[U-Boot] [PATCH] dm: rtc: Add 16-bit read/write support
At present there are only 8-bit and 32-bit read/write routines in the rtc uclass driver. This adds the 16-bit support.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/rtc/rtc-uclass.c | 30 ++++++++++++++++++++++++++++++ include/rtc.h | 20 ++++++++++++++++++++ 2 files changed, 50 insertions(+)
diff --git a/drivers/rtc/rtc-uclass.c b/drivers/rtc/rtc-uclass.c index 300e9b3..89312c5 100644 --- a/drivers/rtc/rtc-uclass.c +++ b/drivers/rtc/rtc-uclass.c @@ -60,6 +60,36 @@ int rtc_write8(struct udevice *dev, unsigned int reg, int val) return ops->write8(dev, reg, val); }
+int rtc_read16(struct udevice *dev, unsigned int reg, u16 *valuep) +{ + u16 value = 0; + int ret; + int i; + + for (i = 0; i < sizeof(value); i++) { + ret = rtc_read8(dev, reg + i); + if (ret < 0) + return ret; + value |= ret << (i << 3); + } + + *valuep = value; + return 0; +} + +int rtc_write16(struct udevice *dev, unsigned int reg, u16 value) +{ + int i, ret; + + for (i = 0; i < sizeof(value); i++) { + ret = rtc_write8(dev, reg + i, (value >> (i << 3)) & 0xff); + if (ret) + return ret; + } + + return 0; +} + int rtc_read32(struct udevice *dev, unsigned int reg, u32 *valuep) { u32 value = 0; diff --git a/include/rtc.h b/include/rtc.h index 69fe8d4..49142b6 100644 --- a/include/rtc.h +++ b/include/rtc.h @@ -128,6 +128,26 @@ int rtc_read8(struct udevice *dev, unsigned int reg); int rtc_write8(struct udevice *dev, unsigned int reg, int val);
/** + * rtc_read16() - Read a 16-bit value from the RTC + * + * @dev: Device to read from + * @reg: Offset to start reading from + * @valuep: Place to put the value that is read + * @return 0 if OK, -ve on error + */ +int rtc_read16(struct udevice *dev, unsigned int reg, u16 *valuep); + +/** + * rtc_write16() - Write a 16-bit value to the RTC + * + * @dev: Device to write to + * @reg: Register to start writing to + * @value: Value to write + * @return 0 if OK, -ve on error + */ +int rtc_write16(struct udevice *dev, unsigned int reg, u16 value); + +/** * rtc_read32() - Read a 32-bit value from the RTC * * @dev: Device to read from
Hi Bin,
- u16 value = 0;
- int ret;
- int i;
- for (i = 0; i < sizeof(value); i++) {
if (ret < 0)
return ret;
- *valuep = value;
- int i, ret;
if (ret)
return ret;
These functions look a bit over-complex for handling 2 byte values to me. Looking at the other functions, you seem to have cloned the 32bit version function. Why not introduce a function taking the length (2 byte, 4 bytes, etc) as a parameter? This way, both the 16bit and 32bit functions can call this new function.
But its no big deal to me. You can keep this version as well, as its probably not worth all this consolidating effort.
Thanks, Stefan
Bin Meng
Stefan Roese
