[U-Boot] Board Porting MACH_TYPE question
I am porting a board similar to the Beagle to U-Boot. The Beagle config works but needs further pin MUXing . I have copied the Beagle board config to a new name and when compiled the binary performs as per the Beale one. My issue is when I change the line
51: gd->bd->bi_arch_number = MACH_TYPE_OMAP3_BEAGLE;
in the copy of beagle.h (now re2v2.h) to
51: gd->bd->bi_arch_number = MACH_TYPE_OMAP3_RE2V2;
The loader now unpacks the loaded kernel and then halts at the stage where it tries to boot it
I have updated arch/arm/include/ asm /mach-types.h and include/ asm /mach-types.h. If I grep for the relevant changes/ additions I get the following:-
grep -r machine_is_omap3_beagle * arch/arm/include/ asm /mach-types.h:# define machine_is_omap3_beagle() (machine_arch_type == MACH_TYPE_OMAP3_BEAGLE) arch/arm/include/ asm /mach-types.h:# define machine_is_omap3_beagle() (0) include/ asm /mach-types.h:# define machine_is_omap3_beagle() (machine_arch_type == MACH_TYPE_OMAP3_BEAGLE) include/ asm /mach-types.h:# define machine_is_omap3_beagle() (0)
grep -r machine_is_omap3_re2v2 * arch/arm/include/ asm /mach-types.h:# define machine_is_omap3_re2v2() (machine_arch_type == MACH_TYPE_OMAP3_RE2V2) arch/arm/include/ asm /mach-types.h:# define machine_is_omap3_re2v2() (0) include/ asm /mach-types.h:# define machine_is_omap3_re2v2() (machine_arch_type == MACH_TYPE_OMAP3_RE2V2) include/ asm /mach-types.h:# define machine_is_omap3_re2v2() (0)
I have defined MACH_TYPE_OMAP3_RE2V2 in arch/arm/include/ asm /mach-types.h and given it the next number I can't see where machine_arch_type is used outside of board configuration I can't see where 1546 (the Beagle number) is used either
Any idea what additional work needs to be done to move to MACH_TYPE_OMAP3_RE2V2 from MACH_TYPE_OMAP3_BEAGLE?
Regards Rob
Blue Chip Technology Limited. Chowley Oak Lane, Tattenhall, Chester, Cheshire CH3 9EX Tel: 01829 772000 Registered in England 3110403 Vat No: GB 618 374134
Dear Robert Mortimer,
In message 1259520402.588.1292850598306.JavaMail.root@mailserver.xen.bluechiptechnology.co.uk you wrote:
I am porting a board similar to the Beagle to U-Boot. The Beagle config works but needs further pin MUXing . I have copied the Beagle board config to a new name and when compiled the binary performs as per the Beale one. My issue is when I change the li ne
Please make sure to use a line lenght of some 70 characters or less.
You are not supposed to mess with exsiting boards. Please create your own board config instead.
Is this an officially registered machine type? I can't find it.
You are not supposed to do that. Please register your board at the ARM machine registry, and when the ID has become available in the Linux tree, then submit an update request for mach-types.h here.
Please register your board.
Robert Mortimer
