[PATCH v2] arm64: zynqmp: Update the usb5744 hub node as per binding
Updating the usb5744 hub node as per the latest upstream DT binding https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/ tree/Documentation/devicetree/bindings/usb/microchip,usb5744.yaml?h=v6.8.8
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Acked-by: Michal Simek michal.simek@amd.com --- Changes in v2: - Updated the hub node for KD board. - Removed the #if code. --- arch/arm/dts/zynqmp-sck-kd-g-revA.dtso | 37 +++++++++----- arch/arm/dts/zynqmp-sck-kr-g-revA.dtso | 67 ++++++++++++++++++------- arch/arm/dts/zynqmp-sck-kr-g-revB.dtso | 68 ++++++++++++++++++-------- arch/arm/dts/zynqmp-sck-kv-g-revA.dtso | 24 ++++++--- arch/arm/dts/zynqmp-sck-kv-g-revB.dtso | 33 +++++++++---- 5 files changed, 162 insertions(+), 67 deletions(-)
diff --git a/arch/arm/dts/zynqmp-sck-kd-g-revA.dtso b/arch/arm/dts/zynqmp-sck-kd-g-revA.dtso index 4de29d5d3f..d56e863ce1 100644 --- a/arch/arm/dts/zynqmp-sck-kd-g-revA.dtso +++ b/arch/arm/dts/zynqmp-sck-kd-g-revA.dtso @@ -80,7 +80,10 @@ "", ""; };
- /* usb5744@2d */ + hub: usb-hub@2d { /* u36 */ + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; };
/* USB 3.0 */ @@ -99,18 +102,6 @@ phys = <&psgtr 2 PHY_TYPE_USB3 0 2>; reset-gpios = <&slg7xl45106 0 GPIO_ACTIVE_LOW>; assigned-clock-rates = <250000000>, <20000000>; -#if 0 - usbhub0: usb-hub { /* u36 */ - i2c-bus = <&i2c1>; - compatible = "microchip,usb5744"; - reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; - }; - - usb2244: usb-sd { /* u41 */ - compatible = "microchip,usb2244"; - reset-gpios = <&slg7xl45106 2 GPIO_ACTIVE_LOW>; - }; -#endif };
&dwc3_0 { @@ -118,6 +109,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub_3_0>; + i2c-bus = <&hub>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub_2_0>; + i2c-bus = <&hub>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; };
&gem1 { /* mdio mio50/51 */ diff --git a/arch/arm/dts/zynqmp-sck-kr-g-revA.dtso b/arch/arm/dts/zynqmp-sck-kr-g-revA.dtso index 6349a0e108..9d0c0c2885 100644 --- a/arch/arm/dts/zynqmp-sck-kr-g-revA.dtso +++ b/arch/arm/dts/zynqmp-sck-kr-g-revA.dtso @@ -105,11 +105,19 @@ #address-cells = <1>; #size-cells = <0>; reg = <0>; + hub_1: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; }; usbhub_i2c1: i2c@1 { #address-cells = <1>; #size-cells = <0>; reg = <1>; + hub_2: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; }; /* Bus 2/3 are not connected */ }; @@ -145,18 +153,6 @@ phys = <&psgtr 2 PHY_TYPE_USB3 0 2>; reset-gpios = <&slg7xl45106 0 GPIO_ACTIVE_LOW>; assigned-clock-rates = <250000000>, <20000000>; -#if 0 - usbhub0: usb-hub { /* u43 */ - i2c-bus = <&usbhub_i2c0>; - compatible = "microchip,usb5744"; - reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; - }; - - usb2244: usb-sd { /* u38 */ - compatible = "microchip,usb2244"; - reset-gpios = <&slg7xl45106 2 GPIO_ACTIVE_LOW>; - }; -#endif };
&dwc3_0 { @@ -164,6 +160,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub_3_0>; + i2c-bus = <&hub_1>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub_2_0>; + i2c-bus = <&hub_1>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; };
&usb1 { /* mio64 - mio75 */ @@ -174,13 +190,6 @@ phys = <&psgtr 3 PHY_TYPE_USB3 1 2>; reset-gpios = <&slg7xl45106 1 GPIO_ACTIVE_LOW>; assigned-clock-rates = <250000000>, <20000000>; -#if 0 - usbhub1: usb-hub { /* u84 */ - i2c-bus = <&usbhub_i2c1>; - compatible = "microchip,usb5744"; - reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; - }; -#endif };
&dwc3_1 { @@ -188,6 +197,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub1_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub1_3_0>; + i2c-bus = <&hub_2>; + reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub1_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub1_2_0>; + i2c-bus = <&hub_2>; + reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; + }; };
&gem0 { /* mdio mio50/51 */ diff --git a/arch/arm/dts/zynqmp-sck-kr-g-revB.dtso b/arch/arm/dts/zynqmp-sck-kr-g-revB.dtso index b0d737d3ca..0d915d496c 100644 --- a/arch/arm/dts/zynqmp-sck-kr-g-revB.dtso +++ b/arch/arm/dts/zynqmp-sck-kr-g-revB.dtso @@ -117,11 +117,19 @@ #address-cells = <1>; #size-cells = <0>; reg = <0>; + hub_1: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; }; usbhub_i2c1: i2c@1 { #address-cells = <1>; #size-cells = <0>; reg = <1>; + hub_2: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; }; /* Bus 2/3 are not connected */ }; @@ -165,18 +173,6 @@ phys = <&psgtr 2 PHY_TYPE_USB3 0 2>; reset-gpios = <&slg7xl45106 0 GPIO_ACTIVE_LOW>; assigned-clock-rates = <250000000>, <20000000>; -#if 0 - usbhub0: usb-hub { /* u43 */ - i2c-bus = <&usbhub_i2c0>; - compatible = "microchip,usb5744"; - reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; - }; - - usb2244: usb-sd { /* u38 */ - compatible = "microchip,usb2244"; - reset-gpios = <&slg7xl45106 2 GPIO_ACTIVE_LOW>; - }; -#endif };
&dwc3_0 { @@ -184,6 +180,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub_3_0>; + i2c-bus = <&hub_1>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub_2_0>; + i2c-bus = <&hub_1>; + reset-gpios = <&slg7xl45106 3 GPIO_ACTIVE_LOW>; + }; };
&usb1 { /* mio64 - mio75 */ @@ -194,14 +210,6 @@ phys = <&psgtr 3 PHY_TYPE_USB3 1 2>; reset-gpios = <&slg7xl45106 1 GPIO_ACTIVE_LOW>; assigned-clock-rates = <250000000>, <20000000>; - -#if 0 - usbhub1: usb-hub { /* u84 */ - i2c-bus = <&usbhub_i2c1>; - compatible = "microchip,usb5744"; - reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; - }; -#endif };
&dwc3_1 { @@ -209,6 +217,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub1_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub1_3_0>; + i2c-bus = <&hub_2>; + reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub1_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub1_2_0>; + i2c-bus = <&hub_2>; + reset-gpios = <&slg7xl45106 4 GPIO_ACTIVE_LOW>; + }; };
&gem0 { /* mdio mio50/51 */ diff --git a/arch/arm/dts/zynqmp-sck-kv-g-revA.dtso b/arch/arm/dts/zynqmp-sck-kv-g-revA.dtso index 561b546e37..a98a888d13 100644 --- a/arch/arm/dts/zynqmp-sck-kv-g-revA.dtso +++ b/arch/arm/dts/zynqmp-sck-kv-g-revA.dtso @@ -129,12 +129,6 @@ pinctrl-0 = <&pinctrl_usb0_default>; phy-names = "usb3-phy"; phys = <&psgtr 2 PHY_TYPE_USB3 0 1>; -#if 0 - usbhub: usb5744 { /* u43 */ - compatible = "microchip,usb5744"; - reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; - }; -#endif };
&dwc3_0 { @@ -142,6 +136,24 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub_3_0>; + reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub_2_0>; + reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; + }; };
&sdhci1 { /* on CC with tuned parameters */ diff --git a/arch/arm/dts/zynqmp-sck-kv-g-revB.dtso b/arch/arm/dts/zynqmp-sck-kv-g-revB.dtso index 64683e0ccb..7490efea98 100644 --- a/arch/arm/dts/zynqmp-sck-kv-g-revB.dtso +++ b/arch/arm/dts/zynqmp-sck-kv-g-revB.dtso @@ -92,7 +92,10 @@ label = "ina260-u14"; reg = <0x40>; }; - /* u43 - 0x2d - USB hub */ + hub: usb-hub@2d { + compatible = "microchip,usb5744"; + reg = <0x2d>; + }; /* u27 - 0xe0 - STDP4320 DP/HDMI splitter */ };
@@ -131,14 +134,6 @@ phy-names = "usb3-phy"; phys = <&psgtr 2 PHY_TYPE_USB3 0 1>; assigned-clock-rates = <250000000>, <20000000>; -#if 0 - usb5744: usb-hub { /* u43 */ - status = "okay"; - compatible = "microchip,usb5744"; - i2c-bus = <&i2c1>; - reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; - }; -#endif };
&dwc3_0 { @@ -146,6 +141,26 @@ dr_mode = "host"; snps,usb3_lpm_capable; maximum-speed = "super-speed"; + #address-cells = <1>; + #size-cells = <0>; + + /* 2.0 hub on port 1 */ + hub_2_0: hub@1 { + compatible = "usb424,2744"; + reg = <1>; + peer-hub = <&hub_3_0>; + i2c-bus = <&hub>; + reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; + }; + + /* 3.0 hub on port 2 */ + hub_3_0: hub@2 { + compatible = "usb424,5744"; + reg = <2>; + peer-hub = <&hub_2_0>; + i2c-bus = <&hub>; + reset-gpios = <&gpio 44 GPIO_ACTIVE_LOW>; + }; };
Changes in v2:
- /* usb5744@2d */
reg = <0x2d>;
/* USB 3.0 */
i2c-bus = <&i2c1>;
-#endif };
#size-cells = <0>;
hub_2_0: hub@1 {
reg = <1>;
i2c-bus = <&hub>;
hub_3_0: hub@2 {
reg = <2>;
i2c-bus = <&hub>;
hub_1: usb-hub@2d {
reg = <0x2d>;
}; usbhub_i2c1: i2c@1 { #address-cells = <1>; #size-cells = <0>; reg = <1>;};
hub_2: usb-hub@2d {
reg = <0x2d>;
}; /* Bus 2/3 are not connected */ };};
-#endif };
#size-cells = <0>;
hub_2_0: hub@1 {
reg = <1>;
i2c-bus = <&hub_1>;
hub_3_0: hub@2 {
reg = <2>;
i2c-bus = <&hub_1>;
-#endif };
#size-cells = <0>;
hub1_2_0: hub@1 {
reg = <1>;
i2c-bus = <&hub_2>;
hub1_3_0: hub@2 {
reg = <2>;
i2c-bus = <&hub_2>;
hub_1: usb-hub@2d {
reg = <0x2d>;
hub_2: usb-hub@2d {
reg = <0x2d>;
-#endif };
#size-cells = <0>;
hub_2_0: hub@1 {
reg = <1>;
i2c-bus = <&hub_1>;
hub_3_0: hub@2 {
reg = <2>;
i2c-bus = <&hub_1>;
-#if 0
-#endif };
#size-cells = <0>;
hub1_2_0: hub@1 {
reg = <1>;
i2c-bus = <&hub_2>;
hub1_3_0: hub@2 {
reg = <2>;
i2c-bus = <&hub_2>;
-#endif };
#size-cells = <0>;
hub_2_0: hub@1 {
reg = <1>;
hub_3_0: hub@2 {
reg = <2>;
- hub: usb-hub@2d {
reg = <0x2d>;
- }; /* u27 - 0xe0 - STDP4320 DP/HDMI splitter */ };
status = "okay";
i2c-bus = <&i2c1>;
-#endif };
#size-cells = <0>;
hub_2_0: hub@1 {
reg = <1>;
i2c-bus = <&hub>;
hub_3_0: hub@2 {
reg = <2>;
i2c-bus = <&hub>;
This has been applied already.
M
Michal Simek
