[U-Boot-Users] [PATCH] Updates to Korat-specific code
This patch contains updates for changes for the Korat PPC440EPx board. These changes include:
(1) Support for "permanent" and "upgradable" copies of U-Boot, as described in the new "doc/README.korat" file;
(2) a new memory map for the registers in the board's CPLD;
(3) a revised format for manufacturer's data in serial EEPROM; and
(4) changes to track updates to U-Boot for the Sequoia board.
Signed-off-by: Larry Johnson lrj@acm.org --- If there is a better (or more canonical) way to generate the two versions of U-Boot for korat, I would appreciate hearing about it. I don't know enough about how "make" works for U-Boot to determine whether the method used for "sequoia" and "sequoia_nand" is appropriate.
Best regards, Larry
board/korat/config.mk | 16 +++- board/korat/init.S | 31 +++++-- board/korat/korat.c | 232 +++++++++++++++++++++++++++++++++++-------- board/korat/u-boot-F7FC.lds | 143 ++++++++++++++++++++++++++ doc/README.korat | 51 ++++++++++ include/configs/korat.h | 65 ++++++++---- 6 files changed, 463 insertions(+), 75 deletions(-) create mode 100644 board/korat/u-boot-F7FC.lds create mode 100644 doc/README.korat
diff --git a/board/korat/config.mk b/board/korat/config.mk index 39966e0..fa8374f 100644 --- a/board/korat/config.mk +++ b/board/korat/config.mk @@ -24,14 +24,24 @@ # Korat (PPC440EPx) board #
-TEXT_BASE = 0xFFFA0000 - PLATFORM_CPPFLAGS += -DCONFIG_440=1
ifeq ($(debug),1) PLATFORM_CPPFLAGS += -DDEBUG endif
+ifeq ($(emul),1) +PLATFORM_CPPFLAGS += -fno-schedule-insns -fno-schedule-insns2 +endif + ifeq ($(dbcr),1) -PLATFORM_CPPFLAGS += -DCFG_INIT_DBCR=0x8cff0000 +PLATFORM_CPPFLAGS += -DCFG_INIT_DBCR=0x8CFF0000 +endif + +ifeq ($(perm),1) +PLATFORM_CPPFLAGS += -DCONFIG_KORAT_PERMANENT +TEXT_BASE = 0xFFFA0000 +else +TEXT_BASE = 0xF7F60000 +LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot-F7FC.lds endif diff --git a/board/korat/init.S b/board/korat/init.S index bd0e8b4..bf8b2c8 100644 --- a/board/korat/init.S +++ b/board/korat/init.S @@ -43,7 +43,7 @@ tlbtab: * BOOT_CS (FLASH) must be first. Before relocation SA_I can be off to use the * speed up boot process. It is patched after relocation to enable SA_I */ - tlbentry( CFG_BOOT_BASE_ADDR, SZ_256M, CFG_BOOT_BASE_ADDR, 1, AC_R|AC_W|AC_X|SA_G ) + tlbentry( 0xF0000000, SZ_256M, 0xF0000000, 1, AC_R|AC_W|AC_X|SA_G )
/* * TLB entries for SDRAM are not needed on this platform. They are @@ -52,24 +52,32 @@ tlbtab:
#ifdef CFG_INIT_RAM_DCACHE /* TLB-entry for init-ram in dcache (SA_I must be turned off!) */ - tlbentry( CFG_INIT_RAM_ADDR, SZ_64K, CFG_INIT_RAM_ADDR, 0, AC_R|AC_W|AC_X|SA_G ) + tlbentry( CFG_INIT_RAM_ADDR, SZ_64K, CFG_INIT_RAM_ADDR, 0, + AC_R|AC_W|AC_X|SA_G ) #endif
/* TLB-entry for PCI Memory */ - tlbentry( CFG_PCI_MEMBASE, SZ_256M, CFG_PCI_MEMBASE, 1, AC_R|AC_W|SA_G|SA_I ) - tlbentry( CFG_PCI_MEMBASE1, SZ_256M, CFG_PCI_MEMBASE1, 1, AC_R|AC_W|SA_G|SA_I ) - tlbentry( CFG_PCI_MEMBASE2, SZ_256M, CFG_PCI_MEMBASE2, 1, AC_R|AC_W|SA_G|SA_I ) - tlbentry( CFG_PCI_MEMBASE3, SZ_256M, CFG_PCI_MEMBASE3, 1, AC_R|AC_W|SA_G|SA_I ) + tlbentry( CFG_PCI_MEMBASE + 0x00000000, SZ_256M, + CFG_PCI_MEMBASE + 0x00000000, 1, AC_R|AC_W|SA_G|SA_I ) + + tlbentry( CFG_PCI_MEMBASE + 0x10000000, SZ_256M, + CFG_PCI_MEMBASE + 0x10000000, 1, AC_R|AC_W|SA_G|SA_I ) + + tlbentry( CFG_PCI_MEMBASE + 0x20000000, SZ_256M, + CFG_PCI_MEMBASE + 0x20000000, 1, AC_R|AC_W|SA_G|SA_I ) + + tlbentry( CFG_PCI_MEMBASE + 0x30000000, SZ_256M, + CFG_PCI_MEMBASE + 0x30000000, 1, AC_R|AC_W|SA_G|SA_I )
/* TLB-entry for EBC */ tlbentry( CFG_CPLD_BASE, SZ_1K, CFG_CPLD_BASE, 1, AC_R|AC_W|SA_G|SA_I )
/* TLB-entry for Internal Registers & OCM */ /* I wonder why this must be executable -- lrj@acm.org 2007-10-08 */ - tlbentry( 0xE0000000, SZ_16M, 0xE0000000, 0, AC_R|AC_W|AC_X|SA_I ) + tlbentry( 0xE0000000, SZ_16M, 0xE0000000, 0, AC_R|AC_W|AC_X|SA_I )
/*TLB-entry PCI registers*/ - tlbentry( 0xEEC00000, SZ_1K, 0xEEC00000, 1, AC_R|AC_W|SA_G|SA_I ) + tlbentry( 0xEEC00000, SZ_1K, 0xEEC00000, 1, AC_R|AC_W|SA_G|SA_I )
/* TLB-entry for peripherals */ tlbentry( 0xEF000000, SZ_16M, 0xEF000000, 1, AC_R|AC_W|SA_G|SA_I) @@ -78,3 +86,10 @@ tlbtab: tlbentry(0xE8000000, SZ_64K, 0xE8000000, 1, AC_R|AC_W|SA_G|SA_I)
tlbtab_end + +#if defined(CONFIG_KORAT_PERMANENT) + .globl korat_branch_absolute +korat_branch_absolute: + mtlr r3 + blr +#endif diff --git a/board/korat/korat.c b/board/korat/korat.c index 90fd0a7..a7b4b27 100644 --- a/board/korat/korat.c +++ b/board/korat/korat.c @@ -2,12 +2,12 @@ * (C) Copyright 2007-2008 * Larry Johnson, lrj@acm.org * - * (C) Copyright 2006-2008 + * (C) Copyright 2006-2007 * Stefan Roese, DENX Software Engineering, sr@denx.de. * * (C) Copyright 2006 * Jacqueline Pira-Ferriol, AMCC/IBM, jpira-ferriol@fr.ibm.com - * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com + * Alain Saurel, AMCC/IBM, alain.saurel@fr.ibm.com * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -39,12 +39,45 @@ extern flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */
ulong flash_get_size(ulong base, int banknum);
+#if defined(CONFIG_KORAT_PERMANENT) +void korat_buzzer(int const on) +{ + if (on) { + out_8((u8 *) CFG_CPLD_BASE + 0x05, + in_8((u8 *) CFG_CPLD_BASE + 0x05) | 0x80); + } else { + out_8((u8 *) CFG_CPLD_BASE + 0x05, + in_8((u8 *) CFG_CPLD_BASE + 0x05) & ~0x80); + } +} +#endif + int board_early_init_f(void) { - u32 sdr0_pfc1, sdr0_pfc2; - u32 reg; + uint32_t sdr0_pfc1, sdr0_pfc2; + uint32_t reg; int eth;
+#if defined(CONFIG_KORAT_PERMANENT) + unsigned mscount; + + extern void korat_branch_absolute(uint32_t addr); + + for (mscount = 0; mscount < CFG_KORAT_MAN_RESET_MS; ++mscount) { + udelay(1000); + if (gpio_read_in_bit(CFG_GPIO_RESET_PRESSED_)) { + /* This call does not return. */ + korat_branch_absolute( + CFG_FLASH1_TOP - 2 * CFG_ENV_SECT_SIZE - 4); + } + } + korat_buzzer(1); + while (!gpio_read_in_bit(CFG_GPIO_RESET_PRESSED_)) + udelay(1000); + + korat_buzzer(0); +#endif + mtdcr(ebccfga, xbcfg); mtdcr(ebccfgd, 0xb8400000);
@@ -75,8 +108,11 @@ int board_early_init_f(void) mtdcr(uic2vr, 0x00000000); /* int31 highest, base=0x000 */ mtdcr(uic2sr, 0xffffffff); /* clear all */
- /* take sim card reader and CF controller out of reset */ - out_8((u8 *) CFG_CPLD_BASE + 0x04, 0x80); + /* + * Take sim card reader and CF controller out of reset. Also enable PHY + * auto-detect until board-specific PHY resets are available. + */ + out_8((u8 *) CFG_CPLD_BASE + 0x02, 0xC0);
/* Configure the two Ethernet PHYs. For each PHY, configure for fiber * if the SFP module is present, and for copper if it is not present. @@ -85,8 +121,8 @@ int board_early_init_f(void) if (gpio_read_in_bit(CFG_GPIO_SFP0_PRESENT_ + eth)) { /* SFP module not present: configure PHY for copper. */ /* Set PHY to autonegotate 10 MB, 100MB, or 1 GB */ - out_8((u8 *) CFG_CPLD_BASE + 0x06, - in_8((u8 *) CFG_CPLD_BASE + 0x06) | + out_8((u8 *) CFG_CPLD_BASE + 0x03, + in_8((u8 *) CFG_CPLD_BASE + 0x03) | 0x06 << (4 * eth)); } else { /* SFP module present: configure PHY for fiber and @@ -99,10 +135,18 @@ int board_early_init_f(void) gpio_write_bit(CFG_GPIO_PHY0_EN, 1); gpio_write_bit(CFG_GPIO_PHY1_EN, 1);
- /* select Ethernet pins */ + /* Wait 1 ms, then enable Fiber signal detect to PHYs. */ + udelay(1000); + out_8((u8 *) CFG_CPLD_BASE + 0x03, + in_8((u8 *) CFG_CPLD_BASE + 0x03) | 0x88); + + /* select Ethernet (and optionally IIC1) pins */ mfsdr(SDR0_PFC1, sdr0_pfc1); sdr0_pfc1 = (sdr0_pfc1 & ~SDR0_PFC1_SELECT_MASK) | SDR0_PFC1_SELECT_CONFIG_4; +#ifdef CONFIG_I2C_MULTI_BUS + sdr0_pfc1 |= ((sdr0_pfc1 & ~SDR0_PFC1_SIS_MASK) | SDR0_PFC1_SIS_IIC1_SEL); +#endif mfsdr(SDR0_PFC2, sdr0_pfc2); sdr0_pfc2 = (sdr0_pfc2 & ~SDR0_PFC2_SELECT_MASK) | SDR0_PFC2_SELECT_CONFIG_4; @@ -116,6 +160,58 @@ int board_early_init_f(void) return 0; }
+/* + * The boot flash on CS0 normally has its write-enable pin disabled, and so will + * not respond to CFI commands. This routine therefore fills in the flash + * information for the boot flash. (The flash at CS1 operates normally.) + */ +ulong board_flash_get_legacy (ulong base, int banknum, flash_info_t * info) +{ + uint32_t addr; + int i; + + if (1 != banknum) + return 0; + + info->size = CFG_FLASH0_SIZE; + info->sector_count = CFG_FLASH0_SIZE / 0x20000; + info->flash_id = 0x01000000; + info->portwidth = 2; + info->chipwidth = 2; + info->buffer_size = 32; + info->erase_blk_tout = 16384; + info->write_tout = 2; + info->buffer_write_tout = 5; + info->vendor = 2; + info->cmd_reset = 0x00F0; + info->interface = 2; + info->legacy_unlock = 0; + info->manufacturer_id = 1; + info->device_id = 0x007E; + +#if CFG_FLASH0_SIZE == 0x01000000 + info->device_id2 = 0x2101; +#elif CFG_FLASH0_SIZE == 0x04000000 + info->device_id2 = 0x2301; +#else +#error Unable to set device_id2 for current CFG_FLASH0_SIZE +#endif + + info->ext_addr = 0x0040; + info->cfi_version = 0x3133; + info->cfi_offset = 0x0055; + info->addr_unlock1 = 0x00000555; + info->addr_unlock2 = 0x000002AA; + info->name = "CFI conformant"; + for (i = 0, addr = -info->size; + i < info->sector_count; + ++i, addr += 0x20000) { + info->start[i] = addr; + info->protect[i] = 0x00; + } + return 1; +} + static int man_data_read(unsigned int addr) { /* @@ -189,12 +285,20 @@ static void set_serial_number(void) * If the environmental variable "serial#" is not set, try to set it * from the manufacturer's information serial EEPROM. */ - char s[MAN_SERIAL_NO_LENGTH + 1]; + char s[MAN_INFO_LENGTH + MAN_MAC_ADDR_LENGTH + 2]; + + if (getenv("serial#")) + return; + + if (!man_data_read_field(s, MAN_INFO_FIELD, MAN_INFO_LENGTH)) + return; + + s[MAN_INFO_LENGTH] = '-'; + if (!man_data_read_field(s + MAN_INFO_LENGTH + 1, MAN_MAC_ADDR_FIELD, + MAN_MAC_ADDR_LENGTH)) + return;
- if (0 == getenv("serial#") && - 0 != man_data_read_field(s, MAN_SERIAL_NO_FIELD, - MAN_SERIAL_NO_LENGTH)) - setenv("serial#", s); + setenv("serial#", s); }
static void set_mac_addresses(void) @@ -204,45 +308,58 @@ static void set_mac_addresses(void) * set, try to set them from the manufacturer's information serial * EEPROM. */ - char s[MAN_MAC_ADDR_LENGTH + 1]; + +#if MAN_MAC_ADDR_LENGTH % 2 != 0 +#error MAN_MAC_ADDR_LENGTH must be an even number +#endif + + char s[(3 * MAN_MAC_ADDR_LENGTH) / 2]; + char *src; + char *dst;
if (0 != getenv("ethaddr") && 0 != getenv("eth1addr")) return;
- if (0 == man_data_read_field(s, MAN_MAC_ADDR_FIELD, - MAN_MAC_ADDR_LENGTH)) + if (0 == man_data_read_field(s + (MAN_MAC_ADDR_LENGTH / 2) - 1, + MAN_MAC_ADDR_FIELD, MAN_MAC_ADDR_LENGTH)) return;
+ for (src = s + (MAN_MAC_ADDR_LENGTH / 2) - 1, dst = s; src != dst;) { + *dst++ = *src++; + *dst++ = *src++; + *dst++ = ':'; + } if (0 == getenv("ethaddr")) setenv("ethaddr", s);
if (0 == getenv("eth1addr")) { - ++s[MAN_MAC_ADDR_LENGTH - 1]; + ++s[((3 * MAN_MAC_ADDR_LENGTH) / 2) - 2]; setenv("eth1addr", s); } }
int misc_init_r(void) { - uint pbcr; - int size_val = 0; - u32 reg; + uint32_t pbcr; + int size_val; + uint32_t reg; unsigned long usb2d0cr = 0; unsigned long usb2phy0cr, usb2h0cr = 0; unsigned long sdr0_pfc1; - char *act = getenv("usbact"); - - /* Re-do flash sizing to get full correct info */ + uint32_t const flash1_size = gd->bd->bi_flashsize - CFG_FLASH0_SIZE; + char const *const act = getenv("usbact");
- /* adjust flash start and offset */ - gd->bd->bi_flashstart = 0 - gd->bd->bi_flashsize; + /* + * Re-do FLASH1 sizing and adjust flash start and offset. + */ + gd->bd->bi_flashstart = CFG_FLASH1_TOP - flash1_size; gd->bd->bi_flashoffset = 0;
- mtdcr(ebccfga, pb0cr); + mtdcr(ebccfga, pb1cr); pbcr = mfdcr(ebccfgd); - size_val = ffs(gd->bd->bi_flashsize) - 21; + size_val = ffs(flash1_size) - 21; pbcr = (pbcr & 0x0001ffff) | gd->bd->bi_flashstart | (size_val << 17); - mtdcr(ebccfga, pb0cr); + mtdcr(ebccfga, pb1cr); mtdcr(ebccfgd, pbcr);
/* @@ -250,14 +367,37 @@ int misc_init_r(void) */ flash_get_size(gd->bd->bi_flashstart, 0);
- /* Monitor protection ON by default */ - (void)flash_protect(FLAG_PROTECT_SET, -CFG_MONITOR_LEN, 0xffffffff, - &flash_info[0]); + /* + * Re-do FLASH1 sizing and adjust flash offset to reserve space for + * environment + */ + gd->bd->bi_flashoffset = + CFG_ENV_ADDR_REDUND + CFG_ENV_SECT_SIZE - CFG_FLASH1_ADDR;
+ mtdcr(ebccfga, pb1cr); + pbcr = mfdcr(ebccfgd); + size_val = ffs(gd->bd->bi_flashsize - CFG_FLASH0_SIZE) - 21; + pbcr = (pbcr & 0x0001ffff) | gd->bd->bi_flashstart | (size_val << 17); + mtdcr(ebccfga, pb1cr); + mtdcr(ebccfgd, pbcr); + + /* Monitor protection ON by default */ +#if defined(CONFIG_KORAT_PERMANENT) + (void)flash_protect(FLAG_PROTECT_SET, CFG_MONITOR_BASE, + CFG_MONITOR_BASE + CFG_MONITOR_LEN - 1, + flash_info + 1); +#else + (void)flash_protect(FLAG_PROTECT_SET, CFG_MONITOR_BASE, + CFG_MONITOR_BASE + CFG_MONITOR_LEN - 1, + flash_info); +#endif /* Env protection ON by default */ + (void)flash_protect(FLAG_PROTECT_SET, CFG_ENV_ADDR, + CFG_ENV_ADDR + CFG_ENV_SECT_SIZE - 1, + flash_info); (void)flash_protect(FLAG_PROTECT_SET, CFG_ENV_ADDR_REDUND, - CFG_ENV_ADDR_REDUND + 2 * CFG_ENV_SECT_SIZE - 1, - &flash_info[0]); + CFG_ENV_ADDR_REDUND + CFG_ENV_SECT_SIZE - 1, + flash_info);
/* * USB suff... @@ -393,6 +533,8 @@ int misc_init_r(void)
set_serial_number(); set_mac_addresses(); + gpio_write_bit(CFG_GPIO_ATMEGA_RESET_, 1); + return 0; }
@@ -402,10 +544,10 @@ int checkboard(void) u8 const rev = in_8((u8 *) CFG_CPLD_BASE + 0);
printf("Board: Korat, Rev. %X", rev); - if (s != NULL) + if (s) printf(", serial# %s", s);
- printf(", Ethernet PHY 0: "); + printf(".\n Ethernet PHY 0: "); if (gpio_read_out_bit(CFG_GPIO_PHY0_FIBER_SEL)) printf("fiber"); else @@ -418,7 +560,10 @@ int checkboard(void) printf("copper");
printf(".\n"); - return (0); +#if defined(CONFIG_KORAT_PERMANENT) + printf(" Executing permanent copy of U-Boot.\n"); +#endif + return 0; }
#if defined(CFG_DRAM_TEST) @@ -529,23 +674,26 @@ void pci_target_init(struct pci_controller *hose) /* * PowerPC440EPX PCI Master configuration. * Map one 1Gig range of PLB/processor addresses to PCI memory space. - * PLB address 0xA0000000-0xDFFFFFFF - * ==> PCI address 0xA0000000-0xDFFFFFFF + * PLB address 0x80000000-0xBFFFFFFF + * ==> PCI address 0x80000000-0xBFFFFFFF * Use byte reversed out routines to handle endianess. * Make this region non-prefetchable. */ out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ /* - disabled b4 setting */ out32r(PCIX0_PMM0LA, CFG_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CFG_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIX0_PMM0PCILA, + CFG_PCI_MEMBASE); /* PMM0 PCI Low Address */ out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ /* and enable region */
out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute */ /* - disabled b4 setting */ - out32r(PCIX0_PMM1LA, CFG_PCI_MEMBASE2); /* PMM0 Local Address */ - out32r(PCIX0_PMM1PCILA, CFG_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIX0_PMM1LA, + CFG_PCI_MEMBASE + 0x20000000); /* PMM0 Local Address */ + out32r(PCIX0_PMM1PCILA, + CFG_PCI_MEMBASE + 0x20000000); /* PMM0 PCI Low Address */ out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, */ /* and enable region */ diff --git a/board/korat/u-boot-F7FC.lds b/board/korat/u-boot-F7FC.lds new file mode 100644 index 0000000..cceb4f5 --- /dev/null +++ b/board/korat/u-boot-F7FC.lds @@ -0,0 +1,143 @@ +/* + * (C) Copyright 2002 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_ARCH(powerpc) +SEARCH_DIR(/lib); SEARCH_DIR(/usr/lib); SEARCH_DIR(/usr/local/lib); SEARCH_DIR(/usr/local/powerpc-any-elf/lib); +/* Do we need any of these for elf? + __DYNAMIC = 0; */ +SECTIONS +{ + .resetvec 0xF7FBFFFC : + { + *(.resetvec) + } = 0xffff + + .bootpg 0xF7FBF000 : + { + cpu/ppc4xx/start.o (.bootpg) + } = 0xffff + + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + .hash : { *(.hash) } + .dynsym : { *(.dynsym) } + .dynstr : { *(.dynstr) } + .rel.text : { *(.rel.text) } + .rela.text : { *(.rela.text) } + .rel.data : { *(.rel.data) } + .rela.data : { *(.rela.data) } + .rel.rodata : { *(.rel.rodata) } + .rela.rodata : { *(.rela.rodata) } + .rel.got : { *(.rel.got) } + .rela.got : { *(.rela.got) } + .rel.ctors : { *(.rel.ctors) } + .rela.ctors : { *(.rela.ctors) } + .rel.dtors : { *(.rel.dtors) } + .rela.dtors : { *(.rela.dtors) } + .rel.bss : { *(.rel.bss) } + .rela.bss : { *(.rela.bss) } + .rel.plt : { *(.rel.plt) } + .rela.plt : { *(.rela.plt) } + .init : { *(.init) } + .plt : { *(.plt) } + .text : + { + /* WARNING - the following is hand-optimized to fit within */ + /* the sector layout of our flash chips! XXX FIXME XXX */ + + cpu/ppc4xx/start.o (.text) + + *(.text) + *(.fixup) + *(.got1) + } + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(.rodata) + *(.rodata1) + *(.rodata.str1.4) + } + .fini : { *(.fini) } =0 + .ctors : { *(.ctors) } + .dtors : { *(.dtors) } + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + *(.got) + _GOT2_TABLE_ = .; + *(.got2) + _FIXUP_TABLE_ = .; + *(.fixup) + } + __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; + __fixup_entries = (. - _FIXUP_TABLE_)>>2; + + .data : + { + *(.data) + *(.data1) + *(.sdata) + *(.sdata2) + *(.dynamic) + CONSTRUCTORS + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss) *(.scommon) + *(.dynbss) + *(.bss) + *(COMMON) + } + + _end = . ; + PROVIDE (end = .); +} diff --git a/doc/README.korat b/doc/README.korat new file mode 100644 index 0000000..0a59f40 --- /dev/null +++ b/doc/README.korat @@ -0,0 +1,51 @@ +The Korat board has two NOR flashes, FLASH0 and FLASH1, which are connected to +chip select 0 and 1, respectively. FLASH0 contains 16 MiB, and is mapped to +addresses 0xFF000000 - 0xFFFFFFFF as U-Boot Flash Bank #2. FLASH1 contains +from 16 to 128 MiB, and is mapped to 0xF?000000 - 0xF7FFFFFF as U-Boot Flash +Bank #1 (with the starting address depending on the flash size detected at +runtime). The write-enable pin on FLASH0 is disabled, so the contents of FLASH0 +cannot be modified in the field. This also prevents FLASH0 from executing +commands to return chip information, so its configuration is hard-coded in +U-Boot. + +There are two versions of U-Boot for Korat: "permanent" and "upgradable". The +permanent U-Boot is pre-programmed at the top of FLASH0, e.g., at addresses +0xFFFA0000 - 0xFFFFFFFF for the current 384 KiB size. The upgradable U-Boot is +located 256 KiB from the top of FLASH1, e.g. at addresses 0xF7F6000 - 0xF7FC0000 +for the current 384 KiB size. FLASH1 addresses 0xF7FE0000 - 0xF7FF0000 are +used for the U-Boot environmental parameters, and addresses 0xF7FC0000 - +0xF7FDFFFF are used for the redundant copy of the parameters. These locations +are used by both versions of U-Boot. + +On booting, the permanent U-Boot in FLASH0 begins executing. After performing +minimal setup, it monitors the state of the board's Reset switch (GPIO47). If +the switch is sensed as open before a timeout period, then U-Boot branches to +address 0xF7FBFFFC. This causes the upgradable U-Boot to execute from the +beginning. If the switch remains closed thoughout the timeout period, the +permanent U-Boot activates the on-board buzzer until the switch is sensed as +opened. It then continues to execute without branching to FLASH1. The effect +of this is that normally the Korat board boots its upgradable U-Boot, but, if +this has been corrupted, the user can boot the permanent U-Boot, which can then +be used to erase and reload FLASH1 as needed. + +Note that it is not necessary for the permanent U-Boot to have all the latest +features, but only that it have sufficient functionality (working "tftp", +"erase", "cp.b", etc.) to repair FLASH1. Also, the permanent U-Boot makes no +assumptions about the size of FLASH1 or the size of the upgradable U-Boot: it is +sufficient that the upgradable U-Boot can be started by a branch to 0xF7FBFFFC. + +The build sequence: + + make korat_config + make all perm=1 + +builds the permanent U-Boot by selecting loader file "u-boot.lds" and defining +preprocessor symbol "CONFIG_KORAT_PERMANENT". The default build: + + make korat_config + make all + +creates the upgradable U-Boot but selecting loader file "u-boot-F7FC.lds" and +leaving preprocessor symbol "CONFIG_KORAT_PERMANENT" undefined. + +2008-02-22, Larry Johnson lrj@acm.org diff --git a/include/configs/korat.h b/include/configs/korat.h index dcec9b0..b4bac54 100644 --- a/include/configs/korat.h +++ b/include/configs/korat.h @@ -45,10 +45,10 @@ * Manufacturer's information serial EEPROM parameters */ #define MAN_DATA_EEPROM_ADDR 0x53 /* EEPROM I2C address */ -#define MAN_SERIAL_NO_FIELD 2 -#define MAN_SERIAL_NO_LENGTH 13 +#define MAN_INFO_FIELD 2 +#define MAN_INFO_LENGTH 9 #define MAN_MAC_ADDR_FIELD 3 -#define MAN_MAC_ADDR_LENGTH 17 +#define MAN_MAC_ADDR_LENGTH 12
/* * Base addresses -- Note these are effective addresses where the actual @@ -57,17 +57,18 @@ #define CFG_MONITOR_LEN (384 * 1024) /* Reserve 384 kiB for Monitor */ #define CFG_MALLOC_LEN (256 * 1024) /* Reserve 256 kiB for malloc() */
-#define CFG_BOOT_BASE_ADDR 0xf0000000 #define CFG_SDRAM_BASE 0x00000000 /* _must_ be 0 */ -#define CFG_FLASH_BASE 0xfc000000 /* start of FLASH */ +#define CFG_FLASH0_SIZE 0x01000000 +#define CFG_FLASH0_ADDR (-CFG_FLASH0_SIZE) +#define CFG_FLASH1_TOP 0xF8000000 +#define CFG_FLASH1_MAX_SIZE 0x08000000 +#define CFG_FLASH1_ADDR (CFG_FLASH1_TOP - CFG_FLASH1_MAX_SIZE) +#define CFG_FLASH_BASE CFG_FLASH1_ADDR /* start of FLASH */ #define CFG_MONITOR_BASE TEXT_BASE #define CFG_OCM_BASE 0xe0010000 /* ocm */ #define CFG_OCM_DATA_ADDR CFG_OCM_BASE #define CFG_PCI_BASE 0xe0000000 /* Internal PCI regs */ #define CFG_PCI_MEMBASE 0x80000000 /* mapped pci memory */ -#define CFG_PCI_MEMBASE1 CFG_PCI_MEMBASE + 0x10000000 -#define CFG_PCI_MEMBASE2 CFG_PCI_MEMBASE1 + 0x10000000 -#define CFG_PCI_MEMBASE3 CFG_PCI_MEMBASE2 + 0x10000000
/* Don't change either of these */ #define CFG_PERIPHERAL_BASE 0xef600000 /* internal peripherals */ @@ -108,13 +109,14 @@ /* * FLASH related */ -#define CFG_FLASH_CFI /* The flash is CFI compatible */ -#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ +#define CONFIG_FLASH_CFI_LEGACY /* Allow hard-coded config for FLASH0 */
-#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CFG_FLASH_BANKS_LIST { CFG_FLASH1_ADDR, CFG_FLASH0_ADDR }
-#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ +#define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ +#define CFG_MAX_FLASH_SECT 1024 /* max number of sectors on one chip */
#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ @@ -126,12 +128,12 @@ #define CFG_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */
#define CFG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ -#define CFG_ENV_ADDR ((-CFG_MONITOR_LEN)-CFG_ENV_SECT_SIZE) +#define CFG_ENV_ADDR (CFG_FLASH1_TOP - CFG_ENV_SECT_SIZE) #define CFG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */
-/* Address and size of Redundant Environment Sector */ -#define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR-CFG_ENV_SECT_SIZE) -#define CFG_ENV_SIZE_REDUND (CFG_ENV_SIZE) +/* Address and size of Redundant Environment Sector */ +#define CFG_ENV_ADDR_REDUND (CFG_ENV_ADDR - CFG_ENV_SECT_SIZE) +#define CFG_ENV_SIZE_REDUND CFG_ENV_SIZE
/* * DDR SDRAM @@ -180,6 +182,7 @@ #define CFG_BOOTFILE "bootfile=/tftpboot/korat/uImage\0" #define CFG_ROOTPATH "rootpath=/opt/eldk/ppc_4xxFP\0"
+/* Note: kernel_addr and ramdisk_addr assume that FLASH1 is 64 MiB. */ #define CONFIG_EXTRA_ENV_SETTINGS \ CFG_BOOTFILE \ CFG_ROOTPATH \ @@ -197,8 +200,8 @@ "bootm ${kernel_addr} ${ramdisk_addr}\0" \ "net_nfs=tftp 200000 ${bootfile};run nfsargs addip addtty;" \ "bootm\0" \ - "kernel_addr=FC000000\0" \ - "ramdisk_addr=FC180000\0" \ + "kernel_addr=F4000000\0" \ + "ramdisk_addr=F4400000\0" \ "load=tftp 200000 /tftpboot/${hostname}/u-boot.bin\0" \ "update=protect off FFFA0000 FFFFFFFF;era FFFA0000 FFFFFFFF;" \ "cp.b 200000 FFFA0000 60000\0" \ @@ -216,7 +219,7 @@ #define CONFIG_PHY_ADDR 2 /* PHY address, See schematics */ #define CONFIG_PHY_DYNAMIC_ANEG 1
-#define CONFIG_PHY_RESET 1 /* reset phy upon startup */ +#undef CONFIG_PHY_RESET /* Don't do software PHY reset */ #define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */
#define CONFIG_HAS_ETH0 @@ -322,6 +325,11 @@ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
/* + * Korat-specific options + */ +#define CFG_KORAT_MAN_RESET_MS 10000 /* timeout for manufacturer reset */ + +/* * PCI stuff */ /* General PCI */ @@ -350,12 +358,23 @@ */
/* Memory Bank 0 (NOR-FLASH) initialization */ +#if CFG_FLASH0_SIZE == 0x01000000 +#define CFG_EBC_PB0AP 0x04017300 +#define CFG_EBC_PB0CR (CFG_FLASH0_ADDR | 0x0009A000) +#elif CFG_FLASH0_SIZE == 0x04000000 #define CFG_EBC_PB0AP 0x04017300 -#define CFG_EBC_PB0CR (CFG_FLASH_BASE | 0x000DA000) +#define CFG_EBC_PB0CR (CFG_FLASH0_ADDR | 0x000DA000) +#else +#error Unable to configure chip select for current CFG_FLASH0_SIZE +#endif
/* Memory Bank 1 (NOR-FLASH) initialization */ +#if CFG_FLASH1_MAX_SIZE == 0x08000000 #define CFG_EBC_PB1AP 0x04017300 -#define CFG_EBC_PB1CR (0xF8000000 | 0x000DA000) +#define CFG_EBC_PB1CR (CFG_FLASH1_ADDR | 0x000FA000) +#else +#error Unable to configure chip select for current CFG_FLASH1_MAX_SIZE +#endif
/* Memory Bank 2 (CPLD) initialization */ #define CFG_EBC_PB2AP 0x04017300 @@ -426,6 +445,7 @@ * GPIO63 xxxx x x (reserved for trace port) */
+#define CFG_GPIO_ATMEGA_RESET_ 12 #define CFG_GPIO_ATMEGA_SS_ 13 #define CFG_GPIO_PHY0_FIBER_SEL 27 #define CFG_GPIO_PHY1_FIBER_SEL 28 @@ -435,6 +455,7 @@ #define CFG_GPIO_SFP1_TX_EN_ 33 #define CFG_GPIO_PHY0_EN 45 #define CFG_GPIO_PHY1_EN 46 +#define CFG_GPIO_RESET_PRESSED_ 47
/* * PPC440 GPIO Configuration
Applied to u-boot-ppc4xx locally. Thanks.
Best regards, Stefan
Larry Johnson
Stefan Roese
