[PATCH 1/9] doc: Move FIT into its own directory
Create a new usage/fit directory which will house information about FIT.
doc/usage/{fit.rst => fit/index.rst} | 4 ++++ doc/usage/index.rst | 2 +- 2 files changed, 5 insertions(+), 1 deletion(-) rename doc/usage/{fit.rst => fit/index.rst} (88%)
diff --git a/doc/usage/fit.rst b/doc/usage/fit/index.rst similarity index 88% rename from doc/usage/fit.rst rename to doc/usage/fit/index.rst index 70374340577e..68641a6704ff 100644 --- a/doc/usage/fit.rst +++ b/doc/usage/fit/index.rst @@ -6,3 +6,7 @@ Flat Image Tree (FIT) U-Boot uses Flat Image Tree (FIT) as a standard file format for packaging images that it it reads and boots. Documentation about FIT is available at doc/uImage.FIT + +.. toctree:: + :maxdepth: 1 + diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 84ef8a9a427d..e1fe284b38c1 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -8,7 +8,7 @@ Use U-Boot dfu environment fdt_overlays - fit + fit/index netconsole partitions cmdline
Move this document and convert it to rST. Make minimal changes, enough for it to build successfully.
doc/usage/fit/index.rst | 1 + .../fit/source_file_format.rst} | 125 +++++++++--------- 2 files changed, 64 insertions(+), 62 deletions(-) rename doc/{uImage.FIT/source_file_format.txt => usage/fit/source_file_format.rst} (84%)
diff --git a/doc/usage/fit/index.rst b/doc/usage/fit/index.rst index 68641a6704ff..93a962319035 100644 --- a/doc/usage/fit/index.rst +++ b/doc/usage/fit/index.rst @@ -10,3 +10,4 @@ doc/uImage.FIT .. toctree:: :maxdepth: 1
+ source_file_format diff --git a/doc/uImage.FIT/source_file_format.txt b/doc/usage/fit/source_file_format.rst similarity index 84% rename from doc/uImage.FIT/source_file_format.txt rename to doc/usage/fit/source_file_format.rst index 269e1fa0b580..9f4688db2a15 100644 --- a/doc/uImage.FIT/source_file_format.txt +++ b/doc/usage/fit/source_file_format.rst @@ -64,16 +64,15 @@ The following picture shows how the new uImage is prepared. Input consists of image source file (.its) and a set of data files. Image is created with the help of standard U-Boot mkimage tool which in turn uses dtc (device tree compiler) to produce image tree blob (.itb). Resulting .itb file is the -actual binary of a new uImage. +actual binary of a new uImage::
- -tqm5200.its -+ -vmlinux.bin.gz mkimage + dtc xfer to target -eldk-4.2-ramdisk --------------> tqm5200.itb --------------> bootm -tqm5200.dtb /|\ -... | - 'new uImage' + tqm5200.its + + + vmlinux.bin.gz mkimage + dtc xfer to target + eldk-4.2-ramdisk --------------> tqm5200.itb --------------> bootm + tqm5200.dtb /|\ + ... | + 'new uImage'
- create .its file, automatically filled-in properties are omitted - call mkimage tool on a .its file @@ -93,25 +92,25 @@ checking required. 3) Root node properties -----------------------
-Root node of the uImage Tree should have the following layout: - -/ o image-tree - |- description = "image description" - |- timestamp = <12399321> - |- #address-cells = <1> - | - o images - | | - | o image-1 {...} - | o image-2 {...} - | ... - | - o configurations - |- default = "conf-1" - | - o conf-1 {...} - o conf-2 {...} - ... +Root node of the uImage Tree should have the following layout:: + + / o image-tree + |- description = "image description" + |- timestamp = <12399321> + |- #address-cells = <1> + | + o images + | | + | o image-1 {...} + | o image-2 {...} + | ... + | + o configurations + |- default = "conf-1" + | + o conf-1 {...} + o conf-2 {...} + ...
Optional property: @@ -138,21 +137,21 @@ Root node of the uImage Tree should have the following layout: -----------------
This node is a container node for component sub-image nodes. Each sub-node of -the '/images' node should have the following layout: - - o image-1 - |- description = "component sub-image description" - |- data = /incbin/("path/to/data/file.bin") - |- type = "sub-image type name" - |- arch = "ARCH name" - |- os = "OS name" - |- compression = "compression name" - |- load = <00000000> - |- entry = <00000000> - | - o hash-1 {...} - o hash-2 {...} - ... +the '/images' node should have the following layout:: + + o image-1 + |- description = "component sub-image description" + |- data = /incbin/("path/to/data/file.bin") + |- type = "sub-image type name" + |- arch = "ARCH name" + |- os = "OS name" + |- compression = "compression name" + |- load = <00000000> + |- entry = <00000000> + | + o hash-1 {...} + o hash-2 {...} + ...
Mandatory properties: - description : Textual description of the component sub-image @@ -202,9 +201,11 @@ the '/images' node should have the following layout: 5) Hash nodes -------------
-o hash-1 - |- algo = "hash or checksum algorithm name" - |- value = [hash or checksum value] +:: + + o hash-1 + |- algo = "hash or checksum algorithm name" + |- value = [hash or checksum value]
Mandatory properties: - algo : Algorithm name, supported are "crc32", "md5" and "sha1". @@ -218,14 +219,14 @@ o hash-1 The 'configurations' node creates convenient, labeled boot configurations, which combine together kernel images with their ramdisks and fdt blobs.
-The 'configurations' node has has the following structure: +The 'configurations' node has has the following structure::
-o configurations - |- default = "default configuration sub-node unit name" - | - o config-1 {...} - o config-2 {...} - ... + o configurations + |- default = "default configuration sub-node unit name" + | + o config-1 {...} + o config-2 {...} + ...
Optional property: @@ -240,15 +241,15 @@ o configurations 7) Configuration nodes ----------------------
-Each configuration has the following structure: +Each configuration has the following structure::
-o config-1 - |- description = "configuration description" - |- kernel = "kernel sub-node unit name" - |- fdt = "fdt sub-node unit-name" [, "fdt overlay sub-node unit-name", ...] - |- loadables = "loadables sub-node unit-name" - |- script = " - |- compatible = "vendor,board-style device tree compatible string" + o config-1 + |- description = "configuration description" + |- kernel = "kernel sub-node unit name" + |- fdt = "fdt sub-node unit-name" [, "fdt overlay sub-node unit-name", ...] + |- loadables = "loadables sub-node unit-name" + |- script = " + |- compatible = "vendor,board-style device tree compatible string"
Mandatory properties: @@ -319,4 +320,4 @@ structure and data to 512 byte, other values available for other align size. 9) Examples -----------
-Please see doc/uImage.FIT/*.its for actual image source files. +Please see `doc/uImage.FIT/*.its` for actual image source files.
- source_file_format
Thanks for moving to HTML documentation. This series will need some follow up work, e.g.
The title is just confusing. The document is about the FIT file format and not about any uImage file format.
Property arch: risc-v is missing.
Property algo: How about sha256, rsa2048?
In chapter "Root node properties" the diagram is wrong: The configurations are subnodes of "/configurations".
Best regards
Heinrich
Fix up headings and tables to read better.
doc/usage/fit/source_file_format.rst | 255 ++++++++++++++++++--------- 1 file changed, 172 insertions(+), 83 deletions(-)
diff --git a/doc/usage/fit/source_file_format.rst b/doc/usage/fit/source_file_format.rst index 9f4688db2a15..4d2ea0a7b158 100644 --- a/doc/usage/fit/source_file_format.rst +++ b/doc/usage/fit/source_file_format.rst @@ -1,11 +1,8 @@ U-Boot new uImage source file format (bindings definition) ==========================================================
-Author: Marian Balakowicz m8@semihalf.com -External data additions, 25/1/16 Simon Glass sjg@chromium.org - -1) Introduction ---------------- +Introduction +------------
Evolution of the 2.6 Linux kernel for embedded PowerPC systems introduced new booting method which requires that hardware description is available to the @@ -30,16 +27,18 @@ All those factors combined clearly show that there is a need for new, more flexible, multi component uImage format.
-2) New uImage format assumptions --------------------------------- +New uImage format assumptions +-----------------------------
-a) Implementation +Implementation +~~~~~~~~~~~~~~
Libfdt has been selected for the new uImage format implementation as (1) it provides needed functionality, (2) is actively maintained and developed and (3) increases code reuse as it is already part of the U-Boot source tree.
-b) Terminology +Terminology +~~~~~~~~~~~
This document defines new uImage structure by providing FDT bindings for new uImage internals. Bindings are defined from U-Boot perspective, i.e. describe @@ -50,15 +49,20 @@ hashes) will need to be filled in automatically by the U-Boot mkimage tool. To avoid confusion with the kernel FDT the following naming convention is proposed for the new uImage format related terms:
-FIT - Flattened uImage Tree +FIT + Flattened uImage Tree
FIT is formally a flattened device tree (in the libfdt meaning), which conforms to bindings defined in this document.
-.its - image tree source -.itb - flattened image tree blob +.its + image tree source + +.itb + flattened image tree blob
-c) Image building procedure +Image building procedure +~~~~~~~~~~~~~~~~~~~~~~~~
The following picture shows how the new uImage is prepared. Input consists of image source file (.its) and a set of data files. Image is created with the @@ -74,14 +78,20 @@ actual binary of a new uImage:: ... | 'new uImage'
- - create .its file, automatically filled-in properties are omitted - - call mkimage tool on a .its file - - mkimage calls dtc to create .itb image and assures that - missing properties are added - - .itb (new uImage) is uploaded onto the target and used therein +Steps: + +#. Create .its file, automatically filled-in properties are omitted + +#. Call mkimage tool on a .its file + +#. mkimage calls dtc to create .itb image and assures that + missing properties are added + +#. .itb (new uImage) is uploaded onto the target and used therein
-d) Unique identifiers +Unique identifiers +~~~~~~~~~~~~~~~~~~
To identify FIT sub-nodes representing images, hashes, configurations (which are defined in the following sections), the "unit name" of the given sub-node @@ -89,8 +99,8 @@ is used as it's identifier as it assures uniqueness without additional checking required.
-3) Root node properties ------------------------ +Root node properties +--------------------
@@ -113,28 +123,42 @@ Root node of the uImage Tree should have the following layout:: ...
- Optional property: - - description : Textual description of the uImage +Optional property +~~~~~~~~~~~~~~~~~
- Mandatory property: - - timestamp : Last image modification time being counted in seconds since +description + Textual description of the uImage + +Mandatory property +~~~~~~~~~~~~~~~~~~ + +timestamp + Last image modification time being counted in seconds since 1970-01-01 00:00:00 - to be automatically calculated by mkimage tool.
- Conditionally mandatory property: - - #address-cells : Number of 32bit cells required to represent entry and +Conditionally mandatory property +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +#address-cells + Number of 32bit cells required to represent entry and load addresses supplied within sub-image nodes. May be omitted when no entry or load addresses are used.
- Mandatory nodes: - - images : This node contains a set of sub-nodes, each of them representing +Mandatory nodes +~~~~~~~~~~~~~~~ + +images + This node contains a set of sub-nodes, each of them representing single component sub-image (like kernel, ramdisk, etc.). At least one sub-image is required. - - configurations : Contains a set of available configuration nodes and + +configurations + Contains a set of available configuration nodes and defines a default configuration.
-4) '/images' node ------------------ +'/images' node +--------------
This node is a container node for component sub-image nodes. Each sub-node of the '/images' node should have the following layout:: @@ -153,53 +177,89 @@ the '/images' node should have the following layout:: o hash-2 {...} ...
- Mandatory properties: - - description : Textual description of the component sub-image - - type : Name of component sub-image type, supported types are: +Mandatory properties +~~~~~~~~~~~~~~~~~~~~ + +description + Textual description of the component sub-image + +type + Name of component sub-image type, supported types are: + "standalone", "kernel", "kernel_noload", "ramdisk", "firmware", "script", "filesystem", "flat_dt" and others (see uimage_type in common/image.c). - - data : Path to the external file which contains this node's binary data. - - compression : Compression used by included data. Supported compressions + +data + Path to the external file which contains this node's binary data. + +compression + Compression used by included data. Supported compressions are "gzip" and "bzip2". If no compression is used compression property should be set to "none". If the data is compressed but it should not be uncompressed by U-Boot (e.g. compressed ramdisk), this should also be set to "none".
- Conditionally mandatory property: - - os : OS name, mandatory for types "kernel". Valid OS names are: +Conditionally mandatory property +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +os + OS name, mandatory for types "kernel". Valid OS names are: "openbsd", "netbsd", "freebsd", "4_4bsd", "linux", "svr4", "esix", "solaris", "irix", "sco", "dell", "ncr", "lynxos", "vxworks", "psos", "qnx", "u-boot", "rtems", "unity", "integrity". - - arch : Architecture name, mandatory for types: "standalone", "kernel", + +arch + Architecture name, mandatory for types: "standalone", "kernel", "firmware", "ramdisk" and "fdt". Valid architecture names are: "alpha", "arm", "i386", "ia64", "mips", "mips64", "ppc", "s390", "sh", "sparc", "sparc64", "m68k", "microblaze", "nios2", "blackfin", "avr32", "st200", "sandbox". - - entry : entry point address, address size is determined by + +entry + entry point address, address size is determined by '#address-cells' property of the root node. Mandatory for types: "firmware", and "kernel". - - load : load address, address size is determined by '#address-cells' + +load + load address, address size is determined by '#address-cells' property of the root node. Mandatory for types: "firmware", and "kernel". - - compatible : compatible method for loading image. + +compatible + compatible method for loading image. Mandatory for types: "fpga", and images that do not specify a load address. Supported compatible methods: - "u-boot,fpga-legacy" - the generic fpga loading routine. - "u-boot,zynqmp-fpga-ddrauth" - signed non-encrypted FPGA bitstream for - Xilinx Zynq UltraScale+ (ZymqMP) device. - "u-boot,zynqmp-fpga-enc" - encrypted FPGA bitstream for Xilinx Zynq + + "u-boot,fpga-legacy" + the generic fpga loading routine. + + "u-boot,zynqmp-fpga-ddrauth" + signed non-encrypted FPGA bitstream for + Xilinx Zynq UltraScale+ (ZymqMP) device. + + "u-boot,zynqmp-fpga-enc" + encrypted FPGA bitstream for Xilinx Zynq + UltraScale+ (ZynqMP) device. - - phase : U-Boot phase for which the image is intended. - "spl" - image is an SPL image - "u-boot" - image is a U-Boot image
- Optional nodes: - - hash-1 : Each hash sub-node represents separate hash or checksum +phase + U-Boot phase for which the image is intended. + + "spl" + image is an SPL image + + "u-boot" + image is a U-Boot image + +Optional nodes: + +hash-1 + Each hash sub-node represents separate hash or checksum calculated for node's data according to specified algorithm.
-5) Hash nodes -------------- +Hash nodes +----------
@@ -207,14 +267,18 @@ the '/images' node should have the following layout:: |- algo = "hash or checksum algorithm name" |- value = [hash or checksum value]
- Mandatory properties: - - algo : Algorithm name, supported are "crc32", "md5" and "sha1". - - value : Actual checksum or hash value, correspondingly 4, 16 or 20 bytes - long. +Mandatory properties +~~~~~~~~~~~~~~~~~~~~ + +algo + Algorithm name, supported are "crc32", "md5" and "sha1". + +value + Actual checksum or hash value, correspondingly 4, 16 or 20 bytes long.
-6) '/configurations' node -------------------------- +'/configurations' node +----------------------
The 'configurations' node creates convenient, labeled boot configurations, which combine together kernel images with their ramdisks and fdt blobs. @@ -229,17 +293,21 @@ The 'configurations' node has has the following structure:: ...
- Optional property: - - default : Selects one of the configuration sub-nodes as a default - configuration. +Optional property +~~~~~~~~~~~~~~~~~
- Mandatory nodes: - - configuration-sub-node-unit-name : At least one of the configuration - sub-nodes is required. +default + Selects one of the configuration sub-nodes as a default configuration.
+Mandatory nodes +~~~~~~~~~~~~~~~ + +configuration-sub-node-unit-name + At least one of the configuration sub-nodes is required.
-7) Configuration nodes ----------------------- + +Configuration nodes +-------------------
@@ -252,27 +320,43 @@ Each configuration has the following structure:: |- compatible = "vendor,board-style device tree compatible string"
- Mandatory properties: - - description : Textual configuration description. - - kernel or firmware: Unit name of the corresponding kernel or firmware +Mandatory properties +~~~~~~~~~~~~~~~~~~~~ + +description + Textual configuration description. + +kernel or firmware + Unit name of the corresponding kernel or firmware (u-boot, op-tee, etc) image. If both "kernel" and "firmware" are specified, control is passed to the firmware image.
- Optional properties: - - fdt : Unit name of the corresponding fdt blob (component image node of a +Optional properties +~~~~~~~~~~~~~~~~~~~ + +fdt + Unit name of the corresponding fdt blob (component image node of a "fdt type"). Additional fdt overlay nodes can be supplied which signify that the resulting device tree blob is generated by the first base fdt blob with all subsequent overlays applied. - - fpga : Unit name of the corresponding fpga bitstream blob + +fpga + Unit name of the corresponding fpga bitstream blob (component image node of a "fpga type"). - - loadables : Unit name containing a list of additional binaries to be + +loadables + Unit name containing a list of additional binaries to be loaded at their given locations. "loadables" is a comma-separated list of strings. U-Boot will load each binary at its given start-address and may optionally invoke additional post-processing steps on this binary based on its component image node type. - - script : The image to use when loading a U-Boot script (for use with the + +script + The image to use when loading a U-Boot script (for use with the source command). - - compatible : The root compatible string of the U-Boot device tree that + +compatible + The root compatible string of the U-Boot device tree that this configuration shall automatically match when CONFIG_FIT_BEST_MATCH is enabled. If this property is not provided, the compatible string will be extracted from the fdt blob instead. This is only possible if the fdt is @@ -287,8 +371,8 @@ Older, 2.4 kernel and 2.6 non-FDT kernel do not use FDT blob, in such cases not* be specified in a configuration node.
-8) External data ----------------- +External data +-------------
The above format shows a 'data' property which holds the data for each image. It is also possible for this data to reside outside the FIT itself. This @@ -298,10 +382,12 @@ be loaded from an external source.
In this case the 'data' property is omitted. Instead you can use:
- - data-offset : offset of the data in a separate image store. The image +data-offset + offset of the data in a separate image store. The image store is placed immediately after the last byte of the device tree binary, aligned to a 4-byte boundary. - - data-size : size of the data in bytes + +data-size : size of the data in bytes
The 'data-offset' property can be substituted with 'data-position', which defines an absolute position or address as the offset. This is helpful when @@ -317,7 +403,10 @@ to block(512 byte) for block device, so that we don't need to do the copy when read the image data in SPL. Pass '-B 0x200' to mkimage to align the FIT structure and data to 512 byte, other values available for other align size.
-9) Examples ------------ +Examples +--------
Please see `doc/uImage.FIT/*.its` for actual image source files. + +.. sectionauthor:: Marian Balakowicz m8@semihalf.com +.. sectionauthor:: External data additions, 25/1/16 Simon Glass sjg@chromium.org
Convert these to rST format and add them to the index.
doc/uImage.FIT/kernel.its | 91 --------------- doc/uImage.FIT/kernel_fdt.its | 51 -------- doc/uImage.FIT/kernel_fdts_compressed.its | 73 ------------ doc/uImage.FIT/multi-with-fpga.its | 68 ----------- doc/uImage.FIT/multi-with-loadables.its | 89 -------------- doc/uImage.FIT/multi.its | 133 --------------------- doc/uImage.FIT/multi_spl.its | 96 --------------- doc/uImage.FIT/sec_firmware_ppa.its | 49 -------- doc/uImage.FIT/sign-configs.its | 45 ------- doc/uImage.FIT/sign-images.its | 42 ------- doc/uImage.FIT/uefi.its | 67 ----------- doc/uImage.FIT/update3.its | 44 ------- doc/uImage.FIT/update_uboot.its | 24 ---- doc/usage/fit/kernel.rst | 93 +++++++++++++++ doc/usage/fit/kernel_fdt.rst | 54 +++++++++ doc/usage/fit/kernel_fdts_compressed.rst | 77 ++++++++++++ doc/usage/fit/multi-with-fpga.rst | 70 +++++++++++ doc/usage/fit/multi-with-loadables.rst | 91 +++++++++++++++ doc/usage/fit/multi.rst | 136 ++++++++++++++++++++++ doc/usage/fit/multi_spl.rst | 101 ++++++++++++++++ doc/usage/fit/sec_firmware_ppa.rst | 54 +++++++++ doc/usage/fit/sign-configs.rst | 52 +++++++++ doc/usage/fit/sign-images.rst | 49 ++++++++ doc/usage/fit/source_file_format.rst | 31 ++++- doc/usage/fit/uefi.rst | 72 ++++++++++++ doc/usage/fit/update3.rst | 47 ++++++++ doc/usage/fit/update_uboot.rst | 28 +++++ 27 files changed, 950 insertions(+), 877 deletions(-) delete mode 100644 doc/uImage.FIT/kernel.its delete mode 100644 doc/uImage.FIT/kernel_fdt.its delete mode 100644 doc/uImage.FIT/kernel_fdts_compressed.its delete mode 100644 doc/uImage.FIT/multi-with-fpga.its delete mode 100644 doc/uImage.FIT/multi-with-loadables.its delete mode 100644 doc/uImage.FIT/multi.its delete mode 100644 doc/uImage.FIT/multi_spl.its delete mode 100644 doc/uImage.FIT/sec_firmware_ppa.its delete mode 100644 doc/uImage.FIT/sign-configs.its delete mode 100644 doc/uImage.FIT/sign-images.its delete mode 100644 doc/uImage.FIT/uefi.its delete mode 100644 doc/uImage.FIT/update3.its delete mode 100644 doc/uImage.FIT/update_uboot.its create mode 100644 doc/usage/fit/kernel.rst create mode 100644 doc/usage/fit/kernel_fdt.rst create mode 100644 doc/usage/fit/kernel_fdts_compressed.rst create mode 100644 doc/usage/fit/multi-with-fpga.rst create mode 100644 doc/usage/fit/multi-with-loadables.rst create mode 100644 doc/usage/fit/multi.rst create mode 100644 doc/usage/fit/multi_spl.rst create mode 100644 doc/usage/fit/sec_firmware_ppa.rst create mode 100644 doc/usage/fit/sign-configs.rst create mode 100644 doc/usage/fit/sign-images.rst create mode 100644 doc/usage/fit/uefi.rst create mode 100644 doc/usage/fit/update3.rst create mode 100644 doc/usage/fit/update_uboot.rst
diff --git a/doc/uImage.FIT/kernel.its b/doc/uImage.FIT/kernel.its deleted file mode 100644 index 77ddf622deb8..000000000000 --- a/doc/uImage.FIT/kernel.its +++ /dev/null @@ -1,91 +0,0 @@ -/* - * Simple U-Boot uImage source file containing a single kernel - */ - -/dts-v1/; - -/ { - description = "Simple image with single Linux kernel"; - #address-cells = <1>; - - images { - kernel { - description = "Vanilla Linux kernel"; - data = /incbin/("./vmlinux.bin.gz"); - type = "kernel"; - arch = "ppc"; - os = "linux"; - compression = "gzip"; - load = <00000000>; - entry = <00000000>; - hash-1 { - algo = "crc32"; - }; - hash-2 { - algo = "sha1"; - }; - }; - }; - - configurations { - default = "config-1"; - config-1 { - description = "Boot Linux kernel"; - kernel = "kernel"; - }; - }; -}; - - - -For x86 a setup node is also required: see x86-fit-boot.txt. - -/dts-v1/; - -/ { - description = "Simple image with single Linux kernel on x86"; - #address-cells = <1>; - - images { - kernel { - description = "Vanilla Linux kernel"; - data = /incbin/("./image.bin.lzo"); - type = "kernel"; - arch = "x86"; - os = "linux"; - compression = "lzo"; - load = <0x01000000>; - entry = <0x00000000>; - hash-2 { - algo = "sha1"; - }; - }; - - setup { - description = "Linux setup.bin"; - data = /incbin/("./setup.bin"); - type = "x86_setup"; - arch = "x86"; - os = "linux"; - compression = "none"; - load = <0x00090000>; - entry = <0x00090000>; - hash-2 { - algo = "sha1"; - }; - }; - }; - - configurations { - default = "config-1"; - config-1 { - description = "Boot Linux kernel"; - kernel = "kernel"; - setup = "setup"; - }; - }; -}; - -Note: the above assumes a 32-bit kernel. To directly boot a 64-bit kernel, -change both arch values to "x86_64". U-Boot will then change to 64-bit mode -before booting the kernel (see boot_linux_kernel()). diff --git a/doc/uImage.FIT/kernel_fdt.its b/doc/uImage.FIT/kernel_fdt.its deleted file mode 100644 index 000d85b8e09c..000000000000 --- a/doc/uImage.FIT/kernel_fdt.its +++ /dev/null @@ -1,51 +0,0 @@ -/* - * Simple U-Boot uImage source file containing a single kernel and FDT blob - */ - -/dts-v1/; - -/ { - description = "Simple image with single Linux kernel and FDT blob"; - #address-cells = <1>; - - images { - kernel { - description = "Vanilla Linux kernel"; - data = /incbin/("./vmlinux.bin.gz"); - type = "kernel"; - arch = "ppc"; - os = "linux"; - compression = "gzip"; - load = <00000000>; - entry = <00000000>; - hash-1 { - algo = "crc32"; - }; - hash-2 { - algo = "sha1"; - }; - }; - fdt-1 { - description = "Flattened Device Tree blob"; - data = /incbin/("./target.dtb"); - type = "flat_dt"; - arch = "ppc"; - compression = "none"; - hash-1 { - algo = "crc32"; - }; - hash-2 { - algo = "sha1"; - }; - }; - }; - - configurations { - default = "conf-1"; - conf-1 { - description = "Boot Linux kernel with FDT blob"; - kernel = "kernel"; - fdt = "fdt-1"; - }; - }; -}; diff --git a/doc/uImage.FIT/kernel_fdts_compressed.its b/doc/uImage.FIT/kernel_fdts_compressed.its deleted file mode 100644 index 8f81106efc70..000000000000 --- a/doc/uImage.FIT/kernel_fdts_compressed.its +++ /dev/null @@ -1,73 +0,0 @@ -/* - * U-Boot uImage source file with a kernel and multiple compressed FDT blobs. - * Since the FDTs are compressed, configurations must provide a compatible - * string to match directly. - */ - -/dts-v1/; - -/ { - description = "Image with single Linux kernel and compressed FDT blobs"; - #address-cells = <1>; - - images { - kernel { - description = "Vanilla Linux kernel"; - data = /incbin/("./vmlinux.bin.gz"); - type = "kernel"; - arch = "ppc"; - os = "linux"; - compression = "gzip"; - load = <00000000>; - entry = <00000000>; - hash-1 { - algo = "crc32"; - }; - hash-2 { - algo = "sha1"; - }; - }; - fdt@1 { - description = "Flattened Device Tree blob 1"; - data = /incbin/("./myboard-var1.dtb"); - type = "flat_dt"; - arch = "ppc"; - compression = "gzip"; - hash-1 { - algo = "crc32"; - }; - hash-2 { - algo = "sha1"; - }; - }; - fdt@2 { - description = "Flattened Device Tree blob 2"; - data = /incbin/("./myboard-var2.dtb"); - type = "flat_dt"; - arch = "ppc"; - compression = "lzma"; - hash-1 { - algo = "crc32"; - }; - hash-2 { - algo = "sha1"; - }; - }; - }; - - configurations { - default = "conf@1"; - conf@1 { - description = "Boot Linux kernel with FDT blob 1"; - kernel = "kernel"; - fdt = "fdt@1"; - compatible = "myvendor,myboard-variant1"; - }; - conf@2 { - description = "Boot Linux kernel with FDT blob 2"; - kernel = "kernel"; - fdt = "fdt@2"; - compatible = "myvendor,myboard-variant2"; - }; - }; -}; diff --git a/doc/uImage.FIT/multi-with-fpga.its b/doc/uImage.FIT/multi-with-fpga.its deleted file mode 100644 index 021cbc7cf4a8..000000000000 --- a/doc/uImage.FIT/multi-with-fpga.its +++ /dev/null @@ -1,68 +0,0 @@ -/* - * U-Boot uImage source file with multiple kernels, ramdisks and FDT blobs - * This example makes use of the 'loadables' field - */ - -/dts-v1/; - -/ { - description = "Configuration to load fpga before Kernel"; - #address-cells = <1>; - - images { - fdt-1 { - description = "zc706"; - data = /incbin/("/tftpboot/devicetree.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - load = <0x10000000>; - hash-1 { - algo = "md5"; - }; - }; - - fpga { - description = "FPGA"; - data = /incbin/("/tftpboot/download.bit"); - type = "fpga"; - arch = "arm"; - compression = "none"; - load = <0x30000000>; - compatible = "u-boot,fpga-legacy" - hash-1 { - algo = "md5"; - }; - }; - - linux_kernel { - description = "Linux"; - data = /incbin/("/tftpboot/zImage"); - type = "kernel"; - arch = "arm"; - os = "linux"; - compression = "none"; - load = <0x8000>; - entry = <0x8000>; - hash-1 { - algo = "md5"; - }; - }; - }; - - configurations { - default = "config-2"; - config-1 { - description = "Linux"; - kernel = "linux_kernel"; - fdt = "fdt-1"; - }; - - config-2 { - description = "Linux with fpga"; - kernel = "linux_kernel"; - fdt = "fdt-1"; - loadables = "fpga"; - }; - }; -}; diff --git a/doc/uImage.FIT/multi-with-loadables.its b/doc/uImage.FIT/multi-with-loadables.its deleted file mode 100644 index 4d4909f83207..000000000000 --- a/doc/uImage.FIT/multi-with-loadables.its +++ /dev/null @@ -1,89 +0,0 @@ -/* - * U-Boot uImage source file with multiple kernels, ramdisks and FDT blobs - * This example makes use of the 'loadables' field - */ - -/dts-v1/; - -/ { - description = "Configuration to load a Xen Kernel"; - #address-cells = <1>; - - images { - xen_kernel { - description = "xen binary"; - data = /incbin/("./xen"); - type = "kernel"; - arch = "arm"; - os = "linux"; - compression = "none"; - load = <0xa0000000>; - entry = <0xa0000000>; - hash-1 { - algo = "md5"; - }; - }; - - fdt-1 { - description = "xexpress-ca15 tree blob"; - data = /incbin/("./vexpress-v2p-ca15-tc1.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - load = <0xb0000000>; - hash-1 { - algo = "md5"; - }; - }; - - fdt-2 { - description = "xexpress-ca15 tree blob"; - data = /incbin/("./vexpress-v2p-ca15-tc1.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - load = <0xb0400000>; - hash-1 { - algo = "md5"; - }; - }; - - linux_kernel { - description = "Linux Image"; - data = /incbin/("./Image"); - type = "kernel"; - arch = "arm"; - os = "linux"; - compression = "none"; - load = <0xa0000000>; - entry = <0xa0000000>; - hash-1 { - algo = "md5"; - }; - }; - }; - - configurations { - default = "config-2"; - - config-1 { - description = "Just plain Linux"; - kernel = "linux_kernel"; - fdt = "fdt-1"; - }; - - config-2 { - description = "Xen one loadable"; - kernel = "xen_kernel"; - fdt = "fdt-1"; - loadables = "linux_kernel"; - }; - - config-3 { - description = "Xen two loadables"; - kernel = "xen_kernel"; - fdt = "fdt-1"; - loadables = "linux_kernel", "fdt-2"; - }; - }; -}; diff --git a/doc/uImage.FIT/multi.its b/doc/uImage.FIT/multi.its deleted file mode 100644 index 26c8dad6a2b2..000000000000 --- a/doc/uImage.FIT/multi.its +++ /dev/null @@ -1,133 +0,0 @@ -/* - * U-Boot uImage source file with multiple kernels, ramdisks and FDT blobs - */ - -/dts-v1/; - -/ { - description = "Various kernels, ramdisks and FDT blobs"; - #address-cells = <1>; - - images { - kernel-1 { - description = "vanilla-2.6.23"; - data = /incbin/("./vmlinux.bin.gz"); - type = "kernel"; - arch = "ppc"; - os = "linux"; - compression = "gzip"; - load = <00000000>; - entry = <00000000>; - hash-1 { - algo = "md5"; - }; - hash-2 { - algo = "sha1"; - }; - }; - - kernel-2 { - description = "2.6.23-denx"; - data = /incbin/("./2.6.23-denx.bin.gz"); - type = "kernel"; - arch = "ppc"; - os = "linux"; - compression = "gzip"; - load = <00000000>; - entry = <00000000>; - hash-1 { - algo = "sha1"; - }; - }; - - kernel-3 { - description = "2.4.25-denx"; - data = /incbin/("./2.4.25-denx.bin.gz"); - type = "kernel"; - arch = "ppc"; - os = "linux"; - compression = "gzip"; - load = <00000000>; - entry = <00000000>; - hash-1 { - algo = "md5"; - }; - }; - - ramdisk-1 { - description = "eldk-4.2-ramdisk"; - data = /incbin/("./eldk-4.2-ramdisk"); - type = "ramdisk"; - arch = "ppc"; - os = "linux"; - compression = "gzip"; - load = <00000000>; - entry = <00000000>; - hash-1 { - algo = "sha1"; - }; - }; - - ramdisk-2 { - description = "eldk-3.1-ramdisk"; - data = /incbin/("./eldk-3.1-ramdisk"); - type = "ramdisk"; - arch = "ppc"; - os = "linux"; - compression = "gzip"; - load = <00000000>; - entry = <00000000>; - hash-1 { - algo = "crc32"; - }; - }; - - fdt-1 { - description = "tqm5200-fdt"; - data = /incbin/("./tqm5200.dtb"); - type = "flat_dt"; - arch = "ppc"; - compression = "none"; - hash-1 { - algo = "crc32"; - }; - }; - - fdt-2 { - description = "tqm5200s-fdt"; - data = /incbin/("./tqm5200s.dtb"); - type = "flat_dt"; - arch = "ppc"; - compression = "none"; - load = <00700000>; - hash-1 { - algo = "sha1"; - }; - }; - - }; - - configurations { - default = "config-1"; - - config-1 { - description = "tqm5200 vanilla-2.6.23 configuration"; - kernel = "kernel-1"; - ramdisk = "ramdisk-1"; - fdt = "fdt-1"; - }; - - config-2 { - description = "tqm5200s denx-2.6.23 configuration"; - kernel = "kernel-2"; - ramdisk = "ramdisk-1"; - fdt = "fdt-2"; - }; - - config-3 { - description = "tqm5200s denx-2.4.25 configuration"; - kernel = "kernel-3"; - ramdisk = "ramdisk-2"; - }; - }; -}; diff --git a/doc/uImage.FIT/multi_spl.its b/doc/uImage.FIT/multi_spl.its deleted file mode 100644 index 594219974412..000000000000 --- a/doc/uImage.FIT/multi_spl.its +++ /dev/null @@ -1,96 +0,0 @@ -/dts-v1/; - -/* - * (Bogus) example FIT image description file demonstrating the usage - * of multiple images loaded by the SPL. - * Several binaries will be loaded at their respective load addresses. - * - * For booting U-Boot, "firmware" is searched first. If not found, "loadables" - * is used to identify images to be loaded into memory. If falcon boot is - * enabled, "kernel" is searched first. If not found, it falls back to the - * same flow as booting U-Boot. Changing image type will result skipping - * specific image. - * - * Finally the one image specifying an entry point will be entered by the SPL. - */ - -/ { - description = "multiple firmware blobs and U-Boot, loaded by SPL"; - #address-cells = <0x1>; - - images { - - uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <0x4a000000>; - }; - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x18000>; - entry = <0x18000>; - }; - - mgmt-firmware { - description = "arisc management processor firmware"; - type = "firmware"; - arch = "or1k"; - compression = "none"; - load = <0x40000>; - }; - - fdt-1 { - description = "Pine64+ DT"; - type = "flat_dt"; - compression = "none"; - load = <0x4fa00000>; - arch = "arm64"; - }; - - fdt-2 { - description = "Pine64 DT"; - type = "flat_dt"; - compression = "none"; - load = <0x4fa00000>; - arch = "arm64"; - }; - - kernel { - description = "4.7-rc5 kernel"; - type = "kernel"; - compression = "none"; - load = <0x40080000>; - arch = "arm64"; - }; - - initrd { - description = "Debian installer initrd"; - type = "ramdisk"; - compression = "none"; - load = <0x4fe00000>; - arch = "arm64"; - }; - }; - - configurations { - default = "config-1"; - - config-1 { - description = "sun50i-a64-pine64-plus"; - loadables = "uboot", "atf", "kernel", "initrd"; - fdt = "fdt-1"; - }; - - config-2 { - description = "sun50i-a64-pine64"; - loadables = "uboot", "atf", "mgmt-firmware"; - fdt = "fdt-2"; - }; - }; -}; diff --git a/doc/uImage.FIT/sec_firmware_ppa.its b/doc/uImage.FIT/sec_firmware_ppa.its deleted file mode 100644 index a7acde17cf3e..000000000000 --- a/doc/uImage.FIT/sec_firmware_ppa.its +++ /dev/null @@ -1,49 +0,0 @@ -/dts-v1/; - -/* - * Example FIT image description file demonstrating the usage - * of SEC Firmware and multiple loadable images loaded by the u-boot. - * For booting PPA (SEC Firmware), "firmware" is searched and loaded. - * - * Multiple binaries will be loaded as "loadables" (if present) at their - * respective load offsets from firmware image address. - */ - -/{ - description = "PPA Firmware"; - #address-cells = <1>; - images { - firmware@1 { - description = "PPA Firmware: <version>"; - data = /incbin/("../obj/monitor.bin"); - type = "firmware"; - arch = "arm64"; - compression = "none"; - }; - trustedOS@1 { - description = "Trusted OS"; - data = /incbin/("../../tee.bin"); - type = "OS"; - arch = "arm64"; - compression = "none"; - load = <0x00200000>; - }; - fuse_scr { - description = "Fuse Script"; - data = /incbin/("../../fuse_scr.bin"); - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x00180000>; - }; - }; - - configurations { - default = "config-1"; - config-1 { - description = "PPA Secure firmware"; - firmware = "firmware@1"; - loadables = "trustedOS@1", "fuse_scr"; - }; - }; -}; diff --git a/doc/uImage.FIT/sign-configs.its b/doc/uImage.FIT/sign-configs.its deleted file mode 100644 index 9e992c198826..000000000000 --- a/doc/uImage.FIT/sign-configs.its +++ /dev/null @@ -1,45 +0,0 @@ -/dts-v1/; - -/ { - description = "Chrome OS kernel image with one or more FDT blobs"; - #address-cells = <1>; - - images { - kernel { - data = /incbin/("test-kernel.bin"); - type = "kernel_noload"; - arch = "sandbox"; - os = "linux"; - compression = "lzo"; - load = <0x4>; - entry = <0x8>; - kernel-version = <1>; - hash-1 { - algo = "sha1"; - }; - }; - fdt-1 { - description = "snow"; - data = /incbin/("sandbox-kernel.dtb"); - type = "flat_dt"; - arch = "sandbox"; - compression = "none"; - fdt-version = <1>; - hash-1 { - algo = "sha1"; - }; - }; - }; - configurations { - default = "conf-1"; - conf-1 { - kernel = "kernel"; - fdt = "fdt-1"; - signature { - algo = "sha1,rsa2048"; - key-name-hint = "dev"; - sign-images = "fdt", "kernel"; - }; - }; - }; -}; diff --git a/doc/uImage.FIT/sign-images.its b/doc/uImage.FIT/sign-images.its deleted file mode 100644 index 18c759e9e65c..000000000000 --- a/doc/uImage.FIT/sign-images.its +++ /dev/null @@ -1,42 +0,0 @@ -/dts-v1/; - -/ { - description = "Chrome OS kernel image with one or more FDT blobs"; - #address-cells = <1>; - - images { - kernel { - data = /incbin/("test-kernel.bin"); - type = "kernel_noload"; - arch = "sandbox"; - os = "linux"; - compression = "none"; - load = <0x4>; - entry = <0x8>; - kernel-version = <1>; - signature { - algo = "sha1,rsa2048"; - key-name-hint = "dev"; - }; - }; - fdt-1 { - description = "snow"; - data = /incbin/("sandbox-kernel.dtb"); - type = "flat_dt"; - arch = "sandbox"; - compression = "none"; - fdt-version = <1>; - signature { - algo = "sha1,rsa2048"; - key-name-hint = "dev"; - }; - }; - }; - configurations { - default = "conf-1"; - conf-1 { - kernel = "kernel"; - fdt = "fdt-1"; - }; - }; -}; diff --git a/doc/uImage.FIT/uefi.its b/doc/uImage.FIT/uefi.its deleted file mode 100644 index 378ca4ed8d7a..000000000000 --- a/doc/uImage.FIT/uefi.its +++ /dev/null @@ -1,67 +0,0 @@ -/* - * Example FIT image description file demonstrating the usage of the - * bootm command to launch UEFI binaries. - * - * Two boot configurations are available to enable booting GRUB2 on QEMU, - * the former uses a FDT blob contained in the FIT image, while the later - * relies on the FDT provided by the board emulator. - */ - -/dts-v1/; - -/ { - description = "GRUB2 EFI and QEMU FDT blob"; - #address-cells = <1>; - - images { - efi-grub { - description = "GRUB EFI Firmware"; - data = /incbin/("bootarm.efi"); - type = "kernel_noload"; - arch = "arm"; - os = "efi"; - compression = "none"; - load = <0x0>; - entry = <0x0>; - hash-1 { - algo = "sha256"; - }; - }; - - fdt-qemu { - description = "QEMU DTB"; - data = /incbin/("qemu-arm.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - hash-1 { - algo = "sha256"; - }; - }; - }; - - configurations { - default = "config-grub-fdt"; - - config-grub-fdt { - description = "GRUB EFI Boot w/ FDT"; - kernel = "efi-grub"; - fdt = "fdt-qemu"; - signature-1 { - algo = "sha256,rsa2048"; - key-name-hint = "dev"; - sign-images = "kernel", "fdt"; - }; - }; - - config-grub-nofdt { - description = "GRUB EFI Boot w/o FDT"; - kernel = "efi-grub"; - signature-1 { - algo = "sha256,rsa2048"; - key-name-hint = "dev"; - sign-images = "kernel"; - }; - }; - }; -}; diff --git a/doc/uImage.FIT/update3.its b/doc/uImage.FIT/update3.its deleted file mode 100644 index 0659f20002d5..000000000000 --- a/doc/uImage.FIT/update3.its +++ /dev/null @@ -1,44 +0,0 @@ -/* - * Example Automatic software update file. - */ - -/dts-v1/; - -/ { - description = "Automatic software updates: kernel, ramdisk, FDT"; - #address-cells = <1>; - - images { - update-1 { - description = "Linux kernel binary"; - data = /incbin/("./vmlinux.bin.gz"); - compression = "none"; - type = "firmware"; - load = <FF700000>; - hash-1 { - algo = "sha1"; - }; - }; - update-2 { - description = "Ramdisk image"; - data = /incbin/("./ramdisk_image.gz"); - compression = "none"; - type = "firmware"; - load = <FF8E0000>; - hash-1 { - algo = "sha1"; - }; - }; - - update-3 { - description = "FDT blob"; - data = /incbin/("./blob.fdt"); - compression = "none"; - type = "firmware"; - load = <FFAC0000>; - hash-1 { - algo = "sha1"; - }; - }; - }; -}; diff --git a/doc/uImage.FIT/update_uboot.its b/doc/uImage.FIT/update_uboot.its deleted file mode 100644 index aec482600815..000000000000 --- a/doc/uImage.FIT/update_uboot.its +++ /dev/null @@ -1,24 +0,0 @@ -/* - * Automatic software update for U-Boot - * Make sure the flashing addresses ('load' prop) is correct for your board! - */ - -/dts-v1/; - -/ { - description = "Automatic U-Boot update"; - #address-cells = <1>; - - images { - update-1 { - description = "U-Boot binary"; - data = /incbin/("./u-boot.bin"); - compression = "none"; - type = "firmware"; - load = <0xFFFC0000>; - hash-1 { - algo = "sha1"; - }; - }; - }; -}; diff --git a/doc/usage/fit/kernel.rst b/doc/usage/fit/kernel.rst new file mode 100644 index 000000000000..012a81efead8 --- /dev/null +++ b/doc/usage/fit/kernel.rst @@ -0,0 +1,93 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Single kernel +============= + +:: + + /dts-v1/; + + / { + description = "Simple image with single Linux kernel"; + #address-cells = <1>; + + images { + kernel { + description = "Vanilla Linux kernel"; + data = /incbin/("./vmlinux.bin.gz"); + type = "kernel"; + arch = "ppc"; + os = "linux"; + compression = "gzip"; + load = <00000000>; + entry = <00000000>; + hash-1 { + algo = "crc32"; + }; + hash-2 { + algo = "sha1"; + }; + }; + }; + + configurations { + default = "config-1"; + config-1 { + description = "Boot Linux kernel"; + kernel = "kernel"; + }; + }; + }; + + +For x86 a setup node is also required: see x86-fit-boot:: + + /dts-v1/; + + / { + description = "Simple image with single Linux kernel on x86"; + #address-cells = <1>; + + images { + kernel { + description = "Vanilla Linux kernel"; + data = /incbin/("./image.bin.lzo"); + type = "kernel"; + arch = "x86"; + os = "linux"; + compression = "lzo"; + load = <0x01000000>; + entry = <0x00000000>; + hash-2 { + algo = "sha1"; + }; + }; + + setup { + description = "Linux setup.bin"; + data = /incbin/("./setup.bin"); + type = "x86_setup"; + arch = "x86"; + os = "linux"; + compression = "none"; + load = <0x00090000>; + entry = <0x00090000>; + hash-2 { + algo = "sha1"; + }; + }; + }; + + configurations { + default = "config-1"; + config-1 { + description = "Boot Linux kernel"; + kernel = "kernel"; + setup = "setup"; + }; + }; + }; + +Note: the above assumes a 32-bit kernel. To directly boot a 64-bit kernel, +change both arch values to "x86_64". U-Boot will then change to 64-bit mode +before booting the kernel (see boot_linux_kernel()). diff --git a/doc/usage/fit/kernel_fdt.rst b/doc/usage/fit/kernel_fdt.rst new file mode 100644 index 000000000000..8eee13af7808 --- /dev/null +++ b/doc/usage/fit/kernel_fdt.rst @@ -0,0 +1,54 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Single kernel and FDT blob +========================== + +:: + + /dts-v1/; + + / { + description = "Simple image with single Linux kernel and FDT blob"; + #address-cells = <1>; + + images { + kernel { + description = "Vanilla Linux kernel"; + data = /incbin/("./vmlinux.bin.gz"); + type = "kernel"; + arch = "ppc"; + os = "linux"; + compression = "gzip"; + load = <00000000>; + entry = <00000000>; + hash-1 { + algo = "crc32"; + }; + hash-2 { + algo = "sha1"; + }; + }; + fdt-1 { + description = "Flattened Device Tree blob"; + data = /incbin/("./target.dtb"); + type = "flat_dt"; + arch = "ppc"; + compression = "none"; + hash-1 { + algo = "crc32"; + }; + hash-2 { + algo = "sha1"; + }; + }; + }; + + configurations { + default = "conf-1"; + conf-1 { + description = "Boot Linux kernel with FDT blob"; + kernel = "kernel"; + fdt = "fdt-1"; + }; + }; + }; diff --git a/doc/usage/fit/kernel_fdts_compressed.rst b/doc/usage/fit/kernel_fdts_compressed.rst new file mode 100644 index 000000000000..0b169c7c27c4 --- /dev/null +++ b/doc/usage/fit/kernel_fdts_compressed.rst @@ -0,0 +1,77 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Kernel and multiple compressed FDT blobs +======================================== + +Since the FDTs are compressed, configurations must provide a compatible +string to match directly. + +:: + + /dts-v1/; + + / { + description = "Image with single Linux kernel and compressed FDT blobs"; + #address-cells = <1>; + + images { + kernel { + description = "Vanilla Linux kernel"; + data = /incbin/("./vmlinux.bin.gz"); + type = "kernel"; + arch = "ppc"; + os = "linux"; + compression = "gzip"; + load = <00000000>; + entry = <00000000>; + hash-1 { + algo = "crc32"; + }; + hash-2 { + algo = "sha1"; + }; + }; + fdt@1 { + description = "Flattened Device Tree blob 1"; + data = /incbin/("./myboard-var1.dtb"); + type = "flat_dt"; + arch = "ppc"; + compression = "gzip"; + hash-1 { + algo = "crc32"; + }; + hash-2 { + algo = "sha1"; + }; + }; + fdt@2 { + description = "Flattened Device Tree blob 2"; + data = /incbin/("./myboard-var2.dtb"); + type = "flat_dt"; + arch = "ppc"; + compression = "lzma"; + hash-1 { + algo = "crc32"; + }; + hash-2 { + algo = "sha1"; + }; + }; + }; + + configurations { + default = "conf@1"; + conf@1 { + description = "Boot Linux kernel with FDT blob 1"; + kernel = "kernel"; + fdt = "fdt@1"; + compatible = "myvendor,myboard-variant1"; + }; + conf@2 { + description = "Boot Linux kernel with FDT blob 2"; + kernel = "kernel"; + fdt = "fdt@2"; + compatible = "myvendor,myboard-variant2"; + }; + }; + }; diff --git a/doc/usage/fit/multi-with-fpga.rst b/doc/usage/fit/multi-with-fpga.rst new file mode 100644 index 000000000000..28d7d5d26261 --- /dev/null +++ b/doc/usage/fit/multi-with-fpga.rst @@ -0,0 +1,70 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Multiple kernels, ramdisks and FDT blobs with FPGA +================================================== + +This example makes use of the 'loadables' field:: + + /dts-v1/; + + / { + description = "Configuration to load fpga before Kernel"; + #address-cells = <1>; + + images { + fdt-1 { + description = "zc706"; + data = /incbin/("/tftpboot/devicetree.dtb"); + type = "flat_dt"; + arch = "arm"; + compression = "none"; + load = <0x10000000>; + hash-1 { + algo = "md5"; + }; + }; + + fpga { + description = "FPGA"; + data = /incbin/("/tftpboot/download.bit"); + type = "fpga"; + arch = "arm"; + compression = "none"; + load = <0x30000000>; + compatible = "u-boot,fpga-legacy" + hash-1 { + algo = "md5"; + }; + }; + + linux_kernel { + description = "Linux"; + data = /incbin/("/tftpboot/zImage"); + type = "kernel"; + arch = "arm"; + os = "linux"; + compression = "none"; + load = <0x8000>; + entry = <0x8000>; + hash-1 { + algo = "md5"; + }; + }; + }; + + configurations { + default = "config-2"; + config-1 { + description = "Linux"; + kernel = "linux_kernel"; + fdt = "fdt-1"; + }; + + config-2 { + description = "Linux with fpga"; + kernel = "linux_kernel"; + fdt = "fdt-1"; + loadables = "fpga"; + }; + }; + }; diff --git a/doc/usage/fit/multi-with-loadables.rst b/doc/usage/fit/multi-with-loadables.rst new file mode 100644 index 000000000000..a0241df96ca2 --- /dev/null +++ b/doc/usage/fit/multi-with-loadables.rst @@ -0,0 +1,91 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Multiple kernels, ramdisks and FDT blobs with Xen +================================================= + +This example makes use of the 'loadables' field:: + + /dts-v1/; + + / { + description = "Configuration to load a Xen Kernel"; + #address-cells = <1>; + + images { + xen_kernel { + description = "xen binary"; + data = /incbin/("./xen"); + type = "kernel"; + arch = "arm"; + os = "linux"; + compression = "none"; + load = <0xa0000000>; + entry = <0xa0000000>; + hash-1 { + algo = "md5"; + }; + }; + + fdt-1 { + description = "xexpress-ca15 tree blob"; + data = /incbin/("./vexpress-v2p-ca15-tc1.dtb"); + type = "flat_dt"; + arch = "arm"; + compression = "none"; + load = <0xb0000000>; + hash-1 { + algo = "md5"; + }; + }; + + fdt-2 { + description = "xexpress-ca15 tree blob"; + data = /incbin/("./vexpress-v2p-ca15-tc1.dtb"); + type = "flat_dt"; + arch = "arm"; + compression = "none"; + load = <0xb0400000>; + hash-1 { + algo = "md5"; + }; + }; + + linux_kernel { + description = "Linux Image"; + data = /incbin/("./Image"); + type = "kernel"; + arch = "arm"; + os = "linux"; + compression = "none"; + load = <0xa0000000>; + entry = <0xa0000000>; + hash-1 { + algo = "md5"; + }; + }; + }; + + configurations { + default = "config-2"; + + config-1 { + description = "Just plain Linux"; + kernel = "linux_kernel"; + fdt = "fdt-1"; + }; + + config-2 { + description = "Xen one loadable"; + kernel = "xen_kernel"; + fdt = "fdt-1"; + loadables = "linux_kernel"; + }; + + config-3 { + description = "Xen two loadables"; + kernel = "xen_kernel"; + fdt = "fdt-1"; + loadables = "linux_kernel", "fdt-2"; + }; + }; + }; diff --git a/doc/usage/fit/multi.rst b/doc/usage/fit/multi.rst new file mode 100644 index 000000000000..2e6ae58c4094 --- /dev/null +++ b/doc/usage/fit/multi.rst @@ -0,0 +1,136 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Multiple kernels, ramdisks and FDT blobs +======================================== + +:: + + /dts-v1/; + + / { + description = "Various kernels, ramdisks and FDT blobs"; + #address-cells = <1>; + + images { + kernel-1 { + description = "vanilla-2.6.23"; + data = /incbin/("./vmlinux.bin.gz"); + type = "kernel"; + arch = "ppc"; + os = "linux"; + compression = "gzip"; + load = <00000000>; + entry = <00000000>; + hash-1 { + algo = "md5"; + }; + hash-2 { + algo = "sha1"; + }; + }; + + kernel-2 { + description = "2.6.23-denx"; + data = /incbin/("./2.6.23-denx.bin.gz"); + type = "kernel"; + arch = "ppc"; + os = "linux"; + compression = "gzip"; + load = <00000000>; + entry = <00000000>; + hash-1 { + algo = "sha1"; + }; + }; + + kernel-3 { + description = "2.4.25-denx"; + data = /incbin/("./2.4.25-denx.bin.gz"); + type = "kernel"; + arch = "ppc"; + os = "linux"; + compression = "gzip"; + load = <00000000>; + entry = <00000000>; + hash-1 { + algo = "md5"; + }; + }; + + ramdisk-1 { + description = "eldk-4.2-ramdisk"; + data = /incbin/("./eldk-4.2-ramdisk"); + type = "ramdisk"; + arch = "ppc"; + os = "linux"; + compression = "gzip"; + load = <00000000>; + entry = <00000000>; + hash-1 { + algo = "sha1"; + }; + }; + + ramdisk-2 { + description = "eldk-3.1-ramdisk"; + data = /incbin/("./eldk-3.1-ramdisk"); + type = "ramdisk"; + arch = "ppc"; + os = "linux"; + compression = "gzip"; + load = <00000000>; + entry = <00000000>; + hash-1 { + algo = "crc32"; + }; + }; + + fdt-1 { + description = "tqm5200-fdt"; + data = /incbin/("./tqm5200.dtb"); + type = "flat_dt"; + arch = "ppc"; + compression = "none"; + hash-1 { + algo = "crc32"; + }; + }; + + fdt-2 { + description = "tqm5200s-fdt"; + data = /incbin/("./tqm5200s.dtb"); + type = "flat_dt"; + arch = "ppc"; + compression = "none"; + load = <00700000>; + hash-1 { + algo = "sha1"; + }; + }; + + }; + + configurations { + default = "config-1"; + + config-1 { + description = "tqm5200 vanilla-2.6.23 configuration"; + kernel = "kernel-1"; + ramdisk = "ramdisk-1"; + fdt = "fdt-1"; + }; + + config-2 { + description = "tqm5200s denx-2.6.23 configuration"; + kernel = "kernel-2"; + ramdisk = "ramdisk-1"; + fdt = "fdt-2"; + }; + + config-3 { + description = "tqm5200s denx-2.4.25 configuration"; + kernel = "kernel-3"; + ramdisk = "ramdisk-2"; + }; + }; + }; diff --git a/doc/usage/fit/multi_spl.rst b/doc/usage/fit/multi_spl.rst new file mode 100644 index 000000000000..74b6f865abd9 --- /dev/null +++ b/doc/usage/fit/multi_spl.rst @@ -0,0 +1,101 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Multiple images for SPL +======================= + +(Bogus) example FIT image description file demonstrating the usage +of multiple images loaded by the SPL. +Several binaries will be loaded at their respective load addresses. + +For booting U-Boot, "firmware" is searched first. If not found, "loadables" +is used to identify images to be loaded into memory. If falcon boot is +enabled, "kernel" is searched first. If not found, it falls back to the +same flow as booting U-Boot. Changing image type will result skipping +specific image. + +Finally the one image specifying an entry point will be entered by the SPL. + +:: + + /dts-v1/; + + / { + description = "multiple firmware blobs and U-Boot, loaded by SPL"; + #address-cells = <0x1>; + + images { + + uboot { + description = "U-Boot (64-bit)"; + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <0x4a000000>; + }; + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x18000>; + entry = <0x18000>; + }; + + mgmt-firmware { + description = "arisc management processor firmware"; + type = "firmware"; + arch = "or1k"; + compression = "none"; + load = <0x40000>; + }; + + fdt-1 { + description = "Pine64+ DT"; + type = "flat_dt"; + compression = "none"; + load = <0x4fa00000>; + arch = "arm64"; + }; + + fdt-2 { + description = "Pine64 DT"; + type = "flat_dt"; + compression = "none"; + load = <0x4fa00000>; + arch = "arm64"; + }; + + kernel { + description = "4.7-rc5 kernel"; + type = "kernel"; + compression = "none"; + load = <0x40080000>; + arch = "arm64"; + }; + + initrd { + description = "Debian installer initrd"; + type = "ramdisk"; + compression = "none"; + load = <0x4fe00000>; + arch = "arm64"; + }; + }; + + configurations { + default = "config-1"; + + config-1 { + description = "sun50i-a64-pine64-plus"; + loadables = "uboot", "atf", "kernel", "initrd"; + fdt = "fdt-1"; + }; + + config-2 { + description = "sun50i-a64-pine64"; + loadables = "uboot", "atf", "mgmt-firmware"; + fdt = "fdt-2"; + }; + }; + }; diff --git a/doc/usage/fit/sec_firmware_ppa.rst b/doc/usage/fit/sec_firmware_ppa.rst new file mode 100644 index 000000000000..4cb292cb4eef --- /dev/null +++ b/doc/usage/fit/sec_firmware_ppa.rst @@ -0,0 +1,54 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +SEC Firmware and multiple loadable images +========================================= + +Example FIT image description file demonstrating the usage +of SEC Firmware and multiple loadable images loaded by U-Boot. +For booting PPA (SEC Firmware), "firmware" is searched and loaded. + +Multiple binaries will be loaded as "loadables" (if present) at their +respective load offsets from firmware image address. + +:: + + /dts-v1/; + + /{ + description = "PPA Firmware"; + #address-cells = <1>; + images { + firmware@1 { + description = "PPA Firmware: <version>"; + data = /incbin/("../obj/monitor.bin"); + type = "firmware"; + arch = "arm64"; + compression = "none"; + }; + trustedOS@1 { + description = "Trusted OS"; + data = /incbin/("../../tee.bin"); + type = "OS"; + arch = "arm64"; + compression = "none"; + load = <0x00200000>; + }; + fuse_scr { + description = "Fuse Script"; + data = /incbin/("../../fuse_scr.bin"); + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x00180000>; + }; + }; + + configurations { + default = "config-1"; + config-1 { + description = "PPA Secure firmware"; + firmware = "firmware@1"; + loadables = "trustedOS@1", "fuse_scr"; + }; + }; + }; diff --git a/doc/usage/fit/sign-configs.rst b/doc/usage/fit/sign-configs.rst new file mode 100644 index 000000000000..6a3df8f2c5b4 --- /dev/null +++ b/doc/usage/fit/sign-configs.rst @@ -0,0 +1,52 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Signed configurations +===================== + +:: + + /dts-v1/; + + / { + description = "Chrome OS kernel image with one or more FDT blobs"; + #address-cells = <1>; + + images { + kernel { + data = /incbin/("test-kernel.bin"); + type = "kernel_noload"; + arch = "sandbox"; + os = "linux"; + compression = "lzo"; + load = <0x4>; + entry = <0x8>; + kernel-version = <1>; + hash-1 { + algo = "sha1"; + }; + }; + fdt-1 { + description = "snow"; + data = /incbin/("sandbox-kernel.dtb"); + type = "flat_dt"; + arch = "sandbox"; + compression = "none"; + fdt-version = <1>; + hash-1 { + algo = "sha1"; + }; + }; + }; + configurations { + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; + signature { + algo = "sha1,rsa2048"; + key-name-hint = "dev"; + sign-images = "fdt", "kernel"; + }; + }; + }; + }; diff --git a/doc/usage/fit/sign-images.rst b/doc/usage/fit/sign-images.rst new file mode 100644 index 000000000000..7d54d702c97f --- /dev/null +++ b/doc/usage/fit/sign-images.rst @@ -0,0 +1,49 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Signed Images +============= + +:: + + /dts-v1/; + + / { + description = "Chrome OS kernel image with one or more FDT blobs"; + #address-cells = <1>; + + images { + kernel { + data = /incbin/("test-kernel.bin"); + type = "kernel_noload"; + arch = "sandbox"; + os = "linux"; + compression = "none"; + load = <0x4>; + entry = <0x8>; + kernel-version = <1>; + signature { + algo = "sha1,rsa2048"; + key-name-hint = "dev"; + }; + }; + fdt-1 { + description = "snow"; + data = /incbin/("sandbox-kernel.dtb"); + type = "flat_dt"; + arch = "sandbox"; + compression = "none"; + fdt-version = <1>; + signature { + algo = "sha1,rsa2048"; + key-name-hint = "dev"; + }; + }; + }; + configurations { + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; + }; + }; + }; diff --git a/doc/usage/fit/source_file_format.rst b/doc/usage/fit/source_file_format.rst index 4d2ea0a7b158..0216ce714a5f 100644 --- a/doc/usage/fit/source_file_format.rst +++ b/doc/usage/fit/source_file_format.rst @@ -1,3 +1,5 @@ +.. SPDX-License-Identifier: GPL-2.0+ + U-Boot new uImage source file format (bindings definition) ==========================================================
@@ -72,10 +74,10 @@ actual binary of a new uImage::
tqm5200.its + - vmlinux.bin.gz mkimage + dtc xfer to target + vmlinux.bin.gz mkimage + dtc xfer to target eldk-4.2-ramdisk --------------> tqm5200.itb --------------> bootm - tqm5200.dtb /|\ - ... | + tqm5200.dtb /|\ + ... | 'new uImage'
Steps: @@ -387,7 +389,8 @@ data-offset store is placed immediately after the last byte of the device tree binary, aligned to a 4-byte boundary.
-data-size : size of the data in bytes +data-size + size of the data in bytes
The 'data-offset' property can be substituted with 'data-position', which defines an absolute position or address as the offset. This is helpful when @@ -406,7 +409,25 @@ structure and data to 512 byte, other values available for other align size. Examples --------
-Please see `doc/uImage.FIT/*.its` for actual image source files. +Some example files are available here, showing various scenarios + +.. toctree:: + :maxdepth: 1 + + kernel + kernel_fdt + kernel_fdts_compressed + kernel + multi + multi_spl + multi-with-fpga + multi-with-loadables + sec_firmware_ppa + sign-configs + sign-images + uefi + update3 + update_uboot
.. sectionauthor:: Marian Balakowicz m8@semihalf.com .. sectionauthor:: External data additions, 25/1/16 Simon Glass sjg@chromium.org diff --git a/doc/usage/fit/uefi.rst b/doc/usage/fit/uefi.rst new file mode 100644 index 000000000000..3bbacb5cad0e --- /dev/null +++ b/doc/usage/fit/uefi.rst @@ -0,0 +1,72 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +UEFI +==== + +Example FIT image description file demonstrating the usage of the +bootm command to launch UEFI binaries. + +Two boot configurations are available to enable booting GRUB2 on QEMU, +the former uses a FDT blob contained in the FIT image, while the later +relies on the FDT provided by the board emulator. + +:: + + /dts-v1/; + + / { + description = "GRUB2 EFI and QEMU FDT blob"; + #address-cells = <1>; + + images { + efi-grub { + description = "GRUB EFI Firmware"; + data = /incbin/("bootarm.efi"); + type = "kernel_noload"; + arch = "arm"; + os = "efi"; + compression = "none"; + load = <0x0>; + entry = <0x0>; + hash-1 { + algo = "sha256"; + }; + }; + + fdt-qemu { + description = "QEMU DTB"; + data = /incbin/("qemu-arm.dtb"); + type = "flat_dt"; + arch = "arm"; + compression = "none"; + hash-1 { + algo = "sha256"; + }; + }; + }; + + configurations { + default = "config-grub-fdt"; + + config-grub-fdt { + description = "GRUB EFI Boot w/ FDT"; + kernel = "efi-grub"; + fdt = "fdt-qemu"; + signature-1 { + algo = "sha256,rsa2048"; + key-name-hint = "dev"; + sign-images = "kernel", "fdt"; + }; + }; + + config-grub-nofdt { + description = "GRUB EFI Boot w/o FDT"; + kernel = "efi-grub"; + signature-1 { + algo = "sha256,rsa2048"; + key-name-hint = "dev"; + sign-images = "kernel"; + }; + }; + }; + }; diff --git a/doc/usage/fit/update3.rst b/doc/usage/fit/update3.rst new file mode 100644 index 000000000000..4ff3950c01e9 --- /dev/null +++ b/doc/usage/fit/update3.rst @@ -0,0 +1,47 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Automatic software update: multiple files +========================================= + +:: + + /dts-v1/; + + / { + description = "Automatic software updates: kernel, ramdisk, FDT"; + #address-cells = <1>; + + images { + update-1 { + description = "Linux kernel binary"; + data = /incbin/("./vmlinux.bin.gz"); + compression = "none"; + type = "firmware"; + load = <FF700000>; + hash-1 { + algo = "sha1"; + }; + }; + update-2 { + description = "Ramdisk image"; + data = /incbin/("./ramdisk_image.gz"); + compression = "none"; + type = "firmware"; + load = <FF8E0000>; + hash-1 { + algo = "sha1"; + }; + }; + + update-3 { + description = "FDT blob"; + data = /incbin/("./blob.fdt"); + compression = "none"; + type = "firmware"; + load = <FFAC0000>; + hash-1 { + algo = "sha1"; + }; + }; + }; + }; diff --git a/doc/usage/fit/update_uboot.rst b/doc/usage/fit/update_uboot.rst new file mode 100644 index 000000000000..a9288ee63679 --- /dev/null +++ b/doc/usage/fit/update_uboot.rst @@ -0,0 +1,28 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Automatic software update +========================= + +Make sure the flashing addresses ('load' prop) is correct for your board! + +:: + + /dts-v1/; + + / { + description = "Automatic U-Boot update"; + #address-cells = <1>; + + images { + update-1 { + description = "U-Boot binary"; + data = /incbin/("./u-boot.bin"); + compression = "none"; + type = "firmware"; + load = <0xFFFC0000>; + hash-1 { + algo = "sha1"; + }; + }; + }; + };
Bring this file into the documentation.
doc/uImage.FIT/x86-fit-boot.txt | 272 -------------------------------- doc/usage/fit/index.rst | 1 + doc/usage/fit/x86-fit-boot.rst | 269 +++++++++++++++++++++++++++++++ 3 files changed, 270 insertions(+), 272 deletions(-) delete mode 100644 doc/uImage.FIT/x86-fit-boot.txt create mode 100644 doc/usage/fit/x86-fit-boot.rst
diff --git a/doc/uImage.FIT/x86-fit-boot.txt b/doc/uImage.FIT/x86-fit-boot.txt deleted file mode 100644 index 88d3460a83eb..000000000000 --- a/doc/uImage.FIT/x86-fit-boot.txt +++ /dev/null @@ -1,272 +0,0 @@ -Booting Linux on x86 with FIT -============================= - -Background ----------- - -(corrections to the text below are welcome) - -Generally Linux x86 uses its own very complex booting method. There is a setup -binary which contains all sorts of parameters and a compressed self-extracting -binary for the kernel itself, often with a small built-in serial driver to -display decompression progress. - -The x86 CPU has various processor modes. I am no expert on these, but my -understanding is that an x86 CPU (even a really new one) starts up in a 16-bit -'real' mode where only 1MB of memory is visible, moves to 32-bit 'protected' -mode where 4GB is visible (or more with special memory access techniques) and -then to 64-bit 'long' mode if 64-bit execution is required. - -Partly the self-extracting nature of Linux was introduced to cope with boot -loaders that were barely capable of loading anything. Even changing to 32-bit -mode was something of a challenge, so putting this logic in the kernel seemed -to make sense. - -Bit by bit more and more logic has been added to this post-boot pre-Linux -wrapper: - -- Changing to 32-bit mode -- Decompression -- Serial output (with drivers for various chips) -- Load address randomisation -- Elf loader complete with relocation (for the above) -- Random number generator via 3 methods (again for the above) -- Some sort of EFI mini-loader (1000+ glorious lines of code) -- Locating and tacking on a device tree and ramdisk - -To my mind, if you sit back and look at things from first principles, this -doesn't make a huge amount of sense. Any boot loader worth its salts already -has most of the above features and more besides. The boot loader already knows -the layout of memory, has a serial driver, can decompress things, includes an -ELF loader and supports device tree and ramdisks. The decision to duplicate -all these features in a Linux wrapper caters for the lowest common -denominator: a boot loader which consists of a BIOS call to load something off -disk, followed by a jmp instruction. - -(Aside: On ARM systems, we worry that the boot loader won't know where to load -the kernel. It might be easier to just provide that information in the image, -or in the boot loader rather than adding a self-relocator to put it in the -right place. Or just use ELF? - -As a result, the x86 kernel boot process is needlessly complex. The file -format is also complex, and obfuscates the contents to a degree that it is -quite a challenge to extract anything from it. This bzImage format has become -so prevalent that is actually isn't possible to produce the 'raw' kernel build -outputs with the standard Makefile (as it is on ARM for example, at least at -the time of writing). - -This document describes an alternative boot process which uses simple raw -images which are loaded into the right place by the boot loader and then -executed. - - -Build the kernel ----------------- - -Note: these instructions assume a 32-bit kernel. U-Boot also supports directly -booting a 64-bit kernel by jumping into 64-bit mode first (see below). - -You can build the kernel as normal with 'make'. This will create a file called -'vmlinux'. This is a standard ELF file and you can look at it if you like: - -$ objdump -h vmlinux - -vmlinux: file format elf32-i386 - -Sections: -Idx Name Size VMA LMA File off Algn - 0 .text 00416850 81000000 01000000 00001000 2**5 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE - 1 .notes 00000024 81416850 01416850 00417850 2**2 - CONTENTS, ALLOC, LOAD, READONLY, CODE - 2 __ex_table 00000c50 81416880 01416880 00417880 2**3 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 3 .rodata 00154b9e 81418000 01418000 00419000 2**5 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 4 __bug_table 0000597c 8156cba0 0156cba0 0056dba0 2**0 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 5 .pci_fixup 00001b80 8157251c 0157251c 0057351c 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 6 .tracedata 00000024 8157409c 0157409c 0057509c 2**0 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 7 __ksymtab 00007ec0 815740c0 015740c0 005750c0 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 8 __ksymtab_gpl 00004a28 8157bf80 0157bf80 0057cf80 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 9 __ksymtab_strings 0001d6fc 815809a8 015809a8 005819a8 2**0 - CONTENTS, ALLOC, LOAD, READONLY, DATA - 10 __init_rodata 00001c3c 8159e0a4 0159e0a4 0059f0a4 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 11 __param 00000ff0 8159fce0 0159fce0 005a0ce0 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 12 __modver 00000330 815a0cd0 015a0cd0 005a1cd0 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 13 .data 00063000 815a1000 015a1000 005a2000 2**12 - CONTENTS, ALLOC, LOAD, RELOC, DATA - 14 .init.text 0002f104 81604000 01604000 00605000 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE - 15 .init.data 00040cdc 81634000 01634000 00635000 2**12 - CONTENTS, ALLOC, LOAD, RELOC, DATA - 16 .x86_cpu_dev.init 0000001c 81674cdc 01674cdc 00675cdc 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 17 .altinstructions 0000267c 81674cf8 01674cf8 00675cf8 2**0 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 18 .altinstr_replacement 00000942 81677374 01677374 00678374 2**0 - CONTENTS, ALLOC, LOAD, READONLY, CODE - 19 .iommu_table 00000014 81677cb8 01677cb8 00678cb8 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 20 .apicdrivers 00000004 81677cd0 01677cd0 00678cd0 2**2 - CONTENTS, ALLOC, LOAD, RELOC, DATA - 21 .exit.text 00001a80 81677cd8 01677cd8 00678cd8 2**0 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE - 22 .data..percpu 00007880 8167a000 0167a000 0067b000 2**12 - CONTENTS, ALLOC, LOAD, RELOC, DATA - 23 .smp_locks 00003000 81682000 01682000 00683000 2**2 - CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA - 24 .bss 000a1000 81685000 01685000 00686000 2**12 - ALLOC - 25 .brk 00424000 81726000 01726000 00686000 2**0 - ALLOC - 26 .comment 00000049 00000000 00000000 00686000 2**0 - CONTENTS, READONLY - 27 .GCC.command.line 0003e055 00000000 00000000 00686049 2**0 - CONTENTS, READONLY - 28 .debug_aranges 0000f4c8 00000000 00000000 006c40a0 2**3 - CONTENTS, RELOC, READONLY, DEBUGGING - 29 .debug_info 0440b0df 00000000 00000000 006d3568 2**0 - CONTENTS, RELOC, READONLY, DEBUGGING - 30 .debug_abbrev 0022a83b 00000000 00000000 04ade647 2**0 - CONTENTS, READONLY, DEBUGGING - 31 .debug_line 004ead0d 00000000 00000000 04d08e82 2**0 - CONTENTS, RELOC, READONLY, DEBUGGING - 32 .debug_frame 0010a960 00000000 00000000 051f3b90 2**2 - CONTENTS, RELOC, READONLY, DEBUGGING - 33 .debug_str 001b442d 00000000 00000000 052fe4f0 2**0 - CONTENTS, READONLY, DEBUGGING - 34 .debug_loc 007c7fa9 00000000 00000000 054b291d 2**0 - CONTENTS, RELOC, READONLY, DEBUGGING - 35 .debug_ranges 00098828 00000000 00000000 05c7a8c8 2**3 - CONTENTS, RELOC, READONLY, DEBUGGING - -There is also the setup binary mentioned earlier. This is at -arch/x86/boot/setup.bin and is about 12KB in size. It includes the command -line and various settings need by the kernel. Arguably the boot loader should -provide all of this also, but setting it up is some complex that the kernel -helps by providing a head start. - -As you can see the code loads to address 0x01000000 and everything else -follows after that. We could load this image using the 'bootelf' command but -we would still need to provide the setup binary. This is not supported by -U-Boot although I suppose you could mostly script it. This would permit the -use of a relocatable kernel. - -All we need to boot is the vmlinux file and the setup.bin file. - - -Create a FIT ------------- - -To create a FIT you will need a source file describing what should go in the -FIT. See kernel.its for an example for x86 and also instructions on setting -the 'arch' value for booting 64-bit kernels if desired. Put this into a file -called image.its. - -Note that setup is loaded to the special address of 0x90000 (a special address -you just have to know) and the kernel is loaded to 0x01000000 (the address you -saw above). This means that you will need to load your FIT to a different -address so that U-Boot doesn't overwrite it when decompressing. Something like -0x02000000 will do so you can set CONFIG_SYS_LOAD_ADDR to that. - -In that example the kernel is compressed with lzo. Also we need to provide a -flat binary, not an ELF. So the steps needed to set things are are: - - # Create a flat binary - objcopy -O binary vmlinux vmlinux.bin - - # Compress it into LZO format - lzop vmlinux.bin - - # Build a FIT image - mkimage -f image.its image.fit - -(be careful to run the mkimage from your U-Boot tools directory since it -will have x86_setup support.) - -You can take a look at the resulting fit file if you like: - -$ dumpimage -l image.fit -FIT description: Simple image with single Linux kernel on x86 -Created: Tue Oct 7 10:57:24 2014 - Image 0 (kernel) - Description: Vanilla Linux kernel - Created: Tue Oct 7 10:57:24 2014 - Type: Kernel Image - Compression: lzo compressed - Data Size: 4591767 Bytes = 4484.15 kB = 4.38 MB - Architecture: Intel x86 - OS: Linux - Load Address: 0x01000000 - Entry Point: 0x00000000 - Hash algo: sha1 - Hash value: 446b5163ebfe0fb6ee20cbb7a8501b263cd92392 - Image 1 (setup) - Description: Linux setup.bin - Created: Tue Oct 7 10:57:24 2014 - Type: x86 setup.bin - Compression: uncompressed - Data Size: 12912 Bytes = 12.61 kB = 0.01 MB - Hash algo: sha1 - Hash value: a1f2099cf47ff9816236cd534c77af86e713faad - Default Configuration: 'config-1' - Configuration 0 (config-1) - Description: Boot Linux kernel - Kernel: kernel - - -Booting the FIT ---------------- - -To make it boot you need to load it and then use 'bootm' to boot it. A -suitable script to do this from a network server is: - - bootp - tftp image.fit - bootm - -This will load the image from the network and boot it. The command line (from -the 'bootargs' environment variable) will be passed to the kernel. - -If you want a ramdisk you can add it as normal with FIT. If you want a device -tree then x86 doesn't normally use those - it has ACPI instead. - - -Why Bother? ------------ - -1. It demystifies the process of booting an x86 kernel -2. It allows use of the standard U-Boot boot file format -3. It allows U-Boot to perform decompression - problems will provide an error -message and you are still in the boot loader. It is possible to investigate. -4. It avoids all the pre-loader code in the kernel which is quite complex to -follow -5. You can use verified/secure boot and other features which haven't yet been -added to the pre-Linux -6. It makes x86 more like other architectures in the way it boots a kernel. -You can potentially use the same file format for the kernel, and the same -procedure for building and packaging it. - - -References ----------- - -In the Linux kernel, Documentation/x86/boot.txt defines the boot protocol for -the kernel including the setup.bin format. This is handled in U-Boot in -arch/x86/lib/zimage.c and arch/x86/lib/bootm.c. - -Various files in the same directory as this file describe the FIT format. - - --- -Simon Glass -sjg@chromium.org -7-Oct-2014 diff --git a/doc/usage/fit/index.rst b/doc/usage/fit/index.rst index 93a962319035..0635d06b811a 100644 --- a/doc/usage/fit/index.rst +++ b/doc/usage/fit/index.rst @@ -11,3 +11,4 @@ doc/uImage.FIT :maxdepth: 1
source_file_format + x86-fit-boot diff --git a/doc/usage/fit/x86-fit-boot.rst b/doc/usage/fit/x86-fit-boot.rst new file mode 100644 index 000000000000..93b73bb90192 --- /dev/null +++ b/doc/usage/fit/x86-fit-boot.rst @@ -0,0 +1,269 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Booting Linux on x86 with FIT +============================= + +Background +---------- + +Generally Linux x86 uses its own very complex booting method. There is a setup +binary which contains all sorts of parameters and a compressed self-extracting +binary for the kernel itself, often with a small built-in serial driver to +display decompression progress. + +The x86 CPU has various processor modes. I am no expert on these, but my +understanding is that an x86 CPU (even a really new one) starts up in a 16-bit +'real' mode where only 1MB of memory is visible, moves to 32-bit 'protected' +mode where 4GB is visible (or more with special memory access techniques) and +then to 64-bit 'long' mode if 64-bit execution is required. + +Partly the self-extracting nature of Linux was introduced to cope with boot +loaders that were barely capable of loading anything. Even changing to 32-bit +mode was something of a challenge, so putting this logic in the kernel seemed +to make sense. + +Bit by bit more and more logic has been added to this post-boot pre-Linux +wrapper: + +- Changing to 32-bit mode +- Decompression +- Serial output (with drivers for various chips) +- Load address randomisation +- Elf loader complete with relocation (for the above) +- Random number generator via 3 methods (again for the above) +- Some sort of EFI mini-loader (1000+ glorious lines of code) +- Locating and tacking on a device tree and ramdisk + +To my mind, if you sit back and look at things from first principles, this +doesn't make a huge amount of sense. Any boot loader worth its salts already +has most of the above features and more besides. The boot loader already knows +the layout of memory, has a serial driver, can decompress things, includes an +ELF loader and supports device tree and ramdisks. The decision to duplicate +all these features in a Linux wrapper caters for the lowest common +denominator: a boot loader which consists of a BIOS call to load something off +disk, followed by a jmp instruction. + +(Aside: On ARM systems, we worry that the boot loader won't know where to load +the kernel. It might be easier to just provide that information in the image, +or in the boot loader rather than adding a self-relocator to put it in the +right place. Or just use ELF? + +As a result, the x86 kernel boot process is needlessly complex. The file +format is also complex, and obfuscates the contents to a degree that it is +quite a challenge to extract anything from it. This bzImage format has become +so prevalent that is actually isn't possible to produce the 'raw' kernel build +outputs with the standard Makefile (as it is on ARM for example, at least at +the time of writing). + +This document describes an alternative boot process which uses simple raw +images which are loaded into the right place by the boot loader and then +executed. + + +Build the kernel +---------------- + +Note: these instructions assume a 32-bit kernel. U-Boot also supports directly +booting a 64-bit kernel by jumping into 64-bit mode first (see below). + +You can build the kernel as normal with 'make'. This will create a file called +'vmlinux'. This is a standard ELF file and you can look at it if you like:: + + $ objdump -h vmlinux + + vmlinux: file format elf32-i386 + + Sections: + Idx Name Size VMA LMA File off Algn + 0 .text 00416850 81000000 01000000 00001000 2**5 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE + 1 .notes 00000024 81416850 01416850 00417850 2**2 + CONTENTS, ALLOC, LOAD, READONLY, CODE + 2 __ex_table 00000c50 81416880 01416880 00417880 2**3 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 3 .rodata 00154b9e 81418000 01418000 00419000 2**5 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 4 __bug_table 0000597c 8156cba0 0156cba0 0056dba0 2**0 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 5 .pci_fixup 00001b80 8157251c 0157251c 0057351c 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 6 .tracedata 00000024 8157409c 0157409c 0057509c 2**0 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 7 __ksymtab 00007ec0 815740c0 015740c0 005750c0 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 8 __ksymtab_gpl 00004a28 8157bf80 0157bf80 0057cf80 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 9 __ksymtab_strings 0001d6fc 815809a8 015809a8 005819a8 2**0 + CONTENTS, ALLOC, LOAD, READONLY, DATA + 10 __init_rodata 00001c3c 8159e0a4 0159e0a4 0059f0a4 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 11 __param 00000ff0 8159fce0 0159fce0 005a0ce0 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 12 __modver 00000330 815a0cd0 015a0cd0 005a1cd0 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 13 .data 00063000 815a1000 015a1000 005a2000 2**12 + CONTENTS, ALLOC, LOAD, RELOC, DATA + 14 .init.text 0002f104 81604000 01604000 00605000 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE + 15 .init.data 00040cdc 81634000 01634000 00635000 2**12 + CONTENTS, ALLOC, LOAD, RELOC, DATA + 16 .x86_cpu_dev.init 0000001c 81674cdc 01674cdc 00675cdc 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 17 .altinstructions 0000267c 81674cf8 01674cf8 00675cf8 2**0 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 18 .altinstr_replacement 00000942 81677374 01677374 00678374 2**0 + CONTENTS, ALLOC, LOAD, READONLY, CODE + 19 .iommu_table 00000014 81677cb8 01677cb8 00678cb8 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 20 .apicdrivers 00000004 81677cd0 01677cd0 00678cd0 2**2 + CONTENTS, ALLOC, LOAD, RELOC, DATA + 21 .exit.text 00001a80 81677cd8 01677cd8 00678cd8 2**0 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE + 22 .data..percpu 00007880 8167a000 0167a000 0067b000 2**12 + CONTENTS, ALLOC, LOAD, RELOC, DATA + 23 .smp_locks 00003000 81682000 01682000 00683000 2**2 + CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA + 24 .bss 000a1000 81685000 01685000 00686000 2**12 + ALLOC + 25 .brk 00424000 81726000 01726000 00686000 2**0 + ALLOC + 26 .comment 00000049 00000000 00000000 00686000 2**0 + CONTENTS, READONLY + 27 .GCC.command.line 0003e055 00000000 00000000 00686049 2**0 + CONTENTS, READONLY + 28 .debug_aranges 0000f4c8 00000000 00000000 006c40a0 2**3 + CONTENTS, RELOC, READONLY, DEBUGGING + 29 .debug_info 0440b0df 00000000 00000000 006d3568 2**0 + CONTENTS, RELOC, READONLY, DEBUGGING + 30 .debug_abbrev 0022a83b 00000000 00000000 04ade647 2**0 + CONTENTS, READONLY, DEBUGGING + 31 .debug_line 004ead0d 00000000 00000000 04d08e82 2**0 + CONTENTS, RELOC, READONLY, DEBUGGING + 32 .debug_frame 0010a960 00000000 00000000 051f3b90 2**2 + CONTENTS, RELOC, READONLY, DEBUGGING + 33 .debug_str 001b442d 00000000 00000000 052fe4f0 2**0 + CONTENTS, READONLY, DEBUGGING + 34 .debug_loc 007c7fa9 00000000 00000000 054b291d 2**0 + CONTENTS, RELOC, READONLY, DEBUGGING + 35 .debug_ranges 00098828 00000000 00000000 05c7a8c8 2**3 + CONTENTS, RELOC, READONLY, DEBUGGING + +There is also the setup binary mentioned earlier. This is at +arch/x86/boot/setup.bin and is about 12KB in size. It includes the command +line and various settings need by the kernel. Arguably the boot loader should +provide all of this also, but setting it up is some complex that the kernel +helps by providing a head start. + +As you can see the code loads to address 0x01000000 and everything else +follows after that. We could load this image using the 'bootelf' command but +we would still need to provide the setup binary. This is not supported by +U-Boot although I suppose you could mostly script it. This would permit the +use of a relocatable kernel. + +All we need to boot is the vmlinux file and the setup.bin file. + + +Create a FIT +------------ + +To create a FIT you will need a source file describing what should go in the +FIT. See kernel.its for an example for x86 and also instructions on setting +the 'arch' value for booting 64-bit kernels if desired. Put this into a file +called image.its. + +Note that setup is loaded to the special address of 0x90000 (a special address +you just have to know) and the kernel is loaded to 0x01000000 (the address you +saw above). This means that you will need to load your FIT to a different +address so that U-Boot doesn't overwrite it when decompressing. Something like +0x02000000 will do so you can set CONFIG_SYS_LOAD_ADDR to that. + +In that example the kernel is compressed with lzo. Also we need to provide a +flat binary, not an ELF. So the steps needed to set things are are:: + + # Create a flat binary + objcopy -O binary vmlinux vmlinux.bin + + # Compress it into LZO format + lzop vmlinux.bin + + # Build a FIT image + mkimage -f image.its image.fit + +(be careful to run the mkimage from your U-Boot tools directory since it +will have x86_setup support.) + +You can take a look at the resulting fit file if you like:: + + $ dumpimage -l image.fit + FIT description: Simple image with single Linux kernel on x86 + Created: Tue Oct 7 10:57:24 2014 + Image 0 (kernel) + Description: Vanilla Linux kernel + Created: Tue Oct 7 10:57:24 2014 + Type: Kernel Image + Compression: lzo compressed + Data Size: 4591767 Bytes = 4484.15 kB = 4.38 MB + Architecture: Intel x86 + OS: Linux + Load Address: 0x01000000 + Entry Point: 0x00000000 + Hash algo: sha1 + Hash value: 446b5163ebfe0fb6ee20cbb7a8501b263cd92392 + Image 1 (setup) + Description: Linux setup.bin + Created: Tue Oct 7 10:57:24 2014 + Type: x86 setup.bin + Compression: uncompressed + Data Size: 12912 Bytes = 12.61 kB = 0.01 MB + Hash algo: sha1 + Hash value: a1f2099cf47ff9816236cd534c77af86e713faad + Default Configuration: 'config-1' + Configuration 0 (config-1) + Description: Boot Linux kernel + Kernel: kernel + + +Booting the FIT +--------------- + +To make it boot you need to load it and then use 'bootm' to boot it. A +suitable script to do this from a network server is:: + + bootp + tftp image.fit + bootm + +This will load the image from the network and boot it. The command line (from +the 'bootargs' environment variable) will be passed to the kernel. + +If you want a ramdisk you can add it as normal with FIT. If you want a device +tree then x86 doesn't normally use those - it has ACPI instead. + + +Why Bother? +----------- + +#. It demystifies the process of booting an x86 kernel +#. It allows use of the standard U-Boot boot file format +#. It allows U-Boot to perform decompression - problems will provide an error + message and you are still in the boot loader. It is possible to investigate. +#. It avoids all the pre-loader code in the kernel which is quite complex to + follow +#. You can use verified/secure boot and other features which haven't yet been + added to the pre-Linux +#. It makes x86 more like other architectures in the way it boots a kernel. + You can potentially use the same file format for the kernel, and the same + procedure for building and packaging it. + + +References +---------- + +In the Linux kernel, Documentation/x86/boot.txt defines the boot protocol for +the kernel including the setup.bin format. This is handled in U-Boot in +arch/x86/lib/zimage.c and arch/x86/lib/bootm.c. + +Various files in the same directory as this file describe the FIT format. + + +.. sectionauthor:: Simon Glass sjg@chromium.org 7-Oct-2014
Bring these files into the documentation.
Fix 'wtih' and 'it' typos and repeated 'could' while we are here.
doc/uImage.FIT/beaglebone_vboot.txt | 607 -------------- doc/uImage.FIT/signature.txt | 707 ---------------- doc/usage/cmd/source.rst | 2 +- doc/usage/fit/beaglebone_vboot.rst | 607 ++++++++++++++ doc/usage/fit/index.rst | 3 + doc/usage/fit/signature.rst | 760 ++++++++++++++++++ .../fit/verified-boot.rst} | 83 +- 7 files changed, 1414 insertions(+), 1355 deletions(-) delete mode 100644 doc/uImage.FIT/beaglebone_vboot.txt delete mode 100644 doc/uImage.FIT/signature.txt create mode 100644 doc/usage/fit/beaglebone_vboot.rst create mode 100644 doc/usage/fit/signature.rst rename doc/{uImage.FIT/verified-boot.txt => usage/fit/verified-boot.rst} (54%)
diff --git a/doc/uImage.FIT/beaglebone_vboot.txt b/doc/uImage.FIT/beaglebone_vboot.txt deleted file mode 100644 index ebd2068ed38d..000000000000 --- a/doc/uImage.FIT/beaglebone_vboot.txt +++ /dev/null @@ -1,607 +0,0 @@ -Verified Boot on the Beaglebone Black -===================================== - -Introduction ------------- - -Before reading this, please read verified-boot.txt and signature.txt. These -instructions are for mainline U-Boot from v2014.07 onwards. - -There is quite a bit of documentation in this directory describing how -verified boot works in U-Boot. There is also a test which runs through the -entire process of signing an image and running U-Boot (sandbox) to check it. -However, it might be useful to also have an example on a real board. - -Beaglebone Black is a fairly common board so seems to be a reasonable choice -for an example of how to enable verified boot using U-Boot. - -First a note that may to help avoid confusion. U-Boot and Linux both use -device tree. They may use the same device tree source, but it is seldom useful -for them to use the exact same binary from the same place. More typically, -U-Boot has its device tree packaged wtih it, and the kernel's device tree is -packaged with the kernel. In particular this is important with verified boot, -since U-Boot's device tree must be immutable. If it can be changed then the -public keys can be changed and verified boot is useless. An attacker can -simply generate a new key and put his public key into U-Boot so that -everything verifies. On the other hand the kernel's device tree typically -changes when the kernel changes, so it is useful to package an updated device -tree with the kernel binary. U-Boot supports the latter with its flexible FIT -format (Flat Image Tree). - - -Overview --------- - -The steps are roughly as follows: - -1. Build U-Boot for the board, with the verified boot options enabled. - -2. Obtain a suitable Linux kernel - -3. Create a Image Tree Source file (ITS) file describing how you want the -kernel to be packaged, compressed and signed. - -4. Create a key pair - -5. Sign the kernel - -6. Put the public key into U-Boot's image - -7. Put U-Boot and the kernel onto the board - -8. Try it - - -Step 1: Build U-Boot --------------------- - -a. Set up the environment variable to point to your toolchain. You will need -this for U-Boot and also for the kernel if you build it. For example if you -installed a Linaro version manually it might be something like: - - export CROSS_COMPILE=/opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.08_linux/bin/arm-linux-gnueabihf- - -or if you just installed gcc-arm-linux-gnueabi then it might be - - export CROSS_COMPILE=arm-linux-gnueabi- - -b. Configure and build U-Boot with verified boot enabled: - - export UBOOT=/path/to/u-boot - cd $UBOOT - # You can add -j10 if you have 10 CPUs to make it faster - make O=b/am335x_boneblack_vboot am335x_boneblack_vboot_config all - export UOUT=$UBOOT/b/am335x_boneblack_vboot - -c. You will now have a U-Boot image: - - file b/am335x_boneblack_vboot/u-boot-dtb.img -b/am335x_boneblack_vboot/u-boot-dtb.img: u-boot legacy uImage, U-Boot 2014.07-rc2-00065-g2f69f8, Firmware/ARM, Firmware Image (Not compressed), 395375 bytes, Sat May 31 16:19:04 2014, Load Address: 0x80800000, Entry Point: 0x00000000, Header CRC: 0x0ABD6ACA, Data CRC: 0x36DEF7E4 - - -Step 2: Build Linux --------------------- - -a. Find the kernel image ('Image') and device tree (.dtb) file you plan to -use. In our case it is am335x-boneblack.dtb and it is built with the kernel. -At the time of writing an SD Boot image can be obtained from here: - - http://www.elinux.org/Beagleboard:Updating_The_Software#Image_For_Booting_Fr... - -You can write this to an SD card and then mount it to extract the kernel and -device tree files. - -You can also build a kernel. Instructions for this are are here: - - http://elinux.org/Building_BBB_Kernel - -or you can use your favourite search engine. Following these instructions -produces a kernel Image and device tree files. For the record the steps were: - - export KERNEL=/path/to/kernel - cd $KERNEL - git clone git://github.com/beagleboard/kernel.git . - git checkout v3.14 - ./patch.sh - cp configs/beaglebone kernel/arch/arm/configs/beaglebone_defconfig - cd kernel - make beaglebone_defconfig - make uImage dtbs # -j10 if you have 10 CPUs - export OKERNEL=$KERNEL/kernel/arch/arm/boot - -c. You now have the 'Image' and 'am335x-boneblack.dtb' files needed to boot. - - -Step 3: Create the ITS ----------------------- - -Set up a directory for your work. - - export WORK=/path/to/dir - cd $WORK - -Put this into a file in that directory called sign.its: - -/dts-v1/; - -/ { - description = "Beaglebone black"; - #address-cells = <1>; - - images { - kernel { - data = /incbin/("Image.lzo"); - type = "kernel"; - arch = "arm"; - os = "linux"; - compression = "lzo"; - load = <0x80008000>; - entry = <0x80008000>; - hash-1 { - algo = "sha1"; - }; - }; - fdt-1 { - description = "beaglebone-black"; - data = /incbin/("am335x-boneblack.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - hash-1 { - algo = "sha1"; - }; - }; - }; - configurations { - default = "conf-1"; - conf-1 { - kernel = "kernel"; - fdt = "fdt-1"; - signature-1 { - algo = "sha1,rsa2048"; - key-name-hint = "dev"; - sign-images = "fdt", "kernel"; - }; - }; - }; -}; - - -The explanation for this is all in the documentation you have already read. -But briefly it packages a kernel and device tree, and provides a single -configuration to be signed with a key named 'dev'. The kernel is compressed -with LZO to make it smaller. - - -Step 4: Create a key pair -------------------------- - -See signature.txt for details on this step. - - cd $WORK - mkdir keys - openssl genrsa -F4 -out keys/dev.key 2048 - openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt - -Note: keys/dev.key contains your private key and is very secret. If anyone -gets access to that file they can sign kernels with it. Keep it secure. - - -Step 5: Sign the kernel ------------------------ - -We need to use mkimage (which was built when you built U-Boot) to package the -Linux kernel into a FIT (Flat Image Tree, a flexible file format that U-Boot -can load) using the ITS file you just created. - -At the same time we must put the public key into U-Boot device tree, with the -'required' property, which tells U-Boot that this key must be verified for the -image to be valid. You will make this key available to U-Boot for booting in -step 6. - - ln -s $OKERNEL/dts/am335x-boneblack.dtb - ln -s $OKERNEL/Image - ln -s $UOUT/u-boot-dtb.img - cp $UOUT/arch/arm/dts/am335x-boneblack.dtb am335x-boneblack-pubkey.dtb - lzop Image - $UOUT/tools/mkimage -f sign.its -K am335x-boneblack-pubkey.dtb -k keys -r image.fit - -You should see something like this: - -FIT description: Beaglebone black -Created: Sun Jun 1 12:50:30 2014 - Image 0 (kernel) - Description: unavailable - Created: Sun Jun 1 12:50:30 2014 - Type: Kernel Image - Compression: lzo compressed - Data Size: 7790938 Bytes = 7608.34 kB = 7.43 MB - Architecture: ARM - OS: Linux - Load Address: 0x80008000 - Entry Point: 0x80008000 - Hash algo: sha1 - Hash value: c94364646427e10f423837e559898ef02c97b988 - Image 1 (fdt-1) - Description: beaglebone-black - Created: Sun Jun 1 12:50:30 2014 - Type: Flat Device Tree - Compression: uncompressed - Data Size: 31547 Bytes = 30.81 kB = 0.03 MB - Architecture: ARM - Hash algo: sha1 - Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d - Default Configuration: 'conf-1' - Configuration 0 (conf-1) - Description: unavailable - Kernel: kernel - FDT: fdt-1 - - -Now am335x-boneblack-pubkey.dtb contains the public key and image.fit contains -the signed kernel. Jump to step 6 if you like, or continue reading to increase -your understanding. - -You can also run fit_check_sign to check it: - - $UOUT/tools/fit_check_sign -f image.fit -k am335x-boneblack-pubkey.dtb - -which results in: - -Verifying Hash Integrity ... sha1,rsa2048:dev+ -## Loading kernel from FIT Image at 7fc6ee469000 ... - Using 'conf-1' configuration - Verifying Hash Integrity ... -sha1,rsa2048:dev+ -OK - - Trying 'kernel' kernel subimage - Description: unavailable - Created: Sun Jun 1 12:50:30 2014 - Type: Kernel Image - Compression: lzo compressed - Data Size: 7790938 Bytes = 7608.34 kB = 7.43 MB - Architecture: ARM - OS: Linux - Load Address: 0x80008000 - Entry Point: 0x80008000 - Hash algo: sha1 - Hash value: c94364646427e10f423837e559898ef02c97b988 - Verifying Hash Integrity ... -sha1+ -OK - -Unimplemented compression type 4 -## Loading fdt from FIT Image at 7fc6ee469000 ... - Using 'conf-1' configuration - Trying 'fdt-1' fdt subimage - Description: beaglebone-black - Created: Sun Jun 1 12:50:30 2014 - Type: Flat Device Tree - Compression: uncompressed - Data Size: 31547 Bytes = 30.81 kB = 0.03 MB - Architecture: ARM - Hash algo: sha1 - Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d - Verifying Hash Integrity ... -sha1+ -OK - - Loading Flat Device Tree ... OK - -## Loading ramdisk from FIT Image at 7fc6ee469000 ... - Using 'conf-1' configuration -Could not find subimage node - -Signature check OK - - -At the top, you see "sha1,rsa2048:dev+". This means that it checked an RSA key -of size 2048 bits using SHA1 as the hash algorithm. The key name checked was -'dev' and the '+' means that it verified. If it showed '-' that would be bad. - -Once the configuration is verified it is then possible to rely on the hashes -in each image referenced by that configuration. So fit_check_sign goes on to -load each of the images. We have a kernel and an FDT but no ramkdisk. In each -case fit_check_sign checks the hash and prints sha1+ meaning that the SHA1 -hash verified. This means that none of the images has been tampered with. - -There is a test in test/vboot which uses U-Boot's sandbox build to verify that -the above flow works. - -But it is fun to do this by hand, so you can load image.fit into a hex editor -like ghex, and change a byte in the kernel: - - $UOUT/tools/fit_info -f image.fit -n /images/kernel -p data -NAME: kernel -LEN: 7790938 -OFF: 168 - -This tells us that the kernel starts at byte offset 168 (decimal) in image.fit -and extends for about 7MB. Try changing a byte at 0x2000 (say) and run -fit_check_sign again. You should see something like: - -Verifying Hash Integrity ... sha1,rsa2048:dev+ -## Loading kernel from FIT Image at 7f5a39571000 ... - Using 'conf-1' configuration - Verifying Hash Integrity ... -sha1,rsa2048:dev+ -OK - - Trying 'kernel' kernel subimage - Description: unavailable - Created: Sun Jun 1 13:09:21 2014 - Type: Kernel Image - Compression: lzo compressed - Data Size: 7790938 Bytes = 7608.34 kB = 7.43 MB - Architecture: ARM - OS: Linux - Load Address: 0x80008000 - Entry Point: 0x80008000 - Hash algo: sha1 - Hash value: c94364646427e10f423837e559898ef02c97b988 - Verifying Hash Integrity ... -sha1 error -Bad hash value for 'hash-1' hash node in 'kernel' image node -Bad Data Hash - -## Loading fdt from FIT Image at 7f5a39571000 ... - Using 'conf-1' configuration - Trying 'fdt-1' fdt subimage - Description: beaglebone-black - Created: Sun Jun 1 13:09:21 2014 - Type: Flat Device Tree - Compression: uncompressed - Data Size: 31547 Bytes = 30.81 kB = 0.03 MB - Architecture: ARM - Hash algo: sha1 - Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d - Verifying Hash Integrity ... -sha1+ -OK - - Loading Flat Device Tree ... OK - -## Loading ramdisk from FIT Image at 7f5a39571000 ... - Using 'conf-1' configuration -Could not find subimage node - -Signature check Bad (error 1) - - -It has detected the change in the kernel. - -You can also be sneaky and try to switch images, using the libfdt utilities -that come with dtc (package name is device-tree-compiler but you will need a -recent version like 1.4: - - dtc -v -Version: DTC 1.4.0 - -First we can check which nodes are actually hashed by the configuration: - - fdtget -l image.fit / -images -configurations - - fdtget -l image.fit /configurations -conf-1 -fdtget -l image.fit /configurations/conf-1 -signature-1 - - fdtget -p image.fit /configurations/conf-1/signature-1 -hashed-strings -hashed-nodes -timestamp -signer-version -signer-name -value -algo -key-name-hint -sign-images - - fdtget image.fit /configurations/conf-1/signature-1 hashed-nodes -/ /configurations/conf-1 /images/fdt-1 /images/fdt-1/hash /images/kernel /images/kernel/hash-1 - -This gives us a bit of a look into the signature that mkimage added. Note you -can also use fdtdump to list the entire device tree. - -Say we want to change the kernel that this configuration uses -(/images/kernel). We could just put a new kernel in the image, but we will -need to change the hash to match. Let's simulate that by changing a byte of -the hash: - - fdtget -tx image.fit /images/kernel/hash-1 value -c9436464 6427e10f 423837e5 59898ef0 2c97b988 - fdtput -tx image.fit /images/kernel/hash-1 value c9436464 6427e10f 423837e5 59898ef0 2c97b981 - -Now check it again: - - $UOUT/tools/fit_check_sign -f image.fit -k am335x-boneblack-pubkey.dtb -Verifying Hash Integrity ... sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13 -rsa_verify_with_keynode: RSA failed to verify: -13 -- -Failed to verify required signature 'key-dev' -Signature check Bad (error 1) - -This time we don't even get as far as checking the images, since the -configuration signature doesn't match. We can't change any hashes without the -signature check noticing. The configuration is essentially locked. U-Boot has -a public key for which it requires a match, and will not permit the use of any -configuration that does not match that public key. The only way the -configuration will match is if it was signed by the matching private key. - -It would also be possible to add a new signature node that does match your new -configuration. But that won't work since you are not allowed to change the -configuration in any way. Try it with a fresh (valid) image if you like by -running the mkimage link again. Then: - - fdtput -p image.fit /configurations/conf-1/signature-1 value fred - $UOUT/tools/fit_check_sign -f image.fit -k am335x-boneblack-pubkey.dtb -Verifying Hash Integrity ... - -sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13 -rsa_verify_with_keynode: RSA failed to verify: -13 -- -Failed to verify required signature 'key-dev' -Signature check Bad (error 1) - - -Of course it would be possible to add an entirely new configuration and boot -with that, but it still needs to be signed, so it won't help. - - -6. Put the public key into U-Boot's image ------------------------------------------ - -Having confirmed that the signature is doing its job, let's try it out in -U-Boot on the board. U-Boot needs access to the public key corresponding to -the private key that you signed with so that it can verify any kernels that -you sign. - - cd $UBOOT - make O=b/am335x_boneblack_vboot EXT_DTB=${WORK}/am335x-boneblack-pubkey.dtb - -Here we are overriding the normal device tree file with our one, which -contains the public key. - -Now you have a special U-Boot image with the public key. It can verify can -kernel that you sign with the private key as in step 5. - -If you like you can take a look at the public key information that mkimage -added to U-Boot's device tree: - - fdtget -p am335x-boneblack-pubkey.dtb /signature/key-dev -required -algo -rsa,r-squared -rsa,modulus -rsa,n0-inverse -rsa,num-bits -key-name-hint - -This has information about the key and some pre-processed values which U-Boot -can use to verify against it. These values are obtained from the public key -certificate by mkimage, but require quite a bit of code to generate. To save -code space in U-Boot, the information is extracted and written in raw form for -U-Boot to easily use. The same mechanism is used in Google's Chrome OS. - -Notice the 'required' property. This marks the key as required - U-Boot will -not boot any image that does not verify against this key. - - -7. Put U-Boot and the kernel onto the board -------------------------------------------- - -The method here varies depending on how you are booting. For this example we -are booting from an micro-SD card with two partitions, one for U-Boot and one -for Linux. Put it into your machine and write U-Boot and the kernel to it. -Here the card is /dev/sde: - - cd $WORK - export UDEV=/dev/sde1 # Change thes two lines to the correct device - export KDEV=/dev/sde2 - sudo mount $UDEV /mnt/tmp && sudo cp $UOUT/u-boot-dtb.img /mnt/tmp/u-boot.img && sleep 1 && sudo umount $UDEV - sudo mount $KDEV /mnt/tmp && sudo cp $WORK/image.fit /mnt/tmp/boot/image.fit && sleep 1 && sudo umount $KDEV - - -8. Try it ---------- - -Boot the board using the commands below: - - setenv bootargs console=ttyO0,115200n8 quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait - ext2load mmc 0:2 82000000 /boot/image.fit - bootm 82000000 - -You should then see something like this: - -U-Boot# setenv bootargs console=ttyO0,115200n8 quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait -U-Boot# ext2load mmc 0:2 82000000 /boot/image.fit -7824930 bytes read in 589 ms (12.7 MiB/s) -U-Boot# bootm 82000000 -## Loading kernel from FIT Image at 82000000 ... - Using 'conf-1' configuration - Verifying Hash Integrity ... sha1,rsa2048:dev+ OK - Trying 'kernel' kernel subimage - Description: unavailable - Created: 2014-06-01 19:32:54 UTC - Type: Kernel Image - Compression: lzo compressed - Data Start: 0x820000a8 - Data Size: 7790938 Bytes = 7.4 MiB - Architecture: ARM - OS: Linux - Load Address: 0x80008000 - Entry Point: 0x80008000 - Hash algo: sha1 - Hash value: c94364646427e10f423837e559898ef02c97b988 - Verifying Hash Integrity ... sha1+ OK -## Loading fdt from FIT Image at 82000000 ... - Using 'conf-1' configuration - Trying 'fdt-1' fdt subimage - Description: beaglebone-black - Created: 2014-06-01 19:32:54 UTC - Type: Flat Device Tree - Compression: uncompressed - Data Start: 0x8276e2ec - Data Size: 31547 Bytes = 30.8 KiB - Architecture: ARM - Hash algo: sha1 - Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d - Verifying Hash Integrity ... sha1+ OK - Booting using the fdt blob at 0x8276e2ec - Uncompressing Kernel Image ... OK - Loading Device Tree to 8fff5000, end 8ffffb3a ... OK - -Starting kernel ... - -[ 0.582377] omap_init_mbox: hwmod doesn't have valid attrs -[ 2.589651] musb-hdrc musb-hdrc.0.auto: Failed to request rx1. -[ 2.595830] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517 -[ 2.606470] musb-hdrc musb-hdrc.1.auto: Failed to request rx1. -[ 2.612723] musb-hdrc musb-hdrc.1.auto: musb_init_controller failed with status -517 -[ 2.940808] drivers/rtc/hctosys.c: unable to open rtc device (rtc0) -[ 7.248889] libphy: PHY 4a101000.mdio:01 not found -[ 7.253995] net eth0: phy 4a101000.mdio:01 not found on slave 1 -systemd-fsck[83]: Angstrom: clean, 50607/218160 files, 306348/872448 blocks - -.---O---. -| | .-. o o -| | |-----.-----.-----.| | .----..-----.-----. -| | | __ | ---'| '--.| .-'| | | -| | | | | |--- || --'| | | ' | | | | -'---'---'--'--'--. |-----''----''--' '-----'-'-'-' - -' | - '---' - -The Angstrom Distribution beaglebone ttyO0 - -Angstrom v2012.12 - Kernel 3.14.1+ - -beaglebone login: - -At this point your kernel has been verified and you can be sure that it is one -that you signed. As an exercise, try changing image.fit as in step 5 and see -what happens. - - -Further Improvements --------------------- - -Several of the steps here can be easily automated. In particular it would be -capital if signing and packaging a kernel were easy, perhaps a simple make -target in the kernel. - -Some mention of how to use multiple .dtb files in a FIT might be useful. - -U-Boot's verified boot mechanism has not had a robust and independent security -review. Such a review should look at the implementation and its resistance to -attacks. - -Perhaps the verified boot feature could could be integrated into the Amstrom -distribution. - - -Simon Glass -sjg@chromium.org -2-June-14 diff --git a/doc/uImage.FIT/signature.txt b/doc/uImage.FIT/signature.txt deleted file mode 100644 index 21eb3894aada..000000000000 --- a/doc/uImage.FIT/signature.txt +++ /dev/null @@ -1,707 +0,0 @@ -U-Boot FIT Signature Verification -================================= - -Introduction ------------- -FIT supports hashing of images so that these hashes can be checked on -loading. This protects against corruption of the image. However it does not -prevent the substitution of one image for another. - -The signature feature allows the hash to be signed with a private key such -that it can be verified using a public key later. Provided that the private -key is kept secret and the public key is stored in a non-volatile place, -any image can be verified in this way. - -See verified-boot.txt for more general information on verified boot. - - -Concepts --------- -Some familiarity with public key cryptography is assumed in this section. - -The procedure for signing is as follows: - - - hash an image in the FIT - - sign the hash with a private key to produce a signature - - store the resulting signature in the FIT - -The procedure for verification is: - - - read the FIT - - obtain the public key - - extract the signature from the FIT - - hash the image from the FIT - - verify (with the public key) that the extracted signature matches the - hash - -The signing is generally performed by mkimage, as part of making a firmware -image for the device. The verification is normally done in U-Boot on the -device. - - -Algorithms ----------- -In principle any suitable algorithm can be used to sign and verify a hash. -U-Boot supports a few hashing and verification algorithms. See below for -details. - -While it is acceptable to bring in large cryptographic libraries such as -openssl on the host side (e.g. mkimage), it is not desirable for U-Boot. -For the run-time verification side, it is important to keep code and data -size as small as possible. - -For this reason the RSA image verification uses pre-processed public keys -which can be used with a very small amount of code - just some extraction -of data from the FDT and exponentiation mod n. Code size impact is a little -under 5KB on Tegra Seaboard, for example. - -It is relatively straightforward to add new algorithms if required. If -another RSA variant is needed, then it can be added with the -U_BOOT_CRYPTO_ALGO() macro. If another algorithm is needed (such as DSA) then -it can be placed in a directory alongside lib/rsa/, and its functions added -using U_BOOT_CRYPTO_ALGO(). - - -Creating an RSA key pair and certificate ----------------------------------------- -To create a new public/private key pair, size 2048 bits: - -$ openssl genpkey -algorithm RSA -out keys/dev.key \ - -pkeyopt rsa_keygen_bits:2048 -pkeyopt rsa_keygen_pubexp:65537 - -To create a certificate for this containing the public key: - -$ openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt - -If you like you can look at the public key also: - -$ openssl rsa -in keys/dev.key -pubout - - -Device Tree Bindings --------------------- -The following properties are required in the FIT's signature node(s) to -allow the signer to operate. These should be added to the .its file. -Signature nodes sit at the same level as hash nodes and are called -signature-1, signature-2, etc. - -- algo: Algorithm name (e.g. "sha1,rsa2048") - -- key-name-hint: Name of key to use for signing. The keys will normally be in -a single directory (parameter -k to mkimage). For a given key <name>, its -private key is stored in <name>.key and the certificate is stored in -<name>.crt. - -When the image is signed, the following properties are added (mandatory): - -- value: The signature data (e.g. 256 bytes for 2048-bit RSA) - -When the image is signed, the following properties are optional: - -- timestamp: Time when image was signed (standard Unix time_t format) - -- signer-name: Name of the signer (e.g. "mkimage") - -- signer-version: Version string of the signer (e.g. "2013.01") - -- comment: Additional information about the signer or image - -- padding: The padding algorithm, it may be pkcs-1.5 or pss, - if no value is provided we assume pkcs-1.5 - -For config bindings (see Signed Configurations below), the following -additional properties are optional: - -- sign-images: A list of images to sign, each being a property of the conf -node that contains then. The default is "kernel,fdt" which means that these -two images will be looked up in the config and signed if present. - -For config bindings, these properties are added by the signer: - -- hashed-nodes: A list of nodes which were hashed by the signer. Each is - a string - the full path to node. A typical value might be: - - hashed-nodes = "/", "/configurations/conf-1", "/images/kernel", - "/images/kernel/hash-1", "/images/fdt-1", - "/images/fdt-1/hash-1"; - -- hashed-strings: The start and size of the string region of the FIT that - was hashed - -Example: See sign-images.its for an example image tree source file and -sign-configs.its for config signing. - - -Public Key Storage ------------------- -In order to verify an image that has been signed with a public key we need to -have a trusted public key. This cannot be stored in the signed image, since -it would be easy to alter. For this implementation we choose to store the -public key in U-Boot's control FDT (using CONFIG_OF_CONTROL). - -Public keys should be stored as sub-nodes in a /signature node. Required -properties are: - -- algo: Algorithm name (e.g. "sha1,rsa2048" or "sha256,ecdsa256") - -Optional properties are: - -- key-name-hint: Name of key used for signing. This is only a hint since it -is possible for the name to be changed. Verification can proceed by checking -all available signing keys until one matches. - -- required: If present this indicates that the key must be verified for the -image / configuration to be considered valid. Only required keys are -normally verified by the FIT image booting algorithm. Valid values are -"image" to force verification of all images, and "conf" to force verification -of the selected configuration (which then relies on hashes in the images to -verify those). - -Each signing algorithm has its own additional properties. - -For RSA the following are mandatory: - -- rsa,num-bits: Number of key bits (e.g. 2048) -- rsa,modulus: Modulus (N) as a big-endian multi-word integer -- rsa,exponent: Public exponent (E) as a 64 bit unsigned integer -- rsa,r-squared: (2^num-bits)^2 as a big-endian multi-word integer -- rsa,n0-inverse: -1 / modulus[0] mod 2^32 - -For ECDSA the following are mandatory: -- ecdsa,curve: Name of ECDSA curve (e.g. "prime256v1") -- ecdsa,x-point: Public key X coordinate as a big-endian multi-word integer -- ecdsa,y-point: Public key Y coordinate as a big-endian multi-word integer - -These parameters can be added to a binary device tree using parameter -K of the -mkimage command:: - - tools/mkimage -f fit.its -K control.dtb -k keys -r image.fit - -Here is an example of a generated device tree node:: - - signature { - key-dev { - required = "conf"; - algo = "sha256,rsa2048"; - rsa,r-squared = <0xb76d1acf 0xa1763ca5 0xeb2f126 - 0x742edc80 0xd3f42177 0x9741d9d9 - 0x35bb476e 0xff41c718 0xd3801430 - 0xf22537cb 0xa7e79960 0xae32a043 - 0x7da1427a 0x341d6492 0x3c2762f5 - 0xaac04726 0x5b262d96 0xf984e86d - 0xb99443c7 0x17080c33 0x940f6892 - 0xd57a95d1 0x6ea7b691 0xc5038fa8 - 0x6bb48a6e 0x73f1b1ea 0x37160841 - 0xe05715ce 0xa7c45bbd 0x690d82d5 - 0x99c2454c 0x6ff117b3 0xd830683b - 0x3f81c9cf 0x1ca38a91 0x0c3392e4 - 0xd817c625 0x7b8e9a24 0x175b89ea - 0xad79f3dc 0x4d50d7b4 0x9d4e90f8 - 0xad9e2939 0xc165d6a4 0x0ada7e1b - 0xfb1bf495 0xfc3131c2 0xb8c6e604 - 0xc2761124 0xf63de4a6 0x0e9565f9 - 0xc8e53761 0x7e7a37a5 0xe99dcdae - 0x9aff7e1e 0xbd44b13d 0x6b0e6aa4 - 0x038907e4 0x8e0d6850 0xef51bc20 - 0xf73c94af 0x88bea7b1 0xcbbb1b30 - 0xd024b7f3>; - rsa,modulus = <0xc0711d6cb 0x9e86db7f 0x45986dbe - 0x023f1e8c9 0xe1a4c4d0 0x8a0dfdc9 - 0x023ba0c48 0x06815f6a 0x5caa0654 - 0x07078c4b7 0x3d154853 0x40729023 - 0x0b007c8fe 0x5a3647e5 0x23b41e20 - 0x024720591 0x66915305 0x0e0b29b0 - 0x0de2ad30d 0x8589430f 0xb1590325 - 0x0fb9f5d5e 0x9eba752a 0xd88e6de9 - 0x056b3dcc6 0x9a6b8e61 0x6784f61f - 0x000f39c21 0x5eec6b33 0xd78e4f78 - 0x0921a305f 0xaa2cc27e 0x1ca917af - 0x06e1134f4 0xd48cac77 0x4e914d07 - 0x0f707aa5a 0x0d141f41 0x84677f1d - 0x0ad47a049 0x028aedb6 0xd5536fcf - 0x03fef1e4f 0x133a03d2 0xfd7a750a - 0x0f9159732 0xd207812e 0x6a807375 - 0x06434230d 0xc8e22dad 0x9f29b3d6 - 0x07c44ac2b 0xfa2aad88 0xe2429504 - 0x041febd41 0x85d0d142 0x7b194d65 - 0x06e5d55ea 0x41116961 0xf3181dde - 0x068bf5fbc 0x3dd82047 0x00ee647e - 0x0d7a44ab3>; - rsa,exponent = <0x00 0x10001>; - rsa,n0-inverse = <0xb3928b85>; - rsa,num-bits = <0x800>; - key-name-hint = "dev"; - }; - }; - - -Signed Configurations ---------------------- -While signing images is useful, it does not provide complete protection -against several types of attack. For example, it it possible to create a -FIT with the same signed images, but with the configuration changed such -that a different one is selected (mix and match attack). It is also possible -to substitute a signed image from an older FIT version into a newer FIT -(roll-back attack). - -As an example, consider this FIT: - -/ { - images { - kernel-1 { - data = <data for kernel1> - signature-1 { - algo = "sha1,rsa2048"; - value = <...kernel signature 1...> - }; - }; - kernel-2 { - data = <data for kernel2> - signature-1 { - algo = "sha1,rsa2048"; - value = <...kernel signature 2...> - }; - }; - fdt-1 { - data = <data for fdt1>; - signature-1 { - algo = "sha1,rsa2048"; - value = <...fdt signature 1...> - }; - }; - fdt-2 { - data = <data for fdt2>; - signature-1 { - algo = "sha1,rsa2048"; - value = <...fdt signature 2...> - }; - }; - }; - configurations { - default = "conf-1"; - conf-1 { - kernel = "kernel-1"; - fdt = "fdt-1"; - }; - conf-2 { - kernel = "kernel-2"; - fdt = "fdt-2"; - }; - }; -}; - -Since both kernels are signed it is easy for an attacker to add a new -configuration 3 with kernel 1 and fdt 2: - - configurations { - default = "conf-1"; - conf-1 { - kernel = "kernel-1"; - fdt = "fdt-1"; - }; - conf-2 { - kernel = "kernel-2"; - fdt = "fdt-2"; - }; - conf-3 { - kernel = "kernel-1"; - fdt = "fdt-2"; - }; - }; - -With signed images, nothing protects against this. Whether it gains an -advantage for the attacker is debatable, but it is not secure. - -To solve this problem, we support signed configurations. In this case it -is the configurations that are signed, not the image. Each image has its -own hash, and we include the hash in the configuration signature. - -So the above example is adjusted to look like this: - -/ { - images { - kernel-1 { - data = <data for kernel1> - hash-1 { - algo = "sha1"; - value = <...kernel hash 1...> - }; - }; - kernel-2 { - data = <data for kernel2> - hash-1 { - algo = "sha1"; - value = <...kernel hash 2...> - }; - }; - fdt-1 { - data = <data for fdt1>; - hash-1 { - algo = "sha1"; - value = <...fdt hash 1...> - }; - }; - fdt-2 { - data = <data for fdt2>; - hash-1 { - algo = "sha1"; - value = <...fdt hash 2...> - }; - }; - }; - configurations { - default = "conf-1"; - conf-1 { - kernel = "kernel-1"; - fdt = "fdt-1"; - signature-1 { - algo = "sha1,rsa2048"; - value = <...conf 1 signature...>; - }; - }; - conf-2 { - kernel = "kernel-2"; - fdt = "fdt-2"; - signature-1 { - algo = "sha1,rsa2048"; - value = <...conf 1 signature...>; - }; - }; - }; -}; - - -You can see that we have added hashes for all images (since they are no -longer signed), and a signature to each configuration. In the above example, -mkimage will sign configurations/conf-1, the kernel and fdt that are -pointed to by the configuration (/images/kernel-1, /images/kernel-1/hash-1, -/images/fdt-1, /images/fdt-1/hash-1) and the root structure of the image -(so that it isn't possible to add or remove root nodes). The signature is -written into /configurations/conf-1/signature-1/value. It can easily be -verified later even if the FIT has been signed with other keys in the -meantime. - - -Details -------- -The signature node contains a property ('hashed-nodes') which lists all the -nodes that the signature was made over. The image is walked in order and each -tag processed as follows: -- DTB_BEGIN_NODE: The tag and the following name are included in the signature - if the node or its parent are present in 'hashed-nodes' -- DTB_END_NODE: The tag is included in the signature if the node or its parent - are present in 'hashed-nodes' -- DTB_PROPERTY: The tag, the length word, the offset in the string table, and - the data are all included if the current node is present in 'hashed-nodes' - and the property name is not 'data'. -- DTB_END: The tag is always included in the signature. -- DTB_NOP: The tag is included in the signature if the current node is present - in 'hashed-nodes' - -In addition, the signature contains a property 'hashed-strings' which contains -the offset and length in the string table of the strings that are to be -included in the signature (this is done last). - -IMPORTANT: To verify the signature outside u-boot, it is vital to not only -calculate the hash of the image and verify the signature with that, but also to -calculate the hashes of the kernel, fdt, and ramdisk images and check those -match the hash values in the corresponding 'hash*' subnodes. - - -Verification ------------- -FITs are verified when loaded. After the configuration is selected a list -of required images is produced. If there are 'required' public keys, then -each image must be verified against those keys. This means that every image -that might be used by the target needs to be signed with 'required' keys. - -This happens automatically as part of a bootm command when FITs are used. - -For Signed Configurations, the default verification behavior can be changed by -the following optional property in /signature node in U-Boot's control FDT. - -- required-mode: Valid values are "any" to allow verified boot to succeed if -the selected configuration is signed by any of the 'required' keys, and "all" -to allow verified boot to succeed if the selected configuration is signed by -all of the 'required' keys. - -This property can be added to a binary device tree using fdtput as shown in -below examples:: - - fdtput -t s control.dtb /signature required-mode any - fdtput -t s control.dtb /signature required-mode all - - -Enabling FIT Verification -------------------------- -In addition to the options to enable FIT itself, the following CONFIGs must -be enabled: - -CONFIG_FIT_SIGNATURE - enable signing and verification in FITs -CONFIG_RSA - enable RSA algorithm for signing -CONFIG_ECDSA - enable ECDSA algorithm for signing - -WARNING: When relying on signed FIT images with required signature check -the legacy image format is default disabled by not defining -CONFIG_LEGACY_IMAGE_FORMAT - - -Testing -------- -An easy way to test signing and verification is to use the test script -provided in test/vboot/vboot_test.sh. This uses sandbox (a special version -of U-Boot which runs under Linux) to show the operation of a 'bootm' -command loading and verifying images. - -A sample run is show below: - -$ make O=sandbox sandbox_config -$ make O=sandbox -$ O=sandbox ./test/vboot/vboot_test.sh - - -Simple Verified Boot Test -========================= - -Please see doc/uImage.FIT/verified-boot.txt for more information - -/home/hs/ids/u-boot/sandbox/tools/mkimage -D -I dts -O dtb -p 2000 -Build keys -do sha1 test -Build FIT with signed images -Test Verified Boot Run: unsigned signatures:: OK -Sign images -Test Verified Boot Run: signed images: OK -Build FIT with signed configuration -Test Verified Boot Run: unsigned config: OK -Sign images -Test Verified Boot Run: signed config: OK -check signed config on the host -Signature check OK -OK -Test Verified Boot Run: signed config: OK -Test Verified Boot Run: signed config with bad hash: OK -do sha256 test -Build FIT with signed images -Test Verified Boot Run: unsigned signatures:: OK -Sign images -Test Verified Boot Run: signed images: OK -Build FIT with signed configuration -Test Verified Boot Run: unsigned config: OK -Sign images -Test Verified Boot Run: signed config: OK -check signed config on the host -Signature check OK -OK -Test Verified Boot Run: signed config: OK -Test Verified Boot Run: signed config with bad hash: OK - -Test passed - - -Software signing: keydir vs keyfile ------------------------------------ - -In the simplest case, signing is done by giving mkimage the 'keyfile'. This is -the path to a file containing the signing key. - -The alternative is to pass the 'keydir' argument. In this case the filename of -the key is derived from the 'keydir' and the "key-name-hint" property in the -FIT. In this case the "key-name-hint" property is mandatory, and the key must -exist in "<keydir>/<key-name-hint>.<ext>" Here the extension "ext" is -specific to the signing algorithm. - - -Hardware Signing with PKCS#11 or with HSM ------------------------------------------ - -Securely managing private signing keys can challenging, especially when the -keys are stored on the file system of a computer that is connected to the -Internet. If an attacker is able to steal the key, they can sign malicious FIT -images which will appear genuine to your devices. - -An alternative solution is to keep your signing key securely stored on hardware -device like a smartcard, USB token or Hardware Security Module (HSM) and have -them perform the signing. PKCS#11 is standard for interfacing with these crypto -device. - -Requirements: -Smartcard/USB token/HSM which can work with some openssl engine -openssl - -For pkcs11 engine usage: -libp11 (provides pkcs11 engine) -p11-kit (recommended to simplify setup) -opensc (for smartcards and smartcard like USB devices) -gnutls (recommended for key generation, p11tool) - -For generic HSMs respective openssl engine must be installed and locateable by -openssl. This may require setting up LD_LIBRARY_PATH if engine is not installed -to openssl's default search paths. - -PKCS11 engine support forms "key id" based on "keydir" and with -"key-name-hint". "key-name-hint" is used as "object" name (if not defined in -keydir). "keydir" (if defined) is used to define (prefix for) which PKCS11 source -is being used for lookup up for the key. - -PKCS11 engine key ids: - "pkcs11:<keydir>;object=<key-name-hint>;type=<public|private>" -or, if keydir contains "object=" - "pkcs11:<keydir>;type=<public|private>" -or - "pkcs11:object=<key-name-hint>;type=<public|private>", - -Generic HSM engine support forms "key id" based on "keydir" and with -"key-name-hint". If "keydir" is specified for mkimage it is used as a prefix in -"key id" and is appended with "key-name-hint". - -Generic engine key ids: - "<keydir><key-name-hint>" -or - "<key-name-hint>" - -In order to set the pin in the HSM, an environment variable "MKIMAGE_SIGN_PIN" -can be specified. - -The following examples use the Nitrokey Pro using pkcs11 engine. Instructions -for other devices may vary. - -Notes on pkcs11 engine setup: - -Make sure p11-kit, opensc are installed and that p11-kit is setup to use opensc. -/usr/share/p11-kit/modules/opensc.module should be present on your system. - - -Generating Keys On the Nitrokey: - -$ gpg --card-edit - -Reader ...........: Nitrokey Nitrokey Pro (xxxxxxxx0000000000000000) 00 00 -Application ID ...: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -Version ..........: 2.1 -Manufacturer .....: ZeitControl -Serial number ....: xxxxxxxx -Name of cardholder: [not set] -Language prefs ...: de -Sex ..............: unspecified -URL of public key : [not set] -Login data .......: [not set] -Signature PIN ....: forced -Key attributes ...: rsa2048 rsa2048 rsa2048 -Max. PIN lengths .: 32 32 32 -PIN retry counter : 3 0 3 -Signature counter : 0 -Signature key ....: [none] -Encryption key....: [none] -Authentication key: [none] -General key info..: [none] - -gpg/card> generate -Make off-card backup of encryption key? (Y/n) n - -Please note that the factory settings of the PINs are - PIN = '123456' Admin PIN = '12345678' -You should change them using the command --change-pin - -What keysize do you want for the Signature key? (2048) 4096 -The card will now be re-configured to generate a key of 4096 bits -Note: There is no guarantee that the card supports the requested size. - If the key generation does not succeed, please check the - documentation of your card to see what sizes are allowed. -What keysize do you want for the Encryption key? (2048) 4096 -The card will now be re-configured to generate a key of 4096 bits -What keysize do you want for the Authentication key? (2048) 4096 -The card will now be re-configured to generate a key of 4096 bits -Please specify how long the key should be valid. - 0 = key does not expire - <n> = key expires in n days - <n>w = key expires in n weeks - <n>m = key expires in n months - <n>y = key expires in n years -Key is valid for? (0) -Key does not expire at all -Is this correct? (y/N) y - -GnuPG needs to construct a user ID to identify your key. - -Real name: John Doe -Email address: john.doe@email.com -Comment: -You selected this USER-ID: - "John Doe john.doe@email.com" - -Change (N)ame, (C)omment, (E)mail or (O)kay/(Q)uit? o - - -Using p11tool to get the token URL: - -Depending on system configuration, gpg-agent may need to be killed first. - -$ p11tool --provider /usr/lib/opensc-pkcs11.so --list-tokens -Token 0: -URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29 -Label: OpenPGP card (User PIN (sig)) -Type: Hardware token -Manufacturer: ZeitControl -Model: PKCS#15 emulated -Serial: 000xxxxxxxxx -Module: (null) - - -Token 1: -URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%29 -Label: OpenPGP card (User PIN) -Type: Hardware token -Manufacturer: ZeitControl -Model: PKCS#15 emulated -Serial: 000xxxxxxxxx -Module: (null) - -Use the portion of the signature token URL after "pkcs11:" as the keydir argument (-k) to mkimage below. - - -Use the URL of the token to list the private keys: - -$ p11tool --login --provider /usr/lib/opensc-pkcs11.so --list-privkeys \ -"pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29" -Token 'OpenPGP card (User PIN (sig))' with URL 'pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29' requires user PIN -Enter PIN: -Object 0: -URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29;id=%01;object=Signature%20key;type=private -Type: Private key -Label: Signature key -Flags: CKA_PRIVATE; CKA_NEVER_EXTRACTABLE; CKA_SENSITIVE; -ID: 01 - -Use the label, in this case "Signature key" as the key-name-hint in your FIT. - -Create the fitImage: -$ ./tools/mkimage -f fit-image.its fitImage - - -Sign the fitImage with the hardware key: - -$ ./tools/mkimage -F -k \ -"model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29" \ --K u-boot.dtb -N pkcs11 -r fitImage - - -Future Work ------------ -- Roll-back protection using a TPM is done using the tpm command. This can -be scripted, but we might consider a default way of doing this, built into -bootm. - - -Possible Future Work --------------------- -- More sandbox tests for failure modes -- Passwords for keys/certificates -- Perhaps implement OAEP -- Enhance bootm to permit scripted signature verification (so that a script -can verify an image but not actually boot it) - - -Simon Glass -sjg@chromium.org -1-1-13 diff --git a/doc/usage/cmd/source.rst b/doc/usage/cmd/source.rst index a5c5204a28b8..697f644745b2 100644 --- a/doc/usage/cmd/source.rst +++ b/doc/usage/cmd/source.rst @@ -22,7 +22,7 @@ Two formats for script files exist: * Flat Image Tree (FIT)
The benefit of the FIT images is that they can be signed and verifed as -decribed in :download:`signature.txt <../../uImage.FIT/signature.txt>`. +described in :doc:`../fit/signature`.
Both formats can be created with the mkimage tool.
diff --git a/doc/usage/fit/beaglebone_vboot.rst b/doc/usage/fit/beaglebone_vboot.rst new file mode 100644 index 000000000000..9851c445c1c9 --- /dev/null +++ b/doc/usage/fit/beaglebone_vboot.rst @@ -0,0 +1,607 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Verified Boot on the Beaglebone Black +===================================== + +Introduction +------------ + +Before reading this, please read :doc:`verified-boot` and :doc:`signature`. +These instructions are for mainline U-Boot from v2014.07 onwards. + +There is quite a bit of documentation in this directory describing how +verified boot works in U-Boot. There is also a test which runs through the +entire process of signing an image and running U-Boot (sandbox) to check it. +However, it might be useful to also have an example on a real board. + +Beaglebone Black is a fairly common board so seems to be a reasonable choice +for an example of how to enable verified boot using U-Boot. + +First a note that may to help avoid confusion. U-Boot and Linux both use +device tree. They may use the same device tree source, but it is seldom useful +for them to use the exact same binary from the same place. More typically, +U-Boot has its device tree packaged with it, and the kernel's device tree is +packaged with the kernel. In particular this is important with verified boot, +since U-Boot's device tree must be immutable. If it can be changed then the +public keys can be changed and verified boot is useless. An attacker can +simply generate a new key and put his public key into U-Boot so that +everything verifies. On the other hand the kernel's device tree typically +changes when the kernel changes, so it is useful to package an updated device +tree with the kernel binary. U-Boot supports the latter with its flexible FIT +format (Flat Image Tree). + + +Overview +-------- + +The steps are roughly as follows: + +#. Build U-Boot for the board, with the verified boot options enabled. + +#. Obtain a suitable Linux kernel + +#. Create a Image Tree Source file (ITS) file describing how you want the + kernel to be packaged, compressed and signed. + +#. Create a key pair + +#. Sign the kernel + +#. Put the public key into U-Boot's image + +#. Put U-Boot and the kernel onto the board + +#. Try it + + +Step 1: Build U-Boot +-------------------- + +a. Set up the environment variable to point to your toolchain. You will need +this for U-Boot and also for the kernel if you build it. For example if you +installed a Linaro version manually it might be something like:: + + export CROSS_COMPILE=/opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.08_linux/bin/arm-linux-gnueabihf- + +or if you just installed gcc-arm-linux-gnueabi then it might be:: + + export CROSS_COMPILE=arm-linux-gnueabi- + +b. Configure and build U-Boot with verified boot enabled:: + + export UBOOT=/path/to/u-boot + cd $UBOOT + # You can add -j10 if you have 10 CPUs to make it faster + make O=b/am335x_boneblack_vboot am335x_boneblack_vboot_config all + export UOUT=$UBOOT/b/am335x_boneblack_vboot + +c. You will now have a U-Boot image:: + + file b/am335x_boneblack_vboot/u-boot-dtb.img + b/am335x_boneblack_vboot/u-boot-dtb.img: u-boot legacy uImage, U-Boot 2014.07-rc2-00065-g2f69f8, Firmware/ARM, Firmware Image (Not compressed), 395375 bytes, Sat May 31 16:19:04 2014, Load Address: 0x80800000, Entry Point: 0x00000000, Header CRC: 0x0ABD6ACA, Data CRC: 0x36DEF7E4 + + +Step 2: Build Linux +-------------------- + +a. Find the kernel image ('Image') and device tree (.dtb) file you plan to +use. In our case it is am335x-boneblack.dtb and it is built with the kernel. +At the time of writing an SD Boot image can be obtained from here:: + + http://www.elinux.org/Beagleboard:Updating_The_Software#Image_For_Booting_Fr... + +You can write this to an SD card and then mount it to extract the kernel and +device tree files. + +You can also build a kernel. Instructions for this are are here:: + + http://elinux.org/Building_BBB_Kernel + +or you can use your favourite search engine. Following these instructions +produces a kernel Image and device tree files. For the record the steps were:: + + export KERNEL=/path/to/kernel + cd $KERNEL + git clone git://github.com/beagleboard/kernel.git . + git checkout v3.14 + ./patch.sh + cp configs/beaglebone kernel/arch/arm/configs/beaglebone_defconfig + cd kernel + make beaglebone_defconfig + make uImage dtbs # -j10 if you have 10 CPUs + export OKERNEL=$KERNEL/kernel/arch/arm/boot + +c. You now have the 'Image' and 'am335x-boneblack.dtb' files needed to boot. + + +Step 3: Create the ITS +---------------------- + +Set up a directory for your work:: + + export WORK=/path/to/dir + cd $WORK + +Put this into a file in that directory called sign.its:: + + /dts-v1/; + + / { + description = "Beaglebone black"; + #address-cells = <1>; + + images { + kernel { + data = /incbin/("Image.lzo"); + type = "kernel"; + arch = "arm"; + os = "linux"; + compression = "lzo"; + load = <0x80008000>; + entry = <0x80008000>; + hash-1 { + algo = "sha1"; + }; + }; + fdt-1 { + description = "beaglebone-black"; + data = /incbin/("am335x-boneblack.dtb"); + type = "flat_dt"; + arch = "arm"; + compression = "none"; + hash-1 { + algo = "sha1"; + }; + }; + }; + configurations { + default = "conf-1"; + conf-1 { + kernel = "kernel"; + fdt = "fdt-1"; + signature-1 { + algo = "sha1,rsa2048"; + key-name-hint = "dev"; + sign-images = "fdt", "kernel"; + }; + }; + }; + }; + + +The explanation for this is all in the documentation you have already read. +But briefly it packages a kernel and device tree, and provides a single +configuration to be signed with a key named 'dev'. The kernel is compressed +with LZO to make it smaller. + + +Step 4: Create a key pair +------------------------- + +See :doc:`signature` for details on this step:: + + cd $WORK + mkdir keys + openssl genrsa -F4 -out keys/dev.key 2048 + openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt + +Note: keys/dev.key contains your private key and is very secret. If anyone +gets access to that file they can sign kernels with it. Keep it secure. + + +Step 5: Sign the kernel +----------------------- + +We need to use mkimage (which was built when you built U-Boot) to package the +Linux kernel into a FIT (Flat Image Tree, a flexible file format that U-Boot +can load) using the ITS file you just created. + +At the same time we must put the public key into U-Boot device tree, with the +'required' property, which tells U-Boot that this key must be verified for the +image to be valid. You will make this key available to U-Boot for booting in +step 6:: + + ln -s $OKERNEL/dts/am335x-boneblack.dtb + ln -s $OKERNEL/Image + ln -s $UOUT/u-boot-dtb.img + cp $UOUT/arch/arm/dts/am335x-boneblack.dtb am335x-boneblack-pubkey.dtb + lzop Image + $UOUT/tools/mkimage -f sign.its -K am335x-boneblack-pubkey.dtb -k keys -r image.fit + +You should see something like this:: + + FIT description: Beaglebone black + Created: Sun Jun 1 12:50:30 2014 + Image 0 (kernel) + Description: unavailable + Created: Sun Jun 1 12:50:30 2014 + Type: Kernel Image + Compression: lzo compressed + Data Size: 7790938 Bytes = 7608.34 kB = 7.43 MB + Architecture: ARM + OS: Linux + Load Address: 0x80008000 + Entry Point: 0x80008000 + Hash algo: sha1 + Hash value: c94364646427e10f423837e559898ef02c97b988 + Image 1 (fdt-1) + Description: beaglebone-black + Created: Sun Jun 1 12:50:30 2014 + Type: Flat Device Tree + Compression: uncompressed + Data Size: 31547 Bytes = 30.81 kB = 0.03 MB + Architecture: ARM + Hash algo: sha1 + Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d + Default Configuration: 'conf-1' + Configuration 0 (conf-1) + Description: unavailable + Kernel: kernel + FDT: fdt-1 + + +Now am335x-boneblack-pubkey.dtb contains the public key and image.fit contains +the signed kernel. Jump to step 6 if you like, or continue reading to increase +your understanding. + +You can also run fit_check_sign to check it:: + + $UOUT/tools/fit_check_sign -f image.fit -k am335x-boneblack-pubkey.dtb + +which results in:: + + Verifying Hash Integrity ... sha1,rsa2048:dev+ + ## Loading kernel from FIT Image at 7fc6ee469000 ... + Using 'conf-1' configuration + Verifying Hash Integrity ... + sha1,rsa2048:dev+ + OK + + Trying 'kernel' kernel subimage + Description: unavailable + Created: Sun Jun 1 12:50:30 2014 + Type: Kernel Image + Compression: lzo compressed + Data Size: 7790938 Bytes = 7608.34 kB = 7.43 MB + Architecture: ARM + OS: Linux + Load Address: 0x80008000 + Entry Point: 0x80008000 + Hash algo: sha1 + Hash value: c94364646427e10f423837e559898ef02c97b988 + Verifying Hash Integrity ... + sha1+ + OK + + Unimplemented compression type 4 + ## Loading fdt from FIT Image at 7fc6ee469000 ... + Using 'conf-1' configuration + Trying 'fdt-1' fdt subimage + Description: beaglebone-black + Created: Sun Jun 1 12:50:30 2014 + Type: Flat Device Tree + Compression: uncompressed + Data Size: 31547 Bytes = 30.81 kB = 0.03 MB + Architecture: ARM + Hash algo: sha1 + Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d + Verifying Hash Integrity ... + sha1+ + OK + + Loading Flat Device Tree ... OK + + ## Loading ramdisk from FIT Image at 7fc6ee469000 ... + Using 'conf-1' configuration + Could not find subimage node + + Signature check OK + + +At the top, you see "sha1,rsa2048:dev+". This means that it checked an RSA key +of size 2048 bits using SHA1 as the hash algorithm. The key name checked was +'dev' and the '+' means that it verified. If it showed '-' that would be bad. + +Once the configuration is verified it is then possible to rely on the hashes +in each image referenced by that configuration. So fit_check_sign goes on to +load each of the images. We have a kernel and an FDT but no ramkdisk. In each +case fit_check_sign checks the hash and prints sha1+ meaning that the SHA1 +hash verified. This means that none of the images has been tampered with. + +There is a test in test/vboot which uses U-Boot's sandbox build to verify that +the above flow works. + +But it is fun to do this by hand, so you can load image.fit into a hex editor +like ghex, and change a byte in the kernel:: + + $UOUT/tools/fit_info -f image.fit -n /images/kernel -p data + NAME: kernel + LEN: 7790938 + OFF: 168 + +This tells us that the kernel starts at byte offset 168 (decimal) in image.fit +and extends for about 7MB. Try changing a byte at 0x2000 (say) and run +fit_check_sign again. You should see something like:: + + Verifying Hash Integrity ... sha1,rsa2048:dev+ + ## Loading kernel from FIT Image at 7f5a39571000 ... + Using 'conf-1' configuration + Verifying Hash Integrity ... + sha1,rsa2048:dev+ + OK + + Trying 'kernel' kernel subimage + Description: unavailable + Created: Sun Jun 1 13:09:21 2014 + Type: Kernel Image + Compression: lzo compressed + Data Size: 7790938 Bytes = 7608.34 kB = 7.43 MB + Architecture: ARM + OS: Linux + Load Address: 0x80008000 + Entry Point: 0x80008000 + Hash algo: sha1 + Hash value: c94364646427e10f423837e559898ef02c97b988 + Verifying Hash Integrity ... + sha1 error + Bad hash value for 'hash-1' hash node in 'kernel' image node + Bad Data Hash + + ## Loading fdt from FIT Image at 7f5a39571000 ... + Using 'conf-1' configuration + Trying 'fdt-1' fdt subimage + Description: beaglebone-black + Created: Sun Jun 1 13:09:21 2014 + Type: Flat Device Tree + Compression: uncompressed + Data Size: 31547 Bytes = 30.81 kB = 0.03 MB + Architecture: ARM + Hash algo: sha1 + Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d + Verifying Hash Integrity ... + sha1+ + OK + + Loading Flat Device Tree ... OK + + ## Loading ramdisk from FIT Image at 7f5a39571000 ... + Using 'conf-1' configuration + Could not find subimage node + + Signature check Bad (error 1) + + +It has detected the change in the kernel. + +You can also be sneaky and try to switch images, using the libfdt utilities +that come with dtc (package name is device-tree-compiler but you will need a +recent version like 1.4:: + + dtc -v + Version: DTC 1.4.0 + +First we can check which nodes are actually hashed by the configuration:: + + $ fdtget -l image.fit / + images + configurations + + $ fdtget -l image.fit /configurations + conf-1 + fdtget -l image.fit /configurations/conf-1 + signature-1 + + $ fdtget -p image.fit /configurations/conf-1/signature-1 + hashed-strings + hashed-nodes + timestamp + signer-version + signer-name + value + algo + key-name-hint + sign-images + + $ fdtget image.fit /configurations/conf-1/signature-1 hashed-nodes + / /configurations/conf-1 /images/fdt-1 /images/fdt-1/hash /images/kernel /images/kernel/hash-1 + +This gives us a bit of a look into the signature that mkimage added. Note you +can also use fdtdump to list the entire device tree. + +Say we want to change the kernel that this configuration uses +(/images/kernel). We could just put a new kernel in the image, but we will +need to change the hash to match. Let's simulate that by changing a byte of +the hash:: + + fdtget -tx image.fit /images/kernel/hash-1 value + c9436464 6427e10f 423837e5 59898ef0 2c97b988 + fdtput -tx image.fit /images/kernel/hash-1 value c9436464 6427e10f 423837e5 59898ef0 2c97b981 + +Now check it again:: + + $UOUT/tools/fit_check_sign -f image.fit -k am335x-boneblack-pubkey.dtb + Verifying Hash Integrity ... sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13 + rsa_verify_with_keynode: RSA failed to verify: -13 + - + Failed to verify required signature 'key-dev' + Signature check Bad (error 1) + +This time we don't even get as far as checking the images, since the +configuration signature doesn't match. We can't change any hashes without the +signature check noticing. The configuration is essentially locked. U-Boot has +a public key for which it requires a match, and will not permit the use of any +configuration that does not match that public key. The only way the +configuration will match is if it was signed by the matching private key. + +It would also be possible to add a new signature node that does match your new +configuration. But that won't work since you are not allowed to change the +configuration in any way. Try it with a fresh (valid) image if you like by +running the mkimage link again. Then:: + + fdtput -p image.fit /configurations/conf-1/signature-1 value fred + $UOUT/tools/fit_check_sign -f image.fit -k am335x-boneblack-pubkey.dtb + Verifying Hash Integrity ... - + sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13 + rsa_verify_with_keynode: RSA failed to verify: -13 + - + Failed to verify required signature 'key-dev' + Signature check Bad (error 1) + + +Of course it would be possible to add an entirely new configuration and boot +with that, but it still needs to be signed, so it won't help. + + +6. Put the public key into U-Boot's image +----------------------------------------- + +Having confirmed that the signature is doing its job, let's try it out in +U-Boot on the board. U-Boot needs access to the public key corresponding to +the private key that you signed with so that it can verify any kernels that +you sign:: + + cd $UBOOT + make O=b/am335x_boneblack_vboot EXT_DTB=${WORK}/am335x-boneblack-pubkey.dtb + +Here we are overriding the normal device tree file with our one, which +contains the public key. + +Now you have a special U-Boot image with the public key. It can verify can +kernel that you sign with the private key as in step 5. + +If you like you can take a look at the public key information that mkimage +added to U-Boot's device tree:: + + fdtget -p am335x-boneblack-pubkey.dtb /signature/key-dev + required + algo + rsa,r-squared + rsa,modulus + rsa,n0-inverse + rsa,num-bits + key-name-hint + +This has information about the key and some pre-processed values which U-Boot +can use to verify against it. These values are obtained from the public key +certificate by mkimage, but require quite a bit of code to generate. To save +code space in U-Boot, the information is extracted and written in raw form for +U-Boot to easily use. The same mechanism is used in Google's Chrome OS. + +Notice the 'required' property. This marks the key as required - U-Boot will +not boot any image that does not verify against this key. + + +7. Put U-Boot and the kernel onto the board +------------------------------------------- + +The method here varies depending on how you are booting. For this example we +are booting from an micro-SD card with two partitions, one for U-Boot and one +for Linux. Put it into your machine and write U-Boot and the kernel to it. +Here the card is /dev/sde:: + + cd $WORK + export UDEV=/dev/sde1 # Change thes two lines to the correct device + export KDEV=/dev/sde2 + sudo mount $UDEV /mnt/tmp && sudo cp $UOUT/u-boot-dtb.img /mnt/tmp/u-boot.img && sleep 1 && sudo umount $UDEV + sudo mount $KDEV /mnt/tmp && sudo cp $WORK/image.fit /mnt/tmp/boot/image.fit && sleep 1 && sudo umount $KDEV + + +8. Try it +--------- + +Boot the board using the commands below:: + + setenv bootargs console=ttyO0,115200n8 quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait + ext2load mmc 0:2 82000000 /boot/image.fit + bootm 82000000 + +You should then see something like this:: + + U-Boot# setenv bootargs console=ttyO0,115200n8 quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait + U-Boot# ext2load mmc 0:2 82000000 /boot/image.fit + 7824930 bytes read in 589 ms (12.7 MiB/s) + U-Boot# bootm 82000000 + ## Loading kernel from FIT Image at 82000000 ... + Using 'conf-1' configuration + Verifying Hash Integrity ... sha1,rsa2048:dev+ OK + Trying 'kernel' kernel subimage + Description: unavailable + Created: 2014-06-01 19:32:54 UTC + Type: Kernel Image + Compression: lzo compressed + Data Start: 0x820000a8 + Data Size: 7790938 Bytes = 7.4 MiB + Architecture: ARM + OS: Linux + Load Address: 0x80008000 + Entry Point: 0x80008000 + Hash algo: sha1 + Hash value: c94364646427e10f423837e559898ef02c97b988 + Verifying Hash Integrity ... sha1+ OK + ## Loading fdt from FIT Image at 82000000 ... + Using 'conf-1' configuration + Trying 'fdt-1' fdt subimage + Description: beaglebone-black + Created: 2014-06-01 19:32:54 UTC + Type: Flat Device Tree + Compression: uncompressed + Data Start: 0x8276e2ec + Data Size: 31547 Bytes = 30.8 KiB + Architecture: ARM + Hash algo: sha1 + Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d + Verifying Hash Integrity ... sha1+ OK + Booting using the fdt blob at 0x8276e2ec + Uncompressing Kernel Image ... OK + Loading Device Tree to 8fff5000, end 8ffffb3a ... OK + + Starting kernel ... + + [ 0.582377] omap_init_mbox: hwmod doesn't have valid attrs + [ 2.589651] musb-hdrc musb-hdrc.0.auto: Failed to request rx1. + [ 2.595830] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517 + [ 2.606470] musb-hdrc musb-hdrc.1.auto: Failed to request rx1. + [ 2.612723] musb-hdrc musb-hdrc.1.auto: musb_init_controller failed with status -517 + [ 2.940808] drivers/rtc/hctosys.c: unable to open rtc device (rtc0) + [ 7.248889] libphy: PHY 4a101000.mdio:01 not found + [ 7.253995] net eth0: phy 4a101000.mdio:01 not found on slave 1 + systemd-fsck[83]: Angstrom: clean, 50607/218160 files, 306348/872448 blocks + + .---O---. + | | .-. o o + | | |-----.-----.-----.| | .----..-----.-----. + | | | __ | ---'| '--.| .-'| | | + | | | | | |--- || --'| | | ' | | | | + '---'---'--'--'--. |-----''----''--' '-----'-'-'-' + -' | + '---' + + The Angstrom Distribution beaglebone ttyO0 + + Angstrom v2012.12 - Kernel 3.14.1+ + + beaglebone login: + +At this point your kernel has been verified and you can be sure that it is one +that you signed. As an exercise, try changing image.fit as in step 5 and see +what happens. + + +Further Improvements +-------------------- + +Several of the steps here can be easily automated. In particular it would be +capital if signing and packaging a kernel were easy, perhaps a simple make +target in the kernel. + +Some mention of how to use multiple .dtb files in a FIT might be useful. + +U-Boot's verified boot mechanism has not had a robust and independent security +review. Such a review should look at the implementation and its resistance to +attacks. + +Perhaps the verified boot feature could be integrated into the Amstrom +distribution. + + +.. sectionauthor:: Simon Glass sjg@chromium.org, 2-June-14 diff --git a/doc/usage/fit/index.rst b/doc/usage/fit/index.rst index 0635d06b811a..0576675ec001 100644 --- a/doc/usage/fit/index.rst +++ b/doc/usage/fit/index.rst @@ -12,3 +12,6 @@ doc/uImage.FIT
source_file_format x86-fit-boot + signature + verified-boot + beaglebone_vboot diff --git a/doc/usage/fit/signature.rst b/doc/usage/fit/signature.rst new file mode 100644 index 000000000000..7d8292ece867 --- /dev/null +++ b/doc/usage/fit/signature.rst @@ -0,0 +1,760 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +U-Boot FIT Signature Verification +================================= + +Introduction +------------ + +FIT supports hashing of images so that these hashes can be checked on +loading. This protects against corruption of the image. However it does not +prevent the substitution of one image for another. + +The signature feature allows the hash to be signed with a private key such +that it can be verified using a public key later. Provided that the private +key is kept secret and the public key is stored in a non-volatile place, +any image can be verified in this way. + +See verified-boot.txt for more general information on verified boot. + + +Concepts +-------- + +Some familiarity with public key cryptography is assumed in this section. + +The procedure for signing is as follows: + + - hash an image in the FIT + - sign the hash with a private key to produce a signature + - store the resulting signature in the FIT + +The procedure for verification is: + + - read the FIT + - obtain the public key + - extract the signature from the FIT + - hash the image from the FIT + - verify (with the public key) that the extracted signature matches the + hash + +The signing is generally performed by mkimage, as part of making a firmware +image for the device. The verification is normally done in U-Boot on the +device. + + +Algorithms +---------- +In principle any suitable algorithm can be used to sign and verify a hash. +U-Boot supports a few hashing and verification algorithms. See below for +details. + +While it is acceptable to bring in large cryptographic libraries such as +openssl on the host side (e.g. mkimage), it is not desirable for U-Boot. +For the run-time verification side, it is important to keep code and data +size as small as possible. + +For this reason the RSA image verification uses pre-processed public keys +which can be used with a very small amount of code - just some extraction +of data from the FDT and exponentiation mod n. Code size impact is a little +under 5KB on Tegra Seaboard, for example. + +It is relatively straightforward to add new algorithms if required. If +another RSA variant is needed, then it can be added with the +U_BOOT_CRYPTO_ALGO() macro. If another algorithm is needed (such as DSA) then +it can be placed in a directory alongside lib/rsa/, and its functions added +using U_BOOT_CRYPTO_ALGO(). + + +Creating an RSA key pair and certificate +---------------------------------------- +To create a new public/private key pair, size 2048 bits:: + + $ openssl genpkey -algorithm RSA -out keys/dev.key \ + -pkeyopt rsa_keygen_bits:2048 -pkeyopt rsa_keygen_pubexp:65537 + +To create a certificate for this containing the public key:: + + $ openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt + +If you like you can look at the public key also:: + + $ openssl rsa -in keys/dev.key -pubout + + +Device Tree Bindings +-------------------- +The following properties are required in the FIT's signature node(s) to +allow the signer to operate. These should be added to the .its file. +Signature nodes sit at the same level as hash nodes and are called +signature-1, signature-2, etc. + +algo + Algorithm name (e.g. "sha1,rsa2048") + +key-name-hint + Name of key to use for signing. The keys will normally be in + a single directory (parameter -k to mkimage). For a given key <name>, its + private key is stored in <name>.key and the certificate is stored in + <name>.crt. + +When the image is signed, the following properties are added (mandatory): + +value + The signature data (e.g. 256 bytes for 2048-bit RSA) + +When the image is signed, the following properties are optional: + +timestamp + Time when image was signed (standard Unix time_t format) + +signer-name + Name of the signer (e.g. "mkimage") + +signer-version + Version string of the signer (e.g. "2013.01") + +comment + Additional information about the signer or image + +padding + The padding algorithm, it may be pkcs-1.5 or pss, + if no value is provided we assume pkcs-1.5 + +For config bindings (see Signed Configurations below), the following +additional properties are optional: + +sign-images + A list of images to sign, each being a property of the conf + node that contains then. The default is "kernel,fdt" which means that these + two images will be looked up in the config and signed if present. + +For config bindings, these properties are added by the signer: + +hashed-nodes + A list of nodes which were hashed by the signer. Each is + a string - the full path to node. A typical value might be:: + + hashed-nodes = "/", "/configurations/conf-1", "/images/kernel", + "/images/kernel/hash-1", "/images/fdt-1", + "/images/fdt-1/hash-1"; + +hashed-strings + The start and size of the string region of the FIT that was hashed + +Example: See :doc:`sign-images` for an example image tree source file and +sign-configs.its for config signing. + + +Public Key Storage +------------------ +In order to verify an image that has been signed with a public key we need to +have a trusted public key. This cannot be stored in the signed image, since +it would be easy to alter. For this implementation we choose to store the +public key in U-Boot's control FDT (using CONFIG_OF_CONTROL). + +Public keys should be stored as sub-nodes in a /signature node. Required +properties are: + +algo + Algorithm name (e.g. "sha1,rsa2048" or "sha256,ecdsa256") + +Optional properties are: + +key-name-hint + Name of key used for signing. This is only a hint since it + is possible for the name to be changed. Verification can proceed by checking + all available signing keys until one matches. + +required + If present this indicates that the key must be verified for the + image / configuration to be considered valid. Only required keys are + normally verified by the FIT image booting algorithm. Valid values are + "image" to force verification of all images, and "conf" to force verification + of the selected configuration (which then relies on hashes in the images to + verify those). + +Each signing algorithm has its own additional properties. + +For RSA the following are mandatory: + +rsa,num-bits + Number of key bits (e.g. 2048) + +rsa,modulus + Modulus (N) as a big-endian multi-word integer + +rsa,exponent + Public exponent (E) as a 64 bit unsigned integer + +rsa,r-squared + (2^num-bits)^2 as a big-endian multi-word integer + +rsa,n0-inverse + -1 / modulus[0] mod 2^32 + +For ECDSA the following are mandatory: + +ecdsa,curve + Name of ECDSA curve (e.g. "prime256v1") + +ecdsa,x-point + Public key X coordinate as a big-endian multi-word integer + +ecdsa,y-point + Public key Y coordinate as a big-endian multi-word integer + +These parameters can be added to a binary device tree using parameter -K of the +mkimage command:: + + tools/mkimage -f fit.its -K control.dtb -k keys -r image.fit + +Here is an example of a generated device tree node:: + + signature { + key-dev { + required = "conf"; + algo = "sha256,rsa2048"; + rsa,r-squared = <0xb76d1acf 0xa1763ca5 0xeb2f126 + 0x742edc80 0xd3f42177 0x9741d9d9 + 0x35bb476e 0xff41c718 0xd3801430 + 0xf22537cb 0xa7e79960 0xae32a043 + 0x7da1427a 0x341d6492 0x3c2762f5 + 0xaac04726 0x5b262d96 0xf984e86d + 0xb99443c7 0x17080c33 0x940f6892 + 0xd57a95d1 0x6ea7b691 0xc5038fa8 + 0x6bb48a6e 0x73f1b1ea 0x37160841 + 0xe05715ce 0xa7c45bbd 0x690d82d5 + 0x99c2454c 0x6ff117b3 0xd830683b + 0x3f81c9cf 0x1ca38a91 0x0c3392e4 + 0xd817c625 0x7b8e9a24 0x175b89ea + 0xad79f3dc 0x4d50d7b4 0x9d4e90f8 + 0xad9e2939 0xc165d6a4 0x0ada7e1b + 0xfb1bf495 0xfc3131c2 0xb8c6e604 + 0xc2761124 0xf63de4a6 0x0e9565f9 + 0xc8e53761 0x7e7a37a5 0xe99dcdae + 0x9aff7e1e 0xbd44b13d 0x6b0e6aa4 + 0x038907e4 0x8e0d6850 0xef51bc20 + 0xf73c94af 0x88bea7b1 0xcbbb1b30 + 0xd024b7f3>; + rsa,modulus = <0xc0711d6cb 0x9e86db7f 0x45986dbe + 0x023f1e8c9 0xe1a4c4d0 0x8a0dfdc9 + 0x023ba0c48 0x06815f6a 0x5caa0654 + 0x07078c4b7 0x3d154853 0x40729023 + 0x0b007c8fe 0x5a3647e5 0x23b41e20 + 0x024720591 0x66915305 0x0e0b29b0 + 0x0de2ad30d 0x8589430f 0xb1590325 + 0x0fb9f5d5e 0x9eba752a 0xd88e6de9 + 0x056b3dcc6 0x9a6b8e61 0x6784f61f + 0x000f39c21 0x5eec6b33 0xd78e4f78 + 0x0921a305f 0xaa2cc27e 0x1ca917af + 0x06e1134f4 0xd48cac77 0x4e914d07 + 0x0f707aa5a 0x0d141f41 0x84677f1d + 0x0ad47a049 0x028aedb6 0xd5536fcf + 0x03fef1e4f 0x133a03d2 0xfd7a750a + 0x0f9159732 0xd207812e 0x6a807375 + 0x06434230d 0xc8e22dad 0x9f29b3d6 + 0x07c44ac2b 0xfa2aad88 0xe2429504 + 0x041febd41 0x85d0d142 0x7b194d65 + 0x06e5d55ea 0x41116961 0xf3181dde + 0x068bf5fbc 0x3dd82047 0x00ee647e + 0x0d7a44ab3>; + rsa,exponent = <0x00 0x10001>; + rsa,n0-inverse = <0xb3928b85>; + rsa,num-bits = <0x800>; + key-name-hint = "dev"; + }; + }; + + +Signed Configurations +--------------------- +While signing images is useful, it does not provide complete protection +against several types of attack. For example, it is possible to create a +FIT with the same signed images, but with the configuration changed such +that a different one is selected (mix and match attack). It is also possible +to substitute a signed image from an older FIT version into a newer FIT +(roll-back attack). + +As an example, consider this FIT:: + + / { + images { + kernel-1 { + data = <data for kernel1> + signature-1 { + algo = "sha1,rsa2048"; + value = <...kernel signature 1...> + }; + }; + kernel-2 { + data = <data for kernel2> + signature-1 { + algo = "sha1,rsa2048"; + value = <...kernel signature 2...> + }; + }; + fdt-1 { + data = <data for fdt1>; + signature-1 { + algo = "sha1,rsa2048"; + value = <...fdt signature 1...> + }; + }; + fdt-2 { + data = <data for fdt2>; + signature-1 { + algo = "sha1,rsa2048"; + value = <...fdt signature 2...> + }; + }; + }; + configurations { + default = "conf-1"; + conf-1 { + kernel = "kernel-1"; + fdt = "fdt-1"; + }; + conf-2 { + kernel = "kernel-2"; + fdt = "fdt-2"; + }; + }; + }; + +Since both kernels are signed it is easy for an attacker to add a new +configuration 3 with kernel 1 and fdt 2:: + + configurations { + default = "conf-1"; + conf-1 { + kernel = "kernel-1"; + fdt = "fdt-1"; + }; + conf-2 { + kernel = "kernel-2"; + fdt = "fdt-2"; + }; + conf-3 { + kernel = "kernel-1"; + fdt = "fdt-2"; + }; + }; + +With signed images, nothing protects against this. Whether it gains an +advantage for the attacker is debatable, but it is not secure. + +To solve this problem, we support signed configurations. In this case it +is the configurations that are signed, not the image. Each image has its +own hash, and we include the hash in the configuration signature. + +So the above example is adjusted to look like this:: + + / { + images { + kernel-1 { + data = <data for kernel1> + hash-1 { + algo = "sha1"; + value = <...kernel hash 1...> + }; + }; + kernel-2 { + data = <data for kernel2> + hash-1 { + algo = "sha1"; + value = <...kernel hash 2...> + }; + }; + fdt-1 { + data = <data for fdt1>; + hash-1 { + algo = "sha1"; + value = <...fdt hash 1...> + }; + }; + fdt-2 { + data = <data for fdt2>; + hash-1 { + algo = "sha1"; + value = <...fdt hash 2...> + }; + }; + }; + configurations { + default = "conf-1"; + conf-1 { + kernel = "kernel-1"; + fdt = "fdt-1"; + signature-1 { + algo = "sha1,rsa2048"; + value = <...conf 1 signature...>; + }; + }; + conf-2 { + kernel = "kernel-2"; + fdt = "fdt-2"; + signature-1 { + algo = "sha1,rsa2048"; + value = <...conf 1 signature...>; + }; + }; + }; + }; + + +You can see that we have added hashes for all images (since they are no +longer signed), and a signature to each configuration. In the above example, +mkimage will sign configurations/conf-1, the kernel and fdt that are +pointed to by the configuration (/images/kernel-1, /images/kernel-1/hash-1, +/images/fdt-1, /images/fdt-1/hash-1) and the root structure of the image +(so that it isn't possible to add or remove root nodes). The signature is +written into /configurations/conf-1/signature-1/value. It can easily be +verified later even if the FIT has been signed with other keys in the +meantime. + + +Details +------- +The signature node contains a property ('hashed-nodes') which lists all the +nodes that the signature was made over. The image is walked in order and each +tag processed as follows: + +DTB_BEGIN_NODE + The tag and the following name are included in the signature + if the node or its parent are present in 'hashed-nodes' + +DTB_END_NODE + The tag is included in the signature if the node or its parent + are present in 'hashed-nodes' + +DTB_PROPERTY + The tag, the length word, the offset in the string table, and + the data are all included if the current node is present in 'hashed-nodes' + and the property name is not 'data'. + +DTB_END + The tag is always included in the signature. + +DTB_NOP + The tag is included in the signature if the current node is present + in 'hashed-nodes' + +In addition, the signature contains a property 'hashed-strings' which contains +the offset and length in the string table of the strings that are to be +included in the signature (this is done last). + +IMPORTANT: To verify the signature outside u-boot, it is vital to not only +calculate the hash of the image and verify the signature with that, but also to +calculate the hashes of the kernel, fdt, and ramdisk images and check those +match the hash values in the corresponding 'hash*' subnodes. + + +Verification +------------ +FITs are verified when loaded. After the configuration is selected a list +of required images is produced. If there are 'required' public keys, then +each image must be verified against those keys. This means that every image +that might be used by the target needs to be signed with 'required' keys. + +This happens automatically as part of a bootm command when FITs are used. + +For Signed Configurations, the default verification behavior can be changed by +the following optional property in /signature node in U-Boot's control FDT. + +required-mode + Valid values are "any" to allow verified boot to succeed if + the selected configuration is signed by any of the 'required' keys, and "all" + to allow verified boot to succeed if the selected configuration is signed by + all of the 'required' keys. + +This property can be added to a binary device tree using fdtput as shown in +below examples:: + + fdtput -t s control.dtb /signature required-mode any + fdtput -t s control.dtb /signature required-mode all + + +Enabling FIT Verification +------------------------- +In addition to the options to enable FIT itself, the following CONFIGs must +be enabled: + +CONFIG_FIT_SIGNATURE + enable signing and verification in FITs + +CONFIG_RSA + enable RSA algorithm for signing + +CONFIG_ECDSA + enable ECDSA algorithm for signing + +WARNING: When relying on signed FIT images with required signature check +the legacy image format is default disabled by not defining +CONFIG_LEGACY_IMAGE_FORMAT + + +Testing +------- + +An easy way to test signing and verification is to use the test script +provided in test/vboot/vboot_test.sh. This uses sandbox (a special version +of U-Boot which runs under Linux) to show the operation of a 'bootm' +command loading and verifying images. + +A sample run is show below:: + + $ make O=sandbox sandbox_config + $ make O=sandbox + $ O=sandbox ./test/vboot/vboot_test.sh + + +Simple Verified Boot Test +------------------------- + +Please see :doc:`verified-boot` for more information:: + + /home/hs/ids/u-boot/sandbox/tools/mkimage -D -I dts -O dtb -p 2000 + Build keys + do sha1 test + Build FIT with signed images + Test Verified Boot Run: unsigned signatures:: OK + Sign images + Test Verified Boot Run: signed images: OK + Build FIT with signed configuration + Test Verified Boot Run: unsigned config: OK + Sign images + Test Verified Boot Run: signed config: OK + check signed config on the host + Signature check OK + OK + Test Verified Boot Run: signed config: OK + Test Verified Boot Run: signed config with bad hash: OK + do sha256 test + Build FIT with signed images + Test Verified Boot Run: unsigned signatures:: OK + Sign images + Test Verified Boot Run: signed images: OK + Build FIT with signed configuration + Test Verified Boot Run: unsigned config: OK + Sign images + Test Verified Boot Run: signed config: OK + check signed config on the host + Signature check OK + OK + Test Verified Boot Run: signed config: OK + Test Verified Boot Run: signed config with bad hash: OK + + Test passed + + +Software signing: keydir vs keyfile +----------------------------------- + +In the simplest case, signing is done by giving mkimage the 'keyfile'. This is +the path to a file containing the signing key. + +The alternative is to pass the 'keydir' argument. In this case the filename of +the key is derived from the 'keydir' and the "key-name-hint" property in the +FIT. In this case the "key-name-hint" property is mandatory, and the key must +exist in "<keydir>/<key-name-hint>.<ext>" Here the extension "ext" is +specific to the signing algorithm. + + +Hardware Signing with PKCS#11 or with HSM +----------------------------------------- + +Securely managing private signing keys can challenging, especially when the +keys are stored on the file system of a computer that is connected to the +Internet. If an attacker is able to steal the key, they can sign malicious FIT +images which will appear genuine to your devices. + +An alternative solution is to keep your signing key securely stored on hardware +device like a smartcard, USB token or Hardware Security Module (HSM) and have +them perform the signing. PKCS#11 is standard for interfacing with these crypto +device. + +Requirements: + - Smartcard/USB token/HSM which can work with some openssl engine + - openssl + +For pkcs11 engine usage: + - libp11 (provides pkcs11 engine) + - p11-kit (recommended to simplify setup) + - opensc (for smartcards and smartcard like USB devices) + - gnutls (recommended for key generation, p11tool) + +For generic HSMs respective openssl engine must be installed and locateable by +openssl. This may require setting up LD_LIBRARY_PATH if engine is not installed +to openssl's default search paths. + +PKCS11 engine support forms "key id" based on "keydir" and with +"key-name-hint". "key-name-hint" is used as "object" name (if not defined in +keydir). "keydir" (if defined) is used to define (prefix for) which PKCS11 source +is being used for lookup up for the key. + +PKCS11 engine key ids + "pkcs11:<keydir>;object=<key-name-hint>;type=<public|private>" + +or, if keydir contains "object=" + "pkcs11:<keydir>;type=<public|private>" + +or + "pkcs11:object=<key-name-hint>;type=<public|private>", + +Generic HSM engine support forms "key id" based on "keydir" and with +"key-name-hint". If "keydir" is specified for mkimage it is used as a prefix in +"key id" and is appended with "key-name-hint". + +Generic engine key ids: + "<keydir><key-name-hint>" + +or + "< key-name-hint>" + +In order to set the pin in the HSM, an environment variable "MKIMAGE_SIGN_PIN" +can be specified. + +The following examples use the Nitrokey Pro using pkcs11 engine. Instructions +for other devices may vary. + +Notes on pkcs11 engine setup: + +Make sure p11-kit, opensc are installed and that p11-kit is setup to use opensc. +/usr/share/p11-kit/modules/opensc.module should be present on your system. + + +Generating Keys On the Nitrokey:: + + $ gpg --card-edit + + Reader ...........: Nitrokey Nitrokey Pro (xxxxxxxx0000000000000000) 00 00 + Application ID ...: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx + Version ..........: 2.1 + Manufacturer .....: ZeitControl + Serial number ....: xxxxxxxx + Name of cardholder: [not set] + Language prefs ...: de + Sex ..............: unspecified + URL of public key : [not set] + Login data .......: [not set] + Signature PIN ....: forced + Key attributes ...: rsa2048 rsa2048 rsa2048 + Max. PIN lengths .: 32 32 32 + PIN retry counter : 3 0 3 + Signature counter : 0 + Signature key ....: [none] + Encryption key....: [none] + Authentication key: [none] + General key info..: [none] + + gpg/card> generate + Make off-card backup of encryption key? (Y/n) n + + Please note that the factory settings of the PINs are + PIN = '123456' Admin PIN = '12345678' + You should change them using the command --change-pin + + What keysize do you want for the Signature key? (2048) 4096 + The card will now be re-configured to generate a key of 4096 bits + Note: There is no guarantee that the card supports the requested size. + If the key generation does not succeed, please check the + documentation of your card to see what sizes are allowed. + What keysize do you want for the Encryption key? (2048) 4096 + The card will now be re-configured to generate a key of 4096 bits + What keysize do you want for the Authentication key? (2048) 4096 + The card will now be re-configured to generate a key of 4096 bits + Please specify how long the key should be valid. + 0 = key does not expire + <n> = key expires in n days + <n>w = key expires in n weeks + <n>m = key expires in n months + <n>y = key expires in n years + Key is valid for? (0) + Key does not expire at all + Is this correct? (y/N) y + + GnuPG needs to construct a user ID to identify your key. + + Real name: John Doe + Email address: john.doe@email.com + Comment: + You selected this USER-ID: + "John Doe john.doe@email.com" + + Change (N)ame, (C)omment, (E)mail or (O)kay/(Q)uit? o + + +Using p11tool to get the token URL: + +Depending on system configuration, gpg-agent may need to be killed first:: + + $ p11tool --provider /usr/lib/opensc-pkcs11.so --list-tokens + Token 0: + URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29 + Label: OpenPGP card (User PIN (sig)) + Type: Hardware token + Manufacturer: ZeitControl + Model: PKCS#15 emulated + Serial: 000xxxxxxxxx + Module: (null) + + + Token 1: + URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%29 + Label: OpenPGP card (User PIN) + Type: Hardware token + Manufacturer: ZeitControl + Model: PKCS#15 emulated + Serial: 000xxxxxxxxx + Module: (null) + +Use the portion of the signature token URL after "pkcs11:" as the keydir argument (-k) to mkimage below. + + +Use the URL of the token to list the private keys:: + + $ p11tool --login --provider /usr/lib/opensc-pkcs11.so --list-privkeys \ + "pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29" + Token 'OpenPGP card (User PIN (sig))' with URL 'pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29' requires user PIN + Enter PIN: + Object 0: + URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29;id=%01;object=Signature%20key;type=private + Type: Private key + Label: Signature key + Flags: CKA_PRIVATE; CKA_NEVER_EXTRACTABLE; CKA_SENSITIVE; + ID: 01 + +Use the label, in this case "Signature key" as the key-name-hint in your FIT. + +Create the fitImage:: + + $ ./tools/mkimage -f fit-image.its fitImage + + +Sign the fitImage with the hardware key:: + + $ ./tools/mkimage -F -k \ + "model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29" \ + -K u-boot.dtb -N pkcs11 -r fitImage + + +Future Work +----------- + +- Roll-back protection using a TPM is done using the tpm command. This can + be scripted, but we might consider a default way of doing this, built into + bootm. + + +Possible Future Work +-------------------- + +- More sandbox tests for failure modes +- Passwords for keys/certificates +- Perhaps implement OAEP +- Enhance bootm to permit scripted signature verification (so that a script + can verify an image but not actually boot it) + + +.. sectionauthor:: Simon Glass sjg@chromium.org, 1-1-13 diff --git a/doc/uImage.FIT/verified-boot.txt b/doc/usage/fit/verified-boot.rst similarity index 54% rename from doc/uImage.FIT/verified-boot.txt rename to doc/usage/fit/verified-boot.rst index 41c9fa9e09f9..bef52ba36ffc 100644 --- a/doc/uImage.FIT/verified-boot.txt +++ b/doc/usage/fit/verified-boot.rst @@ -1,8 +1,11 @@ +.. SPDX-License-Identifier: GPL-2.0+ + U-Boot Verified Boot ====================
Introduction ------------ + Verified boot here means the verification of all software loaded into a machine during the boot process to ensure that it is authorised and correct for that machine. @@ -21,6 +24,7 @@ memory, so that firmware can easily be upgraded in a secure manner.
Signing ------- + Verified boot uses cryptographic algorithms to 'sign' software images. Images are signed using a private key known only to the signer, but can be verified using a public key. As its name suggests the public key can be @@ -28,31 +32,31 @@ made available without risk to the verification process. The private and public keys are mathematically related. For more information on how this works look up "public key cryptography" and "RSA" (a particular algorithm).
-The signing and verification process looks something like this: - - - Signing Verification - ======= ============ - - +--------------+ * - | RSA key pair | * +---------------+ - | .key .crt | * | Public key in | - +--------------+ +------> public key ----->| trusted place | - | | * +---------------+ - | | * | - v | * v - +---------+ | * +--------------+ - | |----------+ * | | - | signer | * | U-Boot | - | |----------+ * | signature |--> yes/no - +---------+ | * | verification | - ^ | * | | - | | * +--------------+ - | | * ^ - +----------+ | * | - | Software | +----> signed image -------------+ - | image | * - +----------+ * +The signing and verification process looks something like this:: + + + Signing Verification + ======= ============ + + +--------------+ * + | RSA key pair | * +---------------+ + | .key .crt | * | Public key in | + +--------------+ +------> public key ----->| trusted place | + | | * +---------------+ + | | * | + v | * v + +---------+ | * +--------------+ + | |----------+ * | | + | signer | * | U-Boot | + | |----------+ * | signature |--> yes/no + +---------+ | * | verification | + ^ | * | | + | | * +--------------+ + | | * ^ + +----------+ | * | + | Software | +----> signed image -------------+ + | image | * + +----------+ *
The signature algorithm relies only on the public key to do its work. Using @@ -70,23 +74,25 @@ the verification is worthless.
Chaining Images --------------- + The above method works for a signer providing images to a run-time U-Boot. It is also possible to extend this scheme to a second level, like this:
-1. Master private key is used by the signer to sign a first-stage image. -2. Master public key is placed in read-only memory. -2. Secondary private key is created and used to sign second-stage images. -3. Secondary public key is placed in first stage images -4. We use the master public key to verify the first-stage image. We then -use the secondary public key in the first-stage image to verify the second- -state image. -5. This chaining process can go on indefinitely. It is recommended to use a -different key at each stage, so that a compromise in one place will not -affect the whole change. +#. Master private key is used by the signer to sign a first-stage image. +#. Master public key is placed in read-only memory. +#. Secondary private key is created and used to sign second-stage images. +#. Secondary public key is placed in first stage images +#. We use the master public key to verify the first-stage image. We then + use the secondary public key in the first-stage image to verify the second- + state image. +#. This chaining process can go on indefinitely. It is recommended to use a + different key at each stage, so that a compromise in one place will not + affect the whole change.
Flattened Image Tree (FIT) -------------------------- + The FIT format is already widely used in U-Boot. It is a flattened device tree (FDT) in a particular format, with images contained within. FITs include hashes to verify images, so it is relatively straightforward to @@ -96,9 +102,6 @@ The public key can be stored in U-Boot's CONFIG_OF_CONTROL device tree in a standard place. Then when a FIT is loaded it can be verified using that public key. Multiple keys and multiple signatures are supported.
-See signature.txt for more information. - +See :doc:`signature` for more information.
-Simon Glass -sjg@chromium.org -1-1-13 +.. sectionauthor:: Simon Glass sjg@chromium.org 1-1-13
On 6/22/23 22:21, Simon Glass wrote:
Bring these files into the documentation.
Fix 'wtih' and 'it' typos and repeated 'could' while we are here.
Signed-off-by: Simon Glass sjg@chromium.org
doc/uImage.FIT/beaglebone_vboot.txt | 607 -------------- doc/uImage.FIT/signature.txt | 707 ---------------- doc/usage/cmd/source.rst | 2 +- doc/usage/fit/beaglebone_vboot.rst | 607 ++++++++++++++ doc/usage/fit/index.rst | 3 + doc/usage/fit/signature.rst | 760 ++++++++++++++++++ .../fit/verified-boot.rst} | 83 +- 7 files changed, 1414 insertions(+), 1355 deletions(-) delete mode 100644 doc/uImage.FIT/beaglebone_vboot.txt delete mode 100644 doc/uImage.FIT/signature.txt create mode 100644 doc/usage/fit/beaglebone_vboot.rst create mode 100644 doc/usage/fit/signature.rst rename doc/{uImage.FIT/verified-boot.txt => usage/fit/verified-boot.rst} (54%)
diff --git a/doc/uImage.FIT/beaglebone_vboot.txt b/doc/uImage.FIT/beaglebone_vboot.txt deleted file mode 100644 index ebd2068ed38d..000000000000 --- a/doc/uImage.FIT/beaglebone_vboot.txt +++ /dev/null @@ -1,607 +0,0 @@
-Verified Boot on the Beaglebone Black
-Introduction
-Before reading this, please read verified-boot.txt and signature.txt. These -instructions are for mainline U-Boot from v2014.07 onwards.
-There is quite a bit of documentation in this directory describing how -verified boot works in U-Boot. There is also a test which runs through the -entire process of signing an image and running U-Boot (sandbox) to check it. -However, it might be useful to also have an example on a real board.
-Beaglebone Black is a fairly common board so seems to be a reasonable choice -for an example of how to enable verified boot using U-Boot.
-First a note that may to help avoid confusion. U-Boot and Linux both use -device tree. They may use the same device tree source, but it is seldom useful -for them to use the exact same binary from the same place. More typically, -U-Boot has its device tree packaged wtih it, and the kernel's device tree is -packaged with the kernel. In particular this is important with verified boot, -since U-Boot's device tree must be immutable. If it can be changed then the -public keys can be changed and verified boot is useless. An attacker can -simply generate a new key and put his public key into U-Boot so that -everything verifies. On the other hand the kernel's device tree typically -changes when the kernel changes, so it is useful to package an updated device -tree with the kernel binary. U-Boot supports the latter with its flexible FIT -format (Flat Image Tree).
-Overview
-The steps are roughly as follows:
-1. Build U-Boot for the board, with the verified boot options enabled.
-2. Obtain a suitable Linux kernel
-3. Create a Image Tree Source file (ITS) file describing how you want the -kernel to be packaged, compressed and signed.
-4. Create a key pair
-5. Sign the kernel
-6. Put the public key into U-Boot's image
-7. Put U-Boot and the kernel onto the board
-8. Try it
-Step 1: Build U-Boot
-a. Set up the environment variable to point to your toolchain. You will need -this for U-Boot and also for the kernel if you build it. For example if you -installed a Linaro version manually it might be something like:
- export CROSS_COMPILE=/opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.08_linux/bin/arm-linux-gnueabihf-
-or if you just installed gcc-arm-linux-gnueabi then it might be
- export CROSS_COMPILE=arm-linux-gnueabi-
-b. Configure and build U-Boot with verified boot enabled:
- export UBOOT=/path/to/u-boot
- cd $UBOOT
- # You can add -j10 if you have 10 CPUs to make it faster
- make O=b/am335x_boneblack_vboot am335x_boneblack_vboot_config all
- export UOUT=$UBOOT/b/am335x_boneblack_vboot
-c. You will now have a U-Boot image:
- file b/am335x_boneblack_vboot/u-boot-dtb.img
-b/am335x_boneblack_vboot/u-boot-dtb.img: u-boot legacy uImage, U-Boot 2014.07-rc2-00065-g2f69f8, Firmware/ARM, Firmware Image (Not compressed), 395375 bytes, Sat May 31 16:19:04 2014, Load Address: 0x80800000, Entry Point: 0x00000000, Header CRC: 0x0ABD6ACA, Data CRC: 0x36DEF7E4
-Step 2: Build Linux
-a. Find the kernel image ('Image') and device tree (.dtb) file you plan to -use. In our case it is am335x-boneblack.dtb and it is built with the kernel. -At the time of writing an SD Boot image can be obtained from here:
-You can write this to an SD card and then mount it to extract the kernel and -device tree files.
-You can also build a kernel. Instructions for this are are here:
-or you can use your favourite search engine. Following these instructions -produces a kernel Image and device tree files. For the record the steps were:
- export KERNEL=/path/to/kernel
- cd $KERNEL
- git clone git://github.com/beagleboard/kernel.git .
- git checkout v3.14
- ./patch.sh
- cp configs/beaglebone kernel/arch/arm/configs/beaglebone_defconfig
- cd kernel
- make beaglebone_defconfig
- make uImage dtbs # -j10 if you have 10 CPUs
- export OKERNEL=$KERNEL/kernel/arch/arm/boot
-c. You now have the 'Image' and 'am335x-boneblack.dtb' files needed to boot.
-Step 3: Create the ITS
-Set up a directory for your work.
- export WORK=/path/to/dir
- cd $WORK
-Put this into a file in that directory called sign.its:
-/dts-v1/;
- description = "Beaglebone black";
- #address-cells = <1>;
- images {
kernel {
type = "kernel";
arch = "arm";
os = "linux";
hash-1 {
algo = "sha1";
fdt-1 {
type = "flat_dt";
arch = "arm";
hash-1 {
algo = "sha1";
- configurations {
default = "conf-1";
conf-1 {
kernel = "kernel";
fdt = "fdt-1";
signature-1 {
-The explanation for this is all in the documentation you have already read. -But briefly it packages a kernel and device tree, and provides a single -configuration to be signed with a key named 'dev'. The kernel is compressed -with LZO to make it smaller.
-Step 4: Create a key pair
-See signature.txt for details on this step.
- cd $WORK
- mkdir keys
- openssl genrsa -F4 -out keys/dev.key 2048
- openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt
-Note: keys/dev.key contains your private key and is very secret. If anyone -gets access to that file they can sign kernels with it. Keep it secure.
-Step 5: Sign the kernel
-We need to use mkimage (which was built when you built U-Boot) to package the -Linux kernel into a FIT (Flat Image Tree, a flexible file format that U-Boot -can load) using the ITS file you just created.
-At the same time we must put the public key into U-Boot device tree, with the -'required' property, which tells U-Boot that this key must be verified for the -image to be valid. You will make this key available to U-Boot for booting in -step 6.
- ln -s $OKERNEL/dts/am335x-boneblack.dtb
- ln -s $OKERNEL/Image
- ln -s $UOUT/u-boot-dtb.img
- cp $UOUT/arch/arm/dts/am335x-boneblack.dtb am335x-boneblack-pubkey.dtb
- lzop Image
- $UOUT/tools/mkimage -f sign.its -K am335x-boneblack-pubkey.dtb -k keys -r image.fit
-You should see something like this:
-FIT description: Beaglebone black -Created: Sun Jun 1 12:50:30 2014
- Image 0 (kernel)
- Description: unavailable
- Created: Sun Jun 1 12:50:30 2014
- Type: Kernel Image
- Compression: lzo compressed
- Data Size: 7790938 Bytes = 7608.34 kB = 7.43 MB
- Architecture: ARM
- OS: Linux
- Load Address: 0x80008000
- Entry Point: 0x80008000
- Hash algo: sha1
- Hash value: c94364646427e10f423837e559898ef02c97b988
- Image 1 (fdt-1)
- Description: beaglebone-black
- Type: Flat Device Tree
- Compression: uncompressed
- Data Size: 31547 Bytes = 30.81 kB = 0.03 MB
- Architecture: ARM
- Hash algo: sha1
- Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d
- Default Configuration: 'conf-1'
- Configuration 0 (conf-1)
- Kernel: kernel
- FDT: fdt-1
-Now am335x-boneblack-pubkey.dtb contains the public key and image.fit contains -the signed kernel. Jump to step 6 if you like, or continue reading to increase -your understanding.
-You can also run fit_check_sign to check it:
- $UOUT/tools/fit_check_sign -f image.fit -k am335x-boneblack-pubkey.dtb
-which results in:
-Verifying Hash Integrity ... sha1,rsa2048:dev+ -## Loading kernel from FIT Image at 7fc6ee469000 ...
- Using 'conf-1' configuration
- Verifying Hash Integrity ...
-sha1,rsa2048:dev+ -OK
- Trying 'kernel' kernel subimage
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha1
-sha1+ -OK
-Unimplemented compression type 4 -## Loading fdt from FIT Image at 7fc6ee469000 ...
- Trying 'fdt-1' fdt subimage
Architecture: ARM
Hash algo: sha1
-sha1+ -OK
- Loading Flat Device Tree ... OK
-## Loading ramdisk from FIT Image at 7fc6ee469000 ...
-Could not find subimage node
-Signature check OK
-At the top, you see "sha1,rsa2048:dev+". This means that it checked an RSA key -of size 2048 bits using SHA1 as the hash algorithm. The key name checked was -'dev' and the '+' means that it verified. If it showed '-' that would be bad.
-Once the configuration is verified it is then possible to rely on the hashes -in each image referenced by that configuration. So fit_check_sign goes on to -load each of the images. We have a kernel and an FDT but no ramkdisk. In each -case fit_check_sign checks the hash and prints sha1+ meaning that the SHA1 -hash verified. This means that none of the images has been tampered with.
-There is a test in test/vboot which uses U-Boot's sandbox build to verify that -the above flow works.
-But it is fun to do this by hand, so you can load image.fit into a hex editor -like ghex, and change a byte in the kernel:
- $UOUT/tools/fit_info -f image.fit -n /images/kernel -p data
-NAME: kernel -LEN: 7790938 -OFF: 168
-This tells us that the kernel starts at byte offset 168 (decimal) in image.fit -and extends for about 7MB. Try changing a byte at 0x2000 (say) and run -fit_check_sign again. You should see something like:
-Verifying Hash Integrity ... sha1,rsa2048:dev+ -## Loading kernel from FIT Image at 7f5a39571000 ...
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha1
-sha1 error -Bad hash value for 'hash-1' hash node in 'kernel' image node -Bad Data Hash
-## Loading fdt from FIT Image at 7f5a39571000 ...
Architecture: ARM
Hash algo: sha1
-sha1+ -OK
-## Loading ramdisk from FIT Image at 7f5a39571000 ...
-Signature check Bad (error 1)
-It has detected the change in the kernel.
-You can also be sneaky and try to switch images, using the libfdt utilities -that come with dtc (package name is device-tree-compiler but you will need a -recent version like 1.4:
- dtc -v
-Version: DTC 1.4.0
-First we can check which nodes are actually hashed by the configuration:
- fdtget -l image.fit /
-images -configurations
- fdtget -l image.fit /configurations
-conf-1 -fdtget -l image.fit /configurations/conf-1 -signature-1
- fdtget -p image.fit /configurations/conf-1/signature-1
-hashed-strings -hashed-nodes -timestamp -signer-version -signer-name -value -algo -key-name-hint -sign-images
- fdtget image.fit /configurations/conf-1/signature-1 hashed-nodes
-/ /configurations/conf-1 /images/fdt-1 /images/fdt-1/hash /images/kernel /images/kernel/hash-1
-This gives us a bit of a look into the signature that mkimage added. Note you -can also use fdtdump to list the entire device tree.
-Say we want to change the kernel that this configuration uses -(/images/kernel). We could just put a new kernel in the image, but we will -need to change the hash to match. Let's simulate that by changing a byte of -the hash:
- fdtget -tx image.fit /images/kernel/hash-1 value
-c9436464 6427e10f 423837e5 59898ef0 2c97b988
- fdtput -tx image.fit /images/kernel/hash-1 value c9436464 6427e10f 423837e5 59898ef0 2c97b981
-Now check it again:
-Verifying Hash Integrity ... sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13
-rsa_verify_with_keynode: RSA failed to verify: -13
-Failed to verify required signature 'key-dev' -Signature check Bad (error 1)
-This time we don't even get as far as checking the images, since the -configuration signature doesn't match. We can't change any hashes without the -signature check noticing. The configuration is essentially locked. U-Boot has -a public key for which it requires a match, and will not permit the use of any -configuration that does not match that public key. The only way the -configuration will match is if it was signed by the matching private key.
-It would also be possible to add a new signature node that does match your new -configuration. But that won't work since you are not allowed to change the -configuration in any way. Try it with a fresh (valid) image if you like by -running the mkimage link again. Then:
- fdtput -p image.fit /configurations/conf-1/signature-1 value fred
-Verifying Hash Integrity ... - -sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13
-Of course it would be possible to add an entirely new configuration and boot -with that, but it still needs to be signed, so it won't help.
-Having confirmed that the signature is doing its job, let's try it out in -U-Boot on the board. U-Boot needs access to the public key corresponding to -the private key that you signed with so that it can verify any kernels that -you sign.
- cd $UBOOT
- make O=b/am335x_boneblack_vboot EXT_DTB=${WORK}/am335x-boneblack-pubkey.dtb
-Here we are overriding the normal device tree file with our one, which -contains the public key.
-Now you have a special U-Boot image with the public key. It can verify can -kernel that you sign with the private key as in step 5.
-If you like you can take a look at the public key information that mkimage -added to U-Boot's device tree:
- fdtget -p am335x-boneblack-pubkey.dtb /signature/key-dev
-required -algo -rsa,r-squared -rsa,modulus -rsa,n0-inverse -rsa,num-bits -key-name-hint
-This has information about the key and some pre-processed values which U-Boot -can use to verify against it. These values are obtained from the public key -certificate by mkimage, but require quite a bit of code to generate. To save -code space in U-Boot, the information is extracted and written in raw form for -U-Boot to easily use. The same mechanism is used in Google's Chrome OS.
-Notice the 'required' property. This marks the key as required - U-Boot will -not boot any image that does not verify against this key.
-The method here varies depending on how you are booting. For this example we -are booting from an micro-SD card with two partitions, one for U-Boot and one -for Linux. Put it into your machine and write U-Boot and the kernel to it. -Here the card is /dev/sde:
- cd $WORK
- export UDEV=/dev/sde1 # Change thes two lines to the correct device
- export KDEV=/dev/sde2
- sudo mount $UDEV /mnt/tmp && sudo cp $UOUT/u-boot-dtb.img /mnt/tmp/u-boot.img && sleep 1 && sudo umount $UDEV
- sudo mount $KDEV /mnt/tmp && sudo cp $WORK/image.fit /mnt/tmp/boot/image.fit && sleep 1 && sudo umount $KDEV
-8. Try it
-Boot the board using the commands below:
- setenv bootargs console=ttyO0,115200n8 quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
- ext2load mmc 0:2 82000000 /boot/image.fit
- bootm 82000000
-You should then see something like this:
-U-Boot# setenv bootargs console=ttyO0,115200n8 quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait -U-Boot# ext2load mmc 0:2 82000000 /boot/image.fit -7824930 bytes read in 589 ms (12.7 MiB/s) -U-Boot# bootm 82000000 -## Loading kernel from FIT Image at 82000000 ...
- Verifying Hash Integrity ... sha1,rsa2048:dev+ OK
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha1
- Verifying Hash Integrity ... sha1+ OK
-## Loading fdt from FIT Image at 82000000 ...
Architecture: ARM
Hash algo: sha1
- Booting using the fdt blob at 0x8276e2ec
- Uncompressing Kernel Image ... OK
- Loading Device Tree to 8fff5000, end 8ffffb3a ... OK
-Starting kernel ...
-[ 0.582377] omap_init_mbox: hwmod doesn't have valid attrs -[ 2.589651] musb-hdrc musb-hdrc.0.auto: Failed to request rx1. -[ 2.595830] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517 -[ 2.606470] musb-hdrc musb-hdrc.1.auto: Failed to request rx1. -[ 2.612723] musb-hdrc musb-hdrc.1.auto: musb_init_controller failed with status -517 -[ 2.940808] drivers/rtc/hctosys.c: unable to open rtc device (rtc0) -[ 7.248889] libphy: PHY 4a101000.mdio:01 not found -[ 7.253995] net eth0: phy 4a101000.mdio:01 not found on slave 1 -systemd-fsck[83]: Angstrom: clean, 50607/218160 files, 306348/872448 blocks
-.---O---. -| | .-. o o -| | |-----.-----.-----.| | .----..-----.-----. -| | | __ | ---'| '--.| .-'| | | -| | | | | |--- || --'| | | ' | | | | -'---'---'--'--'--. |-----''----''--' '-----'-'-'-'
-The Angstrom Distribution beaglebone ttyO0
-Angstrom v2012.12 - Kernel 3.14.1+
-beaglebone login:
-At this point your kernel has been verified and you can be sure that it is one -that you signed. As an exercise, try changing image.fit as in step 5 and see -what happens.
-Further Improvements
-Several of the steps here can be easily automated. In particular it would be -capital if signing and packaging a kernel were easy, perhaps a simple make -target in the kernel.
-Some mention of how to use multiple .dtb files in a FIT might be useful.
-U-Boot's verified boot mechanism has not had a robust and independent security -review. Such a review should look at the implementation and its resistance to -attacks.
-Perhaps the verified boot feature could could be integrated into the Amstrom -distribution.
-Simon Glass -sjg@chromium.org -2-June-14 diff --git a/doc/uImage.FIT/signature.txt b/doc/uImage.FIT/signature.txt deleted file mode 100644 index 21eb3894aada..000000000000 --- a/doc/uImage.FIT/signature.txt +++ /dev/null @@ -1,707 +0,0 @@
-U-Boot FIT Signature Verification
-Introduction
-FIT supports hashing of images so that these hashes can be checked on -loading. This protects against corruption of the image. However it does not -prevent the substitution of one image for another.
-The signature feature allows the hash to be signed with a private key such -that it can be verified using a public key later. Provided that the private -key is kept secret and the public key is stored in a non-volatile place, -any image can be verified in this way.
-See verified-boot.txt for more general information on verified boot.
-Concepts
-Some familiarity with public key cryptography is assumed in this section.
-The procedure for signing is as follows:
-The procedure for verification is:
- read the FIT
hash
-The signing is generally performed by mkimage, as part of making a firmware -image for the device. The verification is normally done in U-Boot on the -device.
-Algorithms
-In principle any suitable algorithm can be used to sign and verify a hash. -U-Boot supports a few hashing and verification algorithms. See below for -details.
-While it is acceptable to bring in large cryptographic libraries such as -openssl on the host side (e.g. mkimage), it is not desirable for U-Boot. -For the run-time verification side, it is important to keep code and data -size as small as possible.
-For this reason the RSA image verification uses pre-processed public keys -which can be used with a very small amount of code - just some extraction -of data from the FDT and exponentiation mod n. Code size impact is a little -under 5KB on Tegra Seaboard, for example.
-It is relatively straightforward to add new algorithms if required. If -another RSA variant is needed, then it can be added with the -U_BOOT_CRYPTO_ALGO() macro. If another algorithm is needed (such as DSA) then -it can be placed in a directory alongside lib/rsa/, and its functions added -using U_BOOT_CRYPTO_ALGO().
-Creating an RSA key pair and certificate
-To create a new public/private key pair, size 2048 bits:
-$ openssl genpkey -algorithm RSA -out keys/dev.key \
- -pkeyopt rsa_keygen_bits:2048 -pkeyopt rsa_keygen_pubexp:65537
-To create a certificate for this containing the public key:
-$ openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt
-If you like you can look at the public key also:
-$ openssl rsa -in keys/dev.key -pubout
-Device Tree Bindings
-The following properties are required in the FIT's signature node(s) to -allow the signer to operate. These should be added to the .its file. -Signature nodes sit at the same level as hash nodes and are called -signature-1, signature-2, etc.
-- algo: Algorithm name (e.g. "sha1,rsa2048")
-- key-name-hint: Name of key to use for signing. The keys will normally be in -a single directory (parameter -k to mkimage). For a given key <name>, its -private key is stored in <name>.key and the certificate is stored in -<name>.crt.
-When the image is signed, the following properties are added (mandatory):
-- value: The signature data (e.g. 256 bytes for 2048-bit RSA)
-When the image is signed, the following properties are optional:
-- timestamp: Time when image was signed (standard Unix time_t format)
-- signer-name: Name of the signer (e.g. "mkimage")
-- signer-version: Version string of the signer (e.g. "2013.01")
-- comment: Additional information about the signer or image
-- padding: The padding algorithm, it may be pkcs-1.5 or pss,
- if no value is provided we assume pkcs-1.5
-For config bindings (see Signed Configurations below), the following -additional properties are optional:
-- sign-images: A list of images to sign, each being a property of the conf -node that contains then. The default is "kernel,fdt" which means that these -two images will be looked up in the config and signed if present.
-For config bindings, these properties are added by the signer:
-- hashed-nodes: A list of nodes which were hashed by the signer. Each is
- a string - the full path to node. A typical value might be:
- hashed-nodes = "/", "/configurations/conf-1", "/images/kernel",
-- hashed-strings: The start and size of the string region of the FIT that
- was hashed
-Example: See sign-images.its for an example image tree source file and -sign-configs.its for config signing.
-Public Key Storage
-In order to verify an image that has been signed with a public key we need to -have a trusted public key. This cannot be stored in the signed image, since -it would be easy to alter. For this implementation we choose to store the -public key in U-Boot's control FDT (using CONFIG_OF_CONTROL).
-Public keys should be stored as sub-nodes in a /signature node. Required -properties are:
-- algo: Algorithm name (e.g. "sha1,rsa2048" or "sha256,ecdsa256")
-Optional properties are:
-- key-name-hint: Name of key used for signing. This is only a hint since it -is possible for the name to be changed. Verification can proceed by checking -all available signing keys until one matches.
-- required: If present this indicates that the key must be verified for the -image / configuration to be considered valid. Only required keys are -normally verified by the FIT image booting algorithm. Valid values are -"image" to force verification of all images, and "conf" to force verification -of the selected configuration (which then relies on hashes in the images to -verify those).
-Each signing algorithm has its own additional properties.
-For RSA the following are mandatory:
-- rsa,num-bits: Number of key bits (e.g. 2048) -- rsa,modulus: Modulus (N) as a big-endian multi-word integer -- rsa,exponent: Public exponent (E) as a 64 bit unsigned integer -- rsa,r-squared: (2^num-bits)^2 as a big-endian multi-word integer -- rsa,n0-inverse: -1 / modulus[0] mod 2^32
-For ECDSA the following are mandatory: -- ecdsa,curve: Name of ECDSA curve (e.g. "prime256v1") -- ecdsa,x-point: Public key X coordinate as a big-endian multi-word integer -- ecdsa,y-point: Public key Y coordinate as a big-endian multi-word integer
-These parameters can be added to a binary device tree using parameter -K of the -mkimage command::
- tools/mkimage -f fit.its -K control.dtb -k keys -r image.fit
-Here is an example of a generated device tree node::
- signature {
key-dev {
required = "conf";
0xd024b7f3>;
0x0d7a44ab3>;
-Signed Configurations
-While signing images is useful, it does not provide complete protection -against several types of attack. For example, it it possible to create a -FIT with the same signed images, but with the configuration changed such -that a different one is selected (mix and match attack). It is also possible -to substitute a signed image from an older FIT version into a newer FIT -(roll-back attack).
-As an example, consider this FIT:
- images {
kernel-1 {
signature-1 {
kernel-2 {
signature-1 {
fdt-1 {
signature-1 {
fdt-2 {
signature-1 {
- configurations {
default = "conf-1";
conf-1 {
fdt = "fdt-1";
conf-2 {
fdt = "fdt-2";
-Since both kernels are signed it is easy for an attacker to add a new -configuration 3 with kernel 1 and fdt 2:
- configurations {
default = "conf-1";
conf-1 {
fdt = "fdt-1";
conf-2 {
fdt = "fdt-2";
conf-3 {
fdt = "fdt-2";
-With signed images, nothing protects against this. Whether it gains an -advantage for the attacker is debatable, but it is not secure.
-To solve this problem, we support signed configurations. In this case it -is the configurations that are signed, not the image. Each image has its -own hash, and we include the hash in the configuration signature.
-So the above example is adjusted to look like this:
- images {
kernel-1 {
hash-1 {
algo = "sha1";
kernel-2 {
hash-1 {
algo = "sha1";
fdt-1 {
hash-1 {
algo = "sha1";
fdt-2 {
hash-1 {
algo = "sha1";
- configurations {
default = "conf-1";
conf-1 {
fdt = "fdt-1";
signature-1 {
conf-2 {
fdt = "fdt-2";
signature-1 {
-You can see that we have added hashes for all images (since they are no -longer signed), and a signature to each configuration. In the above example, -mkimage will sign configurations/conf-1, the kernel and fdt that are -pointed to by the configuration (/images/kernel-1, /images/kernel-1/hash-1, -/images/fdt-1, /images/fdt-1/hash-1) and the root structure of the image -(so that it isn't possible to add or remove root nodes). The signature is -written into /configurations/conf-1/signature-1/value. It can easily be -verified later even if the FIT has been signed with other keys in the -meantime.
-Details
-The signature node contains a property ('hashed-nodes') which lists all the -nodes that the signature was made over. The image is walked in order and each -tag processed as follows: -- DTB_BEGIN_NODE: The tag and the following name are included in the signature
- if the node or its parent are present in 'hashed-nodes'
-- DTB_END_NODE: The tag is included in the signature if the node or its parent
- are present in 'hashed-nodes'
-- DTB_PROPERTY: The tag, the length word, the offset in the string table, and
- the data are all included if the current node is present in 'hashed-nodes'
- and the property name is not 'data'.
-- DTB_END: The tag is always included in the signature. -- DTB_NOP: The tag is included in the signature if the current node is present
- in 'hashed-nodes'
-In addition, the signature contains a property 'hashed-strings' which contains -the offset and length in the string table of the strings that are to be -included in the signature (this is done last).
-IMPORTANT: To verify the signature outside u-boot, it is vital to not only -calculate the hash of the image and verify the signature with that, but also to -calculate the hashes of the kernel, fdt, and ramdisk images and check those -match the hash values in the corresponding 'hash*' subnodes.
-Verification
-FITs are verified when loaded. After the configuration is selected a list -of required images is produced. If there are 'required' public keys, then -each image must be verified against those keys. This means that every image -that might be used by the target needs to be signed with 'required' keys.
-This happens automatically as part of a bootm command when FITs are used.
-For Signed Configurations, the default verification behavior can be changed by -the following optional property in /signature node in U-Boot's control FDT.
-- required-mode: Valid values are "any" to allow verified boot to succeed if -the selected configuration is signed by any of the 'required' keys, and "all" -to allow verified boot to succeed if the selected configuration is signed by -all of the 'required' keys.
-This property can be added to a binary device tree using fdtput as shown in -below examples::
- fdtput -t s control.dtb /signature required-mode any
- fdtput -t s control.dtb /signature required-mode all
-Enabling FIT Verification
-In addition to the options to enable FIT itself, the following CONFIGs must -be enabled:
-CONFIG_FIT_SIGNATURE - enable signing and verification in FITs -CONFIG_RSA - enable RSA algorithm for signing -CONFIG_ECDSA - enable ECDSA algorithm for signing
-WARNING: When relying on signed FIT images with required signature check -the legacy image format is default disabled by not defining -CONFIG_LEGACY_IMAGE_FORMAT
-Testing
-An easy way to test signing and verification is to use the test script -provided in test/vboot/vboot_test.sh. This uses sandbox (a special version -of U-Boot which runs under Linux) to show the operation of a 'bootm' -command loading and verifying images.
-A sample run is show below:
-$ make O=sandbox sandbox_config -$ make O=sandbox -$ O=sandbox ./test/vboot/vboot_test.sh
-Simple Verified Boot Test
-Please see doc/uImage.FIT/verified-boot.txt for more information
-/home/hs/ids/u-boot/sandbox/tools/mkimage -D -I dts -O dtb -p 2000 -Build keys -do sha1 test -Build FIT with signed images -Test Verified Boot Run: unsigned signatures:: OK -Sign images -Test Verified Boot Run: signed images: OK -Build FIT with signed configuration -Test Verified Boot Run: unsigned config: OK -Sign images -Test Verified Boot Run: signed config: OK -check signed config on the host -Signature check OK -OK -Test Verified Boot Run: signed config: OK -Test Verified Boot Run: signed config with bad hash: OK -do sha256 test -Build FIT with signed images -Test Verified Boot Run: unsigned signatures:: OK -Sign images -Test Verified Boot Run: signed images: OK -Build FIT with signed configuration -Test Verified Boot Run: unsigned config: OK -Sign images -Test Verified Boot Run: signed config: OK -check signed config on the host -Signature check OK -OK -Test Verified Boot Run: signed config: OK -Test Verified Boot Run: signed config with bad hash: OK
-Test passed
-Software signing: keydir vs keyfile
-In the simplest case, signing is done by giving mkimage the 'keyfile'. This is -the path to a file containing the signing key.
-The alternative is to pass the 'keydir' argument. In this case the filename of -the key is derived from the 'keydir' and the "key-name-hint" property in the -FIT. In this case the "key-name-hint" property is mandatory, and the key must -exist in "<keydir>/<key-name-hint>.<ext>" Here the extension "ext" is -specific to the signing algorithm.
-Hardware Signing with PKCS#11 or with HSM
-Securely managing private signing keys can challenging, especially when the -keys are stored on the file system of a computer that is connected to the -Internet. If an attacker is able to steal the key, they can sign malicious FIT -images which will appear genuine to your devices.
-An alternative solution is to keep your signing key securely stored on hardware -device like a smartcard, USB token or Hardware Security Module (HSM) and have -them perform the signing. PKCS#11 is standard for interfacing with these crypto -device.
-Requirements: -Smartcard/USB token/HSM which can work with some openssl engine -openssl
-For pkcs11 engine usage: -libp11 (provides pkcs11 engine) -p11-kit (recommended to simplify setup) -opensc (for smartcards and smartcard like USB devices) -gnutls (recommended for key generation, p11tool)
-For generic HSMs respective openssl engine must be installed and locateable by -openssl. This may require setting up LD_LIBRARY_PATH if engine is not installed -to openssl's default search paths.
-PKCS11 engine support forms "key id" based on "keydir" and with -"key-name-hint". "key-name-hint" is used as "object" name (if not defined in -keydir). "keydir" (if defined) is used to define (prefix for) which PKCS11 source -is being used for lookup up for the key.
-PKCS11 engine key ids:
- "pkcs11:<keydir>;object=<key-name-hint>;type=<public|private>"
-or, if keydir contains "object="
- "pkcs11:<keydir>;type=<public|private>"
-or
- "pkcs11:object=<key-name-hint>;type=<public|private>",
-Generic HSM engine support forms "key id" based on "keydir" and with -"key-name-hint". If "keydir" is specified for mkimage it is used as a prefix in -"key id" and is appended with "key-name-hint".
-Generic engine key ids:
- "<keydir><key-name-hint>"
-or
- "<key-name-hint>"
-In order to set the pin in the HSM, an environment variable "MKIMAGE_SIGN_PIN" -can be specified.
-The following examples use the Nitrokey Pro using pkcs11 engine. Instructions -for other devices may vary.
-Notes on pkcs11 engine setup:
-Make sure p11-kit, opensc are installed and that p11-kit is setup to use opensc. -/usr/share/p11-kit/modules/opensc.module should be present on your system.
-Generating Keys On the Nitrokey:
-$ gpg --card-edit
-Reader ...........: Nitrokey Nitrokey Pro (xxxxxxxx0000000000000000) 00 00 -Application ID ...: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -Version ..........: 2.1 -Manufacturer .....: ZeitControl -Serial number ....: xxxxxxxx -Name of cardholder: [not set] -Language prefs ...: de -Sex ..............: unspecified -URL of public key : [not set] -Login data .......: [not set] -Signature PIN ....: forced -Key attributes ...: rsa2048 rsa2048 rsa2048 -Max. PIN lengths .: 32 32 32 -PIN retry counter : 3 0 3 -Signature counter : 0 -Signature key ....: [none] -Encryption key....: [none] -Authentication key: [none] -General key info..: [none]
-gpg/card> generate -Make off-card backup of encryption key? (Y/n) n
-Please note that the factory settings of the PINs are
- PIN = '123456' Admin PIN = '12345678'
-You should change them using the command --change-pin
-What keysize do you want for the Signature key? (2048) 4096 -The card will now be re-configured to generate a key of 4096 bits -Note: There is no guarantee that the card supports the requested size.
- If the key generation does not succeed, please check the
- documentation of your card to see what sizes are allowed.
-What keysize do you want for the Encryption key? (2048) 4096 -The card will now be re-configured to generate a key of 4096 bits -What keysize do you want for the Authentication key? (2048) 4096 -The card will now be re-configured to generate a key of 4096 bits -Please specify how long the key should be valid.
- 0 = key does not expire
- <n> = key expires in n days
- <n>w = key expires in n weeks
- <n>m = key expires in n months
- <n>y = key expires in n years
-Key is valid for? (0) -Key does not expire at all -Is this correct? (y/N) y
-GnuPG needs to construct a user ID to identify your key.
-Real name: John Doe -Email address: john.doe@email.com -Comment: -You selected this USER-ID:
- "John Doe john.doe@email.com"
-Change (N)ame, (C)omment, (E)mail or (O)kay/(Q)uit? o
-Using p11tool to get the token URL:
-Depending on system configuration, gpg-agent may need to be killed first.
-$ p11tool --provider /usr/lib/opensc-pkcs11.so --list-tokens -Token 0: -URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29 -Label: OpenPGP card (User PIN (sig)) -Type: Hardware token -Manufacturer: ZeitControl -Model: PKCS#15 emulated -Serial: 000xxxxxxxxx -Module: (null)
-Token 1: -URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%29 -Label: OpenPGP card (User PIN) -Type: Hardware token -Manufacturer: ZeitControl -Model: PKCS#15 emulated -Serial: 000xxxxxxxxx -Module: (null)
-Use the portion of the signature token URL after "pkcs11:" as the keydir argument (-k) to mkimage below.
-Use the URL of the token to list the private keys:
-$ p11tool --login --provider /usr/lib/opensc-pkcs11.so --list-privkeys \ -"pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29" -Token 'OpenPGP card (User PIN (sig))' with URL 'pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29' requires user PIN -Enter PIN: -Object 0: -URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29;id=%01;object=Signature%20key;type=private -Type: Private key -Label: Signature key -Flags: CKA_PRIVATE; CKA_NEVER_EXTRACTABLE; CKA_SENSITIVE; -ID: 01
-Use the label, in this case "Signature key" as the key-name-hint in your FIT.
-Create the fitImage: -$ ./tools/mkimage -f fit-image.its fitImage
-Sign the fitImage with the hardware key:
-$ ./tools/mkimage -F -k \ -"model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29" \ --K u-boot.dtb -N pkcs11 -r fitImage
-Future Work
-- Roll-back protection using a TPM is done using the tpm command. This can -be scripted, but we might consider a default way of doing this, built into -bootm.
-Possible Future Work
-- More sandbox tests for failure modes -- Passwords for keys/certificates -- Perhaps implement OAEP -- Enhance bootm to permit scripted signature verification (so that a script -can verify an image but not actually boot it)
-Simon Glass -sjg@chromium.org -1-1-13 diff --git a/doc/usage/cmd/source.rst b/doc/usage/cmd/source.rst index a5c5204a28b8..697f644745b2 100644 --- a/doc/usage/cmd/source.rst +++ b/doc/usage/cmd/source.rst @@ -22,7 +22,7 @@ Two formats for script files exist:
- Flat Image Tree (FIT)
The benefit of the FIT images is that they can be signed and verifed as -decribed in :download:`signature.txt <../../uImage.FIT/signature.txt>`. +described in :doc:`../fit/signature`.
Both formats can be created with the mkimage tool.
diff --git a/doc/usage/fit/beaglebone_vboot.rst b/doc/usage/fit/beaglebone_vboot.rst new file mode 100644 index 000000000000..9851c445c1c9 --- /dev/null +++ b/doc/usage/fit/beaglebone_vboot.rst @@ -0,0 +1,607 @@ +.. SPDX-License-Identifier: GPL-2.0+
+Verified Boot on the Beaglebone Black +=====================================
+Introduction +------------
+Before reading this, please read :doc:`verified-boot` and :doc:`signature`. +These instructions are for mainline U-Boot from v2014.07 onwards.
+There is quite a bit of documentation in this directory describing how +verified boot works in U-Boot. There is also a test which runs through the +entire process of signing an image and running U-Boot (sandbox) to check it. +However, it might be useful to also have an example on a real board.
+Beaglebone Black is a fairly common board so seems to be a reasonable choice +for an example of how to enable verified boot using U-Boot.
+First a note that may to help avoid confusion. U-Boot and Linux both use +device tree. They may use the same device tree source, but it is seldom useful +for them to use the exact same binary from the same place. More typically, +U-Boot has its device tree packaged with it, and the kernel's device tree is +packaged with the kernel. In particular this is important with verified boot, +since U-Boot's device tree must be immutable. If it can be changed then the +public keys can be changed and verified boot is useless. An attacker can +simply generate a new key and put his public key into U-Boot so that +everything verifies. On the other hand the kernel's device tree typically +changes when the kernel changes, so it is useful to package an updated device +tree with the kernel binary. U-Boot supports the latter with its flexible FIT +format (Flat Image Tree).
+Overview +--------
+The steps are roughly as follows:
+#. Build U-Boot for the board, with the verified boot options enabled.
+#. Obtain a suitable Linux kernel
+#. Create a Image Tree Source file (ITS) file describing how you want the
- kernel to be packaged, compressed and signed.
+#. Create a key pair
+#. Sign the kernel
+#. Put the public key into U-Boot's image
+#. Put U-Boot and the kernel onto the board
+#. Try it
+Step 1: Build U-Boot +--------------------
+a. Set up the environment variable to point to your toolchain. You will need +this for U-Boot and also for the kernel if you build it. For example if you +installed a Linaro version manually it might be something like::
+or if you just installed gcc-arm-linux-gnueabi then it might be::
+b. Configure and build U-Boot with verified boot enabled::
- cd $UBOOT
+c. You will now have a U-Boot image::
- b/am335x_boneblack_vboot/u-boot-dtb.img: u-boot legacy uImage, U-Boot 2014.07-rc2-00065-g2f69f8, Firmware/ARM, Firmware Image (Not compressed), 395375 bytes, Sat May 31 16:19:04 2014, Load Address: 0x80800000, Entry Point: 0x00000000, Header CRC: 0x0ABD6ACA, Data CRC: 0x36DEF7E4
+Step 2: Build Linux +--------------------
+a. Find the kernel image ('Image') and device tree (.dtb) file you plan to +use. In our case it is am335x-boneblack.dtb and it is built with the kernel. +At the time of writing an SD Boot image can be obtained from here::
+You can write this to an SD card and then mount it to extract the kernel and +device tree files.
+You can also build a kernel. Instructions for this are are here::
+or you can use your favourite search engine. Following these instructions +produces a kernel Image and device tree files. For the record the steps were::
- cd $KERNEL
- ./patch.sh
- cd kernel
+c. You now have the 'Image' and 'am335x-boneblack.dtb' files needed to boot.
+Step 3: Create the ITS +----------------------
+Set up a directory for your work::
- cd $WORK
+Put this into a file in that directory called sign.its::
- /dts-v1/;
images {
kernel {
data = /incbin/("Image.lzo");
type = "kernel";
arch = "arm";
os = "linux";
compression = "lzo";
load = <0x80008000>;
entry = <0x80008000>;
hash-1 {
algo = "sha1";
fdt-1 {
description = "beaglebone-black";
data = /incbin/("am335x-boneblack.dtb");
type = "flat_dt";
arch = "arm";
compression = "none";
hash-1 {
algo = "sha1";
configurations {
default = "conf-1";
conf-1 {
kernel = "kernel";
fdt = "fdt-1";
signature-1 {
key-name-hint = "dev";
sign-images = "fdt", "kernel";
+The explanation for this is all in the documentation you have already read. +But briefly it packages a kernel and device tree, and provides a single +configuration to be signed with a key named 'dev'. The kernel is compressed +with LZO to make it smaller.
+Step 4: Create a key pair +-------------------------
+See :doc:`signature` for details on this step::
- cd $WORK
- mkdir keys
+Note: keys/dev.key contains your private key and is very secret. If anyone +gets access to that file they can sign kernels with it. Keep it secure.
+Step 5: Sign the kernel +-----------------------
+We need to use mkimage (which was built when you built U-Boot) to package the +Linux kernel into a FIT (Flat Image Tree, a flexible file format that U-Boot +can load) using the ITS file you just created.
+At the same time we must put the public key into U-Boot device tree, with the +'required' property, which tells U-Boot that this key must be verified for the +image to be valid. You will make this key available to U-Boot for booting in +step 6::
- lzop Image
+You should see something like this::
- FIT description: Beaglebone black
Image 0 (kernel)
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha1
Image 1 (fdt-1)
Architecture: ARM
Hash algo: sha1
Kernel: kernel
FDT: fdt-1
+Now am335x-boneblack-pubkey.dtb contains the public key and image.fit contains +the signed kernel. Jump to step 6 if you like, or continue reading to increase +your understanding.
+You can also run fit_check_sign to check it::
+which results in::
- ## Loading kernel from FIT Image at 7fc6ee469000 ...
- sha1,rsa2048:dev+
- OK
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha1
- sha1+
- OK
- Unimplemented compression type 4
- ## Loading fdt from FIT Image at 7fc6ee469000 ...
Architecture: ARM
Hash algo: sha1
- sha1+
- OK
- ## Loading ramdisk from FIT Image at 7fc6ee469000 ...
- Could not find subimage node
- Signature check OK
+At the top, you see "sha1,rsa2048:dev+". This means that it checked an RSA key +of size 2048 bits using SHA1 as the hash algorithm. The key name checked was +'dev' and the '+' means that it verified. If it showed '-' that would be bad.
+Once the configuration is verified it is then possible to rely on the hashes +in each image referenced by that configuration. So fit_check_sign goes on to +load each of the images. We have a kernel and an FDT but no ramkdisk. In each +case fit_check_sign checks the hash and prints sha1+ meaning that the SHA1 +hash verified. This means that none of the images has been tampered with.
+There is a test in test/vboot which uses U-Boot's sandbox build to verify that +the above flow works.
+But it is fun to do this by hand, so you can load image.fit into a hex editor +like ghex, and change a byte in the kernel::
- NAME: kernel
- LEN: 7790938
- OFF: 168
+This tells us that the kernel starts at byte offset 168 (decimal) in image.fit +and extends for about 7MB. Try changing a byte at 0x2000 (say) and run +fit_check_sign again. You should see something like::
- ## Loading kernel from FIT Image at 7f5a39571000 ...
- sha1,rsa2048:dev+
- OK
Created: Sun Jun 1 13:09:21 2014
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha1
- sha1 error
- Bad hash value for 'hash-1' hash node in 'kernel' image node
- Bad Data Hash
- ## Loading fdt from FIT Image at 7f5a39571000 ...
Architecture: ARM
Hash algo: sha1
- sha1+
- OK
- ## Loading ramdisk from FIT Image at 7f5a39571000 ...
- Signature check Bad (error 1)
+It has detected the change in the kernel.
+You can also be sneaky and try to switch images, using the libfdt utilities +that come with dtc (package name is device-tree-compiler but you will need a +recent version like 1.4::
- dtc -v
- Version: DTC 1.4.0
+First we can check which nodes are actually hashed by the configuration::
- $ fdtget -l image.fit /
- images
- configurations
- $ fdtget -l image.fit /configurations
- conf-1
- fdtget -l image.fit /configurations/conf-1
- signature-1
- $ fdtget -p image.fit /configurations/conf-1/signature-1
- hashed-strings
- hashed-nodes
- timestamp
- signer-version
- signer-name
- value
- algo
- key-name-hint
- sign-images
- $ fdtget image.fit /configurations/conf-1/signature-1 hashed-nodes
- / /configurations/conf-1 /images/fdt-1 /images/fdt-1/hash /images/kernel /images/kernel/hash-1
+This gives us a bit of a look into the signature that mkimage added. Note you +can also use fdtdump to list the entire device tree.
+Say we want to change the kernel that this configuration uses +(/images/kernel). We could just put a new kernel in the image, but we will +need to change the hash to match. Let's simulate that by changing a byte of +the hash::
- c9436464 6427e10f 423837e5 59898ef0 2c97b988
+Now check it again::
- Verifying Hash Integrity ... sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13
- rsa_verify_with_keynode: RSA failed to verify: -13
- Failed to verify required signature 'key-dev'
+This time we don't even get as far as checking the images, since the +configuration signature doesn't match. We can't change any hashes without the +signature check noticing. The configuration is essentially locked. U-Boot has +a public key for which it requires a match, and will not permit the use of any +configuration that does not match that public key. The only way the +configuration will match is if it was signed by the matching private key.
+It would also be possible to add a new signature node that does match your new +configuration. But that won't work since you are not allowed to change the +configuration in any way. Try it with a fresh (valid) image if you like by +running the mkimage link again. Then::
- Verifying Hash Integrity ... -
- sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13
+Of course it would be possible to add an entirely new configuration and boot +with that, but it still needs to be signed, so it won't help.
+6. Put the public key into U-Boot's image +-----------------------------------------
+Having confirmed that the signature is doing its job, let's try it out in +U-Boot on the board. U-Boot needs access to the public key corresponding to +the private key that you signed with so that it can verify any kernels that +you sign::
- cd $UBOOT
+Here we are overriding the normal device tree file with our one, which +contains the public key.
+Now you have a special U-Boot image with the public key. It can verify can +kernel that you sign with the private key as in step 5.
+If you like you can take a look at the public key information that mkimage +added to U-Boot's device tree::
- required
- algo
- rsa,r-squared
- rsa,modulus
- rsa,n0-inverse
- rsa,num-bits
- key-name-hint
+This has information about the key and some pre-processed values which U-Boot +can use to verify against it. These values are obtained from the public key +certificate by mkimage, but require quite a bit of code to generate. To save +code space in U-Boot, the information is extracted and written in raw form for +U-Boot to easily use. The same mechanism is used in Google's Chrome OS.
+Notice the 'required' property. This marks the key as required - U-Boot will +not boot any image that does not verify against this key.
+7. Put U-Boot and the kernel onto the board +-------------------------------------------
+The method here varies depending on how you are booting. For this example we +are booting from an micro-SD card with two partitions, one for U-Boot and one +for Linux. Put it into your machine and write U-Boot and the kernel to it. +Here the card is /dev/sde::
- cd $WORK
+8. Try it +---------
+Boot the board using the commands below::
- bootm 82000000
+You should then see something like this::
- U-Boot# setenv bootargs console=ttyO0,115200n8 quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
- U-Boot# ext2load mmc 0:2 82000000 /boot/image.fit
- 7824930 bytes read in 589 ms (12.7 MiB/s)
- U-Boot# bootm 82000000
- ## Loading kernel from FIT Image at 82000000 ...
Created: 2014-06-01 19:32:54 UTC
Type: Kernel Image
Data Start: 0x820000a8
Data Size: 7790938 Bytes = 7.4 MiB
Architecture: ARM
OS: Linux
Hash algo: sha1
- ## Loading fdt from FIT Image at 82000000 ...
Data Start: 0x8276e2ec
Data Size: 31547 Bytes = 30.8 KiB
Architecture: ARM
Hash algo: sha1
- Starting kernel ...
- [ 0.582377] omap_init_mbox: hwmod doesn't have valid attrs
- [ 2.589651] musb-hdrc musb-hdrc.0.auto: Failed to request rx1.
- [ 2.595830] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517
- [ 2.606470] musb-hdrc musb-hdrc.1.auto: Failed to request rx1.
- [ 2.612723] musb-hdrc musb-hdrc.1.auto: musb_init_controller failed with status -517
- [ 2.940808] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
- [ 7.248889] libphy: PHY 4a101000.mdio:01 not found
- [ 7.253995] net eth0: phy 4a101000.mdio:01 not found on slave 1
- systemd-fsck[83]: Angstrom: clean, 50607/218160 files, 306348/872448 blocks
- .---O---.
- | | .-. o o
- | | | __ | ---'| '--.| .-'| | |
- The Angstrom Distribution beaglebone ttyO0
- Angstrom v2012.12 - Kernel 3.14.1+
- beaglebone login:
+At this point your kernel has been verified and you can be sure that it is one +that you signed. As an exercise, try changing image.fit as in step 5 and see +what happens.
+Further Improvements +--------------------
+Several of the steps here can be easily automated. In particular it would be +capital if signing and packaging a kernel were easy, perhaps a simple make +target in the kernel.
+Some mention of how to use multiple .dtb files in a FIT might be useful.
+U-Boot's verified boot mechanism has not had a robust and independent security +review. Such a review should look at the implementation and its resistance to +attacks.
+Perhaps the verified boot feature could be integrated into the Amstrom +distribution.
+.. sectionauthor:: Simon Glass sjg@chromium.org, 2-June-14 diff --git a/doc/usage/fit/index.rst b/doc/usage/fit/index.rst index 0635d06b811a..0576675ec001 100644 --- a/doc/usage/fit/index.rst +++ b/doc/usage/fit/index.rst @@ -12,3 +12,6 @@ doc/uImage.FIT
source_file_format x86-fit-boot
- signature
- verified-boot
- beaglebone_vboot
diff --git a/doc/usage/fit/signature.rst b/doc/usage/fit/signature.rst new file mode 100644 index 000000000000..7d8292ece867 --- /dev/null +++ b/doc/usage/fit/signature.rst @@ -0,0 +1,760 @@ +.. SPDX-License-Identifier: GPL-2.0+
+U-Boot FIT Signature Verification +=================================
+FIT supports hashing of images so that these hashes can be checked on +loading. This protects against corruption of the image. However it does not +prevent the substitution of one image for another.
+The signature feature allows the hash to be signed with a private key such +that it can be verified using a public key later. Provided that the private +key is kept secret and the public key is stored in a non-volatile place, +any image can be verified in this way.
+See verified-boot.txt for more general information on verified boot.
+Concepts +--------
+Some familiarity with public key cryptography is assumed in this section.
+The procedure for signing is as follows:
- hash an image in the FIT
- sign the hash with a private key to produce a signature
- store the resulting signature in the FIT
+The procedure for verification is:
- read the FIT
- obtain the public key
- extract the signature from the FIT
- hash the image from the FIT
- verify (with the public key) that the extracted signature matches the
hash
+The signing is generally performed by mkimage, as part of making a firmware +image for the device. The verification is normally done in U-Boot on the +device.
+Algorithms +---------- +In principle any suitable algorithm can be used to sign and verify a hash. +U-Boot supports a few hashing and verification algorithms. See below for +details.
+While it is acceptable to bring in large cryptographic libraries such as +openssl on the host side (e.g. mkimage), it is not desirable for U-Boot. +For the run-time verification side, it is important to keep code and data +size as small as possible.
+For this reason the RSA image verification uses pre-processed public keys +which can be used with a very small amount of code - just some extraction +of data from the FDT and exponentiation mod n. Code size impact is a little +under 5KB on Tegra Seaboard, for example.
+It is relatively straightforward to add new algorithms if required. If +another RSA variant is needed, then it can be added with the +U_BOOT_CRYPTO_ALGO() macro. If another algorithm is needed (such as DSA) then +it can be placed in a directory alongside lib/rsa/, and its functions added +using U_BOOT_CRYPTO_ALGO().
+Creating an RSA key pair and certificate +---------------------------------------- +To create a new public/private key pair, size 2048 bits::
- $ openssl genpkey -algorithm RSA -out keys/dev.key \
+To create a certificate for this containing the public key::
- $ openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt
+If you like you can look at the public key also::
- $ openssl rsa -in keys/dev.key -pubout
+Device Tree Bindings +-------------------- +The following properties are required in the FIT's signature node(s) to +allow the signer to operate. These should be added to the .its file. +Signature nodes sit at the same level as hash nodes and are called +signature-1, signature-2, etc.
+algo
- Algorithm name (e.g. "sha1,rsa2048")
+key-name-hint
- Name of key to use for signing. The keys will normally be in
- a single directory (parameter -k to mkimage). For a given key <name>, its
- private key is stored in <name>.key and the certificate is stored in
- <name>.crt.
+When the image is signed, the following properties are added (mandatory):
+value
- The signature data (e.g. 256 bytes for 2048-bit RSA)
+When the image is signed, the following properties are optional:
+timestamp
- Time when image was signed (standard Unix time_t format)
+signer-name
- Name of the signer (e.g. "mkimage")
+signer-version
- Version string of the signer (e.g. "2013.01")
+comment
- Additional information about the signer or image
+padding
- The padding algorithm, it may be pkcs-1.5 or pss,
+For config bindings (see Signed Configurations below), the following +additional properties are optional:
+sign-images
- A list of images to sign, each being a property of the conf
- node that contains then. The default is "kernel,fdt" which means that these
- two images will be looked up in the config and signed if present.
+For config bindings, these properties are added by the signer:
+hashed-nodes
- A list of nodes which were hashed by the signer. Each is
- a string - the full path to node. A typical value might be::
"/images/kernel/hash-1", "/images/fdt-1",
"/images/fdt-1/hash-1";
+hashed-strings
- The start and size of the string region of the FIT that was hashed
+Example: See :doc:`sign-images` for an example image tree source file and +sign-configs.its for config signing.
+Public Key Storage +------------------ +In order to verify an image that has been signed with a public key we need to +have a trusted public key. This cannot be stored in the signed image, since +it would be easy to alter. For this implementation we choose to store the +public key in U-Boot's control FDT (using CONFIG_OF_CONTROL).
+Public keys should be stored as sub-nodes in a /signature node. Required +properties are:
+algo
- Algorithm name (e.g. "sha1,rsa2048" or "sha256,ecdsa256")
+Optional properties are:
+key-name-hint
- Name of key used for signing. This is only a hint since it
- is possible for the name to be changed. Verification can proceed by checking
- all available signing keys until one matches.
+required
- If present this indicates that the key must be verified for the
- image / configuration to be considered valid. Only required keys are
- normally verified by the FIT image booting algorithm. Valid values are
- "image" to force verification of all images, and "conf" to force verification
- of the selected configuration (which then relies on hashes in the images to
- verify those).
+Each signing algorithm has its own additional properties.
+For RSA the following are mandatory:
+rsa,num-bits
- Number of key bits (e.g. 2048)
+rsa,modulus
- Modulus (N) as a big-endian multi-word integer
+rsa,exponent
- Public exponent (E) as a 64 bit unsigned integer
+rsa,r-squared
- (2^num-bits)^2 as a big-endian multi-word integer
+rsa,n0-inverse
- -1 / modulus[0] mod 2^32
+For ECDSA the following are mandatory:
+ecdsa,curve
- Name of ECDSA curve (e.g. "prime256v1")
+ecdsa,x-point
- Public key X coordinate as a big-endian multi-word integer
+ecdsa,y-point
- Public key Y coordinate as a big-endian multi-word integer
+These parameters can be added to a binary device tree using parameter -K of the +mkimage command::
+Here is an example of a generated device tree node::
- signature {
key-dev {
required = "conf";
algo = "sha256,rsa2048";
rsa,r-squared = <0xb76d1acf 0xa1763ca5 0xeb2f126
0x742edc80 0xd3f42177 0x9741d9d9
0x35bb476e 0xff41c718 0xd3801430
0xf22537cb 0xa7e79960 0xae32a043
0x7da1427a 0x341d6492 0x3c2762f5
0xaac04726 0x5b262d96 0xf984e86d
0xb99443c7 0x17080c33 0x940f6892
0xd57a95d1 0x6ea7b691 0xc5038fa8
0x6bb48a6e 0x73f1b1ea 0x37160841
0xe05715ce 0xa7c45bbd 0x690d82d5
0x99c2454c 0x6ff117b3 0xd830683b
0x3f81c9cf 0x1ca38a91 0x0c3392e4
0xd817c625 0x7b8e9a24 0x175b89ea
0xad79f3dc 0x4d50d7b4 0x9d4e90f8
0xad9e2939 0xc165d6a4 0x0ada7e1b
0xfb1bf495 0xfc3131c2 0xb8c6e604
0xc2761124 0xf63de4a6 0x0e9565f9
0xc8e53761 0x7e7a37a5 0xe99dcdae
0x9aff7e1e 0xbd44b13d 0x6b0e6aa4
0x038907e4 0x8e0d6850 0xef51bc20
0xf73c94af 0x88bea7b1 0xcbbb1b30
0xd024b7f3>;
rsa,modulus = <0xc0711d6cb 0x9e86db7f 0x45986dbe
0x023f1e8c9 0xe1a4c4d0 0x8a0dfdc9
0x023ba0c48 0x06815f6a 0x5caa0654
0x07078c4b7 0x3d154853 0x40729023
0x0b007c8fe 0x5a3647e5 0x23b41e20
0x024720591 0x66915305 0x0e0b29b0
0x0de2ad30d 0x8589430f 0xb1590325
0x0fb9f5d5e 0x9eba752a 0xd88e6de9
0x056b3dcc6 0x9a6b8e61 0x6784f61f
0x000f39c21 0x5eec6b33 0xd78e4f78
0x0921a305f 0xaa2cc27e 0x1ca917af
0x06e1134f4 0xd48cac77 0x4e914d07
0x0f707aa5a 0x0d141f41 0x84677f1d
0x0ad47a049 0x028aedb6 0xd5536fcf
0x03fef1e4f 0x133a03d2 0xfd7a750a
0x0f9159732 0xd207812e 0x6a807375
0x06434230d 0xc8e22dad 0x9f29b3d6
0x07c44ac2b 0xfa2aad88 0xe2429504
0x041febd41 0x85d0d142 0x7b194d65
0x06e5d55ea 0x41116961 0xf3181dde
0x068bf5fbc 0x3dd82047 0x00ee647e
0x0d7a44ab3>;
rsa,exponent = <0x00 0x10001>;
rsa,n0-inverse = <0xb3928b85>;
rsa,num-bits = <0x800>;
+Signed Configurations +--------------------- +While signing images is useful, it does not provide complete protection +against several types of attack. For example, it is possible to create a +FIT with the same signed images, but with the configuration changed such +that a different one is selected (mix and match attack). It is also possible +to substitute a signed image from an older FIT version into a newer FIT +(roll-back attack).
+As an example, consider this FIT::
images {
kernel-1 {
data = <data for kernel1>
signature-1 {
algo = "sha1,rsa2048";
value = <...kernel signature 1...>
kernel-2 {
data = <data for kernel2>
signature-1 {
value = <...kernel signature 2...>
fdt-1 {
data = <data for fdt1>;
signature-1 {
value = <...fdt signature 1...>
fdt-2 {
data = <data for fdt2>;
signature-1 {
value = <...fdt signature 2...>
configurations {
default = "conf-1";
conf-1 {
kernel = "kernel-1";
fdt = "fdt-1";
conf-2 {
kernel = "kernel-2";
fdt = "fdt-2";
+Since both kernels are signed it is easy for an attacker to add a new +configuration 3 with kernel 1 and fdt 2::
- configurations {
default = "conf-1";
conf-1 {
fdt = "fdt-1";
conf-2 {
fdt = "fdt-2";
conf-3 {
fdt = "fdt-2";
+With signed images, nothing protects against this. Whether it gains an +advantage for the attacker is debatable, but it is not secure.
+To solve this problem, we support signed configurations. In this case it +is the configurations that are signed, not the image. Each image has its +own hash, and we include the hash in the configuration signature.
+So the above example is adjusted to look like this::
images {
kernel-1 {
hash-1 {
algo = "sha1";
value = <...kernel hash 1...>
kernel-2 {
hash-1 {
algo = "sha1";
value = <...kernel hash 2...>
fdt-1 {
hash-1 {
algo = "sha1";
value = <...fdt hash 1...>
fdt-2 {
hash-1 {
algo = "sha1";
value = <...fdt hash 2...>
configurations {
default = "conf-1";
conf-1 {
fdt = "fdt-1";
signature-1 {
value = <...conf 1 signature...>;
conf-2 {
fdt = "fdt-2";
signature-1 {
+You can see that we have added hashes for all images (since they are no +longer signed), and a signature to each configuration. In the above example, +mkimage will sign configurations/conf-1, the kernel and fdt that are +pointed to by the configuration (/images/kernel-1, /images/kernel-1/hash-1, +/images/fdt-1, /images/fdt-1/hash-1) and the root structure of the image +(so that it isn't possible to add or remove root nodes). The signature is +written into /configurations/conf-1/signature-1/value. It can easily be +verified later even if the FIT has been signed with other keys in the +meantime.
+Details +------- +The signature node contains a property ('hashed-nodes') which lists all the +nodes that the signature was made over. The image is walked in order and each +tag processed as follows:
+DTB_BEGIN_NODE
- The tag and the following name are included in the signature
+DTB_END_NODE
- The tag is included in the signature if the node or its parent
+DTB_PROPERTY
- The tag, the length word, the offset in the string table, and
+DTB_END
- The tag is always included in the signature.
+DTB_NOP
- The tag is included in the signature if the current node is present
- in 'hashed-nodes'
+In addition, the signature contains a property 'hashed-strings' which contains +the offset and length in the string table of the strings that are to be +included in the signature (this is done last).
+IMPORTANT: To verify the signature outside u-boot, it is vital to not only +calculate the hash of the image and verify the signature with that, but also to +calculate the hashes of the kernel, fdt, and ramdisk images and check those +match the hash values in the corresponding 'hash*' subnodes.
+Verification +------------ +FITs are verified when loaded. After the configuration is selected a list +of required images is produced. If there are 'required' public keys, then +each image must be verified against those keys. This means that every image +that might be used by the target needs to be signed with 'required' keys.
+This happens automatically as part of a bootm command when FITs are used.
+For Signed Configurations, the default verification behavior can be changed by +the following optional property in /signature node in U-Boot's control FDT.
+required-mode
- Valid values are "any" to allow verified boot to succeed if
- the selected configuration is signed by any of the 'required' keys, and "all"
- to allow verified boot to succeed if the selected configuration is signed by
- all of the 'required' keys.
+This property can be added to a binary device tree using fdtput as shown in +below examples::
+Enabling FIT Verification +------------------------- +In addition to the options to enable FIT itself, the following CONFIGs must +be enabled:
+CONFIG_FIT_SIGNATURE
+CONFIG_RSA
+CONFIG_ECDSA
+WARNING: When relying on signed FIT images with required signature check +the legacy image format is default disabled by not defining +CONFIG_LEGACY_IMAGE_FORMAT
+Testing +-------
+An easy way to test signing and verification is to use the test script +provided in test/vboot/vboot_test.sh. This uses sandbox (a special version +of U-Boot which runs under Linux) to show the operation of a 'bootm' +command loading and verifying images.
+A sample run is show below::
- $ make O=sandbox sandbox_config
- $ make O=sandbox
- $ O=sandbox ./test/vboot/vboot_test.sh
+Simple Verified Boot Test +-------------------------
+Please see :doc:`verified-boot` for more information::
- /home/hs/ids/u-boot/sandbox/tools/mkimage -D -I dts -O dtb -p 2000
- Build keys
- do sha1 test
- Build FIT with signed images
- Test Verified Boot Run: unsigned signatures:: OK
- Sign images
- Test Verified Boot Run: signed images: OK
- Build FIT with signed configuration
- Test Verified Boot Run: unsigned config: OK
- Sign images
- Test Verified Boot Run: signed config: OK
- check signed config on the host
- OK
- Test Verified Boot Run: signed config with bad hash: OK
- do sha256 test
- Sign images
- Sign images
- OK
- Test passed
+Software signing: keydir vs keyfile +-----------------------------------
+In the simplest case, signing is done by giving mkimage the 'keyfile'. This is +the path to a file containing the signing key.
+The alternative is to pass the 'keydir' argument. In this case the filename of +the key is derived from the 'keydir' and the "key-name-hint" property in the +FIT. In this case the "key-name-hint" property is mandatory, and the key must +exist in "<keydir>/<key-name-hint>.<ext>" Here the extension "ext" is +specific to the signing algorithm.
+Hardware Signing with PKCS#11 or with HSM +-----------------------------------------
+Securely managing private signing keys can challenging, especially when the +keys are stored on the file system of a computer that is connected to the +Internet. If an attacker is able to steal the key, they can sign malicious FIT +images which will appear genuine to your devices.
+An alternative solution is to keep your signing key securely stored on hardware +device like a smartcard, USB token or Hardware Security Module (HSM) and have +them perform the signing. PKCS#11 is standard for interfacing with these crypto +device.
+Requirements:
- Smartcard/USB token/HSM which can work with some openssl engine
- openssl
+For pkcs11 engine usage:
- libp11 (provides pkcs11 engine)
- p11-kit (recommended to simplify setup)
- opensc (for smartcards and smartcard like USB devices)
- gnutls (recommended for key generation, p11tool)
+For generic HSMs respective openssl engine must be installed and locateable by +openssl. This may require setting up LD_LIBRARY_PATH if engine is not installed +to openssl's default search paths.
+PKCS11 engine support forms "key id" based on "keydir" and with +"key-name-hint". "key-name-hint" is used as "object" name (if not defined in +keydir). "keydir" (if defined) is used to define (prefix for) which PKCS11 source +is being used for lookup up for the key.
+PKCS11 engine key ids
+or, if keydir contains "object="
+or
+Generic HSM engine support forms "key id" based on "keydir" and with +"key-name-hint". If "keydir" is specified for mkimage it is used as a prefix in +"key id" and is appended with "key-name-hint".
+Generic engine key ids:
+or
- "< key-name-hint>"
+In order to set the pin in the HSM, an environment variable "MKIMAGE_SIGN_PIN" +can be specified.
+The following examples use the Nitrokey Pro using pkcs11 engine. Instructions +for other devices may vary.
+Notes on pkcs11 engine setup:
+Make sure p11-kit, opensc are installed and that p11-kit is setup to use opensc. +/usr/share/p11-kit/modules/opensc.module should be present on your system.
+Generating Keys On the Nitrokey::
- $ gpg --card-edit
- Reader ...........: Nitrokey Nitrokey Pro (xxxxxxxx0000000000000000) 00 00
- Application ID ...: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
- Version ..........: 2.1
- Manufacturer .....: ZeitControl
- Serial number ....: xxxxxxxx
- Name of cardholder: [not set]
- Language prefs ...: de
- Sex ..............: unspecified
- URL of public key : [not set]
- Login data .......: [not set]
- Signature PIN ....: forced
- Key attributes ...: rsa2048 rsa2048 rsa2048
- Max. PIN lengths .: 32 32 32
- PIN retry counter : 3 0 3
- Signature counter : 0
- Signature key ....: [none]
- Encryption key....: [none]
- Authentication key: [none]
- General key info..: [none]
- gpg/card> generate
- Make off-card backup of encryption key? (Y/n) n
- Please note that the factory settings of the PINs are
- You should change them using the command --change-pin
- What keysize do you want for the Signature key? (2048) 4096
- The card will now be re-configured to generate a key of 4096 bits
- Note: There is no guarantee that the card supports the requested size.
- What keysize do you want for the Encryption key? (2048) 4096
- What keysize do you want for the Authentication key? (2048) 4096
- Please specify how long the key should be valid.
- Key is valid for? (0)
- Key does not expire at all
- Is this correct? (y/N) y
- GnuPG needs to construct a user ID to identify your key.
- Real name: John Doe
- Email address: john.doe@email.com
- Comment:
- You selected this USER-ID:
- Change (N)ame, (C)omment, (E)mail or (O)kay/(Q)uit? o
+Using p11tool to get the token URL:
+Depending on system configuration, gpg-agent may need to be killed first::
- $ p11tool --provider /usr/lib/opensc-pkcs11.so --list-tokens
- Token 0:
- URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29
- Label: OpenPGP card (User PIN (sig))
- Type: Hardware token
- Manufacturer: ZeitControl
- Model: PKCS#15 emulated
- Serial: 000xxxxxxxxx
- Module: (null)
- Token 1:
- URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%29
- Label: OpenPGP card (User PIN)
- Module: (null)
+Use the portion of the signature token URL after "pkcs11:" as the keydir argument (-k) to mkimage below.
+Use the URL of the token to list the private keys::
- $ p11tool --login --provider /usr/lib/opensc-pkcs11.so --list-privkeys \
- "pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29"
- Token 'OpenPGP card (User PIN (sig))' with URL 'pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29' requires user PIN
- Enter PIN:
- Object 0:
- URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29;id=%01;object=Signature%20key;type=private
- Type: Private key
- Label: Signature key
- Flags: CKA_PRIVATE; CKA_NEVER_EXTRACTABLE; CKA_SENSITIVE;
- ID: 01
+Use the label, in this case "Signature key" as the key-name-hint in your FIT.
+Create the fitImage::
- $ ./tools/mkimage -f fit-image.its fitImage
+Sign the fitImage with the hardware key::
- $ ./tools/mkimage -F -k \
- "model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29" \
- -K u-boot.dtb -N pkcs11 -r fitImage
+Future Work +-----------
+- Roll-back protection using a TPM is done using the tpm command. This can
- be scripted, but we might consider a default way of doing this, built into
- bootm.
+Possible Future Work +--------------------
+- More sandbox tests for failure modes +- Passwords for keys/certificates +- Perhaps implement OAEP +- Enhance bootm to permit scripted signature verification (so that a script
- can verify an image but not actually boot it)
+.. sectionauthor:: Simon Glass sjg@chromium.org, 1-1-13 diff --git a/doc/uImage.FIT/verified-boot.txt b/doc/usage/fit/verified-boot.rst similarity index 54% rename from doc/uImage.FIT/verified-boot.txt rename to doc/usage/fit/verified-boot.rst index 41c9fa9e09f9..bef52ba36ffc 100644 --- a/doc/uImage.FIT/verified-boot.txt +++ b/doc/usage/fit/verified-boot.rst @@ -1,8 +1,11 @@ +.. SPDX-License-Identifier: GPL-2.0+
U-Boot Verified Boot
Introduction
Verified boot here means the verification of all software loaded into a machine during the boot process to ensure that it is authorised and correct for that machine.
@@ -21,6 +24,7 @@ memory, so that firmware can easily be upgraded in a secure manner.
Signing
- Verified boot uses cryptographic algorithms to 'sign' software images. Images are signed using a private key known only to the signer, but can be verified using a public key. As its name suggests the public key can be
@@ -28,31 +32,31 @@ made available without risk to the verification process. The private and public keys are mathematically related. For more information on how this works look up "public key cryptography" and "RSA" (a particular algorithm).
-The signing and verification process looks something like this:
Signing Verification
- | RSA key pair | * +---------------+
- | .key .crt | * | Public key in |
- +--------------+ +------> public key ----->| trusted place |
v | * v
- | signer | * | U-Boot |
- | |----------+ * | signature |--> yes/no
- +---------+ | * | verification |
- | Software | +----> signed image -------------+
- | image | *
+The signing and verification process looks something like this::
v | * v
Please, correct the layout.
Best regards
Heinrich
| image | *
The signature algorithm relies only on the public key to do its work. Using
@@ -70,23 +74,25 @@ the verification is worthless.
Chaining Images
- The above method works for a signer providing images to a run-time U-Boot. It is also possible to extend this scheme to a second level, like this:
-1. Master private key is used by the signer to sign a first-stage image. -2. Master public key is placed in read-only memory. -2. Secondary private key is created and used to sign second-stage images. -3. Secondary public key is placed in first stage images -4. We use the master public key to verify the first-stage image. We then -use the secondary public key in the first-stage image to verify the second- -state image. -5. This chaining process can go on indefinitely. It is recommended to use a -different key at each stage, so that a compromise in one place will not -affect the whole change. +#. Master private key is used by the signer to sign a first-stage image. +#. Master public key is placed in read-only memory. +#. Secondary private key is created and used to sign second-stage images. +#. Secondary public key is placed in first stage images +#. We use the master public key to verify the first-stage image. We then
- use the secondary public key in the first-stage image to verify the second-
- state image.
+#. This chaining process can go on indefinitely. It is recommended to use a
Flattened Image Tree (FIT)
The FIT format is already widely used in U-Boot. It is a flattened device tree (FDT) in a particular format, with images contained within. FITs include hashes to verify images, so it is relatively straightforward to
@@ -96,9 +102,6 @@ The public key can be stored in U-Boot's CONFIG_OF_CONTROL device tree in a standard place. Then when a FIT is loaded it can be verified using that public key. Multiple keys and multiple signatures are supported.
-See signature.txt for more information.
+See :doc:`signature` for more information.
-Simon Glass -sjg@chromium.org -1-1-13 +.. sectionauthor:: Simon Glass sjg@chromium.org 1-1-13
On 6/22/23 22:21, Simon Glass wrote:
Bring these files into the documentation.
Fix 'wtih' and 'it' typos and repeated 'could' while we are here.
Signed-off-by: Simon Glass sjg@chromium.org
doc/uImage.FIT/beaglebone_vboot.txt | 607 -------------- doc/uImage.FIT/signature.txt | 707 ---------------- doc/usage/cmd/source.rst | 2 +- doc/usage/fit/beaglebone_vboot.rst | 607 ++++++++++++++ doc/usage/fit/index.rst | 3 + doc/usage/fit/signature.rst | 760 ++++++++++++++++++ .../fit/verified-boot.rst} | 83 +- 7 files changed, 1414 insertions(+), 1355 deletions(-) delete mode 100644 doc/uImage.FIT/beaglebone_vboot.txt delete mode 100644 doc/uImage.FIT/signature.txt create mode 100644 doc/usage/fit/beaglebone_vboot.rst create mode 100644 doc/usage/fit/signature.rst rename doc/{uImage.FIT/verified-boot.txt => usage/fit/verified-boot.rst} (54%)
diff --git a/doc/uImage.FIT/beaglebone_vboot.txt b/doc/uImage.FIT/beaglebone_vboot.txt deleted file mode 100644 index ebd2068ed38d..000000000000 --- a/doc/uImage.FIT/beaglebone_vboot.txt +++ /dev/null @@ -1,607 +0,0 @@
-Verified Boot on the Beaglebone Black
-Introduction
-Before reading this, please read verified-boot.txt and signature.txt. These -instructions are for mainline U-Boot from v2014.07 onwards.
-There is quite a bit of documentation in this directory describing how -verified boot works in U-Boot. There is also a test which runs through the -entire process of signing an image and running U-Boot (sandbox) to check it. -However, it might be useful to also have an example on a real board.
-Beaglebone Black is a fairly common board so seems to be a reasonable choice -for an example of how to enable verified boot using U-Boot.
-First a note that may to help avoid confusion. U-Boot and Linux both use -device tree. They may use the same device tree source, but it is seldom useful -for them to use the exact same binary from the same place. More typically, -U-Boot has its device tree packaged wtih it, and the kernel's device tree is -packaged with the kernel. In particular this is important with verified boot, -since U-Boot's device tree must be immutable. If it can be changed then the -public keys can be changed and verified boot is useless. An attacker can -simply generate a new key and put his public key into U-Boot so that -everything verifies. On the other hand the kernel's device tree typically -changes when the kernel changes, so it is useful to package an updated device -tree with the kernel binary. U-Boot supports the latter with its flexible FIT -format (Flat Image Tree).
-Overview
-The steps are roughly as follows:
-1. Build U-Boot for the board, with the verified boot options enabled.
-2. Obtain a suitable Linux kernel
-3. Create a Image Tree Source file (ITS) file describing how you want the -kernel to be packaged, compressed and signed.
-4. Create a key pair
-5. Sign the kernel
-6. Put the public key into U-Boot's image
-7. Put U-Boot and the kernel onto the board
-8. Try it
-Step 1: Build U-Boot
-a. Set up the environment variable to point to your toolchain. You will need -this for U-Boot and also for the kernel if you build it. For example if you -installed a Linaro version manually it might be something like:
- export CROSS_COMPILE=/opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.08_linux/bin/arm-linux-gnueabihf-
-or if you just installed gcc-arm-linux-gnueabi then it might be
- export CROSS_COMPILE=arm-linux-gnueabi-
-b. Configure and build U-Boot with verified boot enabled:
- export UBOOT=/path/to/u-boot
- cd $UBOOT
- # You can add -j10 if you have 10 CPUs to make it faster
- make O=b/am335x_boneblack_vboot am335x_boneblack_vboot_config all
- export UOUT=$UBOOT/b/am335x_boneblack_vboot
-c. You will now have a U-Boot image:
- file b/am335x_boneblack_vboot/u-boot-dtb.img
-b/am335x_boneblack_vboot/u-boot-dtb.img: u-boot legacy uImage, U-Boot 2014.07-rc2-00065-g2f69f8, Firmware/ARM, Firmware Image (Not compressed), 395375 bytes, Sat May 31 16:19:04 2014, Load Address: 0x80800000, Entry Point: 0x00000000, Header CRC: 0x0ABD6ACA, Data CRC: 0x36DEF7E4
-Step 2: Build Linux
-a. Find the kernel image ('Image') and device tree (.dtb) file you plan to -use. In our case it is am335x-boneblack.dtb and it is built with the kernel. -At the time of writing an SD Boot image can be obtained from here:
-You can write this to an SD card and then mount it to extract the kernel and -device tree files.
-You can also build a kernel. Instructions for this are are here:
-or you can use your favourite search engine. Following these instructions -produces a kernel Image and device tree files. For the record the steps were:
- export KERNEL=/path/to/kernel
- cd $KERNEL
- git clone git://github.com/beagleboard/kernel.git .
- git checkout v3.14
- ./patch.sh
- cp configs/beaglebone kernel/arch/arm/configs/beaglebone_defconfig
- cd kernel
- make beaglebone_defconfig
- make uImage dtbs # -j10 if you have 10 CPUs
- export OKERNEL=$KERNEL/kernel/arch/arm/boot
-c. You now have the 'Image' and 'am335x-boneblack.dtb' files needed to boot.
-Step 3: Create the ITS
-Set up a directory for your work.
- export WORK=/path/to/dir
- cd $WORK
-Put this into a file in that directory called sign.its:
-/dts-v1/;
- description = "Beaglebone black";
- #address-cells = <1>;
- images {
kernel {
type = "kernel";
arch = "arm";
os = "linux";
hash-1 {
algo = "sha1";
fdt-1 {
type = "flat_dt";
arch = "arm";
hash-1 {
algo = "sha1";
- configurations {
default = "conf-1";
conf-1 {
kernel = "kernel";
fdt = "fdt-1";
signature-1 {
-The explanation for this is all in the documentation you have already read. -But briefly it packages a kernel and device tree, and provides a single -configuration to be signed with a key named 'dev'. The kernel is compressed -with LZO to make it smaller.
-Step 4: Create a key pair
-See signature.txt for details on this step.
- cd $WORK
- mkdir keys
- openssl genrsa -F4 -out keys/dev.key 2048
- openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt
-Note: keys/dev.key contains your private key and is very secret. If anyone -gets access to that file they can sign kernels with it. Keep it secure.
-Step 5: Sign the kernel
-We need to use mkimage (which was built when you built U-Boot) to package the -Linux kernel into a FIT (Flat Image Tree, a flexible file format that U-Boot -can load) using the ITS file you just created.
-At the same time we must put the public key into U-Boot device tree, with the -'required' property, which tells U-Boot that this key must be verified for the -image to be valid. You will make this key available to U-Boot for booting in -step 6.
- ln -s $OKERNEL/dts/am335x-boneblack.dtb
- ln -s $OKERNEL/Image
- ln -s $UOUT/u-boot-dtb.img
- cp $UOUT/arch/arm/dts/am335x-boneblack.dtb am335x-boneblack-pubkey.dtb
- lzop Image
- $UOUT/tools/mkimage -f sign.its -K am335x-boneblack-pubkey.dtb -k keys -r image.fit
-You should see something like this:
-FIT description: Beaglebone black -Created: Sun Jun 1 12:50:30 2014
- Image 0 (kernel)
- Description: unavailable
- Created: Sun Jun 1 12:50:30 2014
- Type: Kernel Image
- Compression: lzo compressed
- Data Size: 7790938 Bytes = 7608.34 kB = 7.43 MB
- Architecture: ARM
- OS: Linux
- Load Address: 0x80008000
- Entry Point: 0x80008000
- Hash algo: sha1
- Hash value: c94364646427e10f423837e559898ef02c97b988
- Image 1 (fdt-1)
- Description: beaglebone-black
- Type: Flat Device Tree
- Compression: uncompressed
- Data Size: 31547 Bytes = 30.81 kB = 0.03 MB
- Architecture: ARM
- Hash algo: sha1
- Hash value: cb09202f889d824f23b8e4404b781be5ad38a68d
- Default Configuration: 'conf-1'
- Configuration 0 (conf-1)
- Kernel: kernel
- FDT: fdt-1
-Now am335x-boneblack-pubkey.dtb contains the public key and image.fit contains -the signed kernel. Jump to step 6 if you like, or continue reading to increase -your understanding.
-You can also run fit_check_sign to check it:
- $UOUT/tools/fit_check_sign -f image.fit -k am335x-boneblack-pubkey.dtb
-which results in:
-Verifying Hash Integrity ... sha1,rsa2048:dev+ -## Loading kernel from FIT Image at 7fc6ee469000 ...
- Using 'conf-1' configuration
-sha1,rsa2048:dev+ -OK
- Trying 'kernel' kernel subimage
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha1
-sha1+ -OK
-Unimplemented compression type 4 -## Loading fdt from FIT Image at 7fc6ee469000 ...
- Trying 'fdt-1' fdt subimage
Architecture: ARM
Hash algo: sha1
-sha1+ -OK
- Loading Flat Device Tree ... OK
-## Loading ramdisk from FIT Image at 7fc6ee469000 ...
-Could not find subimage node
-Signature check OK
-At the top, you see "sha1,rsa2048:dev+". This means that it checked an RSA key -of size 2048 bits using SHA1 as the hash algorithm. The key name checked was -'dev' and the '+' means that it verified. If it showed '-' that would be bad.
-Once the configuration is verified it is then possible to rely on the hashes -in each image referenced by that configuration. So fit_check_sign goes on to -load each of the images. We have a kernel and an FDT but no ramkdisk. In each -case fit_check_sign checks the hash and prints sha1+ meaning that the SHA1 -hash verified. This means that none of the images has been tampered with.
-There is a test in test/vboot which uses U-Boot's sandbox build to verify that -the above flow works.
-But it is fun to do this by hand, so you can load image.fit into a hex editor -like ghex, and change a byte in the kernel:
- $UOUT/tools/fit_info -f image.fit -n /images/kernel -p data
-NAME: kernel -LEN: 7790938 -OFF: 168
-This tells us that the kernel starts at byte offset 168 (decimal) in image.fit -and extends for about 7MB. Try changing a byte at 0x2000 (say) and run -fit_check_sign again. You should see something like:
-Verifying Hash Integrity ... sha1,rsa2048:dev+ -## Loading kernel from FIT Image at 7f5a39571000 ...
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha1
-sha1 error -Bad hash value for 'hash-1' hash node in 'kernel' image node -Bad Data Hash
-## Loading fdt from FIT Image at 7f5a39571000 ...
Architecture: ARM
Hash algo: sha1
-sha1+ -OK
-## Loading ramdisk from FIT Image at 7f5a39571000 ...
-Signature check Bad (error 1)
-It has detected the change in the kernel.
-You can also be sneaky and try to switch images, using the libfdt utilities -that come with dtc (package name is device-tree-compiler but you will need a -recent version like 1.4:
- dtc -v
-Version: DTC 1.4.0
-First we can check which nodes are actually hashed by the configuration:
-images -configurations
-conf-1 -fdtget -l image.fit /configurations/conf-1 -signature-1
- fdtget -p image.fit /configurations/conf-1/signature-1
-hashed-strings -hashed-nodes -timestamp -signer-version -signer-name -value -algo -key-name-hint -sign-images
- fdtget image.fit /configurations/conf-1/signature-1 hashed-nodes
-/ /configurations/conf-1 /images/fdt-1 /images/fdt-1/hash /images/kernel /images/kernel/hash-1
-This gives us a bit of a look into the signature that mkimage added. Note you -can also use fdtdump to list the entire device tree.
-Say we want to change the kernel that this configuration uses -(/images/kernel). We could just put a new kernel in the image, but we will -need to change the hash to match. Let's simulate that by changing a byte of -the hash:
- fdtget -tx image.fit /images/kernel/hash-1 value
-c9436464 6427e10f 423837e5 59898ef0 2c97b988
- fdtput -tx image.fit /images/kernel/hash-1 value c9436464 6427e10f 423837e5 59898ef0 2c97b981
-Now check it again:
-Verifying Hash Integrity ... sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13
-rsa_verify_with_keynode: RSA failed to verify: -13
-Failed to verify required signature 'key-dev' -Signature check Bad (error 1)
-This time we don't even get as far as checking the images, since the -configuration signature doesn't match. We can't change any hashes without the -signature check noticing. The configuration is essentially locked. U-Boot has -a public key for which it requires a match, and will not permit the use of any -configuration that does not match that public key. The only way the -configuration will match is if it was signed by the matching private key.
-It would also be possible to add a new signature node that does match your new -configuration. But that won't work since you are not allowed to change the -configuration in any way. Try it with a fresh (valid) image if you like by -running the mkimage link again. Then:
- fdtput -p image.fit /configurations/conf-1/signature-1 value fred
-Verifying Hash Integrity ... - -sha1,rsa2048:devrsa_verify_with_keynode: RSA failed to verify: -13
-Of course it would be possible to add an entirely new configuration and boot -with that, but it still needs to be signed, so it won't help.
-Having confirmed that the signature is doing its job, let's try it out in -U-Boot on the board. U-Boot needs access to the public key corresponding to -the private key that you signed with so that it can verify any kernels that -you sign.
- cd $UBOOT
- make O=b/am335x_boneblack_vboot EXT_DTB=${WORK}/am335x-boneblack-pubkey.dtb
-Here we are overriding the normal device tree file with our one, which -contains the public key.
-Now you have a special U-Boot image with the public key. It can verify can -kernel that you sign with the private key as in step 5.
-If you like you can take a look at the public key information that mkimage -added to U-Boot's device tree:
- fdtget -p am335x-boneblack-pubkey.dtb /signature/key-dev
-required -algo -rsa,r-squared -rsa,modulus -rsa,n0-inverse -rsa,num-bits -key-name-hint
-This has information about the key and some pre-processed values which U-Boot -can use to verify against it. These values are obtained from the public key -certificate by mkimage, but require quite a bit of code to generate. To save -code space in U-Boot, the information is extracted and written in raw form for -U-Boot to easily use. The same mechanism is used in Google's Chrome OS.
-Notice the 'required' property. This marks the key as required - U-Boot will -not boot any image that does not verify against this key.
-The method here varies depending on how you are booting. For this example we -are booting from an micro-SD card with two partitions, one for U-Boot and one -for Linux. Put it into your machine and write U-Boot and the kernel to it. -Here the card is /dev/sde:
- cd $WORK
- export UDEV=/dev/sde1 # Change thes two lines to the correct device
- export KDEV=/dev/sde2
- sudo mount $UDEV /mnt/tmp && sudo cp $UOUT/u-boot-dtb.img /mnt/tmp/u-boot.img && sleep 1 && sudo umount $UDEV
- sudo mount $KDEV /mnt/tmp && sudo cp $WORK/image.fit /mnt/tmp/boot/image.fit && sleep 1 && sudo umount $KDEV
-8. Try it
-Boot the board using the commands below:
- setenv bootargs console=ttyO0,115200n8 quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
- ext2load mmc 0:2 82000000 /boot/image.fit
- bootm 82000000
-You should then see something like this:
-U-Boot# setenv bootargs console=ttyO0,115200n8 quiet root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait -U-Boot# ext2load mmc 0:2 82000000 /boot/image.fit -7824930 bytes read in 589 ms (12.7 MiB/s) -U-Boot# bootm 82000000 -## Loading kernel from FIT Image at 82000000 ...
- Verifying Hash Integrity ... sha1,rsa2048:dev+ OK
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: sha1
- Verifying Hash Integrity ... sha1+ OK
-## Loading fdt from FIT Image at 82000000 ...
Architecture: ARM
Hash algo: sha1
- Booting using the fdt blob at 0x8276e2ec
- Uncompressing Kernel Image ... OK
- Loading Device Tree to 8fff5000, end 8ffffb3a ... OK
-Starting kernel ...
-[ 0.582377] omap_init_mbox: hwmod doesn't have valid attrs -[ 2.589651] musb-hdrc musb-hdrc.0.auto: Failed to request rx1. -[ 2.595830] musb-hdrc musb-hdrc.0.auto: musb_init_controller failed with status -517 -[ 2.606470] musb-hdrc musb-hdrc.1.auto: Failed to request rx1. -[ 2.612723] musb-hdrc musb-hdrc.1.auto: musb_init_controller failed with status -517 -[ 2.940808] drivers/rtc/hctosys.c: unable to open rtc device (rtc0) -[ 7.248889] libphy: PHY 4a101000.mdio:01 not found -[ 7.253995] net eth0: phy 4a101000.mdio:01 not found on slave 1 -systemd-fsck[83]: Angstrom: clean, 50607/218160 files, 306348/872448 blocks
-.---O---. -| | .-. o o -| | |-----.-----.-----.| | .----..-----.-----. -| | | __ | ---'| '--.| .-'| | | -| | | | | |--- || --'| | | ' | | | | -'---'---'--'--'--. |-----''----''--' '-----'-'-'-'
-The Angstrom Distribution beaglebone ttyO0
-Angstrom v2012.12 - Kernel 3.14.1+
-beaglebone login:
-At this point your kernel has been verified and you can be sure that it is one -that you signed. As an exercise, try changing image.fit as in step 5 and see -what happens.
-Further Improvements
-Several of the steps here can be easily automated. In particular it would be -capital if signing and packaging a kernel were easy, perhaps a simple make -target in the kernel.
-Some mention of how to use multiple .dtb files in a FIT might be useful.
-U-Boot's verified boot mechanism has not had a robust and independent security -review. Such a review should look at the implementation and its resistance to -attacks.
-Perhaps the verified boot feature could could be integrated into the Amstrom -distribution.
-Simon Glass -sjg@chromium.org -2-June-14 diff --git a/doc/uImage.FIT/signature.txt b/doc/uImage.FIT/signature.txt deleted file mode 100644 index 21eb3894aada..000000000000 --- a/doc/uImage.FIT/signature.txt +++ /dev/null @@ -1,707 +0,0 @@
-U-Boot FIT Signature Verification
-Introduction
-FIT supports hashing of images so that these hashes can be checked on -loading. This protects against corruption of the image. However it does not -prevent the substitution of one image for another.
-The signature feature allows the hash to be signed with a private key such -that it can be verified using a public key later. Provided that the private -key is kept secret and the public key is stored in a non-volatile place, -any image can be verified in this way.
-See verified-boot.txt for more general information on verified boot.
-Concepts
-Some familiarity with public key cryptography is assumed in this section.
-The procedure for signing is as follows:
-The procedure for verification is:
- read the FIT
hash
-The signing is generally performed by mkimage, as part of making a firmware -image for the device. The verification is normally done in U-Boot on the -device.
-Algorithms
-In principle any suitable algorithm can be used to sign and verify a hash. -U-Boot supports a few hashing and verification algorithms. See below for -details.
-While it is acceptable to bring in large cryptographic libraries such as -openssl on the host side (e.g. mkimage), it is not desirable for U-Boot. -For the run-time verification side, it is important to keep code and data -size as small as possible.
-For this reason the RSA image verification uses pre-processed public keys -which can be used with a very small amount of code - just some extraction -of data from the FDT and exponentiation mod n. Code size impact is a little -under 5KB on Tegra Seaboard, for example.
-It is relatively straightforward to add new algorithms if required. If -another RSA variant is needed, then it can be added with the -U_BOOT_CRYPTO_ALGO() macro. If another algorithm is needed (such as DSA) then -it can be placed in a directory alongside lib/rsa/, and its functions added -using U_BOOT_CRYPTO_ALGO().
-Creating an RSA key pair and certificate
-To create a new public/private key pair, size 2048 bits:
-$ openssl genpkey -algorithm RSA -out keys/dev.key \
- -pkeyopt rsa_keygen_bits:2048 -pkeyopt rsa_keygen_pubexp:65537
-To create a certificate for this containing the public key:
-$ openssl req -batch -new -x509 -key keys/dev.key -out keys/dev.crt
-If you like you can look at the public key also:
-$ openssl rsa -in keys/dev.key -pubout
-Device Tree Bindings
-The following properties are required in the FIT's signature node(s) to -allow the signer to operate. These should be added to the .its file. -Signature nodes sit at the same level as hash nodes and are called -signature-1, signature-2, etc.
-- algo: Algorithm name (e.g. "sha1,rsa2048")
-- key-name-hint: Name of key to use for signing. The keys will normally be in -a single directory (parameter -k to mkimage). For a given key <name>, its -private key is stored in <name>.key and the certificate is stored in -<name>.crt.
-When the image is signed, the following properties are added (mandatory):
-- value: The signature data (e.g. 256 bytes for 2048-bit RSA)
-When the image is signed, the following properties are optional:
-- timestamp: Time when image was signed (standard Unix time_t format)
-- signer-name: Name of the signer (e.g. "mkimage")
-- signer-version: Version string of the signer (e.g. "2013.01")
-- comment: Additional information about the signer or image
-- padding: The padding algorithm, it may be pkcs-1.5 or pss,
- if no value is provided we assume pkcs-1.5
-For config bindings (see Signed Configurations below), the following -additional properties are optional:
-- sign-images: A list of images to sign, each being a property of the conf -node that contains then. The default is "kernel,fdt" which means that these -two images will be looked up in the config and signed if present.
-For config bindings, these properties are added by the signer:
-- hashed-nodes: A list of nodes which were hashed by the signer. Each is
- hashed-nodes = "/", "/configurations/conf-1", "/images/kernel",
-- hashed-strings: The start and size of the string region of the FIT that
- was hashed
-Example: See sign-images.its for an example image tree source file and -sign-configs.its for config signing.
-Public Key Storage
-In order to verify an image that has been signed with a public key we need to -have a trusted public key. This cannot be stored in the signed image, since -it would be easy to alter. For this implementation we choose to store the -public key in U-Boot's control FDT (using CONFIG_OF_CONTROL).
-Public keys should be stored as sub-nodes in a /signature node. Required -properties are:
-- algo: Algorithm name (e.g. "sha1,rsa2048" or "sha256,ecdsa256")
-Optional properties are:
-- key-name-hint: Name of key used for signing. This is only a hint since it -is possible for the name to be changed. Verification can proceed by checking -all available signing keys until one matches.
-- required: If present this indicates that the key must be verified for the -image / configuration to be considered valid. Only required keys are -normally verified by the FIT image booting algorithm. Valid values are -"image" to force verification of all images, and "conf" to force verification -of the selected configuration (which then relies on hashes in the images to -verify those).
-Each signing algorithm has its own additional properties.
-For RSA the following are mandatory:
-- rsa,num-bits: Number of key bits (e.g. 2048) -- rsa,modulus: Modulus (N) as a big-endian multi-word integer -- rsa,exponent: Public exponent (E) as a 64 bit unsigned integer -- rsa,r-squared: (2^num-bits)^2 as a big-endian multi-word integer -- rsa,n0-inverse: -1 / modulus[0] mod 2^32
-For ECDSA the following are mandatory: -- ecdsa,curve: Name of ECDSA curve (e.g. "prime256v1") -- ecdsa,x-point: Public key X coordinate as a big-endian multi-word integer -- ecdsa,y-point: Public key Y coordinate as a big-endian multi-word integer
-These parameters can be added to a binary device tree using parameter -K of the -mkimage command::
- tools/mkimage -f fit.its -K control.dtb -k keys -r image.fit
-Here is an example of a generated device tree node::
- signature {
key-dev {
required = "conf";
0xd024b7f3>;
0x0d7a44ab3>;
-Signed Configurations
-While signing images is useful, it does not provide complete protection -against several types of attack. For example, it it possible to create a -FIT with the same signed images, but with the configuration changed such -that a different one is selected (mix and match attack). It is also possible -to substitute a signed image from an older FIT version into a newer FIT -(roll-back attack).
-As an example, consider this FIT:
- images {
kernel-1 {
signature-1 {
kernel-2 {
signature-1 {
fdt-1 {
signature-1 {
fdt-2 {
signature-1 {
- configurations {
default = "conf-1";
conf-1 {
fdt = "fdt-1";
conf-2 {
fdt = "fdt-2";
-Since both kernels are signed it is easy for an attacker to add a new -configuration 3 with kernel 1 and fdt 2:
- configurations {
default = "conf-1";
conf-1 {
fdt = "fdt-1";
conf-2 {
fdt = "fdt-2";
conf-3 {
fdt = "fdt-2";
-With signed images, nothing protects against this. Whether it gains an -advantage for the attacker is debatable, but it is not secure.
-To solve this problem, we support signed configurations. In this case it -is the configurations that are signed, not the image. Each image has its -own hash, and we include the hash in the configuration signature.
-So the above example is adjusted to look like this:
- images {
kernel-1 {
hash-1 {
algo = "sha1";
kernel-2 {
hash-1 {
algo = "sha1";
fdt-1 {
hash-1 {
algo = "sha1";
fdt-2 {
hash-1 {
algo = "sha1";
- configurations {
default = "conf-1";
conf-1 {
fdt = "fdt-1";
signature-1 {
conf-2 {
fdt = "fdt-2";
signature-1 {
-You can see that we have added hashes for all images (since they are no -longer signed), and a signature to each configuration. In the above example, -mkimage will sign configurations/conf-1, the kernel and fdt that are -pointed to by the configuration (/images/kernel-1, /images/kernel-1/hash-1, -/images/fdt-1, /images/fdt-1/hash-1) and the root structure of the image -(so that it isn't possible to add or remove root nodes). The signature is -written into /configurations/conf-1/signature-1/value. It can easily be -verified later even if the FIT has been signed with other keys in the -meantime.
-Details
-The signature node contains a property ('hashed-nodes') which lists all the -nodes that the signature was made over. The image is walked in order and each -tag processed as follows: -- DTB_BEGIN_NODE: The tag and the following name are included in the signature
- if the node or its parent are present in 'hashed-nodes'
-- DTB_END_NODE: The tag is included in the signature if the node or its parent
- are present in 'hashed-nodes'
-- DTB_PROPERTY: The tag, the length word, the offset in the string table, and
- the data are all included if the current node is present in 'hashed-nodes'
- and the property name is not 'data'.
-- DTB_END: The tag is always included in the signature. -- DTB_NOP: The tag is included in the signature if the current node is present
- in 'hashed-nodes'
-In addition, the signature contains a property 'hashed-strings' which contains -the offset and length in the string table of the strings that are to be -included in the signature (this is done last).
-IMPORTANT: To verify the signature outside u-boot, it is vital to not only -calculate the hash of the image and verify the signature with that, but also to -calculate the hashes of the kernel, fdt, and ramdisk images and check those -match the hash values in the corresponding 'hash*' subnodes.
-Verification
-FITs are verified when loaded. After the configuration is selected a list -of required images is produced. If there are 'required' public keys, then -each image must be verified against those keys. This means that every image -that might be used by the target needs to be signed with 'required' keys.
-This happens automatically as part of a bootm command when FITs are used.
-For Signed Configurations, the default verification behavior can be changed by -the following optional property in /signature node in U-Boot's control FDT.
-- required-mode: Valid values are "any" to allow verified boot to succeed if -the selected configuration is signed by any of the 'required' keys, and "all" -to allow verified boot to succeed if the selected configuration is signed by -all of the 'required' keys.
-This property can be added to a binary device tree using fdtput as shown in -below examples::
- fdtput -t s control.dtb /signature required-mode any
- fdtput -t s control.dtb /signature required-mode all
-Enabling FIT Verification
-In addition to the options to enable FIT itself, the following CONFIGs must -be enabled:
-CONFIG_FIT_SIGNATURE - enable signing and verification in FITs -CONFIG_RSA - enable RSA algorithm for signing -CONFIG_ECDSA - enable ECDSA algorithm for signing
-WARNING: When relying on signed FIT images with required signature check -the legacy image format is default disabled by not defining -CONFIG_LEGACY_IMAGE_FORMAT
-Testing
-An easy way to test signing and verification is to use the test script -provided in test/vboot/vboot_test.sh. This uses sandbox (a special version -of U-Boot which runs under Linux) to show the operation of a 'bootm' -command loading and verifying images.
-A sample run is show below:
-$ make O=sandbox sandbox_config -$ make O=sandbox -$ O=sandbox ./test/vboot/vboot_test.sh
-Simple Verified Boot Test
-Please see doc/uImage.FIT/verified-boot.txt for more information
-/home/hs/ids/u-boot/sandbox/tools/mkimage -D -I dts -O dtb -p 2000 -Build keys -do sha1 test -Build FIT with signed images -Test Verified Boot Run: unsigned signatures:: OK -Sign images -Test Verified Boot Run: signed images: OK -Build FIT with signed configuration -Test Verified Boot Run: unsigned config: OK -Sign images -Test Verified Boot Run: signed config: OK -check signed config on the host -Signature check OK -OK -Test Verified Boot Run: signed config: OK -Test Verified Boot Run: signed config with bad hash: OK -do sha256 test -Build FIT with signed images -Test Verified Boot Run: unsigned signatures:: OK -Sign images -Test Verified Boot Run: signed images: OK -Build FIT with signed configuration -Test Verified Boot Run: unsigned config: OK -Sign images -Test Verified Boot Run: signed config: OK -check signed config on the host -Signature check OK -OK -Test Verified Boot Run: signed config: OK -Test Verified Boot Run: signed config with bad hash: OK
-Test passed
-Software signing: keydir vs keyfile
-In the simplest case, signing is done by giving mkimage the 'keyfile'. This is -the path to a file containing the signing key.
-The alternative is to pass the 'keydir' argument. In this case the filename of -the key is derived from the 'keydir' and the "key-name-hint" property in the -FIT. In this case the "key-name-hint" property is mandatory, and the key must -exist in "<keydir>/<key-name-hint>.<ext>" Here the extension "ext" is -specific to the signing algorithm.
-Hardware Signing with PKCS#11 or with HSM
-Securely managing private signing keys can challenging, especially when the -keys are stored on the file system of a computer that is connected to the -Internet. If an attacker is able to steal the key, they can sign malicious FIT -images which will appear genuine to your devices.
-An alternative solution is to keep your signing key securely stored on hardware -device like a smartcard, USB token or Hardware Security Module (HSM) and have -them perform the signing. PKCS#11 is standard for interfacing with these crypto -device.
-Requirements: -Smartcard/USB token/HSM which can work with some openssl engine -openssl
-For pkcs11 engine usage: -libp11 (provides pkcs11 engine) -p11-kit (recommended to simplify setup) -opensc (for smartcards and smartcard like USB devices) -gnutls (recommended for key generation, p11tool)
-For generic HSMs respective openssl engine must be installed and locateable by -openssl. This may require setting up LD_LIBRARY_PATH if engine is not installed -to openssl's default search paths.
-PKCS11 engine support forms "key id" based on "keydir" and with -"key-name-hint". "key-name-hint" is used as "object" name (if not defined in -keydir). "keydir" (if defined) is used to define (prefix for) which PKCS11 source -is being used for lookup up for the key.
-PKCS11 engine key ids:
- "pkcs11:<keydir>;object=<key-name-hint>;type=<public|private>"
-or, if keydir contains "object="
- "pkcs11:<keydir>;type=<public|private>"
-or
- "pkcs11:object=<key-name-hint>;type=<public|private>",
-Generic HSM engine support forms "key id" based on "keydir" and with -"key-name-hint". If "keydir" is specified for mkimage it is used as a prefix in -"key id" and is appended with "key-name-hint".
-Generic engine key ids:
- "<keydir><key-name-hint>"
-or
- "<key-name-hint>"
-In order to set the pin in the HSM, an environment variable "MKIMAGE_SIGN_PIN" -can be specified.
-The following examples use the Nitrokey Pro using pkcs11 engine. Instructions -for other devices may vary.
-Notes on pkcs11 engine setup:
-Make sure p11-kit, opensc are installed and that p11-kit is setup to use opensc. -/usr/share/p11-kit/modules/opensc.module should be present on your system.
-Generating Keys On the Nitrokey:
-$ gpg --card-edit
-Reader ...........: Nitrokey Nitrokey Pro (xxxxxxxx0000000000000000) 00 00 -Application ID ...: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx -Version ..........: 2.1 -Manufacturer .....: ZeitControl -Serial number ....: xxxxxxxx -Name of cardholder: [not set] -Language prefs ...: de -Sex ..............: unspecified -URL of public key : [not set] -Login data .......: [not set] -Signature PIN ....: forced -Key attributes ...: rsa2048 rsa2048 rsa2048 -Max. PIN lengths .: 32 32 32 -PIN retry counter : 3 0 3 -Signature counter : 0 -Signature key ....: [none] -Encryption key....: [none] -Authentication key: [none] -General key info..: [none]
-gpg/card> generate -Make off-card backup of encryption key? (Y/n) n
-Please note that the factory settings of the PINs are
- PIN = '123456' Admin PIN = '12345678'
-You should change them using the command --change-pin
-What keysize do you want for the Signature key? (2048) 4096 -The card will now be re-configured to generate a key of 4096 bits -Note: There is no guarantee that the card supports the requested size.
- If the key generation does not succeed, please check the
- documentation of your card to see what sizes are allowed.
-What keysize do you want for the Encryption key? (2048) 4096 -The card will now be re-configured to generate a key of 4096 bits -What keysize do you want for the Authentication key? (2048) 4096 -The card will now be re-configured to generate a key of 4096 bits -Please specify how long the key should be valid.
- 0 = key does not expire
- <n> = key expires in n days
- <n>w = key expires in n weeks
- <n>m = key expires in n months
- <n>y = key expires in n years
-Key is valid for? (0) -Key does not expire at all -Is this correct? (y/N) y
-GnuPG needs to construct a user ID to identify your key.
-Real name: John Doe -Email address: john.doe@email.com -Comment: -You selected this USER-ID:
- "John Doe john.doe@email.com"
-Change (N)ame, (C)omment, (E)mail or (O)kay/(Q)uit? o
-Using p11tool to get the token URL:
-Depending on system configuration, gpg-agent may need to be killed first.
-$ p11tool --provider /usr/lib/opensc-pkcs11.so --list-tokens -Token 0: -URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29 -Label: OpenPGP card (User PIN (sig)) -Type: Hardware token -Manufacturer: ZeitControl -Model: PKCS#15 emulated -Serial: 000xxxxxxxxx -Module: (null)
-Token 1: -URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%29 -Label: OpenPGP card (User PIN) -Type: Hardware token -Manufacturer: ZeitControl -Model: PKCS#15 emulated -Serial: 000xxxxxxxxx -Module: (null)
-Use the portion of the signature token URL after "pkcs11:" as the keydir argument (-k) to mkimage below.
-Use the URL of the token to list the private keys:
-$ p11tool --login --provider /usr/lib/opensc-pkcs11.so --list-privkeys \ -"pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29" -Token 'OpenPGP card (User PIN (sig))' with URL 'pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29' requires user PIN -Enter PIN: -Object 0: -URL: pkcs11:model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29;id=%01;object=Signature%20key;type=private -Type: Private key -Label: Signature key -Flags: CKA_PRIVATE; CKA_NEVER_EXTRACTABLE; CKA_SENSITIVE; -ID: 01
-Use the label, in this case "Signature key" as the key-name-hint in your FIT.
-Create the fitImage: -$ ./tools/mkimage -f fit-image.its fitImage
-Sign the fitImage with the hardware key:
-$ ./tools/mkimage -F -k \ -"model=PKCS%2315%20emulated;manufacturer=ZeitControl;serial=000xxxxxxxxx;token=OpenPGP%20card%20%28User%20PIN%20%28sig%29%29" \ --K u-boot.dtb -N pkcs11 -r fitImage
-Future Work
-- Roll-back protection using a TPM is done using the tpm command. This can -be scripted, but we might consider a default way of doing this, built into -bootm.
-Possible Future Work
-- More sandbox tests for failure modes -- Passwords for keys/certificates -- Perhaps implement OAEP -- Enhance bootm to permit scripted signature verification (so that a script -can verify an image but not actually boot it)
-Simon Glass -sjg@chromium.org -1-1-13 diff --git a/doc/usage/cmd/source.rst b/doc/usage/cmd/source.rst index a5c5204a28b8..697f644745b2 100644 --- a/doc/usage/cmd/source.rst +++ b/doc/usage/cmd/source.rst @@ -22,7 +22,7 @@ Two formats for script files exist:
- Flat Image Tree (FIT)
The benefit of the FIT images is that they can be signed and verifed as -decribed in :download:`signature.txt <../../uImage.FIT/signature.txt>`. +described in :doc:`../fit/signature`.
Both formats can be created with the mkimage tool.
diff --git a/doc/usage/fit/beaglebone_vboot.rst b/doc/usage/fit/beaglebone_vboot.rst new file mode 100644 index 000000000000..9851c445c1c9 --- /dev/null +++ b/doc/usage/fit/beaglebone_vboot.rst @@ -0,0 +1,607 @@ +.. SPDX-License-Identifier: GPL-2.0+
+Verified Boot on the Beaglebone Black +=====================================
+Introduction +------------
+Before reading this, please read :doc:`verified-boot` and :doc:`signature`. +These instructions are for mainline U-Boot from v2014.07 onwards.
+There is quite a bit of documentation in this directory describing how +verified boot works in U-Boot. There is also a test which runs through the +entire process of signing an image and running U-Boot (sandbox) to check it. +However, it might be useful to also have an example on a real board.
+Beaglebone Black is a fairly common board so seems to be a reasonable choice +for an example of how to enable verified boot using U-Boot.
+First a note that may to help avoid confusion. U-Boot and Linux both use +device tree. They may use the same device tree source, but it is seldom useful +for them to use the exact same binary from the same place. More typically, +U-Boot has its device tree packaged with it, and the kernel's device tree is +packaged with the kernel. In particular this is important with verified boot, +since U-Boot's device tree must be immutable. If it can be changed then the +public keys can be changed and verified boot is useless. An attacker can +simply generate a new key and put his public key into U-Boot so that +everything verifies. On the other hand the kernel's device tree typically +changes when the kernel changes, so it is useful to package an updated device +tree with the kernel binary. U-Boot supports the latter with its flexible FIT +format (Flat Image Tree).
+Overview +--------
+The steps are roughly as follows:
+#. Build U-Boot for the board, with the verified boot options enabled.
+#. Obtain a suitable Linux kernel
+#. Create a Image Tree Source file (ITS) file describing how you want the
- kernel to be packaged, compressed and signed.
+#. Create a key pair
+#. Sign the kernel
+#. Put the public key into U-Boot's image
+#. Put U-Boot and the kernel onto the board
+#. Try it
+Step 1: Build U-Boot +--------------------
+a. Set up the environment variable to point to your toolchain. You will need +this for U-Boot and also for the kernel if you build it. For example if you +installed a Linaro version manually it might be something like::
These two lines must be indentend by 3 spaces.
Indent by 7 spaces
+or if you just installed gcc-arm-linux-gnueabi then it might be::
This line must be indented by 3 spaces as it belongs to a.
+b. Configure and build U-Boot with verified boot enabled::
- cd $UBOOT
indent by 7 spaces
+c. You will now have a U-Boot image::
- b/am335x_boneblack_vboot/u-boot-dtb.img: u-boot legacy uImage, U-Boot 2014.07-rc2-00065-g2f69f8, Firmware/ARM, Firmware Image (Not compressed), 395375 bytes, Sat May 31 16:19:04 2014, Load Address: 0x80800000, Entry Point: 0x00000000, Header CRC: 0x0ABD6ACA, Data CRC: 0x36DEF7E4
Please, avoid the need for horizontal scrolling by breaking the output line to 80 charactes.
+Step 2: Build Linux +--------------------
+a. Find the kernel image ('Image') and device tree (.dtb) file you plan to +use. In our case it is am335x-boneblack.dtb and it is built with the kernel. +At the time of writing an SD Boot image can be obtained from here::
Indent by 3 spaces
Indent by 7 spaces
+You can write this to an SD card and then mount it to extract the kernel and +device tree files.
+You can also build a kernel. Instructions for this are are here::
Indent by 3 spaces
Indent by 7 spaces
+or you can use your favourite search engine. Following these instructions +produces a kernel Image and device tree files. For the record the steps were::
Indent by 3 spaces
- cd $KERNEL
- ./patch.sh
- cd kernel
Indent by 7 spaces
Best regards
Heinrich
Bring this file into the documentation.
doc/uImage.FIT/howto.txt | 411 -------------------------------------- doc/usage/fit/howto.rst | 419 +++++++++++++++++++++++++++++++++++++++ doc/usage/fit/index.rst | 1 + 3 files changed, 420 insertions(+), 411 deletions(-) delete mode 100644 doc/uImage.FIT/howto.txt create mode 100644 doc/usage/fit/howto.rst
diff --git a/doc/uImage.FIT/howto.txt b/doc/uImage.FIT/howto.txt deleted file mode 100644 index 6dbd17dc8ca0..000000000000 --- a/doc/uImage.FIT/howto.txt +++ /dev/null @@ -1,411 +0,0 @@ -How to use images in the new image format -========================================= - -Author: Bartlomiej Sieka tur@semihalf.com - - -Overview --------- - -The new uImage format allows more flexibility in handling images of various -types (kernel, ramdisk, etc.), it also enhances integrity protection of images -with sha1 and md5 checksums. - -Two auxiliary tools are needed on the development host system in order to -create an uImage in the new format: mkimage and dtc, although only one -(mkimage) is invoked directly. dtc is called from within mkimage and operates -behind the scenes, but needs to be present in the $PATH nevertheless. It is -important that the dtc used has support for binary includes -- refer to - - git://git.kernel.org/pub/scm/utils/dtc/dtc.git - -for its latest version. mkimage (together with dtc) takes as input -an image source file, which describes the contents of the image and defines -its various properties used during booting. By convention, image source file -has the ".its" extension, also, the details of its format are given in -doc/uImage.FIT/source_file_format.txt. The actual data that is to be included in -the uImage (kernel, ramdisk, etc.) is specified in the image source file in the -form of paths to appropriate data files. The outcome of the image creation -process is a binary file (by convention with the ".itb" extension) that -contains all the referenced data (kernel, ramdisk, etc.) and other information -needed by U-Boot to handle the uImage properly. The uImage file is then -transferred to the target (e.g., via tftp) and booted using the bootm command. - -To summarize the prerequisites needed for new uImage creation: -- mkimage -- dtc (with support for binary includes) -- image source file (*.its) -- image data file(s) - - -Here's a graphical overview of the image creation and booting process: - -image source file mkimage + dtc transfer to target - + ---------------> image file --------------------> bootm -image data file(s) - -SPL usage ---------- - -The SPL can make use of the new image format as well, this traditionally -is used to ship multiple device tree files within one image. Code in the SPL -will choose the one matching the current board and append this to the -U-Boot proper binary to be automatically used up by it. -Aside from U-Boot proper and one device tree blob the SPL can load multiple, -arbitrary image files as well. These binaries should be specified in their -own subnode under the /images node, which should then be referenced from one or -multiple /configurations subnodes. The required images must be enumerated in -the "loadables" property as a list of strings. - -If a platform specific image source file (.its) is shipped with the U-Boot -source, it can be specified using the CONFIG_SPL_FIT_SOURCE Kconfig symbol. -In this case it will be automatically used by U-Boot's Makefile to generate -the image. -If a static source file is not flexible enough, CONFIG_SPL_FIT_GENERATOR -can point to a script which generates this image source file during -the build process. It gets passed a list of device tree files (taken from the -CONFIG_OF_LIST symbol). - -The SPL also records to a DT all additional images (called loadables) which are -loaded. The information about loadables locations is passed via the DT node with -fit-images name. - -Finally, if there are multiple xPL phases (e.g. SPL, VPL), images can be marked -as intended for a particular phase using the 'phase' property. For example, if -fit_image_load() is called with image_ph(IH_PHASE_SPL, IH_TYPE_FIRMWARE), then -only the image listed into the "firmware" property where phase is set to "spl" -will be loaded. - -Loadables Example ------------------ -Consider the following case for an ARM64 platform where U-Boot runs in EL2 -started by ATF where SPL is loading U-Boot (as loadables) and ATF (as firmware). - -/dts-v1/; - -/ { - description = "Configuration to load ATF before U-Boot"; - - images { - uboot { - description = "U-Boot (64-bit)"; - data = /incbin/("u-boot-nodtb.bin"); - type = "firmware"; - os = "u-boot"; - arch = "arm64"; - compression = "none"; - load = <0x8 0x8000000>; - entry = <0x8 0x8000000>; - hash { - algo = "md5"; - }; - }; - atf { - description = "ARM Trusted Firmware"; - data = /incbin/("bl31.bin"); - type = "firmware"; - os = "arm-trusted-firmware"; - arch = "arm64"; - compression = "none"; - load = <0xfffea000>; - entry = <0xfffea000>; - hash { - algo = "md5"; - }; - }; - fdt_1 { - description = "zynqmp-zcu102-revA"; - data = /incbin/("arch/arm/dts/zynqmp-zcu102-revA.dtb"); - type = "flat_dt"; - arch = "arm64"; - compression = "none"; - load = <0x100000>; - hash { - algo = "md5"; - }; - }; - }; - configurations { - default = "config_1"; - - config_1 { - description = "zynqmp-zcu102-revA"; - firmware = "atf"; - loadables = "uboot"; - fdt = "fdt_1"; - }; - }; -}; - -In this case the SPL records via fit-images DT node the information about -loadables U-Boot image. - -ZynqMP> fdt addr $fdtcontroladdr -ZynqMP> fdt print /fit-images -fit-images { - uboot { - os = "u-boot"; - type = "firmware"; - size = <0x001017c8>; - entry = <0x00000008 0x08000000>; - load = <0x00000008 0x08000000>; - }; -}; - -As you can see entry and load properties are 64bit wide to support loading -images above 4GB (in past entry and load properties where just 32bit). - - -Example 1 -- old-style (non-FDT) kernel booting ------------------------------------------------ - -Consider a simple scenario, where a PPC Linux kernel built from sources on the -development host is to be booted old-style (non-FDT) by U-Boot on an embedded -target. Assume that the outcome of the build is vmlinux.bin.gz, a file which -contains a gzip-compressed PPC Linux kernel (the only data file in this case). -The uImage can be produced using the image source file -doc/uImage.FIT/kernel.its (note that kernel.its assumes that vmlinux.bin.gz is -in the current working directory; if desired, an alternative path can be -specified in the kernel.its file). Here's how to create the image and inspect -its contents: - -[on the host system] -$ mkimage -f kernel.its kernel.itb -DTC: dts->dtb on file "kernel.its" -$ -$ mkimage -l kernel.itb -FIT description: Simple image with single Linux kernel -Created: Tue Mar 11 17:26:15 2008 - Image 0 (kernel) - Description: Vanilla Linux kernel - Type: Kernel Image - Compression: gzip compressed - Data Size: 943347 Bytes = 921.24 kB = 0.90 MB - Architecture: PowerPC - OS: Linux - Load Address: 0x00000000 - Entry Point: 0x00000000 - Hash algo: crc32 - Hash value: 2ae2bb40 - Hash algo: sha1 - Hash value: 3c200f34e2c226ddc789240cca0c59fc54a67cf4 - Default Configuration: 'config-1' - Configuration 0 (config-1) - Description: Boot Linux kernel - Kernel: kernel - - -The resulting image file kernel.itb can be now transferred to the target, -inspected and booted (note that first three U-Boot commands below are shown -for completeness -- they are part of the standard booting procedure and not -specific to the new image format). - -[on the target system] -=> print nfsargs -nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} -=> print addip -addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off panic=1 -=> run nfsargs addip -=> tftp 900000 /path/to/tftp/location/kernel.itb -Using FEC device -TFTP from server 192.168.1.1; our IP address is 192.168.160.5 -Filename '/path/to/tftp/location/kernel.itb'. -Load address: 0x900000 -Loading: ################################################################# -done -Bytes transferred = 944464 (e6950 hex) -=> iminfo - -## Checking Image at 00900000 ... - FIT image found - FIT description: Simple image with single Linux kernel - Created: 2008-03-11 16:26:15 UTC - Image 0 (kernel) - Description: Vanilla Linux kernel - Type: Kernel Image - Compression: gzip compressed - Data Start: 0x009000e0 - Data Size: 943347 Bytes = 921.2 kB - Architecture: PowerPC - OS: Linux - Load Address: 0x00000000 - Entry Point: 0x00000000 - Hash algo: crc32 - Hash value: 2ae2bb40 - Hash algo: sha1 - Hash value: 3c200f34e2c226ddc789240cca0c59fc54a67cf4 - Default Configuration: 'config-1' - Configuration 0 (config-1) - Description: Boot Linux kernel - Kernel: kernel - -=> bootm -## Booting kernel from FIT Image at 00900000 ... - Using 'config-1' configuration - Trying 'kernel' kernel subimage - Description: Vanilla Linux kernel - Type: Kernel Image - Compression: gzip compressed - Data Start: 0x009000e0 - Data Size: 943347 Bytes = 921.2 kB - Architecture: PowerPC - OS: Linux - Load Address: 0x00000000 - Entry Point: 0x00000000 - Hash algo: crc32 - Hash value: 2ae2bb40 - Hash algo: sha1 - Hash value: 3c200f34e2c226ddc789240cca0c59fc54a67cf4 - Verifying Hash Integrity ... crc32+ sha1+ OK - Uncompressing Kernel Image ... OK -Memory BAT mapping: BAT2=256Mb, BAT3=0Mb, residual: 0Mb -Linux version 2.4.25 (m8@hekate) (gcc version 4.0.0 (DENX ELDK 4.0 4.0.0)) #2 czw lip 5 17:56:18 CEST 2007 -On node 0 totalpages: 65536 -zone(0): 65536 pages. -zone(1): 0 pages. -zone(2): 0 pages. -Kernel command line: root=/dev/nfs rw nfsroot=192.168.1.1:/opt/eldk-4.1/ppc_6xx ip=192.168.160.5:192.168.1.1::255.255.0.0:lite5200b:eth0:off panic=1 -Calibrating delay loop... 307.20 BogoMIPS - - -Example 2 -- new-style (FDT) kernel booting -------------------------------------------- - -Consider another simple scenario, where a PPC Linux kernel is to be booted -new-style, i.e., with a FDT blob. In this case there are two prerequisite data -files: vmlinux.bin.gz (Linux kernel) and target.dtb (FDT blob). The uImage can -be produced using image source file doc/uImage.FIT/kernel_fdt.its like this -(note again, that both prerequisite data files are assumed to be present in -the current working directory -- image source file kernel_fdt.its can be -modified to take the files from some other location if needed): - -[on the host system] -$ mkimage -f kernel_fdt.its kernel_fdt.itb -DTC: dts->dtb on file "kernel_fdt.its" -$ -$ mkimage -l kernel_fdt.itb -FIT description: Simple image with single Linux kernel and FDT blob -Created: Tue Mar 11 16:29:22 2008 - Image 0 (kernel) - Description: Vanilla Linux kernel - Type: Kernel Image - Compression: gzip compressed - Data Size: 1092037 Bytes = 1066.44 kB = 1.04 MB - Architecture: PowerPC - OS: Linux - Load Address: 0x00000000 - Entry Point: 0x00000000 - Hash algo: crc32 - Hash value: 2c0cc807 - Hash algo: sha1 - Hash value: 264b59935470e42c418744f83935d44cdf59a3bb - Image 1 (fdt-1) - Description: Flattened Device Tree blob - Type: Flat Device Tree - Compression: uncompressed - Data Size: 16384 Bytes = 16.00 kB = 0.02 MB - Architecture: PowerPC - Hash algo: crc32 - Hash value: 0d655d71 - Hash algo: sha1 - Hash value: 25ab4e15cd4b8a5144610394560d9c318ce52def - Default Configuration: 'conf-1' - Configuration 0 (conf-1) - Description: Boot Linux kernel with FDT blob - Kernel: kernel - FDT: fdt-1 - - -The resulting image file kernel_fdt.itb can be now transferred to the target, -inspected and booted: - -[on the target system] -=> tftp 900000 /path/to/tftp/location/kernel_fdt.itb -Using FEC device -TFTP from server 192.168.1.1; our IP address is 192.168.160.5 -Filename '/path/to/tftp/location/kernel_fdt.itb'. -Load address: 0x900000 -Loading: ################################################################# - ########### -done -Bytes transferred = 1109776 (10ef10 hex) -=> iminfo - -## Checking Image at 00900000 ... - FIT image found - FIT description: Simple image with single Linux kernel and FDT blob - Created: 2008-03-11 15:29:22 UTC - Image 0 (kernel) - Description: Vanilla Linux kernel - Type: Kernel Image - Compression: gzip compressed - Data Start: 0x009000ec - Data Size: 1092037 Bytes = 1 MB - Architecture: PowerPC - OS: Linux - Load Address: 0x00000000 - Entry Point: 0x00000000 - Hash algo: crc32 - Hash value: 2c0cc807 - Hash algo: sha1 - Hash value: 264b59935470e42c418744f83935d44cdf59a3bb - Image 1 (fdt-1) - Description: Flattened Device Tree blob - Type: Flat Device Tree - Compression: uncompressed - Data Start: 0x00a0abdc - Data Size: 16384 Bytes = 16 kB - Architecture: PowerPC - Hash algo: crc32 - Hash value: 0d655d71 - Hash algo: sha1 - Hash value: 25ab4e15cd4b8a5144610394560d9c318ce52def - Default Configuration: 'conf-1' - Configuration 0 (conf-1) - Description: Boot Linux kernel with FDT blob - Kernel: kernel - FDT: fdt-1 -=> bootm -## Booting kernel from FIT Image at 00900000 ... - Using 'conf-1' configuration - Trying 'kernel' kernel subimage - Description: Vanilla Linux kernel - Type: Kernel Image - Compression: gzip compressed - Data Start: 0x009000ec - Data Size: 1092037 Bytes = 1 MB - Architecture: PowerPC - OS: Linux - Load Address: 0x00000000 - Entry Point: 0x00000000 - Hash algo: crc32 - Hash value: 2c0cc807 - Hash algo: sha1 - Hash value: 264b59935470e42c418744f83935d44cdf59a3bb - Verifying Hash Integrity ... crc32+ sha1+ OK - Uncompressing Kernel Image ... OK -## Flattened Device Tree from FIT Image at 00900000 - Using 'conf-1' configuration - Trying 'fdt-1' FDT blob subimage - Description: Flattened Device Tree blob - Type: Flat Device Tree - Compression: uncompressed - Data Start: 0x00a0abdc - Data Size: 16384 Bytes = 16 kB - Architecture: PowerPC - Hash algo: crc32 - Hash value: 0d655d71 - Hash algo: sha1 - Hash value: 25ab4e15cd4b8a5144610394560d9c318ce52def - Verifying Hash Integrity ... crc32+ sha1+ OK - Booting using the fdt blob at 0xa0abdc - Loading Device Tree to 007fc000, end 007fffff ... OK -[ 0.000000] Using lite5200 machine description -[ 0.000000] Linux version 2.6.24-rc6-gaebecdfc (m8@hekate) (gcc version 4.0.0 (DENX ELDK 4.1 4.0.0)) #1 Sat Jan 12 15:38:48 CET 2008 - - -Example 3 -- advanced booting ------------------------------ - -Refer to doc/uImage.FIT/multi.its for an image source file that allows more -sophisticated booting scenarios (multiple kernels, ramdisks and fdt blobs). diff --git a/doc/usage/fit/howto.rst b/doc/usage/fit/howto.rst new file mode 100644 index 000000000000..c933703d1d00 --- /dev/null +++ b/doc/usage/fit/howto.rst @@ -0,0 +1,419 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +How to use images in the new image format +========================================= + +Overview +-------- + +The new uImage format allows more flexibility in handling images of various +types (kernel, ramdisk, etc.), it also enhances integrity protection of images +with sha1 and md5 checksums. + +Two auxiliary tools are needed on the development host system in order to +create an uImage in the new format: mkimage and dtc, although only one +(mkimage) is invoked directly. dtc is called from within mkimage and operates +behind the scenes, but needs to be present in the $PATH nevertheless. It is +important that the dtc used has support for binary includes -- refer to:: + + git://git.kernel.org/pub/scm/utils/dtc/dtc.git + +for its latest version. mkimage (together with dtc) takes as input +an image source file, which describes the contents of the image and defines +its various properties used during booting. By convention, image source file +has the ".its" extension, also, the details of its format are given in +doc/uImage.FIT/source_file_format.txt. The actual data that is to be included in +the uImage (kernel, ramdisk, etc.) is specified in the image source file in the +form of paths to appropriate data files. The outcome of the image creation +process is a binary file (by convention with the ".itb" extension) that +contains all the referenced data (kernel, ramdisk, etc.) and other information +needed by U-Boot to handle the uImage properly. The uImage file is then +transferred to the target (e.g., via tftp) and booted using the bootm command. + +To summarize the prerequisites needed for new uImage creation: + +- mkimage +- dtc (with support for binary includes) +- image source file (`*.its`) +- image data file(s) + + +Here's a graphical overview of the image creation and booting process:: + + image source file mkimage + dtc transfer to target + + ---------------> image file --------------------> bootm + image data file(s) + +SPL usage +--------- + +The SPL can make use of the new image format as well, this traditionally +is used to ship multiple device tree files within one image. Code in the SPL +will choose the one matching the current board and append this to the +U-Boot proper binary to be automatically used up by it. +Aside from U-Boot proper and one device tree blob the SPL can load multiple, +arbitrary image files as well. These binaries should be specified in their +own subnode under the /images node, which should then be referenced from one or +multiple /configurations subnodes. The required images must be enumerated in +the "loadables" property as a list of strings. + +If a platform specific image source file (.its) is shipped with the U-Boot +source, it can be specified using the CONFIG_SPL_FIT_SOURCE Kconfig symbol. +In this case it will be automatically used by U-Boot's Makefile to generate +the image. +If a static source file is not flexible enough, CONFIG_SPL_FIT_GENERATOR +can point to a script which generates this image source file during +the build process. It gets passed a list of device tree files (taken from the +CONFIG_OF_LIST symbol). + +The SPL also records to a DT all additional images (called loadables) which are +loaded. The information about loadables locations is passed via the DT node with +fit-images name. + +Finally, if there are multiple xPL phases (e.g. SPL, VPL), images can be marked +as intended for a particular phase using the 'phase' property. For example, if +fit_image_load() is called with image_ph(IH_PHASE_SPL, IH_TYPE_FIRMWARE), then +only the image listed into the "firmware" property where phase is set to "spl" +will be loaded. + +Loadables Example +----------------- +Consider the following case for an ARM64 platform where U-Boot runs in EL2 +started by ATF where SPL is loading U-Boot (as loadables) and ATF (as firmware). + +:: + + /dts-v1/; + + / { + description = "Configuration to load ATF before U-Boot"; + + images { + uboot { + description = "U-Boot (64-bit)"; + data = /incbin/("u-boot-nodtb.bin"); + type = "firmware"; + os = "u-boot"; + arch = "arm64"; + compression = "none"; + load = <0x8 0x8000000>; + entry = <0x8 0x8000000>; + hash { + algo = "md5"; + }; + }; + atf { + description = "ARM Trusted Firmware"; + data = /incbin/("bl31.bin"); + type = "firmware"; + os = "arm-trusted-firmware"; + arch = "arm64"; + compression = "none"; + load = <0xfffea000>; + entry = <0xfffea000>; + hash { + algo = "md5"; + }; + }; + fdt_1 { + description = "zynqmp-zcu102-revA"; + data = /incbin/("arch/arm/dts/zynqmp-zcu102-revA.dtb"); + type = "flat_dt"; + arch = "arm64"; + compression = "none"; + load = <0x100000>; + hash { + algo = "md5"; + }; + }; + }; + configurations { + default = "config_1"; + + config_1 { + description = "zynqmp-zcu102-revA"; + firmware = "atf"; + loadables = "uboot"; + fdt = "fdt_1"; + }; + }; + }; + +In this case the SPL records via fit-images DT node the information about +loadables U-Boot image:: + + ZynqMP> fdt addr $fdtcontroladdr + ZynqMP> fdt print /fit-images + fit-images { + uboot { + os = "u-boot"; + type = "firmware"; + size = <0x001017c8>; + entry = <0x00000008 0x08000000>; + load = <0x00000008 0x08000000>; + }; + }; + +As you can see entry and load properties are 64bit wide to support loading +images above 4GB (in past entry and load properties where just 32bit). + + +Example 1 -- old-style (non-FDT) kernel booting +----------------------------------------------- + +Consider a simple scenario, where a PPC Linux kernel built from sources on the +development host is to be booted old-style (non-FDT) by U-Boot on an embedded +target. Assume that the outcome of the build is vmlinux.bin.gz, a file which +contains a gzip-compressed PPC Linux kernel (the only data file in this case). +The uImage can be produced using the image source file +doc/uImage.FIT/kernel.its (note that kernel.its assumes that vmlinux.bin.gz is +in the current working directory; if desired, an alternative path can be +specified in the kernel.its file). Here's how to create the image and inspect +its contents: + +[on the host system]:: + + $ mkimage -f kernel.its kernel.itb + DTC: dts->dtb on file "kernel.its" + $ + $ mkimage -l kernel.itb + FIT description: Simple image with single Linux kernel + Created: Tue Mar 11 17:26:15 2008 + Image 0 (kernel) + Description: Vanilla Linux kernel + Type: Kernel Image + Compression: gzip compressed + Data Size: 943347 Bytes = 921.24 kB = 0.90 MB + Architecture: PowerPC + OS: Linux + Load Address: 0x00000000 + Entry Point: 0x00000000 + Hash algo: crc32 + Hash value: 2ae2bb40 + Hash algo: sha1 + Hash value: 3c200f34e2c226ddc789240cca0c59fc54a67cf4 + Default Configuration: 'config-1' + Configuration 0 (config-1) + Description: Boot Linux kernel + Kernel: kernel + + +The resulting image file kernel.itb can be now transferred to the target, +inspected and booted (note that first three U-Boot commands below are shown +for completeness -- they are part of the standard booting procedure and not +specific to the new image format). + +[on the target system]:: + + => print nfsargs + nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} + => print addip + addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off panic=1 + => run nfsargs addip + => tftp 900000 /path/to/tftp/location/kernel.itb + Using FEC device + TFTP from server 192.168.1.1; our IP address is 192.168.160.5 + Filename '/path/to/tftp/location/kernel.itb'. + Load address: 0x900000 + Loading: ################################################################# + done + Bytes transferred = 944464 (e6950 hex) + => iminfo + + ## Checking Image at 00900000 ... + FIT image found + FIT description: Simple image with single Linux kernel + Created: 2008-03-11 16:26:15 UTC + Image 0 (kernel) + Description: Vanilla Linux kernel + Type: Kernel Image + Compression: gzip compressed + Data Start: 0x009000e0 + Data Size: 943347 Bytes = 921.2 kB + Architecture: PowerPC + OS: Linux + Load Address: 0x00000000 + Entry Point: 0x00000000 + Hash algo: crc32 + Hash value: 2ae2bb40 + Hash algo: sha1 + Hash value: 3c200f34e2c226ddc789240cca0c59fc54a67cf4 + Default Configuration: 'config-1' + Configuration 0 (config-1) + Description: Boot Linux kernel + Kernel: kernel + + => bootm + ## Booting kernel from FIT Image at 00900000 ... + Using 'config-1' configuration + Trying 'kernel' kernel subimage + Description: Vanilla Linux kernel + Type: Kernel Image + Compression: gzip compressed + Data Start: 0x009000e0 + Data Size: 943347 Bytes = 921.2 kB + Architecture: PowerPC + OS: Linux + Load Address: 0x00000000 + Entry Point: 0x00000000 + Hash algo: crc32 + Hash value: 2ae2bb40 + Hash algo: sha1 + Hash value: 3c200f34e2c226ddc789240cca0c59fc54a67cf4 + Verifying Hash Integrity ... crc32+ sha1+ OK + Uncompressing Kernel Image ... OK + Memory BAT mapping: BAT2=256Mb, BAT3=0Mb, residual: 0Mb + Linux version 2.4.25 (m8@hekate) (gcc version 4.0.0 (DENX ELDK 4.0 4.0.0)) #2 czw lip 5 17:56:18 CEST 2007 + On node 0 totalpages: 65536 + zone(0): 65536 pages. + zone(1): 0 pages. + zone(2): 0 pages. + Kernel command line: root=/dev/nfs rw nfsroot=192.168.1.1:/opt/eldk-4.1/ppc_6xx ip=192.168.160.5:192.168.1.1::255.255.0.0:lite5200b:eth0:off panic=1 + Calibrating delay loop... 307.20 BogoMIPS + + +Example 2 -- new-style (FDT) kernel booting +------------------------------------------- + +Consider another simple scenario, where a PPC Linux kernel is to be booted +new-style, i.e., with a FDT blob. In this case there are two prerequisite data +files: vmlinux.bin.gz (Linux kernel) and target.dtb (FDT blob). The uImage can +be produced using image source file doc/uImage.FIT/kernel_fdt.its like this +(note again, that both prerequisite data files are assumed to be present in +the current working directory -- image source file kernel_fdt.its can be +modified to take the files from some other location if needed): + +[on the host system]:: + + $ mkimage -f kernel_fdt.its kernel_fdt.itb + DTC: dts->dtb on file "kernel_fdt.its" + $ + $ mkimage -l kernel_fdt.itb + FIT description: Simple image with single Linux kernel and FDT blob + Created: Tue Mar 11 16:29:22 2008 + Image 0 (kernel) + Description: Vanilla Linux kernel + Type: Kernel Image + Compression: gzip compressed + Data Size: 1092037 Bytes = 1066.44 kB = 1.04 MB + Architecture: PowerPC + OS: Linux + Load Address: 0x00000000 + Entry Point: 0x00000000 + Hash algo: crc32 + Hash value: 2c0cc807 + Hash algo: sha1 + Hash value: 264b59935470e42c418744f83935d44cdf59a3bb + Image 1 (fdt-1) + Description: Flattened Device Tree blob + Type: Flat Device Tree + Compression: uncompressed + Data Size: 16384 Bytes = 16.00 kB = 0.02 MB + Architecture: PowerPC + Hash algo: crc32 + Hash value: 0d655d71 + Hash algo: sha1 + Hash value: 25ab4e15cd4b8a5144610394560d9c318ce52def + Default Configuration: 'conf-1' + Configuration 0 (conf-1) + Description: Boot Linux kernel with FDT blob + Kernel: kernel + FDT: fdt-1 + + +The resulting image file kernel_fdt.itb can be now transferred to the target, +inspected and booted: + +[on the target system]:: + + => tftp 900000 /path/to/tftp/location/kernel_fdt.itb + Using FEC device + TFTP from server 192.168.1.1; our IP address is 192.168.160.5 + Filename '/path/to/tftp/location/kernel_fdt.itb'. + Load address: 0x900000 + Loading: ################################################################# + ########### + done + Bytes transferred = 1109776 (10ef10 hex) + => iminfo + + ## Checking Image at 00900000 ... + FIT image found + FIT description: Simple image with single Linux kernel and FDT blob + Created: 2008-03-11 15:29:22 UTC + Image 0 (kernel) + Description: Vanilla Linux kernel + Type: Kernel Image + Compression: gzip compressed + Data Start: 0x009000ec + Data Size: 1092037 Bytes = 1 MB + Architecture: PowerPC + OS: Linux + Load Address: 0x00000000 + Entry Point: 0x00000000 + Hash algo: crc32 + Hash value: 2c0cc807 + Hash algo: sha1 + Hash value: 264b59935470e42c418744f83935d44cdf59a3bb + Image 1 (fdt-1) + Description: Flattened Device Tree blob + Type: Flat Device Tree + Compression: uncompressed + Data Start: 0x00a0abdc + Data Size: 16384 Bytes = 16 kB + Architecture: PowerPC + Hash algo: crc32 + Hash value: 0d655d71 + Hash algo: sha1 + Hash value: 25ab4e15cd4b8a5144610394560d9c318ce52def + Default Configuration: 'conf-1' + Configuration 0 (conf-1) + Description: Boot Linux kernel with FDT blob + Kernel: kernel + FDT: fdt-1 + => bootm + ## Booting kernel from FIT Image at 00900000 ... + Using 'conf-1' configuration + Trying 'kernel' kernel subimage + Description: Vanilla Linux kernel + Type: Kernel Image + Compression: gzip compressed + Data Start: 0x009000ec + Data Size: 1092037 Bytes = 1 MB + Architecture: PowerPC + OS: Linux + Load Address: 0x00000000 + Entry Point: 0x00000000 + Hash algo: crc32 + Hash value: 2c0cc807 + Hash algo: sha1 + Hash value: 264b59935470e42c418744f83935d44cdf59a3bb + Verifying Hash Integrity ... crc32+ sha1+ OK + Uncompressing Kernel Image ... OK + ## Flattened Device Tree from FIT Image at 00900000 + Using 'conf-1' configuration + Trying 'fdt-1' FDT blob subimage + Description: Flattened Device Tree blob + Type: Flat Device Tree + Compression: uncompressed + Data Start: 0x00a0abdc + Data Size: 16384 Bytes = 16 kB + Architecture: PowerPC + Hash algo: crc32 + Hash value: 0d655d71 + Hash algo: sha1 + Hash value: 25ab4e15cd4b8a5144610394560d9c318ce52def + Verifying Hash Integrity ... crc32+ sha1+ OK + Booting using the fdt blob at 0xa0abdc + Loading Device Tree to 007fc000, end 007fffff ... OK + [ 0.000000] Using lite5200 machine description + [ 0.000000] Linux version 2.6.24-rc6-gaebecdfc (m8@hekate) (gcc version 4.0.0 (DENX ELDK 4.1 4.0.0)) #1 Sat Jan 12 15:38:48 CET 2008 + + +Example 3 -- advanced booting +----------------------------- + +Refer to :doc:`multi` for an image source file that allows more +sophisticated booting scenarios (multiple kernels, ramdisks and fdt blobs). + +.. sectionauthor:: Bartlomiej Sieka tur@semihalf.com diff --git a/doc/usage/fit/index.rst b/doc/usage/fit/index.rst index 0576675ec001..83bc4d01ca42 100644 --- a/doc/usage/fit/index.rst +++ b/doc/usage/fit/index.rst @@ -11,6 +11,7 @@ doc/uImage.FIT :maxdepth: 1
source_file_format + howto x86-fit-boot signature verified-boot
doc/uImage.FIT/overlay-fdt-boot.txt | 225 --------------------------- doc/usage/fit/index.rst | 1 + doc/usage/fit/overlay-fdt-boot.rst | 227 ++++++++++++++++++++++++++++ 3 files changed, 228 insertions(+), 225 deletions(-) delete mode 100644 doc/uImage.FIT/overlay-fdt-boot.txt create mode 100644 doc/usage/fit/overlay-fdt-boot.rst
diff --git a/doc/uImage.FIT/overlay-fdt-boot.txt b/doc/uImage.FIT/overlay-fdt-boot.txt deleted file mode 100644 index dddc4db1a67d..000000000000 --- a/doc/uImage.FIT/overlay-fdt-boot.txt +++ /dev/null @@ -1,225 +0,0 @@ -U-Boot FDT Overlay FIT usage -============================ - -Introduction ------------- -In many cases it is desirable to have a single FIT image support a multitude -of similar boards and their expansion options. The same kernel on DT enabled -platforms can support this easily enough by providing a DT blob upon boot -that matches the desired configuration. - -This document focuses on specifically using overlays as part of a FIT image. -General information regarding overlays including its syntax and building it -can be found in doc/README.fdt-overlays - -Configuration without overlays ------------------------------- - -Take a hypothetical board named 'foo' where there are different supported -revisions, reva and revb. Assume that both board revisions can use add a bar -add-on board, while only the revb board can use a baz add-on board. - -Without using overlays the configuration would be as follows for every case. - - /dts-v1/; - / { - images { - kernel { - data = /incbin/("./zImage"); - type = "kernel"; - arch = "arm"; - os = "linux"; - load = <0x82000000>; - entry = <0x82000000>; - }; - fdt-1 { - data = /incbin/("./foo-reva.dtb"); - type = "flat_dt"; - arch = "arm"; - }; - fdt-2 { - data = /incbin/("./foo-revb.dtb"); - type = "flat_dt"; - arch = "arm"; - }; - fdt-3 { - data = /incbin/("./foo-reva-bar.dtb"); - type = "flat_dt"; - arch = "arm"; - }; - fdt-4 { - data = /incbin/("./foo-revb-bar.dtb"); - type = "flat_dt"; - arch = "arm"; - }; - fdt-5 { - data = /incbin/("./foo-revb-baz.dtb"); - type = "flat_dt"; - arch = "arm"; - }; - fdt-6 { - data = /incbin/("./foo-revb-bar-baz.dtb"); - type = "flat_dt"; - arch = "arm"; - }; - }; - - configurations { - default = "foo-reva.dtb; - foo-reva.dtb { - kernel = "kernel"; - fdt = "fdt-1"; - }; - foo-revb.dtb { - kernel = "kernel"; - fdt = "fdt-2"; - }; - foo-reva-bar.dtb { - kernel = "kernel"; - fdt = "fdt-3"; - }; - foo-revb-bar.dtb { - kernel = "kernel"; - fdt = "fdt-4"; - }; - foo-revb-baz.dtb { - kernel = "kernel"; - fdt = "fdt-5"; - }; - foo-revb-bar-baz.dtb { - kernel = "kernel"; - fdt = "fdt-6"; - }; - }; - }; - -Note the blob needs to be compiled for each case and the combinatorial explosion of -configurations. A typical device tree blob is in the low hunderds of kbytes so a -multitude of configuration grows the image quite a bit. - -Booting this image is done by using - - # bootm <addr>#<config> - -Where config is one of: - foo-reva.dtb, foo-revb.dtb, foo-reva-bar.dtb, foo-revb-bar.dtb, - foo-revb-baz.dtb, foo-revb-bar-baz.dtb - -This selects the DTB to use when booting. - -Configuration using overlays ----------------------------- - -Device tree overlays can be applied to a base DT and result in the same blob -being passed to the booting kernel. This saves on space and avoid the combinatorial -explosion problem. - - /dts-v1/; - / { - images { - kernel { - data = /incbin/("./zImage"); - type = "kernel"; - arch = "arm"; - os = "linux"; - load = <0x82000000>; - entry = <0x82000000>; - }; - fdt-1 { - data = /incbin/("./foo.dtb"); - type = "flat_dt"; - arch = "arm"; - load = <0x87f00000>; - }; - fdt-2 { - data = /incbin/("./reva.dtbo"); - type = "flat_dt"; - arch = "arm"; - load = <0x87fc0000>; - }; - fdt-3 { - data = /incbin/("./revb.dtbo"); - type = "flat_dt"; - arch = "arm"; - load = <0x87fc0000>; - }; - fdt-4 { - data = /incbin/("./bar.dtbo"); - type = "flat_dt"; - arch = "arm"; - load = <0x87fc0000>; - }; - fdt-5 { - data = /incbin/("./baz.dtbo"); - type = "flat_dt"; - arch = "arm"; - load = <0x87fc0000>; - }; - }; - - configurations { - default = "foo-reva.dtb; - foo-reva.dtb { - kernel = "kernel"; - fdt = "fdt-1", "fdt-2"; - }; - foo-revb.dtb { - kernel = "kernel"; - fdt = "fdt-1", "fdt-3"; - }; - foo-reva-bar.dtb { - kernel = "kernel"; - fdt = "fdt-1", "fdt-2", "fdt-4"; - }; - foo-revb-bar.dtb { - kernel = "kernel"; - fdt = "fdt-1", "fdt-3", "fdt-4"; - }; - foo-revb-baz.dtb { - kernel = "kernel"; - fdt = "fdt-1", "fdt-3", "fdt-5"; - }; - foo-revb-bar-baz.dtb { - kernel = "kernel"; - fdt = "fdt-1", "fdt-3", "fdt-4", "fdt-5"; - }; - bar { - fdt = "fdt-4"; - }; - baz { - fdt = "fdt-5"; - }; - }; - }; - -Booting this image is exactly the same as the non-overlay example. -u-boot will retrieve the base blob and apply the overlays in sequence as -they are declared in the configuration. - -Note the minimum amount of different DT blobs, as well as the requirement for -the DT blobs to have a load address; the overlay application requires the blobs -to be writeable. - -Configuration using overlays and feature selection --------------------------------------------------- - -Although the configuration in the previous section works is a bit inflexible -since it requires all possible configuration options to be laid out before -hand in the FIT image. For the add-on boards the extra config selection method -might make sense. - -Note the two bar & baz configuration nodes. To boot a reva board with -the bar add-on board enabled simply use: - - # bootm <addr>#foo-reva.dtb#bar - -While booting a revb with bar and baz is as follows: - - # bootm <addr>#foo-revb.dtb#bar#baz - -The limitation for a feature selection configuration node is that a single -fdt option is currently supported. - -Pantelis Antoniou -pantelis.antoniou@konsulko.com -12/6/2017 diff --git a/doc/usage/fit/index.rst b/doc/usage/fit/index.rst index 83bc4d01ca42..bd25bd30b284 100644 --- a/doc/usage/fit/index.rst +++ b/doc/usage/fit/index.rst @@ -16,3 +16,4 @@ doc/uImage.FIT signature verified-boot beaglebone_vboot + overlay-fdt-boot diff --git a/doc/usage/fit/overlay-fdt-boot.rst b/doc/usage/fit/overlay-fdt-boot.rst new file mode 100644 index 000000000000..8f8f5e307d26 --- /dev/null +++ b/doc/usage/fit/overlay-fdt-boot.rst @@ -0,0 +1,227 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +U-Boot FDT Overlay FIT usage +============================ + +Introduction +------------ + +In many cases it is desirable to have a single FIT image support a multitude +of similar boards and their expansion options. The same kernel on DT enabled +platforms can support this easily enough by providing a DT blob upon boot +that matches the desired configuration. + +This document focuses on specifically using overlays as part of a FIT image. +General information regarding overlays including its syntax and building it +can be found in doc/README.fdt-overlays + +Configuration without overlays +------------------------------ + +Take a hypothetical board named 'foo' where there are different supported +revisions, reva and revb. Assume that both board revisions can use add a bar +add-on board, while only the revb board can use a baz add-on board. + +Without using overlays the configuration would be as follows for every case:: + + /dts-v1/; + / { + images { + kernel { + data = /incbin/("./zImage"); + type = "kernel"; + arch = "arm"; + os = "linux"; + load = <0x82000000>; + entry = <0x82000000>; + }; + fdt-1 { + data = /incbin/("./foo-reva.dtb"); + type = "flat_dt"; + arch = "arm"; + }; + fdt-2 { + data = /incbin/("./foo-revb.dtb"); + type = "flat_dt"; + arch = "arm"; + }; + fdt-3 { + data = /incbin/("./foo-reva-bar.dtb"); + type = "flat_dt"; + arch = "arm"; + }; + fdt-4 { + data = /incbin/("./foo-revb-bar.dtb"); + type = "flat_dt"; + arch = "arm"; + }; + fdt-5 { + data = /incbin/("./foo-revb-baz.dtb"); + type = "flat_dt"; + arch = "arm"; + }; + fdt-6 { + data = /incbin/("./foo-revb-bar-baz.dtb"); + type = "flat_dt"; + arch = "arm"; + }; + }; + + configurations { + default = "foo-reva.dtb; + foo-reva.dtb { + kernel = "kernel"; + fdt = "fdt-1"; + }; + foo-revb.dtb { + kernel = "kernel"; + fdt = "fdt-2"; + }; + foo-reva-bar.dtb { + kernel = "kernel"; + fdt = "fdt-3"; + }; + foo-revb-bar.dtb { + kernel = "kernel"; + fdt = "fdt-4"; + }; + foo-revb-baz.dtb { + kernel = "kernel"; + fdt = "fdt-5"; + }; + foo-revb-bar-baz.dtb { + kernel = "kernel"; + fdt = "fdt-6"; + }; + }; + }; + +Note the blob needs to be compiled for each case and the combinatorial explosion of +configurations. A typical device tree blob is in the low hunderds of kbytes so a +multitude of configuration grows the image quite a bit. + +Booting this image is done by using:: + + # bootm <addr>#<config> + +Where config is one of:: + + foo-reva.dtb, foo-revb.dtb, foo-reva-bar.dtb, foo-revb-bar.dtb, + foo-revb-baz.dtb, foo-revb-bar-baz.dtb + +This selects the DTB to use when booting. + +Configuration using overlays +---------------------------- + +Device tree overlays can be applied to a base DT and result in the same blob +being passed to the booting kernel. This saves on space and avoid the combinatorial +explosion problem:: + + /dts-v1/; + / { + images { + kernel { + data = /incbin/("./zImage"); + type = "kernel"; + arch = "arm"; + os = "linux"; + load = <0x82000000>; + entry = <0x82000000>; + }; + fdt-1 { + data = /incbin/("./foo.dtb"); + type = "flat_dt"; + arch = "arm"; + load = <0x87f00000>; + }; + fdt-2 { + data = /incbin/("./reva.dtbo"); + type = "flat_dt"; + arch = "arm"; + load = <0x87fc0000>; + }; + fdt-3 { + data = /incbin/("./revb.dtbo"); + type = "flat_dt"; + arch = "arm"; + load = <0x87fc0000>; + }; + fdt-4 { + data = /incbin/("./bar.dtbo"); + type = "flat_dt"; + arch = "arm"; + load = <0x87fc0000>; + }; + fdt-5 { + data = /incbin/("./baz.dtbo"); + type = "flat_dt"; + arch = "arm"; + load = <0x87fc0000>; + }; + }; + + configurations { + default = "foo-reva.dtb; + foo-reva.dtb { + kernel = "kernel"; + fdt = "fdt-1", "fdt-2"; + }; + foo-revb.dtb { + kernel = "kernel"; + fdt = "fdt-1", "fdt-3"; + }; + foo-reva-bar.dtb { + kernel = "kernel"; + fdt = "fdt-1", "fdt-2", "fdt-4"; + }; + foo-revb-bar.dtb { + kernel = "kernel"; + fdt = "fdt-1", "fdt-3", "fdt-4"; + }; + foo-revb-baz.dtb { + kernel = "kernel"; + fdt = "fdt-1", "fdt-3", "fdt-5"; + }; + foo-revb-bar-baz.dtb { + kernel = "kernel"; + fdt = "fdt-1", "fdt-3", "fdt-4", "fdt-5"; + }; + bar { + fdt = "fdt-4"; + }; + baz { + fdt = "fdt-5"; + }; + }; + }; + +Booting this image is exactly the same as the non-overlay example. +u-boot will retrieve the base blob and apply the overlays in sequence as +they are declared in the configuration. + +Note the minimum amount of different DT blobs, as well as the requirement for +the DT blobs to have a load address; the overlay application requires the blobs +to be writeable. + +Configuration using overlays and feature selection +-------------------------------------------------- + +Although the configuration in the previous section works is a bit inflexible +since it requires all possible configuration options to be laid out before +hand in the FIT image. For the add-on boards the extra config selection method +might make sense. + +Note the two bar & baz configuration nodes. To boot a reva board with +the bar add-on board enabled simply use:: + + # bootm <addr>#foo-reva.dtb#bar + +While booting a revb with bar and baz is as follows:: + + # bootm <addr>#foo-revb.dtb#bar#baz + +The limitation for a feature selection configuration node is that a single +fdt option is currently supported. + +.. sectionauthor:: Pantelis Antoniou pantelis.antoniou@konsulko.com, 12/6/2017
.../fit/command_syntax_extensions.rst} | 166 ++++++++++-------- doc/usage/fit/index.rst | 1 + 2 files changed, 97 insertions(+), 70 deletions(-) rename doc/{uImage.FIT/command_syntax_extensions.txt => usage/fit/command_syntax_extensions.rst} (57%)
diff --git a/doc/uImage.FIT/command_syntax_extensions.txt b/doc/usage/fit/command_syntax_extensions.rst similarity index 57% rename from doc/uImage.FIT/command_syntax_extensions.txt rename to doc/usage/fit/command_syntax_extensions.rst index 6a99089ab557..65b7891c8a69 100644 --- a/doc/uImage.FIT/command_syntax_extensions.txt +++ b/doc/usage/fit/command_syntax_extensions.rst @@ -1,3 +1,5 @@ +.. SPDX-License-Identifier: GPL-2.0+ + Command syntax extensions for the new uImage format ===================================================
@@ -20,100 +22,117 @@ of supported bootm usages. Note: U-Boot supports two methods of booting a PowerPC Linux kernel: old way, i.e., without passing the Flattened Device Tree (FDT), and new way, where the kernel is passed a pointer to the FDT. The boot method is indicated for each -scenario. +scenario::
+ 1. bootm boot image at the current address, equivalent to 2,3,8
-1. bootm boot image at the current address, equivalent to 2,3,8 +Old uImage::
-Old uImage: -2. bootm <addr1> /* single image at <addr1> */ -3. bootm <addr1> /* multi-image at <addr1> */ -4. bootm <addr1> - /* multi-image at <addr1> */ -5. bootm <addr1> <addr2> /* single image at <addr1> */ -6. bootm <addr1> <addr2> <addr3> /* single image at <addr1> */ -7. bootm <addr1> - <addr3> /* single image at <addr1> */ + 2. bootm <addr1> /* single image at <addr1> */ + 3. bootm <addr1> /* multi-image at <addr1> */ + 4. bootm <addr1> - /* multi-image at <addr1> */ + 5. bootm <addr1> <addr2> /* single image at <addr1> */ + 6. bootm <addr1> <addr2> <addr3> /* single image at <addr1> */ + 7. bootm <addr1> - <addr3> /* single image at <addr1> */
-New uImage: -8. bootm <addr1> -9. bootm [<addr1>]:<subimg1> -10. bootm [<addr1>]#<conf>[#<extra-conf[#...]] -11. bootm [<addr1>]:<subimg1> [<addr2>]:<subimg2> -12. bootm [<addr1>]:<subimg1> [<addr2>]:<subimg2> [<addr3>]:<subimg3> -13. bootm [<addr1>]:<subimg1> [<addr2>]:<subimg2> <addr3> -14. bootm [<addr1>]:<subimg1> - [<addr3>]:<subimg3> -15. bootm [<addr1>]:<subimg1> - <addr3> +New uImage::
+ 8. bootm <addr1> + 9. bootm [<addr1>]:<subimg1> + 10. bootm [<addr1>]#<conf>[#<extra-conf[#...]] + 11. bootm [<addr1>]:<subimg1> [<addr2>]:<subimg2> + 12. bootm [<addr1>]:<subimg1> [<addr2>]:<subimg2> [<addr3>]:<subimg3> + 13. bootm [<addr1>]:<subimg1> [<addr2>]:<subimg2> <addr3> + 14. bootm [<addr1>]:<subimg1> - [<addr3>]:<subimg3> + 15. bootm [<addr1>]:<subimg1> - <addr3>
Ad. 1. This is equivalent to cases 2,3,8, depending on the type of image at the current image address. + - boot method: see cases 2,3,8
Ad. 2. Boot kernel image located at <addr1>. + - boot method: non-FDT
Ad. 3. First and second components of the image at <addr1> are assumed to be a kernel and a ramdisk, respectively. The kernel is booted with initrd loaded with the ramdisk from the image. + - boot method: depends on the number of components at <addr1>, and on whether - U-Boot is compiled with OF support: + U-Boot is compiled with OF support::
- | 2 components | 3 components | - | (kernel, initrd) | (kernel, initrd, fdt) | ---------------------------------------------------------------------- -#ifdef CONFIG_OF_* | non-FDT | FDT | -#ifndef CONFIG_OF_* | non-FDT | non-FDT | + ====================================================================== + | 2 components | 3 components| + | (kernel, initrd) | (kernel, initrd, fdt) | + ====================================================================== + #ifdef CONFIG_OF_* | non-FDT | FDT | + #ifndef CONFIG_OF_* | non-FDT | non-FDT | + ======================================================================
Ad. 4. Similar to case 3, but the kernel is booted without initrd. Second component of the multi-image is irrelevant (it can be a dummy, 1-byte file). + - boot method: see case 3
Ad. 5. Boot kernel image located at <addr1> with initrd loaded with ramdisk from the image at <addr2>. + - boot method: non-FDT
Ad. 6. <addr1> is the address of a kernel image, <addr2> is the address of a ramdisk image, and <addr3> is the address of a FDT binary blob. Kernel is booted with initrd loaded with ramdisk from the image at <addr2>. + - boot method: FDT
Ad. 7. <addr1> is the address of a kernel image and <addr3> is the address of a FDT binary blob. Kernel is booted without initrd. + - boot method: FDT
Ad. 8. Image at <addr1> is assumed to contain a default configuration, which is booted. + - boot method: FDT or non-FDT, depending on whether the default configuration defines FDT
Ad. 9. Similar to case 2: boot kernel stored in <subimg1> from the image at address <addr1>. + - boot method: non-FDT
Ad. 10. Boot configuration <conf> from the image at <addr1>. + - boot method: FDT or non-FDT, depending on whether the configuration given defines FDT
Ad. 11. Equivalent to case 5: boot kernel stored in <subimg1> from the image at <addr1> with initrd loaded with ramdisk <subimg2> from the image at <addr2>. + - boot method: non-FDT
Ad. 12. Equivalent to case 6: boot kernel stored in <subimg1> from the image at <addr1> with initrd loaded with ramdisk <subimg2> from the image at <addr2>, and pass FDT blob <subimg3> from the image at <addr3>. + - boot method: FDT
Ad. 13. Similar to case 12, the difference being that <addr3> is the address of FDT binary blob that is to be passed to the kernel. + - boot method: FDT
Ad. 14. Equivalent to case 7: boot kernel stored in <subimg1> from the image at <addr1>, without initrd, and pass FDT blob <subimg3> from the image at <addr3>. + - boot method: FDT
Ad. 15. Similar to case 14, the difference being that <addr3> is the address of the FDT binary blob that is to be passed to the kernel. + - boot method: FDT
@@ -123,14 +142,14 @@ New uImage argument syntax New uImage support introduces two new forms for bootm arguments, with the following syntax:
-- new uImage sub-image specification -<addr>:<sub-image unit_name> +new uImage sub-image specification + <addr>:<sub-image unit_name>
-- new uImage configuration specification -<addr>#<configuration unit_name> +new uImage configuration specification + <addr>#<configuration unit_name>
-- new uImage configuration specification with extra configuration components -<addr>#<configuration unit_name>[#<extra configuration unit_name>[#..]] +new uImage configuration specification with extra configuration components + <addr>#<configuration unit_name>[#<extra configuration unit_name>[#..]]
The extra configuration currently is supported only for additional device tree overlays to apply on the base device tree supplied by the first configuration @@ -138,31 +157,38 @@ unit.
Examples:
-- boot kernel "kernel-1" stored in a new uImage located at 200000: -bootm 200000:kernel-1 +boot kernel "kernel-1" stored in a new uImage located at 200000:: + + bootm 200000:kernel-1 + +boot configuration "cfg-1" from a new uImage located at 200000:: + + bootm 200000#cfg-1 + +boot configuration "cfg-1" with extra "cfg-2" from a new uImage located +at 200000:: + + bootm 200000#cfg-1#cfg-2 + +boot "kernel-1" from a new uImage at 200000 with initrd "ramdisk-2" found in +some other new uImage stored at address 800000:: + + bootm 200000:kernel-1 800000:ramdisk-2
-- boot configuration "cfg-1" from a new uImage located at 200000: -bootm 200000#cfg-1 +boot "kernel-2" from a new uImage at 200000, with initrd "ramdisk-1" and FDT +"fdt-1", both stored in some other new uImage located at 800000::
-- boot configuration "cfg-1" with extra "cfg-2" from a new uImage located - at 200000: -bootm 200000#cfg-1#cfg-2 + bootm 200000:kernel-1 800000:ramdisk-1 800000:fdt-1
-- boot "kernel-1" from a new uImage at 200000 with initrd "ramdisk-2" found in - some other new uImage stored at address 800000: -bootm 200000:kernel-1 800000:ramdisk-2 +boot kernel "kernel-2" with initrd "ramdisk-2", both stored in a new uImage +at address 200000, with a raw FDT blob stored at address 600000::
-- boot "kernel-2" from a new uImage at 200000, with initrd "ramdisk-1" and FDT - "fdt-1", both stored in some other new uImage located at 800000: -bootm 200000:kernel-1 800000:ramdisk-1 800000:fdt-1 + bootm 200000:kernel-2 200000:ramdisk-2 600000
-- boot kernel "kernel-2" with initrd "ramdisk-2", both stored in a new uImage - at address 200000, with a raw FDT blob stored at address 600000: -bootm 200000:kernel-2 200000:ramdisk-2 600000 +boot kernel "kernel-2" from new uImage at 200000 with FDT "fdt-1" from the +same new uImage::
-- boot kernel "kernel-2" from new uImage at 200000 with FDT "fdt-1" from the - same new uImage: -bootm 200000:kernel-2 - 200000:fdt-1 + bootm 200000:kernel-2 - 200000:fdt-1
Note on current image address @@ -171,31 +197,31 @@ Note on current image address When bootm is called without arguments, the image at current image address is booted. The current image address is the address set most recently by a load command, etc, and is by default equal to CONFIG_SYS_LOAD_ADDR. For example, consider -the following commands: +the following commands::
-tftp 200000 /tftpboot/kernel -bootm -Last command is equivalent to: -bootm 200000 + tftp 200000 /tftpboot/kernel + bootm + Last command is equivalent to: + bootm 200000
In case of the new uImage argument syntax, the address portion of any argument can be omitted. If <addr3> is omitted, then it is assumed that image at <addr2> should be used. Similarly, when <addr2> is omitted, it is assumed that image at <addr1> should be used. If <addr1> is omitted, it is assumed that the current image address is to be used. For example, consider the following -commands: - -tftp 200000 /tftpboot/uImage -bootm :kernel-1 -Last command is equivalent to: -bootm 200000:kernel-1 - -tftp 200000 /tftpboot/uImage -bootm 400000:kernel-1 :ramdisk-1 -Last command is equivalent to: -bootm 400000:kernel-1 400000:ramdisk-1 - -tftp 200000 /tftpboot/uImage -bootm :kernel-1 400000:ramdisk-1 :fdt-1 -Last command is equivalent to: -bootm 200000:kernel-1 400000:ramdisk-1 400000:fdt-1 +commands:: + + tftp 200000 /tftpboot/uImage + bootm :kernel-1 + Last command is equivalent to: + bootm 200000:kernel-1 + + tftp 200000 /tftpboot/uImage + bootm 400000:kernel-1 :ramdisk-1 + Last command is equivalent to: + bootm 400000:kernel-1 400000:ramdisk-1 + + tftp 200000 /tftpboot/uImage + bootm :kernel-1 400000:ramdisk-1 :fdt-1 + Last command is equivalent to: + bootm 200000:kernel-1 400000:ramdisk-1 400000:fdt-1 diff --git a/doc/usage/fit/index.rst b/doc/usage/fit/index.rst index bd25bd30b284..92998e724c28 100644 --- a/doc/usage/fit/index.rst +++ b/doc/usage/fit/index.rst @@ -17,3 +17,4 @@ doc/uImage.FIT verified-boot beaglebone_vboot overlay-fdt-boot + command_syntax_extensions
This is the wrong place for documenting a command.
Please, create doc/usage/cmd/bootm.rst instead adhering to the style of the other man-pages.
Best regards
Heinrich
- bootm boot image at the current address, equivalent to 2,3,8
- bootm <addr1> /* single image at <addr1> */
- bootm <addr1> /* multi-image at <addr1> */
- bootm <addr1> - /* multi-image at <addr1> */
- bootm <addr1> <addr2> /* single image at <addr1> */
- bootm <addr1> <addr2> <addr3> /* single image at <addr1> */
- bootm <addr1> - <addr3> /* single image at <addr1> */
- bootm <addr1>
- bootm [<addr1>]:<subimg1>
- bootm [<addr1>]#<conf>[#<extra-conf[#...]]
- bootm [<addr1>]:<subimg1> [<addr2>]:<subimg2>
- bootm [<addr1>]:<subimg1> [<addr2>]:<subimg2> [<addr3>]:<subimg3>
- bootm [<addr1>]:<subimg1> [<addr2>]:<subimg2> <addr3>
- bootm [<addr1>]:<subimg1> - [<addr3>]:<subimg3>
- bootm [<addr1>]:<subimg1> - <addr3>
- U-Boot is compiled with OF support::
- boot method: FDT
- boot method: FDT
- boot method: FDT
- boot method: FDT
- boot method: FDT
- boot method: FDT
- <addr>:<sub-image unit_name>
- <addr>#<configuration unit_name>
Examples:
- bootm 200000:kernel-1
- bootm 200000#cfg-1
- bootm 200000#cfg-1#cfg-2
- bootm 200000:kernel-1 800000:ramdisk-2
- at 200000:
- bootm 200000:kernel-1 800000:ramdisk-1 800000:fdt-1
- bootm 200000:kernel-2 200000:ramdisk-2 600000
- same new uImage:
bootm
bootm 200000
-commands:
- tftp 200000 /tftpboot/uImage
- bootm :kernel-1
- Last command is equivalent to:
- bootm 400000:kernel-1 :ramdisk-1
- bootm 400000:kernel-1 400000:ramdisk-1
- bootm :kernel-1 400000:ramdisk-1 :fdt-1
- bootm 200000:kernel-1 400000:ramdisk-1 400000:fdt-1
- command_syntax_extensions
Hi Heinrich,
Yes, I know, but on one wants to document that command. I'll take a look in v2.
Create a new usage/fit directory which will house information about FIT.
doc/usage/{fit.rst => fit/index.rst} | 4 ++++ doc/usage/index.rst | 2 +- 2 files changed, 5 insertions(+), 1 deletion(-) rename doc/usage/{fit.rst => fit/index.rst} (88%)
diff --git a/doc/usage/fit.rst b/doc/usage/fit/index.rst similarity index 88% rename from doc/usage/fit.rst rename to doc/usage/fit/index.rst index 70374340577e..68641a6704ff 100644 --- a/doc/usage/fit.rst +++ b/doc/usage/fit/index.rst @@ -6,3 +6,7 @@ Flat Image Tree (FIT) U-Boot uses Flat Image Tree (FIT) as a standard file format for packaging images that it it reads and boots. Documentation about FIT is available at doc/uImage.FIT
+.. toctree::
- :maxdepth: 1
Please, avoid white space at end of file. But as this is corrected in a later patch:
Reviewed-by: Heinrich Schuchardt <xypron.glpk
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 84ef8a9a427d..e1fe284b38c1 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -8,7 +8,7 @@ Use U-Boot dfu environment fdt_overlays
- fit
- fit/index netconsole partitions cmdline
