[PATCH 1/4] board: keymile: common: fix qrio compilation for arm
This patch is fixing qrio driver compilation for ARM architecture: - It includes asm/io.h for in_/out_ access - It use correct names for set/clear_bits as defined in linux/bitops.h
Signed-off-by: Aleksandar Gerasimovski aleksandar.gerasimovski@hitachi-powergrids.com --- board/keymile/common/qrio.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/board/keymile/common/qrio.c b/board/keymile/common/qrio.c index 06a4e67..d4e75f2 100644 --- a/board/keymile/common/qrio.c +++ b/board/keymile/common/qrio.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/io.h> #include <linux/bitops.h>
#include "common.h" @@ -129,7 +130,7 @@ void qrio_prst(u8 bit, bool en, bool wden)
void qrio_prstcfg(u8 bit, u8 mode) { - u32 prstcfg; + unsigned long prstcfg; u8 i; void __iomem *qrio_base = (void *)CONFIG_SYS_QRIO_BASE;
@@ -137,9 +138,9 @@ void qrio_prstcfg(u8 bit, u8 mode)
for (i = 0; i < 2; i++) { if (mode & (1 << i)) - set_bit(2 * bit + i, &prstcfg); + __set_bit(2 * bit + i, &prstcfg); else - clear_bit(2 * bit + i, &prstcfg); + __clear_bit(2 * bit + i, &prstcfg); }
out_be32(qrio_base + PRSTCFG_OFF, prstcfg);
