[U-Boot] [PATCH 1/4] mini-zed: Add ps7 files so SPL works.
* Files made from sample project.
Signed-off-by: Philip Balister philip@opensdr.com --- board/xilinx/zynq/zynq-minized/ps7_init_gpl.c | 10632 ++++++++++++++++ board/xilinx/zynq/zynq-minized/ps7_init_gpl.h | 131 + 2 files changed, 10763 insertions(+) create mode 100644 board/xilinx/zynq/zynq-minized/ps7_init_gpl.c create mode 100644 board/xilinx/zynq/zynq-minized/ps7_init_gpl.h
diff --git a/board/xilinx/zynq/zynq-minized/ps7_init_gpl.c b/board/xilinx/zynq/zynq-minized/ps7_init_gpl.c new file mode 100644 index 0000000000..654222a36d --- /dev/null +++ b/board/xilinx/zynq/zynq-minized/ps7_init_gpl.c @@ -0,0 +1,10632 @@ +/****************************************************************************** +* (c) Copyright 2010-2018 Xilinx, Inc. All rights reserved. +* +* This program is free software; you can redistribute it and/or modify +* it under the terms of the GNU General Public License as published by +* the Free Software Foundation; either version 2 of the License, or +* (at your option) any later version. +* +* This program is distributed in the hope that it will be useful, +* but WITHOUT ANY WARRANTY; without even the implied warranty of +* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +* GNU General Public License for more details. +* +* You should have received a copy of the GNU General Public License along +* with this program; if not, see http://www.gnu.org/licenses/ +* +* +******************************************************************************/ +/****************************************************************************/ +/** +* +* @file ps7_init_gpl.c +* +* This file is automatically generated +* +*****************************************************************************/ + +#include "ps7_init_gpl.h" + +unsigned long ps7_pll_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: PLL SLCR REGISTERS + // .. .. START: ARM PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000110[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000110[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000110[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U ,0x000FA220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x28 + // .. .. .. ==> 0XF8000100[18:12] = 0x00000028U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00028000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x0007F000U ,0x00028000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. ARM_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. SRCSEL = 0x0 + // .. .. .. ==> 0XF8000120[5:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. .. DIVISOR = 0x2 + // .. .. .. ==> 0XF8000120[13:8] = 0x00000002U + // .. .. .. ==> MASK : 0x00003F00U VAL : 0x00000200U + // .. .. .. CPU_6OR4XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[24:24] = 0x00000001U + // .. .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. .. CPU_3OR2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[25:25] = 0x00000001U + // .. .. .. ==> MASK : 0x02000000U VAL : 0x02000000U + // .. .. .. CPU_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[26:26] = 0x00000001U + // .. .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. .. CPU_1XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[27:27] = 0x00000001U + // .. .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. .. CPU_PERI_CLKACT = 0x1 + // .. .. .. ==> 0XF8000120[28:28] = 0x00000001U + // .. .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U ,0x1F000200U), + // .. .. FINISH: ARM PLL INIT + // .. .. START: DDR PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000114[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000114[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0x12c + // .. .. ==> 0XF8000114[21:12] = 0x0000012CU + // .. .. ==> MASK : 0x003FF000U VAL : 0x0012C000U + // .. .. + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U ,0x0012C220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x20 + // .. .. .. ==> 0XF8000104[18:12] = 0x00000020U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00020000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x0007F000U ,0x00020000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. DDR_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. DDR_3XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. DDR_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. DDR_3XCLK_DIVISOR = 0x2 + // .. .. .. ==> 0XF8000124[25:20] = 0x00000002U + // .. .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. .. DDR_2XCLK_DIVISOR = 0x3 + // .. .. .. ==> 0XF8000124[31:26] = 0x00000003U + // .. .. .. ==> MASK : 0xFC000000U VAL : 0x0C000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U ,0x0C200003U), + // .. .. FINISH: DDR PLL INIT + // .. .. START: IO PLL INIT + // .. .. PLL_RES = 0xc + // .. .. ==> 0XF8000118[7:4] = 0x0000000CU + // .. .. ==> MASK : 0x000000F0U VAL : 0x000000C0U + // .. .. PLL_CP = 0x3 + // .. .. ==> 0XF8000118[11:8] = 0x00000003U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000300U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000118[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U ,0x000FA3C0U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x2a + // .. .. .. ==> 0XF8000108[18:12] = 0x0000002AU + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x0002A000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x0007F000U ,0x0002A000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. IO_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[2:2] = 0x00000001U + // .. .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. FINISH: IO PLL INIT + // .. FINISH: PLL SLCR REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_clock_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: CLOCK CONTROL SLCR REGISTERS + // .. CLKACT = 0x1 + // .. ==> 0XF8000128[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. DIVISOR0 = 0xf + // .. ==> 0XF8000128[13:8] = 0x0000000FU + // .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. DIVISOR1 = 0x7 + // .. ==> 0XF8000128[25:20] = 0x00000007U + // .. ==> MASK : 0x03F00000U VAL : 0x00700000U + // .. + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U ,0x00700F01U), + // .. CLKACT = 0x1 + // .. ==> 0XF800014C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF800014C[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x7 + // .. ==> 0XF800014C[13:8] = 0x00000007U + // .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. + EMIT_MASKWRITE(0XF800014C, 0x00003F31U ,0x00000701U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000150[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000150[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000150[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x38 + // .. ==> 0XF8000150[13:8] = 0x00000038U + // .. ==> MASK : 0x00003F00U VAL : 0x00003800U + // .. + EMIT_MASKWRITE(0XF8000150, 0x00003F33U ,0x00003803U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000154[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000154[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000154[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xe + // .. ==> 0XF8000154[13:8] = 0x0000000EU + // .. ==> MASK : 0x00003F00U VAL : 0x00000E00U + // .. + EMIT_MASKWRITE(0XF8000154, 0x00003F33U ,0x00000E03U), + // .. .. START: TRACE CLOCK + // .. .. FINISH: TRACE CLOCK + // .. .. CLKACT = 0x1 + // .. .. ==> 0XF8000168[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000168[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR = 0x7 + // .. .. ==> 0XF8000168[13:8] = 0x00000007U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. .. + EMIT_MASKWRITE(0XF8000168, 0x00003F31U ,0x00000701U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000170[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x7 + // .. .. ==> 0XF8000170[13:8] = 0x00000007U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. .. DIVISOR1 = 0x4 + // .. .. ==> 0XF8000170[25:20] = 0x00000004U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U + // .. .. + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U ,0x00400700U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000180[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x7 + // .. .. ==> 0XF8000180[13:8] = 0x00000007U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. .. DIVISOR1 = 0x2 + // .. .. ==> 0XF8000180[25:20] = 0x00000002U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U ,0x00200700U), + // .. .. CLK_621_TRUE = 0x1 + // .. .. ==> 0XF80001C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF80001C4, 0x00000001U ,0x00000001U), + // .. .. DMA_CPU_2XCLKACT = 0x1 + // .. .. ==> 0XF800012C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. USB0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[2:2] = 0x00000001U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. USB1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. GEM0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. GEM1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. SDI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[10:10] = 0x00000001U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000400U + // .. .. SDI1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[11:11] = 0x00000001U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000800U + // .. .. SPI0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. SPI1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. CAN0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. CAN1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. I2C0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[18:18] = 0x00000001U + // .. .. ==> MASK : 0x00040000U VAL : 0x00040000U + // .. .. I2C1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. UART0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[20:20] = 0x00000001U + // .. .. ==> MASK : 0x00100000U VAL : 0x00100000U + // .. .. UART1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. GPIO_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[22:22] = 0x00000001U + // .. .. ==> MASK : 0x00400000U VAL : 0x00400000U + // .. .. LQSPI_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[23:23] = 0x00000001U + // .. .. ==> MASK : 0x00800000U VAL : 0x00800000U + // .. .. SMC_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[24:24] = 0x00000001U + // .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU ,0x01FC0C0DU), + // .. FINISH: CLOCK CONTROL SLCR REGISTERS + // .. START: THIS SHOULD BE BLANK + // .. FINISH: THIS SHOULD BE BLANK + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_ddr_init_data_3_0[] = { + // START: top + // .. START: DDR INITIALIZATION + // .. .. START: LOCK DDR + // .. .. reg_ddrc_soft_rstb = 0 + // .. .. ==> 0XF8006000[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x1 + // .. .. ==> 0XF8006000[3:2] = 0x00000001U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000004U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 0x1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000084U), + // .. .. FINISH: LOCK DDR + // .. .. reg_ddrc_t_rfc_nom_x32 = 0x82 + // .. .. ==> 0XF8006004[11:0] = 0x00000082U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000082U + // .. .. reserved_reg_ddrc_active_ranks = 0x1 + // .. .. ==> 0XF8006004[13:12] = 0x00000001U + // .. .. ==> MASK : 0x00003000U VAL : 0x00001000U + // .. .. reg_ddrc_addrmap_cs_bit0 = 0x0 + // .. .. ==> 0XF8006004[18:14] = 0x00000000U + // .. .. ==> MASK : 0x0007C000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU ,0x00001082U), + // .. .. reg_ddrc_hpr_min_non_critical_x32 = 0xf + // .. .. ==> 0XF8006008[10:0] = 0x0000000FU + // .. .. ==> MASK : 0x000007FFU VAL : 0x0000000FU + // .. .. reg_ddrc_hpr_max_starve_x32 = 0xf + // .. .. ==> 0XF8006008[21:11] = 0x0000000FU + // .. .. ==> MASK : 0x003FF800U VAL : 0x00007800U + // .. .. reg_ddrc_hpr_xact_run_length = 0xf + // .. .. ==> 0XF8006008[25:22] = 0x0000000FU + // .. .. ==> MASK : 0x03C00000U VAL : 0x03C00000U + // .. .. + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU ,0x03C0780FU), + // .. .. reg_ddrc_lpr_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF800600C[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_lpr_max_starve_x32 = 0x2 + // .. .. ==> 0XF800600C[21:11] = 0x00000002U + // .. .. ==> MASK : 0x003FF800U VAL : 0x00001000U + // .. .. reg_ddrc_lpr_xact_run_length = 0x8 + // .. .. ==> 0XF800600C[25:22] = 0x00000008U + // .. .. ==> MASK : 0x03C00000U VAL : 0x02000000U + // .. .. + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU ,0x02001001U), + // .. .. reg_ddrc_w_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF8006010[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_w_xact_run_length = 0x8 + // .. .. ==> 0XF8006010[14:11] = 0x00000008U + // .. .. ==> MASK : 0x00007800U VAL : 0x00004000U + // .. .. reg_ddrc_w_max_starve_x32 = 0x2 + // .. .. ==> 0XF8006010[25:15] = 0x00000002U + // .. .. ==> MASK : 0x03FF8000U VAL : 0x00010000U + // .. .. + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU ,0x00014001U), + // .. .. reg_ddrc_t_rc = 0x1b + // .. .. ==> 0XF8006014[5:0] = 0x0000001BU + // .. .. ==> MASK : 0x0000003FU VAL : 0x0000001BU + // .. .. reg_ddrc_t_rfc_min = 0xa1 + // .. .. ==> 0XF8006014[13:6] = 0x000000A1U + // .. .. ==> MASK : 0x00003FC0U VAL : 0x00002840U + // .. .. reg_ddrc_post_selfref_gap_x32 = 0x10 + // .. .. ==> 0XF8006014[20:14] = 0x00000010U + // .. .. ==> MASK : 0x001FC000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU ,0x0004285BU), + // .. .. reg_ddrc_wr2pre = 0x13 + // .. .. ==> 0XF8006018[4:0] = 0x00000013U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000013U + // .. .. reg_ddrc_powerdown_to_x32 = 0x6 + // .. .. ==> 0XF8006018[9:5] = 0x00000006U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000C0U + // .. .. reg_ddrc_t_faw = 0x16 + // .. .. ==> 0XF8006018[15:10] = 0x00000016U + // .. .. ==> MASK : 0x0000FC00U VAL : 0x00005800U + // .. .. reg_ddrc_t_ras_max = 0x24 + // .. .. ==> 0XF8006018[21:16] = 0x00000024U + // .. .. ==> MASK : 0x003F0000U VAL : 0x00240000U + // .. .. reg_ddrc_t_ras_min = 0x13 + // .. .. ==> 0XF8006018[26:22] = 0x00000013U + // .. .. ==> MASK : 0x07C00000U VAL : 0x04C00000U + // .. .. reg_ddrc_t_cke = 0x4 + // .. .. ==> 0XF8006018[31:28] = 0x00000004U + // .. .. ==> MASK : 0xF0000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU ,0x44E458D3U), + // .. .. reg_ddrc_write_latency = 0x5 + // .. .. ==> 0XF800601C[4:0] = 0x00000005U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000005U + // .. .. reg_ddrc_rd2wr = 0x7 + // .. .. ==> 0XF800601C[9:5] = 0x00000007U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000E0U + // .. .. reg_ddrc_wr2rd = 0xf + // .. .. ==> 0XF800601C[14:10] = 0x0000000FU + // .. .. ==> MASK : 0x00007C00U VAL : 0x00003C00U + // .. .. reg_ddrc_t_xp = 0x5 + // .. .. ==> 0XF800601C[19:15] = 0x00000005U + // .. .. ==> MASK : 0x000F8000U VAL : 0x00028000U + // .. .. reg_ddrc_pad_pd = 0x0 + // .. .. ==> 0XF800601C[22:20] = 0x00000000U + // .. .. ==> MASK : 0x00700000U VAL : 0x00000000U + // .. .. reg_ddrc_rd2pre = 0x5 + // .. .. ==> 0XF800601C[27:23] = 0x00000005U + // .. .. ==> MASK : 0x0F800000U VAL : 0x02800000U + // .. .. reg_ddrc_t_rcd = 0x7 + // .. .. ==> 0XF800601C[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU ,0x7282BCE5U), + // .. .. reg_ddrc_t_ccd = 0x4 + // .. .. ==> 0XF8006020[4:2] = 0x00000004U + // .. .. ==> MASK : 0x0000001CU VAL : 0x00000010U + // .. .. reg_ddrc_t_rrd = 0x6 + // .. .. ==> 0XF8006020[7:5] = 0x00000006U + // .. .. ==> MASK : 0x000000E0U VAL : 0x000000C0U + // .. .. reg_ddrc_refresh_margin = 0x2 + // .. .. ==> 0XF8006020[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_rp = 0x7 + // .. .. ==> 0XF8006020[15:12] = 0x00000007U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00007000U + // .. .. reg_ddrc_refresh_to_x32 = 0x8 + // .. .. ==> 0XF8006020[20:16] = 0x00000008U + // .. .. ==> MASK : 0x001F0000U VAL : 0x00080000U + // .. .. reg_ddrc_mobile = 0x0 + // .. .. ==> 0XF8006020[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reg_ddrc_en_dfi_dram_clk_disable = 0x0 + // .. .. ==> 0XF8006020[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reg_ddrc_read_latency = 0x7 + // .. .. ==> 0XF8006020[28:24] = 0x00000007U + // .. .. ==> MASK : 0x1F000000U VAL : 0x07000000U + // .. .. reg_phy_mode_ddr1_ddr2 = 0x1 + // .. .. ==> 0XF8006020[29:29] = 0x00000001U + // .. .. ==> MASK : 0x20000000U VAL : 0x20000000U + // .. .. reg_ddrc_dis_pad_pd = 0x0 + // .. .. ==> 0XF8006020[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU ,0x270872D0U), + // .. .. reg_ddrc_en_2t_timing_mode = 0x0 + // .. .. ==> 0XF8006024[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_prefer_write = 0x0 + // .. .. ==> 0XF8006024[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_mr_wr = 0x0 + // .. .. ==> 0XF8006024[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_ddrc_mr_addr = 0x0 + // .. .. ==> 0XF8006024[8:7] = 0x00000000U + // .. .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. .. reg_ddrc_mr_data = 0x0 + // .. .. ==> 0XF8006024[24:9] = 0x00000000U + // .. .. ==> MASK : 0x01FFFE00U VAL : 0x00000000U + // .. .. ddrc_reg_mr_wr_busy = 0x0 + // .. .. ==> 0XF8006024[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_type = 0x0 + // .. .. ==> 0XF8006024[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_rdata_valid = 0x0 + // .. .. ==> 0XF8006024[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U ,0x00000000U), + // .. .. reg_ddrc_final_wait_x32 = 0x7 + // .. .. ==> 0XF8006028[6:0] = 0x00000007U + // .. .. ==> MASK : 0x0000007FU VAL : 0x00000007U + // .. .. reg_ddrc_pre_ocd_x32 = 0x0 + // .. .. ==> 0XF8006028[10:7] = 0x00000000U + // .. .. ==> MASK : 0x00000780U VAL : 0x00000000U + // .. .. reg_ddrc_t_mrd = 0x4 + // .. .. ==> 0XF8006028[13:11] = 0x00000004U + // .. .. ==> MASK : 0x00003800U VAL : 0x00002000U + // .. .. + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU ,0x00002007U), + // .. .. reg_ddrc_emr2 = 0x8 + // .. .. ==> 0XF800602C[15:0] = 0x00000008U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000008U + // .. .. reg_ddrc_emr3 = 0x0 + // .. .. ==> 0XF800602C[31:16] = 0x00000000U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU ,0x00000008U), + // .. .. reg_ddrc_mr = 0xb30 + // .. .. ==> 0XF8006030[15:0] = 0x00000B30U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000B30U + // .. .. reg_ddrc_emr = 0x4 + // .. .. ==> 0XF8006030[31:16] = 0x00000004U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU ,0x00040B30U), + // .. .. reg_ddrc_burst_rdwr = 0x4 + // .. .. ==> 0XF8006034[3:0] = 0x00000004U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U + // .. .. reg_ddrc_pre_cke_x1024 = 0x16d + // .. .. ==> 0XF8006034[13:4] = 0x0000016DU + // .. .. ==> MASK : 0x00003FF0U VAL : 0x000016D0U + // .. .. reg_ddrc_post_cke_x1024 = 0x1 + // .. .. ==> 0XF8006034[25:16] = 0x00000001U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U + // .. .. reg_ddrc_burstchop = 0x0 + // .. .. ==> 0XF8006034[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU ,0x000116D4U), + // .. .. reg_ddrc_force_low_pri_n = 0x0 + // .. .. ==> 0XF8006038[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_dis_dq = 0x0 + // .. .. ==> 0XF8006038[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006038, 0x00000003U ,0x00000000U), + // .. .. reg_ddrc_addrmap_bank_b0 = 0x6 + // .. .. ==> 0XF800603C[3:0] = 0x00000006U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000006U + // .. .. reg_ddrc_addrmap_bank_b1 = 0x6 + // .. .. ==> 0XF800603C[7:4] = 0x00000006U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000060U + // .. .. reg_ddrc_addrmap_bank_b2 = 0x6 + // .. .. ==> 0XF800603C[11:8] = 0x00000006U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000600U + // .. .. reg_ddrc_addrmap_col_b5 = 0x0 + // .. .. ==> 0XF800603C[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b6 = 0x0 + // .. .. ==> 0XF800603C[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU ,0x00000666U), + // .. .. reg_ddrc_addrmap_col_b2 = 0x0 + // .. .. ==> 0XF8006040[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b3 = 0x0 + // .. .. ==> 0XF8006040[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b4 = 0x0 + // .. .. ==> 0XF8006040[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b7 = 0x0 + // .. .. ==> 0XF8006040[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b8 = 0xf + // .. .. ==> 0XF8006040[19:16] = 0x0000000FU + // .. .. ==> MASK : 0x000F0000U VAL : 0x000F0000U + // .. .. reg_ddrc_addrmap_col_b9 = 0xf + // .. .. ==> 0XF8006040[23:20] = 0x0000000FU + // .. .. ==> MASK : 0x00F00000U VAL : 0x00F00000U + // .. .. reg_ddrc_addrmap_col_b10 = 0xf + // .. .. ==> 0XF8006040[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. reg_ddrc_addrmap_col_b11 = 0xf + // .. .. ==> 0XF8006040[31:28] = 0x0000000FU + // .. .. ==> MASK : 0xF0000000U VAL : 0xF0000000U + // .. .. + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU ,0xFFFF0000U), + // .. .. reg_ddrc_addrmap_row_b0 = 0x5 + // .. .. ==> 0XF8006044[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_addrmap_row_b1 = 0x5 + // .. .. ==> 0XF8006044[7:4] = 0x00000005U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000050U + // .. .. reg_ddrc_addrmap_row_b2_11 = 0x5 + // .. .. ==> 0XF8006044[11:8] = 0x00000005U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000500U + // .. .. reg_ddrc_addrmap_row_b12 = 0x5 + // .. .. ==> 0XF8006044[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. reg_ddrc_addrmap_row_b13 = 0x5 + // .. .. ==> 0XF8006044[19:16] = 0x00000005U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00050000U + // .. .. reg_ddrc_addrmap_row_b14 = 0x5 + // .. .. ==> 0XF8006044[23:20] = 0x00000005U + // .. .. ==> MASK : 0x00F00000U VAL : 0x00500000U + // .. .. reg_ddrc_addrmap_row_b15 = 0xf + // .. .. ==> 0XF8006044[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU ,0x0F555555U), + // .. .. reg_phy_rd_local_odt = 0x0 + // .. .. ==> 0XF8006048[13:12] = 0x00000000U + // .. .. ==> MASK : 0x00003000U VAL : 0x00000000U + // .. .. reg_phy_wr_local_odt = 0x3 + // .. .. ==> 0XF8006048[15:14] = 0x00000003U + // .. .. ==> MASK : 0x0000C000U VAL : 0x0000C000U + // .. .. reg_phy_idle_local_odt = 0x3 + // .. .. ==> 0XF8006048[17:16] = 0x00000003U + // .. .. ==> MASK : 0x00030000U VAL : 0x00030000U + // .. .. reserved_reg_ddrc_rank0_wr_odt = 0x1 + // .. .. ==> 0XF8006048[5:3] = 0x00000001U + // .. .. ==> MASK : 0x00000038U VAL : 0x00000008U + // .. .. reserved_reg_ddrc_rank0_rd_odt = 0x0 + // .. .. ==> 0XF8006048[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006048, 0x0003F03FU ,0x0003C008U), + // .. .. reg_phy_rd_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_wr_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_phy_rdc_we_to_re_delay = 0x8 + // .. .. ==> 0XF8006050[11:8] = 0x00000008U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000800U + // .. .. reg_phy_rdc_fifo_rst_disable = 0x0 + // .. .. ==> 0XF8006050[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_phy_use_fixed_re = 0x1 + // .. .. ==> 0XF8006050[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_rdc_fifo_rst_err_cnt_clr = 0x0 + // .. .. ==> 0XF8006050[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_dis_phy_ctrl_rstn = 0x0 + // .. .. ==> 0XF8006050[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_phy_clk_stall_level = 0x0 + // .. .. ==> 0XF8006050[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[27:24] = 0x00000007U + // .. .. ==> MASK : 0x0F000000U VAL : 0x07000000U + // .. .. reg_phy_wrlvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU ,0x77010800U), + // .. .. reg_ddrc_dis_dll_calib = 0x0 + // .. .. ==> 0XF8006058[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006058, 0x00010000U ,0x00000000U), + // .. .. reg_ddrc_rd_odt_delay = 0x3 + // .. .. ==> 0XF800605C[3:0] = 0x00000003U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000003U + // .. .. reg_ddrc_wr_odt_delay = 0x0 + // .. .. ==> 0XF800605C[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_rd_odt_hold = 0x0 + // .. .. ==> 0XF800605C[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_hold = 0x5 + // .. .. ==> 0XF800605C[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU ,0x00005003U), + // .. .. reg_ddrc_pageclose = 0x0 + // .. .. ==> 0XF8006060[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_lpr_num_entries = 0x1f + // .. .. ==> 0XF8006060[6:1] = 0x0000001FU + // .. .. ==> MASK : 0x0000007EU VAL : 0x0000003EU + // .. .. reg_ddrc_auto_pre_en = 0x0 + // .. .. ==> 0XF8006060[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_ddrc_refresh_update_level = 0x0 + // .. .. ==> 0XF8006060[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_ddrc_dis_wc = 0x0 + // .. .. ==> 0XF8006060[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_ddrc_dis_collision_page_opt = 0x0 + // .. .. ==> 0XF8006060[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_ddrc_selfref_en = 0x0 + // .. .. ==> 0XF8006060[12:12] = 0x00000000U + // .. .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006060, 0x000017FFU ,0x0000003EU), + // .. .. reg_ddrc_go2critical_hysteresis = 0x0 + // .. .. ==> 0XF8006064[12:5] = 0x00000000U + // .. .. ==> MASK : 0x00001FE0U VAL : 0x00000000U + // .. .. reg_arb_go2critical_en = 0x1 + // .. .. ==> 0XF8006064[17:17] = 0x00000001U + // .. .. ==> MASK : 0x00020000U VAL : 0x00020000U + // .. .. + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U ,0x00020000U), + // .. .. reg_ddrc_wrlvl_ww = 0x41 + // .. .. ==> 0XF8006068[7:0] = 0x00000041U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000041U + // .. .. reg_ddrc_rdlvl_rr = 0x41 + // .. .. ==> 0XF8006068[15:8] = 0x00000041U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00004100U + // .. .. reg_ddrc_dfi_t_wlmrd = 0x28 + // .. .. ==> 0XF8006068[25:16] = 0x00000028U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00280000U + // .. .. + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU ,0x00284141U), + // .. .. dfi_t_ctrlupd_interval_min_x1024 = 0x10 + // .. .. ==> 0XF800606C[7:0] = 0x00000010U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000010U + // .. .. dfi_t_ctrlupd_interval_max_x1024 = 0x16 + // .. .. ==> 0XF800606C[15:8] = 0x00000016U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00001600U + // .. .. + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU ,0x00001610U), + // .. .. reg_ddrc_dfi_t_ctrl_delay = 0x1 + // .. .. ==> 0XF8006078[3:0] = 0x00000001U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000001U + // .. .. reg_ddrc_dfi_t_dram_clk_disable = 0x1 + // .. .. ==> 0XF8006078[7:4] = 0x00000001U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000010U + // .. .. reg_ddrc_dfi_t_dram_clk_enable = 0x1 + // .. .. ==> 0XF8006078[11:8] = 0x00000001U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000100U + // .. .. reg_ddrc_t_cksre = 0x6 + // .. .. ==> 0XF8006078[15:12] = 0x00000006U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U + // .. .. reg_ddrc_t_cksrx = 0x6 + // .. .. ==> 0XF8006078[19:16] = 0x00000006U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U + // .. .. reg_ddrc_t_ckesr = 0x4 + // .. .. ==> 0XF8006078[25:20] = 0x00000004U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U + // .. .. + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU ,0x00466111U), + // .. .. reg_ddrc_t_ckpde = 0x2 + // .. .. ==> 0XF800607C[3:0] = 0x00000002U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000002U + // .. .. reg_ddrc_t_ckpdx = 0x2 + // .. .. ==> 0XF800607C[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. reg_ddrc_t_ckdpde = 0x2 + // .. .. ==> 0XF800607C[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_ckdpdx = 0x2 + // .. .. ==> 0XF800607C[15:12] = 0x00000002U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00002000U + // .. .. reg_ddrc_t_ckcsx = 0x3 + // .. .. ==> 0XF800607C[19:16] = 0x00000003U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00030000U + // .. .. + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU ,0x00032222U), + // .. .. reg_ddrc_dis_auto_zq = 0x0 + // .. .. ==> 0XF80060A4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_ddr3 = 0x1 + // .. .. ==> 0XF80060A4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reg_ddrc_t_mod = 0x200 + // .. .. ==> 0XF80060A4[11:2] = 0x00000200U + // .. .. ==> MASK : 0x00000FFCU VAL : 0x00000800U + // .. .. reg_ddrc_t_zq_long_nop = 0x200 + // .. .. ==> 0XF80060A4[21:12] = 0x00000200U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00200000U + // .. .. reg_ddrc_t_zq_short_nop = 0x40 + // .. .. ==> 0XF80060A4[31:22] = 0x00000040U + // .. .. ==> MASK : 0xFFC00000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU ,0x10200802U), + // .. .. t_zq_short_interval_x1024 = 0xcb73 + // .. .. ==> 0XF80060A8[19:0] = 0x0000CB73U + // .. .. ==> MASK : 0x000FFFFFU VAL : 0x0000CB73U + // .. .. dram_rstn_x1024 = 0x69 + // .. .. ==> 0XF80060A8[27:20] = 0x00000069U + // .. .. ==> MASK : 0x0FF00000U VAL : 0x06900000U + // .. .. + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU ,0x0690CB73U), + // .. .. deeppowerdown_en = 0x0 + // .. .. ==> 0XF80060AC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. deeppowerdown_to_x1024 = 0xff + // .. .. ==> 0XF80060AC[8:1] = 0x000000FFU + // .. .. ==> MASK : 0x000001FEU VAL : 0x000001FEU + // .. .. + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU ,0x000001FEU), + // .. .. dfi_wrlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[11:0] = 0x00000FFFU + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000FFFU + // .. .. dfi_rdlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[23:12] = 0x00000FFFU + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00FFF000U + // .. .. ddrc_reg_twrlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. ddrc_reg_trdlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_dfi_wr_level_en = 0x1 + // .. .. ==> 0XF80060B0[26:26] = 0x00000001U + // .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. reg_ddrc_dfi_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF80060B0[27:27] = 0x00000001U + // .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. reg_ddrc_dfi_rd_data_eye_train = 0x1 + // .. .. ==> 0XF80060B0[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU ,0x1CFFFFFFU), + // .. .. reg_ddrc_skip_ocd = 0x1 + // .. .. ==> 0XF80060B4[9:9] = 0x00000001U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. .. + EMIT_MASKWRITE(0XF80060B4, 0x00000200U ,0x00000200U), + // .. .. reg_ddrc_dfi_t_rddata_en = 0x6 + // .. .. ==> 0XF80060B8[4:0] = 0x00000006U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000006U + // .. .. reg_ddrc_dfi_t_ctrlup_min = 0x3 + // .. .. ==> 0XF80060B8[14:5] = 0x00000003U + // .. .. ==> MASK : 0x00007FE0U VAL : 0x00000060U + // .. .. reg_ddrc_dfi_t_ctrlup_max = 0x40 + // .. .. ==> 0XF80060B8[24:15] = 0x00000040U + // .. .. ==> MASK : 0x01FF8000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU ,0x00200066U), + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. Clear_Correctable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000000U), + // .. .. CORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060C8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. ECC_CORRECTED_BIT_NUM = 0x0 + // .. .. ==> 0XF80060C8[7:1] = 0x00000000U + // .. .. ==> MASK : 0x000000FEU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU ,0x00000000U), + // .. .. UNCORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060DC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060DC, 0x00000001U ,0x00000000U), + // .. .. STAT_NUM_CORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[15:8] = 0x00000000U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000000U + // .. .. STAT_NUM_UNCORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[7:0] = 0x00000000U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU ,0x00000000U), + // .. .. reg_ddrc_ecc_mode = 0x0 + // .. .. ==> 0XF80060F4[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_dis_scrub = 0x1 + // .. .. ==> 0XF80060F4[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU ,0x00000008U), + // .. .. reg_phy_dif_on = 0x0 + // .. .. ==> 0XF8006114[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_dif_off = 0x0 + // .. .. ==> 0XF8006114[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006114, 0x000000FFU ,0x00000000U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006118[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006118[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006118[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006118[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF800611C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF800611C[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF800611C[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF800611C[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x0 + // .. .. ==> 0XF8006120[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006120[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006120[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006120[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU ,0x40000000U), + // .. .. reg_phy_data_slice_in_use = 0x0 + // .. .. ==> 0XF8006124[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006124[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006124[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006124[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU ,0x40000000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x7 + // .. .. ==> 0XF800612C[9:0] = 0x00000007U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000007U + // .. .. reg_phy_gatelvl_init_ratio = 0x9f + // .. .. ==> 0XF800612C[19:10] = 0x0000009FU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00027C00U + // .. .. + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU ,0x00027C07U), + // .. .. reg_phy_wrlvl_init_ratio = 0x7 + // .. .. ==> 0XF8006130[9:0] = 0x00000007U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000007U + // .. .. reg_phy_gatelvl_init_ratio = 0x9f + // .. .. ==> 0XF8006130[19:10] = 0x0000009FU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00027C00U + // .. .. + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU ,0x00027C07U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006134[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x7b + // .. .. ==> 0XF8006134[19:10] = 0x0000007BU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x0001EC00U + // .. .. + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU ,0x0001EC00U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006138[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x7b + // .. .. ==> 0XF8006138[19:10] = 0x0000007BU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x0001EC00U + // .. .. + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU ,0x0001EC00U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006140[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006140[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006140[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006144[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006144[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006144[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006148[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006148[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006148[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF800614C[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF800614C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800614C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x87 + // .. .. ==> 0XF8006154[9:0] = 0x00000087U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000087U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006154[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006154[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU ,0x00000087U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x87 + // .. .. ==> 0XF8006158[9:0] = 0x00000087U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000087U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006158[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006158[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU ,0x00000087U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF800615C[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF800615C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800615C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006160[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006160[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006160[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf4 + // .. .. ==> 0XF8006168[10:0] = 0x000000F4U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F4U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006168[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006168[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU ,0x000000F4U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf4 + // .. .. ==> 0XF800616C[10:0] = 0x000000F4U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F4U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF800616C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF800616C[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU ,0x000000F4U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xd0 + // .. .. ==> 0XF8006170[10:0] = 0x000000D0U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000D0U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006170[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006170[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU ,0x000000D0U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xd0 + // .. .. ==> 0XF8006174[10:0] = 0x000000D0U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000D0U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006174[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006174[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU ,0x000000D0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc7 + // .. .. ==> 0XF800617C[9:0] = 0x000000C7U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C7U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF800617C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF800617C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU ,0x000000C7U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc7 + // .. .. ==> 0XF8006180[9:0] = 0x000000C7U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C7U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006180[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006180[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU ,0x000000C7U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006184[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006184[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006184[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006188[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006188[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006188[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_bl2 = 0x0 + // .. .. ==> 0XF8006190[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_at_spd_atpg = 0x0 + // .. .. ==> 0XF8006190[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_bist_enable = 0x0 + // .. .. ==> 0XF8006190[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_force_err = 0x0 + // .. .. ==> 0XF8006190[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_bist_mode = 0x0 + // .. .. ==> 0XF8006190[6:5] = 0x00000000U + // .. .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. .. reg_phy_invert_clkout = 0x1 + // .. .. ==> 0XF8006190[7:7] = 0x00000001U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. .. reg_phy_sel_logic = 0x0 + // .. .. ==> 0XF8006190[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_ratio = 0x100 + // .. .. ==> 0XF8006190[19:10] = 0x00000100U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00040000U + // .. .. reg_phy_ctrl_slave_force = 0x0 + // .. .. ==> 0XF8006190[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006190[27:21] = 0x00000000U + // .. .. ==> MASK : 0x0FE00000U VAL : 0x00000000U + // .. .. reg_phy_lpddr = 0x0 + // .. .. ==> 0XF8006190[29:29] = 0x00000000U + // .. .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. .. reg_phy_cmd_latency = 0x0 + // .. .. ==> 0XF8006190[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU ,0x00040080U), + // .. .. reg_phy_wr_rl_delay = 0x2 + // .. .. ==> 0XF8006194[4:0] = 0x00000002U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000002U + // .. .. reg_phy_rd_rl_delay = 0x4 + // .. .. ==> 0XF8006194[9:5] = 0x00000004U + // .. .. ==> MASK : 0x000003E0U VAL : 0x00000080U + // .. .. reg_phy_dll_lock_diff = 0xf + // .. .. ==> 0XF8006194[13:10] = 0x0000000FU + // .. .. ==> MASK : 0x00003C00U VAL : 0x00003C00U + // .. .. reg_phy_use_wr_level = 0x1 + // .. .. ==> 0XF8006194[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. reg_phy_use_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF8006194[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. reg_phy_use_rd_data_eye_level = 0x1 + // .. .. ==> 0XF8006194[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_dis_calib_rst = 0x0 + // .. .. ==> 0XF8006194[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006194[19:18] = 0x00000000U + // .. .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU ,0x0001FC82U), + // .. .. reg_arb_page_addr_mask = 0x0 + // .. .. ==> 0XF8006204[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006208[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006208[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006208[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006208[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006208, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF800620C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF800620C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF800620C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF800620C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800620C, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006210[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006210[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006210[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006210[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006210, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006214[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006214[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006214[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006214[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006214, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006218[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006218[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006218[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006218[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006218[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF800621C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF800621C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF800621C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF800621C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF800621C[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006220[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006220[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006220[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006220[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006220[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006224[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006224[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006224[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006224[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006224[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU ,0x000003FFU), + // .. .. reg_ddrc_lpddr2 = 0x0 + // .. .. ==> 0XF80062A8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_derate_enable = 0x0 + // .. .. ==> 0XF80062A8[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_ddrc_mr4_margin = 0x0 + // .. .. ==> 0XF80062A8[11:4] = 0x00000000U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U ,0x00000000U), + // .. .. reg_ddrc_mr4_read_interval = 0x0 + // .. .. ==> 0XF80062AC[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_ddrc_min_stable_clock_x1 = 0x5 + // .. .. ==> 0XF80062B0[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_idle_after_reset_x32 = 0x12 + // .. .. ==> 0XF80062B0[11:4] = 0x00000012U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000120U + // .. .. reg_ddrc_t_mrw = 0x5 + // .. .. ==> 0XF80062B0[21:12] = 0x00000005U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU ,0x00005125U), + // .. .. reg_ddrc_max_auto_init_x1024 = 0xa8 + // .. .. ==> 0XF80062B4[7:0] = 0x000000A8U + // .. .. ==> MASK : 0x000000FFU VAL : 0x000000A8U + // .. .. reg_ddrc_dev_zqinit_x32 = 0x12 + // .. .. ==> 0XF80062B4[17:8] = 0x00000012U + // .. .. ==> MASK : 0x0003FF00U VAL : 0x00001200U + // .. .. + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU ,0x000012A8U), + // .. .. START: POLL ON DCI STATUS + // .. .. DONE = 1 + // .. .. ==> 0XF8000B74[13:13] = 0x00000001U + // .. .. ==> MASK : 0x00002000U VAL : 0x00002000U + // .. .. + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + // .. .. FINISH: POLL ON DCI STATUS + // .. .. START: UNLOCK DDR + // .. .. reg_ddrc_soft_rstb = 0x1 + // .. .. ==> 0XF8006000[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x1 + // .. .. ==> 0XF8006000[3:2] = 0x00000001U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000004U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000085U), + // .. .. FINISH: UNLOCK DDR + // .. .. START: CHECK DDR STATUS + // .. .. ddrc_reg_operating_mode = 1 + // .. .. ==> 0XF8006054[2:0] = 0x00000001U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000001U + // .. .. + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + // .. .. FINISH: CHECK DDR STATUS + // .. FINISH: DDR INITIALIZATION + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_mio_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: OCM REMAPPING + // .. FINISH: OCM REMAPPING + // .. START: DDRIOB SETTINGS + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B40[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B40[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B40[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B40[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B40[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B40[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B40[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU ,0x00000600U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B44[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B44[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B44[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B44[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B44[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B44[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B44[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU ,0x00000600U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B48[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B48[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B48[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B48[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B48[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B48[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B48[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU ,0x00000672U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B4C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B4C[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B4C[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B4C[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B4C[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x0 + // .. ==> 0XF8000B4C[10:9] = 0x00000000U + // .. ==> MASK : 0x00000600U VAL : 0x00000000U + // .. PULLUP_EN = 0x1 + // .. ==> 0XF8000B4C[11:11] = 0x00000001U + // .. ==> MASK : 0x00000800U VAL : 0x00000800U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU ,0x00000800U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B50[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B50[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B50[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B50[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B50[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B50[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B50[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU ,0x00000674U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B54[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B54[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B54[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B54[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B54[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x0 + // .. ==> 0XF8000B54[10:9] = 0x00000000U + // .. ==> MASK : 0x00000600U VAL : 0x00000000U + // .. PULLUP_EN = 0x1 + // .. ==> 0XF8000B54[11:11] = 0x00000001U + // .. ==> MASK : 0x00000800U VAL : 0x00000800U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU ,0x00000800U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B58[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B58[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B58[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B58[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B58[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B58[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B58[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU ,0x00000600U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B5C[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B5C[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x3 + // .. ==> 0XF8000B5C[18:14] = 0x00000003U + // .. ==> MASK : 0x0007C000U VAL : 0x0000C000U + // .. reserved_SLEW_N = 0x3 + // .. ==> 0XF8000B5C[23:19] = 0x00000003U + // .. ==> MASK : 0x00F80000U VAL : 0x00180000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B5C[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B5C[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU ,0x0018C068U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B60[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B60[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x6 + // .. ==> 0XF8000B60[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. reserved_SLEW_N = 0x1f + // .. ==> 0XF8000B60[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B60[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B60[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU ,0x00F98068U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B64[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B64[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x6 + // .. ==> 0XF8000B64[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. reserved_SLEW_N = 0x1f + // .. ==> 0XF8000B64[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B64[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B64[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU ,0x00F98068U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B68[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B68[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x6 + // .. ==> 0XF8000B68[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. reserved_SLEW_N = 0x1f + // .. ==> 0XF8000B68[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B68[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B68[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU ,0x00F98068U), + // .. VREF_INT_EN = 0x0 + // .. ==> 0XF8000B6C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. VREF_SEL = 0x0 + // .. ==> 0XF8000B6C[4:1] = 0x00000000U + // .. ==> MASK : 0x0000001EU VAL : 0x00000000U + // .. VREF_EXT_EN = 0x1 + // .. ==> 0XF8000B6C[6:5] = 0x00000001U + // .. ==> MASK : 0x00000060U VAL : 0x00000020U + // .. reserved_VREF_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[8:7] = 0x00000000U + // .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. REFIO_EN = 0x1 + // .. ==> 0XF8000B6C[9:9] = 0x00000001U + // .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. reserved_REFIO_TEST = 0x0 + // .. ==> 0XF8000B6C[11:10] = 0x00000000U + // .. ==> MASK : 0x00000C00U VAL : 0x00000000U + // .. reserved_REFIO_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. reserved_DRST_B_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. reserved_CKE_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[14:14] = 0x00000000U + // .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU ,0x00000220U), + // .. .. START: ASSERT RESET + // .. .. RESET = 1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000001U ,0x00000001U), + // .. .. FINISH: ASSERT RESET + // .. .. START: DEASSERT RESET + // .. .. RESET = 0 + // .. .. ==> 0XF8000B70[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reserved_VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000020U), + // .. .. FINISH: DEASSERT RESET + // .. .. RESET = 0x1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. ENABLE = 0x1 + // .. .. ==> 0XF8000B70[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reserved_VRP_TRI = 0x0 + // .. .. ==> 0XF8000B70[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reserved_VRN_TRI = 0x0 + // .. .. ==> 0XF8000B70[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reserved_VRP_OUT = 0x0 + // .. .. ==> 0XF8000B70[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reserved_VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. NREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[7:6] = 0x00000000U + // .. .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. .. NREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[10:8] = 0x00000000U + // .. .. ==> MASK : 0x00000700U VAL : 0x00000000U + // .. .. NREF_OPT4 = 0x1 + // .. .. ==> 0XF8000B70[13:11] = 0x00000001U + // .. .. ==> MASK : 0x00003800U VAL : 0x00000800U + // .. .. PREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[15:14] = 0x00000000U + // .. .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. .. PREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[19:17] = 0x00000000U + // .. .. ==> MASK : 0x000E0000U VAL : 0x00000000U + // .. .. UPDATE_CONTROL = 0x0 + // .. .. ==> 0XF8000B70[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reserved_INIT_COMPLETE = 0x0 + // .. .. ==> 0XF8000B70[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. reserved_TST_CLK = 0x0 + // .. .. ==> 0XF8000B70[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reserved_TST_HLN = 0x0 + // .. .. ==> 0XF8000B70[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reserved_TST_HLP = 0x0 + // .. .. ==> 0XF8000B70[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. reserved_TST_RST = 0x0 + // .. .. ==> 0XF8000B70[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reserved_INT_DCI_EN = 0x0 + // .. .. ==> 0XF8000B70[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU ,0x00000823U), + // .. FINISH: DDRIOB SETTINGS + // .. START: MIO PROGRAMMING + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000700[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000700[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000700[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000700[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000700[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000700[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000700[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000700[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000700[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000704[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000704[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000704[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000704[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000704[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000704[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000704[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000704[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000704[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU ,0x00001602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000708[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000708[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000708[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000708[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000708[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000708[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000708[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000708[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000708[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800070C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF800070C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800070C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800070C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800070C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800070C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800070C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF800070C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800070C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000710[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000710[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000710[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000710[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000710[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000710[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000710[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000710[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000710[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000714[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000714[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000714[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000714[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000714[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000714[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000714[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000714[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000714[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000718[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000718[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000718[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000718[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000718[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000718[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000718[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000718[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000718[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800071C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800071C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800071C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800071C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800071C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800071C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800071C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF800071C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800071C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU ,0x00000600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000720[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000720[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000720[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000720[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000720[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000720[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000720[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000720[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000720[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000724[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000724[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000724[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000724[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000724[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000724[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000724[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000724[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000724[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000728[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000728[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000728[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000728[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000728[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000728[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000728[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000728[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000728[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800072C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800072C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800072C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800072C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF800072C[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF800072C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800072C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800072C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800072C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000730[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000730[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000730[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000730[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000730[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000730[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000730[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000730[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000730[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000734[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000734[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000734[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000734[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000734[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000734[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000734[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000734[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000734[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000738[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000738[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000738[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000738[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000738[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000738[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000738[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000738[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000738[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800073C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800073C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800073C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800073C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF800073C[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF800073C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800073C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800073C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800073C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000770[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000770[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000770[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000770[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000770[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000770[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000770[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000770[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000770[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000774[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000774[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000774[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000774[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000774[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000774[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000774[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000774[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000774[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU ,0x00001605U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000778[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000778[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000778[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000778[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000778[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000778[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000778[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000778[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000778[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800077C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF800077C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800077C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800077C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800077C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800077C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800077C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800077C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800077C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU ,0x00001605U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000780[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000780[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000780[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000780[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000780[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000780[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000780[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000780[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000780[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000784[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000784[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000784[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000784[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000784[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000784[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000784[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000784[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000784[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000788[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000788[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000788[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000788[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000788[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000788[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000788[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000788[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000788[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800078C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800078C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800078C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800078C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800078C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800078C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800078C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800078C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800078C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000790[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000790[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000790[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000790[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000790[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000790[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000790[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000790[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000790[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU ,0x00001605U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000794[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000794[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000794[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000794[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000794[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000794[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000794[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000794[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000794[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000798[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000798[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000798[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000798[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000798[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000798[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000798[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000798[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000798[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800079C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800079C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800079C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800079C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800079C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800079C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800079C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800079C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800079C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C0[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007C0[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007C0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU ,0x000016E0U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF80007C4[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF80007C4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C4[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007C4[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007C4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU ,0x000016E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007D0[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007D0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007D0[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007D0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007D4[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007D4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007D4[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007D4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU ,0x00001600U), + // .. SDIO0_WP_SEL = 55 + // .. ==> 0XF8000830[5:0] = 0x00000037U + // .. ==> MASK : 0x0000003FU VAL : 0x00000037U + // .. SDIO0_CD_SEL = 56 + // .. ==> 0XF8000830[21:16] = 0x00000038U + // .. ==> MASK : 0x003F0000U VAL : 0x00380000U + // .. + EMIT_MASKWRITE(0XF8000830, 0x003F003FU ,0x00380037U), + // .. SDIO1_WP_SEL = 57 + // .. ==> 0XF8000834[5:0] = 0x00000039U + // .. ==> MASK : 0x0000003FU VAL : 0x00000039U + // .. SDIO1_CD_SEL = 58 + // .. ==> 0XF8000834[21:16] = 0x0000003AU + // .. ==> MASK : 0x003F0000U VAL : 0x003A0000U + // .. + EMIT_MASKWRITE(0XF8000834, 0x003F003FU ,0x003A0039U), + // .. FINISH: MIO PROGRAMMING + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_peripherals_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U ,0x00000000U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000180U ,0x00000000U), + // .. FINISH: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // .. START: SRAM/NOR SET OPMODE + // .. FINISH: SRAM/NOR SET OPMODE + // .. START: UART REGISTERS + // .. BDIV = 0x6 + // .. ==> 0XE0001034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0001034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0001018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0001000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0001000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0001000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0001000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0001000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0001000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0001000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0001000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0001000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0001000, 0x000001FFU ,0x00000017U), + // .. CHMODE = 0x0 + // .. ==> 0XE0001004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0001004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0001004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0001004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0001004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0001004, 0x000003FFU ,0x00000020U), + // .. BDIV = 0x6 + // .. ==> 0XE0000034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0000034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0000018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0000000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0000000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0000000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0000000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0000000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0000000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0000000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0000000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0000000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0000000, 0x000001FFU ,0x00000017U), + // .. CHMODE = 0x0 + // .. ==> 0XE0000004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0000004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0000004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0000004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0000004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0000004, 0x000003FFU ,0x00000020U), + // .. FINISH: UART REGISTERS + // .. START: QSPI REGISTERS + // .. Holdb_dr = 1 + // .. ==> 0XE000D000[19:19] = 0x00000001U + // .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. + EMIT_MASKWRITE(0XE000D000, 0x00080000U ,0x00080000U), + // .. FINISH: QSPI REGISTERS + // .. START: PL POWER ON RESET REGISTERS + // .. PCFG_POR_CNT_4K = 0 + // .. ==> 0XF8007000[29:29] = 0x00000000U + // .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8007000, 0x20000000U ,0x00000000U), + // .. FINISH: PL POWER ON RESET REGISTERS + // .. START: SMC TIMING CALCULATION REGISTER UPDATE + // .. .. START: NAND SET CYCLE + // .. .. FINISH: NAND SET CYCLE + // .. .. START: OPMODE + // .. .. FINISH: OPMODE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: SRAM/NOR CS0 SET CYCLE + // .. .. FINISH: SRAM/NOR CS0 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS0 BASE ADDRESS + // .. .. FINISH: NOR CS0 BASE ADDRESS + // .. .. START: SRAM/NOR CS1 SET CYCLE + // .. .. FINISH: SRAM/NOR CS1 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS1 BASE ADDRESS + // .. .. FINISH: NOR CS1 BASE ADDRESS + // .. .. START: USB RESET + // .. .. .. START: USB0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. DIRECTION_0 = 0x80 + // .. .. .. .. ==> 0XE000A204[31:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU ,0x00000080U), + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xff7f + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FF7FU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFF7F0000U + // .. .. .. .. DATA_0_LSW = 0x80 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFF7F0080U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. OP_ENABLE_0 = 0x80 + // .. .. .. .. ==> 0XE000A208[31:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU ,0x00000080U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xff7f + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FF7FU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFF7F0000U + // .. .. .. .. DATA_0_LSW = 0x0 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFF7F0000U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xff7f + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FF7FU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFF7F0000U + // .. .. .. .. DATA_0_LSW = 0x80 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFF7F0080U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB0 RESET + // .. .. FINISH: USB RESET + // .. .. START: ENET RESET + // .. .. FINISH: ENET RESET + // .. .. START: I2C RESET + // .. .. FINISH: I2C RESET + // .. .. START: NOR CHIP SELECT + // .. .. .. START: DIR MODE BANK 0 + // .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. FINISH: NOR CHIP SELECT + // .. FINISH: SMC TIMING CALCULATION REGISTER UPDATE + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_post_config_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: ENABLING LEVEL SHIFTER + // .. USER_LVL_INP_EN_0 = 1 + // .. ==> 0XF8000900[3:3] = 0x00000001U + // .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. USER_LVL_OUT_EN_0 = 1 + // .. ==> 0XF8000900[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. USER_LVL_INP_EN_1 = 1 + // .. ==> 0XF8000900[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. USER_LVL_OUT_EN_1 = 1 + // .. ==> 0XF8000900[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XF8000900, 0x0000000FU ,0x0000000FU), + // .. FINISH: ENABLING LEVEL SHIFTER + // .. START: FPGA RESETS TO 0 + // .. reserved_3 = 0 + // .. ==> 0XF8000240[31:25] = 0x00000000U + // .. ==> MASK : 0xFE000000U VAL : 0x00000000U + // .. reserved_FPGA_ACP_RST = 0 + // .. ==> 0XF8000240[24:24] = 0x00000000U + // .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS3_RST = 0 + // .. ==> 0XF8000240[23:23] = 0x00000000U + // .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS2_RST = 0 + // .. ==> 0XF8000240[22:22] = 0x00000000U + // .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS1_RST = 0 + // .. ==> 0XF8000240[21:21] = 0x00000000U + // .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS0_RST = 0 + // .. ==> 0XF8000240[20:20] = 0x00000000U + // .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. reserved_2 = 0 + // .. ==> 0XF8000240[19:18] = 0x00000000U + // .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. reserved_FSSW1_FPGA_RST = 0 + // .. ==> 0XF8000240[17:17] = 0x00000000U + // .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. reserved_FSSW0_FPGA_RST = 0 + // .. ==> 0XF8000240[16:16] = 0x00000000U + // .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. reserved_1 = 0 + // .. ==> 0XF8000240[15:14] = 0x00000000U + // .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. reserved_FPGA_FMSW1_RST = 0 + // .. ==> 0XF8000240[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. reserved_FPGA_FMSW0_RST = 0 + // .. ==> 0XF8000240[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. reserved_FPGA_DMA3_RST = 0 + // .. ==> 0XF8000240[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. reserved_FPGA_DMA2_RST = 0 + // .. ==> 0XF8000240[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. reserved_FPGA_DMA1_RST = 0 + // .. ==> 0XF8000240[9:9] = 0x00000000U + // .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. reserved_FPGA_DMA0_RST = 0 + // .. ==> 0XF8000240[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. reserved = 0 + // .. ==> 0XF8000240[7:4] = 0x00000000U + // .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. FPGA3_OUT_RST = 0 + // .. ==> 0XF8000240[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. FPGA2_OUT_RST = 0 + // .. ==> 0XF8000240[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. FPGA1_OUT_RST = 0 + // .. ==> 0XF8000240[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. FPGA0_OUT_RST = 0 + // .. ==> 0XF8000240[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU ,0x00000000U), + // .. FINISH: FPGA RESETS TO 0 + // .. START: AFI REGISTERS + // .. .. START: AFI0 REGISTERS + // .. .. FINISH: AFI0 REGISTERS + // .. .. START: AFI1 REGISTERS + // .. .. FINISH: AFI1 REGISTERS + // .. .. START: AFI2 REGISTERS + // .. .. FINISH: AFI2 REGISTERS + // .. .. START: AFI3 REGISTERS + // .. .. FINISH: AFI3 REGISTERS + // .. .. START: AFI2 SECURE REGISTER + // .. .. FINISH: AFI2 SECURE REGISTER + // .. FINISH: AFI REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_debug_3_0[] = { + // START: top + // .. START: CROSS TRIGGER CONFIGURATIONS + // .. .. START: UNLOCKING CTI REGISTERS + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8898FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_WRITE(0XF8898FB0, 0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8899FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_WRITE(0XF8899FB0, 0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8809FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_WRITE(0XF8809FB0, 0xC5ACCE55U), + // .. .. FINISH: UNLOCKING CTI REGISTERS + // .. .. START: ENABLING CTI MODULES AND CHANNELS + // .. .. FINISH: ENABLING CTI MODULES AND CHANNELS + // .. .. START: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. .. FINISH: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. FINISH: CROSS TRIGGER CONFIGURATIONS + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_pll_init_data_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: PLL SLCR REGISTERS + // .. .. START: ARM PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000110[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000110[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000110[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U ,0x000FA220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x28 + // .. .. .. ==> 0XF8000100[18:12] = 0x00000028U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00028000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x0007F000U ,0x00028000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. ARM_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. SRCSEL = 0x0 + // .. .. .. ==> 0XF8000120[5:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. .. DIVISOR = 0x2 + // .. .. .. ==> 0XF8000120[13:8] = 0x00000002U + // .. .. .. ==> MASK : 0x00003F00U VAL : 0x00000200U + // .. .. .. CPU_6OR4XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[24:24] = 0x00000001U + // .. .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. .. CPU_3OR2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[25:25] = 0x00000001U + // .. .. .. ==> MASK : 0x02000000U VAL : 0x02000000U + // .. .. .. CPU_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[26:26] = 0x00000001U + // .. .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. .. CPU_1XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[27:27] = 0x00000001U + // .. .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. .. CPU_PERI_CLKACT = 0x1 + // .. .. .. ==> 0XF8000120[28:28] = 0x00000001U + // .. .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U ,0x1F000200U), + // .. .. FINISH: ARM PLL INIT + // .. .. START: DDR PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000114[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000114[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0x12c + // .. .. ==> 0XF8000114[21:12] = 0x0000012CU + // .. .. ==> MASK : 0x003FF000U VAL : 0x0012C000U + // .. .. + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U ,0x0012C220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x20 + // .. .. .. ==> 0XF8000104[18:12] = 0x00000020U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00020000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x0007F000U ,0x00020000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. DDR_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. DDR_3XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. DDR_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. DDR_3XCLK_DIVISOR = 0x2 + // .. .. .. ==> 0XF8000124[25:20] = 0x00000002U + // .. .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. .. DDR_2XCLK_DIVISOR = 0x3 + // .. .. .. ==> 0XF8000124[31:26] = 0x00000003U + // .. .. .. ==> MASK : 0xFC000000U VAL : 0x0C000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U ,0x0C200003U), + // .. .. FINISH: DDR PLL INIT + // .. .. START: IO PLL INIT + // .. .. PLL_RES = 0xc + // .. .. ==> 0XF8000118[7:4] = 0x0000000CU + // .. .. ==> MASK : 0x000000F0U VAL : 0x000000C0U + // .. .. PLL_CP = 0x3 + // .. .. ==> 0XF8000118[11:8] = 0x00000003U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000300U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000118[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U ,0x000FA3C0U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x2a + // .. .. .. ==> 0XF8000108[18:12] = 0x0000002AU + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x0002A000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x0007F000U ,0x0002A000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. IO_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[2:2] = 0x00000001U + // .. .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. FINISH: IO PLL INIT + // .. FINISH: PLL SLCR REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_clock_init_data_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: CLOCK CONTROL SLCR REGISTERS + // .. CLKACT = 0x1 + // .. ==> 0XF8000128[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. DIVISOR0 = 0xf + // .. ==> 0XF8000128[13:8] = 0x0000000FU + // .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. DIVISOR1 = 0x7 + // .. ==> 0XF8000128[25:20] = 0x00000007U + // .. ==> MASK : 0x03F00000U VAL : 0x00700000U + // .. + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U ,0x00700F01U), + // .. CLKACT = 0x1 + // .. ==> 0XF800014C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF800014C[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x7 + // .. ==> 0XF800014C[13:8] = 0x00000007U + // .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. + EMIT_MASKWRITE(0XF800014C, 0x00003F31U ,0x00000701U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000150[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000150[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000150[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x38 + // .. ==> 0XF8000150[13:8] = 0x00000038U + // .. ==> MASK : 0x00003F00U VAL : 0x00003800U + // .. + EMIT_MASKWRITE(0XF8000150, 0x00003F33U ,0x00003803U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000154[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000154[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000154[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xe + // .. ==> 0XF8000154[13:8] = 0x0000000EU + // .. ==> MASK : 0x00003F00U VAL : 0x00000E00U + // .. + EMIT_MASKWRITE(0XF8000154, 0x00003F33U ,0x00000E03U), + // .. .. START: TRACE CLOCK + // .. .. FINISH: TRACE CLOCK + // .. .. CLKACT = 0x1 + // .. .. ==> 0XF8000168[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000168[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR = 0x7 + // .. .. ==> 0XF8000168[13:8] = 0x00000007U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. .. + EMIT_MASKWRITE(0XF8000168, 0x00003F31U ,0x00000701U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000170[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x7 + // .. .. ==> 0XF8000170[13:8] = 0x00000007U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. .. DIVISOR1 = 0x4 + // .. .. ==> 0XF8000170[25:20] = 0x00000004U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U + // .. .. + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U ,0x00400700U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000180[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x7 + // .. .. ==> 0XF8000180[13:8] = 0x00000007U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. .. DIVISOR1 = 0x2 + // .. .. ==> 0XF8000180[25:20] = 0x00000002U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U ,0x00200700U), + // .. .. CLK_621_TRUE = 0x1 + // .. .. ==> 0XF80001C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF80001C4, 0x00000001U ,0x00000001U), + // .. .. DMA_CPU_2XCLKACT = 0x1 + // .. .. ==> 0XF800012C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. USB0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[2:2] = 0x00000001U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. USB1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. GEM0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. GEM1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. SDI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[10:10] = 0x00000001U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000400U + // .. .. SDI1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[11:11] = 0x00000001U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000800U + // .. .. SPI0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. SPI1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. CAN0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. CAN1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. I2C0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[18:18] = 0x00000001U + // .. .. ==> MASK : 0x00040000U VAL : 0x00040000U + // .. .. I2C1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. UART0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[20:20] = 0x00000001U + // .. .. ==> MASK : 0x00100000U VAL : 0x00100000U + // .. .. UART1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. GPIO_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[22:22] = 0x00000001U + // .. .. ==> MASK : 0x00400000U VAL : 0x00400000U + // .. .. LQSPI_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[23:23] = 0x00000001U + // .. .. ==> MASK : 0x00800000U VAL : 0x00800000U + // .. .. SMC_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[24:24] = 0x00000001U + // .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU ,0x01FC0C0DU), + // .. FINISH: CLOCK CONTROL SLCR REGISTERS + // .. START: THIS SHOULD BE BLANK + // .. FINISH: THIS SHOULD BE BLANK + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_ddr_init_data_2_0[] = { + // START: top + // .. START: DDR INITIALIZATION + // .. .. START: LOCK DDR + // .. .. reg_ddrc_soft_rstb = 0 + // .. .. ==> 0XF8006000[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x1 + // .. .. ==> 0XF8006000[3:2] = 0x00000001U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000004U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 0x1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000084U), + // .. .. FINISH: LOCK DDR + // .. .. reg_ddrc_t_rfc_nom_x32 = 0x82 + // .. .. ==> 0XF8006004[11:0] = 0x00000082U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000082U + // .. .. reg_ddrc_active_ranks = 0x1 + // .. .. ==> 0XF8006004[13:12] = 0x00000001U + // .. .. ==> MASK : 0x00003000U VAL : 0x00001000U + // .. .. reg_ddrc_addrmap_cs_bit0 = 0x0 + // .. .. ==> 0XF8006004[18:14] = 0x00000000U + // .. .. ==> MASK : 0x0007C000U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_block = 0x1 + // .. .. ==> 0XF8006004[20:19] = 0x00000001U + // .. .. ==> MASK : 0x00180000U VAL : 0x00080000U + // .. .. reg_ddrc_diff_rank_rd_2cycle_gap = 0x0 + // .. .. ==> 0XF8006004[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_cs_bit1 = 0x0 + // .. .. ==> 0XF8006004[26:22] = 0x00000000U + // .. .. ==> MASK : 0x07C00000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_open_bank = 0x0 + // .. .. ==> 0XF8006004[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_4bank_ram = 0x0 + // .. .. ==> 0XF8006004[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006004, 0x1FFFFFFFU ,0x00081082U), + // .. .. reg_ddrc_hpr_min_non_critical_x32 = 0xf + // .. .. ==> 0XF8006008[10:0] = 0x0000000FU + // .. .. ==> MASK : 0x000007FFU VAL : 0x0000000FU + // .. .. reg_ddrc_hpr_max_starve_x32 = 0xf + // .. .. ==> 0XF8006008[21:11] = 0x0000000FU + // .. .. ==> MASK : 0x003FF800U VAL : 0x00007800U + // .. .. reg_ddrc_hpr_xact_run_length = 0xf + // .. .. ==> 0XF8006008[25:22] = 0x0000000FU + // .. .. ==> MASK : 0x03C00000U VAL : 0x03C00000U + // .. .. + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU ,0x03C0780FU), + // .. .. reg_ddrc_lpr_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF800600C[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_lpr_max_starve_x32 = 0x2 + // .. .. ==> 0XF800600C[21:11] = 0x00000002U + // .. .. ==> MASK : 0x003FF800U VAL : 0x00001000U + // .. .. reg_ddrc_lpr_xact_run_length = 0x8 + // .. .. ==> 0XF800600C[25:22] = 0x00000008U + // .. .. ==> MASK : 0x03C00000U VAL : 0x02000000U + // .. .. + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU ,0x02001001U), + // .. .. reg_ddrc_w_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF8006010[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_w_xact_run_length = 0x8 + // .. .. ==> 0XF8006010[14:11] = 0x00000008U + // .. .. ==> MASK : 0x00007800U VAL : 0x00004000U + // .. .. reg_ddrc_w_max_starve_x32 = 0x2 + // .. .. ==> 0XF8006010[25:15] = 0x00000002U + // .. .. ==> MASK : 0x03FF8000U VAL : 0x00010000U + // .. .. + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU ,0x00014001U), + // .. .. reg_ddrc_t_rc = 0x1b + // .. .. ==> 0XF8006014[5:0] = 0x0000001BU + // .. .. ==> MASK : 0x0000003FU VAL : 0x0000001BU + // .. .. reg_ddrc_t_rfc_min = 0xa1 + // .. .. ==> 0XF8006014[13:6] = 0x000000A1U + // .. .. ==> MASK : 0x00003FC0U VAL : 0x00002840U + // .. .. reg_ddrc_post_selfref_gap_x32 = 0x10 + // .. .. ==> 0XF8006014[20:14] = 0x00000010U + // .. .. ==> MASK : 0x001FC000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU ,0x0004285BU), + // .. .. reg_ddrc_wr2pre = 0x13 + // .. .. ==> 0XF8006018[4:0] = 0x00000013U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000013U + // .. .. reg_ddrc_powerdown_to_x32 = 0x6 + // .. .. ==> 0XF8006018[9:5] = 0x00000006U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000C0U + // .. .. reg_ddrc_t_faw = 0x16 + // .. .. ==> 0XF8006018[15:10] = 0x00000016U + // .. .. ==> MASK : 0x0000FC00U VAL : 0x00005800U + // .. .. reg_ddrc_t_ras_max = 0x24 + // .. .. ==> 0XF8006018[21:16] = 0x00000024U + // .. .. ==> MASK : 0x003F0000U VAL : 0x00240000U + // .. .. reg_ddrc_t_ras_min = 0x13 + // .. .. ==> 0XF8006018[26:22] = 0x00000013U + // .. .. ==> MASK : 0x07C00000U VAL : 0x04C00000U + // .. .. reg_ddrc_t_cke = 0x4 + // .. .. ==> 0XF8006018[31:28] = 0x00000004U + // .. .. ==> MASK : 0xF0000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU ,0x44E458D3U), + // .. .. reg_ddrc_write_latency = 0x5 + // .. .. ==> 0XF800601C[4:0] = 0x00000005U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000005U + // .. .. reg_ddrc_rd2wr = 0x7 + // .. .. ==> 0XF800601C[9:5] = 0x00000007U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000E0U + // .. .. reg_ddrc_wr2rd = 0xf + // .. .. ==> 0XF800601C[14:10] = 0x0000000FU + // .. .. ==> MASK : 0x00007C00U VAL : 0x00003C00U + // .. .. reg_ddrc_t_xp = 0x5 + // .. .. ==> 0XF800601C[19:15] = 0x00000005U + // .. .. ==> MASK : 0x000F8000U VAL : 0x00028000U + // .. .. reg_ddrc_pad_pd = 0x0 + // .. .. ==> 0XF800601C[22:20] = 0x00000000U + // .. .. ==> MASK : 0x00700000U VAL : 0x00000000U + // .. .. reg_ddrc_rd2pre = 0x5 + // .. .. ==> 0XF800601C[27:23] = 0x00000005U + // .. .. ==> MASK : 0x0F800000U VAL : 0x02800000U + // .. .. reg_ddrc_t_rcd = 0x7 + // .. .. ==> 0XF800601C[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU ,0x7282BCE5U), + // .. .. reg_ddrc_t_ccd = 0x4 + // .. .. ==> 0XF8006020[4:2] = 0x00000004U + // .. .. ==> MASK : 0x0000001CU VAL : 0x00000010U + // .. .. reg_ddrc_t_rrd = 0x6 + // .. .. ==> 0XF8006020[7:5] = 0x00000006U + // .. .. ==> MASK : 0x000000E0U VAL : 0x000000C0U + // .. .. reg_ddrc_refresh_margin = 0x2 + // .. .. ==> 0XF8006020[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_rp = 0x7 + // .. .. ==> 0XF8006020[15:12] = 0x00000007U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00007000U + // .. .. reg_ddrc_refresh_to_x32 = 0x8 + // .. .. ==> 0XF8006020[20:16] = 0x00000008U + // .. .. ==> MASK : 0x001F0000U VAL : 0x00080000U + // .. .. reg_ddrc_sdram = 0x1 + // .. .. ==> 0XF8006020[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. reg_ddrc_mobile = 0x0 + // .. .. ==> 0XF8006020[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reg_ddrc_clock_stop_en = 0x0 + // .. .. ==> 0XF8006020[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reg_ddrc_read_latency = 0x7 + // .. .. ==> 0XF8006020[28:24] = 0x00000007U + // .. .. ==> MASK : 0x1F000000U VAL : 0x07000000U + // .. .. reg_phy_mode_ddr1_ddr2 = 0x1 + // .. .. ==> 0XF8006020[29:29] = 0x00000001U + // .. .. ==> MASK : 0x20000000U VAL : 0x20000000U + // .. .. reg_ddrc_dis_pad_pd = 0x0 + // .. .. ==> 0XF8006020[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. reg_ddrc_loopback = 0x0 + // .. .. ==> 0XF8006020[31:31] = 0x00000000U + // .. .. ==> MASK : 0x80000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006020, 0xFFFFFFFCU ,0x272872D0U), + // .. .. reg_ddrc_en_2t_timing_mode = 0x0 + // .. .. ==> 0XF8006024[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_prefer_write = 0x0 + // .. .. ==> 0XF8006024[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_max_rank_rd = 0xf + // .. .. ==> 0XF8006024[5:2] = 0x0000000FU + // .. .. ==> MASK : 0x0000003CU VAL : 0x0000003CU + // .. .. reg_ddrc_mr_wr = 0x0 + // .. .. ==> 0XF8006024[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_ddrc_mr_addr = 0x0 + // .. .. ==> 0XF8006024[8:7] = 0x00000000U + // .. .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. .. reg_ddrc_mr_data = 0x0 + // .. .. ==> 0XF8006024[24:9] = 0x00000000U + // .. .. ==> MASK : 0x01FFFE00U VAL : 0x00000000U + // .. .. ddrc_reg_mr_wr_busy = 0x0 + // .. .. ==> 0XF8006024[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_type = 0x0 + // .. .. ==> 0XF8006024[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_rdata_valid = 0x0 + // .. .. ==> 0XF8006024[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFFFU ,0x0000003CU), + // .. .. reg_ddrc_final_wait_x32 = 0x7 + // .. .. ==> 0XF8006028[6:0] = 0x00000007U + // .. .. ==> MASK : 0x0000007FU VAL : 0x00000007U + // .. .. reg_ddrc_pre_ocd_x32 = 0x0 + // .. .. ==> 0XF8006028[10:7] = 0x00000000U + // .. .. ==> MASK : 0x00000780U VAL : 0x00000000U + // .. .. reg_ddrc_t_mrd = 0x4 + // .. .. ==> 0XF8006028[13:11] = 0x00000004U + // .. .. ==> MASK : 0x00003800U VAL : 0x00002000U + // .. .. + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU ,0x00002007U), + // .. .. reg_ddrc_emr2 = 0x8 + // .. .. ==> 0XF800602C[15:0] = 0x00000008U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000008U + // .. .. reg_ddrc_emr3 = 0x0 + // .. .. ==> 0XF800602C[31:16] = 0x00000000U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU ,0x00000008U), + // .. .. reg_ddrc_mr = 0xb30 + // .. .. ==> 0XF8006030[15:0] = 0x00000B30U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000B30U + // .. .. reg_ddrc_emr = 0x4 + // .. .. ==> 0XF8006030[31:16] = 0x00000004U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU ,0x00040B30U), + // .. .. reg_ddrc_burst_rdwr = 0x4 + // .. .. ==> 0XF8006034[3:0] = 0x00000004U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U + // .. .. reg_ddrc_pre_cke_x1024 = 0x16d + // .. .. ==> 0XF8006034[13:4] = 0x0000016DU + // .. .. ==> MASK : 0x00003FF0U VAL : 0x000016D0U + // .. .. reg_ddrc_post_cke_x1024 = 0x1 + // .. .. ==> 0XF8006034[25:16] = 0x00000001U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U + // .. .. reg_ddrc_burstchop = 0x0 + // .. .. ==> 0XF8006034[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU ,0x000116D4U), + // .. .. reg_ddrc_force_low_pri_n = 0x0 + // .. .. ==> 0XF8006038[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_dis_dq = 0x0 + // .. .. ==> 0XF8006038[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_debug_mode = 0x0 + // .. .. ==> 0XF8006038[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_phy_wr_level_start = 0x0 + // .. .. ==> 0XF8006038[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_phy_rd_level_start = 0x0 + // .. .. ==> 0XF8006038[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_phy_dq0_wait_t = 0x0 + // .. .. ==> 0XF8006038[12:9] = 0x00000000U + // .. .. ==> MASK : 0x00001E00U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006038, 0x00001FC3U ,0x00000000U), + // .. .. reg_ddrc_addrmap_bank_b0 = 0x6 + // .. .. ==> 0XF800603C[3:0] = 0x00000006U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000006U + // .. .. reg_ddrc_addrmap_bank_b1 = 0x6 + // .. .. ==> 0XF800603C[7:4] = 0x00000006U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000060U + // .. .. reg_ddrc_addrmap_bank_b2 = 0x6 + // .. .. ==> 0XF800603C[11:8] = 0x00000006U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000600U + // .. .. reg_ddrc_addrmap_col_b5 = 0x0 + // .. .. ==> 0XF800603C[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b6 = 0x0 + // .. .. ==> 0XF800603C[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU ,0x00000666U), + // .. .. reg_ddrc_addrmap_col_b2 = 0x0 + // .. .. ==> 0XF8006040[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b3 = 0x0 + // .. .. ==> 0XF8006040[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b4 = 0x0 + // .. .. ==> 0XF8006040[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b7 = 0x0 + // .. .. ==> 0XF8006040[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b8 = 0xf + // .. .. ==> 0XF8006040[19:16] = 0x0000000FU + // .. .. ==> MASK : 0x000F0000U VAL : 0x000F0000U + // .. .. reg_ddrc_addrmap_col_b9 = 0xf + // .. .. ==> 0XF8006040[23:20] = 0x0000000FU + // .. .. ==> MASK : 0x00F00000U VAL : 0x00F00000U + // .. .. reg_ddrc_addrmap_col_b10 = 0xf + // .. .. ==> 0XF8006040[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. reg_ddrc_addrmap_col_b11 = 0xf + // .. .. ==> 0XF8006040[31:28] = 0x0000000FU + // .. .. ==> MASK : 0xF0000000U VAL : 0xF0000000U + // .. .. + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU ,0xFFFF0000U), + // .. .. reg_ddrc_addrmap_row_b0 = 0x5 + // .. .. ==> 0XF8006044[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_addrmap_row_b1 = 0x5 + // .. .. ==> 0XF8006044[7:4] = 0x00000005U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000050U + // .. .. reg_ddrc_addrmap_row_b2_11 = 0x5 + // .. .. ==> 0XF8006044[11:8] = 0x00000005U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000500U + // .. .. reg_ddrc_addrmap_row_b12 = 0x5 + // .. .. ==> 0XF8006044[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. reg_ddrc_addrmap_row_b13 = 0x5 + // .. .. ==> 0XF8006044[19:16] = 0x00000005U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00050000U + // .. .. reg_ddrc_addrmap_row_b14 = 0x5 + // .. .. ==> 0XF8006044[23:20] = 0x00000005U + // .. .. ==> MASK : 0x00F00000U VAL : 0x00500000U + // .. .. reg_ddrc_addrmap_row_b15 = 0xf + // .. .. ==> 0XF8006044[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU ,0x0F555555U), + // .. .. reg_ddrc_rank0_rd_odt = 0x0 + // .. .. ==> 0XF8006048[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_rank0_wr_odt = 0x1 + // .. .. ==> 0XF8006048[5:3] = 0x00000001U + // .. .. ==> MASK : 0x00000038U VAL : 0x00000008U + // .. .. reg_ddrc_rank1_rd_odt = 0x1 + // .. .. ==> 0XF8006048[8:6] = 0x00000001U + // .. .. ==> MASK : 0x000001C0U VAL : 0x00000040U + // .. .. reg_ddrc_rank1_wr_odt = 0x1 + // .. .. ==> 0XF8006048[11:9] = 0x00000001U + // .. .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. .. reg_phy_rd_local_odt = 0x0 + // .. .. ==> 0XF8006048[13:12] = 0x00000000U + // .. .. ==> MASK : 0x00003000U VAL : 0x00000000U + // .. .. reg_phy_wr_local_odt = 0x3 + // .. .. ==> 0XF8006048[15:14] = 0x00000003U + // .. .. ==> MASK : 0x0000C000U VAL : 0x0000C000U + // .. .. reg_phy_idle_local_odt = 0x3 + // .. .. ==> 0XF8006048[17:16] = 0x00000003U + // .. .. ==> MASK : 0x00030000U VAL : 0x00030000U + // .. .. reg_ddrc_rank2_rd_odt = 0x0 + // .. .. ==> 0XF8006048[20:18] = 0x00000000U + // .. .. ==> MASK : 0x001C0000U VAL : 0x00000000U + // .. .. reg_ddrc_rank2_wr_odt = 0x0 + // .. .. ==> 0XF8006048[23:21] = 0x00000000U + // .. .. ==> MASK : 0x00E00000U VAL : 0x00000000U + // .. .. reg_ddrc_rank3_rd_odt = 0x0 + // .. .. ==> 0XF8006048[26:24] = 0x00000000U + // .. .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. .. reg_ddrc_rank3_wr_odt = 0x0 + // .. .. ==> 0XF8006048[29:27] = 0x00000000U + // .. .. ==> MASK : 0x38000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006048, 0x3FFFFFFFU ,0x0003C248U), + // .. .. reg_phy_rd_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_wr_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_phy_rdc_we_to_re_delay = 0x8 + // .. .. ==> 0XF8006050[11:8] = 0x00000008U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000800U + // .. .. reg_phy_rdc_fifo_rst_disable = 0x0 + // .. .. ==> 0XF8006050[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_phy_use_fixed_re = 0x1 + // .. .. ==> 0XF8006050[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_rdc_fifo_rst_err_cnt_clr = 0x0 + // .. .. ==> 0XF8006050[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_dis_phy_ctrl_rstn = 0x0 + // .. .. ==> 0XF8006050[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_phy_clk_stall_level = 0x0 + // .. .. ==> 0XF8006050[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[27:24] = 0x00000007U + // .. .. ==> MASK : 0x0F000000U VAL : 0x07000000U + // .. .. reg_phy_wrlvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU ,0x77010800U), + // .. .. reg_ddrc_dll_calib_to_min_x1024 = 0x1 + // .. .. ==> 0XF8006058[7:0] = 0x00000001U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000001U + // .. .. reg_ddrc_dll_calib_to_max_x1024 = 0x1 + // .. .. ==> 0XF8006058[15:8] = 0x00000001U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000100U + // .. .. reg_ddrc_dis_dll_calib = 0x0 + // .. .. ==> 0XF8006058[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006058, 0x0001FFFFU ,0x00000101U), + // .. .. reg_ddrc_rd_odt_delay = 0x3 + // .. .. ==> 0XF800605C[3:0] = 0x00000003U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000003U + // .. .. reg_ddrc_wr_odt_delay = 0x0 + // .. .. ==> 0XF800605C[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_rd_odt_hold = 0x0 + // .. .. ==> 0XF800605C[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_hold = 0x5 + // .. .. ==> 0XF800605C[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU ,0x00005003U), + // .. .. reg_ddrc_pageclose = 0x0 + // .. .. ==> 0XF8006060[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_lpr_num_entries = 0x1f + // .. .. ==> 0XF8006060[6:1] = 0x0000001FU + // .. .. ==> MASK : 0x0000007EU VAL : 0x0000003EU + // .. .. reg_ddrc_auto_pre_en = 0x0 + // .. .. ==> 0XF8006060[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_ddrc_refresh_update_level = 0x0 + // .. .. ==> 0XF8006060[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_ddrc_dis_wc = 0x0 + // .. .. ==> 0XF8006060[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_ddrc_dis_collision_page_opt = 0x0 + // .. .. ==> 0XF8006060[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_ddrc_selfref_en = 0x0 + // .. .. ==> 0XF8006060[12:12] = 0x00000000U + // .. .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006060, 0x000017FFU ,0x0000003EU), + // .. .. reg_ddrc_go2critical_hysteresis = 0x0 + // .. .. ==> 0XF8006064[12:5] = 0x00000000U + // .. .. ==> MASK : 0x00001FE0U VAL : 0x00000000U + // .. .. reg_arb_go2critical_en = 0x1 + // .. .. ==> 0XF8006064[17:17] = 0x00000001U + // .. .. ==> MASK : 0x00020000U VAL : 0x00020000U + // .. .. + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U ,0x00020000U), + // .. .. reg_ddrc_wrlvl_ww = 0x41 + // .. .. ==> 0XF8006068[7:0] = 0x00000041U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000041U + // .. .. reg_ddrc_rdlvl_rr = 0x41 + // .. .. ==> 0XF8006068[15:8] = 0x00000041U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00004100U + // .. .. reg_ddrc_dfi_t_wlmrd = 0x28 + // .. .. ==> 0XF8006068[25:16] = 0x00000028U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00280000U + // .. .. + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU ,0x00284141U), + // .. .. dfi_t_ctrlupd_interval_min_x1024 = 0x10 + // .. .. ==> 0XF800606C[7:0] = 0x00000010U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000010U + // .. .. dfi_t_ctrlupd_interval_max_x1024 = 0x16 + // .. .. ==> 0XF800606C[15:8] = 0x00000016U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00001600U + // .. .. + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU ,0x00001610U), + // .. .. reg_ddrc_dfi_t_ctrl_delay = 0x1 + // .. .. ==> 0XF8006078[3:0] = 0x00000001U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000001U + // .. .. reg_ddrc_dfi_t_dram_clk_disable = 0x1 + // .. .. ==> 0XF8006078[7:4] = 0x00000001U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000010U + // .. .. reg_ddrc_dfi_t_dram_clk_enable = 0x1 + // .. .. ==> 0XF8006078[11:8] = 0x00000001U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000100U + // .. .. reg_ddrc_t_cksre = 0x6 + // .. .. ==> 0XF8006078[15:12] = 0x00000006U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U + // .. .. reg_ddrc_t_cksrx = 0x6 + // .. .. ==> 0XF8006078[19:16] = 0x00000006U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U + // .. .. reg_ddrc_t_ckesr = 0x4 + // .. .. ==> 0XF8006078[25:20] = 0x00000004U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U + // .. .. + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU ,0x00466111U), + // .. .. reg_ddrc_t_ckpde = 0x2 + // .. .. ==> 0XF800607C[3:0] = 0x00000002U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000002U + // .. .. reg_ddrc_t_ckpdx = 0x2 + // .. .. ==> 0XF800607C[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. reg_ddrc_t_ckdpde = 0x2 + // .. .. ==> 0XF800607C[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_ckdpdx = 0x2 + // .. .. ==> 0XF800607C[15:12] = 0x00000002U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00002000U + // .. .. reg_ddrc_t_ckcsx = 0x3 + // .. .. ==> 0XF800607C[19:16] = 0x00000003U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00030000U + // .. .. + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU ,0x00032222U), + // .. .. refresh_timer0_start_value_x32 = 0x0 + // .. .. ==> 0XF80060A0[11:0] = 0x00000000U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000000U + // .. .. refresh_timer1_start_value_x32 = 0x8 + // .. .. ==> 0XF80060A0[23:12] = 0x00000008U + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00008000U + // .. .. + EMIT_MASKWRITE(0XF80060A0, 0x00FFFFFFU ,0x00008000U), + // .. .. reg_ddrc_dis_auto_zq = 0x0 + // .. .. ==> 0XF80060A4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_ddr3 = 0x1 + // .. .. ==> 0XF80060A4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reg_ddrc_t_mod = 0x200 + // .. .. ==> 0XF80060A4[11:2] = 0x00000200U + // .. .. ==> MASK : 0x00000FFCU VAL : 0x00000800U + // .. .. reg_ddrc_t_zq_long_nop = 0x200 + // .. .. ==> 0XF80060A4[21:12] = 0x00000200U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00200000U + // .. .. reg_ddrc_t_zq_short_nop = 0x40 + // .. .. ==> 0XF80060A4[31:22] = 0x00000040U + // .. .. ==> MASK : 0xFFC00000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU ,0x10200802U), + // .. .. t_zq_short_interval_x1024 = 0xcb73 + // .. .. ==> 0XF80060A8[19:0] = 0x0000CB73U + // .. .. ==> MASK : 0x000FFFFFU VAL : 0x0000CB73U + // .. .. dram_rstn_x1024 = 0x69 + // .. .. ==> 0XF80060A8[27:20] = 0x00000069U + // .. .. ==> MASK : 0x0FF00000U VAL : 0x06900000U + // .. .. + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU ,0x0690CB73U), + // .. .. deeppowerdown_en = 0x0 + // .. .. ==> 0XF80060AC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. deeppowerdown_to_x1024 = 0xff + // .. .. ==> 0XF80060AC[8:1] = 0x000000FFU + // .. .. ==> MASK : 0x000001FEU VAL : 0x000001FEU + // .. .. + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU ,0x000001FEU), + // .. .. dfi_wrlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[11:0] = 0x00000FFFU + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000FFFU + // .. .. dfi_rdlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[23:12] = 0x00000FFFU + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00FFF000U + // .. .. ddrc_reg_twrlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. ddrc_reg_trdlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_dfi_wr_level_en = 0x1 + // .. .. ==> 0XF80060B0[26:26] = 0x00000001U + // .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. reg_ddrc_dfi_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF80060B0[27:27] = 0x00000001U + // .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. reg_ddrc_dfi_rd_data_eye_train = 0x1 + // .. .. ==> 0XF80060B0[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU ,0x1CFFFFFFU), + // .. .. reg_ddrc_2t_delay = 0x0 + // .. .. ==> 0XF80060B4[8:0] = 0x00000000U + // .. .. ==> MASK : 0x000001FFU VAL : 0x00000000U + // .. .. reg_ddrc_skip_ocd = 0x1 + // .. .. ==> 0XF80060B4[9:9] = 0x00000001U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. .. reg_ddrc_dis_pre_bypass = 0x0 + // .. .. ==> 0XF80060B4[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060B4, 0x000007FFU ,0x00000200U), + // .. .. reg_ddrc_dfi_t_rddata_en = 0x6 + // .. .. ==> 0XF80060B8[4:0] = 0x00000006U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000006U + // .. .. reg_ddrc_dfi_t_ctrlup_min = 0x3 + // .. .. ==> 0XF80060B8[14:5] = 0x00000003U + // .. .. ==> MASK : 0x00007FE0U VAL : 0x00000060U + // .. .. reg_ddrc_dfi_t_ctrlup_max = 0x40 + // .. .. ==> 0XF80060B8[24:15] = 0x00000040U + // .. .. ==> MASK : 0x01FF8000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU ,0x00200066U), + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. Clear_Correctable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000000U), + // .. .. CORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060C8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. ECC_CORRECTED_BIT_NUM = 0x0 + // .. .. ==> 0XF80060C8[7:1] = 0x00000000U + // .. .. ==> MASK : 0x000000FEU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU ,0x00000000U), + // .. .. UNCORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060DC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060DC, 0x00000001U ,0x00000000U), + // .. .. STAT_NUM_CORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[15:8] = 0x00000000U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000000U + // .. .. STAT_NUM_UNCORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[7:0] = 0x00000000U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU ,0x00000000U), + // .. .. reg_ddrc_ecc_mode = 0x0 + // .. .. ==> 0XF80060F4[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_dis_scrub = 0x1 + // .. .. ==> 0XF80060F4[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU ,0x00000008U), + // .. .. reg_phy_dif_on = 0x0 + // .. .. ==> 0XF8006114[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_dif_off = 0x0 + // .. .. ==> 0XF8006114[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006114, 0x000000FFU ,0x00000000U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006118[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006118[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006118[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006118[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006118[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006118[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF800611C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF800611C[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF800611C[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF800611C[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF800611C[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF800611C[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x0 + // .. .. ==> 0XF8006120[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006120[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006120[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006120[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006120[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006120[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. reg_phy_data_slice_in_use = 0x0 + // .. .. ==> 0XF8006120[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006120[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006120[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006120[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006120[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006120[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFFFU ,0x40000000U), + // .. .. reg_phy_data_slice_in_use = 0x0 + // .. .. ==> 0XF8006124[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006124[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006124[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006124[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006124[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006124[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFFFU ,0x40000000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x7 + // .. .. ==> 0XF800612C[9:0] = 0x00000007U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000007U + // .. .. reg_phy_gatelvl_init_ratio = 0x9f + // .. .. ==> 0XF800612C[19:10] = 0x0000009FU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00027C00U + // .. .. + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU ,0x00027C07U), + // .. .. reg_phy_wrlvl_init_ratio = 0x7 + // .. .. ==> 0XF8006130[9:0] = 0x00000007U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000007U + // .. .. reg_phy_gatelvl_init_ratio = 0x9f + // .. .. ==> 0XF8006130[19:10] = 0x0000009FU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00027C00U + // .. .. + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU ,0x00027C07U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006134[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x7b + // .. .. ==> 0XF8006134[19:10] = 0x0000007BU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x0001EC00U + // .. .. + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU ,0x0001EC00U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006138[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x7b + // .. .. ==> 0XF8006138[19:10] = 0x0000007BU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x0001EC00U + // .. .. + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU ,0x0001EC00U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006140[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006140[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006140[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006144[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006144[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006144[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006148[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006148[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006148[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF800614C[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF800614C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800614C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x87 + // .. .. ==> 0XF8006154[9:0] = 0x00000087U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000087U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006154[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006154[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU ,0x00000087U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x87 + // .. .. ==> 0XF8006158[9:0] = 0x00000087U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000087U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006158[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006158[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU ,0x00000087U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF800615C[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF800615C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800615C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006160[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006160[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006160[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf4 + // .. .. ==> 0XF8006168[10:0] = 0x000000F4U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F4U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006168[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006168[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU ,0x000000F4U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf4 + // .. .. ==> 0XF800616C[10:0] = 0x000000F4U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F4U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF800616C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF800616C[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU ,0x000000F4U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xd0 + // .. .. ==> 0XF8006170[10:0] = 0x000000D0U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000D0U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006170[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006170[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU ,0x000000D0U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xd0 + // .. .. ==> 0XF8006174[10:0] = 0x000000D0U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000D0U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006174[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006174[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU ,0x000000D0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc7 + // .. .. ==> 0XF800617C[9:0] = 0x000000C7U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C7U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF800617C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF800617C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU ,0x000000C7U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc7 + // .. .. ==> 0XF8006180[9:0] = 0x000000C7U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C7U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006180[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006180[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU ,0x000000C7U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006184[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006184[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006184[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006188[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006188[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006188[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_loopback = 0x0 + // .. .. ==> 0XF8006190[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_bl2 = 0x0 + // .. .. ==> 0XF8006190[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_at_spd_atpg = 0x0 + // .. .. ==> 0XF8006190[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_bist_enable = 0x0 + // .. .. ==> 0XF8006190[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_force_err = 0x0 + // .. .. ==> 0XF8006190[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_bist_mode = 0x0 + // .. .. ==> 0XF8006190[6:5] = 0x00000000U + // .. .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. .. reg_phy_invert_clkout = 0x1 + // .. .. ==> 0XF8006190[7:7] = 0x00000001U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. .. reg_phy_all_dq_mpr_rd_resp = 0x0 + // .. .. ==> 0XF8006190[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_phy_sel_logic = 0x0 + // .. .. ==> 0XF8006190[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_ratio = 0x100 + // .. .. ==> 0XF8006190[19:10] = 0x00000100U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00040000U + // .. .. reg_phy_ctrl_slave_force = 0x0 + // .. .. ==> 0XF8006190[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006190[27:21] = 0x00000000U + // .. .. ==> MASK : 0x0FE00000U VAL : 0x00000000U + // .. .. reg_phy_use_rank0_delays = 0x1 + // .. .. ==> 0XF8006190[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. reg_phy_lpddr = 0x0 + // .. .. ==> 0XF8006190[29:29] = 0x00000000U + // .. .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. .. reg_phy_cmd_latency = 0x0 + // .. .. ==> 0XF8006190[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. reg_phy_int_lpbk = 0x0 + // .. .. ==> 0XF8006190[31:31] = 0x00000000U + // .. .. ==> MASK : 0x80000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006190, 0xFFFFFFFFU ,0x10040080U), + // .. .. reg_phy_wr_rl_delay = 0x2 + // .. .. ==> 0XF8006194[4:0] = 0x00000002U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000002U + // .. .. reg_phy_rd_rl_delay = 0x4 + // .. .. ==> 0XF8006194[9:5] = 0x00000004U + // .. .. ==> MASK : 0x000003E0U VAL : 0x00000080U + // .. .. reg_phy_dll_lock_diff = 0xf + // .. .. ==> 0XF8006194[13:10] = 0x0000000FU + // .. .. ==> MASK : 0x00003C00U VAL : 0x00003C00U + // .. .. reg_phy_use_wr_level = 0x1 + // .. .. ==> 0XF8006194[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. reg_phy_use_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF8006194[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. reg_phy_use_rd_data_eye_level = 0x1 + // .. .. ==> 0XF8006194[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_dis_calib_rst = 0x0 + // .. .. ==> 0XF8006194[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006194[19:18] = 0x00000000U + // .. .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU ,0x0001FC82U), + // .. .. reg_arb_page_addr_mask = 0x0 + // .. .. ==> 0XF8006204[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006208[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006208[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006208[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006208[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006208[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006208, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF800620C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF800620C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF800620C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF800620C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF800620C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF800620C, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006210[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006210[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006210[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006210[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006210[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006210, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006214[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006214[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006214[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006214[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006214[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006214, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006218[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006218[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006218[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006218[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006218[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF800621C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF800621C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF800621C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF800621C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF800621C[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006220[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006220[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006220[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006220[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006220[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006224[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006224[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006224[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006224[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006224[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU ,0x000003FFU), + // .. .. reg_ddrc_lpddr2 = 0x0 + // .. .. ==> 0XF80062A8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_per_bank_refresh = 0x0 + // .. .. ==> 0XF80062A8[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_derate_enable = 0x0 + // .. .. ==> 0XF80062A8[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_ddrc_mr4_margin = 0x0 + // .. .. ==> 0XF80062A8[11:4] = 0x00000000U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062A8, 0x00000FF7U ,0x00000000U), + // .. .. reg_ddrc_mr4_read_interval = 0x0 + // .. .. ==> 0XF80062AC[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_ddrc_min_stable_clock_x1 = 0x5 + // .. .. ==> 0XF80062B0[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_idle_after_reset_x32 = 0x12 + // .. .. ==> 0XF80062B0[11:4] = 0x00000012U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000120U + // .. .. reg_ddrc_t_mrw = 0x5 + // .. .. ==> 0XF80062B0[21:12] = 0x00000005U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU ,0x00005125U), + // .. .. reg_ddrc_max_auto_init_x1024 = 0xa8 + // .. .. ==> 0XF80062B4[7:0] = 0x000000A8U + // .. .. ==> MASK : 0x000000FFU VAL : 0x000000A8U + // .. .. reg_ddrc_dev_zqinit_x32 = 0x12 + // .. .. ==> 0XF80062B4[17:8] = 0x00000012U + // .. .. ==> MASK : 0x0003FF00U VAL : 0x00001200U + // .. .. + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU ,0x000012A8U), + // .. .. START: POLL ON DCI STATUS + // .. .. DONE = 1 + // .. .. ==> 0XF8000B74[13:13] = 0x00000001U + // .. .. ==> MASK : 0x00002000U VAL : 0x00002000U + // .. .. + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + // .. .. FINISH: POLL ON DCI STATUS + // .. .. START: UNLOCK DDR + // .. .. reg_ddrc_soft_rstb = 0x1 + // .. .. ==> 0XF8006000[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x1 + // .. .. ==> 0XF8006000[3:2] = 0x00000001U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000004U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000085U), + // .. .. FINISH: UNLOCK DDR + // .. .. START: CHECK DDR STATUS + // .. .. ddrc_reg_operating_mode = 1 + // .. .. ==> 0XF8006054[2:0] = 0x00000001U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000001U + // .. .. + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + // .. .. FINISH: CHECK DDR STATUS + // .. FINISH: DDR INITIALIZATION + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_mio_init_data_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: OCM REMAPPING + // .. FINISH: OCM REMAPPING + // .. START: DDRIOB SETTINGS + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B40[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B40[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B40[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B40[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B40[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B40[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B40[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU ,0x00000600U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B44[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B44[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B44[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B44[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B44[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B44[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B44[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU ,0x00000600U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B48[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B48[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B48[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B48[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B48[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B48[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B48[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU ,0x00000672U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B4C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B4C[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B4C[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B4C[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B4C[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x0 + // .. ==> 0XF8000B4C[10:9] = 0x00000000U + // .. ==> MASK : 0x00000600U VAL : 0x00000000U + // .. PULLUP_EN = 0x1 + // .. ==> 0XF8000B4C[11:11] = 0x00000001U + // .. ==> MASK : 0x00000800U VAL : 0x00000800U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU ,0x00000800U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B50[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B50[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B50[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B50[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B50[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B50[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B50[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU ,0x00000674U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B54[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B54[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B54[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B54[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B54[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x0 + // .. ==> 0XF8000B54[10:9] = 0x00000000U + // .. ==> MASK : 0x00000600U VAL : 0x00000000U + // .. PULLUP_EN = 0x1 + // .. ==> 0XF8000B54[11:11] = 0x00000001U + // .. ==> MASK : 0x00000800U VAL : 0x00000800U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU ,0x00000800U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B58[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B58[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B58[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B58[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B58[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B58[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B58[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU ,0x00000600U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B5C[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B5C[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x3 + // .. ==> 0XF8000B5C[18:14] = 0x00000003U + // .. ==> MASK : 0x0007C000U VAL : 0x0000C000U + // .. SLEW_N = 0x3 + // .. ==> 0XF8000B5C[23:19] = 0x00000003U + // .. ==> MASK : 0x00F80000U VAL : 0x00180000U + // .. GTL = 0x0 + // .. ==> 0XF8000B5C[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B5C[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU ,0x0018C068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B60[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B60[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B60[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B60[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B60[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B60[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU ,0x00F98068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B64[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B64[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B64[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B64[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B64[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B64[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU ,0x00F98068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B68[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B68[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B68[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B68[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B68[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B68[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU ,0x00F98068U), + // .. VREF_INT_EN = 0x0 + // .. ==> 0XF8000B6C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. VREF_SEL = 0x0 + // .. ==> 0XF8000B6C[4:1] = 0x00000000U + // .. ==> MASK : 0x0000001EU VAL : 0x00000000U + // .. VREF_EXT_EN = 0x1 + // .. ==> 0XF8000B6C[6:5] = 0x00000001U + // .. ==> MASK : 0x00000060U VAL : 0x00000020U + // .. VREF_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[8:7] = 0x00000000U + // .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. REFIO_EN = 0x1 + // .. ==> 0XF8000B6C[9:9] = 0x00000001U + // .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. REFIO_TEST = 0x0 + // .. ==> 0XF8000B6C[11:10] = 0x00000000U + // .. ==> MASK : 0x00000C00U VAL : 0x00000000U + // .. REFIO_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DRST_B_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. CKE_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[14:14] = 0x00000000U + // .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU ,0x00000220U), + // .. .. START: ASSERT RESET + // .. .. RESET = 1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000021U), + // .. .. FINISH: ASSERT RESET + // .. .. START: DEASSERT RESET + // .. .. RESET = 0 + // .. .. ==> 0XF8000B70[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000020U), + // .. .. FINISH: DEASSERT RESET + // .. .. RESET = 0x1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. ENABLE = 0x1 + // .. .. ==> 0XF8000B70[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. VRP_TRI = 0x0 + // .. .. ==> 0XF8000B70[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. VRN_TRI = 0x0 + // .. .. ==> 0XF8000B70[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. VRP_OUT = 0x0 + // .. .. ==> 0XF8000B70[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. NREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[7:6] = 0x00000000U + // .. .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. .. NREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[10:8] = 0x00000000U + // .. .. ==> MASK : 0x00000700U VAL : 0x00000000U + // .. .. NREF_OPT4 = 0x1 + // .. .. ==> 0XF8000B70[13:11] = 0x00000001U + // .. .. ==> MASK : 0x00003800U VAL : 0x00000800U + // .. .. PREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[16:14] = 0x00000000U + // .. .. ==> MASK : 0x0001C000U VAL : 0x00000000U + // .. .. PREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[19:17] = 0x00000000U + // .. .. ==> MASK : 0x000E0000U VAL : 0x00000000U + // .. .. UPDATE_CONTROL = 0x0 + // .. .. ==> 0XF8000B70[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. INIT_COMPLETE = 0x0 + // .. .. ==> 0XF8000B70[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. TST_CLK = 0x0 + // .. .. ==> 0XF8000B70[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. TST_HLN = 0x0 + // .. .. ==> 0XF8000B70[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. TST_HLP = 0x0 + // .. .. ==> 0XF8000B70[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. TST_RST = 0x0 + // .. .. ==> 0XF8000B70[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. INT_DCI_EN = 0x0 + // .. .. ==> 0XF8000B70[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x07FFFFFFU ,0x00000823U), + // .. FINISH: DDRIOB SETTINGS + // .. START: MIO PROGRAMMING + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000700[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000700[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000700[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000700[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000700[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000700[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000700[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000700[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000700[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000704[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000704[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000704[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000704[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000704[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000704[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000704[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000704[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000704[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU ,0x00001602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000708[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000708[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000708[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000708[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000708[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000708[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000708[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000708[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000708[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800070C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF800070C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800070C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800070C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800070C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800070C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800070C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF800070C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800070C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000710[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000710[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000710[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000710[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000710[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000710[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000710[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000710[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000710[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000714[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000714[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000714[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000714[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000714[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000714[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000714[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000714[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000714[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000718[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000718[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000718[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000718[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000718[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000718[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000718[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000718[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000718[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800071C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800071C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800071C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800071C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800071C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800071C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800071C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF800071C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800071C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU ,0x00000600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000720[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000720[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000720[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000720[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000720[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000720[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000720[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000720[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000720[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000724[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000724[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000724[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000724[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000724[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000724[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000724[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000724[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000724[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000728[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000728[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000728[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000728[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000728[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000728[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000728[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000728[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000728[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800072C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800072C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800072C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800072C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF800072C[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF800072C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800072C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800072C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800072C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000730[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000730[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000730[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000730[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000730[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000730[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000730[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000730[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000730[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000734[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000734[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000734[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000734[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000734[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000734[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000734[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000734[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000734[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000738[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000738[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000738[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000738[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000738[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000738[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000738[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000738[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000738[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800073C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800073C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800073C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800073C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF800073C[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF800073C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800073C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800073C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800073C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000770[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000770[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000770[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000770[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000770[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000770[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000770[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000770[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000770[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000774[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000774[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000774[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000774[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000774[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000774[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000774[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000774[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000774[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU ,0x00001605U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000778[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000778[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000778[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000778[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000778[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000778[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000778[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000778[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000778[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800077C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF800077C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800077C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800077C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800077C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800077C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800077C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800077C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800077C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU ,0x00001605U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000780[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000780[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000780[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000780[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000780[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000780[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000780[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000780[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000780[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000784[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000784[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000784[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000784[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000784[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000784[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000784[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000784[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000784[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000788[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000788[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000788[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000788[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000788[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000788[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000788[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000788[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000788[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800078C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800078C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800078C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800078C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800078C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800078C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800078C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800078C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800078C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000790[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000790[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000790[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000790[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000790[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000790[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000790[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000790[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000790[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU ,0x00001605U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000794[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000794[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000794[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000794[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000794[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000794[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000794[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000794[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000794[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000798[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000798[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000798[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000798[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000798[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000798[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000798[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000798[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000798[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800079C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800079C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800079C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800079C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800079C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800079C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800079C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800079C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800079C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C0[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007C0[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007C0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU ,0x000016E0U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF80007C4[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF80007C4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C4[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007C4[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007C4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU ,0x000016E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007D0[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007D0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007D0[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007D0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007D4[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007D4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007D4[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007D4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU ,0x00001600U), + // .. SDIO0_WP_SEL = 55 + // .. ==> 0XF8000830[5:0] = 0x00000037U + // .. ==> MASK : 0x0000003FU VAL : 0x00000037U + // .. SDIO0_CD_SEL = 56 + // .. ==> 0XF8000830[21:16] = 0x00000038U + // .. ==> MASK : 0x003F0000U VAL : 0x00380000U + // .. + EMIT_MASKWRITE(0XF8000830, 0x003F003FU ,0x00380037U), + // .. SDIO1_WP_SEL = 57 + // .. ==> 0XF8000834[5:0] = 0x00000039U + // .. ==> MASK : 0x0000003FU VAL : 0x00000039U + // .. SDIO1_CD_SEL = 58 + // .. ==> 0XF8000834[21:16] = 0x0000003AU + // .. ==> MASK : 0x003F0000U VAL : 0x003A0000U + // .. + EMIT_MASKWRITE(0XF8000834, 0x003F003FU ,0x003A0039U), + // .. FINISH: MIO PROGRAMMING + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_peripherals_init_data_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U ,0x00000000U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000180U ,0x00000000U), + // .. FINISH: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // .. START: SRAM/NOR SET OPMODE + // .. FINISH: SRAM/NOR SET OPMODE + // .. START: UART REGISTERS + // .. BDIV = 0x6 + // .. ==> 0XE0001034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0001034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0001018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0001000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0001000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0001000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0001000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0001000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0001000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0001000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0001000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0001000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0001000, 0x000001FFU ,0x00000017U), + // .. IRMODE = 0x0 + // .. ==> 0XE0001004[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. UCLKEN = 0x0 + // .. ==> 0XE0001004[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. CHMODE = 0x0 + // .. ==> 0XE0001004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0001004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0001004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0001004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0001004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0001004, 0x00000FFFU ,0x00000020U), + // .. BDIV = 0x6 + // .. ==> 0XE0000034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0000034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0000018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0000000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0000000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0000000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0000000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0000000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0000000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0000000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0000000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0000000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0000000, 0x000001FFU ,0x00000017U), + // .. IRMODE = 0x0 + // .. ==> 0XE0000004[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. UCLKEN = 0x0 + // .. ==> 0XE0000004[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. CHMODE = 0x0 + // .. ==> 0XE0000004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0000004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0000004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0000004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0000004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0000004, 0x00000FFFU ,0x00000020U), + // .. FINISH: UART REGISTERS + // .. START: QSPI REGISTERS + // .. Holdb_dr = 1 + // .. ==> 0XE000D000[19:19] = 0x00000001U + // .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. + EMIT_MASKWRITE(0XE000D000, 0x00080000U ,0x00080000U), + // .. FINISH: QSPI REGISTERS + // .. START: PL POWER ON RESET REGISTERS + // .. PCFG_POR_CNT_4K = 0 + // .. ==> 0XF8007000[29:29] = 0x00000000U + // .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8007000, 0x20000000U ,0x00000000U), + // .. FINISH: PL POWER ON RESET REGISTERS + // .. START: SMC TIMING CALCULATION REGISTER UPDATE + // .. .. START: NAND SET CYCLE + // .. .. FINISH: NAND SET CYCLE + // .. .. START: OPMODE + // .. .. FINISH: OPMODE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: SRAM/NOR CS0 SET CYCLE + // .. .. FINISH: SRAM/NOR CS0 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS0 BASE ADDRESS + // .. .. FINISH: NOR CS0 BASE ADDRESS + // .. .. START: SRAM/NOR CS1 SET CYCLE + // .. .. FINISH: SRAM/NOR CS1 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS1 BASE ADDRESS + // .. .. FINISH: NOR CS1 BASE ADDRESS + // .. .. START: USB RESET + // .. .. .. START: USB0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. DIRECTION_0 = 0x80 + // .. .. .. .. ==> 0XE000A204[31:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU ,0x00000080U), + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xff7f + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FF7FU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFF7F0000U + // .. .. .. .. DATA_0_LSW = 0x80 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFF7F0080U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. OP_ENABLE_0 = 0x80 + // .. .. .. .. ==> 0XE000A208[31:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU ,0x00000080U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xff7f + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FF7FU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFF7F0000U + // .. .. .. .. DATA_0_LSW = 0x0 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFF7F0000U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xff7f + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FF7FU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFF7F0000U + // .. .. .. .. DATA_0_LSW = 0x80 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFF7F0080U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB0 RESET + // .. .. FINISH: USB RESET + // .. .. START: ENET RESET + // .. .. FINISH: ENET RESET + // .. .. START: I2C RESET + // .. .. FINISH: I2C RESET + // .. .. START: NOR CHIP SELECT + // .. .. .. START: DIR MODE BANK 0 + // .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. FINISH: NOR CHIP SELECT + // .. FINISH: SMC TIMING CALCULATION REGISTER UPDATE + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_post_config_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: ENABLING LEVEL SHIFTER + // .. USER_INP_ICT_EN_0 = 3 + // .. ==> 0XF8000900[1:0] = 0x00000003U + // .. ==> MASK : 0x00000003U VAL : 0x00000003U + // .. USER_INP_ICT_EN_1 = 3 + // .. ==> 0XF8000900[3:2] = 0x00000003U + // .. ==> MASK : 0x0000000CU VAL : 0x0000000CU + // .. + EMIT_MASKWRITE(0XF8000900, 0x0000000FU ,0x0000000FU), + // .. FINISH: ENABLING LEVEL SHIFTER + // .. START: FPGA RESETS TO 0 + // .. reserved_3 = 0 + // .. ==> 0XF8000240[31:25] = 0x00000000U + // .. ==> MASK : 0xFE000000U VAL : 0x00000000U + // .. FPGA_ACP_RST = 0 + // .. ==> 0XF8000240[24:24] = 0x00000000U + // .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. FPGA_AXDS3_RST = 0 + // .. ==> 0XF8000240[23:23] = 0x00000000U + // .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. FPGA_AXDS2_RST = 0 + // .. ==> 0XF8000240[22:22] = 0x00000000U + // .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. FPGA_AXDS1_RST = 0 + // .. ==> 0XF8000240[21:21] = 0x00000000U + // .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. FPGA_AXDS0_RST = 0 + // .. ==> 0XF8000240[20:20] = 0x00000000U + // .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. reserved_2 = 0 + // .. ==> 0XF8000240[19:18] = 0x00000000U + // .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. FSSW1_FPGA_RST = 0 + // .. ==> 0XF8000240[17:17] = 0x00000000U + // .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. FSSW0_FPGA_RST = 0 + // .. ==> 0XF8000240[16:16] = 0x00000000U + // .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. reserved_1 = 0 + // .. ==> 0XF8000240[15:14] = 0x00000000U + // .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. FPGA_FMSW1_RST = 0 + // .. ==> 0XF8000240[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. FPGA_FMSW0_RST = 0 + // .. ==> 0XF8000240[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. FPGA_DMA3_RST = 0 + // .. ==> 0XF8000240[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. FPGA_DMA2_RST = 0 + // .. ==> 0XF8000240[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. FPGA_DMA1_RST = 0 + // .. ==> 0XF8000240[9:9] = 0x00000000U + // .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. FPGA_DMA0_RST = 0 + // .. ==> 0XF8000240[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. reserved = 0 + // .. ==> 0XF8000240[7:4] = 0x00000000U + // .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. FPGA3_OUT_RST = 0 + // .. ==> 0XF8000240[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. FPGA2_OUT_RST = 0 + // .. ==> 0XF8000240[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. FPGA1_OUT_RST = 0 + // .. ==> 0XF8000240[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. FPGA0_OUT_RST = 0 + // .. ==> 0XF8000240[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU ,0x00000000U), + // .. FINISH: FPGA RESETS TO 0 + // .. START: AFI REGISTERS + // .. .. START: AFI0 REGISTERS + // .. .. FINISH: AFI0 REGISTERS + // .. .. START: AFI1 REGISTERS + // .. .. FINISH: AFI1 REGISTERS + // .. .. START: AFI2 REGISTERS + // .. .. FINISH: AFI2 REGISTERS + // .. .. START: AFI3 REGISTERS + // .. .. FINISH: AFI3 REGISTERS + // .. FINISH: AFI REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_debug_2_0[] = { + // START: top + // .. START: CROSS TRIGGER CONFIGURATIONS + // .. .. START: UNLOCKING CTI REGISTERS + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8898FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_WRITE(0XF8898FB0, 0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8899FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_WRITE(0XF8899FB0, 0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8809FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_WRITE(0XF8809FB0, 0xC5ACCE55U), + // .. .. FINISH: UNLOCKING CTI REGISTERS + // .. .. START: ENABLING CTI MODULES AND CHANNELS + // .. .. FINISH: ENABLING CTI MODULES AND CHANNELS + // .. .. START: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. .. FINISH: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. FINISH: CROSS TRIGGER CONFIGURATIONS + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_pll_init_data_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: PLL SLCR REGISTERS + // .. .. START: ARM PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000110[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000110[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000110[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U ,0x000FA220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x28 + // .. .. .. ==> 0XF8000100[18:12] = 0x00000028U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00028000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x0007F000U ,0x00028000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. ARM_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. SRCSEL = 0x0 + // .. .. .. ==> 0XF8000120[5:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. .. DIVISOR = 0x2 + // .. .. .. ==> 0XF8000120[13:8] = 0x00000002U + // .. .. .. ==> MASK : 0x00003F00U VAL : 0x00000200U + // .. .. .. CPU_6OR4XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[24:24] = 0x00000001U + // .. .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. .. CPU_3OR2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[25:25] = 0x00000001U + // .. .. .. ==> MASK : 0x02000000U VAL : 0x02000000U + // .. .. .. CPU_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[26:26] = 0x00000001U + // .. .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. .. CPU_1XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[27:27] = 0x00000001U + // .. .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. .. CPU_PERI_CLKACT = 0x1 + // .. .. .. ==> 0XF8000120[28:28] = 0x00000001U + // .. .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U ,0x1F000200U), + // .. .. FINISH: ARM PLL INIT + // .. .. START: DDR PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000114[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000114[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0x12c + // .. .. ==> 0XF8000114[21:12] = 0x0000012CU + // .. .. ==> MASK : 0x003FF000U VAL : 0x0012C000U + // .. .. + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U ,0x0012C220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x20 + // .. .. .. ==> 0XF8000104[18:12] = 0x00000020U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00020000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x0007F000U ,0x00020000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. DDR_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. DDR_3XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. DDR_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. DDR_3XCLK_DIVISOR = 0x2 + // .. .. .. ==> 0XF8000124[25:20] = 0x00000002U + // .. .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. .. DDR_2XCLK_DIVISOR = 0x3 + // .. .. .. ==> 0XF8000124[31:26] = 0x00000003U + // .. .. .. ==> MASK : 0xFC000000U VAL : 0x0C000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U ,0x0C200003U), + // .. .. FINISH: DDR PLL INIT + // .. .. START: IO PLL INIT + // .. .. PLL_RES = 0xc + // .. .. ==> 0XF8000118[7:4] = 0x0000000CU + // .. .. ==> MASK : 0x000000F0U VAL : 0x000000C0U + // .. .. PLL_CP = 0x3 + // .. .. ==> 0XF8000118[11:8] = 0x00000003U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000300U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000118[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U ,0x000FA3C0U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x2a + // .. .. .. ==> 0XF8000108[18:12] = 0x0000002AU + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x0002A000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x0007F000U ,0x0002A000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. IO_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[2:2] = 0x00000001U + // .. .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. FINISH: IO PLL INIT + // .. FINISH: PLL SLCR REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_clock_init_data_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: CLOCK CONTROL SLCR REGISTERS + // .. CLKACT = 0x1 + // .. ==> 0XF8000128[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. DIVISOR0 = 0xf + // .. ==> 0XF8000128[13:8] = 0x0000000FU + // .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. DIVISOR1 = 0x7 + // .. ==> 0XF8000128[25:20] = 0x00000007U + // .. ==> MASK : 0x03F00000U VAL : 0x00700000U + // .. + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U ,0x00700F01U), + // .. CLKACT = 0x1 + // .. ==> 0XF800014C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF800014C[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x7 + // .. ==> 0XF800014C[13:8] = 0x00000007U + // .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. + EMIT_MASKWRITE(0XF800014C, 0x00003F31U ,0x00000701U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000150[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000150[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000150[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x38 + // .. ==> 0XF8000150[13:8] = 0x00000038U + // .. ==> MASK : 0x00003F00U VAL : 0x00003800U + // .. + EMIT_MASKWRITE(0XF8000150, 0x00003F33U ,0x00003803U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000154[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000154[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000154[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xe + // .. ==> 0XF8000154[13:8] = 0x0000000EU + // .. ==> MASK : 0x00003F00U VAL : 0x00000E00U + // .. + EMIT_MASKWRITE(0XF8000154, 0x00003F33U ,0x00000E03U), + // .. .. START: TRACE CLOCK + // .. .. FINISH: TRACE CLOCK + // .. .. CLKACT = 0x1 + // .. .. ==> 0XF8000168[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000168[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR = 0x7 + // .. .. ==> 0XF8000168[13:8] = 0x00000007U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. .. + EMIT_MASKWRITE(0XF8000168, 0x00003F31U ,0x00000701U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000170[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x7 + // .. .. ==> 0XF8000170[13:8] = 0x00000007U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. .. DIVISOR1 = 0x4 + // .. .. ==> 0XF8000170[25:20] = 0x00000004U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U + // .. .. + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U ,0x00400700U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000180[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x7 + // .. .. ==> 0XF8000180[13:8] = 0x00000007U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U + // .. .. DIVISOR1 = 0x2 + // .. .. ==> 0XF8000180[25:20] = 0x00000002U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U ,0x00200700U), + // .. .. CLK_621_TRUE = 0x1 + // .. .. ==> 0XF80001C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF80001C4, 0x00000001U ,0x00000001U), + // .. .. DMA_CPU_2XCLKACT = 0x1 + // .. .. ==> 0XF800012C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. USB0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[2:2] = 0x00000001U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. USB1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. GEM0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. GEM1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. SDI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[10:10] = 0x00000001U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000400U + // .. .. SDI1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[11:11] = 0x00000001U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000800U + // .. .. SPI0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. SPI1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. CAN0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. CAN1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. I2C0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[18:18] = 0x00000001U + // .. .. ==> MASK : 0x00040000U VAL : 0x00040000U + // .. .. I2C1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. UART0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[20:20] = 0x00000001U + // .. .. ==> MASK : 0x00100000U VAL : 0x00100000U + // .. .. UART1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. GPIO_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[22:22] = 0x00000001U + // .. .. ==> MASK : 0x00400000U VAL : 0x00400000U + // .. .. LQSPI_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[23:23] = 0x00000001U + // .. .. ==> MASK : 0x00800000U VAL : 0x00800000U + // .. .. SMC_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[24:24] = 0x00000001U + // .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU ,0x01FC0C0DU), + // .. FINISH: CLOCK CONTROL SLCR REGISTERS + // .. START: THIS SHOULD BE BLANK + // .. FINISH: THIS SHOULD BE BLANK + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_ddr_init_data_1_0[] = { + // START: top + // .. START: DDR INITIALIZATION + // .. .. START: LOCK DDR + // .. .. reg_ddrc_soft_rstb = 0 + // .. .. ==> 0XF8006000[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x1 + // .. .. ==> 0XF8006000[3:2] = 0x00000001U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000004U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 0x1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000084U), + // .. .. FINISH: LOCK DDR + // .. .. reg_ddrc_t_rfc_nom_x32 = 0x82 + // .. .. ==> 0XF8006004[11:0] = 0x00000082U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000082U + // .. .. reg_ddrc_active_ranks = 0x1 + // .. .. ==> 0XF8006004[13:12] = 0x00000001U + // .. .. ==> MASK : 0x00003000U VAL : 0x00001000U + // .. .. reg_ddrc_addrmap_cs_bit0 = 0x0 + // .. .. ==> 0XF8006004[18:14] = 0x00000000U + // .. .. ==> MASK : 0x0007C000U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_block = 0x1 + // .. .. ==> 0XF8006004[20:19] = 0x00000001U + // .. .. ==> MASK : 0x00180000U VAL : 0x00080000U + // .. .. reg_ddrc_diff_rank_rd_2cycle_gap = 0x0 + // .. .. ==> 0XF8006004[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_cs_bit1 = 0x0 + // .. .. ==> 0XF8006004[26:22] = 0x00000000U + // .. .. ==> MASK : 0x07C00000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_open_bank = 0x0 + // .. .. ==> 0XF8006004[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_4bank_ram = 0x0 + // .. .. ==> 0XF8006004[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006004, 0x1FFFFFFFU ,0x00081082U), + // .. .. reg_ddrc_hpr_min_non_critical_x32 = 0xf + // .. .. ==> 0XF8006008[10:0] = 0x0000000FU + // .. .. ==> MASK : 0x000007FFU VAL : 0x0000000FU + // .. .. reg_ddrc_hpr_max_starve_x32 = 0xf + // .. .. ==> 0XF8006008[21:11] = 0x0000000FU + // .. .. ==> MASK : 0x003FF800U VAL : 0x00007800U + // .. .. reg_ddrc_hpr_xact_run_length = 0xf + // .. .. ==> 0XF8006008[25:22] = 0x0000000FU + // .. .. ==> MASK : 0x03C00000U VAL : 0x03C00000U + // .. .. + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU ,0x03C0780FU), + // .. .. reg_ddrc_lpr_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF800600C[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_lpr_max_starve_x32 = 0x2 + // .. .. ==> 0XF800600C[21:11] = 0x00000002U + // .. .. ==> MASK : 0x003FF800U VAL : 0x00001000U + // .. .. reg_ddrc_lpr_xact_run_length = 0x8 + // .. .. ==> 0XF800600C[25:22] = 0x00000008U + // .. .. ==> MASK : 0x03C00000U VAL : 0x02000000U + // .. .. + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU ,0x02001001U), + // .. .. reg_ddrc_w_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF8006010[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_w_xact_run_length = 0x8 + // .. .. ==> 0XF8006010[14:11] = 0x00000008U + // .. .. ==> MASK : 0x00007800U VAL : 0x00004000U + // .. .. reg_ddrc_w_max_starve_x32 = 0x2 + // .. .. ==> 0XF8006010[25:15] = 0x00000002U + // .. .. ==> MASK : 0x03FF8000U VAL : 0x00010000U + // .. .. + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU ,0x00014001U), + // .. .. reg_ddrc_t_rc = 0x1b + // .. .. ==> 0XF8006014[5:0] = 0x0000001BU + // .. .. ==> MASK : 0x0000003FU VAL : 0x0000001BU + // .. .. reg_ddrc_t_rfc_min = 0xa1 + // .. .. ==> 0XF8006014[13:6] = 0x000000A1U + // .. .. ==> MASK : 0x00003FC0U VAL : 0x00002840U + // .. .. reg_ddrc_post_selfref_gap_x32 = 0x10 + // .. .. ==> 0XF8006014[20:14] = 0x00000010U + // .. .. ==> MASK : 0x001FC000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU ,0x0004285BU), + // .. .. reg_ddrc_wr2pre = 0x13 + // .. .. ==> 0XF8006018[4:0] = 0x00000013U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000013U + // .. .. reg_ddrc_powerdown_to_x32 = 0x6 + // .. .. ==> 0XF8006018[9:5] = 0x00000006U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000C0U + // .. .. reg_ddrc_t_faw = 0x16 + // .. .. ==> 0XF8006018[15:10] = 0x00000016U + // .. .. ==> MASK : 0x0000FC00U VAL : 0x00005800U + // .. .. reg_ddrc_t_ras_max = 0x24 + // .. .. ==> 0XF8006018[21:16] = 0x00000024U + // .. .. ==> MASK : 0x003F0000U VAL : 0x00240000U + // .. .. reg_ddrc_t_ras_min = 0x13 + // .. .. ==> 0XF8006018[26:22] = 0x00000013U + // .. .. ==> MASK : 0x07C00000U VAL : 0x04C00000U + // .. .. reg_ddrc_t_cke = 0x4 + // .. .. ==> 0XF8006018[31:28] = 0x00000004U + // .. .. ==> MASK : 0xF0000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU ,0x44E458D3U), + // .. .. reg_ddrc_write_latency = 0x5 + // .. .. ==> 0XF800601C[4:0] = 0x00000005U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000005U + // .. .. reg_ddrc_rd2wr = 0x7 + // .. .. ==> 0XF800601C[9:5] = 0x00000007U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000E0U + // .. .. reg_ddrc_wr2rd = 0xf + // .. .. ==> 0XF800601C[14:10] = 0x0000000FU + // .. .. ==> MASK : 0x00007C00U VAL : 0x00003C00U + // .. .. reg_ddrc_t_xp = 0x5 + // .. .. ==> 0XF800601C[19:15] = 0x00000005U + // .. .. ==> MASK : 0x000F8000U VAL : 0x00028000U + // .. .. reg_ddrc_pad_pd = 0x0 + // .. .. ==> 0XF800601C[22:20] = 0x00000000U + // .. .. ==> MASK : 0x00700000U VAL : 0x00000000U + // .. .. reg_ddrc_rd2pre = 0x5 + // .. .. ==> 0XF800601C[27:23] = 0x00000005U + // .. .. ==> MASK : 0x0F800000U VAL : 0x02800000U + // .. .. reg_ddrc_t_rcd = 0x7 + // .. .. ==> 0XF800601C[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU ,0x7282BCE5U), + // .. .. reg_ddrc_t_ccd = 0x4 + // .. .. ==> 0XF8006020[4:2] = 0x00000004U + // .. .. ==> MASK : 0x0000001CU VAL : 0x00000010U + // .. .. reg_ddrc_t_rrd = 0x6 + // .. .. ==> 0XF8006020[7:5] = 0x00000006U + // .. .. ==> MASK : 0x000000E0U VAL : 0x000000C0U + // .. .. reg_ddrc_refresh_margin = 0x2 + // .. .. ==> 0XF8006020[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_rp = 0x7 + // .. .. ==> 0XF8006020[15:12] = 0x00000007U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00007000U + // .. .. reg_ddrc_refresh_to_x32 = 0x8 + // .. .. ==> 0XF8006020[20:16] = 0x00000008U + // .. .. ==> MASK : 0x001F0000U VAL : 0x00080000U + // .. .. reg_ddrc_sdram = 0x1 + // .. .. ==> 0XF8006020[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. reg_ddrc_mobile = 0x0 + // .. .. ==> 0XF8006020[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reg_ddrc_clock_stop_en = 0x0 + // .. .. ==> 0XF8006020[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reg_ddrc_read_latency = 0x7 + // .. .. ==> 0XF8006020[28:24] = 0x00000007U + // .. .. ==> MASK : 0x1F000000U VAL : 0x07000000U + // .. .. reg_phy_mode_ddr1_ddr2 = 0x1 + // .. .. ==> 0XF8006020[29:29] = 0x00000001U + // .. .. ==> MASK : 0x20000000U VAL : 0x20000000U + // .. .. reg_ddrc_dis_pad_pd = 0x0 + // .. .. ==> 0XF8006020[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. reg_ddrc_loopback = 0x0 + // .. .. ==> 0XF8006020[31:31] = 0x00000000U + // .. .. ==> MASK : 0x80000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006020, 0xFFFFFFFCU ,0x272872D0U), + // .. .. reg_ddrc_en_2t_timing_mode = 0x0 + // .. .. ==> 0XF8006024[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_prefer_write = 0x0 + // .. .. ==> 0XF8006024[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_max_rank_rd = 0xf + // .. .. ==> 0XF8006024[5:2] = 0x0000000FU + // .. .. ==> MASK : 0x0000003CU VAL : 0x0000003CU + // .. .. reg_ddrc_mr_wr = 0x0 + // .. .. ==> 0XF8006024[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_ddrc_mr_addr = 0x0 + // .. .. ==> 0XF8006024[8:7] = 0x00000000U + // .. .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. .. reg_ddrc_mr_data = 0x0 + // .. .. ==> 0XF8006024[24:9] = 0x00000000U + // .. .. ==> MASK : 0x01FFFE00U VAL : 0x00000000U + // .. .. ddrc_reg_mr_wr_busy = 0x0 + // .. .. ==> 0XF8006024[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_type = 0x0 + // .. .. ==> 0XF8006024[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_rdata_valid = 0x0 + // .. .. ==> 0XF8006024[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFFFU ,0x0000003CU), + // .. .. reg_ddrc_final_wait_x32 = 0x7 + // .. .. ==> 0XF8006028[6:0] = 0x00000007U + // .. .. ==> MASK : 0x0000007FU VAL : 0x00000007U + // .. .. reg_ddrc_pre_ocd_x32 = 0x0 + // .. .. ==> 0XF8006028[10:7] = 0x00000000U + // .. .. ==> MASK : 0x00000780U VAL : 0x00000000U + // .. .. reg_ddrc_t_mrd = 0x4 + // .. .. ==> 0XF8006028[13:11] = 0x00000004U + // .. .. ==> MASK : 0x00003800U VAL : 0x00002000U + // .. .. + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU ,0x00002007U), + // .. .. reg_ddrc_emr2 = 0x8 + // .. .. ==> 0XF800602C[15:0] = 0x00000008U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000008U + // .. .. reg_ddrc_emr3 = 0x0 + // .. .. ==> 0XF800602C[31:16] = 0x00000000U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU ,0x00000008U), + // .. .. reg_ddrc_mr = 0xb30 + // .. .. ==> 0XF8006030[15:0] = 0x00000B30U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000B30U + // .. .. reg_ddrc_emr = 0x4 + // .. .. ==> 0XF8006030[31:16] = 0x00000004U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU ,0x00040B30U), + // .. .. reg_ddrc_burst_rdwr = 0x4 + // .. .. ==> 0XF8006034[3:0] = 0x00000004U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U + // .. .. reg_ddrc_pre_cke_x1024 = 0x16d + // .. .. ==> 0XF8006034[13:4] = 0x0000016DU + // .. .. ==> MASK : 0x00003FF0U VAL : 0x000016D0U + // .. .. reg_ddrc_post_cke_x1024 = 0x1 + // .. .. ==> 0XF8006034[25:16] = 0x00000001U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U + // .. .. reg_ddrc_burstchop = 0x0 + // .. .. ==> 0XF8006034[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU ,0x000116D4U), + // .. .. reg_ddrc_force_low_pri_n = 0x0 + // .. .. ==> 0XF8006038[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_dis_dq = 0x0 + // .. .. ==> 0XF8006038[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_debug_mode = 0x0 + // .. .. ==> 0XF8006038[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_phy_wr_level_start = 0x0 + // .. .. ==> 0XF8006038[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_phy_rd_level_start = 0x0 + // .. .. ==> 0XF8006038[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_phy_dq0_wait_t = 0x0 + // .. .. ==> 0XF8006038[12:9] = 0x00000000U + // .. .. ==> MASK : 0x00001E00U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006038, 0x00001FC3U ,0x00000000U), + // .. .. reg_ddrc_addrmap_bank_b0 = 0x6 + // .. .. ==> 0XF800603C[3:0] = 0x00000006U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000006U + // .. .. reg_ddrc_addrmap_bank_b1 = 0x6 + // .. .. ==> 0XF800603C[7:4] = 0x00000006U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000060U + // .. .. reg_ddrc_addrmap_bank_b2 = 0x6 + // .. .. ==> 0XF800603C[11:8] = 0x00000006U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000600U + // .. .. reg_ddrc_addrmap_col_b5 = 0x0 + // .. .. ==> 0XF800603C[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b6 = 0x0 + // .. .. ==> 0XF800603C[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU ,0x00000666U), + // .. .. reg_ddrc_addrmap_col_b2 = 0x0 + // .. .. ==> 0XF8006040[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b3 = 0x0 + // .. .. ==> 0XF8006040[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b4 = 0x0 + // .. .. ==> 0XF8006040[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b7 = 0x0 + // .. .. ==> 0XF8006040[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b8 = 0xf + // .. .. ==> 0XF8006040[19:16] = 0x0000000FU + // .. .. ==> MASK : 0x000F0000U VAL : 0x000F0000U + // .. .. reg_ddrc_addrmap_col_b9 = 0xf + // .. .. ==> 0XF8006040[23:20] = 0x0000000FU + // .. .. ==> MASK : 0x00F00000U VAL : 0x00F00000U + // .. .. reg_ddrc_addrmap_col_b10 = 0xf + // .. .. ==> 0XF8006040[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. reg_ddrc_addrmap_col_b11 = 0xf + // .. .. ==> 0XF8006040[31:28] = 0x0000000FU + // .. .. ==> MASK : 0xF0000000U VAL : 0xF0000000U + // .. .. + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU ,0xFFFF0000U), + // .. .. reg_ddrc_addrmap_row_b0 = 0x5 + // .. .. ==> 0XF8006044[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_addrmap_row_b1 = 0x5 + // .. .. ==> 0XF8006044[7:4] = 0x00000005U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000050U + // .. .. reg_ddrc_addrmap_row_b2_11 = 0x5 + // .. .. ==> 0XF8006044[11:8] = 0x00000005U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000500U + // .. .. reg_ddrc_addrmap_row_b12 = 0x5 + // .. .. ==> 0XF8006044[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. reg_ddrc_addrmap_row_b13 = 0x5 + // .. .. ==> 0XF8006044[19:16] = 0x00000005U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00050000U + // .. .. reg_ddrc_addrmap_row_b14 = 0x5 + // .. .. ==> 0XF8006044[23:20] = 0x00000005U + // .. .. ==> MASK : 0x00F00000U VAL : 0x00500000U + // .. .. reg_ddrc_addrmap_row_b15 = 0xf + // .. .. ==> 0XF8006044[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU ,0x0F555555U), + // .. .. reg_ddrc_rank0_rd_odt = 0x0 + // .. .. ==> 0XF8006048[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_rank0_wr_odt = 0x1 + // .. .. ==> 0XF8006048[5:3] = 0x00000001U + // .. .. ==> MASK : 0x00000038U VAL : 0x00000008U + // .. .. reg_ddrc_rank1_rd_odt = 0x1 + // .. .. ==> 0XF8006048[8:6] = 0x00000001U + // .. .. ==> MASK : 0x000001C0U VAL : 0x00000040U + // .. .. reg_ddrc_rank1_wr_odt = 0x1 + // .. .. ==> 0XF8006048[11:9] = 0x00000001U + // .. .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. .. reg_phy_rd_local_odt = 0x0 + // .. .. ==> 0XF8006048[13:12] = 0x00000000U + // .. .. ==> MASK : 0x00003000U VAL : 0x00000000U + // .. .. reg_phy_wr_local_odt = 0x3 + // .. .. ==> 0XF8006048[15:14] = 0x00000003U + // .. .. ==> MASK : 0x0000C000U VAL : 0x0000C000U + // .. .. reg_phy_idle_local_odt = 0x3 + // .. .. ==> 0XF8006048[17:16] = 0x00000003U + // .. .. ==> MASK : 0x00030000U VAL : 0x00030000U + // .. .. reg_ddrc_rank2_rd_odt = 0x0 + // .. .. ==> 0XF8006048[20:18] = 0x00000000U + // .. .. ==> MASK : 0x001C0000U VAL : 0x00000000U + // .. .. reg_ddrc_rank2_wr_odt = 0x0 + // .. .. ==> 0XF8006048[23:21] = 0x00000000U + // .. .. ==> MASK : 0x00E00000U VAL : 0x00000000U + // .. .. reg_ddrc_rank3_rd_odt = 0x0 + // .. .. ==> 0XF8006048[26:24] = 0x00000000U + // .. .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. .. reg_ddrc_rank3_wr_odt = 0x0 + // .. .. ==> 0XF8006048[29:27] = 0x00000000U + // .. .. ==> MASK : 0x38000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006048, 0x3FFFFFFFU ,0x0003C248U), + // .. .. reg_phy_rd_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_wr_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_phy_rdc_we_to_re_delay = 0x8 + // .. .. ==> 0XF8006050[11:8] = 0x00000008U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000800U + // .. .. reg_phy_rdc_fifo_rst_disable = 0x0 + // .. .. ==> 0XF8006050[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_phy_use_fixed_re = 0x1 + // .. .. ==> 0XF8006050[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_rdc_fifo_rst_err_cnt_clr = 0x0 + // .. .. ==> 0XF8006050[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_dis_phy_ctrl_rstn = 0x0 + // .. .. ==> 0XF8006050[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_phy_clk_stall_level = 0x0 + // .. .. ==> 0XF8006050[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[27:24] = 0x00000007U + // .. .. ==> MASK : 0x0F000000U VAL : 0x07000000U + // .. .. reg_phy_wrlvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU ,0x77010800U), + // .. .. reg_ddrc_dll_calib_to_min_x1024 = 0x1 + // .. .. ==> 0XF8006058[7:0] = 0x00000001U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000001U + // .. .. reg_ddrc_dll_calib_to_max_x1024 = 0x1 + // .. .. ==> 0XF8006058[15:8] = 0x00000001U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000100U + // .. .. reg_ddrc_dis_dll_calib = 0x0 + // .. .. ==> 0XF8006058[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006058, 0x0001FFFFU ,0x00000101U), + // .. .. reg_ddrc_rd_odt_delay = 0x3 + // .. .. ==> 0XF800605C[3:0] = 0x00000003U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000003U + // .. .. reg_ddrc_wr_odt_delay = 0x0 + // .. .. ==> 0XF800605C[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_rd_odt_hold = 0x0 + // .. .. ==> 0XF800605C[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_hold = 0x5 + // .. .. ==> 0XF800605C[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU ,0x00005003U), + // .. .. reg_ddrc_pageclose = 0x0 + // .. .. ==> 0XF8006060[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_lpr_num_entries = 0x1f + // .. .. ==> 0XF8006060[6:1] = 0x0000001FU + // .. .. ==> MASK : 0x0000007EU VAL : 0x0000003EU + // .. .. reg_ddrc_auto_pre_en = 0x0 + // .. .. ==> 0XF8006060[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_ddrc_refresh_update_level = 0x0 + // .. .. ==> 0XF8006060[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_ddrc_dis_wc = 0x0 + // .. .. ==> 0XF8006060[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_ddrc_dis_collision_page_opt = 0x0 + // .. .. ==> 0XF8006060[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_ddrc_selfref_en = 0x0 + // .. .. ==> 0XF8006060[12:12] = 0x00000000U + // .. .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006060, 0x000017FFU ,0x0000003EU), + // .. .. reg_ddrc_go2critical_hysteresis = 0x0 + // .. .. ==> 0XF8006064[12:5] = 0x00000000U + // .. .. ==> MASK : 0x00001FE0U VAL : 0x00000000U + // .. .. reg_arb_go2critical_en = 0x1 + // .. .. ==> 0XF8006064[17:17] = 0x00000001U + // .. .. ==> MASK : 0x00020000U VAL : 0x00020000U + // .. .. + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U ,0x00020000U), + // .. .. reg_ddrc_wrlvl_ww = 0x41 + // .. .. ==> 0XF8006068[7:0] = 0x00000041U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000041U + // .. .. reg_ddrc_rdlvl_rr = 0x41 + // .. .. ==> 0XF8006068[15:8] = 0x00000041U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00004100U + // .. .. reg_ddrc_dfi_t_wlmrd = 0x28 + // .. .. ==> 0XF8006068[25:16] = 0x00000028U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00280000U + // .. .. + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU ,0x00284141U), + // .. .. dfi_t_ctrlupd_interval_min_x1024 = 0x10 + // .. .. ==> 0XF800606C[7:0] = 0x00000010U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000010U + // .. .. dfi_t_ctrlupd_interval_max_x1024 = 0x16 + // .. .. ==> 0XF800606C[15:8] = 0x00000016U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00001600U + // .. .. + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU ,0x00001610U), + // .. .. refresh_timer0_start_value_x32 = 0x0 + // .. .. ==> 0XF80060A0[11:0] = 0x00000000U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000000U + // .. .. refresh_timer1_start_value_x32 = 0x8 + // .. .. ==> 0XF80060A0[23:12] = 0x00000008U + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00008000U + // .. .. + EMIT_MASKWRITE(0XF80060A0, 0x00FFFFFFU ,0x00008000U), + // .. .. reg_ddrc_dis_auto_zq = 0x0 + // .. .. ==> 0XF80060A4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_ddr3 = 0x1 + // .. .. ==> 0XF80060A4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reg_ddrc_t_mod = 0x200 + // .. .. ==> 0XF80060A4[11:2] = 0x00000200U + // .. .. ==> MASK : 0x00000FFCU VAL : 0x00000800U + // .. .. reg_ddrc_t_zq_long_nop = 0x200 + // .. .. ==> 0XF80060A4[21:12] = 0x00000200U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00200000U + // .. .. reg_ddrc_t_zq_short_nop = 0x40 + // .. .. ==> 0XF80060A4[31:22] = 0x00000040U + // .. .. ==> MASK : 0xFFC00000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU ,0x10200802U), + // .. .. t_zq_short_interval_x1024 = 0xcb73 + // .. .. ==> 0XF80060A8[19:0] = 0x0000CB73U + // .. .. ==> MASK : 0x000FFFFFU VAL : 0x0000CB73U + // .. .. dram_rstn_x1024 = 0x69 + // .. .. ==> 0XF80060A8[27:20] = 0x00000069U + // .. .. ==> MASK : 0x0FF00000U VAL : 0x06900000U + // .. .. + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU ,0x0690CB73U), + // .. .. deeppowerdown_en = 0x0 + // .. .. ==> 0XF80060AC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. deeppowerdown_to_x1024 = 0xff + // .. .. ==> 0XF80060AC[8:1] = 0x000000FFU + // .. .. ==> MASK : 0x000001FEU VAL : 0x000001FEU + // .. .. + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU ,0x000001FEU), + // .. .. dfi_wrlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[11:0] = 0x00000FFFU + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000FFFU + // .. .. dfi_rdlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[23:12] = 0x00000FFFU + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00FFF000U + // .. .. ddrc_reg_twrlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. ddrc_reg_trdlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_dfi_wr_level_en = 0x1 + // .. .. ==> 0XF80060B0[26:26] = 0x00000001U + // .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. reg_ddrc_dfi_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF80060B0[27:27] = 0x00000001U + // .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. reg_ddrc_dfi_rd_data_eye_train = 0x1 + // .. .. ==> 0XF80060B0[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU ,0x1CFFFFFFU), + // .. .. reg_ddrc_2t_delay = 0x0 + // .. .. ==> 0XF80060B4[8:0] = 0x00000000U + // .. .. ==> MASK : 0x000001FFU VAL : 0x00000000U + // .. .. reg_ddrc_skip_ocd = 0x1 + // .. .. ==> 0XF80060B4[9:9] = 0x00000001U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. .. reg_ddrc_dis_pre_bypass = 0x0 + // .. .. ==> 0XF80060B4[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060B4, 0x000007FFU ,0x00000200U), + // .. .. reg_ddrc_dfi_t_rddata_en = 0x6 + // .. .. ==> 0XF80060B8[4:0] = 0x00000006U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000006U + // .. .. reg_ddrc_dfi_t_ctrlup_min = 0x3 + // .. .. ==> 0XF80060B8[14:5] = 0x00000003U + // .. .. ==> MASK : 0x00007FE0U VAL : 0x00000060U + // .. .. reg_ddrc_dfi_t_ctrlup_max = 0x40 + // .. .. ==> 0XF80060B8[24:15] = 0x00000040U + // .. .. ==> MASK : 0x01FF8000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU ,0x00200066U), + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. Clear_Correctable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000000U), + // .. .. CORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060C8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. ECC_CORRECTED_BIT_NUM = 0x0 + // .. .. ==> 0XF80060C8[7:1] = 0x00000000U + // .. .. ==> MASK : 0x000000FEU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU ,0x00000000U), + // .. .. UNCORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060DC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060DC, 0x00000001U ,0x00000000U), + // .. .. STAT_NUM_CORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[15:8] = 0x00000000U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000000U + // .. .. STAT_NUM_UNCORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[7:0] = 0x00000000U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU ,0x00000000U), + // .. .. reg_ddrc_ecc_mode = 0x0 + // .. .. ==> 0XF80060F4[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_dis_scrub = 0x1 + // .. .. ==> 0XF80060F4[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU ,0x00000008U), + // .. .. reg_phy_dif_on = 0x0 + // .. .. ==> 0XF8006114[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_dif_off = 0x0 + // .. .. ==> 0XF8006114[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006114, 0x000000FFU ,0x00000000U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006118[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006118[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006118[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006118[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006118[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006118[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF800611C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF800611C[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF800611C[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF800611C[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF800611C[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF800611C[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x0 + // .. .. ==> 0XF8006120[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006120[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006120[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006120[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006120[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006120[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFFFU ,0x40000000U), + // .. .. reg_phy_data_slice_in_use = 0x0 + // .. .. ==> 0XF8006124[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006124[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006124[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006124[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006124[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006124[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFFFU ,0x40000000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x7 + // .. .. ==> 0XF800612C[9:0] = 0x00000007U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000007U + // .. .. reg_phy_gatelvl_init_ratio = 0x9f + // .. .. ==> 0XF800612C[19:10] = 0x0000009FU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00027C00U + // .. .. + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU ,0x00027C07U), + // .. .. reg_phy_wrlvl_init_ratio = 0x7 + // .. .. ==> 0XF8006130[9:0] = 0x00000007U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000007U + // .. .. reg_phy_gatelvl_init_ratio = 0x9f + // .. .. ==> 0XF8006130[19:10] = 0x0000009FU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00027C00U + // .. .. + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU ,0x00027C07U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006134[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x7b + // .. .. ==> 0XF8006134[19:10] = 0x0000007BU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x0001EC00U + // .. .. + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU ,0x0001EC00U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006138[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x7b + // .. .. ==> 0XF8006138[19:10] = 0x0000007BU + // .. .. ==> MASK : 0x000FFC00U VAL : 0x0001EC00U + // .. .. + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU ,0x0001EC00U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006140[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006140[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006140[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006144[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006144[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006144[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006148[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006148[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006148[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF800614C[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF800614C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800614C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x87 + // .. .. ==> 0XF8006154[9:0] = 0x00000087U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000087U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006154[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006154[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU ,0x00000087U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x87 + // .. .. ==> 0XF8006158[9:0] = 0x00000087U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000087U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006158[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006158[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU ,0x00000087U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF800615C[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF800615C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800615C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006160[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006160[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006160[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf4 + // .. .. ==> 0XF8006168[10:0] = 0x000000F4U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F4U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006168[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006168[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU ,0x000000F4U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xf4 + // .. .. ==> 0XF800616C[10:0] = 0x000000F4U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000F4U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF800616C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF800616C[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU ,0x000000F4U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xd0 + // .. .. ==> 0XF8006170[10:0] = 0x000000D0U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000D0U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006170[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006170[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU ,0x000000D0U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xd0 + // .. .. ==> 0XF8006174[10:0] = 0x000000D0U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000D0U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006174[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006174[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU ,0x000000D0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc7 + // .. .. ==> 0XF800617C[9:0] = 0x000000C7U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C7U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF800617C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF800617C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU ,0x000000C7U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc7 + // .. .. ==> 0XF8006180[9:0] = 0x000000C7U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C7U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006180[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006180[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU ,0x000000C7U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006184[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006184[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006184[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006188[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006188[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006188[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_loopback = 0x0 + // .. .. ==> 0XF8006190[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_bl2 = 0x0 + // .. .. ==> 0XF8006190[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_at_spd_atpg = 0x0 + // .. .. ==> 0XF8006190[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_bist_enable = 0x0 + // .. .. ==> 0XF8006190[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_force_err = 0x0 + // .. .. ==> 0XF8006190[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_bist_mode = 0x0 + // .. .. ==> 0XF8006190[6:5] = 0x00000000U + // .. .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. .. reg_phy_invert_clkout = 0x1 + // .. .. ==> 0XF8006190[7:7] = 0x00000001U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. .. reg_phy_all_dq_mpr_rd_resp = 0x0 + // .. .. ==> 0XF8006190[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_phy_sel_logic = 0x0 + // .. .. ==> 0XF8006190[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_ratio = 0x100 + // .. .. ==> 0XF8006190[19:10] = 0x00000100U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00040000U + // .. .. reg_phy_ctrl_slave_force = 0x0 + // .. .. ==> 0XF8006190[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006190[27:21] = 0x00000000U + // .. .. ==> MASK : 0x0FE00000U VAL : 0x00000000U + // .. .. reg_phy_use_rank0_delays = 0x1 + // .. .. ==> 0XF8006190[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. reg_phy_lpddr = 0x0 + // .. .. ==> 0XF8006190[29:29] = 0x00000000U + // .. .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. .. reg_phy_cmd_latency = 0x0 + // .. .. ==> 0XF8006190[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. reg_phy_int_lpbk = 0x0 + // .. .. ==> 0XF8006190[31:31] = 0x00000000U + // .. .. ==> MASK : 0x80000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006190, 0xFFFFFFFFU ,0x10040080U), + // .. .. reg_phy_wr_rl_delay = 0x2 + // .. .. ==> 0XF8006194[4:0] = 0x00000002U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000002U + // .. .. reg_phy_rd_rl_delay = 0x4 + // .. .. ==> 0XF8006194[9:5] = 0x00000004U + // .. .. ==> MASK : 0x000003E0U VAL : 0x00000080U + // .. .. reg_phy_dll_lock_diff = 0xf + // .. .. ==> 0XF8006194[13:10] = 0x0000000FU + // .. .. ==> MASK : 0x00003C00U VAL : 0x00003C00U + // .. .. reg_phy_use_wr_level = 0x1 + // .. .. ==> 0XF8006194[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. reg_phy_use_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF8006194[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. reg_phy_use_rd_data_eye_level = 0x1 + // .. .. ==> 0XF8006194[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_dis_calib_rst = 0x0 + // .. .. ==> 0XF8006194[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006194[19:18] = 0x00000000U + // .. .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU ,0x0001FC82U), + // .. .. reg_arb_page_addr_mask = 0x0 + // .. .. ==> 0XF8006204[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006208[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006208[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006208[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006208[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006208[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006208, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF800620C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF800620C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF800620C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF800620C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF800620C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF800620C, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006210[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006210[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006210[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006210[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006210[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006210, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006214[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006214[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006214[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006214[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006214[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006214, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006218[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006218[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006218[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006218[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006218[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF800621C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF800621C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF800621C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF800621C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF800621C[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006220[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006220[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006220[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006220[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006220[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006224[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006224[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006224[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006224[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006224[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU ,0x000003FFU), + // .. .. reg_ddrc_lpddr2 = 0x0 + // .. .. ==> 0XF80062A8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_per_bank_refresh = 0x0 + // .. .. ==> 0XF80062A8[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_derate_enable = 0x0 + // .. .. ==> 0XF80062A8[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_ddrc_mr4_margin = 0x0 + // .. .. ==> 0XF80062A8[11:4] = 0x00000000U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062A8, 0x00000FF7U ,0x00000000U), + // .. .. reg_ddrc_mr4_read_interval = 0x0 + // .. .. ==> 0XF80062AC[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_ddrc_min_stable_clock_x1 = 0x5 + // .. .. ==> 0XF80062B0[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_idle_after_reset_x32 = 0x12 + // .. .. ==> 0XF80062B0[11:4] = 0x00000012U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000120U + // .. .. reg_ddrc_t_mrw = 0x5 + // .. .. ==> 0XF80062B0[21:12] = 0x00000005U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU ,0x00005125U), + // .. .. reg_ddrc_max_auto_init_x1024 = 0xa8 + // .. .. ==> 0XF80062B4[7:0] = 0x000000A8U + // .. .. ==> MASK : 0x000000FFU VAL : 0x000000A8U + // .. .. reg_ddrc_dev_zqinit_x32 = 0x12 + // .. .. ==> 0XF80062B4[17:8] = 0x00000012U + // .. .. ==> MASK : 0x0003FF00U VAL : 0x00001200U + // .. .. + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU ,0x000012A8U), + // .. .. START: POLL ON DCI STATUS + // .. .. DONE = 1 + // .. .. ==> 0XF8000B74[13:13] = 0x00000001U + // .. .. ==> MASK : 0x00002000U VAL : 0x00002000U + // .. .. + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + // .. .. FINISH: POLL ON DCI STATUS + // .. .. START: UNLOCK DDR + // .. .. reg_ddrc_soft_rstb = 0x1 + // .. .. ==> 0XF8006000[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x1 + // .. .. ==> 0XF8006000[3:2] = 0x00000001U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000004U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000085U), + // .. .. FINISH: UNLOCK DDR + // .. .. START: CHECK DDR STATUS + // .. .. ddrc_reg_operating_mode = 1 + // .. .. ==> 0XF8006054[2:0] = 0x00000001U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000001U + // .. .. + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + // .. .. FINISH: CHECK DDR STATUS + // .. FINISH: DDR INITIALIZATION + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_mio_init_data_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: OCM REMAPPING + // .. FINISH: OCM REMAPPING + // .. START: DDRIOB SETTINGS + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B40[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B40[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B40[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B40[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B40[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B40[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B40[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU ,0x00000600U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B44[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B44[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B44[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B44[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B44[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B44[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B44[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU ,0x00000600U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B48[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B48[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B48[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B48[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B48[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B48[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B48[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU ,0x00000672U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B4C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B4C[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B4C[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B4C[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B4C[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x0 + // .. ==> 0XF8000B4C[10:9] = 0x00000000U + // .. ==> MASK : 0x00000600U VAL : 0x00000000U + // .. PULLUP_EN = 0x1 + // .. ==> 0XF8000B4C[11:11] = 0x00000001U + // .. ==> MASK : 0x00000800U VAL : 0x00000800U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU ,0x00000800U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B50[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B50[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B50[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B50[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B50[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B50[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B50[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU ,0x00000674U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B54[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B54[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B54[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B54[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B54[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x0 + // .. ==> 0XF8000B54[10:9] = 0x00000000U + // .. ==> MASK : 0x00000600U VAL : 0x00000000U + // .. PULLUP_EN = 0x1 + // .. ==> 0XF8000B54[11:11] = 0x00000001U + // .. ==> MASK : 0x00000800U VAL : 0x00000800U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU ,0x00000800U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B58[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B58[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B58[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B58[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B58[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B58[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B58[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU ,0x00000600U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B5C[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B5C[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x3 + // .. ==> 0XF8000B5C[18:14] = 0x00000003U + // .. ==> MASK : 0x0007C000U VAL : 0x0000C000U + // .. SLEW_N = 0x3 + // .. ==> 0XF8000B5C[23:19] = 0x00000003U + // .. ==> MASK : 0x00F80000U VAL : 0x00180000U + // .. GTL = 0x0 + // .. ==> 0XF8000B5C[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B5C[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU ,0x0018C068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B60[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B60[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B60[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B60[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B60[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B60[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU ,0x00F98068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B64[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B64[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B64[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B64[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B64[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B64[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU ,0x00F98068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B68[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B68[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B68[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B68[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B68[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B68[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU ,0x00F98068U), + // .. VREF_INT_EN = 0x0 + // .. ==> 0XF8000B6C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. VREF_SEL = 0x0 + // .. ==> 0XF8000B6C[4:1] = 0x00000000U + // .. ==> MASK : 0x0000001EU VAL : 0x00000000U + // .. VREF_EXT_EN = 0x1 + // .. ==> 0XF8000B6C[6:5] = 0x00000001U + // .. ==> MASK : 0x00000060U VAL : 0x00000020U + // .. VREF_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[8:7] = 0x00000000U + // .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. REFIO_EN = 0x1 + // .. ==> 0XF8000B6C[9:9] = 0x00000001U + // .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. REFIO_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DRST_B_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. CKE_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[14:14] = 0x00000000U + // .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B6C, 0x000073FFU ,0x00000220U), + // .. .. START: ASSERT RESET + // .. .. RESET = 1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000021U), + // .. .. FINISH: ASSERT RESET + // .. .. START: DEASSERT RESET + // .. .. RESET = 0 + // .. .. ==> 0XF8000B70[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000020U), + // .. .. FINISH: DEASSERT RESET + // .. .. RESET = 0x1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. ENABLE = 0x1 + // .. .. ==> 0XF8000B70[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. VRP_TRI = 0x0 + // .. .. ==> 0XF8000B70[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. VRN_TRI = 0x0 + // .. .. ==> 0XF8000B70[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. VRP_OUT = 0x0 + // .. .. ==> 0XF8000B70[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. NREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[7:6] = 0x00000000U + // .. .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. .. NREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[10:8] = 0x00000000U + // .. .. ==> MASK : 0x00000700U VAL : 0x00000000U + // .. .. NREF_OPT4 = 0x1 + // .. .. ==> 0XF8000B70[13:11] = 0x00000001U + // .. .. ==> MASK : 0x00003800U VAL : 0x00000800U + // .. .. PREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[16:14] = 0x00000000U + // .. .. ==> MASK : 0x0001C000U VAL : 0x00000000U + // .. .. PREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[19:17] = 0x00000000U + // .. .. ==> MASK : 0x000E0000U VAL : 0x00000000U + // .. .. UPDATE_CONTROL = 0x0 + // .. .. ==> 0XF8000B70[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. INIT_COMPLETE = 0x0 + // .. .. ==> 0XF8000B70[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. TST_CLK = 0x0 + // .. .. ==> 0XF8000B70[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. TST_HLN = 0x0 + // .. .. ==> 0XF8000B70[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. TST_HLP = 0x0 + // .. .. ==> 0XF8000B70[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. TST_RST = 0x0 + // .. .. ==> 0XF8000B70[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. INT_DCI_EN = 0x0 + // .. .. ==> 0XF8000B70[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x07FFFFFFU ,0x00000823U), + // .. FINISH: DDRIOB SETTINGS + // .. START: MIO PROGRAMMING + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000700[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000700[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000700[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000700[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000700[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000700[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000700[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000700[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000700[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000704[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000704[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000704[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000704[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000704[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000704[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000704[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000704[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000704[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU ,0x00001602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000708[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000708[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000708[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000708[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000708[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000708[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000708[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000708[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000708[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800070C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF800070C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800070C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800070C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800070C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800070C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800070C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF800070C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800070C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000710[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000710[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000710[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000710[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000710[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000710[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000710[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000710[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000710[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000714[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000714[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000714[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000714[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000714[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000714[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000714[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000714[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000714[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000718[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000718[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000718[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000718[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000718[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000718[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000718[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000718[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000718[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800071C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800071C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800071C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800071C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800071C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800071C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800071C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF800071C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800071C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU ,0x00000600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000720[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000720[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000720[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000720[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000720[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000720[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000720[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 0 + // .. ==> 0XF8000720[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000720[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU ,0x00000602U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000724[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000724[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000724[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000724[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000724[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000724[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000724[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000724[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000724[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000728[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000728[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000728[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000728[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000728[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000728[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000728[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000728[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000728[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800072C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800072C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800072C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800072C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF800072C[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF800072C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800072C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800072C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800072C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000730[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000730[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000730[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000730[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000730[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000730[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000730[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000730[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000730[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000734[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000734[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000734[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000734[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000734[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000734[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000734[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000734[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000734[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000738[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000738[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000738[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000738[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF8000738[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF8000738[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000738[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000738[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000738[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800073C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800073C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800073C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800073C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF800073C[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF800073C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800073C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800073C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800073C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU ,0x00001680U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000770[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000770[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000770[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000770[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000770[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000770[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000770[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000770[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000770[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000774[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000774[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000774[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000774[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000774[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000774[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000774[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000774[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000774[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU ,0x00001605U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000778[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000778[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000778[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000778[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000778[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000778[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000778[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000778[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000778[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800077C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF800077C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800077C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800077C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800077C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800077C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800077C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800077C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800077C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU ,0x00001605U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000780[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000780[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000780[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000780[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000780[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000780[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000780[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000780[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000780[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000784[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000784[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000784[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000784[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000784[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000784[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000784[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000784[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000784[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000788[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000788[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000788[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000788[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000788[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000788[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000788[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000788[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000788[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800078C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800078C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800078C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800078C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800078C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800078C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800078C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800078C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800078C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000790[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000790[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000790[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000790[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000790[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000790[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000790[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000790[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000790[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU ,0x00001605U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000794[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000794[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000794[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000794[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000794[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000794[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000794[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000794[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000794[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000798[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000798[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000798[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000798[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000798[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000798[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF8000798[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF8000798[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000798[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800079C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800079C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800079C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800079C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800079C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800079C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF800079C[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF800079C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800079C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU ,0x00001604U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C0[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007C0[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007C0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU ,0x000016E0U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF80007C4[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF80007C4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C4[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007C4[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007C4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU ,0x000016E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007D0[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007D0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007D0[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007D0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU ,0x00001600U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007D4[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007D4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 3 + // .. ==> 0XF80007D4[11:9] = 0x00000003U + // .. ==> MASK : 0x00000E00U VAL : 0x00000600U + // .. PULLUP = 1 + // .. ==> 0XF80007D4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU ,0x00001600U), + // .. SDIO0_WP_SEL = 55 + // .. ==> 0XF8000830[5:0] = 0x00000037U + // .. ==> MASK : 0x0000003FU VAL : 0x00000037U + // .. SDIO0_CD_SEL = 56 + // .. ==> 0XF8000830[21:16] = 0x00000038U + // .. ==> MASK : 0x003F0000U VAL : 0x00380000U + // .. + EMIT_MASKWRITE(0XF8000830, 0x003F003FU ,0x00380037U), + // .. SDIO1_WP_SEL = 57 + // .. ==> 0XF8000834[5:0] = 0x00000039U + // .. ==> MASK : 0x0000003FU VAL : 0x00000039U + // .. SDIO1_CD_SEL = 58 + // .. ==> 0XF8000834[21:16] = 0x0000003AU + // .. ==> MASK : 0x003F0000U VAL : 0x003A0000U + // .. + EMIT_MASKWRITE(0XF8000834, 0x003F003FU ,0x003A0039U), + // .. FINISH: MIO PROGRAMMING + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_peripherals_init_data_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U ,0x00000000U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000180U ,0x00000000U), + // .. FINISH: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // .. START: SRAM/NOR SET OPMODE + // .. FINISH: SRAM/NOR SET OPMODE + // .. START: UART REGISTERS + // .. BDIV = 0x6 + // .. ==> 0XE0001034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0001034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0001018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0001000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0001000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0001000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0001000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0001000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0001000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0001000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0001000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0001000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0001000, 0x000001FFU ,0x00000017U), + // .. IRMODE = 0x0 + // .. ==> 0XE0001004[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. UCLKEN = 0x0 + // .. ==> 0XE0001004[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. CHMODE = 0x0 + // .. ==> 0XE0001004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0001004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0001004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0001004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0001004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0001004, 0x00000FFFU ,0x00000020U), + // .. BDIV = 0x6 + // .. ==> 0XE0000034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0000034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0000018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0000000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0000000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0000000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0000000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0000000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0000000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0000000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0000000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0000000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0000000, 0x000001FFU ,0x00000017U), + // .. IRMODE = 0x0 + // .. ==> 0XE0000004[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. UCLKEN = 0x0 + // .. ==> 0XE0000004[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. CHMODE = 0x0 + // .. ==> 0XE0000004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0000004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0000004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0000004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0000004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0000004, 0x00000FFFU ,0x00000020U), + // .. FINISH: UART REGISTERS + // .. START: QSPI REGISTERS + // .. Holdb_dr = 1 + // .. ==> 0XE000D000[19:19] = 0x00000001U + // .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. + EMIT_MASKWRITE(0XE000D000, 0x00080000U ,0x00080000U), + // .. FINISH: QSPI REGISTERS + // .. START: PL POWER ON RESET REGISTERS + // .. PCFG_POR_CNT_4K = 0 + // .. ==> 0XF8007000[29:29] = 0x00000000U + // .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8007000, 0x20000000U ,0x00000000U), + // .. FINISH: PL POWER ON RESET REGISTERS + // .. START: SMC TIMING CALCULATION REGISTER UPDATE + // .. .. START: NAND SET CYCLE + // .. .. FINISH: NAND SET CYCLE + // .. .. START: OPMODE + // .. .. FINISH: OPMODE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: SRAM/NOR CS0 SET CYCLE + // .. .. FINISH: SRAM/NOR CS0 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS0 BASE ADDRESS + // .. .. FINISH: NOR CS0 BASE ADDRESS + // .. .. START: SRAM/NOR CS1 SET CYCLE + // .. .. FINISH: SRAM/NOR CS1 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS1 BASE ADDRESS + // .. .. FINISH: NOR CS1 BASE ADDRESS + // .. .. START: USB RESET + // .. .. .. START: USB0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. DIRECTION_0 = 0x80 + // .. .. .. .. ==> 0XE000A204[31:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU ,0x00000080U), + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xff7f + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FF7FU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFF7F0000U + // .. .. .. .. DATA_0_LSW = 0x80 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFF7F0080U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. OP_ENABLE_0 = 0x80 + // .. .. .. .. ==> 0XE000A208[31:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU ,0x00000080U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xff7f + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FF7FU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFF7F0000U + // .. .. .. .. DATA_0_LSW = 0x0 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFF7F0000U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xff7f + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FF7FU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFF7F0000U + // .. .. .. .. DATA_0_LSW = 0x80 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000080U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000080U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFF7F0080U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB0 RESET + // .. .. FINISH: USB RESET + // .. .. START: ENET RESET + // .. .. FINISH: ENET RESET + // .. .. START: I2C RESET + // .. .. FINISH: I2C RESET + // .. .. START: NOR CHIP SELECT + // .. .. .. START: DIR MODE BANK 0 + // .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. FINISH: NOR CHIP SELECT + // .. FINISH: SMC TIMING CALCULATION REGISTER UPDATE + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_post_config_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_WRITE(0XF8000008, 0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: ENABLING LEVEL SHIFTER + // .. USER_INP_ICT_EN_0 = 3 + // .. ==> 0XF8000900[1:0] = 0x00000003U + // .. ==> MASK : 0x00000003U VAL : 0x00000003U + // .. USER_INP_ICT_EN_1 = 3 + // .. ==> 0XF8000900[3:2] = 0x00000003U + // .. ==> MASK : 0x0000000CU VAL : 0x0000000CU + // .. + EMIT_MASKWRITE(0XF8000900, 0x0000000FU ,0x0000000FU), + // .. FINISH: ENABLING LEVEL SHIFTER + // .. START: FPGA RESETS TO 0 + // .. reserved_3 = 0 + // .. ==> 0XF8000240[31:25] = 0x00000000U + // .. ==> MASK : 0xFE000000U VAL : 0x00000000U + // .. FPGA_ACP_RST = 0 + // .. ==> 0XF8000240[24:24] = 0x00000000U + // .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. FPGA_AXDS3_RST = 0 + // .. ==> 0XF8000240[23:23] = 0x00000000U + // .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. FPGA_AXDS2_RST = 0 + // .. ==> 0XF8000240[22:22] = 0x00000000U + // .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. FPGA_AXDS1_RST = 0 + // .. ==> 0XF8000240[21:21] = 0x00000000U + // .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. FPGA_AXDS0_RST = 0 + // .. ==> 0XF8000240[20:20] = 0x00000000U + // .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. reserved_2 = 0 + // .. ==> 0XF8000240[19:18] = 0x00000000U + // .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. FSSW1_FPGA_RST = 0 + // .. ==> 0XF8000240[17:17] = 0x00000000U + // .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. FSSW0_FPGA_RST = 0 + // .. ==> 0XF8000240[16:16] = 0x00000000U + // .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. reserved_1 = 0 + // .. ==> 0XF8000240[15:14] = 0x00000000U + // .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. FPGA_FMSW1_RST = 0 + // .. ==> 0XF8000240[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. FPGA_FMSW0_RST = 0 + // .. ==> 0XF8000240[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. FPGA_DMA3_RST = 0 + // .. ==> 0XF8000240[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. FPGA_DMA2_RST = 0 + // .. ==> 0XF8000240[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. FPGA_DMA1_RST = 0 + // .. ==> 0XF8000240[9:9] = 0x00000000U + // .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. FPGA_DMA0_RST = 0 + // .. ==> 0XF8000240[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. reserved = 0 + // .. ==> 0XF8000240[7:4] = 0x00000000U + // .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. FPGA3_OUT_RST = 0 + // .. ==> 0XF8000240[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. FPGA2_OUT_RST = 0 + // .. ==> 0XF8000240[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. FPGA1_OUT_RST = 0 + // .. ==> 0XF8000240[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. FPGA0_OUT_RST = 0 + // .. ==> 0XF8000240[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU ,0x00000000U), + // .. FINISH: FPGA RESETS TO 0 + // .. START: AFI REGISTERS + // .. .. START: AFI0 REGISTERS + // .. .. FINISH: AFI0 REGISTERS + // .. .. START: AFI1 REGISTERS + // .. .. FINISH: AFI1 REGISTERS + // .. .. START: AFI2 REGISTERS + // .. .. FINISH: AFI2 REGISTERS + // .. .. START: AFI3 REGISTERS + // .. .. FINISH: AFI3 REGISTERS + // .. FINISH: AFI REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_WRITE(0XF8000004, 0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_debug_1_0[] = { + // START: top + // .. START: CROSS TRIGGER CONFIGURATIONS + // .. .. START: UNLOCKING CTI REGISTERS + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8898FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_WRITE(0XF8898FB0, 0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8899FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_WRITE(0XF8899FB0, 0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8809FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_WRITE(0XF8809FB0, 0xC5ACCE55U), + // .. .. FINISH: UNLOCKING CTI REGISTERS + // .. .. START: ENABLING CTI MODULES AND CHANNELS + // .. .. FINISH: ENABLING CTI MODULES AND CHANNELS + // .. .. START: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. .. FINISH: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. FINISH: CROSS TRIGGER CONFIGURATIONS + // FINISH: top + // + EMIT_EXIT(), + + // +}; + + +#include "xil_io.h" +#define PS7_MASK_POLL_TIME 100000000 + +char* +getPS7MessageInfo(unsigned key) { + + char* err_msg = ""; + switch (key) { + case PS7_INIT_SUCCESS: err_msg = "PS7 initialization successful"; break; + case PS7_INIT_CORRUPT: err_msg = "PS7 init Data Corrupted"; break; + case PS7_INIT_TIMEOUT: err_msg = "PS7 init mask poll timeout"; break; + case PS7_POLL_FAILED_DDR_INIT: err_msg = "Mask Poll failed for DDR Init"; break; + case PS7_POLL_FAILED_DMA: err_msg = "Mask Poll failed for PLL Init"; break; + case PS7_POLL_FAILED_PLL: err_msg = "Mask Poll failed for DMA done bit"; break; + default: err_msg = "Undefined error status"; break; + } + + return err_msg; +} + +unsigned long +ps7GetSiliconVersion () { + // Read PS version from MCTRL register [31:28] + unsigned long mask = 0xF0000000; + unsigned long *addr = (unsigned long*) 0XF8007080; + unsigned long ps_version = (*addr & mask) >> 28; + return ps_version; +} + +void mask_write (unsigned long add , unsigned long mask, unsigned long val ) { + volatile unsigned long *addr = (volatile unsigned long*) add; + *addr = ( val & mask ) | ( *addr & ~mask); + //xil_printf("MaskWrite : 0x%x--> 0x%x \n \r" ,add, *addr); +} + + +int mask_poll(unsigned long add , unsigned long mask ) { + volatile unsigned long *addr = (volatile unsigned long*) add; + int i = 0; + while (!(*addr & mask)) { + if (i == PS7_MASK_POLL_TIME) { + return -1; + } + i++; + } + return 1; + //xil_printf("MaskPoll : 0x%x --> 0x%x \n \r" , add, *addr); +} + +unsigned long mask_read(unsigned long add , unsigned long mask ) { + volatile unsigned long *addr = (volatile unsigned long*) add; + unsigned long val = (*addr & mask); + //xil_printf("MaskRead : 0x%x --> 0x%x \n \r" , add, val); + return val; +} + + + +int +ps7_config(unsigned long * ps7_config_init) +{ + unsigned long *ptr = ps7_config_init; + + unsigned long opcode; // current instruction .. + unsigned long args[16]; // no opcode has so many args ... + int numargs; // number of arguments of this instruction + int j; // general purpose index + + volatile unsigned long *addr; // some variable to make code readable + unsigned long val,mask; // some variable to make code readable + + int finish = -1 ; // loop while this is negative ! + int i = 0; // Timeout variable + + while( finish < 0 ) { + numargs = ptr[0] & 0xF; + opcode = ptr[0] >> 4; + + for( j = 0 ; j < numargs ; j ++ ) + args[j] = ptr[j+1]; + ptr += numargs + 1; + + + switch ( opcode ) { + + case OPCODE_EXIT: + finish = PS7_INIT_SUCCESS; + break; + + case OPCODE_CLEAR: + addr = (unsigned long*) args[0]; + *addr = 0; + break; + + case OPCODE_WRITE: + addr = (unsigned long*) args[0]; + val = args[1]; + *addr = val; + break; + + case OPCODE_MASKWRITE: + addr = (unsigned long*) args[0]; + mask = args[1]; + val = args[2]; + *addr = ( val & mask ) | ( *addr & ~mask); + break; + + case OPCODE_MASKPOLL: + addr = (unsigned long*) args[0]; + mask = args[1]; + i = 0; + while (!(*addr & mask)) { + if (i == PS7_MASK_POLL_TIME) { + finish = PS7_INIT_TIMEOUT; + break; + } + i++; + } + break; + case OPCODE_MASKDELAY: + addr = (unsigned long*) args[0]; + mask = args[1]; + int delay = get_number_of_cycles_for_delay(mask); + perf_reset_and_start_timer(); + while ((*addr < delay)) { + } + break; + default: + finish = PS7_INIT_CORRUPT; + break; + } + } + return finish; +} + +unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; +unsigned long *ps7_pll_init_data = ps7_pll_init_data_3_0; +unsigned long *ps7_clock_init_data = ps7_clock_init_data_3_0; +unsigned long *ps7_ddr_init_data = ps7_ddr_init_data_3_0; +unsigned long *ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + +int +ps7_post_config() +{ + // Get the PS_VERSION on run time + unsigned long si_ver = ps7GetSiliconVersion (); + int ret = -1; + if (si_ver == PCW_SILICON_VERSION_1) { + ret = ps7_config (ps7_post_config_1_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } else if (si_ver == PCW_SILICON_VERSION_2) { + ret = ps7_config (ps7_post_config_2_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } else { + ret = ps7_config (ps7_post_config_3_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } + return PS7_INIT_SUCCESS; +} + +int +ps7_debug() +{ + // Get the PS_VERSION on run time + unsigned long si_ver = ps7GetSiliconVersion (); + int ret = -1; + if (si_ver == PCW_SILICON_VERSION_1) { + ret = ps7_config (ps7_debug_1_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } else if (si_ver == PCW_SILICON_VERSION_2) { + ret = ps7_config (ps7_debug_2_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } else { + ret = ps7_config (ps7_debug_3_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } + return PS7_INIT_SUCCESS; +} + + +int ps7_reset_apu() +{ + mask_write(0xF8000244, 0x00000022U ,0x00000022U); + return PS7_INIT_SUCCESS; +} + +int +ps7_init() +{ + // Get the PS_VERSION on run time + unsigned long si_ver = ps7GetSiliconVersion (); + int ret; + //int pcw_ver = 0; + + ret = ps7_reset_apu(); + if (ret != PS7_INIT_SUCCESS) return ret; + + if (si_ver == PCW_SILICON_VERSION_1) { + ps7_mio_init_data = ps7_mio_init_data_1_0; + ps7_pll_init_data = ps7_pll_init_data_1_0; + ps7_clock_init_data = ps7_clock_init_data_1_0; + ps7_ddr_init_data = ps7_ddr_init_data_1_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_1_0; + //pcw_ver = 1; + + } else if (si_ver == PCW_SILICON_VERSION_2) { + ps7_mio_init_data = ps7_mio_init_data_2_0; + ps7_pll_init_data = ps7_pll_init_data_2_0; + ps7_clock_init_data = ps7_clock_init_data_2_0; + ps7_ddr_init_data = ps7_ddr_init_data_2_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_2_0; + //pcw_ver = 2; + + } else { + ps7_mio_init_data = ps7_mio_init_data_3_0; + ps7_pll_init_data = ps7_pll_init_data_3_0; + ps7_clock_init_data = ps7_clock_init_data_3_0; + ps7_ddr_init_data = ps7_ddr_init_data_3_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + //pcw_ver = 3; + } + + // MIO init + ret = ps7_config (ps7_mio_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + // PLL init + ret = ps7_config (ps7_pll_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + // Clock init + ret = ps7_config (ps7_clock_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + // DDR init + ret = ps7_config (ps7_ddr_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + + + // Peripherals init + ret = ps7_config (ps7_peripherals_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + //xil_printf ("\n PCW Silicon Version : %d.0", pcw_ver); + return PS7_INIT_SUCCESS; +} + + + + +/* For delay calculation using global timer */ + +/* start timer */ + void perf_start_clock(void) +{ + *(volatile unsigned int*)SCU_GLOBAL_TIMER_CONTROL = ((1 << 0) | // Timer Enable + (1 << 3) | // Auto-increment + (0 << 8) // Pre-scale + ); +} + +/* stop timer and reset timer count regs */ + void perf_reset_clock(void) +{ + perf_disable_clock(); + *(volatile unsigned int*)SCU_GLOBAL_TIMER_COUNT_L32 = 0; + *(volatile unsigned int*)SCU_GLOBAL_TIMER_COUNT_U32 = 0; +} + +/* Compute mask for given delay in miliseconds*/ +int get_number_of_cycles_for_delay(unsigned int delay) +{ + // GTC is always clocked at 1/2 of the CPU frequency (CPU_3x2x) + return (APU_FREQ*delay/(2*1000)); + +} + +/* stop timer */ + void perf_disable_clock(void) +{ + *(volatile unsigned int*)SCU_GLOBAL_TIMER_CONTROL = 0; +} + +void perf_reset_and_start_timer() +{ + perf_reset_clock(); + perf_start_clock(); +} + + + + diff --git a/board/xilinx/zynq/zynq-minized/ps7_init_gpl.h b/board/xilinx/zynq/zynq-minized/ps7_init_gpl.h new file mode 100644 index 0000000000..f3e0d06583 --- /dev/null +++ b/board/xilinx/zynq/zynq-minized/ps7_init_gpl.h @@ -0,0 +1,131 @@ +/****************************************************************************** +* +* Copyright (C) 2018 Xilinx, Inc. All rights reserved. +* +* This program is free software; you can redistribute it and/or modify +* it under the terms of the GNU General Public License as published by +* the Free Software Foundation; either version 2 of the License, or +* (at your option) any later version. +* +* This program is distributed in the hope that it will be useful, +* but WITHOUT ANY WARRANTY; without even the implied warranty of +* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +* GNU General Public License for more details. +* +* You should have received a copy of the GNU General Public License along +* with this program; if not, see http://www.gnu.org/licenses/ +* +* +******************************************************************************/ +/****************************************************************************/ +/** +* +* @file ps7_init_gpl.h +* +* This file can be included in FSBL code +* to get prototype of ps7_init() function +* and error codes +* +*****************************************************************************/ + + + + +#ifdef __cplusplus +extern "C" { +#endif + + +//typedef unsigned int u32; + + +/** do we need to make this name more unique ? **/ +//extern u32 ps7_init_data[]; +extern unsigned long * ps7_ddr_init_data; +extern unsigned long * ps7_mio_init_data; +extern unsigned long * ps7_pll_init_data; +extern unsigned long * ps7_clock_init_data; +extern unsigned long * ps7_peripherals_init_data; + + + +#define OPCODE_EXIT 0U +#define OPCODE_CLEAR 1U +#define OPCODE_WRITE 2U +#define OPCODE_MASKWRITE 3U +#define OPCODE_MASKPOLL 4U +#define OPCODE_MASKDELAY 5U +#define NEW_PS7_ERR_CODE 1 + +/* Encode number of arguments in last nibble */ +#define EMIT_EXIT() ( (OPCODE_EXIT << 4 ) | 0 ) +#define EMIT_CLEAR(addr) ( (OPCODE_CLEAR << 4 ) | 1 ) , addr +#define EMIT_WRITE(addr,val) ( (OPCODE_WRITE << 4 ) | 2 ) , addr, val +#define EMIT_MASKWRITE(addr,mask,val) ( (OPCODE_MASKWRITE << 4 ) | 3 ) , addr, mask, val +#define EMIT_MASKPOLL(addr,mask) ( (OPCODE_MASKPOLL << 4 ) | 2 ) , addr, mask +#define EMIT_MASKDELAY(addr,mask) ( (OPCODE_MASKDELAY << 4 ) | 2 ) , addr, mask + +/* Returns codes of PS7_Init */ +#define PS7_INIT_SUCCESS (0) // 0 is success in good old C +#define PS7_INIT_CORRUPT (1) // 1 the data is corrupted, and slcr reg are in corrupted state now +#define PS7_INIT_TIMEOUT (2) // 2 when a poll operation timed out +#define PS7_POLL_FAILED_DDR_INIT (3) // 3 when a poll operation timed out for ddr init +#define PS7_POLL_FAILED_DMA (4) // 4 when a poll operation timed out for dma done bit +#define PS7_POLL_FAILED_PLL (5) // 5 when a poll operation timed out for pll sequence init + + +/* Silicon Versions */ +#define PCW_SILICON_VERSION_1 0 +#define PCW_SILICON_VERSION_2 1 +#define PCW_SILICON_VERSION_3 2 + +/* This flag to be used by FSBL to check whether ps7_post_config() proc exixts */ +#define PS7_POST_CONFIG + +/* Freq of all peripherals */ + +#define APU_FREQ 666666687 +#define DDR_FREQ 533333374 +#define DCI_FREQ 10158730 +#define QSPI_FREQ 200000000 +#define SMC_FREQ 10000000 +#define ENET0_FREQ 10000000 +#define ENET1_FREQ 10000000 +#define USB0_FREQ 60000000 +#define USB1_FREQ 60000000 +#define SDIO_FREQ 25000000 +#define UART_FREQ 100000000 +#define SPI_FREQ 10000000 +#define I2C_FREQ 111111115 +#define WDT_FREQ 111111115 +#define TTC_FREQ 50000000 +#define CAN_FREQ 10000000 +#define PCAP_FREQ 200000000 +#define TPIU_FREQ 200000000 +#define FPGA0_FREQ 50000000 +#define FPGA1_FREQ 100000000 +#define FPGA2_FREQ 10000000 +#define FPGA3_FREQ 10000000 + + +/* For delay calculation using global registers*/ +#define SCU_GLOBAL_TIMER_COUNT_L32 0xF8F00200 +#define SCU_GLOBAL_TIMER_COUNT_U32 0xF8F00204 +#define SCU_GLOBAL_TIMER_CONTROL 0xF8F00208 +#define SCU_GLOBAL_TIMER_AUTO_INC 0xF8F00218 + +int ps7_config( unsigned long*); +int ps7_init(); +int ps7_post_config(); +int ps7_debug(); +char* getPS7MessageInfo(unsigned key); + +void perf_start_clock(void); +void perf_disable_clock(void); +void perf_reset_clock(void); +void perf_reset_and_start_timer(); +int get_number_of_cycles_for_delay(unsigned int delay); +#ifdef __cplusplus +} +#endif +
Signed-off-by: Philip Balister philip@opensdr.com --- arch/arm/dts/zynq-minized.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/zynq-minized.dts b/arch/arm/dts/zynq-minized.dts index 525921ee7b..9ad7f090fe 100644 --- a/arch/arm/dts/zynq-minized.dts +++ b/arch/arm/dts/zynq-minized.dts @@ -38,6 +38,7 @@ };
&qspi { + u-boot,dm-pre-reloc; status = "okay"; is-dual = <0>; num-cs = <1>;
&qspi {
- u-boot,dm-pre-reloc; status = "okay"; is-dual = <0>; num-cs = <1>;
I don't have 1/4 in my inbox but I see it on web. That ps7 config should be tuned and fixed. We have converted others based on miami boards that's why please do it too.
2/4 There should be something in commit message and I do prefer to have subjects not to end with dot.
Thanks, Michal
&qspi {
What do you mean by tuned and fixed? My goal here is get to a u-boot we can actually boot the minized with and do some useful things.
I will add a message explaining we need qspi for SPL.
Philip
Thanks, Michal
pá 26. 4. 2019 v 6:18 odesílatel Philip Balister philip@balister.org napsal:
&qspi {
Just take a look at other boards and how that init files looks like. It is not straight copy of what xilinx tools generate. Comments are removed. Unused functions are removed. Coding style is fixed, etc.
Thanks, Michal
Signed-off-by: Philip Balister philip@opensdr.com --- include/configs/zynq_minized.h | 54 ++++++++++++++++++++++++++++++++++ 1 file changed, 54 insertions(+) create mode 100644 include/configs/zynq_minized.h
diff --git a/include/configs/zynq_minized.h b/include/configs/zynq_minized.h new file mode 100644 index 0000000000..6d89e3da29 --- /dev/null +++ b/include/configs/zynq_minized.h @@ -0,0 +1,54 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2019 Philip Balister philip@balister.org. + * + * Configuration settings for the MiniZed board + * See zynq-common.h for Zynq common configs + */ + +#ifndef __CONFIG_ZYNQ_MINIZED_H +#define __CONFIG_ZYNQ_MINIZED_H + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fit_image=fitImage\0" \ + "bit_file=fpga.bit\0" \ + "load_addr=0x2000000\0" \ + "fit_size=0x800000\0" \ + "flash_off=0x100000\0" \ + "nor_flash_off=0xE2100000\0" \ + "fdt_high=0x20000000\0" \ + "initrd_high=0x20000000\0" \ + "loadbootenv_addr=0x2000000\0" \ + "fdt_addr_r=0x1f00000\0" \ + "kernel_addr_r=0x2000000\0" \ + "ramdisk_addr_r=0x3100000\0" \ + "bootenv=uEnv.txt\0" \ + "bootenv_dev=mmc\0" \ + "qspiboot=echo Copying FIT from QSPI to RAM... (Not Yet) \0" \ + "mmcboot= " \ + "echo Copying fpga.bit from MMC and loading FPGA... && " \ + "load mmc 0:1 ${load_addr} /boot/${bit_file} && " \ + "fpga loadb 0 ${load_addr} ${filesize} && " \ + "echo Copying FIT from MMC to RAM... && " \ + "load mmc 0:1 ${load_addr} /boot/${fit_image} && " \ + "setenv bootargs root=/dev/mmcblk1p1 rootwait && " \ + "bootm ${load_addr}\0" \ + "usbboot=if usb start; then " \ + "echo Copying fpga.bit from USB and loading FPGA... && " \ + "load usb 0 ${load_addr} /boot/${bit_file} && " \ + "fpga loadb 0 ${load_addr} ${filesize} && " \ + "echo Copying FIT from USB to RAM... && " \ + "load usb 0 ${load_addr} /boot/${fit_image} && " \ + "setenv bootargs root=/dev/sda1 rootwait && " \ + "bootm ${load_addr}; fi\0" \ + "usbrecover=if usb start; then " \ + "echo Copying fpga.bit from USB and loading FPGA... && " \ + "load usb 0 ${load_addr} ${bit_file} && " \ + "fpga loadb 0 ${load_addr} ${filesize} && " \ + "echo Copying FIT from USB to RAM... && " \ + "load usb 0 ${load_addr} ${fit_image} && " \ + "bootm ${load_addr}; fi\0" + +#include <configs/zynq-common.h> + +#endif /* __CONFIG_ZYNQ_MINIZED_H */
- (C) Copyright 2019 Philip Balister philip@balister.org.
- Configuration settings for the MiniZed board
- See zynq-common.h for Zynq common configs
- "fit_image=fitImage\0" \
- "bit_file=fpga.bit\0" \
- "load_addr=0x2000000\0" \
- "fit_size=0x800000\0" \
- "flash_off=0x100000\0" \
- "nor_flash_off=0xE2100000\0" \
- "fdt_high=0x20000000\0" \
- "initrd_high=0x20000000\0" \
- "loadbootenv_addr=0x2000000\0" \
- "fdt_addr_r=0x1f00000\0" \
- "kernel_addr_r=0x2000000\0" \
- "ramdisk_addr_r=0x3100000\0" \
- "bootenv=uEnv.txt\0" \
- "bootenv_dev=mmc\0" \
- "qspiboot=echo Copying FIT from QSPI to RAM... (Not Yet) \0" \
- "mmcboot= " \
- "usbboot=if usb start; then " \
- "usbrecover=if usb start; then " \
We are moving towards distro boot that's why if this can't be done via distro boot then it should be extended. sd/mmc boot mode is handled there properly that's why I have strong doubts that this is really necessary.
M
- "mmcboot= " \
Are there any good distro boot examples or write ups? Basically, I am trying to make it easy for people to work with the minized. Well at least easy for me :)
Philip
M
pá 26. 4. 2019 v 6:59 odesílatel Philip Balister philip@balister.org napsal:
- "mmcboot= " \
Take a look at this. https://github.com/Xilinx/u-boot-xlnx/tree/master/board/xilinx/bootscripts There are also other bootscripts for other boards.
M
--- w: www.monstr.eu p: +42-0-721842854 Maintainer of Linux kernel - Xilinx Microblaze Maintainer of Linux kernel - Xilinx Zynq ARM and ZynqMP ARM64 SoCs U-Boot custodian - Xilinx Microblaze/Zynq/ZynqMP/Versal SoCs
Signed-off-by: Philip Balister philip@opensdr.com --- configs/zynq_minized_defconfig | 16 +++++----------- 1 file changed, 5 insertions(+), 11 deletions(-)
diff --git a/configs/zynq_minized_defconfig b/configs/zynq_minized_defconfig index d61659f785..6c56b9b9b9 100644 --- a/configs/zynq_minized_defconfig +++ b/configs/zynq_minized_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="zynq_minized" CONFIG_ARCH_ZYNQ=y CONFIG_SYS_TEXT_BASE=0x4000000 CONFIG_SPL=y @@ -12,9 +13,9 @@ CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_SPI_LOAD=y CONFIG_SYS_PROMPT="Zynq> " -CONFIG_CMD_THOR_DOWNLOAD=y -CONFIG_CMD_DFU=y +# CONFIG_CMD_ELF is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_FPGA_LOADBP=y CONFIG_CMD_FPGA_LOADFS=y @@ -25,15 +26,12 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-minized" CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_NET_RANDOM_ETHADDR=y +# CONFIG_NET is not set CONFIG_SPL_DM_SEQ_ALIAS=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y @@ -44,11 +42,6 @@ CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_XILINX=y -CONFIG_MII=y -CONFIG_ZYNQ_GEM=y CONFIG_DEBUG_UART_ZYNQ=y CONFIG_ZYNQ_SERIAL=y CONFIG_ZYNQ_QSPI=y @@ -63,3 +56,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_THOR=y +CONFIG_REGEX=y
this is here because of 3/4
What's the reason?
If there is usb host you maybe need this for usb to ethernet convertors.
if there is no physical port we can remove this.
Don't have this board to say what it is reasonable. I see some usbs on pictures that's why maybe that DFU stuff can stay there too.
Please put it to description in v2.
M
Yes. Should we be looking at cleaning up the default zynq environment?
What's the reason?
I'm not a DFU expert. The time I saw it used, the board needed to be a USB device. The minized only supports USB host. The micro usb connectors are for serial/jtag and an extra power supply.
As I recall DFU has a maximum payload size that is smaller then the available emmc. This can be really confusing to uncover.
There is USB host. Do many people use usb ethernet convertors with u-boot?
OK
Thanks for the review.
Philip
M
pá 26. 4. 2019 v 7:11 odesílatel Philip Balister philip@balister.org napsal:
yes.
What's the reason?
ok. Then dfu can be removed. I was more curious about disabling CMD_ELF then dfu.
if board has no ethernet port then ethernet convertors are the way to go. I use that a lot with ultra96.
OK
Thanks, Michal
Michal Simek
Philip Balister
