30.bin \
- fip/zero_tmp \
- fip/bl30_zero.bin \
- fip/bl301.bin \
- fip/bl301_zero.bin \
- fip/bl30_new.bin \
- bl30
$FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 $FIPDIR/blx_fix.sh \- fip/bl2_acs.bin \
- fip/zero_tmp \
- fip/bl2_zero.bin \
- fip/bl21.bin \
- fip/bl21_zero.bin \
- fip/bl2_new.bin \
- bl2
$FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl30_new.bin $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl31.img $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl33.bin $FIPDIR/gxl/aml_encrypt_gxl --bl2sig --input fip/bl2_new.bin --output fip/bl2.n.bin.sig $FIPDIR/gxl/aml_encrypt_gxl --bootmk \--output fip/u-boot.bin \
DEV=/dev/your_sd_device dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444diff --git a/board/amlogic/p201/p201.c b/board/amlogic/p201/p201.c new file mode 100644 index 0000000000..ef0c65cd9f --- /dev/null +++ b/board/amlogic/p201/p201.c @@ -0,0 +1,43 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com
- u8 mac_addr[EFUSE_MAC_SIZE];
- char serial[EFUSE_SN_SIZE];
- ssize_t len;
- meson_eth_init(PHY_INTERFACE_MODE_RMII, 0);
- if (!eth_env_get_enetaddr("ethaddr", mac_addr)) {
- if (!env_get("serial#")) {
EFUSE_SN_SIZE);
2.21.0
Lookgs good,
Signed-off-by: Mohammad Rasim mohammad.rasim96@gmail.com --- board/amlogic/odroid-c2/README.p200 | 103 ++++++++++++++++++++++++++++ configs/p200_defconfig | 41 +++++++++++ 2 files changed, 144 insertions(+) create mode 100644 board/amlogic/odroid-c2/README.p200 create mode 100644 configs/p200_defconfig
diff --git a/board/amlogic/odroid-c2/README.p200 b/board/amlogic/odroid-c2/README.p200 new file mode 100644 index 0000000000..01d82d1e79 --- /dev/null +++ b/board/amlogic/odroid-c2/README.p200 @@ -0,0 +1,103 @@ +U-Boot for Amlogic P200 +======================= + +P200 is a reference board manufactured by Amlogic with the following +specifications: + + - Amlogic S905 ARM Cortex-A53 quad-core SoC @ 1.5GHz + - ARM Mali 450 GPU + - 2GB DDR3 SDRAM + - Gigabit Ethernet + - HDMI 2.0 4K/60Hz display + - 2 x USB 2.0 Host + - eMMC, microSD + - Infrared receiver + - SDIO WiFi Module + - CVBS+Stereo Audio Jack + +Schematics are available from Amlogic on demand. + +Currently the u-boot port supports the following devices: + - serial + - eMMC, microSD + - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - USB Host + - ADC + +u-boot compilation +================== + + > export ARCH=arm + > export CROSS_COMPILE=aarch64-none-elf- + > make p200_defconfig + > make + +Image creation +============== + +Amlogic doesn't provide sources for the firmware and for tools needed +to create the bootloader image, so it is necessary to obtain them from +the git tree published by the board vendor: + + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz + > tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz + > export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH + > git clone https://github.com/BayLibre/u-boot.git -b n-amlogic-openlinux-20170606 amlogic-u-boot + > cd amlogic-u-boot + > make gxb_p200_v1_defconfig + > make + > export FIPDIR=$PWD/fip + +Go back to mainline U-boot source tree then : + > mkdir fip + + > cp $FIPDIR/gxl/bl2.bin fip/ + > cp $FIPDIR/gxl/acs.bin fip/ + > cp $FIPDIR/gxl/bl21.bin fip/ + > cp $FIPDIR/gxl/bl30.bin fip/ + > cp $FIPDIR/gxl/bl301.bin fip/ + > cp $FIPDIR/gxl/bl31.img fip/ + > cp u-boot.bin fip/bl33.bin + + > $FIPDIR/blx_fix.sh \ + fip/bl30.bin \ + fip/zero_tmp \ + fip/bl30_zero.bin \ + fip/bl301.bin \ + fip/bl301_zero.bin \ + fip/bl30_new.bin \ + bl30 + + > $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 + + > $FIPDIR/blx_fix.sh \ + fip/bl2_acs.bin \ + fip/zero_tmp \ + fip/bl2_zero.bin \ + fip/bl21.bin \ + fip/bl21_zero.bin \ + fip/bl2_new.bin \ + bl2 + + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl30_new.bin + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl31.img + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl33.bin + > $FIPDIR/gxl/aml_encrypt_gxl --bl2sig --input fip/bl2_new.bin --output fip/bl2.n.bin.sig + > $FIPDIR/gxl/aml_encrypt_gxl --bootmk \ + --output fip/u-boot.bin \ + --bl2 fip/bl2.n.bin.sig \ + --bl30 fip/bl30_new.bin.enc \ + --bl31 fip/bl31.img.enc \ + --bl33 fip/bl33.bin.enc + +and then write the image to SD with: + + > DEV=/dev/your_sd_device + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444 diff --git a/configs/p200_defconfig b/configs/p200_defconfig new file mode 100644 index 0000000000..4011866140 --- /dev/null +++ b/configs/p200_defconfig @@ -0,0 +1,41 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" p200" +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p200" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MESON=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_GXBB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SYS_BOARD="odroid-c2" -- 2.21.0
You should also update the MAINTAINERS file in board/amlogic/odroid-c2/ for configs/p200_defconfig
Otherwise looks good
Neil
- ARM Mali 450 GPU
- 2GB DDR3 SDRAM
- Gigabit Ethernet
- 2 x USB 2.0 Host
- eMMC, microSD
- Infrared receiver
- SDIO WiFi Module
- serial
- eMMC, microSD
- Ethernet
- I2C
- Regulators
- Reset controller
- Clock controller
- USB Host
- ADC
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make p200_defconfig make+Image creation +==============
wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH git clone https://github.com/BayLibre/u-boot.git -b n-amlogic-openlinux-20170606 amlogic-u-boot cd amlogic-u-boot make gxb_p200_v1_defconfig make export FIPDIR=$PWD/fip+Go back to mainline U-boot source tree then :
- fip/zero_tmp \
- fip/bl301.bin \
- bl30
- fip/zero_tmp \
- fip/bl21.bin \
- fip/bl2_new.bin \
- bl2
DEV=/dev/your_sd_device dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444diff --git a/configs/p200_defconfig b/configs/p200_defconfig new file mode 100644 index 0000000000..4011866140 --- /dev/null +++ b/configs/p200_defconfig @@ -0,0 +1,41 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_DEBUG_UART_BASE=0xc81004c0 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" p200" +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-p200" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MESON=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_GXBB=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_OF_LIBFDT_OVERLAY=y
2.21.0
Mohammad Rasim
Neil Armstrong
