[PATCH] ARM: imx: Set stdio to serial on Data Modul i.MX8M Mini/Plus eDM SBC
In case CONSOLE_MUX and SYS_CONSOLE_IS_IN_ENV are enabled, the console stdin, stdout, stderr must be defined in environment. Define the default settings to fix the following warning on boot:
" In: No input devices available! Out: No output devices available! Err: No error devices available! "
Sort the default environment as well.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de --- include/configs/imx8mm_data_modul_edm_sbc.h | 11 +++++++---- include/configs/imx8mp_data_modul_edm_sbc.h | 9 ++++++--- 2 files changed, 13 insertions(+), 7 deletions(-)
diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index f7d2b660c1f..b777fe6073b 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -34,13 +34,11 @@ #define CFG_SYS_FSL_USDHC_NUM 2 #define CFG_SYS_FSL_ESDHC_ADDR 0
-#define CFG_EXTRA_ENV_SETTINGS \ +#define CFG_EXTRA_ENV_SETTINGS \ "altbootcmd=setenv devpart 2 && run bootcmd ; reset\0" \ "bootlimit=3\0" \ "devtype=mmc\0" \ "devpart=1\0" \ - /* Give slow devices beyond USB HUB chance to come up. */ \ - "usb_pgood_delay=2000\0" \ "dfu_alt_info=" \ /* RAM block at DRAM offset 256..768 MiB */ \ "ram ram0=ram ram 0x50000000 0x20000000&" \ @@ -76,6 +74,11 @@ "setenv stderr ${stderr},nc && " \ "setenv stdout ${stdout},nc && " \ "setenv stdin ${stdin},nc ; " \ - "fi" + "fi\0" \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" \ + /* Give slow devices beyond USB HUB chance to come up. */ \ + "usb_pgood_delay=2000\0"
#endif diff --git a/include/configs/imx8mp_data_modul_edm_sbc.h b/include/configs/imx8mp_data_modul_edm_sbc.h index 11ac3c00f7e..8d7954004c2 100644 --- a/include/configs/imx8mp_data_modul_edm_sbc.h +++ b/include/configs/imx8mp_data_modul_edm_sbc.h @@ -29,8 +29,6 @@ "bootlimit=3\0" \ "devtype=mmc\0" \ "devpart=1\0" \ - /* Give slow devices beyond USB HUB chance to come up. */ \ - "usb_pgood_delay=2000\0" \ "dmo_update_env=" \ "setenv dmo_update_env true ; saveenv ; saveenv\0" \ "dmo_update_sf_write_data=" \ @@ -40,6 +38,11 @@ "run dmo_update_sf_write_data\0" \ "dmo_update_sd_to_sf=" \ "load mmc 1:1 ${loadaddr} boot/flash.bin && " \ - "run dmo_update_sf_write_data\0" + "run dmo_update_sf_write_data\0" \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" \ + /* Give slow devices beyond USB HUB chance to come up. */ \ + "usb_pgood_delay=2000\0"
#endif
Applied, thanks.
Fabio Estevam
