[U-Boot] [PATCH] make fw_setenv write multiple variables
This patch makes fw_setenv write multiple variables on a single command line. That is "fw_setenv var1 value1 var2 value2" will write all variables and values without the need to erase multiple times the environment.
regards, Nikos
Dear Nikos Mavrogiannopoulos,
I reject this as it would introduce serious incompatibilities with the existing interfaces, both in fw_setenv and in the U-Boot setenv command.
Not to mention that it would be extremely error prone.
But I understand that such a functionality may be useful - just your interface design is bogus.
What about the following alternative: add an option to fw_setenv to read the commands (evventually even with an [optional?] leading "setenv") from a file (or from stdin, if no file name or '-' is given). Then you can have one set of parameters per line, and no argument counting or similar things are needed.
What do you think?
IIRC fw_setenv uses the first word as key and all the rest as the value. Judging on the description of your patch, this will probably break this behaviour.
I wrote a fw_editenv with -k/-v flags a couple of years ago in order to get around this, but i don't remember if I submitted it to the list.
If I didn't in the past, I did now; this is what we are using to write from the firmware to do bulk changes in the u-boot config space.
The patch is against 1.3.3
Dear Marc,
Thanks a lot.
Hm... this seems a lot of code to deal with a trivial issue. I think implementing my idea (reading the input line by line from a text file) would be much easier to implement and easier to use as well.
And of course the patch doesn't apply any more against current code.
[Not to mention that the Signed-off-by: line is missing, plus there are coding style issues.]
Yeah, probably.
IIRC, I tried to stick as close to the fw_Xenv code structure as possible; as such, this basically copies the fw_setenv block and modifies it without interfering or breaking in the upstream code.
I haven't looked at it, but unless there are large differences and rewrites in fw_env.c; the block of code should apply pretty easily: that's one of the underlying reasons keeping to current fw_env.c code separate and adding on it.
I didn't expect it to get applied: I just used it as input to the
fw_setenv key val val val val
example
Dear Marc Leeman,
In message 1f729c480904300627r5661774ej7d2cf5a19bee1083@mail.gmail.com you wrote:
Indeed. That code duplication is another problem, which for itself would be reason enough to reject the patch. It's unmaintainable.
Marc Leeman
