Subject: [PATCH 1/6 v2] serial: qcom: add support for GENI serial driver
From b2516d965ee933bdb10fc158e36dedcf65bd7ce9 Mon Sep 17 00:00:00 2001
From: Dzmitry Sankouski dsankouski@gmail.com Date: Fri, 27 Aug 2021 17:47:22 +0300 Subject: [PATCH 1/6 v2] serial: qcom: add support for GENI serial driver
Generic Interface (GENI) Serial Engine (SE) based uart can be found on newer qualcomm SOCs, starting from SDM845. Tested on Samsung SM-G9600(starqltechn) by chain-loading u-boot with stock bootloader.
Signed-off-by: Dzmitry Sankouski dsankouski@gmail.com Cc: Ramon Fried rfried.dev@gmail.com --- Changes for v2: - change functions return type to void, where possible - remove '.' from summary line
MAINTAINERS | 1 + .../serial/msm-geni-serial.txt | 6 + drivers/serial/Kconfig | 17 + drivers/serial/Makefile | 1 + drivers/serial/serial_msm_geni.c | 579 ++++++++++++++++++ 5 files changed, 604 insertions(+) create mode 100644 doc/device-tree-bindings/serial/msm-geni-serial.txt create mode 100644 drivers/serial/serial_msm_geni.c
diff --git a/MAINTAINERS b/MAINTAINERS index 776ff703b9..52ddc99cda 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -390,6 +390,7 @@ F: drivers/gpio/msm_gpio.c F: drivers/mmc/msm_sdhci.c F: drivers/phy/msm8916-usbh-phy.c F: drivers/serial/serial_msm.c +F: drivers/serial/serial_msm_geni.c F: drivers/smem/msm_smem.c F: drivers/usb/host/ehci-msm.c
diff --git a/doc/device-tree-bindings/serial/msm-geni-serial.txt b/doc/device-tree-bindings/serial/msm-geni-serial.txt new file mode 100644 index 0000000000..9eadc2561b --- /dev/null +++ b/doc/device-tree-bindings/serial/msm-geni-serial.txt @@ -0,0 +1,6 @@ +Qualcomm GENI UART + +Required properties: +- compatible: must be "qcom,msm-geni-uart" +- reg: start address and size of the registers +- clock: interface clock (must accept baudrate as a frequency) diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 93348c0929..b420a5720d 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -278,6 +278,14 @@ config DEBUG_UART_S5P will need to provide parameters to make this work. The driver will be available until the real driver-model serial is running.
+config DEBUG_UART_MSM_GENI + bool "Qualcomm snapdragon" + depends on ARCH_SNAPDRAGON + help + Select this to enable a debug UART using the serial_msm driver. You + will need to provide parameters to make this work. The driver will + be available until the real driver-model serial is running. + config DEBUG_UART_MESON bool "Amlogic Meson" depends on MESON_SERIAL @@ -783,6 +791,15 @@ config MSM_SERIAL for example APQ8016 and MSM8916. Single baudrate is supported in current implementation (115200).
+config MSM_GENI_SERIAL + bool "Qualcomm on-chip GENI UART" + help + Support UART based on Generic Interface (GENI) Serial Engine (SE), used on Qualcomm Snapdragon SoCs. + Should support all qualcomm SOCs with Qualcomm Universal Peripheral (QUP) Wrapper cores, + i.e. newer ones, starting from SDM845. + Driver works in FIFO mode. + Multiple baudrates supported. + config OCTEON_SERIAL_BOOTCMD bool "MIPS Octeon PCI remote bootcmd input" depends on ARCH_OCTEON diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 3cbea8156f..d44caf4ea2 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -62,6 +62,7 @@ obj-$(CONFIG_PIC32_SERIAL) += serial_pic32.o obj-$(CONFIG_BCM283X_MU_SERIAL) += serial_bcm283x_mu.o obj-$(CONFIG_BCM283X_PL011_SERIAL) += serial_bcm283x_pl011.o obj-$(CONFIG_MSM_SERIAL) += serial_msm.o +obj-$(CONFIG_MSM_GENI_SERIAL) += serial_msm_geni.o obj-$(CONFIG_MVEBU_A3700_UART) += serial_mvebu_a3700.o obj-$(CONFIG_MPC8XX_CONS) += serial_mpc8xx.o obj-$(CONFIG_NULLDEV_SERIAL) += serial_nulldev.o diff --git a/drivers/serial/serial_msm_geni.c b/drivers/serial/serial_msm_geni.c new file mode 100644 index 0000000000..833e7df82e --- /dev/null +++ b/drivers/serial/serial_msm_geni.c @@ -0,0 +1,579 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Qualcomm GENI serial engine UART driver + * + * (C) Copyright 2021 Dzmitry Sankouski dsankouski@gmail.com + * + * Based on Linux driver. + */ + +#include <asm/io.h> +#include <clk.h> +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <errno.h> +#include <linux/compiler.h> +#include <log.h> +#include <malloc.h> +#include <serial.h> +#include <watchdog.h> + +#define UART_OVERSAMPLING (32) +#define STALE_TIMEOUT (160) +#define SE_UART_RX_STALE_CNT (0x294) +#define S_GENI_CMD_ABORT (BIT(1)) + +#define SE_GENI_S_CMD_CTRL_REG (0x634) +#define SE_GENI_M_CMD_CTRL_REG (0x604) + +/* GENI_M_CMD_CTRL_REG */ +#define M_GENI_CMD_CANCEL BIT(2) +#define M_GENI_CMD_ABORT BIT(1) +#define M_GENI_DISABLE BIT(0) + +/* GENI_S_CMD0 fields */ +#define S_OPCODE_MSK GENMASK(31, 27) +#define S_OPCODE_SHFT 27 +#define S_PARAMS_MSK GENMASK(26, 0) + +/* GENI_STATUS fields */ +#define M_GENI_CMD_ACTIVE BIT(0) +#define S_GENI_CMD_ACTIVE BIT(12) +#define S_CMD_DONE_EN (BIT(0)) +#define M_CMD_DONE_EN (BIT(0)) + +#define USEC_PER_SEC 1000000L + +#define SE_GENI_STATUS 0x40 +#define GENI_SER_M_CLK_CFG (0x48) +#define GENI_SER_S_CLK_CFG (0x4C) +#define SE_GENI_M_CMD0 0x600 +#define SE_GENI_M_IRQ_CLEAR 0x618 +#define SE_GENI_S_IRQ_STATUS (0x640) +#define SE_GENI_S_IRQ_CLEAR (0x648) +#define SE_GENI_S_IRQ_EN (0x644) +#define SE_GENI_M_IRQ_EN (0x614) +#define SE_GENI_TX_FIFOn 0x700 +#define SE_GENI_RX_FIFOn 0x780 +#define SE_GENI_TX_FIFO_STATUS 0x800 +#define SE_GENI_RX_FIFO_STATUS 0x804 +#define SE_GENI_TX_WATERMARK_REG (0x80C) +#define M_TX_FIFO_WATERMARK_EN (BIT(30)) +#define DEF_TX_WM (2) +#define SE_UART_TX_TRANS_LEN 0x270 +#define SE_GENI_TX_PACKING_CFG0 0x260 +#define SE_GENI_TX_PACKING_CFG1 0x264 +#define SE_GENI_RX_PACKING_CFG0 0x284 +#define SE_GENI_RX_PACKING_CFG1 0x288 +#define SE_UART_TX_STOP_BIT_LEN 0x26c +#define SE_UART_TX_WORD_LEN 0x268 +#define SE_UART_RX_WORD_LEN 0x28c +#define SE_UART_RX_TRANS_CFG 0x280 +#define SE_UART_RX_PARITY_CFG 0x2a8 +#define SE_UART_TX_TRANS_CFG 0x25c +#define SE_UART_TX_PARITY_CFG 0x2a4 + +#define GENI_FORCE_DEFAULT_REG (0x20) +/* GENI_FORCE_DEFAULT_REG fields */ +#define FORCE_DEFAULT (BIT(0)) + +#define S_CMD_ABORT_EN (BIT(5)) + +#define SE_GENI_S_CMD0 (0x630) +#define UART_START_READ (0x1) + +/* GENI_M_CMD_CTRL_REG */ +#define M_GENI_CMD_CANCEL BIT(2) +#define M_GENI_CMD_ABORT BIT(1) +#define M_GENI_DISABLE BIT(0) + +#define M_CMD_ABORT_EN BIT(5) + +#define M_CMD_DONE_EN (BIT(0)) +#define M_CMD_DONE_DISABLE_MASK ~M_CMD_DONE_EN +#define SE_GENI_M_IRQ_STATUS (0x610) + +#define M_OPCODE_SHIFT (27) +#define S_OPCODE_SHIFT (27) +#define M_TX_FIFO_WATERMARK_EN (BIT(30)) +#define UART_START_TX (0x1) +#define UART_CTS_MASK BIT(1) +#define M_SEC_IRQ_EN (BIT(31)) +#define TX_FIFO_WC_MSK (GENMASK(27, 0)) +#define RX_FIFO_WC_MSK (GENMASK(24, 0)) + +#define S_RX_FIFO_WATERMARK_EN (BIT(26)) +#define S_RX_FIFO_LAST_EN (BIT(27)) +#define M_RX_FIFO_WATERMARK_EN (BIT(26)) +#define M_RX_FIFO_LAST_EN (BIT(27)) + +/* GENI_SER_M_CLK_CFG/GENI_SER_S_CLK_CFG */ +#define SER_CLK_EN (BIT(0)) +#define CLK_DIV_MSK (GENMASK(15, 4)) +#define CLK_DIV_SHFT (4) + +#define SE_HW_PARAM_0 (0xE24) +/* SE_HW_PARAM_0 fields */ +#define TX_FIFO_WIDTH_MSK (GENMASK(29, 24)) +#define TX_FIFO_WIDTH_SHFT (24) +#define TX_FIFO_DEPTH_MSK (GENMASK(21, 16)) +#define TX_FIFO_DEPTH_SHFT (16) + +DECLARE_GLOBAL_DATA_PTR; + +struct msm_serial_data { + phys_addr_t base; + u32 baud; +}; + +static int get_clk_cfg(unsigned long clk_freq, unsigned long *ser_clk) { + unsigned long root_freq[] = {7372800, 14745600, 19200000, 29491200, + 32000000, 48000000, 64000000, 80000000, + 96000000, 100000000}; + int i; + int match = -1; + + for (i = 0; i < ARRAY_SIZE(root_freq); i++) { + if (clk_freq > root_freq[i]) + continue; + + if (!(root_freq[i] % clk_freq)) { + match = i; + break; + } + } + if (match != -1) + *ser_clk = root_freq[match]; + else + pr_err("clk_freq %ld\n", clk_freq); + return match; +} + +static int get_clk_div_rate(u32 baud, u64 *desired_clk_rate) { + unsigned long ser_clk; + int dfs_index; + int clk_div = 0; + + *desired_clk_rate = baud * UART_OVERSAMPLING; + dfs_index = get_clk_cfg(*desired_clk_rate, &ser_clk); + if (dfs_index < 0) { + pr_err("%s: Can't find matching DFS entry for baud %d\n", + __func__, baud); + clk_div = -EINVAL; + goto exit_get_clk_div_rate; + } + + clk_div = ser_clk / *desired_clk_rate; + *desired_clk_rate = ser_clk; +exit_get_clk_div_rate: + return clk_div; +} + +static int geni_serial_set_clock_rate(struct udevice *dev, u64 rate) { + struct clk *clk; + int ret; + + clk = devm_clk_get(dev, "se-clk"); + if (!clk) + return -EINVAL; + + ret = clk_set_rate(clk, rate); + return ret; +} + +/** + * geni_se_get_tx_fifo_depth() - Get the TX fifo depth of the serial engine + * @base: Pointer to the concerned serial engine. + * + * This function is used to get the depth i.e. number of elements in the + * TX fifo of the serial engine. + * + * Return: TX fifo depth in units of FIFO words. + */ +static inline u32 geni_se_get_tx_fifo_depth(long base) { + u32 tx_fifo_depth; + + tx_fifo_depth = ((readl(base + SE_HW_PARAM_0) & TX_FIFO_DEPTH_MSK) >> + TX_FIFO_DEPTH_SHFT); + return tx_fifo_depth; +} + +/** + * geni_se_get_tx_fifo_width() - Get the TX fifo width of the serial engine + * @base: Pointer to the concerned serial engine. + * + * This function is used to get the width i.e. word size per element in the + * TX fifo of the serial engine. + * + * Return: TX fifo width in bits + */ +static inline u32 geni_se_get_tx_fifo_width(long base) { + u32 tx_fifo_width; + + tx_fifo_width = ((readl(base + SE_HW_PARAM_0) & TX_FIFO_WIDTH_MSK) >> + TX_FIFO_WIDTH_SHFT); + return tx_fifo_width; +} + +static inline void geni_serial_baud(phys_addr_t base_address, u64 uclk, + int baud) { + u32 clk_div; + u32 s_clk_cfg = 0; + + clk_div = get_clk_div_rate(baud, &uclk); + + s_clk_cfg |= SER_CLK_EN; + s_clk_cfg |= (clk_div << CLK_DIV_SHFT); + + writel(s_clk_cfg, base_address + GENI_SER_M_CLK_CFG); + writel(s_clk_cfg, base_address + GENI_SER_S_CLK_CFG); +} + +int msm_serial_setbrg(struct udevice *dev, int baud) { + struct msm_serial_data *priv = dev_get_priv(dev); + + priv->baud = baud; + u32 clk_div; + u64 clk_rate; + + clk_div = get_clk_div_rate(baud, &clk_rate); + geni_serial_set_clock_rate(dev, clk_rate); + geni_serial_baud(priv->base, clk_rate, baud); + + return 0; +} + +static bool qcom_geni_serial_poll_bit(const struct udevice *dev, int offset, + int field, bool set) { + u32 reg; + struct msm_serial_data *priv = dev_get_priv(dev); + unsigned int baud; + unsigned int tx_fifo_depth; + unsigned int tx_fifo_width; + unsigned int fifo_bits; + unsigned long timeout_us = 10000; + + baud = 115200; + + if (priv) { + baud = priv->baud; + if (!baud) + baud = 115200; + tx_fifo_depth = geni_se_get_tx_fifo_depth(priv->base); + tx_fifo_width = geni_se_get_tx_fifo_width(priv->base); + fifo_bits = tx_fifo_depth * tx_fifo_width; + /* + * Total polling iterations based on FIFO worth of bytes to be + * sent at current baud. Add a little fluff to the wait. + */ + timeout_us = ((fifo_bits * USEC_PER_SEC) / baud) + 500; + } + + /* + * Use custom implementation instead of readl_poll_atomic since ktimer + * is not ready at the time of early console. + */ + timeout_us = DIV_ROUND_UP(timeout_us, 10) * 10; + while (timeout_us) { + reg = readl(priv->base + offset); + if ((bool)(reg & field) == set) + return true; + udelay(10); + timeout_us -= 10; + } + return false; +} + +static void qcom_geni_serial_setup_tx(u64 base, u32 xmit_size) { + u32 m_cmd; + + writel(xmit_size, base + SE_UART_TX_TRANS_LEN); + m_cmd = UART_START_TX << M_OPCODE_SHIFT; + writel(m_cmd, base + SE_GENI_M_CMD0); +} + +static inline void qcom_geni_serial_poll_tx_done(const struct udevice *dev) { + struct msm_serial_data *priv = dev_get_priv(dev); + int done = 0; + u32 irq_clear = M_CMD_DONE_EN; + + done = qcom_geni_serial_poll_bit(dev, SE_GENI_M_IRQ_STATUS, + M_CMD_DONE_EN, true); + if (!done) { + writel(M_GENI_CMD_ABORT, priv->base + SE_GENI_M_CMD_CTRL_REG); + irq_clear |= M_CMD_ABORT_EN; + qcom_geni_serial_poll_bit(dev, SE_GENI_M_IRQ_STATUS, + M_CMD_ABORT_EN, true); + } + writel(irq_clear, priv->base + SE_GENI_M_IRQ_CLEAR); +} + +static u32 qcom_geni_serial_tx_empty(u64 base) { + return !readl(base + SE_GENI_TX_FIFO_STATUS); +} + +/** + * geni_se_setup_s_cmd() - Setup the secondary sequencer + * @se: Pointer to the concerned serial engine. + * @cmd: Command/Operation to setup in the secondary sequencer. + * @params: Parameter for the sequencer command. + * + * This function is used to configure the secondary sequencer with the + * command and its associated parameters. + */ +static inline void geni_se_setup_s_cmd(u64 base, u32 cmd, u32 params) { + u32 s_cmd; + + s_cmd = readl(base + SE_GENI_S_CMD0); + s_cmd &= ~(S_OPCODE_MSK | S_PARAMS_MSK); + s_cmd |= (cmd << S_OPCODE_SHFT); + s_cmd |= (params & S_PARAMS_MSK); + writel(s_cmd, base + SE_GENI_S_CMD0); +} + +static void qcom_geni_serial_start_tx(u64 base) { + u32 irq_en; + u32 status; + + status = readl(base + SE_GENI_STATUS); + if (status & M_GENI_CMD_ACTIVE) + return; + + if (!qcom_geni_serial_tx_empty(base)) + return; + + irq_en = readl(base + SE_GENI_M_IRQ_EN); + irq_en |= M_TX_FIFO_WATERMARK_EN | M_CMD_DONE_EN; + + writel(DEF_TX_WM, base + SE_GENI_TX_WATERMARK_REG); + writel(irq_en, base + SE_GENI_M_IRQ_EN); +} + +static void qcom_geni_serial_start_rx(struct udevice *dev) { + u32 irq_en; + u32 status; + struct msm_serial_data *priv = dev_get_priv(dev); + + status = readl(priv->base + SE_GENI_STATUS); + + geni_se_setup_s_cmd(priv->base, UART_START_READ, 0); + + irq_en = readl(priv->base + SE_GENI_S_IRQ_EN); + irq_en |= S_RX_FIFO_WATERMARK_EN | S_RX_FIFO_LAST_EN; + writel(irq_en, priv->base + SE_GENI_S_IRQ_EN); + + irq_en = readl(priv->base + SE_GENI_M_IRQ_EN); + irq_en |= M_RX_FIFO_WATERMARK_EN | M_RX_FIFO_LAST_EN; + writel(irq_en, priv->base + SE_GENI_M_IRQ_EN); +} + +static void msm_geni_serial_setup_rx(struct udevice *dev) { + u32 irq_clear = S_CMD_DONE_EN; + u32 geni_s_irq_en; + u32 geni_m_irq_en; + u32 cfg0; + u32 cfg1; + struct msm_serial_data *priv = dev_get_priv(dev); + + irq_clear |= S_CMD_ABORT_EN; + + writel(S_GENI_CMD_ABORT, priv->base + SE_GENI_S_CMD_CTRL_REG); + qcom_geni_serial_poll_bit(dev, SE_GENI_S_CMD_CTRL_REG, S_GENI_CMD_ABORT, + false); + writel(irq_clear, priv->base + SE_GENI_S_IRQ_CLEAR); + writel(FORCE_DEFAULT, priv->base + GENI_FORCE_DEFAULT_REG); + + cfg0 = 0xf; + cfg1 = 0x0; + writel(cfg0, priv->base + SE_GENI_RX_PACKING_CFG0); + writel(cfg1, priv->base + SE_GENI_RX_PACKING_CFG1); + + geni_se_setup_s_cmd(priv->base, UART_START_READ, 0); + + geni_s_irq_en = readl(priv->base + SE_GENI_S_IRQ_EN); + geni_m_irq_en = readl(priv->base + SE_GENI_M_IRQ_EN); + + geni_s_irq_en |= S_RX_FIFO_WATERMARK_EN | S_RX_FIFO_LAST_EN; + geni_m_irq_en |= M_RX_FIFO_WATERMARK_EN | M_RX_FIFO_LAST_EN; + + writel(geni_s_irq_en, priv->base + SE_GENI_S_IRQ_EN); + writel(geni_m_irq_en, priv->base + SE_GENI_M_IRQ_EN); +} + +static int msm_serial_putc(struct udevice *dev, const char ch) { + struct msm_serial_data *priv = dev_get_priv(dev); + + writel(DEF_TX_WM, priv->base + SE_GENI_TX_WATERMARK_REG); + qcom_geni_serial_setup_tx(priv->base, 1); + + qcom_geni_serial_poll_bit(dev, SE_GENI_M_IRQ_STATUS, + M_TX_FIFO_WATERMARK_EN, true); + + writel(ch, priv->base + SE_GENI_TX_FIFOn); + writel(M_TX_FIFO_WATERMARK_EN, priv->base + SE_GENI_M_IRQ_CLEAR); + + qcom_geni_serial_poll_tx_done(dev); + + return 0; +} + +static int msm_serial_getc(struct udevice *dev) { + struct msm_serial_data *priv = dev_get_priv(dev); + u32 rx_fifo; + u32 m_irq_status; + u32 s_irq_status; + + writel(1 << S_OPCODE_SHIFT, priv->base + SE_GENI_S_CMD0); + + qcom_geni_serial_poll_bit(dev, SE_GENI_M_IRQ_STATUS, M_SEC_IRQ_EN, + true); + + m_irq_status = readl(priv->base + SE_GENI_M_IRQ_STATUS); + s_irq_status = readl(priv->base + SE_GENI_S_IRQ_STATUS); + writel(m_irq_status, priv->base + SE_GENI_M_IRQ_CLEAR); + writel(s_irq_status, priv->base + SE_GENI_S_IRQ_CLEAR); + qcom_geni_serial_poll_bit(dev, SE_GENI_RX_FIFO_STATUS, RX_FIFO_WC_MSK, + true); + + if (!readl(priv->base + SE_GENI_RX_FIFO_STATUS)) + return 0; + + rx_fifo = readl(priv->base + SE_GENI_RX_FIFOn); + return rx_fifo & 0xff; +} + +static int msm_serial_pending(struct udevice *dev, bool input) { + struct msm_serial_data *priv = dev_get_priv(dev); + + if (input) + return readl(priv->base + SE_GENI_RX_FIFO_STATUS) & + RX_FIFO_WC_MSK; + else + return readl(priv->base + SE_GENI_TX_FIFO_STATUS) & + TX_FIFO_WC_MSK; + + return 0; +} + +static const struct dm_serial_ops msm_serial_ops = { + .putc = msm_serial_putc, + .pending = msm_serial_pending, + .getc = msm_serial_getc, + .setbrg = msm_serial_setbrg, +}; + +static inline void geni_serial_init(phys_addr_t base_address) { + u32 tx_trans_cfg; + u32 tx_parity_cfg = 0; /* Disable Tx Parity */ + u32 rx_trans_cfg = 0; + u32 rx_parity_cfg = 0; /* Disable Rx Parity */ + u32 stop_bit_len = 0; /* Default stop bit length - 1 bit */ + u32 bits_per_char; + + /* + * Ignore Flow control. + * n = 8. + */ + tx_trans_cfg = UART_CTS_MASK; + bits_per_char = BITS_PER_BYTE; + + u32 cfg0 = 0xf; + + u32 cfg1 = 0x0; + + /* + * Make an unconditional cancel on the main sequencer to reset + * it else we could end up in data loss scenarios. + */ + writel(cfg0, base_address + SE_GENI_TX_PACKING_CFG0); + writel(cfg1, base_address + SE_GENI_TX_PACKING_CFG1); + writel(cfg0, base_address + SE_GENI_RX_PACKING_CFG0); + writel(cfg1, base_address + SE_GENI_RX_PACKING_CFG1); + + writel(tx_trans_cfg, base_address + SE_UART_TX_TRANS_CFG); + writel(tx_parity_cfg, base_address + SE_UART_TX_PARITY_CFG); + writel(rx_trans_cfg, base_address + SE_UART_RX_TRANS_CFG); + writel(rx_parity_cfg, base_address + SE_UART_RX_PARITY_CFG); + writel(bits_per_char, base_address + SE_UART_TX_WORD_LEN); + writel(bits_per_char, base_address + SE_UART_RX_WORD_LEN); + writel(stop_bit_len, base_address + SE_UART_TX_STOP_BIT_LEN); +} + +static int msm_serial_probe(struct udevice *dev) { + struct msm_serial_data *priv = dev_get_priv(dev); + + /* No need to reinitialize the UART after relocation */ + if (gd->flags & GD_FLG_RELOC) + return 0; + + geni_serial_init(priv->base); + msm_geni_serial_setup_rx(dev); + qcom_geni_serial_start_rx(dev); + qcom_geni_serial_start_tx(priv->base); + + pinctrl_select_state(dev, "uart"); + + return 0; +} + +static int msm_serial_ofdata_to_platdata(struct udevice *dev) { + struct msm_serial_data *priv = dev_get_priv(dev); + + priv->base = dev_read_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + return 0; +} + +static const struct udevice_id msm_serial_ids[] = { + {.compatible = "qcom,msm-geni-uart"}, {}}; + +U_BOOT_DRIVER(serial_msm_geni) = { + .name = "serial_msm_geni", + .id = UCLASS_SERIAL, + .of_match = msm_serial_ids, + .of_to_plat = msm_serial_ofdata_to_platdata, + .priv_auto = sizeof(struct msm_serial_data), + .probe = msm_serial_probe, + .ops = &msm_serial_ops, +}; + +#ifdef CONFIG_DEBUG_UART_MSM_GENI + +static struct msm_serial_data init_serial_data = { + .base = CONFIG_DEBUG_UART_BASE +}; + +/* Serial dumb device, to reuse driver code */ +static struct udevice init_dev = { + .priv_ = &init_serial_data, +}; + +#include <debug_uart.h> + +static inline void _debug_uart_init(void) { + phys_addr_t base = CONFIG_DEBUG_UART_BASE; + + geni_serial_init(base); + geni_serial_baud(base, CONFIG_DEBUG_UART_CLOCK, CONFIG_BAUDRATE); + qcom_geni_serial_start_tx(base); +} + +static inline void _debug_uart_putc(int ch) { + phys_addr_t base = CONFIG_DEBUG_UART_BASE; + + writel(DEF_TX_WM, base + SE_GENI_TX_WATERMARK_REG); + qcom_geni_serial_setup_tx(base, 1); + qcom_geni_serial_poll_bit(&init_dev, SE_GENI_M_IRQ_STATUS, + M_TX_FIFO_WATERMARK_EN, true); + + writel(ch, base + SE_GENI_TX_FIFOn); + writel(M_TX_FIFO_WATERMARK_EN, base + SE_GENI_M_IRQ_CLEAR); + qcom_geni_serial_poll_tx_done(&init_dev); +} + +DEBUG_UART_FUNCS + +#endif
Dear Dzmitry Sankouski ,
On Tue, 31 Aug 2021 at 20:29, Дмитрий Санковский dsankouski@gmail.com wrote:
From b2516d965ee933bdb10fc158e36dedcf65bd7ce9 Mon Sep 17 00:00:00 2001 From: Dzmitry Sankouski dsankouski@gmail.com Date: Fri, 27 Aug 2021 17:47:22 +0300 Subject: [PATCH 1/6 v2] serial: qcom: add support for GENI serial driver
Changes for v2:
Please check the coding style first. It will help you: CodingStyle < U-Boot < DENX https://www.denx.de/wiki/U-Boot/CodingStyle
Minkyu Kang
Дмитрий Санковский
