[PATCH u-boot v2 0/4] r8152: support more chips
v2: For patch #1, replace u32 with u8 for rtl_reset_bmu().
For patch #3, use USB_BP(n) to replace USB_BP_0 ~ USB_BP_7. Write the registers in bulk for rtl_clear_bp().
For patch #4, add a macro for the magic value. Remove type casts. Write the register in bulk, if it is possible. Reduce indent.
v1: The first two patched are some improvements. And the last two patches are used to support RTL8153B and RTL8154B.
Hayes Wang (4): eth/r8152: reset bmu after disabling Tx/Rx eth/r8152: reset PHY after setting it eth/r8152: modify rtl_clear_bp function eth/r8152: support RTL8153B/RTL8154B
drivers/usb/eth/r8152.c | 223 +++++++++++++++++++++++++++++++++- drivers/usb/eth/r8152.h | 71 +++++++++-- drivers/usb/eth/r8152_fw.c | 239 +++++++++++++++++++++++++++++++++---- 3 files changed, 493 insertions(+), 40 deletions(-)
Reset bmu after disabling Tx/Rx. This is used to clear the FIFO of Tx/Rx. The remained data may be transferred after Tx/Rx is re-enabled. And it results in garbage data.
Signed-off-by: Hayes Wang hayeswang@realtek.com --- drivers/usb/eth/r8152.c | 14 ++++++++++++++ drivers/usb/eth/r8152.h | 7 ++++++- 2 files changed, 20 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/eth/r8152.c b/drivers/usb/eth/r8152.c index f201a1789b..041cb22dd3 100644 --- a/drivers/usb/eth/r8152.c +++ b/drivers/usb/eth/r8152.c @@ -568,6 +568,17 @@ static void r8153_power_cut_en(struct r8152 *tp, bool enable) ocp_write_word(tp, MCU_TYPE_USB, USB_MISC_0, ocp_data); }
+static void rtl_reset_bmu(struct r8152 *tp) +{ + u8 ocp_data; + + ocp_data = ocp_read_byte(tp, MCU_TYPE_USB, USB_BMU_RESET); + ocp_data &= ~(BMU_RESET_EP_IN | BMU_RESET_EP_OUT); + ocp_write_byte(tp, MCU_TYPE_USB, USB_BMU_RESET, ocp_data); + ocp_data |= BMU_RESET_EP_IN | BMU_RESET_EP_OUT; + ocp_write_byte(tp, MCU_TYPE_USB, USB_BMU_RESET, ocp_data); +} + static int r8152_read_mac(struct r8152 *tp, unsigned char *macaddr) { int ret; @@ -786,6 +797,7 @@ static void r8153_first_init(struct r8152 *tp) r8153_hw_phy_cfg(tp);
rtl8152_nic_reset(tp); + rtl_reset_bmu(tp);
ocp_data = ocp_read_byte(tp, MCU_TYPE_PLA, PLA_OOB_CTRL); ocp_data &= ~NOW_IS_OOB; @@ -832,6 +844,7 @@ static void r8153_enter_oob(struct r8152 *tp) ocp_write_byte(tp, MCU_TYPE_PLA, PLA_OOB_CTRL, ocp_data);
rtl_disable(tp); + rtl_reset_bmu(tp);
rtl8152_reinit_ll(tp);
@@ -873,6 +886,7 @@ static void rtl8153_disable(struct r8152 *tp) { r8153_disable_aldps(tp); rtl_disable(tp); + rtl_reset_bmu(tp); }
static int rtl8152_set_speed(struct r8152 *tp, u8 autoneg, u16 speed, u8 duplex) diff --git a/drivers/usb/eth/r8152.h b/drivers/usb/eth/r8152.h index 10e0da8eb1..4daf4ee87d 100644 --- a/drivers/usb/eth/r8152.h +++ b/drivers/usb/eth/r8152.h @@ -89,9 +89,10 @@ #define USB_TX_DMA 0xd434 #define USB_TOLERANCE 0xd490 #define USB_LPM_CTRL 0xd41a +#define USB_BMU_RESET 0xd4b0 #define USB_UPS_CTRL 0xd800 -#define USB_MISC_0 0xd81a #define USB_POWER_CUT 0xd80a +#define USB_MISC_0 0xd81a #define USB_AFE_CTRL2 0xd824 #define USB_WDT11_CTRL 0xe43c #define USB_BP_BA 0xfc26 @@ -324,6 +325,10 @@ #define TEST_MODE_DISABLE 0x00000001 #define TX_SIZE_ADJUST1 0x00000100
+/* USB_BMU_RESET */ +#define BMU_RESET_EP_IN 0x01 +#define BMU_RESET_EP_OUT 0x02 + /* USB_UPS_CTRL */ #define POWER_CUT 0x0100
Applied all to next, thanks!
Some settings of PHY have to work after resetting PHY.
Signed-off-by: Hayes Wang hayeswang@realtek.com --- drivers/usb/eth/r8152.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/eth/r8152.c b/drivers/usb/eth/r8152.c index 041cb22dd3..7f988543a1 100644 --- a/drivers/usb/eth/r8152.c +++ b/drivers/usb/eth/r8152.c @@ -947,7 +947,7 @@ static int rtl8152_set_speed(struct r8152 *tp, u8 autoneg, u16 speed, u8 duplex) return -EINVAL; }
- bmcr = BMCR_ANENABLE | BMCR_ANRESTART; + bmcr = BMCR_ANENABLE | BMCR_ANRESTART | BMCR_RESET; }
if (tp->supports_gmii)
The original rtl_clear_bp() is used to clear the firmware of both PLA and USB MCU. The new one could clear the firmware of PLA or USB independently. It is unnecessary to clear firmware, if there is no one to be updated.
Besides, clear the firmware by writing the relative registers in bulk.
Signed-off-by: Hayes Wang hayeswang@realtek.com --- drivers/usb/eth/r8152.h | 13 ++------- drivers/usb/eth/r8152_fw.c | 58 ++++++++++++++++++++++---------------- 2 files changed, 36 insertions(+), 35 deletions(-)
diff --git a/drivers/usb/eth/r8152.h b/drivers/usb/eth/r8152.h index 4daf4ee87d..710637d7a2 100644 --- a/drivers/usb/eth/r8152.h +++ b/drivers/usb/eth/r8152.h @@ -95,16 +95,9 @@ #define USB_MISC_0 0xd81a #define USB_AFE_CTRL2 0xd824 #define USB_WDT11_CTRL 0xe43c -#define USB_BP_BA 0xfc26 -#define USB_BP_0 0xfc28 -#define USB_BP_1 0xfc2a -#define USB_BP_2 0xfc2c -#define USB_BP_3 0xfc2e -#define USB_BP_4 0xfc30 -#define USB_BP_5 0xfc32 -#define USB_BP_6 0xfc34 -#define USB_BP_7 0xfc36 -#define USB_BP_EN 0xfc38 +#define USB_BP_BA PLA_BP_BA +#define USB_BP(n) (0xfc28 + 2 * (n)) +#define USB_BP_EN PLA_BP_EN
/* OCP Registers */ #define OCP_ALDPS_CONFIG 0x2010 diff --git a/drivers/usb/eth/r8152_fw.c b/drivers/usb/eth/r8152_fw.c index f953b0384b..2da1f221b4 100644 --- a/drivers/usb/eth/r8152_fw.c +++ b/drivers/usb/eth/r8152_fw.c @@ -729,28 +729,30 @@ static u16 r8153_pla_patch_d_bp[] = { 0xfc2e, 0x0000, 0xfc30, 0x0000, 0xfc32, 0x0000, 0xfc34, 0x0000, 0xfc36, 0x0000, 0xfc38, 0x0007 };
-static void rtl_clear_bp(struct r8152 *tp) +static void rtl_clear_bp(struct r8152 *tp, u16 type) { - ocp_write_dword(tp, MCU_TYPE_PLA, PLA_BP_0, 0); - ocp_write_dword(tp, MCU_TYPE_PLA, PLA_BP_2, 0); - ocp_write_dword(tp, MCU_TYPE_PLA, PLA_BP_4, 0); - ocp_write_dword(tp, MCU_TYPE_PLA, PLA_BP_6, 0); - ocp_write_dword(tp, MCU_TYPE_USB, USB_BP_0, 0); - ocp_write_dword(tp, MCU_TYPE_USB, USB_BP_2, 0); - ocp_write_dword(tp, MCU_TYPE_USB, USB_BP_4, 0); - ocp_write_dword(tp, MCU_TYPE_USB, USB_BP_6, 0); + u8 zeros[16] = {0}; + + switch (tp->version) { + case RTL_VER_01: + case RTL_VER_02: + case RTL_VER_07: + break; + case RTL_VER_03: + case RTL_VER_04: + case RTL_VER_05: + case RTL_VER_06: + ocp_write_byte(tp, type, PLA_BP_EN, 0); + break; + default: + break; + }
- mdelay(6); + generic_ocp_write(tp, USB_BP(0), 0xff, sizeof(zeros), zeros, type);
- ocp_write_word(tp, MCU_TYPE_PLA, PLA_BP_BA, 0); - ocp_write_word(tp, MCU_TYPE_USB, USB_BP_BA, 0); -} + mdelay(6);
-static void r8153_clear_bp(struct r8152 *tp) -{ - ocp_write_byte(tp, MCU_TYPE_PLA, PLA_BP_EN, 0); - ocp_write_byte(tp, MCU_TYPE_USB, USB_BP_EN, 0); - rtl_clear_bp(tp); + ocp_write_word(tp, type, PLA_BP_BA, 0); }
static void r8152b_set_dq_desc(struct r8152 *tp) @@ -826,7 +828,7 @@ void r8152b_firmware(struct r8152 *tp) int i;
r8152b_set_dq_desc(tp); - rtl_clear_bp(tp); + rtl_clear_bp(tp, MCU_TYPE_PLA);
generic_ocp_write(tp, 0xf800, 0x3f, sizeof(r8152b_pla_patch_a), @@ -847,7 +849,7 @@ void r8152b_firmware(struct r8152 *tp) ocp_write_word(tp, MCU_TYPE_PLA, 0xb098, 0x0200); ocp_write_word(tp, MCU_TYPE_PLA, 0xb092, 0x7030); } else if (tp->version == RTL_VER_02) { - rtl_clear_bp(tp); + rtl_clear_bp(tp, MCU_TYPE_PLA);
generic_ocp_write(tp, 0xf800, 0xff, sizeof(r8152b_pla_patch_a2), @@ -866,8 +868,6 @@ void r8153_firmware(struct r8152 *tp) int i;
if (tp->version == RTL_VER_03) { - r8153_clear_bp(tp); - r8153_pre_ram_code(tp, 0x7000);
for (i = 0; i < ARRAY_SIZE(r8153_ram_code_a); i += 2) @@ -887,7 +887,8 @@ void r8153_firmware(struct r8152 *tp) r8153_post_ram_code(tp);
r8153_wdt1_end(tp); - r8153_clear_bp(tp); + + rtl_clear_bp(tp, MCU_TYPE_USB);
ocp_write_word(tp, MCU_TYPE_USB, USB_BP_EN, 0x0000); generic_ocp_write(tp, 0xf800, 0xff, @@ -904,6 +905,8 @@ void r8153_firmware(struct r8152 *tp) ocp_write_word(tp, MCU_TYPE_PLA, 0xd38e, 0x0082); }
+ rtl_clear_bp(tp, MCU_TYPE_PLA); + ocp_write_word(tp, MCU_TYPE_PLA, PLA_BP_EN, 0x0000); generic_ocp_write(tp, 0xf800, 0xff, sizeof(r8153_pla_patch_b), @@ -932,7 +935,8 @@ void r8153_firmware(struct r8152 *tp) r8153_post_ram_code(tp);
ocp_write_word(tp, MCU_TYPE_USB, USB_BP_EN, 0x0000); generic_ocp_write(tp, 0xf800, 0xff, @@ -951,6 +955,8 @@ void r8153_firmware(struct r8152 *tp) ocp_write_word(tp, MCU_TYPE_USB, USB_BP_EN, 0x00ef); }
+ rtl_clear_bp(tp, MCU_TYPE_PLA); + ocp_write_word(tp, MCU_TYPE_PLA, PLA_BP_EN, 0x0000); generic_ocp_write(tp, 0xf800, 0xff, sizeof(r8153_pla_patch_c), @@ -985,7 +991,7 @@ void r8153_firmware(struct r8152 *tp)
- r8153_clear_bp(tp); + rtl_clear_bp(tp, MCU_TYPE_USB);
ocp_write_word(tp, MCU_TYPE_USB, USB_BP_EN, 0x0000); generic_ocp_write(tp, 0xf800, 0xff, sizeof(usb_patch_d), @@ -996,6 +1002,8 @@ void r8153_firmware(struct r8152 *tp) r8153_usb_patch_d_bp[i], r8153_usb_patch_d_bp[i+1]);
+ rtl_clear_bp(tp, MCU_TYPE_PLA); + ocp_write_word(tp, MCU_TYPE_PLA, PLA_BP_EN, 0x0000); generic_ocp_write(tp, 0xf800, 0xff, sizeof(pla_patch_d), pla_patch_d, MCU_TYPE_PLA);
This is used to support RTL8153B and RTL8154B.
Signed-off-by: Hayes Wang hayeswang@realtek.com --- drivers/usb/eth/r8152.c | 207 ++++++++++++++++++++++++++++++++++++- drivers/usb/eth/r8152.h | 41 +++++++- drivers/usb/eth/r8152_fw.c | 170 ++++++++++++++++++++++++++++++ 3 files changed, 414 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/eth/r8152.c b/drivers/usb/eth/r8152.c index 7f988543a1..d8fb0acd0f 100644 --- a/drivers/usb/eth/r8152.c +++ b/drivers/usb/eth/r8152.c @@ -68,6 +68,8 @@ static const struct r8152_version r8152_versions[] = { { 0x5c20, RTL_VER_05, 1 }, { 0x5c30, RTL_VER_06, 1 }, { 0x4800, RTL_VER_07, 0 }, + { 0x6000, RTL_VER_08, 1 }, + { 0x6010, RTL_VER_09, 1 }, };
static @@ -331,6 +333,12 @@ void sram_write(struct r8152 *tp, u16 addr, u16 data) ocp_reg_write(tp, OCP_SRAM_DATA, data); }
+static u16 sram_read(struct r8152 *tp, u16 addr) +{ + ocp_reg_write(tp, OCP_SRAM_ADDR, addr); + return ocp_reg_read(tp, OCP_SRAM_DATA); +} + int r8152_wait_for_bit(struct r8152 *tp, bool ocp_reg, u16 type, u16 index, const u32 mask, bool set, unsigned int timeout) { @@ -467,12 +475,56 @@ static void r8153_set_rx_early_timeout(struct r8152 *tp) { u32 ocp_data = tp->coalesce / 8;
- ocp_write_word(tp, MCU_TYPE_USB, USB_RX_EARLY_TIMEOUT, ocp_data); + switch (tp->version) { + case RTL_VER_03: + case RTL_VER_04: + case RTL_VER_05: + case RTL_VER_06: + ocp_write_word(tp, MCU_TYPE_USB, USB_RX_EARLY_TIMEOUT, + ocp_data); + break; + + case RTL_VER_08: + case RTL_VER_09: + /* The RTL8153B uses USB_RX_EXTRA_AGGR_TMR for rx timeout + * primarily. For USB_RX_EARLY_TIMEOUT, we fix it to 1264ns. + */ + ocp_write_word(tp, MCU_TYPE_USB, USB_RX_EARLY_TIMEOUT, + RX_AUXILIARY_TIMER / 8); + ocp_write_word(tp, MCU_TYPE_USB, USB_RX_EXTRA_AGGR_TMR, + ocp_data); + break; + + default: + debug("** %s Invalid Device\n", __func__); + break; + } }
static void r8153_set_rx_early_size(struct r8152 *tp) { - u32 ocp_data = (RTL8152_AGG_BUF_SZ - RTL8153_RMS) / 4; + u32 ocp_data = (RTL8152_AGG_BUF_SZ - RTL8153_RMS - + sizeof(struct rx_desc)); + + switch (tp->version) { + case RTL_VER_03: + case RTL_VER_04: + case RTL_VER_05: + case RTL_VER_06: + ocp_write_word(tp, MCU_TYPE_USB, USB_RX_EARLY_SIZE, + ocp_data / 4); + break; + + case RTL_VER_08: + case RTL_VER_09: + ocp_write_word(tp, MCU_TYPE_USB, USB_RX_EARLY_SIZE, + ocp_data / 8); + break; + + default: + debug("** %s Invalid Device\n", __func__); + break; + }
ocp_write_word(tp, MCU_TYPE_USB, USB_RX_EARLY_SIZE, ocp_data); } @@ -540,6 +592,19 @@ static void r8153_u1u2en(struct r8152 *tp, bool enable) usb_ocp_write(tp, USB_TOLERANCE, BYTE_EN_SIX_BYTES, sizeof(u1u2), u1u2); }
+static void r8153b_u1u2en(struct r8152 *tp, bool enable) +{ + u16 ocp_data; + + ocp_data = ocp_read_word(tp, MCU_TYPE_USB, USB_LPM_CONFIG); + if (enable) + ocp_data |= LPM_U1U2_EN; + else + ocp_data &= ~LPM_U1U2_EN; + + ocp_write_word(tp, MCU_TYPE_USB, USB_LPM_CONFIG, ocp_data); +} + static void r8153_u2p3en(struct r8152 *tp, bool enable) { u32 ocp_data; @@ -784,6 +849,71 @@ static void r8153_hw_phy_cfg(struct r8152 *tp) sram_write(tp, SRAM_10M_AMP2, 0x0208); }
+static u32 r8152_efuse_read(struct r8152 *tp, u8 addr) +{ + u32 ocp_data; + + ocp_write_word(tp, MCU_TYPE_PLA, PLA_EFUSE_CMD, EFUSE_READ_CMD | addr); + ocp_data = ocp_read_word(tp, MCU_TYPE_PLA, PLA_EFUSE_CMD); + ocp_data = (ocp_data & EFUSE_DATA_BIT16) << 9; /* data of bit16 */ + ocp_data |= ocp_read_word(tp, MCU_TYPE_PLA, PLA_EFUSE_DATA); + + return ocp_data; +} + +static void r8153b_hw_phy_cfg(struct r8152 *tp) +{ + u32 ocp_data; + u16 data; + + data = r8152_mdio_read(tp, MII_BMCR); + if (data & BMCR_PDOWN) { + data &= ~BMCR_PDOWN; + r8152_mdio_write(tp, MII_BMCR, data); + } + + /* U1/U2/L1 idle timer. 500 us */ + ocp_write_word(tp, MCU_TYPE_USB, USB_U1U2_TIMER, 500); + + r8153b_firmware(tp); + + data = sram_read(tp, SRAM_GREEN_CFG); + data |= R_TUNE_EN; + sram_write(tp, SRAM_GREEN_CFG, data); + data = ocp_reg_read(tp, OCP_NCTL_CFG); + data |= PGA_RETURN_EN; + ocp_reg_write(tp, OCP_NCTL_CFG, data); + + /* ADC Bias Calibration: + * read efuse offset 0x7d to get a 17-bit data. Remove the dummy/fake + * bit (bit3) to rebuild the real 16-bit data. Write the data to the + * ADC ioffset. + */ + ocp_data = r8152_efuse_read(tp, 0x7d); + ocp_data = ((ocp_data & 0x1fff0) >> 1) | (ocp_data & 0x7); + if (ocp_data != 0xffff) + ocp_reg_write(tp, OCP_ADC_IOFFSET, ocp_data); + + /* ups mode tx-link-pulse timing adjustment: + * rg_saw_cnt = OCP reg 0xC426 Bit[13:0] + * swr_cnt_1ms_ini = 16000000 / rg_saw_cnt + */ + ocp_data = ocp_reg_read(tp, 0xc426); + ocp_data &= 0x3fff; + if (ocp_data) { + u32 swr_cnt_1ms_ini; + + swr_cnt_1ms_ini = (16000000 / ocp_data) & SAW_CNT_1MS_MASK; + ocp_data = ocp_read_word(tp, MCU_TYPE_USB, USB_UPS_CFG); + ocp_data = (ocp_data & ~SAW_CNT_1MS_MASK) | swr_cnt_1ms_ini; + ocp_write_word(tp, MCU_TYPE_USB, USB_UPS_CFG, ocp_data); + } + + ocp_data = ocp_read_word(tp, MCU_TYPE_PLA, PLA_PHY_PWR); + ocp_data |= PFM_PWM_SWITCH; + ocp_write_word(tp, MCU_TYPE_PLA, PLA_PHY_PWR, ocp_data); +} + static void r8153_first_init(struct r8152 *tp) { u32 ocp_data; @@ -991,6 +1121,16 @@ static void rtl8153_down(struct r8152 *tp) r8153_enter_oob(tp); }
+static void rtl8153b_up(struct r8152 *tp) +{ + r8153_first_init(tp); +} + +static void rtl8153b_down(struct r8152 *tp) +{ + r8153_enter_oob(tp); +} + static void r8152b_get_version(struct r8152 *tp) { u32 ocp_data; @@ -1154,6 +1294,60 @@ static void r8153_init(struct r8152 *tp) rtl_tally_reset(tp); }
+static void r8153b_init(struct r8152 *tp) +{ + u32 ocp_data; + int i; + + r8153_disable_aldps(tp); + r8153b_u1u2en(tp, false); + + r8152_wait_for_bit(tp, 0, MCU_TYPE_PLA, PLA_BOOT_CTRL, + AUTOLOAD_DONE, 1, R8152_WAIT_TIMEOUT); + + for (i = 0; i < R8152_WAIT_TIMEOUT; i++) { + ocp_data = ocp_reg_read(tp, OCP_PHY_STATUS) & PHY_STAT_MASK; + if (ocp_data == PHY_STAT_LAN_ON || ocp_data == PHY_STAT_PWRDN) + break; + + mdelay(1); + } + + r8153_u2p3en(tp, false); + + /* MSC timer = 0xfff * 8ms = 32760 ms */ + ocp_write_word(tp, MCU_TYPE_USB, USB_MSC_TIMER, 0x0fff); + + r8153_power_cut_en(tp, false); + + /* MAC clock speed down */ + ocp_data = ocp_read_word(tp, MCU_TYPE_PLA, PLA_MAC_PWR_CTRL2); + ocp_data |= MAC_CLK_SPDWN_EN; + ocp_write_word(tp, MCU_TYPE_PLA, PLA_MAC_PWR_CTRL2, ocp_data); + + ocp_data = ocp_read_word(tp, MCU_TYPE_PLA, PLA_MAC_PWR_CTRL3); + ocp_data &= ~PLA_MCU_SPDWN_EN; + ocp_write_word(tp, MCU_TYPE_PLA, PLA_MAC_PWR_CTRL3, ocp_data); + + if (tp->version == RTL_VER_09) { + /* Disable Test IO for 32QFN */ + if (ocp_read_byte(tp, MCU_TYPE_PLA, 0xdc00) & BIT(5)) { + ocp_data = ocp_read_word(tp, MCU_TYPE_PLA, PLA_PHY_PWR); + ocp_data |= TEST_IO_OFF; + ocp_write_word(tp, MCU_TYPE_PLA, PLA_PHY_PWR, ocp_data); + } + } + + /* rx aggregation */ + ocp_data = ocp_read_word(tp, MCU_TYPE_USB, USB_USB_CTRL); + ocp_data &= ~(RX_AGG_DISABLE | RX_ZERO_EN); + ocp_write_word(tp, MCU_TYPE_USB, USB_USB_CTRL, ocp_data); + + rtl_tally_reset(tp); + r8153b_hw_phy_cfg(tp); + r8152b_enable_fc(tp); +} + static void rtl8152_unload(struct r8152 *tp) { if (tp->version != RTL_VER_01) @@ -1194,6 +1388,15 @@ static int rtl_ops_init(struct r8152 *tp) ops->unload = rtl8153_unload; break;
+ case RTL_VER_08: + case RTL_VER_09: + ops->init = r8153b_init; + ops->enable = rtl8153_enable; + ops->disable = rtl8153_disable; + ops->up = rtl8153b_up; + ops->down = rtl8153b_down; + break; + default: ret = -ENODEV; printf("r8152 Unknown Device\n"); diff --git a/drivers/usb/eth/r8152.h b/drivers/usb/eth/r8152.h index 710637d7a2..fa57e42502 100644 --- a/drivers/usb/eth/r8152.h +++ b/drivers/usb/eth/r8152.h @@ -26,6 +26,8 @@ #define PLA_TEREDO_TIMER 0xd2cc #define PLA_REALWOW_TIMER 0xd2e8 #define PLA_EXTRA_STATUS 0xd398 +#define PLA_EFUSE_DATA 0xdd00 +#define PLA_EFUSE_CMD 0xdd02 #define PLA_LEDSEL 0xdd90 #define PLA_LED_FEATURE 0xdd92 #define PLA_PHYAR 0xde00 @@ -76,8 +78,10 @@ #define USB_CSR_DUMMY2 0xb466 #define USB_DEV_STAT 0xb808 #define USB_CONNECT_TIMER 0xcbf8 +#define USB_MSC_TIMER 0xcbfc #define USB_BURST_SIZE 0xcfc0 #define USB_FW_FIX_EN1 0xcfcc +#define USB_LPM_CONFIG 0xcfd8 #define USB_USB_CTRL 0xd406 #define USB_PHY_CTRL 0xd408 #define USB_TX_AGG 0xd40a @@ -85,19 +89,23 @@ #define USB_USB_TIMER 0xd428 #define USB_RX_EARLY_TIMEOUT 0xd42c #define USB_RX_EARLY_SIZE 0xd42e -#define USB_PM_CTRL_STATUS 0xd432 +#define USB_PM_CTRL_STATUS 0xd432 /* RTL8153A */ +#define USB_RX_EXTRA_AGGR_TMR 0xd432 /* RTL8153B */ #define USB_TX_DMA 0xd434 #define USB_TOLERANCE 0xd490 #define USB_LPM_CTRL 0xd41a #define USB_BMU_RESET 0xd4b0 +#define USB_U1U2_TIMER 0xd4da #define USB_UPS_CTRL 0xd800 #define USB_POWER_CUT 0xd80a #define USB_MISC_0 0xd81a #define USB_AFE_CTRL2 0xd824 +#define USB_UPS_CFG 0xd842 #define USB_WDT11_CTRL 0xe43c #define USB_BP_BA PLA_BP_BA #define USB_BP(n) (0xfc28 + 2 * (n)) -#define USB_BP_EN PLA_BP_EN +#define USB_BP_EN PLA_BP_EN /* RTL8153A */ +#define USB_BP2_EN 0xfc48
/* OCP Registers */ #define OCP_ALDPS_CONFIG 0x2010 @@ -108,6 +116,7 @@ #define OCP_EEE_AR 0xa41a #define OCP_EEE_DATA 0xa41c #define OCP_PHY_STATUS 0xa420 +#define OCP_NCTL_CFG 0xa42c #define OCP_POWER_CFG 0xa430 #define OCP_EEE_CFG 0xa432 #define OCP_SRAM_ADDR 0xa436 @@ -117,9 +126,11 @@ #define OCP_EEE_ADV 0xa5d0 #define OCP_EEE_LPABLE 0xa5d2 #define OCP_PHY_STATE 0xa708 /* nway state for 8153 */ +#define OCP_ADC_IOFFSET 0xbcfc #define OCP_ADC_CFG 0xbc06
/* SRAM Register */ +#define SRAM_GREEN_CFG 0x8011 #define SRAM_LPF_CFG 0x8012 #define SRAM_10M_AMP1 0x8080 #define SRAM_10M_AMP2 0x8082 @@ -201,6 +212,7 @@ /* PLA_PHY_PWR */ #define PLA_PHY_PWR_LLR (LINK_LIST_READY << 24) #define PLA_PHY_PWR_TXEMP (TXFIFO_EMPTY << 24) +#define TEST_IO_OFF BIT(4)
/* PLA_MISC_1 */ #define RXDY_GATED_EN 0x0008 @@ -224,6 +236,10 @@ /* PLA_BDC_CR */ #define ALDPS_PROXY_MODE 0x0001
+/* PLA_EFUSE_CMD */ +#define EFUSE_READ_CMD BIT(15) +#define EFUSE_DATA_BIT16 BIT(7) + /* PLA_CONFIG34 */ #define LINK_ON_WAKE_EN 0x0010 #define LINK_OFF_WAKE_EN 0x0008 @@ -249,8 +265,10 @@
/* PLA_MAC_PWR_CTRL2 */ #define EEE_SPDWN_RATIO 0x8007 +#define MAC_CLK_SPDWN_EN BIT(15)
/* PLA_MAC_PWR_CTRL3 */ +#define PLA_MCU_SPDWN_EN BIT(14) #define PKT_AVAIL_SPDWN_EN 0x0100 #define SUSPEND_SPDWN_EN 0x0004 #define U1U2_SPDWN_EN 0x0002 @@ -306,6 +324,9 @@ /* USB_FW_FIX_EN1 */ #define FW_IP_RESET_EN BIT(9)
+/* USB_LPM_CONFIG */ +#define LPM_U1U2_EN BIT(0) + /* USB_TX_AGG */ #define TX_AGG_MAX_THRESHOLD 0x03
@@ -314,6 +335,9 @@ #define RX_THR_HIGH 0x7a120180 #define RX_THR_SLOW 0xffff0180
+/* USB_RX_EARLY_TIMEOUT */ +#define RX_AUXILIARY_TIMER 1264 + /* USB_TX_DMA */ #define TEST_MODE_DISABLE 0x00000001 #define TX_SIZE_ADJUST1 0x00000100 @@ -364,6 +388,9 @@ #define SEN_VAL_NORMAL 0xa000 #define SEL_RXIDLE 0x0100
+/* USB_UPS_CFG */ +#define SAW_CNT_1MS_MASK 0x0fff + /* OCP_ALDPS_CONFIG */ #define ENPWRSAVE 0x8000 #define ENPDNPS 0x0200 @@ -375,6 +402,9 @@ #define PHY_STAT_LAN_ON 3 #define PHY_STAT_PWRDN 5
+/* OCP_NCTL_CFG */ +#define PGA_RETURN_EN BIT(1) + /* OCP_POWER_CFG */ #define EEE_CLKDIV_EN 0x8000 #define EN_ALDPS 0x0004 @@ -427,6 +457,10 @@ #define ADC_EN 0x0080 #define EN_EMI_L 0x0040
+/* SRAM_GREEN_CFG */ +#define GREEN_ETH_EN BIT(15) +#define R_TUNE_EN BIT(11) + /* SRAM_LPF_CFG */ #define LPF_AUTO_TUNE 0x8000
@@ -571,6 +605,8 @@ enum rtl_version { RTL_VER_05, RTL_VER_06, RTL_VER_07, + RTL_VER_08, + RTL_VER_09, RTL_VER_MAX };
@@ -638,4 +674,5 @@ int r8152_wait_for_bit(struct r8152 *tp, bool ocp_reg, u16 type, u16 index,
void r8152b_firmware(struct r8152 *tp); void r8153_firmware(struct r8152 *tp); +void r8153b_firmware(struct r8152 *tp); #endif diff --git a/drivers/usb/eth/r8152_fw.c b/drivers/usb/eth/r8152_fw.c index 2da1f221b4..a41abed306 100644 --- a/drivers/usb/eth/r8152_fw.c +++ b/drivers/usb/eth/r8152_fw.c @@ -729,6 +729,127 @@ static u16 r8153_pla_patch_d_bp[] = { 0xfc2e, 0x0000, 0xfc30, 0x0000, 0xfc32, 0x0000, 0xfc34, 0x0000, 0xfc36, 0x0000, 0xfc38, 0x0007 };
+static u8 usb_patch2_b[] = { + 0x10, 0xe0, 0x26, 0xe0, 0x3a, 0xe0, 0x58, 0xe0, + 0x6c, 0xe0, 0x85, 0xe0, 0xa5, 0xe0, 0xbe, 0xe0, + 0xd8, 0xe0, 0xdb, 0xe0, 0xf3, 0xe0, 0xf5, 0xe0, + 0xf7, 0xe0, 0xf9, 0xe0, 0xfb, 0xe0, 0xfd, 0xe0, + 0x16, 0xc0, 0x00, 0x75, 0xd1, 0x49, 0x0d, 0xf0, + 0x0f, 0xc0, 0x0f, 0xc5, 0x00, 0x1e, 0x08, 0x9e, + 0x0c, 0x9d, 0x0c, 0xc6, 0x0a, 0x9e, 0x8f, 0x1c, + 0x0e, 0x8c, 0x0e, 0x74, 0xcf, 0x49, 0xfe, 0xf1, + 0x02, 0xc0, 0x00, 0xb8, 0x96, 0x31, 0x00, 0xdc, + 0x24, 0xe4, 0x80, 0x02, 0x34, 0xd3, 0xff, 0xc3, + 0x60, 0x72, 0xa1, 0x49, 0x0d, 0xf0, 0xf8, 0xc3, + 0xf8, 0xc2, 0x00, 0x1c, 0x68, 0x9c, 0xf6, 0xc4, + 0x6a, 0x9c, 0x6c, 0x9a, 0x8f, 0x1c, 0x6e, 0x8c, + 0x6e, 0x74, 0xcf, 0x49, 0xfe, 0xf1, 0x04, 0xc0, + 0x02, 0xc2, 0x00, 0xba, 0xa8, 0x28, 0xf8, 0xc7, + 0xea, 0xc0, 0x00, 0x75, 0xd1, 0x49, 0x15, 0xf0, + 0x19, 0xc7, 0x17, 0xc2, 0xec, 0x9a, 0x00, 0x19, + 0xee, 0x89, 0xee, 0x71, 0x9f, 0x49, 0xfe, 0xf1, + 0xea, 0x71, 0x9f, 0x49, 0x0a, 0xf0, 0xd9, 0xc2, + 0xec, 0x9a, 0x00, 0x19, 0xe8, 0x99, 0x81, 0x19, + 0xee, 0x89, 0xee, 0x71, 0x9f, 0x49, 0xfe, 0xf1, + 0x06, 0xc3, 0x02, 0xc2, 0x00, 0xba, 0xf0, 0x1d, + 0x4c, 0xe8, 0x00, 0xdc, 0x00, 0xd4, 0xcb, 0xc0, + 0x00, 0x75, 0xd1, 0x49, 0x0d, 0xf0, 0xc4, 0xc0, + 0xc4, 0xc5, 0x00, 0x1e, 0x08, 0x9e, 0xc2, 0xc6, + 0x0a, 0x9e, 0x0c, 0x9d, 0x8f, 0x1c, 0x0e, 0x8c, + 0x0e, 0x74, 0xcf, 0x49, 0xfe, 0xf1, 0x04, 0xc0, + 0x02, 0xc1, 0x00, 0xb9, 0xc4, 0x16, 0x20, 0xd4, + 0xb6, 0xc0, 0x00, 0x75, 0xd1, 0x48, 0x00, 0x9d, + 0xe5, 0xc7, 0xaf, 0xc2, 0xec, 0x9a, 0x00, 0x19, + 0xe8, 0x9a, 0x81, 0x19, 0xee, 0x89, 0xee, 0x71, + 0x9f, 0x49, 0xfe, 0xf1, 0x2c, 0xc1, 0xec, 0x99, + 0x81, 0x19, 0xee, 0x89, 0xee, 0x71, 0x9f, 0x49, + 0xfe, 0xf1, 0x04, 0xc3, 0x02, 0xc2, 0x00, 0xba, + 0x96, 0x1c, 0xc0, 0xd4, 0xc0, 0x88, 0x1e, 0xc6, + 0xc0, 0x70, 0x8f, 0x49, 0x0e, 0xf0, 0x8f, 0x48, + 0x93, 0xc6, 0xca, 0x98, 0x11, 0x18, 0xc8, 0x98, + 0x16, 0xc0, 0xcc, 0x98, 0x8f, 0x18, 0xce, 0x88, + 0xce, 0x70, 0x8f, 0x49, 0xfe, 0xf1, 0x0b, 0xe0, + 0x43, 0xc6, 0x00, 0x18, 0xc8, 0x98, 0x0b, 0xc0, + 0xcc, 0x98, 0x81, 0x18, 0xce, 0x88, 0xce, 0x70, + 0x8f, 0x49, 0xfe, 0xf1, 0x02, 0xc0, 0x00, 0xb8, + 0xf2, 0x19, 0x40, 0xd3, 0x20, 0xe4, 0x33, 0xc2, + 0x40, 0x71, 0x91, 0x48, 0x40, 0x99, 0x30, 0xc2, + 0x00, 0x19, 0x48, 0x99, 0xf8, 0xc1, 0x4c, 0x99, + 0x81, 0x19, 0x4e, 0x89, 0x4e, 0x71, 0x9f, 0x49, + 0xfe, 0xf1, 0x0b, 0xc1, 0x4c, 0x99, 0x81, 0x19, + 0x4e, 0x89, 0x4e, 0x71, 0x9f, 0x49, 0xfe, 0xf1, + 0x02, 0x71, 0x02, 0xc2, 0x00, 0xba, 0x0e, 0x34, + 0x24, 0xe4, 0x19, 0xc2, 0x40, 0x71, 0x91, 0x48, + 0x40, 0x99, 0x16, 0xc2, 0x00, 0x19, 0x48, 0x99, + 0xde, 0xc1, 0x4c, 0x99, 0x81, 0x19, 0x4e, 0x89, + 0x4e, 0x71, 0x9f, 0x49, 0xfe, 0xf1, 0xf1, 0xc1, + 0x4c, 0x99, 0x81, 0x19, 0x4e, 0x89, 0x4e, 0x71, + 0x9f, 0x49, 0xfe, 0xf1, 0x02, 0x71, 0x02, 0xc2, + 0x00, 0xba, 0x60, 0x33, 0x34, 0xd3, 0x00, 0xdc, + 0x1e, 0x89, 0x02, 0xc0, 0x00, 0xb8, 0xfa, 0x12, + 0x18, 0xc0, 0x00, 0x65, 0xd1, 0x49, 0x0e, 0xf0, + 0x11, 0xc0, 0x11, 0xc5, 0x00, 0x1e, 0x08, 0x9e, + 0x0c, 0x9d, 0x0e, 0xc6, 0x0a, 0x9e, 0x8f, 0x1c, + 0x0e, 0x8c, 0x0e, 0x74, 0xcf, 0x49, 0xfe, 0xf1, + 0x04, 0xc0, 0x02, 0xc2, 0x00, 0xba, 0xa0, 0x41, + 0x06, 0xd4, 0x00, 0xdc, 0x24, 0xe4, 0x80, 0x02, + 0x34, 0xd3, 0x02, 0xc0, 0x00, 0xb8, 0x00, 0x00, + 0x02, 0xc0, 0x00, 0xb8, 0x00, 0x00, 0x02, 0xc0, + 0x00, 0xb8, 0x00, 0x00, 0x02, 0xc0, 0x00, 0xb8, + 0x00, 0x00, 0x02, 0xc0, 0x00, 0xb8, 0x00, 0x00, + 0x02, 0xc0, 0x00, 0xb8, 0x00, 0x00, 0x00, 0x00 }; + +static u16 r8153b_usb_patch_b_bp[] = { + 0xfc26, 0xa000, 0xfc28, 0x2a20, 0xfc2a, 0x28a6, 0xfc2c, 0x1dee, + 0xfc2e, 0x16c2, 0xfc30, 0x1c94, 0xfc32, 0x19f0, 0xfc34, 0x340c, + 0xfc36, 0x335e, 0xfc38, 0x12f8, 0xfc3a, 0x419e, 0xfc3c, 0x0000, + 0xfc3e, 0x0000, 0xfc40, 0x0000, 0xfc42, 0x0000, 0xfc44, 0x0000, + 0xfc46, 0x0000, 0xfc48, 0x03ff }; + +static u8 pla_patch2_b[] = { + 0x05, 0xe0, 0x1b, 0xe0, 0x2c, 0xe0, 0x60, 0xe0, + 0x73, 0xe0, 0x15, 0xc6, 0xc2, 0x64, 0xd2, 0x49, + 0x06, 0xf1, 0xc4, 0x48, 0xc5, 0x48, 0xc6, 0x48, + 0xc7, 0x48, 0x05, 0xe0, 0x44, 0x48, 0x45, 0x48, + 0x46, 0x48, 0x47, 0x48, 0xc2, 0x8c, 0xc0, 0x64, + 0x46, 0x48, 0xc0, 0x8c, 0x05, 0xc5, 0x02, 0xc4, + 0x00, 0xbc, 0x18, 0x02, 0x06, 0xdc, 0xb0, 0xc0, + 0x10, 0xc5, 0xa0, 0x77, 0xa0, 0x74, 0x46, 0x48, + 0x47, 0x48, 0xa0, 0x9c, 0x0b, 0xc5, 0xa0, 0x74, + 0x44, 0x48, 0x43, 0x48, 0xa0, 0x9c, 0x05, 0xc5, + 0xa0, 0x9f, 0x02, 0xc5, 0x00, 0xbd, 0x3c, 0x03, + 0x1c, 0xe8, 0x20, 0xe8, 0xd4, 0x49, 0x04, 0xf1, + 0xd5, 0x49, 0x20, 0xf1, 0x28, 0xe0, 0x2a, 0xc7, + 0xe0, 0x75, 0xda, 0x49, 0x14, 0xf0, 0x27, 0xc7, + 0xe0, 0x75, 0xdc, 0x49, 0x10, 0xf1, 0x24, 0xc7, + 0xe0, 0x75, 0x25, 0xc7, 0xe0, 0x74, 0x2c, 0x40, + 0x0a, 0xfa, 0x1f, 0xc7, 0xe4, 0x75, 0xd0, 0x49, + 0x09, 0xf1, 0x1c, 0xc5, 0xe6, 0x9d, 0x11, 0x1d, + 0xe4, 0x8d, 0x04, 0xe0, 0x16, 0xc7, 0x00, 0x1d, + 0xe4, 0x8d, 0xe0, 0x8e, 0x11, 0x1d, 0xe0, 0x8d, + 0x07, 0xe0, 0x0c, 0xc7, 0xe0, 0x75, 0xda, 0x48, + 0xe0, 0x9d, 0x0b, 0xc7, 0xe4, 0x8e, 0x02, 0xc4, + 0x00, 0xbc, 0x28, 0x03, 0x02, 0xc4, 0x00, 0xbc, + 0x14, 0x03, 0x12, 0xe8, 0x4e, 0xe8, 0x1c, 0xe6, + 0x20, 0xe4, 0x80, 0x02, 0xa4, 0xc0, 0x12, 0xc2, + 0x40, 0x73, 0xb0, 0x49, 0x08, 0xf0, 0xb8, 0x49, + 0x06, 0xf0, 0xb8, 0x48, 0x40, 0x9b, 0x0b, 0xc2, + 0x40, 0x76, 0x05, 0xe0, 0x02, 0x61, 0x02, 0xc3, + 0x00, 0xbb, 0x0a, 0x0a, 0x02, 0xc3, 0x00, 0xbb, + 0x1a, 0x0a, 0x98, 0xd3, 0x1e, 0xfc, 0xfe, 0xc0, + 0x02, 0x62, 0xa0, 0x48, 0x02, 0x8a, 0x00, 0x72, + 0xa0, 0x49, 0x11, 0xf0, 0x13, 0xc1, 0x20, 0x62, + 0x2e, 0x21, 0x2f, 0x25, 0x00, 0x71, 0x9f, 0x24, + 0x0a, 0x40, 0x09, 0xf0, 0x00, 0x71, 0x18, 0x48, + 0xa0, 0x49, 0x03, 0xf1, 0x9f, 0x48, 0x02, 0xe0, + 0x1f, 0x48, 0x00, 0x99, 0x02, 0xc2, 0x00, 0xba, + 0xda, 0x0e, 0x08, 0xe9 }; + +static u16 r8153b_pla_patch_b_bp[] = { + 0xfc26, 0x8000, 0xfc28, 0x0216, 0xfc2a, 0x0332, 0xfc2c, 0x030c, + 0xfc2e, 0x0a08, 0xfc30, 0x0ec0, 0xfc32, 0x0000, 0xfc34, 0x0000, + 0xfc36, 0x0000, 0xfc38, 0x001e }; + static void rtl_clear_bp(struct r8152 *tp, u16 type) { u8 zeros[16] = {0}; @@ -744,7 +865,17 @@ static void rtl_clear_bp(struct r8152 *tp, u16 type) case RTL_VER_06: ocp_write_byte(tp, type, PLA_BP_EN, 0); break; + case RTL_VER_08: + case RTL_VER_09: default: + if (type == MCU_TYPE_USB) { + ocp_write_byte(tp, MCU_TYPE_USB, USB_BP2_EN, 0); + + generic_ocp_write(tp, USB_BP(8), 0xff, sizeof(zeros), + zeros, type); + } else { + ocp_write_byte(tp, MCU_TYPE_PLA, PLA_BP_EN, 0); + } break; }
@@ -1022,3 +1153,42 @@ void r8153_firmware(struct r8152 *tp) ocp_write_word(tp, MCU_TYPE_USB, USB_FW_FIX_EN1, ocp_data); } } + +void r8153b_firmware(struct r8152 *tp) +{ + u32 ocp_data; + int i; + + if (tp->version != RTL_VER_09) + return; + + rtl_clear_bp(tp, MCU_TYPE_USB); + + ocp_write_word(tp, MCU_TYPE_USB, USB_BP_EN, 0x0000); + generic_ocp_write(tp, 0xe600, 0xff, sizeof(usb_patch2_b), + usb_patch2_b, MCU_TYPE_USB); + + for (i = 0; i < ARRAY_SIZE(r8153b_usb_patch_b_bp); i += 2) + ocp_write_word(tp, MCU_TYPE_USB, + r8153b_usb_patch_b_bp[i], + r8153b_usb_patch_b_bp[i + 1]); + + rtl_clear_bp(tp, MCU_TYPE_PLA); + + ocp_write_word(tp, MCU_TYPE_PLA, PLA_BP_EN, 0x0000); + generic_ocp_write(tp, 0xf800, 0xff, sizeof(pla_patch2_b), + pla_patch2_b, MCU_TYPE_PLA); + + for (i = 0; i < ARRAY_SIZE(r8153b_pla_patch_b_bp); i += 2) + ocp_write_word(tp, MCU_TYPE_PLA, + r8153b_pla_patch_b_bp[i], + r8153b_pla_patch_b_bp[i + 1]); + + ocp_data = ocp_read_byte(tp, MCU_TYPE_USB, USB_USB2PHY); + ocp_data |= USB2PHY_L1 | USB2PHY_SUSPEND; + ocp_write_byte(tp, MCU_TYPE_USB, USB_USB2PHY, ocp_data); + + ocp_data = ocp_read_word(tp, MCU_TYPE_USB, USB_FW_FIX_EN1); + ocp_data |= FW_IP_RESET_EN; + ocp_write_word(tp, MCU_TYPE_USB, USB_FW_FIX_EN1, ocp_data); +}
Hayes Wang
