[GIT PULL] TI changes for v2021.07 rc4
Hi Tom, Please find the PR for master branch targeted for v2021.07-rc4 release. Details about the PR are updated in the tag message.
Gitlab CI report: https://source.denx.de/u-boot/custodians/u-boot-ti/-/pipelines/7645
The following changes since commit e1bf0336a58cfe873a34c36ff53e5e3806f2d263:
Prepare v2021.07-rc3 (2021-05-24 20:53:13 -0400)
https://source.denx.de/u-boot/custodians/u-boot-ti.git tags/ti-v2021.07-rc4
for you to fetch changes up to fed603f868469a0d8f2548bdac137feead333c6b:
ARM: ti: Increase the allocated size for MLO.raw (2021-05-27 14:56:42 +0530)
---------------------------------------------------------------- - Fix reset for AM64 platforms - Enable networking PHY driver for AM64 - Fix default R5F cluster setting in J7
Dave Gerlach (1): firmware: ti_sci: Update ti_sci_msg_req_reboot to include domain
Faiz Abbas (1): ARM: ti: Increase the allocated size for MLO.raw
Suman Anna (3): arm: dts: k3-j721e: Fix up MAIN R5FSS cluster mode back to Split-mode arm: dts: k3-am642-evm: Add sysreset controller node arm: dts: k3-am642-sk: Add sysreset controller node
Vignesh Raghavendra (1): configs: am64x_evm_a53_defconfig: Enable DP83867 PHY driver
arch/arm/dts/k3-am642-evm-u-boot.dtsi | 4 ++++ arch/arm/dts/k3-am642-sk-u-boot.dtsi | 4 ++++ arch/arm/dts/k3-j721e-common-proc-board-u-boot.dtsi | 8 ++++++++ configs/am64x_evm_a53_defconfig | 1 + drivers/firmware/ti_sci.c | 1 + drivers/firmware/ti_sci.h | 2 ++ include/environment/ti/dfu.h | 4 ++-- 7 files changed, 22 insertions(+), 2 deletions(-)
Lokesh Vutla
