[U-Boot] Antw: [PATCH v11 3/4] mtd: nand: omap: add CONFIG_NAND_OMAP_ECCSCHEME for selection of ecc-scheme
Dear Pekon,
thanks for your mail. This ECC topic is of some complexity. :(
I am close to solve a huge problem here, switching boards from 1bit-SW-ECC to BCH4. The only missing part is, that OMAP xloader and uboot calculates the BCH4 ECC values than Sitara XLoader (although the x-loader binaries are identical). Main problem is not that this is different to Linux - this is not nice, but not a problem. I solved this by implementing a second linux compatible BCH4 in uboot (which works on both platforms). Problem is, that BCH4 (as it is implemented in aragos xloader) seems not to work on OMAP3503. And it is not understood by me, why this is not working, or what can the reason for this.
You suggestions address kernel/uboot changes. For this I have already a solution. I am running into other troubles if I shift to your suggestions, and I can't see an improvement for the xloader problem. I know, nowadays the xloader is SPL and is derived from uboot. But I haven't the power to completely change everything again. Frankly speaking, I afraid another nightmare here. Unfortunatly TI doesn't have an newer SDK for OMAP3503/AM3703. Is it true, that in this Arago or TI SDK the only functional ECC scheme are 1 bit SW and 1 bit HW (for xloader)?
For me it seems (if you check my logs) that in xloader the omap_calculate_ecc_bch4() uses hardware GPMC registers. Main question: why this doens't work or give different results in OMAP?
The version I take over for uboot and kernel (according to Technical Note from Micron tn2971_software_bch_ecc_on_linux.pdf), this functions. The counterpart for this seems to me in bch.c encode_bch(), which seems to run completly independent on hardware.
Please understand my situation. At TI forum I asked since monthes with no real help. So I started my work and succeeded 90%.
Best regards Steffen
"Gupta, Pekon" pekon@ti.com schrieb am 21.11.13 um 06:12:
This patch adds new CONFIG_NAND_OMAP_ECCSCHEME, replacing other
distributed
CONFIG_xx used for selecting NAND ecc-schemes. This patch aims at solving following issues.
- Currently ecc-scheme is tied to SoC platform, which prevents user
to
select other ecc-schemes also supported in hardware. like;
- most of OMAP3 SoC platforms use only 1-bit Hamming ecc-scheme,
inspite
the fact that they can use higher ecc-schemes like 8-bit
ecc-schemes with
software based error detection
(OMAP_ECC_BCH4_CODE_HW_DETECTION_SW).
- most of AM33xx SoC plaforms use 8-bit BCH ecc-scheme for now, but
hardware
supports BCH16 ecc-scheme also.
- Different platforms use different CONFIG_xx to select ecc-schemes,
which
adds confusion for user while migrating platforms.
- *CONFIG_NAND_OMAP_ELM* which enables ELM hardware engine, selects
only
8-bit BCH ecc-scheme with h/w based error-correction
(OMAP_ECC_BCH8_CODE_HW) whereas ELM hardware engine supports other ecc-schemes also like;
BCH4,
and BCH16 (in future).
- *CONFIG_NAND_OMAP_BCH8* selects 8-bit BCH ecc-scheme with s/w
based error
correction (OMAP_ECC_BCH8_CODE_HW_DETECTION_SW).
- *CONFIG_SPL_NAND_SOFTECC* selects 1-bit Hamming ecc-scheme using
s/w library
Thus adding new *CONFIG_NAND_OMAP_ECCSCHEME* de-couples ecc-scheme
dependency
on SoC platform and NAND driver. And user can select ecc-scheme
independently
foreach board. However, selection some hardware based ecc-schemes
(OMAP_ECC_BCHx_CODE_HW)
still depends on presence of ELM hardware engine on SoC. (Refer
doc/README.nand)
Signed-off-by: Pekon Gupta pekon@ti.com
doc/README.nand | 23 +++++++++++++++++++++++ doc/README.omap3 | 3 +-- drivers/mtd/nand/omap_gpmc.c | 13 ++++--------- include/configs/am335x_evm.h | 3 ++- include/configs/am335x_igep0033.h | 1 + include/configs/am3517_crane.h | 1 + include/configs/am3517_evm.h | 1 + include/configs/devkit8000.h | 1 + include/configs/mcx.h | 2 +- include/configs/omap3_beagle.h | 1 + include/configs/omap3_evm.h | 1 + include/configs/omap3_evm_quick_nand.h | 1 + include/configs/omap3_igep00x0.h | 1 + include/configs/omap3_overo.h | 1 + include/configs/siemens-am33x-common.h | 1 + include/configs/tam3517-common.h | 2 +- include/configs/tricorder.h | 2 +- 17 files changed, 43 insertions(+), 15 deletions(-)
diff --git a/doc/README.nand b/doc/README.nand index 8a4252b..25a4412 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -198,6 +198,29 @@ Platform specific options detection. However ECC calculation on such plaforms would
still be
done by GPMC controller.
- CONFIG_NAND_OMAP_ECCSCHEME
On OMAP platforms, this CONFIG specifies NAND ECC scheme.
It can take following values:
OMAP_ECC_HAM1_CODE_SW
1-bit Hamming code using software lib.
(for legacy devices only)
OMAP_ECC_HAM1_CODE_HW
1-bit Hamming code using GPMC hardware.
4-bit BCH code (unsupported)
8-bit BCH code with
- ecc calculation using GPMC hardware engine,
- error detection using software library.
- requires CONFIG_BCH to enable software BCH library
(For legacy device which do not have ELM h/w engine)
8-bit BCH code with
- error detection using ELM hardware engine.
NOTE:
diff --git a/doc/README.omap3 b/doc/README.omap3 index 1fbe79d..a62c357 100644 --- a/doc/README.omap3 +++ b/doc/README.omap3 @@ -161,8 +161,7 @@ BCH8
To enable hardware assisted BCH8 (8-bit BCH [Bose, Chaudhuri,
Hocquenghem])
on OMAP3 devices we can use the BCH library in lib/bch.c. To do so add
CONFIG_BCH -to enable the library and CONFIG_NAND_OMAP_BCH8 to to enable
hardware
assisted -syndrom generation to your board config. +and set CONFIG_NAND_OMAP_ECCSCHEME=5 (refer README.nand) for
selecting
BCH8_SW. The NAND OOB layout is the same as in linux kernel, if the linux
kernel
BCH8 implementation for OMAP3 works for you so the u-boot version should
also.
When you require the SPL to read with BCH8 there are two more
configs to
diff --git a/drivers/mtd/nand/omap_gpmc.c
b/drivers/mtd/nand/omap_gpmc.c
index e6b289d..5e7e6b3 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -1004,18 +1004,13 @@ int board_nand_init(struct nand_chip *nand) nand->ecc.layout = &omap_ecclayout;
/* select ECC scheme */
-#if defined(CONFIG_NAND_OMAP_ELM)
err = omap_select_ecc_scheme(nand, OMAP_ECC_BCH8_CODE_HW,
+#if defined(CONFIG_NAND_OMAP_ECCSCHEME)
CONFIG_SYS_NAND_PAGE_SIZE,
CONFIG_SYS_NAND_OOBSIZE);
-#elif defined(CONFIG_NAND_OMAP_BCH8)
OMAP_ECC_BCH8_CODE_HW_DETECTION_SW,
-#elif !defined(CONFIG_SPL_BUILD) ||
defined(CONFIG_SPL_NAND_SOFTECC)
+#else
/* pagesize and oobsize are not required to configure sw
ecc-scheme
*/ err = omap_select_ecc_scheme(nand, OMAP_ECC_HAM1_CODE_SW, 0, 0); -#else
err = omap_select_ecc_scheme(nand, OMAP_ECC_HAM1_CODE_HW,
#endif if (err) return err; diff --git a/include/configs/am335x_evm.h
b/include/configs/am335x_evm.h
index 4c79ddb..d75df92 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -239,7 +239,8 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14
+#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #endif diff --git a/include/configs/am335x_igep0033.h b/include/configs/am335x_igep0033.h index 88ced73..115d1b3 100644 --- a/include/configs/am335x_igep0033.h +++ b/include/configs/am335x_igep0033.h @@ -264,6 +264,7 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 14 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW
diff --git a/include/configs/am3517_crane.h
b/include/configs/am3517_crane.h
index 6fd3fb9..468fb43 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -340,6 +340,7 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000
diff --git a/include/configs/am3517_evm.h
b/include/configs/am3517_evm.h
index 7e9c55e..a3473b5 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -334,6 +334,7 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000
diff --git a/include/configs/devkit8000.h
b/include/configs/devkit8000.h
index 474a568..4f43ba9 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -327,6 +327,7 @@
diff --git a/include/configs/mcx.h b/include/configs/mcx.h index a2f7cf7..dcd29ce 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -353,7 +353,6 @@ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_BOARD_INIT #define CONFIG_SPL_NAND_SIMPLE -#define CONFIG_SPL_NAND_SOFTECC
#define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBDISK_SUPPORT @@ -395,6 +394,7 @@ 56, 57, 58, 59, 60, 61, 62,
63}
#define CONFIG_SYS_NAND_ECCSIZE 256 #define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_SW
diff --git a/include/configs/omap3_beagle.h
b/include/configs/omap3_beagle.h
index bba39d4..9eab190 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -431,6 +431,7 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000
diff --git a/include/configs/omap3_evm.h
b/include/configs/omap3_evm.h
index 3ace8bb..b7638fb 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -107,6 +107,7 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000
diff --git a/include/configs/omap3_evm_quick_nand.h b/include/configs/omap3_evm_quick_nand.h index 9ecd70d..4427e88 100644 --- a/include/configs/omap3_evm_quick_nand.h +++ b/include/configs/omap3_evm_quick_nand.h @@ -86,6 +86,7 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000
diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 75d7d70..71062a6 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -362,6 +362,7 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 #endif diff --git a/include/configs/omap3_overo.h
b/include/configs/omap3_overo.h
index 84b4aee..e0f0262 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -324,6 +324,7 @@ 10, 11, 12, 13} #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 85d6dc2..f37653f 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -195,6 +195,7 @@
#define CONFIG_SYS_NAND_ECCSTEPS 4 #define CONFIG_SYS_NAND_ECCTOTAL
(CONFIG_SYS_NAND_ECCBYTES *
\ diff --git a/include/configs/tam3517-common.h
b/include/configs/tam3517-common.h
index 6112c1b..439fc47 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -224,7 +224,6 @@ #define CONFIG_SPL_BOARD_INIT #define CONFIG_SPL_CONSOLE #define CONFIG_SPL_NAND_SIMPLE -#define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SPL_NAND_WORKSPACE 0x8f07f000 /* below BSS */
#define CONFIG_SPL_LIBCOMMON_SUPPORT @@ -261,6 +260,7 @@ 56, 57, 58, 59, 60, 61, 62,
63}
diff --git a/include/configs/tricorder.h
b/include/configs/tricorder.h
index afd8707..b38b955 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -138,7 +138,6 @@
#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number
of
NAND */ /* devices
-#define CONFIG_NAND_OMAP_BCH8 #define CONFIG_BCH
/* commands to include */ @@ -374,6 +373,7 @@
#define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 13 +#define CONFIG_NAND_OMAP_ECCSCHEME
-- 1.8.1
+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1994 bis 2014 - 20 Jahre SensoPart Industriesensorik >> http://www.sensopart.com/de/aktuelles/sensopart-news +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Besuchen Sie uns 2014 auf folgenden Messen: 21.-24.01.2014 NORTEC, Hamburg 13.-16.03.2014 CWIEME, Xian, China 01.-03.04.2014 Smart Industrie, Paris 07.-09.05.2014 Industrial Automation, Peking 03.-06.06.2014 AUTOMATICA, München 01.-05.09.2014 CNZBH, Shenyang, China 06.-09.10.2014 MOTEK, Stuttgart 04.-08.11.2014 CIIF Expo, Shanghai 05.-07.11.2014 FMB Forum Maschinenbau, Bad Salzuflen 04.-06.11.2014 VISION, Stuttgart 25.-27.11.2014 sps ipc drives, Nürnberg +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Besuchen Sie uns auf http://www.sensopart.com
Postanschrift: Sensopart GmbH | Am Wiedenbach 1 | D-79695 Wieden, Germany Geschäftsführer: Dr. Theodor Wanner - Sitz der Gesellschaft: 79695 Wieden/Baden-Württemberg Handelsregister: Amtsgericht Freiburg HRB 660163 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Zusätzliche Hinweise / Additional information
Vertraulichkeit: Diese E-Mail und/oder ihre Anhänge kann vertrauliche und/oder rechtlich geschützte Informationen enthalten. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
Virus: Diese E-Mail wurde auf Viren überprüft. Dies garantiert aber keine Virenfreiheit. Wir übernehmen keine Haftung für eventuelle Schäden, die durch diese E-Mail oder deren Anhänge entstehen könnten. Danke für Ihr Verständnis.
Notice: This transmittal and/or attachments may be privileged or confidential. If you are not the intended recipient, you are hereby notified that you have received this transmittal in error; any review, dissemination, or copying is strictly prohibited. If you received this transmittal in error, please notify us immediately by reply and immediately delete this message and all its attachments. Thank you
Dear Steffen Arendt,
you could test the tricorder configuration. It does work with Pekon's patchset mentioned in your mail. I haven't tested Pekon's changes when they where included. But my regular tests before each U-Boot release showed a change in OOB layout, therefore commit 1b82491ee6ee1e986e5521b33692a00e1f38fe75 was generated. It seems my first attempt to implement OMAP3 HW supported BCH in u-boot was buggy :( Sorry for that!
On 07/11/2014 10:27 AM, Steffen Arendt wrote:
Dear Pekon,
There is an issue in GPMC for AM37xx up to revision 1.0 (Advisory 1.54 'GPMC Has Incorrect ECC Computation for 4-Bit BCH Mode'). I think this includes the OMAP35xx variants.
U-Boot had also only 1 bit Hamming with two different OOB-schemes before my attempt to support BCH. Since X-Loader is outdated I think nobody cared to port these changes. Sorry, I never worked with X-Loader so I can't tell anything about it. You should really migrate to U-Boot!
I think it is because of the errata mentioned above. You should switch to BCH8 on OMAP3 devices in favor of BCH4.
U-Boot BCH8 support for OMAP3 is working, one example is tricorder board.
Best regards
Andreas Bießmann
Andreas Bießmann
Steffen Arendt
