[PATCH v1 1/1] tools/netconsole: Add support for socat
socat is a very powerful tool to work with socets (and not only) in UNIX systems. Let's add support for it in netconsole.
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- tools/netconsole | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/tools/netconsole b/tools/netconsole index 1a0ef22244e3..155453320f73 100755 --- a/tools/netconsole +++ b/tools/netconsole @@ -34,7 +34,7 @@ if [ -z "${ip}" ] || [ -n "$4" ] ; then usage "Invalid number of arguments" fi
-for nc in netcat nc ; do +for nc in socat netcat nc ; do type ${nc} >/dev/null 2>&1 && break done
@@ -47,6 +47,10 @@ if type ncb 2>/dev/null ; then # see if ncb is in $PATH exec ncb ${board_out_port}
+elif [ "${nc}" = "socat" ] ; then + # socat does support broadcast + while ${nc} STDIO "UDP4-LISTEN:${board_out_port}"; do :; done + elif [ -x ${0%/*}/ncb ] ; then # maybe it's in the same dir as the netconsole script exec ${0%/*}/ncb ${board_out_port} @@ -59,5 +63,9 @@ else fi ) & pid=$! -${nc} -u ${ip} ${board_in_port} +if [ "${nc}" = "socat" ] ; then + ${nc} - "UDP4:${ip}:${board_in_port}" +else + ${nc} -u ${ip} ${board_in_port} +fi kill ${pid} 2>/dev/null
Op 17-11-2021 om 18:15 schreef Andy Shevchenko:
Tested-by: Ferry Toth fntoth@gmail.com
- # socat does support broadcast
- while ${nc} STDIO "UDP4-LISTEN:${board_out_port}"; do :; done
- elif [ -x ${0%/*}/ncb ] ; then # maybe it's in the same dir as the netconsole script exec ${0%/*}/ncb ${board_out_port}
- ${nc} - "UDP4:${ip}:${board_in_port}"
+else
- ${nc} -u ${ip} ${board_in_port}
Thanks!
Can thi be applied, please?
+else
On Fri, Nov 26, 2021 at 6:05 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
Thanks!
+else
-- With Best Regards, Andy Shevchenko
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Thanks!
+else
Applied to u-boot-net/next, Thanks.
Andy Shevchenko
Andy Shevchenko
Ferry Toth
Ramon Fried
