[PATCH v1 0/3] Support Aspeed SGPIO controller
AST2600 SoC has 2 SGPIO master interfaces one with 128 pins another one with 80 pins, AST2500/AST2400 SoC has 1 SGPIO master interface that supports up to 80 pins.
Billy Tsai (3): gpio: Add Aspeed SGPIO driver ARM: dts: ast2500: Add SGPIO to device tree ARM: dts: ast2600: Add SGPIO to device tree
arch/arm/dts/ast2500-evb.dts | 5 + arch/arm/dts/ast2500.dtsi | 20 ++ arch/arm/dts/ast2600-evb.dts | 10 + arch/arm/dts/ast2600.dtsi | 40 +++ drivers/gpio/Kconfig | 7 + drivers/gpio/Makefile | 1 + drivers/gpio/gpio-aspeed-sgpio.c | 310 +++++++++++++++++++++++ drivers/pinctrl/aspeed/pinctrl_ast2500.c | 1 + drivers/pinctrl/aspeed/pinctrl_ast2600.c | 10 + 9 files changed, 404 insertions(+) create mode 100644 drivers/gpio/gpio-aspeed-sgpio.c
The Aspeed SGPIO driver supports the SGPIO controllers found in the AST2400, AST2500 and AST2600 BMC SoCs. The implementation is a cut-down copy of the upstream Linux kernel driver, adapted for u-boot.
Signed-off-by: Billy Tsai billy_tsai@aspeedtech.com --- drivers/gpio/Kconfig | 7 + drivers/gpio/Makefile | 1 + drivers/gpio/gpio-aspeed-sgpio.c | 310 +++++++++++++++++++++++++++++++ 3 files changed, 318 insertions(+) create mode 100644 drivers/gpio/gpio-aspeed-sgpio.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 1e5711663eb..92a8597420a 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -157,6 +157,13 @@ config ASPEED_GPIO is found in the AST2400, AST2500 and AST2600 BMC SoCs and provides access to over 200 GPIOs on each chip.
+config ASPEED_SGPIO + bool "Aspeed SGPIO Driver" + help + Say yes here to support the Aspeed serial GPIO driver. The controller + is found in the AST2400, AST2500 and AST2600 BMC SoCs and + provides access to generate serial GPIO signal. + config ASPEED_G7_GPIO bool "Aspeed G7 GPIO Driver" help diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index fe81b6ba88b..3f882c065d8 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -14,6 +14,7 @@ obj-$(CONFIG_$(XPL_)DM_PCA953X) += pca953x_gpio.o
obj-$(CONFIG_ASPEED_GPIO) += gpio-aspeed.o obj-$(CONFIG_ASPEED_G7_GPIO) += gpio-aspeed-g7.o +obj-$(CONFIG_ASPEED_SGPIO) += gpio-aspeed-sgpio.o obj-$(CONFIG_AT91_GPIO) += at91_gpio.o obj-$(CONFIG_ATMEL_PIO4) += atmel_pio4.o obj-$(CONFIG_BCM6345_GPIO) += bcm6345_gpio.o diff --git a/drivers/gpio/gpio-aspeed-sgpio.c b/drivers/gpio/gpio-aspeed-sgpio.c new file mode 100644 index 00000000000..4bbdec756f3 --- /dev/null +++ b/drivers/gpio/gpio-aspeed-sgpio.c @@ -0,0 +1,310 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) ASPEED Technology Inc. + * Billy Tsai billy_tsai@aspeedtech.com + */ +#include <asm/io.h> +#include <asm/gpio.h> + +#include <config.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <asm/io.h> +#include <linux/bug.h> +#include <linux/sizes.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> + +#define ASPEED_SGPIO_CTRL 0x54 + +#define ASPEED_SGPIO_CLK_DIV_MASK GENMASK(31, 16) +#define ASPEED_SGPIO_ENABLE BIT(0) +#define ASPEED_SGPIO_PINS_SHIFT 6 + +struct aspeed_sgpio_priv { + void *base; + struct clk pclk; + const struct aspeed_sgpio_pdata *pdata; +}; + +struct aspeed_sgpio_pdata { + const u32 pin_mask; + const struct aspeed_sgpio_llops *llops; +}; + +struct aspeed_sgpio_bank { + u16 val_regs; + u16 rdata_reg; + u16 tolerance_regs; + const char names[4][3]; +}; + +/* + * Note: The "value" register returns the input value when the GPIO is + * configured as an input. + * + * The "rdata" register returns the output value when the GPIO is + * configured as an output. + */ +static const struct aspeed_sgpio_bank aspeed_sgpio_banks[] = { + { + .val_regs = 0x0000, + .rdata_reg = 0x0070, + .tolerance_regs = 0x0018, + .names = { "A", "B", "C", "D" }, + }, + { + .val_regs = 0x001C, + .rdata_reg = 0x0074, + .tolerance_regs = 0x0034, + .names = { "E", "F", "G", "H" }, + }, + { + .val_regs = 0x0038, + .rdata_reg = 0x0078, + .tolerance_regs = 0x0050, + .names = { "I", "J", "K", "L" }, + }, + { + .val_regs = 0x0090, + .rdata_reg = 0x007C, + .tolerance_regs = 0x00A8, + .names = { "M", "N", "O", "P" }, + }, +}; + +enum aspeed_sgpio_reg { + reg_val, + reg_rdata, + reg_tolerance, +}; + +struct aspeed_sgpio_llops { + void (*reg_bit_set)(struct aspeed_sgpio_priv *gpio, unsigned int offset, + const enum aspeed_sgpio_reg reg, bool val); + bool (*reg_bit_get)(struct aspeed_sgpio_priv *gpio, unsigned int offset, + const enum aspeed_sgpio_reg reg); +}; + +#define GPIO_VAL_VALUE 0x00 + +static void __iomem *bank_reg(struct aspeed_sgpio_priv *gpio, + const struct aspeed_sgpio_bank *bank, + const enum aspeed_sgpio_reg reg) +{ + switch (reg) { + case reg_val: + return gpio->base + bank->val_regs + GPIO_VAL_VALUE; + case reg_rdata: + return gpio->base + bank->rdata_reg; + case reg_tolerance: + return gpio->base + bank->tolerance_regs; + default: + /* acturally if code runs to here, it's an error case */ + BUG(); + } +} + +#define GPIO_BANK(x) ((x) >> 6) +#define GPIO_OFFSET(x) ((x) & GENMASK(5, 0)) +#define GPIO_BIT(x) BIT(GPIO_OFFSET(x) >> 1) + +static const struct aspeed_sgpio_bank *to_bank(unsigned int offset) +{ + unsigned int bank; + + bank = GPIO_BANK(offset); + + WARN_ON(bank >= ARRAY_SIZE(aspeed_sgpio_banks)); + return &aspeed_sgpio_banks[bank]; +} + +static bool aspeed_sgpio_is_input(unsigned int offset) +{ + return !(offset % 2); +} + +static int aspeed_sgpio_get_value(struct udevice *dev, unsigned int offset) +{ + struct aspeed_sgpio_priv *gpio = dev_get_priv(dev); + enum aspeed_sgpio_reg reg; + + reg = aspeed_sgpio_is_input(offset) ? reg_val : reg_rdata; + + return gpio->pdata->llops->reg_bit_get(gpio, offset, reg); +} + +static int aspeed_sgpio_set_value(struct udevice *dev, unsigned int offset, + int value) +{ + struct aspeed_sgpio_priv *gpio = dev_get_priv(dev); + + if (aspeed_sgpio_is_input(offset)) + return -EINVAL; + + gpio->pdata->llops->reg_bit_set(gpio, offset, reg_val, value); + + return 0; +} + +static int aspeed_sgpio_direction_input(struct udevice *dev, + unsigned int offset) +{ + return aspeed_sgpio_is_input(offset) ? 0 : -EINVAL; +} + +static int aspeed_sgpio_set_flags(struct udevice *dev, unsigned int offset, ulong flags) +{ + int ret = -EOPNOTSUPP; + + if (flags & GPIOD_IS_OUT) { + bool value = flags & GPIOD_IS_OUT_ACTIVE; + + ret = aspeed_sgpio_set_value(dev, offset, value); + } else if (flags & GPIOD_IS_IN) { + ret = aspeed_sgpio_direction_input(dev, offset); + } + return ret; +} + +static int aspeed_sgpio_get_function(struct udevice *dev, unsigned int offset) +{ + return aspeed_sgpio_is_input(offset) ? GPIOF_INPUT : GPIOF_OUTPUT; +} + +static void aspeed_g4_reg_bit_set(struct aspeed_sgpio_priv *gpio, unsigned int offset, + const enum aspeed_sgpio_reg reg, bool val) +{ + const struct aspeed_sgpio_bank *bank = to_bank(offset); + void __iomem *addr = bank_reg(gpio, bank, reg); + u32 temp; + + if (reg == reg_val) + /* Since this is an output, read the cached value from rdata, then update val. */ + temp = readl(bank_reg(gpio, bank, reg_rdata)); + else + temp = readl(addr); + + if (val) + temp |= GPIO_BIT(offset); + else + temp &= ~GPIO_BIT(offset); + + writel(temp, addr); +} + +static bool aspeed_g4_reg_bit_get(struct aspeed_sgpio_priv *gpio, unsigned int offset, + const enum aspeed_sgpio_reg reg) +{ + const struct aspeed_sgpio_bank *bank = to_bank(offset); + void __iomem *addr = bank_reg(gpio, bank, reg); + + return !!(readl(addr) & GPIO_BIT(offset)); +} + +static const struct aspeed_sgpio_llops aspeed_g4_llops = { + .reg_bit_set = aspeed_g4_reg_bit_set, + .reg_bit_get = aspeed_g4_reg_bit_get, +}; + +static const struct dm_gpio_ops aspeed_sgpio_ops = { + .get_value = aspeed_sgpio_get_value, + .set_value = aspeed_sgpio_set_value, + .get_function = aspeed_sgpio_get_function, + .set_flags = aspeed_sgpio_set_flags, +}; + +static int aspeed_sgpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct aspeed_sgpio_priv *priv = dev_get_priv(dev); + u32 sgpio_freq, sgpio_clk_div, nr_gpios, gpio_cnt_regval, pin_mask; + ulong apb_freq; + int ret; + + priv->base = devfdt_get_addr_ptr(dev); + if (IS_ERR(priv->base)) + return PTR_ERR(priv->base); + + priv->pdata = (const struct aspeed_sgpio_pdata *)dev_get_driver_data(dev); + if (!priv->pdata) + return -EINVAL; + + pin_mask = priv->pdata->pin_mask; + + ret = ofnode_read_u32(dev_ofnode(dev), "ngpios", &nr_gpios); + if (ret < 0) { + dev_err(dev, "Could not read ngpios property\n"); + return -EINVAL; + } else if (nr_gpios % 8) { + dev_err(dev, "Number of GPIOs not multiple of 8: %d\n", + nr_gpios); + return -EINVAL; + } + + ret = ofnode_read_u32(dev_ofnode(dev), "bus-frequency", &sgpio_freq); + if (ret < 0) { + dev_err(dev, "Could not read bus-frequency property\n"); + return -EINVAL; + } + + ret = clk_get_by_index(dev, 0, &priv->pclk); + if (ret < 0) { + dev_err(dev, "get clock failed\n"); + return ret; + } + + apb_freq = clk_get_rate(&priv->pclk); + + /* + * From the datasheet, + * SGPIO period = 1/PCLK * 2 * (GPIO254[31:16] + 1) + * period = 2 * (GPIO254[31:16] + 1) / PCLK + * frequency = 1 / (2 * (GPIO254[31:16] + 1) / PCLK) + * frequency = PCLK / (2 * (GPIO254[31:16] + 1)) + * frequency * 2 * (GPIO254[31:16] + 1) = PCLK + * GPIO254[31:16] = PCLK / (frequency * 2) - 1 + */ + if (sgpio_freq == 0) + return -EINVAL; + + sgpio_clk_div = (apb_freq / (sgpio_freq * 2)) - 1; + + if (sgpio_clk_div > (1 << 16) - 1) + return -EINVAL; + + gpio_cnt_regval = ((nr_gpios / 8) << ASPEED_SGPIO_PINS_SHIFT) & pin_mask; + writel(FIELD_PREP(ASPEED_SGPIO_CLK_DIV_MASK, sgpio_clk_div) | gpio_cnt_regval | + ASPEED_SGPIO_ENABLE, priv->base + ASPEED_SGPIO_CTRL); + + uc_priv->bank_name = dev->name; + uc_priv->gpio_count = nr_gpios * 2; + + return 0; +} + +static const struct aspeed_sgpio_pdata ast2400_sgpio_pdata = { + .pin_mask = GENMASK(9, 6), + .llops = &aspeed_g4_llops, +}; + +static const struct aspeed_sgpio_pdata ast2600_sgpiom_pdata = { + .pin_mask = GENMASK(10, 6), + .llops = &aspeed_g4_llops, +}; + +static const struct udevice_id aspeed_sgpio_ids[] = { + { .compatible = "aspeed,ast2400-sgpio", .data = (ulong)&ast2400_sgpio_pdata, }, + { .compatible = "aspeed,ast2500-sgpio", .data = (ulong)&ast2400_sgpio_pdata, }, + { .compatible = "aspeed,ast2600-sgpiom", .data = (ulong)&ast2600_sgpiom_pdata, }, +}; + +U_BOOT_DRIVER(sgpio_aspeed) = { + .name = "sgpio-aspeed", + .id = UCLASS_GPIO, + .of_match = aspeed_sgpio_ids, + .ops = &aspeed_sgpio_ops, + .probe = aspeed_sgpio_probe, + .priv_auto = sizeof(struct aspeed_sgpio_priv), +};
Add SGPIO DTS node and enable it for AST2500 EVB.
Signed-off-by: Billy Tsai billy_tsai@aspeedtech.com --- arch/arm/dts/ast2500-evb.dts | 5 +++++ arch/arm/dts/ast2500.dtsi | 20 ++++++++++++++++++++ drivers/pinctrl/aspeed/pinctrl_ast2500.c | 1 + 3 files changed, 26 insertions(+)
diff --git a/arch/arm/dts/ast2500-evb.dts b/arch/arm/dts/ast2500-evb.dts index d481eadfeb0..9a5037deca2 100644 --- a/arch/arm/dts/ast2500-evb.dts +++ b/arch/arm/dts/ast2500-evb.dts @@ -129,3 +129,8 @@ reg = <0x4d>; }; }; + +&sgpio { + status = "okay"; + ngpios = <80>; +}; diff --git a/arch/arm/dts/ast2500.dtsi b/arch/arm/dts/ast2500.dtsi index 320d2e5340a..d677705fe85 100644 --- a/arch/arm/dts/ast2500.dtsi +++ b/arch/arm/dts/ast2500.dtsi @@ -255,6 +255,21 @@ interrupt-controller; };
+ sgpio: sgpio@1e780200 { + compatible = "aspeed,ast2500-sgpio"; + reg = <0x1e780200 0x100>; + interrupts = <40>; + clocks = <&scu ASPEED_CLK_APB>; + #gpio-cells = <2>; + gpio-controller; + #interrupt-cells = <2>; + interrupt-controller; + bus-frequency = <1000000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sgpm_default>; + status = "disabled"; + }; + timer: timer@1e782000 { /* This timer is a Faraday FTTMR010 derivative */ compatible = "aspeed,ast2400-timer"; @@ -1445,4 +1460,9 @@ function = "WDTRST2"; groups = "WDTRST2"; }; + + pinctrl_sgpm_default: sgpm_default { + function = "SGPM"; + groups = "SGPM"; + }; }; diff --git a/drivers/pinctrl/aspeed/pinctrl_ast2500.c b/drivers/pinctrl/aspeed/pinctrl_ast2500.c index 9e7c347caf8..5ecd3f262b9 100644 --- a/drivers/pinctrl/aspeed/pinctrl_ast2500.c +++ b/drivers/pinctrl/aspeed/pinctrl_ast2500.c @@ -62,6 +62,7 @@ static const struct ast2500_group_config ast2500_groups[] = { { "SD2", 5, (1 << 1) }, { "FWSPICS1", 3, (1 << 24) }, { "SPI1CS1", 1, (1 << 15) }, + { "SGPM", 2, (1 << 11) | (1 << 10) | (1 << 9) | (1 << 8) }, };
static int ast2500_pinctrl_get_groups_count(struct udevice *dev)
Add SGPIO DTS node and enable them for AST2600 EVB.
Signed-off-by: Billy Tsai billy_tsai@aspeedtech.com --- arch/arm/dts/ast2600-evb.dts | 10 ++++++ arch/arm/dts/ast2600.dtsi | 40 ++++++++++++++++++++++++ drivers/pinctrl/aspeed/pinctrl_ast2600.c | 10 ++++++ 3 files changed, 60 insertions(+)
diff --git a/arch/arm/dts/ast2600-evb.dts b/arch/arm/dts/ast2600-evb.dts index 9aac0e26f28..570ba61965a 100644 --- a/arch/arm/dts/ast2600-evb.dts +++ b/arch/arm/dts/ast2600-evb.dts @@ -266,3 +266,13 @@ bootph-all; status = "okay"; }; + +&sgpiom0 { + status = "okay"; + ngpios = <128>; +}; + +&sgpiom1 { + status = "okay"; + ngpios = <80>; +}; diff --git a/arch/arm/dts/ast2600.dtsi b/arch/arm/dts/ast2600.dtsi index 43db80edfe5..cb8ce8b6b6f 100644 --- a/arch/arm/dts/ast2600.dtsi +++ b/arch/arm/dts/ast2600.dtsi @@ -501,6 +501,36 @@ ngpios = <208>; };
+ sgpiom0: sgpiom@1e780500 { + compatible = "aspeed,ast2600-sgpiom"; + reg = <0x1e780500 0x100>; + interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&scu ASPEED_CLK_APB2>; + #gpio-cells = <2>; + gpio-controller; + #interrupt-cells = <2>; + interrupt-controller; + bus-frequency = <1000000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sgpm1_default>; + status = "disabled"; + }; + + sgpiom1: sgpiom@1e780600 { + compatible = "aspeed,ast2600-sgpiom"; + reg = <0x1e780600 0x100>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&scu ASPEED_CLK_APB2>; + #gpio-cells = <2>; + gpio-controller; + #interrupt-cells = <2>; + interrupt-controller; + bus-frequency = <12000000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sgpm2_default>; + status = "disabled"; + }; + gpio1: gpio@1e780800 { compatible = "aspeed,ast2600-gpio"; reg = <0x1e780800 0x800>; @@ -2167,4 +2197,14 @@ function = "PCIE1RC"; groups = "PCIE1RC"; }; + + pinctrl_sgpm1_default: sgpm1_default { + function = "SGPM1"; + groups = "SGPM1"; + }; + + pinctrl_sgpm2_default: sgpm2_default { + function = "SGPM2"; + groups = "SGPM2"; + }; }; diff --git a/drivers/pinctrl/aspeed/pinctrl_ast2600.c b/drivers/pinctrl/aspeed/pinctrl_ast2600.c index bc12590e583..f4bec6fe53c 100644 --- a/drivers/pinctrl/aspeed/pinctrl_ast2600.c +++ b/drivers/pinctrl/aspeed/pinctrl_ast2600.c @@ -454,6 +454,14 @@ static struct aspeed_sig_desc pwm15g1[] = { {0x41c, BIT(31), 0}, };
+static struct aspeed_sig_desc sgpm1[] = { + {0x414, GENMASK(27, 24), 0}, +}; + +static struct aspeed_sig_desc sgpm2[] = { + {0x6d0, GENMASK(7, 4), 0}, +}; + static const struct aspeed_group_config ast2600_groups[] = { { "MAC1LINK", ARRAY_SIZE(mac1_link), mac1_link }, { "MAC2LINK", ARRAY_SIZE(mac2_link), mac2_link }, @@ -543,6 +551,8 @@ static const struct aspeed_group_config ast2600_groups[] = { { "PWM14G1", ARRAY_SIZE(pwm14g1), pwm14g1 }, { "PWM15G0", ARRAY_SIZE(pwm15g0), pwm15g0 }, { "PWM15G1", ARRAY_SIZE(pwm15g1), pwm15g1 }, + { "SGPM1", ARRAY_SIZE(sgpm1), sgpm1 }, + { "SGPM2", ARRAY_SIZE(sgpm2), sgpm2 }, };
static int ast2600_pinctrl_get_groups_count(struct udevice *dev)
Billy Tsai
