[U-Boot] [PATCH] spi: pic32_spi: add SPI master driver for PIC32 SoC.
This driver implements SPI protocol in master mode to communicate with the SPI device connected on SPI bus. It handles /CS explicitly by controlling respective pin as gpio ('cs-gpios' property in dt node) and uses PIO mode for SPI transaction. It is configurable based on driver-model only.
Cc: Jagan Teki jteki@openedev.com Signed-off-by: Purna Chandra Mandal purna.mandal@microchip.com
drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/pic32_spi.c | 448 ++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 457 insertions(+) create mode 100644 drivers/spi/pic32_spi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index b7fd8e5..aca385d 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -75,6 +75,14 @@ config ICH_SPI access the SPI NOR flash on platforms embedding this Intel ICH IP core.
+config PIC32_SPI + bool "Microchip PIC32 SPI driver" + depends on MACH_PIC32 + help + Enable the Microchip PIC32 SPI driver. This driver can be used + to access the SPI NOR flash, MMC-over-SPI on platforms based on + Microchip PIC32 family devices. + config ROCKCHIP_SPI bool "Rockchip SPI driver" help diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 7fb2926..b1d9e20 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -40,6 +40,7 @@ obj-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o obj-$(CONFIG_MXC_SPI) += mxc_spi.o obj-$(CONFIG_MXS_SPI) += mxs_spi.o obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o +obj-$(CONFIG_PIC32_SPI) += pic32_spi.o obj-$(CONFIG_ROCKCHIP_SPI) += rk_spi.o obj-$(CONFIG_SANDBOX_SPI) += sandbox_spi.o obj-$(CONFIG_SH_SPI) += sh_spi.o diff --git a/drivers/spi/pic32_spi.c b/drivers/spi/pic32_spi.c new file mode 100644 index 0000000..25ca1f3 --- /dev/null +++ b/drivers/spi/pic32_spi.c @@ -0,0 +1,448 @@ +/* + * Microchip PIC32 SPI controller driver. + * + * Copyright (c) 2015, Microchip Technology Inc. + * Purna Chandra Mandal purna.mandal@microchip.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <linux/compat.h> +#include <malloc.h> +#include <spi.h> + +#include <asm/types.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include <dt-bindings/clock/microchip,clock.h> +#include <mach/pic32.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* PIC32 SPI controller registers */ +struct pic32_reg_spi { + struct pic32_reg_atomic ctrl; + struct pic32_reg_atomic status; + struct pic32_reg_atomic buf; + struct pic32_reg_atomic baud; + struct pic32_reg_atomic ctrl2; +}; + +/* Bit fields in SPI Control Register */ +#define PIC32_SPI_CTRL_MSTEN BIT(5) /* Enable SPI Master */ +#define PIC32_SPI_CTRL_CKP BIT(6) /* active low */ +#define PIC32_SPI_CTRL_CKE BIT(8) /* Tx on falling edge */ +#define PIC32_SPI_CTRL_SMP BIT(9) /* Rx at middle or end of tx */ +#define PIC32_SPI_CTRL_BPW_MASK 0x03 /* Bits per word */ +#define PIC32_SPI_CTRL_BPW_8 0x0 +#define PIC32_SPI_CTRL_BPW_16 0x1 +#define PIC32_SPI_CTRL_BPW_32 0x2 +#define PIC32_SPI_CTRL_BPW_SHIFT 10 +#define PIC32_SPI_CTRL_ON BIT(15) /* Macro enable */ +#define PIC32_SPI_CTRL_ENHBUF BIT(16) /* Enable enhanced buffering */ +#define PIC32_SPI_CTRL_MCLKSEL BIT(23) /* Select SPI Clock src */ +#define PIC32_SPI_CTRL_MSSEN BIT(28) /* SPI macro will drive SS */ +#define PIC32_SPI_CTRL_FRMEN BIT(31) /* Enable framing mode */ + +/* Bit fields in SPI Status Register */ +#define PIC32_SPI_STAT_RX_OV BIT(6) /* err, s/w needs to clear */ +#define PIC32_SPI_STAT_TF_LVL_MASK 0x1f +#define PIC32_SPI_STAT_TF_LVL_SHIFT 16 +#define PIC32_SPI_STAT_RF_LVL_MASK 0x1f +#define PIC32_SPI_STAT_RF_LVL_SHIFT 24 + +/* Bit fields in SPI Baud Register */ +#define PIC32_SPI_BAUD_MASK 0x1ff + +struct pic32_spi_priv { + struct pic32_reg_spi *regs; + u32 fifo_depth; /* FIFO depth in bytes */ + u32 fifo_n_word; /* FIFO depth in words */ + struct gpio_desc cs_gpio; + + /* Current SPI slave specific */ + ulong clk_rate; + u32 speed_hz; /* spi-clk rate */ + int mode; + + /* Current message/transfer state */ + const void *tx; + const void *tx_end; + const void *rx; + const void *rx_end; + u32 len; + + /* SPI FiFo accessor */ + void (*rx_fifo)(struct pic32_spi_priv *); + void (*tx_fifo)(struct pic32_spi_priv *); +}; + +static inline void pic32_spi_enable(struct pic32_spi_priv *priv) +{ + writel(PIC32_SPI_CTRL_ON, &priv->regs->ctrl.set); +} + +static inline void pic32_spi_disable(struct pic32_spi_priv *priv) +{ + writel(PIC32_SPI_CTRL_ON, &priv->regs->ctrl.clr); +} + +static inline u32 pic32_spi_rx_fifo_level(struct pic32_spi_priv *priv) +{ + u32 sr = readl(&priv->regs->status.raw); + + return (sr >> PIC32_SPI_STAT_RF_LVL_SHIFT) & PIC32_SPI_STAT_RF_LVL_MASK; +} + +static inline u32 pic32_spi_tx_fifo_level(struct pic32_spi_priv *priv) +{ + u32 sr = readl(&priv->regs->status.raw); + + return (sr >> PIC32_SPI_STAT_TF_LVL_SHIFT) & PIC32_SPI_STAT_TF_LVL_MASK; +} + +/* Return the max entries we can fill into tx fifo */ +static u32 pic32_tx_max(struct pic32_spi_priv *priv, int n_bytes) +{ + u32 tx_left, tx_room, rxtx_gap; + + tx_left = (priv->tx_end - priv->tx) / n_bytes; + tx_room = priv->fifo_n_word - pic32_spi_tx_fifo_level(priv); + + rxtx_gap = (priv->rx_end - priv->rx) - (priv->tx_end - priv->tx); + rxtx_gap /= n_bytes; + return min3(tx_left, tx_room, (u32)(priv->fifo_n_word - rxtx_gap)); +} + +/* Return the max entries we should read out of rx fifo */ +static u32 pic32_rx_max(struct pic32_spi_priv *priv, int n_bytes) +{ + u32 rx_left = (priv->rx_end - priv->rx) / n_bytes; + + return min_t(u32, rx_left, pic32_spi_rx_fifo_level(priv)); +} + +#define BUILD_SPI_FIFO_RW(__name, __type, __bwl) \ +static void pic32_spi_rx_##__name(struct pic32_spi_priv *priv) \ +{ \ + __type val; \ + u32 mx = pic32_rx_max(priv, sizeof(__type)); \ + \ + for (; mx; mx--) { \ + val = read##__bwl(&priv->regs->buf.raw); \ + if (priv->rx_end - priv->len) \ + *(__type *)(priv->rx) = val; \ + priv->rx += sizeof(__type); \ + } \ +} \ + \ +static void pic32_spi_tx_##__name(struct pic32_spi_priv *priv) \ +{ \ + __type val; \ + u32 mx = pic32_tx_max(priv, sizeof(__type)); \ + \ + for (; mx ; mx--) { \ + val = (__type) ~0U; \ + if (priv->tx_end - priv->len) \ + val = *(__type *)(priv->tx); \ + write##__bwl(val, &priv->regs->buf.raw); \ + priv->tx += sizeof(__type); \ + } \ +} +BUILD_SPI_FIFO_RW(byte, u8, b); +BUILD_SPI_FIFO_RW(word, u16, w); +BUILD_SPI_FIFO_RW(dword, u32, l); + +static int pic32_spi_set_word_size(struct pic32_spi_priv *priv, + unsigned int wordlen) +{ + u32 bits_per_word; + u32 val; + + switch (wordlen) { + case 8: + priv->rx_fifo = pic32_spi_rx_byte; + priv->tx_fifo = pic32_spi_tx_byte; + bits_per_word = PIC32_SPI_CTRL_BPW_8; + break; + case 16: + priv->rx_fifo = pic32_spi_rx_word; + priv->tx_fifo = pic32_spi_tx_word; + bits_per_word = PIC32_SPI_CTRL_BPW_16; + break; + case 32: + priv->rx_fifo = pic32_spi_rx_dword; + priv->tx_fifo = pic32_spi_tx_dword; + bits_per_word = PIC32_SPI_CTRL_BPW_32; + break; + default: + printf("pic32-spi: unsupported wordlen\n"); + return -EINVAL; + } + + /* set bits-per-word */ + val = readl(&priv->regs->ctrl.raw); + val &= ~(PIC32_SPI_CTRL_BPW_MASK << PIC32_SPI_CTRL_BPW_SHIFT); + val |= bits_per_word << PIC32_SPI_CTRL_BPW_SHIFT; + writel(val, &priv->regs->ctrl.raw); + + /* calculate maximum number of words fifo can hold */ + priv->fifo_n_word = DIV_ROUND_UP(priv->fifo_depth, wordlen / 8); + + return 0; +} + +static int pic32_spi_claim_bus(struct udevice *slave) +{ + struct pic32_spi_priv *priv = dev_get_priv(slave->parent); + + /* enable chip */ + pic32_spi_enable(priv); + + return 0; +} + +static int pic32_spi_release_bus(struct udevice *slave) +{ + struct pic32_spi_priv *priv = dev_get_priv(slave->parent); + + /* disable chip */ + pic32_spi_disable(priv); + + return 0; +} + +static void spi_cs_activate(struct pic32_spi_priv *priv) +{ + if (!dm_gpio_is_valid(&priv->cs_gpio)) + return; + + dm_gpio_set_value(&priv->cs_gpio, 1); +} + +static void spi_cs_deactivate(struct pic32_spi_priv *priv) +{ + if (!dm_gpio_is_valid(&priv->cs_gpio)) + return; + + dm_gpio_set_value(&priv->cs_gpio, 0); +} + +static int pic32_spi_xfer(struct udevice *slave, unsigned int bitlen, + const void *tx_buf, void *rx_buf, + unsigned long flags) +{ + struct dm_spi_slave_platdata *slave_plat; + struct udevice *bus = slave->parent; + struct pic32_spi_priv *priv; + int len = bitlen / 8; + int ret = 0; + ulong tbase; + + priv = dev_get_priv(bus); + slave_plat = dev_get_parent_platdata(slave); + + debug("spi_xfer: bus:%i cs:%i flags:%lx\n", + bus->seq, slave_plat->cs, flags); + debug("msg tx %p, rx %p submitted of %d byte(s)\n", + tx_buf, rx_buf, len); + + /* assert cs */ + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(priv); + + /* set current transfer information */ + priv->tx = tx_buf; + priv->rx = rx_buf; + priv->tx_end = priv->tx + len; + priv->rx_end = priv->rx + len; + priv->len = len; + + /* transact by polling */ + tbase = get_timer(0); + for (;;) { + priv->tx_fifo(priv); + priv->rx_fifo(priv); + + /* received sufficient data */ + if (priv->rx >= priv->rx_end) { + ret = 0; + break; + } + + if (get_timer(tbase) > 5 * CONFIG_SYS_HZ) { + printf("pic32_spi: error, xfer timedout.\n"); + flags |= SPI_XFER_END; + ret = -ETIMEDOUT; + break; + } + } + + /* deassert cs */ + if (flags & SPI_XFER_END) + spi_cs_deactivate(priv); + + return ret; +} + +static int pic32_spi_set_speed(struct udevice *bus, uint speed) +{ + struct pic32_spi_priv *priv = dev_get_priv(bus); + u32 div; + + debug("%s: %s, speed %u\n", __func__, bus->name, speed); + + /* div = [clk_in / (2 * spi_clk)] - 1 */ + div = (priv->clk_rate / 2 / speed) - 1; + div &= PIC32_SPI_BAUD_MASK; + writel(div, &priv->regs->baud.raw); + + priv->speed_hz = speed; + + return 0; +} + +static int pic32_spi_set_mode(struct udevice *bus, uint mode) +{ + struct pic32_spi_priv *priv = dev_get_priv(bus); + u32 val; + + debug("%s: %s, mode %d\n", __func__, bus->name, mode); + + /* set spi-clk mode */ + val = readl(&priv->regs->ctrl.raw); + /* HIGH when idle */ + if (mode & SPI_CPOL) + val |= PIC32_SPI_CTRL_CKP; + else + val &= ~PIC32_SPI_CTRL_CKP; + + /* TX at idle-to-active clk transition */ + if (mode & SPI_CPHA) + val &= ~PIC32_SPI_CTRL_CKE; + else + val |= PIC32_SPI_CTRL_CKE; + + /* RX at end of tx */ + val |= PIC32_SPI_CTRL_SMP; + writel(val, &priv->regs->ctrl.raw); + + priv->mode = mode; + + return 0; +} + +static int pic32_spi_set_wordlen(struct udevice *slave, unsigned int wordlen) +{ + struct pic32_spi_priv *priv = dev_get_priv(slave->parent); + + return pic32_spi_set_word_size(priv, wordlen); +} + +static void pic32_spi_hw_init(struct pic32_spi_priv *priv) +{ + u32 val; + + /* disable module */ + pic32_spi_disable(priv); + + val = readl(&priv->regs->ctrl); + + /* enable enhanced fifo of 128bit deep */ + val |= PIC32_SPI_CTRL_ENHBUF; + priv->fifo_depth = 16; + + /* disable framing mode */ + val &= ~PIC32_SPI_CTRL_FRMEN; + + /* enable master mode */ + val |= PIC32_SPI_CTRL_MSTEN; + + /* select clk source */ + val &= ~PIC32_SPI_CTRL_MCLKSEL; + + /* set manual /CS mode */ + val &= ~PIC32_SPI_CTRL_MSSEN; + + writel(val, &priv->regs->ctrl); + + /* clear rx overflow indicator */ + writel(PIC32_SPI_STAT_RX_OV, &priv->regs->status.clr); +} + +static int pic32_spi_probe(struct udevice *bus) +{ + struct pic32_spi_priv *priv = dev_get_priv(bus); + struct dm_spi_bus *dm_spi = dev_get_uclass_priv(bus); + struct udevice *clkdev; + fdt_addr_t addr; + fdt_size_t size; + int ret; + + debug("%s: %d, bus: %i\n", __func__, __LINE__, bus->seq); + addr = fdtdec_get_addr_size(gd->fdt_blob, bus->of_offset, "reg", &size); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->regs = ioremap(addr, size); + if (!priv->regs) + return -EINVAL; + + dm_spi->max_hz = fdtdec_get_int(gd->fdt_blob, bus->of_offset, + "spi-max-frequency", 250000000); + /* get clock rate */ + ret = clk_get_by_index(bus, 0, &clkdev); + if (ret < 0) { + printf("pic32-spi: error, clk not found\n"); + return ret; + } + priv->clk_rate = clk_get_periph_rate(clkdev, ret); + + /* initialize HW */ + pic32_spi_hw_init(priv); + + /* set word len */ + pic32_spi_set_word_size(priv, SPI_DEFAULT_WORDLEN); + + /* PIC32 SPI controller can automatically drive /CS during transfer + * depending on fifo fill-level. /CS will stay asserted as long as + * TX fifo is non-empty, else will be deasserted confirming completion + * of the ongoing transfer. To avoid this sort of error we will drive + * /CS manually by toggling cs-gpio pins. + */ + ret = gpio_request_by_name_nodev(gd->fdt_blob, bus->of_offset, + "cs-gpios", 0, + &priv->cs_gpio, GPIOD_IS_OUT); + if (ret) { + printf("pic32-spi: error, cs-gpios not found\n"); + return ret; + } + + return 0; +} + +static const struct dm_spi_ops pic32_spi_ops = { + .claim_bus = pic32_spi_claim_bus, + .release_bus = pic32_spi_release_bus, + .xfer = pic32_spi_xfer, + .set_speed = pic32_spi_set_speed, + .set_mode = pic32_spi_set_mode, + .set_wordlen = pic32_spi_set_wordlen, +}; + +static const struct udevice_id pic32_spi_ids[] = { + { .compatible = "microchip,pic32mzda-spi" }, + { } +}; + +U_BOOT_DRIVER(pic32_spi) = { + .name = "pic32_spi", + .id = UCLASS_SPI, + .of_match = pic32_spi_ids, + .ops = &pic32_spi_ops, + .priv_auto_alloc_size = sizeof(struct pic32_spi_priv), + .probe = pic32_spi_probe, +};
Am 02.06.2016 um 10:56 schrieb Purna Chandra Mandal:
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
+config PIC32_SPI
- bool "Microchip PIC32 SPI driver"
- depends on MACH_PIC32
- help
- Microchip PIC32 SPI controller driver.
- Copyright (c) 2015, Microchip Technology Inc.
Purna Chandra Mandal <purna.mandal@microchip.com>
- struct pic32_reg_atomic ctrl;
- struct pic32_reg_atomic status;
- struct pic32_reg_atomic buf;
- struct pic32_reg_atomic baud;
- struct pic32_reg_atomic ctrl2;
- struct pic32_reg_spi *regs;
- u32 fifo_depth; /* FIFO depth in bytes */
- u32 fifo_n_word; /* FIFO depth in words */
- struct gpio_desc cs_gpio;
- /* Current SPI slave specific */
- ulong clk_rate;
- u32 speed_hz; /* spi-clk rate */
- int mode;
- /* Current message/transfer state */
- const void *tx;
- const void *tx_end;
- const void *rx;
- const void *rx_end;
- u32 len;
- /* SPI FiFo accessor */
- void (*rx_fifo)(struct pic32_spi_priv *);
- void (*tx_fifo)(struct pic32_spi_priv *);
- writel(PIC32_SPI_CTRL_ON, &priv->regs->ctrl.set);
- writel(PIC32_SPI_CTRL_ON, &priv->regs->ctrl.clr);
- u32 sr = readl(&priv->regs->status.raw);
- return (sr >> PIC32_SPI_STAT_RF_LVL_SHIFT) & PIC32_SPI_STAT_RF_LVL_MASK;
- return (sr >> PIC32_SPI_STAT_TF_LVL_SHIFT) & PIC32_SPI_STAT_TF_LVL_MASK;
- u32 tx_left, tx_room, rxtx_gap;
- tx_left = (priv->tx_end - priv->tx) / n_bytes;
- tx_room = priv->fifo_n_word - pic32_spi_tx_fifo_level(priv);
- rxtx_gap = (priv->rx_end - priv->rx) - (priv->tx_end - priv->tx);
- rxtx_gap /= n_bytes;
- return min3(tx_left, tx_room, (u32)(priv->fifo_n_word - rxtx_gap));
- u32 rx_left = (priv->rx_end - priv->rx) / n_bytes;
- return min_t(u32, rx_left, pic32_spi_rx_fifo_level(priv));
- __type val; \
- u32 mx = pic32_rx_max(priv, sizeof(__type)); \
- for (; mx; mx--) { \
- __type val; \
- u32 mx = pic32_tx_max(priv, sizeof(__type)); \
- for (; mx ; mx--) { \
- u32 bits_per_word;
- u32 val;
- switch (wordlen) {
- case 8:
break;
- case 16:
break;
- case 32:
break;
- default:
return -EINVAL;
- /* set bits-per-word */
- val = readl(&priv->regs->ctrl.raw);
- val &= ~(PIC32_SPI_CTRL_BPW_MASK << PIC32_SPI_CTRL_BPW_SHIFT);
- val |= bits_per_word << PIC32_SPI_CTRL_BPW_SHIFT;
- writel(val, &priv->regs->ctrl.raw);
- /* calculate maximum number of words fifo can hold */
- priv->fifo_n_word = DIV_ROUND_UP(priv->fifo_depth, wordlen / 8);
- struct pic32_spi_priv *priv = dev_get_priv(slave->parent);
- /* enable chip */
- pic32_spi_enable(priv);
- /* disable chip */
- pic32_spi_disable(priv);
- if (!dm_gpio_is_valid(&priv->cs_gpio))
return;
- dm_gpio_set_value(&priv->cs_gpio, 1);
return;
- dm_gpio_set_value(&priv->cs_gpio, 0);
- struct dm_spi_slave_platdata *slave_plat;
- struct udevice *bus = slave->parent;
- struct pic32_spi_priv *priv;
- int len = bitlen / 8;
- int ret = 0;
- ulong tbase;
- priv = dev_get_priv(bus);
- slave_plat = dev_get_parent_platdata(slave);
- debug("spi_xfer: bus:%i cs:%i flags:%lx\n",
- debug("msg tx %p, rx %p submitted of %d byte(s)\n",
- /* assert cs */
- if (flags & SPI_XFER_BEGIN)
- /* set current transfer information */
- priv->tx = tx_buf;
- priv->rx = rx_buf;
- priv->tx_end = priv->tx + len;
- priv->rx_end = priv->rx + len;
- priv->len = len;
- /* transact by polling */
- tbase = get_timer(0);
- for (;;) {
ret = 0;
break;
ret = -ETIMEDOUT;
break;
- /* deassert cs */
- if (flags & SPI_XFER_END)
- return ret;
- struct pic32_spi_priv *priv = dev_get_priv(bus);
- u32 div;
- debug("%s: %s, speed %u\n", __func__, bus->name, speed);
- /* div = [clk_in / (2 * spi_clk)] - 1 */
- div = (priv->clk_rate / 2 / speed) - 1;
- div &= PIC32_SPI_BAUD_MASK;
- writel(div, &priv->regs->baud.raw);
- priv->speed_hz = speed;
- u32 val;
- debug("%s: %s, mode %d\n", __func__, bus->name, mode);
- /* set spi-clk mode */
- /* HIGH when idle */
- if (mode & SPI_CPOL)
- else
- /* TX at idle-to-active clk transition */
- if (mode & SPI_CPHA)
- else
- /* RX at end of tx */
- val |= PIC32_SPI_CTRL_SMP;
- priv->mode = mode;
- return pic32_spi_set_word_size(priv, wordlen);
- u32 val;
- /* disable module */
- val = readl(&priv->regs->ctrl);
- /* enable enhanced fifo of 128bit deep */
- val |= PIC32_SPI_CTRL_ENHBUF;
- priv->fifo_depth = 16;
- /* disable framing mode */
- val &= ~PIC32_SPI_CTRL_FRMEN;
- /* enable master mode */
- val |= PIC32_SPI_CTRL_MSTEN;
- /* select clk source */
- val &= ~PIC32_SPI_CTRL_MCLKSEL;
- /* set manual /CS mode */
- val &= ~PIC32_SPI_CTRL_MSSEN;
- writel(val, &priv->regs->ctrl);
- /* clear rx overflow indicator */
- writel(PIC32_SPI_STAT_RX_OV, &priv->regs->status.clr);
- struct dm_spi_bus *dm_spi = dev_get_uclass_priv(bus);
- struct udevice *clkdev;
- fdt_addr_t addr;
- fdt_size_t size;
- int ret;
- debug("%s: %d, bus: %i\n", __func__, __LINE__, bus->seq);
- addr = fdtdec_get_addr_size(gd->fdt_blob, bus->of_offset, "reg", &size);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- priv->regs = ioremap(addr, size);
- if (!priv->regs)
return -EINVAL;
- dm_spi->max_hz = fdtdec_get_int(gd->fdt_blob, bus->of_offset,
- /* get clock rate */
- ret = clk_get_by_index(bus, 0, &clkdev);
- if (ret < 0) {
return ret;
- priv->clk_rate = clk_get_periph_rate(clkdev, ret);
- /* initialize HW */
- pic32_spi_hw_init(priv);
- /* set word len */
- pic32_spi_set_word_size(priv, SPI_DEFAULT_WORDLEN);
- /* PIC32 SPI controller can automatically drive /CS during transfer
- ret = gpio_request_by_name_nodev(gd->fdt_blob, bus->of_offset,
"cs-gpios", 0,
- if (ret) {
return ret;
- .claim_bus = pic32_spi_claim_bus,
- .release_bus = pic32_spi_release_bus,
- .xfer = pic32_spi_xfer,
- .set_speed = pic32_spi_set_speed,
- .set_mode = pic32_spi_set_mode,
- .set_wordlen = pic32_spi_set_wordlen,
- { .compatible = "microchip,pic32mzda-spi" },
- .name = "pic32_spi",
- .id = UCLASS_SPI,
- .of_match = pic32_spi_ids,
- .ops = &pic32_spi_ops,
- .priv_auto_alloc_size = sizeof(struct pic32_spi_priv),
- .probe = pic32_spi_probe,
applied to u-boot-mips, thanks.
Daniel Schwierzeck
