[U-Boot] [PATCH] nios2: convert do_reset to use dm cpu data
Convert do_reset to use dm cpu data.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/cpu/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/nios2/cpu/cpu.c b/arch/nios2/cpu/cpu.c index 106f0bf..229a07b 100644 --- a/arch/nios2/cpu/cpu.c +++ b/arch/nios2/cpu/cpu.c @@ -25,7 +25,7 @@ int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { disable_interrupts(); /* indirect call to go beyond 256MB limitation of toolchain */ - nios2_callr(CONFIG_SYS_RESET_ADDR); + nios2_callr(gd->arch.reset_addr); return 0; }
Hi Thomas,
BTW if you are interested, you can implement a reset driver UCLASS_RESET.
Applied to u-boot-nios.
- nios2_callr(gd->arch.reset_addr); return 0; }
Thomas Chou
