[U-Boot-Users] Enabling the data size parameter for memory commands like "md"?
Hello,
I'm playing around with a day-old cvs snapshot of U-Boot, using it with "make at91rm9200dk_config". My problem is the same with 0.4.0.
From the source (and from the usage help) I understand that at least the
memory commands like "md" should accept (optional) data size parameter (.b/.w/.l) as the first parameter.
How do you enable this? In my environment they don't work: 1) argv[0] is the command itself (like "md"), not the data size parameter from where the source tries to read it and 2) if I give the data size parameter, the upper framework counts the amount of parameters to be illegal and therefore certain commands give me an error message (the short usage).
I suppose there is a #define missing? What is it? I could not quickly find it grepping the source, googling the net / mailing list archives.
Best Regards,
Pasi Huhtiniemi
Hi Pasi,
I think you misunderstood the docs. The size specification is not a parameter but rather a part of the command name - that's why the source looks at argv[0]. Check out the examples in our documentation[1].
Cheers Detlev
[1] https://www.denx.de/twiki/bin/view/DULG/UBootCmdGroupMemory#Section_5.9.2.5.
Dear Pasi,
in message Pine.LNX.4.44.0310141425340.4900-100000@melkki.cs.Helsinki.FI you wrote:
No, this is wrong. This is NOT the first parameter, but a command qualifier.
Which is the correct reaction on incorrect command usage.
Ummm... I suggest you start RTFM?
See for example http://www.denx.de/twiki/bin/view/DULG/UBootCmdGroupMemory#Section_5.9.2.3.
Detlev Zundel
Pasi Huhtiniemi
