[PATCH] Makefile: Silence new GNU linker warnings
The next version of the linker will complain about rwx segments with permissions and executable stacks:
https://sourceware.org/git/?p=binutils-gdb.git;a=commit;h=ba951afb99912da01a... https://sourceware.org/git/?p=binutils-gdb.git;a=commit;h=0d38576a34ec64a1b4...
These warnings are relevant for ELF binaries loaded by an operating system linker, but do not make sense in the context of u-boot where the objects are loaded by other means.
Disable the warnings using the following options:
--no-warn-rwx-segments
warning: u-boot has a LOAD segment with RWX permissions warning: u-boot-spl has a LOAD segment with RWX permissions
--no-warn-execstack
warning: arch/arm/lib/setjmp.o: missing .note.GNU-stack section implies executable stack NOTE: This behaviour is deprecated and will be removed in a future version of the linker
Signed-off-by: Joel Stanley joel@jms.id.au --- This behaviour can be seen when building with binutils 2.38.90.20220713-2 from Debian testing.
Makefile | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index ff25f9297486..32aac7493f8d 100644 --- a/Makefile +++ b/Makefile @@ -432,7 +432,8 @@ KBUILD_CFLAGS := -Wall -Wstrict-prototypes \ -fno-builtin -ffreestanding $(CSTD_FLAG) KBUILD_CFLAGS += -fshort-wchar -fno-strict-aliasing KBUILD_AFLAGS := -D__ASSEMBLY__ -KBUILD_LDFLAGS := +KBUILD_LDFLAGS := $(call ld-option, --no-warn-rwx-segments) \ + $(call ld-option, --no-warn-execstack)
ifeq ($(cc-name),clang) ifneq ($(CROSS_COMPILE),)
The ELF binary can be loaded by OpenSBI or QEMU. The information about rwx segments can be relevant for these. Only if a non-ELF form is used it is irrelevant.
You should instead fix the single file that has a problem:
test/overlay/test-fdt-overlay-stacked.dtb.S
Just add the missing section information or change the build flags for this single binary.
Best regards
Heinrich
--no-warn-execstack
I couldn't see where it was used in the qemu elf loader.
I had assumed the system would need an operating system and/or to be running with a MMU turned on to do anything sensible with the information.
I saw it triggering on a different set of files:
$ make evb-ast2600_defconfig && make CROSS_COMPILE=arm-linux-gnueabihf- -s -j8 # # configuration written to .config # arm-linux-gnueabihf-ld.bfd: warning: arch/arm/lib/lib1funcs.o: missing .note.GNU-stack section implies executable stack arm-linux-gnueabihf-ld.bfd: NOTE: This behaviour is deprecated and will be removed in a future version of the linker arm-linux-gnueabihf-ld.bfd: warning: u-boot has a LOAD segment with RWX permissions arm-linux-gnueabihf-ld.bfd: warning: arch/arm/lib/lib1funcs.o: missing .note.GNU-stack section implies executable stack arm-linux-gnueabihf-ld.bfd: NOTE: This behaviour is deprecated and will be removed in a future version of the linker arm-linux-gnueabihf-ld.bfd: warning: u-boot-spl has a LOAD segment with RWX permissions
Cheers,
Joel
Joel Stanley
