[PATCH 0/8] led: update LED boot/activity to new property implementation
This series is split in 2 part.
While adapting the LED boot and activity code to the new property accepted by Rob in dt-schema repository, a big BUG was discovered.
The reason wasn't clear at start and took me some days to figure it out.
This was triggered by adding a new phandle in the test.dts to introduce test for the new OPs.
This single addition caused the sandbox CI test to fail in the dm_test_ofnode_phandle_ot test.
This doesn't make sense as reverting the change made the CI test to correctly finish. Also moving the uboot node down after the first phandle (in test.dts the gpio one) also made the CI test to correctly finish.
A little bit of searching and debugging made me realize the parse phandle OPs didn't support other.dts at all and they were still referencing phandle index from test.dts. (more info in the related commit)
In short the test was broken all along and was working by pure luck. The first 4 patch address and fix the problem for good.
The other 4 patch expand and address the property change for LED boot/activity.
Posting in a single series as changes are trivial and just to speedup review process. (and also because the second part depends on the first)
Christian Marangi (8): dm: core: implement oftree variant of parse_phandle OPs test: dm: fix broken dm_test_ofnode_phandle_ot dm: core: implement ofnode/tree_parse_phandle() helper test: dm: Expand dm_test_ofnode_phandle(_ot) with new ofnode/tree_parse_phandle dm: core: implement phandle ofnode_options helper test: dm: Add test for ofnode options phandle helper led: update LED boot/activity to new property implementation test: dm: Update test for LED activity and boot
arch/sandbox/dts/other.dts | 33 ++++++++-- arch/sandbox/dts/test.dts | 16 +++-- drivers/core/of_access.c | 61 +++++++++++++----- drivers/core/ofnode.c | 118 ++++++++++++++++++++++++++++++++++ drivers/led/led-uclass.c | 30 ++++++--- include/dm/of_access.h | 86 +++++++++++++++++++++++++ include/dm/ofnode.h | 107 +++++++++++++++++++++++++++++++ test/dm/led.c | 18 +++--- test/dm/ofnode.c | 125 ++++++++++++++++++++++++++++++++----- 9 files changed, 539 insertions(+), 55 deletions(-)
Implement oftree variant of parse_phandle OPs.
There is currently a very hidden and laten BUG with parse_phandle OPs that doesn't permit the support of multiple DTS in a system. One usage example if sandbox with the usage of other.dts
The BUG is only present on live scenario where of_... OPs are used and it's not present when fdt... OPs are used.
This is caused by an assumption made in __of_parse_phandle_with_args, with the of_find_node_by_phandle call that pass the first arg as NULL.
This makes of_find_node_by_phandle use the default root node of the system and doesn't permit the usage of alternative tree. This is correct for normal system and also for the linux kernel where it's assumed a single device tree.
It's problematic if other device tree needs to be used.
To fix this, introduce __of_root_parse_phandle_with_args to define a root device tree for of_find_node_by_phandle.
Introduce all the variant OPs for this and in ofnode, the oftree OPs following how it's done for other OPs with similar task.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/core/of_access.c | 61 ++++++++++++++++++++-------- drivers/core/ofnode.c | 45 +++++++++++++++++++++ include/dm/of_access.h | 86 ++++++++++++++++++++++++++++++++++++++++ include/dm/ofnode.h | 66 ++++++++++++++++++++++++++++++ 4 files changed, 241 insertions(+), 17 deletions(-)
diff --git a/drivers/core/of_access.c b/drivers/core/of_access.c index 77acd766262..b11e36202c1 100644 --- a/drivers/core/of_access.c +++ b/drivers/core/of_access.c @@ -666,11 +666,12 @@ int of_property_read_string_helper(const struct device_node *np, return i <= 0 ? -ENODATA : i; }
-static int __of_parse_phandle_with_args(const struct device_node *np, - const char *list_name, - const char *cells_name, - int cell_count, int index, - struct of_phandle_args *out_args) +static int __of_root_parse_phandle_with_args(struct device_node *root, + const struct device_node *np, + const char *list_name, + const char *cells_name, + int cell_count, int index, + struct of_phandle_args *out_args) { const __be32 *list, *list_end; int rc = 0, cur_index = 0; @@ -706,7 +707,7 @@ static int __of_parse_phandle_with_args(const struct device_node *np, * below. */ if (cells_name || cur_index == index) { - node = of_find_node_by_phandle(NULL, phandle); + node = of_find_node_by_phandle(root, phandle); if (!node) { dm_warn("%s: could not find phandle\n", np->full_name); @@ -783,39 +784,65 @@ static int __of_parse_phandle_with_args(const struct device_node *np, return rc; }
-struct device_node *of_parse_phandle(const struct device_node *np, - const char *phandle_name, int index) +struct device_node *of_root_parse_phandle(struct device_node *root, + const struct device_node *np, + const char *phandle_name, int index) { struct of_phandle_args args;
if (index < 0) return NULL;
- if (__of_parse_phandle_with_args(np, phandle_name, NULL, 0, index, - &args)) + if (__of_root_parse_phandle_with_args(root, np, phandle_name, NULL, 0, + index, &args)) return NULL;
return args.np; }
+int of_root_parse_phandle_with_args(struct device_node *root, + const struct device_node *np, + const char *list_name, const char *cells_name, + int cell_count, int index, + struct of_phandle_args *out_args) +{ + if (index < 0) + return -EINVAL; + + return __of_root_parse_phandle_with_args(root, np, list_name, cells_name, + cell_count, index, out_args); +} + +int of_root_count_phandle_with_args(struct device_node *root, + const struct device_node *np, + const char *list_name, const char *cells_name, + int cell_count) +{ + return __of_root_parse_phandle_with_args(root, np, list_name, cells_name, + cell_count, -1, NULL); +} + +struct device_node *of_parse_phandle(const struct device_node *np, + const char *phandle_name, int index) +{ + return of_root_parse_phandle(NULL, np, phandle_name, index); +} + int of_parse_phandle_with_args(const struct device_node *np, const char *list_name, const char *cells_name, int cell_count, int index, struct of_phandle_args *out_args) { - if (index < 0) - return -EINVAL; - - return __of_parse_phandle_with_args(np, list_name, cells_name, - cell_count, index, out_args); + return of_root_parse_phandle_with_args(NULL, np, list_name, cells_name, + cell_count, index, out_args); }
int of_count_phandle_with_args(const struct device_node *np, const char *list_name, const char *cells_name, int cell_count) { - return __of_parse_phandle_with_args(np, list_name, cells_name, - cell_count, -1, NULL); + return of_root_count_phandle_with_args(NULL, np, list_name, cells_name, + cell_count); }
static void of_alias_add(struct alias_prop *ap, struct device_node *np, diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 950895e72a9..a2136f61b7d 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -929,6 +929,39 @@ int ofnode_parse_phandle_with_args(ofnode node, const char *list_name, return 0; }
+int oftree_parse_phandle_with_args(oftree tree, ofnode node, const char *list_name, + const char *cells_name, int cell_count, + int index, + struct ofnode_phandle_args *out_args) +{ + if (ofnode_is_np(node)) { + struct of_phandle_args args; + int ret; + + ret = of_root_parse_phandle_with_args(tree.np, + ofnode_to_np(node), + list_name, cells_name, + cell_count, index, + &args); + if (ret) + return ret; + ofnode_from_of_phandle_args(&args, out_args); + } else { + struct fdtdec_phandle_args args; + int ret; + + ret = fdtdec_parse_phandle_with_args(tree.fdt, + ofnode_to_offset(node), + list_name, cells_name, + cell_count, index, &args); + if (ret) + return ret; + ofnode_from_fdtdec_phandle_args(&args, out_args); + } + + return 0; +} + int ofnode_count_phandle_with_args(ofnode node, const char *list_name, const char *cells_name, int cell_count) { @@ -941,6 +974,18 @@ int ofnode_count_phandle_with_args(ofnode node, const char *list_name, cell_count, -1, NULL); }
+int oftree_count_phandle_with_args(oftree tree, ofnode node, const char *list_name, + const char *cells_name, int cell_count) +{ + if (ofnode_is_np(node)) + return of_root_count_phandle_with_args(tree.np, ofnode_to_np(node), + list_name, cells_name, cell_count); + else + return fdtdec_parse_phandle_with_args(tree.fdt, + ofnode_to_offset(node), list_name, cells_name, + cell_count, -1, NULL); +} + ofnode ofnode_path(const char *path) { if (of_live_active()) diff --git a/include/dm/of_access.h b/include/dm/of_access.h index de740d44674..44143a5a391 100644 --- a/include/dm/of_access.h +++ b/include/dm/of_access.h @@ -453,6 +453,92 @@ static inline int of_property_count_strings(const struct device_node *np, return of_property_read_string_helper(np, propname, NULL, 0, 0); }
+/** + * of_root_parse_phandle - Resolve a phandle property to a device_node pointer + * from a root node + * @root: Pointer to root device tree node (default root node if NULL) + * @np: Pointer to device node holding phandle property + * @phandle_name: Name of property holding a phandle value + * @index: For properties holding a table of phandles, this is the index into + * the table + * + * Return: + * the device_node pointer with refcount incremented. Use + * of_node_put() on it when done. + */ +struct device_node *of_root_parse_phandle(struct device_node *root, + const struct device_node *np, + const char *phandle_name, int index); + +/** + * of_root_parse_phandle_with_args() - Find a node pointed by phandle in a list + * from a root node + * + * @root: pointer to root device tree node (default root node if NULL) + * @np: pointer to a device tree node containing a list + * @list_name: property name that contains a list + * @cells_name: property name that specifies phandles' arguments count + * @cells_count: Cell count to use if @cells_name is NULL + * @index: index of a phandle to parse out + * @out_args: optional pointer to output arguments structure (will be filled) + * Return: + * 0 on success (with @out_args filled out if not NULL), -ENOENT if + * @list_name does not exist, -EINVAL if a phandle was not found, + * @cells_name could not be found, the arguments were truncated or there + * were too many arguments. + * + * This function is useful to parse lists of phandles and their arguments. + * Returns 0 on success and fills out_args, on error returns appropriate + * errno value. + * + * Caller is responsible to call of_node_put() on the returned out_args->np + * pointer. + * + * Example: + * + * .. code-block:: + * + * phandle1: node1 { + * #list-cells = <2>; + * }; + * phandle2: node2 { + * #list-cells = <1>; + * }; + * node3 { + * list = <&phandle1 1 2 &phandle2 3>; + * }; + * + * To get a device_node of the `node2' node you may call this: + * of_root_parse_phandle_with_args(node3, "list", "#list-cells", 1, &args); + */ +int of_root_parse_phandle_with_args(struct device_node *root, + const struct device_node *np, + const char *list_name, const char *cells_name, + int cells_count, int index, + struct of_phandle_args *out_args); + +/** + * of_root_count_phandle_with_args() - Count the number of phandle in a list + * from a root node + * + * @root: pointer to root device tree node (default root node if NULL) + * @np: pointer to a device tree node containing a list + * @list_name: property name that contains a list + * @cells_name: property name that specifies phandles' arguments count + * @cells_count: Cell count to use if @cells_name is NULL + * Return: + * number of phandle found, -ENOENT if @list_name does not exist, + * -EINVAL if a phandle was not found, @cells_name could not be found, + * the arguments were truncated or there were too many arguments. + * + * Returns number of phandle found on success, on error returns appropriate + * errno value. + */ +int of_root_count_phandle_with_args(struct device_node *root, + const struct device_node *np, + const char *list_name, const char *cells_name, + int cells_count); + /** * of_parse_phandle - Resolve a phandle property to a device_node pointer * @np: Pointer to device node holding phandle property diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 0787758926f..7ece68874ae 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -909,6 +909,72 @@ int ofnode_parse_phandle_with_args(ofnode node, const char *list_name, int ofnode_count_phandle_with_args(ofnode node, const char *list_name, const char *cells_name, int cell_count);
+/** + * oftree_parse_phandle_with_args() - Find a node pointed by phandle in a list + * from a root node + * + * This function is useful to parse lists of phandles and their arguments. + * Returns 0 on success and fills out_args, on error returns appropriate + * errno value. + * + * Caller is responsible to call of_node_put() on the returned out_args->np + * pointer. + * + * Example: + * + * .. code-block:: + * + * phandle1: node1 { + * #list-cells = <2>; + * }; + * phandle2: node2 { + * #list-cells = <1>; + * }; + * node3 { + * list = <&phandle1 1 2 &phandle2 3>; + * }; + * + * To get a device_node of the `node2' node you may call this: + * oftree_parse_phandle_with_args(node3, "list", "#list-cells", 0, 1, &args); + * + * @tree: device tree to use + * @node: device tree node containing a list + * @list_name: property name that contains a list + * @cells_name: property name that specifies phandles' arguments count + * @cell_count: Cell count to use if @cells_name is NULL + * @index: index of a phandle to parse out + * @out_args: optional pointer to output arguments structure (will be filled) + * Return: + * 0 on success (with @out_args filled out if not NULL), -ENOENT if + * @list_name does not exist, -EINVAL if a phandle was not found, + * @cells_name could not be found, the arguments were truncated or there + * were too many arguments. + */ +int oftree_parse_phandle_with_args(oftree tree, ofnode node, const char *list_name, + const char *cells_name, int cell_count, + int index, + struct ofnode_phandle_args *out_args); + +/** + * oftree_count_phandle_with_args() - Count number of phandle in a list + * from a root node + * + * This function is useful to count phandles into a list. + * Returns number of phandle on success, on error returns appropriate + * errno value. + * + * @tree: device tree to use + * @node: device tree node containing a list + * @list_name: property name that contains a list + * @cells_name: property name that specifies phandles' arguments count + * @cell_count: Cell count to use if @cells_name is NULL + * Return: + * number of phandle on success, -ENOENT if @list_name does not exist, + * -EINVAL if a phandle was not found, @cells_name could not be found. + */ +int oftree_count_phandle_with_args(oftree tree, ofnode node, const char *list_name, + const char *cells_name, int cell_count); + /** * ofnode_path() - find a node by full path *
Fix broken dm_test_ofnode_phandle_ot test. They never actually worked and were passing test by pure luck by having the same phandle index of test.dts that coincicentally had #gpio-cells in the same index node.
It was sufficient to add a phandle to test.dts to make the test fail.
To correctly test these feature, make use oif the new OPs oftree to parse phandle.
For consistency with the dm_test_ofnode_phandle, rework the test and other.dts to use the same property with the other- prefix to every node.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- arch/sandbox/dts/other.dts | 26 +++++++++++--- test/dm/ofnode.c | 72 +++++++++++++++++++++++++++++++------- 2 files changed, 82 insertions(+), 16 deletions(-)
diff --git a/arch/sandbox/dts/other.dts b/arch/sandbox/dts/other.dts index 395a7923228..110063fa1c6 100644 --- a/arch/sandbox/dts/other.dts +++ b/arch/sandbox/dts/other.dts @@ -8,14 +8,14 @@
/dts-v1/;
+#include <dt-bindings/gpio/gpio.h> + / { compatible = "sandbox-other"; #address-cells = <1>; #size-cells = <1>;
node { - target = <&target 3 4>; - subnode { compatible = "sandbox-other2"; str-prop = "other"; @@ -25,10 +25,28 @@ }; };
+ other-a-test { + other-test-gpios = <&other_gpio_a 1>, <&other_gpio_a 4>, + <&other_gpio_b 5 GPIO_ACTIVE_HIGH 3 2 1>, + <0>, <&other_gpio_a 12>; + other-phandle-value = <&other_gpio_c 10>, <0xFFFFFFFF 20>, <&other_gpio_a 30>; + }; + + other_gpio_a: other-gpio-a { + #gpio-cells = <1>; + }; + + other_gpio_b: other-gpio-b { + #gpio-cells = <5>; + }; + + other_gpio_c: other-gpio-c { + #gpio-cells = <2>; + }; + target: target { compatible = "sandbox-other2"; - #gpio-cells = <2>; - str-prop = "other"; + reg = <0x8000 0x100>; status = "disabled"; }; diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index ce996567c3c..5e36a228395 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -349,30 +349,78 @@ static int dm_test_ofnode_phandle(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_phandle, UTF_SCAN_PDATA | UTF_SCAN_FDT);
-/* test ofnode_count_/parse_phandle_with_args() with 'other' tree */ +/* test oftree_count_/parse_phandle_with_args() with 'other' tree */ static int dm_test_ofnode_phandle_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); struct ofnode_phandle_args args; ofnode node; int ret; + const char prop[] = "other-test-gpios"; + const char cell[] = "#gpio-cells"; + const char prop2[] = "other-phandle-value";
- node = oftree_path(otree, "/node"); + node = oftree_path(otree, "/other-a-test"); + ut_assert(ofnode_valid(node));
- /* Test ofnode_count_phandle_with_args with cell name */ - ret = ofnode_count_phandle_with_args(node, "missing", "#gpio-cells", 0); + /* Test oftree_count_phandle_with_args with cell name */ + ret = oftree_count_phandle_with_args(otree, node, "missing", cell, 0); ut_asserteq(-ENOENT, ret); - ret = ofnode_count_phandle_with_args(node, "target", "#invalid", 0); + ret = oftree_count_phandle_with_args(otree, node, prop, "#invalid", 0); ut_asserteq(-EINVAL, ret); - ret = ofnode_count_phandle_with_args(node, "target", "#gpio-cells", 0); - ut_asserteq(1, ret); + ret = oftree_count_phandle_with_args(otree, node, prop, cell, 0); + ut_asserteq(5, ret);
- ret = ofnode_parse_phandle_with_args(node, "target", "#gpio-cells", 0, - 0, &args); + /* Test oftree_parse_phandle_with_args with cell name */ + ret = oftree_parse_phandle_with_args(otree, node, "missing", cell, 0, 0, + &args); + ut_asserteq(-ENOENT, ret); + ret = oftree_parse_phandle_with_args(otree, node, prop, "#invalid", 0, 0, + &args); + ut_asserteq(-EINVAL, ret); + ret = oftree_parse_phandle_with_args(otree, node, prop, cell, 0, 0, &args); ut_assertok(ret); - ut_asserteq(2, args.args_count); - ut_asserteq(3, args.args[0]); - ut_asserteq(4, args.args[1]); + ut_asserteq(1, args.args_count); + ut_asserteq(1, args.args[0]); + ret = oftree_parse_phandle_with_args(otree, node, prop, cell, 0, 1, &args); + ut_assertok(ret); + ut_asserteq(1, args.args_count); + ut_asserteq(4, args.args[0]); + ret = oftree_parse_phandle_with_args(otree, node, prop, cell, 0, 2, &args); + ut_assertok(ret); + ut_asserteq(5, args.args_count); + ut_asserteq(5, args.args[0]); + ut_asserteq(1, args.args[4]); + ret = oftree_parse_phandle_with_args(otree, node, prop, cell, 0, 3, &args); + ut_asserteq(-ENOENT, ret); + ret = oftree_parse_phandle_with_args(otree, node, prop, cell, 0, 4, &args); + ut_assertok(ret); + ut_asserteq(1, args.args_count); + ut_asserteq(12, args.args[0]); + ret = oftree_parse_phandle_with_args(otree, node, prop, cell, 0, 5, &args); + ut_asserteq(-ENOENT, ret); + + /* Test oftree_count_phandle_with_args with cell count */ + ret = oftree_count_phandle_with_args(otree, node, "missing", NULL, 2); + ut_asserteq(-ENOENT, ret); + ret = oftree_count_phandle_with_args(otree, node, prop2, NULL, 1); + ut_asserteq(3, ret); + + /* Test oftree_parse_phandle_with_args with cell count */ + ret = oftree_parse_phandle_with_args(otree, node, prop2, NULL, 1, 0, &args); + ut_assertok(ret); + ut_asserteq(1, ofnode_valid(args.node)); + ut_asserteq(1, args.args_count); + ut_asserteq(10, args.args[0]); + ret = oftree_parse_phandle_with_args(otree, node, prop2, NULL, 1, 1, &args); + ut_asserteq(-EINVAL, ret); + ret = oftree_parse_phandle_with_args(otree, node, prop2, NULL, 1, 2, &args); + ut_assertok(ret); + ut_asserteq(1, ofnode_valid(args.node)); + ut_asserteq(1, args.args_count); + ut_asserteq(30, args.args[0]); + ret = oftree_parse_phandle_with_args(otree, node, prop2, NULL, 1, 3, &args); + ut_asserteq(-ENOENT, ret);
return 0; }
Implement ofnode/tree_parse_phandle() helper as an equivalent of of_parse_phandle to handle simple single value phandle.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/core/ofnode.c | 58 +++++++++++++++++++++++++++++++++++++++++++ include/dm/ofnode.h | 26 +++++++++++++++++++ 2 files changed, 84 insertions(+)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index a2136f61b7d..774b428c43f 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -879,6 +879,64 @@ int ofnode_read_string_list(ofnode node, const char *property, return count; }
+ofnode ofnode_parse_phandle(ofnode node, const char *phandle_name, + int index) +{ + ofnode phandle; + + if (ofnode_is_np(node)) { + struct device_node *np; + + np = of_parse_phandle(ofnode_to_np(node), phandle_name, + index); + if (!np) + return ofnode_null(); + + phandle = np_to_ofnode(np); + } else { + struct fdtdec_phandle_args args; + + if (fdtdec_parse_phandle_with_args(ofnode_to_fdt(node), + ofnode_to_offset(node), + phandle_name, NULL, + 0, index, &args)) + return ofnode_null(); + + phandle = offset_to_ofnode(args.node); + } + + return phandle; +} + +ofnode oftree_parse_phandle(oftree tree, ofnode node, const char *phandle_name, + int index) +{ + ofnode phandle; + + if (ofnode_is_np(node)) { + struct device_node *np; + + np = of_root_parse_phandle(tree.np, ofnode_to_np(node), + phandle_name, index); + if (!np) + return ofnode_null(); + + phandle = np_to_ofnode(np); + } else { + struct fdtdec_phandle_args args; + + if (fdtdec_parse_phandle_with_args(tree.fdt, + ofnode_to_offset(node), + phandle_name, NULL, + 0, index, &args)) + return ofnode_null(); + + phandle = offset_to_ofnode(args.node); + } + + return phandle; +} + static void ofnode_from_fdtdec_phandle_args(struct fdtdec_phandle_args *in, struct ofnode_phandle_args *out) { diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 7ece68874ae..eea6b13217c 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -847,6 +847,18 @@ int ofnode_read_string_count(ofnode node, const char *property); int ofnode_read_string_list(ofnode node, const char *property, const char ***listp);
+/** + * ofnode_parse_phandle() - Resolve a phandle property to an ofnode + * + * @node: node to check + * @phandle_name: Name of property holding a phandle value + * @index: For properties holding a table of phandles, this is the index into + * the table + * Return: ofnode that the phandle points to or ofnode_null() on error. + */ +ofnode ofnode_parse_phandle(ofnode node, const char *phandle_name, + int index); + /** * ofnode_parse_phandle_with_args() - Find a node pointed by phandle in a list * @@ -909,6 +921,20 @@ int ofnode_parse_phandle_with_args(ofnode node, const char *list_name, int ofnode_count_phandle_with_args(ofnode node, const char *list_name, const char *cells_name, int cell_count);
+/** + * oftree_parse_phandle() - Resolve a phandle property to an ofnode + * from a root node + * + * @tree: device tree to use + * @node: node to check + * @phandle_name: Name of property holding a phandle value + * @index: For properties holding a table of phandles, this is the index into + * the table + * Return: ofnode that the phandle points to or ofnode_null() on error. + */ +ofnode oftree_parse_phandle(oftree tree, ofnode node, const char *phandle_name, + int index); + /** * oftree_parse_phandle_with_args() - Find a node pointed by phandle in a list * from a root node
Expand dm_test_ofnode_phandle(_ot) with new ofnode/tree_parse_phandle() op.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- arch/sandbox/dts/other.dts | 7 ++++++ arch/sandbox/dts/test.dts | 7 ++++++ test/dm/ofnode.c | 44 ++++++++++++++++++++++++++++++++++---- 3 files changed, 54 insertions(+), 4 deletions(-)
diff --git a/arch/sandbox/dts/other.dts b/arch/sandbox/dts/other.dts index 110063fa1c6..226226e3020 100644 --- a/arch/sandbox/dts/other.dts +++ b/arch/sandbox/dts/other.dts @@ -30,6 +30,7 @@ <&other_gpio_b 5 GPIO_ACTIVE_HIGH 3 2 1>, <0>, <&other_gpio_a 12>; other-phandle-value = <&other_gpio_c 10>, <0xFFFFFFFF 20>, <&other_gpio_a 30>; + other-phandle-nodes = <&other_phandle_node_1>, <&other_phandle_node_2>; };
other_gpio_a: other-gpio-a { @@ -44,6 +45,12 @@ #gpio-cells = <2>; };
+ other_phandle_node_1: other-phandle-node-1 { + }; + + other_phandle_node_2: other-phandle-node-2 { + }; + target: target { compatible = "sandbox-other2";
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 3017b33d67b..b8a46463158 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -296,6 +296,12 @@ compatible = "sandbox,dsi-host"; };
+ phandle_node_1: phandle-node-1 { + }; + + phandle_node_2: phandle-node-2 { + }; + a-test { reg = <0 1>; compatible = "denx,u-boot-fdt-test"; @@ -334,6 +340,7 @@ interrupts-extended = <&irq 3 0>; acpi,name = "GHIJ"; phandle-value = <&gpio_c 10>, <0xFFFFFFFF 20>, <&gpio_a 30>; + phandle-nodes = <&phandle_node_1>, <&phandle_node_2>;
mux-controls = <&muxcontroller0 0>, <&muxcontroller0 1>, <&muxcontroller0 2>, <&muxcontroller0 3>, diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index 5e36a228395..c05de1c54ca 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -273,15 +273,16 @@ static int dm_test_ofnode_read_ot(struct unit_test_state *uts) } DM_TEST(dm_test_ofnode_read_ot, UTF_SCAN_FDT | UTF_OTHER_FDT);
-/* test ofnode_count_/parse_phandle_with_args() */ +/* test ofnode_count_/parse/_phandle_with_args() */ static int dm_test_ofnode_phandle(struct unit_test_state *uts) { struct ofnode_phandle_args args; - ofnode node; + ofnode node, phandle, target; int ret; const char prop[] = "test-gpios"; const char cell[] = "#gpio-cells"; const char prop2[] = "phandle-value"; + const char prop3[] = "phandle-nodes";
node = ofnode_path("/a-test"); ut_assert(ofnode_valid(node)); @@ -345,20 +346,38 @@ static int dm_test_ofnode_phandle(struct unit_test_state *uts) ret = ofnode_parse_phandle_with_args(node, prop2, NULL, 1, 3, &args); ut_asserteq(-ENOENT, ret);
+ /* Test ofnode_parse_phandle */ + phandle = ofnode_parse_phandle(node, "missing", 0); + ut_assert(ofnode_equal(ofnode_null(), phandle)); + + target = ofnode_path("/phandle-node-1"); + ut_assert(ofnode_valid(target)); + phandle = ofnode_parse_phandle(node, prop3, 0); + ut_assert(ofnode_equal(target, phandle)); + + target = ofnode_path("/phandle-node-2"); + ut_assert(ofnode_valid(target)); + phandle = ofnode_parse_phandle(node, prop3, 1); + ut_assert(ofnode_equal(target, phandle)); + + phandle = ofnode_parse_phandle(node, prop3, 3); + ut_assert(ofnode_equal(ofnode_null(), phandle)); + return 0; } DM_TEST(dm_test_ofnode_phandle, UTF_SCAN_PDATA | UTF_SCAN_FDT);
-/* test oftree_count_/parse_phandle_with_args() with 'other' tree */ +/* test oftree_count_/parse/_phandle_with_args() with 'other' tree */ static int dm_test_ofnode_phandle_ot(struct unit_test_state *uts) { oftree otree = get_other_oftree(uts); struct ofnode_phandle_args args; - ofnode node; + ofnode node, phandle, target; int ret; const char prop[] = "other-test-gpios"; const char cell[] = "#gpio-cells"; const char prop2[] = "other-phandle-value"; + const char prop3[] = "other-phandle-nodes";
node = oftree_path(otree, "/other-a-test"); ut_assert(ofnode_valid(node)); @@ -422,6 +441,23 @@ static int dm_test_ofnode_phandle_ot(struct unit_test_state *uts) ret = oftree_parse_phandle_with_args(otree, node, prop2, NULL, 1, 3, &args); ut_asserteq(-ENOENT, ret);
+ /* Test oftree_parse_phandle */ + phandle = oftree_parse_phandle(otree, node, "missing", 0); + ut_assert(ofnode_equal(ofnode_null(), phandle)); + + target = oftree_path(otree, "/other-phandle-node-1"); + ut_assert(ofnode_valid(target)); + phandle = oftree_parse_phandle(otree, node, prop3, 0); + ut_assert(ofnode_equal(target, phandle)); + + target = oftree_path(otree, "/other-phandle-node-2"); + ut_assert(ofnode_valid(target)); + phandle = oftree_parse_phandle(otree, node, prop3, 1); + ut_assert(ofnode_equal(target, phandle)); + + phandle = oftree_parse_phandle(otree, node, prop3, 3); + ut_assert(ofnode_equal(ofnode_null(), phandle)); + return 0; } DM_TEST(dm_test_ofnode_phandle_ot, UTF_OTHER_FDT);
Implement ofnode_options phandle helper to get an ofnode from a phandle option in /options/u-boot.
This helper can be useful since new DT yaml usually require to link a phandle of a node instead of referencing it by name or other indirect way.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/core/ofnode.c | 15 +++++++++++++++ include/dm/ofnode.h | 15 +++++++++++++++ 2 files changed, 30 insertions(+)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 774b428c43f..3a96bf4f0c5 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -1871,6 +1871,21 @@ const char *ofnode_options_read_str(const char *prop_name) return ofnode_read_string(uboot, prop_name); }
+int ofnode_options_get_by_phandle(const char *prop_name, ofnode *nodep) +{ + ofnode uboot; + + uboot = ofnode_path("/options/u-boot"); + if (!ofnode_valid(uboot)) + return -EINVAL; + + *nodep = ofnode_parse_phandle(uboot, prop_name, 0); + if (!ofnode_valid(*nodep)) + return -EINVAL; + + return 0; +} + int ofnode_read_bootscript_address(u64 *bootscr_address, u64 *bootscr_offset) { int ret; diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index eea6b13217c..890f0e6cf40 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1720,6 +1720,21 @@ int ofnode_options_read_int(const char *prop_name, int default_val); */ const char *ofnode_options_read_str(const char *prop_name);
+/** + * ofnode_options_get_by_phandle() - Get a ofnode from phandle from the U-Boot options + * + * This reads a property from the /options/u-boot/ node of the devicetree. + * + * This only works with the control FDT. + * + * See dtschema/schemas/options/u-boot.yaml in dt-schema project for bindings + * + * @prop_name: property name to look up + * @nodep: pointer to ofnode where node is stored + * Return: 0, if found, or negative error if not + */ +int ofnode_options_get_by_phandle(const char *prop_name, ofnode *nodep); + /** * ofnode_read_bootscript_address() - Read bootscr-address or bootscr-ram-offset *
Add test for ofnode options phandle helper and add new property in the sandbox test dts.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- arch/sandbox/dts/test.dts | 1 + test/dm/ofnode.c | 11 +++++++++++ 2 files changed, 12 insertions(+)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index b8a46463158..1ffa64a43e2 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -106,6 +106,7 @@ testing-bool; testing-int = <123>; testing-str = "testing"; + testing-phandle = <&phandle_node_1>; }; };
diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c index c05de1c54ca..0c9d856b97a 100644 --- a/test/dm/ofnode.c +++ b/test/dm/ofnode.c @@ -697,6 +697,10 @@ static int dm_test_ofnode_options(struct unit_test_state *uts) { u64 bootscr_address, bootscr_offset; u64 bootscr_flash_offset, bootscr_flash_size; + ofnode node, phandle_node, target; + + node = ofnode_path("/options/u-boot"); + ut_assert(ofnode_valid(node));
ut_assert(!ofnode_options_read_bool("missing")); ut_assert(ofnode_options_read_bool("testing-bool")); @@ -707,6 +711,13 @@ static int dm_test_ofnode_options(struct unit_test_state *uts) ut_assertnull(ofnode_options_read_str("missing")); ut_asserteq_str("testing", ofnode_options_read_str("testing-str"));
+ ut_asserteq(-EINVAL, ofnode_options_get_by_phandle("missing", &phandle_node)); + + target = ofnode_path("/phandle-node-1"); + ut_assert(ofnode_valid(target)); + ut_assertok(ofnode_options_get_by_phandle("testing-phandle", &phandle_node)); + ut_assert(ofnode_equal(target, phandle_node)); + ut_assertok(ofnode_read_bootscript_address(&bootscr_address, &bootscr_offset)); ut_asserteq_64(0, bootscr_address);
Update LED boot/activity to reference by phandle instead of label and add to period property the "-ms" suffix. This is a followup request by dt-schema maintainers that required LED node to be referenced by a phandle to the node instead of indirectly by the LED label and for timevalue to have a suffix.
While at it generalize the LED node label parsing since the logic is common for generic LED bind and LED activity/boot.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- drivers/led/led-uclass.c | 30 ++++++++++++++++++++++-------- 1 file changed, 22 insertions(+), 8 deletions(-)
diff --git a/drivers/led/led-uclass.c b/drivers/led/led-uclass.c index 05e09909b7d..760750568c0 100644 --- a/drivers/led/led-uclass.c +++ b/drivers/led/led-uclass.c @@ -232,16 +232,24 @@ int led_activity_blink(void) #endif #endif
+static const char *led_get_label(ofnode node) +{ + const char *label; + + label = ofnode_read_string(node, "label"); + if (!label && !ofnode_read_string(node, "compatible")) + label = ofnode_get_name(node); + + return label; +} + static int led_post_bind(struct udevice *dev) { struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); const char *default_state;
if (!uc_plat->label) - uc_plat->label = dev_read_string(dev, "label"); - - if (!uc_plat->label && !dev_read_string(dev, "compatible")) - uc_plat->label = ofnode_get_name(dev_ofnode(dev)); + uc_plat->label = led_get_label(dev_ofnode(dev));
uc_plat->default_state = LEDST_COUNT;
@@ -300,15 +308,21 @@ static int led_post_probe(struct udevice *dev) static int led_init(struct uclass *uc) { struct led_uc_priv *priv = uclass_get_priv(uc); + ofnode led_node; + int ret;
#ifdef CONFIG_LED_BOOT - priv->boot_led_label = ofnode_options_read_str("boot-led"); - priv->boot_led_period = ofnode_options_read_int("boot-led-period", 250); + ret = ofnode_options_get_by_phandle("boot-led", &led_node); + if (!ret) + priv->boot_led_label = led_get_label(led_node); + priv->boot_led_period = ofnode_options_read_int("boot-led-period-ms", 250); #endif
#ifdef CONFIG_LED_ACTIVITY - priv->activity_led_label = ofnode_options_read_str("activity-led"); - priv->activity_led_period = ofnode_options_read_int("activity-led-period", + ret = ofnode_options_get_by_phandle("activity-led", &led_node); + if (!ret) + priv->activity_led_label = led_get_label(led_node); + priv->activity_led_period = ofnode_options_read_int("activity-led-period-ms", 250); #endif
Update test for LED activity and boot to follow new implementation with property set to the LED node phandle.
Also update a copy-paste error in the function name for the activity tests and actually enable the test with the DM_TEST macro.
Signed-off-by: Christian Marangi ansuelsmth@gmail.com --- arch/sandbox/dts/test.dts | 8 ++++---- test/dm/led.c | 18 +++++++++++------- 2 files changed, 15 insertions(+), 11 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 1ffa64a43e2..e9b3b151e10 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -101,8 +101,8 @@ bootscr-ram-offset = /bits/ 64 <0x12345678>; bootscr-flash-offset = /bits/ 64 <0>; bootscr-flash-size = /bits/ 64 <0x2000>; - boot-led = "sandbox:green"; - activity-led = "sandbox:red"; + boot-led = <&sandbox_led_green>; + activity-led = <&sandbox_led_red>; testing-bool; testing-int = <123>; testing-str = "testing"; @@ -988,12 +988,12 @@ leds { compatible = "gpio-leds";
- iracibble { + sandbox_led_red: iracibble { gpios = <&gpio_a 1 0>; label = "sandbox:red"; };
- martinet { + sandbox_led_green: martinet { gpios = <&gpio_a 2 0>; label = "sandbox:green"; }; diff --git a/test/dm/led.c b/test/dm/led.c index 884f6410b70..e5b86326c3a 100644 --- a/test/dm/led.c +++ b/test/dm/led.c @@ -144,7 +144,7 @@ static int dm_test_led_boot(struct unit_test_state *uts) { struct udevice *dev
- /* options/u-boot/boot-led is set to "sandbox:green" */ + /* options/u-boot/boot-led is set to phandle to "sandbox:green" */ ut_assertok(led_get_by_label("sandbox:green", &dev)); ut_asserteq(LEDST_OFF, led_get_state(dev)); ut_assertok(led_boot_on()); @@ -154,14 +154,15 @@ static int dm_test_led_boot(struct unit_test_state *uts)
return 0; } +DM_TEST(dm_test_led_boot, UTF_SCAN_PDATA | UTF_SCAN_FDT);
/* Test LED boot blink fallback */ #ifndef CONFIG_LED_BLINK -static int dm_test_led_boot(struct unit_test_state *uts) +static int dm_test_led_boot_blink(struct unit_test_state *uts) { struct udevice *dev
- /* options/u-boot/boot-led is set to "sandbox:green" */ + /* options/u-boot/boot-led is set to phandle to "sandbox:green" */ ut_assertok(led_get_by_label("sandbox:green", &dev)); ut_asserteq(LEDST_OFF, led_get_state(dev)); ut_assertok(led_boot_blink()); @@ -171,16 +172,17 @@ static int dm_test_led_boot(struct unit_test_state *uts)
return 0; } +DM_TEST(dm_test_led_boot_blink, UTF_SCAN_PDATA | UTF_SCAN_FDT); #endif #endif
/* Test LED activity */ #ifdef CONFIG_LED_ACTIVITY -static int dm_test_led_boot(struct unit_test_state *uts) +static int dm_test_led_activity(struct unit_test_state *uts) { struct udevice *dev
- /* options/u-boot/activity-led is set to "sandbox:red" */ + /* options/u-boot/activity-led is set to phandle to "sandbox:red" */ ut_assertok(led_get_by_label("sandbox:red", &dev)); ut_asserteq(LEDST_OFF, led_get_state(dev)); ut_assertok(led_activity_on()); @@ -190,14 +192,15 @@ static int dm_test_led_boot(struct unit_test_state *uts)
return 0; } +DM_TEST(dm_test_led_activity, UTF_SCAN_PDATA | UTF_SCAN_FDT);
/* Test LED activity blink fallback */ #ifndef CONFIG_LED_BLINK -static int dm_test_led_boot(struct unit_test_state *uts) +static int dm_test_led_activityt_blink(struct unit_test_state *uts) { struct udevice *dev
- /* options/u-boot/activity-led is set to "sandbox:red" */ + /* options/u-boot/activity-led is set to phandle to "sandbox:red" */ ut_assertok(led_get_by_label("sandbox:red", &dev)); ut_asserteq(LEDST_OFF, led_get_state(dev)); ut_assertok(led_activity_blink()); @@ -207,5 +210,6 @@ static int dm_test_led_boot(struct unit_test_state *uts)
return 0; } +DM_TEST(dm_test_led_activityt_blink, UTF_SCAN_PDATA | UTF_SCAN_FDT); #endif #endif
For everyone checking this, tomorrow I will push v2 of this series since CI catched additional BUGs for flat tree scenario. (I didn't test this with sandbox)
I also handle this and everything should be ok.
Hi Christian,
Thank you for digging into this and figuring it out.
-- 2.45.2
Christian Marangi
