[PATCH v2 0/2] Arm Juno board documentation
The Arm Ltd. Juno development board is an open, vendor-neutral, Armv8-A development platform. U-Boot is one of the two supported normal world payloads in the firmware design, though U-Boot never really described the process of building or installing it.
Fix that by adding documentation for the board in the doc/board directory.
Cheers, Andre
Changelog: v1 ... v2: - fvp64: RST improvements (links, make command line) - fvp64: use most common platform name in TF-A build command - juno: use more precise naming for Juno development *platform* - juno: fix wrong naming of MCC management controller - juno: mention and link to Juno TRM - juno: simplify SD card connection instructions - juno: use fiptool update instead of complicated explicit re-packaging - juno: describe devicetree selection more precisely
Andre Przywara (1): doc: add Arm Juno board documentation
Peter Hoyes (1): doc: Add documentation for the Arm VExpress64 board configs
doc/board/armltd/fvp64.rst | 30 ++++++++++ doc/board/armltd/index.rst | 11 ++++ doc/board/armltd/juno.rst | 114 +++++++++++++++++++++++++++++++++++++ doc/board/index.rst | 1 + 4 files changed, 156 insertions(+) create mode 100644 doc/board/armltd/fvp64.rst create mode 100644 doc/board/armltd/index.rst create mode 100644 doc/board/armltd/juno.rst
Create a new documentation section for Arm Ltd boards with a sub-page for the FVP VExpress64 system.
Signed-off-by: Peter Hoyes Peter.Hoyes@arm.com [Andre: remove Juno stub, RSTify] Signed-off-by: Andre Przywara andre.przywara@arm.com --- doc/board/armltd/fvp64.rst | 30 ++++++++++++++++++++++++++++++ doc/board/armltd/index.rst | 10 ++++++++++ doc/board/index.rst | 1 + 3 files changed, 41 insertions(+) create mode 100644 doc/board/armltd/fvp64.rst create mode 100644 doc/board/armltd/index.rst
diff --git a/doc/board/armltd/fvp64.rst b/doc/board/armltd/fvp64.rst new file mode 100644 index 0000000000..4dc341bf2a --- /dev/null +++ b/doc/board/armltd/fvp64.rst @@ -0,0 +1,30 @@ +.. SPDX-License-Identifier: GPL-2.0 + +Fixed Virtual Platforms +======================= + +The Fixed Virtual Platforms (FVP) are complete software simulations of an Arm +system, including processor, memory and peripherals. They are set out in a +"programmer's view", which gives a comprehensive model on which to build and +test software. + +The supported FVPs are available free of charge and can be downloaded from the +`Arm developer site`_ (user registration might be required). + +Supported features: + + * GICv3 + * Generic timer + * PL011 UART + +The default configuration assumes that U-Boot is bootstrapped using a suitable +bootloader, such as `Trusted Firmware-A`_. The U-Boot binary can be passed +into the TF-A build:: + + make PLAT=fvp all fip BL33=/path/to/u-boot.bin + +The FVPs can be debugged using `Arm Development Studio`_. + +.. _`Arm developer site`: https://developer.arm.com/tools-and-software/simulation-models/fixed-virtual... +.. _`Trusted Firmware-A`: https://www.trustedfirmware.org/projects/tf-a/ +.. _`Arm Development Studio`: https://developer.arm.com/tools-and-software/embedded/arm-development-studio diff --git a/doc/board/armltd/index.rst b/doc/board/armltd/index.rst new file mode 100644 index 0000000000..caa6fd2bb0 --- /dev/null +++ b/doc/board/armltd/index.rst @@ -0,0 +1,10 @@ +.. SPDX-License-Identifier: GPL-2.0 +.. Copyright (C) 2021 Arm Ltd. + +ARM Ltd. boards and emulated systems +==================================== + +.. toctree:: + :maxdepth: 2 + + fvp64 diff --git a/doc/board/index.rst b/doc/board/index.rst index 13f4db848e..d0a7838550 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -11,6 +11,7 @@ Board-specific doc AndesTech/index amlogic/index apple/index + armltd/index atmel/index congatec/index coreboot/index
Reviewed-by: Sudeep Holla sudeep.holla@arm.com
Reviewed-by: Linus Walleij linus.walleij@linaro.org
Yours, Linus Walleij
Reviewed-by: Simon Glass sjg@chromium.org Missing change log
The Juno Arm development board is an open, vendor-neutral, Armv8-A development platform. Add documentation that briefly outlines the hardware, and describes building and installation of U-Boot.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- doc/board/armltd/index.rst | 1 + doc/board/armltd/juno.rst | 114 +++++++++++++++++++++++++++++++++++++ 2 files changed, 115 insertions(+) create mode 100644 doc/board/armltd/juno.rst
diff --git a/doc/board/armltd/index.rst b/doc/board/armltd/index.rst index caa6fd2bb0..68d938c647 100644 --- a/doc/board/armltd/index.rst +++ b/doc/board/armltd/index.rst @@ -8,3 +8,4 @@ ARM Ltd. boards and emulated systems :maxdepth: 2
fvp64 + juno diff --git a/doc/board/armltd/juno.rst b/doc/board/armltd/juno.rst new file mode 100644 index 0000000000..3d20ff129c --- /dev/null +++ b/doc/board/armltd/juno.rst @@ -0,0 +1,114 @@ +.. SPDX-License-Identifier: GPL-2.0 +.. Copyright (C) 2021 Arm Ltd. + +Arm Juno development platform +============================= + +The `Juno development board`_ is an open, vendor-neutral, Armv8-A development +platform, made by Arm Ltd. It is part of the Versatile Express family. +There are three revisions of the board: + +* Juno r0, with two Cortex-A57 and four Cortex-A53 cores, without PCIe. +* Juno r1, with two Cortex-A57 and four Cortex-A53 cores, in later silicon + revisions, and with PCIe slots, Gigabit Ethernet and two SATA ports. +* Juno r2, with two Cortex-A72 and four Cortex-A53 cores, otherwise the + same as r1. + +Among other things, the motherboard contains a management controller (MCC), +an FPGA providing I/O interfaces (IOFPGA) and 64MB of NOR flash. The provided +platform devices resemble the VExpress peripherals. +The actual SoC also contains a Cortex-M3 based System Control Processor (SCP). +The `V2M-Juno TRM`_ contains more technical details. + +U-Boot build +------------ +There is only one defconfig and one binary build that covers all three board +revisions, so to generate the needed ``u-boot.bin``: + +.. code-block:: bash + + $ make vexpress_aemv8a_juno_defconfig + $ make + +The automatic distro boot sequence looks for UEFI boot applications and +``boot.scr`` scripts on various boot media, starting with USB, then on disks +connected to the two SATA ports, PXE, DHCP and eventually on the NOR flash. + +U-Boot installation +------------------- +This assumes there is some firmware on the SD card or NOR flash (see below +for more details). The U-Boot binary is included in the Trusted Firmware +FIP image, so after building U-Boot, this needs to be repackaged or recompiled. + +The NOR flash will be updated by the MCC, based on the content of a micro-SD +card, which is exported as a USB mass storage device via the rear USB-B +socket. So to access that SD card, connect a cable to some host computer, and +mount the FAT16 partition of the UMS device. +If there is no device, check the upper serial port for a prompt, and +explicitly enable the USB interface:: + + Cmd> usb_on + Enabling debug USB... + +Repackaging an existing FIP image +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ +To prevent problems, it is probably a good idea to backup the existing firmware, +for instance by just copying the entire ``SOFTWARE/`` directory, or at least +the current ``fip.bin``, beforehand. + +To just replace the BL33 image in the exising FIP image, you can use +`fiptool`_ from the Trusted Firmware repository, on the image file: + +.. code-block:: bash + + $ git clone https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git + $ cd trusted-firmware-a + $ make fiptool + $ tools/fiptool/fiptool update --nt-fw=/path/to/your/u-boot.bin /mnt/juno/SOFTWARE/fip.bin + +Unmount the USB mass storage device and reboot the board, the new ``fip.bin`` +will be automatically written to the NOR flash and then used. + +Rebuilding Trusted Firmware +^^^^^^^^^^^^^^^^^^^^^^^^^^^ +You can also generate a new FIP image by compiling Arm Trusted Firmware, +and providing ``u-boot.bin`` as the BL33 file. For that you can either build +the required `SCP firmware`_ yourself, or just extract the existing +version from your ``fip.bin``, using `fiptool`_ (see above): + +.. code-block:: bash + + $ mkdir /tmp/juno; cd /tmp/juno + $ fiptool unpack /mnt/juno/SOFTWARE/fip.bin + +Then build TF-A: + +.. code-block:: bash + + $ git clone https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git + $ cd trusted-firmware-a + $ make CROSS_COMPILE=aarch64-linux-gnu- PLAT=juno DEBUG=1 \ + SCP_BL2=/tmp/juno/scp-fw.bin BL33=/path/to/your/u-boot.bin fiptool all fip + $ cp build/juno/debug/bl1.bin build/juno/debug/fip.bin /mnt/juno/SOFTWARE + +Then umount the USB device, and reboot, as above. + +Device trees +------------ +The device tree files for the boards are maintained in the Linux kernel +repository. They end up in the ``SOFTWARE/`` directory of the SD card, as +``juno.dtb``, ``juno-r1.dtb``, and ``juno-r2.dtb``, respectively. The MCC +firmware will look into the images.txt file matching the board revision, from +the ``SITE1/`` directory. Each version there will reference its respective DTB +file in ``SOFTWARE/``, and so the correct version will end in the NOR flash, in +the ``board.dtb`` partition. U-Boot picks its control DTB from there, you can +pass this on to a kernel using ``$fdtcontroladdr``. + +You can update the DTBs anytime, by building them using the ``dtbs`` make +target from a Linux kernel tree, then just copying the generated binaries +to the ``SOFTWARE/`` directory of the SD card. + +.. _`Juno development board`: https://developer.arm.com/tools-and-software/development-boards/juno-develop... +.. _`V2M-Juno TRM`: https://developer.arm.com/documentation/100113/latest +.. _`fiptool`: https://github.com/ARM-software/arm-trusted-firmware/tree/master/tools/fipto... +.. _`SCP firmware`: https://github.com/ARM-software/SCP-firmware.git
This is excellent and much needed documentation. Thank you so much for doing this Andre! Reviewed-by: Linus Walleij linus.walleij@linaro.org
Missing change log
Andre Przywara
Linus Walleij
Sudeep Holla
