[U-Boot] [PATCH] efi: Export mbr partition for EFI.
While MBR partition isn't supposed to work in a EFI environment some board rely partially or fully on MBR (BeagleBone, RPI and probably others). This export the MBR partition as logical partition which is useful to efi application that cannot read raw disks.
Signed-off-by: Emmanuel Vadot manu@bidouilliste.com --- lib/efi_loader/efi_disk.c | 59 +++++++++++++++++++++++++++++++++++++++-------- 1 file changed, 50 insertions(+), 9 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 39e602a868..1f8ca86e29 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -197,11 +197,13 @@ static void efi_disk_add_dev(const char *name, const char *if_typename, const struct blk_desc *desc, int dev_index, - lbaint_t offset) + disk_partition_t *info, + int logical_partition) { struct efi_disk_obj *diskobj; struct efi_device_path_file_path *dp; int objlen = sizeof(*diskobj) + (sizeof(*dp) * 2); + static int mediaid;
/* Don't add empty devices */ if (!desc->lba) @@ -218,16 +220,26 @@ static void efi_disk_add_dev(const char *name, diskobj->ops = block_io_disk_template; diskobj->ifname = if_typename; diskobj->dev_index = dev_index; - diskobj->offset = offset; + if (info) + diskobj->offset = info->start; + diskobj->desc = desc;
/* Fill in EFI IO Media info (for read/write callbacks) */ diskobj->media.removable_media = desc->removable; diskobj->media.media_present = 1; - diskobj->media.block_size = desc->blksz; - diskobj->media.io_align = desc->blksz; - diskobj->media.last_block = desc->lba - offset; + diskobj->media.media_id = mediaid++; diskobj->ops.media = &diskobj->media; + if (logical_partition) { + diskobj->media.logical_partition = 1; + diskobj->media.block_size = info->blksz; + diskobj->media.io_align = info->blksz; + diskobj->media.last_block = info->size - 1; + } else { + diskobj->media.block_size = desc->blksz; + diskobj->media.io_align = desc->blksz; + diskobj->media.last_block = desc->lba; + }
/* Fill in device path */ dp = (void*)&diskobj[1]; @@ -262,8 +274,33 @@ static int efi_disk_create_eltorito(struct blk_desc *desc, while (!part_get_info(desc, part, &info)) { snprintf(devname, sizeof(devname), "%s:%d", pdevname, part); - efi_disk_add_dev(devname, if_typename, desc, diskid, - info.start); + efi_disk_add_dev(devname, if_typename, desc, diskid, 0, 0); + part++; + disks++; + } +#endif + + return disks; +} + +static int efi_disk_create_mbr(struct blk_desc *desc, + const char *if_typename, + int diskid) +{ + int disks = 0; +#if CONFIG_IS_ENABLED(DOS_PARTITION) + char devname[32] = { 0 }; /* dp->str is u16[32] long */ + disk_partition_t info; + int part = 1; + + if (desc->part_type != PART_TYPE_DOS) + return 0; + + while (!part_get_info(desc, part, &info)) { + snprintf(devname, sizeof(devname), "%s%d:%d", if_typename, + diskid, part); + + efi_disk_add_dev(devname, if_typename, desc, diskid, &info, 1); part++; disks++; } @@ -296,13 +333,15 @@ int efi_disk_register(void) const char *if_typename = dev->driver->name;
printf("Scanning disk %s...\n", dev->name); - efi_disk_add_dev(dev->name, if_typename, desc, desc->devnum, 0); + efi_disk_add_dev(dev->name, if_typename, desc, desc->devnum, + NULL, 0); disks++;
/* * El Torito images show up as block devices in an EFI world, * so let's create them here */ + disks += efi_disk_create_mbr(desc, if_typename, desc->devnum); disks += efi_disk_create_eltorito(desc, if_typename, desc->devnum, dev->name); } @@ -332,15 +371,17 @@ int efi_disk_register(void)
snprintf(devname, sizeof(devname), "%s%d", if_typename, i); - efi_disk_add_dev(devname, if_typename, desc, i, 0); + efi_disk_add_dev(devname, if_typename, desc, i, 0, 0); disks++;
/* * El Torito images show up as block devices * in an EFI world, so let's create them here */ + disks += efi_disk_create_mbr(desc, cur_drvr, i); disks += efi_disk_create_eltorito(desc, if_typename, i, devname); + } } #endif
Emmanuel Vadot
