[U-Boot] [PATCH] mx28evk: Convert to phylib framework
mx28evk has a LAN8270 ethernet phy and we can use the phylib framework.
One of the advantages of converting to phylib is that we no longer see a timeout prior to the first transfer in the 'tftp' command.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- After applying this patch I get:
U-Boot 2013.04-11810-gd6d75ec-dirty (Jul 12 2013 - 01:15:03)
CPU: Freescale i.MX28 rev1.2 at 454 MHz BOOT: SSP SD/MMC #0, 3V3 DRAM: 128 MiB MMC: MXS MMC: 0 Video: MXSFB: 'videomode' variable not set! In: serial Out: serial Err: serial Net: Phy not found
I still get this 'Phy not found' message, but I think this is not related to the board code.
board/freescale/mx28evk/mx28evk.c | 15 +-------------- include/configs/mx28evk.h | 3 ++- 2 files changed, 3 insertions(+), 15 deletions(-)
diff --git a/board/freescale/mx28evk/mx28evk.c b/board/freescale/mx28evk/mx28evk.c index 4edd9f4..cd81d58 100644 --- a/board/freescale/mx28evk/mx28evk.c +++ b/board/freescale/mx28evk/mx28evk.c @@ -110,7 +110,6 @@ int board_eth_init(bd_t *bis) { struct mxs_clkctrl_regs *clkctrl_regs = (struct mxs_clkctrl_regs *)MXS_CLKCTRL_BASE; - struct eth_device *dev; int ret;
ret = cpu_eth_init(bis); @@ -133,24 +132,12 @@ int board_eth_init(bd_t *bis) return ret; }
- ret = fecmxc_initialize_multi(bis, 1, 3, MXS_ENET1_BASE); + ret = fecmxc_initialize_multi(bis, 1, 1, MXS_ENET1_BASE); if (ret) { puts("FEC MXS: Unable to init FEC1\n"); return ret; }
- dev = eth_get_dev_by_name("FEC0"); - if (!dev) { - puts("FEC MXS: Unable to get FEC0 device entry\n"); - return -EINVAL; - } - - dev = eth_get_dev_by_name("FEC1"); - if (!dev) { - puts("FEC MXS: Unable to get FEC1 device entry\n"); - return -EINVAL; - } - return ret; }
diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index de69182..2431b83 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -170,12 +170,13 @@
/* Ethernet on SOC (FEC) */ #ifdef CONFIG_CMD_NET -#define CONFIG_NET_MULTI #define CONFIG_ETHPRIME "FEC0" #define CONFIG_FEC_MXC #define CONFIG_MII #define CONFIG_FEC_XCV_TYPE RMII #define CONFIG_MX28_FEC_MAC_IN_OCOTP +#define CONFIG_PHYLIB +#define CONFIG_PHY_SMSC #endif
/* RTC */
Dear Fabio Estevam,
This is because PHYlib doesn't know your PHY. You might need to add a definition for it into drivers/net/phy/smsc.c
- ret = fecmxc_initialize_multi(bis, 1, 1, MXS_ENET1_BASE);
Are you sure the PHY address on the MII bus for FEC1 is 0x01 ?
Best regards, Marek Vasut
On Fri, Jul 12, 2013 at 1:40 AM, Marek Vasut marex@denx.de wrote:
Dear Fabio Estevam,
mx28evk uses a LAN8270.
drivers/net/phy/smsc.c has an entry for "SMSC LAN8710/LAN8720", so not sure why it fails to recognize it. I haven't debugged it yet.
Which phy does sc_sps_1.h use? Is it also a 8720? Is the phy recognized on boot?
Regards,
Fabio Estevam
Dear Fabio Estevam,
Dear Fabio Estevam,
I think it's 8720 , but it's recognised , yes. Are you sure the PHY addresses are correct ? You can dig into phylib a bit and see what IDs does it report.
On Fri, Jul 12, 2013 at 1:58 AM, Marek Vasut marex@denx.de wrote:
Dear Fabio Estevam,
Dear Fabio Estevam,
I think Fabio needs to define CONFIG_PHY_SMSC and use PHY address 3.
Dear Alexandre Pereira da Silva,
Dear Fabio Estevam,
Dear Fabio Estevam,
He already did and the LAN8720 can use either phy addr 0x00 or 0x01, so that seem ok as well.
Fabio Estevam
