[U-Boot] [PATCH 01/10][v6] rsa: Split the rsa-verify to separate the modular exponentiation
Public exponentiation which is required in rsa verify functionality is tightly integrated with verification code in rsa_verify.c. The patch splits the file into twp separating the modular exponentiation.
1. rsa-verify.c - The file parses device tree keys node to fill a keyprop structure. The keyprop structure can then be converted to implementation specific format. (struct rsa_pub_key for sw implementation) - The parsed device tree node is then passed to a generic rsa_mod_exp function.
2. rsa-mod-exp.c Move the software specific functions related to modular exponentiation from rsa-verify.c to this file.
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com CC: Simon Glass sjg@chromium.org --- Changes in v6: No changes
Changes in v5: Reverted change in rsa_mod_exp_sw function to add pointer to output length Addressed other comments by Simon
Changes in v4: Modified rsa_mod_exp_sw function to add pointer to output length
Changes in v3: Kconfig moved to separate patch. This patch just splits the file now
Changes in v2: Addressed few of Simon Glass's comments: - Kconfig option added for RSA - Comments added for new keyprop struct
include/u-boot/rsa-mod-exp.h | 43 ++++++ lib/rsa/Makefile | 2 +- lib/rsa/rsa-mod-exp.c | 303 +++++++++++++++++++++++++++++++++++++++ lib/rsa/rsa-verify.c | 329 ++++++++----------------------------------- tools/Makefile | 3 +- 5 files changed, 404 insertions(+), 276 deletions(-) create mode 100644 include/u-boot/rsa-mod-exp.h create mode 100644 lib/rsa/rsa-mod-exp.c
diff --git a/include/u-boot/rsa-mod-exp.h b/include/u-boot/rsa-mod-exp.h new file mode 100644 index 0000000..59cd9ea --- /dev/null +++ b/include/u-boot/rsa-mod-exp.h @@ -0,0 +1,43 @@ +/* + * Copyright (c) 2014, Ruchika Gupta. + * + * SPDX-License-Identifier: GPL-2.0+ +*/ + +#ifndef _RSA_MOD_EXP_H +#define _RSA_MOD_EXP_H + +#include <errno.h> +#include <image.h> + +/** + * struct key_prop - holder for a public key properties + * + * The struct has pointers to modulus (Typically called N), + * The inverse, R^2, exponent. These can be typecasted and + * used as byte arrays or converted to the required format + * as per requirement of RSA implementation. + */ +struct key_prop { + const void *rr; /* R^2 can be treated as byte array */ + const void *modulus; /* modulus as byte array */ + const void *public_exponent; /* public exponent as byte array */ + uint32_t n0inv; /* -1 / modulus[0] mod 2^32 */ + int num_bits; /* Key length in bits */ + uint32_t exp_len; /* Exponent length in number of uint8_t */ +}; + +/** + * rsa_mod_exp_sw() - Perform RSA Modular Exponentiation in sw + * + * Operation: out[] = sig ^ exponent % modulus + * + * @sig: RSA PKCS1.5 signature + * @sig_len: Length of signature in number of bytes + * @node: Node with RSA key elements like modulus, exponent, R^2, n0inv + * @out: Result in form of byte array + */ +int rsa_mod_exp_sw(const uint8_t *sig, uint32_t sig_len, + struct key_prop *node, uint8_t *out); + +#endif diff --git a/lib/rsa/Makefile b/lib/rsa/Makefile index a5a96cb6..cc25b3c 100644 --- a/lib/rsa/Makefile +++ b/lib/rsa/Makefile @@ -7,4 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_FIT_SIGNATURE) += rsa-verify.o rsa-checksum.o +obj-$(CONFIG_FIT_SIGNATURE) += rsa-verify.o rsa-checksum.o rsa-mod-exp.o diff --git a/lib/rsa/rsa-mod-exp.c b/lib/rsa/rsa-mod-exp.c new file mode 100644 index 0000000..4a6de2b --- /dev/null +++ b/lib/rsa/rsa-mod-exp.c @@ -0,0 +1,303 @@ +/* + * Copyright (c) 2013, Google Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef USE_HOSTCC +#include <common.h> +#include <fdtdec.h> +#include <asm/types.h> +#include <asm/byteorder.h> +#include <asm/errno.h> +#include <asm/types.h> +#include <asm/unaligned.h> +#else +#include "fdt_host.h" +#include "mkimage.h" +#include <fdt_support.h> +#endif +#include <u-boot/rsa.h> +#include <u-boot/rsa-mod-exp.h> + +#define UINT64_MULT32(v, multby) (((uint64_t)(v)) * ((uint32_t)(multby))) + +#define get_unaligned_be32(a) fdt32_to_cpu(*(uint32_t *)a) +#define put_unaligned_be32(a, b) (*(uint32_t *)(b) = cpu_to_fdt32(a)) + +/* Default public exponent for backward compatibility */ +#define RSA_DEFAULT_PUBEXP 65537 + +/** + * subtract_modulus() - subtract modulus from the given value + * + * @key: Key containing modulus to subtract + * @num: Number to subtract modulus from, as little endian word array + */ +static void subtract_modulus(const struct rsa_public_key *key, uint32_t num[]) +{ + int64_t acc = 0; + uint i; + + for (i = 0; i < key->len; i++) { + acc += (uint64_t)num[i] - key->modulus[i]; + num[i] = (uint32_t)acc; + acc >>= 32; + } +} + +/** + * greater_equal_modulus() - check if a value is >= modulus + * + * @key: Key containing modulus to check + * @num: Number to check against modulus, as little endian word array + * @return 0 if num < modulus, 1 if num >= modulus + */ +static int greater_equal_modulus(const struct rsa_public_key *key, + uint32_t num[]) +{ + int i; + + for (i = (int)key->len - 1; i >= 0; i--) { + if (num[i] < key->modulus[i]) + return 0; + if (num[i] > key->modulus[i]) + return 1; + } + + return 1; /* equal */ +} + +/** + * montgomery_mul_add_step() - Perform montgomery multiply-add step + * + * Operation: montgomery result[] += a * b[] / n0inv % modulus + * + * @key: RSA key + * @result: Place to put result, as little endian word array + * @a: Multiplier + * @b: Multiplicand, as little endian word array + */ +static void montgomery_mul_add_step(const struct rsa_public_key *key, + uint32_t result[], const uint32_t a, const uint32_t b[]) +{ + uint64_t acc_a, acc_b; + uint32_t d0; + uint i; + + acc_a = (uint64_t)a * b[0] + result[0]; + d0 = (uint32_t)acc_a * key->n0inv; + acc_b = (uint64_t)d0 * key->modulus[0] + (uint32_t)acc_a; + for (i = 1; i < key->len; i++) { + acc_a = (acc_a >> 32) + (uint64_t)a * b[i] + result[i]; + acc_b = (acc_b >> 32) + (uint64_t)d0 * key->modulus[i] + + (uint32_t)acc_a; + result[i - 1] = (uint32_t)acc_b; + } + + acc_a = (acc_a >> 32) + (acc_b >> 32); + + result[i - 1] = (uint32_t)acc_a; + + if (acc_a >> 32) + subtract_modulus(key, result); +} + +/** + * montgomery_mul() - Perform montgomery mutitply + * + * Operation: montgomery result[] = a[] * b[] / n0inv % modulus + * + * @key: RSA key + * @result: Place to put result, as little endian word array + * @a: Multiplier, as little endian word array + * @b: Multiplicand, as little endian word array + */ +static void montgomery_mul(const struct rsa_public_key *key, + uint32_t result[], uint32_t a[], const uint32_t b[]) +{ + uint i; + + for (i = 0; i < key->len; ++i) + result[i] = 0; + for (i = 0; i < key->len; ++i) + montgomery_mul_add_step(key, result, a[i], b); +} + +/** + * num_pub_exponent_bits() - Number of bits in the public exponent + * + * @key: RSA key + * @num_bits: Storage for the number of public exponent bits + */ +static int num_public_exponent_bits(const struct rsa_public_key *key, + int *num_bits) +{ + uint64_t exponent; + int exponent_bits; + const uint max_bits = (sizeof(exponent) * 8); + + exponent = key->exponent; + exponent_bits = 0; + + if (!exponent) { + *num_bits = exponent_bits; + return 0; + } + + for (exponent_bits = 1; exponent_bits < max_bits + 1; ++exponent_bits) + if (!(exponent >>= 1)) { + *num_bits = exponent_bits; + return 0; + } + + return -EINVAL; +} + +/** + * is_public_exponent_bit_set() - Check if a bit in the public exponent is set + * + * @key: RSA key + * @pos: The bit position to check + */ +static int is_public_exponent_bit_set(const struct rsa_public_key *key, + int pos) +{ + return key->exponent & (1ULL << pos); +} + +/** + * pow_mod() - in-place public exponentiation + * + * @key: RSA key + * @inout: Big-endian word array containing value and result + */ +static int pow_mod(const struct rsa_public_key *key, uint32_t *inout) +{ + uint32_t *result, *ptr; + uint i; + int j, k; + + /* Sanity check for stack size - key->len is in 32-bit words */ + if (key->len > RSA_MAX_KEY_BITS / 32) { + debug("RSA key words %u exceeds maximum %d\n", key->len, + RSA_MAX_KEY_BITS / 32); + return -EINVAL; + } + + uint32_t val[key->len], acc[key->len], tmp[key->len]; + uint32_t a_scaled[key->len]; + result = tmp; /* Re-use location. */ + + /* Convert from big endian byte array to little endian word array. */ + for (i = 0, ptr = inout + key->len - 1; i < key->len; i++, ptr--) + val[i] = get_unaligned_be32(ptr); + + if (0 != num_public_exponent_bits(key, &k)) + return -EINVAL; + + if (k < 2) { + debug("Public exponent is too short (%d bits, minimum 2)\n", + k); + return -EINVAL; + } + + if (!is_public_exponent_bit_set(key, 0)) { + debug("LSB of RSA public exponent must be set.\n"); + return -EINVAL; + } + + /* the bit at e[k-1] is 1 by definition, so start with: C := M */ + montgomery_mul(key, acc, val, key->rr); /* acc = a * RR / R mod n */ + /* retain scaled version for intermediate use */ + memcpy(a_scaled, acc, key->len * sizeof(a_scaled[0])); + + for (j = k - 2; j > 0; --j) { + montgomery_mul(key, tmp, acc, acc); /* tmp = acc^2 / R mod n */ + + if (is_public_exponent_bit_set(key, j)) { + /* acc = tmp * val / R mod n */ + montgomery_mul(key, acc, tmp, a_scaled); + } else { + /* e[j] == 0, copy tmp back to acc for next operation */ + memcpy(acc, tmp, key->len * sizeof(acc[0])); + } + } + + /* the bit at e[0] is always 1 */ + montgomery_mul(key, tmp, acc, acc); /* tmp = acc^2 / R mod n */ + montgomery_mul(key, acc, tmp, val); /* acc = tmp * a / R mod M */ + memcpy(result, acc, key->len * sizeof(result[0])); + + /* Make sure result < mod; result is at most 1x mod too large. */ + if (greater_equal_modulus(key, result)) + subtract_modulus(key, result); + + /* Convert to bigendian byte array */ + for (i = key->len - 1, ptr = inout; (int)i >= 0; i--, ptr++) + put_unaligned_be32(result[i], ptr); + return 0; +} + +static void rsa_convert_big_endian(uint32_t *dst, const uint32_t *src, int len) +{ + int i; + + for (i = 0; i < len; i++) + dst[i] = fdt32_to_cpu(src[len - 1 - i]); +} + +int rsa_mod_exp_sw(const uint8_t *sig, uint32_t sig_len, + struct key_prop *prop, uint8_t *out) +{ + struct rsa_public_key key; + int ret; + + if (!prop) { + debug("%s: Skipping invalid prop", __func__); + return -EBADF; + } + key.n0inv = prop->n0inv; + key.len = prop->num_bits; + + if (!prop->public_exponent) + key.exponent = RSA_DEFAULT_PUBEXP; + else + key.exponent = + fdt64_to_cpu(*((uint64_t *)(prop->public_exponent))); + + if (!key.len || !prop->modulus || !prop->rr) { + debug("%s: Missing RSA key info", __func__); + return -EFAULT; + } + + /* Sanity check for stack size */ + if (key.len > RSA_MAX_KEY_BITS || key.len < RSA_MIN_KEY_BITS) { + debug("RSA key bits %u outside allowed range %d..%d\n", + key.len, RSA_MIN_KEY_BITS, RSA_MAX_KEY_BITS); + return -EFAULT; + } + key.len /= sizeof(uint32_t) * 8; + uint32_t key1[key.len], key2[key.len]; + + key.modulus = key1; + key.rr = key2; + rsa_convert_big_endian(key.modulus, (uint32_t *)prop->modulus, key.len); + rsa_convert_big_endian(key.rr, (uint32_t *)prop->rr, key.len); + if (!key.modulus || !key.rr) { + debug("%s: Out of memory", __func__); + return -ENOMEM; + } + + uint32_t buf[sig_len / sizeof(uint32_t)]; + + memcpy(buf, sig, sig_len); + + ret = pow_mod(&key, buf); + if (ret) + return ret; + + memcpy(out, buf, sig_len); + + return 0; +} diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index 4ef19b6..f8bc086 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -17,230 +17,26 @@ #include "mkimage.h" #include <fdt_support.h> #endif +#include <u-boot/rsa-mod-exp.h> #include <u-boot/rsa.h> -#include <u-boot/sha1.h> -#include <u-boot/sha256.h> - -#define UINT64_MULT32(v, multby) (((uint64_t)(v)) * ((uint32_t)(multby))) - -#define get_unaligned_be32(a) fdt32_to_cpu(*(uint32_t *)a) -#define put_unaligned_be32(a, b) (*(uint32_t *)(b) = cpu_to_fdt32(a))
/* Default public exponent for backward compatibility */ #define RSA_DEFAULT_PUBEXP 65537
/** - * subtract_modulus() - subtract modulus from the given value - * - * @key: Key containing modulus to subtract - * @num: Number to subtract modulus from, as little endian word array - */ -static void subtract_modulus(const struct rsa_public_key *key, uint32_t num[]) -{ - int64_t acc = 0; - uint i; - - for (i = 0; i < key->len; i++) { - acc += (uint64_t)num[i] - key->modulus[i]; - num[i] = (uint32_t)acc; - acc >>= 32; - } -} - -/** - * greater_equal_modulus() - check if a value is >= modulus - * - * @key: Key containing modulus to check - * @num: Number to check against modulus, as little endian word array - * @return 0 if num < modulus, 1 if num >= modulus - */ -static int greater_equal_modulus(const struct rsa_public_key *key, - uint32_t num[]) -{ - int i; - - for (i = (int)key->len - 1; i >= 0; i--) { - if (num[i] < key->modulus[i]) - return 0; - if (num[i] > key->modulus[i]) - return 1; - } - - return 1; /* equal */ -} - -/** - * montgomery_mul_add_step() - Perform montgomery multiply-add step - * - * Operation: montgomery result[] += a * b[] / n0inv % modulus + * rsa_verify_key() - Verify a signature against some data using RSA Key * - * @key: RSA key - * @result: Place to put result, as little endian word array - * @a: Multiplier - * @b: Multiplicand, as little endian word array - */ -static void montgomery_mul_add_step(const struct rsa_public_key *key, - uint32_t result[], const uint32_t a, const uint32_t b[]) -{ - uint64_t acc_a, acc_b; - uint32_t d0; - uint i; - - acc_a = (uint64_t)a * b[0] + result[0]; - d0 = (uint32_t)acc_a * key->n0inv; - acc_b = (uint64_t)d0 * key->modulus[0] + (uint32_t)acc_a; - for (i = 1; i < key->len; i++) { - acc_a = (acc_a >> 32) + (uint64_t)a * b[i] + result[i]; - acc_b = (acc_b >> 32) + (uint64_t)d0 * key->modulus[i] + - (uint32_t)acc_a; - result[i - 1] = (uint32_t)acc_b; - } - - acc_a = (acc_a >> 32) + (acc_b >> 32); - - result[i - 1] = (uint32_t)acc_a; - - if (acc_a >> 32) - subtract_modulus(key, result); -} - -/** - * montgomery_mul() - Perform montgomery mutitply - * - * Operation: montgomery result[] = a[] * b[] / n0inv % modulus - * - * @key: RSA key - * @result: Place to put result, as little endian word array - * @a: Multiplier, as little endian word array - * @b: Multiplicand, as little endian word array - */ -static void montgomery_mul(const struct rsa_public_key *key, - uint32_t result[], uint32_t a[], const uint32_t b[]) -{ - uint i; - - for (i = 0; i < key->len; ++i) - result[i] = 0; - for (i = 0; i < key->len; ++i) - montgomery_mul_add_step(key, result, a[i], b); -} - -/** - * num_pub_exponent_bits() - Number of bits in the public exponent - * - * @key: RSA key - * @num_bits: Storage for the number of public exponent bits - */ -static int num_public_exponent_bits(const struct rsa_public_key *key, - int *num_bits) -{ - uint64_t exponent; - int exponent_bits; - const uint max_bits = (sizeof(exponent) * 8); - - exponent = key->exponent; - exponent_bits = 0; - - if (!exponent) { - *num_bits = exponent_bits; - return 0; - } - - for (exponent_bits = 1; exponent_bits < max_bits + 1; ++exponent_bits) - if (!(exponent >>= 1)) { - *num_bits = exponent_bits; - return 0; - } - - return -EINVAL; -} - -/** - * is_public_exponent_bit_set() - Check if a bit in the public exponent is set - * - * @key: RSA key - * @pos: The bit position to check - */ -static int is_public_exponent_bit_set(const struct rsa_public_key *key, - int pos) -{ - return key->exponent & (1ULL << pos); -} - -/** - * pow_mod() - in-place public exponentiation + * Verify a RSA PKCS1.5 signature against an expected hash using + * the RSA Key properties in prop structure. * - * @key: RSA key - * @inout: Big-endian word array containing value and result + * @prop: Specifies key + * @sig: Signature + * @sig_len: Number of bytes in signature + * @hash: Pointer to the expected hash + * @algo: Checksum algo structure having information on RSA padding etc. + * @return 0 if verified, -ve on error */ -static int pow_mod(const struct rsa_public_key *key, uint32_t *inout) -{ - uint32_t *result, *ptr; - uint i; - int j, k; - - /* Sanity check for stack size - key->len is in 32-bit words */ - if (key->len > RSA_MAX_KEY_BITS / 32) { - debug("RSA key words %u exceeds maximum %d\n", key->len, - RSA_MAX_KEY_BITS / 32); - return -EINVAL; - } - - uint32_t val[key->len], acc[key->len], tmp[key->len]; - uint32_t a_scaled[key->len]; - result = tmp; /* Re-use location. */ - - /* Convert from big endian byte array to little endian word array. */ - for (i = 0, ptr = inout + key->len - 1; i < key->len; i++, ptr--) - val[i] = get_unaligned_be32(ptr); - - if (0 != num_public_exponent_bits(key, &k)) - return -EINVAL; - - if (k < 2) { - debug("Public exponent is too short (%d bits, minimum 2)\n", - k); - return -EINVAL; - } - - if (!is_public_exponent_bit_set(key, 0)) { - debug("LSB of RSA public exponent must be set.\n"); - return -EINVAL; - } - - /* the bit at e[k-1] is 1 by definition, so start with: C := M */ - montgomery_mul(key, acc, val, key->rr); /* acc = a * RR / R mod n */ - /* retain scaled version for intermediate use */ - memcpy(a_scaled, acc, key->len * sizeof(a_scaled[0])); - - for (j = k - 2; j > 0; --j) { - montgomery_mul(key, tmp, acc, acc); /* tmp = acc^2 / R mod n */ - - if (is_public_exponent_bit_set(key, j)) { - /* acc = tmp * val / R mod n */ - montgomery_mul(key, acc, tmp, a_scaled); - } else { - /* e[j] == 0, copy tmp back to acc for next operation */ - memcpy(acc, tmp, key->len * sizeof(acc[0])); - } - } - - /* the bit at e[0] is always 1 */ - montgomery_mul(key, tmp, acc, acc); /* tmp = acc^2 / R mod n */ - montgomery_mul(key, acc, tmp, val); /* acc = tmp * a / R mod M */ - memcpy(result, acc, key->len * sizeof(result[0])); - - /* Make sure result < mod; result is at most 1x mod too large. */ - if (greater_equal_modulus(key, result)) - subtract_modulus(key, result); - - /* Convert to bigendian byte array */ - for (i = key->len - 1, ptr = inout; (int)i >= 0; i--, ptr++) - put_unaligned_be32(result[i], ptr); - return 0; -} - -static int rsa_verify_key(const struct rsa_public_key *key, const uint8_t *sig, +static int rsa_verify_key(struct key_prop *prop, const uint8_t *sig, const uint32_t sig_len, const uint8_t *hash, struct checksum_algo *algo) { @@ -248,10 +44,10 @@ static int rsa_verify_key(const struct rsa_public_key *key, const uint8_t *sig, int pad_len; int ret;
- if (!key || !sig || !hash || !algo) + if (!prop || !sig || !hash || !algo) return -EIO;
- if (sig_len != (key->len * sizeof(uint32_t))) { + if (sig_len != (prop->num_bits / 8)) { debug("Signature is of incorrect length %d\n", sig_len); return -EINVAL; } @@ -265,13 +61,13 @@ static int rsa_verify_key(const struct rsa_public_key *key, const uint8_t *sig, return -EINVAL; }
- uint32_t buf[sig_len / sizeof(uint32_t)]; - - memcpy(buf, sig, sig_len); + uint8_t buf[sig_len];
- ret = pow_mod(key, buf); - if (ret) + ret = rsa_mod_exp_sw(sig, sig_len, prop, buf); + if (ret) { + debug("Error in Modular exponentation\n"); return ret; + }
padding = algo->rsa_padding; pad_len = algo->pad_len - algo->checksum_len; @@ -291,72 +87,57 @@ static int rsa_verify_key(const struct rsa_public_key *key, const uint8_t *sig, return 0; }
-static void rsa_convert_big_endian(uint32_t *dst, const uint32_t *src, int len) -{ - int i; - - for (i = 0; i < len; i++) - dst[i] = fdt32_to_cpu(src[len - 1 - i]); -} - +/** + * rsa_verify_with_keynode() - Verify a signature against some data using + * information in node with prperties of RSA Key like modulus, exponent etc. + * + * Parse sign-node and fill a key_prop structure with properties of the + * key. Verify a RSA PKCS1.5 signature against an expected hash using + * the properties parsed + * + * @info: Specifies key and FIT information + * @hash: Pointer to the expected hash + * @sig: Signature + * @sig_len: Number of bytes in signature + * @node: Node having the RSA Key properties + * @return 0 if verified, -ve on error + */ static int rsa_verify_with_keynode(struct image_sign_info *info, - const void *hash, uint8_t *sig, uint sig_len, int node) + const void *hash, uint8_t *sig, + uint sig_len, int node) { const void *blob = info->fdt_blob; - struct rsa_public_key key; - const void *modulus, *rr; - const uint64_t *public_exponent; + struct key_prop prop; int length; - int ret; + int ret = 0;
if (node < 0) { debug("%s: Skipping invalid node", __func__); return -EBADF; } - if (!fdt_getprop(blob, node, "rsa,n0-inverse", NULL)) { - debug("%s: Missing rsa,n0-inverse", __func__); - return -EFAULT; - } - key.len = fdtdec_get_int(blob, node, "rsa,num-bits", 0); - key.n0inv = fdtdec_get_int(blob, node, "rsa,n0-inverse", 0); - public_exponent = fdt_getprop(blob, node, "rsa,exponent", &length); - if (!public_exponent || length < sizeof(*public_exponent)) - key.exponent = RSA_DEFAULT_PUBEXP; - else - key.exponent = fdt64_to_cpu(*public_exponent); - modulus = fdt_getprop(blob, node, "rsa,modulus", NULL); - rr = fdt_getprop(blob, node, "rsa,r-squared", NULL); - if (!key.len || !modulus || !rr) { - debug("%s: Missing RSA key info", __func__); - return -EFAULT; - }
- /* Sanity check for stack size */ - if (key.len > RSA_MAX_KEY_BITS || key.len < RSA_MIN_KEY_BITS) { - debug("RSA key bits %u outside allowed range %d..%d\n", - key.len, RSA_MIN_KEY_BITS, RSA_MAX_KEY_BITS); + prop.num_bits = fdtdec_get_int(blob, node, "rsa,num-bits", 0); + + prop.n0inv = fdtdec_get_int(blob, node, "rsa,n0-inverse", 0); + + prop.public_exponent = fdt_getprop(blob, node, "rsa,exponent", &length); + if (!prop.public_exponent || length < sizeof(uint64_t)) + prop.public_exponent = NULL; + + prop.exp_len = sizeof(uint64_t); + + prop.modulus = fdt_getprop(blob, node, "rsa,modulus", NULL); + + prop.rr = fdt_getprop(blob, node, "rsa,r-squared", NULL); + + if (!prop.num_bits || !prop.modulus) { + debug("%s: Missing RSA key info", __func__); return -EFAULT; } - key.len /= sizeof(uint32_t) * 8; - uint32_t key1[key.len], key2[key.len]; - - key.modulus = key1; - key.rr = key2; - rsa_convert_big_endian(key.modulus, modulus, key.len); - rsa_convert_big_endian(key.rr, rr, key.len); - if (!key.modulus || !key.rr) { - debug("%s: Out of memory", __func__); - return -ENOMEM; - }
- debug("key length %d\n", key.len); - ret = rsa_verify_key(&key, sig, sig_len, hash, info->algo->checksum); - if (ret) { - printf("%s: RSA failed to verify: %d\n", __func__, ret); - return ret; - } + ret = rsa_verify_key(&prop, sig, sig_len, hash, info->algo->checksum);
- return 0; + return ret; }
int rsa_verify(struct image_sign_info *info, diff --git a/tools/Makefile b/tools/Makefile index e549f8e..46b90b2 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -60,7 +60,8 @@ FIT_SIG_OBJS-$(CONFIG_FIT_SIGNATURE) := common/image-sig.o LIBFDT_OBJS := $(addprefix lib/libfdt/, \ fdt.o fdt_ro.o fdt_rw.o fdt_strerror.o fdt_wip.o) RSA_OBJS-$(CONFIG_FIT_SIGNATURE) := $(addprefix lib/rsa/, \ - rsa-sign.o rsa-verify.o rsa-checksum.o) + rsa-sign.o rsa-verify.o rsa-checksum.o \ + rsa-mod-exp.o)
# common objs for dumpimage and mkimage dumpimage-mkimage-objs := aisimage.o \
For FIT signature based approach to work, RSA library needs to be selected. The FIT_SIGNATURE option in Kconfig is modified to automatically select RSA. Selecting RSA compiles the RSA library required for image verification.
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com CC: Simon Glass sjg@chromium.org Acked-by: Simon Glass sjg@chromium.org --- Changes in v6: No Changes
Changes in v5: Word wrapping in commit Added space after .
Changes in v4: Expanded CONFIG_RSA with documentation link
Changes in v3: New patch created for adding Kconfig option for FIT signature
Kconfig | 3 ++- lib/Kconfig | 7 +++++++ 2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/Kconfig b/Kconfig index 4157da3..fed488f 100644 --- a/Kconfig +++ b/Kconfig @@ -116,8 +116,9 @@ config FIT_VERBOSE depends on FIT
config FIT_SIGNATURE - bool "Enabel signature verification of FIT uImages" + bool "Enable signature verification of FIT uImages" depends on FIT + select RSA help This option enables signature verification of FIT uImages, using a hash signed and verified using RSA. diff --git a/lib/Kconfig b/lib/Kconfig index 8460439..79b91b7 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -27,4 +27,11 @@ config SYS_HZ get_timer() must operate in milliseconds and this option must be set to 1000.
+config RSA + bool "Use RSA Library" + help + RSA support. This enables the RSA algorithm used for FIT image + verification in U-Boot. + See doc/uImage.FIT/signature.txt for more details. + endmenu
On 23 January 2015 at 03:31, Ruchika Gupta ruchika.gupta@freescale.com wrote:
Applied to u-boot-dm, thanks!
Add a new rsa uclass for performing modular exponentiation and implement the software driver basing on this uclass.
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com CC: Simon Glass sjg@chromium.org --- Changes in v6: No Changes
Changes in v5: Changed UCLASS name to UCLASS_MOD_EXP
Changes in v4: Removed Kconfig option for DM_RSA Corrected driver name for sw rsa driver Updated the rsa_mod_exp operation to have output length
Changes in v3: New patch with driver model for RSA UCLASS
drivers/crypto/Makefile | 1 + drivers/crypto/rsa_mod_exp/Kconfig | 5 ++++ drivers/crypto/rsa_mod_exp/Makefile | 7 ++++++ drivers/crypto/rsa_mod_exp/mod_exp_sw.c | 39 +++++++++++++++++++++++++++++ drivers/crypto/rsa_mod_exp/mod_exp_uclass.c | 31 +++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/u-boot/rsa-mod-exp.h | 34 ++++++++++++++++++++++++- 7 files changed, 117 insertions(+), 1 deletion(-) create mode 100644 drivers/crypto/rsa_mod_exp/Kconfig create mode 100644 drivers/crypto/rsa_mod_exp/Makefile create mode 100644 drivers/crypto/rsa_mod_exp/mod_exp_sw.c create mode 100644 drivers/crypto/rsa_mod_exp/mod_exp_uclass.c
diff --git a/drivers/crypto/Makefile b/drivers/crypto/Makefile index 7b79237..fb8c10b 100644 --- a/drivers/crypto/Makefile +++ b/drivers/crypto/Makefile @@ -6,4 +6,5 @@ #
obj-$(CONFIG_EXYNOS_ACE_SHA) += ace_sha.o +obj-y += rsa_mod_exp/ obj-y += fsl/ diff --git a/drivers/crypto/rsa_mod_exp/Kconfig b/drivers/crypto/rsa_mod_exp/Kconfig new file mode 100644 index 0000000..6dcb39a --- /dev/null +++ b/drivers/crypto/rsa_mod_exp/Kconfig @@ -0,0 +1,5 @@ +config DM_MOD_EXP + bool "Enable Driver Model for RSA Modular Exponentiation" + depends on DM + help + If you want to use driver model for RSA Modular Exponentiation, say Y. diff --git a/drivers/crypto/rsa_mod_exp/Makefile b/drivers/crypto/rsa_mod_exp/Makefile new file mode 100644 index 0000000..915b751 --- /dev/null +++ b/drivers/crypto/rsa_mod_exp/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2014 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_RSA) += mod_exp_uclass.o mod_exp_sw.o diff --git a/drivers/crypto/rsa_mod_exp/mod_exp_sw.c b/drivers/crypto/rsa_mod_exp/mod_exp_sw.c new file mode 100644 index 0000000..dc6c064 --- /dev/null +++ b/drivers/crypto/rsa_mod_exp/mod_exp_sw.c @@ -0,0 +1,39 @@ +/* + * (C) Copyright 2014 Freescale Semiconductor, Inc. + * Author: Ruchika Gupta ruchika.gupta@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> +#include <dm.h> +#include <u-boot/rsa-mod-exp.h> + +int mod_exp_sw(struct udevice *dev, const uint8_t *sig, uint32_t sig_len, + struct key_prop *prop, uint8_t *out) +{ + int ret = 0; + + ret = rsa_mod_exp_sw(sig, sig_len, prop, out); + if (ret) { + debug("%s: RSA failed to verify: %d\n", __func__, ret); + return ret; + } + + return 0; +} + +static const struct mod_exp_ops mod_exp_ops_sw = { + .mod_exp = mod_exp_sw, +}; + +U_BOOT_DRIVER(mod_exp_sw) = { + .name = "mod_exp_sw", + .id = UCLASS_MOD_EXP, + .ops = &mod_exp_ops_sw, +}; + +U_BOOT_DEVICE(mod_exp_sw) = { + .name = "mod_exp_sw", +}; diff --git a/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c b/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c new file mode 100644 index 0000000..266f094 --- /dev/null +++ b/drivers/crypto/rsa_mod_exp/mod_exp_uclass.c @@ -0,0 +1,31 @@ +/* + * (C) Copyright 2014 Freescale Semiconductor, Inc + * Author: Ruchika Gupta ruchika.gupta@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <u-boot/rsa-mod-exp.h> +#include <errno.h> +#include <fdtdec.h> +#include <malloc.h> +#include <asm/io.h> +#include <linux/list.h> + +int rsa_mod_exp(struct udevice *dev, const uint8_t *sig, uint32_t sig_len, + struct key_prop *node, uint8_t *out) +{ + const struct mod_exp_ops *ops = device_get_ops(dev); + + if (!ops->mod_exp) + return -ENOSYS; + + return ops->mod_exp(dev, sig, sig_len, node, out); +} + +UCLASS_DRIVER(mod_exp) = { + .id = UCLASS_MOD_EXP, + .name = "rsa_mod_exp", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index f17c3c2..91bb90d 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -33,6 +33,7 @@ enum uclass_id { UCLASS_I2C, /* I2C bus */ UCLASS_I2C_GENERIC, /* Generic I2C device */ UCLASS_I2C_EEPROM, /* I2C EEPROM device */ + UCLASS_MOD_EXP, /* RSA Mod Exp device */
UCLASS_COUNT, UCLASS_INVALID = -1, diff --git a/include/u-boot/rsa-mod-exp.h b/include/u-boot/rsa-mod-exp.h index 59cd9ea..fce445a 100644 --- a/include/u-boot/rsa-mod-exp.h +++ b/include/u-boot/rsa-mod-exp.h @@ -35,9 +35,41 @@ struct key_prop { * @sig: RSA PKCS1.5 signature * @sig_len: Length of signature in number of bytes * @node: Node with RSA key elements like modulus, exponent, R^2, n0inv - * @out: Result in form of byte array + * @out: Result in form of byte array of len equal to sig_len */ int rsa_mod_exp_sw(const uint8_t *sig, uint32_t sig_len, struct key_prop *node, uint8_t *out);
+int rsa_mod_exp(struct udevice *dev, const uint8_t *sig, uint32_t sig_len, + struct key_prop *node, uint8_t *out); + +/** + * struct struct mod_exp_ops - Driver model for RSA Modular Exponentiation + * operations + * + * The uclass interface is implemented by all crypto devices which use + * driver model. + */ +struct mod_exp_ops { + /** + * Perform Modular Exponentiation + * + * Operation: out[] = sig ^ exponent % modulus + * + * @dev: RSA Device + * @sig: RSA PKCS1.5 signature + * @sig_len: Length of signature in number of bytes + * @node: Node with RSA key elements like modulus, exponent, + * R^2, n0inv + * @out: Result in form of byte array of len equal to sig_len + * + * This function computes exponentiation over the signature. + * Returns: 0 if exponentiation is successful, or a negative value + * if it wasn't. + */ + int (*mod_exp)(struct udevice *dev, const uint8_t *sig, + uint32_t sig_len, struct key_prop *node, + uint8_t *outp); +}; + #endif
Hi Ruchika,
Just in case there is a v7:
- (C) Copyright 2014 Freescale Semiconductor, Inc
- Author: Ruchika Gupta ruchika.gupta@freescale.com
You can trim headers here.
Hi Ruchika,
On 26 January 2015 at 06:39, Simon Glass sjg@chromium.org wrote:
Hi Ruchika,
There are a few nits I mentioned in your patches.
To avoid further delay and testing I would like to pick these patches up as is, but if you like you could send a follow-on patch.
On 26 January 2015 at 06:41, Simon Glass sjg@chromium.org wrote:
Hi Ruchika,
Hi Ruchika,
For the platforms which use,CONFIG_FIT_SIGNATURE, the required configs are moved to the platform's defconfig file. Selecting CONFIG_FIT_SIGNATURE using defconfig automatically resolves the dependencies for signature verification. The RSA library gets automatically selected and user does not have to define CONFIG_RSA manually.
Changes in v5: No changes
Changes in v4: No changes
configs/ids8313_defconfig | 2 ++ configs/sandbox_defconfig | 3 +++ configs/zynq_microzed_defconfig | 3 +++ configs/zynq_zc70x_defconfig | 3 +++ configs/zynq_zc770_xm010_defconfig | 3 +++ configs/zynq_zc770_xm012_defconfig | 3 +++ configs/zynq_zc770_xm013_defconfig | 3 +++ configs/zynq_zed_defconfig | 3 +++ configs/zynq_zybo_defconfig | 3 +++ include/configs/am335x_evm.h | 4 ++-- include/configs/ids8313.h | 3 --- include/configs/sandbox.h | 3 --- include/configs/zynq-common.h | 6 ------ 13 files changed, 28 insertions(+), 14 deletions(-)
diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 1c665aa..8479cd4 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -1,4 +1,6 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xFFF00000" CONFIG_PPC=y CONFIG_MPC83xx=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y CONFIG_TARGET_IDS8313=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 47d8400..0111f25 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -1,3 +1,6 @@ CONFIG_OF_CONTROL=y CONFIG_OF_HOSTFILE=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y CONFIG_DEFAULT_DEVICE_TREE="sandbox" diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index 9588849..b9a6fe5 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -3,4 +3,7 @@ CONFIG_SPL=y +S:CONFIG_ZYNQ=y +S:CONFIG_TARGET_ZYNQ_MICROZED=y CONFIG_OF_CONTROL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y CONFIG_DEFAULT_DEVICE_TREE="zynq-microzed" diff --git a/configs/zynq_zc70x_defconfig b/configs/zynq_zc70x_defconfig index cf50730..dc8aa84 100644 --- a/configs/zynq_zc70x_defconfig +++ b/configs/zynq_zc70x_defconfig @@ -4,3 +4,6 @@ CONFIG_SPL=y +S:CONFIG_TARGET_ZYNQ_ZC70X=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zc702" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 8bb405d..2f5fa8c 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -5,3 +5,6 @@ CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM010" +S:CONFIG_TARGET_ZYNQ_ZC770=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm010" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 0ba5da5..a92d495 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -5,3 +5,6 @@ CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM012" +S:CONFIG_TARGET_ZYNQ_ZC770=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm012" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 13f8112..3a02f75 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -5,3 +5,6 @@ CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM013" +S:CONFIG_TARGET_ZYNQ_ZC770=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm013" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index eb057fa..1d816f6 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -4,3 +4,6 @@ CONFIG_SPL=y +S:CONFIG_TARGET_ZYNQ_ZED=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zed" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 12311cd..9183629 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -4,3 +4,6 @@ CONFIG_SPL=y +S:CONFIG_TARGET_ZYNQ_ZYBO=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="zynq-zybo" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 0004750..f9bc23b 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -23,8 +23,8 @@ # define CONFIG_TIMESTAMP # define CONFIG_LZO # ifdef CONFIG_ENABLE_VBOOT -# define CONFIG_FIT_SIGNATURE -# define CONFIG_RSA +# define CONFIG_FIT_SIGNATURE +# define CONFIG_RSA # endif #endif
diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index f084834..2384864 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -575,12 +575,9 @@
#define CONFIG_VERSION_VARIABLE
-#define CONFIG_FIT -#define CONFIG_FIT_SIGNATURE #define CONFIG_IMAGE_FORMAT_LEGACY #define CONFIG_CMD_FDT #define CONFIG_CMD_HASH -#define CONFIG_RSA #define CONFIG_SHA1 #define CONFIG_SHA256
diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 657f751..6fd29b9 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -41,9 +41,6 @@
#define CONFIG_OF_LIBFDT #define CONFIG_LMB -#define CONFIG_FIT -#define CONFIG_FIT_SIGNATURE -#define CONFIG_RSA #define CONFIG_CMD_FDT #define CONFIG_ANDROID_BOOT_IMAGE
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 87b4fff..3894517 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -219,17 +219,11 @@ #define CONFIG_OF_LIBFDT
/* FIT support */ -#define CONFIG_FIT -#define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ #define CONFIG_IMAGE_FORMAT_LEGACY /* enable also legacy image format */
/* FDT support */ #define CONFIG_DISPLAY_BOARDINFO_LATE
-/* RSA support */ -#define CONFIG_FIT_SIGNATURE -#define CONFIG_RSA - /* Extend size of kernel image for uncompression */ #define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024)
Modify rsa_verify to use the rsa driver of DM library .The tools will continue to use the same RSA sw library.
CONFIG_RSA is now dependent on CONFIG_DM. All configurations which enable FIT based signatures have been modified to enable CONFIG_DM by default.
Changes in v5: Added signature option in am335x_boneblack_vboot_defconfig Made changes in rsa-verify.c as suggested by Simon
Changes in v4: Make CONFIG_RSA always depenedent on Driver Model. Add CONFIG_DM in defconfigs of the platforms which enable CONFIG_FIT_SIGNATURE
README | 7 ++++++- configs/am335x_boneblack_vboot_defconfig | 4 ++++ configs/ids8313_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_zc70x_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + include/configs/am335x_evm.h | 6 ++---- include/configs/sandbox.h | 1 - lib/rsa/rsa-verify.c | 14 ++++++++++++++ 14 files changed, 35 insertions(+), 6 deletions(-)
diff --git a/README b/README index fefa71c..cac7978 100644 --- a/README +++ b/README @@ -3176,8 +3176,13 @@ CBFS (Coreboot Filesystem) support This enables the RSA algorithm used for FIT image verification in U-Boot. See doc/uImage.FIT/signature.txt for more information.
+ The Modular Exponentiation algorithm in RSA is implemented using + driver model. So CONFIG_DM needs to be enabled by default for this + library to function. + The signing part is build into mkimage regardless of this - option. + option. The software based modular exponentiation is built into + mkimage irrespective of this option.
- bootcount support: CONFIG_BOOTCOUNT_LIMIT diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 5837a0a..51bf370 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -4,3 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT,ENABLE_VBOOT" +S:CONFIG_TARGET_AM335X_EVM=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am335x-boneblack" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y +CONFIG_DM=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 8479cd4..0950ec8 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -4,3 +4,4 @@ CONFIG_MPC83xx=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_TARGET_IDS8313=y +CONFIG_DM=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 0111f25..660063e 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -3,4 +3,5 @@ CONFIG_OF_HOSTFILE=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_DM=y CONFIG_DEFAULT_DEVICE_TREE="sandbox" diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index b9a6fe5..8b985fe 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -6,4 +6,5 @@ CONFIG_OF_CONTROL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_DM=y CONFIG_DEFAULT_DEVICE_TREE="zynq-microzed" diff --git a/configs/zynq_zc70x_defconfig b/configs/zynq_zc70x_defconfig index dc8aa84..cceb321 100644 --- a/configs/zynq_zc70x_defconfig +++ b/configs/zynq_zc70x_defconfig @@ -7,3 +7,4 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc702" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_DM=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 2f5fa8c..2935c0d 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -8,3 +8,4 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm010" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_DM=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index a92d495..0401739 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -8,3 +8,4 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm012" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_DM=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 3a02f75..a95970a 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -8,3 +8,4 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zc770-xm013" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_DM=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 1d816f6..0fbc41a 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -7,3 +7,4 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zed" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_DM=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 9183629..4e66760 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -7,3 +7,4 @@ CONFIG_DEFAULT_DEVICE_TREE="zynq-zybo" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_DM=y diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index f9bc23b..76ce7de 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -19,13 +19,11 @@ #include <configs/ti_am335x_common.h>
#ifndef CONFIG_SPL_BUILD +#ifndef CONFIG_FIT # define CONFIG_FIT +#endif # define CONFIG_TIMESTAMP # define CONFIG_LZO -# ifdef CONFIG_ENABLE_VBOOT -# define CONFIG_FIT_SIGNATURE -# define CONFIG_RSA -# endif #endif
#define CONFIG_SYS_BOOTM_LEN (16 << 20) diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 6fd29b9..e9d3f32 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -23,7 +23,6 @@
#define CONFIG_BOOTSTAGE #define CONFIG_BOOTSTAGE_REPORT -#define CONFIG_DM #define CONFIG_CMD_DEMO #define CONFIG_CMD_DM #define CONFIG_DM_DEMO diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index f8bc086..da45daf 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -12,6 +12,7 @@ #include <asm/errno.h> #include <asm/types.h> #include <asm/unaligned.h> +#include <dm.h> #else #include "fdt_host.h" #include "mkimage.h" @@ -43,6 +44,9 @@ static int rsa_verify_key(struct key_prop *prop, const uint8_t *sig, const uint8_t *padding; int pad_len; int ret; +#if !defined(USE_HOSTCC) + struct udevice *mod_exp_dev; +#endif
if (!prop || !sig || !hash || !algo) return -EIO; @@ -63,7 +67,17 @@ static int rsa_verify_key(struct key_prop *prop, const uint8_t *sig,
+#if !defined(USE_HOSTCC) + ret = uclass_get_device(UCLASS_MOD_EXP, 0, &mod_exp_dev); + if (ret) { + printf("RSA: Can't find Modular Exp implementation\n"); + return -EINVAL; + } + + ret = rsa_mod_exp(mod_exp_dev, sig, sig_len, prop, buf); +#else ret = rsa_mod_exp_sw(sig, sig_len, prop, buf); +#endif if (ret) { debug("Error in Modular exponentation\n"); return ret;
Driver added for RSA Modular Exponentiation using Freescale Hardware Accelerator CAAM. The driver uses UCLASS_MOD_EXP
Changes in v5: Reverted mod_exp not to use output length
Changes in v4: Modified for the changes in op function of rsa class mod_exp
Changes in v3: Moved to integrate with RSA UCLASS
drivers/crypto/Kconfig | 1 + drivers/crypto/fsl/Kconfig | 6 +++++ drivers/crypto/fsl/Makefile | 1 + drivers/crypto/fsl/fsl_rsa.c | 60 +++++++++++++++++++++++++++++++++++++++++++ drivers/crypto/fsl/jobdesc.c | 28 ++++++++++++++++++++ drivers/crypto/fsl/jobdesc.h | 5 ++++ drivers/crypto/fsl/rsa_caam.h | 28 ++++++++++++++++++++ 7 files changed, 129 insertions(+) create mode 100644 drivers/crypto/fsl/Kconfig create mode 100644 drivers/crypto/fsl/fsl_rsa.c create mode 100644 drivers/crypto/fsl/rsa_caam.h
diff --git a/drivers/crypto/Kconfig b/drivers/crypto/Kconfig index e69de29..bd26a2b 100644 --- a/drivers/crypto/Kconfig +++ b/drivers/crypto/Kconfig @@ -0,0 +1 @@ +source drivers/crypto/fsl/Kconfig diff --git a/drivers/crypto/fsl/Kconfig b/drivers/crypto/fsl/Kconfig new file mode 100644 index 0000000..86b2f2f --- /dev/null +++ b/drivers/crypto/fsl/Kconfig @@ -0,0 +1,6 @@ +config FSL_CAAM + bool "Freescale Crypto Driver Support" + help + Enables the Freescale's Cryptographic Accelerator and Assurance + Module (CAAM), also known as the SEC version 4 (SEC4). The driver uses + Job Ring as interface to communicate with CAAM. diff --git a/drivers/crypto/fsl/Makefile b/drivers/crypto/fsl/Makefile index cb13d2e..db3c010 100644 --- a/drivers/crypto/fsl/Makefile +++ b/drivers/crypto/fsl/Makefile @@ -8,3 +8,4 @@
obj-$(CONFIG_FSL_CAAM) += jr.o fsl_hash.o jobdesc.o error.o obj-$(CONFIG_CMD_BLOB) += fsl_blob.o +obj-$(CONFIG_RSA_FREESCALE_EXP) += fsl_rsa.o diff --git a/drivers/crypto/fsl/fsl_rsa.c b/drivers/crypto/fsl/fsl_rsa.c new file mode 100644 index 0000000..cf1c4c1 --- /dev/null +++ b/drivers/crypto/fsl/fsl_rsa.c @@ -0,0 +1,60 @@ +/* + * (C) Copyright 2014 Freescale Semiconductor, Inc. + * Author: Ruchika Gupta ruchika.gupta@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> +#include <dm.h> +#include <asm/types.h> +#include <malloc.h> +#include "jobdesc.h" +#include "desc.h" +#include "jr.h" +#include "rsa_caam.h" +#include <u-boot/rsa-mod-exp.h> + +int fsl_mod_exp(struct udevice *dev, const uint8_t *sig, uint32_t sig_len, + struct key_prop *prop, uint8_t *out) +{ + uint32_t keylen; + struct pk_in_params pkin; + uint32_t desc[MAX_CAAM_DESCSIZE]; + int ret; + + /* Length in bytes */ + keylen = prop->num_bits / 8; + + pkin.a = sig; + pkin.a_siz = sig_len; + pkin.n = prop->modulus; + pkin.n_siz = keylen; + pkin.e = prop->public_exponent; + pkin.e_siz = prop->exp_len; + + inline_cnstr_jobdesc_pkha_rsaexp(desc, &pkin, out, sig_len); + + ret = run_descriptor_jr(desc); + if (ret) { + debug("%s: RSA failed to verify: %d\n", __func__, ret); + return -EFAULT; + } + + return 0; +} + +static const struct mod_exp_ops fsl_mod_exp_ops = { + .mod_exp = fsl_mod_exp, +}; + +U_BOOT_DRIVER(fsl_rsa_mod_exp) = { + .name = "fsl_rsa_mod_exp", + .id = UCLASS_MOD_EXP, + .ops = &fsl_mod_exp_ops, +}; + +U_BOOT_DEVICE(fsl_rsa) = { + .name = "fsl_rsa_mod_exp", +}; diff --git a/drivers/crypto/fsl/jobdesc.c b/drivers/crypto/fsl/jobdesc.c index 1386bae..cc0dced 100644 --- a/drivers/crypto/fsl/jobdesc.c +++ b/drivers/crypto/fsl/jobdesc.c @@ -11,6 +11,7 @@ #include <common.h> #include "desc_constr.h" #include "jobdesc.h" +#include "rsa_caam.h"
#define KEY_BLOB_SIZE 32 #define MAC_SIZE 16 @@ -123,3 +124,30 @@ void inline_cnstr_jobdesc_rng_instantiation(uint32_t *desc) append_operation(desc, OP_TYPE_CLASS1_ALG | OP_ALG_ALGSEL_RNG | OP_ALG_RNG4_SK); } + +/* Change key size to bytes form bits in calling function*/ +void inline_cnstr_jobdesc_pkha_rsaexp(uint32_t *desc, + struct pk_in_params *pkin, uint8_t *out, + uint32_t out_siz) +{ + dma_addr_t dma_addr_e, dma_addr_a, dma_addr_n, dma_addr_out; + + dma_addr_e = virt_to_phys((void *)pkin->e); + dma_addr_a = virt_to_phys((void *)pkin->a); + dma_addr_n = virt_to_phys((void *)pkin->n); + dma_addr_out = virt_to_phys((void *)out); + + init_job_desc(desc, 0); + append_key(desc, dma_addr_e, pkin->e_siz, KEY_DEST_PKHA_E | CLASS_1); + + append_fifo_load(desc, dma_addr_a, + pkin->a_siz, LDST_CLASS_1_CCB | FIFOLD_TYPE_PK_A); + + append_fifo_load(desc, dma_addr_n, + pkin->n_siz, LDST_CLASS_1_CCB | FIFOLD_TYPE_PK_N); + + append_operation(desc, OP_TYPE_PK | OP_ALG_PK | OP_ALG_PKMODE_MOD_EXPO); + + append_fifo_store(desc, dma_addr_out, out_siz, + LDST_CLASS_1_CCB | FIFOST_TYPE_PKHA_B); +} diff --git a/drivers/crypto/fsl/jobdesc.h b/drivers/crypto/fsl/jobdesc.h index 3cf7226..84b3edd 100644 --- a/drivers/crypto/fsl/jobdesc.h +++ b/drivers/crypto/fsl/jobdesc.h @@ -10,6 +10,7 @@
#include <common.h> #include <asm/io.h> +#include "rsa_caam.h"
#define KEY_IDNFR_SZ_BYTES 16
@@ -26,4 +27,8 @@ void inline_cnstr_jobdesc_blob_decap(uint32_t *desc, uint8_t *key_idnfr, uint32_t out_sz);
void inline_cnstr_jobdesc_rng_instantiation(uint32_t *desc); + +void inline_cnstr_jobdesc_pkha_rsaexp(uint32_t *desc, + struct pk_in_params *pkin, uint8_t *out, + uint32_t out_siz); #endif diff --git a/drivers/crypto/fsl/rsa_caam.h b/drivers/crypto/fsl/rsa_caam.h new file mode 100644 index 0000000..4ff87ef --- /dev/null +++ b/drivers/crypto/fsl/rsa_caam.h @@ -0,0 +1,28 @@ +/* + * Copyright 2014 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __RSA_CAAM_H +#define __RSA_CAAM_H + +#include <common.h> + +/** + * struct pk_in_params - holder for input to PKHA block in CAAM + * These parameters are required to perform Modular Exponentiation + * using PKHA Block in CAAM + */ +struct pk_in_params { + const uint8_t *e; /* public exponent as byte array */ + uint32_t e_siz; /* size of e[] in number of bytes */ + const uint8_t *n; /* modulus as byte array */ + uint32_t n_siz; /* size of n[] in number of bytes */ + const uint8_t *a; /* Signature as byte array */ + uint32_t a_siz; /* size of a[] in number of bytes */ + uint8_t *b; /* Result exp. modulus in number of bytes */ + uint32_t b_siz; /* size of b[] in number of bytes */ +}; + +#endif
I don't see what you want inline functions in jobdesc.h, but I suppose that is your business.
Kconfig option added for devices which support RSA Verification. 1. RSA_SOFTWARE_EXP Enables driver for supporting RSA Modular Exponentiation in Software 2. RSA_FREESCALE_EXP Enables driver for supporting RSA Modular Exponentiation using Freescale specific driver
The above drivers use RSA uclass
Changes in v4: Introduced 2 options when CONFIG_RSA is selected: RSA_SOFTWARE_EXP RSA_FREESCALE_EXP
Removed RSA_HW. Changes the name pf RSA_SW to RSA_SOFTWARE_EXP
Changes in v3: New patch lib/Kconfig | 7 +------ lib/rsa/Kconfig | 28 ++++++++++++++++++++++++++++ 2 files changed, 29 insertions(+), 6 deletions(-) create mode 100644 lib/rsa/Kconfig
diff --git a/lib/Kconfig b/lib/Kconfig index 79b91b7..a1f30a2 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -27,11 +27,6 @@ config SYS_HZ get_timer() must operate in milliseconds and this option must be set to 1000.
-config RSA - bool "Use RSA Library" - help - RSA support. This enables the RSA algorithm used for FIT image - verification in U-Boot. - See doc/uImage.FIT/signature.txt for more details. +source lib/rsa/Kconfig
endmenu diff --git a/lib/rsa/Kconfig b/lib/rsa/Kconfig new file mode 100644 index 0000000..4fa79d7 --- /dev/null +++ b/lib/rsa/Kconfig @@ -0,0 +1,28 @@ +config RSA + bool "Use RSA Library" + select RSA_FREESCALE_EXP if FSL_CAAM + select RSA_SOFTWARE_EXP if !RSA_FREESCALE_EXP + help + RSA support. This enables the RSA algorithm used for FIT image + verification in U-Boot. + See doc/uImage.FIT/signature.txt for more details. + See doc/uImage.FIT/signature.txt for more details. + +if RSA +config RSA_SOFTWARE_EXP + bool "Enable driver for RSA Modular Exponentiation in software" + depends on DM && RSA + help + Enables driver for modular exponentiation in software. This is a RSA + algorithm used in FIT image verification. It required RSA Key as + input. + See doc/uImage.FIT/signature.txt for more details. + +config RSA_FREESCALE_EXP + bool "Enable RSA Modular Exponentiation with FSL crypto accelerator" + depends on DM && RSA && FSL_CAAM + help + Enables driver for RSA modular exponentiation using Freescale cryptographic + accelerator - CAAM. + +endif
- RSA_SOFTWARE_EXP
(note the duplicated line in your Kconfig if you issue a new version, but I can clean that up when applying it)
help
- RSA_SOFTWARE_EXP
help
I tidied this up.
The hash_algo structure has some implementations in which progressive hash API's are not defined. These are basically the hardware based implementations of SHA. An API is added to find the algo which has progressive hash API's defined. This can then be integrated with RSA checksum library which uses Progressive Hash API's.
Changes in v5: None
Changes in v4: Few cosmetic changes. Currently I have not replaced CONFIG_SHA1 with CONFIG_CMD_SHA1SUM. Waiting for reply from Simon and Denx for the same.
Changes in v3 : Corrected ifdef for SHA1
Changes in v2 : Added commit message
common/hash.c | 33 ++++++++++++++++++++++++--------- include/hash.h | 14 ++++++++++++++ 2 files changed, 38 insertions(+), 9 deletions(-)
diff --git a/common/hash.c b/common/hash.c index aceabc5..c4d8c3a 100644 --- a/common/hash.c +++ b/common/hash.c @@ -20,7 +20,7 @@ #include <asm/io.h> #include <asm/errno.h>
-#ifdef CONFIG_CMD_SHA1SUM +#ifdef CONFIG_SHA1 static int hash_init_sha1(struct hash_algo *algo, void **ctxp) { sha1_context *ctx = malloc(sizeof(sha1_context)); @@ -125,12 +125,7 @@ static struct hash_algo hash_algo[] = { CHUNKSZ_SHA256, }, #endif - /* - * This is CONFIG_CMD_SHA1SUM instead of CONFIG_SHA1 since otherwise - * it bloats the code for boards which use SHA1 but not the 'hash' - * or 'sha1sum' commands. - */ -#ifdef CONFIG_CMD_SHA1SUM +#ifdef CONFIG_SHA1 { "sha1", SHA1_SUM_LEN, @@ -140,7 +135,6 @@ static struct hash_algo hash_algo[] = { hash_update_sha1, hash_finish_sha1, }, -#define MULTI_HASH #endif #ifdef CONFIG_SHA256 { @@ -152,7 +146,6 @@ static struct hash_algo hash_algo[] = { hash_update_sha256, hash_finish_sha256, }, -#define MULTI_HASH #endif { "crc32", @@ -165,6 +158,10 @@ static struct hash_algo hash_algo[] = { }, };
+#if defined(CONFIG_SHA256) || defined(CONFIG_CMD_SHA1SUM) +#define MULTI_HASH +#endif + #if defined(CONFIG_HASH_VERIFY) || defined(CONFIG_CMD_HASH) #define MULTI_HASH #endif @@ -311,6 +308,24 @@ int hash_lookup_algo(const char *algo_name, struct hash_algo **algop) return -EPROTONOSUPPORT; }
+int hash_progressive_lookup_algo(const char *algo_name, + struct hash_algo **algop) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(hash_algo); i++) { + if (!strcmp(algo_name, hash_algo[i].name)) { + if (hash_algo[i].hash_init) { + *algop = &hash_algo[i]; + return 0; + } + } + } + + debug("Unknown hash algorithm '%s'\n", algo_name); + return -EPROTONOSUPPORT; +} + void hash_show(struct hash_algo *algo, ulong addr, ulong len, uint8_t *output) { int i; diff --git a/include/hash.h b/include/hash.h index d8ec4f0..c0a7ebc 100644 --- a/include/hash.h +++ b/include/hash.h @@ -128,6 +128,20 @@ int hash_block(const char *algo_name, const void *data, unsigned int len, int hash_lookup_algo(const char *algo_name, struct hash_algo **algop);
/** + * hash_progressive_lookup_algo() - Look up hash_algo for prog. hash support + * + * The function returns the pointer to the struct or -EPROTONOSUPPORT if the + * algorithm is not available with progressive hash support. + * + * @algo_name: Hash algorithm to look up + * @algop: Pointer to the hash_algo struct if found + * + * @return 0 if ok, -EPROTONOSUPPORT for an unknown algorithm. + */ +int hash_progressive_lookup_algo(const char *algo_name, + struct hash_algo **algop); + +/** * hash_show() - Print out a hash algorithm and value * * You will get a message like this (without a newline at the end):
Changes in v5: None
Changes in v5: None
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com CC: Simon Glass sjg@chromium.org --- Changes in v6: Fixed compilation error in this file for tools when FIT_SIGNATURE not enabled
Changes in v5: New patch based on WIP patch by Simon.
common/hash.c | 81 +++++++++++++++++++++++++++++++++------------------------- include/hash.h | 34 ++++++++++++------------ tools/Makefile | 1 + 3 files changed, 65 insertions(+), 51 deletions(-)
diff --git a/common/hash.c b/common/hash.c index c4d8c3a..d154d02 100644 --- a/common/hash.c +++ b/common/hash.c @@ -10,15 +10,24 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#ifndef USE_HOSTCC #include <common.h> #include <command.h> #include <malloc.h> #include <hw_sha.h> +#include <asm/io.h> +#include <asm/errno.h> +#else +#include "mkimage.h" +#include <time.h> +#include <image.h> +#endif /* !USE_HOSTCC*/ + #include <hash.h> +#include <u-boot/crc.h> #include <u-boot/sha1.h> #include <u-boot/sha256.h> -#include <asm/io.h> -#include <asm/errno.h> +#include <u-boot/md5.h>
#ifdef CONFIG_SHA1 static int hash_init_sha1(struct hash_algo *algo, void **ctxp) @@ -173,6 +182,40 @@ static struct hash_algo hash_algo[] = { #define multi_hash() 0 #endif
+int hash_lookup_algo(const char *algo_name, struct hash_algo **algop) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(hash_algo); i++) { + if (!strcmp(algo_name, hash_algo[i].name)) { + *algop = &hash_algo[i]; + return 0; + } + } + + debug("Unknown hash algorithm '%s'\n", algo_name); + return -EPROTONOSUPPORT; +} + +int hash_progressive_lookup_algo(const char *algo_name, + struct hash_algo **algop) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(hash_algo); i++) { + if (!strcmp(algo_name, hash_algo[i].name)) { + if (hash_algo[i].hash_init) { + *algop = &hash_algo[i]; + return 0; + } + } + } + + debug("Unknown hash algorithm '%s'\n", algo_name); + return -EPROTONOSUPPORT; +} + +#ifndef USE_HOSTCC /** * store_result: Store the resulting sum to an address or variable * @@ -293,39 +336,6 @@ static int parse_verify_sum(struct hash_algo *algo, char *verify_str, return 0; }
-int hash_lookup_algo(const char *algo_name, struct hash_algo **algop) -{ - int i; - - for (i = 0; i < ARRAY_SIZE(hash_algo); i++) { - if (!strcmp(algo_name, hash_algo[i].name)) { - *algop = &hash_algo[i]; - return 0; - } - } - - debug("Unknown hash algorithm '%s'\n", algo_name); - return -EPROTONOSUPPORT; -} - -int hash_progressive_lookup_algo(const char *algo_name, - struct hash_algo **algop) -{ - int i; - - for (i = 0; i < ARRAY_SIZE(hash_algo); i++) { - if (!strcmp(algo_name, hash_algo[i].name)) { - if (hash_algo[i].hash_init) { - *algop = &hash_algo[i]; - return 0; - } - } - } - - debug("Unknown hash algorithm '%s'\n", algo_name); - return -EPROTONOSUPPORT; -} - void hash_show(struct hash_algo *algo, ulong addr, ulong len, uint8_t *output) { int i; @@ -439,3 +449,4 @@ int hash_command(const char *algo_name, int flags, cmd_tbl_t *cmdtp, int flag,
return 0; } +#endif diff --git a/include/hash.h b/include/hash.h index c0a7ebc..f4eb100 100644 --- a/include/hash.h +++ b/include/hash.h @@ -17,7 +17,6 @@ enum { HASH_FLAG_ENV = 1 << 1, /* Allow env vars */ };
-#ifndef USE_HOSTCC #if defined(CONFIG_SHA1SUM_VERIFY) || defined(CONFIG_CRC32_VERIFY) #define CONFIG_HASH_VERIFY #endif @@ -77,6 +76,7 @@ struct hash_algo { int size); };
+#ifndef USE_HOSTCC /** * hash_command: Process a hash command for a particular algorithm * @@ -115,6 +115,23 @@ int hash_block(const char *algo_name, const void *data, unsigned int len, uint8_t *output, int *output_size);
/** + * hash_show() - Print out a hash algorithm and value + * + * You will get a message like this (without a newline at the end): + * + * "sha1 for 9eb3337c ... 9eb3338f ==> 7942ef1df479fd3130f716eb9613d107dab7e257" + * + * @algo: Algorithm used for hash + * @addr: Address of data that was hashed + * @len: Length of data that was hashed + * @output: Hash value to display + */ +void hash_show(struct hash_algo *algo, ulong addr, ulong len, + uint8_t *output); + +#endif /* !USE_HOSTCC */ + +/** * hash_lookup_algo() - Look up the hash_algo struct for an algorithm * * The function returns the pointer to the struct or -EPROTONOSUPPORT if the @@ -141,19 +158,4 @@ int hash_lookup_algo(const char *algo_name, struct hash_algo **algop); int hash_progressive_lookup_algo(const char *algo_name, struct hash_algo **algop);
-/** - * hash_show() - Print out a hash algorithm and value - * - * You will get a message like this (without a newline at the end): - * - * "sha1 for 9eb3337c ... 9eb3338f ==> 7942ef1df479fd3130f716eb9613d107dab7e257" - * - * @algo: Algorithm used for hash - * @addr: Address of data that was hashed - * @len: Length of data that was hashed - * @output: Hash value to display - */ -void hash_show(struct hash_algo *algo, ulong addr, ulong len, - uint8_t *output); -#endif /* !USE_HOSTCC */ #endif diff --git a/tools/Makefile b/tools/Makefile index 46b90b2..ea76a3e 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -91,6 +91,7 @@ dumpimage-mkimage-objs := aisimage.o \ socfpgaimage.o \ lib/sha1.o \ lib/sha256.o \ + common/hash.o \ ublimage.o \ $(LIBFDT_OBJS) \ $(RSA_OBJS-y)
Currently the hash functions used in RSA are called directly from the sha1 and sha256 libraries. Change the RSA checksum library to use the progressive hash API's registered with struct hash_algo. This will allow the checksum library to use the hardware accelerated progressive hash API's once available.
Signed-off-by: Ruchika Gupta ruchika.gupta@freescale.com CC: Simon Glass sjg@chromium.org --- Changes in v6: Removed changes in ls1021aqds.h accidently included in this patch
Changes in v5: Both tools and uboot use the same code in rsa-checksum.c
Changes in v4: No changes in this patch. Still under discussion
Changes in v3: Modified rsa-verify to check for return from checksum function
Changes in v2: Added generic function hash_calculate. Pass an additional argument as name of algorithm.
common/image-sig.c | 6 +++--- include/image.h | 5 +++-- include/u-boot/rsa-checksum.h | 17 +++++++++++---- lib/rsa/rsa-checksum.c | 50 ++++++++++++++++++++++++++----------------- lib/rsa/rsa-verify.c | 7 +++++- 5 files changed, 55 insertions(+), 30 deletions(-)
diff --git a/common/image-sig.c b/common/image-sig.c index 8601eda..2c9f0cd 100644 --- a/common/image-sig.c +++ b/common/image-sig.c @@ -38,7 +38,7 @@ struct checksum_algo checksum_algos[] = { #if IMAGE_ENABLE_SIGN EVP_sha1, #endif - sha1_calculate, + hash_calculate, padding_sha1_rsa2048, }, { @@ -48,7 +48,7 @@ struct checksum_algo checksum_algos[] = { #if IMAGE_ENABLE_SIGN EVP_sha256, #endif - sha256_calculate, + hash_calculate, padding_sha256_rsa2048, }, { @@ -58,7 +58,7 @@ struct checksum_algo checksum_algos[] = { #if IMAGE_ENABLE_SIGN EVP_sha256, #endif - sha256_calculate, + hash_calculate, padding_sha256_rsa4096, }
diff --git a/include/image.h b/include/image.h index ee3afe3..dcbc72f 100644 --- a/include/image.h +++ b/include/image.h @@ -927,8 +927,9 @@ struct checksum_algo { #if IMAGE_ENABLE_SIGN const EVP_MD *(*calculate_sign)(void); #endif - void (*calculate)(const struct image_region region[], - int region_count, uint8_t *checksum); + int (*calculate)(const char *name, + const struct image_region region[], + int region_count, uint8_t *checksum); const uint8_t *rsa_padding; };
diff --git a/include/u-boot/rsa-checksum.h b/include/u-boot/rsa-checksum.h index c996fb3..3c69d85 100644 --- a/include/u-boot/rsa-checksum.h +++ b/include/u-boot/rsa-checksum.h @@ -16,9 +16,18 @@ extern const uint8_t padding_sha256_rsa4096[]; extern const uint8_t padding_sha256_rsa2048[]; extern const uint8_t padding_sha1_rsa2048[];
-void sha256_calculate(const struct image_region region[], int region_count, - uint8_t *checksum); -void sha1_calculate(const struct image_region region[], int region_count, - uint8_t *checksum); +/** + * hash_calculate() - Calculate hash over the data + * + * @name: Name of algorithm to be used for hash calculation + * @region: Array having info of regions over which hash needs to be calculated + * @region_count: Number of regions in the region array + * @checksum: Buffer contanining the output hash + * + * @return 0 if OK, < 0 if error + */ +int hash_calculate(const char *name, + const struct image_region region[], int region_count, + uint8_t *checksum);
#endif diff --git a/lib/rsa/rsa-checksum.c b/lib/rsa/rsa-checksum.c index 8d8b59f..68d9d65 100644 --- a/lib/rsa/rsa-checksum.c +++ b/lib/rsa/rsa-checksum.c @@ -10,12 +10,13 @@ #include <asm/byteorder.h> #include <asm/errno.h> #include <asm/unaligned.h> +#include <hash.h> #else #include "fdt_host.h" -#endif -#include <u-boot/rsa.h> #include <u-boot/sha1.h> #include <u-boot/sha256.h> +#endif +#include <u-boot/rsa.h>
/* PKCS 1.5 paddings as described in the RSA PKCS#1 v2.1 standard. */
@@ -136,28 +137,37 @@ const uint8_t padding_sha256_rsa4096[RSA4096_BYTES - SHA256_SUM_LEN] = { 0x03, 0x04, 0x02, 0x01, 0x05, 0x00, 0x04, 0x20 };
-void sha1_calculate(const struct image_region region[], int region_count, - uint8_t *checksum) +int hash_calculate(const char *name, + const struct image_region region[], + int region_count, uint8_t *checksum) { - sha1_context ctx; + struct hash_algo *algo; + int ret = 0; + void *ctx; uint32_t i; i = 0;
- sha1_starts(&ctx); - for (i = 0; i < region_count; i++) - sha1_update(&ctx, region[i].data, region[i].size); - sha1_finish(&ctx, checksum); -} + ret = hash_progressive_lookup_algo(name, &algo); + if (ret) + return ret;
-void sha256_calculate(const struct image_region region[], int region_count, - uint8_t *checksum) -{ - sha256_context ctx; - uint32_t i; - i = 0; + ret = algo->hash_init(algo, &ctx); + if (ret) + return ret; + + for (i = 0; i < region_count - 1; i++) { + ret = algo->hash_update(algo, ctx, region[i].data, + region[i].size, 0); + if (ret) + return ret; + } + + ret = algo->hash_update(algo, ctx, region[i].data, region[i].size, 1); + if (ret) + return ret; + ret = algo->hash_finish(algo, ctx, checksum, algo->digest_size); + if (ret) + return ret;
- sha256_starts(&ctx); - for (i = 0; i < region_count; i++) - sha256_update(&ctx, region[i].data, region[i].size); - sha256_finish(&ctx, checksum); + return 0; } diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index da45daf..60126d2 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -184,7 +184,12 @@ int rsa_verify(struct image_sign_info *info, }
/* Calculate checksum with checksum-algorithm */ - info->algo->checksum->calculate(region, region_count, hash); + ret = info->algo->checksum->calculate(info->algo->checksum->name, + region, region_count, hash); + if (ret < 0) { + debug("%s: Error in checksum calculation\n", __func__); + return -EINVAL; + }
/* See if we must use a particular key */ if (info->required_keynode != -1) {
I had to make a tweak to include/configs/ti_am335x_common.h to avoid a build breakage. With that:
Public exponentiation which is required in rsa verify functionality is tightly integrated with verification code in rsa_verify.c. The patch splits the file into twp separating the modular exponentiation.
- rsa-verify.c
- The file parses device tree keys node to fill a keyprop structure.
The keyprop structure can then be converted to implementation specific format. (struct rsa_pub_key for sw implementation)
- The parsed device tree node is then passed to a generic rsa_mod_exp
function.
- rsa-mod-exp.c
Move the software specific functions related to modular exponentiation from rsa-verify.c to this file.
Changes in v6: No changes
Changes in v5: Reverted change in rsa_mod_exp_sw function to add pointer to output length Addressed other comments by Simon
Changes in v4: Modified rsa_mod_exp_sw function to add pointer to output length
Changes in v3: Kconfig moved to separate patch. This patch just splits the file now
Changes in v2: Addressed few of Simon Glass's comments:
- Kconfig option added for RSA
- Comments added for new keyprop struct
include/u-boot/rsa-mod-exp.h | 43 ++++++ lib/rsa/Makefile | 2 +- lib/rsa/rsa-mod-exp.c | 303 +++++++++++++++++++++++++++++++++++++++ lib/rsa/rsa-verify.c | 329 ++++++++----------------------------------- tools/Makefile | 3 +- 5 files changed, 404 insertions(+), 276 deletions(-) create mode 100644 include/u-boot/rsa-mod-exp.h create mode 100644 lib/rsa/rsa-mod-exp.c
- rsa-verify.c
function.
- rsa-mod-exp.c
Ruchika Gupta
