Re: [U-Boot] [PATCH 2/3] armv8: layerscape: Adjust memory mapping for Flash/SD card on LS1043A
On 04/27/2017 01:08 AM, Alison Wang wrote:
This patch is to adjust the memory mapping for FLash/SD card on LS1043AQDS and LS1043ARDB, such as PPA firmware load address, FMAN firmware load address, QE firmware load address, U-Boot start address on serial flash and environment address.
Signed-off-by: Alison Wang alison.wang@nxp.com
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 8 ++++---- include/configs/ls1043a_common.h | 10 +++++----- include/configs/ls1043aqds.h | 10 +++++----- include/configs/ls1043ardb.h | 8 ++++---- 4 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 4c16c4c..82c76e2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -163,11 +163,11 @@ endchoice config SYS_LS_PPA_FW_ADDR hex "Address of PPA firmware loading from" depends on FSL_LS_PPA
- default 0x40500000 if SYS_LS_PPA_FW_IN_XIP && QSPI_BOOT
- default 0x40400000 if SYS_LS_PPA_FW_IN_XIP && QSPI_BOOT default 0x580a00000 if SYS_LS_PPA_FW_IN_XIP && ARCH_LS2080A
- default 0x60500000 if SYS_LS_PPA_FW_IN_XIP
- default 0x500000 if SYS_LS_PPA_FW_IN_MMC
- default 0x500000 if SYS_LS_PPA_FW_IN_NAND
default 0x60400000 if SYS_LS_PPA_FW_IN_XIP
default 0x400000 if SYS_LS_PPA_FW_IN_MMC
default 0x400000 if SYS_LS_PPA_FW_IN_NAND
help If the PPA firmware locate at XIP flash, such as NOR or diff --git
a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index e269248..155da92 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -208,9 +208,9 @@ #define CONFIG_SYS_FM_MURAM_SIZE 0x60000
#ifdef CONFIG_NAND_BOOT -/* Store Fman ucode at offeset 0x160000(11 blocks). */ +/* Store Fman ucode at offeset 0x900000(72 blocks). */ #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (72 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) /*
- PBL SD boot image should stored at 0x1000(8 blocks), the size of
the image is @@ -218,10 +218,10 @@
- 0x2000 (16 blocks), 8 + 2040 + 16 = 2064, enlarge it to 2080(0x820).
*/ #define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x820) +#define CONFIG_SYS_FMAN_FW_ADDR (512 * 0x4800)
Alison,
Please update the comments. It still says 0x820. [Alison Wang] Yes, I will update. Thanks for reminding me.
Best Regards, Alison Wang
Alison Wang
